Special
New York to London - New Subsonic Flight Time Record
Sun Feb 09, 2020 6:28 am
As result of Storm Ciara, BA112 took approximately 4 hours and 56 minutes (according to Flightradar24) which breaks the previous record held by Norwegian 787-9 which took 5 hours and 13 minutes roughly two years ago. Also VS4 was close too (flight time of 4 hours and 58 minutes).
Reason: Updated title for clarity
Ishrion
Re: New York to London - New Flight Time Record
VS4 was literally ONE minute off at 4:57.
https://www.flightradar24.com/data/flights/vs4#23cda8ed
Ishrion
Sun Feb 09, 2020 6:55 am
VS46 just did it in 4 hours and 59 minutes. Three flights have now done it under 5 hours.
https://www.flightradar24.com/data/flights/vs46
Fuling
Sun Feb 09, 2020 7:41 am
Impressive! Can you imagine how tight together the meal services must have been though! (1.5 hours maybe??) I'm aware breakfast is a quick run-through-the-cabin affair, but still, WOW!
FGITD
Sun Feb 09, 2020 9:00 am
I'll be more impressed when someone breaks the 2h52m mark.
LGWGate49
Sun Feb 09, 2020 9:01 am
I was following Norwegian DI7016 on Flightradar24 (aircraft G-CKWT), and she would have broken it at 4 hours 54 minutes but had to do a go-around (due to high winds!).
Oddly she is currently now heading over the North Sea back at 37,000ft, so will keep an eye where she is being diverted to.
Look for the ridiculous in everything, and you will find it
bcworld
Sun Feb 09, 2020 9:02 am
DI7018 diverted to CPH.
LAX772LR
Sun Feb 09, 2020 9:57 am
The word "subsonic" should appear somewhere in this title, and obviously Concorde continues to hold the ACTUAL record.
jules48
Sun Feb 09, 2020 10:35 am
NZ2 from Los Angeles 90 minutes early.Flying time 9hrs 20 approx
Flanker7
Sun Feb 09, 2020 10:47 am
KL644 arrived 1 1/2 hours ahead of schedule making record time
Flying blue only if possible
BlueberryWheats
Or subsonic civilian. I think the Blackbird beat the Concorde. :stirthepot:
The tallest blade of grass is the first to be cut.
mcogator
Sun Feb 09, 2020 11:15 am
Yes, the Blackbird holds the actual flight record at 1 hour, 54 minutes, 56.4 seconds.
“Traveling – it leaves you speechless, then turns you into a storyteller.” – Ibn Battuta
Arion640
Sun Feb 09, 2020 12:47 pm
You are incorrect. The blackbird holds the ACTUAL record.
zkojq
Re: New York to London - New Subsonic Flight Time Record
Sun Feb 09, 2020 1:01 pm
A Ukraine 777 from JFK crossed just north of Bristol at 4:35. That's some serious tailwinds.
First to fly the 787-9
JibberJim
Sun Feb 09, 2020 1:41 pm
What airports did it use? 'cos the typical reports say such things as:
https://www.wired.com/2010/09/0901sr-71 ... ic-record/
Wired wrote:
For the New York–to–London flight, Sullivan flew the SR-71 through an imaginary gate 80,000 feet above New York. Heading east, he flew 3,461.528 miles until passing through another imaginary gate over London. The the trip lasted only 1 hour, 54 minutes, 56.4 seconds.
Where not having to take off or land makes a pretty significant difference to your speed...
PlymSpotter
Sun Feb 09, 2020 1:52 pm
With significant short and long haul cancellations at LHR, those flights which can set it down first time have a slight advantage over other days, as there is less traffic and shorter / no holds to factor in.
