enilria
OAG Changes 4/5/2020: Jaw-Dropping
Sun Apr 05, 2020 11:48 am
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
This seems bad. Is it true?
7H ABL-OBU MAY 0.5>0[0.5] JUN 0.5>0[0.5] JUL 0.5>0[0.5] AUG 0.5>0[0.5] SEP 0.5>0[0.5] OCT 0.5>0[0.5] NOV 0.5>0[0.5] DEC 0.5>0[0.5] JAN 0.5>0[0.5]
7H ABL-OTZ MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H ABL-SHG MAY 0.4>0[0.4] JUN 0.4>0[0.4] JUL 0.4>0[0.4] AUG 0.4>0[0.4] SEP 0.4>0[0.4] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
7H ADQ-ANC MAY 3>2[2]
7H AIN-ATK MAY 0.3>0[0.9] JUN 0.3>0[1.3] JUL 0.3>0[1.3] AUG 0.3>0[1.4] SEP 0.3>0[1.3] OCT 0.3>0[0.9] NOV 0.2>0[0.3] DEC 0.3>0[0.3] JAN 0.3>0[0.3]
7H AIN-BRW MAY 2>0[1.7] JUN 2>0[1.3] JUL 2>0[1.3] AUG 2>0[1.4] SEP 2>0[1.3] OCT 2>0[1.8] NOV 2>0[2] DEC 2>0[2] JAN 2>0[2]
7H AKI-KKI MAY 1.4>0[1.5] JUN 1.4>0[1.5] JUL 1.4>0[1.4] AUG 1.4>0[1.5] SEP 1.4>0[1.5] OCT 1.4>0[1.5] NOV 1.4>0[1.5] DEC 1.4>0[1.5] JAN 1.4>0[1.5]
7H AKI-TLT MAY 1.4>0[1.5] JUN 1.4>0[1.5] JUL 1.4>0[1.4] AUG 1.4>0[1.5] SEP 1.4>0[1.5] OCT 1.4>0[1.5] NOV 1.4>0[1.5] DEC 1.4>0[1.5] JAN 1.4>0[1.5]
7H AKN-ANC MAY 2.0>1.3[0.2]
7H ANC-ANI MAY 1.0>0.5[1.0]
7H ANC-DLG MAY 2.0>1.3[0.7]
7H ANC-DUT MAY 1.7>1.3[0] JUN 3>1.3[0]
7H ANC-ENA MAY 9>6[9]
7H ANC-HOM MAY 4>3[4]
7H ANC-KSM MAY 1.0>0.7[1.0]
7H ANC-OTZ MAY 0.5>0.2[0.5]
7H ANC-UNK MAY 1.0>0.7[1.0]
7H ANI-CHU MAY 0.4>0[0.7] JUN 0.4>0[0.4] JUL 0.4>0[0.4] AUG 0.4>0[0.4] SEP 0.4>0[0.4] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
7H ANI-HCR MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[0.9] OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0]
7H ANI-KLG MAY 3>0[3] JUN 3>0[3] JUL 3>0[3] AUG 3>0[3] SEP 3>0[2] OCT 3>0[3] NOV 3>0[3] DEC 3>0[3] JAN 3>0[3]
7H ANI-MCG MAY 0>0.3[0]
7H ANI-RSH MAY 0.8>0[0.8] JUN 0.9>0[0.8] JUL 0.8>0[0.8] AUG 0.8>0[0.9] SEP 0.8>0[0.7] OCT 0.9>0[0.9] NOV 0.8>0[0.8] DEC 0.8>0[0.8] JAN 0.8>0[0.8]
7H ANI-SHX MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[0.9] OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0]
7H ANI-SRV MAY 0.4>0[0.4] JUN 0.4>0[0.4] JUL 0.4>0[0.4] AUG 0.4>0[0.4] SEP 0.4>0[0.4] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
7H ANV-HCR MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[0.9] OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0]
7H ANV-KGX MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[0.9] OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0]
7H ATK-BRW MAY 2>0[1.7] JUN 2>0[1.3] JUL 2>0[1.3] AUG 2>0[1.4] SEP 2>0[1.3] OCT 2>0[1.8] NOV 2>0[2] DEC 2>0[2] JAN 2>0[2]
7H ATT-BET MAY 1.4>0[1.4] JUN 1.4>0[1.4] JUL 1.4>0[1.4] AUG 1.4>0[1.4] SEP 1.4>0[1.4] OCT 1.4>0[1.4] NOV 1.4>0[1.4] DEC 1.4>0[1.4] JAN 1.4>0[1.4]
7H ATT-NUP MAY 1.4>0[1.4] JUN 1.4>0[1.4] JUL 1.4>0[1.4] AUG 1.4>0[1.4] SEP 1.4>0[1.4] OCT 1.4>0[1.4] NOV 1.4>0[1.4] DEC 1.4>0[1.4] JAN 1.4>0[1.4]
7H AUK-EMK MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H AUK-SXP MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H BET-CYF MAY 1.8>0[1.8] JUN 1.9>0[1.8] JUL 1.8>0[1.8] AUG 1.8>0[1.9] SEP 1.8>0[1.8] OCT 1.9>0[1.9] NOV 1.8>0[1.8] DEC 1.8>0[1.8] JAN 1.8>0[1.8]
7H BET-EEK MAY 1.8>0[0.4] JUN 1.9>0[0.4] JUL 1.8>0[0.4] AUG 1.8>0[0.4] SEP 1.8>0[0.4] OCT 1.9>0[0.4] NOV 1.8>0[0.4] DEC 1.8>0[0.4] JAN 1.8>0[0.4]
7H BET-HPB MAY 0.5>0[0.5] JUN 0.5>0[0.5] JUL 0.5>0[0.5] AUG 0.5>0[0.5] SEP 0.5>0[0.5] OCT 0.5>0[0.5] NOV 0.5>0[0.5] DEC 0.5>0[0.5] JAN 0.5>0[0.5]
7H BET-KKH MAY 1.4>0[1.4] JUN 1.4>0[1.4] JUL 1.4>0[1.4] AUG 1.4>0[1.4] SEP 1.4>0[1.4] OCT 1.4>0[1.4] NOV 1.4>0[1.4] DEC 1.4>0[1.4] JAN 1.4>0[1.4]
7H BET-KLG MAY 1.9>0[1.8] JUN 2>0[1.8] JUL 1.9>0[1.8] AUG 2>0[1.9] SEP 1.9>0[1.7] OCT 2>0[1.9] NOV 1.9>0[1.8] DEC 1.9>0[1.8] JAN 1.9>0[1.8]
7H BET-KPN MAY 1.8>0[1.8] JUN 1.9>0[1.8] JUL 1.8>0[1.8] AUG 1.8>0[1.9] SEP 1.8>0[1.8] OCT 1.9>0[1.9] NOV 1.8>0[1.8] DEC 1.8>0[1.8] JAN 1.8>0[1.8]
7H BET-KUK MAY 1.4>0[1.4] JUN 1.4>0[1.4] JUL 1.4>0[1.4] AUG 1.4>0[1.4] SEP 1.4>0[1.4] OCT 1.4>0[1.4] NOV 1.4>0[1.4] DEC 1.4>0[1.4] JAN 1.4>0[1.4]
7H BET-KWK MAY 1.4>0[1.4] JUN 1.4>0[1.4] JUL 1.4>0[1.4] AUG 1.4>0[1.4] SEP 1.4>0[1.4] OCT 1.4>0[1.4] NOV 1.4>0[1.4] DEC 1.4>0[1.4] JAN 1.4>0[1.4]
7H BET-KWN MAY 1.8>0[1.8] JUN 1.9>0[1.8] JUL 1.8>0[1.8] AUG 1.8>0[1.9] SEP 1.8>0[1.8] OCT 1.9>0[1.9] NOV 1.8>0[1.8] DEC 1.8>0[1.8] JAN 1.8>0[1.8]
7H BET-KWT MAY 1.4>0[1.5] JUN 1.4>0[1.5] JUL 1.4>0[1.4] AUG 1.4>0[1.5] SEP 1.4>0[1.5] OCT 1.4>0[1.5] NOV 1.4>0[1.5] DEC 1.4>0[1.5] JAN 1.4>0[1.5]
7H BET-MLL MAY 1.4>0[1.4] JUN 1.4>0[1.4] JUL 1.4>0[1.4] AUG 1.4>0[1.4] SEP 1.4>0[1.4] OCT 1.4>0[1.4] NOV 1.4>0[1.4] DEC 1.4>0[1.4] JAN 1.4>0[1.4]
7H BET-MYU MAY 0.9>0[0] JUN 0.9>0[0] JUL 0.9>0[0] AUG 0.9>0[0] SEP 0.9>0[0] OCT 0.9>0[0] NOV 0.9>0[0] DEC 0.9>0[0] JAN 0.9>0[0]
7H BET-NME MAY 1.5>0[1.4] JUN 1.5>0[1.4] JUL 1.5>0[0.9] AUG 1.5>0[1.4] SEP 1.5>0[1.4] OCT 1.5>0[1.4] NOV 1.5>0[1.4] DEC 1.5>0[1.4] JAN 1.5>0[1.4]
7H BET-OOK MAY 0.9>0[0] JUN 0.9>0[0] JUL 0.9>0[0] AUG 0.9>0[0] SEP 0.9>0[0] OCT 0.9>0[0] NOV 0.9>0[0] DEC 0.9>0[0] JAN 0.9>0[0]
7H BET-PQS MAY 1.8>0[1.8] JUN 1.9>0[1.8] JUL 1.8>0[1.8] AUG 1.8>0[1.9] SEP 1.8>0[1.8] OCT 1.9>0[1.9] NOV 1.8>0[1.8] DEC 1.8>0[1.8] JAN 1.8>0[1.8]
7H BET-RSH MAY 1.4>0[1.4] JUN 1.4>0[1.4] JUL 1.4>0[1.4] AUG 1.4>0[1.4] SEP 1.4>0[1.4] OCT 1.4>0[1.4] NOV 1.4>0[1.4] DEC 1.4>0[1.4] JAN 1.4>0[1.4]
7H BET-SCM MAY 1.4>0[1.4] JUN 1.4>0[1.4] JUL 1.4>0[1.4] AUG 1.4>0[1.4] SEP 1.4>0[1.4] OCT 1.4>0[1.4] NOV 1.4>0[1.4] DEC 1.4>0[1.4] JAN 1.4>0[1.4]
7H BET-TLT MAY 1.4>0[1.5] JUN 1.4>0[1.5] JUL 1.4>0[1.4] AUG 1.4>0[1.5] SEP 1.4>0[1.5] OCT 1.4>0[1.5] NOV 1.4>0[1.5] DEC 1.4>0[1.5] JAN 1.4>0[1.5]
7H BET-TNK MAY 1.5>0[1.4] JUN 1.5>0[1.4] JUL 1.5>0[0.9] AUG 1.5>0[1.4] SEP 1.5>0[1.4] OCT 1.5>0[1.4] NOV 1.5>0[1.4] DEC 1.5>0[1.4] JAN 1.5>0[1.4]
7H BET-VAK MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H BET-WTL MAY 3>0[1.4] JUN 3>0[1.4] JUL 3>0[1.4] AUG 3>0[1.4] SEP 3>0[1.4] OCT 3>0[1.4] NOV 3>0[1.4] DEC 3>0[1.4] JAN 3>0[1.4]
7H BKC-DRG MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H BKC-OTZ MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H BRW-NUI MAY 1.0>0[1.4] JUN 1.4>0[1.3] JUL 1.4>0[1.4] AUG 1.4>0[1.4] SEP 1.4>0[1.4] OCT 1.4>0[1.4] NOV 1.4>0[1.4] DEC 1.4>0[1.4] JAN 1.4>0[1.4]
7H BRW-PIZ MAY 1.8>0[1.6] JUN 1.9>0[1.6] JUL 1.8>0[1.6] AUG 1.8>0[1.7] SEP 1.8>0[1.6] OCT 1.9>0[1.7] NOV 1.8>0[1.9] DEC 1.8>0[1.8] JAN 1.8>0[1.7]
7H BTI-FAI MAY 0.6>0[0.1] JUN 0.7>0[0.1] JUL 0.7>0[0.1] AUG 0.7>0[0.3] SEP 0.7>0[0.8] OCT 0.7>0[0.8] NOV 0.7>0[0.7] DEC 0.7>0[0.7] JAN 0.6>0[0.7]
7H BTI-SCC MAY 0.8>0[0.8] JUN 1.2>0[0.8] JUL 1.2>0[0.8] AUG 1.1>0[1.0] SEP 1.1>0[1.6] OCT 1.1>0[1.0] NOV 1.1>0[1.1] DEC 1.2>0[1.1] JAN 1.1>0[1.1]
7H CHU-CKD MAY 0.4>0[0.7] JUN 0.4>0[0.4] JUL 0.4>0[0.4] AUG 0.4>0[0.4] SEP 0.4>0[0.4] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
7H CKD-RDV MAY 0.4>0[0.4] JUN 0.4>0[0.4] JUL 0.4>0[0.4] AUG 0.4>0[0.4] SEP 0.4>0[0.4] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
7H CYF-KPN MAY 1.8>0[1.8] JUN 1.9>0[1.8] JUL 1.8>0[1.8] AUG 1.8>0[1.9] SEP 1.8>0[1.8] OCT 1.9>0[1.9] NOV 1.8>0[1.8] DEC 1.8>0[1.8] JAN 1.8>0[1.8]
7H DRG-OTZ MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H EEK-KWN MAY 1.8>0[1.8] JUN 1.9>0[1.8] JUL 1.8>0[1.8] AUG 1.8>0[1.9] SEP 1.8>0[1.8] OCT 1.9>0[1.9] NOV 1.8>0[1.8] DEC 1.8>0[1.8] JAN 1.8>0[1.8]
7H ELI-GLV MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H ELI-OME MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H EMK-KOT MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H FAI-GAL MAY 1.9>0[1.9] JUN 2>0[2] JUL 1.9>0[1.9] AUG 2>0[2] SEP 1.9>0[1.9] OCT 2>0[2] NOV 1.9>0[1.9] DEC 1.9>0[1.9] JAN 1.9>0[1.9]
7H FAI-RBY MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0]
7H FAI-SCC MAY 0.4>0.1[0.4]
7H GAL-HSL MAY 0.5>0[0.5] JUN 0.5>0[0.5] JUL 0.5>0[0.5] AUG 0.5>0[0.5] SEP 0.5>0[0.5] OCT 0.5>0[0.5] NOV 0.5>0[0.5] DEC 0.5>0[0.5] JAN 0.5>0[0.5]
7H GAL-KAL MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0]
7H GAL-KYU MAY 0.3>0[0.4] JUN 0.4>0[0.3] JUL 0.4>0[0.4] AUG 0.3>0[0.4] SEP 0.4>0[0.3] OCT 0.4>0[0.4] NOV 0.3>0[0.3] DEC 0.4>0[0.3] JAN 0.3>0[0.4]
7H GAL-NUL MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0]
7H GAL-RBY MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0]
7H GAM-OME MAY 0.9>0[1.4] JUN 0.9>0[1.4] JUL 0.9>0[1.4] AUG 0.9>0[1.4] SEP 0.9>0[1.4] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H GAM-SVA MAY 0.9>0[1.4] JUN 0.9>0[1.4] JUL 0.9>0[1.4] AUG 0.9>0[1.4] SEP 0.9>0[1.4] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H GLV-WMO MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H HPB-SCM MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H HPB-VAK MAY 1.4>0[1.4] JUN 1.4>0[1.4] JUL 1.4>0[1.4] AUG 1.4>0[1.4] SEP 1.4>0[1.4] OCT 1.4>0[1.4] NOV 1.4>0[1.4] DEC 1.4>0[1.4] JAN 1.4>0[1.4]
7H HSL-KYU MAY 0.3>0[0.4] JUN 0.4>0[0.3] JUL 0.4>0[0.4] AUG 0.3>0[0.4] SEP 0.4>0[0.3] OCT 0.4>0[0.4] NOV 0.3>0[0.3] DEC 0.4>0[0.3] JAN 0.3>0[0.4]
7H IAN-ORV MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H IAN-OTZ MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H KAL-NUL MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0]
7H KGX-SHX MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[0.9] OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0]
7H KKA-SKK MAY 1.0>0[1.4] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0]
7H KKA-UNK MAY 1.0>0[1.4] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0]
7H KKH-KWK MAY 1.4>0[1.4] JUN 1.4>0[1.4] JUL 1.4>0[1.4] AUG 1.4>0[1.4] SEP 1.4>0[1.4] OCT 1.4>0[1.4] NOV 1.4>0[1.4] DEC 1.4>0[1.4] JAN 1.4>0[1.4]
7H KKI-KWT MAY 1.4>0[1.5] JUN 1.4>0[1.5] JUL 1.4>0[1.4] AUG 1.4>0[1.5] SEP 1.4>0[1.5] OCT 1.4>0[1.5] NOV 1.4>0[1.5] DEC 1.4>0[1.5] JAN 1.4>0[1.5]
7H KLG-RSH MAY 0.8>0[0.8] JUN 0.9>0[0.8] JUL 0.8>0[0.8] AUG 0.8>0[0.9] SEP 0.8>0[0.7] OCT 0.9>0[0.9] NOV 0.8>0[0.8] DEC 0.8>0[0.8] JAN 0.8>0[0.8]
7H KOT-KSM MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H KSM-MOU MAY 1.8>0[1.8] JUN 1.9>0[1.8] JUL 1.8>0[1.8] AUG 1.8>0[1.9] SEP 1.8>0[1.8] OCT 1.9>0[1.9] NOV 1.8>0[1.8] DEC 1.8>0[1.8] JAN 1.8>0[1.8]
7H KSM-SXP MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H KSM-UNK MAY 0>0.3[0]
7H KTS-OME MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H KTS-WAA MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H KUK-NUP MAY 1.4>0[1.4] JUN 1.4>0[1.4] JUL 1.4>0[1.4] AUG 1.4>0[1.4] SEP 1.4>0[1.4] OCT 1.4>0[1.4] NOV 1.4>0[1.4] DEC 1.4>0[1.4] JAN 1.4>0[1.4]
7H KVL-OTZ MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H KVL-WTK MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H MLL-RSH MAY 1.4>0[1.4] JUN 1.4>0[1.4] JUL 1.4>0[1.4] AUG 1.4>0[1.4] SEP 1.4>0[1.4] OCT 1.4>0[1.4] NOV 1.4>0[1.4] DEC 1.4>0[1.4] JAN 1.4>0[1.4]
7H MOU-PQS MAY 1.8>0[1.8] JUN 1.9>0[1.8] JUL 1.8>0[1.8] AUG 1.8>0[1.9] SEP 1.8>0[1.8] OCT 1.9>0[1.9] NOV 1.8>0[1.8] DEC 1.8>0[1.8] JAN 1.8>0[1.8]
7H MYU-OOK MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[0.5] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0]
7H NME-OOK MAY 0.5>0[0.4] JUN 0.5>0[0.4] JUL 0.5>0[0.4] AUG 0.5>0[0.4] SEP 0.5>0[0.4] OCT 0.5>0[0.4] NOV 0.5>0[0.4] DEC 0.5>0[0.4] JAN 0.5>0[0.4]
7H NME-TNK MAY 0.9>0[0] JUN 0.9>0[0] JUL 0.9>0[0] AUG 0.9>0[0] SEP 0.9>0[0] OCT 0.9>0[0] NOV 0.9>0[0] DEC 0.9>0[0] JAN 0.9>0[0]
7H NUI-SCC MAY 1.0>0[1.4] JUN 2>0[1.3] JUL 2>0[1.4] AUG 2>0[1.4] SEP 2>0[1.4] OCT 2>0[1.4] NOV 2>0[2] DEC 2>0[2] JAN 2>0[2]
7H OBU-OTZ MAY 0.4>0[0.4] JUN 0.4>0[0.4] JUL 0.4>0[0.4] AUG 0.4>0[0.4] SEP 0.4>0[0.4] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
