readytotaxi
BA new A350 damaged at Tel Aviv
Tue Jan 21, 2020 10:07 am
Growing older, but not up.
817Dreamliiner
Re: BA new A350 damaged at Tel Aviv
Tue Jan 21, 2020 10:12 am
Hmmm and its G-XWBD again... ( the one Airbus bent up in the paint hanger).
Life is encrypted, you are modified, Like a virus in a lullaby, Artificial till the day you die, silly programme, You're corrupted
747fly
Heady landing - needs to be check/repaired, then will position back to LHR.
N14AZ
Tue Jan 21, 2020 1:48 pm
According to Aviation Herald, a passenger reported the ceiling panels came down in the aft galley at touch down. Source: http://avherald.com/h?article=4d23c7df&opt=0
I had no clue that BA is using their A350 for flights to TLV. Kind of training flights?
WayexTDI
Tue Jan 21, 2020 2:02 pm
And I love how some started right away with asking if it was a write-off... Obviously not an a.net exclusivity.
WesYan
Tue Jan 21, 2020 3:46 pm
G-XWBD again. Seems like this aircraft can’t catch a break.
AECM
Tue Jan 21, 2020 4:16 pm
It's on its way to LHR i think (BAW164F)
https://fr24.com/BAW164F/2399a3e4
scbriml
Tue Jan 21, 2020 4:26 pm
Probably a special condition ferry flight back to LHR prior to scrapping in the BA mainentance area. :duck:
Erebus
Tue Jan 21, 2020 4:32 pm
Sure. Parts of it. The broken bits, of course. :white:
Tue Jan 21, 2020 4:37 pm
They are trying really hard with a heavy landing to give it a break, just not hard enough this time ;)
GZM1
Tue Jan 21, 2020 6:23 pm
It’s all in the registration, it’s there for all to see: G-XWBD = Gee-Xtra Weight, Body Damaged. It is obvious to every superstitious traveler that the plane needs to be re-registered.
It’s all Greek to me! Aeroplane Basic Category Cycle Dynamic Economics Ecstasy Fantasy Galaxy Geometry Harmony History Horizon Idea Logic Magnetism Music Mystery Nautical Orchestra Organism Phenomenon Political Problem Symphony Technology Telephone Zone
ClipperYankee
Tue Jan 21, 2020 6:30 pm
I'm having deja vu. Didn't another aircraft (not sure of the type) recently have a ceiling panel come down on landing? I want to say I remember it being a Latam bird? Maybe I'm way off.
707/717/727/737-100,200,300,400,500,700,800/747-200,300,400/757-200,300/767-300,400
772/788&9/DC3/DC6/DC8/DC9/DC10/MD80s/L1011/A300/A319,320,321/A332&3/A343/A359/A388/
BAE146/ATP/ATR42/DHC2,3,7,8/S340B/CRJ200,700,900/E140,145,175,190/F70,100/B1900
dtw2hyd
Tue Jan 21, 2020 6:36 pm
It is hard work to be the hanger queen of the fleet, but someone got to do it.
Jokes aside, ferry flight is cruising at decent altitude, so damage maybe minimal, although this would have been a good test for field repair process. I would guess it is easy to repair A350 compared to 787 in the field, as it has metal structure with CFRP panels.
All posts are just opinions.
metroline2006
Tue Jan 21, 2020 6:38 pm
Gonna be converted to a 900 lol
ltbewr
Tue Jan 21, 2020 6:40 pm
Must of passed a preliminary check to allow it to fly to LHR mx hub for BA. Likely minor damage that will be fixed in a few days pending further inspection. No need for a write-off, yet.
readytotaxi
Tue Jan 21, 2020 7:19 pm
During Jan the aircraft has been ping ponging between Bangalore and Tel Aviv.
yochai
Tue Jan 21, 2020 9:55 pm
Regular equipment to TLV (runs year round)
Kindanew
Tue Jan 21, 2020 10:35 pm
The A350 has huge composite panels on a composite frame (although I understand some frames are metal).
Back in 2006 when the XWB was launched it was to have a metal frame with composite panels but it was changed later to a composite frame.
dtw2hyd
Tue Jan 21, 2020 11:04 pm
Me thinks, as long as the structure is panel on frame, not weaved CFRP tube sectons, repairs are going to be easier. Though A350 design is evolutionary, not revolutionary like 787, field repairs are easy.
Not that BA will let any details leak, do we know the damage was minor (or) the bean counters decided to grind down mx efficiencies and told boys put on your oxygen masks, we are flying this bird home one way or the other.
Longhornmaniac
Tue Jan 21, 2020 11:16 pm
Sounds like they need a little more training. :duck:
Cameron
TC957
Tue Jan 21, 2020 11:22 pm
It was at FL410 over Croatia on it's ferry flight back so I wouldn't have thought airframe damage was much.
alasizon
Tue Jan 21, 2020 11:50 pm
That was an actual overhead bin and ceiling section. The reports sound more like just a ceiling panel with nothing attached to it. Not all that uncommon over the aisles and galley.
BOAC1966
Wed Jan 22, 2020 10:51 pm
En route tonight to TLV .....no problems .....
uta999
Wed Jan 22, 2020 11:01 pm
Probably giving the ex-Ryanair FO another crack of the whip. Now listen “Retard”
Your computer just got better
itisi
Wed Jan 22, 2020 11:49 pm
Correct me if I'm wrong but once you land harder than the limit it doesn't matter if there is any visible problem.... You ground it for checks.
Clearly some here wanted it to be a big deal but it wasn't. Seeing its flying already and did the ferry flight pressurized.
