enilria
OAG Changes 3/15/2020: ARMAGEDDON + AS Exits BWI-LAX,RNO-SJC;UA Suspends SMX
Sun Mar 15, 2020 12:40 pm
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
3M ELH-FLL APR 3>2[4]
3M EYW-TPA APR 3>2[3]
3M FLL-GGT APR 1.6>1.1[1.7]
3M MCO-MHH APR 0.3>0.1[1.3]
**3M MCO-VPS APR 0.5>0.1[0] MAY 0.6>0[0.5] JUN 0.6>0[1.0] JUL 0.5>0[1.0] AUG 0.6>0[1.0]
3U HGH-LAX MAY 0.4>0[0.5] JUN 0.4>0[0.4] JUL 0.5>0[0.5] AUG 0.4>0[0.4]
3U LAX-TNA MAY 0.4>0[0.4] JUN 0.4>0[0.4] JUL 0.4>0[0.4] AUG 0.4>0[0.4]
4P BKL-LUK MAY 1.8>1.3[1.4]
4P CLT-LUK APR 0.6>0[0.7] MAY 0.5>0[0.5]
4P LUK-MDW APR 0.7>0.4[0.7] MAY 0.6>0.2[0.7]
7H AIN-ATK OCT 0.9>0.3[0.9] NOV 0.9>0.2[0.3] DEC 0.9>0.3[0.3]
7H AIN-BRW OCT 1.8>2[1.8] NOV 1.7>2[2] DEC 1.7>2[2]
7H ATK-BRW OCT 1.8>2[1.8] NOV 1.7>2[2] DEC 1.7>2[2]
7H BET-EEK APR 0.4>1.9[0.4] MAY 0.4>1.8[0.4] JUN 0.4>1.9[0.4] JUL 0.4>1.8[0.4] AUG 0.4>1.8[0.4] SEP 0.4>1.8[0.4] OCT 0.4>1.9[0.4] NOV 0.4>1.8[0.4] DEC 0.4>1.8[0.4]
7H BET-GNU APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0]
7H BET-MYU APR 0>0.9[0] MAY 0>0.9[0] JUN 0>0.9[0] JUL 0>0.9[0] AUG 0>0.9[0] SEP 0>0.9[0] OCT 0>0.9[0] NOV 0>0.9[0] DEC 0>0.9[0]
7H BET-OOK APR 0>0.9[0] MAY 0>0.9[0] JUN 0>0.9[0] JUL 0>0.9[0] AUG 0>0.9[0] SEP 0>0.9[0] OCT 0>0.9[0] NOV 0>0.9[0] DEC 0>0.9[0]
7H BET-PKA APR 1.4>0[1.4] MAY 1.4>0[1.4] JUN 1.4>0[1.4] JUL 1.4>0[1.4] AUG 1.4>0[1.4] SEP 1.4>0[1.4] OCT 1.4>0[1.4] NOV 1.4>0[1.4] DEC 1.4>0[1.4]
7H BET-PTU APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0]
7H BET-WNA APR 1.4>0[1.4] MAY 1.4>0[1.4] JUN 1.4>0[1.4] JUL 1.4>0[1.4] AUG 1.4>0[1.4] SEP 1.4>0[1.4] OCT 1.4>0[1.4] NOV 1.4>0[1.4] DEC 1.4>0[1.4]
7H BET-WTL APR 1.4>3[1.4] MAY 1.4>3[1.4] JUN 1.4>3[1.4] JUL 1.4>3[1.4] AUG 1.4>3[1.4] SEP 1.4>3[1.4] OCT 1.4>3[1.4] NOV 1.4>3[1.4] DEC 1.4>3[1.4]
7H BTI-SCC OCT 0.8>1.1[1.0] NOV 0.8>1.1[1.1] DEC 0.8>1.2[1.1]
7H EEK-WTL APR 1.4>0[1.4] MAY 1.4>0[1.4] JUN 1.4>0[1.4] JUL 1.4>0[1.4] AUG 1.4>0[1.4] SEP 1.4>0[1.4] OCT 1.4>0[1.4] NOV 1.4>0[1.4] DEC 1.4>0[1.4]
7H GNU-PTU APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0]
7H MYU-NME APR 1.0>0.1[1.0] MAY 1.0>0.1[1.0] JUN 1.0>0.1[1.0] JUL 1.0>0.1[0.5] AUG 1.0>0.1[1.0] SEP 1.0>0.1[1.0] OCT 1.0>0.1[1.0] NOV 1.0>0.1[1.0] DEC 1.0>0.1[1.0]
7H NME-TNK APR 0>0.9[0] MAY 0>0.9[0] JUN 0>0.9[0] JUL 0>0.9[0] AUG 0>0.9[0] SEP 0>0.9[0] OCT 0>0.9[0] NOV 0>0.9[0] DEC 0>0.9[0]
7H NUI-SCC OCT 1.4>2[1.4] NOV 1.4>2[2] DEC 1.4>2[2]
7H OME-SKK APR 0.4>0[0] MAY 0.3>0[0] JUN 0.4>0[0.3] JUL 0.4>0[0.4] AUG 0.3>0[0.4] SEP 0.4>0[0.3] OCT 0.4>0[0.4] NOV 0.3>0[0.3] DEC 0.4>0[0.3]
7H OME-UNK APR 0>0.4[0] MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0]
7H OOK-TNK APR 1.4>0.6[1.4] MAY 1.4>0.6[1.4] JUN 1.4>0.6[1.4] JUL 1.4>0.5[0.9] AUG 1.4>0.6[1.4] SEP 1.4>0.6[1.4] OCT 1.4>0.6[1.4] NOV 1.4>0.6[1.4] DEC 1.4>0.5[1.4]
7H PKA-WNA APR 1.4>0[1.4] MAY 1.4>0[1.4] JUN 1.4>0[1.4] JUL 1.4>0[1.4] AUG 1.4>0[1.4] SEP 1.4>0[1.4] OCT 1.4>0[1.4] NOV 1.4>0[1.4] DEC 1.4>0[1.4]
7H SKK-UNK APR 1.4>1.9[1.4] MAY 1.3>1.8[1.4] JUN 1.4>1.9[1.3] JUL 1.3>1.8[1.3] AUG 1.3>1.8[1.4] SEP 1.3>1.8[1.3] OCT 1.4>1.9[1.4] NOV 1.3>1.8[1.3] DEC 1.3>1.8[1.3]
9K BOS-PVC APR 3>0[2]
AA ABI-DFW APR 6>5[5]
AA ABQ-LAX APR 3>2[3]
AA ABQ-ORD APR 3>2[2]
AA ACT-DFW APR 5>4[5]
*AA AMS-PHL APR 1.0>0[1.0]
AA ATL-LAX APR 3>2[3]
AA ATL-ORD APR 4>3[4]
AA AUS-JFK APR 2.0>1.4[2.0]
AA AUS-LAX APR 4>2[4]
AA AVP-ORD APR 1.9>1.3[1.9]
AA AZO-ORD APR 3>2[2]
*AA BCN-CLT MAY 0.8>0[0.9]
*AA BCN-JFK APR 1.0>0[1.0]
*AA BCN-MIA APR 1.0>0[1.0]
*AA BCN-ORD APR 0.8>0[0]
*AA BCN-PHL APR 1.0>0[1.0]
AA BDA-DCA AUG 1.0>0.5[1.0]
AA BDL-ORD APR 4>3[4] MAY 5>4[5]
AA BGR-DCA MAY 2>4[3]
Something was added?
*AA BGR-LGA MAY 0>0.8[0]
AA BNA-CLT APR 9>8[8]
AA BNA-LAX APR 3>1.9[3]
AA BOI-PHX APR 2>1.2[1.9]
AA BOS-DCA MAY 10>12[14]
AA BOS-LAX APR 4>3[6]
AA BTR-DFW APR 6>5[6]
AA BWI-DFW APR 4>3[3]
AA BWI-JFK MAY 1.0>1.9[1.0]
AA BWI-PHL MAY 4>3[3]
*AA CDG-CLT APR 1.0>0[1.0]
*AA CDG-DFW APR 1.0>0[1.0]
*AA CDG-JFK APR 1.0>0[1.0]
Interesting this one goes to 5/31
*AA CDG-MIA APR 1.0>0[1.0] MAY 1.0>0[1.0]
*AA CDG-ORD APR 1.0>0[1.0]
*AA CDG-PHL APR 1.0>0[1.0]
AA CHA-PHL APR 0.9>0.2[0]
AA CLE-LGA MAY 3>4[4]
AA CLE-ORD APR 7>6[6]
AA CLE-PHL APR 6>5[5]
AA CLT-FAY APR 6>5[6]
*AA CLT-FCO APR 1.0>0[1.0] MAY 1.0>0[1.0]
*AA CLT-FRA APR 1.0>0[1.0]
AA CLT-GSP APR 9>8[9]
AA CLT-HPN APR 5>4[4]
AA CLT-IAH APR 6>5[6]
*AA CLT-MAD APR 1.0>0[1.0]
AA CLT-MOB APR 5>4[4]
AA CLT-MUC APR 1.0>0[1.0]
AA CLT-RDU APR 10>9[9]
AA CLT-SAN APR 4>3[3]
AA CLT-SEA APR 3>1.9[3]
AA CMH-ORD APR 9>7[9]
AA CMH-PHL APR 5>4[6]
AA CMH-PHX APR 2.0>1.2[1.9]
*AA COR-MIA APR 0.4>0[0]
*AA CUU-PHX APR 1.0>0.2[0] MAY 1.0>0[0]
AA CVG-LGA MAY 1.8>3[1.7]
AA CVG-ORD APR 7>6[7]
AA DEN-LAX APR 4>3[3]
*AA DFW-EZE APR 1.0>0[1.0]
*AA DFW-FCO APR 1.0>0[1.0] JUL 2.0>1.0[1.0] AUG 1.5>1.0[1.0]
AA DFW-FRA APR 1.0>0[1.0]
AA DFW-HKG APR 0.2>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0.4[1.0] AUG 1.0>0.5[1.0] SEP 1.0>0.4[1.0] OCT 1.0>0.6[1.0]
AA DFW-HRL APR 3>2[3]
*AA DFW-ICN APR 0.2>0[1.0]
AA DFW-IND APR 6>5[5]
AA DFW-JFK APR 1.6>1.2[3] MAY 1.6>2[4]
AA DFW-LHR APR 4>3[4]
*AA DFW-MAD APR 1.0>0[1.0]
*AA DFW-PEK APR 0.2>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
AA DFW-PHX APR 12>10[12]
*AA DFW-PVG APR 0.2>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
AA DFW-SAN APR 9>8[9]
*AA DFW-SCL APR 1.0>0[1.0]
AA DRO-PHX APR 2>1.2[2]
AA DTW-ORD APR 7>6[6]
AA ELP-LAX APR 3>2[3]
AA EWR-PHX APR 3>2[3]
Not part of ban YET, or did Argentina ban Americans?
