Sun Mar 08, 2020 12:19 pm
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
3F KTB-KTN APR 0.6>0[0.9] MAY 0.5>0[3] JUN 0.6>0[3] JUL 0.6>0[3] AUG 0.5>0[3] SEP 0.6>0[3] OCT 0.6>0[3] NOV 0.6>0[3] DEC 0.6>0[0.5]
3F KTN-MTM APR 0.6>0[1.7] MAY 0.5>0[3] JUN 0.6>0[3] JUL 0.6>0[3] AUG 0.5>0[3] SEP 0.6>0[3] OCT 0.6>0[3] NOV 0.6>0[3] DEC 0.6>0[0.5]
3M ELH-MCO SEP 0.3>0.1[0] OCT 0.3>0[0] NOV 0.3>0[0.4]
*3M MCO-MHH SEP 0.3>0.0[0.1] OCT 0.3>0[0] NOV 0.3>0[0] DEC 0.3>0.1[0]
3U HGH-LAX APR 0.4>0[0.3]
3U LAX-TNA APR 0.4>0[0.4]
4O GDL-LAS JUN 1.0>0.4[1.0] JUL 1.0>0.5[1.0] AUG 1.0>0.4[1.0] SEP 1.0>0.4[0.9] OCT 1.0>0.4[0.9] NOV 1.0>0.4[1.0] DEC 1.0>0.4[1.0]
4O GDL-LAX JUN 1.0>0.6[2] JUL 1.0>0.6[2] AUG 1.0>0.6[2] SEP 1.0>0.6[1.5] OCT 1.0>0.5[1.6] NOV 1.0>0.6[1.0] DEC 1.0>0.5[1.0]
4O GDL-ORD JUN 1.0>0.6[1.0] JUL 1.0>0.6[1.0] AUG 1.0>0.6[1.0] SEP 1.0>0.6[1.0] OCT 1.0>0.5[1.0] NOV 1.0>0.6[1.0] DEC 1.0>0.5[1.0]
4O GDL-SAT JUN 1.0>0.4[1.0] JUL 1.0>0.4[1.1] AUG 1.0>0.4[1.1] SEP 1.0>0.4[1.0] OCT 1.0>0.5[1.0] NOV 1.0>0.4[1.0] DEC 1.0>0.5[1.0]
4O GDL-SFO JUN 1.0>0.5[1.0] JUL 1.0>0.6[1.0] AUG 1.0>0.6[1.0] SEP 1.0>0.6[1.0] OCT 1.0>0.5[1.0] NOV 1.0>0.6[1.0] DEC 1.0>0.5[1.0]
4O JFK-MEX JUN 2>1.0[3] JUL 2>1.0[3] AUG 2>1.0[3] SEP 2>1.0[3] OCT 2>1.0[2] NOV 2>1.0[2] DEC 2.0>1.0[2]
7H ANC-DUT JUN 2>3[0] NOV 2>3[0] DEC 2>3[1.9]
9X ACK-HYA APR 0>0.6[0] MAY 0>1.9[0] JUN 0>3[0] JUL 0>3[0] AUG 0>3[0] SEP 0>2[0] OCT 0>0.6[0]
9X ACK-OWD MAY 0>0.8[0] JUN 0>1.5[0] JUL 0>1.6[0.7] AUG 0>1.6[0.7] SEP 0>0.9[0.7]
9X ACK-PVD APR 0>0.3[0] MAY 0>0.9[0] JUN 0>1.6[0] JUL 0>1.5[0.9] AUG 0>1.6[1.0] OCT 0>0.3[0.5]
9X HYA-OWD APR 0>0.3[0] MAY 0>1.0[0] JUN 0>1.5[0] JUL 0>1.4[0] AUG 0>1.5[0] SEP 0>1.0[0] OCT 0>0.3[0]
This looks like the MAX cancellations extended through the Summer, not COVID related. Still cutting JFK...
AA ABE-PHL JUN 4>3[3] JUL 4>3[4]
AA AMA-DFW JUN 8>7[7] JUL 8>7[7]
AA ATL-CLT JUN 9>8[9] JUL 9>8[8]
AA ATL-DCA JUN 5>4[4] JUL 5>3[4]
AA ATL-MIA JUN 8>7[7] JUL 8>7[8] AUG 8>7[8]
AA ATL-ORD JUN 5>6[5] JUL 5>6[5]
AA ATL-PHL JUN 6>5[6] JUL 6>5[6]
AA ATL-PHX JUN 1.9>1.0[1.7] JUL 2>1.0[1.6] AUG 2>1.5[1.6]
AA ATW-ORD JUN 3>4[3] JUL 3>4[3]
AA AVL-PHL JUN 1.9>1.0[1.0] JUL 2>1.0[1.0] AUG 2>1.5[1.0]
AA AVP-PHL JUN 4>3[3] JUL 4>3[3]
AA BDL-DFW JUN 2>1.1[1.1] JUL 2>1.0[0.9] AUG 2>1.5[1.3]
AA BDL-ORD JUN 4>5[5] JUL 4>5[4]
AA BDL-PHL JUN 6>5[5] JUL 6>5[5]
AA BGR-CLT JUN 1.1>1.4[1.0] JUL 1.1>1.4[1.0]
AA BGR-LGA JUN 0.5>1.2[0.3]
AA BNA-CLT JUN 9>7[7] JUL 9>7[7] AUG 9>8[7]
*AA BNA-JFK JUN 2>1.1[2] JUL 2>1.0[2] AUG 2>1.5[2]
AA BNA-ORD JUN 8>9[9] JUL 8>9[8]
AA BOS-DCA JUN 14>10[11] JUL 14>10[11] AUG 14>12[11]
*AA BOS-JFK JUN 6>3[1.0] JUL 6>3[0.6] AUG 6>4[0.5]
AA BOS-LGA JUN 12>10[10] JUL 12>10[10]
AA BRO-DFW JUN 4>3[4] JUL 4>3[4]
AA BUF-DCA JUL 4>3[3]
AA BWI-DFW JUN 4>3[4] JUL 4>3[4]
*AA BWI-JFK JUN 5>1.9[1.0] JUL 5>2.0[1.0] AUG 5>3[1.0]
AA BZN-DFW SEP 1.3>2[1.0] OCT 1.0>1.2[1.0]
AA CAE-PHL JUN 3>2[3] JUL 3>2.0[3]
AA CHA-CLT JUN 7>6[6] JUL 7>6[6]
**AA CHA-PHL JUN 0.9>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0] NOV 1.0>0[1.1] DEC 1.0>0[1.0]
AA CHS-CLT JUL 9>8[9]
AA CID-CLT JUN 3>2[2] JUL 3>2[2]
AA CLE-DFW JUN 5>4[5] JUL 5>4[4]
*AA CLE-JFK JUN 1.8>0[1.0] JUL 2>0[1.0] AUG 2>0.9[1.0]
AA CLT-DEN JUN 7>6[6] JUL 7>6[6]
AA CLT-DFW JUN 10>9[10] JUL 10>9[10]
AA CLT-EWR JUL 9>8[8]
AA CLT-GRR JUN 3>4[3] JUL 3>4[3]
AA CLT-IAH JUL 5>4[4]
AA CLT-ILM JUN 9>8[9] JUL 9>8[9]
AA CLT-MDT JUN 5>6[6] JUL 5>6[6]
AA CLT-ORD JUN 10>9[10] JUL 10>9[10]
AA CLT-PHF JUL 6>7[6]
AA CLT-RDU JUL 9>8[8]
AA CLT-RIC JUL 8>9[8]
AA CLT-ROA JUN 8>7[7] JUL 8>7[7]
AA CLT-ROC JUN 3>4[4] JUL 3>4[4]
AA CLT-SAV JUL 9>8[9]
AA CLT-SBY JUN 3>2[2] JUL 3>2[2]
*AA CMH-JFK JUN 1.9>1.0[1.0] JUL 2>1.0[1.0] AUG 2>1.5[1.0]
AA CMH-PHL JUN 7>6[6] JUL 7>6[5]
AA CMH-PHX JUN 2.0>1.1[2] JUL 2>1.0[1.9] AUG 2>1.5[1.7]
AA COU-ORD JUN 3>4[4] JUL 3>4[4]
AA CRP-DFW JUN 8>7[8] JUL 8>7[7]
AA CUN-MIA DEC 5>6[4]
AA CUN-PHX AUG 1.5>1.0[1.0] SEP 0.7>0.5[0.4]
AA CVG-PHL JUN 6>5[6] JUL 6>5[6]
AA DAY-LGA JUN 3>2[3] JUL 3>2[3]
AA DAY-ORD JUL 4>5[5]
*AA DCA-JFK JUN 4>3[0.6] JUL 4>3[0.1]
AA DCA-LGA JUL 11>10[8]
AA DCA-PBI JUN 1.1>2[1.0] JUL 1.0>1.9[1.0] AUG 1.0>1.5[1.0]
AA DCA-TPA JUN 4>3[3] JUL 4>3[3]
AA DEN-LAX JUN 4>3[3] JUL 4>3[3]
AA DEN-ORD JUN 4>6[5] JUL 4>6[5] AUG 4>5[5]
AA DEN-PHL JUN 3>1.9[3] JUL 3>2.0[3]
AA DFW-DTW JUN 6>5[5] JUL 6>5[5]
AA DFW-FAT JUN 3>4[3] JUL 3>4[2] AUG 3>4[3] SEP 2>4[3]
AA DFW-FSD JUN 2>3[2] JUL 2>3[2] AUG 2>3[2]
AA DFW-GEG SEP 1.0>1.7[1.0] OCT 1.0>2[1.0] NOV 1.0>2[1.0] DEC 1.0>2[1.4]
AA DFW-IAH JUN 10>9[10] JUL 10>9[10]
AA DFW-ICN APR 1.0>0.2[1.0]
AA DFW-JAX JUN 6>5[5] JUL 6>5[5]
*AA DFW-JFK JUN 4>1.7[2] JUL 4>1.7[2] AUG 4>3[2]
AA DFW-LAS JUN 12>11[11] JUL 12>11[10]
AA DFW-LAX JUN 16>15[15] JUL 16>15[15]
AA DFW-MEM JUN 8>7[9] JUL 8>7[8]
AA DFW-MSY JUN 9>8[8] JUL 9>8[8]
**AA DFW-OAK JUN 0.9>0[0.8] JUL 1.0>0[0.2] AUG 1.0>0[0] SEP 1.0>0[0] OCT 0.8>0[0]
AA DFW-PBI JUN 3>2[2] JUL 3>2[1.9]
AA DFW-SEA JUN 10>9[9]
AA DFW-SLC JUN 7>5[7] JUL 7>5[7] AUG 7>6[7]
AA DFW-SWO JUN 3>2[3] JUL 3>2[3]
AA DSM-PHL JUN 1.9>1.0[2.0] JUL 2>1.0[2.0] AUG 2>1.5[1.8]
AA DTW-PHL JUL 6>5[5]
*AA ERI-ORD JUN 0.9>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0.5[1.0]
AA FAR-ORD JUN 3>4[3] JUL 3>4[3]
AA FAT-LAX JUN 4>3[3] JUL 4>3[3]
AA FNT-ORD JUN 3>4[4] JUL 3>4[4]
AA FWA-PHL JUN 1.9>1.0[2] JUL 2>1.0[1.9] AUG 2>1.5[1.6]
AA GRR-MIA DEC 0>0.5[0.4]
AA GRR-ORD JUN 7>8[7] JUL 7>8[7]
AA GSP-ORD JUN 2.0>3[3] JUL 1.9>3[3] AUG 2>3[3]
Surplus widebody?
