mercure1
ANA - Singapore Airlines to form JV
Mon Jan 20, 2020 10:38 pm
The two high-quality airlines seek to get closer.
Suspect the recent news SQ wants to fly Tokyo-New York is related.
TOKYO -- All Nippon Airways enters a comprehensive tie-up with Singapore Airlines as early as this month, joining forces with Star Alliance partner to fend off competition in an increasingly crowded Asian market.
This type of partnership, known as a joint venture in the aviation industry, will go beyond the carriers' current code-sharing agreement to let them coordinate schedules and fares. The arrangement is slated to launch around 2021 once the airlines receive the necessary antitrust exemptions.
The tie-up marks the ANA Holdings unit's first joint venture with an Asian partner, and its third overall after agreements with United Airlines and Lufthansa.
https://asia.nikkei.com/Business/Transp ... rket-grows
https://www.straitstimes.com/singapore/ ... ht-options
mercure f-wtcc
Nicknuzzii
Re: ANA - Singapore Airlines to form JV
Mon Jan 20, 2020 11:25 pm
I think this could bring major changes to both airlines NYC ops.
What we know already,
ANA flies to JFK
SQ flies to EWR and JFK (via FRA)
UA has a fortress hub at EWR
SQ has applied to fly SIN-NRT-NYC
What can happen; (some of these are unlikely)
- SQ consolidates to EWR and begins SIN-NRT-EWR
- ANA begins to fly to EWR and SQ takes over NRT-JFK while dropping FRA
- SQ drops FRA-JFK in favor of NRT-JFK
ITSTours
Mon Jan 20, 2020 11:38 pm
Interesting. More related to JL-MH deal I guess.
ITSTours
Mon Jan 20, 2020 11:40 pm
https://trafficnews.jp/post/93085 (article in Japanese)
Indeed. The JV does not include US. The scope involves Japan, Singapore, Malaysia, Indonesia, India, and Australia.
SCFlyer
Mon Jan 20, 2020 11:58 pm
Possibly opens an opportunity for a potential 3-way SQ/NH/VA JV when the existing SQ/VA partnership expires at the end of Q3 2021.
J343
Tue Jan 21, 2020 12:16 am
Will this move open the oppirtunity for CX and JL to form a JV for HKG-Japan flights? They have extensive codesharing for most routes to and from Japan and HK vice versa.
eamondzhang
Tue Jan 21, 2020 1:21 am
Believe they already have a JV.
Michael
Tabito
Tue Jan 21, 2020 5:53 am
Michael
Not JV, only code share and FFP agreement between CX/JL/KA.
Current JV: Trans Pacific AA/JL and Trans Siberian AY/BA/IB/JL
Ongoing JV: PRC-Japan JL/MU, Japan-Malaysia JL/MH
Pending JV Hawaii-Japan HA/JL, Indonesia-Japan GA/JL or NH
YYZORD
Tue Jan 21, 2020 7:14 am
I can see NH flying to EWR but it would probably be with their 789 as the premium route is always better at JFK with their 773
yonahleung
Tue Jan 21, 2020 7:33 am
Competition authorities would not allow. If CX and JL forms a JV there will be a monopoly on most HKG-Japan flights.
SYDSpotter
Tue Jan 21, 2020 7:53 am
With SQ and NH controlling more than 2/3 of the current non-stop services between SIN and TYO, would competition authorities approve this?
319_320_321_332_333_359_388 / 734_737_738_743_744_762_763_772_773_77W_788_789
LAX772LR
Tue Jan 21, 2020 8:32 am
EWR isn't remotely a "fortress" for UA, or anyone else
If by some, you mean "all," then sure.
FRA by SQ's own admission has been significantly profitable for them, hence its survival for decades despite it no longer being an operational necessity.
Barring some radical market change, why would they bother with any of the above?
LAX772LR
Tue Jan 21, 2020 8:52 am
it gets even worse when you look at secondary Japanese gateways
mmo
Tue Jan 21, 2020 10:36 am
The FRA-JFK flight for SQ is a money maker. I flew it several times when I worked for SQ and it was always full in J/F and Y had a consistently high load. In addition, on the 744, a significant amount of cargo could be loaded. At that time, the flight was the first European arrival in JFK and always had a few "high profile" paxs on the aircraft. Eliminating the JFK turn would require a significant retiming of the return FRA-SIN flight which does quite well with the current timings.
Nicknuzzii
Tue Jan 21, 2020 11:06 am
If 65-70% isn’t a fortress hub I don’t know what is.
ZK-NBT
Tue Jan 21, 2020 11:07 am
The FRA-SIN flight wouldn’t need to retimed at all, it would arrive FRA around 0630 and depart at the same time it does now 1130? Arrive SIN 0630 like most of the other European services for SQ, they would save 1 aircraft without the JFK leg.
United1
Tue Jan 21, 2020 2:51 pm
NH already flies to EWR via their JV with UA...unless the JV wants to add more capacity to the NYC market there is no need to.
I know the voices in my head aren't real but sometimes their ideas are just awesome!!!
mmo
Tue Jan 21, 2020 3:49 pm
And it would also give up the revenue from the flight? Believe me, after working for SQ for over 10+ years, if they aren't making money on a flight, they will drop it like a hot potato.
Plus it takes 2 aircraft to do the rotation. The FRA-JFK aircraft sits for the better part of the day. Maintenance is performed so, there is some rationale for having the aircraft sit at JFK. It departs or used to depart around 11pm while the new FRA-JFK was landing and being turned.
When a 744 operated the flight a good 35+ tonnes of cargo would be uploaded and the revenue generated with the premium cabins was something SQ would be reluctant to give up.
