enilria
OAG Changes 3/22/2020
Sun Mar 22, 2020 1:41 pm
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
NOTE: There's too much for me to summarize. Please crowd source any patterns you see. I only marked things that appear permanent.
3M FLL-GHB APR 0.6>0.1[0.7]
3M FLL-MCO APR 1.7>1.3[2]
3M FLL-MHH APR 0.9>0.4[4]
3M FLL-PNS APR 0.9>0.1[1.0]
3M FLL-TLH APR 1.6>0.7[1.5]
3M FLL-TPA APR 2>1.5[2]
3M HSV-MCO APR 1.0>0.5[1.0]
3M MCO-MHH MAY 0.3>0[1.3]
3M MCO-PNS APR 1.7>1.2[1.7]
3M TLH-TPA APR 1.6>1.1[1.6]
4M EZE-MIA APR 1.0>0[1.1]
4O JFK-MEX MAY 2>1.1[4]
I didn't realize BKL had service. This was a corporate shuttle for P&G I assume?
*4P BKL-LUK APR 1.5>0[1.5] MAY 1.3>0[1.4] JUN 1.5>0[1.3] JUL 1.5>0[1.4] AUG 1.4>0[1.4] SEP 1.4>0[1.3] OCT 1.2>0[1.5]
*4P LUK-MDW APR 0.4>0[0.7]
*4P LUK-PDK APR 0.7>0[0.7] MAY 0.6>0[0.7]
7H ANC-CDB OCT 0.9>0.4[0.4] NOV 0.8>0.4[0.4] DEC 0.9>0.5[0.5]
7H ANC-SDP OCT 0.9>0.4[0.4] NOV 0.8>0.4[0.4] DEC 0.9>0.5[0.5]
7Q EWR-VRB DEC 0>0.3[0.5]
9K BOS-PWM APR 4>0[0] MAY 4>0[0]
Wow, too many to even mark...
AA AGS-DCA APR 1.2>0.9[0.5]
AA AGS-DFW APR 2>1.6[1.2]
AA AGS-LGA APR 0.4>0[0.3]
AA AGS-MIA APR 0.2>0[0.3]
AA AGS-ORD APR 0.2>0[0.3]
AA AGS-PHL APR 0.3>0[0.3]
AA AGU-DFW APR 2>1.2[2]
AA ASE-DFW APR 1.7>0[1.1] MAY 1.0>0.8[1.0]
AA ASE-LAX APR 0.2>0[0.0]
AA ASE-ORD APR 0.2>0[0.0]
AA ASE-PHX APR 0.2>0[0.0]
AA AUA-CLT APR 1.3>0[1.4]
AA AUA-LGA APR 0.2>0[0]
AA AUA-MIA APR 2>0[2]
AA AUA-PHL APR 1.0>0[1.0]
AA AUS-BOS APR 1.3>0[0]
AA AUS-JFK APR 1.4>0.7[2.0]
AA AUS-SJC APR 1.4>0[0] MAY 1.5>1.2[0]
AA BAQ-MIA APR 1.0>0[1.0]
AA BDA-JFK APR 1.0>0[1.0]
AA BDA-MIA APR 1.0>0[1.0]
AA BDA-PHL APR 0.8>0[1.0]
AA BNA-JFK APR 2>0.4[2]
AA BOG-DFW APR 1.0>0[1.0]
AA BOG-MIA APR 3>0[3]
AA BON-MIA APR 0.4>0[0.6]
AA BOS-JFK APR 3>0.6[4]
AA BOS-LGA APR 10>9[11]
AA BOS-LHR APR 1.0>0[0]
AA BSB-MIA APR 1.0>0[1.0]
AA BWI-JFK APR 3>1.2[1.0]
AA BZE-DFW APR 1.1>0[1.1]
AA BZE-MIA APR 2>0[2]
AA CAK-LGA APR 0.9>0.3[0.9]
AA CAP-MIA APR 1.0>0[1.0]
AA CID-PHX NOV 0>0.4[0] DEC 0>1.0[0.4]
AA CLE-LGA APR 3>2[3]
AA CLO-MIA APR 1.0>0[1.0]
AA CLT-CUN APR 3>1.5[3]
AA CLT-GCM APR 2>0[3] MAY 1.4>0.9[1.4]
AA CLT-JFK APR 6>5[6]
AA CLT-LHR APR 2>0[2]
AA CLT-LIR APR 0.3>0[0.3]
AA CLT-MBJ APR 3>0[3]
AA CLT-PUJ APR 1.0>0[2]
AA CLT-SJO APR 1.0>0[1.0] MAY 0.5>0.3[0.3]
AA CLT-SXM APR 1.0>0[1.1]
AA CLT-YUL APR 2>0[2]
AA CLT-YYZ APR 5>2[4]
AA CMH-JFK APR 1.0>0.2[1.0]
AA CMH-LGA APR 5>4[5]
AA CTG-MIA APR 1.0>0[1.0]
AA CUN-JFK APR 2>0.4[1.9]
AA CUR-MIA APR 2>0[2]
AA CVG-JFK APR 1.0>0.3[1.0]
AA CVG-LGA APR 1.9>1.2[1.9]
AA DAY-LGA APR 3>2[3]
AA DCA-GSO APR 3>2[3]
AA DCA-MCI APR 3>2[3]
AA DCA-ORF APR 3>2[3]
AA DCA-YYZ APR 1.9>0[3]
AA DFW-EGE APR 1.3>0[0.1] MAY 1.0>0.8[0]
AA DFW-GCM APR 0.4>0[0.3]
AA DFW-GRU APR 0.8>0[1.0] MAY 1.0>0.8[1.0]
AA DFW-GUA APR 2>0[1.1]
AA DFW-GUC APR 0.2>0[0.0]
AA DFW-GYE APR 0.7>0[0]
AA DFW-HDN APR 0.2>0[0.0]
AA DFW-HND APR 1.0>0[0]
AA DFW-JAC APR 1.0>0[1.1]
AA DFW-LHR APR 3>1.0[4]
AA DFW-LIM APR 1.0>0[1.0]
AA DFW-LIR APR 1.1>0[0.7] MAY 0.9>0.7[0.2]
AA DFW-MBJ APR 1.0>0[0.8]
AA DFW-MTJ APR 1.2>0[1.0] MAY 1.0>0.8[1.0]
AA DFW-NRT APR 1.0>0.4[2]
AA DFW-SAL APR 0.6>0[0]
AA DFW-SAP APR 0.6>0[0]
AA DFW-SJO APR 2>0[1.0] MAY 1.2>0.8[1.0]
AA DFW-TGU APR 0.4>0[0]
AA DFW-UIO APR 0.7>0[0]
AA DFW-YUL APR 1.0>0[1.0]
AA DFW-YYC APR 2>1.0[1.8]
AA DFW-YYZ APR 3>1.0[3]
AA DUB-PHL APR 1.0>0[1.0]
AA EDI-PHL APR 0.9>0[1.0]
AA EGE-JFK APR 0.2>0[0.0]
AA EGE-LAX APR 0.2>0[0.0]
AA EGE-MIA APR 0.2>0[0.0]
AA EGE-ORD APR 0.2>0[0.1]
AA EZE-MIA APR 0.9>0[1.8]
AA FAR-PHX NOV 0>0.4[0] DEC 0>1.0[0.5]
AA GCM-MIA APR 3>0[3]
AA GCM-PHL APR 0.3>0[0.3]
AA GEO-JFK APR 1.0>0[0]
AA GEO-MIA APR 1.0>0[0.6]
AA GIG-MIA APR 1.0>0[1.0]
AA GRR-PHX NOV 0>0.4[0] DEC 0>1.0[0.5]
AA GRU-JFK APR 1.0>0[1.0]
AA GRU-MIA APR 2>0[2]
AA GSO-LGA APR 3>2[3]
AA GUA-MIA APR 3>0[3] MAY 3>2[3]
AA GYE-MIA APR 2.0>0[2]
AA HAV-MIA APR 6>4[5]
AA HDN-ORD APR 0.2>0[0.0]
AA HND-LAX APR 2>0[1.0]
AA ILM-LGA APR 3>2.0[3]
AA JAC-LAX APR 0.2>0[0]
AA JAC-ORD APR 0.2>0[0.0]
AA JFK-LHR APR 3>0[4]
AA JFK-MBJ APR 1.0>0[0]
AA JFK-PHL APR 3>2[1.0]
AA JFK-PIT APR 2>1.2[0.0]
AA JFK-RDU APR 5>3[3]
AA JFK-RIC APR 4>3[0] MAY 1.8>1.4[0]
AA JFK-SJO APR 1.0>0[0]
AA JFK-YUL APR 1.0>0[2]
AA KIN-MIA APR 3>1.0[3]
AA LAX-LHR APR 2>0[2]
AA LAX-SYD APR 1.0>0[1.0]
AA LAX-YVR APR 2>0[2]
AA LGA-MSP APR 1.7>1.0[1.9]
AA LGA-ORD APR 11>9[14]
AA LGA-ORF APR 1.9>1.2[3]
AA LGA-RIC APR 4>3[5]
AA LGA-SDF APR 1.8>1.0[1.6]
AA LGA-STL APR 3>2.0[3]
AA LGA-TYS APR 1.7>0.4[2]
AA LGA-YUL APR 3>0[3]
AA LGA-YYZ APR 4>0[5]
AA LHR-ORD APR 3>0[4]
AA LHR-PHL APR 2>0[2]
AA LHR-PHX APR 1.0>0[1.0]
AA LIM-MIA APR 3>0[2]
AA LIR-MIA APR 1.9>0[1.8]
AA MAN-PHL APR 1.0>0[1.0]
AA MAO-MIA APR 0.7>0[1.0]
AA MBJ-MIA APR 3>1.0[3]
AA MBJ-ORD APR 1.0>0[0.8] MAY 0.3>0.1[0.2]
AA MBJ-PHL APR 2>0[2]
AA MDE-MIA APR 2>0[2]
AA MGA-MIA APR 2>0[3]
AA MIA-MTY APR 0.7>0[1.0]
AA MIA-MVD APR 0.7>0[1.0]
AA MIA-PEI APR 0.4>0[0.4]
AA MIA-PLS APR 2>0.9[3]
AA MIA-POP APR 1.0>0[1.0]
AA MIA-POS APR 2>0[2]
AA MIA-PTY APR 2>0[3]
AA MIA-PUJ APR 2>0[3]
AA MIA-RTB APR 0.3>0[0.3]
AA MIA-SAL APR 1.0>0[1.0]
AA MIA-SAP APR 1.0>0[2.0]
AA MIA-SCL APR 1.0>0[1.0]
AA MIA-SDQ APR 4>0[4]
AA MIA-SJO APR 3>0[3]
AA MIA-SKB APR 1.7>1.0[1.7]
AA MIA-STI APR 1.0>0[1.0]
AA MIA-SXM APR 1.0>0[1.0]
AA MIA-TGU APR 1.0>0[1.1]
AA MIA-UIO APR 2>0[2]
AA MIA-YUL APR 1.0>0[1.0]
AA MIA-YYZ APR 1.0>0[3]
AA MSN-PHX NOV 0>0.4[0.3] DEC 0>1.0[0.5]
AA MSY-PHX NOV 0>0.4[0] DEC 0>1.0[0.5]
AA MTJ-ORD APR 0.2>0[0]
AA MTJ-PHX APR 0.2>0[0.0]
AA NAS-PHL APR 1.3>0.3[1.3]
AA ORD-YUL APR 2>0.4[2]
AA ORD-YYZ APR 5>3[5]
AA PHL-SXM APR 0.3>0[1.0]
AA PHL-YOW APR 2>1.0[3]
AA PHL-YUL APR 2>1.0[3]
AA PHL-YYZ APR 4>1.9[4]
AA PHX-PSP APR 6>4[7]
AA PHX-SJO APR 0.3>0[0.2]
AC ATL-YYZ APR 4>0.5[4] MAY 5>4[5]
AC AUS-YYZ APR 1.0>0[1.1]
AC BDL-YUL APR 0.8>0[0.7]
AC BDL-YYZ APR 2.0>0[3]
AC BNA-YYZ APR 2>0[3]
AC BOS-YHZ APR 1.8>0[1.9] MAY 2>1.0[1.9]
AC BOS-YOW APR 1.8>0[1.5]
AC BOS-YUL APR 4>3[5]
AC BOS-YYZ APR 7>4[8] MAY 7>6[7]
AC BWI-YUL APR 1.0>0[1.0]
AC BWI-YYZ APR 2>0[3] MAY 3>2[3]
AC CLE-YYZ APR 4>0[4]
AC CLT-YYZ APR 2>0[1.9]
AC CMH-YYZ APR 4>0[3]
AC CVG-YYZ APR 3>0[3]
AC DCA-YOW APR 1.9>0[1.9]
AC DCA-YYZ APR 4>3[4]
AC DEN-YUL APR 0.7>1.0[1.0] MAY 1.0>0.7[1.0]
AC DEN-YVR APR 2>1.0[2.0]
AC DFW-YUL APR 1.0>0.2[1.0]
AC DFW-YVR APR 1.0>0[1.0] MAY 1.0>0[1.0]
AC DFW-YYZ APR 3>0.5[3] MAY 4>3[4]
AC DTW-YYZ APR 4>0[4]
AC EWR-YOW APR 3>0[2]
AC EWR-YUL APR 4>2[4]
AC EWR-YVR APR 1.0>0[1.0]
AC EWR-YYC APR 1.0>0[1.0]
AC EWR-YYZ APR 5>3[6] MAY 7>6[7]
AC FLL-YOW APR 0.4>0[0.7]
AC FLL-YUL APR 3>1.0[3]
AC FLL-YYZ APR 3>1.0[3]
AC HNL-YVR APR 1.0>0[1.8]
AC HNL-YYZ APR 0.4>0[0.3]
AC IAD-YYZ MAY 3>2[3]
AC IAH-YUL MAY 2>1.0[2]
AC IAH-YYC APR 2>0[2]
AC IAH-YYZ APR 3>2[3]
AC IND-YYZ APR 2>0[2]
AC KOA-YVR APR 0.3>0[0.4]
AC LAS-YUL APR 1.7>0[2] MAY 2>1.6[2]
AC LAS-YVR APR 1.0>0[2]
AC LAS-YYC APR 0.9>0[1.0]
AC LAS-YYZ APR 2>0[3] MAY 3>1.7[2]
AC LAX-YUL APR 1.9>1.0[2]
AC LAX-YVR APR 5>2[5]
AC LAX-YYC APR 1.0>0[2.0] MAY 2>1.0[2]
AC LAX-YYZ APR 4>2[4] MAY 5>4[5] JUL 7>6[6] AUG 7>6[6]
AC LGA-YUL APR 7>3[8]
AC LGA-YYZ APR 11>3[12]
AC MCI-YYZ APR 1.0>0[1.0]
AC MCO-YHZ APR 1.0>0[0.7]
AC MCO-YOW APR 0.8>0[0.7]
AC MCO-YUL APR 2>1.0[2]
AC MCO-YYZ APR 3>1.0[3]
AC MEM-YYZ APR 1.0>0[1.0]
AC MIA-YUL APR 1.7>0[1.5]
AC MIA-YYZ APR 3>0[2]
AC MKE-YYZ APR 1.7>0[1.7]
AC MSP-YYZ APR 2>0.4[3]
AC MSY-YYZ APR 2>0[2]
AC OGG-YVR APR 1.0>0[1.9]
AC OGG-YYC APR 0.4>0[0.6]
AC ORD-YUL MAY 5>3[5]
AC ORD-YVR APR 1.0>0[1.0]
AC ORD-YYZ APR 7>4[8] MAY 8>7[8]
AC PBI-YUL APR 0.6>0[0.5]
AC PBI-YYZ APR 1.0>0[1.5]
AC PDX-YVR APR 4>0[4]