7H OBU-SHG MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H OME-SHH MAY 1.8>0[1.8] JUN 1.9>0[1.8] JUL 1.8>0[1.8] AUG 1.8>0[1.9] SEP 1.8>0[1.8] OCT 1.9>0[1.9] NOV 1.8>0[1.8] DEC 1.8>0[1.8] JAN 1.8>0[1.8]
7H OME-SVA MAY 0.9>0[1.4] JUN 0.9>0[1.4] JUL 0.9>0[1.4] AUG 0.9>0[1.4] SEP 0.9>0[1.4] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H OME-UNK MAY 0.4>0[0] JUN 0.4>0[0] JUL 0.4>0[0] AUG 0.4>0[0] SEP 0.4>0[0] OCT 0.4>0[0] NOV 0.4>0[0] DEC 0.4>0[0] JAN 0.4>0[0]
7H OME-WAA MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H OME-WBB MAY 1.4>0[1.7] JUN 1.4>0[1.3] JUL 1.4>0[1.3] AUG 1.4>0[1.4] SEP 1.4>0[1.3] OCT 1.4>0[1.4] NOV 1.4>0[1.3] DEC 1.4>0[1.3] JAN 1.4>0[1.3]
7H OME-WMO MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H OOK-TNK MAY 0.6>0[1.4] JUN 0.6>0[1.4] JUL 0.5>0[0.9] AUG 0.6>0[1.4] SEP 0.6>0[1.4] OCT 0.6>0[1.4] NOV 0.6>0[1.4] DEC 0.5>0[1.4] JAN 0.6>0[1.4]
7H ORV-OTZ MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H OTZ-PHO MAY 1.9>0[1.9] JUN 2>0[2] JUL 1.9>0[1.9] AUG 2>0[2] SEP 1.9>0[1.9] OCT 2>0[2] NOV 1.9>0[1.9] DEC 1.9>0[1.9] JAN 1.9>0[1.9]
7H OTZ-SHG MAY 0.5>0[0.5] JUN 0.5>0[0.5] JUL 0.5>0[0.5] AUG 0.5>0[0.5] SEP 0.5>0[0.5] OCT 0.5>0[0.5] NOV 0.5>0[0.5] DEC 0.5>0[0.5] JAN 0.5>0[0.5]
7H OTZ-WLK MAY 1.9>0[1.9] JUN 2>0[2] JUL 1.9>0[1.9] AUG 2>0[2] SEP 1.9>0[1.9] OCT 2>0[2] NOV 1.9>0[1.9] DEC 1.9>0[1.9] JAN 1.9>0[1.9]
7H OTZ-WTK MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
7H PHO-PIZ MAY 0.3>0[0.3] JUN 0.3>0[0.3] JUL 0.3>0[0.3] AUG 0.3>0[0.3] SEP 0.3>0[0.3] OCT 0.3>0[0.3] NOV 0.2>0[0.3] DEC 0.3>0[0.3] JAN 0.3>0[0.3]
7H RDV-SLQ MAY 0.4>0[0.4] JUN 0.4>0[0.4] JUL 0.4>0[0.4] AUG 0.4>0[0.4] SEP 0.4>0[0.4] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
7H SCM-VAK MAY 0.5>0[0.5] JUN 0.5>0[0.5] JUL 0.5>0[0.5] AUG 0.5>0[0.5] SEP 0.5>0[0.5] OCT 0.5>0[0.5] NOV 0.5>0[0.5] DEC 0.5>0[0.5] JAN 0.5>0[0.5]
7H SKK-UNK MAY 1.8>0[1.4] JUN 1.9>0[1.3] JUL 1.8>0[1.3] AUG 1.8>0[1.4] SEP 1.8>0[1.3] OCT 1.9>0[1.4] NOV 1.8>0[1.3] DEC 1.8>0[1.3] JAN 1.8>0[1.3]
7H SLQ-SRV MAY 0.4>0[0.4] JUN 0.4>0[0.4] JUL 0.4>0[0.4] AUG 0.4>0[0.4] SEP 0.4>0[0.4] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
7H SMK-UNK MAY 2>0[2] JUN 2>0[3] JUL 2>0[3] AUG 2>0[3] SEP 2>0[2] OCT 2>0[3] NOV 2>0[3] DEC 2>0[2] JAN 2>0[3]
7H SMK-WBB MAY 2>0[2] JUN 2>0[3] JUL 2>0[3] AUG 2>0[3] SEP 2>0[2] OCT 2>0[3] NOV 2>0[3] DEC 2>0[2] JAN 2>0[3]
7H UNK-WBB MAY 0.9>0[0.5] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
8E ABL-OBU MAY 0.4>0[0.4] JUN 0.4>0[0.4] JUL 0.4>0[0.4] AUG 0.4>0[0.4] SEP 0.4>0[0.4] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
8E ABL-OTZ MAY 0.9>0.4[0.9] JUN 0.9>0.4[0.9] JUL 0.9>0.4[0.9] AUG 0.9>0.4[0.9] SEP 0.9>0.4[0.9] OCT 0.9>0.4[0.9] NOV 0.9>0.4[0.9] DEC 0.9>0.4[0.9] JAN 0.9>0.4[0.9]
8E BKC-DRG MAY 0.9>0.4[0.9] JUN 0.9>0.4[0.9] JUL 0.9>0.4[0.9] AUG 0.9>0.4[0.9] SEP 0.9>0.4[0.9] OCT 0.9>0.4[0.9] NOV 0.9>0.4[0.9] DEC 0.9>0.4[0.9] JAN 0.9>0.4[0.9]
8E BKC-OTZ MAY 0.9>0.4[0.9] JUN 0.9>0.4[0.9] JUL 0.9>0.4[0.9] AUG 0.9>0.4[0.9] SEP 0.9>0.4[0.9] OCT 0.9>0.4[0.9] NOV 0.9>0.4[0.9] DEC 0.9>0.4[0.9] JAN 0.9>0.4[0.9]
8E DRG-OTZ MAY 0.9>0.4[0.9] JUN 0.9>0.4[0.9] JUL 0.9>0.4[0.9] AUG 0.9>0.4[0.9] SEP 0.9>0.4[0.9] OCT 0.9>0.4[0.9] NOV 0.9>0.4[0.9] DEC 0.9>0.4[0.9] JAN 0.9>0.4[0.9]
8E ELI-GLV MAY 0.9>0.4[0.9] JUN 0.9>0.4[0.9] JUL 0.9>0.4[0.9] AUG 0.9>0.4[0.9] SEP 0.9>0.4[0.9] OCT 0.9>0.4[0.9] NOV 0.9>0.4[0.9] DEC 0.9>0.4[0.9] JAN 0.9>0.4[0.9]
8E ELI-OME MAY 0.9>0.4[0.9] JUN 0.9>0.4[0.9] JUL 0.9>0.4[0.9] AUG 0.9>0.4[0.9] SEP 0.9>0.4[0.9] OCT 0.9>0.4[0.9] NOV 0.9>0.4[0.9] DEC 0.9>0.4[0.9] JAN 0.9>0.4[0.9]
8E GAM-OME MAY 1.6>0.8[1.7] JUN 1.7>0.9[1.6] JUL 1.7>0.8[1.7] AUG 1.6>0.8[1.6] SEP 1.7>0.9[1.6] OCT 1.6>0.9[1.7] NOV 1.6>0.8[1.6] DEC 1.7>0.8[1.6] JAN 1.6>0.8[1.7]
8E GLV-WMO MAY 0.9>0.4[0.9] JUN 0.9>0.4[0.9] JUL 0.9>0.4[0.9] AUG 0.9>0.4[0.9] SEP 0.9>0.4[0.9] OCT 0.9>0.4[0.9] NOV 0.9>0.4[0.9] DEC 0.9>0.4[0.9] JAN 0.9>0.4[0.9]
8E IAN-ORV MAY 0.9>0.4[0.9] JUN 0.9>0.4[0.9] JUL 0.9>0.4[0.9] AUG 0.9>0.4[0.9] SEP 0.9>0.4[0.9] OCT 0.9>0.4[0.9] NOV 0.9>0.4[0.9] DEC 0.9>0.4[0.9] JAN 0.9>0.4[0.9]
8E IAN-OTZ MAY 0.9>0.4[0.9] JUN 0.9>0.4[0.9] JUL 0.9>0.4[0.9] AUG 0.9>0.4[0.9] SEP 0.9>0.4[0.9] OCT 0.9>0.4[0.9] NOV 0.9>0.4[0.9] DEC 0.9>0.4[0.9] JAN 0.9>0.4[0.9]
8E KKA-OME MAY 0.9>0.4[0.9] JUN 0.9>0.4[0.9] JUL 0.9>0.4[0.9] AUG 0.9>0.4[0.9] SEP 0.9>0.4[0.9] OCT 0.9>0.4[0.9] NOV 0.9>0.4[0.9] DEC 0.9>0.4[0.9] JAN 0.9>0.4[0.9]
8E KKA-SKK MAY 0.9>0.4[0.9] JUN 0.9>0.4[0.9] JUL 0.9>0.4[0.9] AUG 0.9>0.4[0.9] SEP 0.9>0.4[0.9] OCT 0.9>0.4[0.9] NOV 0.9>0.4[0.9] DEC 0.9>0.4[0.9] JAN 0.9>0.4[0.9]
8E KTS-OME MAY 0.4>0[0.4] JUN 0.4>0[0.4] JUL 0.4>0[0.4] AUG 0.4>0[0.4] SEP 0.4>0[0.4] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
8E KTS-TLA MAY 0.9>0.4[0.9] JUN 0.9>0.4[0.9] JUL 0.9>0.4[0.9] AUG 0.9>0.4[0.9] SEP 0.9>0.4[0.9] OCT 0.9>0.4[0.9] NOV 0.9>0.4[0.9] DEC 0.9>0.4[0.9] JAN 0.9>0.4[0.9]
8E KVL-PHO MAY 0.4>0.8[0.4] JUN 0.4>0.9[0.4] JUL 0.4>0.8[0.4] AUG 0.4>0.8[0.4] SEP 0.4>0.9[0.4] OCT 0.4>0.9[0.4] NOV 0.4>0.8[0.4] DEC 0.4>0.8[0.4] JAN 0.4>0.8[0.4]
8E KVL-WTK MAY 0.5>0[0.5] JUN 0.5>0[0.5] JUL 0.5>0[0.5] AUG 0.5>0[0.5] SEP 0.5>0[0.5] OCT 0.5>0[0.5] NOV 0.5>0[0.5] DEC 0.5>0[0.5] JAN 0.5>0[0.5]
8E OBU-SHG MAY 0.9>0.4[0.9] JUN 0.9>0.4[0.9] JUL 0.9>0.4[0.9] AUG 0.9>0.4[0.9] SEP 0.9>0.4[0.9] OCT 0.9>0.4[0.9] NOV 0.9>0.4[0.9] DEC 0.9>0.4[0.9] JAN 0.9>0.4[0.9]
8E OME-OTZ MAY 0.7>0[0.7] JUN 0.7>0[0.7] JUL 0.7>0[0.7] AUG 0.7>0[0.7] SEP 0.7>0[0.7] OCT 0.7>0[0.7] NOV 0.7>0[0.7] DEC 0.7>0[0.7] JAN 0.7>0[0.7]
8E OME-SHH MAY 1.0>0.4[1.0] JUN 1.0>0.4[1.0] JUL 1.0>0.4[1.0] AUG 1.0>0.4[1.0] SEP 1.0>0.4[1.0] OCT 1.0>0.4[1.0] NOV 1.0>0.4[1.0] DEC 1.0>0.4[1.0] JAN 1.0>0.4[1.0]
8E OME-SVA MAY 1.6>0.8[1.7] JUN 1.7>0.9[1.6] JUL 1.7>0.8[1.7] AUG 1.6>0.8[1.6] SEP 1.7>0.9[1.6] OCT 1.6>0.9[1.7] NOV 1.6>0.8[1.6] DEC 1.7>0.8[1.6] JAN 1.6>0.8[1.7]
8E OME-TLA MAY 0.9>0.4[0.9] JUN 0.9>0.4[0.9] JUL 0.9>0.4[0.9] AUG 0.9>0.4[0.9] SEP 0.9>0.4[0.9] OCT 0.9>0.4[0.9] NOV 0.9>0.4[0.9] DEC 0.9>0.4[0.9] JAN 0.9>0.4[0.9]
8E OME-TNC MAY 0.4>0[0.4] JUN 0.4>0[0.4] JUL 0.4>0[0.4] AUG 0.4>0[0.4] SEP 0.4>0[0.4] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
8E OME-UNK MAY 0.9>0.4[0.9] JUN 0.9>0.4[0.9] JUL 0.9>0.4[0.9] AUG 0.9>0.4[0.9] SEP 0.9>0.4[0.9] OCT 0.9>0.4[0.9] NOV 0.9>0.4[0.9] DEC 0.9>0.4[0.9] JAN 0.9>0.4[0.9]
8E OME-WAA MAY 0.9>0.4[0.9] JUN 0.9>0.4[0.9] JUL 0.9>0.4[0.9] AUG 0.9>0.4[0.9] SEP 0.9>0.4[0.9] OCT 0.9>0.4[0.9] NOV 0.9>0.4[0.9] DEC 0.9>0.4[0.9] JAN 0.9>0.4[0.9]
8E OME-WBB MAY 0.9>0[0.9] JUN 0.9>0[0.9] JUL 0.9>0[0.9] AUG 0.9>0[0.9] SEP 0.9>0[0.9] OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.9>0[0.9]
8E OME-WMO MAY 0.9>0.4[0.9] JUN 0.9>0.4[0.9] JUL 0.9>0.4[0.9] AUG 0.9>0.4[0.9] SEP 0.9>0.4[0.9] OCT 0.9>0.4[0.9] NOV 0.9>0.4[0.9] DEC 0.9>0.4[0.9] JAN 0.9>0.4[0.9]
8E ORV-OTZ MAY 0.9>0.4[0.9] JUN 0.9>0.4[0.9] JUL 0.9>0.4[0.9] AUG 0.9>0.4[0.9] SEP 0.9>0.4[0.9] OCT 0.9>0.4[0.9] NOV 0.9>0.4[0.9] DEC 0.9>0.4[0.9] JAN 0.9>0.4[0.9]
8E OTZ-PHO MAY 1.3>0.8[1.3] JUN 1.3>0.9[1.3] JUL 1.3>0.8[1.3] AUG 1.3>0.8[1.3] SEP 1.3>0.9[1.3] OCT 1.3>0.9[1.3] NOV 1.3>0.8[1.3] DEC 1.3>0.8[1.3] JAN 1.3>0.8[1.3]
8E OTZ-SHG MAY 0.4>0[0.4] JUN 0.4>0[0.4] JUL 0.4>0[0.4] AUG 0.4>0[0.4] SEP 0.4>0[0.4] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
8E OTZ-WLK MAY 1.8>0.8[1.9] JUN 1.9>0.9[1.8] JUL 1.9>0.8[1.9] AUG 1.8>0.8[1.9] SEP 1.9>0.9[1.8] OCT 1.9>0.9[1.9] NOV 1.8>0.8[1.9] DEC 1.9>0.8[1.8] JAN 1.8>0.8[1.9]
8E OTZ-WTK MAY 1.3>0.8[1.4] JUN 1.4>0.9[1.3] JUL 1.4>0.8[1.4] AUG 1.3>0.8[1.4] SEP 1.4>0.9[1.3] OCT 1.4>0.9[1.4] NOV 1.3>0.8[1.4] DEC 1.4>0.8[1.3] JAN 1.3>0.8[1.4]
8E SHH-WAA MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0]
8E SKK-UNK MAY 0.9>0.4[0.9] JUN 0.9>0.4[0.9] JUL 0.9>0.4[0.9] AUG 0.9>0.4[0.9] SEP 0.9>0.4[0.9] OCT 0.9>0.4[0.9] NOV 0.9>0.4[0.9] DEC 0.9>0.4[0.9] JAN 0.9>0.4[0.9]
8E SMK-UNK MAY 1.3>0.4[1.4] JUN 1.4>0.4[1.3] JUL 1.4>0.4[1.4] AUG 1.3>0.4[1.4] SEP 1.4>0.4[1.3] OCT 1.4>0.4[1.4] NOV 1.3>0.4[1.4] DEC 1.4>0.4[1.3] JAN 1.3>0.4[1.4]
8E SMK-WBB MAY 1.3>0.4[1.4] JUN 1.4>0.4[1.3] JUL 1.4>0.4[1.4] AUG 1.3>0.4[1.4] SEP 1.4>0.4[1.3] OCT 1.4>0.4[1.4] NOV 1.3>0.4[1.4] DEC 1.4>0.4[1.3] JAN 1.3>0.4[1.4]
8E TNC-WAA MAY 0.4>0[0.4] JUN 0.4>0[0.4] JUL 0.4>0[0.4] AUG 0.4>0[0.4] SEP 0.4>0[0.4] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4]
9K ACK-JFK MAY 1.0>0.6[0.5]
9K BOS-LEB MAY 4>5[4]
9K HPN-LEB MAY 2>1.2[2]
9K JFK-MVY MAY 1.0>0.6[0]
Wow. It's not just Summer Int'l that's out, it's really the rest of 2020. Jaw-dropping.
AA ABE-CLT MAY 3>2[3]
AA ABE-ORD MAY 1.9>0.7[1.8]
AA ABE-PHL MAY 1.8>0.0[3]
AA ABI-DFW MAY 6>3[7]
AA ABQ-DFW MAY 8>5[8]
AA ABQ-LAX MAY 3>0[3]
AA ABQ-ORD MAY 3>0.7[2.0]
AA ABQ-PHX MAY 4>0.7[5]
AA ACT-DFW MAY 5>2[6]
AA AEX-DFW MAY 3>1.0[3]
AA AGS-CLT MAY 6>3[6]
AA AGS-DCA MAY 0.8>0[0]
AA AGS-DFW MAY 1.8>1.0[1.0]
AA AGU-DFW MAY 1.8>1.0[2]
**AA AKL-DFW NOV 0.4>0[0] DEC 1.0>0[0] JAN 1.0>0[0]
AA AKL-LAX OCT 0.8>0.3[0.2]
AA ALB-CLT MAY 3>2.0[3]
AA ALB-DCA MAY 4>0.1[4]
AA ALB-ORD MAY 3>0.7[3]
AA ALB-PHL MAY 6>1.3[6]
AA AMA-DFW MAY 7>4[8]
AA AMS-DFW MAY 0.8>0[0.9]
AA AMS-PHL MAY 0.8>0[1.0]
AA ANC-DFW MAY 0.8>0[0.5]
AA ANC-ORD MAY 0.8>0[0]
AA ANU-JFK MAY 0.7>0[1.0]
AA ANU-MIA MAY 1.6>0.7[1.0]
AA ATH-ORD MAY 0.8>0[0.9]
**AA ATH-PHL MAY 0.8>0[0.9] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[0.9] OCT 0.2>0[0]
AA ATL-CLT MAY 7>4[9]
AA ATL-DCA MAY 3>0.0[4]
AA ATL-DFW MAY 8>5[8]
AA ATL-LAX MAY 2>0[3]
AA ATL-LGA MAY 4>0.1[5]
AA ATL-MIA MAY 7>2[8]
AA ATL-ORD MAY 3>1.3[4]
AA ATL-PHL MAY 4>0.8[6]
AA ATL-PHX MAY 0.9>0[1.7]
AA ATW-ORD MAY 3>0.7[3]
AA AUA-CLT MAY 1.7>0[2]
AA AUA-MIA MAY 1.6>0.7[2]
AA AUA-PHL MAY 0.8>0[0.7]
AA AUS-BOS MAY 1.2>0[0]
AA AUS-CLT MAY 5>3[5]
AA AUS-DFW MAY 11>5[10]
AA AUS-JFK MAY 1.5>0[1.1]
AA AUS-LAX MAY 3>0[3]
AA AUS-MIA MAY 3>1.7[3]
AA AUS-ORD MAY 3>0.7[4]
AA AUS-PHL MAY 1.7>0.1[2.0]
AA AUS-PHX MAY 4>0.8[4]
AA AUS-SJC MAY 1.2>0[0]
AA AUS-SJD MAY 0.3>0[0]
AA AVL-CLT MAY 7>3[8]
AA AVL-DFW MAY 2>1.0[0.9]
AA AVL-LGA MAY 0.8>0[0.3]
AA AVL-PHL MAY 1.0>0.1[1.0]
AA AVP-CLT MAY 4>2[4]
AA AVP-ORD MAY 1.7>0.6[2]
AA AVP-PHL MAY 3>0.1[3]
AA AZO-ORD MAY 3>0.7[3]
**AA BCN-CLT JUN 0.9>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[0.9] OCT 0.2>0[0]
**AA BCN-JFK MAY 0.8>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
**AA BCN-MIA MAY 0.8>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
AA BCN-ORD MAY 0.8>0[0.9]
**AA BCN-PHL MAY 0.8>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
AA BDA-MIA MAY 0.8>0[1.0]
AA BDA-PHL MAY 0.8>0[1.0]
AA BDL-CLT MAY 6>3[7]
AA BDL-DCA MAY 5>0.1[5]
AA BDL-DFW MAY 1.8>1.0[1.0]
AA BDL-LAX MAY 0.8>0[1.0]
AA BDL-MIA MAY 1.1>0.8[1.0]
AA BDL-ORD MAY 3>1.3[5]
AA BDL-PHL MAY 4>1.4[4]
AA BFL-DFW MAY 2>1.0[1.0]
AA BFL-PHX MAY 2>0.7[3]
AA BGI-MIA MAY 1.6>0.7[2]
AA BGR-DCA MAY 3>0[3]
AA BGR-LGA MAY 0.8>0[0]
AA BGR-PHL MAY 5>1.4[5]
AA BHM-CLT MAY 7>3[6]
AA BHM-DCA MAY 3>0[3]
AA BHM-DFW MAY 6>3[7]
AA BHM-MIA MAY 2>0.8[2]
AA BHM-ORD MAY 1.5>0.0[1.8]
AA BHM-PHL MAY 3>0.1[3]
AA BIL-DFW MAY 2>1.0[1.0]
AA BIS-DFW MAY 2>1.0[1.8]
**AA BLR-SEA OCT 0.2>0[0] NOV 1.0>0[0] DEC 1.0>0[0] JAN 1.0>0[0]
AA BMI-DFW MAY 2>1.0[2.0]
AA BMI-ORD MAY 3>0.1[3]
AA BNA-CLT MAY 8>4[7]
AA BNA-DCA MAY 4>0.1[5]
AA BNA-DFW MAY 7>5[8]
AA BNA-JFK MAY 1.6>0[2]
AA BNA-LAX MAY 2>0[1.8]
AA BNA-LGA MAY 4>0.0[4]
AA BNA-MIA MAY 2.0>0.8[3]
AA BNA-ORD MAY 8>2[9]
AA BNA-PHL MAY 4>1.4[5]
AA BOG-DFW MAY 0.8>0[1.0]
