ryanflyer
China Eastern A330 Combi
Tue Mar 24, 2020 12:59 pm
While I was under impression that something like this would take a recertification, China Eastern has Removed seats on one of their A330 aircraft to put it into a 42Y and All J seating, with the rest of the space for cargo. Does anyone have any other insight into this, and or the regulations behind it?
https://twitter.com/ChinaAvReview/statu ... 43840?s=20
Francoflier
Re: China Eastern A330 Combi
Tue Mar 24, 2020 1:09 pm
They are only removing seats in order to transport cargo pallets on the main deck, without passengers.
They are basically using pax airplanes as cargo airplanes, as several airlines around Asia are doing in a time all passengers are grounded, but finding ways to put some cargo on the main deck as well instead of just using the holds.
This is temporary, and not a combi conversion.
As for the crash wall that is supposed to protect the flight deck in proper cargo airplanes, I suspect they may have had a temporary exemption from the CAAC as long as the cargo is light and not dense (surgical masks in this case), and some rows of seats are left fwd of the cargo to absorb any potential impact... or something of the sort.
Pretty smart way of using your otherwise useless aircraft in a time of crisis if you ask me.
SwissCanuck
Tue Mar 24, 2020 1:24 pm
How do pallets fit through the main deck door?
Momo1435
Tue Mar 24, 2020 1:28 pm
They will have to bulk load the maindeck as it doesn't have a cargo door that would fit a pallet, but that should not be a big issue. This is much more volume them putting boxes on the seats as has been done many times this last week.
Francoflier
Tue Mar 24, 2020 1:55 pm
I meant small, common pallets (made out of wood or plastic), on which the cargo is stacked, not proper aviation cargo pallets.
I'm guessing they put nets on them and tie everything up to the seat rails.
raylee67
Tue Mar 24, 2020 3:17 pm
The tweet says "...to transport medical supplies during #COVID19 outbreak..."
So this is not an ordinary civilian flight. I would think that for emergency use, anything goes, as long as the plane can lift off and stay in the air.
For example, El Al has flown a 747 with 1,122 passengers on board on an evacuation flight from Addis Ababa back in 1991. Surely "illegal" under any regulation.
319/20/21 332/33 342/43/45 359/51 388 707 717 732/36/3G/38/39 74R/42/43/44/4E/48 757 762/63 772/7L/73/7W 788/89 D10 M80 135/40/45 175/90 DH1/4 CRJ/R7 L10
AY LH OU SR BA FI
AA DL UA NW AC CP WS FL NK PD
CI NH SQ KA CX JL BR OZ TG KE CA CZ NZ JQ RS
trex8
Tue Mar 24, 2020 3:25 pm
Some DC10 operators , LH, have several luggage containers they could stash in the back of the cabin which only fit through the regular doors?
I would think a lot of other Far East carriers with big cargo ops may start doing similar to MU or as OS did wth the cargo in the seats, eg CX, CI, KE
from previous thread DC10/baggage containers
http://www.historyofpia.com/forums/view ... 7&start=15
viewtopic.php?t=567039
IWMBH
Tue Mar 24, 2020 3:41 pm
The photo of the DC-10 was taken before the SAA crash. You can’t do that anymore, at least not with passengers on board. But, as mentioned above for most carriers that’s not an issue because there are no passengers willing to fly these days.
SwissCanuck
Wed Mar 25, 2020 7:21 pm
A standard pallet still wouldn't fit. I'm guessing you'd have to go down to a half-europallet.
A388
Wed Mar 25, 2020 8:50 pm
The term A330 Combi in such cases is misleading. This is no combi aircraft in any sense of the word. It's still a passenger aircraft. The only difference being that some seats have been removed in order to carry smaller sized cargo being loaded on this main deck where the seats have been removed. Nothing else. There is no strengthened main deck floor, no main deck cargo door and only specific types of cargo can be loaded on to this "cargo main deck". No re-certification is needed as this is only permitted as an exception due to the Covid-19 crisis.
A388
trex8
Wed Mar 25, 2020 10:37 pm
Can CAAC "approve" MU or other Chinese carriers doing this "permanently" and will eg EASE/FAA allow these planes to operate routinely into their jurisdictions?
alasizon
Thu Mar 26, 2020 3:23 am
As long as the cargo is restrained and the resulting load from an accident less than the max G load of the seats it would be crashing into, I see no reason why CAAC wouldn't allow this on a temporary basis.
That being said, I suspect the cargo is free loaded onto a pallet inside the aircraft and then secured which would be a pain.
andrej
Thu Mar 26, 2020 4:26 am
For all curious minds, this A330 is being offloaded in Prague.
All credit to: Dan Materna, MAFRA
VSMUT
Thu Mar 26, 2020 4:57 am
I've done this sort of cargo flying, in Europe of all places. Really rare, but not illegal. There were strict rules on not placing dangerous goods there, only non-flammable stuff. In practice you would place a piece of plywood down to distribute the weight, then stack the boxes on top, finally strapping it down with a net and straps to the seat rails. Loading and offloading required lots of manual work carrying boxes and cases through the aisle.