CarbonFibre
Sun Feb 09, 2020 2:22 pm
The BBC couldn't even be bothered to find a 747 photo. https://www.bbc.co.uk/news/uk-england-london-51433720
washingtonflyer
Sun Feb 09, 2020 3:28 pm
Its made CNN.
https://www.cnn.com/travel/article/brit ... index.html
Absolutely absurd flight time. Faster than going from the east coast USA to west coast.
ltbewr
Sun Feb 09, 2020 3:56 pm
Of course, the westbound flights at the same time were practically going in reverse, taking and hour or more than normal and some narrow-bodies needing a fuel stop in eastern Canada. Heck, that is less time JFK-LHR than sometimes going westbound EWR/JFK-LAX. On those short flights, one barely had time to take nap and your might arrive well before you can check in at your hotel.
dmstorm22
Sun Feb 09, 2020 4:27 pm
Yeah, while it is cool to see JFK-LHR done it that speed, I would have HATED to be on that flight. What little rest you could potentially have gets cut by a good 90 minutes.
Back when I was taking SFO-EWR weekly it would get me so, so angry how basically every week there would always be good tailwinds.
Give me a nice little headwind on those short red-eyes for once!
StrandedAtMKG
Imagine being a family of American tourists (Norwegian's core clientele), maybe Mom and Dad, a couple teenagers, and Grandma visiting London for Grandma's 75th birthday, and instead of dropping you off into the waiting arms of Cousin Arthur and his wife Jennifer in London they divert you to Copenhagen, half a continent away.
AVLAirlineFreq
Sun Feb 09, 2020 4:29 pm
Westbound transatlantic flights having to take a much more northerly track today:
https://twitter.com/flightradar24/statu ... 9335919616
Mboyle1988
Sun Feb 09, 2020 5:13 pm
It would be so much more convenient if the prevailing winds were in the opposite direction so the red eye flights were longer and the daytime flights shorter.
shamrock350
Sun Feb 09, 2020 5:33 pm
Meanwhile Aer Lingus flight EI136 BOS-DUB (A333) made it across the Atlantic in 4 hrs 49 mins last night but it was Shannon that set the fastest time for Aer Lingus this week, EI134 BOS-SNN (A321LR) made it across in just 4 hrs 43 mins the night before.
It may not be the traditional New York to London routing but impressive all the same.
glideslope
Sun Feb 09, 2020 5:56 pm
Nice to see the Queen retake the record. Hope it holds up for long time.
jetmatt777
Sun Feb 09, 2020 6:40 pm
This always makes me wonder if airlines would be able to pull off a "sleeper" service. Intentionally flying a slower, longer route to add time to the flight. We have some redeyes out of DEN that depart pretty late in the night for the only purpose of having a 5-6am arrival time. Would be nice to take off earlier and fly slower. I'd take an extra 45 mins of "airplane sleep" over sitting in the bright, sterile concourse hearing announcements every 5 minutes and pondering my existence.
747megatop
Sun Feb 09, 2020 6:45 pm
Well, at that point the plane would have gone supersonic :D and the manufacturer can start marketing the aircraft as such.
mcogator
Sun Feb 09, 2020 6:49 pm
Why does someone need to rest on a < 5 hour daytime flight? I'm on LAX-MCO at least monthly, and unless I take the redeye, rest is not on my mind.
LAX772LR
Sun Feb 09, 2020 6:57 pm
Meh.
While no one's going to contend that Concorde could match a Blackbird in speed, it's sorta anecdotal to use that flight as a comparative record when the latter was already at speed, and at altitude, before and after the timing was started and stopped.
Takeoff and landing were not included, as it has in essentially every other flight claiming a record.
OBVIOUS ANSWER BEING: maybe others have difference preferences than you? :scratchchin:
cpd
Sun Feb 09, 2020 7:27 pm
It is still two hours slower than the record, so it is not the record holder of civil passenger carrying aircraft.
Perhaps this will change if the Boeing 969 reaches production, it might be able to do the journey in less than three hours. Doubtful - can’t see anything of the sort arriving in ten years. :(
And the SR-71 would still likely beat Concorde if takeoff and landing was included (from KJFK TO EGLL), but it wouldn’t be as big a time difference. The Blackbird would probably immediately refuel after takeoff (they takeoff with a light fuel load normally), while Concorde can go pretty much flat out right away if cleared to do so (which I think it did going from NY).
Arion640
Sun Feb 09, 2020 7:45 pm
Meh.
Doesn’t change a thing. The blackbird still holds the fastest crossing, regardless of wherever it took off from.
cpd
Sun Feb 09, 2020 7:59 pm
Meh.