*AA EZE-JFK APR 1.0>0[1.0]
*AA EZE-LAX APR 0.4>0[0.4]
AA EZE-MIA APR 1.9>0.9[1.8]
AA FAT-LAX APR 4>2[5]
AA FAT-PHX APR 5>4[5]
*AA FCO-JFK APR 1.0>0[0]
*AA FCO-ORD APR 1.0>0[1.0] MAY 1.0>0[1.0]
*AA FCO-PHL APR 1.0>0[1.0]
AA FDF-MIA AUG 1.0>0.5[1.0] SEP 0.3>0[0.1]
AA FLG-PHX APR 4>3[4]
AA FNT-ORD APR 3>2[3]
AA GGT-MIA SEP 0.7>1.0[0.8]
AA GJT-PHX APR 3>2[2]
AA GRR-ORD APR 6>4[7]
AA GRU-LAX APR 0.6>0[0.6]
*AA HKG-LAX APR 0.2>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
AA IAH-LAX APR 3>2[3]
AA IAH-PHL APR 3>2[2]
AA IAH-PHX APR 4>3[4]
AA ILM-PHL APR 4>3[3]
AA IND-LAX APR 1.9>1.1[1.1]
AA IND-ORD APR 8>6[7]
AA IND-PHX APR 2>1.2[2]
AA JFK-LAX APR 11>9[11]
AA JFK-LHR APR 4>3[4]
*AA JFK-MAD APR 1.0>0[1.0] MAY 1.0>0[1.0]
*AA JFK-MXP APR 0.2>0[1.0]
AA JFK-ORD APR 0.9>0.3[1.9] MAY 1.0>1.7[1.5]
AA JFK-ORF MAY 0>1.6[3] JUN 0.9>1.1[3]
AA JFK-PHL MAY 0.4>2[0.1] JUN 0>0.2[0]
AA JFK-RIC MAY 1.0>1.8[0]
AA LAS-PHX APR 6>5[5]
AA LAX-MCO APR 4>3[3]
AA LAX-MIA APR 9>8[9]
*AA LAX-PEK APR 0.2>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[0.9] OCT 1.0>0.3[1.0]
*AA LAX-PVG APR 0.2>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
AA LAX-RDU APR 1.2>0.3[1.8] MAY 0.9>1.4[1.0]
AA LAX-RNO APR 5>4[5]
AA LAX-SAN APR 5>3[6]
AA LAX-SEA APR 5>3[5] SEP 5>4[4]
AA LAX-SFO APR 8>5[10]
AA LAX-SJC APR 7>4[6]
AA LAX-STL APR 1.9>1.2[2.0]
AA LGA-MIA MAY 11>12[10]
AA LGA-MSP MAY 1.5>2[1.8]
AA LGA-ORF MAY 1.8>3[3]
AA LGA-PWM MAY 2>3[1.9]
AA LGA-SDF MAY 2.0>3[2.0]
AA LHR-ORD APR 4>3[4]
Interesting LHRRDU was cut before the UK ban
*AA LHR-RDU APR 1.0>0[1.0]
*AA LIS-PHL APR 1.0>0[1.0]
*AA MAD-MIA APR 1.0>0[1.0]
*AA MAD-PHL APR 1.0>0[1.0]
AA MCI-ORD APR 6>4[6]
AA MCI-PHX APR 1.8>1.2[1.8]
AA MIA-MTY APR 1.0>0.7[1.0]
*AA MIA-MVD MAY 1.0>0.2[0.9] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 0.8>0[0.7] OCT 0.7>0[0.7] NOV 0.8>0[0.7] DEC 1.0>0.5[1.0]
*AA MIA-MXP APR 0.2>0[1.0]
AA MIA-PHX APR 3>2[3]
AA MIA-STL APR 2>1.2[1.9]
AA MSN-ORD APR 6>5[5]
AA MSP-ORD APR 6>4[7]
AA OMA-ORD APR 5>4[5]
AA ONT-PHX APR 5>4[5]
AA ORD-PHX APR 9>8[9]
AA ORD-PIT APR 5>4[7]
AA ORD-SAN APR 5>4[4]
AA ORD-SAT APR 3>1.8[3]
AA ORD-SDF APR 5>4[4]
AA ORD-SEA APR 3>1.8[3]
AA ORD-SFO APR 5>4[5]
AA ORD-SJC APR 1.0>0.2[1.0] MAY 1.0>0.8[1.7]
*AA ORD-VCE MAY 0.8>0[0.9]
AA ORD-XNA APR 6>4[5]
AA PHL-PHX APR 7>6[6]
AA PHL-PIT APR 5>4[6]
AA PHL-XNA APR 0.9>0.2[0]
*AA PHL-ZRH APR 0.9>0[1.0]
AA PHX-SAF APR 2>1.2[1.0]
AA PHX-SAN APR 6>5[5]
AA PHX-SEA APR 2>1.6[4]
AA PHX-SLC APR 5>3[4]
AA PHX-SNA APR 6>4[5]
AA PHX-TUS APR 7>5[8]
AA PHX-YUM APR 5>3[5]
AC BOS-YYZ APR 8>7[8]
AC BWI-YYZ APR 3>2[3]
AC DEN-YUL APR 1.0>0.7[1.0]
AC EWR-YYZ APR 6>5[6]
AC IAH-YUL APR 2>1.0[1.7]
AC LGA-YYZ APR 12>11[12]
AC MSP-YYZ APR 3>2[3]
AC ORD-YUL APR 4>3[4]
AC ORD-YYZ APR 8>7[8]
AC PDX-YYZ JUN 0.9>0[0.3]
AC PHL-YUL APR 1.8>1.0[1.9]
AC PHL-YYZ APR 4>3[4]
AC PIT-YUL APR 1.0>0.7[0.9]
AC PIT-YYZ APR 3>2[3]
AC SEA-YUL MAY 0.9>0[0]
AC SFO-YVR APR 5>4[4]
AC SFO-YYZ APR 4>3[4]
AC SJC-YVR APR 3>2[3]
AC SJC-YYZ MAY 0.9>0[0]
AD CNF-FLL APR 0.4>0[0] MAY 0.3>0[0] JUN 0.3>0.0[0]
AD CNF-MCO APR 0.3>0[0.4] MAY 0.3>0[0.2] JUN 0.3>0.0[0.4]
AD JFK-VCP JUN 0.5>0[0] JUL 1.0>0[0] AUG 1.0>0[0]
AR EZE-MIA APR 1.8>1.0[2]
AS BIL-PDX AUG 1.5>1.0[1.0]
AS BOS-SAN AUG 1.5>2[1.0] SEP 1.0>1.3[1.0]
**AS BWI-LAX SEP 1.0>0.3[1.0] OCT 1.0>0[1.0] NOV 1.0>0[0.9] DEC 1.0>0[0.9]
AS BZN-PDX AUG 1.5>2[1.8]
AS HNL-SFO SEP 1.0>0.7[1.0] OCT 1.0>0.5[1.0] NOV 1.0>0.8[1.0]
AS KOA-PDX AUG 0.6>0.8[0]
AS KOA-SJC AUG 1.0>0.7[0.8]
AS LAX-LIR SEP 0.8>0.4[0.6]
AS LAX-MZT AUG 0.7>0.5[0.5]
AS LAX-PDX JUL 8>6[8] AUG 8>7[8]
AS OGG-PDX AUG 2>1.5[1.7] SEP 1.3>1.0[1.0]
AS OGG-SFO SEP 1.0>0.6[1.0] OCT 1.0>0.5[1.0] NOV 1.0>0.6[0.9]
**AS RNO-SJC MAY 1.0>0.0[1.8] JUN 1.0>0[1.8] JUL 1.0>0[1.8] AUG 1.0>0[1.8] SEP 1.0>0[1.9] OCT 1.0>0[1.9] NOV 1.0>0[1.8] DEC 1.0>0[1.9]
AS SAN-SFO JUL 8>7[5]
AT BOS-CMN APR 0.4>0.2[0]
AV BOG-MIA APR 4>3[4]
AV LIM-MIA APR 2>1.0[1.0]
AY HEL-JFK APR 1.4>0.7[1.0]
AY HEL-ORD APR 0.8>0.5[0.9]
AZ BOS-FCO APR 0.9>0.7[0.9]
AZ FCO-IAD APR 0.7>0[0]
AZ FCO-MIA APR 1.0>0.7[1.0]
B6 BOS-DCA SEP 15>14[13] OCT 12>11[13]
B6 EWR-SDQ APR 1.0>0.8[1.0]
B6 FLL-RIC MAY 0.7>0.5[1.7]
B6 JFK-SMF JUN 1.4>1.0[1.0] JUL 1.5>1.0[1.0] AUG 1.5>1.0[1.0]
*BA JFK-LCY APR 0.8>0[0.8] MAY 0.8>0[0.8] JUN 0.9>0[0.8] JUL 0.9>0[0.7]
BA JFK-LGW APR 1.0>0.6[1.0] MAY 1.0>0.5[1.0]
BA LGW-MCO JUN 2>1.4[1.9]
BR IAH-TPE APR 1.0>0.7[0.8]
BR JFK-TPE APR 1.0>0.8[1.0]
BR LAX-TPE APR 3>2[3]
BR SEA-TPE APR 1.3>1.0[1.0]
BR SFO-TPE APR 3>2[3]
*CA EWR-PEK APR 1.0>0[1.0]
*CA IAD-JFK APR 0>0.4[0]
*CA IAD-PEK APR 1.0>0[1.0]
*CA IAH-PEK APR 0.9>0[0.8]
*CA IAH-PTY APR 0.3>0[0.3]
*CA JFK-PEK APR 2>0.7[2]
CA LAX-PEK APR 3>1.0[3]
*CA LAX-SFO APR 0>0.6[0]
*CA LAX-SZX APR 0.4>0[0.4]
CA PEK-SFO APR 1.0>0.6[1.4]
CI LAX-TPE APR 1.4>1.0[1.0]
CI ONT-TPE APR 1.0>0.4[1.0]
I think this is only phase 1. It looks to me like they only really chopped ATL so far.
DL AGS-ATL JUN 9>7[8] JUL 9>7[8]
DL ALB-MSP DEC 1.0>0.6[0.3]
Odd they didn't cut these AMS, I'm sure next week.