AC PDX-YYC APR 0.9>0[0.8]
AC PHL-YUL APR 1.0>0[1.9] MAY 3>2.0[1.8]
AC PHL-YYZ APR 3>0.5[4] MAY 5>3[4]
AC PHX-YUL APR 0.6>0[0.6]
AC PHX-YVR APR 1.0>0[0.9]
AC PHX-YYC APR 0.8>0[0.9]
AC PHX-YYZ APR 2>0[2]
AC PIT-YUL APR 0.7>0[0.9] MAY 1.0>0.7[1.0]
AC PIT-YYZ APR 2>0[3] MAY 4>2[4]
AC PSP-YVR APR 0.9>0[0.9]
AC PSP-YYZ APR 0.8>0[0.6]
AC PVD-YYZ MAY 0.2>0[0.2]
AC RDU-YUL APR 1.0>0[0]
AC RDU-YYZ APR 3>0[3]
AC RSW-YUL APR 0.7>0[0.7]
AC RSW-YYZ APR 2>0[2]
AC SAN-YVR APR 3>0[3]
AC SAN-YYZ APR 1.0>0[1.0]
AC SAV-YYZ APR 1.0>0[1.0]
AC SEA-YVR APR 6>3[5] MAY 6>5[6]
AC SEA-YYZ APR 1.0>0[1.0]
AC SFO-YEG APR 1.0>0[1.0] MAY 1.0>0[1.0]
AC SFO-YUL APR 1.0>0[1.6]
AC SFO-YVR APR 4>2[4]
AC SFO-YYC APR 1.0>0[2] MAY 2>1.0[2]
AC SFO-YYZ APR 3>2[4] MAY 4>3[4]
AC SJC-YVR APR 2>0[3] MAY 3>2[3]
AC SMF-YVR APR 1.0>0[1.0]
AC SRQ-YYZ APR 0.7>0[0.8]
AC STL-YYZ APR 3>0[3]
AC TPA-YHZ APR 0.8>0[0.7]
AC TPA-YUL APR 0.7>0[0.8]
AC TPA-YYZ APR 1.9>0[2]
AD JFK-VCP SEP 0.7>0[0] OCT 0.7>0[0] NOV 0.7>0[0] DEC 0.7>0[0]
AM BJX-DTW APR 0.7>0[0.7]
AM DEN-MEX APR 0.7>0.5[0.6]
AM DFW-MEX APR 1.0>0.7[2]
AM DTW-QRO APR 0.7>0[0.7]
AM IAH-MEX APR 3>2[3]
AM JFK-MEX APR 3>2[4] MAY 3>2[4] JUN 3>2[4] JUL 3>2[4]
AM JFK-MTY APR 1.0>0.7[1.0]
AM LAS-MEX APR 1.1>0.6[1.3]
AM LAS-MTY APR 0.3>0[0.3]
AM LAX-MEX APR 4>3[5] MAY 4>2[3] JUN 4>2[5] JUL 5>3[5] AUG 4>3[3]
AM LAX-MTY APR 1.0>0.7[1.0]
AM MCO-MEX APR 1.3>0.9[1.3]
AM MEX-MIA APR 2>1.6[2]
AM MEX-SAT APR 1.0>0.7[1.0]
AM MEX-SEA APR 1.0>0.7[1.0]
AM MEX-SFO APR 2>1.1[2]
AN ABQ-SVC APR 2>4[2]
AN PHX-SVC APR 1.0>2[1.0]
AR EZE-JFK APR 0.5>0.2[1.0]
AR EZE-MIA APR 1.0>0.6[2]
AS AUS-SEA JUL 3>2[2] AUG 3>2[2]
AS AUS-SFO APR 1.9>1.0[1.9]
AS AUS-SJC APR 1.9>1.1[1.9]
AS BOI-PDX APR 9>7[8]
AS BOI-SEA APR 11>8[9]
AS BOS-SEA APR 2>1.3[3]
AS BOS-SFO APR 1.4>0.9[1.9]
AS BWI-SEA APR 2>1.0[1.0]
Quick uturn on that ill-conceived plan
**AS CVG-SEA AUG 0.5>0[0] SEP 1.0>0[0] OCT 1.0>0[0] NOV 1.0>0[0] DEC 1.0>0[0]
AS DAL-LAX APR 3>2[3]
AS DAL-PDX APR 3>1.8[1.9]
AS DAL-SFO APR 3>1.8[3]
AS DCA-SEA APR 2>1.0[2]
AS EWR-LAX APR 3>1.6[3]
AS EWR-SEA APR 3>2[3]
AS EWR-SFO APR 3>1.9[3]
AS GEG-PDX APR 9>7[8]
AS GEG-SEA APR 13>11[14]
AS IAD-LAX APR 1.9>0.9[1.9]
AS IAD-SFO APR 1.9>0.9[1.9]
AS JFK-LAX APR 5>3[5]
AS JFK-SEA APR 3>2[3]
AS JFK-SFO APR 4>3[4]
AS LAX-SEA APR 13>8[14]
AS LAX-SFO APR 10>5[10]
AS LAX-SJC APR 7>3[4]
*AS LAX-SLC MAY 0.6>0[1.0]
AS OGG-SFO AUG 1.0>0.7[1.0]
AS PDX-SEA APR 19>15[16]
AS PDX-SFO APR 7>5[8]
*AS PDX-YVR APR 1.0>0[1.0]
AS SAN-SEA APR 8>6[7]
AS SAN-SFO APR 5>3[5]
AS SAN-SJC APR 6>5[4]
*AS SAN-SLC APR 1.5>1.2[1.0] MAY 0.6>0[1.0]
AS SAN-SMF APR 4>2.0[4]
AS SEA-SFO APR 12>8[11]
AS SEA-SJC APR 8>6[8]
AS SEA-SLC APR 5>4[4]
AS SEA-TPA APR 2>1.0[1.4]
AS SEA-YEG APR 3>1.0[2]
AS SEA-YLW APR 2>1.0[2]
AS SEA-YVR APR 7>3[6]
AS SEA-YYC APR 2>1.0[2]
AS SEA-YYJ APR 3>1.0[3]
AV BAQ-MIA APR 1.0>0[1.0]
AV BOG-FLL APR 1.0>0[1.0]
AV BOG-IAD APR 2>0[0.9]
AV BOG-JFK APR 3>0[3]
AV BOG-LAX APR 1.0>0[1.0]
AV BOG-MCO APR 1.0>0[0.9]
AV BOG-MIA APR 3>0[4]
AV CLO-MIA APR 1.0>0[1.0]
AV DFW-SAL APR 1.0>0[1.0]
AV EWR-SAL APR 1.0>0[1.0]
AV GUA-LAX APR 1.0>0[1.0]
AV IAD-SAL APR 3>0[3]
AV IAH-SAL APR 1.0>0[1.0]
AV JFK-MDE APR 0.6>0[1.0]
AV JFK-SAL APR 2>0[1.9]
AV LAX-SAL APR 4>0.3[3]
AV LIM-MIA APR 1.0>0[1.0]
AV MDE-MIA APR 1.0>0[1.0]
AV MIA-SAL APR 1.0>0[1.0]
AV SAL-SFO APR 2>0[2]
AY HEL-JFK APR 0.7>0[1.0] MAY 1.5>0[1.0] JUN 1.7>0[1.0]
AY HEL-LAX APR 0.3>0[0.4] MAY 0.4>0[0.4] JUN 0.4>0[0.4]
AY HEL-ORD APR 0.5>0[0.9] MAY 1.0>0[1.0] JUN 1.0>0[1.0]
AY HEL-SFO APR 0.3>0[0.3] MAY 0.6>0[0.6] JUN 0.6>0[0.6]
AZ BOS-FCO APR 0.7>0.4[0.9]
AZ FCO-JFK APR 3>1.9[3]
AZ FCO-LAX APR 0.4>0.2[0.6]
AZ FCO-MIA APR 0.7>0.4[1.0]
AZ JFK-MXP APR 0.9>0.6[1.0]
B0 EWR-NCE MAY 0.5>0[0.5]
B0 EWR-ORY APR 1.9>0.6[1.9] MAY 1.5>1.0[1.3] JUN 1.5>1.0[2.0]
B6 ALB-FLL APR 1.0>0.6[1.0]
B6 ALB-MCO APR 1.0>0.4[1.0]
B6 AUA-BOS APR 3>0[3]
B6 AUA-FLL APR 0.6>0[1.0]
B6 AUA-JFK APR 2>0[2]
B6 AUS-BOS APR 1.9>1.1[1.0]
B6 AUS-JFK APR 2>1.1[2]
B6 BDL-MCO APR 3>2[3]
B6 BDL-PBI APR 1.9>1.0[1.0]
B6 BDL-SJU APR 2.0>1.1[2.0]
B6 BNA-BOS APR 3>2.0[2]
B6 BOG-FLL APR 1.0>0[1.0]
B6 BOS-BUF APR 4>3[4]
B6 BOS-BWI APR 5>3[5]
B6 BOS-CLE APR 4>3[3]
B6 BOS-DCA APR 13>7[10]
B6 BOS-DFW APR 1.7>0.7[1.7]
B6 BOS-EWR APR 6>3[5]
B6 BOS-JAX APR 2.0>1.1[3]
B6 BOS-JFK APR 6>5[5]
B6 BOS-LAX APR 4>3[4]
B6 BOS-LGA APR 5>3[5]
B6 BOS-MCO APR 8>6[7]
B6 BOS-MSP APR 2>1.9[3]
B6 BOS-NAS APR 1.7>1.0[2]
B6 BOS-PBI APR 7>6[7]
B6 BOS-PHL APR 7>4[6]
B6 BOS-PIT APR 5>3[5]
B6 BOS-RDU APR 5>4[6]
B6 BOS-RSW APR 7>5[8]
B6 BOS-SAN APR 3>1.9[1.9]
B6 BOS-SEA APR 1.9>1.0[1.9]
B6 BOS-SFO APR 5>4[5]
B6 BOS-SJU APR 3.0>2.0[2.0]
B6 BOS-SXM APR 0.4>0[0.3]
B6 BOS-TPA APR 6>4[5]
B6 BTV-JFK APR 3>2[3]
B6 BUF-JFK APR 5>3[5]
B6 BUR-JFK APR 1.9>1.0[1.9]
B6 CTG-FLL APR 0.6>0[1.0]
B6 CTG-JFK APR 0.6>0[0.6]
B6 CUN-JFK APR 2>1.0[2]
B6 CUR-JFK APR 0.4>0[0.4]
B6 DCA-FLL APR 6>3[5]
B6 DCA-MCO APR 4>2[4]
B6 DCA-PBI APR 2>1.0[1.0]
B6 DCA-RSW APR 3>1.9[2]
B6 EWR-MCO APR 6>4[6]
B6 EWR-RSW APR 2>2.0[3]
B6 EWR-TPA APR 3>2[2]
B6 FLL-GCM APR 1.0>0.6[1.0]
B6 FLL-GYE APR 1.0>0[1.0]
B6 FLL-HAV APR 3>1.0[3]
B6 FLL-HPN APR 2>1.5[2]
B6 FLL-JAX APR 3>2[3]
B6 FLL-JFK APR 8>6[8]
B6 FLL-KIN APR 1.9>1.0[2]
B6 FLL-LAS APR 1.7>1.0[1.0]
B6 FLL-LGA APR 4>2[5]
B6 FLL-MDE APR 0.7>0[0.7]
B6 FLL-NAS APR 3>2[5]
B6 FLL-ORH APR 1.0>0.6[1.0]
B6 FLL-PAP APR 1.7>1.0[1.1]
B6 FLL-PHL APR 1.9>1.5[2]
B6 FLL-PVD APR 1.0>0.7[1.0]
B6 FLL-RDU APR 1.7>1.0[2]
B6 FLL-RIC APR 1.9>1.0[2]
B6 FLL-SFO APR 2>1.1[2]
B6 FLL-SJO APR 1.0>0.6[1.0]
B6 FLL-SWF APR 1.0>0.6[1.0]
B6 FLL-SXM APR 0.4>0[1.0]
B6 FLL-UIO APR 1.0>0[1.0]
B6 GCM-JFK APR 1.0>0.5[1.0]
B6 GEO-JFK APR 1.0>0[0]
B6 GYE-JFK APR 1.0>0[0]
B6 HPN-MCO APR 3>2[3]
B6 HPN-PBI APR 5>3[5]
B6 HPN-RSW APR 1.6>1.0[1.0]
B6 JAX-JFK APR 3>2[3]
B6 JFK-LAX APR 10>8[10]
B6 JFK-LGB APR 1.9>1.4[1.9]
B6 JFK-LIR APR 0.7>0.4[0.8]
B6 JFK-MBJ APR 3>1.0[2]
B6 JFK-MCO APR 9>5[8]
B6 JFK-NAS APR 3>1.5[3]
B6 JFK-OAK APR 0.5>0[0.7]
B6 JFK-ONT APR 1.0>0.6[1.0]
B6 JFK-ORD APR 2>1.0[2]
B6 JFK-PAP APR 1.1>0.8[1.1]
B6 JFK-PBI APR 5>3[5]
B6 JFK-PTP APR 0.4>0[0]
B6 JFK-PUJ APR 1.3>1.0[2]
B6 JFK-ROC APR 3>2[3]
B6 JFK-SAV APR 2>1.5[2]
B6 JFK-SDQ APR 5>4[5]
B6 JFK-SEA APR 1.9>0.9[1.9]
B6 JFK-SFO APR 6>4[6]
B6 JFK-SJO APR 0.4>0.1[0]
B6 JFK-SLC APR 2>1.4[2]
B6 JFK-SXM APR 1.1>0[1.1]
B6 JFK-TPA APR 3>2[4]
B6 LAS-LGB APR 3>1.9[3]
B6 LAX-MCO APR 1.0>0.6[1.0]
B6 LGA-MCO APR 3>2[4]
B6 LGA-PBI APR 3>2[3]
B6 LGB-OAK APR 1.9>0[2]
B6 LGB-SEA APR 2>1.0[1.9]
B6 LGB-SFO APR 2>1.0[2]
B6 LGB-SJC APR 1.9>0[2]
B6 LGB-SLC APR 3>2[3]
B6 LGB-SMF APR 1.9>0[2]
B6 MCO-ORH APR 1.0>0.4[1.0]
B6 MCO-PVD APR 2.0>1.0[2.0]
B6 MCO-RIC APR 2.0>1.0[2]
B6 MCO-SJO APR 1.0>0.6[1.0]
B6 MCO-SJU APR 4>3.1[6]
B6 MCO-SLC APR 1.0>0.7[1.0]
B6 MCO-SWF APR 1.0>0.4[1.0]
B6 PBI-PVD APR 1.0>0.7[1.0]
BA ATL-LHR APR 1.0>0[1.0]
BA AUS-LHR APR 1.0>0[1.0]
BA BNA-LHR APR 1.0>0[0.8]
BA BOS-LHR APR 4>1.0[4]
BA BWI-LHR APR 1.0>0[1.0]
BA CHS-LHR APR 0.3>0[0.3]
BA DEN-LHR APR 1.0>0[1.0]
BA DFW-LHR APR 1.0>0[1.0]
BA EWR-LHR APR 2.0>0[2]
BA IAD-LHR APR 2>1.0[2]
BA IAH-LHR APR 2>0[1.9]
BA JFK-LGW APR 0.6>0[1.0]
BA JFK-LHR APR 8>1.9[8]
BA LAS-LGW APR 0.8>0[0.7]
BA LAS-LHR APR 1.0>0[1.0]
BA LAX-LHR APR 3>1.0[3]
BA LGW-MCO APR 2>0.6[1.9]
BA LGW-TPA APR 0.9>0[1.0]
BA LHR-MIA APR 3>0[3]
BA LHR-MSY APR 0.9>0[0.7]
BA LHR-ORD APR 1.9>0.8[2]
BA LHR-PHL APR 1.4>0[1.4]
BA LHR-PHX APR 1.0>0[1.0]
BA LHR-PIT APR 0.6>0[0.6]
BA LHR-SAN APR 1.0>0[1.0]
BA LHR-SEA APR 2.0>1.0[2]
BA LHR-SFO APR 2>0.9[2]
BA LHR-SJC APR 0.9>0[0.9]
BR LAX-TPE APR 2>1.4[3]
BR SFO-TPE APR 2>1.4[3]
CA PEK-SFO APR 0.6>0.3[1.4]
