enilria
OAG Changes 4/19/2020:F9 Cuts AUG/SEP;DL Exits JAXRDU;UA Follows AA by Decimating Int'l for May and Summer, Drops SCKLAX
Sun Apr 19, 2020 11:46 am
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
3M BIM-FLL MAY 1.0>0.5[1.5]
3M ELH-FLL MAY 2>1.1[4]
3M EYW-FLL MAY 3>1.2[3]
3M EYW-MCO MAY 2>0.7[2]
3M EYW-TPA MAY 3>1.1[3]
3M FLL-FPO MAY 0.9>0.5[3]
3M FLL-GGT MAY 1.5>0.8[1.7]
3M FLL-GHB MAY 0.6>0.3[0.7]
3M FLL-MCO MAY 1.8>1.0[2]
3M FLL-MHH MAY 0.8>0.5[4]
3M FLL-PNS MAY 0.9>0.4[1.0]
3M FLL-TLH MAY 1.5>0.5[1.5]
3M FLL-TPA MAY 1.9>1.0[2]
3M HSV-MCO MAY 0.9>0.6[1.0]
3M MCO-PNS MAY 1.7>0.8[1.7]
3M NAS-TPA MAY 1.0>0.4[1.0]
3M PNS-TPA MAY 1.7>0.6[1.7]
3M TLH-TPA MAY 1.5>0.8[1.6]
I'm assuming that is all USA service?
4O CUN-MIA MAY 0.6>0[0]
4O DFW-MEX MAY 2.0>0[1.7]
4O GDL-LAS MAY 1.0>0[1.0]
4O GDL-LAX MAY 1.0>0[1.9]
4O GDL-ORD MAY 1.0>0[1.0]
4O GDL-SAT MAY 1.0>0[1.0]
4O GDL-SFO MAY 1.0>0[1.0]
4O IAH-MEX MAY 2.0>0[1.6]
4O IAH-MTY MAY 1.0>0[0.8]
4O JFK-MEX MAY 1.0>0[4]
4O LAS-MEX MAY 0.6>0[1.0]
4O LAS-MTY MAY 1.0>0[0.6]
4O LAX-MEX MAY 2.0>0[1.7]
4O LAX-MTY MAY 0.6>0[0]
4O MCO-MEX MAY 1.0>0[1.1]
4O MEX-MIA MAY 1.0>0[1.7]
4O MEX-ORD MAY 2.0>0[2]
4O MEX-SAT MAY 2>0[1.7]
4O MTY-SAT MAY 1.0>0[0.7]
7S ANC-ANI MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0] NOV 0>0.3[0] DEC 0>0.3[0] JAN 0>0.3[0]
7S ANC-UNK MAY 0>0.3[0] JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0] NOV 0>0.3[0] DEC 0>0.3[0] JAN 0>0.3[0]
7S ANI-BET MAY 0>0.8[0] JUN 0>0.9[0] JUL 0>0.9[0] AUG 0>0.8[0] SEP 0>0.9[0] OCT 0>0.9[0] NOV 0>0.8[0] DEC 0>0.9[0] JAN 0>0.8[0]
7S ANI-CHU MAY 0>0.2[0] JUN 0>0.2[0] JUL 0>0.2[0] AUG 0>0.2[0] SEP 0>0.2[0] OCT 0>0.2[0] NOV 0>0.2[0] DEC 0>0.2[0] JAN 0>0.2[0]
7S ANI-KLG MAY 0.8>0.4[0.9] JUN 0.9>0.4[0.8] JUL 0.9>0.4[0.9] AUG 0.8>0.4[0.9] SEP 0.9>0.4[0.8] OCT 0.9>0.4[0.9] NOV 0.8>0.4[0.9] DEC 0.9>0.4[0.8] JAN 0.8>0.4[0.9]
7S ANI-RSH MAY 0.8>0.4[0.9] JUN 0.9>0.4[0.8] JUL 0.9>0.4[0.9] AUG 0.8>0.4[0.9] SEP 0.9>0.4[0.8] OCT 0.9>0.4[0.9] NOV 0.8>0.4[0.9] DEC 0.9>0.4[0.8] JAN 0.8>0.4[0.9]
7S ANI-SRV MAY 0>0.2[0] JUN 0>0.2[0] JUL 0>0.2[0] AUG 0>0.2[0] SEP 0>0.2[0] OCT 0>0.2[0] NOV 0>0.2[0] DEC 0>0.2[0] JAN 0>0.2[0]
7S ATT-BET MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0]
7S ATT-MLL MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0]
7S BET-MLL MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0]
7S BET-MYU MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0]
7S BET-SCM MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0]
7S BET-TNK MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0]
7S BET-VAK MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0]
7S CHU-CKD MAY 0>0.2[0] JUN 0>0.2[0] JUL 0>0.2[0] AUG 0>0.2[0] SEP 0>0.2[0] OCT 0>0.2[0] NOV 0>0.2[0] DEC 0>0.2[0] JAN 0>0.2[0]
7S CKD-RDV MAY 0>0.2[0] JUN 0>0.2[0] JUL 0>0.2[0] AUG 0>0.2[0] SEP 0>0.2[0] OCT 0>0.2[0] NOV 0>0.2[0] DEC 0>0.2[0] JAN 0>0.2[0]
7S HPB-SCM MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0]
7S HPB-VAK MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0]