Air Greenland often puts mail sacks in the passenger seats.
LAX772LR
Thu Mar 26, 2020 6:49 am
Can they? Well, they're the authority for what goes on in Chinese aviation, so not sure what would stop them.
FAA has made it more than clear that they won't be approving same-deck combis without a fixed bulkhead; so the likelihood of them allowing such in US operations, in all but the most inconceivable circumstances (which I doubt even this qualifies as), is slim to none.
kelval
Thu Mar 26, 2020 8:09 am
I doubt there would be any interest in making this permanent anyways.
This is a crisis relief solution, not an efficient one.
tvh
Thu Mar 26, 2020 8:57 am
They should use catering trucks to load and unload, plenty unused for the moment.
tcas69
Thu Mar 26, 2020 9:10 am
This is the temporary solution on an Austrian 777 Xiamen Vienna
around 4 of their fleet in shuttle mode Penang, Xiamen Shanghai bringing coronaequipment to Austria and Italy
www.austrianwings.info/fileadmin/aw/202 ... to_ZVG.jpg
Gemuser
Thu Mar 26, 2020 11:10 am
If the FAA did not allow such converted aircraft registered in China & operated by Chinese airlines into US airspace they would be vilolating the ICAO conventions and inviting retaliations. If the Chinese pushed it IMHO the FAA would turn a blind eye lest they find that B787s are not allowed in Chinese airspace, much like they did to the BA 3 engined B747 flight from near LAX to the UK.
Actually it won't come to that it will be worked out diplomatically, if it even arises.
Gemuser
LAX772LR
Thu Mar 26, 2020 2:35 pm
What specific provision requires reciprocal approval of a foreign design/configuration deemed by a civil authority to be unsafe?
trex8
Thu Mar 26, 2020 7:14 pm
Having pax/cargo at the same time on main deck in a 'combi" configuration without certifiable barrier will certainly not be ok, but having only cargo and crew on main deck and no pax on a "pax" plane might be ok?
Anyone know what the rules are for crew (flight/loadmasters) and main deck cargo on freighters? Is there a need for some fire/smoke barrier? I know most freighters do have something.
Gemuser
Fri Mar 27, 2020 6:45 am
If you read the convention AND the documents on the ICAO web site ALL members of ICAO are required to accept the certifications of all other members, unless that certification does not comply with ICAO rules, for aircraft and airlines registered in that country That is the whole basis of intenational civil aviation. There are specified exemption which require specific approval.
So UNLESS the fixed barrier is an ICAO requirement [which it could be IDK but I've never seen it referred to as such but it could be] then banning an aircraft which complies with ICAO rules would be a violation of the convention.
As I said in the previous post, IF it becomes an issue the diplomats will sort it out.I am pretty sure that your State Depart is the relevent USA authority for treaty compliance matters as is our DFAT in Australia.
Gemuser
LAX772LR
Fri Mar 27, 2020 8:38 am
You're taking way too generalist of an approach.
I'll stand corrected if you can show otherwise, but there's no ICAO provision that would force a CAA with preexisting statutory prohibitions (14 CRF 25; sections 25.851, 25.855, 25.857) against a design or configuration, on the basis of safety, resulting from TSB recommendations due to a mass-fatality; into complying with a subsequent unilateral approval of that same design or config., with no exemption. It's not even implicit.
Yes, I'm aware that diplomats on both sides would likely try to talk sense into the approving party; but still the concept above remains.
Gemuser
Fri Mar 27, 2020 11:34 am
My training in the area IS old, but I doubt the basics have changed much since then.
Gemuser
mxaxai
Fri Mar 27, 2020 11:55 am
Gemuser
Wasn't the 737max banned from many countries' airspace unilaterally? I agree that usually countries accept each others' certifications and if you look at, for example, EASA regulations those explicitly only apply to aircraft registered in an EASA member state. Nevertheless, countries can and sometimes do close their airspace to certain foreign registered aircraft. Other examples would be the EU and FAA prohibiting some carriers from entering, or countries demanding that certain equipment (like ADS-B) be installed.
tomcat
Fri Mar 27, 2020 6:08 pm
Or install a sheet of plywood over the stairs so that they can slide the boxes downstairs. This would only require to install a padded reception area to avoid damaging the boxes at the bottom of the slide. The a baggage loader unit could transfer the boxes from the reception area to the truck.
zkojq
Sat Mar 28, 2020 7:15 pm
Airbus A330-200MRTT carrying supplies from Tianjin to Getafe:
First to fly the 787-9
WayexTDI
Sun Mar 29, 2020 2:19 am
Which country was that MRTT from?
zkojq
Sun Mar 29, 2020 5:27 am
Good question - I'm not sure. It's one which is yet to be delivered to it's customer. Still painted in the yellow primer. It has Rolls Royce engines if that's any help.
https://twitter.com/Airbus/status/12438 ... 17920?s=19
Francoflier
Sun Mar 29, 2020 7:12 am
Airbus has also sent the A330-800 prototype to Tianjin to bring medical supplies back to Europe:
