OB1504
DL201 JNB-ATL 777 diverts to MIA this morning
Sat Jan 18, 2020 3:07 pm
Anyone know why N702DN diverted to MIA this morning? If it’s mechanical, it seems like Delta has had a lot of maintenance issues with their 777s lately.
CriticalPoint
Re: DL201 JNB-ATL 777 diverts to MIA this morning
Sat Jan 18, 2020 3:14 pm
They have had a few fuel stops on that route lately.
SteelChair
Sat Jan 18, 2020 3:41 pm
I'm sure it's the next step in the MIA buildup after the LATAM deal.... :stirthepot: :rotfl:
Q
Sat Jan 18, 2020 3:47 pm
probably it was a strong headwind fuel burned too much had to refuel MIA before going to ATL.
Q
Cubsrule
Sat Jan 18, 2020 3:53 pm
Not a diversion at all. They left JNB filed to MIA. JNB hasn’t been hot (highs in low-mid 20s), so it was almost certainly a headwinds issue.
x1234
Sat Jan 18, 2020 4:12 pm
Wth UA's success on EWR-CPT I wonder if UA will consider (and the B789 has better performance) EWR-JNB which is actually shorter than ATL-JNB.
Cointrin330
Sat Jan 18, 2020 4:15 pm
JNB-ATL has diverted a few times in recent weeks, including stops in SJU. Headwinds likely. Interestingly, it is quite blustery in South Florida at the moment.
DTWLAX
Sat Jan 18, 2020 4:40 pm
Looks like it was a planned stop due to headwinds. But what 777 maintenance issues are you talking about? Other than the issue with the LAX-PVG flight earlier this week that led to the fuel dump over LA, what other DL 777 issues have come up? Certainly not a "lot" as you say.
Q
Sat Jan 18, 2020 4:55 pm
Delta should switches from B777LR to Airbus 350. Maybe A350 is better performance than 777LR.
Q
sxf24
Sat Jan 18, 2020 5:01 pm
Q
Not on JNB.
pnutt
Sat Jan 18, 2020 5:07 pm
On December 29, they had a (fuel?) stop in JFK. I had to correct my mental map a little: JNB-JFK is about 400nm shorter than JNB-ATL, which I would not have expected.
Cubsrule
Sat Jan 18, 2020 5:26 pm
Yup; it’s easy to forget just how far west ATL is (actually slightly west of DTW). But if they can make it, JFK is easily the best/least bad place to drop in because it’s a crew base and if the flight cancels on the ground or passengers deplane and clear formalities for some reason, reaccommodation options abound.
Q
Sat Jan 18, 2020 5:28 pm
I found the source. EWR-SIN has a nonstop flight for Singapore Airlines uses Airbus 350 than distance JNB-ATL. It is able to fly a range enough fuel. No more stop fuel diversion ever again! Look at the Map. http://www.gcmap.com/mapui?P=EWR-SIN,+JNB-ATL
Q
ikolkyo
Sat Jan 18, 2020 5:32 pm
Q
EWR-SIN operates with a reduced capacity A350 that can carry a lot more fuel. JNB is typically a Hot and High elevation airport which kills aircraft performance.
Cubsrule
Q
Keep in mind that SQ’s aircraft on that route aren’t very dense, JNB-ATL is much more westbound, and SIN is at sea level.
CriticalPoint
Sat Jan 18, 2020 5:54 pm
Q
dL A350s can’t even fly to SYD from LAX....let alone the hot and height JNB-ATL
NYCAAer
Sat Jan 18, 2020 6:00 pm
I think he’s referring to the DL 777 that diverted to BOS that was operating LAS-CDG for the CES show. There was a loud bang and the pilots decided to land in BOS. It’s not completely clear yet but they think it was in the air conditioning duct.