**AA HNL-ORD JUN 0>0.9[0] JUL 0>1.0[0] AUG 0>0.5[0]
AA IND-LAX JUN 2>1.1[1.0] JUL 2>1.0[1.0] AUG 1.5>1.0[1.0]
AA ITH-PHL JUL 2>1.5[3]
No JFK-SAN cut this time
*AA JFK-LAS JUN 1.8>0.9[1.7] JUL 2>1.0[1.2] AUG 2>1.5[1.0]
*AA JFK-MXP APR 1.0>0.2[1.0]
*AA JFK-ORD JUN 4>0.9[1.9] JUL 4>0.9[2] AUG 4>2[2]
*AA JFK-ORF JUN 1.8>0.9[3] JUL 2>1.0[3] AUG 2>1.5[3]
**AA JFK-PHL JUN 5>0[0] JUL 5>0[0] AUG 5>2[0]
AA JFK-PHX JUN 6>5[5] JUL 6>5[4]
*AA JFK-PIT JUN 4>1.0[1.0] JUL 4>1.0[1.0] AUG 4>2[1.0]
*AA JFK-RDU JUN 4>2[2] JUL 4>2[2] AUG 4>3[2]
*AA JFK-RIC JUN 3>1.0[0] JUL 3>1.0[0] AUG 3>1.9[0]
*AA JFK-YUL JUN 1.9>1.0[1.0] JUL 2>1.0[1.0] AUG 2>1.5[1.0]
*AA JFK-YYZ JUN 1.8>0[2] JUL 2>0[2] AUG 2>0.9[2]
AA LAX-MFR JUN 1.0>0.1[1.0] JUL 1.0>0[1.0] AUG 1.0>0.5[1.0]
AA LAX-RNO JUN 5>4[4] JUL 5>4[4]
AA LAX-SEA NOV 6>5[4] DEC 6>5[4]
AA LBB-PHX JUN 1.0>1.5[1.0] JUL 1.0>1.6[1.0] AUG 1.0>1.3[0.9]
AA LEX-PHL JUN 3>2[3] JUL 3>2[3]
AA LGA-ORD JUN 12>11[12] JUL 13>11[12]
AA LGA-PHL JUN 4>3[3] JUL 4>3[3]
AA LIT-ORD JUN 3>4[4] JUL 3>4[4]
AA MDT-PHL JUN 6>5[5] JUL 6>5[5]
AA MEM-ORD JUN 4>5[5] JUL 4>5[5]
AA MIA-MXP APR 1.0>0.2[1.0]
AA MIA-OMA DEC 0>0.5[0.4]
AA MIA-RTB DEC 0.3>0.6[0.3]
AA MIA-SAV SEP 2>3[2] OCT 2>3[2]
AA MQT-ORD JUN 1.0>1.8[1.7] JUL 1.0>1.9[1.9] AUG 1.0>1.5[1.5]
AA MSP-ORD JUL 7>6[7]
AA MSP-PHL JUN 4>2[3] JUL 4>2[3] AUG 4>3[3]
AA MSP-PHX JUN 4>3[3] JUL 4>3[3]
AA MSY-PHL JUN 3>1.0[2.0] JUL 3>1.0[1.8] AUG 3>1.9[1.9]
AA MYR-PHL JUL 4>3[2]
AA OKC-PHL JUN 1.9>1.0[1.1] JUL 2>1.0[0.9] AUG 2>1.5[1.0]
AA OMA-PHL JUN 1.9>1.0[1.2] JUL 2>1.0[1.0] AUG 2>1.5[1.0]
AA ORD-ORF JUN 1.9>3[3] JUL 1.9>3[3] AUG 2>3[3]
AA ORD-SJC JUN 1.8>3[2.0] JUL 1.9>3[3] AUG 2>3[2]
AA ORF-PHL JUN 6>5[6] JUL 6>5[6]
AA PHL-PWM JUN 6>5[4] JUL 6>5[4]
AA PHL-RDU JUL 7>6[6]
AA PHL-RIC JUN 7>6[5] JUL 7>6[6]
AA PHL-RSW JUN 4>3[3] JUL 4>3[3]
*AA PHL-SAT JUN 0.9>0[1.0] JUL 1.0>0[0.2] AUG 1.0>0.5[0]
AA PHL-SBY JUL 4>3[4]
AA PHL-SCE JUL 5>4[5]
AA PHL-SDF JUN 4>3[4] JUL 4>3[4]
*AA PHL-SRQ JUN 1.0>0.2[0.3] JUL 1.0>0.1[0.3] AUG 0.5>0.1[0.3]
AA PHL-TPA JUN 5>6[6] JUL 5>6[6]
*AA PHL-XNA JUN 1.0>0.1[0.1] JUL 1.0>0[0] AUG 1.0>0.5[0]
**AA PHX-PIT JUN 1.0>0.1[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[0.9] OCT 1.0>0[1.0]
AA PHX-SAN JUN 6>5[6] JUL 6>5[6]
**AA PHX-TPA JUN 2>0.2[2] JUL 2>0[2.0] AUG 2>0[1.8] SEP 2>0[1.7] OCT 2>0[1.9]
AC ANC-YVR AUG 2>1.0[2]
AC LAS-YVR AUG 2>1.0[1.0]
AC LAX-YYZ AUG 6>7[6]
*AC SNA-YVR JUN 0>0.5[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>1.0[0]
AD BEL-FLL AUG 0.6>0.2[0.5] SEP 0.6>0.1[0.4] OCT 0.5>0.1[0.4] NOV 0.6>0.2[0.4] DEC 0.5>0.4[0.6]
AD FLL-VCP JUL 1.4>1.0[1.4] AUG 1.5>1.0[1.3] SEP 1.4>1.0[1.1] OCT 1.4>1.0[1.1] NOV 1.4>1.0[1.0]
AD JFK-VCP SEP 1.0>0.7[0] OCT 1.0>0.7[0] NOV 1.0>0.7[0]
AD MCO-REC NOV 0.5>0.1[0.3]
AD MCO-VCP JUN 1.1>0.9[1.0]
AM FAT-GDL JUL 1.4>1.0[1.0] AUG 1.1>0.8[1.0]
AM GDL-ORD JUN 0.8>1.1[1.4] JUL 1.5>1.8[2] AUG 1.1>1.3[1.5]
AS ANC-LAX OCT 1.0>0.7[0.5] NOV 1.0>0.7[0.8]
AS ANC-ORD OCT 1.0>0.2[0.7] NOV 1.0>0.4[0.4]
AS AUS-SEA JUL 2>3[2] AUG 2>3[2]
Likely their retaliation for DL CMH-SEA
**AS CVG-SEA AUG 0>0.5[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>1.0[0]
B0 EWR-ORY JUL 1.0>1.4[1.6]
While I wonder if it will fly, this looks like a JFK increase which I assume is tied to AA's continued poor slot usage at JFK.
B6 ANU-JFK JUL 0.6>0.9[0.5] AUG 0.5>0.8[0.6]
B6 ATL-JFK JUN 2>3[2] JUL 1.9>3[2] AUG 1.8>3[2]
B6 BOS-CHS JUN 2>1.7[2] JUL 2>1.1[2] AUG 2>1.2[2]
B6 BOS-DEN JUN 3>1.9[1.9]
B6 BOS-JFK JUL 6>7[5] AUG 6>7[5]
B6 BOS-ORD JUL 6>5[5] AUG 6>5[5]
B6 BOS-PBI JUN 3>4[3]
B6 BOS-PDX JUN 1.3>0.7[1.1]
B6 BOS-SJC JUN 1.6>1.0[0.9]
B6 BQN-MCO MAY 1.9>1.4[1.5] JUN 3.0>2.0[2.0] JUL 3.0>2.0[2.0] AUG 3.0>2.0[1.1]
B6 DEN-JFK MAY 2>3[1.6]
B6 FLL-JAX JUL 4>3[3]
B6 FLL-LAS MAY 2>1.2[1.0]
B6 FLL-MBJ JUL 3>2[2] AUG 3>2[2]
B6 FLL-NAS JUL 4>3[4] AUG 4>3[4]
B6 FLL-PAP JUN 2>1.8[3]
B6 FLL-RDU JUN 1.9>1.2[2] JUL 2>1.0[2]
B6 FLL-RIC MAY 1.0>0.7[1.7]
B6 JFK-KIN JUL 4>5[4] AUG 4>5[4]
B6 JFK-LAX MAY 11>12[11]
B6 JFK-MBJ JUN 2.0>3[2] JUL 2>3[3] AUG 2>3[4]
B6 JFK-MCO MAY 8>9[8] JUN 8>9[7] JUL 9>10[9]
B6 JFK-ONT JUN 1.0>1.3[1.0] JUL 1.0>1.4[1.0] AUG 1.0>1.4[1.0]
B6 JFK-ORD MAY 1.8>3[2] JUN 1.9>3[2] JUL 1.9>3[2] AUG 1.8>3[2]
B6 JFK-PLS JUL 1.1>1.4[1.0] AUG 1.2>1.4[1.0]
B6 JFK-PWM JUL 3>4[3] AUG 3>4[3]
B6 JFK-RDU JUN 2>3[2] JUL 2>3[2] AUG 2>3[2]
B6 JFK-SDQ MAY 5>6[5]
B6 JFK-SFO JUL 6>7[6] AUG 6>7[6]
B6 JFK-SMF JUN 1.0>1.4[1.0] JUL 1.0>1.5[1.0] AUG 1.0>1.5[1.0]
B6 JFK-STI JUL 7>8[8] AUG 7>8[8]
B6 JFK-TPA JUL 3>4[3] AUG 3>4[3]
B6 JFK-UVF JUN 1.0>1.3[1.1] JUL 1.1>1.5[1.0] AUG 1.2>1.6[1.0]
B6 SJU-TPA JUN 1.7>1.0[2.0] JUL 2.0>1.0[2.0] AUG 2.0>1.0[1.5]
*BW FLL-MBJ JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>0.2[0]
*DE MUC-SEA OCT 0.0>0.3[0] NOV 0>0.3[0] DEC 0>0.3[0]
I'd assume the APR cuts are COVID related, fairly few so far...
DL ALB-MSP DEC 0>1.0[0.3]
DL ATL-BHM DEC 11>10[9]
DL ATL-BUF DEC 5>4[4]
DL ATL-CID APR 3>2[3]
DL ATL-DAB APR 6>5[5] SEP 6>5[5] OCT 6>5[5] NOV 6>5[5] DEC 6>5[5]
DL ATL-DEN NOV 9>8[6]
DL ATL-EWR OCT 11>10[10] NOV 11>10[9]
DL ATL-FLL DEC 12>14[12]
*DL ATL-HND APR 1.0>0.7[0]
DL ATL-MCO APR 17>16[17] DEC 16>18[17]
DL ATL-PBI DEC 10>11[10]
DL ATL-RDU APR 13>12[12]
DL ATL-RIC DEC 9>8[7]
DL ATL-RST DEC 2>1.6[1.6]
DL ATL-RSW DEC 8>9[8]
DL ATL-SLC APR 10>9[7]
DL BDL-CVG DEC 1.0>0.6[0.6]
DL BHM-DTW DEC 3>2[2]
DL BNA-LAX DEC 1.0>1.9[1.3]
DL BNA-RDU DEC 1.8>1.1[1.2]
DL BNA-SLC DEC 3>1.8[1.0]
DL BOS-CLE OCT 3>4[2] NOV 3>4[2] DEC 3>4[2]
**DL BOS-MEM OCT 0>0.9[0] NOV 0>1.0[0] DEC 0>1.0[0]
DL BOS-SLC SEP 3>1.9[1.8]
DL BUR-SLC DEC 4>5[4]
DL BWI-CVG DEC 2>1.8[1.9]
DL BWI-RDU DEC 1.5>1.2[1.2]
DL CHA-DTW DEC 3>1.6[1.2]
*DL CHS-MSP SEP 1.0>0.2[0.0] OCT 1.0>0[0]
DL CLE-RDU DEC 0.8>0.5[0.6]
DL CLT-CVG DEC 2>1.5[1.7]
DL CMH-RDU DEC 1.7>1.1[1.1]
DL CVG-MCI DEC 1.5>1.0[1.1]
DL CVG-PHL DEC 2>1.5[1.7]
DL CVG-RDU DEC 3>2.0[1.5]
DL CVG-STL DEC 1.5>1.0[1.1]
DL CVG-YYZ APR 1.2>0.6[1.6]
DL DCA-LEX DEC 0.8>0.5[0.6]
DL DCA-MSN DEC 0.8>0.5[0.6]
DL DCA-OMA DEC 0.8>0.5[0.6]
DL DEN-JFK DEC 3>2[2]
DL DTW-EVV DEC 3>2[2]
DL DTW-FLL DEC 4>5[5]
DL DTW-HSV DEC 1.0>0.6[0.6]
DL DTW-LIT DEC 0.9>0.6[0.0]
DL DTW-PBI DEC 1.0>1.4[1.1]
DL DTW-PWM APR 3>2[3]
DL DTW-RSW DEC 4>5[5]
DL DTW-SJC AUG 1.8>1.4[0.8] SEP 1.7>0.9[0.6] OCT 1.8>1.0[0.7] NOV 1.9>1.0[0.9] DEC 1.8>1.0[1.1]
DL FLL-MSP DEC 1.0>1.4[1.4]
*DL HND-MSP APR 1.0>0.7[1.0]
*DL HND-PDX APR 0.8>0.3[0]
DL HNL-KIX APR 1.0>0.4[1.0]
DL HNL-NGO APR 0.6>0.3[0.7]
DL HNL-SEA SEP 1.3>1.0[1.0]
DL JFK-KIN APR 1.0>0.7[1.0]
*DL JFK-MXP APR 1.0>0[1.0]
DL JFK-PWM DEC 3>2[1.6]
DL JFK-SLC APR 6>5[5]
*DL JFK-VCE APR 1.0>0[1.0]
**DL KIX-SEA APR 0.8>0[1.0] MAY 0.9>0[0.9] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.7]
DL LAS-MSP OCT 7>6[6]
DL LAX-SJC SEP 7>8[6] OCT 7>8[6] NOV 7>8[6]
DL LGA-RSW SEP 3>1.9[1.9]
DL MBS-MSP DEC 0.8>0.5[0.6]
DL MCO-MSP DEC 4>5[5]
DL MSP-ORF DEC 0.8>0.5[0.1]
DL MSP-PBI DEC 0>0.4[0.3]
DL MSP-PIA DEC 0.8>0.5[0.6]
DL MSP-RIC SEP 3>1.8[1.8] OCT 3>1.8[1.7] NOV 3>1.9[1.8] DEC 3>1.5[1.6]
DL MSP-RSW DEC 3>4[4]
DL MSP-TYS DEC 1.0>0.6[0.7]
DL ORD-RDU DEC 3>2[1.7]
DL PIT-RDU DEC 0.8>0.5[0.6]
Schedule extension.