AA BOG-MIA MAY 2>1.4[3]
AA BOI-PHX MAY 1.7>0.6[2]
AA BON-MIA MAY 0.4>0[0.6]
AA BOS-CLT MAY 9>4[9]
AA BOS-DCA MAY 11>3[14] JUN 10>9[11]
AA BOS-DFW MAY 8>5[7]
AA BOS-IND MAY 1.5>0[0]
AA BOS-JFK MAY 3>0.0[1.2]
AA BOS-LAX MAY 3>0.1[5]
AA BOS-LGA MAY 8>4[12] JUN 10>9[10]
**AA BOS-LHR MAY 0.8>0[0] JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0] OCT 1.0>0.3[0]
AA BOS-MDT MAY 0.9>0.0[0.9]
AA BOS-MIA MAY 7>1.8[6]
AA BOS-ORD MAY 7>1.6[8]
AA BOS-PHL MAY 9>5[11]
AA BOS-PHX MAY 4>0.8[4]
AA BOS-RDU MAY 4>0[0]
AA BOS-ROC MAY 3>0.1[3]
AA BOS-SYR MAY 0.9>0.0[0.9]
AA BPT-DFW MAY 3>1.0[3]
AA BRO-DFW MAY 3>1.0[4]
**AA BSB-MIA MAY 0.8>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[0.6] AUG 0.9>0[0.6] SEP 0.7>0[0.6] OCT 0.7>0.2[0.6]
AA BTR-CLT MAY 3>1.9[3]
AA BTR-DFW MAY 5>3[5]
AA BTV-CLT MAY 3>1.9[2]
AA BTV-DCA MAY 3>0.0[3]
AA BTV-PHL MAY 4>1.4[4]
**AA BUD-ORD MAY 0.5>0[0] JUN 0.6>0[0] JUL 0.6>0[0] AUG 0.6>0[0] SEP 0.6>0[0] OCT 0.4>0[0]
**AA BUD-PHL MAY 0.8>0[0.9] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
AA BUF-CLT MAY 3>2[3]
AA BUF-DCA MAY 2>0[3]
AA BUF-ORD MAY 4>0.8[5]
AA BUF-PHL MAY 5>1.5[5]
AA BUR-DFW MAY 2>1.0[2]
AA BUR-PHX MAY 4>0.7[4]
AA BWI-CLT MAY 8>4[7]
AA BWI-DFW MAY 4>1.9[3]
AA BWI-JFK MAY 1.4>0[1.0]
AA BWI-MIA MAY 0.9>0[3]
AA BWI-ORD MAY 3>0.7[4]
AA BWI-PHL MAY 3>0.0[3]
AA BZE-DFW MAY 0.9>0[1.1]
AA BZE-MIA MAY 1.6>0.7[2]
AA CAE-CLT MAY 7>4[7]
AA CAE-DCA MAY 2>0.1[4]
AA CAE-DFW MAY 3>1.0[2]
AA CAE-LGA MAY 0.8>0[0.9]
AA CAE-PHL MAY 3>0.1[1.9]
AA CAK-CLT MAY 5>1.3[5]
AA CAK-DCA MAY 1.0>0[1.0]
AA CAK-LGA MAY 0.7>0[0.8]
AA CAK-ORD MAY 1.6>0[1.7]
AA CAK-PHL MAY 2.0>0.8[2.0]
AA CAP-MIA MAY 0.8>0[0.6]
**AA CDG-CLT MAY 0.8>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
AA CDG-DFW JUN 1.9>1.0[1.8] JUL 2>1.0[2] AUG 2>1.0[2] SEP 2>1.0[2] OCT 1.9>1.1[1.9]
AA CDG-JFK MAY 0.8>0[1.0]
**AA CDG-MIA JUN 0.9>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
**AA CDG-ORD MAY 0.8>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
**AA CDG-PHL MAY 0.8>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
AA CHA-CLT MAY 7>2[6]
AA CHA-DCA MAY 0.8>0[0.9]
AA CHA-DFW MAY 3>1.1[3]
**AA CHC-LAX NOV 0.4>0[0] DEC 0.4>0[0] JAN 0.5>0[0]
AA CHO-CLT MAY 8>3[7]
AA CHO-LGA MAY 1.8>0.1[1.9]
AA CHO-ORD MAY 1.6>0[3]
AA CHO-PHL MAY 1.7>0.1[1.9]
AA CHS-CLT MAY 9>4[9]
AA CHS-DCA MAY 4>0.0[4]
AA CHS-DFW MAY 4>2.0[4]
AA CHS-LGA MAY 0.8>0[0.9]
AA CHS-MIA MAY 3>0.9[4]
AA CHS-ORD MAY 1.2>0.7[1.1]
AA CHS-PHL MAY 5>1.4[5]
AA CID-CLT MAY 3>1.8[2]
AA CID-DFW MAY 3>1.9[3]
AA CID-ORD MAY 4>1.2[5]
AA CLE-CLT MAY 7>3[7]
AA CLE-DCA MAY 3>0[3]
AA CLE-LGA MAY 3>0[4]
AA CLE-MIA MAY 3>0.8[3]
AA CLE-ORD MAY 6>1.3[7]
AA CLE-PHL MAY 6>1.3[6]
AA CLL-DFW MAY 3>2[4]
AA CLT-CMH MAY 7>4[8]
AA CLT-CRW MAY 4>2[5]
AA CLT-CUN MAY 3>1.0[3]
AA CLT-CVG MAY 7>3[7]
AA CLT-DAB MAY 5>2[4]
AA CLT-DAY MAY 5>2[6]
AA CLT-DCA MAY 9>4[9]
AA CLT-DEN MAY 5>2.0[6]
AA CLT-DFW MAY 9>5[10]
AA CLT-DSM MAY 3>2.0[3]
AA CLT-DTW MAY 6>3[6]
**AA CLT-DUB MAY 0.8>0[0.9] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
AA CLT-ECP MAY 3>1.0[2]
AA CLT-ELH MAY 0.3>0[0.1]
AA CLT-ERI MAY 2>1.0[1.9]
AA CLT-EVV MAY 2>1.0[2.0]
AA CLT-EWN MAY 5>2[5]
AA CLT-EWR MAY 8>3[8]
AA CLT-EYW MAY 2>1.3[1.3]
AA CLT-FAY MAY 6>2[7]
**AA CLT-FCO JUN 0.9>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
AA CLT-FLL MAY 7>4[6]
AA CLT-FLO MAY 3>2[4]
AA CLT-FNT MAY 2>1.0[0]
**AA CLT-FRA MAY 0.8>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
AA CLT-FWA MAY 2>1.0[2.0]
AA CLT-GCM MAY 0.9>0[1.4]
AA CLT-GDL MAY 0.2>0[0]
AA CLT-GNV MAY 4>2.0[4]
AA CLT-GPT MAY 3>1.0[2]
AA CLT-GRR MAY 3>2[3]
AA CLT-GSO MAY 9>4[9]
AA CLT-GSP MAY 8>4[9]
AA CLT-HHH MAY 4>1.9[3]
AA CLT-HPN MAY 4>2.0[4]
AA CLT-HSV MAY 4>2.0[4]
AA CLT-HTS MAY 3>2.0[3]
AA CLT-IAD MAY 6>2[7]
AA CLT-IAH MAY 5>3[6]
AA CLT-ILM MAY 9>3[9]
AA CLT-IND MAY 8>4[8]
AA CLT-JAN MAY 4>1.9[3]
AA CLT-JAX MAY 8>4[8]
AA CLT-JFK MAY 5>3[6]
AA CLT-LAS MAY 5>2[5]
AA CLT-LAX MAY 7>3[7]
AA CLT-LEX MAY 5>3[5]
AA CLT-LGA MAY 9>4[10]
AA CLT-LHR MAY 1.6>0[2] JUN 2>0.9[2] JUL 2>1.0[2] AUG 2>1.0[2] SEP 2>1.0[2] OCT 2>1.3[2]
AA CLT-LIR MAY 0.3>0[0.3]
AA CLT-LIT MAY 4>2.0[4]
AA CLT-LYH MAY 6>2[6]
**AA CLT-MAD MAY 0.8>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.8>0[0.8]
AA CLT-MBJ MAY 3>0[3]
AA CLT-MCI MAY 4>2[4]
AA CLT-MCO MAY 11>4[9] JUN 11>10[10]
AA CLT-MDT MAY 6>3[6]
AA CLT-MEM MAY 6>3[7]
AA CLT-MGM MAY 3>1.9[3]
AA CLT-MHT MAY 4>1.9[4]
AA CLT-MIA MAY 7>4[7]
AA CLT-MKE MAY 5>3[5]
AA CLT-MLB MAY 3>1.9[3]
AA CLT-MOB MAY 5>2.0[4]
AA CLT-MSN MAY 3>2.0[2]
AA CLT-MSP MAY 4>1.9[4]
AA CLT-MSY MAY 7>4[7]
AA CLT-MUC MAY 0.8>0[1.0]
AA CLT-MYR MAY 8>3[8]
AA CLT-NAS MAY 1.7>0[2]
AA CLT-OAJ MAY 6>2[6]
AA CLT-OKC MAY 3>1.9[3]
AA CLT-OMA MAY 3>1.9[3]
AA CLT-ORD MAY 9>4[10]
AA CLT-ORF MAY 9>4[8]
AA CLT-PBI MAY 6>3[6]
AA CLT-PGV MAY 4>1.9[5]
AA CLT-PHF MAY 6>3[6]
AA CLT-PHL MAY 8>4[9]
AA CLT-PHX MAY 7>3[8]
AA CLT-PIA MAY 2>1.0[2]
AA CLT-PIT MAY 8>4[9]
AA CLT-PLS MAY 1.7>0[1.4]
AA CLT-PNS MAY 5>2[5]
AA CLT-PUJ MAY 0.8>0[3]
AA CLT-PVD MAY 5>3[5]
AA CLT-PWM MAY 3>1.8[2]
AA CLT-RDU MAY 10>4[9]
AA CLT-RIC MAY 8>4[8]
AA CLT-ROA MAY 8>3[7]
AA CLT-ROC MAY 4>2.0[4]
AA CLT-RSW MAY 6>3[6]
AA CLT-SAN MAY 4>1.9[4]
AA CLT-SAT MAY 4>2.0[4]
AA CLT-SAV MAY 8>4[9]
AA CLT-SBN MAY 2>1.0[2.0]
AA CLT-SBY MAY 3>2[2]
AA CLT-SDF MAY 7>2[7]
AA CLT-SEA MAY 3>0.9[3]
AA CLT-SFO MAY 4>2[5]
AA CLT-SGF MAY 4>1.8[4]
AA CLT-SHV MAY 2>1.0[2]
AA CLT-SJO MAY 0.3>0[0.3]
AA CLT-SJU MAY 1.9>0.2[2.1]
AA CLT-SRQ MAY 5>2[4]
AA CLT-STL MAY 6>3[6]
AA CLT-STT MAY 0.8>0[1.0]
AA CLT-SXM MAY 0.8>0[1.0]
AA CLT-SYR MAY 4>1.9[4]
AA CLT-TLH MAY 4>1.9[4]
AA CLT-TOL MAY 2>1.0[2]
AA CLT-TPA MAY 10>4[9]
AA CLT-TRI MAY 4>3[5]
AA CLT-TUL MAY 2>1.0[3]
AA CLT-TYS MAY 7>3[6]
AA CLT-VPS MAY 5>2[5]
AA CLT-XNA MAY 4>1.9[4]
AA CLT-YUL MAY 1.6>0.8[2]
AA CLT-YYZ MAY 4>1.8[5]
AA CMH-DCA MAY 5>0.1[5]
AA CMH-DFW MAY 4>1.9[4]
AA CMH-JFK MAY 0.8>0[1.0]
AA CMH-LAX MAY 0.8>0[1.7]
AA CMH-LGA MAY 5>0.1[6]
AA CMH-MIA MAY 3>1.7[4]
AA CMH-ORD MAY 8>1.9[9]
AA CMH-PHL MAY 5>1.5[6]
AA CMH-PHX MAY 1.6>0[2]
AA CMI-DFW MAY 2>1.1[2]
AA CMI-ORD MAY 4>1.5[5]
**AA CMN-PHL JUN 0.4>0[0] JUL 0.4>0[0] AUG 0.5>0[0]
AA COS-DFW MAY 6>2[5]
AA COS-ORD MAY 0.8>0[1.0]
AA COS-PHX MAY 1.6>0[0]
AA COU-DFW MAY 3>1.0[3]
AA COU-ORD MAY 3>0.7[4]
AA CRP-DFW MAY 7>3[7]
AA CRW-DCA MAY 0.8>0[1.0]
AA CRW-PHL MAY 0.7>0[1.0]
AA CUN-DFW MAY 5>3[6]
AA CUN-JFK MAY 1.6>0[1.1]
AA CUN-MIA MAY 5>1.6[5]
AA CUN-ORD MAY 1.0>0.6[0.7]
AA CUN-PHL MAY 1.9>0.7[2]
AA CUN-PHX MAY 1.0>0[1.0]
AA CUR-MIA MAY 1.6>0.7[2]
AA CUU-DFW MAY 1.8>1.0[3]
AA CVG-DCA MAY 1.8>0.1[3]
AA CVG-DFW MAY 5>3[5]
AA CVG-JFK MAY 0.8>0[1.0]
AA CVG-LGA MAY 2>0[1.7]
AA CVG-MIA MAY 3>1.0[3]
AA CVG-ORD MAY 7>2[8]
AA CVG-PHL MAY 4>1.4[5]
AA CWA-ORD MAY 3>0.6[3]
AA CYS-DFW MAY 0.8>0[1.9]
AA DAB-LGA MAY 0.3>0[0.2]
AA DAY-DCA MAY 2>0.0[3]
AA DAY-DFW MAY 4>2[4]
AA DAY-LGA MAY 2>0[3]
AA DAY-ORD MAY 4>1.4[5]
AA DAY-PHL MAY 4>1.4[4]
AA DBQ-ORD MAY 2>0.7[3]
**AA DBV-PHL JUN 0.9>0[0.4] JUL 1.0>0[0.4] AUG 1.0>0[0.4] SEP 1.0>0[0.5] OCT 0.4>0[0]
AA DCA-DFW MAY 9>5[10]
AA DCA-DSM MAY 1.6>0.0[1.8]
AA DCA-DTW MAY 2>0[2]
AA DCA-ECP MAY 0.8>0[0]
AA DCA-EYW MAY 0.5>0.0[0.3]
AA DCA-GRR MAY 1.6>0[1.9]
AA DCA-GSO MAY 2>0[3]
AA DCA-GSP MAY 2>0.0[3]
AA DCA-HPN MAY 4>0.1[5]
AA DCA-HSV MAY 3>0[3]
AA DCA-ILM MAY 1.0>0[1.0]
AA DCA-IND MAY 5>0.1[6]
AA DCA-JAN MAY 1.0>0.0[1.0]
AA DCA-JAX MAY 3>0.0[4]
AA DCA-JFK MAY 1.8>0.2[3]
AA DCA-LAN MAY 0.6>0[0.8]
AA DCA-LAS MAY 1.0>0.0[1.0]
AA DCA-LGA MAY 9>3[11] JUN 10>9[8]
AA DCA-LIT MAY 1.0>0.0[1.0]
AA DCA-MCI MAY 2>0.0[3]
AA DCA-MCO MAY 4>0.2[4]
AA DCA-MEM MAY 3>0.0[3]
AA DCA-MGM MAY 1.0>0[0.9]
AA DCA-MHT MAY 3>0[3]
AA DCA-MIA MAY 9>5[9]
AA DCA-MSP MAY 2>0.0[3]
AA DCA-MSY MAY 4>0.1[4]
AA DCA-MYR MAY 1.1>0.0[1.3]
AA DCA-OKC MAY 0.8>0[1.0]
AA DCA-ORD MAY 8>3[8]
AA DCA-ORF MAY 2>0.0[3]
AA DCA-PBI MAY 1.9>0.0[1.3]
AA DCA-PHL MAY 3>0.9[3]
AA DCA-PHX MAY 3>2.0[3]
AA DCA-PIT MAY 4>0.1[4]
AA DCA-PNS MAY 1.9>0.0[2]
AA DCA-PVD MAY 6>0.1[6]
AA DCA-PWM MAY 4>0.0[5]
AA DCA-RDU MAY 6>0.8[6]
AA DCA-ROC MAY 3>0.0[4]
AA DCA-RSW MAY 1.1>0.0[1.0]
AA DCA-SAV MAY 1.9>0.0[2]
AA DCA-SDF MAY 3>0.1[3]
AA DCA-SRQ MAY 1.2>0.0[0.9]
AA DCA-STL MAY 3>0.0[4]
AA DCA-SYR MAY 3>0.0[4]
AA DCA-TLH MAY 1.0>0.0[1.0]
AA DCA-TPA MAY 4>1.2[4]
AA DCA-TYS MAY 2>0[3]
AA DCA-VPS MAY 1.0>0[1.1]
AA DCA-XNA MAY 0.8>0[1.0]
AA DCA-YYZ MAY 1.6>0[1.9]
AA DEN-DFW MAY 9>5[9]
AA DEN-LAX MAY 4>0[3]
AA DEN-ORD MAY 4>0.7[5]
AA DEN-PHL MAY 1.3>0.1[3]
AA DEN-PHX MAY 4>0.7[4]
AA DFW-DRO MAY 3>1.0[3]
AA DFW-DRT MAY 2>1.0[2]
AA DFW-DSM MAY 4>1.3[4]
AA DFW-DTW MAY 5>2.0[5]
AA DFW-DUB MAY 0.8>0[0]
AA DFW-ECP MAY 2>1.0[2]
AA DFW-ELP MAY 9>5[8]
AA DFW-EVV MAY 2>1.0[2]
AA DFW-EWR MAY 5>1.9[5]
AA DFW-EYW MAY 1.2>0.2[1.1]
**AA DFW-EZE MAY 0.8>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
AA DFW-FAR MAY 2>0.2[2.0]
AA DFW-FAT MAY 3>1.9[3]
AA DFW-FCA MAY 0.8>0[0]
**AA DFW-FCO MAY 0.8>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[0.8] NOV 1.0>0[0] DEC 1.0>0[0]
AA DFW-FLG MAY 1.8>1.0[2]
AA DFW-FLL MAY 5>4[6]
AA DFW-FRA MAY 0.8>0[1.0]
AA DFW-FSD MAY 3>1.1[2]
AA DFW-FSM MAY 4>1.1[4]
AA DFW-GCM MAY 0.3>0[0.5]
AA DFW-GGG MAY 3>1.0[3]
AA DFW-GJT MAY 3>1.0[3]
AA DFW-GNV MAY 1.8>1.0[2.0]
AA DFW-GPT MAY 3>1.2[3]
AA DFW-GRK MAY 7>2[8]
AA DFW-GRR MAY 3>1.8[3]
**AA DFW-GRU JUN 0.9>0.4[1.0] JUL 1.0>0.4[1.0] AUG 1.0>0.4[1.0] SEP 1.0>0.4[1.0] OCT 1.0>0.6[1.0]
AA DFW-GSO MAY 3>1.0[3]
AA DFW-GSP MAY 3>1.1[3]
AA DFW-GUA MAY 1.6>0[1.1]
AA DFW-GYE MAY 0.6>0[0]
AA DFW-HKG AUG 0.5>0.7[1.0] SEP 0.4>1.0[1.0] OCT 0.6>1.0[1.0]
**AA DFW-HND MAY 0.8>0[0] JUN 1.0>0[0] JUL 1.0>0.3[0] AUG 1.0>0.7[0]
AA DFW-HNL MAY 1.1>0[1.9] JUN 1.9>0.9[2] JUL 2>1.0[2] AUG 2>1.0[1.9] SEP 1.2>0.6[1.7] OCT 1.8>1.1[1.7]
AA DFW-HOU MAY 8>4[8]
AA DFW-HRL MAY 3>1.0[3]
AA DFW-HSV MAY 5>2[5]
AA DFW-IAD MAY 3>1.8[4]
AA DFW-IAH MAY 9>5[9]
*AA DFW-ICN MAY 0.8>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0.3[1.0] AUG 1.0>0.7[1.0]
AA DFW-ICT MAY 6>3[7]
AA DFW-ILM MAY 1.8>1.0[1.0]
AA DFW-IND MAY 5>3[5]
AA DFW-JAN MAY 6>2[7]
AA DFW-JAX MAY 4>3[5]
AA DFW-JFK MAY 2>0[4]
AA DFW-JLN MAY 3>0.9[3]
**AA DFW-KOA JUN 0.9>0[0.8] JUL 1.0>0[1.0] AUG 0.5>0[0.6]
AA DFW-LAS MAY 10>5[10]
AA DFW-LAW MAY 3>1.1[4]
AA DFW-LAX MAY 14>6[15]
AA DFW-LBB MAY 7>2[8]
AA DFW-LCH MAY 3>1.2[3]
AA DFW-LEX MAY 3>1.9[3]
AA DFW-LFT MAY 4>2[4]
AA DFW-LGA MAY 11>5[12]
AA DFW-LHR MAY 3>1.0[4]
AA DFW-LIM MAY 0.8>0[1.0]
AA DFW-LIR MAY 0.7>0[0.2]
AA DFW-LIT MAY 8>3[9]
AA DFW-LRD MAY 4>1.1[5]
AA DFW-MAD JUN 1.9>1.0[1.8] JUL 2>1.0[2] AUG 2>1.0[2] SEP 2>1.0[2] OCT 1.9>1.2[1.9]
AA DFW-MAF MAY 7>3[7]
AA DFW-MBJ MAY 0.8>0[1.0]
AA DFW-MCI MAY 8>5[7]
AA DFW-MCO MAY 9>5[10]
AA DFW-MDT MAY 1.0>0.1[0]
AA DFW-MEM MAY 7>4[9]
AA DFW-MEX MAY 4>3[5]
AA DFW-MFE MAY 7>3[8]
AA DFW-MGM MAY 3>1.1[3]
AA DFW-MHK MAY 3>1.0[3]
AA DFW-MIA MAY 9>5[11]
AA DFW-MKE MAY 3>2[4]
AA DFW-MLI MAY 2.0>1.0[2]
AA DFW-MLU MAY 3>1.0[3]
AA DFW-MOB MAY 4>1.2[4]
AA DFW-MRY MAY 2>1.0[1.0]
AA DFW-MSN MAY 3>1.0[3]
AA DFW-MSP MAY 5>3[6]
AA DFW-MSY MAY 9>5[8]
AA DFW-MTY MAY 4>1.8[5]
**AA DFW-MUC JUN 0.9>0[0.8] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
AA DFW-NAS MAY 0.8>0[1.0]
AA DFW-NRT MAY 0.9>0.5[2] JUN 1.0>0.4[2]
AA DFW-OGG MAY 0.8>0[1.5] JUN 1.9>0.9[1.9] JUL 2>1.0[2] AUG 2>1.0[1.6] SEP 1.2>0.6[1.0] OCT 1.8>1.1[1.0]
AA DFW-OKC MAY 9>5[9]
AA DFW-OMA MAY 4>3[4]
AA DFW-ONT MAY 6>3[6]
AA DFW-ORD MAY 12>6[14]
AA DFW-ORF MAY 3>1.8[2]
AA DFW-PBI MAY 3>1.0[2]
AA DFW-PDX MAY 4>3[4]
AA DFW-PHL MAY 7>5[9]
AA DFW-PHX MAY 11>5[12]