CI HNL-TPE APR 0.4>0[0.3] MAY 0.4>0.2[0.5]
CX BOS-HKG MAY 1.0>0.6[1.0]
CX EWR-HKG APR 0.8>0[0.9] MAY 0.9>0[1.0]
CX HKG-IAD APR 0.5>0[0.6] MAY 0.6>0[0.6]
CX HKG-JFK APR 3>1.0[3] MAY 3>1.7[3]
CX HKG-ORD APR 0.9>0.4[0.9] MAY 1.0>0.6[1.0]
CX HKG-SEA APR 0.7>0.4[0.6]
CX HKG-SFO APR 3>1.0[3] MAY 3>1.7[3]
CZ CAN-JFK APR 0.6>1.0[1.4] MAY 0.6>1.4[1.4]
CZ CAN-LAX APR 0.6>1.0[1.3] MAY 0.6>1.0[1.4]
CZ JFK-WUH APR 0>0.4[0] MAY 0>0.4[0]
DE FRA-LAS APR 0.4>0.2[0.4]
DL ABE-ATL APR 3>1.9[3]
DL ABQ-ATL APR 1.9>1.0[2.0]
DL ABQ-LAX APR 3>2[1.0]
DL ABY-ATL APR 3>2[3]
DL AEX-ATL APR 4>3[4]
DL AGS-ATL APR 9>7[8]
DL AGS-LGA APR 0.3>0[0.3]
DL ALB-ATL APR 3>2[3]
DL ALB-MSP APR 0.9>0.0[0.9]
DL ATL-ATW APR 2>1.0[2]
DL ATL-AUS APR 8>6[7]
DL ATL-AVL APR 8>6[7]
DL ATL-AVP APR 1.0>0.0[1.0]
DL ATL-BDL APR 7>6[7]
DL ATL-BHM APR 10>9[9]
DL ATL-BMI APR 3>2[3]
DL ATL-BNA APR 10>8[10]
DL ATL-BOG APR 1.0>0[1.0]
DL ATL-BOS APR 11>8[12] SEP 12>11[11]
DL ATL-BUF APR 5>4[5]
DL ATL-BUR APR 1.0>0.7[0]
DL ATL-BWI APR 10>8[11]
DL ATL-CAE APR 9>6[8]
DL ATL-CHA APR 10>8[9]
DL ATL-CHO APR 5>4[5]
DL ATL-CHS APR 10>9[10]
DL ATL-CLT APR 9>7[9]
DL ATL-CRW APR 5>4[5]
DL ATL-CSG APR 4>3[4]
DL ATL-CUN APR 6>3[6] MAY 6>4[6]
DL ATL-CVG APR 8>7[8]
DL ATL-DAB APR 5>4[5]
DL ATL-DAY APR 4>3[4]
DL ATL-DCA APR 11>9[12]
DL ATL-DEN APR 8>6[8] JUL 11>10[9]
DL ATL-DFW APR 8>7[10]
DL ATL-DSM APR 3>1.9[3]
DL ATL-DTW APR 11>10[11] JUN 12>11[12] JUL 12>11[12] AUG 12>11[12] SEP 11>10[11]
DL ATL-ECP APR 6>5[6]
DL ATL-ELP APR 3>1.9[3]
DL ATL-EZE APR 1.0>0.5[1.0]
DL ATL-FAY APR 5>4[5]
DL ATL-FLL APR 13>9[13]
DL ATL-FNT APR 3>2[3]
DL ATL-FWA APR 4>3[4]
DL ATL-GCM APR 1.3>0.7[1.3]
DL ATL-GDL APR 1.0>0.7[0.7] MAY 1.0>0.7[1.0]
DL ATL-GIG APR 1.0>0.7[1.0]
DL ATL-GNV APR 8>6[7]
DL ATL-GPT APR 5>4[5]
DL ATL-GRB DEC 1.5>1.9[1.0]
DL ATL-GRR APR 5>4[5]
DL ATL-GSP APR 9>8[7]
DL ATL-GUA APR 2>0.7[2]
DL ATL-HPN APR 6>5[6]
DL ATL-HSV APR 8>6[7]
DL ATL-IAD APR 7>6[6]
DL ATL-IAH APR 7>6[8]
DL ATL-IND APR 9>8[9]
DL ATL-JAN APR 8>6[6]
DL ATL-JAX APR 11>10[12]
DL ATL-JFK APR 8>5[8]
DL ATL-LAS APR 8>6[8]
DL ATL-LAX APR 11>9[11] AUG 13>12[12]
DL ATL-LEX APR 8>7[8]
DL ATL-LGA APR 14>10[16]
DL ATL-LIR APR 1.3>0.7[1.1]
DL ATL-LIT APR 7>6[6]
DL ATL-LNK APR 0.8>0[0.7]
DL ATL-MCO APR 16>11[17]
DL ATL-MDT APR 3>1.9[3]
DL ATL-MDW APR 6>5[6]
DL ATL-MEM APR 10>8[10]
DL ATL-MEX APR 5>3[5] MAY 5>3[5]
DL ATL-MGM APR 7>6[6]
DL ATL-MHT APR 1.0>0.0[1.0]
DL ATL-MIA APR 10>9[12]
DL ATL-MKE APR 7>6[7]
DL ATL-MLI APR 3>2[3]
DL ATL-MLU APR 4>3[4]
DL ATL-MSP APR 11>9[11]
DL ATL-MSY APR 10>9[11]
DL ATL-MTY APR 1.7>1.0[2] MAY 1.8>0.8[2]
DL ATL-MYR APR 5>4[4]
DL ATL-OKC APR 6>5[6]
DL ATL-OMA APR 5>4[5]
DL ATL-ONT APR 1.6>1.0[0.2]
DL ATL-ORD APR 10>7[11]
DL ATL-ORF APR 9>8[9]
DL ATL-PBI APR 10>8[10]
DL ATL-PDX JUL 6>5[6]
DL ATL-PHL APR 10>7[10]
DL ATL-PHX APR 7>5[7]
DL ATL-PNS APR 8>7[8]
DL ATL-PSP APR 0.3>0[0]
DL ATL-PVD APR 3>2[3]
DL ATL-PVR APR 0.8>0.6[1.1]
DL ATL-RDU APR 12>10[12]
DL ATL-RIC APR 9>8[10]
DL ATL-ROA APR 5>4[5]
DL ATL-SAN APR 5>4[5]
DL ATL-SAT APR 7>5[7]
DL ATL-SAV APR 11>9[10]
DL ATL-SBN APR 4>3[4]
DL ATL-SDF APR 9>8[8]
DL ATL-SEA APR 6>5[6]
DL ATL-SFO APR 7>5[7]
DL ATL-SJC APR 3>2[3]
DL ATL-SJD APR 1.1>0.8[1.1] MAY 1.2>0.9[1.1]
DL ATL-SJO APR 2>1.7[2]
DL ATL-SLC JUL 11>10[10] AUG 10>9[9] SEP 9>8[8]
DL ATL-SMF APR 3>2[3]
DL ATL-SNA APR 3>2[3]
DL ATL-SYR APR 3>2[3]
DL ATL-TLH APR 8>6[7]
DL ATL-TPA APR 13>11[13]
DL ATL-TRI APR 6>5[6]
DL ATL-TUL APR 5>4[5]
DL ATL-TUS APR 2>1.1[2]
DL ATL-TYS APR 9>8[8]
DL ATL-UIO APR 1.0>0.4[1.0]
DL ATL-VPS APR 7>5[7]
DL ATL-YUL APR 5>4[4]
DL ATL-YYZ APR 6>5[6]
DL AUS-CVG APR 0.9>0.6[0.8]
DL AUS-DTW APR 3>2[3]
DL AUS-LAX APR 3>2[3]
DL AUS-MSP APR 3>2[3]
DL AUS-RDU APR 0.9>0.0[0.8]
DL AUS-SLC APR 3>2[3]
DL AZO-MSP APR 1.7>0.1[1.7]
DL BDL-CLE APR 0.9>0.0[0.9]
DL BDL-CVG APR 0.9>0.0[0.8]
DL BDL-DTW APR 5>4[4]
DL BDL-MSP APR 4>3[4]
DL BDL-RDU APR 0.9>0.0[0.9]
DL BGR-LGA APR 3>2[3]
DL BHM-DTW APR 3>1.9[3]
DL BHM-LGA APR 3>1.8[2]
DL BIS-MSP APR 6>5[6]
DL BNA-BOS APR 4>3[3]
DL BNA-DTW APR 6>5[6]
DL BNA-JFK APR 3>1.6[3]
DL BNA-LAX APR 1.6>1.0[1.5]
DL BNA-LGA APR 5>4[5]
DL BNA-MSP APR 4>3[4]
DL BNA-RDU APR 1.9>0.1[1.8] DEC 1.1>1.5[1.2]
DL BNA-SLC APR 1.9>0.9[1.0]
DL BOG-JFK APR 0.9>0[0]
DL BOI-LAX APR 1.9>1.2[1.0]
DL BOI-MSP APR 1.9>0.7[1.9]
DL BOI-SLC APR 6>4[6]
DL BOS-CVG APR 4>3[4]
DL BOS-DCA APR 6>4[0]
DL BOS-DTW APR 6>5[6]
DL BOS-FLL APR 1.7>1.0[2]
DL BOS-IND APR 4>3[3]
DL BOS-JFK APR 8>6[8]
DL BOS-LAS APR 0.7>1.0[0.9]
DL BOS-LAX APR 3>1.9[2]
DL BOS-LGA APR 13>4[13]
DL BOS-MCI APR 3>1.9[1.7]
DL BOS-ORD APR 5>3[0]
DL BOS-PBI APR 0.7>0.9[0.7]
DL BOS-SLC APR 3>2[3]
DL BTV-JFK APR 3>2[3]
DL BUF-JFK APR 5>4[5]
DL BUF-LGA APR 4>3[4]
DL BUR-SLC APR 5>4[4]
DL BWI-CVG APR 3>1.7[3]
DL BWI-JFK APR 4>2[4]
DL BWI-MSP APR 3>2[3]
DL CAE-LGA APR 1.8>1.0[0.9]
DL CHA-LGA APR 1.0>0.0[1.0]
DL CHO-LGA APR 3>1.9[1.8]
DL CHS-DTW APR 2>1.0[2.0]
DL CHS-JFK APR 3>2[3]
DL CID-DTW APR 4>3[3]
DL CID-MSP APR 4>3[3]
DL CLE-JFK APR 4>3[4]
DL CLE-LGA APR 5>4[5]
DL CLE-MSP APR 4>3[4]
DL CLE-RDU APR 0.9>0.0[0.9] DEC 0.5>0.9[0.6]
DL CLT-CVG APR 2>1.6[2]
DL CLT-JFK APR 4>3[4]
DL CLT-LGA APR 7>5[7]
DL CLT-MSP APR 4>3[4]
DL CMH-JFK APR 3>2[3]
DL CMH-LGA APR 5>4[5]
DL CMH-RDU APR 1.7>0.1[1.7]
DL COS-SLC APR 2>1.1[2]
DL CPR-SLC APR 2>1.0[2]
DL CUN-DTW APR 2>1.5[2]
DL CUN-JFK APR 2>1.1[2.0] MAY 2>1.2[2]
DL CUN-MSP APR 2>1.5[2]
DL CVG-DCA APR 3>1.9[4]
DL CVG-DEN APR 1.0>0.7[1.0]
DL CVG-DFW APR 2>1.6[3]
DL CVG-DTW APR 5>4[5]
DL CVG-EWR APR 2>1.6[2]
DL CVG-LAX APR 1.7>1.0[1.7] DEC 1.0>1.4[1.3]
DL CVG-LGA APR 5>4[5]
DL CVG-MCI APR 1.7>0.9[1.6]
DL CVG-MSP APR 5>4[5]
DL CVG-PHL APR 2>1.7[2]
DL CVG-PHX APR 0.7>0.0[1.0]
DL CVG-RDU APR 1.7>1.4[1.8]
DL CVG-SLC APR 1.6>1.0[1.5]
DL CVG-STL APR 1.7>0.9[1.6]
DL CWA-MSP APR 3>2[3]
DL DCA-DTW APR 6>5[6]
DL DCA-JFK APR 5>3[5]
DL DCA-LEX APR 0.9>0[0.9]
DL DCA-LGA APR 8>4[10]
DL DCA-MSP APR 6>5[6]
DL DCA-RDU APR 3>2[3]
DL DEN-JFK APR 3>2[3]
DL DEN-LGA APR 2>1.2[2.0]
DL DEN-MSP APR 6>4[6]
DL DEN-SLC APR 6>5[7]
DL DFW-DTW APR 5>4[5]
DL DFW-JFK APR 3>2[3]
DL DFW-LAX SEP 5>4[3] DEC 5>3[3]
DL DFW-LGA APR 5>4[5]
DL DFW-MSP APR 6>4[6]
DL DSM-DTW APR 4>3[4]
DL DSM-LGA APR 1.8>1.0[1.7]
DL DSM-SLC DEC 1.0>1.4[1.2]
DL DTW-ELM APR 5>4[5]
DL DTW-ERI APR 3>2[3]
DL DTW-EWR APR 6>5[6]
DL DTW-FWA APR 3>1.1[3]
DL DTW-GRR APR 7>5[6]
DL DTW-GSO APR 3>1.9[3]
DL DTW-HPN APR 4>3[4]
DL DTW-IAD APR 5>4[5]
DL DTW-IAH APR 5>4[5]
DL DTW-JAX APR 2>1.0[1.9]
DL DTW-JFK APR 5>4[4]
DL DTW-LAS APR 6>5[5]
DL DTW-LAX APR 6>5[6]
DL DTW-LGA APR 7>6[7]
DL DTW-LHR APR 1.3>0.9[1.5]
DL DTW-LIT APR 0.9>0.1[0.9]
DL DTW-LSE APR 1.0>0[1.0]
DL DTW-MCI APR 4>3[4]
DL DTW-MCO JUL 6>5[6]
DL DTW-MDT APR 4>3[4]
DL DTW-MKE APR 5>4[6]
DL DTW-MQT APR 1.7>1.0[1.7]
DL DTW-MSN APR 5>4[5]
DL DTW-MSP APR 8>7[8]
*DL DTW-MTY APR 0.9>0[0.9] MAY 0.8>0[0.9] JUN 0.9>0.7[0.8]
DL DTW-ORD APR 7>4[6]
DL DTW-PHX APR 4>3[4]
DL DTW-RDU APR 5>4[4]
DL DTW-RIC APR 4>2[3]
DL DTW-SAN APR 2>1.0[2]
DL DTW-SAT APR 3>2[3]
DL DTW-SAV APR 1.0>0.0[1.0]
DL DTW-SEA APR 4>3[4] AUG 7>6[7]
DL DTW-SFO APR 4>3[4]
DL DTW-SJC APR 1.0>0.6[0.7]
DL DTW-STL APR 5>4[5]
DL DTW-TYS APR 5>4[4]
DL DUB-JFK APR 1.0>0.6[1.0]
DL EDI-JFK APR 1.0>0[1.0]
DL EKO-SLC APR 1.9>1.0[1.9]
DL EWR-MSP APR 5>4[5]
DL EWR-RDU APR 3>2[3]
DL FAR-MSP APR 8>7[7]
DL FLL-JFK APR 4>3[4]
DL FLL-LGA APR 4>3[5]
DL FLL-RDU DEC 1.0>1.8[1.6]
DL FSD-MSP APR 7>6[6]
DL FWA-MSP APR 1.0>0.0[1.0]
DL GEG-MSP APR 1.9>1.0[1.9]
DL GEG-SLC APR 4>3[4]
DL GFK-MSP APR 5>4[5]
DL GJT-SLC APR 3>1.0[3]
DL GRB-MSP APR 4>3[4]
DL GRR-LGA APR 3>1.9[3]
DL GRR-MSP APR 5>3[5]
