enilria
OAG Changes 2/9/2020:NK Cuts BOSRDU,DEN-DFW/MSY,MSP-DFW/IAH,Adds LGAMCO;AS Adds PAEBOI;MU Ends HNLPVG,SFOTAO;SA IAD?
Sun Feb 09, 2020 12:39 pm
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
3M BHB-BOS SEP 0.5>2[0.2] OCT 0>0.9[0]
*3M ELH-MCO MAY 0.5>0.1[0.4] JUN 0.4>0[0.4] JUL 0.4>0[0.4] AUG 0.4>0[0.3] SEP 0.4>0[0] OCT 0.4>0[0] NOV 0.4>0[0.4]
3M FLL-FPO APR 0.7>1.0[3] MAY 0.7>1.0[3] JUN 0.7>1.0[3] JUL 0.7>1.0[2] AUG 0.7>1.0[2] SEP 0.7>1.0[3] OCT 0.7>1.0[3] NOV 0.7>1.0[0.8]
9X HNL-JHM MAY 0.5>5[7] JUN 0>5[0] JUL 0>5[0] AUG 0>0.5[0]
9X HNL-LUP MAY 0.1>0.8[0.9] JUN 0>0.9[0] JUL 0>0.9[0]
9X HNL-MKK MAY 0.8>9[11] JUN 0>9[0] JUL 0>9[0] AUG 0>0.8[0]
9X HNL-OGG MAY 0.5>5[3] JUN 0>5[0] JUL 0>5[0] AUG 0>0.5[0]
9X HNM-OGG MAY 0.2>2[1.9] JUN 0>2[0] JUL 0>2[0] AUG 0>0.2[0]
9X KOA-OGG MAY 1.1>12[12] JUN 0>12[0] JUL 0>12[0] AUG 0>1.1[0]
9X LNY-OGG MAY 0.2>2[0] JUN 0>2[0] JUL 0>2[0] AUG 0>0.2[0]
9X LUP-MKK MAY 0.1>1.0[0.9] JUN 0>1.0[0] JUL 0>1.0[0]
9X MKK-OGG MAY 0.7>8[10] JUN 0>8[0] JUL 0>8[0] AUG 0>0.7[0]
9X MUE-OGG MAY 0.2>2[1.9] JUN 0>2[0] JUL 0>2[0] AUG 0>0.2[0]
MAX Cut Extension. JFK Once again clipped. Playing with fire IMHO.
AA ABI-DFW MAY 7>6[7]
AA ABQ-LAX MAY 3>4[3]
AA AMA-DFW MAY 8>7[8]
AA ATL-DCA MAY 4>3[4]
AA ATL-MIA MAY 9>8[8]
AA ATL-ORD MAY 5>4[4] SEP 5>6[5] OCT 5>6[5] NOV 5>6[4]
AA ATL-PHL MAY 6>4[6]
AA ATL-PHX MAY 1.8>1.1[1.7]
AA AUS-LAX MAY 3>4[3] SEP 3>4[4] OCT 3>4[4] NOV 3>4[4]
AA AUS-ORD MAY 4>3[4]
AA AUS-PHL MAY 3>2[2.0]
AA AVL-LGA MAY 0.3>0.9[0.3]
AA BDL-ORD MAY 4>5[5] SEP 4>5[4] OCT 4>5[4] NOV 4>5[4]
AA BDL-PHL MAY 6>5[4]
AA BGR-DCA MAY 3>2[3]
AA BNA-LAX MAY 2>3[1.8]
Bulking up to defend MIA against DL growth?
*AA BNA-MIA JUN 3>4[3] JUL 3>4[3] AUG 3>4[3] SEP 3>4[2] OCT 3>4[2] NOV 3>4[2]
AA BNA-ORD SEP 8>9[9] OCT 8>9[9] NOV 8>9[8]
AA BNA-PHL MAY 6>5[5]
AA BOI-DFW MAY 3>2[1.9]
AA BOS-DCA MAY 13>10[14]
AA BOS-JFK MAY 5>3[1.2]
AA BOS-LAX MAY 5>4[5]
AA BOS-LGA MAY 11>10[12]
*AA BOS-MIA JUN 7>8[6] JUL 7>8[6]
AA BOS-ORD MAY 9>7[8] SEP 9>8[9] OCT 9>8[9] NOV 9>8[7]
AA BOS-PHL MAY 11>10[11] SEP 11>12[9] OCT 11>12[9] NOV 11>12[10]
AA BRO-DFW MAY 4>3[4]
AA BTR-DFW MAY 7>6[5]
AA BTV-PHL MAY 5>4[4]
AA BUF-CLT MAY 4>3[3]
AA BWI-CLT MAY 9>8[7]
AA BWI-MIA MAY 3>1.1[3]
AA BWI-PHL MAY 3>4[3]
AA CID-ORD SEP 5>6[5] OCT 5>6[6] NOV 5>6[6]
AA CLE-DCA JUN 3>4[3] JUL 3>4[3] AUG 3>4[3] SEP 3>4[3] OCT 3>4[3] NOV 3>4[3]
AA CLE-DFW MAY 4>3[5]
AA CLT-ECP MAY 2>3[2]
AA CLT-EWR MAY 9>8[8]
AA CLT-FLL MAY 9>8[6]
AA CLT-IAH APR 5>6[6]
AA CLT-JFK MAY 6>5[6]
AA CLT-LAS MAY 6>5[5]
AA CLT-LYH MAY 6>7[6]
AA CLT-MCO MAY 11>12[9]
AA CLT-MDT MAY 5>6[6]
AA CLT-MOB MAY 4>5[4]
AA CLT-PVD APR 4>5[5]
AA CLT-RDU MAY 9>11[9]
AA CLT-ROC MAY 3>4[4]
AA CLT-RSW MAY 4>6[6]
AA CLT-SAV MAY 9>8[9]
AA CLT-SEA MAY 4>3[3]
AA CLT-SGF MAY 3>4[4]
AA CLT-SRQ MAY 4>5[4]
AA CLT-STT AUG 1.0>0.6[0.9]
AA CLT-SXM AUG 2>1.2[1.6] SEP 0.6>0.1[0.2]
AA CLT-TRI MAY 5>4[5]
AA CMH-DFW MAY 5>4[4]
AA CMH-JFK MAY 1.8>1.0[1.0]
AA CMH-LAX MAY 1.8>1.0[1.7] AUG 2>1.5[1.8] SEP 2>1.0[1.6] OCT 2>1.0[1.5] NOV 2>1.0[1.6]
AA CMH-PHL MAY 6>5[6]
AA CUN-JFK MAY 1.2>2[1.1]
AA CVG-DCA MAY 3>1.8[3]
AA CVG-PHL MAY 6>5[5]
AA DAY-DCA MAY 4>3[3]
AA DAY-ORD SEP 4>5[5] OCT 4>5[5] NOV 4>5[5]
AA DCA-JFK MAY 3>2[3]
*AA DCA-MKE JUL 0>0.3[0]
AA DCA-YYZ MAY 3>2.0[1.9]
AA DEN-DFW MAY 10>9[9]
AA DEN-MIA MAY 1.8>1.0[1.7]
AA DEN-ORD SEP 4>5[5] OCT 4>5[5] NOV 4>5[4]
AA DEN-PHL MAY 3>1.4[3]
AA DFW-DTW MAY 6>5[5]
AA DFW-FSD MAY 2>3[2]
AA DFW-GSO MAY 2>3[3]
AA DFW-IAH MAY 10>9[9]
AA DFW-JAX MAY 6>5[5]
AA DFW-JFK MAY 4>1.6[4]
AA DFW-LAS MAY 12>11[10]
AA DFW-LAW MAY 4>3[4]
AA DFW-LAX MAY 15>14[15]
