720B
Thai Airways Airbus A350 was involved in a serious landing incident
Mon Mar 30, 2020 5:54 pm
As per Sam Chui's website, A Thai Airways Airbus A350 was involved in a serious landing incident, on January 1st 2020; which involved the aircraft descending below 670 feet, whilst still nearly 6.5 nautical miles from the airport.
https://samchui.com/2020/03/30/thai-air ... oIx9YhKiUl
ATCtower
Re: Thai Airways Airbus A350 was involved in a serious landing incident
Mon Mar 30, 2020 6:18 pm
Reading the link that sure sounds scary as hell!
Equally scary, a captain of a wide body aircraft with only 400 hours in the type???
By reading the above post you waive all rights to be offended. If you do not like what you read, forget it.
Weatherwatcher1
Mon Mar 30, 2020 6:21 pm
Unstable approaches are nothing new in aviation, but certainly worth investigating. I’m curious how the navigation system was performing. Hopefully the investigation will tell us what led to the approach so we don’t end up with another Alitalia 404 or Asiana 214
https://en.m.wikipedia.org/wiki/Alitalia_Flight_404
https://en.m.wikipedia.org/wiki/Asiana_ ... Flight_214
sailsail
Mon Mar 30, 2020 6:23 pm
It’s a newish aircraft to the fleet and the world for that matter. There are going to be captains with low hours, also they don’t have to be a first officer for years in the type before becoming captain. He/she could have been a captain on something else and then upgraded. I don’t know the carrier specifics but generally you have check pilots sitting in FOs spot and higher qualified FO’s until some predetermine time that the captain is ready. Again it changes by carrier. There are other rules as well till they obtain enough hours in the left seat.
Weatherwatcher1
That’s not unusual for such a new airplane like the A350. It’s not like Thai Airways captains can get easily get hours On a type of plane that the airline doesn’t fly
VSMUT
You have to start somewhere. "Only" 400 hours on the A350 could still mean he holds 10.000 hours on the A380 or A330.
SEPilot
Mon Mar 30, 2020 6:41 pm
When an airline gets a new type every single pilot, including the one flying the first revenue flight, will have 0 to low double digit hours in the type (there will be some training flights, but most will be in simulators). You have to start somewhere. And due to the similarities and common type ratings with other Airbus planes, it really isn’t relevant if the pilot has experience in others. Flying an unstabilized approach has nothing to do with being unfamiliar with the aircraft type; there is something else wrong.
TaromA380
Mon Mar 30, 2020 8:24 pm
The Airbus envelope protection should have avoided any real danger, or not, in this case ?
zkojq
Mon Mar 30, 2020 8:41 pm
Sounds like a false glideslope, no?
Airbus' flight envelope protection system is perfectly happy for you to fly into terrain - so long as you're not about to stall or overspeed whilst doing so. ;)
First to fly the 787-9
WayexTDI
Mon Mar 30, 2020 9:03 pm
I guess Germanwings 9525 is a perfect example of that.
LDRA
Mon Mar 30, 2020 9:16 pm
prebennorholm
Tue Mar 31, 2020 2:16 am
This incident has nothing with aircraft type to do. And both flight crew members had thousands of hours. Even if any zero hours pilot should be crucified for doing this mistake.
It looks like they did a slam dunk approach, and both crews happened to fall asleep in the process. The GPWS saved the day, as it was designed to do.
Further details in the BFU report early next year or so.
They had a medical emergency in the cabin. The reason for mentioning that could be to make us readers guess that the reason for the non-standard approach was some priority granted by the tower due to the medical. The BFU of course never provides anything with a smell of guesswork in a preliminary report. Facts only. But facts (and rumors) are the building blocks of every guess.
ATCtower
Tue Mar 31, 2020 2:59 am
I obviously stand corrected about hour accumulation.
Still seems odd that a FO would have significantly more hours in the type than a captain.
I know the promotion to captain is more than hours and is often politics but I’m not sure how I would feel trusting my life to the ultimate decision maker when they’re still so fresh to the plane they certainly couldn’t understand it all.
I guess to me it’s akin to a controller who may have been certified at 6 different facilities on their first day without a trainer at their new facility. Sure, they can probably get the job done but damn it just seems like introducing risk.
BenTheGreat97
Tue Mar 31, 2020 3:26 am
Example:
First officer on the a330 has 2,500 hours and instead of waiting a few years and a few thousand more hours, bids for an FO spot on the a350 and gets it. Flies for a while and acumulates 1,500 hours on type.
Captain on the a330 has 7,600 hours total, has been captain for probably several years now and has an opportunity to bid captain on the a350. He gets it. Since Airbus planes are all pretty similar to one another, the things he's responsible for as captain don't really change, he just has to know the new computer systems, speeds and limitations on the a350 for the most part.
I highly doubt this had any bearing on the incident whatsoever.
KFTG
Tue Mar 31, 2020 3:36 am
This is nonsensical and has nothing to do with reality and is brought up every time there is an incident or accident. How else are pilots supposed to get experience in the seat without experience in the seat? While we're on the subject, how many hours did the Asiana pilots have before they flew the jet into the sea wall? The quality of training is more important than the quantity of the training.
N47
Tue Mar 31, 2020 3:52 am
Thats a good guess. I would say thats unlikely since false glideslopes tend to produce glide path angles higher than 3 and usually multiples of 3 degrees such as 6 depending on the glideslope type. The most issue is the null reference type of glide slope. TK6491 IIRC was the one caused by a false GS. Maybe GS or ILS were out of service at the time, similar to what happened in the asiana 214 case.
conaly
Tue Mar 31, 2020 6:45 am
There has been a thread already: viewtopic.php?f=3&t=1439109&p=21937017#p21936933
Airports 2019: ADB, ALG, AMD, ATL, BOG, BOS, CDG, CTS, DEL, DTW, DUS, EWR, FRA, FUK, HAM, HFT, HIJ, HND, HVG, IST, ITM, JFK, MUC, NGO, NUE, OKA, PHL, SIN, STN, TOS, YYZ, ZRH
Airports 2020: ALG, CTS, FRA, HKG, HND, MSQ, MUC, NUE, TLV, ZRH
B777LRF
Tue Mar 31, 2020 7:11 am
Perhaps the crew were not alert to the degree one would prefer, but the root cause of the incident seems to be ATC vectoring an aircraft to intercept the glide slope from above. Not the first time it's caused in an incident in FRA (and elsewhere) and I, for one, trust the BFU will not go for the easy option and throw the crew under the bus, but rather investigate why FRA ATC has a tendency to vector aircraft in ways that may lead to an incident such as this. Once all of the root causes have been established, develop mitigating actions to reduce or eliminate the risk of reoccurrence.
PS
It's not a landing incident, as the aircraft never came close to making contact with the runway. It's a final approach incident.
Signature. You just read one.