DL GSO-LGA APR 4>3[4]
DL GSP-LGA APR 3>1.9[2]
DL GTF-SLC APR 3>1.0[3]
DL GUA-LAX APR 1.0>0.4[1.0]
DL HAV-MIA APR 1.8>1.0[2]
DL HLN-SLC APR 3>2[3]
DL HND-HNL APR 0.8>0.5[0]
DL HNL-KIX APR 0.4>0.1[1.0]
DL IAD-JFK APR 4>3[4]
DL IAD-MSP APR 3>2[3]
DL IAH-JFK APR 2>1.0[0]
DL IAH-LGA APR 4>3[4]
DL IAH-MSP APR 5>4[5]
DL IND-JFK APR 3>2[2]
DL IND-LGA APR 5>4[4]
DL IND-MCO APR 0.8>0.0[1.0]
DL IND-MSP APR 5>4[5]
DL IND-RDU APR 1.7>0.1[1.7]
DL IND-SLC APR 1.0>0.7[0.9]
DL JAX-JFK APR 3>2.0[3]
DL JAX-RDU APR 0.9>0.0[0]
DL JFK-KEF APR 0.7>0[0.7]
DL JFK-LAS APR 5>4[5]
DL JFK-LAX APR 9>7[9]
DL JFK-MIA APR 4>3[4]
DL JFK-MSP APR 4>3[4]
DL JFK-MSY APR 3>2[3]
DL JFK-ORD APR 5>3[5]
DL JFK-ORF APR 3>2[3]
DL JFK-PBI APR 1.9>0.1[1.7]
DL JFK-PHX APR 3>2[3]
DL JFK-PWM APR 3>2[3]
DL JFK-RDU APR 5>4[5]
DL JFK-RIC APR 4>2[3]
DL JFK-SAV APR 2>1.0[2]
DL JFK-SEA APR 4>2[4]
DL JFK-SFO APR 7>3[7]
DL JFK-SJC APR 0.9>0.6[0.9]
DL JFK-SLC APR 5>4[5] AUG 6>5[5]
DL JFK-SYR APR 3>2[3]
DL JFK-TPA APR 4>3[4]
DL JFK-YUL APR 3>2[3]
DL LAN-MSP APR 1.0>0.0[1.0]
DL LAS-LAX APR 7>6[8]
DL LAS-LGB APR 1.7>0.1[0]
DL LAS-MSP APR 6>5[6]
DL LAS-SAN APR 3>2.0[3]
DL LAS-SEA APR 6>5[5]
DL LAS-SJC APR 3>2[3]
DL LAS-SNA APR 4>2[4]
DL LAX-MCO APR 3>2[3]
DL LAX-MSP APR 7>6[7] DEC 5>6[6]
DL LAX-PDX APR 5>4[5]
DL LAX-PHX APR 5>4[5]
DL LAX-RDU DEC 1.0>1.4[1.2]
DL LAX-SEA APR 8>7[8]
DL LAX-SFO APR 7>4[8]
DL LAX-SJO APR 1.0>0.5[1.0]
DL LAX-SLC APR 8>7[8]
DL LAX-SYD APR 1.0>0.6[1.0]
DL LAX-TPA DEC 1.0>1.4[1.3]
DL LGA-MCI APR 4>3[4]
DL LGA-MHT APR 0.9>0.0[0.9]
DL LGA-MSN APR 3>1.9[2]
DL LGA-MSP APR 6>5[6]
DL LGA-MSY APR 3>2[3]
DL LGA-ORD APR 10>5[13]
DL LGA-ORF APR 4>3[4]
DL LGA-PBI APR 4>3[4]
DL LGA-PIT APR 7>4[7]
DL LGA-PWM APR 3>1.9[3]
DL LGA-RDU APR 7>5[7]
DL LGA-RSW APR 3>1.9[3]
DL LGA-SAV APR 3>2[3]
DL LGA-SDF APR 3>1.9[3]
DL LGA-STL APR 5>4[5]
DL LGA-TPA APR 4>3[4]
DL LGA-TYS APR 3>1.8[3]
DL LGA-YUL APR 4>3[3]
DL LIR-MSP APR 0.3>0[0]
DL LSE-MSP APR 2>1.1[2]
DL LWS-SLC APR 3>1.0[3]
DL MCI-SLC APR 3>2[3]
DL MCO-SLC APR 3>2[3]
DL MEM-MSP APR 3>2[3]
DL MEX-MSP APR 1.0>0.7[0] MAY 1.0>0.7[0]
DL MEX-SLC APR 1.0>0.7[1.0] MAY 1.0>0.7[1.0]
DL MIA-MSP APR 3>2[2]
DL MQT-MSP APR 1.0>0.0[1.0]
DL MSN-MSP APR 6>4[5]
DL MSP-OKC APR 1.9>1.0[1.9]
DL MSP-OMA APR 7>5[6]
DL MSP-ORD APR 7>4[7]
DL MSP-ORF APR 0.9>0.0[0.9]
DL MSP-PDX APR 4>1.9[3]
DL MSP-PHX APR 6>4[6]
DL MSP-PSP APR 0.7>0.0[1.0]
DL MSP-RDU APR 4>3[4]
DL MSP-RIC APR 1.9>1.0[1.9]
DL MSP-SAN APR 4>3[4]
DL MSP-SDF APR 3>1.9[3]
DL MSP-SEA APR 6>5[6]
DL MSP-SFO APR 5>3[5]
DL MSP-SLC APR 6>5[6]
DL MSP-SNA APR 3>1.9[3]
DL MSP-TUS APR 0.6>0.0[1.0]
DL MSP-TYS APR 1.0>0.0[1.0]
DL MSP-YYC APR 3>2[2]
DL MSY-SLC APR 1.0>0.7[1.0]
DL OAK-SLC APR 5>4[5]
DL ORD-SEA APR 3>2.0[3]
DL ORD-SLC APR 4>3[4]
DL PIH-SLC APR 3>1.0[3]
DL PIT-RDU APR 0.7>0.0[0]
DL PIT-SLC APR 1.0>0.7[1.0]
DL PSP-SEA APR 1.3>0.1[1.0]
DL RNO-SLC APR 5>4[5]
DL SAN-SEA APR 5>4[4]
DL SEA-SFO APR 6>3[6]
DL SEA-SJC APR 6>5[4]
DL SEA-SJD APR 0.8>0.4[0.1]
DL SEA-TUS APR 0.3>0.1[0]
DL SFO-SLC APR 5>3[5]
DL SGU-SLC APR 4>1.0[4]
DL SLC-SNA APR 5>4[5]
DL SLC-STL APR 3>2[3]
DL SLC-TPA APR 0.9>0.6[0.7]
DL SLC-TWF APR 3>1.0[3]
EI BDL-DUB APR 1.0>0.5[0.9]
EI DUB-MCO APR 0.9>0.4[0.6]
EI DUB-MSP APR 0.7>0.4[0]
EI DUB-PHL APR 0.9>0.4[0.9]
I believe they announced JFK is also suspended
EK ATH-EWR APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0.0[1.0]
EK DXB-EWR APR 1.0>0[0.5] MAY 1.0>0[0.0] JUN 1.0>0[1.0]
EK DXB-FLL APR 0.6>0[0.5] MAY 0.6>0[0.4] JUN 0.6>0[0.6]
EK DXB-IAH APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0]
EK DXB-MCO APR 0.7>0[0.6] MAY 0.7>0[0.6] JUN 1.0>0[0.7]
EK DXB-ORD APR 1.0>0[0.9] MAY 1.0>0[0.9] JUN 1.0>0[1.0]
EK DXB-SFO APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0]
EK JFK-MXP APR 0.9>0[1.0] MAY 1.0>0.4[1.0]
EW DUS-EWR APR 0.9>0.3[0.8]
EW DUS-MIA APR 0.4>0.1[0.7]
EW DUS-RSW APR 0.4>0.2[0.4]
EW FRA-LAS APR 0.4>0.2[0]
EW MCO-MUC MAY 0.4>0[0]
EY AUH-IAD APR 1.0>0.6[1.0]
EY AUH-ORD APR 1.0>0.6[1.0]
Is F9 really flying their whole schedule???
F9 BIS-DEN APR 0.4>0.1[0]
F9 GUA-MIA MAY 0.7>0[0] JUN 0.8>0.2[0]
F9 GUA-ONT MAY 0.7>0[0] JUN 0.8>0.2[0]
F9 MBJ-PHL APR 0.3>0[0.3]
FJ LAX-NAN APR 1.0>0.7[1.0] MAY 1.0>0.7[1.0]
FJ NAN-SFO APR 0.4>0[0.4] MAY 0.4>0[0.4]
G3 BSB-MCO APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0]
G3 BSB-MIA APR 0.6>0[1.0]
G4 ABQ-AUS MAY 0.3>0.1[0.3]
G4 BNA-GPT MAY 0.3>0[0]
G4 LAX-PVU MAY 0.3>0.1[0.3]
HA AKL-HNL APR 0.5>0[0.7] MAY 0.4>0[0.4]
HA BNE-HNL APR 0.4>0[0.4] MAY 0.5>0[0.5]
HA BOS-HNL APR 0.7>0.4[0.7]
*HA CTS-HNL APR 0.4>0[0.4] MAY 0.4>0[0.4] JUN 0.4>0[0.4] JUL 0.4>0.2[0.4]
HA HNL-ITO APR 14>7[15]
HA HNL-JFK APR 1.0>0.6[1.0]
HA HNL-KOA APR 17>10[18]
HA HNL-LAS APR 3>1.0[3]
HA HNL-LAX APR 3>2[3]
HA HNL-LIH APR 17>10[18]
HA HNL-OGG APR 25>16[27]
HA HNL-PHX APR 1.0>0.7[1.0]
HA HNL-SEA APR 1.4>1.0[1.0]
HA HNL-SFO APR 2>1.0[1.0]
HA HNL-SJC APR 1.0>0.7[1.0]
HA HNL-SYD APR 1.0>0[1.0]
HA ITO-OGG APR 2>1.0[2]
HA KOA-LAX APR 1.0>0.7[1.0]
HA KOA-LIH APR 1.0>0[1.0]
HA KOA-OGG APR 3>2[3]
HA LAS-OGG APR 0.6>0[0]
HA LAX-LIH APR 1.0>0.7[1.0]
HA LIH-OAK APR 1.0>0.7[1.0]
HA LIH-OGG APR 4>2[3]
HA OGG-SFO APR 1.0>0.7[1.0]
HA OGG-SJC APR 1.0>0.7[1.0]
HU BOS-PVG MAY 0.6>0[0.5] JUN 0.6>0[0.6]
HU CKG-JFK MAY 0.3>0[0.3] JUN 0.3>0[0.3]
HU CKG-LAX MAY 0.3>0[0.3] JUN 0.3>0[0.3]
HU CSX-LAX MAY 0.3>0.0[0.3] JUN 0.3>0[0.3]
HU CTU-JFK APR 0.4>0.2[0.4] MAY 0.5>0.0[0.5] JUN 0.4>0[0.4]
HU CTU-LAX APR 0.4>0.2[0.4] MAY 0.4>0[0.4] JUN 0.4>0[0.4]
HU CTU-ORD MAY 0.3>0[0] JUN 0.3>0[0]
HU LAX-XIY MAY 0.3>0.0[0.3] JUN 0.3>0[0.3]
HU ORD-PEK JUN 0.6>0[0.6] JUL 0.5>0[0.5] AUG 0.6>0[0.6] SEP 0.6>0[0.6] OCT 0.5>0[0.5]
HU PEK-SJC APR 0.7>0[0.7] MAY 0.7>0[0.6] JUN 0.7>0[0.7] JUL 0.7>0[0.5] AUG 0.7>0[0.6] SEP 0.7>0[0.6] OCT 0.5>0[0.5]
HU PVG-SEA MAY 0.4>0[0.5] JUN 0.4>0[0.4]
IB BCN-BOS APR 0.6>0.4[0.4]
IB JFK-MAD APR 2>1.5[2]
JL HND-HNL APR 2>1.2[0]
JL HNL-NRT APR 2>1.1[4]
JL KOA-NRT APR 1.0>0.7[1.0]
JQ HNL-MEL APR 0.4>0[0.4] MAY 0.3>0[0.5]
JQ HNL-SYD APR 0.5>0[0.7] MAY 0.5>0[0.7]
LA GRU-JFK APR 1.0>0.7[0]
LA GRU-MCO APR 1.0>0[0]
LA GRU-MIA APR 2>1.4[0]
LA JFK-SCL APR 1.0>0.7[1.0]
LA LAX-SCL APR 1.0>0.0[0.7]
LA LIM-MCO APR 1.0>0[1.0]
LA MIA-REC APR 0.3>0[0]
I thought LH said they would only keep LAX/JFK/ORD
LH ATL-FRA APR 1.0>0.5[1.0]
LH AUS-FRA APR 0.7>0.4[0]
LH BOS-FRA APR 1.0>0.6[1.0]
LH BOS-MUC APR 1.0>0.6[1.0]
LH CLT-MUC APR 1.0>0.5[1.0]
LH DEN-FRA APR 1.0>0.6[1.0]
LH DEN-MUC APR 1.0>0.6[1.0]
LH DFW-FRA APR 1.0>0.5[1.0]
LH DTW-FRA APR 1.0>0.5[1.0]
LH EWR-MUC APR 1.0>0.6[1.0]
LH FRA-IAD APR 1.5>0.8[1.4]
LH FRA-IAH APR 1.0>0.6[1.0]
LH FRA-JFK APR 2>1.2[2]
LH FRA-LAX APR 1.0>0.6[1.0]
LH FRA-MCO APR 1.0>0.6[1.0]
LH FRA-MIA APR 1.0>0.6[1.0]
LH FRA-PHL APR 1.0>0.5[1.0]
LH FRA-SAN APR 0.7>0.4[0.7]
LH FRA-SEA APR 1.0>0.6[1.0]
LH FRA-SFO APR 1.0>0.6[1.0]
LH FRA-TPA APR 0.8>0.5[0.9]
LH IAD-MUC APR 1.0>0.6[1.0]
LH JFK-MUC APR 1.0>0.6[1.0]
LH LAX-MUC APR 1.0>0.6[1.0]
LH MUC-ORD APR 2>0.8[1.9]
LH MUC-SFO APR 1.0>0.6[1.0]
LO LAX-WAW APR 0.6>0.4[0.9]
LX BOS-ZRH APR 0.8>0.5[1.0]
LX GVA-JFK APR 0.9>0.5[1.0]
LX LAX-ZRH APR 1.0>0.6[1.0]
LX MIA-ZRH APR 1.6>1.0[1.6]
LX SFO-ZRH APR 1.0>0.6[1.0]
LY BOS-TLV APR 0.3>0[0.4]
LY EWR-TLV APR 1.3>0.6[1.2]
LY JFK-TLV APR 2>0.6[1.8]
LY LAX-TLV APR 0.5>0[0.6]
LY MIA-TLV APR 0.5>0[0.4]
LY ORD-TLV APR 0.4>0[0] MAY 0.4>0[0] JUN 0.4>0.1[0]
LY SFO-TLV APR 0.3>0[0]
NH HND-HNL APR 1.0>0.3[1.0]
NH HND-IAD APR 1.0>0.6[0]
NH HND-JFK APR 1.0>0.3[1.0]
NH HND-LAX APR 2>1.2[1.0]
NH HND-ORD APR 1.0>0.2[1.0]
NH HND-SEA APR 1.0>0.6[0]
NH HND-SJC APR 1.0>0.2[0]
NK ACY-ATL MAY 1.0>0.4[1.0]