DL AMS-SEA APR 2>1.6[1.4]
DL AMS-TPA APR 0.6>0.4[0]
DL ATH-JFK APR 0.7>0.5[0.6] MAY 2>1.4[1.0]
DL ATL-AVL JUL 8>7[8]
DL ATL-BOI JUL 0.8>0.6[0]
DL ATL-BOS APR 12>11[12]
DL ATL-BRU MAY 1.0>0.7[0.9]
DL ATL-BTR MAY 7>6[7]
DL ATL-BUR APR 1.7>1.0[0]
DL ATL-BWI OCT 11>10[10] NOV 11>10[10]
DL ATL-BZN JUL 0.9>0.7[0.7]
DL ATL-CDG APR 2>1.6[2]
DL ATL-CID MAY 3>2[3]
DL ATL-COS APR 0.9>0.6[0.7]
DL ATL-DUS APR 1.0>0.7[1.0]
*DL ATL-FCO APR 1.0>0[1.0] MAY 2>1.4[1.3]
DL ATL-FLL OCT 13>12[11]
DL ATL-GEG JUL 0.8>0.6[0] DEC 0.6>0.4[0]
DL ATL-GRB MAY 1.8>1.0[1.8]
DL ATL-GSO OCT 9>8[8] NOV 9>8[8]
DL ATL-HND MAY 1.0>0.7[0]
*DL ATL-ICN APR 0.7>0[0.9] MAY 1.0>0[1.0]
DL ATL-IND OCT 10>9[9] NOV 10>9[9]
DL ATL-LAS APR 9>8[8]
DL ATL-LGA APR 16>14[16]
DL ATL-MAD APR 1.0>0.7[0.8]
DL ATL-MCI OCT 9>8[7] NOV 9>8[7]
DL ATL-MCO OCT 17>16[16] NOV 17>16[17]
DL ATL-MIA OCT 11>10[10] NOV 11>10[10]
DL ATL-MUC APR 1.0>0.7[1.0]
DL ATL-OAK DEC 1.0>0.6[0.1]
DL ATL-ONT APR 2>1.6[0.2]
DL ATL-ORD SEP 11>9[10] OCT 11>9[10] NOV 11>9[10] DEC 10>9[10]
DL ATL-ORF OCT 9>8[8] NOV 9>8[8]
DL ATL-PBI OCT 10>9[9] NOV 11>10[10]
DL ATL-PHL OCT 10>9[9] NOV 10>9[9]
DL ATL-PHX NOV 7>5[6] DEC 7>5[6]
*DL ATL-PVG MAY 1.0>0[1.0]
DL ATL-RDU SEP 12>11[12]
DL ATL-RIC APR 10>9[10]
DL ATL-RST MAY 1.9>0.9[1.5]
DL ATL-RSW APR 9>8[10]
DL ATL-SAL DEC 1.0>1.3[1.3]
DL ATL-SAN APR 6>5[5]
DL ATL-SAV OCT 11>10[10] NOV 11>10[10] DEC 10>9[8]
DL ATL-SLC APR 9>8[7] OCT 10>9[8] NOV 10>9[8]
DL AUS-CVG DEC 0.8>0.5[0.6]
DL BDL-CLE DEC 0.8>0.5[0.6]
DL BDL-CVG DEC 0.6>1.0[0.6]
DL BGM-DTW APR 3>2[3] MAY 3>2[3]
DL BOG-JFK MAY 1.0>0.7[0]
DL BOM-JFK APR 1.0>0.6[0] MAY 1.0>0.6[0] JUN 1.0>0.6[0] JUL 1.0>0.6[0] AUG 1.0>0.5[0] SEP 1.0>0.6[0] OCT 1.0>0.6[0] NOV 1.0>0.7[0]
DL BOS-LAS APR 1.0>0.7[0.9]
DL BOS-LGA APR 14>13[13] JUL 14>13[12]
DL BOS-MEM DEC 1.0>0.6[0]
DL BWI-MSP OCT 4>3[3] NOV 4>3[3]
DL BWI-RDU AUG 1.7>2[1.7] SEP 1.7>3[1.7] OCT 1.7>3[1.6] NOV 1.7>3[1.5] DEC 1.2>1.9[1.2]
DL BWI-SLC APR 1.6>1.0[1.7]
*DL BZN-DTW DEC 0.4>0[0.3]
DL CDG-CVG APR 1.0>0.7[1.0]
DL CDG-DTW APR 1.5>1.0[1.4] MAY 2>1.4[2]
DL CDG-JFK MAY 2>1.4[1.0]
DL CDG-MSP APR 1.0>0.7[1.0]
DL CDG-RDU APR 1.0>0.7[1.0]
DL CDG-SEA APR 1.0>0.7[1.0]
DL CDG-SLC APR 1.0>0.7[1.0]
DL CHA-DTW MAY 2>1.8[1.6]
DL CHA-LGA DEC 0.9>0.5[0.6]
DL CLE-DTW DEC 8>6[5]
DL CMH-DTW DEC 8>7[6]
DL CMH-LAX APR 0.9>0.6[0.7]
DL CMH-SEA DEC 1.0>0.6[0]
DL CPH-JFK MAY 0.9>0.4[0.3]
DL CVG-IAH DEC 1.5>1.0[0.6]
DL CVG-LAS APR 1.0>0.7[1.0]
DL CVG-SFO APR 0.9>0.6[0.9]
DL CVG-YYZ MAY 1.5>0.8[1.5] DEC 1.5>1.0[1.1]
*DL DTW-FCO APR 1.0>0[0.8]
DL DTW-ICN MAY 1.0>0.7[1.0]
DL DTW-ITH APR 3>1.9[3] MAY 3>1.8[3]
DL DTW-LAS APR 7>6[5]
DL DTW-LEX MAY 5>4[4]
DL DTW-MCO APR 7>6[7]
*DL DTW-NGO APR 0.4>0[0.8] MAY 0.6>0[0.8]
DL DTW-OKC MAY 1.8>1.0[1.5]
*DL DTW-PKX MAY 1.0>0[0]
*DL DTW-PVG MAY 1.0>0[1.0]
DL DTW-PWM JUN 3>2[3] JUL 3>2.0[3]
DL DTW-SCE APR 3>2[3] MAY 3>1.8[3]
DL DTW-YOW SEP 1.8>3[1.8] OCT 1.8>3[1.7] NOV 1.9>3[1.7] DEC 1.8>2[1.9]
DL EWR-SLC APR 1.6>1.1[1.0] AUG 1.8>1.4[1.4]
DL FCO-JFK APR 1.0>0[1.0]
DL GJT-SLC APR 4>3[3]
DL GSO-LGA MAY 4>3[4]
DL HND-MSP APR 0.7>0.4[1.0] MAY 1.0>0.5[1.0]
*DL HND-PDX APR 0.3>0[0] MAY 1.0>0[0]
DL HNL-KIX MAY 1.0>0.5[0.9]
DL HNL-NGO MAY 0.8>0.5[0.7]
*DL ICN-MSP MAY 1.0>0[0.9]
DL ICN-SEA MAY 1.0>0.7[1.0]
DL IND-LAX APR 0.9>0.6[0.9]
DL JAC-SLC SEP 3>4[3] OCT 3>4[3] NOV 3>4[3]
DL JFK-MCO APR 5>4[5]
DL JFK-MEX MAY 1.0>2.0[1.0] JUN 1.0>2[1.0] JUL 1.0>2[1.0] AUG 1.0>1.5[1.0]
DL JFK-MXP MAY 1.0>0.4[1.0]
DL JFK-TLV JUN 2>1.5[1.5] JUL 2>1.6[2] AUG 2>1.6[2]
DL JFK-VCE MAY 1.0>0.4[1.0]
*DL JFK-YVR APR 0.6>0.0[0]
DL LAS-LGB APR 2>1.7[0] MAY 3>2.0[0]
DL LAS-PDX APR 1.7>1.0[0]
DL LAX-MEX MAY 1.0>3[3] JUN 1.0>3[1.0] JUL 1.0>3[1.0] AUG 1.0>2[3]
*DL LAX-PVG MAY 1.0>0[1.0]
DL LEX-LGA DEC 0.9>0.5[0.6]
DL LGA-MCO APR 6>5[6]
DL LGA-MEM APR 3>1.8[2]
DL LGA-MHT DEC 0.8>0.5[0.6]
DL LGA-OMA APR 3>1.9[1.8]
DL LGA-ORD APR 13>10[13]
DL LGA-PWM MAY 4>3[4]
DL LGA-XNA DEC 0.8>0.5[0.6]
DL MSP-MSY APR 2.0>1.2[1.0]
DL MSP-PSP APR 1.0>0.7[1.0]
DL MSP-SAT APR 3>2.0[2]
DL MSP-SJC APR 1.3>0.9[1.4]
DL MSP-TUL MAY 1.8>1.0[1.5]
*DL MSY-RDU APR 0.2>0[0]
*DL PKX-SEA MAY 1.0>0[0]
*DL PVG-SEA MAY 1.0>0[1.0]
DL SGU-SLC APR 5>4[4]
Meanwhile at F9 they are like "Air travel is imploding, should we cut the schedule? I guess...DEN-FLL is a little weak." :)
F9 DEN-FLL APR 0.5>0.2[1.0]
G3 BSB-MIA MAY 0.5>0[1.0] JUN 0.6>0[1.0]
GV AKN-DLG MAY 0.8>1.7[0] JUN 0.9>1.7[0] JUL 0.8>1.7[0] AUG 0.8>1.7[0] SEP 0.9>1.7[0] OCT 0.9>1.7[0] NOV 0.8>1.7[0] DEC 0.9>1.7[0]
GV AKN-EGX APR 0.9>0[0.4] MAY 0.8>0[4] JUN 0.9>0[4] JUL 0.9>0[4] AUG 0.8>0[4] SEP 0.9>0[0.4] OCT 0.9>0[0.4] NOV 0.8>0[0.4] DEC 0.9>0[0.4]
GV AKN-UGB SEP 0>0.5[0] OCT 0>0.5[0] NOV 0>0.5[0] DEC 0>0.5[0]
GV AKN-WSN MAY 0.4>1.1[1.9] JUN 0.4>1.2[1.8] JUL 0.4>1.1[1.9] AUG 0.4>1.1[1.9] SEP 0.4>1.2[1.7] OCT 0.4>1.2[1.7] NOV 0.4>1.1[1.7] DEC 0.4>1.2[1.7]
GV CDB-PML APR 0.1>0.4[0.4] MAY 0.1>0.4[0.4] JUN 0.1>0.4[0.4] JUL 0.1>0.4[0.4] AUG 0.1>0.4[0.5] SEP 0.1>0.4[0.4] OCT 0.1>0.5[0.5] NOV 0.1>0.4[0.1] DEC 0.1>0.5[0.1]
GV DLG-WSN MAY 0>0.8[1.9] JUN 0>0.9[1.8] JUL 0>0.8[1.9] AUG 0>0.8[1.9] SEP 0>0.9[1.7] OCT 0>0.9[1.7] NOV 0>0.8[1.7] DEC 0>0.9[1.7]
GV KLL-WSN MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0] NOV 0>0.3[0] DEC 0>0.3[0]
GV UGB-WSN MAY 0.4>0[0] JUN 0.4>0[0] JUL 0.4>0[0] AUG 0.4>0[0] SEP 0.4>0[0] OCT 0.4>0[0] NOV 0.4>0[0] DEC 0.4>0[0]
HA HND-HNL APR 3>2[1.6]
*HA HND-KOA APR 0.4>0[0.4]
IB MAD-ORD APR 1.0>0.7[1.0]
IB MAD-SFO APR 0.4>0[0.3]
J2 GYD-JFK APR 0.3>0[0.3]
KG MSP-TVF JUN 0>1.7[0] JUL 0>1.7[0] AUG 0>1.7[0] SEP 0>1.7[0] OCT 0>1.7[0]
LO BUD-JFK APR 0.4>0.2[0.6]
LO EWR-WAW APR 0.7>0.4[0.6]
LO LAX-WAW APR 0.8>0.6[0.9]
LO MIA-WAW APR 0.6>0.3[0]
LX IAD-ZRH APR 1.0>0.2[0]
LX JFK-ZRH APR 2>1.4[2]
NK ATL-BOS APR 0.6>0.4[0.4]
NK ATL-FLL APR 6>5[5]
NK ATL-TPA APR 2>1.3[1.5]
NK AUS-MSY APR 1.0>0.5[1.0]
NK AVL-MCO APR 0.8>0.5[0.6]
NK BNA-BWI APR 1.0>0.8[0]
NK BNA-MSY APR 1.0>0.6[0]
NK BOS-RDU APR 0.7>0.1[0]
NK BUR-LAS APR 2.0>1.2[0]
NK BWI-CLT APR 1.0>0.6[0]
NK BWI-RDU APR 1.0>0.2[0]
NK CMH-FLL APR 1.0>0.7[1.0]
NK DFW-DTW APR 1.1>0.9[1.0]
NK DTW-LAS APR 4>3[3]
*NK DTW-RDU APR 0.3>0[0] MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK FLL-KIN APR 0.8>0.4[0.7]
NK FLL-MBJ APR 1.0>0.7[1.0]
NK FLL-PHL APR 3>2[2]
NK FLL-PUJ APR 0.6>0.4[0.4]
NK FLL-RDU APR 1.0>0.8[0]
NK GSO-MCO APR 1.0>0.7[0.6]
NK IAH-TPA APR 1.0>0.7[1.0]
NK IND-RSW APR 1.0>0.7[0]
NK IND-TPA APR 1.0>0.7[0]
NK LAX-MSP APR 1.0>0.7[1.0]
NK LAX-OAK APR 1.3>1.0[2]
NK MCO-RDU APR 1.3>1.0[0]
NK MSP-MSY APR 0.6>0.4[0.6]
*NK ORD-RDU APR 0.3>0[0]
OS BOS-VIE APR 0.7>0[0] MAY 0.9>0[0]
OZ ICN-JFK APR 2>1.0[1.0]
OZ ICN-LAX APR 2>1.0[2]
OZ ICN-SEA APR 1.0>0[0.8] MAY 1.0>0.7[1.0]
PD EWR-YTZ APR 9>8[11]
*QF BNE-ORD APR 0.3>0[0] MAY 0.6>0[0]
*QF BNE-SFO MAY 0.4>0[0] JUN 0.4>0[0] JUL 0.4>0[0]
QF MEL-SFO APR 0.6>0.3[0.5] MAY 0.6>0[0.6] JUN 0.6>0[0.6] JUL 0.6>0[0.5]
S4 BOS-TER JUL 0.4>0.6[0.3]
*SQ HKG-SFO APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0]
SQ LAX-SIN APR 1.3>1.0[1.4]
SQ SFO-SIN JUN 1.4>2[1.4]
SU JFK-SVO APR 3>2[3]
*SY LAS-PDX JUN 0.3>0[0.7] JUL 0.3>0[0.7] AUG 0.2>0[0.7]
SY LAX-MSP APR 1.5>1.1[1.4] MAY 2.0>1.4[1.8]
SY MSP-SEA MAY 1.3>1.0[1.4]
SY MSP-SFO MAY 1.3>1.0[1.5]
*UA AMS-EWR APR 2>1.0[1.0]
*UA AMS-IAD APR 1.0>0[1.0]
*UA AMS-IAH APR 1.0>0[1.0]
*UA AMS-ORD APR 1.0>0[1.0]
*UA AMS-SFO APR 1.0>0[1.0]
*UA BCN-EWR APR 1.0>0[1.0]
UA BOG-IAH APR 2>1.1[2]
*UA BRU-IAD APR 1.0>0[1.0]
*UA BRU-ORD APR 0.8>0[0.8]
*UA CDG-IAD APR 1.0>0[1.0]
*UA CDG-ORD APR 1.0>0[1.0]
*UA CDG-SFO APR 1.0>0[1.0]
UA CID-ORD SEP 7>8[5]
*UA DEN-FRA APR 1.0>0[0]
UA DEN-SGU APR 3>2[3]
SMX to All appears suspended from JUN to SEP. Why?
