PSAatSAN4Ever
Honolulu (HNL) & San Diego (SAN) Terminal Questions
Fri Mar 20, 2020 4:50 pm
Greetings to all - mods, please move if this belongs elsewhere.
A couple of questions about HNL airport.
First, if one does a Google search, virtually all maps of the passenger facilities are shown upside-down:
https://www.google.com/search?hl=en&tbm=isch&source=hp&biw=1536&bih=722&ei=3vF0XsqwLpHb-gT-5IawCA&q=HNL+terminal+map&oq=HNL+terminal+map&gs_l=img.3..0j0i8i30l3j0i24.1662.4520..4817...0.0..0.168.1548.12j4......0....1..gws-wiz-img.......0i30.zENSxt9WiW0&ved=0ahUKEwjKl5X9vqnoAhWRrZ4KHX6yAYYQ4dUDCAY&uact=5
To my knowledge, this is the only airport whose diagrams where North is NOT at the top of the page.
Why is this? Is there some comparative advantage that only seems to work for this airport?
Second: In the discussion on the San Diego airport (SAN) thread, I was reminded that, in the United States, there are no isolated areas post-security for departing international passengers. You are free to mingle with other domestic-departing passengers in the same facilities.
But both HNL and SAN have had and/or currently do have "isolation" gates, where all passengers can be "separated" from others, via a closing door. In 2009, my Hawaiian Airlines flight HNL-SAN departed from Gate 25. This gate, at the time, was not open-air at all - one had to show their boarding pass to the agent to enter this area, and after we were all checked-in, the door was locked behind us, and then we waited a bit until it was time for boarding. SAN had the same set-up at the old international gate, but if I remember right, Hawaiian used this same gate and waiting area (with the sliding doors left open) until T2West was completed and they moved over there.
What would the purpose of gates like these before? Were these originally designed for international departures only?
My international flying experiences are limited, by the way, to three times at LAX (LAX-MLM, MLM-LAX, and LAX-FRA) and one arrival at SAN (ZRH-SAN), but the SAN arrival was in July, 2017, just before the new international terminal opened.
Thanks in advance for the information!! And a big hearty Prost to the day when flying returns to "normal"!
ScottB
Re: Honolulu (HNL) & San Diego (SAN) Terminal Questions
Fri Mar 20, 2020 6:55 pm
I wouldn't necessarily say that's true. Most maps of the OAK terminals have the gates/concourses at the top even though the terminal complex faces southwest. Similarly, the Barbara Jordan Terminal at AUS has the concourse to the south, but many maps have that area at the top of the diagram. Many maps of IAD have the Saarinen terminal at the bottom even though it is north of the remote concourses.
But in those cases, as with HNL, the landside tends to be at the bottom of the map, with gates/concourses at the top. This is also a common choice.
Polot
Fri Mar 20, 2020 7:00 pm
Having terminal landslide be “south” and airside “north” is probably the most common terminal map layout. Visitors don’t know (or really care) which way is true north, they are trying to navigate through the terminal and tend to view “up” on a map as forward.
Now for the overall airport layout they might use north as up as people may be trying to get an understanding of the layout based on how they are approaching airport.
airportugal310
Fri Mar 20, 2020 7:03 pm
Gate 25 (now B gates) at HNL is outside of the usual Agricultural inspection area since its within the Interisland terminal, and as such, "ag" is located in the gate area. To be let in, they typically will check your boarding pass (but not always)
“They bought their tickets, they knew what they were getting into. I say, let 'em crash.”
airportugal310
Fri Mar 20, 2020 8:55 pm
Disregard my comment above. I was mistaken about 25...
aloha73g
Fri Mar 20, 2020 10:07 pm
One reason may be that in Hawai'i we do not really use North, South, East and West. All directions are generally given using Mauka (towards the Mountains) or Makai (towards the Ocean) as well as lots of reliance on landmarks ... particularly landmarks that are at the edge or point of an Island such as Diamond Head, Koko Head, Ewa, etc.
-Aloha!
Aloha Airlines - The Spirit Moves Us. Gone but NEVER Forgotten. Aloha, A Hui Hou!
