rjsampson wrote:For the life of me: I don't understand why widebodies weren't configured as 3-3-3 from the outset. (?)
It's pretty obvious to the industry that not only is 3-3-3 more comfortable and easier for the crew to service -- but potentially having two passengers in order to exit/evacuate is unprecedented, and surely the safety implications would have been obvious?
rjsampson wrote:It's pretty obvious to the industry that not only is 3-3-3 more comfortable and easier for the crew to service -- but potentially having two passengers in order to exit/evacuate is unprecedented, and surely the safety implications would have been obvious?
rjsampson wrote:...potentially having two passengers in order to exit/evacuate is unprecedented, and surely the safety implications would have been obvious?
RWA380 wrote:rjsampson wrote:For the life of me: I don't understand why widebodies weren't configured as 3-3-3 from the outset. (?)
It gave the carriers the opportunity to offer individual travelers & couples seating together, as well as being able to accomodate larger parties together like families, not that it's hard now. I am uncertain exactly why that changed, but I bet, as you mention, safety is the likely culprit.
tharanga wrote:I disliked the L1011 because of the middle 5, and I'm actually amazed in hindsight that airlines carried that configuration over to more modern aircraft.
DL_Mech wrote:tharanga wrote:I disliked the L1011 because of the middle 5, and I'm actually amazed in hindsight that airlines carried that configuration over to more modern aircraft.
Was 3-3-3 even offered on the 777 to early customers? Anyone know the first airline with it?
USAirALB wrote:Besides that one middle seat in the middle section, I actually think 2-5-2 is superior personally because of the twin seats.
DL/UA/AA all had 2-5-2 on their 777s. DL was the first to shift to 3-3-3 around 2003~2005. UA began to switch around 2008 or so with the IPTE retrofit. AA only switched after the merger with US was announced and they immediately switched to 3-4-3.
TTailedTiger wrote:DL_Mech wrote:tharanga wrote:I disliked the L1011 because of the middle 5, and I'm actually amazed in hindsight that airlines carried that configuration over to more modern aircraft.
Weren't Continental's 777 always 3-3-3? I heard that's why Delta switched to 3-3-3 because they were in Skyteam with Continental.
cschleic wrote:What were really nice were the KLM MD-11s that were 2-4-3. Lots of variety. In the 3 row, you could get a single on one side and a couple on the other with an empty in between.
Ziyulu wrote:I'm not understanding why the OP said it is safer to have 3-3-3? In 3-3-3, two pax per row have to climb over two people, while in 2-5-2, only one climbs, and he has a choice on which way to go.
deltairlines wrote:Give me 2-5-2 as a single traveler everyday of the week. As a window seat person, that meant only one person to climb over to get to the aisle for those times I was stuck in coach.
smi0006 wrote:Was 2-5-2 ever adopted outside the US?
DenverTed wrote:For the early 9x configurations, the DC-10s and L1011 went from 2-4-2 to 2-5-2, and the 747s started at 3-4-2, which was nice, but asymmetrical.
raylee67 wrote:KLM's MD11 has 3-4-2 config till the very end. But I think it's the only carrier going with 3-4-2 on MD11.
rjsampson wrote:Ziyulu wrote:I'm not understanding why the OP said it is safer to have 3-3-3? In 3-3-3, two pax per row have to climb over two people, while in 2-5-2, only one climbs, and he has a choice on which way to go.
I was *assuming* (perhaps incorrectly, thereby making an @$$ of U + me) that 3-3-3 is safer than 2-5-2 specifically for FAA evacuation requirements, which are based on 100% load factor. I was thinking strictly about the middle seat, needing to evacuate, in either direction (perhaps directly laterally): Two passengers, an aisle, two more passengers, then window/door (i.e. 4 seats in either direction) whereas 3-3-3 would be 3 seats in either direction.
Bad assumption? Thoughts anyone?
SpaceshipDC10 wrote:raylee67 wrote:KLM's MD11 has 3-4-2 config till the very end. But I think it's the only carrier going with 3-4-2 on MD11.
I believe about ten years before their retirement, they were reconfigured to 3-3-3.
cedarjet wrote:2-5-2 is far superior, as pointed out above, the middle seat is the only seat that’s two seats from the aisle, and you have a choice of which way out, whereas 3-3-3 has two seats that are two seats away from the aisle, and there’s only one way out.
AleksW wrote:smi0006 wrote:Was 2-5-2 ever adopted outside the US?
Finnair had 2-5-2 on their MD-11 too. Not sure if it was modified closed to its retirement, but in the early 2000 it was 2-5-2.
Max Q wrote:It does minimize the number of middle seats however if you’re in that middle it’s a special kind of claustrophobic hell
airbazar wrote:Max Q wrote:It does minimize the number of middle seats however if you’re in that middle it’s a special kind of claustrophobic hell
It has the same exact number of middle seats: 3 per row.
What it minimizes is: the number of seats more than 1 seat away from the aisle, the AVOD equipment, seat complexity, and weight.
The 3-3-3 also allows for larger overhead storage bins on the window sides as with 3 seats the bins can be extended further without protruding over the aisle.
Having said that, the loss of the 2-seat cluster was a big loss but it's making a come back in the form of premium economy.
rjsampson wrote:Ziyulu wrote:whereas 3-3-3 would be 3 seats in either direction.
