leghorn
Does a 737 Max 10 really need MCAS?
Sat Jan 04, 2020 6:59 pm
Irrespective of whether it will be fitted or not does a 737 Max-10 need MCAS or does the length of the fuselage compensate enough to make it handle similar to previous 737 versions.
sevenair
Re: Does a 737 Max 10 really need MCAS?
Sat Jan 04, 2020 7:18 pm
If it didn't then I'd guess Boeing would remove it and get it flying. At least then some of the 737 MAXs could fly. As it stands MCAS is required and therefore grounding is appropriate.
mcdu
Sat Jan 04, 2020 7:32 pm
Have been told by more than one person the max10 does not have MCAS. But would Boeing really say if it did or didn’t? Maybe since Mark Forkner is no longer at Boeing telling lies to the Feds, then maybe there is some truth to the rumor.
ikolkyo
Sat Jan 04, 2020 7:39 pm
I don’t think anybody actually knows the answer. I’d honestly just assume it does until told otherwise.
weekendppl
Sat Jan 04, 2020 7:45 pm
They haven't flown it yet. All they have is modeling and simulation results to tell them one way or the other. The nacelles, presumably, have the same aero characteristics as they do on the Max8 and Max9, so, presumably, generate the same lift component at the same offset from CG at the same AoAs and airspeeds.
Stitch
Sat Jan 04, 2020 7:59 pm
BoeingGuy said all of the family models have MCAS and his source is the Boeing CSID (Crew Systems Interface Document) for the MAX family.
Avgeek21 stated that the MAX-10 would not have it and never intended to have it, but did not clarify his source beyond it being "inside Boeing".
Whether it has it or not is irrelevant to its airworthiness since MCAS is just one of the things that will need to be addressed before the MAX's Type Certificate is restored and any MAX family member can return to revenue service.
leghorn
Sat Jan 04, 2020 8:00 pm
max-10 is over 4 metres longer. The horizontal stabilizers and rudder should be over 2 metres further back.
Antarius
Sat Jan 04, 2020 8:38 pm
MAX10 is also taller, which may negate the need for MCAS.
Honestly, it is unknown. And Boeing has a giant cockup to fix and hundreds of grounded existing planes to fix before switching focus.
2020: SFO DFW IAH HOU CLT MEX BIS MIA GUA ORD DTW LGA BOS LHR DUB BFS BHD STN OAK PHL ISP JFK SJC DEN SJU LAS TXL GDL
Palop
Sat Jan 04, 2020 8:57 pm
This needs to be clarified. How is the Max10 taller?
And if it is taller, how would it change the need for MCAS?
Antarius
Sat Jan 04, 2020 9:08 pm
Here is an article explaining it better than I can
https://www.flightglobal.com/airframers ... 86.article
It has a taller gear due to the longer fuselage needing more clearance to avoid tail strikes. As a result, the engines potentially would not need to be pushed forward, thereby negating the need for MCAS - this is just a theory based on the gear and length of the aircraft though, it may still need MCAS for something else.
ikolkyo
Sat Jan 04, 2020 9:11 pm
It’s only taller on rotation and landing, on the ground it sits the same as the rest of the family.
VSMUT
Sat Jan 04, 2020 9:17 pm
1. It sits at the same height on the ground. It is the rotation angle that has been changed slighty.
2. The issues that required MCAS pop up in flight, not on the ground.
Palop
Sat Jan 04, 2020 9:22 pm
According to that explanation, the landing gear extends 241 mm when the plane is about to do the rotation when taking off. This is to avoid tail strikes and/or excessive runway requirements.
However at standstill, taxiing and run up before takeoff the landing gear has the same length as before. Thus, you cannot push the engines down and back.
Remember one of the limits on the landing gear length is that there is a max height from the wings down as there are no slides on the overwing exits. This is why thr exotic landing gear that only telescopes and extends just prior to the takeoff rotation.
So the max10 landing gear does not help with the MCAS predicament
sevenair
Sat Jan 04, 2020 9:26 pm
ABSOLUTELY. For once I'd expect Boeing to be totally open and honest about MCAS.