F9 ABQ-DEN AUG 0.1>0.4[0.5] SEP 0>0.4[0.5] OCT 0>0.4[0.5]
F9 ALB-DEN AUG 0.1>0.4[0.4] SEP 0>0.3[0.4] OCT 0>0.3[0.5]
F9 ALB-MCO AUG 0.1>0.3[0.4] SEP 0>0.3[0.5] OCT 0>0.3[0.4]
F9 ALB-RDU AUG 0.1>0.3[0.4] SEP 0>0.3[0.4] OCT 0>0.3[0.5]
F9 ATL-AUS AUG 0.1>0.3[0.6] SEP 0>0.3[0.6] OCT 0>0.3[0.5]
F9 ATL-CVG AUG 0.2>0.6[0.4] SEP 0>0.6[0.4] OCT 0>0.6[0.5]
F9 ATL-DEN AUG 0.3>1.0[1.4] SEP 0>1.0[1.4] OCT 0>1.0[1.5] NOV 0>0.3[1.2]
F9 ATL-EWR AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0]
F9 ATL-ISP AUG 0.2>0.6[0.6] SEP 0>0.5[0.6] OCT 0>0.4[0.5]
F9 ATL-LAS AUG 0.3>1.0[1.0] SEP 0>1.0[1.5] OCT 0>1.0[1.5] NOV 0>0.3[1.2]
F9 ATL-LAX AUG 0.1>0.5[0.4] SEP 0>0.6[0.4] OCT 0>0.6[0.5]
F9 ATL-LGA AUG 0.3>1.0[1.0] NOV 0>0.3[1.0]
F9 ATL-MCO AUG 0.3>1.0[1.1] SEP 0>1.0[1.5] OCT 0>1.0[1.5] NOV 0>0.3[1.8]
F9 ATL-MIA AUG 0.6>2[0.4] SEP 0>2[0.4] OCT 0>2[0.5] NOV 0>0.6[0.7]
F9 ATL-PHL AUG 0.3>1.0[0.4] SEP 0>1.0[0.4] OCT 0>1.0[0.5] NOV 0>0.3[0.5]
F9 ATL-RDU AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0.6]
F9 ATL-SAT AUG 0.1>0.3[0.4] SEP 0>0.3[0.4] OCT 0>0.3[0.5]
F9 ATL-SFO AUG 0.2>0.5[0.6] SEP 0>0.4[0.6] OCT 0>0.4[0.5]
F9 ATL-SJU AUG 0.3>1.0[0.4] SEP 0>0.7[0.4] OCT 0>0.7[0.5]
F9 ATL-SLC AUG 0.2>0.6[0.6] OCT 0>0.6[0.5]
F9 ATL-TPA AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0.4] NOV 0>0.3[0.4]
F9 ATL-TTN AUG 0.3>1.0[1.0] NOV 0>0.3[1.0]
F9 AUS-CLE AUG 0.2>0.6[0.3] SEP 0>0.6[0.3] OCT 0>0.6[0.3]
F9 AUS-DEN AUG 0.3>1.0[1.0] NOV 0>0.3[1.0]
F9 AUS-LAS AUG 0.3>1.0[1.0] NOV 0>0.3[1.0]
F9 AUS-MCO AUG 0.3>0.9[0.6] SEP 0>0.9[0.6] OCT 0>0.8[0.5] NOV 0>0.3[0.5]
F9 AUS-MIA AUG 0.1>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0]
F9 AUS-MSY AUG 0.2>0.5[0.4] OCT 0>0.4[0.5]
F9 AUS-ORD AUG 0.2>0.6[0.4] SEP 0>0.6[0.4] OCT 0>0.6[0.5]
F9 AUS-PHL AUG 0.1>0.3[0.5] SEP 0>0.3[0.6] OCT 0>0.3[0.5]
F9 AUS-SAN AUG 0.2>0.5[0.6] SEP 0>0.4[0.6] OCT 0>0.4[0.5]
F9 BDL-DEN AUG 0.1>0.3[0.4] SEP 0>0.3[0.4] OCT 0>0.3[0.5]
F9 BDL-MCO AUG 0.2>0.5[0.7] SEP 0>0.4[0.5] OCT 0>0.4[0.5]
F9 BDL-RDU AUG 0.2>0.6[0.4] SEP 0>0.6[0.4] OCT 0>0.6[0.5]
F9 BIL-DEN AUG 0.1>0.3[0.4] SEP 0>0.3[0.4] OCT 0>0.3[0.5]
F9 BIS-DEN AUG 0.1>0.3[0.4] SEP 0>0.3[0.4] OCT 0>0.3[0.5]
F9 BKG-DEN AUG 0.1>0.4[0.5] SEP 0>0.4[0.6] OCT 0>0.4[0.5]
F9 BMI-DEN AUG 0.1>0.3[0.4] SEP 0>0.3[0.4] OCT 0>0.3[0.5]
F9 BNA-DEN AUG 0.3>1.0[1.0] NOV 0>0.3[0.8]
F9 BNA-LAS AUG 0.2>0.5[0.6] SEP 0>0.4[0.8] OCT 0>0.4[0.8]
F9 BNA-MCO AUG 0.2>0.6[0.5] OCT 0>0.6[0.5]
F9 BNA-ORD AUG 0.2>0.6[0.3] SEP 0>0.6[0.3] OCT 0>0.6[0.3]
F9 BNA-PHL AUG 0.2>0.6[0.6] NOV 0>0.2[0.5]
F9 BNA-TTN AUG 0.1>0.3[0.4] SEP 0>0.3[0.4] OCT 0>0.3[0.5]
F9 BOS-DEN AUG 0.2>0.5[1.0] SEP 0>0.4[1.0] OCT 0>0.4[1.0]
F9 BOS-MCO AUG 0.3>0.9[1.0] SEP 0>0.8[1.0] OCT 0>0.9[1.0] NOV 0>0.3[0.9]
F9 BOS-MIA AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0.6]
F9 BOS-PHL AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0]
F9 BOS-RDU AUG 0.2>0.6[0.6] OCT 0>0.6[0.5]
F9 BOS-SJU AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0]
F9 BUF-DEN AUG 0.2>0.6[0.7] SEP 0>0.6[0.7] OCT 0>0.6[0.7]
F9 BUF-MCO AUG 0.2>0.6[1.0] SEP 0>0.6[1.0] OCT 0>0.6[1.0]
F9 BUF-RDU AUG 0.1>0.4[0.3] OCT 0>0.3[0.0]
F9 BWI-DEN AUG 0.3>1.0[0.6] SEP 0>1.0[0.6] OCT 0>1.0[0.5] NOV 0>0.3[0.6]
F9 BWI-MCO AUG 0.3>1.0[0.4] SEP 0>1.0[0.4] OCT 0>1.0[0.5] NOV 0>0.3[0.5]
F9 BWI-MIA AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0]
F9 BWI-SAL NOV 0>0.3[0]
F9 BWI-SJU AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0]
F9 BZN-DEN AUG 0.2>0.6[0.6] OCT 0>0.6[0.5]
F9 CHS-PHL AUG 0.2>0.5[0.4] SEP 0>0.4[0.3] OCT 0>0.5[0.3]
F9 CHS-TTN AUG 0.1>0.4[0.5] SEP 0>0.4[0.6] OCT 0>0.4[0.5]
F9 CID-DEN AUG 0.2>0.6[0.6] SEP 0>0.6[0.7] OCT 0>0.6[0.7]
F9 CLE-DEN AUG 0.3>1.0[1.2] SEP 0>1.0[1.1] OCT 0>1.0[1.1] NOV 0>0.3[0.8]
F9 CLE-LAS AUG 0.3>1.0[1.0] NOV 0>0.3[1.3]
F9 CLE-MCO AUG 0.6>1.9[1.3] SEP 0>1.8[1.2] OCT 0>1.9[1.3] NOV 0>0.6[1.5]
F9 CLE-MSP AUG 0.1>0.4[0.6] SEP 0>0.4[0.6] OCT 0>0.4[0.1]
F9 CLE-PHX AUG 0.2>0.5[0.6] SEP 0>0.4[0.6] OCT 0>0.4[0.6]
F9 CLE-RDU AUG 0.2>0.6[0.6] OCT 0>0.6[0.1]
F9 CLE-RSW AUG 0.5>1.6[1.0] SEP 0>1.6[1.1] OCT 0>1.6[1.2] NOV 0>0.5[1.6]
F9 CLE-SEA AUG 0.2>0.6[0.6]
F9 CLE-TPA AUG 0.4>1.3[1.6] SEP 0>1.3[1.5] OCT 0>1.3[1.5] NOV 0>0.4[1.8]
F9 CLT-DEN AUG 0.3>1.0[1.3] SEP 0>1.0[1.4] OCT 0>1.0[1.4] NOV 0>0.3[1.0]
F9 CLT-LAS AUG 0.3>1.0[1.0] NOV 0>0.3[1.0]
F9 CLT-MCO AUG 0.3>1.0[0.9] SEP 0>1.0[0.6] OCT 0>1.0[0.5] NOV 0>0.3[0.8]
F9 CLT-PHL AUG 0.3>1.0[1.0] NOV 0>0.3[1.0]
F9 CLT-TTN AUG 0.2>0.6[0.6] OCT 0>0.6[0.5]
F9 CMH-DEN AUG 0.1>0.3[0.5] SEP 0>0.3[0.6] OCT 0>0.3[0.5]
F9 COS-LAS AUG 0.3>1.0[1.3] SEP 0>1.0[1.3] OCT 0>1.0[1.3] NOV 0>0.3[1.4]
F9 COS-MCO AUG 0.1>0.3[0.6] SEP 0>0.3[0.1] OCT 0>0.3[0.5]
F9 COS-PHX AUG 0.3>1.0[1.0] NOV 0>0.3[1.2]
F9 CUN-DEN AUG 0.3>0.7[0.6] OCT 0>0.6[0.5]
F9 CUN-EWR AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0]
F9 CUN-ORD AUG 0.3>0.7[0.7] NOV 0>0.2[0.8]
F9 CVG-DEN AUG 0.3>1.0[1.1] NOV 0>0.3[0.8]
F9 CVG-DFW AUG 0.1>0.3[0.1] SEP 0>0.3[0] OCT 0>0.3[0]
F9 CVG-LAS AUG 0.3>1.0[1.0] SEP 0>1.0[1.2] OCT 0>1.0[1.3] NOV 0>0.3[1.1]
F9 CVG-LAX AUG 0.2>0.5[0.5] SEP 0>0.4[0.6] OCT 0>0.4[0.5]
F9 CVG-MCO AUG 0.3>1.0[1.1] NOV 0>0.3[1.5]
F9 CVG-MSP AUG 0.1>0.3[0.4] SEP 0>0.3[0.4] OCT 0>0.3[0.1]
F9 CVG-RSW AUG 0.1>0.3[0.5] SEP 0>0.3[0.5] OCT 0>0.3[0.5]
F9 CVG-SAN AUG 0.1>0.3[0.3] SEP 0>0.3[0.0] OCT 0>0.3[0]
F9 CVG-TPA AUG 0.2>0.5[0.9] SEP 0>0.4[0.8] OCT 0>0.5[0.7]
F9 DCA-DEN AUG 0.9>3[3] NOV 0>0.9[3]
F9 DEN-DFW AUG 0.9>3[2] SEP 0>3[2] NOV 0>0.6[1.6]
F9 DEN-DSM AUG 0.2>0.6[0.5] OCT 0>0.6[0.5]
F9 DEN-DTW AUG 0.3>1.0[0.9] NOV 0>0.3[0.5]
F9 DEN-ELP AUG 0.2>0.6[0.6] OCT 0>0.6[0.5]
F9 DEN-EWR AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0]
F9 DEN-FAR AUG 0.2>0.6[0.4] SEP 0>0.6[0.4] OCT 0>0.6[0.4]
F9 DEN-FAT AUG 0.2>0.6[0.4] SEP 0>0.6[0.4] OCT 0>0.6[0.5]
F9 DEN-FSD AUG 0.2>0.6[0.6] OCT 0>0.6[0.5]
F9 DEN-GEG AUG 0.2>0.6[0.4] SEP 0>0.5[0.4] OCT 0>0.4[0.5]
F9 DEN-GRB AUG 0.1>0.4[0.4] OCT 0>0.4[0.5]
F9 DEN-GRR AUG 0.2>0.6[0.6] SEP 0>0.5[0.6] OCT 0>0.4[0.5]
F9 DEN-HSV AUG 0.1>0.3[0.3] SEP 0>0.3[0.4] OCT 0>0.3[0.5]
F9 DEN-IAH AUG 0.3>0.9[2] SEP 0>0.8[2] OCT 0>0.9[2] NOV 0>0.3[1.4]
F9 DEN-ICT AUG 0.1>0.3[0.4] SEP 0>0.3[0.4] OCT 0>0.3[0.5]
F9 DEN-IND AUG 0.3>1.0[1.0] NOV 0>0.3[0.8]
F9 DEN-JAC AUG 0.1>0.4[0.4] SEP 0>0.4[0.3] OCT 0>0.4[0.1]
F9 DEN-LAS AUG 1.1>4[3] NOV 0>1.2[4]
F9 DEN-LAX AUG 0.9>3[2] SEP 0>3[2] OCT 0>3[2] NOV 0>0.9[2]
F9 DEN-LIT AUG 0.1>0.4[0.6] SEP 0>0.4[0.6] OCT 0>0.4[0.5]