7S KLG-RSH MAY 0.8>0.4[0.9] JUN 0.9>0.4[0.8] JUL 0.9>0.4[0.9] AUG 0.8>0.4[0.9] SEP 0.9>0.4[0.8] OCT 0.9>0.4[0.9] NOV 0.8>0.4[0.9] DEC 0.9>0.4[0.8] JAN 0.8>0.4[0.9]
7S KSM-MLL MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0]
7S KSM-MOU MAY 0>0.8[0] JUN 0>0.9[0] JUL 0>0.9[0] AUG 0>0.8[0] SEP 0>0.9[0] OCT 0>0.9[0] NOV 0>0.8[0] DEC 0>0.9[0] JAN 0>0.8[0]
7S KSM-PQS MAY 0>1.3[0] JUN 0>1.3[0] JUL 0>1.3[0] AUG 0>1.3[0] SEP 0>1.3[0] OCT 0>1.3[0] NOV 0>1.3[0] DEC 0>1.3[0] JAN 0>1.3[0]
7S MLL-PQS MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0]
7S MYU-OOK MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0]
7S OOK-TNK MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0]
7S RDV-SLQ MAY 0>0.2[0] JUN 0>0.2[0] JUL 0>0.2[0] AUG 0>0.2[0] SEP 0>0.2[0] OCT 0>0.2[0] NOV 0>0.2[0] DEC 0>0.2[0] JAN 0>0.2[0]
7S SKK-UNK MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0]
7S SKK-WBB MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0]
7S SLQ-SRV MAY 0>0.2[0] JUN 0>0.2[0] JUL 0>0.2[0] AUG 0>0.2[0] SEP 0>0.2[0] OCT 0>0.2[0] NOV 0>0.2[0] DEC 0>0.2[0] JAN 0>0.2[0]
7S SMK-UNK MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0]
7S SMK-WBB MAY 0>0.4[0] JUN 0>0.4[0] JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0]
7S UNK-WBB MAY 0>0.8[0] JUN 0>0.9[0] JUL 0>0.9[0] AUG 0>0.8[0] SEP 0>0.9[0] OCT 0>0.9[0] NOV 0>0.8[0] DEC 0>0.9[0] JAN 0>0.8[0]
9K BHB-BOS SEP 3>1.0[3] OCT 3>2[3]
9K BOS-PWM MAY 0>0.4[0]
AA AMS-DFW OCT 0>0.2[0]
AA CDG-DFW MAY 0.8>0[1.0]
AA HAV-MIA MAY 3>0[5]
*AA KEF-PHL JUN 0.9>0[0] JUL 1.0>0[0] AUG 0.5>0[0]
AC DCA-YUL MAY 1.0>0[2]
Wasn't this one of 2 routes they were keeping to the USA?
AC DCA-YYZ MAY 1.0>0[4]
AC DEN-YYZ MAY 1.0>0.7[3]
AC EWR-YUL MAY 1.0>0[4]
AC EWR-YYZ MAY 1.0>0[7]
AC LAX-YUL MAY 0.5>0.3[2]
AF ATL-CDG MAY 1.8>0.2[2]
AF BOS-CDG MAY 1.8>0[1.0]
AF CDG-DFW MAY 0.4>0[0.5]
AF CDG-DTW MAY 0.9>0[1.0]
AF CDG-IAD MAY 1.5>0[1.1]
AF CDG-IAH MAY 0.9>0[1.0]
AF CDG-JFK MAY 5>0.5[4]
AF CDG-LAX MAY 2>0.4[2]
AF CDG-MIA MAY 0.9>0[1.0]
AF CDG-MSP MAY 0.8>0[0.9]
AF CDG-ORD MAY 0.9>0.0[1.0]
AF CDG-SEA MAY 0.7>0[0.7]
AF CDG-SFO MAY 2>0[1.7]
AF JFK-ORY MAY 0.9>0[1.0]
AF LAX-PPT MAY 0.4>0[0.4]
The stuff not dropped is now the more interesting part
*AF MIA-PAP MAY 0.5>0.2[0.6]
AM AUS-MEX MAY 0.9>0[0.7]
AM DEN-MEX MAY 0.3>0[0]
AM DFW-MEX MAY 1.0>0[2]
AM DTW-MTY MAY 1.0>0[1.0]
AM FAT-GDL MAY 0.5>0[0.7]
AM GDL-LAX MAY 1.0>0[1.3]
AM GDL-ORD MAY 0.4>0[1.3]
AM GDL-SFO MAY 0.4>0[0.9]
AM GDL-SLC MAY 1.0>0.7[1.0]
AM IAH-MEX MAY 3>0.3[3]
AM JFK-MEX MAY 2>0.4[4]
AM LAS-MEX MAY 1.0>0[1.3]
AM LAX-MEX MAY 2>0.6[3]
AM MCO-MEX MAY 1.1>0[1.3]
AM MEX-MIA MAY 2>0[2]
AM MEX-ORD MAY 1.0>0.5[2]
AM MEX-SAT MAY 1.0>0[1.0]
AM MEX-SEA MAY 1.0>0[1.0]
AM MEX-SFO MAY 2>0[2]
AV BOG-IAD MAY 1.0>0.5[1.0]
AV BOG-JFK MAY 1.0>0.5[3]
AV BOG-MCO MAY 0.6>0.3[1.0]
AV BOG-MIA MAY 1.0>0.5[3]
B0 EWR-ORY MAY 1.0>0[1.3]
B6 BQN-MCO MAY 0>0.4[1.5]
B6 MCO-PSE MAY 0>0.4[2.0]
Do we think BA will actually run all of these London flights? Perhaps they just suspended till May 20th for some reason...