AKL321NX
Sat Jan 18, 2020 7:15 pm
CriticalPoint wrote:
Q
Hey that lie again
Q
Sat Jan 18, 2020 7:19 pm
Q
A what? A350 LAX-SYD can't fly. What are you thinking of this aircraft? A350 and B787 are very similar. Two engines and almost same size. A350 is able to fly that range for fuel burns. It does not make any sense to me. You are not an expertise Airbus 350 performance. Ask Airbus and if they are able to fly that range. United flies 787 LAX/IAH to SYD. It works.
Q
CriticalPoint
Sat Jan 18, 2020 7:27 pm
[threeid][/threeid]
Q
Q
Yes the A350 can of course fly from LAX-SYD. However with ETOPS fuel and required ALT fuel and reserves. DLs A350s cannot fly LAX-SYD with a payload tha makes sense to them.
Route planning isn’t just about if the plane can make it.....that’s why United stopped flying LAX-SIN. The plane could make it there just fine but the weight hit was to much
LAOCA
Sat Jan 18, 2020 8:29 pm
[threeid][/threeid]
Q
I'm pretty sure some of that has changed. Part of the issue was getting rights to use CBR as an alternate. Also, some new frames coming in are 280T. Delta also took a very conservative position on flight planning initially. But everything points to the 350 flying this route before the end of next year.
DylanHarvey
Sat Jan 18, 2020 8:34 pm
Q
This route is the only route in the system where the 77L really outshines the A359.
DylanHarvey
Sat Jan 18, 2020 8:36 pm
[threeid][/threeid]
Q
Delta average 50+ tons of payload on the 77L to SYD. Delta has massive cargo businesses, its not an inditement on the 359. The 35K can make it with that absurd amount of payload, but the 359 a little less.
LAX772LR
Sat Jan 18, 2020 9:00 pm
Wait, you somehow believe that a 789 has "better performance" than a 772LR, from a hot-high airport prior to a 16hr flight?
That's... interesting.
Here's the problem with that:
EWR and SIN are sea-level gateways, being flown with a modified A359 carrying 37% less pax than their typical configuration.
That's not going to work for an airline wanting to fly from a gateway at 5500ft, carrying cargo and a full pax load.
As much as you're attempting to couch it, your statement is still not accurate.
The correct response is that: in the current market situation, DL's calculation for its now 275tonne A359s (nearly all of which are capable of being uprated another 2tonnes+ if desired) is such that the opportunity cost remains greater than the benefit of using them in lieu of the 77L, on a route such as LAX-SYD.
Your statement also seems to assume that such a situation is predicated on what the A359 can/cannot carry, which again isn't necessary accurate, nor necessarily of primary concern.
An even bigger contribution can be "what do you then do with the 77L?"
It's the heaviest and longest ranged asset in their fleet, with essentially no value on the secondary market; thus there's not many other places to send an 8800nm/347tonne aircraft and expect to make money. Thus, even putting the A359s on SYD were to make ($N) extra money for DL, it does them no good on a systemwide basis if they have to place the 77Ls on a route that loses ($N+X).
CriticalPoint
Sat Jan 18, 2020 9:04 pm
EWR and SIN are sea-level gateways, being flown with a modified A359 carrying 40% less pax than typical.
That's not going to work for an airline flying from a gateway at 5500ft, carrying cargo.
Your statement also seems to assume that such a situation is predicated on what the A359 can/cannot carry, which again isn't necessary accurate. An even bigger contribution can be "what do you then do with the 77L?"
Ok.....you just used more words than me. Perhaps “can’t” was the wrong word. Perhaps I should have said is unable to fly LAX-SYD due to it not being able too with a payload DL deems profitable.
LAX772LR
Sat Jan 18, 2020 9:06 pm
I didn't "use more words," I admonished two unsubstantiated assumptions, that you apparently missed and/or learned nothing from.....
As demonstrated by your repetition of the exact thing I warned you against focusing on.
evanb
Sat Jan 18, 2020 9:50 pm
DL have 10 B777-200LRs, likely nearly paid off and nearly fully depreciated. They need to fly somewhere. They're best suited to their longest routes or those that need the largest lifting power, invariably that is going to be routes like ATL-JNB, LAX-SYD, JFK-BOM, ATL-PVG, etc. It's the existence of the B777-200LR in the DL fleet that has influenced DL to go with the lower TOW and higher density on the A350.