J343
Tue Jan 21, 2020 6:54 pm
Wouldn't that be the same case for SIN-Japan flights if NH and SQ pushes through with their JV?
paperwastage
Tue Jan 21, 2020 10:43 pm
Doesn't UA and NH have a JV on usa-asia(excluding China)? How would a JV between SQ+NH play out for SIN-TYO-NYC?
From my previous post on this: I could be wrong, can someone pull up the travel stats for NYC-TYO city pair?
Even with the new HND slots, it was UA adding EWR-HND (772) starting March 2020 along with existing EWR-NRT (777-300)
NH and ANA both operate double daily out of JFK (one to NRF, one to HND), so a total of 6 after UA's addition, all 777s
I don't think there's enough traffic to add a 7th, even if NH+JL operate the ultra premium heavy configs (212seats on NH and 244 on JL, 350+276 on UA 77W+772)
LAX772LR
Wed Jan 22, 2020 3:42 am
Well yeah, we established those last five words previously.
UA doesn't have anywhere near the leverage to control the pricepoint or flows of that market, due to the combined impact of numerous foreign flags, the buildups of NK and F9, and proximity to competitive gateways that can/do duplicate services.
EWR is many things to UA, but a "fortress" it is not.
In fact, that's the downside of UA's generous hub layout; global cities with huge corporate demand, but huge competition in return.... about the closest thing it has to a fortress in a single gateway is IAH, and it's still not much of one as a city/metro, due to the competing LoCo domestic gateway right down the proverbial road.
SFOtoORD
Wed Jan 22, 2020 3:50 am
From the post above:
Antaras
Wed Jan 22, 2020 4:20 am
ANA also has stakes in Vietnam Airlines.
What are ANA purposes by partnering (and absorbing) bunches of ASEAN carriers from different alliances (VN from Skyteam, SQ from Star) :?: :confused:
If you disagree with my statement, assume that it was just a joke :duck:
SCFlyer
Wed Jan 22, 2020 4:23 am
2021 is the same year SQ's JV with VA expires. Assumably at the end of Q3 (October).
https://australianaviation.com.au/2016/ ... -alliance/
Speculation Time: Per earlier post, I wonder if this evolves into a 3-way SQ/NH/VA JV, or remains a separate SQ/NH JV with the SQ/VA JV being renewed, or if it replaces the SQ/VA JV.
paperwastage
Wed Jan 22, 2020 4:49 am
True, but rumors for NYC-TYO doesn't fit this Asia/Oceania JV
And which other carrier has JVs that overlap with other JVs?
LH has JVs east(UA) and west (ANA), but I doubt there's major overlapping traffic (someone flies from usa-europe-asia maybe excluding India)?
SFOtoORD
Wed Jan 22, 2020 6:16 am
I think ANA - UA covers all Japan - USA flights so I’m guessing the only to include SQ’s Japan - USA traffic would be to have SQ join that JV. Seems like it would be a cold day in hell for that to happen.
EightyFour
Wed Jan 22, 2020 8:08 am
Is there a lot of Australia-Japan traffic connecting over Singapore?
SCFlyer
Wed Jan 22, 2020 9:06 am
SQ traditionally carries VA passengers between AU and Japan via SIN as part of the SQ/VA alliance (JV). This has slowly been changing with the recently signed NH/VA codeshare agreement in anticipation of the upcoming new HND flights from VA and NH.
Ishrion
Fri Jan 31, 2020 2:56 am
Tabito
Fri Jan 31, 2020 5:37 am
Tabito
Fri Jan 31, 2020 12:53 pm
jayunited
Wed Feb 05, 2020 12:52 am
There is a great article on Flight Global's website on this SQ, NH proposed joint venture.
According to Yuji Hirako the CEO of NH one potential wrinkle in the proposed JV between the two carriers is NH's JV with UA. That JV covers UA's nonstops from the US to Singapore but more importantly the JV covers NH's flights from Tokyo to SIN. Hirako states the current language in NH's JV with UA it is exclusive between the the two airlines meaning SQ under the current terms can not be apart of any JV between Tokyo and Singapore. SQ wants to leverage NH's strong domestic network, while NH was to capitalize on SQ's (and the low cost carriers) strong Australia, Indonesia, and Indian networks but these carriers also want the JV to cover TYO-SIN-TYO.
https://www.flightglobal.com/networks/a ... 90.article
My question is with because UA's JV with NH is exclusive and includes Tokyo (I'm assuming that means both HND and NRT) how does NH get UA to come back to the negotiating table to perhaps talk about excluding both UA's NH's flights to SIN? From the article it is clear both SQ and NH want TYO-SIN-TYO included in their JV how do they go about it with UA standing in the way.
Also the article mentions SQ's newly granted rights to operate flights between Tokyo and New York. SQ's CEO made it clear no final decision has been made as to if SQ will actually exercise those rights. I'm sure NH is getting an ear full from JV partner UA whose probably in full opposition to SQ entering this market. Does NH have any leverage here because it seems like they will be stuck in the middle of a bitter useless feud between SQ and UA. UA with our two daily nonstops SFO-SIN-SFO probably could amend the JV and release NH from the exclusivity terms. If UA were inclined to amend the terms of their JV with NH what would UA ask for in return from NH? Could UA's price be that NH firmly request (or demand) their newly JV partner SQ stay out of the TYO-New York market? Although there is little to no chance of a NH/SQ/UA JV if UA were to put this ridiculous feud behind them UA could perhaps benefit from having a closer non-JV relationship with SQ.
Nicknuzzii
Wed Feb 05, 2020 1:34 am
Where does UA’s hatred of SQ stem from?