F9 DEN-MCI AUG 0.3>1.0[1.0] NOV 0>0.3[0.7]
F9 DEN-MCO AUG 0.6>1.8[2] SEP 0>1.7[1.2] NOV 0>0.5[2]
F9 DEN-MEM AUG 0.2>0.6[0.6] OCT 0>0.6[0.5]
F9 DEN-MIA AUG 0.3>0.9[1.0] SEP 0>0.8[1.0] OCT 0>0.9[1.0] NOV 0>0.3[1.0]
F9 DEN-MKE AUG 0.3>1.0[1.3] SEP 0>1.0[1.4] OCT 0>1.0[1.5] NOV 0>0.3[0.9]
F9 DEN-MSN AUG 0.2>0.6[0.6] SEP 0>0.6[0.7] OCT 0>0.6[0.7]
F9 DEN-MSO AUG 0.1>0.4[0.5] SEP 0>0.4[0.6] OCT 0>0.4[0.5]
F9 DEN-MSP AUG 0.3>1.0[2] SEP 0>1.0[2] OCT 0>1.0[2] NOV 0>0.3[2]
F9 DEN-MSY AUG 0.3>0.8[1.0] SEP 0>0.7[1.0] OCT 0>0.7[1.0] NOV 0>0.2[0.8]
F9 DEN-OKC AUG 0.1>0.4[0.4] OCT 0>0.4[0.5]
F9 DEN-OMA AUG 0.2>0.6[0.7] SEP 0>0.6[0.7] OCT 0>0.6[0.7]
F9 DEN-ONT AUG 0.3>1.0[0.8] SEP 0>1.0[0.9] NOV 0>0.3[1.0]
F9 DEN-ORD AUG 0.3>1.0[2] SEP 0>1.0[2.0] OCT 0>1.0[2.0] NOV 0>0.3[1.4]
F9 DEN-ORF AUG 0.1>0.4[0.4] OCT 0>0.4[0.5]
F9 DEN-PDX AUG 0.6>2[1.9] NOV 0>0.6[1.4]
F9 DEN-PHL AUG 0.3>0.8[1.0] SEP 0>0.7[1.0] OCT 0>0.7[1.0] NOV 0>0.2[1.0]
F9 DEN-PHX AUG 0.9>3[2] SEP 0>3[2] OCT 0>3[2] NOV 0>0.9[3]
F9 DEN-PIT AUG 0.1>0.4[0.4] SEP 0>0.3[0.4] OCT 0>0.3[0.5]
F9 DEN-PNS AUG 0.1>0.4[0.4] OCT 0>0.4[0.5]
F9 DEN-PWM AUG 0.1>0.5[0.4] SEP 0>0.6[0.4] OCT 0>0.6[0.4]
F9 DEN-RDU AUG 0.3>1.0[1.0] NOV 0>0.3[1.0]
F9 DEN-RNO AUG 0.2>0.6[0.4] SEP 0>0.5[0.4] OCT 0>0.4[0.5]
F9 DEN-SAN AUG 0.6>2[2] NOV 0>0.6[2]
F9 DEN-SAT AUG 0.2>0.6[1.0] SEP 0>0.6[1.0] OCT 0>0.6[1.0]
F9 DEN-SBA AUG 0.1>0.3[0.4] SEP 0>0.3[0.4] OCT 0>0.3[0.5]
F9 DEN-SEA AUG 0.6>2[2] NOV 0>0.6[1.2]
F9 DEN-SFO AUG 0.9>3[2] SEP 0>3[2] OCT 0>3[2] NOV 0>0.8[2]
F9 DEN-SLC AUG 0.9>3[2] SEP 0>3[2] OCT 0>3[2] NOV 0>0.9[2]
F9 DEN-SMF AUG 0.3>1.0[0.5] SEP 0>1.0[0.6] OCT 0>1.0[0.5] NOV 0>0.3[0.5]
F9 DEN-SNA AUG 0.3>1.0[1.4] SEP 0>1.0[1.4] OCT 0>1.0[1.5] NOV 0>0.3[1.2]
F9 DEN-STL AUG 0.3>1.0[2] SEP 0>1.0[1.9] OCT 0>1.0[1.9] NOV 0>0.3[1.1]
F9 DEN-SYR AUG 0.1>0.4[0.6] SEP 0>0.3[0.6] OCT 0>0.3[0.5]
F9 DEN-TPA AUG 0.3>1.0[1.3] NOV 0>0.3[1.4]
F9 DEN-TYS AUG 0.2>0.6[0.6] OCT 0>0.6[0.5]
F9 DEN-XNA AUG 0.1>0.4[0.4] OCT 0>0.4[0.5]
F9 DFW-EWR AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0]
F9 DFW-LAS AUG 0.2>0.9[0.6] SEP 0>1.0[0.6] OCT 0>1.0[0.5] NOV 0>0.3[0.6]
F9 DFW-MCO AUG 0.3>1.0[0.6] SEP 0>1.0[0.6] OCT 0>1.0[0.5] NOV 0>0.3[0.6]
F9 DFW-PHL AUG 0.1>0.3[0.4] SEP 0>0.3[0.4] OCT 0>0.3[0.5]
F9 DTW-LAS AUG 0.3>1.0[0.6] SEP 0>1.0[0.8] OCT 0>1.0[0.8] NOV 0>0.3[0.9]
F9 DTW-MCO AUG 0.3>1.0[0.6] SEP 0>1.0[0.6] OCT 0>1.0[0.5] NOV 0>0.3[0.8]
F9 DTW-MIA AUG 0.2>0.6[0] SEP 0>0.6[0] OCT 0>0.6[0]
F9 DTW-PHX AUG 0.3>0.7[0] SEP 0>0.5[0] OCT 0>0.6[0] NOV 0>0.2[0.3]
F9 DTW-RDU AUG 0.1>0.4[0.5] SEP 0>0.4[0.1] OCT 0>0.4[0]
F9 DTW-TTN AUG 0.1>0.3[0.4] SEP 0>0.3[0.4] OCT 0>0.3[0.5]
F9 ELP-ORD AUG 0.1>0.3[0.1] SEP 0>0.3[0] OCT 0>0.3[0]
F9 EWR-LAS AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0.6]
F9 EWR-MCO AUG 0.6>2[0] SEP 0>2[0] OCT 0>2[0] NOV 0>0.6[1.1]
F9 EWR-ONT AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0]
F9 EWR-ORD AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0]
F9 EWR-PHX AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0]
F9 EWR-RDU AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0]
F9 EWR-SDQ AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0]
F9 EWR-STI AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0]
F9 EWR-TPA AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0]
F9 GUA-MIA AUG 0.2>0.6[0] SEP 0>0.6[0] OCT 0>0.6[0]
F9 GUA-ONT AUG 0.2>0.6[0] SEP 0>0.6[0] OCT 0>0.6[0]
F9 HSV-MCO AUG 0.1>0.3[0.3] SEP 0>0.3[0.4] OCT 0>0.3[0.5]
F9 IAD-MCO AUG 0.1>0.4[0.6] SEP 0>0.4[0.6] OCT 0>0.4[0.6]
F9 IAH-LAS AUG 0.1>0.8[0.4] SEP 0>1.0[0.9] NOV 0>0.3[0.8]
F9 IAH-RDU AUG 0.1>0.3[0.3] OCT 0>0.3[0.5]
F9 ILG-MCO AUG 0.1>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0]
F9 IND-LAS AUG 0.1>0.3[0.4] SEP 0>0.3[0.4] OCT 0>0.3[0.5]
F9 ISP-MCO AUG 0.6>2[1.0] SEP 0>2[0.9] OCT 0>2[0.8] NOV 0>0.6[1.5]
F9 ISP-MIA AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0]
F9 ISP-MYR AUG 0.1>0.4[0.5] OCT 0>0.4[0.5]
F9 ISP-RDU AUG 0.1>0.3[0.4] SEP 0>0.3[0.4] OCT 0>0.3[0.5]
F9 ISP-TPA AUG 0.2>0.6[0.5] OCT 0>0.6[0.5]
F9 JAX-TTN AUG 0.1>0.3[0.4] SEP 0>0.3[0.4] OCT 0>0.3[0.5]
F9 LAS-LAX AUG 0.3>1.0[0] SEP 0>1.0[0.7] NOV 0>0.3[0.6]
F9 LAS-MCO AUG 0.3>1.0[1.0] SEP 0>1.0[1.2] OCT 0>1.0[1.2] NOV 0>0.3[1.1]
F9 LAS-MIA AUG 0.3>1.0[0] SEP 0>1.0[0.7] NOV 0>0.3[0.6]
F9 LAS-MKE AUG 0.2>0.6[0.3] SEP 0>0.5[0.4] OCT 0>0.6[0.5] NOV 0>0.2[0.4]
F9 LAS-OMA AUG 0.1>0.4[0.4] OCT 0>0.4[0.5]
F9 LAS-ONT AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0]
F9 LAS-ORD AUG 0.3>1.0[1.0] NOV 0>0.3[1.0]
F9 LAS-PDX AUG 0.2>0.6[0] SEP 0>0.5[0] OCT 0>0.6[0] NOV 0>0.2[0.3]
F9 LAS-PHL AUG 0.3>1.0[1.0] SEP 0>1.0[1.2] OCT 0>1.0[1.3] NOV 0>0.3[1.1]
F9 LAS-PHX AUG 0.5>1.5[0] SEP 0>1.4[1.2] OCT 0>1.4[1.5] NOV 0>0.5[1.7]
F9 LAS-RDU AUG 0.3>1.0[1.0] NOV 0>0.3[1.0]
F9 LAS-RNO AUG 0.1>0.5[0] SEP 0>0.6[0] OCT 0>0.6[0]
F9 LAS-SAN AUG 0.3>1.0[0.7] SEP 0>1.0[0.9] OCT 0>1.0[0.8] NOV 0>0.3[0.9]
F9 LAS-SAT AUG 0.2>0.6[0.8] SEP 0>0.5[1.0] OCT 0>0.6[1.0] NOV 0>0.2[0.8]
F9 LAS-SEA AUG 0.2>0.6[0] SEP 0>0.5[0] OCT 0>0.6[0] NOV 0>0.2[0.3]
F9 LAS-SFO AUG 0.3>1.0[0.8] NOV 0>0.3[1.0]
F9 LAS-SJC AUG 0.2>0.9[0.6] SEP 0>1.0[0.9] NOV 0>0.3[0.9]
F9 LAS-SLC AUG 0.3>1.0[0.4] SEP 0>1.0[0.9] NOV 0>0.3[0.8]
F9 LAS-SMF AUG 0.3>1.0[0.8] NOV 0>0.3[1.0]
F9 LAS-SNA AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0.5]
F9 LAS-STL AUG 0.3>1.0[1.0] NOV 0>0.3[1.0]
F9 LAS-TPA AUG 0.3>1.0[1.0] NOV 0>0.3[1.0]
F9 LAX-PHL AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0]
F9 LAX-PHX AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0]
F9 LGA-MCO AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0.6]
F9 LGA-MIA AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0.6]
F9 MCO-MDT AUG 0.1>0.3[0.4] SEP 0>0.3[0.4] OCT 0>0.3[0.4]
F9 MCO-MEM AUG 0.2>0.6[0.3] SEP 0>0.6[0.3] OCT 0>0.6[0.3]
F9 MCO-MKE AUG 0.3>1.0[0.9] NOV 0>0.3[1.0]
F9 MCO-MSP AUG 0.1>0.4[0.8] SEP 0>0.4[0.9] OCT 0>0.5[1.0]
F9 MCO-MSY AUG 0.2>0.6[0.7] SEP 0>0.6[0.4] OCT 0>0.6[0.3]
F9 MCO-ONT AUG 0.3>1.0[0.8] SEP 0>1.0[0.9] NOV 0>0.3[1.0]
F9 MCO-ORD AUG 0.3>0.9[1.0] SEP 0>0.8[1.1] OCT 0>0.9[1.2] NOV 0>0.3[1.4]
F9 MCO-ORF AUG 0.1>0.4[0.3] SEP 0>0.4[0.3] OCT 0>0.4[0.3]
F9 MCO-PHL AUG 1.1>3[3] SEP 0>3[4] NOV 0>1.0[3]
F9 MCO-PVD AUG 0.1>0.3[0.8] SEP 0>0.3[0.6] OCT 0>0.3[0.5]
F9 MCO-PWM AUG 0.1>0.4[0.4] OCT 0>0.4[0.5]
F9 MCO-RDU AUG 0.2>0.9[0.9] OCT 0>1.0[0.9] NOV 0>0.3[1.0]
F9 MCO-SAT AUG 0.1>0.3[0.4] SEP 0>0.3[0.4] OCT 0>0.3[0.5]