AA DFW-LGA MAY 12>11[12]
AA DFW-MAF MAY 8>7[7]
AA DFW-MSP MAY 6>5[6]
AA DFW-ONT MAY 7>6[6]
AA DFW-ORD MAY 14>13[14]
AA DFW-PDX MAY 5>4[4]
*AA DFW-PEK MAR 1.0>0.1[1.0]
AA DFW-PHL MAY 9>7[9]
AA DFW-PSP MAY 2>3[2]
*AA DFW-PVG MAR 1.0>0.1[1.0]
AA DFW-SAT MAY 11>12[11]
AA DFW-SBP MAY 1.8>1.1[1.0]
AA DFW-SEA MAY 9>8[9]
AA DFW-SLC MAY 7>5[6]
AA DFW-SPS MAY 4>3[4]
AA DFW-YVR JUN 2>3[3] JUL 2>3[3] AUG 2>3[3] SEP 2>3[1.8]
AA DSM-ORD SEP 7>6[7] OCT 7>6[7] NOV 7>6[6]
AA DSM-PHL MAY 1.8>1.0[1.8]
AA DTW-LGA SEP 4>5[4] OCT 4>5[4] NOV 4>5[4]
AA DTW-ORD SEP 7>6[7] OCT 7>6[8] NOV 7>6[6]
AA DTW-PHL MAY 6>5[5]
AA EWR-PHX MAY 4>3[3]
Seeing some recent EYW capacity rolling back now
*AA EYW-PHL AUG 1.0>0.5[0.2] SEP 0.3>0[0]
AA FLL-PHL MAY 5>4[4]
AA FNT-ORD SEP 3>4[4] OCT 3>4[4] NOV 3>4[4]
AA FWA-PHL MAY 1.8>1.0[2.0]
AA GRR-ORD SEP 7>8[7] OCT 7>8[8] NOV 7>8[7]
AA GRR-PHL MAY 3>1.9[3]
AA GSP-ORD MAY 2>3[2] AUG 1.8>2[3] SEP 1.9>3[2] OCT 1.8>3[1.7] NOV 1.9>3[1.8]
AA HKG-LAX MAR 1.0>0.1[1.0]
*AA HNL-PHX JUN 2>1.1[2] JUL 2>1.0[2] AUG 2>1.0[2] SEP 2>1.0[2]
AA HVN-PHL MAY 3>2.0[3]
AA IAH-MIA MAY 5>4[5]
AA IAH-PHL MAY 4>3[3]
AA ILM-PHL MAY 3>4[3]
AA IND-LAX AUG 2>1.5[1.0] SEP 2>1.0[1.0] OCT 2>1.0[1.0] NOV 2>1.0[1.2]
AA IPT-PHL MAY 2>1.8[3] JUN 3>1.9[3] JUL 3>1.9[3] AUG 3>1.8[3] SEP 3>1.9[2] OCT 3>1.8[2] NOV 3>1.9[1.9]
AA JAX-ORD MAY 3>1.9[3] SEP 3>1.9[1.9] OCT 3>1.9[2] NOV 3>1.9[2]
AA JFK-LAS MAY 1.6>0[1.1]
AA JFK-MBJ AUG 1.0>0.6[0] SEP 1.0>0.8[0]
AA JFK-MIA MAY 7>6[5]
AA JFK-ORD MAY 3>1.0[1.5]
AA JFK-PHX MAY 6>5[4]
AA JFK-PIT MAY 3>1.0[1.0]
AA JFK-RIC MAY 3>1.0[0]
AA JFK-SAN MAY 0.8>0[0.9]
AA JFK-YUL MAY 1.8>1.0[1.1]
AA LAN-ORD MAY 2>3[2]
AA LAS-LAX MAY 7>8[7]
AA LAS-PHL MAY 4>2[4]
AA LAX-MCO SEP 4>3[2] OCT 4>3[1.9] NOV 4>3[3]
AA LAX-PHL MAY 6>7[7] JUN 6>7[7] JUL 6>7[7] AUG 6>7[7] SEP 6>7[6] OCT 6>7[6] NOV 6>7[6]
AA LAX-SLC MAY 4>3[3]
AA LAX-TUS MAY 3>4[3]
AA LAX-YVR SEP 2>3[2] OCT 2>3[2] NOV 2>3[1.9]
AA LGA-MIA MAY 12>11[10]
AA LGA-MSP MAY 2>1.5[1.8]
AA LGA-ORD MAY 12>10[12]
AA LGA-ORF MAY 3>1.8[3]
AA LGA-STL SEP 5>4[4] OCT 5>4[4] NOV 5>4[3]
AA LIT-ORD MAY 3>4[4]
Hourly?!? DL response obviously.
**AA MCO-MIA JUN 7>12[7] JUL 7>12[6] AUG 7>12[6] SEP 7>12[6] OCT 7>12[7] NOV 7>12[6]
AA MCO-ORD MAR 5>6[5] SEP 5>4[4] OCT 5>4[4] NOV 5>4[4]
AA MCO-PHL MAY 7>6[8]
AA MEM-ORD MAY 4>5[5] SEP 4>5[4]
AA MHK-ORD MAY 3>2[3]
AA MIA-ORD MAY 9>8[7]
AA MIA-PHL MAY 6>4[6]
AA MIA-PIT MAY 2>3[3]
*AA MIA-RDU JUN 3>5[3] JUL 3>5[3] AUG 3>5[3] SEP 3>5[3] OCT 3>5[4] NOV 3>5[4]
AA MIA-SFO MAY 4>3[2]
*AA MIA-TPA MAY 6>5[6] JUN 7>8[6] JUL 7>8[6] AUG 7>8[6] SEP 7>8[5] OCT 7>8[5] NOV 7>8[5]
AA MIA-YYZ MAY 3>1.0[3]
AA MKE-PHL MAY 5>4[4]
AA MSP-ORD MAY 7>6[6]
AA MSP-PHL MAY 3>1.7[3]
AA MSP-PHX MAY 4>3[3]
AA MSY-ORD MAY 3>2[1.8] SEP 3>1.9[2] OCT 3>1.7[3] NOV 1.9>0.9[2]
AA MSY-PHL MAY 3>1.0[3]
AA OGG-PHX JUN 1.9>1.0[1.9] JUL 2>1.0[2] AUG 1.6>1.0[1.7]
AA OKC-PHL MAY 1.8>1.0[1.8]
AA OMA-PHL MAY 1.8>1.0[2.0]
AA ORD-ORF AUG 1.8>2[3] SEP 1.9>3[2] OCT 1.8>3[2] NOV 1.9>3[1.9]
AA ORD-PBI AUG 1.4>1.0[1.0] SEP 2>1.0[1.0] OCT 2>1.0[1.6] NOV 2>1.0[2]
AA ORD-PHL MAY 9>7[9] JUL 9>10[9] AUG 9>10[9] SEP 9>10[8] OCT 9>10[9] NOV 9>10[8]
AA ORD-PVD MAY 3>2[3]
AA ORD-RSW AUG 2>1.5[1.0] SEP 3>1.0[1.0] OCT 3>1.0[1.9] NOV 4>1.0[3]
AA ORD-SJC MAY 1.7>1.0[1.7] AUG 1.9>2[2] SEP 1.9>3[1.7] OCT 1.9>3[1.8] NOV 1.9>3[2]
AA ORD-SNA SEP 4>5[4] OCT 4>5[4] NOV 4>5[4]
AA ORD-SUX MAY 3>1.9[3] SEP 3>1.9[3] OCT 3>1.8[3] NOV 3>1.9[3]
AA ORD-TPA MAR 4>5[3]
AA ORD-TUL MAY 2>3[3] SEP 2>3[3] OCT 2>3[3] NOV 2>3[3]
AA ORD-TVC SEP 5>6[5] OCT 5>6[5] NOV 5>6[5]
AA ORD-TYS MAY 3>4[4]
AA PBI-PHL MAY 5>3[3]
When will PUJ recover?