AA DFW-PIA MAY 2>1.0[2]
AA DFW-PIT MAY 5>2[4]
AA DFW-PNS MAY 6>2[5]
AA DFW-PSP MAY 3>1.9[2]
AA DFW-PVR MAY 3>1.9[3]
AA DFW-QRO MAY 1.8>1.0[2]
AA DFW-RDU MAY 6>3[6]
AA DFW-RIC MAY 3>1.8[3]
AA DFW-RNO MAY 3>1.8[3]
AA DFW-ROW MAY 3>1.1[3]
AA DFW-RSW MAY 4>2.0[3]
AA DFW-SAF MAY 3>1.8[4]
AA DFW-SAL MAY 0.5>0[0]
AA DFW-SAN MAY 8>5[9]
AA DFW-SAP MAY 0.5>0[0]
AA DFW-SAT MAY 12>5[11]
AA DFW-SAV MAY 3>1.1[3]
AA DFW-SBA MAY 1.8>1.0[1.9]
AA DFW-SCL JUN 0.9>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
AA DFW-SDF MAY 6>3[6]
AA DFW-SEA MAY 8>5[9]
AA DFW-SFO MAY 9>5[10]
AA DFW-SGF MAY 8>4[8]
AA DFW-SGU MAY 0.8>0[0]
AA DFW-SHV MAY 6>3[6]
AA DFW-SJC MAY 4>1.9[3]
AA DFW-SJD MAY 4>1.8[4]
AA DFW-SJO MAY 0.8>0[1.0]
AA DFW-SJT MAY 5>3[5]
AA DFW-SJU MAY 1.6>0[1.0]
AA DFW-SLC MAY 5>2[6]
AA DFW-SLP MAY 1.8>1.0[2]
AA DFW-SMF MAY 4>2.0[5]
AA DFW-SNA MAY 8>4[9]
AA DFW-SPS MAY 3>2.0[4]
AA DFW-STL MAY 8>4[8]
AA DFW-SUX MAY 1.0>0.2[1.0]
AA DFW-SWO MAY 3>1.0[3]
AA DFW-TGU MAY 0.4>0[0]
AA DFW-TLH MAY 3>1.9[3]
AA DFW-TLV SEP 0.3>0[0] OCT 0.4>0.1[0]
AA DFW-TPA MAY 7>4[7]
AA DFW-TRI MAY 2>1.0[0]
AA DFW-TUL MAY 9>5[9]
AA DFW-TUS MAY 7>4[6]
AA DFW-TXK MAY 3>1.9[4]
AA DFW-TYR MAY 4>1.9[4]
AA DFW-TYS MAY 5>2[5]
AA DFW-UIO MAY 0.6>0[0]
AA DFW-VPS MAY 6>2[5]
AA DFW-XNA MAY 8>3[8]
AA DFW-YUL MAY 0.8>0[1.0]
AA DFW-YVR MAY 1.8>1.0[3]
AA DFW-YYC MAY 1.8>1.0[2]
AA DFW-YYZ MAY 2>0.2[3]
AA DRO-PHX MAY 1.8>0.7[2]
AA DSM-ORD MAY 7>1.0[7]
AA DSM-PHL MAY 1.0>0.1[1.8]
AA DSM-PHX MAY 1.9>0.6[2]
AA DTW-LGA MAY 4>0[5]
AA DTW-MIA MAY 1.7>0.8[1.9]
AA DTW-ORD MAY 6>1.4[6]
AA DTW-PHL MAY 5>1.4[5]
AA DTW-PHX MAY 2>0.6[1.9]
AA DUB-ORD MAY 0.8>0[0.9]
AA DUB-PHL MAY 0.8>0[1.0]
AA ECP-ORD MAY 0.3>0[0.1]
AA EDI-PHL MAY 0.8>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.6>0[0.8]
AA ELP-LAX MAY 2>0[3]
AA ELP-ORD MAY 1.8>0.6[2.0]
AA ELP-PHX MAY 5>0.7[5]
AA EUG-LAX MAY 1.6>0[2.0]
AA EUG-PHX MAY 1.0>0.7[1.0]
AA EVV-ORD MAY 1.6>0[3]
AA EWR-MIA MAY 3>0.9[3]
AA EWR-ORD MAY 5>0.7[6]
AA EWR-PHX MAY 2>0[3]
AA EYW-MIA MAY 4>1.8[5]
AA EYW-ORD MAY 1.0>0.7[0.1]
AA EYW-PHL MAY 1.0>0.7[0.1]
AA EZE-JFK MAY 0.8>0[1.0]
**AA EZE-LAX MAY 0.3>0[0.5] JUN 0.4>0[0.4] JUL 0.5>0[0.5] AUG 0.4>0[0.4] SEP 0.4>0[0.4] OCT 0.4>0.1[0.4]
AA EZE-MIA MAY 1.5>0.7[1.9] JUN 1.8>0.9[1.9] JUL 1.9>1.0[1.8] AUG 1.9>1.0[1.9] SEP 1.8>1.0[1.9] OCT 1.9>1.2[1.8]
AA FAR-ORD MAY 3>0.7[3]
AA FAT-LAX MAY 3>0[3]
AA FAT-PHX MAY 5>0.7[5]
**AA FCO-JFK MAY 0.8>0[0.9] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
**AA FCO-ORD JUN 0.9>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
**AA FCO-PHL MAY 0.8>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
AA FLG-PHX MAY 4>0.7[4]
AA FLL-ORD MAY 0.9>0.6[0.9]
AA FLL-PHL MAY 4>1.7[4]
AA FNT-ORD MAY 3>0.7[4]
AA FSD-ORD MAY 3>0.8[3]
AA FSD-PHX MAY 1.0>0.7[1.0]
AA FWA-ORD MAY 4>0.8[3]
AA FWA-PHL MAY 1.0>0.1[2.0]
AA GCM-MIA MAY 2>0.7[2]
AA GDL-PHX MAY 0.8>0.6[1.0]
AA GEG-PHX MAY 2>0.7[2]
AA GEO-JFK MAY 0.8>0[0]
AA GEO-MIA MAY 0.8>0[1.0]
AA GGT-MIA MAY 1.8>0.8[1.1]
AA GIG-MIA MAY 0.8>0[1.0]
AA GJT-PHX MAY 3>0.7[3]
AA GNV-MIA MAY 1.7>0.1[1.8]
AA GRB-ORD MAY 4>0.8[4]
AA GRR-ORD MAY 6>1.3[6]
AA GRR-PHL MAY 1.9>0.2[3]
AA GRU-JFK MAY 0.8>0[1.0]
**AA GRU-LAX MAY 0.5>0[0.5] JUN 0.6>0[0.6] JUL 0.5>0[0.5] AUG 0.6>0[0.6] SEP 0.6>0[0.6] OCT 0.6>0.1[0.6]
AA GRU-MIA MAY 1.6>0.7[2] JUN 2>0.9[2] JUL 2>1.0[2] AUG 2>1.0[2] SEP 2>1.0[2] OCT 2>1.5[2]
AA GSO-LGA MAY 2>0[4]
AA GSO-MIA MAY 1.8>0.9[1.9]
AA GSO-ORD MAY 2>0.8[3]
AA GSO-PHL MAY 4>1.2[4]
AA GSP-MIA MAY 2.0>0.9[2]
AA GSP-ORD MAY 3>0.6[2]
AA GSP-PHL MAY 4>1.4[3]
AA GUA-MIA MAY 2>0.7[3]
AA GYE-MIA MAY 1.6>0.7[2]
AA HAV-MIA MAY 5>3[5]
AA HMO-PHX MAY 1.6>0.6[1.0]
AA HND-LAX MAY 1.6>0[1.0] JUN 2>0[1.0] JUL 2>0.8[1.0] AUG 2>1.0[1.0] SEP 2>1.0[1.0] OCT 2>1.3[1.0]
AA HNL-LAX MAY 4>1.0[4]
AA HNL-PHX MAY 1.6>0[1.6]
AA HPN-ORD MAY 3>0.7[3]
AA HSV-ORD MAY 1.5>0[1.6]
AA HVN-PHL MAY 2.0>0.7[3]
AA IAD-LAX MAY 1.6>0[1.0]
AA IAH-LAX MAY 2>0[3]
AA IAH-MIA MAY 4>1.6[5]
AA IAH-ORD MAY 3>0.7[3]
AA IAH-PHL MAY 2>0.6[3]
AA IAH-PHX MAY 4>0.7[4]
AA ICT-ORD MAY 3>0.7[3]
AA ILM-LGA MAY 2>0[3]
AA ILM-PHL MAY 4>1.3[3]
AA IND-JFK MAY 0.8>0[1.0]
AA IND-LAX MAY 1.6>0[1.0]
AA IND-LGA MAY 1.9>0[2]
AA IND-MIA MAY 3>1.6[3]
AA IND-ORD MAY 7>1.5[7]
AA IND-PHL MAY 6>1.5[6]
AA IND-PHX MAY 1.8>0.7[1.9]
AA IPT-PHL MAY 1.8>0.7[3]
AA ISP-PHL MAY 3>0.7[3]
AA ITH-PHL MAY 3>0.7[3]
AA JAX-MIA MAY 5>1.1[5]
AA JAX-ORD MAY 1.8>0.7[3]
AA JAX-PHL MAY 4>0.7[3]
AA JFK-LAX MAY 11>3[11] JUN 10>9[11]
AA JFK-LHR MAY 3>0[4] JUN 4>3[4] JUL 4>3[4] AUG 4>3[4] SEP 4>3[4]
AA JFK-MBJ MAY 0.8>0[0]
AA JFK-MIA MAY 5>2[5]
**AA JFK-MXP MAY 0.8>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
AA JFK-ORD MAY 1.5>0.0[1.5] JUN 1.0>0.8[1.9]
AA JFK-ORF MAY 1.6>0[3]
**AA JFK-PHL MAY 1.6>0[0.1] JUN 0.2>0[0]
AA JFK-PHX MAY 5>2[4]
AA JFK-PIT MAY 0.8>0[1.0]
AA JFK-RDU MAY 3>0[2]
AA JFK-RIC MAY 1.0>0[0]
AA JFK-SAT MAY 1.0>0.2[1.0]
AA JFK-SFO MAY 4>0.0[5]
AA JFK-SJO MAY 0.8>0[0]
AA JFK-SKB MAY 0.2>0[0.0]
AA JFK-YUL MAY 0.8>0[1.1]
AA JLN-ORD MAY 1.8>0.1[0]
AA KIN-MIA MAY 3>0.8[2]
AA KOA-LAX MAY 1.5>0[1.8]
AA KOA-PHX MAY 0.8>0[0.8]
**AA KRK-ORD MAY 0.6>0[0] JUN 0.7>0[0] JUL 0.7>0[0] AUG 0.7>0[0] SEP 0.7>0[0] OCT 0.5>0[0]
AA LAN-ORD MAY 3>0.7[2]
AA LAS-LAX MAY 7>0.0[7] JUN 7>6[7]
AA LAS-MIA MAY 3>1.5[3]
AA LAS-ORD MAY 4>1.2[4]
AA LAS-PHL MAY 1.9>0.2[4]
AA LAS-PHX MAY 6>0.8[5]
AA LAX-LHR MAY 1.6>0[2]
AA LAX-LIH MAY 1.7>0[1.5]
AA LAX-MCO MAY 3>0.0[3]
AA LAX-MFR MAY 0.8>0[1.0]
AA LAX-MIA MAY 9>3[7]
AA LAX-MSY MAY 0.8>0[0.4]
AA LAX-OGG MAY 3>0[3]
AA LAX-OKC MAY 1.6>0[2]
AA LAX-OMA MAY 1.6>0[2]
AA LAX-ORD MAY 9>3[10]
AA LAX-PDX MAY 2>0[3]
AA LAX-PHL MAY 7>2[7]
AA LAX-PHX MAY 7>4[7]
AA LAX-RDM MAY 0.8>0[1.6]
AA LAX-RDU MAY 1.4>0[1.0]
AA LAX-RNO MAY 4>0[4]
AA LAX-SAN MAY 4>0[5]
AA LAX-SAT MAY 2>0[3]
AA LAX-SDF MAY 0.8>0[0.9]
AA LAX-SEA MAY 4>0.0[5] NOV 5>4[4] DEC 5>4[4] JAN 5>4[4]
AA LAX-SFO MAY 6>0[8] JUN 7>6[8]
AA LAX-SJC MAY 5>0[5]
AA LAX-SLC MAY 2>0[3]
AA LAX-SMF MAY 3>0[4]
AA LAX-STL MAY 1.6>0[2]
AA LAX-STS MAY 0.8>0[0.9]
**AA LAX-SYD MAY 0.7>0[1.0] JUN 0.9>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
AA LAX-TUL MAY 0.8>0[1.0]
AA LAX-TUS MAY 3>0[3]
AA LAX-XNA MAY 1.6>0[2.0]
AA LAX-YVR MAY 1.6>0[2]
AA LBB-PHX MAY 0.8>0.6[1.0]
AA LEX-ORD MAY 3>0.6[3]
AA LEX-PHL MAY 3>0.1[3]
AA LGA-MCO MAY 1.4>0[1.0]
AA LGA-MEM MAY 1.8>0.0[1.7]
AA LGA-MIA MAY 12>4[10] JUN 12>11[10]
AA LGA-MSP MAY 2>0.0[1.8]
AA LGA-ORD MAY 10>2[12] JUN 11>10[12]
AA LGA-ORF MAY 2>0[3]
AA LGA-PHL MAY 4>1.0[4]
AA LGA-PIT MAY 5>0.0[6]
AA LGA-PWM MAY 3>0.0[1.9]
AA LGA-RDU MAY 6>0.1[7]
AA LGA-RIC MAY 3>0[5]
AA LGA-ROA MAY 0.8>0[1.0]
AA LGA-SDF MAY 2>0[2.0]
AA LGA-STL MAY 3>0.0[4]
AA LGA-TYS MAY 1.4>0[1.9]
AA LGA-XNA MAY 1.5>0[1.7]
AA LGA-YUL MAY 2>0[3]
AA LGA-YYZ MAY 3>0[4]
AA LGB-PHX MAY 3>0.6[3]
AA LHR-ORD MAY 3>0[4] JUN 4>3[4] JUL 4>3[4] AUG 4>3[4] SEP 4>3[4] OCT 4>3[4]
AA LHR-PHL MAY 1.6>0[2]
**AA LHR-PHX MAY 0.8>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0]
AA LHR-RDU MAY 0.8>0[1.0]
AA LIH-PHX MAY 0.9>0[0.7]
AA LIM-MIA MAY 2>1.4[2]
AA LIR-MIA MAY 1.5>0.7[1.9]
**AA LIS-PHL MAY 0.8>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[0.8] NOV 1.0>0[0] DEC 1.0>0[0]
AA LIT-ORD MAY 3>0.7[4]
AA LSE-ORD MAY 3>0.7[4]
AA MAD-MIA MAY 0.8>0[1.0]
AA MAD-PHL MAY 0.8>0[1.0]
AA MAF-PHX MAY 0.9>0.6[1.0]
**AA MAN-PHL MAY 0.8>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
AA MAO-MIA MAY 0.6>0[0.7]
AA MBJ-MIA MAY 3>0.8[3]
AA MBJ-PHL MAY 1.6>0[2]
AA MCI-MIA MAY 1.8>0.8[2]
AA MCI-ORD MAY 6>1.3[7]
AA MCI-PHL MAY 3>0.7[3]
AA MCI-PHX MAY 1.8>0.7[1.9]
AA MCO-MIA MAY 8>3[7]
AA MCO-ORD MAY 4>1.3[5]
AA MCO-PHL MAY 6>2[8]
AA MCO-PHX MAY 3>0.8[3]
AA MDE-MIA MAY 1.6>0.7[2]
AA MDT-ORD MAY 4>0.7[4]
AA MDT-PHL MAY 5>1.5[5]
AA MEI-ORD MAY 0.9>0.7[1.0]
AA MEM-MIA MAY 2>0.8[2]
AA MEM-ORD MAY 4>0.7[5]
AA MEM-PHL MAY 3>0.7[3]
AA MEM-PHX MAY 1.5>0[2]
AA MEX-MIA MAY 4>2[4]
AA MEX-PHX MAY 0.8>0.6[1.0]
AA MFR-PHX MAY 1.0>0.7[1.0]
AA MGA-MIA MAY 1.6>0.7[1.7]
AA MHK-ORD MAY 2>0.2[3]
AA MHT-ORD MAY 2>0.7[0]
AA MHT-PHL MAY 5>1.4[6]
AA MIA-MSP MAY 1.8>0.8[2]
AA MIA-MSY MAY 4>0.9[4]
AA MIA-MTY MAY 0.8>0[1.0]
**AA MIA-MXP MAY 0.8>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
AA MIA-NAS MAY 7>1.9[7]
AA MIA-OKC MAY 1.0>0.8[0]
AA MIA-ORD MAY 8>3[7]
AA MIA-ORF MAY 3>0.8[4]
AA MIA-PAP MAY 1.6>0.7[2]
AA MIA-PEI MAY 0.4>0[0.4]
AA MIA-PHL MAY 4>3[6]
AA MIA-PHX MAY 3>1.8[3]
AA MIA-PIT MAY 3>0.9[3]
AA MIA-PLS MAY 1.6>0.7[3]
AA MIA-PNS MAY 4>0.2[3]
AA MIA-POS MAY 1.6>0.7[2]
AA MIA-PTY MAY 1.6>0.7[2]
AA MIA-PUJ MAY 1.6>0.7[3]
AA MIA-RDU MAY 5>1.7[3]
AA MIA-RIC MAY 2>0.9[2]
AA MIA-RTB MAY 0.2>0[0.3]
AA MIA-SAN MAY 1.0>0.1[0.7]
AA MIA-SAT MAY 1.0>0.8[1.6]
AA MIA-SAV MAY 3>0.9[2]
AA MIA-SDF MAY 1.7>0.8[2]
AA MIA-SDQ MAY 3>1.4[3]
AA MIA-SEA MAY 0.9>0.1[1.0]
AA MIA-SFO MAY 3>1.7[2]
AA MIA-SJO MAY 2>0.7[3]
AA MIA-SJU MAY 5>1.6[6]
AA MIA-SKB MAY 1.4>0.7[1.1]
AA MIA-STL MAY 1.8>0.8[1.9]
AA MIA-STT MAY 2.6>0.8[2.0]
AA MIA-STX MAY 1.8>0.8[2.0]
AA MIA-SVD MAY 0.2>0[0.1]
AA MIA-TLH MAY 4>1.6[4]
AA MIA-TPA MAY 5>2[6]
AA MIA-TYS MAY 1.9>0.8[2]
AA MIA-UIO MAY 1.6>0.7[2.0]
AA MIA-UVF MAY 1.6>0.7[1.0]
AA MIA-XNA MAY 1.0>0.1[0]
AA MIA-YUL MAY 0.8>0[1.0]
AA MIA-YYZ MAY 0.8>0[3]
AA MKE-ORD MAY 4>1.9[3]
AA MKE-PHL MAY 3>0.7[4]
AA MKE-PHX MAY 2>0.7[1.9]
AA MLI-ORD MAY 3>0.7[4]
AA MQT-ORD MAY 1.0>0.7[1.0]
AA MRY-PHX MAY 3>0.6[4]
AA MSN-ORD MAY 5>0.7[5]
AA MSN-PHL MAY 1.9>0.7[1.9]
AA MSN-PHX MAY 1.0>0.7[0.1]
AA MSP-ORD MAY 5>1.3[6]
AA MSP-PHL MAY 1.7>0.7[3]
AA MSP-PHX MAY 3>0.7[3]
AA MSY-ORD MAY 2>0.7[1.8]
AA MSY-PHL MAY 1.0>0.7[3]
AA MYR-PHL MAY 3>0.7[2]
AA MZT-PHX MAY 1.0>0.7[1.0]
AA NAS-PHL MAY 0.8>0[1.0]
AA OAK-PHX MAY 3>0.7[4]
AA OGG-PHX MAY 0.9>0[1.1]
AA OKC-ORD MAY 3>0.7[5]
AA OKC-PHL MAY 0.8>0[1.8]
AA OKC-PHX MAY 2>0.8[2]
AA OMA-ORD MAY 5>1.3[6]
AA OMA-PHL MAY 1.0>0.1[2.0]
AA OMA-PHX MAY 1.0>0.7[1.1]
AA ONT-PHX MAY 5>0.7[5]
AA ORD-ORF MAY 1.9>0.6[2]
AA ORD-PBI MAY 1.6>0.6[1.1]
AA ORD-PDX MAY 1.6>0.6[1.8]
AA ORD-PHL MAY 6>3[9]
AA ORD-PHX MAY 8>3[8]
AA ORD-PIA MAY 3>0.7[3]
AA ORD-PIT MAY 5>1.4[6]
AA ORD-PNS MAY 0.3>0[0.1]
**AA ORD-PRG MAY 0.5>0[0] JUN 0.7>0[0] JUL 0.7>0[0] AUG 0.7>0[0] SEP 0.7>0[0] OCT 0.5>0[0]
AA ORD-PSP MAY 1.0>0.7[1.1]
AA ORD-PVD MAY 1.8>0.7[3]
AA ORD-RAP MAY 0.8>0.6[1.0]
AA ORD-RDU MAY 5>1.3[4]
AA ORD-RIC MAY 4>0.7[5]
AA ORD-ROC MAY 4>0.6[4]
AA ORD-RST MAY 4>0.8[4]
AA ORD-RSW MAY 2>0.6[2]
AA ORD-SAN MAY 4>0.7[3]
AA ORD-SAT MAY 3>0.1[3]
AA ORD-SAV MAY 1.0>0.6[1.1]
AA ORD-SCE MAY 1.9>0.7[2]
AA ORD-SDF MAY 4>1.3[4]
AA ORD-SEA MAY 3>0.7[4]
AA ORD-SFO MAY 4>0.7[4]
AA ORD-SGF MAY 4>1.5[4]
AA ORD-SJC MAY 0.8>0[1.7]
AA ORD-SJD MAY 0.3>0[0.3]
AA ORD-SJU MAY 0.8>0[0.7]
AA ORD-SLC MAY 3>1.3[3]
AA ORD-SMF MAY 0.8>0[0.9]
AA ORD-SNA MAY 3>0.7[4]
AA ORD-STL MAY 6>1.3[6]
AA ORD-SUX MAY 1.9>0.7[3]
AA ORD-SYR MAY 4>0.7[4]
AA ORD-TOL MAY 3>0.7[3]
AA ORD-TPA MAY 2>0.6[3]
AA ORD-TUL MAY 3>0.7[3]
AA ORD-TUS MAY 1.6>0.6[2]
AA ORD-TVC MAY 4>0.7[6]
AA ORD-TYS MAY 4>1.4[4]
**AA ORD-VCE JUN 0.9>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
AA ORD-VPS MAY 0.3>0[0.1]
AA ORD-XNA MAY 5>1.3[6]
AA ORD-YUL MAY 1.6>0.6[2]
AA ORD-YYC MAY 1.0>0.1[0]
AA ORD-YYZ MAY 4>1.4[5]
AA ORF-PHL MAY 5>1.5[6]
AA ORH-PHL MAY 1.0>0.7[1.7]
AA PBI-PHL MAY 3>1.3[3]
AA PDX-PHX MAY 3>0.7[3]
AA PHF-PHL MAY 3>0.7[3]
AA PHL-PHX MAY 6>2[7]
AA PHL-PIT MAY 5>1.4[6]
AA PHL-PLS MAY 0.3>0[0.3]
AA PHL-PNS MAY 1.0>0.1[1.0]
**AA PHL-PRG MAY 0.8>0[0.9] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[0.8] NOV 1.0>0[0] DEC 1.0>0[0]
AA PHL-PVD MAY 5>1.3[6]