NK ACY-FLL APR 3>1.9[3] MAY 2>1.6[2]
NK ACY-RSW APR 1.7>1.2[2]
NK ATL-BOS APR 0.4>0.8[0.4]
NK ATL-BWI MAY 3>2[3]
NK ATL-CLE APR 0.9>0.7[1.0] MAY 1.0>0.6[1.0]
NK ATL-DFW MAY 2>1.0[2.0]
NK ATL-DTW MAY 3>2[3]
NK ATL-FLL APR 5>4[5] MAY 5>3[4]
NK ATL-LAS APR 2>1.2[1.0] MAY 2>1.0[1.0]
NK ATL-LAX APR 1.1>0.8[1.0] MAY 2>0.7[1.0] JUN 2>1.6[1.0]
NK ATL-MCO APR 2>1.3[2] MAY 2>1.0[2]
NK ATL-MSY APR 0.9>0.6[1.0] MAY 1.0>0.4[1.0]
NK ATL-ORD APR 1.0>0.6[1.0] MAY 1.0>0.4[1.0]
NK ATL-PHL APR 1.0>0.6[1.0] MAY 1.0>0.4[1.0]
NK ATL-TPA APR 1.3>0.9[1.5] MAY 2>0.7[1.6]
NK AUS-BNA APR 0.8>0.2[0] MAY 1.0>0[0] JUN 1.0>0.7[0]
NK AUS-BWI APR 1.0>0.7[1.0] MAY 1.0>0.6[1.0]
NK AUS-DEN APR 0.5>0.2[1.0] MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK AUS-DTW APR 0.9>0.3[1.0] MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK AUS-FLL APR 0.9>0.6[1.0] MAY 1.0>0.6[1.0]
NK AUS-LAS APR 0.9>0.6[1.0] MAY 1.0>0.6[1.0]
NK AUS-MCO MAY 1.6>1.0[1.0]
NK AUS-MSY MAY 1.0>0.6[1.0]
NK AVL-MCO MAY 1.0>0.3[0.6] JUN 1.0>0.8[0.6]
NK AXM-FLL APR 0.4>0.2[0.4]
NK BAQ-FLL MAY 0.4>0[0]
NK BDL-FLL APR 1.7>1.2[2]
NK BDL-MCO APR 2>1.3[2] MAY 2>1.0[2]
NK BDL-MYR APR 1.3>1.8[0.6]
NK BDL-TPA APR 1.4>0.9[1.0]
NK BGA-FLL MAY 0.4>0[0]
NK BNA-BWI MAY 1.0>0.6[0]
NK BNA-LAS APR 1.0>0.7[0] MAY 1.0>0.6[0]
NK BNA-LAX APR 0.8>0.5[0] MAY 1.0>0.4[0]
NK BNA-MCO MAY 1.4>1.0[0]
NK BNA-MSY MAY 1.0>0.4[0]
NK BOG-FLL APR 1.0>0.4[1.0]
NK BOG-MCO APR 1.0>0.2[1.0] MAY 1.0>0.6[1.0]
NK BOS-CLE MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK BOS-DFW APR 0.1>0.3[0]
NK BOS-DTW MAY 1.0>0.6[1.0]
NK BOS-ORD APR 0.1>0.3[0]
NK BOS-RSW APR 1.9>1.1[2]
NK BQN-FLL APR 1.0>0.5[1.4] MAY 1.0>0.4[1.0]
NK BQN-MCO MAY 1.0>0.6[1.0]
NK BUR-LAS MAY 2>1.0[0]
NK BWI-CLT MAY 1.0>0.4[0]
NK BWI-DEN APR 0.9>0.2[1.0] MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK BWI-DFW APR 0.2>0.4[1.0] MAY 1.0>0.6[1.0]
NK BWI-FLL MAY 4>3[3]
NK BWI-JAX APR 1.0>0.7[1.0] MAY 1.0>0.6[1.0]
NK BWI-MBJ APR 1.0>0[1.0] MAY 1.0>0.3[1.0]
NK BWI-MCO MAY 4>3[3]
NK BWI-MSP APR 0.9>0.7[1.0] MAY 1.0>0.6[1.0]
NK BWI-MYR MAY 1.7>1.1[1.5]
NK BWI-ORD APR 1.2>1.6[1.0]
NK BWI-RDU MAY 1.0>0[1.2] JUN 1.0>0.7[2]
NK BWI-RSW APR 0.7>0.3[1.0]
NK BWI-SAL MAY 0.4>0[0] JUN 1.0>0.7[0]
NK CAK-RSW APR 0.4>0.1[0.6]
NK CAK-TPA APR 0.3>0.1[0.4]
NK CLE-FLL APR 1.7>1.1[1.5] MAY 2>1.0[1.0]
NK CLE-LAS MAY 2.0>1.0[1.0]
NK CLE-MCO APR 2>1.7[1.5] MAY 3>1.6[1.0]
NK CLE-MYR APR 0.6>0.9[0.4]
NK CLE-RSW APR 0.7>0.2[1.3]
NK CLE-TPA APR 1.0>0.7[1.0] MAY 1.0>0.6[0.0]
NK CLO-FLL APR 1.0>0.2[1.0] MAY 1.0>0.6[1.0]
NK CLT-FLL APR 0.9>0.7[0] MAY 1.0>0.6[0]
NK CMH-FLL MAY 1.0>0.7[1.0]
NK CMH-MSY MAY 0.4>0[0.4]
NK CMH-MYR MAY 0.3>0[0.5]
NK CMH-RSW APR 0.7>0.2[1.0]
NK CMH-TPA APR 0.7>0.2[1.0]
NK CRW-MYR MAY 0.3>0[0.3]
NK CTG-FLL APR 0.6>0.2[0.6]
NK CTG-MCO APR 0.3>0[0.3] MAY 0.3>0[0.3]
NK CUN-DFW APR 0.6>0.9[0.4]
NK CUN-IAH APR 0.6>0.9[0.4]
NK DEN-DFW APR 0.7>0.2[1.0]
NK DEN-FLL MAY 2>1.4[1.0]
NK DEN-IAH APR 1.0>0.6[1.0] MAY 1.0>0.4[1.0]
NK DEN-LAS APR 2>1.4[1.0] MAY 2>1.3[2.0]
NK DEN-LAX APR 0.3>0[0] MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK DEN-MCO MAY 1.0>0.6[1.0]
NK DEN-ORD MAY 2>1.6[2.0]
NK DFW-DTW MAY 1.4>1.0[1.4]
NK DFW-FLL MAY 3>2[3]
NK DFW-LAS MAY 4>3[4]
NK DFW-LAX MAY 4>3[4]
NK DFW-MCO APR 2>3[2]
NK DFW-MSY MAY 1.0>0.6[1.0]
NK DFW-MYR MAY 0.4>0[0.4]
NK DFW-ORD APR 0.9>0.7[1.0] MAY 1.0>0.6[2.0]
NK DFW-PHL APR 0.2>0.4[1.0] MAY 1.0>0.6[1.0]
NK DFW-SAN APR 0.0>0.3[0]
NK DFW-TPA APR 1.0>0.7[1.0] MAY 1.0>0.6[1.0]
NK DTW-FLL APR 3>2[2]
NK DTW-IAH APR 1.0>0.7[1.0] MAY 1.0>0.6[1.0]
NK DTW-JAX APR 0.5>0.2[1.0]
NK DTW-LAS MAY 4>3[3]
NK DTW-LAX MAY 2>1.6[2.0]
NK DTW-MBJ APR 0.3>0[0.4]
NK DTW-MCI APR 1.0>0.5[1.0] MAY 1.0>0.5[1.0]
NK DTW-MSY APR 1.5>1.0[1.0] MAY 1.0>0.7[1.0]
NK DTW-PBI APR 0.4>0.1[0.6]
NK DTW-PHL APR 0.3>0[0] MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK DTW-RSW APR 2>1.4[4]
NK DTW-SAN APR 0.0>0.3[0]
NK DTW-SEA MAY 1.0>0.6[1.0]
NK DTW-TPA APR 2>1.5[3]
NK EWR-MSY APR 1.0>0.8[1.0] MAY 1.0>0.7[1.0]
NK EWR-MYR APR 0.7>0.9[0.6]
NK EWR-SJU APR 2.0>1.2[0] MAY 2.0>1.0[0]
NK FLL-GUA APR 1.2>0.4[1.0] MAY 1.6>1.0[1.0]
NK FLL-GYE APR 1.0>0[1.0]
NK FLL-IAG APR 0.8>0.4[1.0]
NK FLL-KIN APR 0.4>0[0.7] MAY 0.9>0.1[1.0]
NK FLL-LIM APR 1.0>0.4[1.0]
NK FLL-MBJ APR 0.7>0[1.0] MAY 1.0>0.3[1.0]
NK FLL-MDE APR 1.0>0.4[1.0]
NK FLL-MGA APR 1.0>0.6[0.6] MAY 1.0>0.6[1.0]
NK FLL-MSP APR 0.7>0.2[1.0]
NK FLL-MSY MAY 3>2[2.0]
NK FLL-MYR MAY 2>1.0[1.3]
NK FLL-ORD MAY 3>2[2]
NK FLL-PAP APR 1.0>0.2[1.0] MAY 1.0>0.4[1.0]
NK FLL-PBG APR 0.8>0.4[1.0]
NK FLL-PHL MAY 4>2[2]
NK FLL-PIT APR 1.7>1.2[1.0] MAY 2>1.0[1.0]
NK FLL-PTY APR 1.0>0.1[1.0] MAY 1.0>0.6[1.0]
NK FLL-PUJ APR 0.4>0.2[0.4] MAY 1.0>0.6[1.0]
NK FLL-RDU MAY 1.0>0.6[1.0]
NK FLL-SAL APR 0.8>0.4[0.4] MAY 1.3>0.8[0.6]
NK FLL-SAP APR 1.0>0.4[1.0]
NK FLL-SDQ APR 1.3>0.4[1.0] MAY 2>1.0[1.0]
NK FLL-SJO APR 2>1.2[2] MAY 2>1.0[1.9]
NK FLL-SJU APR 2.0>1.2[2.0] MAY 2.0>1.0[1.3]
NK FLL-STI APR 0.6>0.1[0.6] MAY 0.6>0.3[0.5]
NK FLL-STX MAY 1.0>0.6[0.7]
NK FLL-TPA APR 1.6>1.2[2] MAY 2>1.0[1.0]
NK GSO-MCO APR 0.7>0.4[0.6] MAY 1.0>0.3[0.6] JUN 1.0>0.8[0.6]
NK GUA-IAH APR 0.6>0[0.6] MAY 0.6>0[0.6]
NK GUA-MCO APR 0.6>0[0.6] MAY 0.6>0[0.6]
NK IAH-LAS MAY 3>2[2]
NK IAH-LAX MAY 3>2[2]
NK IAH-MCO APR 3>2[2] MAY 3>1.9[2]
NK IAH-MSY APR 1.0>0.7[1.0] MAY 1.0>0.6[1.0]
NK IAH-OAK MAY 1.0>0.7[1.0]
NK IAH-ORD MAY 2>1.6[2]
NK IAH-SAL APR 0.4>0[0.4] MAY 0.4>0[0.4]
NK IAH-SAN APR 1.0>0.7[1.0] MAY 1.0>0.6[1.0]
NK IAH-SAP APR 0.5>0[0.6] MAY 0.4>0[0.4]
NK IAH-SEA MAY 1.0>0.6[1.0]
NK IAH-TPA MAY 1.0>0.7[1.0]
NK IND-RSW APR 0.7>0.2[0] MAY 0.9>0[0] JUN 1.0>0.7[0]
NK IND-TPA APR 0.7>0.2[0] MAY 1.0>0[0] JUN 1.0>0.7[0]
NK JAX-ORD APR 0.5>0.2[1.0]
NK LAS-LAX APR 3>1.9[3] MAY 3>1.6[3]
NK LAS-MCI MAY 2>1.6[1.0]
NK LAS-MSP APR 1.7>1.1[2]
NK LAS-OAK MAY 4>3[4]
NK LAS-PDX MAY 3>2[3]
NK LAS-SAN APR 3>1.8[3] MAY 3>1.6[4]
NK LAS-SEA APR 2>1.7[3] MAY 3>1.6[4]
NK LAS-SMF APR 3>1.8[0] MAY 3>1.6[0]
NK LAX-MCI APR 0.8>0.6[1.0] MAY 1.0>0.6[1.0]
NK LAX-MSP APR 0.7>1.0[1.0]
NK LAX-OAK MAY 2>1.0[2.0]
NK LAX-ORD MAY 2>1.6[2]
NK LAX-PHL APR 1.0>0.2[1.0] MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK LAX-PIT MAY 2>1.0[1.0]
NK LBE-RSW APR 0.4>0.1[0.6]
NK LBE-TPA APR 0.3>0.1[0.4]
NK MBJ-MCO APR 0.4>0[0.6] MAY 0.4>0[0.5]
NK MCO-MSY APR 1.3>1.0[1.0] MAY 2>1.0[1.0]
NK MCO-ORD APR 1.7>1.2[2]
NK MCO-PIT APR 1.6>1.2[1.0] MAY 1.4>1.0[1.0]
NK MCO-RDU MAY 2>1.0[1.0]
NK MCO-RIC APR 1.0>0.8[1.0] MAY 1.0>0.7[1.0]
NK MCO-SAL APR 0.3>0[0.3] MAY 0.3>0[0.3]
NK MCO-SAP APR 0.3>0[0.3] MAY 0.3>0[0.3]
NK MCO-SJO APR 1.0>0.7[1.0] MAY 1.0>0.6[1.0]
NK MCO-SJU MAY 4>3.0[2.7]
NK MSP-MSY MAY 0.6>0.3[0.6]
NK MSP-PHX APR 0.7>0.2[1.0]
NK MSP-RSW APR 0.7>0.2[1.3]
NK MSY-ORD MAY 2>1.0[1.0] JUN 1.3>1.0[1.0]
NK MSY-PHL APR 0.6>0.3[0] MAY 0.6>0.3[0.5]
NK MSY-RDU APR 0.9>0.6[0] MAY 1.0>0.6[1.0]
NK MYR-PIT APR 0.6>0.9[0.4]
NK OAK-ORD MAY 1.0>0.7[1.0]
NK ORD-PHX APR 0.7>0.2[1.0]
NK ORD-RDU MAY 0.9>0[1.0] JUN 1.0>0.7[1.0]
NK ORD-RSW APR 1.7>0.9[2] MAY 1.0>0.6[1.0]
NK ORD-SAN APR 1.0>0.6[1.0] MAY 1.0>0.4[1.0]
NK ORD-SEA APR 0.3>0[0] MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK ORD-TPA APR 1.7>1.2[2]
NK PHL-RSW APR 0.3>0.6[0.4]
NK PHL-SJU APR 2.0>1.2[0] MAY 2.0>1.0[0.3]
NK PHL-TPA APR 0.7>0.2[0.6]
NK PHX-SEA APR 0.7>0.2[0]
NK PIT-RSW APR 0.7>0.2[1.0]
NK PIT-TPA APR 0.7>0.2[1.0]
OR AMS-MIA APR 0.3>0[0.3]
OS EWR-VIE APR 1.0>0.6[1.0]
OS IAD-VIE APR 0.9>0.6[0.9]
OS JFK-VIE APR 1.0>0.6[1.0]
OS LAX-VIE APR 0.7>0.4[0.7]
OZ HNL-ICN APR 1.0>0.5[0.7]
OZ ICN-SFO APR 0.4>0.0[1.0]
PD BOS-YTZ APR 5>0[5] MAY 6>0[6]
