asuflyer
Icelandair FI529 landing incident at KEF
Fri Feb 07, 2020 5:00 pm
An Icelandair 757 TF-FIA operating FI529 from TXL suffered a right main landing gear collapse upon landing. Not much is known yet about evacuation or if there were any injuries.
https://www.ruv.is/frett/vidbunadur-veg ... hjolabunad
enilria
Re: Icelandair FI529 landing incident at KEF
Fri Feb 07, 2020 5:06 pm
Do we think the plane suffered serious damage? I imagine it doesn’t take much to “total” a 757.
gatibosgru
Fri Feb 07, 2020 5:12 pm
Ouch! How's FI doing on capacity without the MAX? Hopefully this one won't be out of service for long.
@DadCelo
dc855
Fri Feb 07, 2020 5:16 pm
This certainly won't help with their capacity issues but they should manage as long as it is back before the summer season starts. At "only" 19,5 years of age this is actually one of their youngest 757s.
BravoEcho757
Fri Feb 07, 2020 5:17 pm
Good landing, but since it can't be used again for a while it falls just short of the great landing threshold. :D
CO764
Fri Feb 07, 2020 5:18 pm
I suspect it's weather-related. Current METAR: BIKF 071700Z 13042G58KT 6000 -RA BR SCT009 BKN013 BKN039 06/06 Q0965. Those winds are insane.
CO764
Fri Feb 07, 2020 5:21 pm
Also, AY933 (FIN4XP) bound for Keflavik seems to be turning around and heading for Scotland since I suppose Runway 11 is still closed.
SASViking
Fri Feb 07, 2020 5:25 pm
A Dash 8 in disguise as a 757. Hopefully everyone onboard are safe and unhurt
Types flown: A319, A320, A32N, A321, A332, A333, A343, AT43, AT75, AT76, B717, B732, B735, B736, B737, B738, B752, B753, CRJ9, DC10, DH4D, DHC3, E135, E145, E175, E190, E195, F100, MD11, MD81, MD82, MD87, RJ1H
MIflyer12
Fri Feb 07, 2020 5:29 pm
I can think it would take a bit to total a 20-year old 757, as demonstrated in this long thread: viewtopic.php?t=1429525
ericm2031
Fri Feb 07, 2020 5:34 pm
Doesn't look too bad besides for the engine
SpaceshipDC10
Fri Feb 07, 2020 5:42 pm
As does Wizz SVG-KEF flight.
N14AZ
Fri Feb 07, 2020 5:43 pm
I would hope there was no evacuation at all. An evacuation might have led to injuries whereas it doesn’t look as if it was necessary to evacuate. But okay, it’s easy to say this in hindsight.
737max8
Fri Feb 07, 2020 5:52 pm
Yikes, just visited KEF last weekend and the weather was gorgeous.
Side note - does anyone know why TF-FIC has no blue belly? Flew that 757 both ways ORD-KEF-ORD
The thoughts and opinions expressed in my comments do not represent that of any airline or affiliate.
Flown on: 717 733 734 735 736 737 738 739 7M8 744 744ER 752 753 762 763 772 773ER 788 789 A220 A319/20/21 A332 A333 A339 A343 A346 A359 A388
asuflyer
Fri Feb 07, 2020 5:59 pm
Apparently pax are still in the aircraft, it is too windy to use jetbridges at the moment.
eaa3
Fri Feb 07, 2020 6:06 pm
No, they were offloaded right away. People on other aircraft are still waiting.
SASViking
Simply because they haven't bothered painting it. When it came to FI it was operated on behalf of UN (United Nations) in white with UN titles. The aircraft has also been leased to Air Niugini since also in white with Air Niugini titles
akb88
Fri Feb 07, 2020 7:29 pm
Weather has been very unruly at KEF lately, a lot of cancellations.
Here are some photos from the scene. https://www.dv.is/frettir/2020/2/7/hjol ... il-ovissa/
FlyingMSY
Fri Feb 07, 2020 7:37 pm
Gear looks like it's been twisted towards the wing, seems more severe than first glance.
737max8
Fri Feb 07, 2020 9:48 pm
Thanks for the update. I find Icelandair such an interesting carrier.
hvusslax
Sat Feb 08, 2020 6:39 am
It may have something to do with it but according to the passengers on board, there was nothing unusual about the initial touch on the ground. They did not feel anything until the engine touched ground later in the landing run.
ba9216c
Sat Feb 08, 2020 7:24 am
I would assume it was a hard landing or severe cross wind at touchdown. The gear is designed to shear off under such loads rather then then puncturing a fuel tank. The BA777 at Heathrow was an example of this.
factsonly
Sat Feb 08, 2020 7:48 am
AY993 A321 OH-LZR diverted to EDI, a 3hrs.30 min. flight became a 4hr. 35 min flight time.
https://www.flightradar24.com/data/flig ... 3#23c98b83
bennett123
Sat Feb 08, 2020 7:51 am
The B757 looks in good shape, apart from the engine. However it’s not clear what state the undercarriage is in. Also what stress will have been exerted on the wing spars?.
What is that hanging down from the wing root.
arcticcruiser
Sat Feb 08, 2020 9:10 am
The main gear door and the landing gear side brace.
Sat Feb 08, 2020 10:37 am
The pilots wrote up in the maintenance log that it appeared to be sluggish to taxi, always wanting to go to the right, lots of rudder and nose tiller require, higher than normal amount of thrust to move forward. Apart from that its a good ship.;)
mm320cap
Sat Feb 08, 2020 10:10 pm
Video from the cabin of the approach. Doesn’t appear to have been caused by a hard landing.
https://mobile.twitter.com/breakingavne ... 2934200320
bennett123
Sat Feb 08, 2020 11:00 pm
My impression was that it floated, and on landing it bounced.
o0OOO0oChris
Sun Feb 09, 2020 1:15 am
Avherald updated it`s article, adding a better photo of the landing gear:
http://avherald.com/h?article=4d2fd39b&opt=0
Pretty obvious that a bolt is missing.
Also mentions that this bird had a landing gear change mid January 2020.
bennett123
Wed Feb 26, 2020 5:24 pm
Any more news?.
hvusslax
Mon Apr 06, 2020 2:30 pm
A interim report is out about this incident: http://www.rnsa.is/media/4633/interim-r ... ikf-r1.pdf
The result is basically that a wrong sized nut was in the landing gear that failed.
AirlineCritic
Mon Apr 06, 2020 5:50 pm
Interesting. I didn't realise that aircraft can be fitted with undersize nuts & threads in maintenance, I suppose due to re-threading bolts? Clearly an opportunity for an error...
Wacker1000
Mon Apr 06, 2020 6:17 pm
It is a very common process on landing gear components. Overhaul facilities and operators often have a method to identify resized threads (the yellow paint is likely that indicator). There is no more opportunity for error than if you were installing a regular nut since you are supposed to install the part IAW some sort of document and the document identifies the undersized nut for a 2nd undersized thread. Unfortunately someone didn't follow the manual or policy.