F9 MCO-SJU AUG 0.6>2.0[2.0] OCT 0>2.0[1.8] NOV 0>0.6[1.9]
F9 MCO-STL AUG 0.3>1.0[1.0] NOV 0>0.3[1.0]
F9 MCO-SYR AUG 0.1>0.4[0.4] OCT 0>0.4[0.5]
F9 MCO-TTN AUG 0.3>1.0[1.0] NOV 0>0.3[1.6]
F9 MIA-ONT AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0]
F9 MIA-ORD AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0.6]
F9 MIA-PHL AUG 0.3>0.9[0.6] OCT 0>0.9[0.8] NOV 0>0.3[1.2]
F9 MIA-SAL AUG 0.1>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0]
F9 MIA-SDQ AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0]
F9 MIA-SJU AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0]
F9 MIA-TTN AUG 0.1>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0]
F9 MKE-TPA AUG 0.1>0.5[0.1] SEP 0>0.5[0] OCT 0>0.6[0] NOV 0>0.2[0.6]
F9 MSY-PHL AUG 0.2>0.5[0.7] SEP 0>0.4[0.7] OCT 0>0.5[0.7]
F9 MYR-TTN AUG 0.2>0.6[0.4] SEP 0>0.5[0.4] OCT 0>0.4[0.5]
F9 ONT-SAL AUG 0.1>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0]
F9 ONT-SEA AUG 0.1>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0]
F9 ORD-PHL AUG 0.1>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0]
F9 ORD-PHX AUG 0.2>0.7[0.7] SEP 0>0.7[1.0] OCT 0>0.7[1.0] NOV 0>0.2[1.0]
F9 ORD-PUJ NOV 0>0.3[1.0]
F9 ORD-SJU AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0]
F9 ORD-TPA AUG 0.3>1.0[0.4] SEP 0>1.0[0.4] OCT 0>1.0[0.5] NOV 0>0.3[0.7]
F9 ORD-TTN AUG 0.3>1.0[1.0] NOV 0>0.3[0.4]
F9 PBI-TTN AUG 0.2>0.6[0.4] SEP 0>0.6[0.4] OCT 0>0.6[0.5]
F9 PHL-RDU AUG 0.2>0.5[0.4] OCT 0>0.4[0.5]
F9 PHL-RSW AUG 0.3>1.0[0.7] SEP 0>1.0[0.9] NOV 0>0.3[1.6]
F9 PHL-SAV AUG 0.1>0.3[0.4] SEP 0>0.3[0.4] OCT 0>0.3[0.5]
F9 PHL-SJU AUG 0.6>2.0[1.7] NOV 0>0.6[2.1]
F9 PHL-TPA AUG 0.3>1.0[1.0] NOV 0>0.3[1.5]
F9 PHX-SAN AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0.6]
F9 PHX-SJC AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0]
F9 PHX-SLC AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>0.3[0.6]
F9 PWM-RDU AUG 0.1>0.5[0.4] SEP 0>0.6[0.4] OCT 0>0.6[0.4]
F9 RDU-SJU SEP 0>0.4[0.3] OCT 0>0.4[0.3]
F9 RDU-TTN AUG 0.2>0.6[0.5] OCT 0>0.6[0.5]
F9 RSW-TTN AUG 0.2>0.6[0.4] SEP 0>0.6[0.4] OCT 0>0.6[0.5]
F9 SJU-TPA AUG 0.2>0.6[0] SEP 0>0.6[0] OCT 0>0.6[0]
F9 TPA-TTN AUG 0.2>0.7[0.6] SEP 0>0.7[0.6] OCT 0>0.7[0.5] NOV 0>0.2[0.8]
GV BET-DLG JUN 0>0.4[0.3] AUG 0>0.4[0.5]
IB BOS-MAD APR 0.1>1.0[0.9] OCT 0.1>0.9[0.9]
COVID slashing
KE ATL-ICN APR 1.0>0.6[1.0]
KE BOS-ICN APR 0.5>0.1[0.5]
KE DFW-ICN APR 0.5>0.1[0.7]
KE HNL-ICN APR 1.0>0.6[1.0]
KE IAD-ICN APR 0.8>0.5[1.0]
KE ICN-LAS APR 0.7>0.1[0.7]
KE ICN-LAX APR 2>1.2[2]
KE ICN-ORD APR 0.8>0.5[1.0]
KE ICN-SEA APR 1.0>0.2[1.0]
KE ICN-SFO APR 1.3>0.8[2]
This is highly interesting. I proposed recently that PAE may see a prop carrier soak up slots at AS' behest.
**M5 BFI-PAE MAY 0>2[0] JUN 0>2[0] JUL 0>2[0] AUG 0>2[0] SEP 0>2[0] OCT 0>0.7[0]
**M5 ESD-PAE MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0] OCT 0>0.4[0]
**M5 FRD-PAE MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0] OCT 0>0.4[0]
Schedule extension. NOV is a partial month, ignore.
NK ACY-ATL SEP 0.3>0.8[0.8] NOV 0>0.4[0.3]
NK ACY-FLL SEP 0.8>3[1.7] OCT 0>3[1.7] NOV 0>1.5[2]
NK ACY-MCO SEP 0.7>3[2] OCT 0>3[2] NOV 0>1.6[2.0]
NK ACY-MYR SEP 0.4>1.3[1.0] OCT 0>1.3[1.0] NOV 0>0.7[1.0]
NK ACY-RSW SEP 0.3>1.0[1.0] NOV 0>0.6[1.6]
NK ACY-TPA SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK ATL-AUS SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK ATL-BOS SEP 0.3>1.0[0.5] OCT 0>1.0[0.5] NOV 0>0.6[0.4]
NK ATL-BWI SEP 0.8>3[3] NOV 0>1.7[2]
NK ATL-CLE SEP 0.3>0.8[0.8] OCT 0>1.0[0.7] NOV 0>0.6[0.9]
NK ATL-DFW SEP 0.5>2[1.6] OCT 0>2[1.5] NOV 0>1.1[1.3]
NK ATL-DTW SEP 0.8>2[2] NOV 0>1.1[2]
NK ATL-EWR SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK ATL-FLL SEP 1.3>5[4] OCT 0>5[4] NOV 0>3[5]
NK ATL-IAH SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK ATL-LAS SEP 0.5>2[2] NOV 0>1.1[2]
NK ATL-LAX SEP 0.5>2[1.0] OCT 0>2[1.0] NOV 0>1.1[1.0]
NK ATL-MCO SEP 0.5>1.8[1.8] NOV 0>1.0[1.9]
NK ATL-MSP SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK ATL-MSY SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK ATL-ORD SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK ATL-PHL SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK ATL-TPA SEP 0.5>2[2] NOV 0>1.1[2.0]
NK AUS-BNA SEP 0.3>0.8[0] OCT 0>0.7[0] NOV 0>0.4[0]
NK AUS-BWI SEP 0.3>0.9[0.8] OCT 0>0.9[0.7] NOV 0>0.5[0.9]
NK AUS-CUN SEP 0.1>0.4[0] OCT 0>0.5[0] NOV 0>0.2[0]
NK AUS-DEN SEP 0.3>0.8[1.0] OCT 0>0.7[1.0] NOV 0>0.4[1.0]
NK AUS-DTW SEP 0.3>0.8[1.0] OCT 0>0.7[1.0] NOV 0>0.4[1.0]
NK AUS-EWR SEP 0.3>1.0[0] OCT 0>1.0[0] NOV 0>0.6[0]
NK AUS-FLL SEP 0.3>0.8[0.8] NOV 0>0.4[0.9]
NK AUS-LAS SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK AUS-LAX SEP 0.3>0.8[0.8] NOV 0>0.4[0.9]
NK AUS-MCO SEP 0.4>1.2[0.8] OCT 0>1.2[0.7] NOV 0>0.6[0.9]
NK AUS-MSY SEP 0.3>1.0[0.8] OCT 0>1.0[0.7] NOV 0>0.6[0.9]
NK AUS-ORD SEP 0.3>1.0[0.8] OCT 0>1.0[0.7] NOV 0>0.6[0.9]
NK AVL-MCO SEP 0.3>0.8[0.5] OCT 0>0.7[0.4] NOV 0>0.4[0.8]
NK AXM-FLL SEP 0.1>0.4[0.4] OCT 0>0.4[0.5] NOV 0>0.3[0.4]
NK BAQ-FLL SEP 0.1>0.4[0] OCT 0>0.4[0] NOV 0>0.3[0]
NK BDL-FLL SEP 0.3>1.0[1.0] NOV 0>0.6[1.6]
NK BDL-MCO SEP 0.5>1.6[1.8] OCT 0>1.5[1.7] NOV 0>0.8[1.9]
NK BDL-MYR SEP 0.5>2[1.0] OCT 0>2[1.0] NOV 0>1.1[0.4]
NK BGA-FLL SEP 0.1>0.4[0] OCT 0>0.4[0] NOV 0>0.2[0]
NK BNA-BWI SEP 0.3>1.0[0] OCT 0>1.0[0.7] NOV 0>0.6[1.0]
NK BNA-CUN SEP 0.1>0.3[0] OCT 0>0.3[0]
NK BNA-EWR SEP 0.3>1.0[0] OCT 0>1.0[0] NOV 0>0.6[0]
NK BNA-FLL SEP 0.3>1.0[0] OCT 0>1.0[0.7] NOV 0>0.6[1.0]
NK BNA-LAS SEP 0.3>0.8[0] NOV 0>0.4[1.0]
NK BNA-LAX SEP 0.3>0.8[0] OCT 0>0.7[0] NOV 0>0.4[0]
NK BNA-MCO SEP 0.4>1.3[0] OCT 0>1.3[0.7] NOV 0>0.7[1.0]
NK BNA-MSY SEP 0.3>1.0[0] OCT 0>1.0[0.7] NOV 0>0.6[1.0]
NK BNA-TPA SEP 0.3>1.0[0] OCT 0>1.0[0] NOV 0>0.6[0.9]
NK BOG-FLL SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK BOG-MCO SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK BOS-BWI SEP 0.5>1.8[1.8] NOV 0>1.0[1.9]
NK BOS-CLE SEP 0.3>0.7[0.7] OCT 0>0.6[0.5] NOV 0>0.3[0.2]
NK BOS-DTW SEP 0.3>0.7[0.7] OCT 0>0.6[0.5] NOV 0>0.3[0.2]
NK BOS-FLL SEP 0.5>2[1.7] OCT 0>2[1.5] NOV 0>1.1[1.9]
NK BOS-LAS SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK BOS-MCO SEP 0.5>1.8[1.8] NOV 0>1.0[1.9]
NK BOS-MSY SEP 0.3>0.8[0.8] NOV 0>0.4[0.9]
NK BOS-MYR SEP 0.5>1.5[1.0] OCT 0>1.4[1.0] NOV 0>0.8[1.0]
NK BOS-RSW SEP 0>0.4[0.5] OCT 0>0.6[0.5] NOV 0>0.3[1.4]
NK BOS-SJU SEP 0.3>0.8[0] OCT 0>0.7[0] NOV 0>0.4[0]
NK BQN-FLL SEP 0.3>0.9[0.6] OCT 0>0.9[0.6] NOV 0>0.5[0.8]