*UA DEN-SMX JUN 0.9>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0]
UA DLH-ORD OCT 2>3[4] NOV 2>3[3]
UA DTW-EWR APR 5>6[6]
UA DTW-ORD AUG 7>8[8] SEP 5>8[8]
UA EGE-ORD AUG 1.0>0.5[0] SEP 0.2>0[0]
*UA EWR-FCO APR 0.8>0[1.0]
*UA EWR-GVA APR 1.0>0[1.0]
*UA EWR-LIS APR 1.0>0.6[1.0]
*UA EWR-MAD APR 1.0>0[1.0]
UA EWR-MEX APR 3>1.9[3]
UA EWR-MIA APR 6>5[6]
*UA EWR-MXP APR 0.4>0[1.0]
*UA EWR-OPO APR 1.0>0[0.1]
*UA EWR-POS APR 1.0>0[1.0]
UA EWR-SDQ APR 3>2[2]
*UA EWR-SLC MAY 0.8>0[1.0]
*UA EWR-TXL APR 1.0>0[1.0]
UA FRA-IAD APR 1.8>1.0[1.9]
*UA FRA-IAH APR 1.0>0[1.0]
*UA FRA-ORD APR 1.9>0[1.8]
UA FRA-SFO APR 1.8>1.0[1.9]
*UA GRU-IAD APR 1.0>0[1.0]
*UA IAD-LIS APR 1.0>0[1.0]
*UA IAD-MUC APR 1.0>0[1.0]
*UA IAD-TLV APR 0.4>0[0]
*UA IAD-ZRH APR 1.0>0[1.0]
UA IAH-MEX APR 6>5[6]
UA IAH-MTY APR 7>6[7]
UA IAH-MUC APR 0.8>0[0.9]
UA IAH-QRO APR 4>3[4]
UA IAH-RTB APR 0.7>0.9[1.1]
UA IAH-SLP APR 2>1.0[2]
Somehow JAN-ORD is back!
**UA JAN-ORD AUG 0>0.5[0] SEP 0>1.0[0]
**UA LAX-SMX JUN 0.9>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0]
UA LIT-ORD SEP 2>4[3]
UA MUC-ORD APR 1.0>0[1.0]
UA ORD-ROA APR 1.2>2[3]
**UA SFO-SMX JUN 0.9>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0]
UA SFO-TLV APR 0.8>0.6[0.9]
UX JFK-MAD APR 0.6>0[0.7]
UX MAD-MIA APR 1.0>0[1.0]
VH MDE-MIA JUL 0.6>1.2[1.0] AUG 0>1.6[1.0] SEP 0>1.6[0.6] OCT 0>1.5[0.5] NOV 0>1.6[0.6] DEC 0>1.5[1.3]
VR BOS-SID APR 0.3>0[0] MAY 0.3>0[0]
VS JFK-LHR APR 5>4[6]
VW LRD-MEX MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.5[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0]
This is the normal WN schedule extension, remember to compare to prior year. I'm too overwhelmed to look through it. Plz somebody post anything significant.
WN ABQ-LAX AUG 0.8>2[2] SEP 0>2[2.0] OCT 0>3[2]
WN ABQ-MCI AUG 0.3>0.8[0.9] OCT 0>0.9[1.0]
WN ABQ-MDW AUG 0.5>1.8[1.9] SEP 0>1.9[1.3] OCT 0>1.9[2.0]
WN ABQ-SAN AUG 0.6>1.4[1.9] SEP 0>1.1[1.8] OCT 0>1.5[1.7]
WN ABQ-SJC AUG 0.1>0.6[0.9] SEP 0>0.9[1.0] OCT 0>0.8[1.0]
WN ALB-DEN OCT 0>0.7[0]
WN ALB-MCO AUG 0.4>1.1[1.2] SEP 0>1.0[1.2] OCT 0>1.1[1.2]
WN ALB-MDW AUG 0.6>2[2] SEP 0>2[1.7] OCT 0>1.9[2.0]
WN AMA-DAL AUG 1.1>4[4] OCT 0>3[4]
WN AMA-HOU AUG 0.3>0.8[0] SEP 0>0.9[0] OCT 0>0.8[0.1]
WN ATL-AUS AUG 0.9>3[3] SEP 0>4[2] OCT 0>4[3]
WN ATL-BWI AUG 2>7[7] OCT 0>6[7]
WN ATL-CLE AUG 0.4>1.6[1.8] SEP 0>1.7[1.8] OCT 0>1.7[1.9]
WN ATL-CUN OCT 0>0.2[0.5]
WN ATL-DAL AUG 2>6[5] SEP 0>7[5] OCT 0>6[5]
WN ATL-DEN AUG 1.5>4[5] OCT 0>5[4]
WN ATL-IAD AUG 0.8>3[1.9] SEP 0>3[1.8] OCT 0>3[2]
WN ATL-JAX AUG 0.6>2[3] OCT 0>3[2.0]
WN ATL-LAX AUG 0.8>3[2.0] SEP 0>3[1.9] OCT 0>3[1.8]
WN ATL-MDW AUG 2.0>7[6] SEP 0>7[6] OCT 0>7[6]
WN ATL-MEM AUG 0.5>1.7[0] SEP 0>1.7[0] OCT 0>1.7[0]
WN ATL-MKE AUG 0.6>1.9[2] SEP 0>1.8[1.9] OCT 0>1.8[1.9]
WN ATL-PBI AUG 0.4>1.2[1.1] SEP 0>1.1[1.0] OCT 0>1.1[1.0]
WN ATL-PHL AUG 0.8>3[2] SEP 0>3[2] OCT 0>3[1.6]
WN ATL-RSW AUG 0.6>1.8[1.8] OCT 0>1.8[1.7]
WN ATL-SAN AUG 0.4>1.1[1.0] SEP 0>1.1[1.0] OCT 0>1.1[0.9]
WN ATL-SAT AUG 0.7>2[1.9] OCT 0>1.9[2]
WN AUA-BWI AUG 0.5>0.7[0.5] SEP 0>0.3[0.1] OCT 0>0.4[0.3]
WN AUS-BNA AUG 1.2>4[3] SEP 0>4[3] OCT 0>4[3]
WN AUS-FLL AUG 0.6>1.3[1.3] SEP 0>0.9[1.2] OCT 0>1.0[0.6]
WN AUS-HRL AUG 0.3>0.8[0.9] OCT 0>0.8[0.9]
WN AUS-LBB AUG 0.3>0.9[0.9] OCT 0>0.8[0.9]
WN AUS-MCI AUG 0.4>1.0[0.9] SEP 0>1.0[0.9] OCT 0>1.1[1.0]
WN AUS-OAK AUG 0.1>0.7[0.9] SEP 0>0.9[0.7] OCT 0>0.8[0.9]
WN AUS-PHX AUG 1.2>4[3] SEP 0>4[3] OCT 0>4[5]
WN AUS-RDU AUG 0.2>0.7[0.2] SEP 0>0.9[0.1] OCT 0>0.8[0]
WN AUS-SAN AUG 0.9>3[3] OCT 0>3[2]
WN AUS-SMF AUG 0.3>1.0[1.0] SEP 0>0.9[1.0] OCT 0>0.9[0.6]
WN AUS-STL AUG 0.8>3[1.9] SEP 0>3[1.9] OCT 0>2[1.9]
WN AUS-TPA AUG 0.6>1.3[1.2] OCT 0>1.7[1.8]
WN BDL-BWI AUG 1.5>5[5] SEP 0>6[5] OCT 0>6[5]
WN BDL-MCO AUG 0.5>1.3[2] SEP 0>1.0[2.0] OCT 0>1.8[2]
WN BDL-STL AUG 0.3>0.9[1.0] SEP 0>0.9[1.0] OCT 0>0.9[1.0]
WN BHM-BWI AUG 0.5>1.2[1.2] SEP 0>1.0[1.2] OCT 0>1.6[1.1]
WN BHM-HOU AUG 0.7>2[2] SEP 0>3[2] OCT 0>2.0[1.6]
WN BHM-LAS OCT 0>0.8[0]
WN BHM-TPA OCT 0>0.9[1.8]
WN BNA-BOS AUG 1.1>3[3] OCT 0>3[4]
WN BNA-BUR OCT 0>0.7[0]
WN BNA-BWI AUG 1.8>6[6] SEP 0>7[6] OCT 0>7[6]
WN BNA-CHS AUG 0.5>1.4[1.1] SEP 0>1.1[1.0] OCT 0>1.2[1.8]
WN BNA-CLT AUG 0.6>1.8[1.7] SEP 0>1.9[1.2] OCT 0>1.8[1.9]
WN BNA-CMH AUG 0.6>2[2] OCT 0>2.0[3]
WN BNA-DAL AUG 1.9>6[5] SEP 0>6[5] OCT 0>6[5]
WN BNA-HOU AUG 1.6>5[4] SEP 0>5[4] OCT 0>5[4]
WN BNA-LGA AUG 1.3>4[3] OCT 0>4[3]
WN BNA-MKE AUG 0.5>1.9[2] SEP 0>2.0[1.9] OCT 0>1.9[2]
WN BNA-MSP AUG 0.5>1.8[1.9] SEP 0>1.9[1.5] OCT 0>1.9[1.8]
WN BNA-OKC AUG 0.3>1.0[0.1] SEP 0>1.0[0.2] OCT 0>1.0[0.1]
WN BNA-OMA AUG 0.3>0.5[0.1] SEP 0>0.3[0.2]
WN BNA-ORF AUG 0.1>0.3[0.3]
WN BNA-RDU AUG 0.9>3[3] OCT 0>3[2]
WN BNA-SAN AUG 0.7>3[2] SEP 0>3[1.9] OCT 0>2[3]
WN BNA-SAT AUG 0.9>2[2] SEP 0>2[2.0] OCT 0>3[1.9]
WN BNA-SJC OCT 0>0.7[1.0]
WN BNA-STL AUG 1.0>4[3] SEP 0>4[3] OCT 0>4[3]
WN BNA-TPA AUG 1.7>5[3] SEP 0>4[3] OCT 0>4[3]
WN BOI-DEN AUG 0.7>3[2] SEP 0>3[2.0] OCT 0>3[2]
WN BOI-GEG AUG 0.5>1.7[1.7] SEP 0>1.7[1.0] OCT 0>1.7[0.9]
WN BOI-LAS AUG 0.7>3[2] SEP 0>3[2.0] OCT 0>3[2]
WN BOI-OAK AUG 0.6>2.0[2] OCT 0>1.9[2]
WN BOI-PHX AUG 0.4>1.2[1.0] SEP 0>1.1[1.0] OCT 0>1.1[0.9]
WN BOI-SAN AUG 0.3>0.9[1.0] OCT 0>1.0[0.9]
WN BOI-SJC AUG 0.3>1.0[1.7] SEP 0>0.9[1.7] OCT 0>1.4[1.0]
WN BOS-CMH AUG 0.4>1.5[1.7] SEP 0>1.6[1.0] OCT 0>1.6[1.8]
WN BOS-DAL AUG 0.4>0.6[1.1]
WN BOS-DEN AUG 0.7>3[3] SEP 0>3[2] OCT 0>2[2.0]
WN BOS-HOU AUG 0.2>0.8[1.1] SEP 0>0.9[1.1] OCT 0>0.9[1.1]
WN BUF-DEN AUG 0.3>1.0[0.2] SEP 0>1.0[0.1] OCT 0>1.0[0]
WN BUF-LAS AUG 0.3>1.1[1.1] OCT 0>1.1[1.8]
WN BUF-TPA AUG 0.4>1.2[1.1] SEP 0>1.0[1.2] OCT 0>1.2[1.3]
WN BUR-DAL AUG 0.3>1.0[1.0] SEP 0>0.9[1.0] OCT 0>0.9[1.0]
WN BUR-DEN AUG 1.1>4[3] SEP 0>4[3] OCT 0>4[3]
WN BUR-HOU AUG 0>0.7[1.0] SEP 0>0.9[1.0] OCT 0>0.9[1.0]
WN BUR-LAS AUG 3>11[10] SEP 0>11[10] OCT 0>11[10]