BA ATL-LHR MAY 1.0>0.0[1.0]
BA AUS-LHR MAY 1.0>0.5[1.0]
BA BNA-LHR MAY 1.0>0.3[1.0]
BA BOS-LHR MAY 4>1.2[4]
BA DEN-LHR MAY 1.0>0.0[1.0]
BA DFW-LHR MAY 1.0>0.0[1.0]
BA EWR-LHR MAY 1.9>0.9[2]
BA IAD-LHR MAY 2>1.0[2]
BA IAH-LHR MAY 2>1.1[2]
BA JFK-LGW MAY 0.5>0[1.0]
BA JFK-LHR MAY 8>2[8]
BA LAS-LGW MAY 0.9>0.1[0.7]
BA LAS-LHR MAY 1.0>0.0[1.0]
BA LAX-LHR MAY 3>1.0[3]
BA LGW-MCO MAY 2>0.2[1.8]
BA LGW-TPA MAY 0.9>0[1.0]
BA LHR-MIA MAY 3>0.9[3]
BA LHR-ORD MAY 2>1.0[2]
BA LHR-PHL MAY 1.5>0.6[1.4]
BA LHR-SEA MAY 3>0.9[2]
BA LHR-SFO MAY 2>0.5[2]
BF ORY-SFO MAY 0.4>0[0.4]
BF PPT-SFO MAY 0.4>0[0.5]
Are all CA flights now not operating?
CA IAD-PEK MAY 0.5>0[1.0]
CA IAH-PEK MAY 0.4>0[0.9]
CA JFK-PEK MAY 1.0>0[2]
CA LAX-PEK MAY 1.2>0.0[3]
CA PEK-SFO MAY 0.5>0[1.5]
CI JFK-TPE MAY 0.5>0[0.6]
CI ONT-TPE MAY 1.0>0[1.0]
CI SFO-TPE MAY 1.0>0.4[1.0]
CZ CAN-JFK MAY 1.4>0.9[1.4]
DI AUS-LGW MAY 0.4>0[0.4]
DI BOS-LGW MAY 1.0>0[1.0]
DI DEN-LGW MAY 0.4>0[0.4]
DI JFK-LGW MAY 3>0[2]
DI LAX-LGW MAY 1.3>0[1.0]
DI LGW-MCO MAY 0.7>0[0.9]
DI LGW-MIA MAY 0.9>0[1.0]
DI LGW-ORD MAY 0.6>0[0.6]
DI LGW-SEA MAY 0.5>0[0.6]
DI LGW-SFO MAY 0.8>0[0.7]
DI LGW-TPA MAY 0.4>0[0.3]
DL ABE-DTW MAY 1.8>1.4[3]
DL ABQ-ATL MAY 0.8>0[2]
DL ABY-ATL MAY 1.8>1.4[3]
DL AEX-ATL MAY 1.8>1.3[4]
DL ALB-ATL MAY 1.0>0.5[3]
DL AMS-BOS MAY 1.9>0[2]
DL ASE-SLC SEP 1.9>1.0[1.0] OCT 2>1.0[1.0] NOV 2>1.0[1.0] DEC 1.9>1.4[1.3]
DL ATL-AVL MAY 3>1.9[7]
DL ATL-BHM MAY 4>3[9]
DL ATL-BNA MAY 4>2[10] JAN 10>9[9]
DL ATL-BOG MAY 1.0>0.4[1.0]
DL ATL-BOS MAY 5>3[12]
DL ATL-BQK MAY 1.8>1.0[3]
DL ATL-BTR MAY 3>1.5[7]
DL ATL-BWI MAY 4>2[11]
DL ATL-CAE MAY 4>3[8]
DL ATL-CHA MAY 4>3[10]
DL ATL-CHO MAY 3>1.3[5]
DL ATL-CHS MAY 4>2[10]
DL ATL-CLT MAY 4>3[9]
DL ATL-CMH MAY 4>2[8]
DL ATL-CRW MAY 1.8>1.4[5]
DL ATL-CSG MAY 2>1.5[4]
DL ATL-CVG MAY 4>3[8]
DL ATL-DAB MAY 3>1.9[5]
DL ATL-DAY MAY 1.8>0.5[4]
DL ATL-DCA MAY 4>2[12]
DL ATL-DFW MAY 4>2[10]
DL ATL-DHN MAY 2>1.5[4]
DL ATL-DTW MAY 6>4[11]
DL ATL-ELP DEC 3>2[2] JAN 3>2[1.9]
DL ATL-EVV JAN 4>3[3]
DL ATL-EWR DEC 11>9[9] JAN 10>9[9]
DL ATL-EYW MAY 2.0>1.0[5]