PD EWR-YTZ APR 8>0[11] MAY 11>0[12]
PD IAD-YTZ APR 3>0[3] MAY 3>0[3]
PD MDW-YTZ APR 3>0[3] MAY 5>0[5]
PD MYR-YTZ APR 0.3>0[0.3]
QR DOH-JFK APR 2>1.0[2]
QR DOH-MIA JUN 1.0>0.7[0.7]
QR DOH-ORD APR 1.0>0.7[1.0]
RJ AMM-JFK APR 0.6>0[0.6] MAY 0.6>0[0.6] JUN 0.8>0[0.9] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 0.8>0[0.7] OCT 0.5>0[0.5] NOV 0.4>0[0.4] DEC 0.6>0[0.6]
S4 BOS-PDL APR 0.8>0.4[0.9]
SA ACC-IAD APR 1.0>0[0.7] MAY 1.0>0[0.7]
SA JFK-JNB APR 1.0>0[1.0] MAY 1.0>0[1.0]
SN BRU-IAD APR 1.0>0.4[1.0]
SN BRU-JFK APR 1.0>0.4[1.0]
SQ FRA-JFK APR 1.0>0[1.0] MAY 1.0>0[1.0]
SS MIA-ORY APR 0.7>0[0] MAY 0.7>0[0]
SU LAX-SVO APR 1.0>0[1.0]
SU MIA-SVO APR 0.5>0[0.6]
SY CUN-MSP APR 1.2>0.9[1.3]
SY LAS-MSP APR 3>1.8[3]
SY LIR-MSP APR 0.3>0[0.3]
SY MBJ-MSP APR 0.3>0[0.3]
SY MCO-MSP APR 3>1.9[3]
SY MIA-MSP APR 1.2>0.8[0.9]
SY MSP-ORD APR 0.5>0[0.2]
SY MSP-PHX APR 2>1.4[2]
SY MSP-PUJ APR 0.4>0[0.7]
SY MSP-RSW APR 3>1.8[3]
SY MSP-TPA APR 1.8>1.1[1.7]
TA MGA-MIA APR 1.0>0[0.9]
TP BOS-LIS APR 1.0>0.3[1.0]
TP EWR-OPO APR 0.7>0[0.3]
TP IAD-LIS APR 0.6>0.0[0]
TP JFK-LIS APR 1.0>0[1.0]
TP LIS-MIA APR 1.4>0.3[1.0]
TP LIS-ORD APR 0.6>0[0]
TP LIS-SFO APR 0.5>0[0]
TS FLL-YQB APR 0.7>0[0.5]
TS FLL-YUL APR 1.0>0[0.7]
TS FLL-YVR APR 0.3>0[0]
TS FLL-YYZ APR 0.7>0.0[0.7]
TS MCO-YHZ APR 0.3>0[0.3]
TS MCO-YQB APR 0.3>0[0.3]
TS MCO-YUL APR 0.4>0[0.4]
TS MCO-YYZ APR 0.4>0[0.3]
TS MSY-YUL APR 0.3>0[0]
UA ACA-IAH APR 0.3>0[0.3]
UA ACV-DEN APR 1.0>0[0] MAY 1.0>0[0]
UA AGU-IAH APR 1.0>0[2]
UA AKL-SFO APR 0.4>0[0.4]
UA AMS-EWR APR 1.0>0[1.0]
UA ANU-EWR APR 0.4>0.1[0.4]
UA ASE-DEN NOV 5>4[4] DEC 5>4[6]
UA ASE-LAX APR 0.2>0[0.2]
UA ASE-ORD APR 0.2>0[0.3]
UA ATL-EWR APR 7>6[7]
UA AUA-EWR APR 2>0[2]
UA AUA-IAD APR 0.4>0[0.4]
UA AUA-ORD APR 0.7>0[0.4]
UA AUS-LAX APR 1.0>0[1.9] MAY 1.5>0[1.9]
UA BDL-IAH APR 1.0>0[1.0] MAY 1.0>0[1.0]
UA BIS-ORD APR 1.0>0[2] MAY 1.8>0[2]
UA BJX-IAH APR 3>2[3]
UA BNA-SFO APR 1.7>0[2] MAY 1.8>0[2]
UA BOG-EWR APR 1.0>0[1.0]
UA BOG-IAH APR 1.1>0[2]
UA BOI-IAH APR 1.0>0[1.0] MAY 1.6>0[1.0]
UA BOM-EWR APR 1.0>0[1.0]
UA BOS-EWR APR 10>9[10]
UA BQN-EWR APR 1.0>0[1.0]
UA BWI-LAX APR 1.0>0[1.0] MAY 1.0>0[1.0]
UA BWI-SFO APR 1.2>0[1.9] MAY 1.8>0[1.9]
UA BZE-IAH APR 2>1.0[2]
UA BZN-LAX APR 0.9>0.7[1.0]
UA BZN-ORD APR 1.9>0[2] MAY 1.2>0[2]
UA BZN-SFO APR 1.0>0.8[1.0]
UA CAK-EWR APR 1.0>0[1.9] MAY 0.2>0[2]
UA CDG-EWR APR 1.0>0[1.0]
UA CLE-EWR APR 7>6[6]
UA CMH-SFO APR 1.0>0[0] MAY 1.0>0[0]
UA CUN-DEN APR 2>0[2]
UA CUN-EWR APR 4>1.0[4]
UA CUN-IAD APR 2>0[1.9]
UA CUN-IAH APR 5>4[5]
UA CUN-LAX APR 2>0[2]
UA CUN-ORD APR 3>1.0[3]
UA CUU-IAH APR 1.0>0[1.0]
UA CZM-IAH APR 1.0>0[0.6]
UA DCA-EWR APR 12>11[7]
UA DCA-ORD APR 14>13[14]
UA DEL-EWR APR 1.0>0[1.0]
UA DEL-SFO APR 0.4>0[0]
UA DEN-FAI JUN 0.4>0[0.5] JUL 1.0>0[0.6] AUG 0.5>0[0.4]
UA DEN-KOA APR 1.0>0[1.0]
UA DEN-LHR APR 1.0>0[1.0]
UA DEN-LIH APR 1.0>0[1.0]
UA DEN-NRT APR 1.0>0[1.0]
UA DEN-PRC MAY 2>1.5[1.0]
UA DEN-PVR APR 0.6>0[0.5]
UA DEN-SJD APR 1.1>0[0.5]
UA DEN-YEG APR 2>1.5[2]
UA DEN-YWG APR 1.0>0.8[1.1]
UA DEN-YYC APR 3>2[3]
UA DEN-YYZ APR 2>1.5[2]
UA DTW-SFO APR 1.0>0[1.0] MAY 1.0>0[1.0]
UA DUB-EWR APR 1.0>0[1.0]
UA DUB-IAD APR 1.0>0[1.0]
UA DUB-ORD APR 1.0>0[1.0]
UA EAR-ORD APR 1.0>0.8[0]
UA EDI-EWR APR 1.0>0[1.0]
UA EWR-FLL APR 8>7[8]
UA EWR-GCM APR 1.3>0[0.3]
UA EWR-GRU APR 1.0>0[1.0]
UA EWR-HAV APR 1.0>0[1.0]
UA EWR-HHH APR 0.5>0[0.3] MAY 0.6>0[0.1] JUN 0.3>0[0.3] JUL 0.3>0[0.3] AUG 0.3>0[0.2]
UA EWR-HND APR 1.0>0[0]
UA EWR-HNL APR 1.0>0.8[1.0]
UA EWR-LHR APR 5>1.0[5]
UA EWR-LIM APR 1.0>0[0.6]
UA EWR-LIR APR 1.1>0[1.1]
UA EWR-LIS APR 0.6>0[1.0]
UA EWR-MAN APR 1.0>0[1.0]
UA EWR-MBJ APR 2>0[1.7]
UA EWR-MCO APR 10>9[11]
UA EWR-MEX APR 1.9>0[3]
UA EWR-MSY APR 6>5[6]
UA EWR-MUC APR 1.0>0[1.0]
UA EWR-NAS APR 2>1.0[1.9]
UA EWR-NRT APR 0.8>0.6[1.0]
UA EWR-OMA APR 1.1>0[3] MAY 1.9>0[3]
UA EWR-PBI APR 7>6[8]
UA EWR-PDX APR 1.0>0[1.7] MAY 1.7>0[1.8]
UA EWR-POP APR 1.0>0[0.9]
UA EWR-PTY APR 1.4>0[1.4]
UA EWR-PUJ APR 2>0[2]
UA EWR-RDU APR 8>7[9]
UA EWR-SDQ APR 2>0[2]
UA EWR-SEA APR 1.7>0[3] MAY 3>0[3]
UA EWR-SFO APR 11>9[13]
UA EWR-SJD APR 0.4>0[0.4]
UA EWR-SJO APR 2>0[2]
UA EWR-SJU APR 2.3>1.0[2.2]
UA EWR-SMF APR 1.0>0[0.7] MAY 1.0>0[1.0]
UA EWR-SNN APR 1.0>0[1.0]
UA EWR-STI APR 1.0>0[1.0]
UA EWR-SXM APR 1.0>0[0.9]
UA EWR-TLV APR 1.6>1.0[1.9]
UA EWR-TPA APR 6>5[6]
UA EWR-TYS APR 1.0>0[1.0] MAY 1.0>0[1.0]
UA EWR-XNA APR 1.0>0[1.0] MAY 1.0>0[0.9]
UA EWR-YHZ APR 2>1.5[2]
UA EWR-YQB APR 3>2[3]
UA EWR-YUL APR 3>2[3]
UA EWR-YYZ APR 4>3[4]
UA EWR-ZRH APR 1.0>0[1.0]
UA EZE-IAH APR 1.0>0[1.0]
UA FAT-ORD APR 1.0>0[1.0] MAY 1.0>0[1.0]
UA FLL-IAH APR 6>5[5]
UA FRA-IAD APR 1.0>0[1.9]
UA FRA-SFO APR 1.0>0[1.9]
UA GCM-IAH APR 1.0>0[0.5]
UA GCM-ORD APR 0.3>0[0.3]
UA GDL-IAH APR 3>2[4]
UA GEG-ORD APR 1.0>0[1.0] MAY 1.0>0[1.0]
UA GIG-IAH APR 1.0>0[1.0]
UA GRR-IAD APR 1.0>0[1.0] MAY 1.0>0[1.0]
UA GRR-IAH APR 1.0>0[1.9] MAY 1.0>0[1.9]
UA GRU-ORD APR 1.0>0[1.0]
UA GUA-IAD APR 0.3>0[0.3]
UA GUA-IAH APR 3>0[3]
UA HAV-IAH APR 1.0>0[1.0]
UA HND-IAD APR 1.0>0[0]
UA HND-LAX APR 1.0>0[0]
UA HND-ORD APR 1.0>0[0]
UA HNL-MAJ APR 0.4>0.0[0.6]
UA HNL-NRT APR 1.0>0[1.0]
UA IAD-LHR APR 3>1.0[3]
UA IAD-MEX APR 1.0>0[1.0]
UA IAD-PDX APR 1.0>0[1.0] MAY 1.0>0[1.0]
UA IAD-PUJ APR 1.1>0[1.9]
UA IAD-SJO APR 0.3>0[0.3]
UA IAD-SJU APR 1.3>0[1.2]
UA IAD-SMF APR 1.0>0[1.0] MAY 1.0>0[1.0]
UA IAD-STT APR 1.0>0[0.9]
UA IAD-YUL APR 3>2[3]
UA IAH-LEX APR 1.0>0[1.0] MAY 1.1>0[1.1]
UA IAH-LHR APR 1.9>0[1.7]
UA IAH-LIM APR 1.0>0[1.0]
UA IAH-LIR APR 2>0[2]
UA IAH-MEX APR 5>4[6]
UA IAH-MGA APR 1.0>0[0.6]
UA IAH-MID APR 1.0>0[0.9]
UA IAH-MLM APR 1.0>0[1.0]
UA IAH-MTY APR 6>3[7]
UA IAH-NAS APR 1.1>0[1.2]
UA IAH-NRT APR 0.2>0[1.0]
UA IAH-OAX APR 0.5>0[0.9]
UA IAH-ONT APR 1.0>0[0] MAY 1.0>0[0]
UA IAH-PBC APR 1.0>0[1.0]
UA IAH-POS APR 1.0>0[1.0]
UA IAH-PSP APR 3>0[3] MAY 0.8>0[0]
UA IAH-PTY APR 2>0[3]
UA IAH-PUJ APR 0.3>0[0.3]
UA IAH-PVR APR 2>1.0[2]
UA IAH-QRO APR 3>0[4]
UA IAH-RTB APR 0.9>0[1.1]
UA IAH-SAL APR 2>0[2]
UA IAH-SAP APR 1.0>0[1.0]
UA IAH-SCL APR 1.0>0[1.0]
UA IAH-SJC APR 1.0>0[1.9] MAY 1.8>0[1.9]
UA IAH-SJO APR 2>0[2]
UA IAH-SJU APR 2.0>0[1.3]
UA IAH-SLP APR 1.0>0[2]
UA IAH-SYD APR 0.6>0[0.6]
UA IAH-TAM APR 1.0>0[1.0]
UA IAH-TGU APR 1.0>0[1.0]
UA IAH-UIO APR 1.0>0[1.0]
UA IAH-VER APR 1.0>0[1.0]
UA IAH-YYC APR 1.0>0.8[1.9]
UA IAH-YYZ APR 2>1.5[3]
UA IAH-ZIH APR 0.4>0[0.4]
UA ICN-SFO APR 0.4>0[1.6]
UA IND-SFO APR 1.2>0[1.0] MAY 1.8>0[1.7]
UA KIX-SFO APR 0.8>0[1.0]
UA KOA-LAX APR 1.1>0.9[2]
UA LAX-LHR APR 1.0>0[1.0]
UA LAX-LIH APR 0.8>0.6[1.1]
UA LAX-MEL APR 0.6>0[1.0]
UA LAX-MMH APR 1.0>0[1.0] MAY 1.0>0[1.0]
UA LAX-MSN APR 1.0>0[1.0] MAY 1.0>0[1.0]
UA LAX-MSO JUN 0.9>0.5[0.5] JUL 1.0>0.6[1.0] AUG 0.5>0.3[0.6]
UA LAX-NRT APR 0.2>0[1.0]
UA LAX-OGG APR 2>1.6[2]
UA LAX-PVR APR 0.3>0[0.1]
UA LAX-SAT APR 1.5>0[1.6] MAY 1.6>0[1.5]
*UA LAX-SGU APR 1.0>0[1.1] MAY 1.0>0[1.0] JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0.2] OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0]
UA LAX-SYD APR 0.4>0[0.4]
UA LAX-YVR APR 1.0>0.8[1.0]
UA LGA-ORD APR 14>12[16]
UA LHR-ORD APR 3>0[3]
UA LHR-SFO APR 1.8>0[1.8]
UA LIR-ORD APR 0.5>0[0.5]
UA MBJ-ORD APR 1.0>0[0.9]
UA MCI-SFO APR 1.0>0[1.9] MAY 1.8>0[1.9]
UA MEL-SFO APR 0.4>0[0]
UA MEX-ORD APR 1.9>0[1.9]
UA MEX-SFO APR 2>0[2]
UA MMH-SFO APR 1.0>0[0]
UA MSN-SFO APR 1.0>0[1.0] MAY 1.0>0[1.0]
UA MSY-SFO APR 0.4>0[2.0]
UA MTY-ORD APR 2>0[2]
UA MUC-SFO APR 1.0>0[1.0]
UA NAS-ORD APR 1.1>0[1.1]
UA OGG-ORD APR 0.7>0[0.7]
UA OMA-SFO APR 1.0>0[1.7] MAY 1.8>0[1.7]
UA ORD-PLS APR 0.5>0[0.1]
UA ORD-PSP APR 1.0>0[0.9] MAY 0.4>0[0]