WN BUR-MDW AUG 0.4>1.1[0.9] SEP 0>0.9[0.8] OCT 0>0.9[1.2]
WN BUR-OAK AUG 4>12[13] OCT 0>12[13]
WN BUR-PDX AUG 0.3>1.0[1.0] SEP 0>0.9[0.7] OCT 0>0.8[0.9]
WN BUR-PHX AUG 1.7>6[6] OCT 0>6[7]
WN BUR-SJC AUG 3>11[11] OCT 0>10[11]
WN BUR-SLC AUG 0.3>0.8[0.9] OCT 0>0.8[0.9]
WN BWI-CHS AUG 1.3>4[4] SEP 0>4[3] OCT 0>4[3]
WN BWI-CUN AUG 0.7>1.5[1.3] OCT 0>1.2[1.1]
WN BWI-CVG AUG 0.7>3[3] OCT 0>3[2]
WN BWI-DAL AUG 1.5>5[4] SEP 0>5[4] OCT 0>5[4]
WN BWI-DEN AUG 1.9>6[6] OCT 0>6[5]
WN BWI-FLL AUG 3>9[8] SEP 0>9[7] OCT 0>9[7]
WN BWI-GRR AUG 0.3>1.0[1.0] SEP 0>0.9[1.0] OCT 0>0.9[1.0]
WN BWI-GSP AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0]
WN BWI-HOU AUG 1.3>5[4] SEP 0>5[4] OCT 0>5[4]
WN BWI-JAX AUG 1.2>4[4] SEP 0>4[3] OCT 0>4[3]
WN BWI-MBJ AUG 0.7>2[2] SEP 0>1.4[1.1] OCT 0>1.8[2.0]
WN BWI-MCO AUG 3>11[9] SEP 0>11[8] OCT 0>10[8]
WN BWI-MEM AUG 0.6>1.7[1.1] SEP 0>1.7[1.1] OCT 0>1.8[1.1]
WN BWI-MKE AUG 1.0>4[3] SEP 0>4[3] OCT 0>4[3]
WN BWI-MSP AUG 0.7>3[2] SEP 0>3[2.0] OCT 0>2.0[1.8]
WN BWI-NAS AUG 0.3>0.5[0.2] OCT 0>0.2[0.3]
WN BWI-OAK AUG 0.4>1.1[1.0] SEP 0>1.0[0.7] OCT 0>1.0[0.6]
WN BWI-ORF AUG 1.4>5[5] OCT 0>5[4]
WN BWI-PBI AUG 1.0>3[2] SEP 0>3[2.0] OCT 0>3[2]
WN BWI-PHX AUG 0.7>3[2] SEP 0>4[2] OCT 0>4[3]
WN BWI-PVD AUG 2>7[6] SEP 0>7[6] OCT 0>7[6]
WN BWI-PWM AUG 1.3>5[5] SEP 0>5[4] OCT 0>5[4]
WN BWI-RSW AUG 1.3>4[3] SEP 0>4[2] OCT 0>4[3]
WN BWI-SAT AUG 0.7>3[1.5] SEP 0>3[1.7] OCT 0>2[1.4]
WN BWI-SDF AUG 0.9>3[3] OCT 0>3[4]
WN BWI-SEA AUG 0.3>1.0[1.0] OCT 0>0.2[0.5]
WN BWI-SLC AUG 0.4>1.1[1.1] OCT 0>1.0[0.9]
WN BWI-TPA AUG 2>8[7] SEP 0>8[6] OCT 0>8[6]
WN CHS-DAL AUG 0.3>0.5[1.0] SEP 0>0.3[1.0] OCT 0>0.8[1.0]
WN CHS-DEN OCT 0>0.2[0.3]
WN CHS-HOU AUG 0.3>1.0[1.0] SEP 0>0.9[1.0] OCT 0>0.9[1.0]
WN CHS-MDW AUG 0.5>1.9[2] SEP 0>1.9[1.3] OCT 0>1.8[2.0]
WN CLE-LAS OCT 0>0.2[0.3]
WN CLE-MDW AUG 1.1>4[5] OCT 0>4[5]
WN CLE-MKE AUG 0.3>1.3[1.5] OCT 0>1.5[1.6]
WN CLE-PHX AUG 0.3>1.0[1.0] OCT 0>1.0[1.1]
WN CLT-DAL AUG 0.3>1.0[1.0] OCT 0>1.1[1.0]
WN CLT-HOU AUG 0.3>1.0[1.0] SEP 0>0.9[1.0] OCT 0>0.8[1.0]
WN CMH-DCA AUG 0.5>1.7[1.8] SEP 0>1.7[1.9] OCT 0>1.8[1.9]
WN CMH-DEN AUG 0.6>1.8[1.1] SEP 0>1.8[1.0] OCT 0>1.8[1.0]
WN CMH-FLL AUG 0.4>1.1[1.0] SEP 0>1.1[1.0] OCT 0>1.1[1.0]
WN CMH-LAS AUG 0.5>1.8[1.9] SEP 0>2[2.0] OCT 0>2.0[2]
WN CMH-MCO AUG 0.9>3[2] SEP 0>3[2] OCT 0>4[3]
WN CMH-PHX AUG 0.3>1.1[1.0] SEP 0>1.1[1.0] OCT 0>1.1[1.0]
WN CMH-RSW AUG 0.5>1.3[1.1] SEP 0>1.2[1.0] OCT 0>1.3[1.1]
WN CRP-HOU AUG 1.1>4[4] OCT 0>3[4]
WN CUN-DEN AUG 0.5>1.1[1.1] OCT 0>1.2[1.1]
WN CUN-HOU AUG 1.0>3[2] SEP 0>3[2] OCT 0>3[2]
WN CUN-MDW AUG 0.5>1.2[1.2] SEP 0>1.0[1.1] OCT 0>1.2[1.1]
WN CUN-STL AUG 0.3>0.5[0.2] OCT 0>0.8[1.0]
WN CVG-DEN AUG 0.3>1.0[1.0] SEP 0>0.9[1.0] OCT 0>0.9[1.0]
WN CVG-MCO OCT 0>0.2[0.3]
WN CZM-HOU AUG 0.6>1.3[0] SEP 0>0.4[0] OCT 0>0.8[0]
WN DAL-DEN AUG 3>9[7] SEP 0>9[7] OCT 0>8[7]
WN DAL-ECP AUG 0.8>2[2] OCT 0>1.2[1.0]
WN DAL-FLL AUG 1.3>3[3] OCT 0>4[3]
WN DAL-HOU AUG 6>18[18] OCT 0>18[19]
WN DAL-IND AUG 0.5>1.9[1.1] SEP 0>1.9[1.0] OCT 0>2[1.3]
WN DAL-LAS AUG 1.7>6[5] SEP 0>6[5] OCT 0>6[5]
WN DAL-LBB AUG 1.4>5[5] OCT 0>4[5]
WN DAL-LGA AUG 1.4>5[5] OCT 0>4[5]
WN DAL-LIT AUG 0.6>2[3] SEP 0>2[3] OCT 0>1.9[3]
WN DAL-MAF AUG 1.4>4[5] SEP 0>4[5] OCT 0>4[5]
WN DAL-MDW AUG 3>8[7] SEP 0>8[7] OCT 0>8[7]
WN DAL-MEM AUG 0.6>1.8[3] SEP 0>1.8[3] OCT 0>1.9[3]
WN DAL-MKE AUG 0.3>1.0[1.0] OCT 0>1.1[1.0]
WN DAL-MSP AUG 0.3>1.0[1.0] SEP 0>0.9[1.0] OCT 0>0.9[1.0]
WN DAL-OAK AUG 0.5>1.7[1.7] OCT 0>1.8[1.7]
WN DAL-PDX AUG 0.3>0.5[1.0] SEP 0>0.3[1.0]
WN DAL-PHX AUG 2>7[6] SEP 0>8[6] OCT 0>7[6]
WN DAL-PIT AUG 0.3>1.1[1.0] SEP 0>1.1[1.0] OCT 0>1.1[1.0]
WN DAL-PNS AUG 0.5>1.1[1.1] OCT 0>0.4[1.0]
WN DAL-RDU AUG 0.4>1.1[1.0] OCT 0>1.1[1.0]
WN DAL-RSW OCT 0>0.7[0]
WN DAL-SDF AUG 0.3>1.0[1.0] SEP 0>0.9[1.0] OCT 0>0.9[1.0]
WN DAL-SEA AUG 0.3>0.5[1.0] SEP 0>0.3[1.0]
WN DAL-SLC AUG 0.4>1.2[1.0] SEP 0>1.1[1.0] OCT 0>1.1[1.0]
WN DAL-TUL AUG 1.0>3[4] SEP 0>3[4] OCT 0>3[4]
WN DCA-MCO AUG 0.7>2[2] SEP 0>2[1.3] OCT 0>2[2.0]
WN DCA-PVD AUG 0.6>2[2] OCT 0>1.9[2]
WN DCA-TPA AUG 0.6>2[2] OCT 0>1.9[2]
WN DEN-DSM AUG 0.3>1.0[0] SEP 0>0.9[0] OCT 0>0.9[0]
WN DEN-DTW AUG 0.5>1.7[2.0] SEP 0>1.8[2.0] OCT 0>1.7[2]
WN DEN-ELP AUG 0.3>0.9[1.0] SEP 0>0.9[1.0] OCT 0>0.8[1.0]
WN DEN-GEG AUG 0.8>2[2] OCT 0>1.9[1.5]
WN DEN-HOU AUG 2>8[7] SEP 0>8[6] OCT 0>8[7]
WN DEN-LAS AUG 3>10[9] SEP 0>10[9] OCT 0>10[9]
WN DEN-LBB AUG 0.3>1.0[1.0] SEP 0>0.9[1.0] OCT 0>0.8[1.0]
WN DEN-MSY AUG 0.8>2[2] OCT 0>3[2]
WN DEN-OMA AUG 1.1>4[3] SEP 0>4[3] OCT 0>4[3]
WN DEN-PHL AUG 0.8>3[3] OCT 0>3[2]
WN DEN-PHX AUG 4>12[11] SEP 0>12[11] OCT 0>12[11]
WN DEN-PVR OCT 0>0.2[0.1]
WN DEN-RDU AUG 0.6>1.9[1.9] OCT 0>1.7[1.9]
WN DEN-RNO AUG 0.7>3[2] SEP 0>3[2] OCT 0>3[2]
WN DEN-SAN AUG 2>7[6] SEP 0>7[6] OCT 0>7[6]
WN DEN-SEA AUG 1.8>6[5] SEP 0>6[4] OCT 0>5[4]
WN DEN-SJD OCT 0>0.2[0.3]
WN DEN-SNA AUG 1.2>4[3] SEP 0>4[3] OCT 0>3[4]
WN DEN-TUL AUG 0.6>2[2] SEP 0>2[2.0] OCT 0>3[2]
WN DEN-TUS AUG 0.7>3[2] SEP 0>3[2] OCT 0>3[1.9]
WN DSM-STL AUG 0.6>1.8[1.8] OCT 0>1.8[1.9]
WN DTW-PHX AUG 0.4>1.1[1.0] OCT 0>1.0[0.6]
WN DTW-STL AUG 0.7>2[3] OCT 0>2.0[3]
WN ELP-SAT AUG 0.6>2[2] SEP 0>2[2.0] OCT 0>1.9[2]
WN FLL-GCM AUG 0.3>0.8[1.0] OCT 0>0.5[0.7]
WN FLL-HOU AUG 1.2>4[3] SEP 0>4[3] OCT 0>4[3]
WN FLL-IND AUG 0.5>1.2[1.0] SEP 0>1.1[1.0] OCT 0>1.3[1.1]
WN FLL-MBJ AUG 0.6>2[2] SEP 0>1.2[2] OCT 0>1.5[2]
WN FLL-MCI AUG 0.5>1.1[1.1] SEP 0>1.1[1.0] OCT 0>1.2[1.0]
WN FLL-MSY AUG 0.6>2[2.0] SEP 0>2[1.4] OCT 0>1.9[1.7]
WN FLL-NAS AUG 0.6>2[2] OCT 0>1.9[2]
WN FLL-PHX AUG 0.4>1.0[1.1] SEP 0>0.9[1.2] OCT 0>0.9[1.1]
WN FLL-RDU AUG 0.1>0.8[1.0] SEP 0>1.1[1.0] OCT 0>1.1[0.8]
WN FLL-SAT AUG 0.3>0.5[1.0]
WN FLL-SJU AUG 1.0>2.3[2.1] SEP 0>2.0[1.4] OCT 0>2.1[3.0]
WN FLL-STL AUG 0.9>2[3] SEP 0>2[1.9] OCT 0>2[1.9]
WN GEG-LAS AUG 0.6>2.0[2] SEP 0>2[1.7] OCT 0>1.9[2.0]