NK BQN-MCO SEP 0.3>0.9[1.1] OCT 0>0.9[1.0] NOV 0>0.5[1.0]
NK BUR-LAS SEP 0.5>1.8[3] OCT 0>1.7[2] NOV 0>1.0[2]
NK BUR-SEA SEP 0.3>1.0[0] OCT 0>1.0[0] NOV 0>0.6[0]
NK BWI-CLT SEP 0.3>0.8[1.0] OCT 0>0.7[1.0] NOV 0>0.4[1.0]
NK BWI-CUN SEP 0.3>0.8[0.5] OCT 0>0.9[0.4] NOV 0>0.5[0.7]
NK BWI-DEN SEP 0.3>0.7[0.7] OCT 0>0.6[0.5] NOV 0>0.3[0.8]
NK BWI-DFW SEP 0.3>1.0[1.0] NOV 0>0.6[1.1]
NK BWI-DTW SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK BWI-FLL SEP 1.1>4[3] NOV 0>2[4]
NK BWI-IAH SEP 0.3>1.3[1.7] OCT 0>1.5[1.4] NOV 0>0.8[1.3]
NK BWI-JAX SEP 0.3>0.8[0.8] NOV 0>0.4[0.9]
NK BWI-LAS SEP 0.3>1.0[1.7] OCT 0>1.0[1.7] NOV 0>0.6[1.3]
NK BWI-LAX SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK BWI-MBJ SEP 0.3>0.8[0.8] NOV 0>0.4[0.9]
NK BWI-MCO SEP 1.1>4[2] OCT 0>4[2] NOV 0>2[3]
NK BWI-MSP SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK BWI-MSY SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK BWI-MYR SEP 0.6>2[1.3] OCT 0>1.7[1.3] NOV 0>1.0[0.7]
NK BWI-ORD SEP 0.5>2[1.8] OCT 0>2[1.7] NOV 0>1.1[1.3]
NK BWI-RDU SEP 0.3>0.8[1.1] OCT 0>0.7[1.0] NOV 0>0.4[1.0]
NK BWI-SAL SEP 0.3>1.0[0] OCT 0>1.0[0] NOV 0>0.6[0]
NK BWI-SEA SEP 0.3>1.0[0.1] OCT 0>1.0[0] NOV 0>0.6[0]
NK BWI-SJU SEP 0.5>1.8[0.2] OCT 0>1.7[0] NOV 0>1.0[0.6]
NK BWI-TPA SEP 0.5>2[0.9] OCT 0>2[0.9] NOV 0>1.1[0.9]
NK CAK-MCO SEP 0.3>0.9[0.8] OCT 0>0.9[0.7] NOV 0>0.5[0.9]
NK CLE-CUN SEP 0.1>0.4[0] OCT 0>0.5[0] NOV 0>0.2[0]
NK CLE-DFW SEP 0.3>0.8[0.8] NOV 0>0.4[0.3]
NK CLE-FLL SEP 0.5>2[1.2] OCT 0>2[1.1] NOV 0>1.1[1.2]
NK CLE-LAS SEP 0.5>2[1.0] OCT 0>2[1.0] NOV 0>1.1[1.0]
NK CLE-LAX SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK CLE-MCO SEP 0.7>2[1.3] OCT 0>2[1.3] NOV 0>1.4[1.1]
NK CLE-MYR SEP 0.5>1.2[0.8] OCT 0>1.0[0.7] NOV 0>0.6[0.3]
NK CLE-RSW SEP 0>0.3[0.4] OCT 0>0.5[0.4] NOV 0>0.2[0.8]
NK CLE-TPA SEP 0.3>0.8[0.7] OCT 0>1.0[0.7] NOV 0>0.6[0.9]
NK CLO-FLL SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK CLT-EWR SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK CLT-FLL SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK CLT-MCO SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK CMH-FLL SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK CMH-LAS SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK CMH-MCO SEP 0.3>1.2[1.0] OCT 0>1.3[1.0] NOV 0>0.7[1.0]
NK CMH-MSY SEP 0.1>0.4[0.3] OCT 0>0.4[0.3] NOV 0>0.3[0.1]
NK CRW-MCO SEP 0.1>0.4[0] OCT 0>0.4[0] NOV 0>0.3[0]
NK CTG-FLL SEP 0.1>0.6[0.5] NOV 0>0.3[0.6]
NK CUN-DTW SEP 0.3>0.8[0.1] OCT 0>0.7[0.1] NOV 0>0.4[0.6]
NK CUN-FLL SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK CUN-IAH SEP 0.3>0.8[0.5] OCT 0>0.9[0.4] NOV 0>0.5[0.4]
**NK CUN-MSY JUN 0>0.4[0] JUL 0>0.6[0] AUG 0>0.6[0] SEP 0>0.6[0] OCT 0>0.6[0] NOV 0>0.3[0]
NK CUN-ORD SEP 0.3>0.8[0.5] OCT 0>0.7[0.4] NOV 0>0.4[0.7]
NK CUN-PHL SEP 0.3>0.8[0] OCT 0>0.7[0] NOV 0>0.4[0]
NK CUN-PIT SEP 0.1>0.3[0] OCT 0>0.3[0]
NK DEN-DTW SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK DEN-FLL SEP 0.5>1.8[1.7] NOV 0>1.0[1.9]
NK DEN-IAH SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK DEN-LAS SEP 0.5>1.8[1.3] OCT 0>1.7[1.3] NOV 0>1.0[1.1]
NK DEN-LAX SEP 0.3>0.8[0.8] NOV 0>0.4[0.3]
NK DEN-MCO SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK DEN-MSP SEP 0.3>1.0[1.0] NOV 0>0.6[0.4]
NK DEN-ORD SEP 0.5>1.8[1.8] NOV 0>1.0[1.3]
NK DFW-DTW SEP 0.4>1.1[1.1] NOV 0>0.6[1.1]
NK DFW-FLL SEP 0.8>3[3] NOV 0>1.7[3]
NK DFW-LAS SEP 1.1>3[4] NOV 0>1.7[3]
NK DFW-LAX SEP 0.9>3[2] OCT 0>3[1.8] NOV 0>1.7[1.9]
NK DFW-LGA SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK DFW-MCO SEP 0.8>2[2] NOV 0>1.1[2.0]
NK DFW-MSY SEP 0.3>1.0[0.8] OCT 0>1.0[0.7] NOV 0>0.6[0.3]
NK DFW-ORD SEP 0.5>1.8[2] OCT 0>1.7[2] NOV 0>1.0[1.5]
NK DFW-PHL SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK DFW-PHX SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK DFW-SJD SEP 0.2>0.4[0.1] OCT 0>0.3[0]
NK DFW-TPA SEP 0.3>1.0[0.8] OCT 0>1.0[0.7] NOV 0>0.6[0.9]
NK DTW-FLL SEP 0.8>3[2] NOV 0>1.7[3]
NK DTW-IAH SEP 0.3>0.8[0.8] NOV 0>0.4[0.9]
NK DTW-LAS SEP 1.1>4[3] OCT 0>4[3] NOV 0>2[3]
NK DTW-LAX SEP 0.5>1.8[1.8] NOV 0>1.0[1.3]
NK DTW-LGA SEP 0.5>2[2] NOV 0>1.1[2]
NK DTW-MCI SEP 0.3>1.0[0.8] OCT 0>1.0[0.7] NOV 0>0.6[0.9]
NK DTW-MCO SEP 0.8>3[3] NOV 0>1.5[3]
NK DTW-MSP SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK DTW-MSY SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK DTW-MYR SEP 0.3>1.0[1.0] NOV 0>0.6[0.4]
NK DTW-PHL SEP 0.3>0.9[0.8] OCT 0>0.9[0.7] NOV 0>0.5[0.3]
NK DTW-RDU SEP 0.3>0.8[0.9] OCT 0>0.7[0.8] NOV 0>0.4[0.9]
NK DTW-RSW SEP 0.3>0.8[1.0] OCT 0>0.7[1.0] NOV 0>0.4[2]
NK DTW-TPA SEP 0.3>1.0[0.9] NOV 0>0.6[2]
NK EWR-FLL SEP 0.5>3[2] OCT 0>3[2] NOV 0>1.7[3]
NK EWR-IAH SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK EWR-LAS SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK EWR-MCO SEP 0.8>3[3] NOV 0>1.7[3]
NK EWR-MSY SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK EWR-SJU SEP 0.5>2.0[0] OCT 0>2.0[0] NOV 0>1.1[0]
NK FLL-GYE SEP 0.3>1.0[0.8] NOV 0>0.6[1.0]
NK FLL-IAH SEP 0.5>2[1.1] OCT 0>2[1.0] NOV 0>1.1[1.0]
NK FLL-KIN SEP 0.3>0.8[0.8] NOV 0>0.4[0.9]
NK FLL-LAS SEP 0.3>1.5[1.7] NOV 0>1.0[1.3]
NK FLL-LAX SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK FLL-LBE NOV 0>0.4[0.9]
NK FLL-LGA SEP 1.1>4[4] NOV 0>2[4]
NK FLL-MBJ SEP 0.3>0.8[0.8] NOV 0>0.4[0.9]
NK FLL-MCO SEP 0.5>2[2] NOV 0>1.1[2]
NK FLL-MDE SEP 0.3>1.0[0.8] OCT 0>1.0[0.7] NOV 0>0.6[0.9]
NK FLL-MGA SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK FLL-MSY SEP 0.5>2[2] NOV 0>1.1[2.0]
NK FLL-MYR SEP 0.5>2[1.4] OCT 0>2[1.4] NOV 0>1.1[1.5]
NK FLL-ORD SEP 0.8>3[2] OCT 0>3[2] NOV 0>1.5[3]
NK FLL-PAP SEP 0.3>0.8[0.8] NOV 0>0.4[0.9]
NK FLL-PIT SEP 0.5>2[1.3] OCT 0>2[1.3] NOV 0>1.1[1.7]
NK FLL-PTY SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK FLL-RDU SEP 0.3>1.0[0.8] OCT 0>1.0[0.7] NOV 0>0.6[0.9]
NK FLL-RIC SEP 0.3>1.0[0.8] NOV 0>0.6[1.0]
NK FLL-SAL SEP 0.4>1.1[0.5] OCT 0>1.0[0.4] NOV 0>0.6[0.5]
NK FLL-SAP SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK FLL-SDQ SEP 0.5>2[1.0] OCT 0>2[1.0] NOV 0>1.1[1.0]
NK FLL-SJO SEP 0.5>2[2.0] NOV 0>1.1[2]
NK FLL-SJU SEP 0.5>2.0[1.1] OCT 0>2.0[1.2] NOV 0>1.1[2.2]
NK FLL-STI SEP 0.2>0.6[0.6] OCT 0>0.6[0.5] NOV 0>0.3[0.6]
NK FLL-STT SEP 0.3>0.8[0.8] OCT 0>0.7[0.7] NOV 0>0.4[0.9]
NK FLL-TPA SEP 0.5>2[1.9] NOV 0>1.1[1.9]
NK GSO-MCO SEP 0.3>0.8[0.5] OCT 0>0.7[0.4] NOV 0>0.4[0.8]
NK GUA-IAH SEP 0.1>0.5[0.4] NOV 0>0.2[0.5]