UA ORD-PUJ APR 1.1>0[1.1]
UA ORD-PVR APR 2>0[1.9] MAY 0.6>0.4[0.1]
UA ORD-RNO APR 1.0>0[0.3] MAY 1.0>0[1.0]
UA ORD-SJC APR 1.0>0[1.9] MAY 1.0>0[1.7]
UA ORD-SJD APR 1.0>0[0.9]
UA ORD-SJO APR 0.4>0[0.4]
UA ORD-SJU APR 1.4>0[1.4]
UA ORD-YOW APR 2>0[3] MAY 3>0[3]
UA ORD-YUL APR 3>2[3]
UA ORD-YVR APR 1.0>0.7[1.9]
UA ORD-YWG APR 1.0>0.8[2]
UA ORD-YYC APR 2>1.5[3]
UA ORD-YYZ APR 6>5[7]
UA PHL-SFO APR 1.3>0[1.9] MAY 1.8>0[1.9]
UA PIT-SFO APR 1.2>0[1.7] MAY 1.7>0[1.9]
UA PPT-SFO APR 0.4>0[0.4]
UA RDM-SFO APR 4>3[4] MAY 4>3[5]
UA RDU-SFO APR 1.1>0[1.7] MAY 1.7>0[1.8]
UA RIW-SHR APR 1.0>0.8[0]
UA SAT-SFO APR 1.0>0[1.0] MAY 1.0>0[1.0]
UA SFO-SIN APR 1.2>0[2]
UA SFO-STL APR 1.0>0[1.9] MAY 1.7>0[1.9]
UA SFO-TLV APR 0.6>0[0.9]
UA SFO-TPA APR 1.0>0[1.0] MAY 1.7>0[1.0]
UA SFO-TPE APR 1.0>0[1.0]
UA SFO-YYC APR 1.9>1.4[2]
UA SFO-YYZ APR 1.7>0[2] MAY 1.7>0[2]
VA BNE-LAX APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0.2[0.9]
VA LAX-MEL APR 0.7>0[0.7] MAY 0.7>0[0.6] JUN 0.7>0.2[0.7]
VA LAX-SYD APR 1.0>0[1.0] MAY 1.0>0[0.9] JUN 1.0>0.5[1.0]
VR IAD-SID APR 0.3>0[0]
VS ATL-LHR APR 1.0>0.6[1.0]
VS ATL-MAN APR 1.0>0.6[0.9]
VS BOS-LHR APR 1.7>1.1[2]
**VS EWR-LHR APR 0.9>0.0[1.0] MAY 1.0>0[1.0] JUN 0.9>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 0.9>0[0.9]
VS IAD-LHR APR 0.9>0.5[1.0]
VS JFK-LHR APR 4>3[6]
VS JFK-MAN APR 1.0>0.6[1.0]
VS LAS-LHR APR 1.0>0.6[1.0]
VS LAS-MAN APR 0.6>0.3[0.6]
VS LAX-LHR APR 2>1.7[2]
VS LGW-MCO APR 1.9>1.1[2]
VS LHR-MIA APR 1.0>0.6[1.0]
VS LHR-SEA APR 1.3>0.8[1.0]
VS LHR-SFO APR 1.7>1.0[1.9]
VS MAN-MCO APR 1.6>0.9[1.8]
WK LAS-ZRH APR 0.3>0[0.1]
WK TPA-ZRH APR 0.4>0[0.2]
WN ABQ-DEN MAY 3>2[3]
WN ABQ-PHX MAY 5>4[5]
WN ATL-BNA MAY 4>3[4]
WN ATL-BWI MAY 6>5[5]
WN ATL-DCA MAY 4>3[4]
WN ATL-HOU MAY 5>4[5]
WN ATL-IND MAY 3>1.9[3]
WN ATL-MDW MAY 7>6[6]
WN ATL-TPA MAY 6>5[5]
WN AUS-ELP APR 2>1.9[3] MAY 3>1.7[3]
WN BHM-BWI MAY 1.7>1.3[1.0]
WN BHM-MDW APR 1.8>1.3[1.9] MAY 1.7>0.9[1.8]
WN BHM-TPA APR 2.0>1.5[1.9] MAY 1.8>1.0[1.8]
WN BNA-CLT APR 1.7>1.3[1.9] MAY 1.5>0.9[1.8]
WN BNA-CMH APR 1.7>1.3[2] MAY 1.6>1.0[2]
WN BNA-DAL MAY 6>5[5]
WN BNA-HOU MAY 4>3[4]
WN BNA-MSP MAY 1.0>0.7[1.0]
WN BNA-SAT MAY 2>1.8[1.9]
WN BOS-CMH APR 1.3>0.9[1.5] MAY 1.7>1.0[1.7]
WN BUR-LAS MAY 10>9[10]
WN BUR-OAK MAY 12>11[11]
WN BUR-SFO MAY 4>3[4]
WN BUR-SJC MAY 10>9[10]
WN BUR-SMF MAY 9>8[8]
WN BWI-CLE MAY 4>3[3]
WN BWI-CLT MAY 3>2[3]
WN BWI-CVG MAY 3>2.0[3]
WN BWI-DTW MAY 3>2[2]
WN BWI-FLL MAY 11>10[10]
WN BWI-PIT MAY 1.8>1.5[3]
WN BWI-RDU MAY 6>5[6]
WN BWI-TPA MAY 8>7[7]
WN CLE-MDW MAY 4>3[4]
WN CLE-MKE APR 1.4>1.0[1.6] MAY 1.1>0.5[1.6]
WN CLE-STL APR 2.0>1.6[2.0] MAY 1.9>1.2[2.0]
WN CMH-DCA APR 1.7>1.3[1.9] MAY 1.7>1.0[1.9]
WN CMH-STL APR 1.5>1.1[3] MAY 1.9>1.2[3]
WN CVG-MDW MAY 4>3[5]
WN DAL-HOU MAY 18>17[19]
WN DAL-SAT MAY 9>8[9]
WN DCA-TPA MAY 2>1.7[2]
WN DEN-LAS MAY 10>9[10]
WN DEN-MDW MAY 9>8[9]
WN DEN-PHX MAY 12>10[12]
WN DEN-SLC MAY 5>4[6]
WN DEN-TUL MAY 1.8>1.4[1.9]
WN DTW-MDW MAY 4>3[4]
WN DTW-STL APR 2>1.6[1.9] MAY 1.9>1.1[1.9]
WN ELP-SAT APR 2>1.5[1.9] MAY 2.0>1.0[1.9]
WN FLL-MCO MAY 3>2[4]
WN GEG-OAK MAY 1.1>0.8[1.8]
WN HOU-MSY MAY 9>8[10]
WN HOU-STL MAY 4>3[4]
WN HOU-TPA MAY 4>3[3]
WN IND-MCI MAY 1.5>1.1[1.7]
WN LAS-LAX MAY 10>9[9]
WN LAS-ONT MAY 5>4[4]
WN LAS-PHX MAY 11>10[10]
WN LAS-RNO MAY 10>9[10]
WN LAS-SAN MAY 10>9[11]
WN LAS-SJC MAY 11>10[10]
WN LAS-SLC MAY 4>3[5]
WN LAS-SMF MAY 9>8[8]
WN LAX-OAK MAY 12>11[11]
WN LAX-PHX MAY 8>7[8]
WN LAX-RNO MAY 3>1.8[3]
WN LAX-SFO MAY 6>5[9]
WN LAX-SJC MAY 10>9[10]
WN LAX-SMF MAY 8>7[8]
WN MCI-MDW MAY 7>6[7]
WN MDW-SDF MAY 3>2[4]
WN MDW-STL MAY 6>5[7]
WN MSP-STL APR 2>1.6[3] MAY 2>1.4[3]
WN MSY-STL APR 2>1.7[2] MAY 2>1.3[2.0]
WN OAK-ONT MAY 6>5[7]
WN OAK-RNO MAY 1.3>1.0[1.8]
WN OKC-STL APR 1.8>1.4[1.9] MAY 1.8>1.1[1.9]
WN OMA-STL MAY 3>2[3]
WN ONT-PHX MAY 6>5[6]
WN ONT-SFO MAY 3>1.8[0]
WN ONT-SJC MAY 5>4[5]
WN ONT-SMF MAY 7>6[6]
WN PDX-SJC MAY 5>4[5]
WN PDX-SMF MAY 5>4[4]
WN PHX-SAN MAY 11>10[10]
WN PHX-SLC MAY 6>5[5]
WN PHX-TPA MAY 0.9>0.5[1.0]
WN PIT-STL MAY 1.4>1.1[1.1]
WN RDU-TPA MAY 2.0>1.6[3]
WN SAN-SAT MAY 1.7>1.3[1.8]
WN SAN-SFO MAY 7>6[7]
WN SAN-SJC MAY 14>13[13]
WN SAN-SMF MAY 13>12[13]
WN SAT-STL APR 2>1.5[2] MAY 2>1.2[2]
WN SJC-SLC MAY 1.4>1.0[1.7]
WN SLC-STL APR 0.9>0.7[0] MAY 0.8>0.5[0]
WS ATL-YYC APR 1.0>0.3[1.0]
WS AZA-YYC APR 0.3>0.1[0.3]
WS BNA-YYC APR 0.3>0.1[0.3]
WS BNA-YYZ APR 1.0>0.4[0.9]
WS BOS-YYZ APR 2>0.6[3]
WS DEN-YYC APR 0.4>0.1[0.4]
WS FLL-YYZ APR 2>0.4[2]
WS HNL-YVR APR 2>0.5[1.9]
WS IAH-YYC APR 1.7>0.5[1.7]
WS JFK-YYC APR 0.9>0.3[0.9]
WS KOA-YVR APR 0.8>0.1[0.9]
WS LAS-YEG APR 0.6>0.2[0.6]
WS LAS-YQR APR 0.2>0.0[0.2]
WS LAS-YVR APR 1.8>0.5[2]
WS LAS-YWG APR 0.3>0.1[0.3]
WS LAS-YXE APR 0.2>0.0[0.2]
WS LAS-YYC APR 3>0.9[3]
WS LAS-YYZ APR 1.8>0.6[2]
WS LAX-YEG APR 0.9>0.3[1.0]
WS LAX-YVR APR 3>0.9[3]
WS LAX-YYC APR 2.0>0.6[2.0]
WS LAX-YYZ APR 1.1>0.4[1.1]
WS LGA-YYZ APR 7>2[7]
WS LIH-YVR APR 0.8>0.1[0.9]
WS MCO-YHZ APR 0.4>0.1[0.4]
WS MCO-YOW APR 0.4>0.1[0.4]
WS MCO-YWG APR 0.2>0.0[0.4]
WS MCO-YYC APR 0.8>0.1[0.8]
WS MCO-YYZ APR 2>0.7[3]
WS MIA-YYZ APR 0.8>0.1[0.9]
WS OGG-YVR APR 1.8>0.4[1.9]
WS OGG-YYC APR 0.6>0.1[0.9]
WS PDX-YYC APR 1.0>0.3[0.1]
WS PHX-YEG APR 1.1>0.3[1.4]
WS PHX-YQR APR 0.4>0.1[0.4]
WS PHX-YVR APR 0.9>0.2[0.9]
WS PHX-YWG APR 0.2>0.0[0.5]
WS PHX-YXE APR 0.4>0.1[0.4]
WS PHX-YYC APR 3>0.7[3]
WS PHX-YYZ APR 0.2>0[0.5]
WS PSP-YEG APR 0.8>0.1[0.9]
WS PSP-YVR APR 2.0>0.5[2]
WS PSP-YYC APR 3>0.7[3]
WS RSW-YYZ APR 1.4>0.4[1.3]
WS SAN-YYC APR 0.8>0.2[0.9]
WS SNA-YVR APR 1.0>0.3[0.9]
WS TPA-YYZ APR 1.0>0.2[1.1]
XL GYE-JFK APR 1.0>0.5[1.0]
Z3 AKN-IGG APR 0>0.4[0] MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.5[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0]
Reason: Clickbait title
enilria
Re: OAG Changes 3/22/2020: APOCALYPSE
Sun Mar 22, 2020 1:42 pm
Apocalypse: an event involving destruction or damage on an awesome or catastrophic scale.
catdaddy63
Sun Mar 22, 2020 1:55 pm
Thank you enilria for your usual hard work. Honestly, I thought the US domestic cuts would be deeper.
Nicknuzzii
Thanks again for this awesome thread. Does anyone have any idea what EK’s plan is for the rest of their US destinations? Are they just pulling out indefinitely?
tphuang
Sun Mar 22, 2020 1:58 pm
Good morning, thanks enilria.
Looks to me at least that AA/DL cuts are only minimally loaded up to this point. Not sure if they will just cancel last minute on these. UA's seems to have more of their announced cuts loaded.
AS's cuts look to match what their announced cuts for April at least. NK seems to have loaded everything too. WN looks mostly loaded. I think there will be more cuts still. My guess is B6 still has some Caribbean cuts that need to be loaded as other countries close their borders.
HA cuts will get deeper I think with the recent 14 day announcement.
Not sure how F9 is going to run most of their schedule. Kind of crazy to me.
jb1087xna
Sun Mar 22, 2020 2:02 pm
Thanks as always for the Sunday morning read!
Some of the seemingly little blinking that XNA has experienced so far. UA pulled SFO a few weeks back, but I wonder if that one is 100% virus related...I have my doubts, especially as it was pulled all the way through the fall.
AA still has a robust schedule to DFW in April at 9 daily, which is I think just 1 or 2 below their peak season schedule, though with no mainline included. DL pulled one of their 6 flights to ATL and down-gauged their morning mainline to a CR9 but that's about it...MSP and LGA remain and with their CR9s as always.