DL ATL-EZE MAY 0.9>0.2[1.0]
DL ATL-FLL MAY 5>3[13]
DL ATL-FWA MAY 1.8>0.9[4]
DL ATL-GCM MAY 1.0>0[1.1]
DL ATL-GIG MAY 0.6>0[1.0]
DL ATL-GRB DEC 1.9>1.0[1.0] JAN 1.9>1.0[1.0]
DL ATL-GRR MAY 1.0>0[5]
DL ATL-GRU MAY 0.9>0.5[1.0]
DL ATL-GSO MAY 4>3[8]
DL ATL-GSP MAY 4>3[7]
DL ATL-GTR MAY 2>1.5[3]
DL ATL-HND MAY 0.7>0[0]
DL ATL-HNL MAY 1.0>0[1.0]
DL ATL-HPN MAY 1.8>0.6[6]
DL ATL-HSV MAY 4>3[7]
DL ATL-ICT MAY 1.8>1.3[3]
DL ATL-IND MAY 4>2[9]
DL ATL-JAN MAY 3>2.0[6]
DL ATL-JAX MAY 5>3[12]
DL ATL-JFK MAY 4>3[8]
DL ATL-LAS MAY 4>1.1[8]
DL ATL-LAX MAY 5>4[12] OCT 11>10[10] NOV 11>10[10] DEC 12>10[11] JAN 11>10[10]
DL ATL-LFT MAY 1.8>1.4[5] JAN 4>3[3]
DL ATL-LGA MAY 5>3[15]
DL ATL-LIM MAY 0.9>0.5[1.0]
DL ATL-MCO MAY 5>4[16]
DL ATL-MDT MAY 1.0>0.5[3]
DL ATL-MDW MAY 3>1.9[6] JAN 6>5[5]
DL ATL-MGM MAY 3>2[6]
DL ATL-MIA MAY 5>3[12]
DL ATL-MLB MAY 3>1.5[4]
DL ATL-MLU MAY 1.8>1.4[4]
DL ATL-MOB MAY 3>1.9[7]
DL ATL-MSN JAN 4>3[3]
DL ATL-MSP MAY 5>4[11]
DL ATL-MSY MAY 4>2[10]
DL ATL-MYR MAY 2.0>1.5[4]
DL ATL-NAS MAY 1.0>0.5[4]
DL ATL-OAJ MAY 1.0>2[4]
DL ATL-OKC MAY 3>2.0[5]
DL ATL-OMA MAY 3>1.9[5]
DL ATL-ORD MAY 5>3[11]
DL ATL-ORF MAY 4>2[8]
DL ATL-PBI MAY 5>3[10]
DL ATL-PDX OCT 4>3[3] NOV 4>3[3] DEC 4>3[3] JAN 4>3[3]
DL ATL-PHL MAY 4>2[10]
DL ATL-PHX MAY 2.0>1.5[6]
DL ATL-PIT MAY 4>2[8]
DL ATL-PNS MAY 4>3[8]
DL ATL-PTY MAY 0.5>0.3[1.0]
DL ATL-PVD MAY 1.0>0.5[3]
DL ATL-RDU MAY 5>3[12]
DL ATL-RIC MAY 4>2[10]
DL ATL-ROA MAY 2.0>1.5[5]
DL ATL-ROC MAY 1.0>0.5[3]
DL ATL-RST JAN 1.9>1.0[1.0]
DL ATL-RSW MAY 5>3[9]
DL ATL-SAN MAY 2.0>1.5[5]
DL ATL-SAV MAY 5>3[10]
DL ATL-SCL MAY 0.9>0.3[1.0]
DL ATL-SDF MAY 4>3[8]
DL ATL-SEA DEC 8>7[6]
DL ATL-SFO MAY 3>2[7]
DL ATL-SHV JAN 7>6[6]
DL ATL-SJC MAY 1.0>0.5[3]
DL ATL-SJU MAY 2.0>1.4[3.1]
DL ATL-SNA MAY 1.0>0.5[3]
DL ATL-SRQ MAY 4>3[7]
DL ATL-STL MAY 4>3[8]
DL ATL-SYR MAY 1.0>0.5[3]
DL ATL-TPA MAY 5>3[13]
DL ATL-TUL MAY 2.0>1.5[5]
DL ATL-TUS MAY 1.0>0.5[2.0]
DL ATL-TYS MAY 4>3[8]
DL ATL-UIO MAY 1.0>0.2[1.0]
DL ATL-VLD MAY 1.8>1.4[3]
DL ATL-VPS MAY 4>2[7]
DL ATL-XNA MAY 2.0>1.5[5]
DL ATL-YYZ MAY 1.0>0.5[6]
DL ATW-DTW MAY 2.0>1.2[3]