WN GEG-OAK AUG 0.5>1.9[2] SEP 0>1.9[2.0] OCT 0>1.9[1.7]
WN GEG-SJC AUG 0.3>1.0[1.0] SEP 0>0.9[1.0] OCT 0>0.8[0.6]
WN HNL-ITO AUG 1.3>4[0] SEP 0>4[0] OCT 0>4[0]
WN HNL-LIH AUG 1.3>4[0] SEP 0>4[0] OCT 0>4[0]
WN HNL-OAK AUG 0.6>2[2] OCT 0>1.9[2]
WN HNL-OGG AUG 1.9>6[4] SEP 0>6[4] OCT 0>6[4]
WN HNL-SAN AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0]
WN HNL-SMF AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0]
WN HOU-IND AUG 0.4>1.6[1.9] SEP 0>1.9[1.8] OCT 0>1.9[2]
WN HOU-JAX AUG 0.6>1.3[1.0] OCT 0>1.0[0.7]
WN HOU-LAX AUG 1.4>5[5] OCT 0>4[5]
WN HOU-LBB AUG 0.3>1.0[0.1] SEP 0>1.0[0.2] OCT 0>1.0[0.1]
WN HOU-LIT AUG 0.4>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0]
WN HOU-MAF AUG 1.2>4[4] OCT 0>3[4]
WN HOU-MBJ AUG 0.5>0.6[0.5] OCT 0>0.8[1.0]
WN HOU-MCO AUG 1.7>5[4] SEP 0>5[4] OCT 0>5[4]
WN HOU-MKE AUG 0.4>1.7[1.0] SEP 0>1.9[1.0] OCT 0>1.8[1.0]
WN HOU-OMA AUG 0.2>0.9[1.0] SEP 0>0.9[1.0] OCT 0>0.9[1.0]
WN HOU-PIT AUG 0.3>1.7[1.0] SEP 0>1.9[1.0] OCT 0>1.9[1.3]
WN HOU-PNS AUG 0.4>1.1[1.0] SEP 0>1.1[1.0] OCT 0>1.1[1.0]
WN HOU-RDU AUG 0.4>1.1[1.0] OCT 0>1.1[1.0]
WN HOU-SAT AUG 1.7>6[5] OCT 0>6[5]
WN HOU-SDF AUG 0.3>0.9[1.0] SEP 0>0.9[1.0] OCT 0>0.9[1.0]
WN HOU-SJD AUG 0.6>2[1.1] SEP 0>2[1.0] OCT 0>1.9[1.1]
WN HOU-SMF AUG 0.3>1.0[0.1] SEP 0>1.0[0.1] OCT 0>1.0[0]
WN HOU-TPA AUG 1.2>4[2] SEP 0>4[3] OCT 0>4[3]
WN ICT-STL AUG 0.6>1.8[1.8] OCT 0>1.8[1.9]
WN IND-LAS AUG 0.8>2[2] OCT 0>3[2]
WN IND-LAX OCT 0>0.7[0.6]
WN IND-MCI AUG 0.5>1.5[1.8] SEP 0>1.6[1.8] OCT 0>1.7[1.9]
WN IND-MCO AUG 1.1>3[2] SEP 0>3[2] OCT 0>4[3]
WN IND-MDW AUG 0.3>1.0[1.2] SEP 0>1.0[1.4] OCT 0>1.0[0.9]
WN IND-PHX AUG 0.6>1.8[1.7] SEP 0>1.7[1.4] OCT 0>1.8[1.5]
WN ISP-PBI AUG 0.5>1.3[2.0] SEP 0>1.0[2.0] OCT 0>1.5[1.9]
WN ISP-TPA AUG 0.3>0.9[1.0] SEP 0>0.9[1.0] OCT 0>0.9[1.0]
WN JAX-MDW AUG 0.3>1.0[1.0] OCT 0>1.1[0.9]
WN KOA-OAK AUG 0.3>0.7[0] SEP 0>0.6[0] OCT 0>0.5[0]
WN KOA-OGG AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0]
WN KOA-SJC AUG 0.3>0.6[0] SEP 0>0.4[0] OCT 0>0.4[0]
WN LAS-LGB AUG 0.3>0.6[3] SEP 0>0.5[3] OCT 0>0.5[0.8]
WN LAS-MCO AUG 0.6>3[1.9] SEP 0>3[1.5] OCT 0>1.6[2.0]
WN LAS-MDW AUG 2>8[8] SEP 0>9[8] OCT 0>8[9]
WN LAS-MKE AUG 0.8>2[2] OCT 0>2[3]
WN LAS-MSY AUG 0.4>1.7[1.9] SEP 0>2.0[1.8] OCT 0>1.4[1.3]
WN LAS-OAK AUG 3>9[8] OCT 0>8[9]
WN LAS-ONT AUG 1.3>5[4] SEP 0>5[4] OCT 0>5[4]
WN LAS-PDX AUG 1.3>4[4] SEP 0>5[4] OCT 0>5[4]
WN LAS-PIT AUG 0.3>2[1.7] SEP 0>3[2.0] OCT 0>2[1.3]
WN LAS-RNO AUG 3>10[9] SEP 0>11[9] OCT 0>10[9]
WN LAS-SAN AUG 4>12[10] SEP 0>12[10] OCT 0>11[10]
WN LAS-SEA AUG 1.0>3[3] OCT 0>3[2]
WN LAS-SJC AUG 3>11[10] SEP 0>12[10] OCT 0>11[10]
WN LAS-SMF AUG 3>9[8] SEP 0>9[8] OCT 0>9[8]
WN LAS-TPA AUG 0.4>1.2[0.9] SEP 0>1.1[1.0] OCT 0>1.1[1.2]
WN LAX-MSY AUG 0.2>1.9[1.8] SEP 0>3[1.9] OCT 0>3[2]
WN LAX-PDX OCT 0>0.6[1.6]
WN LAX-SAT AUG 0.4>1.7[1.8] OCT 0>1.8[1.7]
WN LAX-SJC AUG 3>10[10] OCT 0>10[11]
WN LAX-SJD AUG 0.3>0.5[0.7] SEP 0>0.3[0.7] OCT 0>0.3[0.7]
WN LGA-MCI AUG 0.4>1.2[1.8] SEP 0>1.0[1.9] OCT 0>1.1[1.9]
WN LGA-MDW AUG 2>7[6] SEP 0>7[6] OCT 0>7[6]
WN LGA-MSY AUG 0.3>0.9[1.0] SEP 0>0.9[1.0] OCT 0>0.8[1.1]
WN LGA-STL AUG 1.2>4[3] SEP 0>4[3] OCT 0>4[3]
WN LGB-OAK AUG 1.3>5[4] SEP 0>5[4] OCT 0>5[4]
WN LGB-SJC AUG 1.2>4[4] SEP 0>5[4] OCT 0>5[4]
WN LIH-OAK AUG 0.3>0.6[0] SEP 0>0.4[0] OCT 0>0.4[0]
WN LIH-SJC AUG 0.3>0.7[0] SEP 0>0.6[0] OCT 0>0.5[0]
WN LIT-STL AUG 0.5>1.8[1.8] OCT 0>1.8[1.9]
WN MCI-MCO AUG 1.1>2[2] SEP 0>1.3[1.4] OCT 0>3[2]
WN MCI-MKE AUG 0.5>1.8[1.8] OCT 0>1.7[1.9]
WN MCI-MSP AUG 0.4>1.4[1.7] SEP 0>1.6[1.4] OCT 0>1.5[1.1]
WN MCI-MSY AUG 0.4>1.2[1.1] OCT 0>1.1[0.8]
WN MCI-OAK AUG 0.4>1.1[0.9] SEP 0>1.0[0.8] OCT 0>0.9[0.7]
WN MCI-PDX AUG 0.3>0.5[1.0] SEP 0>0.3[1.0]
WN MCI-RDU AUG 0.2>0.8[0.9] OCT 0>0.8[0.9]
WN MCI-SAN AUG 0.6>1.4[1.7] SEP 0>1.1[1.7] OCT 0>1.1[1.4]
WN MCI-SEA AUG 0.3>0.5[1.0] SEP 0>0.3[1.0]
WN MCI-TPA AUG 0.6>1.3[1.0] SEP 0>1.0[0.9] OCT 0>1.1[1.0]
WN MCO-MHT AUG 0.5>1.3[1.2] SEP 0>1.2[0.5] OCT 0>1.6[1.9]
WN MCO-MKE AUG 0.8>3[2] SEP 0>3[2.0] OCT 0>3[2]
WN MCO-ORF AUG 0.4>1.1[1.2] SEP 0>1.0[1.1] OCT 0>1.0[0.9]
WN MCO-PHX AUG 0.5>1.2[1.1] OCT 0>1.2[1.1]
WN MCO-PIT AUG 1.4>4[4] OCT 0>4[3]
WN MCO-RDU AUG 0.9>2[2] OCT 0>2[1.8]
WN MCO-ROC AUG 0.3>0.5[1.0] OCT 0>0.8[1.0]
WN MCO-SAN AUG 0.3>0.8[0.0] SEP 0>0.9[0.0] OCT 0>0.8[0]
WN MCO-SAT AUG 0.8>1.5[1.4] SEP 0>1.0[1.3] OCT 0>1.2[1.8]
WN MCO-SDF AUG 0.5>1.2[1.2] SEP 0>1.0[1.2] OCT 0>1.9[2.0]
WN MDW-MEM AUG 0.6>1.8[1.8] SEP 0>1.9[1.6] OCT 0>1.8[1.9]
WN MDW-MHT AUG 0.6>1.5[3] SEP 0>1.1[3] OCT 0>1.2[3]
WN MDW-OAK AUG 1.0>4[3] OCT 0>3[4]
WN MDW-ORF AUG 0.4>1.3[1.3] OCT 0>1.2[1.3]
WN MDW-PDX AUG 0.6>1.4[0.9] SEP 0>1.1[1.5] OCT 0>1.6[1.1]
WN MDW-PHL AUG 1.5>5[6] SEP 0>6[5] OCT 0>6[5]
WN MDW-PVD AUG 0.6>1.5[3] SEP 0>1.3[3] OCT 0>1.8[3]
WN MDW-RDU AUG 1.1>4[3] SEP 0>4[3] OCT 0>3[4]
WN MDW-SDF AUG 0.9>3[4] SEP 0>3[4] OCT 0>3[4]
WN MDW-SEA AUG 1.0>2[2] SEP 0>1.9[3] OCT 0>1.8[1.5]
WN MDW-SFO AUG 0.5>1.7[1.7] OCT 0>1.7[1.5]
WN MDW-SJC AUG 0.5>1.7[1.7] OCT 0>2[1.7]
WN MDW-SLC AUG 0.9>2[2] SEP 0>1.9[2] OCT 0>1.9[2]
WN MDW-SMF AUG 0.6>1.9[1.1] SEP 0>1.9[1.0] OCT 0>1.2[1.0]
WN MDW-STL AUG 2>8[7] SEP 0>8[7] OCT 0>8[7]
WN MDW-TPA AUG 1.5>4[4] SEP 0>4[3] OCT 0>5[4]
WN MEM-TPA OCT 0>0.7[1.0]
WN MHT-TPA OCT 0>0.8[1.0]
WN MKE-PHX AUG 0.6>3[1.8] SEP 0>3[1.9] OCT 0>3[1.9]
WN MKE-STL AUG 0.8>3[1.8] SEP 0>3[1.9] OCT 0>1.9[1.4]
WN MKE-TPA AUG 0.5>1.0[0.9] OCT 0>1.0[1.1]
WN MSP-OAK AUG 0.3>1.0[0.1] SEP 0>1.0[0.0] OCT 0>0.2[0]
WN MSP-PHX AUG 0.4>1.8[2] OCT 0>1.4[2]
WN MSY-OAK AUG 0.1>0.7[0.9] OCT 0>0.9[1.0]
WN MSY-PHX AUG 0.1>0.8[1.0] OCT 0>1.7[1.0]
WN MSY-SAT AUG 0.3>1.7[1.7] SEP 0>2[1.7] OCT 0>2[1.9]
WN OAK-OGG AUG 0.6>2[2] OCT 0>1.9[2]
WN OAK-ONT AUG 1.9>6[6] OCT 0>6[7]
WN OAK-RNO AUG 0.4>1.6[1.7] OCT 0>1.7[1.9]
WN OAK-SAT AUG 0.1>0.7[0.2] SEP 0>0.9[0.1] OCT 0>0.9[0]