NK IAG-MYR SEP 0.1>0.4[0.6] OCT 0>0.4[0.5] NOV 0>0.2[0.3]
NK IAH-LAS SEP 0.8>3[3] NOV 0>1.5[2]
NK IAH-LAX SEP 0.8>3[2] OCT 0>3[2] NOV 0>1.7[2]
NK IAH-MCO SEP 0.8>3[3] NOV 0>1.7[2]
NK IAH-MSY SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK IAH-OAK SEP 0.3>0.9[0.8] OCT 0>0.9[0.7] NOV 0>0.5[0.3]
NK IAH-ORD SEP 0.5>2[1.8] OCT 0>2[1.7] NOV 0>1.1[1.9]
NK IAH-SAL SEP 0.1>0.4[0.4] OCT 0>0.4[0.5] NOV 0>0.3[0.4]
NK IAH-SAN SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK IAH-SAP SEP 0.1>0.4[0.6] OCT 0>0.4[0.5] NOV 0>0.2[0.6]
NK IAH-SJD SEP 0.2>0.4[0.1] OCT 0>0.3[0]
NK IAH-TPA SEP 0.3>0.8[0.8] NOV 0>0.4[0.9]
NK IND-LAS SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK IND-MCO SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK IND-RSW SEP 0.3>0.5[0] OCT 0>0.3[0]
NK IND-TPA SEP 0.3>0.5[0] OCT 0>0.3[0]
NK LAS-LAX SEP 0.8>3[3] NOV 0>1.5[3]
NK LAS-MCI SEP 0.5>2[1.0] OCT 0>2[1.0] NOV 0>1.1[1.0]
NK LAS-MCO SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK LAS-MSP SEP 0.3>1.0[1.7] OCT 0>1.0[1.7] NOV 0>0.6[1.8]
NK LAS-MSY SEP 0.3>1.0[0.8] OCT 0>1.0[0.7] NOV 0>0.6[1.4]
NK LAS-OAK SEP 1.1>4[4] NOV 0>2[3]
NK LAS-ORD SEP 0.8>3[3] NOV 0>1.7[3]
NK LAS-PDX SEP 0.8>3[3] NOV 0>1.7[2]
NK LAS-PHL SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK LAS-PIT SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK LAS-SAN SEP 0.8>3[4] NOV 0>1.7[3]
NK LAS-SEA SEP 0.8>3[4] NOV 0>1.7[3]
NK LAS-SMF SEP 0.8>3[3] NOV 0>1.7[3]
NK LAS-TPA SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK LAX-MCI SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK LAX-MSP SEP 0.3>0.8[1.0] OCT 0>0.7[1.0] NOV 0>0.4[1.0]
NK LAX-MSY SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK LAX-OAK SEP 0.5>2[2.0] NOV 0>1.1[2.0]
NK LAX-ORD SEP 0.5>2[2] NOV 0>1.1[2]
NK LAX-PHL SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK LAX-PIT SEP 0.5>1.0[1.0] OCT 0>0.7[1.0] NOV 0>0.4[1.0]
NK LBE-MCO NOV 0>0.6[1.0]
NK LBE-MYR SEP 0.4>0.9[1.0] OCT 0>1.4[0.8] NOV 0>0.8[0.4]
NK LGA-MYR SEP 0.5>2[2] NOV 0>1.1[1.4]
NK LGA-ORD SEP 0.3>1.0[2] OCT 0>1.0[2] NOV 0>0.6[1.4]
NK MBJ-MCO SEP 0.1>0.4[0.5] OCT 0>0.4[0.5] NOV 0>0.3[0.4]
NK MCI-MCO SEP 0.3>1.3[1.0] OCT 0>1.3[1.0] NOV 0>0.7[1.0]
NK MCO-MDE SEP 0.1>0.4[0.3] OCT 0>0.4[0.3] NOV 0>0.2[0.3]
NK MCO-MSP SEP 0.3>1.0[0.8] OCT 0>1.0[0.7] NOV 0>0.6[0.9]
NK MCO-MSY SEP 0.5>2[1.0] OCT 0>2[1.0] NOV 0>1.1[1.0]
NK MCO-ORD SEP 0.3>1.0[1.0] NOV 0>0.6[1.6]
NK MCO-PHL SEP 0.8>3[3] NOV 0>1.7[3]
NK MCO-RIC SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK MCO-SJO SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK MCO-SJU SEP 1.1>3.8[2.1] OCT 0>3.7[2.0] NOV 0>2.1[2.0]
NK MSP-MSY SEP 0.1>0.4[0.5] OCT 0>0.5[0.4] NOV 0>0.2[0.5]
NK MSY-ORD SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK MSY-PHL SEP 0.1>0.6[0.5] OCT 0>0.6[0.4] NOV 0>0.3[0.2]
NK MSY-RDU SEP 0.3>1.0[0.8] OCT 0>1.0[0.7] NOV 0>0.6[0.9]
**NK MSY-SAP JUN 0>0.3[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.3[0]
NK MSY-TPA SEP 0.3>1.0[1.0] NOV 0>0.6[1.0]
NK MYR-ORD SEP 0.3>0.9[1.0] OCT 0>0.9[1.0] NOV 0>0.5[0.4]
NK MYR-PHL SEP 0.3>1.2[0.8] OCT 0>1.0[0.7] NOV 0>0.6[0.3]
NK MYR-PIT SEP 0.4>1.5[0.8] OCT 0>1.4[0.7] NOV 0>0.8[0.3]
NK OAK-ORD SEP 0.3>1.0[0.7] OCT 0>1.0[0.5] NOV 0>0.6[0.2]
NK ORD-RDU SEP 0.3>0.8[1.0] OCT 0>0.7[1.0] NOV 0>0.4[1.0]
NK ORD-RSW SEP 0.3>0.8[0.8] NOV 0>0.4[1.4]
NK ORD-SAN SEP 0.3>0.8[0.8] NOV 0>0.4[0.9]
NK ORD-SEA SEP 0.3>1.0[0.1] OCT 0>1.0[0] NOV 0>0.6[0]
NK ORD-TPA SEP 0.3>0.8[0.8] NOV 0>0.4[1.4]
NK PHL-SJU SEP 0.5>1.8[0.8] OCT 0>1.7[0.7] NOV 0>1.0[0.9]
NK PIT-TPA SEP 0>0.3[0.4] OCT 0>0.5[0.4] NOV 0>0.2[0.8]
NK SJU-TPA SEP 0.3>0.8[0.8] OCT 0>0.7[0.7] NOV 0>0.4[0.9]
QF LAX-SYD DEC 1.0>1.3[1.2]
PDX weakens for SY
*SY BNA-PDX AUG 0.6>0.2[0.6]
SY DFW-MSP MAY 0.6>0.4[0.1]
*SY HNL-PDX JUN 0.3>0[0.3] JUL 0.3>0[0.3] AUG 0.2>0[0.3]
*SY LAS-PDX MAY 0.3>0.0[0.6]
SY MSP-ORD MAY 0.6>0.5[0.6]
SY MSP-SAN MAY 0.8>0.6[0.7]
*SY PDX-SFO JUN 0.3>0[0.5] JUL 0.3>0[0.8] AUG 0.2>0[0.9]
*TJ HPN-NPT JUL 0>0.6[0] AUG 0>0.6[0]
COVID cuts
UA ABQ-DEN APR 5>4[4]
UA ABQ-SFO AUG 1.8>2[3]
UA ACV-LAX APR 2>1.1[1.0]
UA AGU-IAH APR 2>1.0[2]
UA ALB-IAD APR 3>2[3]
UA AUA-ORD APR 0.9>0.7[0.4]
UA AUS-LAX APR 1.6>1.0[1.9]
UA AUS-ORD APR 4>3[4] SEP 4>5[4]
UA AUS-SFO APR 6>5[5]
UA BHM-IAH SEP 5>6[5]
UA BIS-DEN APR 4>3[4]
UA BIS-ORD APR 2>1.0[2]
UA BJX-IAH APR 4>3[3]
UA BNA-EWR APR 7>6[6]
UA BOI-DEN APR 5>4[4]
UA BOI-ORD APR 3>2[2]
UA BOS-IAD APR 5>4[4]
UA BOS-SFO APR 6>5[7]
UA BTV-IAD APR 3>2[4]
UA BUF-IAD APR 4>3[3]
UA BUR-SFO APR 6>5[6]
UA BWI-SFO APR 1.9>1.2[1.9]
UA CAK-EWR APR 1.9>1.0[1.9] MAY 0.4>0.2[2]
**UA CAK-IAH APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0]
UA CAK-ORD SEP 5>4[5] OCT 5>4[4] NOV 5>4[4] DEC 5>4[4]
UA CHA-ORD APR 4>3[3]
UA CHO-IAD APR 3>2[3]
UA CHS-EWR APR 5>4[5]
UA CHS-IAD APR 4>3[4]
UA CID-ORD SEP 8>7[5]
UA CLE-LAX APR 1.9>1.0[1.9]
UA CLE-SFO APR 1.7>1.0[1.7]
UA CMH-EWR APR 7>6[6] JUN 8>7[7] JUL 8>7[7]
UA CMH-ORD APR 7>6[7]
UA CNY-DEN AUG 1.7>2[2.0] SEP 1.7>3[2]
UA COS-DEN APR 9>8[9]
UA COS-LAX APR 3>2.0[1.6]
UA CUN-SFO APR 2>1.1[1.4]
UA CVG-IAD APR 4>3[3]
UA DAY-DEN APR 2>1.0[2.0]
UA DDC-DEN JUN 1.3>0.9[0] JUL 1.7>0.9[0] AUG 1.7>1.2[0]
UA DDC-PUB JUN 0.5>0.9[0] JUL 0>1.0[0] AUG 0>0.5[0]
UA DEN-FAR APR 4>3[4] SEP 4>5[4]
UA DEN-FAT APR 5>4[3]
UA DEN-GJT JUL 7>6[5]
UA DEN-IAD APR 6>5[6]
UA DEN-IAH APR 10>9[10]
UA DEN-ICT APR 5>4[4]
UA DEN-IDA APR 4>3[3]
UA DEN-LAX APR 8>6[7]
UA DEN-LGA JUL 7>6[7]
UA DEN-MAF APR 4>3[3]
UA DEN-MCO APR 5>3[3]
UA DEN-MRY APR 2>1.0[2]
UA DEN-MSN APR 3>2[3]
UA DEN-ORD APR 10>9[9]
UA DEN-PAE APR 3>1.0[2.0]
UA DEN-PRC JUN 1.5>1.1[1.0] JUL 2>1.0[1.0] AUG 2>1.5[1.0]
UA DEN-PSP APR 5>4[5]
UA DEN-RAP APR 6>5[4]
UA DEN-RSW JUL 1.0>1.3[0.3] AUG 1.0>1.2[0.2]
UA DEN-SGU JUL 3>2[0] AUG 3>2[0] SEP 3>2[0.3]
UA DEN-SHR AUG 0.8>1.3[0] SEP 0.9>1.9[0] OCT 0.8>1.8[0] NOV 0.9>1.9[0] DEC 0.9>1.9[0]
UA DEN-SLC APR 7>6[6]
UA DEN-TPA APR 3>2[3]
UA DEN-TVC JUL 1.0>1.3[1.0]
UA DFW-EWR APR 6>5[5]
UA DFW-ORD APR 6>5[6]
UA DLH-ORD SEP 4>3[4]
UA DTW-EWR APR 6>5[6]
UA DTW-IAD APR 4>3[4]
UA DTW-IAH APR 5>4[5]
UA DTW-ORD AUG 8>7[8] SEP 8>5[8]
UA EUG-LAX APR 1.9>1.0[2]
*UA EUG-ORD APR 1.0>0[0] MAY 1.0>0[0]
UA EWR-EYW APR 3>2[2]
UA EWR-FCO APR 1.0>0.8[1.0]
UA EWR-FLL APR 9>8[8]
UA EWR-IAD APR 7>5[6]
UA EWR-LAS APR 7>5[6]
UA EWR-LAX APR 11>9[11] JUL 12>11[11]
UA EWR-MCO APR 12>10[11]
UA EWR-MIA APR 8>6[6]
They didn't drop it for the whole month???