DL ATW-MSP MAY 3>1.5[4]
DL AUS-DTW MAY 1.8>0.9[3] DEC 4>3[3] JAN 4>3[3]
DL AUS-LAX MAY 1.0>0.5[3]
DL AUS-MSP MAY 2.0>1.0[3] DEC 3>2[2] JAN 3>2[1.9]
DL AUS-SLC MAY 2.0>1.5[3]
DL AVP-DTW MAY 1.8>1.4[3]
DL AZO-DTW MAY 2>1.5[5]
DL BDL-CVG DEC 0.9>0.5[0.6]
DL BGR-JFK MAY 2.0>1.0[0]
DL BIL-MSP SEP 3>2[1.9] OCT 3>2[1.9] NOV 3>2[1.8]
DL BNA-BOS MAY 0.8>0[3] JAN 4>3[3]
DL BNA-DTW MAY 2.0>1.5[5]
DL BNA-JFK DEC 3>2[2.0] JAN 3>2[3]
DL BNA-LAX DEC 1.9>0.9[1.3] JAN 1.8>0.9[1.0]
DL BNA-MSP MAY 2.0>1.5[4]
DL BNA-RDU DEC 1.5>1.1[1.2]
DL BNA-SLC MAY 1.0>0[1.0] DEC 1.5>1.0[1.0] JAN 1.4>1.0[1.5]
DL BOS-CLE OCT 4>3[2] NOV 4>3[2] DEC 4>3[2] JAN 4>3[2]
DL BOS-CVG MAY 1.0>0[4]
DL BOS-DTW MAY 4>3[6]
DL BOS-IND JAN 4>3[3]
DL BOS-JAX JAN 3>1.8[1.8]
DL BOS-JFK DEC 8>7[7] JAN 8>7[7]
DL BOS-LAX MAY 1.0>0.5[2]
DL BOS-LGA MAY 1.9>1.0[14]
DL BOS-MCI JAN 3>1.8[1.7]
DL BOS-MCO MAY 1.0>0[3]
DL BOS-PIT MAY 1.0>0.0[4]
DL BOS-RDU MAY 1.6>0[5]
DL BOS-SLC MAY 1.0>0.5[3]
DL BTV-DTW MAY 2.0>1.5[3]
DL BTV-JFK MAY 1.8>0[3] DEC 3>2[3] JAN 3>2[1.9]
DL BUF-JFK MAY 3>0.5[5] JAN 5>4[4]
DL BWI-DTW MAY 2.0>1.5[5]
DL BWI-RDU DEC 1.6>1.2[1.2]
DL BWI-SLC DEC 1.8>1.3[1.3] JAN 1.8>1.0[1.0]
DL BZN-SLC MAY 2.0>1.5[4] SEP 5>3[3] OCT 5>3[3] NOV 5>3[3] DEC 5>4[3]
DL CHA-DTW DEC 1.6>1.1[1.2] JAN 2>1.7[1.4]
DL CHS-DTW MAY 1.0>0.0[2.0]
DL CID-MSP MAY 3>2[3]
DL CLE-DTW MAY 4>3[5]
DL CLE-LGA JAN 5>4[4]
DL CLT-CVG JAN 2>1.5[1.4]
DL CLT-DTW MAY 3>1.9[5]
DL CLT-LGA MAY 1.8>0[7]
DL CLT-MSP MAY 1.8>0[4]
DL CMH-DTW MAY 3>2.0[6]
DL CMH-MSP MAY 2.0>1.0[4] JAN 4>3[3]
DL CMH-RDU JAN 1.7>0.9[0.7]
DL CMH-SLC JAN 1.0>0.1[0.1]
DL CVG-DFW OCT 2.0>2[2]
DL CVG-DTW MAY 4>3[5]
DL CVG-IAH NOV 1.7>1.0[0.8] JAN 1.5>1.0[0.7]
DL CVG-LGA MAY 1.8>0[5]
DL CVG-MCI NOV 1.4>1.7[1.4] DEC 0.8>1.0[1.1] JAN 1.2>1.5[1.3]
DL CVG-PHL JAN 2>1.5[1.4]
DL CVG-SLC DEC 2>1.4[1.4] JAN 2>1.1[1.0]
DL CWA-MSP MAY 2>1.5[3]
DL DAY-MSP JAN 3>2.0[1.8]
DL DCA-LGA MAY 1.6>0.5[10]
DL DCA-MSP MAY 3>1.8[6]
DL DCA-SLC MAY 1.0>0.5[1.0]
DL DEN-DTW MAY 2>1.5[4]
DL DEN-JFK MAY 1.0>0[3]
DL DEN-LAX JAN 4>3[3]
DL DEN-MSP MAY 2.0>1.5[5]
DL DFW-DTW MAY 2.0>1.5[5]