*AA PHL-PUJ AUG 0.5>0.2[1.7] SEP 1.0>0.1[1.0] OCT 1.2>0.2[1.1] NOV 1.1>0.5[1.1]
AA PHL-RIC MAY 7>6[6]
AA PHL-ROC MAY 6>5[6]
AA PHL-SAN MAY 3>1.9[3] AUG 3>4[3] SEP 3>4[2] OCT 3>4[2] NOV 3>4[1.9]
AA PHL-SAT MAY 0.8>0[1.0]
AA PHL-SDF MAY 4>2.0[3]
AA PHL-SFO MAY 5>4[5]
AA PHL-SRQ AUG 1.0>0.5[0.3] SEP 0.3>0[0]
AA PHL-TPA MAY 5>4[6]
AA PHX-SEA MAY 4>3[3]
AA PHX-SFO MAY 5>4[5]
AA PHX-SNA MAY 5>6[5]
AA PHX-TUS MAY 6>7[7]
AC CLE-YYZ MAY 3>4[4] JUN 3>4[4]
AC EWR-YVR JUN 1.3>1.0[1.0]
AC MSP-YYZ MAY 4>3[3] JUN 4>3[3] JUL 4>3[3] AUG 4>3[3] SEP 4>3[4] OCT 4>3[4]
AC MSY-YYZ JUN 1.5>1.0[1.0]
AC PDX-YYZ MAY 0.5>0[0]
AC SFO-YYZ MAY 5>4[4] JUN 5>4[5]
Interesting. TCB has preclearance?
*AJ FXE-TCB MAR 0>0.4[0] APR 0>0.4[0] MAY 0>0.5[0] JUN 0>0.4[0] JUL 0>0.5[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0]
AM BJX-LAX JUN 0>0.4[1.0] AUG 0>0.5[0.8]
*AM DTW-MEX JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[0] SEP 1.0>0[0] OCT 1.0>0[0] NOV 1.0>0[0]
AM FAT-GDL JUN 0.7>1.2[0.9] JUL 0.7>1.9[1.0] AUG 0.7>1.3[1.0]
AM GDL-LAX JUN 1.0>1.4[1.5] JUL 1.0>2[1.8] AUG 1.0>1.4[1.3]
AM GDL-SMF JUN 1.0>1.4[1.0] JUL 1.0>2[1.0] AUG 1.0>1.5[1.0]
AM JFK-MEX JUN 4>3[4] JUL 4>3[4] AUG 4>3[4] SEP 4>3[3] OCT 4>3[2] NOV 4>3[2]
AM LAX-MEX SEP 5>4[2] OCT 5>4[1.1] NOV 5>4[1.1]
AM MCO-MTY JUN 0>0.3[0.2] JUL 0>0.5[0.4] AUG 0>0.2[0.3]
AM MEX-MIA JUL 2>3[3] AUG 2>3[3] NOV 2>3[2]
AM MEX-SAT JUN 1.0>1.4[1.0] JUL 1.0>1.9[1.0] AUG 1.0>1.3[1.0]
AM MEX-SFO JUN 2>3[3] JUL 2>4[3] AUG 2>3[3]
AS ANC-SFO SEP 1.0>0.3[0] OCT 0.2>0[0]
AS BIL-PDX JUN 2>1.4[1.0]
How can this be good? I wonder if this blocks the prime "slot" opened by UA ending SFO.
**AS BOI-PAE JUN 0>0.4[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>1.0[0]
AS KOA-SEA JUL 2>3[2] AUG 2>3[1.9] SEP 2>3[1.4] OCT 2>3[2] NOV 2>3[2]
AS MSO-PDX MAY 1.6>2[1.0] JUN 1.0>1.6[1.0]
AS PDX-SLC JUN 5>4[3] JUL 5>4[3]
AV JFK-MDE APR 1.0>0.6[1.0] MAY 1.0>0.5[1.0] JUN 1.0>0.6[1.0]
B6 schedule extension. Note that partial months make it hard to interpret.
B6 ABQ-JFK SEP 0.3>1.0[0.8] OCT 0>0.8[0.9]
B6 ACK-BOS SEP 0.4>1.3[0.8]
B6 ACK-DCA SEP 0.1>0.4[0.3] OCT 0>0.3[0.1]
B6 ACK-HPN SEP 0.2>0.6[0.7]
B6 ACK-JFK SEP 1.1>3[2] OCT 0>0.7[0.8]
B6 ALB-FLL SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 ALB-MCO SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 ATL-BOS SEP 1.3>4[4] OCT 0>3[4]
B6 ATL-FLL SEP 0.5>2[2] OCT 0>1.5[2]
B6 ATL-JFK SEP 0.5>1.9[2] OCT 0>1.4[2]
B6 ATL-MCO SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 AUA-BOS SEP 0.4>1.6[1.4] OCT 0>1.3[1.6]
B6 AUA-FLL SEP 0.1>0.6[1.0] OCT 0>0.4[1.0]
B6 AUA-JFK JUL 2>3[2] AUG 2>3[2] SEP 0.6>1.6[1.7] OCT 0>1.0[1.9]
B6 AUS-BOS SEP 0.8>3[1.7] OCT 0>2[1.8]
B6 AUS-FLL SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 AUS-JFK SEP 0.5>2[1.9] OCT 0>2[1.8]
B6 AUS-LGB SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 AUS-MCO SEP 0.2>0.9[1.0] OCT 0>0.8[1.0]
B6 BDA-BOS SEP 0.3>1.0[1.0] OCT 0>0.7[1.0]
B6 BDA-JFK SEP 0.5>1.3[2] OCT 0>0.7[1.3]
B6 BDL-FLL SEP 0.5>1.7[1.6] OCT 0>1.2[1.9]
B6 BDL-PBI SEP 0.3>1.0[1.4] OCT 0>0.8[1.4]
B6 BDL-RSW SEP 0>0.7[0.9] OCT 0>0.8[1.0]
B6 BDL-SJU SEP 0.8>1.9[1.1] OCT 0>1.3[1.0]
B6 BDL-TPA SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 BGI-JFK SEP 0.8>2.0[1.7] OCT 0>1.2[1.7]
B6 BNA-BOS SEP 0.5>2[3] OCT 0>2[3]
B6 BNA-FLL SEP 0.3>1.0[1.5] OCT 0>0.8[1.5]
B6 BNA-JFK SEP 0.5>2[0] OCT 0>1.5[0]
B6 BOG-FLL SEP 0.5>1.3[1.0] OCT 0>0.8[1.0]
B6 BOS-BUF SEP 0.8>3[4] OCT 0>2[4]
B6 BOS-BUR SEP 0.3>1.0[0.6] OCT 0>0.8[0.7]
B6 BOS-BWI SEP 1.3>5[5] OCT 0>4[5]
B6 BOS-CHS SEP 0.6>2[3] OCT 0>1.6[2]
B6 BOS-DCA SEP 4>16[13] OCT 0>12[13]
B6 BOS-DEN SEP 0.8>3[1.9] OCT 0>2[1.8]
B6 BOS-DFW SEP 0.5>3[1.9] OCT 0>2[1.8]
B6 BOS-EWR SEP 1.8>6[6] OCT 0>5[6]
B6 BOS-FLL SEP 1.1>5[5] OCT 0>4[6]
B6 BOS-IAH SEP 0.3>1.0[0] OCT 0>0.8[0.2]
B6 BOS-JAX SEP 0.5>1.9[3] OCT 0>1.4[3]
B6 BOS-JFK MAY 5>6[6] SEP 1.6>6[6] OCT 0>5[6]
B6 BOS-LAS SEP 1.1>4[4] OCT 0>3[4]
B6 BOS-LGA SEP 2>9[5] OCT 0>7[5]
B6 BOS-LGB SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 BOS-MBJ SEP 0.1>0.3[0.1] OCT 0>0.2[0.1]
B6 BOS-MCO SEP 1.6>6[6] OCT 0>6[7]
