Noshow
Re: Boeing 777-9 first flight 24 January 2020 (weather permitting)
Fri Jan 24, 2020 8:37 pm
Is there something smoldering near to the street in the background?
Starfuryt
I still don't see the beacon either top or bottom but that may just be due to the video quality.
aumaverick
Fri Jan 24, 2020 8:38 pm
2+ hrs and holding. The F/As had better distribute food and water. At 3 hours they have to return to the gate to let the engineers off.
I'm just here so I won't get fined. - Marshawn Lynch
PeteKMCFC
Fri Jan 24, 2020 8:39 pm
MileHFL400 wrote:
PeteKMCFC wrote:
Engines running I believe....
How can you tell?
Wishful thinking maybe! Sounded very much like a triple 7 start up just then!
pugman211
Fri Jan 24, 2020 8:41 pm
I dont think engines are on. You have to have the transponder on just to even move an aircraft with a tug and that's with engines off
adamant365
Fri Jan 24, 2020 8:42 pm
I did see the tell tale vortices coming off the taxiway a moment ago. Pretty sure at least the left engine is running.
PeteKMCFC
E90SLAM wrote:
Might be this flight instead.
https://www.flightradar24.com/BOE636/23a35c1d
Absolutely. Apologies for any false hope! I'm at home in Manchester UK watching and listening. The Mrs is very confused as to why!!
NYPECO
Fri Jan 24, 2020 8:43 pm
The engine start sound could have been from the 767.
atsiang
FlyThiz wrote:
I believe the engine start up we hear is from the north end of the field.
I'm pretty sure that was not the engine start up of the 777-9. The camera is way too far from the plane. The engine start up was most likely from other planes nearby the camera.
PeteKMCFC
Fri Jan 24, 2020 8:44 pm
JAL B789 about to land. Shame this camera doesn't rotate.
UWPAviation
It aint going to happen today folks....
Gasman
Amazing aircraft. Let's hope one day soon we're sitting around watching the first flight of the 767NG
CWL757
Fri Jan 24, 2020 8:46 pm
It probably was the 767 but are you aware of how loud 777 engines are on start up? They can be heard over all the other aircraft at LHR so we should definitely hear them start here.
A319, A320, 738, 743, 744, 752, 772, 788, C150, E175, E190, F70, R22
sharpley
something smoking in the distance
par13del
Fri Jan 24, 2020 8:47 pm
We are being scammed, notice the video, the helicopter blades are spinning the same way, I think it is a loop....
I will try counting the shakes of the camera....
uta999
Chase plane coming in
Your computer just got better
JannEejit
Fri Jan 24, 2020 8:48 pm
Possibly the commentary duo, trying to keep warm ?
atsiang
Fri Jan 24, 2020 8:49 pm
Yes I do know how loud the 777 engines are. I've flown on 777-300ER and 777-200ER many many times and I've heard them far away. But from the camera vantage point, the plane is quite far far away. I doubt the sound of the engine was from the 777-9. The engine start up that we all heard sounds like it could have been from a 777-300ER.
firemansparky
Chopper just lifted off....
firemansparky
Fri Jan 24, 2020 8:51 pm
Someone sacrificing the "Please Let There Be A First Flight" goat!
par13del
Yeah and the helicopter that has been orbiting between the parallels must be doing real good against those gust, unless they dropped anchor...
NYPECO
Looks like the helicopter took off so luckily that's not the case, or at least not anymore :duck:
tistpaa727
Fri Jan 24, 2020 8:52 pm
Someone tell these fools to stop zooming so we can a) see more of what is going on and b) my motion sickness stops from all the bouncing!
Don't sweat the little things.
777GE90
Fri Jan 24, 2020 8:53 pm
Jefford717 wrote:
Greta Thunberg be like, “How dare you for idling there for 3 hours”
I thought the beacon lights were off? Have they not shut down?
par13del
Ok so at least now we know what time they will take off........
When the engines of the helicopter cool down enough for them to refuel and relaunch....
Yahhhh
aumaverick
Fri Jan 24, 2020 8:54 pm
For those wondering what the smoke is, its probably Mukilteo's Speedway Cafe or the Mexican restuarant next door.
kraz911
Hello all,
I hope this will be a success for Boeing and the 777 program as I love the bird. I was wondering why there are no scallops on the engine cowling as in the 787? When they first appeared, Boeing touted them as the best thing since sliced bread. Thanks...
par13del
Fri Jan 24, 2020 8:55 pm
kraz911 wrote:
Hello all,
Moved on to Rolls............
Jefford717
Fri Jan 24, 2020 8:56 pm
APU is running for sure
ikolkyo
35 minutes until the window closes for a chance to fly today.
yendig
Fri Jan 24, 2020 8:57 pm
BOE411, a 77W, has just appeared on FR24 close by where the microphones are....maybe that's the 'engine start' we heard?
Noshow
When the chase plane needs to turn back to Boeing Field for refueling we know it's called off for today.
PepeTheFrog
Fri Jan 24, 2020 8:58 pm
Me at home:
Boeing1978
Fri Jan 24, 2020 8:59 pm
Airbus: "Ah, now eventually you do plan to have dinosaurs on your, on your dinosaur tour, right? Hello?"
by738
Fri Jan 24, 2020 9:00 pm
this is over...
PeteKMCFC
PepeTheFrog wrote:
Me at home:
Brilliant!!
N14AZ
Fri Jan 24, 2020 9:01 pm
Confucius says: Do not be desirous of having things done quickly.
AA777223
You guys do realize that the engines on the 77X are different than the 777s you're used to, right? Specifically, these are quieter...
A318/19/20/21, A300, A332/3, A343/6, A388, L1011, DC-9, DC-10, MD-11, MD-80, B722, B732/3/4/5/7/8/9, B743/4/4M, B752/3, B762/3/4, B772/E/W, B788/9, F-100, CRJ-200/700/900, ERJ-135/145/175/190, DH-8, ATR-72, DO-328, BAE-146
JeremyB
Fri Jan 24, 2020 9:02 pm
Well we at least heard a tripple 7 take off just now... not the one we are waiting for but still
Noshow
Fri Jan 24, 2020 9:03 pm
Gusting 34. No way today.
AA777223
Geez, you'd think they would use a camera with a little bit of a stronger mount. Watching this, I'm gonna need a Dramamine.
boondoggle
Fri Jan 24, 2020 9:05 pm
If they have a window of time to do this, and they need the winds below 10 kts, it ain't happening today folks....just not gonna happen. Not sure what Boeing management was smoking to think it would happen today. But hey, at least that news helicopter is getting TONS if file footage of the newest Boeing aircraft sitting on taxiway!!
Blasst
Fri Jan 24, 2020 9:07 pm
I have been watching the KOMO news live feed also, as it is a bit better with the video stabilization
gatibosgru
Fri Jan 24, 2020 9:08 pm
Can already see the sensationalist headlines tomorrow :duck:
@DadCelo
E90SLAM
Gusting 34 kts...not going to happen today
Strato2
If the plane does not fly today it will another PR black eye for Boeing so I presume they will fly regardless of what their procedures say.
Opus99
They should just wrap this up
ikolkyo
Fri Jan 24, 2020 9:09 pm
22 gusting 34, 20 minutes until the window is shut. Good luck.
Noshow
Wind 22 gusts 34. Too much.
It's not a shame to not fly today.
InThrustWeTrust
Two hours ago I saw à FedEx van pass i the backround , that was funny...zzzzzzzzzzzzzzzz