737-300/400/500 ... are NOT classics :)
Thu Jan 23, 2020 6:06 am
Actually after a suspected heavy landing a special report is sent off to Airbus for analysis. Normally the report says the landing was ok.
It takes some time to do the analysis.
Tristarsteve
Thu Jan 23, 2020 11:20 am
It is not a ferry flight, it is a regular flight with freight only. The F suffix on the flight number is used when there are no passengers on board.
Maintenance ferry flights at BA are extremly rare. Getting permission for a flight outside the MEL / CDL / AMM is difficult.
dtw2hyd
Thu Jan 23, 2020 3:18 pm
BA does weird things during IRROPS to save few dollars on mx,parts or passenger accommodation
The infamous PHX-LHR 747 3-engine ferry. Of course, no one in USA can fix a 747 engine.
2016,BA7 to Japan turned around over Finland, returned to LHR. No country in between Finland and Japan is capable to fixing a 777.
2018 BA233 to Moscow has turned around over Latvia, returned to LHR.
2019 BA293 returned to LHR after a steward "knocked himself out". Why Ireland don't have Doctors,
Long ago, there was another 747 en-route USA turned around over Iceland due to operational reasons, returned to LHR
So if BA thinks TLV AMT hourly rates or too high, or parts are marked up, or shop supplies are too expensive or parking fees are unnecessary it will bring the bird back to base. Also if unpressurized flight burns too much fuel, suit up the crew and fly normal cruise altitude.
Past history is always a factor in any behavioral analysis.
Antarius
Thu Jan 23, 2020 6:31 pm
Unless it is an emergency, you return to base. What if the aircraft couldn't be fixed or the repair took longer? Now you've stranded 250 passengers in Finland or somewhere else. Better to return to LHR, then you have staff and control over the situation.
Not to mention visa issues that can result.
But hey, let's not let logic get in the way of slamming meanie BA
2020: SFO DFW IAH HOU CLT MEX BIS MIA GUA ORD DTW LGA BOS LHR DUB BFS BHD STN OAK PHL ISP JFK SJC DEN SJU LAS TXL GDL
theginge
Thu Jan 23, 2020 7:53 pm
BA regularly flies empty 744s on 3 engines, why pay to ship an engine several thousand miles when the 744 is certified to fly on 3 allowing the aircraft to fly back to base?
That country between Finland and Japan is Russia, yes of course they could fix a 777 but then the Pilots decided not to fly for hours over very remote areas with a problem but rather return to base. Also considering the passengers, be handled at Heathrow or some remote airfield in Russia.
You don't always need to land at the first available airfield, eg flying over Ireland to get to London, obviously the Steward wasn't serious enough to need immediate attention but it couldn't wait for 5 hours to get to the USA
Tristarsteve
Thu Jan 23, 2020 8:16 pm
What on earth has this to do with the question?
If a B747-400 needs an engine change, BA will always fly the aircraft back to the UK to change it. Once, to my knowledge, when they needed an engine change in Sydney did they loan an engine from Qantas and fly the plane back. It is cheaper and quicker to 3 engine ferry, than to ship an engine and people and stands around the world.
Incidently, about 5 years ago there was a directive from above to the BA operations centre that, if an aircraft had problems, but could still reach its planned destination, then it should continue, even if it was AOG on arrival.
HEATHROWHUNTER
Thu Jan 23, 2020 8:47 pm
Does anyone know whether this hard landing was a fault by the pilot or another factor which contributed ? What is BA’s policy with pilots and these situations ? Is this simply they are to the sim for more training or would he/she face more stricter sanctions?
dtw2hyd
Thu Jan 23, 2020 9:22 pm
Tristarsteve wrote:
What on earth has this to do with the question?.
Proves
is not accurate.
That's what most airlines do. Long flights to nowhere is unique to BA. That's what pax on those planes thought, if you read their Twitter posts.
Examples I quoted didn't follow the directive, or you are missing a caveat that the destination is London.
Latvia is closer to Moscow(Destination) than London, should have continued to Moscow
No need to turn around over Iceland en-route Chicago just because wing landing gear pins were not removed. Could have continued to Chicago.
WesternDC6B
Thu Jan 23, 2020 9:28 pm
Imagine what the passengers are thinking! Not to mention, the catering bill must be a fortune!
Never employ grandios verbiage when the utilisation of diminutive phraseology will suffice.
DL757NYC
Thu Jan 23, 2020 9:38 pm
Reminds me of the time my buddy put a ding in a brand new 777LR with the FMC. Lucky it was within limits.
Sat Jan 25, 2020 1:48 pm
I doubt it was a hard landing given how quick it returned to service.
Hard landings are very difficult for pilots to know by feel, the gear attachment on the 350 is very different to the 330. We have had landings on the 350 which on an 330 would be a hard landing.
If crew suspect a hard landing they make an entry to that effect into the maintenance log for the aircraft. The mechanics will do their normal post flight inspection and send off a special landing report they downloaded from the aircraft with a USB.
Airbus does analysis on that file, normally it comes back with no issues, sometimes they will issue a conditional release for 30 flight cycles while they do more analysis.
I don’t know about BA specific policy, as an organisation we would look at a landing like that, and if there is lessons that can be learned we will share that with the wider pilot community. Nothing punitive would be done to the specific crew.
TLV can be tricky this time of year, they can get some strong wind gradients, and if it’s an onshore wind RW30 would be used with an RNAV approach.
Users browsing this forum: Baidu [Spider], boquera, Lifes, LionelHutz, max999, MrHMSH, opticalilyushin, Petri70, qf789, RalXWB, Rifitto, rugeley123, seansasLCY, shez, Shuttle, Sokes, steman, VHZNE, VS11 and 218 guests