B6 BOS-MSP SEP 0.8>3[3] OCT 0>2[3]
B6 BOS-MSY SEP 0.3>1.7[1.9] OCT 0>1.7[2.0]
B6 BOS-ORD SEP 1.6>5[5] OCT 0>3[5]
B6 BOS-PAP SEP 0.2>0.4[0.3]
B6 BOS-PBI SEP 1.1>4[3] OCT 0>3[4]
B6 BOS-PDX SEP 0.5>1.3[1.1] OCT 0>0.8[1.0]
B6 BOS-PHL SEP 2>7[7] OCT 0>6[7]
B6 BOS-PHX SEP 0.5>1.9[1.0] OCT 0>1.4[1.0]
B6 BOS-PIT SEP 1.2>5[6] OCT 0>4[6]
B6 BOS-RDU SEP 1.6>6[6] OCT 0>4[6]
B6 BOS-RIC SEP 1.0>4[4] OCT 0>3[4]
B6 BOS-ROC SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 BOS-RSW SEP 0.7>3[3] OCT 0>2[3]
B6 BOS-SAV SEP 0.3>1.5[1.6] OCT 0>1.4[1.6]
B6 BOS-SDQ SEP 0.8>1.8[2] OCT 0>0.8[1.5]
B6 BOS-SEA SEP 0.8>3[1.9] OCT 0>1.5[1.9]
B6 BOS-SFO SEP 1.6>6[5] OCT 0>5[6]
B6 BOS-SJC SEP 0.5>1.2[0.8] OCT 0>0.8[0.7]
B6 BOS-SJU MAY 4>3.0[3.0] SEP 1.1>2.5[2.1] OCT 0>2.1[2.2]
B6 BOS-SMF SEP 0.3>0.7[0.1] OCT 0>0.5[0]
B6 BOS-SRQ SEP 0>0.7[0.9] OCT 0>0.8[1.0]
B6 BOS-STI SEP 0.5>1.3[1.2] OCT 0>0.8[1.0]
B6 BOS-SYR SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 BOS-TPA MAY 4>3[4] SEP 0.8>3[4] OCT 0>2[4]
B6 BQN-FLL SEP 0.3>0.7[0.6] OCT 0>0.5[0.6]
B6 BQN-JFK SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 BQN-MCO SEP 0.8>1.5[1.0] OCT 0>1.5[1.2]
B6 BTV-JFK SEP 0.8>3[3] OCT 0>2[3]
B6 BUF-FLL SEP 0.3>0.8[0.8] OCT 0>0.8[0.7]
B6 BUF-JFK SEP 1.3>5[6] OCT 0>4[6]
B6 BUF-LAX SEP 0.3>0.8[0.7] OCT 0>0.6[0.7]
B6 BUF-MCO SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 BUR-JFK SEP 0.5>1.9[1.6] OCT 0>1.4[1.5]
B6 CHS-FLL SEP 0.3>0.7[1.0] OCT 0>0.5[1.0]
B6 CHS-JFK SEP 0.5>2[2] OCT 0>1.5[2]
B6 CLE-FLL SEP 0.3>0.8[1.0] OCT 0>0.6[1.0]
B6 CTG-FLL SEP 0.3>0.7[0.6] OCT 0>0.5[0.6]
B6 CTG-JFK SEP 0.4>0.8[0.4] OCT 0>0.5[0.4]
B6 CUN-FLL SEP 0.8>1.5[1.1] OCT 0>0.8[1.0]
B6 CUN-JFK SEP 0.8>3[1.9] OCT 0>2[1.8]
B6 CUN-MCO SEP 0.5>1.8[1.0] OCT 0>1.5[1.0]
B6 CUR-JFK SEP 0.1>0.3[0.3] OCT 0>0.2[0.3]
B6 DCA-MCO SEP 1.1>4[4] OCT 0>3[4]
B6 DCA-PBI SEP 0.5>2[1.0] OCT 0>1.5[1.2]
B6 DCA-RSW SEP 0.3>1.0[1.0] OCT 0>0.8[1.2]
B6 DCA-SJU SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 DEN-JFK SEP 0.5>2[1.2] OCT 0>1.5[1.0]
B6 EWR-FLL SEP 1.2>4[3] OCT 0>3[4]
B6 EWR-MCO SEP 1.6>5[6] OCT 0>4[6]
B6 EWR-PBI SEP 0.5>2[2] OCT 0>1.5[2]
B6 EWR-RSW SEP 0.3>1.0[1.9] OCT 0>0.8[2]
B6 EWR-SDQ SEP 0.5>1.3[1.0] OCT 0>0.8[1.0]
B6 EWR-SJU SEP 1.0>1.8[1.2] OCT 0>1.2[1.0]
B6 EWR-STI SEP 0.8>2[1.1] OCT 0>1.4[1.0]
B6 EWR-TPA SEP 0.5>2[2] OCT 0>1.5[2]
B6 FLL-GCM SEP 0.1>0.4[0.7] OCT 0>0.4[0.7]
B6 FLL-GYE SEP 0.3>1.0[0.8] OCT 0>0.8[1.0]
B6 FLL-HAV SEP 0.7>3[3] OCT 0>2[3]
B6 FLL-HPN SEP 0.5>1.8[1.9] OCT 0>1.4[1.9]
B6 FLL-KIN SEP 1.1>1.8[2] OCT 0>1.3[2]
B6 FLL-LAS SEP 0.3>1.7[1.0] OCT 0>1.5[1.1]
B6 FLL-LAX SEP 1.1>3[3] OCT 0>2[3]
B6 FLL-LGA SEP 0.5>2[5] OCT 0>1.5[4]
B6 FLL-LIM SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 FLL-MBJ SEP 0.8>2[1.1] OCT 0>1.5[1.1]
B6 FLL-MDE SEP 0.3>1.0[1.0] OCT 0>0.8[0.9]
B6 FLL-MSY SEP 0.3>0.7[0.6] OCT 0>0.5[0.7]
B6 FLL-NAS SEP 1.1>3[4] OCT 0>2[4]
B6 FLL-ORD SEP 0.3>0.8[0.9] OCT 0>0.6[0.9]
B6 FLL-ORH SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 FLL-PAP SEP 0.8>2[2] OCT 0>0.8[2]
B6 FLL-PHL SEP 0.3>1.0[1.9] OCT 0>0.8[1.9]
B6 FLL-PHX SEP 0.3>0.8[1.0] OCT 0>0.6[1.0]
B6 FLL-PLS SEP 0.2>0.5[1.0] OCT 0>0.4[1.0]
B6 FLL-PUJ SEP 0.1>0.4[1.1] OCT 0>0.3[0.4]
B6 FLL-PVD SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 FLL-RDU SEP 0.5>1.6[1.8] OCT 0>1.2[1.7]
B6 FLL-RIC SEP 0.4>0.9[1.0] OCT 0>0.6[1.2]
B6 FLL-SDQ SEP 0.3>1.0[1.0] OCT 0>0.8[1.2]
B6 FLL-SJO SEP 0.3>0.8[1.0] OCT 0>0.6[1.0]
B6 FLL-SJU SEP 1.5>4[5] OCT 0>3.1[5]
B6 FLL-SLC SEP 0.3>0.8[0.8] OCT 0>0.6[0.7]
B6 FLL-SWF SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 FLL-SXM SEP 0.1>0.4[1.0] OCT 0>0.4[1.0]
B6 FLL-UIO SEP 0.5>1.3[1.1] OCT 0>0.8[1.0]
B6 GEO-JFK SEP 0.3>1.0[0] OCT 0>0.8[0]
B6 GUA-JFK SEP 0.3>1.0[0] OCT 0>0.8[0]
B6 GYE-JFK SEP 0.3>1.0[0] OCT 0>0.8[0]
B6 HPN-MCO SEP 0.8>3[3] OCT 0>2[3]
B6 HPN-PBI SEP 0.8>3[3] OCT 0>2[4]
B6 HPN-RSW SEP 0.5>2[1.0] OCT 0>1.5[1.0]
B6 HPN-TPA SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 HYA-JFK SEP 0.3>0.6[0.1]
B6 IAH-JFK SEP 0.3>1.0[0] OCT 0>0.8[0.2]
B6 JAX-JFK SEP 0.8>3[3] OCT 0>2[3]
B6 JFK-KIN SEP 1.1>3[3] OCT 0>2[3]