DL DFW-LGA MAY 1.0>0[5]
DL DFW-MSP MAY 2.0>1.5[6]
DL DFW-SLC MAY 2.0>1.5[5]
DL DLH-MSP MAY 3>1.9[5]
DL DSM-LGA JAN 1.5>0.8[0.8]
DL DTW-EWR MAY 3>1.5[6]
DL DTW-FLL MAY 2.0>1.0[4]
DL DTW-FRA MAY 0.9>0[1.0]
DL DTW-GRB MAY 2>1.5[4]
DL DTW-GRR MAY 4>3[6]
DL DTW-GSO MAY 0.8>0.5[3]
DL DTW-GSP MAY 0.8>0.5[3]
DL DTW-HND MAY 0.8>0.5[0]
DL DTW-HPN MAY 1.9>0.6[3]
DL DTW-IAH MAY 1.8>1.4[5]
DL DTW-ITH MAY 1.8>1.4[3]
DL DTW-JAX MAY 1.0>0.5[1.8]
DL DTW-LAS MAY 3>1.0[5]
DL DTW-LAX MAY 3>2[6]
DL DTW-LEX MAY 1.8>0.8[4] OCT 5>4[4] NOV 5>4[4]
DL DTW-LHR MAY 1.0>0[1.9]
DL DTW-LIT DEC 0.6>0[0.0] JAN 0.8>0[0]
DL DTW-MBS MAY 3>1.9[5]
DL DTW-MCI MAY 1.8>1.4[4]
DL DTW-MCO MAY 2.0>1.0[6]
DL DTW-MDT MAY 1.8>1.5[4]
DL DTW-MEM MAY 1.0>0.5[3]
DL DTW-MHT MAY 1.8>1.3[3]
DL DTW-MIA MAY 2.0>1.0[2]
DL DTW-MKE MAY 3>1.4[6]
DL DTW-MLI MAY 1.0>0.5[1.9]
DL DTW-MSN MAY 3>1.4[5]
DL DTW-MSY MAY 1.8>0.5[3]
DL DTW-MTY JUN 0.7>0.9[0.8]
DL DTW-OKC DEC 1.8>1.0[1.1] JAN 1.8>1.0[1.0]
DL DTW-OMA DEC 4>3[3] JAN 4>3[2]
DL DTW-ORF JAN 4>3[3]
DL DTW-PDX DEC 1.6>1.0[1.3] JAN 1.7>1.0[0.8]
DL DTW-PHL MAY 3>2[5]
DL DTW-PHX MAY 2.0>1.5[4]
DL DTW-PVD MAY 2>1.5[3]
DL DTW-PWM MAY 1.8>1.0[3]
DL DTW-RDU MAY 3>2.0[4]
DL DTW-RIC JAN 4>3[3]
DL DTW-RSW MAY 2.0>1.0[3]
DL DTW-SAN MAY 1.0>0.5[2]
DL DTW-SBN JAN 5>4[4]
DL DTW-SCE MAY 1.8>1.3[3]
DL DTW-SDF MAY 3>1.4[5]
DL DTW-SEA OCT 6>5[5]
DL DTW-STL MAY 2.0>1.5[5]
DL DTW-TPA MAY 2.0>1.0[4]
DL DTW-TVC MAY 2.0>1.5[4]
DL DTW-TYS MAY 1.8>1.4[4]
DL EWR-MSP MAY 2>1.5[5] DEC 6>4[4] JAN 6>4[4]
DL FAR-MSP MAY 4>3[7]
DL FCA-SLC MAY 2.0>1.5[3]
DL FLL-JFK MAY 1.0>0.5[4]
DL FLL-LGA MAY 1.0>0[5]
DL FSD-MSP MAY 4>3[5]
DL GEG-SEA MAY 4>3[8]
DL GFK-MSP MAY 3>2.0[5]
DL GRB-MSP MAY 2.0>1.0[4] JAN 4>3[3]
DL GRR-MSP MAY 1.8>0.9[5]
DL GRU-JFK MAY 0.9>0[1.0]
DL GSP-LGA MAY 0.8>0[2]
DL GTF-MSP MAY 1.0>0.5[1.0]
DL HLN-SLC MAY 1.8>1.4[3]
DL HND-HNL MAY 0.9>0[0]
DL HND-LAX MAY 1.0>0[1.0]
DL HND-MSP MAY 0.5>0[1.0]
DL HND-SEA MAY 1.0>0.4[0]
DL HNL-KIX MAY 0.4>0[0.9]
DL HNL-LAX MAY 2.0>1.5[4]
DL HNL-MSP MAY 0.7>0[0.7]
DL HNL-NGO MAY 0.4>0[0.7]
DL IAD-JFK MAY 1.0>0[4] JAN 4>3[3]