AA PHL-PWM MAY 6>1.5[5]
AA PHL-RDU MAY 6>1.4[6]
AA PHL-RIC MAY 6>1.5[6]
AA PHL-ROA MAY 1.7>1.4[1.9]
AA PHL-ROC MAY 5>0.9[6]
AA PHL-RSW MAY 4>1.3[3]
AA PHL-SAN MAY 1.7>0.1[3]
AA PHL-SAV MAY 3>1.4[3]
AA PHL-SBY MAY 2>0.7[3]
AA PHL-SCE MAY 3>0.7[4]
AA PHL-SDF MAY 1.9>0.7[3]
AA PHL-SEA MAY 0.8>0[3]
AA PHL-SFO MAY 4>0.2[5]
AA PHL-SJU MAY 1.6>0[2.0]
**AA PHL-SNN MAY 0.8>0[0.8] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[0.9] OCT 0.2>0[0]
AA PHL-SRQ MAY 1.0>0.1[0.3]
AA PHL-STL MAY 4>1.4[5]
AA PHL-STT MAY 0.8>0[0.8]
AA PHL-SWF MAY 3>0.7[4]
AA PHL-SYR MAY 5>0.9[5]
AA PHL-TPA MAY 4>2[6]
**AA PHL-TXL JUN 0.9>0[0.5] JUL 1.0>0[0.6] AUG 1.0>0[0.6] SEP 1.0>0[0.5] OCT 0.2>0[0]
AA PHL-TYS MAY 3>0.8[3]
**AA PHL-VCE MAY 0.8>0[0.9] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
AA PHL-YOW MAY 1.7>0.7[2]
AA PHL-YUL MAY 4>0.7[5]
AA PHL-YYZ MAY 4>0.7[5]
AA PHL-ZRH MAY 0.8>0[1.0]
AA PHX-PIT MAY 0.8>0[1.1]
AA PHX-PSP MAY 5>0.8[5]
AA PHX-PVR MAY 1.1>0.1[1.2]
AA PHX-RAP MAY 0.8>0[0]
AA PHX-RDM MAY 1.0>0.7[1.0]
AA PHX-RDU MAY 1.0>0.1[0.9]
AA PHX-RNO MAY 5>0.8[5]
AA PHX-ROW MAY 0.8>0[1.0]
AA PHX-SAF MAY 1.6>0.6[1.9]
AA PHX-SAN MAY 5>0.8[5]
AA PHX-SAT MAY 4>0.8[3]
AA PHX-SBA MAY 4>0.7[5]
AA PHX-SBP MAY 4>0.7[4]
AA PHX-SEA MAY 3>0.7[3]
AA PHX-SFO MAY 3>0.8[5]
AA PHX-SGU MAY 3>0.8[3]
AA PHX-SJC MAY 4>0.7[5]
AA PHX-SJD MAY 3>0.7[3]
AA PHX-SLC MAY 4>0.7[4]
AA PHX-SMF MAY 4>0.7[5]
AA PHX-SNA MAY 5>0.8[5]
AA PHX-STL MAY 1.8>0.7[1.2]
AA PHX-STS MAY 2.0>0.7[1.0]
AA PHX-TPA MAY 1.6>0[2] JUN 0.2>0[2]
AA PHX-TUS MAY 6>1.3[7]
AA PHX-YUM MAY 4>1.2[5]
AA PIT-RDU MAY 0.8>0[1.0]
AC ANC-YVR MAY 0.7>0[0.7]
AC ATL-YYZ MAY 4>0[5]
AC AUS-YYZ MAY 1.8>0[1.9]
AC BDL-YUL MAY 1.0>0[0.8]
AC BDL-YYZ MAY 3>0[3]
AC BNA-YYZ MAY 2>0[3]
AC BOS-YHZ MAY 1.0>0[1.9]
AC BOS-YOW MAY 1.7>0[1.6]
AC BOS-YUL MAY 5>1.0[5]
AC BOS-YYZ MAY 6>3[7]
AC BWI-YUL MAY 1.0>0[1.0]
AC BWI-YYZ MAY 2>0[3]
AC CLE-YYZ MAY 4>0[4]
AC CLT-YYZ MAY 2>0[2]
AC CMH-YYZ MAY 4>0[4]
AC CVG-YYZ MAY 3>0[3]
AC DCA-YOW MAY 1.8>0[1.7]
AC DCA-YUL MAY 2>1.0[2]
AC DCA-YYZ MAY 4>3[4]
AC DEN-YUL MAY 0.7>1.0[1.0]
AC DEN-YVR MAY 1.8>1.0[1.9]
AC DEN-YYZ MAY 2>1.5[3]
AC DFW-YUL MAY 1.0>0[1.0]
AC DFW-YYZ MAY 3>0[4]
AC DTW-YYZ MAY 4>0[5]
AC EWR-YOW MAY 3>0[3]
AC EWR-YUL MAY 4>2[4]
AC EWR-YVR MAY 1.0>0[1.0]
AC EWR-YYC MAY 1.0>0[0.8]
AC EWR-YYZ MAY 6>3[7]
AC HNL-YVR MAY 0.6>0[0.6]
AC IAD-YUL MAY 2.0>1.0[2.0]
AC IAH-YYC MAY 2>0[2]
AC IAH-YYZ MAY 3>1.5[3]
AC IND-YYZ MAY 2>0[2]
AC LAS-YUL MAY 1.6>0[2]
AC LAS-YVR MAY 2>0[2]
AC LAS-YYC MAY 1.0>0[1.0]
AC LAS-YYZ MAY 1.7>0[2]
AC LAX-YUL MAY 2>1.0[2]
AC LAX-YVR MAY 4>2[4]
AC LAX-YYC MAY 1.0>0[2]
AC LAX-YYZ MAY 4>2.0[5]
AC LGA-YUL MAY 8>2[8]
AC LGA-YYZ MAY 12>3[12]
AC MCI-YYZ MAY 1.0>0[1.0]
AC MEM-YYZ MAY 1.0>0[1.0]
AC MIA-YUL MAY 0.7>0[0.7]
AC MIA-YYZ MAY 2>0[2]
AC MKE-YYZ MAY 1.8>0[1.7]
AC MSP-YYZ MAY 3>0[3]
AC MSY-YYZ MAY 2>0[1.0]
AC OGG-YVR MAY 0.4>0[0.4]
AC ORD-YUL MAY 3>2[5]
AC ORD-YVR MAY 1.0>0[1.0]
AC ORD-YYZ MAY 7>3[8]
AC PDX-YVR MAY 4>0[4]
AC PDX-YYC MAY 1.0>0[1.0]
AC PHL-YUL MAY 2.0>0[1.8]
AC PHL-YYZ MAY 3>0[4]
AC PHX-YUL MAY 0.6>0[0.6]
AC PHX-YVR MAY 1.0>0[1.0]
AC PHX-YYC MAY 1.0>0[1.0]
AC PHX-YYZ MAY 1.0>0[1.0]
AC PIT-YUL MAY 0.7>0[1.0]
AC PIT-YYZ MAY 2>0[4]
AC RDU-YUL MAY 1.0>0[0]
AC RDU-YYZ MAY 3>0[3]
AC RSW-YYZ MAY 0.6>0[0.5]
AC SAN-YVR MAY 3>1.0[3]
AC SAN-YYZ MAY 1.0>0[1.0]
AC SAV-YYZ MAY 1.0>0[0.9]
AC SEA-YVR MAY 5>3[6]
AC SEA-YYZ MAY 1.0>0[1.0]
AC SFO-YUL MAY 2.0>0[2]
AC SFO-YVR MAY 4>2[4]
AC SFO-YYC MAY 1.0>0[2]
AC SFO-YYZ MAY 3>2.0[4]
AC SJC-YVR MAY 2>0[3]
AC SMF-YVR MAY 1.0>0[1.0]
AC STL-YYZ MAY 2>0[3]
AC TPA-YYZ MAY 2>0[2.0]
AD FLL-VCP MAY 1.0>0.3[1.4]
AD MCO-VCP MAY 1.0>0.2[1.2]
AV BAQ-MIA MAY 1.0>0[1.0]
AV BOG-FLL MAY 1.0>0[1.0]
AV BOG-IAD MAY 2.0>1.0[1.0]
AV BOG-JFK MAY 3>1.0[3]
AV BOG-LAX MAY 1.0>0[1.0]
AV BOG-MCO MAY 1.1>0.6[1.0]
AV BOG-MIA MAY 4>1.0[3]
AV CLO-MIA MAY 1.0>0[1.0]
AV DFW-SAL MAY 1.0>0.4[1.0]
AV GUA-LAX MAY 1.0>0[1.0]
AV IAD-SAL MAY 3>1.0[3]
AV IAH-SAL MAY 1.0>0.6[1.0]
AV JFK-MDE MAY 0.5>0[1.0]
AV JFK-SAL MAY 1.9>1.0[2]
AV LAX-SAL MAY 4>1.0[3]
AV LIM-MIA MAY 2>0[1.0]
AV MDE-MIA MAY 1.0>0[1.0]
AV SAL-SFO MAY 2.0>0.6[2]
B6 did a schedule extension mixed in here, so quite a mess to read.
B6 ABQ-JFK MAY 0.6>0.3[0.8] DEC 0>0.8[0.9]
B6 ACK-BOS MAY 0.4>0.2[0.3]
B6 ACK-DCA MAY 0.2>0[0.1]
B6 ACK-JFK MAY 0.5>0.2[1.4]
B6 ANU-JFK MAY 0.3>0[0.4] OCT 0.5>0.6[0.5] NOV 0>0.9[0.7] DEC 0>0.9[0.7]
B6 ATL-BOS MAY 3>2[5] OCT 3>4[4] NOV 0>3[4] JAN 0>0.3[4]
B6 ATL-FLL OCT 1.5>2[2] DEC 0>2[3] JAN 0>0.3[3]
B6 ATL-JFK MAY 2.0>1.0[2] OCT 1.4>1.8[2] NOV 0>1.9[2] DEC 0>2.0[2] JAN 0>0.3[2]
B6 AUA-BOS OCT 1.3>1.6[1.6] NOV 0>1.7[1.6] DEC 0>2[1.8] JAN 0>0.5[1.7]
B6 AUA-FLL MAY 0.3>0[1.0] NOV 0>0.6[1.0] DEC 0>0.7[1.0]
B6 AUA-JFK OCT 1.0>1.4[1.9] NOV 0>1.6[2] JAN 0>0.4[1.5]
B6 AUS-BOS MAY 1.9>1.5[1.0] OCT 2>3[1.8] NOV 0>3[1.8] DEC 0>2.0[1.9]
B6 AUS-JFK OCT 2>3[1.8] NOV 0>2[1.6] DEC 0>2[1.6] JAN 0>0.2[1.9]
B6 BDA-BOS MAY 1.0>0[1.0] JUN 1.0>0.7[1.0] DEC 0>0.5[0.4]
B6 BDA-JFK MAY 0.5>0.1[1.0] DEC 0>0.6[0.5]
B6 BDL-FLL OCT 1.2>1.7[1.9] JAN 0>0.3[1.9]
B6 BDL-MCO OCT 2>3[2] DEC 0>2.0[2] JAN 0>0.3[2]
B6 BDL-SJU OCT 1.3>1.8[1.0] NOV 0>2.0[1.8] DEC 0>2.7[2.0] JAN 0>0.4[1.9]
B6 BGI-JFK MAY 1.0>0[2] JUN 3>2[1.9] OCT 1.2>1.6[1.7] NOV 0>1.9[1.7] DEC 0>2[1.7] JAN 0>0.3[1.9]
B6 BNA-BOS MAY 3>0.9[3] JUN 2>1.6[2] NOV 0>1.6[2] DEC 0>1.5[1.9]
B6 BNA-JFK OCT 1.5>1.9[0] NOV 0>1.7[0] DEC 0>1.7[0] JAN 0>0.3[0]
B6 BOG-FLL MAY 1.0>0.3[1.0] OCT 0.8>1.0[1.0] DEC 0>1.6[1.0] JAN 0>0.2[1.0]
B6 BOS-BUF OCT 2>3[4] JAN 0>0.3[3]
B6 BOS-BUR OCT 0.8>1.0[0.7] DEC 0>0.9[1.0]
B6 BOS-BWI MAY 5>3[6] OCT 4>5[5] JAN 0>0.3[4]
B6 BOS-CHS MAY 3>1.3[3] OCT 1.6>2[2] NOV 0>2.0[2] JAN 0>0.3[1.1]
B6 BOS-CLE MAY 3>1.9[3] JAN 0>0.4[3]
B6 BOS-CLT MAY 4>3[2] OCT 3>4[3] DEC 0>3[4] JAN 0>0.3[4]
B6 BOS-CUN MAY 0.6>0.3[0.5] OCT 0.3>0.5[0.3] NOV 0>1.1[0.7] DEC 0>1.1[0.8]
B6 BOS-DCA MAY 8>6[10] OCT 11>15[13] NOV 0>15[13] DEC 0>15[12] JAN 0>1.8[13]
B6 BOS-DEN MAY 1.8>0.8[1.9] NOV 0>1.9[1.7] DEC 0>1.8[1.7] JAN 0>0.2[1.7]
B6 BOS-DFW MAY 1.8>1.0[1.9] OCT 2>3[1.8] NOV 0>3[1.7] DEC 0>1.9[1.5]
B6 BOS-DTW MAY 3>2[3] OCT 3>4[3] JAN 0>0.3[3]
B6 BOS-EWR MAY 3>1.8[4] OCT 5>6[6] NOV 0>6[5] DEC 0>7[6] JAN 0>0.8[7]
B6 BOS-FLL OCT 4>5[6] NOV 0>5[6] DEC 0>6[7] JAN 0>0.9[6]
B6 BOS-JAX OCT 1.4>1.8[3] NOV 0>1.9[1.8] JAN 0>0.3[2]
B6 BOS-JFK OCT 5>6[6] JAN 0>0.5[5]
B6 BOS-LAS OCT 3>4[4] DEC 0>3[4] JAN 0>0.4[4]
B6 BOS-LAX OCT 4>5[4] NOV 0>5[4] JAN 0>0.5[4]
B6 BOS-LGA MAY 6>5[5] OCT 7>9[5] NOV 0>9[5] DEC 0>9[5] JAN 0>1.1[5]
B6 BOS-MBJ DEC 0>0.4[0.3]
B6 BOS-MCO OCT 6>7[7] NOV 0>7[8] DEC 0>8[7] JAN 0>1.1[6]
B6 BOS-MSP MAY 1.8>1.0[3] NOV 0>1.9[3] DEC 0>1.4[2]
B6 BOS-MSY MAY 1.8>1.5[2] JUN 1.3>1.0[1.4] OCT 1.7>2[2.0] NOV 0>1.9[2] DEC 0>1.3[1.5]
B6 BOS-MVY MAY 0.2>0[0]
B6 BOS-ORD OCT 3>4[5] DEC 0>3[4] JAN 0>0.3[4]
B6 BOS-PAP DEC 0>0.3[0.2]
B6 BOS-PBI OCT 3>4[4] NOV 0>5[6] JAN 0>0.9[5]
B6 BOS-PHL OCT 6>7[7] DEC 0>6[7] JAN 0>0.5[7]
B6 BOS-PIT OCT 4>5[6] JAN 0>0.4[5]
B6 BOS-PLS NOV 0>0.3[0.2] DEC 0>0.3[0.1]
B6 BOS-PUJ MAY 0.9>0.6[1.1] NOV 0>0.4[0.2] DEC 0>0.4[0.1]
B6 BOS-RDU OCT 4>5[6] DEC 0>4[5] JAN 0>0.4[5]
B6 BOS-RIC MAY 3>2.0[4] OCT 3>4[4] JAN 0>0.4[3]
B6 BOS-RSW OCT 2>3[3] DEC 0>5[6] JAN 0>0.8[5]
B6 BOS-SAN OCT 3>4[3] DEC 0>3[2] JAN 0>0.2[3]
B6 BOS-SAV OCT 1.4>1.8[1.6] NOV 0>1.7[1.2] DEC 0>1.8[1.4] JAN 0>0.3[1.2]
B6 BOS-SDQ MAY 1.6>1.0[1.9] OCT 0.8>1.0[1.5] NOV 0>1.0[2] JAN 0>0.4[1.9]
B6 BOS-SEA OCT 1.5>2.0[1.9] JAN 0>0.2[1.9]
B6 BOS-SFO OCT 5>6[6] NOV 0>6[5] DEC 0>5[4] JAN 0>0.5[5]
B6 BOS-SJU MAY 3.0>1.0[3.0] OCT 2.1>2.8[2.2] NOV 0>3.0[3.2] JAN 0>0.5[3.6]
B6 BOS-SLC DEC 0>0.7[0.8]
B6 BOS-SRQ OCT 0.8>1.0[1.0] DEC 0>1.0[1.1]
B6 BOS-STI MAY 1.0>0[1.0] JUN 1.7>1.3[1.4] OCT 0.8>1.0[1.0] DEC 0>1.7[1.6] JAN 0>0.3[1.1]
B6 BOS-SXM NOV 0>0.3[0.2] DEC 0>0.4[0.1]
B6 BOS-TPA OCT 2>3[4] DEC 0>4[5] JAN 0>0.6[4]
B6 BOS-UVF DEC 0>0.2[0.1]
B6 BTV-JFK MAY 2>1.0[3] OCT 2>3[3] JAN 0>0.3[3]
B6 BUF-FLL MAY 0.7>0[1.0] JUN 0.9>0.7[1.0] NOV 0>0.8[0.9] DEC 0>0.8[0.9]
B6 BUF-JFK MAY 4>3[5] OCT 4>5[6] NOV 0>5[6] DEC 0>5[6] JAN 0>0.5[5]
B6 BUR-JFK OCT 1.4>1.8[1.5] NOV 0>1.8[1.6] DEC 0>1.5[1.3]
B6 BZN-JFK DEC 0>0.2[0]
B6 BZN-LGB DEC 0>0.5[0.2]
B6 CHS-FLL MAY 1.0>0.6[1.0] OCT 0.5>0.7[1.0] NOV 0>1.0[1.7] DEC 0>1.0[0.9]
B6 CHS-JFK MAY 3>1.0[3] OCT 1.5>2[2] JAN 0>0.3[2.0]
B6 CLE-FLL MAY 0.7>0[1.0] JUN 0.9>0.7[1.0] NOV 0>0.7[1.0] DEC 0>0.8[1.0]
B6 CTG-FLL MAY 0.5>0[0.6] DEC 0>1.5[1.0] JAN 0>0.3[0.7]
B6 CTG-JFK MAY 0.7>0[0.4] JUN 1.0>0.8[0.6] OCT 0.5>0.7[0.4] NOV 0>1.0[0.6] DEC 0>1.4[0.9] JAN 0>0.3[1.0]
B6 CUN-FLL MAY 1.0>0.4[1.0] OCT 0.8>1.0[1.0] DEC 0>1.5[1.0] JAN 0>0.3[1.0]
B6 CUN-JFK OCT 2>3[1.8] NOV 0>3[2.0] DEC 0>3[1.6] JAN 0>0.4[1.4]
B6 CUN-MCO MAY 1.0>0.6[1.0] OCT 1.5>1.9[1.0] NOV 0>1.9[1.0] DEC 0>1.9[1.0] JAN 0>0.3[1.0]
B6 DCA-FLL MAY 3>2[5] OCT 5>7[5] DEC 0>5[6] JAN 0>0.6[6]
B6 DCA-MCO OCT 3>4[4] JAN 0>0.5[4]
B6 DCA-PBI MAY 1.0>0.6[1.0] OCT 1.5>2[1.2] DEC 0>2[1.9] JAN 0>0.3[1.9]
B6 DCA-RSW OCT 0.8>1.0[1.2] NOV 0>1.0[2] DEC 0>1.0[2]
B6 DEN-JFK DEC 0>1.5[1.0] JAN 0>0.3[1.0]
B6 EWR-FLL OCT 3>4[4] NOV 0>4[5] JAN 0>0.8[5]
B6 EWR-MCO OCT 4>5[6] NOV 0>8[7] JAN 0>1.0[7]
B6 EWR-PBI OCT 1.5>2[2] DEC 0>4[3] JAN 0>0.5[3]
B6 EWR-RSW OCT 0.8>1.2[2] NOV 0>1.8[2] DEC 0>1.9[2] JAN 0>0.3[1.9]
B6 EWR-SJU OCT 1.2>1.6[1.0] DEC 0>2.0[2.3]
B6 EWR-STI MAY 1.0>0.6[1.0] DEC 0>1.5[1.8] JAN 0>0.3[1.9]
B6 EWR-TPA OCT 1.5>2[2] JAN 0>0.3[2]
B6 FLL-GCM NOV 0>0.4[1.0] DEC 0>0.5[1.0]
B6 FLL-HAV MAY 1.8>1.0[3] OCT 2>3[3] JAN 0>0.4[3]
B6 FLL-HPN OCT 1.4>1.8[1.9] NOV 0>2[2.0] JAN 0>0.3[2]
B6 FLL-JAX OCT 3>4[3] DEC 0>4[3] JAN 0>0.5[3]
B6 FLL-JFK MAY 4>3[7] OCT 7>9[6] DEC 0>9[8] JAN 0>1.3[8]
B6 FLL-KIN MAY 1.0>0.4[2] OCT 1.3>1.8[2] JAN 0>0.6[2]
B6 FLL-LAS OCT 1.5>2.0[1.1] NOV 0>2[1.7] DEC 0>1.5[1.0]
B6 FLL-LAX OCT 2>3[3] NOV 0>4[3] DEC 0>4[3] JAN 0>0.5[4]
B6 FLL-LGA MAY 1.6>0.6[5] OCT 1.5>2[4] NOV 0>2[4] DEC 0>2[4] JAN 0>0.3[4]
B6 FLL-MBJ MAY 1.1>0.5[1.0] OCT 1.5>2.0[1.1] NOV 0>1.7[1.9] DEC 0>1.5[2]
B6 FLL-NAS OCT 2>3[4] NOV 0>3[4] JAN 0>0.5[3]
B6 FLL-ORD MAY 0.7>0[1.0] JUN 0.9>0.7[1.0] NOV 0>0.7[1.0] DEC 0>0.8[1.0]
B6 FLL-PAP MAY 1.0>0.6[2] OCT 0.8>1.2[2] DEC 0>3[2] JAN 0>0.4[1.3]
B6 FLL-PHL OCT 0.8>1.0[1.9] NOV 0>1.3[1.8] DEC 0>1.5[1.7] JAN 0>0.3[1.8]
B6 FLL-PHX MAY 0.7>0[1.0] JUN 0.9>0.7[1.0] NOV 0>0.8[1.0] DEC 0>0.9[1.0]
B6 FLL-PLS NOV 0>0.7[1.0] DEC 0>0.6[1.0]
B6 FLL-PUJ MAY 0.4>0.2[1.4] DEC 0>0.7[0.4]
B6 FLL-PVD OCT 0.8>1.0[1.0] DEC 0>1.5[1.0] JAN 0>0.3[1.0]
B6 FLL-RDU OCT 1.2>1.6[1.7] NOV 0>1.6[2] DEC 0>1.3[2]
B6 FLL-RIC OCT 0.6>0.8[1.2] NOV 0>1.0[2] DEC 0>1.9[2] JAN 0>0.4[2]
B6 FLL-SAN MAY 0.6>0[0.6] DEC 0>0.7[0.8]
B6 FLL-SDQ OCT 0.8>1.0[1.2] NOV 0>1.0[1.1] DEC 0>1.7[1.6] JAN 0>0.3[1.0]
B6 FLL-SFO OCT 2>3[2] NOV 0>3[2] DEC 0>3[2] JAN 0>0.3[2]
B6 FLL-SJO NOV 0>0.8[1.0] DEC 0>1.5[1.0] JAN 0>0.3[1.0]
B6 FLL-SJU OCT 3.1>4[5] NOV 0>4[5] DEC 0>5[5] JAN 0>0.8[5]
B6 FLL-SXM NOV 0>0.4[1.0] DEC 0>0.5[1.0]
B6 GCM-JFK MAY 0.6>0.2[0.7] NOV 0>0.6[0.9] DEC 0>0.7[1.0]
B6 GEO-JFK JUN 0.7>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0] OCT 0.8>0.2[0] NOV 0>1.0[0] DEC 0>1.0[0]
B6 GND-JFK MAY 0.7>0.4[0.8] OCT 0.7>0.9[0.7] NOV 0>1.0[0.8] DEC 0>1.1[1.0]
B6 GUA-JFK JUN 0.7>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0] OCT 0.8>0.2[0] NOV 0>1.0[0] DEC 0>1.0[0]
B6 GYE-JFK OCT 0.8>1.0[0] NOV 0>1.0[0] DEC 0>1.5[0.9] JAN 0>0.3[1.0]
B6 HPN-MCO OCT 2>3[3] JAN 0>0.4[3]
B6 HPN-PBI MAY 1.6>1.0[5] OCT 2>3[4] NOV 0>4[5] JAN 0>0.8[5]
B6 HPN-RSW OCT 1.5>2[1.0] NOV 0>2[1.0] DEC 0>2[1.0] JAN 0>0.3[1.7]
B6 HYA-JFK MAY 0.3>0[0]