B6 JFK-LAX MAY 10>11[11] SEP 3>12[11] OCT 0>9[11]
B6 JFK-LGB SEP 0.5>1.9[1.9] OCT 0>1.4[1.9]
B6 JFK-MBJ SEP 0.8>2[3] OCT 0>1.5[3]
B6 JFK-MSY SEP 0.5>2[3] OCT 0>1.5[3]
B6 JFK-MVY SEP 0.5>1.5[1.2] OCT 0>0.7[0.5]
B6 JFK-NAS SEP 0.5>1.3[1.2] OCT 0>0.8[1.0]
B6 JFK-ONT SEP 0.3>1.0[0.8] OCT 0>0.8[0.7]
B6 JFK-ORD SEP 0.5>1.9[2] OCT 0>1.4[2]
B6 JFK-ORH SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 JFK-PAP SEP 0.5>1.3[2] OCT 0>0.8[2]
B6 JFK-PHX SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 JFK-PLS SEP 0.3>0.8[0.8] OCT 0>0.8[0.9]
B6 JFK-POP SEP 0.5>1.3[1.0] OCT 0>0.8[1.0]
B6 JFK-POS SEP 0.5>1.3[1.1] OCT 0>0.8[1.0]
B6 JFK-PSE SEP 0.3>0.7[0.7] OCT 0>0.5[0.7]
B6 JFK-PUJ SEP 0.5>1.2[1.1] OCT 0>0.8[1.0]
B6 JFK-RDU SEP 0.5>2[3] OCT 0>1.5[3]
B6 JFK-ROC SEP 0.8>3[3] OCT 0>2[3]
B6 JFK-RSW SEP 0.8>2[2] OCT 0>1.5[2]
B6 JFK-SAN SEP 0.8>2[3] OCT 0>1.5[3]
B6 JFK-SAV SEP 0.5>2[2] OCT 0>1.5[2]
B6 JFK-SDQ SEP 1.9>5[6] OCT 0>3[4]
B6 JFK-SEA SEP 0.5>2[1.9] OCT 0>1.5[1.8]
B6 JFK-SFO SEP 1.6>7[6] OCT 0>5[6]
B6 JFK-SJO SEP 0.3>0.6[0] OCT 0>0.3[0]
B6 JFK-SJU SEP 1.9>6[5] OCT 0>3.9[4]
B6 JFK-SLC SEP 0.5>2[2] OCT 0>1.5[2]
B6 JFK-SMF SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 JFK-SRQ SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 JFK-STI SEP 1.9>6[6] OCT 0>4[5]
B6 JFK-SXM SEP 0.3>0.9[1.0] OCT 0>0.8[1.0]
B6 JFK-SYR SEP 0.5>2[2] OCT 0>1.5[2]
B6 JFK-TPA SEP 0.8>3[3] OCT 0>2[3]
B6 JFK-UVF SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 LAS-LGB SEP 0.5>2[3] OCT 0>1.5[3]
B6 LGA-MCO SEP 0.5>2[4] OCT 0>1.5[4]
B6 LGA-PBI SEP 0.5>2[3] OCT 0>1.5[3]
B6 LGB-PDX SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 LGB-RNO SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 LGB-SEA SEP 0.5>2[2] OCT 0>1.5[2]
B6 LGB-SFO SEP 0.5>2[1.4] OCT 0>1.5[2]
B6 LGB-SLC SEP 0.7>3[3] OCT 0>2[3]
B6 MBJ-MCO SEP 0.5>2[1.1] OCT 0>1.5[1.0]
B6 MCO-NAS SEP 0.3>0.7[0.7] OCT 0>0.5[0.9]
B6 MCO-ORH SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 MCO-PSE SEP 0.5>1.3[1.0] OCT 0>0.8[1.0]
B6 MCO-PVD SEP 0.3>1.0[1.7] OCT 0>0.8[1.9]
B6 MCO-RIC SEP 0.5>1.3[1.0] OCT 0>0.8[1.2]
B6 MCO-SDQ SEP 0.5>1.3[1.0] OCT 0>0.8[1.0]
B6 MCO-SJO SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 MCO-SJU SEP 1.9>5[6] OCT 0>3.1[6]
B6 MCO-SLC SEP 0.3>0.8[0.8] OCT 0>0.6[0.7]
B6 MCO-SWF SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 MCO-SYR SEP 0.3>1.0[1.0] OCT 0>0.8[1.0]
B6 PBI-PVD SEP 0.3>1.0[0.8] OCT 0>0.8[0.9]
B6 SJU-TPA SEP 0.5>1.3[1.0] OCT 0>0.8[1.2]
*CA EWR-PEK MAR 0.6>0.1[0.6]
*CA IAD-PEK MAR 0.7>0.1[0.6]
*CA IAH-PEK MAR 0.7>0.1[0.7]
*CA IAH-PTY MAR 0.3>0.0[0.3]
*CA JFK-PEK MAR 1.5>0.5[1.7]
*CA LAX-PEK MAR 2>0.8[3]
*CA LAX-SZX MAR 0.3>0.0[0.3]
*CA PEK-SFO MAR 1.0>0.1[1.0]
*CZ CAN-JFK MAR 0.9>0.1[1.4]
*CZ CAN-LAX MAR 0.9>0.1[1.3]
*CZ CAN-SFO MAR 0.5>0.1[0.6]
*CZ JFK-WUH MAR 0.4>0.0[0]
*CZ SFO-WUH MAR 0.4>0.0[0.4]
DL ABQ-SLC OCT 3>4[3] NOV 3>4[3]
DL ATL-SAN NOV 7>6[5]
DL GEG-MSP OCT 3>2[2] NOV 3>2[1.8]
DL IDA-SLC OCT 4>5[4] NOV 4>5[4]
DL MSP-PHX OCT 5>6[5] NOV 5>6[5]
DL PSC-SLC OCT 3>4[3] NOV 3>4[3]
DL SEA-SFO SEP 7>8[7] OCT 7>8[7] NOV 7>8[6]
DL SLC-TUS OCT 3>4[3] NOV 3>4[3]
DY BCN-LAX NOV 0>0.5[0.4]
*HU BOS-PEK MAR 0.7>0.5[0.7]
*HU BOS-PVG MAR 0.5>0.1[0.6]
*HU CSX-LAX MAR 0.3>0.0[0.3]
*HU CTU-JFK MAR 0.3>0[0.3]
*HU CTU-LAX MAR 0.3>0.0[0.3]
*HU CTU-ORD MAR 0.3>0.0[0]
*HU LAX-XIY MAR 0.3>0.0[0.3]
*HU PVG-SEA MAR 0.3>0.0[0.4]
KG DEN-TEX APR 0.2>1.0[0] MAY 0>1.0[0.5] JUN 0>1.4[1.0] JUL 0>2[1.0] AUG 0>2[1.0] SEP 0>1.3[1.0] OCT 0>1.0[0.5]
LA GRU-MCO JUL 1.0>1.4[0]
*LF BNA-IND JUN 0>1.2[0] JUL 0>1.7[0] AUG 0>1.7[0] SEP 0>1.7[0]
*LF IND-PIT JUN 0>0.7[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0]
*LF IND-STL JUN 0>1.2[0] JUL 0>1.7[0] AUG 0>1.7[0] SEP 0>1.7[0]
*LV BOS-ORY APR 0.4>0[0] MAY 0.4>0[0] JUN 0.4>0[0] JUL 0.4>0[0] AUG 0.4>0[0] SEP 0.6>0[0] OCT 0.4>0[0]
LV EWR-ORY MAY 0.7>0.9[0.6] JUN 0.7>0.9[0.5] SEP 0.7>1.0[0.7] OCT 0.5>0.7[0.7]
*LV LAS-ORY MAR 0.3>0[0] APR 0.3>0[0] MAY 0.3>0[0] JUN 0.3>0[0] JUL 0.3>0[0] AUG 0.3>0[0] SEP 0.3>0[0] OCT 0.2>0[0.0]
*MF LAX-XMN MAR 0.3>0.0[0.4]
HNL-PVG and SFO-TAO appear permanently dropped.
