NYC-air
UAL at EWR - new Terminal One
Tue Jan 14, 2020 1:52 pm
Does anyone know what United's plan's are following Terminal One's opening? Will their express flights move from A to One when A closes?
Or are they eyeing, perhaps, Terminal B? B would be closer to their current operation.
SQ789
Re: UAL at EWR - new Terminal One
Tue Jan 14, 2020 1:53 pm
Not sure. Do you have any source?
If it's not Boeing, I'm not going!
ddaly241
Tue Jan 14, 2020 2:22 pm
Will united expand their service once terminal 1 is opened? Just curious.
FSDan
Tue Jan 14, 2020 4:59 pm
Service expansion by any airline at EWR is limited by runway capacity. As a level-2 schedule-facilitated airport, new services are regulated by the FAA, and they haven't been approving flights during peak afternoon hours.
https://www.faa.gov/about/office_org/headquarters_offices/ato/service_units/systemops/perf_analysis/slot_administration/slot_administration_schedule_facilitation/level-2-airports/
That said, UA will continue to expand at EWR through the use of larger aircraft. It's been happening over the last few years, and it will continue.
This is my signature until I think of a better one.
KMCOFlyer
Tue Jan 14, 2020 7:33 pm
I’d say either is possible. Some of the renderings on the T1 redevelopment website shows a DL plane at a new gate, but this could mean anything. If they do decide to switch to Terminal B, they could easily swap with DL and take over their pier on B which would be much closer to the rest of UAs operations at Terminal C.
ordbosewr
Tue Jan 14, 2020 7:57 pm
If we all believe that the plans for EWR is to redo T2 once T1 redevelopment is completed, then I am not sure what is in it for UA to do any swap into T2. They already use many of the T2 gates for international arrivals. I can be corrected, but I think UA needs more than what just DL has in T2.
Nicknuzzii
Tue Jan 14, 2020 8:13 pm
While I don’t have any confirmation on any of this I do have a few scenarios of what could happen.
A: United, just like the other carriers serving terminal A right now will move to T1 with probably a regional exclusive op., which is what is done currently.
B: United decides to pick up Deltas gates in terminal B resulting in DL and NK moving to T1. United would benefit from this scenario the most because instead of them operating in all 3 terminals they would consolidate to 2 all while gaining mainline gates.
C: United consolidates and shrinks it’s mainline ops. to Terminal C and hardstands until they decide to go mainline or drop the route down to IAD.
Polot
Tue Jan 14, 2020 8:25 pm
Gates are currently a hot commodity at EWR right now. UA is definitely not going to shrink and give up gates, and probably sees operating out of all 3 terminals as a plus as it helps keep competition out.
codc10
Tue Jan 14, 2020 8:40 pm
UA will be the largest tenant in T1, with a mixed mainline/regional, primarily domestic operation. Longhaul will stay at C as there are no plans for a 2nd Polaris Lounge at T1. There will, however, be a large United Club.
tjwgrr
Tue Jan 14, 2020 8:54 pm
Heard somewhere UA will have at least one wide-body gate at T1 used by UA domestic wide-body flights and AC's YVR 787 flights.
Direct KNOBS, maintain 2700' until established on the localizer, cleared ILS runway 26 left approach.