I keep hearing it does but then I hear it doesn't have MCAS. Given that MCAS is the cause of two catastrophes and that the -10 is still grounded certainly gives credit to the theory of the version having MCAS.
leghorn
Sat Jan 04, 2020 9:30 pm
A simpler explanation might be that the plane doesn't have the problem but their limited resources need to be first assigned to the airframe that has already been released and was in service and for which there are thousands of hard orders.
It could be a case that the Max10 won't have these problems and Boeing would only give that plane to customers instead of a Max8 in desparation should no other solution be approved.
Antarius
Sat Jan 04, 2020 9:48 pm
Yes. I misunderstood the at-rest position. Thanks (and to the posters above as well).
Stitch
Sat Jan 04, 2020 10:40 pm
The 737-10 is still in flight test and certification so it's not like any frame would be in revenue service with a customer even if the family was not grounded, so the presence or lack of presence of MCAS would not matter at this point.
We also know that the investigation has raised other issues with the MAX and the regulatory authorities are likely going to want those addressed before they restore the Type Certificate. So once the 737-10 is ready to be delivered to customer airlines, if the TC has not yet been restored, then it's not going to fly, MCAS or no MCAS.
LAX772LR
Sat Jan 04, 2020 10:56 pm
Not really.
Unlike the other two versions, the -10 was never certified to fly. So even if it doesn't/didn't/never had MCAS, and was never intended to, it'd still have to go through the certification process.
And right now, Boeing logically seems far more concerned with getting the two previously-certified models, for whom there are far more orders (not to mention compensatory requirements) back; than with getting something that's never been certified, in the air.
zkojq
Sun Jan 05, 2020 12:17 am
If you're changing the engine placement, you'll need to design a new pylon which will be very expensive.
First to fly the 787-9
Francoflier
Sun Jan 05, 2020 1:26 am
I can't see why a longer fuselage would negate the need for MCAS.
The nacelle lift is still there at high AOA, therefore the pitch up moment and lightening of control forces would still be present then.
The higher effectiveness of the controls surfaces in the back might make this lightening much less pronounced however, meaning that it might only need a less agressive action from MCAS.
Unless there is a threshold under which the lightening becomes weak enough that it passes the requirement, but it's not my understanding of the regulation.
Aesma
Sun Jan 05, 2020 1:49 am
Yes, keep in mind MCAS is as much there to do something for safety, as it is there to make the MAX feel like an NG. So if the 10 is acting differently, it's not really a good thing for Boeing, they want it to act just like the other models.
FluidFlow
Sun Jan 05, 2020 3:55 am
Why not certify the -10 as an independent type from the -8/9 and get over all the trouble at the cost of a different pilot pool.
Stitch
Sun Jan 05, 2020 4:30 am
It cannot be certified except under an amendment to the existing 737 Type Certificate as it leverages systems and such that would not be allowed on a new type under current regulations.
weekendppl
Sun Jan 05, 2020 4:54 am
Because then they have to start over as if clean sheet and lots of things that get grandfathered from the original 737 type certificate no longer get grandfathered. The pilot pool could even be the same if they flew the same. But any FAR changes from 1965 or so on that didn't apply to derivatives of existing types (i.e., the 737 Classic, NG, MAX...) would apply to design and certification of such an "independent type". This problem is a major part of why the 737 MAX is the 737 MAX, not a 797... (And an A320 NEO is an A320 NEO for that matter.)
TheWorm123
Sun Jan 05, 2020 7:12 am
Out of curiosity, what are examples of systems on the 737 that wouldn’t pass modern scrutiny on new types in 2020?
B752 B753 A332 A321 B738
mdavies06
Sun Jan 05, 2020 7:42 am
viewtopic.php?t=1422939
viewtopic.php?t=1424433
Here are some threads on the same topic last year
kalvado
Sun Jan 05, 2020 9:51 am
I think a better question to ask is of max10 can be considered as mcas-free (if it is) separate subtype, derived from ng, not as part of the -8 -9 family.