**MU HNL-PVG MAR 0.4>0[0.9] APR 0.8>0[0.9] MAY 0.9>0[0.8] JUN 0.9>0[0.9] JUL 0.8>0[0.8] AUG 0.9>0[0.9] SEP 0.8>0[0.8] OCT 0.9>0.2[0.8]
*MU JFK-PVG MAR 1.9>0.5[1.8] APR 2>1.1[2]
*MU LAX-NKG MAR 0.4>0[0.4] APR 0.4>0[0.4] MAY 0.4>0[0.4] JUN 0.4>0.1[0.4]
*MU LAX-PVG MAR 1.8>0.5[1.9] APR 2>1.1[2]
*MU ORD-PVG MAR 0.7>0.0[0.7] APR 1.0>0.6[0.7]
*MU PVG-SFO MAR 1.0>0.0[1.0] APR 1.0>0.7[1.0]
**MU SFO-TAO MAR 0.4>0[0.4] APR 0.4>0[0.4] MAY 0.4>0[0.4] JUN 0.4>0[0.4] JUL 0.4>0[0.4] AUG 0.4>0[0.5] SEP 0.4>0[0.4] OCT 0.5>0.1[0.5]
NK ACY-FLL JUL 2>3[1.3] AUG 2>3[1.3] SEP 0.5>0.8[1.7]
NK ACY-MCO JUL 2>3[2] AUG 2>3[2] SEP 0.5>0.7[2]
NK BOS-MYR MAY 1.3>1.0[1.0]
**NK BOS-RDU APR 1.0>0.7[0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 0.3>0[0.8]
NK CLE-MYR JUL 1.9>1.4[1.0] AUG 1.8>1.4[1.0]
NK CMH-MYR MAY 0.6>0.3[0.5] JUN 0.6>0.3[0.6] JUL 0.6>0.3[0.6] AUG 0.6>0.3[0.6]
**NK DEN-DFW APR 1.0>0.7[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 0.3>0[1.0]
**NK DEN-MSY APR 0.5>0.2[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 0.3>0[1.0]
**NK DFW-MSP APR 0.3>0[0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 0.3>0[0.8]
NK DTW-FLL JUL 2>3[2] AUG 2>3[2] SEP 0.5>0.8[2]
NK FLL-GUA MAY 1.0>1.6[1.0] JUN 1.0>1.6[1.0] JUL 1.0>1.6[1.0] AUG 1.0>1.6[1.0]
NK FLL-MSY MAY 2>3[2.0]
NK FLL-MYR APR 1.0>1.3[1.0] MAY 1.0>2[1.3] JUN 1.0>2[1.3] JUL 1.0>2[1.3] AUG 1.0>2[1.3] SEP 0.3>0.5[1.4]
NK FLL-PHL MAY 3>4[2] JUN 3>4[2] JUL 3>4[2] AUG 3>4[2] SEP 0.8>1.1[2]
NK FLL-SAL MAY 0.8>1.3[0.6] JUN 0.9>1.3[0.6] JUL 0.9>1.3[0.5] AUG 0.8>1.3[0.6]
NK FLL-STX MAY 0.6>1.0[0.7] JUN 0.6>1.0[0.6] JUL 0.6>1.0[0.6] AUG 0.6>1.0[0.6]
NK GUA-MCO JUL 0.6>0.9[0.5] AUG 0.6>1.0[0.6]
**NK IAH-MSP APR 0.3>0[0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 0.3>0[1.0]
**NK LGA-MCO APR 0.7>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.3[0]
NK LGA-ORD APR 1.3>1.0[2] MAY 2>1.0[2] JUN 2>1.0[2] JUL 2>1.0[2] AUG 2>1.0[2] SEP 0.5>0.3[2]
NK MCI-MCO JUL 1.0>1.2[1.0] AUG 1.0>1.3[1.0]
NK MCO-PIT JUL 1.4>1.8[1.0] AUG 1.4>2[1.0]
NK MCO-RDU APR 1.0>1.3[0] MAY 1.0>2[1.0] JUN 1.0>2[1.0] JUL 1.0>2[1.0] AUG 1.0>2[1.0] SEP 0.3>0.5[0.9]
QR DOH-MIA JUN 0.7>1.0[0.7] JUL 0.7>1.0[0.7] AUG 0.7>1.0[0.7] SEP 0.7>1.0[0.7] OCT 0.8>1.0[0.8]
**SA DSS-IAD MAY 0.3>0[0.3] JUN 0.3>0[0.3] JUL 0.3>0[0.3] AUG 0.3>0[0.3] SEP 0.3>0[0.0] OCT 0.2>0[0]
TK EWR-IST OCT 0.8>1.0[0] NOV 0>1.0[0]
UA ACK-EWR AUG 3>1.6[3] SEP 1.3>0[0.8]
UA ASE-LAX SEP 2>1.2[1.1]
UA CLE-MCO MAR 1.0>1.8[1.0]
UA CLE-RSW MAR 1.1>1.9[1.1]
UA CTU-SFO MAR 0.4>0.1[0.4]
UA CUN-DEN AUG 0.7>1.1[0.8] SEP 0.1>1.0[0.1]
UA DEN-SAV SEP 0.2>1.0[0] OCT 0>1.0[0] NOV 0>1.0[0]
UA DEN-TVC SEP 0.2>1.0[0.1]
UA EWR-MYR SEP 0.9>0.2[0.3]
UA EWR-TVC SEP 0.4>0.2[0.3]
UA FCA-SFO AUG 1.5>1.1[1.7] SEP 0.5>0.2[0.1]
UA IAD-LAS MAR 2>3[1.9]
UA IAD-MIA MAR 2>3[1.0]
UA LAX-PVG MAR 0.5>0.1[1.0]
I guess UA won the MEX slots that were surrendered by B6/WN
*UA MEX-SFO MAY 2>3[2] JUN 2>3[2] JUL 2>3[2] AUG 2>3[2] SEP 2>3[2] OCT 2>3[2]
*UA PEK-SFO MAR 1.0>0.1[1.0]
*UA PVG-SFO MAR 1.1>0.3[2]
WS FLL-YYZ MAY 1.1>0.8[1.1] JUL 1.0>0.7[1.0] AUG 1.0>0.7[1.0]
WS PSP-YYC MAY 1.7>1.0[1.4]
WS SFO-YYC MAY 1.5>2[1.5]
Cointrin330
Re: OAG Changes 2/9/2020:NK Cuts BOSRDU,DEN-DFW/MSY,MSP-DFW/IAH,Adds LGAMCO;AS Adds PAEBOI;MU Ends HNLPVG,SFOTAO;SA IAD?