WN OAK-SJD AUG 0.3>0.5[0.3] OCT 0>0.3[0.7]
WN OAK-SNA AUG 2>6[7] SEP 0>6[7] OCT 0>6[7]
WN OAK-STL AUG 0.1>0.9[1.0] OCT 0>0.9[1.0]
WN OGG-SAN AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0]
WN OGG-SMF AUG 0.3>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0]
WN OKC-PHX AUG 0.8>3[1.9] SEP 0>3[1.8] OCT 0>3[1.9]
WN OKC-STL AUG 0.5>1.7[1.9] OCT 0>1.8[1.9]
WN OMA-PHX AUG 0.4>1.2[1.1] SEP 0>1.1[1.2] OCT 0>1.7[1.9]
WN OMA-SAN OCT 0>0.6[0.8]
WN PDX-PHX AUG 1.1>4[4] SEP 0>4[3] OCT 0>3[2]
WN PDX-SAN OCT 0>0.7[1.7]
WN PDX-SJC AUG 1.7>6[5] OCT 0>6[5]
WN PDX-STL AUG 0.3>1.0[1.0] OCT 0>1.0[0.9]
WN PHL-STL AUG 0.7>3[3] OCT 0>3[2]
WN PHL-TPA AUG 0.4>1.2[1.1] OCT 0>0.9[1.0]
WN PHX-PVR OCT 0>0.7[0]
WN PHX-RDU AUG 0.3>1.0[1.0] SEP 0>1.0[0.8] OCT 0>1.0[0.6]
WN PHX-SEA AUG 1.4>5[4] SEP 0>5[4] OCT 0>4[3]
WN PHX-SFO AUG 1.1>4[5] SEP 0>5[4] OCT 0>5[4]
WN PHX-SJD OCT 0>1.5[0]
WN PHX-SLC AUG 1.6>5[5] SEP 0>6[5] OCT 0>6[5]
WN PHX-SMF AUG 1.6>5[6] OCT 0>6[5]
WN PHX-SNA AUG 1.8>6[7] SEP 0>6[7] OCT 0>6[7]
WN PHX-STL AUG 1.0>3[3] OCT 0>4[3]
WN PHX-TPA AUG 0.4>1.0[0.9] SEP 0>0.9[0.7] OCT 0>0.9[1.0]
WN PHX-TUL AUG 0.4>1.1[1.7] SEP 0>1.0[1.7] OCT 0>1.1[1.0]
WN PIT-RSW OCT 0>0.9[1.0]
WN PIT-STL AUG 0.5>1.7[1.1] SEP 0>1.7[1.2] OCT 0>1.8[1.1]
WN PIT-TPA AUG 0.9>1.7[2] SEP 0>1.3[1.6] OCT 0>2.0[2]
WN PNS-STL AUG 0.1>0.3[0.2] SEP 0>0.3[0.1]
WN PVR-SAN AUG 0.1>0.3[0.1] OCT 0>0.2[0.3]
WN RDU-TPA AUG 0.4>1.7[1.9] SEP 0>2.0[1.6] OCT 0>1.3[1.5]
WN RSW-STL AUG 0.6>1.4[1.1] SEP 0>1.1[1.0] OCT 0>1.2[1.0]
WN SAN-SAT AUG 0.4>1.7[1.6] OCT 0>1.2[1.6]
WN SAN-SJC AUG 4>14[15] OCT 0>14[15]
WN SAN-SJD AUG 0.3>1.0[1.0] OCT 0>0.8[1.0]
WN SAN-SLC AUG 0.3>1.5[1.8] SEP 0>1.7[1.8] OCT 0>1.9[1.8]
WN SAN-STL AUG 0.6>1.5[1.6] SEP 0>1.1[1.5] OCT 0>1.7[2.0]
WN SAN-TUS AUG 0.6>2[1.9] SEP 0>2.0[1.8] OCT 0>2[1.9]
WN SAT-STL AUG 0.8>2[1.9] OCT 0>1.9[1.8]
WN SAT-TPA OCT 0>0.8[0.9]
WN SDF-TPA AUG 0.5>1.2[1.1] SEP 0>1.1[1.0] OCT 0>1.2[1.1]
WN SEA-SJC AUG 1.4>5[5] SEP 0>5[4] OCT 0>5[4]
WN SEA-SMF AUG 1.8>6[5] SEP 0>6[5] OCT 0>6[4]
WN SFO-STL AUG 0.3>1.0[1.0] OCT 0>1.0[0.6]
WN SJC-STL AUG 0.3>1.0[1.0] OCT 0>1.0[0.6]
WN SJD-SMF OCT 0>0.2[0.1]
WN SJU-TPA AUG 0.6>1.3[1.1] OCT 0>1.1[1.1]
WN SLC-SMF AUG 0.4>1.1[1.1] SEP 0>0.9[1.2] OCT 0>0.8[0.9]
WN SLC-STL OCT 0>0.6[0.5]
WN SMF-SNA AUG 1.7>6[6] OCT 0>5[6]
WN STL-TPA AUG 1.2>3[2] SEP 0>3[2] OCT 0>3[2]
WN STL-TUL AUG 0.5>1.8[1.8] OCT 0>1.8[1.9]
WS SFO-YYC MAY 2>1.5[1.5]
BAINY3
Re: OAG Changes 3/15/2020: ARMAGEDDON + AS Exits BWI-LAX,RNO-SJC;UA Suspends SMX
Sun Mar 15, 2020 1:03 pm
Does anyone know what the airline deadline is for schedule change submissions to make it into the weekly OAG? Some of these schedule changes were actually relatively light compared to what I thought I'd see.
Chuska
Sun Mar 15, 2020 1:14 pm
I agree, changes are most likely being made daily. Looking here at ABQ, AA also cut ABQ-PHX from 5 to 4 on 4/7 and UA cut ABQ-DEN from 4 to 3 on 4/5. Taos Air announced all flights will end after next Sunday, 3/22 as Taos Ski Valley will close three weeks early. United now has a notice on their website to check back within 72 hours of you trip. Enilria--Thanks again!!!
Midwestindy
Thanks for the update!
So far DL has been doing a weird update where they "zero-out" the inventory for certain flights they plan to cut, & leave them in as sold-out for a week, and then pull them out of the schedule about a week later. For this reason I don't think a lot of their cuts are going to show up for a week, if at all.
Status for 2019/2020: AAdvantage Platinum, Delta Gold, Southwest A-List
tphuang
Sun Mar 15, 2020 1:24 pm
Thanks enilria for the update.
It looks to me that only UA has fully loaded in their April changes. It matches what their website have been saying. AA's change to cut international flying by 75% has definitely not been loaded in yet. It looks to me that JFK slot waivers are not in place yet, because I would otherwise expect them to cut their JFK flying to bare bones (<40 flights a day). Same with DL, I think most of their changes have not been loaded yet. This is another one where I believe because slot waivers are not in yet, they have not filed more JFK changes. I can't imagine a lot of AA/DL feeder flights will stick around in JFK without TATL flights to connect to.
I'm sure this has been a very hectic couple of weeks for the network planners, so not a surprise they haven't fully loaded the changes in.
I think in the case of B6, they have been cutting flights much closer in, so they haven't shown up on OAG yet. Again, they are also waiting on JFK slot waivers to be in place.
For LCC/ULCC, I'd expect them to do a lot of what NK is doing, which is cutting offpeak capacities.
WidebodyPTV
Sun Mar 15, 2020 1:27 pm
The bloodbath hasn’t begun yet. What we’re seeing... is likely the initial 10% cuts DL was discussing heading into last week. Plenty more cuts were loaded yesterday that aren’t reflected here, but it’s just the beginning. Tons of low fares are currently available - about $20 from ATL to anywhere in Florida, etc.
So far, the schedule that’s currently available for sale barely touches SEA — likely the hub bleeding the most cash, as most of the service has yet to mature.
afcjets
Sun Mar 15, 2020 1:36 pm
It's easier to zero out a flight and reopen inventory later than cancel a flight and add it back if things change. It also preserves existing bookings in the interim.
Gulfstream500
Sun Mar 15, 2020 1:55 pm
I have noticed this as well. Maybe this is to reduce the number of calls that their call center receives in a day due to cancelled flights?
So... when will the Northwest DC-9s be retired?
PSU.DTW.SCE
Sun Mar 15, 2020 2:00 pm
Yes there is a whole workflow involved to cancel flights that interfaces between multiple systems.