DL IAH-SLC MAY 2.0>1.5[3]
DL ICN-SEA MAY 0.7>0.5[1.0]
DL ICT-MSP MAY 1.0>0.5[3]
DL IDA-SLC OCT 5>4[4] NOV 5>4[4] JAN 5>4[4]
DL IND-JFK MAY 1.0>0[1.9] DEC 3>2[2.0] JAN 3>2[2.0]
DL IND-MSP MAY 2.0>1.0[5]
DL JAC-SLC MAY 2.0>1.5[3]
**DL JAX-RDU JUN 0.8>0.2[0] JUL 0.8>0[0] AUG 0.8>0[0] SEP 0.8>0[0.8] OCT 0.8>0[1.0] NOV 0.9>0[1.0] DEC 0.8>0[1.0] JAN 0.8>0[0.9]
DL JFK-KIN JUN 0.2>0[1.0]
DL JFK-LAS MAY 1.0>0[5] DEC 5>4[4] JAN 5>4[5]
DL JFK-LAX SEP 9>8[8] OCT 9>8[9] NOV 9>8[9] DEC 9>8[9] JAN 9>8[9]
DL JFK-MCO MAY 1.0>0.5[5]
DL JFK-MEX MAY 1.0>0[1.0]
DL JFK-MIA MAY 1.0>0.5[4]
DL JFK-MSP MAY 2.0>1.5[4]
DL JFK-MSY MAY 1.0>0[3]
DL JFK-ORD MAY 0.8>0[5] DEC 5>4[4] JAN 5>4[4]
DL JFK-PDX DEC 2>1.0[1.3] JAN 2>1.0[1.0]
DL JFK-PIT MAY 0.8>0[3]
DL JFK-RDU MAY 1.6>0[5]
DL JFK-RIC MAY 1.0>0[3]
DL JFK-ROC MAY 3>0.5[3]
DL JFK-SAV MAY 1.0>0[2]
DL JFK-SEA DEC 4>3[4] JAN 4>3[3]
DL JFK-SFO MAY 1.0>0.5[7]
DL JFK-SYR MAY 3>0.5[3] JAN 3>2[2]
DL JFK-TLV MAY 1.0>0.7[1.0]
DL JFK-TPA MAY 1.0>0.5[4]
DL JFK-YUL JAN 3>2[1.8]
DL JFK-YYZ DEC 4>3[3] JAN 4>3[3]
DL LAS-MSP MAY 3>1.0[6]
DL LAS-SLC MAY 3>2[6]
DL LAX-MCI MAY 0.8>0[1.8]
DL LAX-MCO MAY 1.0>0[3]
DL LAX-MSP MAY 3>2[7]
DL LAX-MSY MAY 0.8>0[3]
DL LAX-PVR MAY 0.7>0.5[1.0]
DL LAX-SEA MAY 4>3[9]
DL LAX-SJD MAY 0.8>0.6[2]
DL LAX-SLC MAY 5>3[8]
DL LAX-SMF MAY 2>1.5[5]
DL LAX-SYD MAY 0.9>0[1.0]
DL LEX-MSP DEC 1.0>0.4[0.3] JAN 1.0>0.1[0.0]
DL LGA-MCO MAY 1.0>0[6]
DL LGA-MIA MAY 1.0>0[5] SEP 5>4[4] OCT 5>4[4]
DL LGA-MSP MAY 3>2.0[6]
DL LGA-OMA JAN 2>1.8[1.6]
DL LGA-ORD MAY 1.0>0[13]
DL LGA-PWM JAN 4>3[3]
DL LGA-RDU MAY 1.0>0[7]
DL LGA-RIC MAY 0.8>0[4]
DL LGA-SAV MAY 0.8>0[3] DEC 3>2[2] JAN 3>1.9[1.8]
DL LGA-TPA MAY 1.0>0[4]
DL LGA-TYS MAY 0.8>0[3]
DL LGA-YOW JUN 2>1.8[1.8] JUL 2>1.9[1.7] AUG 3>1.8[1.8] SEP 3>1.9[1.7] OCT 3>1.8[1.7] NOV 3>1.9[1.6] DEC 2>1.9[1.5] JAN 2>1.8[1.7]
DL LGB-SLC MAY 1.8>1.4[4]
DL LNK-MSP MAY 1.8>1.4[3]
DL MCO-MSP MAY 2.0>1.0[4]
DL MCO-SLC MAY 1.9>0.5[3]
DL MEM-MSP MAY 1.0>0.0[3]
DL MFR-SEA MAY 1.8>1.4[3]
DL MIA-MSP MAY 1.0>0.5[1.9]
DL MKE-MSP MAY 3>1.8[5]
DL MLI-MSP NOV 1.9>1.2[1.0] DEC 1.5>1.0[1.0] JAN 1.8>1.0[1.0]