Other issues such as rudder cables would still be the same, and as we don't know what keeps max grounded - this is not a sure fire approach.
mcdu
Sun Jan 05, 2020 12:47 pm
The -10 was just rolled out a few weeks ago. Not sure it’s first flight ready with or without MCAS
JetBuddy
Sun Jan 05, 2020 3:07 pm
The whole aircraft is based on 50s/60s architecture that originated with the 707 and 727. It would be like taking a 60s Ford F-150, installing a new engine and updating the instruments, and trying to certify it as a brand new car.
Some of the things that would not pass muster:
- Doors are too small
- Aircraft sits too low
- Seats / cabin floor G-forces rating
- Archaic cables & pulleys flight control system
- No EICAS
.. and probably a bunch of other things.
Blockplus
Sun Jan 05, 2020 3:17 pm
Originally we were told MCAS was put put on to make the plane feel like an ng would during certain cg/weight/speed parameters. If so why not just have the elevator feel computer just make the controls heavier. Or place strakes under the tail?
hOMSaR
Sun Jan 05, 2020 3:18 pm
What elevator feel computer?
I was raised by a cup of coffee.
kalvado
Sun Jan 05, 2020 3:21 pm
NG has simulated stick force, which is provided by hydraulic computer based on airspeed, elevator AoA etc. There is even a separate pitot tube on vertical stabilizer for that
TheWorm123
Sun Jan 05, 2020 3:58 pm
- No EICAS
Thank you, I’ve yet to fly a 737 but the design overall looks fairly aged when you compare the nose to more modern jets like the A320 or even the 757.
767333ER
Sun Jan 05, 2020 4:15 pm
- No EICAS
IIf memory serves the doors also require too much force to open. The one thing they were not allowed to grandfather was the window exit design which is why the 737NG got those built in opening exits it has (the one good design on the plane).
Been on: 732 733 734 73G 738 752 763 A319 A320 A321 CRJ CR7 CRA/CR9 E145 E175 E190 F28 MD-82 MD-83 C172R C172S P2006T PA-28-180
2 ears for spatial hearing, 2 eyes for depth perception, 2 ears for balance... How did Boeing think 1 sensor was good enough?!
CALTECH
Sun Jan 05, 2020 4:34 pm
They all have it, according to the Boeing Manuals.....
737-7/8/8200/9/10
ALL
Maneuvering Characteristic Augmentation System (MCAS)
You are here.
UpNAWAy
Sun Jan 05, 2020 5:16 pm
To fly no, to certify as a common B737 yes.
Venatt
Sun Jan 05, 2020 5:49 pm
My main concern is what if the landing gear fails to extend while rotating and the plane is on the run way at high speed ?
Stitch
Sun Jan 05, 2020 6:12 pm
I don't see how this would be possible since it is a MAX model and incorporates systems unique to the MAX and not found on the NG.
I believe the natural position for the strut is extended - it is the weight of the airframe pushing down on it on the ground that keeps it compressed. As the wings take the airframe weight load, the struts extend naturally. And when the plane lands and the wings shed the airframe weight load, the strut naturally compresses under the airframe weight. So they would always extend upon rotation.
kalvado
Sun Jan 05, 2020 8:38 pm
Well, max is a modified NG for certification reasons. Can there be another subtype of 737, say Super, another flavor ofupgraded NG having just one model- formerly known as max10, without mcas and without but flip computer upgrade? Paperwork mess, but then super10 can be delivered before max rts
sxf24
Sun Jan 05, 2020 10:39 pm
- No EICAS
You have no clue what you’re talking about. None of those items are certification issues for the 737.
CALTECH
Sun Jan 05, 2020 11:06 pm
https://www.boeing.com/features/2018/08 ... 08-18.page
You are here.
JetBuddy
Mon Jan 06, 2020 1:09 am
- No EICAS
Actually, you're the one who doesn't know what I'm talking about.
The question was what would be issues if the 737 were to be certified as a brand new aircraft today, without any grandfathering.
Next time, try reading the original question before posting.
sxf24
Mon Jan 06, 2020 1:19 am
- No EICAS
The only item that could potentially be an issue is is EICAS.
planecane
Mon Jan 06, 2020 3:26 am
The EFC has no way to know what the AoA is. Also, it is a hydraulic computer. It can't run algorithms like MCAS.
They would have to design and certify a whole new EFC with new capabilities and architecture.