Sun Feb 09, 2020 12:53 pm
Interesting to see Spirit cut RDU-BOS before the AA service starts. Something had to give there and this is first and foremost a business market, not a leisure one so it stands to reason NK wouldn't last on this route.
Ishrion
Sun Feb 09, 2020 12:54 pm
Thanks as always!
Not only is it hourly, it's purely mainline. Here's an example of the aircraft for July 15, 2020:
2x 757-200
2x A321
1x A319
4x 737-800
3x 737 MAX 8 (subject to change of course)
Atlwarrior
Sun Feb 09, 2020 12:56 pm
Thanks for posting. Can someone confirm if my understanding is correct. The below means that ATL to DCA is cut by 1 flight on May 4.
enilria
Sun Feb 09, 2020 12:57 pm
I think F9 would have stayed, but NK has diverged on strategy from F9.
Ishrion wrote:
Thanks as always!
2x 757-200
2x A321
1x A319
4x 737-800
Talk about something having to give. AA will walk that back IMHO.
jmscsc
Sun Feb 09, 2020 1:19 pm
No, ATL-DCA went from 4 daily flights in May to 3.
Chuska
Sun Feb 09, 2020 1:44 pm
LF (Contour) starting IND-BNA/PIT/STL in June. Glad to see them venture out and do some non EAS markets and fill in some point to point gaps where there's no service. (future ExpressJet?) Good luck to them!
knope2001
Sun Feb 09, 2020 1:57 pm
The first of what I assume will be several additions or upgrades as Milwaukee hosts the Democratic National Convention in mid July. Eight round trips on E75.
JetAwayDrew
Sun Feb 09, 2020 2:07 pm
It looks like NK is starting to scale back on Its DFW focus city. Interesting.
Midwestindy
Sun Feb 09, 2020 2:23 pm
It's a big VFR route
Status for 2019/2020: AAdvantage Platinum, Delta Gold, Southwest A-List
flyiguy
Sun Feb 09, 2020 2:29 pm
This was cut September 1st 2019. SA will now serve JFK nonstop from JNB with the A350 and IAD will now be served daily via ACC.
FLY
The opinions I post are of mine and mine alone, not of the airline I work for.
avi8
Sun Feb 09, 2020 2:42 pm
Wow, NK FLL-GUA going up to 11 weekly and MCO-GUA going to daily. That is great news. NK will have up to 4 flights a day to GUA compared to only 5 weekly flights a little more than a year ago.
avi8
wedgetail737
Sun Feb 09, 2020 2:44 pm
It is my understanding that PAE-PDX is dropping to 2X daily.
malev2012
Sun Feb 09, 2020 2:57 pm
Yea this interesting considering how many new birds they have coming online. Midsize cities growth like in BNA and AUS is needed to keep up with the new birds. Guess these routes they have other ULCC to fight with DEN F9 and MSP SY.
Airlines flown: AA, AB, AC, AY, BA, CO, DL, DY, EW, F9, G4, IB, KL, LH, LX, NK, NW, NZ, OS, QF, SN, TP, UA, US, VA, VC, WN, XE
MIflyer12
Sun Feb 09, 2020 2:59 pm
I didn't think this route would sustain 5 carriers when AA announced. I expected F9 to bail before NK but maybe this is a sign NK is smarter!
Brandon757
Sun Feb 09, 2020 3:18 pm
Wow, I hate seeing DFW-DEN dropped by Spirit. I haved traveled that route frequently out of DFW for the last 10 years or so. Nine times out of ten NK was the cheapest option out of the airlines that fly it (I don't give a rat's behind about brand loyalty I shop to find the cheapest deal).
FlyPNS1
The close-in adds on IAD-LAS/MIA are interesting...spare capacity from the China cuts trickling down?
The extra IAD-LAS flight is only 30minutes from another IAD-LAS flight. Plus it’s a 752 which is unusual for that route.
ericm2031
Sun Feb 09, 2020 3:26 pm
You're probably right, with the extra capacity moved to Spring Break destinations...LAS/MIA/RSW/MCO
Rdh3e
Sun Feb 09, 2020 4:09 pm
Looks like some of the Widebody aircraft are seeing spoke service.
ORD-MCO sees a second 777 in International configuration (already had a domestic configuration 777), ORD-LAS and EWR-LAS seeing international configured 777s.
Aliqiout
Sun Feb 09, 2020 5:05 pm
Has this been confirmed? 3X are still for sale (for only $44 each way).
BA
Sun Feb 09, 2020 5:45 pm
Nothing to do with UA ending SFO. They're dropping PAE-PDX from 3x to 2x to support launching BOI.
https://www.heraldnet.com/business/alas ... e-in-june/
"Generosity is giving more than you can, and pride is taking less than you need." - Khalil Gibran
usflyguy
Sun Feb 09, 2020 5:52 pm
FXE has customs and immigration clearance... it even has global entry kiosks and automate passport control kiosks.
My post is my ideas and my opinions only, I do not represent the ideas or opinions of anyone else or company.
dc10lover
Sun Feb 09, 2020 6:20 pm
AS PAE BOI is a great "Business Route". This will be successful.
Why endure the nightmare and congestion of LAX when BUR, LGB, ONT & SNA is so much easier to fly in and out of. Same with OAK & SJC when it comes to SFO.
jplatts
Sun Feb 09, 2020 6:24 pm
F9 will still be operating BOS-RDU, DEN-DFW, and DEN-MSY nonstop service once NK discontinues BOS-RDU, DEN-DFW, and DEN-MSY nonstop service.
DFW/DAL and MSY will also still have nonstop service out of DEN on WN and UA once NK discontinues DEN-DFW and DEN-MSY nonstop service, and AA will also still serve DFW nonstop from DEN in addition to UA, F9, and WN after NK discontinues DEN-DFW nonstop service.
DL and B6 will also still be serving RDU nonstop from BOS once NK discontinues BOS-RDU nonstop service.
AA, DL, and SY will all still be serving MSP nonstop from DFW after NK discontinues DFW-MSP nonstop service, and WN will still be serving MSP nonstop from DAL after NK discontinues DFW-MSP nonstop service.
While MSP will no longer have nonstop LCC service from Houston after NK drops IAH-MSP nonstop service, WN adding HOU-MSP nonstop service is a possibility with HOU being one of the largest WN focus cities that WN doesn't currently serve nonstop from MSP. SY re-entering the Houston market is also a possibility with SY having already re-entered a few markets that it previously pulled out of.
Nicknuzzii
Sun Feb 09, 2020 6:39 pm
NK up to 11 flights a day at ACY, how long has it been since it’s been that high? Any chance they give MSY another run? Or even stretch to SJU/BNA/LAS?
HNLSLCPDX
Sun Feb 09, 2020 8:42 pm
Thank you enilria! Your post are appreciated.
wedgetail737
Sun Feb 09, 2020 8:43 pm
Who knows. UA could have sold one or more of their slots to AS.
dfwjim1
Sun Feb 09, 2020 8:47 pm
Ishrion wrote:
Thanks as always!
2x 757-200
2x A321
1x A319
4x 737-800
Has AA ever run 777s between MIA and MCO?
redzeppelin
Sun Feb 09, 2020 8:49 pm
Watch this space, as they say. Phase 1 of SLC's terminal reconstruction is set to open in September, and there is plenty of speculation about new routes and service enhancements from DL and others. These changes may just be restoring frequencies that were lost to gate limits during construction, but still represent some of first changes we've seen for after the planned opening. I'm really curious to see what else happens, or if it will just be business as usual.
Atlwarrior
Sun Feb 09, 2020 8:50 pm
[threeid][/threeid]
Thank you. Got it!