B6 JAX-JFK MAY 2>1.0[3] OCT 2>3[3] JAN 0>0.4[3]
B6 JFK-KIN MAY 2>1.0[3] OCT 2>3[3] NOV 0>3[2] JAN 0>0.5[3]
B6 JFK-LAS OCT 4>5[4] NOV 0>4[3] JAN 0>0.4[3]
B6 JFK-LAX MAY 7>6[11] OCT 9>11[11] NOV 0>11[12] JAN 0>1.2[9]
B6 JFK-LGB OCT 1.4>1.8[1.9] NOV 0>1.9[1.8] JAN 0>0.2[1.9]
B6 JFK-MBJ OCT 1.5>2[3] JAN 0>0.4[2]
B6 JFK-MCO OCT 7>9[7] NOV 0>7[6] DEC 0>8[7] JAN 0>1.2[7]
B6 JFK-MSY MAY 1.6>1.0[4] OCT 1.5>2[3] JAN 0>0.3[1.1]
B6 JFK-MVY MAY 0.2>0[0.3]
B6 JFK-NAS MAY 1.0>0.6[1.8] OCT 0.8>1.1[1.0] DEC 0>1.5[1.8] JAN 0>0.3[1.2]
B6 JFK-ORD MAY 1.8>0[2] JUN 2>1.9[2] OCT 1.4>1.8[2] NOV 0>1.9[2] DEC 0>1.5[1.6]
B6 JFK-PAP MAY 1.0>0.4[2] OCT 0.8>1.0[2] NOV 0>1.0[2] DEC 0>1.7[1.5] JAN 0>0.3[1.3]
B6 JFK-PBI OCT 4>5[4] NOV 0>5[4] JAN 0>0.8[5]
B6 JFK-PDX MAY 0.6>0[0.6] NOV 0>0.6[0.7] DEC 0>0.7[0.8]
B6 JFK-PLS MAY 0.9>0.6[1.0] OCT 0.8>1.0[0.9] NOV 0>1.1[1.5] JAN 0>0.3[1.0]
B6 JFK-POP OCT 0.8>1.0[1.0] DEC 0>1.5[1.0] JAN 0>0.3[1.0]
B6 JFK-POS MAY 1.0>0[1.0] OCT 0.8>1.0[1.0] DEC 0>1.7[1.3] JAN 0>0.3[1.2]
B6 JFK-PSE MAY 1.0>0[0.6] NOV 0>0.7[1.0] DEC 0>0.8[1.0]
B6 JFK-PTP NOV 0>0.4[0] DEC 0>0.7[0]
B6 JFK-PUJ OCT 0.8>1.0[1.0] DEC 0>1.5[1.0] JAN 0>0.3[1.0]
B6 JFK-RDU MAY 2>1.0[2] OCT 1.5>2[3] JAN 0>0.3[1.9]
B6 JFK-RNO MAY 0.4>0[0.6] NOV 0>0.2[0.5] DEC 0>0.5[0.7]
B6 JFK-ROC MAY 3>1.0[3] JUN 3>2[3] OCT 2>3[3] JAN 0>0.4[3]
B6 JFK-RSW OCT 1.5>2[2] JAN 0>0.5[2]
B6 JFK-SAN MAY 2>1.0[1.9] OCT 1.5>2[3] NOV 0>3[2] JAN 0>0.2[1.9]
B6 JFK-SAV OCT 1.5>2[2] NOV 0>2[2.0] JAN 0>0.3[2]
B6 JFK-SDQ MAY 4>2[5] OCT 3>4[4] JAN 0>0.9[6]
B6 JFK-SFO OCT 5>7[6] NOV 0>7[6] DEC 0>6[5] JAN 0>0.6[6]
B6 JFK-SJC MAY 0.7>0[1.0] JUN 0.9>0.7[1.0] DEC 0>0.9[0.8]
B6 JFK-SJO DEC 0>0.4[0.5]
B6 JFK-SJU MAY 5>2.9[5] OCT 3.9>5[4] JAN 0>0.8[6]
B6 JFK-SLC OCT 1.5>2[2] DEC 0>2[2.0] JAN 0>0.3[2.0]
B6 JFK-SMF MAY 0.9>0.6[1.0] OCT 0.8>1.0[1.0] DEC 0>1.5[1.0] JAN 0>0.3[0.8]
B6 JFK-STI MAY 5>2[6] JUN 6>5[7] OCT 4>5[5] JAN 0>0.9[6]
B6 JFK-SXM OCT 0.8>1.0[1.0] NOV 0>1.6[1.0] DEC 0>1.7[1.0] JAN 0>0.3[0.9]
B6 JFK-SYR MAY 2>1.0[2] OCT 1.5>2[2] NOV 0>2.0[2] JAN 0>0.3[2]
B6 JFK-TPA MAY 3>2[3] OCT 2>3[3] NOV 0>3[4] DEC 0>3[4] JAN 0>0.5[3]
B6 JFK-UVF MAY 0.9>0.6[1.1] OCT 0.8>1.0[1.0] DEC 0>1.5[1.1] JAN 0>0.3[1.0]
B6 LAS-LGB MAY 1.0>0.7[3] OCT 1.5>2[3] NOV 0>2[3] DEC 0>2[3] JAN 0>0.3[3]
B6 LAX-MCO MAY 0.6>0[0.9] DEC 0>0.7[0.8]
B6 LGA-MCO MAY 1.6>1.0[4] OCT 1.5>2[4] NOV 0>2[3] DEC 0>2[3] JAN 0>0.3[3]
B6 LGA-PBI MAY 1.6>0.6[3] OCT 1.5>2[3] NOV 0>2[3] DEC 0>2[3] JAN 0>0.3[3]
B6 LGB-SEA MAY 1.0>0.6[2] OCT 1.5>2[2] DEC 0>1.5[2]
B6 LGB-SFO MAY 1.0>0[2] OCT 1.5>2[2] JAN 0>0.3[2]
B6 LGB-SLC MAY 2>1.6[3] OCT 2>3[3] JAN 0>0.4[3]
B6 MBJ-MCO MAY 1.5>0.4[1.0] JUN 2>1.5[1.0] OCT 1.5>1.9[1.0] NOV 0>1.3[1.0] DEC 0>1.5[1.0] JAN 0>0.3[0.8]
B6 MCO-PVD OCT 0.8>1.0[1.9] NOV 0>1.9[2] DEC 0>1.7[2] JAN 0>0.3[1.9]
B6 MCO-RIC MAY 1.0>0.7[1.7] OCT 0.8>1.2[1.2] JAN 0>0.4[1.6]
B6 MCO-SDQ MAY 1.0>0[1.0] OCT 0.8>1.0[1.0] DEC 0>1.5[1.0] JAN 0>0.3[1.0]
B6 MCO-SJO MAY 0.7>0.4[1.0] OCT 0.8>1.0[1.0] DEC 0>1.5[1.0] JAN 0>0.3[1.0]
B6 MCO-SJU MAY 5>3.7[7] OCT 3.1>4[6] DEC 0>6[7] JAN 0>0.8[6]
B6 SJU-TPA MAY 1.0>0.6[2.0] NOV 0>1.0[2.0] DEC 0>1.7[2.0]
I expected more from DL, they must have missed the pick up window.
DL ACK-LGA JUL 0.6>0.4[0.7] AUG 0.8>0.5[0.7]
DL ALB-DTW OCT 5>4[4] NOV 5>4[3] DEC 5>4[4] JAN 5>4[3]
DL ATL-GIG MAY 0.9>0.6[1.0]
DL ATL-JFK JUL 8>7[8] AUG 9>8[8] SEP 8>7[8] OCT 9>8[8] NOV 9>8[8] DEC 8>7[7] JAN 9>8[7]
DL ATL-PIT SEP 8>7[8] OCT 9>8[7] NOV 9>8[7]
DL AUS-JFK JUN 4>3[3] JUL 4>3[3] AUG 4>3[3]
DL CVG-JFK JUN 2>1.2[1.0] JUL 2>1.0[1.0] AUG 2>1.0[1.0] SEP 1.9>1.0[1.0] OCT 2>1.0[1.0] NOV 2>1.0[1.0] DEC 2>1.0[1.0] JAN 2>1.0[1.8]
DL DFW-LGA SEP 6>5[5]
DL DTW-JFK OCT 5>4[4] NOV 5>4[4] DEC 5>4[4] JAN 5>4[5]
DL DTW-ROC SEP 5>4[4] OCT 5>4[4] NOV 5>4[4] DEC 5>4[4] JAN 5>4[3]
DL DTW-SYR OCT 5>4[4] NOV 5>4[3] JAN 4>3[4]
DL EWR-SLC SEP 1.7>0.9[0.9] OCT 1.9>1.0[1.0] NOV 1.9>1.0[0.9] DEC 1.8>1.0[1.3]
DL HDN-MSP JAN 0>0.2[0.4]
DL JFK-KIN JUN 1.0>0.2[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 0.8>0[0.9] OCT 0.9>0[0.8] NOV 0.9>0[1.0] DEC 1.0>0.4[1.0]
DL JFK-RIC JUL 4>3[3]
DL LGA-MKE OCT 6>5[4] NOV 6>5[4] DEC 5>4[4] JAN 5>4[4]
DL LGA-MVY JUL 0.6>0.4[0.7] AUG 0.8>0.5[0.7]
DL PHL-SLC SEP 1.7>0.9[0.9] OCT 1.8>0.9[1.0] NOV 1.9>0.9[0.8] DEC 1.8>0.9[0.9] JAN 1.8>0.9[1.0]
*EW ANC-FRA JUN 0.4>0[0] JUL 0.4>0[0] AUG 0.5>0[0] SEP 0.4>0[0]
EW FRA-LAS MAY 0.4>0.6[0] JUN 0.4>0.7[0] JUL 0.4>0.7[0] AUG 0.4>0.7[0] SEP 0.4>0.7[0] OCT 0.4>0.6[0.1]
EW FRA-PHX MAY 0.7>0[0]
*EW LAS-MUC MAY 0.3>0[0] JUN 0.3>0[0] JUL 0.3>0[0] AUG 0.3>0[0] SEP 0.3>0[0] OCT 0.2>0[0]
*EW MCO-MUC JUN 0.4>0[0] JUL 0.4>0[0] AUG 0.4>0[0] SEP 0.4>0[0] OCT 0.3>0[0]
Wow
F9 ABQ-DEN MAY 0.6>0.0[0.5]
F9 ALB-DEN MAY 0.2>0[0.4]
F9 ALB-MCO MAY 0.4>0.1[0.4]
F9 ALB-RDU MAY 0.4>0[0.4]
F9 ATL-AUS MAY 0.4>0[0.6]
F9 ATL-CVG MAY 0.6>0.3[0.4]
F9 ATL-DEN MAY 1.0>0.5[1.4]
F9 ATL-EWR MAY 1.0>0[0]
F9 ATL-ISP MAY 0.6>0[0.6]
F9 ATL-LAS MAY 1.0>0.3[1.0]
F9 ATL-LAX MAY 0.4>0[0.4]
F9 ATL-LGA MAY 1.0>0.5[1.0]
F9 ATL-MCO MAY 1.0>0.5[1.0]
F9 ATL-MIA MAY 1.9>0.5[0.4]
F9 ATL-PHL MAY 1.0>0.5[0.4]
F9 ATL-RDU MAY 1.0>0[0]
F9 ATL-SAT MAY 0.4>0[0.4]
F9 ATL-SFO MAY 0.6>0[0.6]
F9 ATL-SJU MAY 1.0>0[0.4]
F9 ATL-SLC MAY 0.6>0[0.6]
F9 ATL-TPA MAY 1.0>0[0]
F9 ATL-TTN MAY 1.0>0.3[1.0]
F9 AUS-CLE MAY 0.3>0[0.4]
F9 AUS-DEN MAY 0.9>0.6[1.0]
F9 AUS-IAD MAY 0.3>0[0.5]
F9 AUS-LAS MAY 1.0>0.3[1.0]
F9 AUS-MCO MAY 1.0>0.3[0.6]
F9 AUS-ORD MAY 0.6>0.3[0.4]
F9 AUS-PHL MAY 0.3>0[0.6]
F9 AUS-SAN MAY 0.5>0[0.6]
F9 AUS-SEA MAY 0.4>0[0.1]
F9 AUS-SFO MAY 0.6>0[0.2]
F9 AUS-TPA MAY 0.3>0[0.1]
F9 BDL-DEN MAY 0.4>0[0.4]
F9 BDL-MCO MAY 0.6>0.1[0.4]
F9 BDL-RDU MAY 0.6>0[0.4]
F9 BIL-DEN MAY 0.4>0.0[0.0]
F9 BKG-DEN MAY 0.4>0[0.5]
F9 BMI-DEN MAY 0.4>0.0[0.4]
F9 BNA-DEN MAY 1.0>0.5[1.0]
F9 BNA-LAS MAY 0.4>0[0.4]
F9 BNA-MCO MAY 0.6>0.3[0.5]
F9 BNA-PHL MAY 0.6>0.3[0.4]
F9 BNA-TTN MAY 0.3>0[0.4]
F9 BOS-DEN MAY 0.6>0[1.0]
F9 BOS-MCO MAY 0.7>0.3[1.0]
F9 BOS-MIA MAY 1.0>0.3[0]
F9 BOS-PHL MAY 1.0>0[0]
F9 BOS-RDU MAY 0.6>0[0.6]
F9 BOS-SJU MAY 1.0>0[0]
F9 BTV-DEN MAY 0.4>0.0[0.5]
F9 BUF-DEN MAY 0.6>0.3[0.7]
F9 BUF-MCO MAY 0.6>0.4[0.9]
F9 BUF-RDU MAY 0.4>0[0.3]
F9 BUF-TPA MAY 0.4>0[0.4]
F9 BWI-DEN MAY 0.5>0.3[0.6]
F9 BWI-MCO MAY 1.0>0.4[0.4]
F9 BWI-MIA MAY 0.8>0.3[0]
F9 BWI-SJU MAY 1.0>0[0]
F9 BZN-DEN MAY 0.6>0.3[0.6]
F9 CID-DEN MAY 0.6>0.2[0.5]
F9 CLE-DEN MAY 1.0>0.3[1.4]
F9 CLE-LAS MAY 1.0>0[1.0]
F9 CLE-MCO MAY 2>1.0[1.2]
F9 CLE-PHX MAY 0.6>0[0.5]
F9 CLE-RDU MAY 0.6>0[0.6]
F9 CLE-RSW MAY 1.0>0.4[1.0]
F9 CLE-TPA MAY 1.4>0.5[1.4]
F9 CLT-DEN MAY 1.0>0.3[1.0]
F9 CLT-LAS MAY 1.0>0[0]
F9 CLT-MCO MAY 1.0>0.4[0.6]
F9 CLT-PHL MAY 1.0>0.5[0.8]
F9 CLT-TTN MAY 0.6>0.3[0.6]
F9 CMH-DEN MAY 0.4>0.0[0.5]
F9 CMH-MCO MAY 0.4>0.1[0.3]
F9 COS-LAS MAY 1.0>0.4[1.3]
F9 COS-MCO MAY 0.4>0[0.4]
F9 COS-PHX MAY 1.0>0.3[1.0]
F9 CUN-DEN MAY 0.4>0[0.6]
F9 CUN-EWR MAY 0.4>0[0]
F9 CUN-ORD MAY 0.4>0.1[1.0]
F9 CUN-PHL MAY 0.4>0.1[0.6]
F9 CUN-STL MAY 0.4>0.1[1.0]
F9 CVG-DEN MAY 1.0>0.5[1.2]
F9 CVG-DFW MAY 0.4>0[0.5]
F9 CVG-LAS MAY 1.0>0.3[1.0]
F9 CVG-LAX MAY 0.6>0[0]
F9 CVG-MCO MAY 0.9>0.6[0.9]
F9 CVG-MSP MAY 0.3>0[0.4]
F9 CVG-SAN MAY 0.4>0[0.3]
F9 CVG-TPA MAY 0.6>0.3[0.6]
F9 DCA-DEN MAY 3>1.5[3]
F9 DEN-DFW MAY 2>1.1[2]
F9 DEN-DSM MAY 0.6>0.4[0.5]
F9 DEN-DTW MAY 1.0>0[0.7]
F9 DEN-ELP MAY 0.6>0.3[0.3]
F9 DEN-EWR MAY 1.0>0[0]
F9 DEN-FAR MAY 0.6>0.3[0.5]
F9 DEN-FAT MAY 0.6>0.3[0.4]
F9 DEN-FSD MAY 0.6>0.3[0.6]
F9 DEN-GEG MAY 0.6>0.1[0.3]
F9 DEN-GRB MAY 0.4>0[0.1]
F9 DEN-GRR MAY 0.6>0.2[0.6]
F9 DEN-HSV MAY 0.4>0[0.4]
F9 DEN-IAH MAY 0.9>1.1[2]
F9 DEN-ICT MAY 0.4>0.0[0.4]
F9 DEN-LAS MAY 4>1.5[3]
F9 DEN-LAX MAY 3>1.0[1.4]
F9 DEN-LIT MAY 0.4>0.1[0.5]
F9 DEN-MCI MAY 1.0>0.4[1.0]
F9 DEN-MCO MAY 1.6>0.6[2.0]
F9 DEN-MEM MAY 0.6>0.3[0.6]
F9 DEN-MIA MAY 1.0>0.3[1.0]
F9 DEN-MKE MAY 0.7>0.3[1.0]
F9 DEN-MSN MAY 0.6>0.2[0.5]
F9 DEN-MSO MAY 0.4>0.2[0.5]
F9 DEN-MSP MAY 0.9>0.6[2]
F9 DEN-MSY MAY 1.0>0.3[0.8]
F9 DEN-OKC MAY 0.4>0.0[0.4]
F9 DEN-ONT MAY 1.0>0.6[0.7]
F9 DEN-ORD MAY 1.0>0.5[1.7]
F9 DEN-ORF MAY 0.4>0[0.4]
F9 DEN-PDX MAY 2>0.5[1.8]
F9 DEN-PHL MAY 1.0>0.4[1.0]
F9 DEN-PHX MAY 3>1.9[1.8]
F9 DEN-PIT MAY 0.4>0[0.4]
F9 DEN-PWM MAY 0.4>0[0.5]
F9 DEN-RDU MAY 1.0>0.3[1.0]
F9 DEN-RNO MAY 0.3>0[0.3]
F9 DEN-RSW MAY 0.6>0[0.5]
F9 DEN-SAN MAY 2>1.0[2]
F9 DEN-SAT MAY 0.6>0.1[1.0]
F9 DEN-SDF MAY 0.5>0[0.6]
F9 DEN-SEA MAY 2>0.5[2.0]
F9 DEN-SFO MAY 3>1.0[2]
F9 DEN-SLC MAY 3>1.9[1.9]
F9 DEN-SMF MAY 1.0>0.3[0.6]
F9 DEN-SNA MAY 1.0>0.2[1.4]
F9 DEN-STL MAY 0.9>0.6[2]
F9 DEN-SYR MAY 0.4>0[0.6]
F9 DEN-TPA MAY 1.0>0.3[1.0]
F9 DEN-TUL MAY 0.4>0.1[0.3]
F9 DEN-TYS MAY 0.6>0[0.5]
F9 DEN-XNA MAY 0.4>0.2[0]
F9 DFW-EWR MAY 1.0>0[0]
F9 DFW-LAS MAY 0.6>0.3[0.6]
F9 DFW-MCO MAY 1.0>0.3[0.6]
F9 DFW-PHL MAY 0.3>0[0.4]
F9 DTW-LAS MAY 1.0>0[0.7]
F9 DTW-MCO MAY 0.9>0.4[0.6]
F9 DTW-MIA MAY 0.6>0.3[0]
F9 DTW-PHX MAY 1.0>0[0]
F9 DTW-RDU MAY 0.3>0[0.4]
F9 DTW-TTN MAY 0.3>0[0.3]
F9 ELP-ORD MAY 0.3>0[0.3]
F9 EWR-LAS MAY 1.0>0[0]
F9 EWR-MCO MAY 2>0.6[0]
F9 EWR-MIA MAY 2>0.3[0]
F9 EWR-ONT MAY 1.0>0[0]
F9 EWR-ORD MAY 1.0>0[0]
F9 EWR-PBI MAY 0.9>0[0]
F9 EWR-PHX MAY 1.0>0[0]
F9 EWR-RDU MAY 1.0>0[0]
F9 EWR-SDQ MAY 0.4>0[0]
F9 EWR-SJU MAY 2.0>0[0]
F9 EWR-TPA MAY 1.0>0[0]
F9 HSV-MCO MAY 0.3>0.0[0.4]
F9 IAH-MCO MAY 0.5>0.3[0.4]
F9 IAH-PHL MAY 0.2>0[0.5]
F9 IAH-RDU MAY 0.4>0[0.3]
F9 ILG-MCO MAY 0.3>0[0]
F9 IND-LAS MAY 0.3>0[0.4]
F9 IND-MCO MAY 0.6>0.3[0.6]
F9 ISP-MCO MAY 1.3>0.6[0.7]
F9 ISP-MIA MAY 0.7>0.3[0]
F9 ISP-MYR MAY 0.4>0[0.6]
F9 ISP-RDU MAY 0.4>0[0.4]
F9 ISP-TPA MAY 0.6>0.3[0.4]
F9 JAX-PHL MAY 0.6>0.0[0.6]
F9 JAX-TTN MAY 0.4>0[0.4]
F9 LAS-LAX MAY 1.0>0.5[0]
F9 LAS-MCO MAY 1.0>0.3[0.7]
F9 LAS-MIA MAY 1.0>0[0]
F9 LAS-MKE MAY 0.6>0.3[0.3]
F9 LAS-ONT MAY 1.0>0[0]
F9 LAS-ORD MAY 1.0>0.5[1.0]
F9 LAS-PDX MAY 0.6>0.3[0]
F9 LAS-PHL MAY 1.0>0[1.0]
F9 LAS-PHX MAY 1.6>0.5[0]
F9 LAS-RDU MAY 1.0>0[1.0]
F9 LAS-SAN MAY 1.0>0.6[0.7]
F9 LAS-SAT MAY 0.7>0.1[0.5]
F9 LAS-SFO MAY 1.0>0.5[0.6]
F9 LAS-SLC MAY 1.0>0.5[0.4]
F9 LAS-SMF MAY 1.0>0.6[1.0]
F9 LAS-SNA MAY 0.3>0.6[0]
F9 LAS-STL MAY 1.0>0.3[1.0]
F9 LAS-TPA MAY 1.0>0[1.0]
F9 LAX-PHL MAY 1.0>0[0]
F9 LAX-PHX MAY 1.0>0[0]
F9 LGA-MCO MAY 1.0>0.5[0]
F9 LGA-MIA MAY 1.0>0.4[0]
F9 MCO-MDT MAY 0.3>0.0[0.4]
F9 MCO-MEM MAY 0.6>0.3[0.3]
F9 MCO-MKE MAY 1.0>0.3[0.7]
F9 MCO-MSP MAY 0.5>0[1.0]
F9 MCO-ONT MAY 1.0>0[0.7]
F9 MCO-ORD MAY 1.0>0.5[0.7]
F9 MCO-PHL MAY 4>1.5[3]
F9 MCO-PUJ MAY 0.2>0[0.4]
F9 MCO-PWM MAY 0.4>0.1[0.4]
F9 MCO-SJU MAY 2.0>0.6[1.3]
F9 MCO-STL MAY 1.3>0.5[1.0]
F9 MCO-SYR MAY 0.4>0.1[0.4]
F9 MCO-TTN MAY 1.0>0.6[1.0]
F9 MIA-ONT MAY 1.0>0[0]
F9 MIA-ORD MAY 1.0>0[0]
F9 MIA-PHL MAY 1.0>0.5[0.6]
F9 MIA-RDU MAY 0>0.3[0]
F9 MIA-SDQ MAY 0.4>0[0]
F9 MIA-SJU MAY 1.0>0.3[0]
F9 MKE-TPA MAY 0.3>0[0.4]
F9 MSY-PHL MAY 0.6>0.3[0.7]
F9 MYR-PHL MAY 0.4>0[0.3]
F9 MYR-TTN MAY 0.5>0[0.4]
F9 ORD-PHL MAY 0.2>0[0]
F9 ORD-PHX MAY 0.7>0.3[0.5]
F9 ORD-PUJ MAY 0.4>0[1.0]
F9 ORD-SJU MAY 0.5>0[0]
F9 ORD-TPA MAY 0.9>0[0.4]
F9 ORD-TTN MAY 0.9>0.3[1.0]
F9 PBI-TTN MAY 0.6>0.3[0.4]
F9 PHL-RSW MAY 1.0>0.6[0.7]
F9 PHL-SJU MAY 2.0>0[1.0]
F9 PHL-TPA MAY 1.0>0.6[1.0]
F9 PHX-SAN MAY 1.0>0.5[0]
F9 PHX-SJC MAY 1.0>0[0]
F9 PHX-SLC MAY 1.0>0.5[0]
F9 PUJ-STL MAY 0.2>0[0.4]
F9 PWM-RDU MAY 0.4>0[0.5]
F9 RDU-SJU MAY 0.4>0[0.3]
F9 RDU-SYR MAY 0.6>0.3[0.4]
F9 RDU-TTN MAY 0.6>0.3[0.5]
F9 RSW-TTN MAY 0.6>0.3[0.4]
F9 SJU-TPA MAY 0.6>0[0]
F9 TPA-TTN MAY 0.7>0.3[0.6]
FJ LAX-NAN MAY 0.7>0[1.0]
G7 ORD-STL MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0.3] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0]
This must be a filing error, right? They deleted their whole schedule till Halloween?