Zeroing out inventory is just the first step
Boof02671
Sun Mar 15, 2020 2:01 pm
AA cut RDU, CLT and PHL to LHR as those cities were not an approved gateway by the Feds.
Midwestindy
Sun Mar 15, 2020 2:19 pm
Haven't seen BOS, but CVG/RDU appear to be hit hard, each down around 20+ flights/day. Looks like DL is avoiding cutting too much from SEA
From RDU alone, all of these appear to be gone for most of April
RDULAS
RDUBNA
RDUAUS
RDUPIT
RDUMSY
RDUIND
RDUCLE
RDUCMH
RDUJAX
RDUBDL
Some high profile exits in April as well, SLC-FLL, MSP-SMF/TYS/ORF, DTW-PDX/SAV, JFK-PBI, BOS-ORF, CVG-MCI/YYZ/BDL/PHX, JFK-YVR pushed back start
They appear to be lengthening the time they are zeroing out flights, when they do a normal schedule load it takes an hour or two tops, not an entire week
bluefltspecial
I'm curious to see where US carriers put all those widebodies... I know a number of them will get parked, but maybe we'll see some nice upgrades until domestic air travel is shut down in the US, too.
Save a horse, ride a Fly-boy....
MIflyer12
Sun Mar 15, 2020 2:22 pm
They've already announced domestic cuts. They're not going to sub widebodies generally and wind up running just 1/3-1/2 the frequency.
LAXdude1023
Sun Mar 15, 2020 2:26 pm
Latin American wasnt hit as hard by UA as I thought it would be.
FOR THE LOVE OF GOD BRING BACK THE PAYWALL!!!!
enilria
Sun Mar 15, 2020 2:41 pm
Saturday night. That's when most airlines normally do schedule changes, but nothing is normal now.
I know why.
If they cancel the flight they have to refund the money. The longer they wait the more people will self-cancel and be stuck with a rebook or credit or change fee.
This report doesn't capture the current month.
This isn't even 10%
That's not it, see above.
RDULAS
RDUBNA
RDUAUS
RDUPIT
RDUMSY
RDUIND
RDUCLE
RDUCMH
RDUJAX
RDUBDL
See above
OzarkD9S
Sun Mar 15, 2020 3:02 pm
They may have to. Depends on the seniority of flight crews. If airlines start laying off employees at unionized airlines, they have to start at the bottom. International/widebody crews tend to be more senior. Even DL may have to keep widebody qualified FA's working even if they aren't unionized, the pilots are. Will be interesting to see what happens.
"True, I talk of dreams,
Which are the children of an idle brain." -Mercutio
incitatus
Sun Mar 15, 2020 3:04 pm
Elniria spoke too soon calling these cuts Armageddon. This is just the beginning.
I do not consume Murdoch products including the Wall Street Journal
jetmatt777
Sun Mar 15, 2020 3:06 pm
Can you maintain currency with sim time alone?
Could they have pilots come in and do a few touch and gos in a sim and be good for the month?
chonetsao
Sun Mar 15, 2020 3:09 pm
Why didn't AA keep some degree of flexibility for April? The current ban last for 30 days. It is likely this ban would be lifted before 15th April. What AA could do was to have a temporary schedule between 13th April to 5th May, and then decide whether to operate or not following the status of the ban. Such deep cut into May in one go seems to be too drastic and do not leave any room for manoeuvre. I am sure AA have done some home work and know the market reaction. I am just curious that what they know.
panamair
All DL FAs are qualified on all mainline types.
OzarkD9S
Sun Mar 15, 2020 3:13 pm
Did not know that. Thanks for in info.
FlyHossD
Sun Mar 15, 2020 3:14 pm
If the sim is landings certified, in many cases, yes, it can be used for landings credit. Landings currency is based on a 90 day window (not a month), as I recall.
onwFan
Sun Mar 15, 2020 3:18 pm
Given the state of affairs, I think it is hardly worth it. I guess every two days, they will have to change their schedules, reaccommodate passengers - route and aircraft planning has already probably become impossible. Not to mention the big question of when people will start to travel or not. This will give them better flexibility to retire all the B767s and give them some breathing time to plan for the summer schedule (even that is uncertain now).
Brickell305
Sun Mar 15, 2020 3:26 pm
The cut to RDU came BEFORE LHR was added to the travel ban. That was lack of demand.
aemoreira1981
Sun Mar 15, 2020 3:28 pm
American theoretically could park its B772 fleet for now, and only operate the B77Ws, B788, and B789 wide-bodies. UA could park its B772 and high-J B763 fleet in the interim.
AirFiero
Sun Mar 15, 2020 3:36 pm
Actually, the big cuts seem to be happening *now*, but quietly. In other words the real cuts aren’t published.
If I were to bet, I’d say the worst of this will be over in April, *maybe* May, then things will slowly get back to normal.
AirFiero
Sun Mar 15, 2020 3:38 pm
Landings and instrument approaches. Both should be able to be satisfied in a sim.
Planeboy17
Sun Mar 15, 2020 3:53 pm
B6 has cancelled all flights to Ecuador thru March 22 per the new Government Restriction barring entry of foreign visitors arriving into Ecuador.
It’s getting very difficult for airlines to find destinations to fly to right now and in the near future.
Let’s just hope the measures being put in place can slow down what is happening and a return to normal ( although not sure what that will be ) will happen sooner than later.
Boof02671
Sun Mar 15, 2020 3:54 pm
Once again when the Feds put the ban on everywhere EXCEPT the UK, CLT, PHL and RDU were not approved cities to keep flying to LHR
Brickell305
Sun Mar 15, 2020 3:57 pm
The approved gateway airports at the time only applied to Schengen airports. PHL/CLT-LHR only got cut after the ban was extended to the U.K. RDU was cut prior to that before the list of approved airports applied to U.K. passengers.
WidebodyPTV
Sun Mar 15, 2020 4:09 pm
It could take years before things get back to normal. Things are going to get worse before they'll get better :(.
jayunited
Sun Mar 15, 2020 4:24 pm
Unionized FA's are qualified to work all fleet types as others have stated if and or when furloughs start at union carriers like AA and UA they start from the bottom of the seniority list and work their way up. With DL's FA's being nonunion one would hope DL would start from the bottom of the list. But without a contract DL management can technically do whatever they want to do should furloughs become necessary.
Judging from China's apparent recovery I think here in the US the recovery will probably begin in mid-June or early July. According to Scott Kirbys recent town hall he stated parking or grounding an entire large fleet type for such a short period of time not cost efficient. The operative word there is large. For an airline like AA or UA to ground their entire 772/ER fleets it might look like they are saving money but the cost to stand the fleet back up and certify all those pilots would cost more than the money saved by grounding the entire fleet. No one at the town hall asked if simulators are enough to keep pilots current but he seemed to suggest they are not when he stated training cost to re-certify the pilots would be expensive and it would take time.
If UA and AA had a smaller fleet of 772 perhaps they would park the fleet kind of like what we are seeing LH do with their A380's. But for the time being UA's plan is to park a mixture of all our fleet types while at the same time keeping all our fleet types flying. Meaning UA will park portions of our A320/19s, 737s, 757s, 767s, 777s, and 787s but also keep every fleet type flying to keep pilots current (at least that was the plan on this past Friday morning but of course plans can/will change).
Chriswebb775
Sun Mar 15, 2020 4:32 pm
UA AS AA AND WN are all Cutting flights in-and-out of Reno and as of the news yesterday that the ski resorts are temporarily closing . The flights will be going out pretty much empty.
9207DA
ericm2031
Sun Mar 15, 2020 4:46 pm
New station start-up. Probably not much point to open it up when the demand won't be there. They can also easily reaccommodate 45 mins to the North or South out of SBP or SBA.
dcajet
Sun Mar 15, 2020 4:49 pm
Indeed, Argentina instituted a travel ban from the US, Europe, China, South Korea and Iran beginning tomorrow 16/3. American won't return to EZE (as of today) until June, except Miami which begins in May but with only one daily flight. LAX-EZE is suspended untill October 2020. Of course, this is all very fluid.
Turkish Airlines is not banned, same as Emirates, Ethiopian, Qatar and Latin American airlines & Air Canada. Yet. All European and American carriers end their services tomorrow, a well as Aerolineas Argentinas and LATAM services to Europe and the US. AR to operate repatriation flights from the US and Europe to bring back Argentina nationals stranded there.
MIflyer12
Sun Mar 15, 2020 4:51 pm
They'll schedule all pilots to keep them current. That doesn't take many hours. If they dramatically crush frequency in a busy market they'll add to the demand decline. 3x a day ATL-ORD wouldn't cut it - they'd lose too many passengers to AA/UA/WN.
It might be interesting to start aircraft park/retirement threads by carrier rather than dumping them all together. My thesis is they're going to take a little off the top of many middle-age to high-average-age types (757, 767, 320, MD-90) rather than eliminating types entirely (with the exception of MD-88s, which they have long said would be done by 12/31/20, anyway.)
DTWLAX
Sun Mar 15, 2020 4:54 pm
DL suspended all MSP-AMS and MSP-CDG flights starting March 14th.
https://www.bizjournals.com/twincities/ ... yptr=yahoo
Is DL the first airline to suspend all hub-to-hub routes from a particular hub? MSP-ICN is also gone.
Ishrion
Sun Mar 15, 2020 4:59 pm
Likely one of the first. If you consider London Heathrow an AA hub, then AA is another as they have suspended ORD/LAX/JFK/CLT/PHL-LHR.
Packson
Sun Mar 15, 2020 5:01 pm
Landings are 90 day cycle. The bigger problem is going to be all the pilots who just finished up, are in training or about to start. Pilots have to accumulate 100 hours on new planes (a few exceptions exist) within 120 days. With such a large volume of cancelled flights and with some international fleets losing 75-85% percent of their flying.... consolidation will be impossible!
Midwestindy
Sun Mar 15, 2020 5:04 pm
I guess you missed the news last night that AA is grounding nearly its entire widebody fleet.....
https://thepointsguy.com/news/american- ... body-jets/
How many passengers are there to lose at this point?......Preserving frequency to satisfy consumers is NOT the thing to be doing right now.
When demand is back, then you can worry about preserving market share
klwright69
Sun Mar 15, 2020 5:05 pm
DL is reducing BOM. Interesting. And JFK to BOG.
SuseJ772
Sun Mar 15, 2020 5:09 pm
Ha ha ha. Between this and your title (even if next weeks will be Armageddon 2), you sir win the Internet today.
Currently at PIE, requesting FWA >> >>
chepos
Sun Mar 15, 2020 5:11 pm
BOM is getting suspended.
Fly the Flag!!!!
afcjets
Delta ATL-SLC, two flights are A330s and one is a 763.
ericm2031
Sun Mar 15, 2020 5:28 pm
Has WN not made any close-in cuts yet? Or do they just not show up on here? There's got to be some weakness that can be pulled on the intra-CA/TX routes, FL, LAS, etc.
AirFiero
Sun Mar 15, 2020 5:33 pm
Possibly. But my guess is months.
jbs2886
Sun Mar 15, 2020 5:40 pm
AA announced their parking almost their entire wide body fleet. Furthermore, domestic travel is cratering...they don’t need the upguage.
DTWLAX
Sun Mar 15, 2020 5:56 pm
DL has temporarily suspended JFK-BOM
https://news.delta.com/delta-reduces-us ... jfk-mumbai
blueflyer
Sun Mar 15, 2020 6:05 pm
I would think the prize goes to United, no? They've killed all TATL out of ORD, including to Star hubs FRA and BRU, and their Asian flights haven't resumed yet that I know of
EMB170
Sun Mar 15, 2020 6:15 pm
Add SQ JFK-FRA-SIN is now XLD thru 5/31
IND ORD ATL MCO PIT EWR BUF CVG DEN RNO JFK DTW BOS BDL BWI IAD RDU CLT MYR CHS TPA CID MSP STL MSY DFW IAH AUS SLC LAS