Prost
Sun Feb 09, 2020 9:01 pm
Things have been silent from DL lately, redzeppelin gives me hope that this may be a temporary lull in new routes.
enilria
Sun Feb 09, 2020 9:08 pm
Aliqiout
Sun Feb 09, 2020 10:23 pm
Several sources have said that PDX is being reduced, so that is probably right, but usually AS will unually zero out all but the full fare buckets on flights they are planning to cancel, and as of right now they are still selling X class on all three flights.
If they had acquired one of the UA slots I would have expected an announcement. Maybe they are hoping to get their hands on one? Or are they cutting something else, or just baiting and switching?
knope2001
Sun Feb 09, 2020 10:32 pm
BTW Thanks as always for taking the time to compile and post, enilria...
It's generally timed for business as long as you're BOI-originating headed northwest -- early BOI-PAE, early evening PAE-BOI. The only game in town so hopefully you have pretty much a full day of business up there.
Brickell305
Sun Feb 09, 2020 10:33 pm
dfwjim1 wrote:
Ishrion wrote:
Thanks as always!
2x 757-200
2x A321
1x A319
4x 737-800
No. Domestic 777s are usually cycled between hubs. Although this year they are using it on MIA-BOS to be able to run the BOS-LHR flight.
jagraham
Mon Feb 10, 2020 12:04 am
Anybody know where these birds are coming from? 4 77Es are being converted to domestic, I just want to be sure these flights are not any of the 77E domestics.
msycajun
Mon Feb 10, 2020 12:17 am
It looks like a significant expansion for NK at FLL, with some longstanding routes being cut to fund it. I wonder if there is some reason for the sudden growth - perhaps a play for more real estate or defending against other carriers?
I'm surprised to see MSY-DEN go, as it seemed to perform well last summer. I wonder if we'll see it return in the fall or if perhaps the flight is simply being retimed and could reappear.
tphuang
Mon Feb 10, 2020 1:38 am
Pretty aggressive expansion by NK at FLL. I think it's timed this way to catch B6 facing A321 delivery issues and focus elsewhere + WN facing MAX issues and focusing elsewhere. Probably good moves. As for some of their cuts, it was a ridiculous move for them to enter BOS-RDU or DEN-DFW. Those clearly can't work.
rjbesikof
Mon Feb 10, 2020 1:52 am
Are the China Eastern changes due to the coronavirus?
Rdh3e
Mon Feb 10, 2020 3:00 am
It's the aircraft that would otherwise have been flying to China if not for Coronavirus.
capitalflyer
Mon Feb 10, 2020 4:24 pm
Shortcomings of B6 data aside, could B6 do some damage to AA in this shuttle market with its greater frequencies, including 6am departure that gets you to either city in time for 9am meeting? Is there really much wiggle room in this market between airlines? I would guess that these are premium heavy with a large percentage of pax being FF members, people who won't switch airlines unless there is a very compelling argument. Perhaps the 9am meeting is that argument?
I assume the continued false start by AA on the BOS shuttle expansion is need for A319 to fill the MAX holes.
This I believe is just finishing the process they began end of last year to route these same plane stopovers to JNB through ACC rather than Dakar. Apparently more Ghanaians in DC than Senegalese. This is still 3x weekly.
Picking up UA slack.
Why bother? Just end the route already. Are there international destinations that folks at DCA can't access from CLT? A quick look suggests the main destinations are LHR, CDG, and MXP. If folks want to go to any of those places, they can make the trek to IAD and hop BA 744/789 to LHR and connect everywhere. This route is pointless.
Meh
I believe this is only for the Democratic National Convention which is in July in MKE. There are two flights to MKE on the 12th, 17th, 18th (855A and 505P) and 2 return flights to DCA on same days at 1110A and 655P. Looks like simple out and back using planes already at DCA (E75).
What are DL and AA trying to do? Is the leisure MCO market that lucrative? Or are they just trying to mess with B6 and each other? I can't imagine this is high yielding traffic since it is so leisure heavy. Chasing folks who are willing to pay $49 on NK and wear all their clothes on their flight to save money seems like a losing proposition.
enilria
Mon Feb 10, 2020 4:33 pm
That's a really good guess I bet.
The changes by the Chinese carriers that are 1 or 2 months in the future are. HNLPVG and SFOTAO are out forever, so those are not.
Obviously this is all about maximizing Latin connects as AA loses LATAM, but SERIOUSLY is hourly service needed to provide connections??? NO. This is will be a bloodbath to end all bloodbaths. I bet they start chopping the freq down before it even flies.
ILNFlyer
Mon Feb 10, 2020 4:35 pm
Nice to see AA's uptick in DAY frequency to ORD.
Aliqiout
Mon Feb 10, 2020 7:02 pm
DCA-JFK may be pointless to you, but the professionals at AA see a point. Undoubtably one or a combination of:
1. They think this will be profitable with a combination of O&D and connections they would otherwise lose to other carriers.
2.This frees up space that they can sell for a higher profit through other hubs.
3. It provides network benefits that are important to encouraging loyalty in high value costumers.
4 . It is the most cost effective method to hold onto JFK and/or DCA slots.
enilria
Mon Feb 10, 2020 7:11 pm
I hadn't noticed this, but they seem to be pulling the same slot utilization game at DCA. This is 8 net RTs out of DCA in MAY. Perhaps whatever complaint was filed at JFK needs to be expanded.
FSDan
Mon Feb 10, 2020 7:59 pm
I think this is more about trying to get DL off the route than it is about AA needing additional capacity for connections. DL's starting the route 5x daily in order to provide feed traffic to Latam at MIA (and I'd guess there's a decent amount of MCO traffic originating from LA's secondary Brazil flights). AA obviously wants DL off this important feeder route ASAP, and is pulling a response like what UA did on SFO-DEN when VX entered. The difference here is that DL has the deep pockets to hang in this money-losing route longer term since it's strategically important for them. VX didn't have the ability to do that on SFO-DEN, and once they dropped it UA returned from something like 16x daily back down to ~11 daily. We'll see how long AA maintains this frequency on MIA-MCO. I suspect they'll go back to a more reasonable level after summer, with DL continuing to stick it out.
This is my signature until I think of a better one.
Midwestindy
Mon Feb 10, 2020 8:40 pm
A few decreases from DCA appear to be from weekend cutbacks. ATL-DCA is still 4x Mon-Fri & BOS-DCA is still 13x Mon-Fri
Central Florida has a significant amount of Latin America O&D.
enilria
Tue Feb 11, 2020 2:14 pm
It's only about connects. There is no local market from MCO to MIA. What minimal traffic appears in DB1B is really nearly all double ticketing. If prices fall to $49 there may be some local market created, but lets be clear this is 100% about connect passengers. That's why I think AA's strategy of flying hourly makes no sense. That's what you do in a big local market. That doesn't exist here.
The existing PDEW traffic (which as I said is likely nearly all double ticketing) is 235 PDEW. There will be 2302 seats per day this Summer. The "local" market would only fill 10% of seats.
WN732
Tue Feb 11, 2020 3:12 pm
I cannot believe that AA cut JFK-SAN. That used to be a 767 route just a few years back, with several frequencies per day. Wow how times have changed.
Miamiairport
Tue Feb 11, 2020 5:59 pm
dfwjim1 wrote:
Ishrion wrote:
Thanks as always!
2x 757-200
2x A321
1x A319
4x 737-800
AA has run 772s on occasional one offs. I remember one time when I was going back and forth between MIA and MCO they sub'd a 773 for a 321. IIRC the summer of 2018 it was all 763. With this many flights AA will need to stimulate local demand with cheap flights. I'll bite if it's not BE. I looked at mid week in mid July. BE starts at $139 r/t and Main Cabin at $177. AA has a ways to go to meet Spirit fares. Of course that's still months off.