HA AKL-HNL JUN 0.4>0[0.5] JUL 0.4>0[0.7] AUG 0.4>0[0.5] SEP 0.4>0[0.6] OCT 0.5>0.1[0.6]
HA BNE-HNL JUN 0.4>0[0.4] JUL 0.5>0[0.4] AUG 0.4>0[0.4] SEP 0.4>0[0.5] OCT 0.4>0.1[0.5]
HA BOS-HNL MAY 0.7>0[0.7] JUN 0.7>0[0.9] JUL 0.7>0[0.8] AUG 0.7>0[0.9] SEP 0.7>0[0.8] OCT 0.7>0.2[0.7]
HA CTS-HNL AUG 0.4>0[0.5] SEP 0.4>0[0.4] OCT 0.5>0.1[0.5]
HA FUK-HNL MAY 0.5>0[0] JUN 0.6>0[0] JUL 0.5>0[0] AUG 0.6>0[0] SEP 0.6>0[0] OCT 0.6>0.1[0]
HA HND-HNL MAY 3>0[1.5] JUN 3>0[1.6] JUL 3>0[1.6] AUG 3>0[1.6] SEP 3>0[1.6] OCT 3>0.6[1.6]
HA HND-KOA MAY 0.4>0[0.5] JUN 0.4>0[0.4] JUL 0.5>0[0.4] AUG 0.4>0[0.4] SEP 0.4>0[0.4] OCT 0.4>0.1[0.4]
HA HNL-ICN MAY 0.7>0[0.7] JUN 0.7>0[0.7] JUL 0.7>0[0.7] AUG 0.7>0[0.7] SEP 0.7>0[0.7] OCT 0.7>0.2[0.7]
HA HNL-ITO MAY 13>0[15] JUN 13>0[15] JUL 13>0[14] AUG 13>0[14] SEP 13>0[14] OCT 13>3[14]
HA HNL-JFK MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
HA HNL-KIX MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 2.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
HA HNL-KOA MAY 18>0[19] JUN 19>0[21] JUL 19>0[21] AUG 19>0[21] SEP 19>0[19] OCT 19>4[19]
HA HNL-LAS MAY 3>0[3] JUN 3>0[3] JUL 3>0[3] AUG 3>0[3] SEP 3>0[3] OCT 3>0.6[3]
HA HNL-LAX MAY 3>0[3] JUN 3>0[3] JUL 3>0[3] AUG 3>0[3] SEP 3>0[3] OCT 3>0.7[3]
HA HNL-LGB MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
HA HNL-LIH MAY 18>0[18] JUN 19>0[20] JUL 19>0[20] AUG 20>0[20] SEP 19>0[18] OCT 18>4[18]
HA HNL-LNY MAY 4>0[5] JUN 4>0[5] JUL 4>0[5] AUG 4>0[5] SEP 4>0[5] OCT 4>0.9[5]
HA HNL-MKK MAY 3>0[3] JUN 3>0[3] JUL 3>0[3] AUG 3>0[3] SEP 3>0[3] OCT 3>0.7[3]
HA HNL-NRT MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[2] SEP 1.0>0[2.0] OCT 1.0>0.2[1.0]
HA HNL-OAK MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[0.9] OCT 1.0>0.2[1.0]
HA HNL-OGG MAY 25>0[27] JUN 26>0[27] JUL 26>0[26] AUG 26>0[26] SEP 26>0[27] OCT 26>6[27]
HA HNL-PDX MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
HA HNL-PHX MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
HA HNL-PPG JUN 0.2>0[0.2] JUL 0.2>0[0.2] AUG 0.2>0[0.2]
HA HNL-SAN MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
HA HNL-SEA MAY 1.4>0[1.0] JUN 1.4>0[1.0] JUL 1.4>0[1.0] AUG 1.4>0[1.0] SEP 1.4>0[1.0] OCT 1.4>0.3[1.0]
HA HNL-SFO MAY 2.0>0[1.0] JUN 2>0[1.0] JUL 2>0[1.0] AUG 2>0[1.0] SEP 2>0[1.0] OCT 2>0.5[1.5]
HA HNL-SJC MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
HA HNL-SMF MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
HA HNL-SYD MAY 1.0>0[1.0] JUN 0.8>0[1.0] JUL 1.0>0[1.0] AUG 0.8>0[0.9] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
HA ITO-OGG MAY 2>0[2] JUN 2>0[2] JUL 2>0[2] AUG 2>0[2] SEP 2>0[2] OCT 2>0.5[2]
HA KOA-LAX MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
HA KOA-LIH MAY 1.0>0[1.0] JUN 1.0>0[1.1] JUL 1.0>0[1.1] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
HA KOA-OGG MAY 3>0[3] JUN 3>0[3] JUL 3>0[3] AUG 3>0[3] SEP 3>0[3] OCT 3>0.7[3]
HA LAS-OGG MAY 0.6>0[0] JUN 0.6>0[0] JUL 0.6>0[0] AUG 0.6>0[0] SEP 0.6>0[0] OCT 0.6>0.1[0]
HA LAX-LIH MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
HA LAX-OGG MAY 1.3>0[1.0] JUN 2>0[1.0] JUL 2>0[1.0] AUG 2.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
HA LIH-OAK MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
HA LIH-OGG MAY 4>0[3] JUN 4>0[3] JUL 4>0[3] AUG 4>0[4] SEP 4>0[3] OCT 4>0.9[3]
HA OAK-OGG MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
HA OGG-PDX MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
HA OGG-SAN MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
HA OGG-SEA MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
HA OGG-SFO MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
HA OGG-SJC MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
HA OGG-SMF MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
K3 CGA-KLW MAY 1.6>1.3[1.7] JUN 1.7>1.4[1.7] JUL 1.7>1.3[1.7] AUG 1.7>1.3[1.7] SEP 1.7>1.3[1.7] OCT 1.7>1.3[1.7] NOV 1.7>1.2[1.6] DEC 1.7>1.3[0] JAN 1.7>1.3[0]
K3 CGA-KTB MAY 0.8>0.5[0.9] JUN 0.9>0.5[0.8] JUL 0.8>0.5[0.9] AUG 0.8>0.5[0.9] SEP 0.8>0.5[0.9] OCT 0.8>0.5[0.8] NOV 0.8>0.5[0.8] DEC 0.9>0.5[0] JAN 0.8>0.5[0]
K3 HYL-KLW MAY 0.7>0[0.7] JUN 0.9>0[0.8] JUL 0.8>0[0.9] AUG 0.8>0[0.9] SEP 0.8>0[0.1] OCT 0.8>0[0] NOV 0.8>0[0] DEC 0.9>0[0] JAN 0.8>0[0]
K3 HYL-KTN MAY 0.4>0[0.4] JUN 0.4>0[0.4] JUL 0.4>0[0.4] AUG 0.4>0[0.4] SEP 0.4>0[0.1] OCT 0.4>0[0] NOV 0.4>0[0] DEC 0.4>0[0] JAN 0.4>0[0]
*LH DTW-MUC MAY 0.6>0[0] JUN 0.7>0[0] JUL 0.7>0[0] AUG 0.7>0[0] SEP 0.7>0[0] OCT 0.6>0[0]
*LH MUC-SEA JUN 0.9>0[0] JUL 0.8>0[0] AUG 0.9>0[0] SEP 0.9>0[0] OCT 0.6>0[0]
LX IAD-ZRH MAY 1.0>0[0]
*MU HNL-PVG OCT 0.2>0[0.8] NOV 0.9>0[0.9] DEC 0.8>0[0.9] JAN 0.9>0[0.8]
*MU SFO-TAO NOV 0.4>0[0.4] DEC 0.5>0[0.4] JAN 0.4>0[0.4]
enilria
Re: OAG Changes 4/5/2020: Jaw-Dropping
Sun Apr 05, 2020 11:48 am
Wow, I hit the character post limit. Not good
NK ACY-ATL MAY 0.4>0.0[1.0]
NK ACY-FLL MAY 1.6>0.9[2]
NK ACY-MCO MAY 2>1.0[2]
NK ACY-MYR MAY 1.0>0.6[1.0]
NK ACY-RSW MAY 1.0>0.6[1.0]
NK ACY-TPA MAY 1.0>0.6[1.0]
NK ATL-AUS MAY 1.0>0[0.3] JUN 1.0>0.7[1.0]
NK ATL-BOS MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK ATL-BWI MAY 2>0.9[3]
NK ATL-DTW MAY 2>1.0[3]
NK ATL-FLL MAY 3>1.4[4]
NK ATL-IAH MAY 1.0>0.6[1.0]
NK ATL-LAS MAY 1.0>0[1.0]
NK ATL-LAX MAY 0.7>0[1.0]
NK ATL-MCO MAY 1.0>0.6[2]
NK ATL-MSP MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK ATL-MSY MAY 0.4>0.6[1.0]
NK ATL-ORD MAY 0.4>0.6[1.0]
NK ATL-PHL MAY 0.4>0.6[1.0]
NK AUS-BWI MAY 0.6>0[1.0]
NK AUS-CUN MAY 0.6>0[0]
NK AUS-EWR MAY 1.0>0[0] JUN 1.0>0.7[0]
NK AUS-LAS MAY 0.6>0[1.0]
NK AUS-LAX MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK AUS-MSY MAY 0.6>0[1.0]
NK AUS-ORD MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK AVL-MCO MAY 0.3>0[0.6]
NK AXM-FLL MAY 0.4>0[0.5]
NK BDL-FLL MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK BDL-MCO MAY 1.0>0[2]
NK BDL-MYR MAY 2>0.6[1.3]
NK BNA-BWI MAY 0.6>0[0]
NK BNA-CUN MAY 0.4>0[0]
NK BNA-EWR MAY 1.0>0[0] JUN 1.0>0.7[0]
NK BNA-FLL MAY 1.0>0.6[0]
NK BNA-LAS MAY 0.6>0[0]
NK BNA-LAX MAY 0.4>0[0]
NK BNA-MCO MAY 1.0>0.6[0]
NK BNA-MSY MAY 0.4>0[0]
NK BNA-TPA MAY 1.0>0[0] JUN 1.0>0.7[0]
NK BOG-FLL MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK BOG-MCO MAY 0.6>0[1.0]
NK BOS-BWI MAY 2>0[2] JUN 2>1.4[2]
NK BOS-DFW MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK BOS-DTW MAY 0.6>0[1.0]
NK BOS-FLL MAY 2>0.7[2]
NK BOS-LAS MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK BOS-MCO MAY 2>0.5[2] JUN 2>1.6[2]
NK BOS-MSY MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK BOS-MYR MAY 1.3>0.6[1.0]
NK BOS-ORD MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK BOS-SJU MAY 1.0>0[0]
NK BQN-FLL MAY 0.4>0[1.0]
NK BQN-MCO MAY 0.6>0[1.0]
NK BUR-LAS MAY 1.0>0.6[0]
NK BWI-CLT MAY 0.4>0[0]
NK BWI-CUN MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK BWI-DTW MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK BWI-FLL MAY 3>0.9[3]
NK BWI-IAH MAY 1.0>0.6[1.0]
NK BWI-JAX MAY 0.6>0[1.0]
NK BWI-LAS MAY 1.0>0.5[1.0]
NK BWI-LAX MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK BWI-MBJ MAY 0.3>0[1.0] JUN 1.0>0.7[1.0]
NK BWI-MCO MAY 3>1.0[3]
NK BWI-MSP MAY 0.6>0[1.0]
NK BWI-MSY MAY 1.0>0.5[1.0]
NK BWI-MYR MAY 1.1>0.6[1.5]
NK BWI-ORD MAY 1.8>0.6[2.0]
NK BWI-SJU MAY 1.0>0[1.0]
NK BWI-TPA MAY 1.0>0.5[1.6]
NK CAK-MCO MAY 1.0>0.5[1.0]
NK CLE-CUN MAY 0.6>0[0]
NK CLE-DFW MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK CLE-LAS MAY 1.0>0.5[1.0]
NK CLE-LAX MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK CLE-MCO MAY 1.6>0.9[1.0]
NK CLE-MSY MAY 0.4>0[0.4]
NK CLE-MYR MAY 1.0>0.5[1.0]
NK CLE-TPA MAY 0.6>0[0.0]
NK CLO-FLL MAY 0.6>0[1.0]
NK CLT-EWR MAY 1.0>0[0] JUN 1.0>0.7[0.4]
NK CLT-MCO MAY 1.0>0.6[0]
NK CMH-LAS MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK CRW-MCO MAY 0.4>0[0]
NK CTG-FLL MAY 0.6>0[0.6]
NK CUN-DFW MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK CUN-DTW MAY 1.0>0[0.2] JUN 1.0>0.7[0.2]
NK CUN-FLL MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK CUN-IAH MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK CUN-ORD MAY 1.0>0[0.2] JUN 1.0>0.7[0.3]
NK CUN-PHL MAY 1.0>0[0] JUN 1.0>0.7[0]
NK CUN-PIT MAY 0.4>0[0]
NK DEN-DTW MAY 1.0>0.0[1.0] JUN 1.0>0.7[1.0]
NK DEN-FLL MAY 1.4>0.4[1.0]
NK DEN-IAH MAY 0.4>0[1.0]
NK DEN-LAS MAY 1.3>0.9[2.0]
NK DEN-MCO MAY 0.6>0[1.0]
NK DEN-MSP MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK DEN-ORD MAY 1.6>0.1[2.0] JUN 1.9>1.4[2]
NK DFW-DTW MAY 1.0>0.6[1.4]
NK DFW-FLL MAY 2>0.6[3]
NK DFW-LAS MAY 3>0.5[4]
NK DFW-LAX MAY 3>0.5[4]
NK DFW-LGA MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK DFW-MCO MAY 3>0.6[3] JUN 3>2[3]
NK DFW-MSY MAY 0.6>0[1.0]
NK DFW-ORD MAY 0.6>0[2.0]
NK DFW-PHL MAY 0.6>0[1.0]
NK DFW-SAN MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK DFW-SJD MAY 0.6>0[0.5]
NK DFW-TPA MAY 0.6>0[1.0]
NK DTW-FLL MAY 2>0.9[2]
NK DTW-IAH MAY 0.6>0.1[1.0]
NK DTW-LAS MAY 3>1.0[3]
NK DTW-LAX MAY 1.6>0.1[2.0] JUN 1.9>1.4[2]
NK DTW-MCO MAY 3>0.7[3] JUN 3>2[3]
NK DTW-MSP MAY 1.0>0.6[1.0]
NK DTW-MYR MAY 1.0>0.6[1.2]
NK DTW-OAK MAY 0.8>0[1.0] JUN 1.0>0.7[1.0]
NK DTW-RSW MAY 1.0>0[1.0] JUN 1.0>0.7[0.9]
NK DTW-SAN MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK DTW-SEA MAY 0.6>0[1.0]
NK DTW-TPA MAY 1.0>0.7[0.9]
NK EWR-FLL MAY 2>0.9[2]
NK EWR-IAH MAY 1.0>0.6[1.0]
NK EWR-LAS MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK EWR-MCO MAY 3>0.9[3]
NK EWR-MSY MAY 0.7>0[1.0]
NK EWR-RSW MAY 1.0>0[0] JUN 1.0>0.7[0]
NK EWR-SJU MAY 1.0>0[0]
NK EWR-TPA MAY 1.0>0[0] JUN 1.0>0.7[0]
NK FLL-GUA MAY 1.0>0[1.0] JUN 1.4>1.1[1.0]
NK FLL-GYE MAY 0.9>0[1.0] JUN 1.0>0.7[1.0]
NK FLL-IAG MAY 0.3>0[0.3]
NK FLL-IAH MAY 1.7>0.7[2.0]
NK FLL-LAS MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK FLL-LAX MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK FLL-LBE MAY 1.0>0[1.0] JUN 1.0>0.7[0.9]
NK FLL-LGA MAY 4>0.9[4] JUN 4>3[4]
NK FLL-LIM MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK FLL-MBJ MAY 0.3>0[1.0] JUN 1.0>0.7[1.0]
NK FLL-MCO MAY 2>0.0[2] JUN 2>1.4[2]
NK FLL-MDE MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK FLL-MGA MAY 0.6>0[1.0]
NK FLL-MSY MAY 2>1.0[2.0]
NK FLL-MYR MAY 1.0>0.6[1.3]
NK FLL-OAK MAY 1.0>0.5[0]
NK FLL-ORD MAY 2>1.0[2]
NK FLL-PAP MAY 0.4>0[1.0]
NK FLL-PBG MAY 0.3>0[0.3]
NK FLL-PHL MAY 2>1.0[2]
NK FLL-PTY MAY 0.6>0[1.0]
NK FLL-PUJ MAY 0.6>0[1.0]
NK FLL-RIC MAY 0.9>0.5[1.0]
NK FLL-SAL MAY 0.8>0[0.6] JUN 1.2>0.9[0.6]
NK FLL-SAP MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK FLL-SDQ MAY 1.0>0[1.0]
NK FLL-SJO MAY 1.0>0[1.9]
NK FLL-STI MAY 0.3>0[0.5]
NK FLL-STT MAY 1.0>0.5[1.0]
NK FLL-TPA MAY 1.0>0[1.0]
NK GSO-MCO MAY 0.3>0[0.6]
NK IAG-MYR MAY 0.7>0.3[0.7]
NK IAH-LAS MAY 2>0.7[2]
NK IAH-LAX MAY 2>0.6[2]
NK IAH-MCO MAY 1.9>0.6[2]
NK IAH-OAK MAY 0.7>0[1.0]
NK IAH-ORD MAY 1.6>0.1[2] JUN 1.9>1.4[2]
NK IAH-SAN MAY 0.6>0[1.0]
NK IAH-SEA MAY 0.6>0[1.0]
NK IAH-SJD MAY 0.6>0[0.5]
NK IAH-TPA MAY 0.7>0[1.0] JUN 0.9>0.7[1.0]
NK IND-LAS MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK IND-MCO MAY 1.0>0.6[1.0]
NK LAS-LAX MAY 1.6>0.6[3]
NK LAS-MCI MAY 1.6>0.9[1.0]
NK LAS-MCO MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK LAS-MSP MAY 0.8>0[1.0] JUN 1.0>0.7[1.0]
NK LAS-MSY MAY 1.0>0.6[1.0]
NK LAS-OAK MAY 3>0.6[4]
NK LAS-ORD MAY 3>0.7[3] JUN 3>2[3]
NK LAS-PDX MAY 2>0.6[3]
NK LAS-PHL MAY 1.0>0.0[1.0] JUN 1.0>0.7[1.0]
NK LAS-PIT MAY 1.0>0.5[1.0]
NK LAS-SAN MAY 1.6>0.7[4]
NK LAS-SEA MAY 1.6>1.0[4]
NK LAS-SMF MAY 1.6>0.6[0]
NK LAS-TPA MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK LAX-MSP MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK LAX-MSY MAY 1.0>0.5[1.0]
NK LAX-ORD MAY 1.6>1.0[2]
NK LAX-PIT MAY 1.0>0.6[1.0]
NK LBE-MCO MAY 1.0>0.6[1.0]
NK LBE-MYR MAY 1.4>0[1.4] JUN 1.4>1.0[1.4]
NK LGA-MYR MAY 2>0.6[2]
NK LGA-ORD MAY 1.0>0[2] JUN 1.0>0.7[2]
NK MCO-MDE MAY 0.4>0[0.3]
NK MCO-MSP MAY 1.0>0[1.0] JUN 1.0>0.7[1.0]
NK MCO-MSY MAY 1.0>0.6[1.0]
NK MCO-MYR MAY 0.3>0[0.3]
NK MCO-PHL MAY 3>1.0[3]
NK MCO-RDU MAY 1.0>0.6[1.0]
NK MCO-SJO MAY 0.6>0[1.0]
NK MCO-SJU MAY 3.0>0.9[2.7]
NK MCO-STT MAY 0.4>0[0.4]
NK MSP-MSY MAY 0.3>0[0.6]
NK MSP-MYR MAY 0.3>0[0.4]
NK MSY-ORD MAY 1.0>0.6[1.0]
NK MSY-PHL MAY 0.3>0[0.5]
NK MSY-RDU MAY 0.6>0[1.0]
NK MYR-ORD MAY 1.0>0.6[1.0]
NK MYR-PBG MAY 0.3>0[0.3]
NK MYR-PHL MAY 1.0>0.6[1.0]
NK MYR-PIT MAY 1.0>0.5[1.0]
NK OAK-ORD MAY 0.7>0[1.0] JUN 0.9>0.7[1.0]
NK ORD-RSW MAY 0.6>0.1[1.0]
NK ORD-SAN MAY 0.4>0[1.0]
NK ORD-TPA MAY 1.0>0.5[1.0]
NK PHL-SJU MAY 1.0>0.5[0.3]
NK SJU-TPA MAY 0.7>0[1.0]
*OS BOS-VIE JUN 0.8>0[0] JUL 0.9>0[0] AUG 0.8>0[0] SEP 0.9>0[0] OCT 0.7>0[0]
QF BNE-LAX MAY 1.0>0[1.4]
QF DFW-SYD MAY 0.9>0[0.9]
QF HNL-SYD MAY 0.7>0[0.7]
QF JFK-LAX MAY 1.0>0[1.0]
QF LAX-MEL MAY 1.1>0[1.3]
QF LAX-SYD MAY 1.0>0[1.0]
QF SFO-SYD MAY 1.0>0[0.8]
QR DOH-ORD MAY 0.8>0.6[1.0]
SY BNA-MSN MAY 0.3>0[0]
SY BOS-MSN MAY 0.3>0[0]
SY EWR-MSN MAY 0.2>0[0]
SY LAS-MSP MAY 3>0.9[3]
SY LAX-MSP MAY 1.4>1.1[1.8]
SY MCO-MSN MAY 0.3>0[0]
SY MCO-MSP MAY 2.0>1.0[1.9]
SY MSN-SEA MAY 0.2>0[0]
SY MSP-RSW MAY 1.4>1.0[1.3]
SY MSP-SAV MAY 0.2>0[0.3]
SY MSP-SEA MAY 0.9>0.7[1.4]
SY MSP-SFO MAY 1.0>0.7[1.5]
TP BOS-PDL JUN 0.6>0.2[0]
UA AVL-ORD MAY 3>0[3]
UA EAR-ORD MAY 1.0>0[0] JUN 1.0>0.4[0]
UA RIW-SHR MAY 1.0>0[0] JUN 1.0>0[0] JUL 1.0>0[0] AUG 0.5>0[0]
X4 GST-JNU MAY 5>1.5[5] JUN 6>3[6]
SeaDoo
Sun Apr 05, 2020 12:24 pm
Thanks, as always.