Q
Mon Jan 20, 2020 4:26 am
Here you go! South African approved fly JNB-JFK Airbus 350. See?
https://www.routesonline.com/news/38/ai ... -jan-2020/
Delta could fly A350 JNB to ATL almost same as JFK.
Q
dennypayne
Mon Jan 20, 2020 4:38 am
Yes, but are you not understanding what LAX772LR wrote above? South African doesn't have 777's that they would then need to take off that route and fly somewhere else with, like Delta does.
A300/310/319/320/321/332/333/343/380 AN24/28/38/148 ARJ AT6/7 B190
B717/722/732/3/4/5/7/8/9 741/744/752/753/762/763/764/772/773/788/789
CR1/2/7/9 D8S D93/4/5 DHC2/3/7/8 D28/38 EMB/EM2/ER3/D/4/E70/75/90
F50/100 J31 L10 L4T M11/80/87/90 SF3 SU9 TU3/TU5 YK2
IPFreely
Mon Jan 20, 2020 6:08 am
DylanHarvey wrote:
Delta has massive cargo businesses.
Delta just released their 2019 annual report. Cargo business was 1.6% of total revenue. That's not massive.
dstblj52
Mon Jan 20, 2020 7:18 am
Yes but Cargo can not be huge overall and still be very good on particular routes
DylanHarvey
Mon Jan 20, 2020 8:00 am
My point is some routes it can have an impact. DL made $254,000 on cargo on one flight to JNB.
777Mech
Mon Jan 20, 2020 8:33 am
$752 million is nothing to sneeze at.
INFINITI329
Mon Jan 20, 2020 6:09 pm
At first glance, I scratched my head at JFK. Once I got geographic bearings I understood along with the reasons listed above. I am surprised DL doesn't have a destinated diversion airport for the JNB-ATL when the weather becomes a factor. According to this forum, there has been 3 different airports chosen in the past few weeks SJU,MIA & JFK.
Cubsrule
Mon Jan 20, 2020 6:30 pm
I don't have enough information about the specific situation of each flight to be sure, but at least on a superficial level, all three stops seem consistent with an effort to get the flight as close to ATL as possible before diverting, and that seems a reasonable approach to me on this particular flight given that getting closer to ATL increases the odds of landing in the country of destination and increases the services available both for crew and passengers on the ground. (If ATL-JNB needed fuel stops sometimes, I don't know that the "get as close as possible to the destination" approach would make as much sense.)
evanb
Mon Jan 20, 2020 6:48 pm
But likely to be the only 3 times (maybe one or two more) that they'll have this problem all year.
SuseJ772
Mon Jan 20, 2020 6:52 pm
Plus, it probably has a much higher margin and a larger impact on EBITDA.
Currently at PIE, requesting FWA >> >>
ethernal
Mon Jan 20, 2020 6:56 pm
This. Even accounting for extra fuel, ground handling costs, and extra administrative overhead of running the cargo business, this business probably sees 30-50% net margins because the flying is pretty much already paid for.
evanb
Mon Jan 20, 2020 6:59 pm
And so? If you neighbor jumps off a bridge do you follow him?
A few things at play here ... 1) JNB-JFK is nearly an hour shorter than JNB-ATL. 2) SA's A350s likely have the higher TOW option than DL's. 3) JNB-JFK takes off an hour later, and thus at a slightly cooler temperature than JNB-ATL. 4) The routing to JFK is further north with an entirely different weather profile.
Points 1, 3 and possibly even 4 are a reason why DL chose to divert a JNB-ATL flight to JFK on 29 December (staggering, but true).
So the premise that DL could fly the A350 on JNB-ATL just because SA plan to fly is on JNB-JFK is false.