*UA EWR-MXP APR 1.0>0.4[1.0]
UA EWR-OMA APR 1.9>1.1[3]
UA EWR-ORD APR 10>9[10]
UA EWR-ORF APR 6>5[4]
UA EWR-PBI APR 9>7[8]
UA EWR-PDX APR 1.9>1.0[1.7]
UA EWR-PHX APR 5>4[4]
UA EWR-PIT APR 10>8[7] JUN 8>7[7] JUL 8>7[7]
*UA EWR-PSP APR 0.3>0[0.7]
UA EWR-PVD AUG 3>4[3] SEP 3>5[3] OCT 3>5[3] NOV 3>5[3] DEC 3>5[3]
UA EWR-PWM AUG 5>6[6] SEP 5>7[6] OCT 5>7[6] NOV 5>7[5] DEC 5>7[5]
UA EWR-RDU JUN 9>8[8] JUL 9>8[8] AUG 9>8[8] SEP 9>8[8] OCT 9>8[8] NOV 9>8[8] DEC 9>8[8]
UA EWR-RIC SEP 6>7[6] OCT 6>7[6] NOV 6>7[6] DEC 6>7[5]
UA EWR-ROC SEP 4>5[4] OCT 4>5[4] NOV 4>5[5] DEC 4>5[4]
UA EWR-RSW APR 6>5[6]
UA EWR-SAV AUG 4>5[3] SEP 3>5[3] OCT 3>5[3] NOV 3>5[3] DEC 3>5[3]
UA EWR-SEA APR 3>1.7[3]
UA EWR-SFO APR 14>11[13]
*UA EWR-SLC APR 1.0>0[1.0] MAY 1.0>0.8[1.0]
UA EWR-SRQ APR 3>2[2]
UA EWR-STL SEP 5>6[6]
UA EWR-TPA APR 7>6[6]
UA EWR-YQB SEP 3>4[3] OCT 3>4[3]
UA EYW-ORD APR 2>1.0[1.0] MAY 0.6>0.4[1.0]
UA FAT-SFO APR 4>3[4]
*UA FCO-IAD APR 1.0>0[1.0]
UA FLL-IAH SEP 5>3[4]
UA FLL-ORD APR 5>4[4] AUG 1.9>1.0[1.1] SEP 3>1.0[1.1]
**UA FLL-SFO APR 1.0>0.0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0]
UA GDL-IAH APR 4>3[4]
UA GPT-IAH SEP 3>4[3] OCT 3>4[3] NOV 3>4[3] DEC 3>4[3]
UA GRK-IAH APR 3>2[3]
UA GRR-IAH APR 2>1.0[1.9]
UA GSP-IAH SEP 2>3[2.0]
UA GVA-IAD APR 0.6>0.1[0.8]
UA HHH-IAD AUG 1.3>0.7[2] SEP 0.5>0[0.5]
UA HNL-SFO APR 5>4[5]
UA HRL-IAH SEP 5>4[4]
UA HSV-IAD SEP 2>3[2.0] OCT 2>3[2.0] NOV 2>3[1.8] DEC 2>3[1.5]
UA HSV-IAH SEP 4>3[4]
UA IAD-IAH APR 4>3[4] SEP 4>5[4] OCT 4>5[4] NOV 4>5[4] DEC 4>5[5]
UA IAD-ITH APR 3>1.9[2]
UA IAD-LAS SEP 2>3[2.0] OCT 2>3[3] NOV 2>3[3] DEC 2>3[3]
UA IAD-LAX APR 7>5[7] SEP 7>6[7]
UA IAD-MCO APR 5>4[5]
UA IAD-MDT APR 4>3[3]
UA IAD-MHT APR 3>2[3] SEP 3>2[3]
UA IAD-ORD SEP 5>6[5] OCT 5>6[5] NOV 5>6[5] DEC 5>6[5]
UA IAD-ORF APR 4>3[4]
UA IAD-PIT APR 4>3[4]
UA IAD-RIC APR 4>3[4]
UA IAD-ROC APR 4>3[3]
UA IAD-SAT OCT 2>3[2] NOV 2>3[2.0] DEC 2>3[2]
UA IAD-SAV APR 3>2[3]
UA IAD-SCE APR 3>1.7[3]
UA IAD-SFO APR 8>6[8] SEP 7>6[7]
UA IAD-TYS APR 3>2[2]
UA IAD-YOW APR 3>1.9[3]
UA IAH-LAS APR 7>6[6] SEP 7>6[6]
UA IAH-LAX APR 8>7[10] SEP 11>10[9]
UA IAH-LCH AUG 2>3[3] SEP 3>4[3] OCT 3>4[3] NOV 3>4[4] DEC 3>4[3]
UA IAH-LFT SEP 5>6[6] OCT 5>6[6] NOV 5>6[6] DEC 5>6[6]
UA IAH-MCO APR 7>6[7]
UA IAH-MFE APR 7>6[6]
UA IAH-MIA APR 5>4[4] SEP 4>3[3]
UA IAH-MKE APR 1.9>1.0[2]
UA IAH-MOB SEP 5>4[4] OCT 5>4[5] NOV 5>4[6] DEC 5>4[4]
UA IAH-MOT JUL 0>0.3[0.2]
UA IAH-OAX APR 1.0>0.5[0.9]
UA IAH-ORD APR 10>9[10] SEP 9>10[9] OCT 9>10[9] NOV 9>10[9] DEC 9>10[9]
UA IAH-PHX SEP 5>4[4]
UA IAH-PTY APR 3>2[3]
UA IAH-RDU SEP 5>4[4] OCT 5>4[4] NOV 5>4[4] DEC 5>4[4]
UA IAH-RIC SEP 3>2[2]
*UA IAH-RNO APR 1.0>0[0.1] MAY 1.0>0[1.0]
UA IAH-RTB APR 1.1>0.7[1.1]
UA IAH-SAN APR 6>5[5]
UA IAH-SDF SEP 4>3[4]
UA IAH-SEA APR 5>3[5] SEP 5>4[5]
UA IAH-SFO APR 9>8[10]
UA IAH-SLC AUG 4>5[5] SEP 4>5[5] OCT 4>5[4] NOV 4>5[3] DEC 4>5[4]
UA IAH-SMF SEP 2>3[1.9] OCT 2>3[2.0] NOV 2>3[2] DEC 2>3[2]
UA IAH-TPA APR 5>4[5] SEP 5>4[4]
UA IAH-VPS APR 3>2[3]
UA IAH-XNA APR 5>4[5]
**UA IAH-YEG APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0]
UA IAH-YVR APR 1.0>0[1.0] MAY 1.0>0[1.0] AUG 1.5>2[2] SEP 1.0>2[1.1]
UA IAH-YYC APR 1.9>1.0[1.9]
Simultaneously cutting and adding, LOL!
*UA ILM-ORD APR 1.0>0[2] MAY 1.6>0[2] AUG 1.0>1.5[1.1] SEP 1.0>2[2.0] OCT 1.0>2[1.0] NOV 1.0>2[1.0] DEC 1.0>2[1.0]
UA IND-ORD APR 10>9[10]
UA IND-SFO APR 1.7>1.2[1.0] SEP 1.9>0.9[1.0]
*UA JAN-ORD APR 1.0>0[2.0] MAY 0.2>0[1.0] AUG 0.5>0[0] SEP 1.0>0[0]
UA LAS-ORD APR 6>5[5]
UA LAS-SFO APR 9>7[9] SEP 8>7[8]
UA LAX-MFR APR 1.7>1.0[1.7]
UA LAX-MRY OCT 4>5[4] NOV 4>5[4] DEC 4>5[4]
UA LAX-MSO JUN 0.7>0.9[0.5] JUL 0.6>1.0[1.0] AUG 0.3>0.5[0.6]
UA LAX-ORD APR 9>8[10] SEP 10>9[10]
UA LAX-RDM AUG 2>1.5[1.0] SEP 2>1.0[1.0]
UA LAX-SAN SEP 4>5[5]
UA LAX-SFO JUL 12>11[12]
UA LIT-ORD SEP 4>2[3]
UA LNK-ORD APR 4>3[4] SEP 4>5[4] OCT 4>5[4] NOV 4>5[4] DEC 4>5[3]
UA LWB-ORD JUL 1.0>1.3[1.0]
UA MCI-SFO APR 1.9>1.0[1.9]
UA MCO-ORD APR 7>5[6] SEP 5>4[4]
UA MCO-SFO APR 3>2[3]
UA MDT-ORD SEP 4>5[4]
UA MKE-ORD APR 9>8[9]
UA MLI-ORD SEP 4>5[4] OCT 4>5[4] NOV 4>5[4] DEC 4>5[3]
UA MSP-ORD APR 9>8[8]
**UA MSY-SFO APR 1.0>0.4[2.0] MAY 1.1>0.2[1.9] JUN 1.0>0[1.1] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0]
**UA MTJ-SFO JUL 0>0.3[0] AUG 0>0.2[0]
UA MYR-ORD JUL 1.0>1.3[1.3] AUG 0.5>0.7[0.8]
UA ONT-SFO APR 5>4[5]
UA ORD-ORF SEP 3>4[4]
UA ORD-PBI APR 2>1.0[0.9] MAY 0.5>0.2[0.3]
UA ORD-PDX APR 3>2[3]
UA ORD-PHX APR 6>5[5]
UA ORD-PIT SEP 6>7[6] OCT 6>7[6] NOV 6>7[6] DEC 6>7[5]
UA ORD-PNS APR 2>1.0[2] AUG 1.5>2[1.6] SEP 1.0>2[1.0]
UA ORD-RAP AUG 2>3[3] SEP 2>3[3]
UA ORD-ROA APR 3>1.2[3] SEP 3>4[3] OCT 3>4[3] NOV 3>4[3] DEC 3>4[3]
UA ORD-RSW APR 5>4[3]
UA ORD-SBN APR 6>5[5]
UA ORD-SDF SEP 6>7[6]
UA ORD-SEA APR 4>3[5]
UA ORD-SFO APR 10>9[11]
UA ORD-SGF SEP 4>5[5]
UA ORD-SJC AUG 1.0>1.5[1.0] SEP 1.0>2[1.7]
UA ORD-SLC SEP 3>5[3]
UA ORD-STL APR 9>8[9]
UA ORD-TPA APR 4>3[4]
UA ORD-TVC SEP 4>5[5]
UA ORD-XNA APR 5>4[4]
UA ORD-YOW SEP 3>1.9[0]
UA ORD-YVR SEP 2>3[3]
UA ORD-YYZ APR 7>6[7]
UA ORD-ZRH APR 0.9>0[0]
UA PDX-SFO SEP 8>7[7]
UA PHL-SFO APR 1.8>1.3[1.9]
UA PHX-SFO SEP 4>5[5]
UA PIT-SFO APR 1.7>1.2[1.7]
UA PSP-SFO SEP 3>4[3]
UA RDU-SFO APR 1.9>1.1[1.7] SEP 3>2[1.0]
*UA RIW-SHR AUG 1.0>0.5[0] SEP 1.0>0[0] OCT 1.0>0[0] NOV 1.0>0[0] DEC 1.0>0[0]
UA RNO-SFO APR 5>4[5] SEP 4>5[4]
UA SAN-SFO APR 9>7[9] SEP 9>8[7]
UA SBA-SFO APR 6>5[6] SEP 7>6[5]
UA SBP-SFO SEP 5>4[4]
UA SEA-SFO APR 7>6[8] SEP 8>7[7]
UA SFO-SMF APR 5>4[5] SEP 5>4[4]
UA SFO-STL AUG 2>1.5[2] SEP 2>1.0[1.1]
UA SFO-TPA APR 1.9>1.0[1.0]
**UA SFO-XNA APR 0.9>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0]
UA SFO-YYZ JUN 2>1.1[2] JUL 2>1.0[2] AUG 2>1.5[2]
Z3 AKN-EGX APR 0>0.4[0] MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.5[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0]
Z3 AKN-IGG APR 0.7>0[0] MAY 0.7>0[0] JUN 0.7>0[0] JUL 0.7>0[0] AUG 0.7>0[0] SEP 0.7>0[0] OCT 0.7>0[0] NOV 0.7>0[0] DEC 0.7>0[0]