Lots of changes. So I am assuming this means no QF flights between the US and Australia. I am assuming that is no flights from HA to the mainland too.
Interesting too that nothing from Alaska nor Southwest, and little changes from Delta, and almost no change from United.
knope2001
Sun Apr 05, 2020 12:50 pm
Thanks as always, enilria, for all your work on this. Pretty amazing stuff these weeks.
enilria wrote:
AA ABE-ORD MAY 1.9>0.7[1.8]
AA ABQ-ORD MAY 3>0.7[2.0]
AA ALB-ORD MAY 3>0.7[3]
AA ATL-ORD MAY 3>1.3[4]
AA ATW-ORD MAY 3>0.7[3]
AA AUS-ORD MAY 3>0.7[4]
AA AVP-ORD MAY 1.7>0.6[2]
AA AZO-ORD MAY 3>0.7[3]
AA BDL-ORD MAY 3>1.3[5]
etc
Not only are most ORD routes cut to 1 or sometimes 2 trips but those fractional remainders (like 0.7 or 1.3) mean further reduced or no weekend flying. . O'Hare as a hub looks pretty much shut down for AA on Saturdays. I wonder if the emergency funding didn't have provisions to not drop cities if they would have simply dropped the majority of ORD-only feeder network.
enilria wrote:
AA AGS-DCA MAY 0.8>0[0]
AA ALB-DCA MAY 4>0.1[4]
AA ATL-DCA MAY 3>0.0[4]
AA BHM-DCA MAY 3>0[3]
AA BDL-DCA MAY 5>0.1[5]
AA BGR-DCA MAY 3>0[3]
AA BNA-DCA MAY 4>0.1[5]
etc.
DCA hub operation seems pretty much closed for May. Looks like LGA is in pretty similar.
If I have time I may try to monkey more with all this AA data. Pretty remarkable stuff. :-/ It's amazing to think that markets like AA BNA-LGA and DCA-ATL could be dropped and not get any special mention, but you'd have worn out your * key if you tried to. Definitely appreciate you sharing all this stuff.
Speaking of monkeying with data, earlier this week I spent a whole lot of time with the WN website looking at the mid April - mid May cuts they had put out there. Because the cuts are split between parts of two months I figured the cuts would be muddier to recognize here. I started with a few markets, then a few more, and eventually did 'em all. They are posted in the WN thread.
viewtopic.php?p=22135099#p22135099
jrkmsp
Sun Apr 05, 2020 12:53 pm
Looks like the United schedule change to pull EWR and LGA basically down to zero must have been filed late in the day. That would have been an annihilation. Next week, I guess.
chonetsao
Sun Apr 05, 2020 12:56 pm
Wowwww AA is really gutted. I wonder when DL and UA will publish the May schedule.
QF no longer fly to USA mainland in May? I guess that is the only thing they can do. Australia is closed to foreign traveller for a while. I guess this is the only choice.
Thank you for the post. There are too much information to digest! And can you imagine both DL and UA announce further cut? You may need another post to just list the individual changes with each of UA or DL.
catdaddy63
Sun Apr 05, 2020 1:08 pm
Thank you enilria, truly a crazy day as far as cuts.
lowfareair
Sun Apr 05, 2020 1:12 pm
It's telling that the smallest AA cuts are the hub-hub flying with the biggest being those overflying another hub. I guess they expect many of those in hubs will need to connect in a different hub to get where they are going with so many routes being cut for May.
CIDFlyer
Wow DCA AA hub pretty much closed for a May and ORD take a huge hit. I do like thought for the most part AA kept a majority of its hubs connected with the out stations
PSU.DTW.SCE
Sun Apr 05, 2020 1:13 pm
For May it’s almost going to be easier to list what is actually flying.
enilria
Sun Apr 05, 2020 1:29 pm
SeaDoo wrote:
Thanks, as always.
I think HA is wrong. They dropped their whole schedule.
AA BOS-ORD MAY 7>1.6[8]
etc
AA BUF-DCA MAY 2>0[3]
etc.
Yeah, I started to asterisk and stopped at the ones that started with the letter B 100s asterisks later!
I think it also missed the latest from DL. Keep in mind this report doesn't cover the current month, so both of those may have been April only.
Numbers I have seen show DCA is down more on traffic than any other large airport. Cockroach lobbyists staying home???
Chuska
Sun Apr 05, 2020 1:40 pm
Enilria--Will this report make a special run during the week in case any of these other carriers chime in that we didn't hear much from today?
Boof02671
Sun Apr 05, 2020 1:44 pm
UA is gutting EWR from over a 100 flights a day to just 15 and severe cuts at LGA down to two flights a day
sunking737
Sun Apr 05, 2020 1:49 pm
Enilria, wow do you have hand cramps after typing this out?? At this point if I had to fly anywhere I would check in this order SY, WN and then DL out of MSP. I don't want to be an employee in scheduling right now..route planning, crews, MX, etc holy crap..Stress City USA.
"Don't believe it unless its parked on the ramp, or printed in the schedule...SUBJECT TO CHANGE"
I'm a SUNDUCK......Worked for RC & SY @ MSP
Chuska
Sun Apr 05, 2020 1:55 pm
AA seems to have an interim schedule for May 1 thru 7 then another change eff May 8. DFW holds up ok with many flights still running daily however most other hubs see flights that are except Tue/Wed/Sat. Markets like ABQ-DFW have no 738's or A321's and ELP-DFW and COS-DFW are all Eagle! FAT--you lucked out, still two 738's to DFW.
CIDFlyer
Sun Apr 05, 2020 1:59 pm
I’ve noticed that a lot of routes like DSM and OMA are going to all Eagle as well. Guess terminal B and E will keep busy
jetmatt777
Sun Apr 05, 2020 2:04 pm
OKC-DFW will be 5x daily all on Eagle. This route was 9x daily, 8 of those being mainline 738/319's.
wnflyguy
Sun Apr 05, 2020 2:19 pm
WN put out a revised May schedule have you had a chance to sift through the cuts yet?
We may never see eye to eye on industry stuff. But I just want to say THANK YOU for always posting all this every week. Times like this your post helps me escape the day to day worries About this pandemic even if this is horrible news with all the industry cuts.
Flyguy
My Wings are clipped just another Retired Airline person. The Ultimate Armchair out of the loop airline industry geek. Aloha Mr Hand!
Chuska
Sun Apr 05, 2020 2:35 pm
AA at PHX going down to two banks per day, a 1000am westbound and a 300pm eastbound, with nothing on Tuesdays or Saturdays except to other hubs.
afcjets
Sun Apr 05, 2020 2:46 pm
In April they are only flying LAX-HNL and LAX-SFO with only one daily flight. Maybe it's going to be extended.
https://www.hawaiianairlines.com/coronavirus
EA CO AS
Sun Apr 05, 2020 3:23 pm
I'm surprised the AS changes weren't in the mix; they were loaded yesterday. At least the 4/10 to 4/30 schedule, anyway.
EA CO AS
Sun Apr 05, 2020 3:28 pm
Seconded. Thanks, Enilria, for all you do!
MIflyer12
Does AA have much of a domestic ORD-only destination set? I started looking at route maps and it made my head hurt...
rj1385
Sun Apr 05, 2020 3:31 pm
Imagine if the airlines start doing multi-stop: DL DTW-BUF-ROC-DTW
enilria
Sun Apr 05, 2020 3:32 pm
The report doesn't cover current month. The problem is that the number of days I divide over starts to be wrong inside the month as it would need to correct for the number of days remaining in the month and that would vary depending upon where each Sunday falls as well. To avoid that issue the report has never covered current month. :(
TW870
Sun Apr 05, 2020 3:33 pm
It looks like American's Europe schedule is gutted to bare bones until October, when you begin to see less than daily service built back in to the larger, year-round European markets. Will be interesting to see how DL and UA build the fall to Europe.
Thank you as always Enilria for archiving these painful times in the industry.
OA412
Interestingly, AA will operate ORD-ATH, but not PHL-ATH, which has operated for a longer period of time. Are the 333s being parked this summer?
Hughes Airwest - Top Banana In The West
AirFiero
Sun Apr 05, 2020 3:40 pm
Indeed, thanks for your efforts for the weekly obituary...er...OAG report.
enilria
Sun Apr 05, 2020 3:44 pm
Yup, that's what it is.
I doubt the economics can ever work for that.
The source I get it from only has a single weekly update unless they screw it up and do a fix. I would if that was not the case. I hear some of the industry schedule data vendors are now offering that if your work needs it.
N292UX
Sun Apr 05, 2020 3:50 pm
enilria wrote:
FAQ
AA DCA-DFW MAY 9>5[10]
AA DCA-DSM MAY 1.6>0.0[1.8]
AA DCA-DTW MAY 2>0[2]
AA DCA-ECP MAY 0.8>0[0]
AA DCA-EYW MAY 0.5>0.0[0.3]
AA DCA-GRR MAY 1.6>0[1.9]
AA DCA-GSO MAY 2>0[3]
AA DCA-GSP MAY 2>0.0[3]
AA DCA-HPN MAY 4>0.1[5]
AA DCA-HSV MAY 3>0[3]
AA DCA-ILM MAY 1.0>0[1.0]
AA DCA-IND MAY 5>0.1[6]
AA DCA-JAN MAY 1.0>0.0[1.0]
AA DCA-JAX MAY 3>0.0[4]
AA DCA-JFK MAY 1.8>0.2[3]
AA DCA-LAN MAY 0.6>0[0.8]
AA DCA-LAS MAY 1.0>0.0[1.0]
AA DCA-LGA MAY 9>3[11] JUN 10>9[8]
AA DCA-LIT MAY 1.0>0.0[1.0]
AA DCA-MCI MAY 2>0.0[3]
AA DCA-MCO MAY 4>0.2[4]
AA DCA-MEM MAY 3>0.0[3]
AA DCA-MGM MAY 1.0>0[0.9]
AA DCA-MHT MAY 3>0[3]
AA DCA-MIA MAY 9>5[9]
AA DCA-MSP MAY 2>0.0[3]
AA DCA-MSY MAY 4>0.1[4]
AA DCA-MYR MAY 1.1>0.0[1.3]
AA DCA-OKC MAY 0.8>0[1.0]
AA DCA-ORD MAY 8>3[8]
AA DCA-ORF MAY 2>0.0[3]
AA DCA-PBI MAY 1.9>0.0[1.3]
AA DCA-PHL MAY 3>0.9[3]
AA DCA-PHX MAY 3>2.0[3]
AA DCA-PIT MAY 4>0.1[4]
AA DCA-PNS MAY 1.9>0.0[2]
AA DCA-PVD MAY 6>0.1[6]
AA DCA-PWM MAY 4>0.0[5]
AA DCA-RDU MAY 6>0.8[6]
AA DCA-ROC MAY 3>0.0[4]
AA DCA-RSW MAY 1.1>0.0[1.0]
AA DCA-SAV MAY 1.9>0.0[2]
AA DCA-SDF MAY 3>0.1[3]
AA DCA-SRQ MAY 1.2>0.0[0.9]
AA DCA-STL MAY 3>0.0[4]
AA DCA-SYR MAY 3>0.0[4]
AA DCA-TLH MAY 1.0>0.0[1.0]
AA DCA-TPA MAY 4>1.2[4]
AA DCA-TYS MAY 2>0[3]
AA DCA-VPS MAY 1.0>0[1.1]
AA DCA-XNA MAY 0.8>0[1.0]
AA DCA-YYZ MAY 1.6>0[1.9]
Yikes. As a frequent DCA flyer, this is not good to see. Regularly fly DCA-IND, so no way that will be happening in May. I'm scheduled to be flying DCA-IND in June, August, and October. Fingers crossed for there being some normality then.
aemoreira1981
Sun Apr 05, 2020 3:54 pm
I expect a bigger bloodbath when UA puts out its schedule. As for TP, I'd be surprised if some routes didn't return, like BOS-LIS (nonstop; service via PDL remaining) and JFK-LIS, with EWR downgauged to an A321neo on some days and West Coast service cancelled.
As for Ravn Alaska...are they done?
alasizon
Sun Apr 05, 2020 3:57 pm
Starting the 8th, ORD, PHL, PHX and MIA all do not operate other than hub to hub on Tue. MIA runs a mostly full schedule on Sat. ORD, PHL and PHX all do not operate anything other than hub to hub on Saturday as well.
DFW and CLT are the only full scale operations on a daily basis.
There is no Regional flying in LAX or JFK and DCA only has regional flying on the shuttle, no actual connectivity flying.
NYCAAer
Sun Apr 05, 2020 4:01 pm
Could be. It was announced that all 9 of the 333s were being retired. I don’t get why ORD-ATH is going to operate.
ytib
Sun Apr 05, 2020 4:16 pm
Just a handful of cities left.
viewtopic.php?f=3&t=1443945
318, 319, 320, 321, 332, 333, 388, 707, 717, 722, 732, 733, 734, 73Q, 735, 73G, 738, 7M8, 739, 752, 753, 742, 74L, 744, 762, 763, 772, 77L, 77W, 789, 142, CN1, CR2, CR7, DC8, DH2, DH8, D8Q, D10, D95, EM2, ER3, ER4, E70, 100, J31, M11, M83, M88, M90, SF3
CIDFlyer
Sun Apr 05, 2020 4:19 pm
There are quite a few ORD only spokes in the upper Midwest. ROC, DBQ, LSE, GRB, ATW, AZO off the top of my head that I can think of.
32andBelow
Sun Apr 05, 2020 4:20 pm
You have to submit changes to OAG about a week in advance. So it would show up next week.
EA CO AS
Sun Apr 05, 2020 4:22 pm
The AS schedule load includes some interesting tag flights:
SEA-PIT-BWI
SEA-RDU-CHS
SEA-DFW-IAH
SEA-MSP-CMH
SEA-SBP-SBA
SEA-FCA-HLN
alasizon
Not exactly true, changes that are loaded Fri night/Sat morning show up all the time in the OAG threads.
All the AA cuts were loaded on Friday night and they show up correctly.
umichman
Sun Apr 05, 2020 4:24 pm
Oops, someone beat me and noted AS is doing this.
tphuang
Sun Apr 05, 2020 4:29 pm
That's probably why the DL cuts didn't show up. I think they just had another round of major cuts for April. I assume all these airlines are still working through how much they want to cut from each station since situations are changing so fast. Maybe we will see UA/DL make their major May cuts in the next couple of weeks. I'm sure WN/B6 are going to put in more cuts for May also. B6 only finished processing their 70% cut for April this past week.
alasizon
SEA-PIT-BWI
SEA-RDU-CHS
SEA-DFW-IAH
SEA-MSP-CMH
SEA-SBP-SBA
SEA-FCA-HLN
Slightly surprised there aren't more of these on the southbound California routes (i.e. PDX-SMF-STS) given the way the LF has plummeted.
maps4ltd
Sun Apr 05, 2020 4:39 pm
Seems DEN did become WN's largest focus city, just not the way they would've hoped.
Delta Gold Medallion
32andBelow
Sun Apr 05, 2020 5:01 pm
SEA-PIT-BWI
SEA-RDU-CHS
SEA-DFW-IAH
SEA-MSP-CMH
SEA-SBP-SBA
SEA-FCA-HLN
It looks like ANCSEA is down to 2 a day on the app
LJ
Sun Apr 05, 2020 5:12 pm
It looks like only the routes which depend on the Summer season have been cut till October. All the others are only cut for May. Thus not really to the bare bone. I think you'll see the same for the other airlines. Routes which are there to capture the Summer peak will be cut, the remainder will only be cut based on the expectation for the next month. Seems a wise strategy.
Scarebus34
Sun Apr 05, 2020 5:13 pm
A majority of these flights were already being tactically cancelled each day...
Chuska
Sun Apr 05, 2020 7:11 pm
Great to see AS doing those tag-on's. Maybe SEA-ABQ-ELP and fill in the ABQ-ELP void that WN dropped several years ago.
This whole ordeal reminds me some of the cuts made in 1973 during the Arab oil embargo except this at least ten times worse.
ROW is now at 187 stored aircraft between AA, UA, and F9 since Mar 18.
WidebodyPTV
Sun Apr 05, 2020 7:13 pm
UA loaded its schedule changes overnight Saturday. AA loaded even more changes last night. Due to timing, they're not reflected in this report. Not that it matters much, anyway, since the remaining flights still reflect way too much capacity for the level of traffic that's flying, and same day flight cancellations will continue...
ericm2031
Sun Apr 05, 2020 8:09 pm
For those who keep talking about UA cuts, again, since it is already April, they don't show up on the report. And they haven't pushed out the cuts into May yet...once that happens, it'll show on the report.
flyboy7974
Sun Apr 05, 2020 8:30 pm
The A333 are most likely not returning at all.
Varsity1
Sun Apr 05, 2020 8:33 pm
Looks like the end of AA's focus city in BOS.
"PPRuNe will no longer allow discussions regarding Etihad Airlines, its employees, executives, agents, or other representatives. Such threads will be deleted." - ME3 thug airlines suing anyone who brings negative information public..