I'm assuming the big three want to have their options readily available once business traffic start to creep back, whenever that may be.
factsonly
Sun Mar 22, 2020 2:04 pm
EMIRATES suspends all passenger operations from 25 March 2020:
HH Sheikh Ahmed bin Saeed Al Maktoum, Chairman and Chief Executive of Emirates Group said: "As a global network airline, we find ourselves in a situation where we cannot viably operate passenger services until countries re-open their borders, and travel confidence returns. By Wednesday 25 March, although we will still operate cargo flights which remain busy, Emirates will have temporarily suspended all its passenger operations. We continue to watch the situation closely, and as soon as things allow, we will reinstate our services."
https://www.emirates.com/media-centre/t ... -covid-19/
rajincajun01
Sun Mar 22, 2020 2:05 pm
Interesting possible strategy at play for SEA. Gate allocation is based off of available seats. DL or AS could invest in flying empty planes to squeeze the other out of so many gates.
A319 A320 A321 A332 B1900 B717 B727 B737 B757 B767 B777 B787 CR2 CR7 CRJ9 E120 ERJ135 ERJ145 L1011 MD80 SF340 AvGeek Superstore
ChrisNH38
Sun Mar 22, 2020 2:06 pm
EK whacked SEA, too, but kept BOS at daily (kind of surprised at that). Draconian BA cuts on LHR-BOS as noted, but I thought the single daily would be on something bigger than a 772.
https://my.flightradar24.com/ChrisNH
jmscsc
Same here. I'll be curious to see what more comes in the weeks ahead. I flew DL twice in the last few weeks and there weren't any changes, though things were just starting, and I was on the DL Elite yesterday in regards to a trip in a little more than three weeks to BDL and was surprised that my DTW connection was upgauged to a 737-900 and they're still operating the same number of flights between those two cities.
I concur with so many every week ... thanks Enilria for your dedication and hard work. It's appreciated by so many and looked forward to every Sunday with my cup of coffee! Stay safe everyone.
Nicknuzzii
Sun Mar 22, 2020 2:12 pm
I was under the impression the LH group was temporarily consolidating to EWR not JFK.
CHOWahoo
Sun Mar 22, 2020 2:14 pm
I usually eagerly await these posts every Sunday, but this week's version just makes me sad. I honestly don't even have the morbid curiosity to go line by line to see routes that are going on hiatus and quite possibly never coming back.
Dominion301
Sun Mar 22, 2020 2:15 pm
Amazing how some of this is already outdated. For example UA announced they’re suspending all transborder ops for April as are WS.
iflykpdx
Sun Mar 22, 2020 2:18 pm
Looks like HU PEK-SJC might be finished. Down to two intercontinental flights assuming NH and BA return.
Airport Management - UND
DiamondFlyer
Sun Mar 22, 2020 2:23 pm
It just goes to show how quickly things are moving in the environment. I applaud enilria for even attempting it this week, I'm sure it's a ton of work
From my cold, dead hands
iyerhari
Sun Mar 22, 2020 2:28 pm
I just think there maybe hardly any demand based on future bookings and lack of spot bookings.
Enilrea - thank you for doing a fabulous job and great hard work. I just think a lot more cuts should be expected.
enilria
Sun Mar 22, 2020 2:33 pm
I'm sure this is not everything announced.
I believe they suspended all service to the USA in an announcement yesterday.
Is F9 really running everything? Perhaps with their non-daily schedule they can't really cut.
I'll keep doing it as long as I can and there are schedules to cut. LOL
I was kinda too sad to look at the details.
That means a lot. Thanks
TYSflyer
Sun Mar 22, 2020 2:36 pm
Thanks again for all that you do. I know we all knew that this was coming, but it is just brutal to see the magnitude of it. Some of these temporary suspensions on the longer routes to small markets may evolve into permanent cuts as the economy continues to slow. I think it will be also ominous when airports start reporting March and April traffic numbers just to see the year over year percent decline.
LAXdude1023
Sun Mar 22, 2020 2:43 pm
Watching something you love so dearly disintegrate right in front of you is incredibly painful.
Thanks for putting it together anyway Enilria.
FOR THE LOVE OF GOD BRING BACK THE PAYWALL!!!!
lavalampluva
Sun Mar 22, 2020 2:59 pm
A lot of the winter seasonal flights were going to be trimmed anyways, so those changes were expected.
Remind me to send a thank you note to Mr. Boeing.
jayunited
Sun Mar 22, 2020 3:04 pm
Thank you Enilria for the time and effort you put into doing this for us every Sunday. I know a few weeks ago I came at you pretty hard when I thought you were singling out UA unfairly. But just know I do appreciate all the effort and time you put into these threads every week.
These past two weeks reading the OAG thread have just been painful, and it doesn't matter what airline we work for, or which airline is our favorite airline, it is just painful to see the entire industry suffering like this.
enilria
Sun Mar 22, 2020 3:18 pm
I hear that right now we are down about 80% in terms of traffic.
Agreed. Thanks.
Thanks JayUnited. One thing we can all agree on is that we love this industry and seeing it attacked hurts all of us. If only we could retaliate against this virus like the airlines retaliate against each other, :)
Rdh3e
Sun Mar 22, 2020 3:19 pm
Perhaps their cash position is such that they cannot afford any refunds at this time and will just cancel day of?
djack
Sun Mar 22, 2020 3:25 pm
Thanks, Enilria for your weekly posts! Long time reader...I apparently have some time to actually post.
I received an email from Frontier offering a $50 additional credit if I cancel my reservation by Monday. Those credits will be good for bookings made by December 31, 2020, but you don't have to fly by that date. My guess is we'll see a big Frontier adjustment next weekend and this credit was their attempt to get people jump and cancel before they did a major schedule adjustment. The benefit for Frontier is they keep the money as opposed to issuing refunds for flight cancelations.
usflyer msp
Sun Mar 22, 2020 3:27 pm
I would not be surprised if one of the ULCC carriers just does a temporary shutdown soon. Leisure travel is basically non-existent right now and their customer base has been the most affected by the service industry essentially being decimated by social distancing and quarantines.
LCDFlight
Completely surreal!
AirFiero
Sun Mar 22, 2020 3:33 pm
Look at the other routes. All cancelled for the entire filed schedule. Is HU dead?
knope2001
Thanks as always for your efforts and willingness to share, enilria!
Quick count (weekday-ish) reduction in flights in those DL changes by hub/focus for April:
156 ATL
69 MSP
65 LGA
56 JFK
53 DTW
38 SLC
26 BOS
22 LAX
19 RDU
15 SEA
13 CVG
A few themes in the cuts:
--Huge majority are one or two frequency cuts
--Some of the highest-frequency shuttle-ish markets got notably bigger cuts such as NYC-BOS/WAS/CHI, LAX-SFO.
--Of fully-suspended markets the majority seem to be point-to-point or hub-overfly (like ALB-MSP)
--Between RDU and CVG, Raleigh saw more P2P routes fully suspended while CVG's primarily saw frequency cuts and fewer suspensions
Speaking of RDU they seemed to take it harder on the chin than pretty much any non-connecting hub this week. I come up with 30 fewer (weekday-approximate) departures in April and 11 markets suspended, though a few (such as BNA-RDU) have another carrier. At the moment May holds a handful more flight cuts and two more route suspensions. Makes you wonder if some big RDU traffic generators were hit especially hard compared to the general freefall we see everywhere, or if perhaps a lot of RDU buildup was about pushing marginal routes/frequencies in a fast-growing market aimed at future profitability.
FLL2go
Sun Mar 22, 2020 3:39 pm
I completely agree. There is at least another 25% reduction expected as well as extensions into May.
For example, there were no reductions to EYW from any carrier this time around. Announced just two days ago and effective today, the hotels are all shutdown in addition to the bars and restaurants.
These decisions for reduced capacity for this week's load were made before states and cities announced they were going to complete lockdown.
incitatus
Sun Mar 22, 2020 3:45 pm
There is still a lot of fiction published out there. Dallas-Houston on Southwest 17 x day? That is going to be a LOT of empty seats. Like Enilria said, a lot yet to come.
I have the impression that long-haul schedules are a lot easier to cut. The domestic schedule is more complicated to shred in part.
I do not consume Murdoch products including the Wall Street Journal
AirFiero
Sun Mar 22, 2020 3:46 pm
Same here. I’d be surprised if airlines fly much of what wasn’t cut, at least in April and maybe May.
ncflyer
Sun Mar 22, 2020 3:50 pm
It's really becoming clear to me that airlines can't cut flights fast enough from their schedule. These cuts just aren't close to what needs to happen. I'm noticing that in CLE UA is cancelling quite a few flights, maybe this is easier to do than loading new schedules.
MIflyer12
Sun Mar 22, 2020 3:53 pm
If they have it in the schedule they have to schedule crew. Crew that get scheduled get paid whether the flight goes or not. The DOT would not be impressed with terminating flights a month in advance and failing to notify customers.
MIflyer12
Sun Mar 22, 2020 3:58 pm
Thanks for the cut by hub count, and for the lucid observations. In total that's nowhere - nowhere - near the 70% systemwide cut they talked about on 3/18/20, even adjusting for gauge and stage length. There must be many more cuts to come.
Midwestindy
Since F9 is privately owned by Indigo, they won't publicly announce cuts most likely. Although a week or so ago they internally announced 10% capacity reductions for April, 20% for May, and now I'm hearing it has been revised to 70% cuts for May.
I'm assuming those will be loaded in either on Tuesday or Thursday
My immediate inclination is that, given RDU & ATL's proximity, they are going to drive as many connections through ATL as possible. Although given many of the RDU routes are on CR2s & CR7s, I'd imagine they'd lose a significant amount of money on some of the suspended routes, operating 2 flights a day with only a couple people per flight.
They are keeping RDU-BOS 6x daily which is bizarre to me other than the Pharma connections, considering RDU-LGA will only be 5x daily.
That SEA pettiness got to them, I'd be surprised if DL keeps the same launch date for Columbus & Dallas
Status for 2019/2020: AAdvantage Platinum, Delta Gold, Southwest A-List
727LOVER
Sun Mar 22, 2020 4:08 pm
Why did you remove it from the title? :lol:
"We must accept finite disappointment, but never lose infinite hope." - Martin Luther King, Jr.
iflykpdx
Sun Mar 22, 2020 4:16 pm
Only a couple were cut through OCT. Were the others seasonal to begin with?
ericm2031
Sun Mar 22, 2020 4:37 pm
I’m assuming we’ll see a bunch more still...especially from AA.
For UA I’ve noticed they’ve only loaded a lot of April cuts for just the 1st week so those aren’t even showing on here, so I’m sure once they extend those, it will look much worse. Just do a dummy booking the 1st week of April and you’ll get a glimpse.
TW870
Sun Mar 22, 2020 4:40 pm
Yep these cuts are already totally outdated. Right now the way it seems to be working - at least at DL - is that they are zeroing out a lot of flights so they can stop adding passengers to those flights, and then cancelling on an as needed basis in a 24-48 hour window before departure. My guess is they don't want to trim the schedule too aggressively right now, because doing so would overwhelm the app and the call centers when millions of people got cancelled flight messages. Overall, though, I am quite surprised how much actual flying there still is, especially when, as enilria said, the information we have is that most flights are completely empty. For today, for example, four of six DL MSP-LAX flights are operating, which is a giant amount of capacity between one place on partial lockdown and one place on total lockdown.
Enilria, thank you as always for putting this together. These threads have huge historic value despite how painful they are to read.
KFTG
Sun Mar 22, 2020 4:41 pm
Are AA and UA publishing their new cargo flights?
tphuang
Sun Mar 22, 2020 4:42 pm
156 ATL
69 MSP
65 LGA
56 JFK
53 DTW
38 SLC
26 BOS
22 LAX
19 RDU
15 SEA
13 CVG
Thanks for tallying this up. This is more like a 15% cut that they initially announced vs the more recent 70% cuts. Once those cuts are made for April and May, that will be interesting to look at.
chonetsao
Sun Mar 22, 2020 4:44 pm
Looks like LH and VS are keeping a lot of routes than other airlines. Is there that much of demand? Or they will run the flight empty with cargo only?
HVNandrew
Sun Mar 22, 2020 5:02 pm
156 ATL
69 MSP
65 LGA
56 JFK
53 DTW
38 SLC
26 BOS
22 LAX
19 RDU
15 SEA
13 CVG
To your point, a lot of the reductions are 1-2x frequency cuts. For RDU, that means a lot of markets are cut, as many are only served 1-2x per day. I made this point in the DL coming out as a smaller carrier thread. The Shuttle markets must be especially bad; they're 2/3 frequency cuts. I'm not sure any of those cuts will ever be fully restored. The Shuttle-type service might be hard for anyone to sustain going forward.
drdisque
Sun Mar 22, 2020 5:15 pm
Notable is that as far as I can tell, none of the US4 are closing a single domestic year-round station completely (at least through this update).
It is a shame for example, for a route like SFO-DTW that UA tried really hard for 5 years to make work for all the work and progress to be flushed down the toilet, but that's how it goes in this industry. The route was dependent on connections to Asia and Australia and never captured much of the local market.
Likewise for routes that just launched and haven't really gotten a chance to develop.
I wonder not cutting any domestic stations is part of their backroom dealings for a bailout.
jco613
Sun Mar 22, 2020 5:35 pm
I think this is a great point. Remember, Walmart runs XNA and Walmart is one of the few businesses actually doing fairly well right now (hiring over 1,000 temp workers during this). I think cities like XNA, RDU, CVG, CLE and similar will see their demand rebound faster than other markets. I also think we'll see some typically seasonal tourist destinations (Domestically) get a boost in their offseason once this is done. Near distance vacations and some business travel will be the first to recover. We all need a vacation after this!
But honestly, these are just guesses. Nobody knows, but if you assume what I said to be true, you have to maintain your presence to be ready for the demand. RDU and similar cities you can reroute traffic as demand escalates, but XNA with it's already limited service, needs to maintain close to current levels.
umichman
Sun Mar 22, 2020 5:45 pm
CVG April cuts have not yet been fully reflected in schedule. CVG-STL and CVG-MCI have been cut for April (all flights zero'd out April 2 - May 2), but are still showing in schedule. CVG-BDL cut made this schedule change.
admanager
Sun Mar 22, 2020 5:55 pm
Thanks Enilria - I'm pleasantly surprised it was posted as soon as it was given the number of changes.
What's as intriguing as what was posted, is what wasn't. A couple examples.
PAE had no cuts.
SEA - CHS on AS wasn't cut, Thursday I was on that flight and there were 20 passengers.
CHS shows 4 cuts (1 by DL on each of ATL, DTW, JFK) and the BA flight.
It's going to get worse.
Next week's title...Hold my beer and watch this.
tphuang
Sun Mar 22, 2020 6:03 pm
It does make me wonder what's taking AA/DL this long to make their cuts. They are probably 1/4 or less through the cuts that they said they are making for April. Is it just a matter of different factions inside the company making pleas to not cut them? Seems like the LCCs have more or less made all their cuts already (aside from F9/G4) aside from possible future international closures.
incitatus
Sun Mar 22, 2020 6:22 pm
China Southern is planning the resumption of WUH-JFK in April....????? There is no way Wuhan is going to let in passengers from New York. The City is headed to a worse situation than Wuhan ever had.
FSDan
Sun Mar 22, 2020 6:25 pm
Looks like there are a few permanent cuts (cut through August or into Fall/Winter) mixed into the April/May carnage.
UA LAX-SGU
UA DEN-FAI? (summer seasonal, cut for summer)
UA EWR-HHH? (summer seasonal, cut for summer)
AD JFK-VCP
VS EWR-LHR
RJ JFK-AMM
HU SJC-PEK
HU ORD-PEK
This is my signature until I think of a better one.