It does, they must both takeoff and land at the same point or the timing is pointless. Removing the takeoff portion saves a huge chunk of time. It’s like saying a car is faster to 200km/h when one car starts from 0 and the other is already doing 100. Not comparable.
LAX772LR
Sun Feb 09, 2020 8:01 pm
As well as approach and decell.
It most definitely changes "a thing." :roll:
rlwynn
Sun Feb 09, 2020 8:03 pm
I was on AA 70 DFW-FRA today. I Bet we broke that record.
I can drive faster than you
global2
Sun Feb 09, 2020 8:05 pm
It's nice to see that that 50 years after its maiden voyage (also JFK-LHR) the Queen of the Skies is still making news.
cpd
Sun Feb 09, 2020 8:06 pm
Did you time it?
I’m sure you could chop the decel time if needed. “Falling off the wall”.... (some of you will understand what that means).
Arion640
Sun Feb 09, 2020 8:17 pm
The blackbird still holds the fastest crossing, regardless of where it took off.
LAX772LR
Sun Feb 09, 2020 8:33 pm
So I guess the whole concept of anecdotal comparison is lost on you? Fair enough.
While we're at it, let's call Boeing's 77L marketing flight the "longest passenger service," and the Operation Solomon 747 the "busiest pax service" ....
Turnhouse1
Sun Feb 09, 2020 8:38 pm
Where did the Blackbird take off? Where did the Blackbird Land? What was the elapsed time?
glideslope
Sun Feb 09, 2020 8:41 pm
Yes, I should have clarified as Subsonic. I simply assumed that would be how it was read.
n729pa
Sun Feb 09, 2020 8:50 pm
How much were the westbound flights slowed down? Must have been hard going. I had a HAM-FRA flight a few years ago flying into a strong storm headwind like this and it was quite uncomfortable flight. About the only time I was glad to get off a plane.
jetwet1
Sun Feb 09, 2020 9:25 pm
Question....As these flights landed way early, how does that work with the 6am "curfew", I know there are a limited number of slots before 6am, but do VS/BA have access to those?
hOMSaR
Sun Feb 09, 2020 9:30 pm
Who’s talking about rest on a daytime flight? BA112 is scheduled to depart at 6:30 pm NY time and arrive at 6:25 am London time the next day. That’s the epitome of a redeye flight, just like most eastbound transatlantic flights.
I was raised by a cup of coffee.
MIflyer12
Sun Feb 09, 2020 9:39 pm
Airspeeds weren't any higher than normal but I suppose that 'Eastbound TATL tail winds strong yesterday' lacks the drama sought by the OP.
Arion640
Sun Feb 09, 2020 9:43 pm
It still doesn’t change the fact the blackbird holds the fastest transatlantic crossing time.
fxramper
Sun Feb 09, 2020 9:50 pm
Also interested how they landed before the 0600 curfew. Many times my flights have slowed down or delayed in NYC because we'd land too early.
BA777FO
Sun Feb 09, 2020 10:01 pm
The curfew can be eliminated in the event of forecast disruption such as when the airport expects LVPs to be in force or strong winds from the storm such as today.
Additionally, some airlines, of which BA is one, have a pool of night jet movements which can be substituted between flights. For example, if a flight that was due to land before 6am was delayed, that night jet movement can be allocated to another service providing the overall quota for the season is not exceeded.
We had a groundspeed in excess of 670kts coming back the other night over the Atlantic - 11 miles per minute! The jetstreams were getting up to about 215 knots.
LAX772LR
Sun Feb 09, 2020 10:04 pm
(see? Others can repeat the same thing and hope it elicits a different response too) :roll:
There are exceptions for emergencies and atypical conditions.
26point2
Sun Feb 09, 2020 10:05 pm
What about the poor buggers going the other direction? A different sort of record I suppose
ydahman
Sun Feb 09, 2020 10:15 pm
I read the article on CNN.com and I think the report is inaccurate when they stated that the flight time from JFK to LHR was about 2 hours shorter than normal. I dont think the flight takes more than 6 hours on that route. I actually flew IAD to LHR in about 6 hours in the past. It takes about 7 hours the other way around. Does anyone else agree?