DL MSN-MSP MAY 3>2[5]
DL MSO-MSP DEC 2>1.0[1.3] JAN 2>1.0[0.8]
DL MSP-MSY MAY 1.0>0[1.0]
DL MSP-OKC DEC 3>2[1.6] JAN 3>2[1.0]
DL MSP-ORF DEC 0.5>0[0.1] JAN 0.8>0[0]
DL MSP-PDX MAY 1.8>0.8[3] DEC 5>4[3]
DL MSP-PHL MAY 2>1.5[5]
DL MSP-PHX MAY 3>1.5[5]
DL MSP-PIT MAY 1.8>1.4[4]
DL MSP-PSC DEC 2>1.0[1.1] JAN 2>1.0[0.9]
DL MSP-RAP NOV 5>4[4] JAN 5>4[3]
DL MSP-RDU MAY 2.0>1.0[4] JAN 4>3[3]
DL MSP-RIC JAN 1.8>0.9[1.0]
DL MSP-RST MAY 3>1.9[4]
DL MSP-SBN DEC 1.6>1.0[1.0] JAN 1.8>1.0[1.0]
DL MSP-SDF JAN 3>1.8[1.9]
DL MSP-SEA MAY 4>2[6] JAN 7>6[5]
DL MSP-SFO MAY 1.8>1.0[5]
DL MSP-SLC MAY 4>3[6] OCT 6>5[5] NOV 6>5[5] DEC 6>5[5] JAN 6>5[5]
DL MSP-STL MAY 2.0>1.0[5]
DL MSP-XWA SEP 3>2[0] OCT 3>2[1.4] NOV 3>2[1.9]
DL MSP-YWG MAY 0.6>0.3[4]
DL MSP-YXE MAY 0.6>0.3[1.9]
DL MSY-SLC MAY 0.7>0.4[1.0]
DL OAK-SLC MAY 2.0>1.5[5]
DL OGG-SEA MAY 1.0>0.5[1.0]
DL OKC-SLC OCT 3>2[1.8] NOV 3>2[1.7] DEC 3>2[1.8] JAN 3>2[1.9]
DL OMA-SLC SEP 3>2[1.9] OCT 3>2[1.7] NOV 3>2[1.7]
DL ORD-SLC MAY 1.8>1.0[4]
DL PDX-SLC DEC 6>5[5] JAN 6>5[5]
DL PSC-SLC OCT 4>3[3] NOV 4>3[3] DEC 4>3[3] JAN 4>3[3]
DL PSP-SLC MAY 2.0>1.5[2]
DL RAP-SLC NOV 2>1.0[1.0] DEC 2>1.0[1.0] JAN 2>1.0[1.0]
DL RDM-SEA MAY 2>1.5[3]
DL SEA-SFO SEP 8>7[7] OCT 8>7[7] NOV 8>7[6] JAN 8>7[5]
DL SEA-SLC MAY 5>4[8]
DL SLC-TUS OCT 4>3[3] NOV 4>3[3] DEC 4>3[3] JAN 4>3[2]
DY AMS-JFK MAY 1.0>0[1.0]
DY ATH-JFK MAY 0.6>0[0]
DY AUS-CDG MAY 0.4>0[0]
DY BCN-FLL MAY 0.3>0[0.3]
DY BCN-JFK MAY 1.0>0[0]
DY BCN-LAX MAY 0.9>0[0.7]
DY BCN-ORD MAY 0.4>0[0]
DY BCN-SFO MAY 0.5>0[0]
DY BOS-CDG MAY 0.7>0[0.6]
DY CDG-DEN MAY 0.6>0[0.5]
DY CDG-FLL MAY 0.4>0[0.4]
DY CDG-JFK MAY 1.3>0[1.0]
DY CDG-LAX MAY 1.1>0[1.2]
DY CDG-MCO MAY 0.3>0[0.3]
DY CDG-ORD MAY 0.7>0[0]
DY CDG-SFO MAY 0.4>0[0]
DY FLL-OSL MAY 0.3>0[0.3]
DY JFK-OSL MAY 0.6>0[0.7]
DY LAX-MAD MAY 0.4>0[0.6]
DY LAX-OSL MAY 0.3>0[0.3]
DY OSL-SFO MAY 0.3>0[0]
EK BOS-DXB MAY 1.0>0[0.9]
EK DFW-DXB MAY 1.0>0[1.0]
EK DXB-EWR JUN 1.0>0[1.0] JUL 1.0>0[1.0]
EK DXB-FLL JUL 0.5>0[0.5] AUG 0.6>0[0.6]
EK DXB-IAD MAY 1.0>0[1.0]
EK DXB-IAH JUN 1.0>0[1.0] JUL 1.0>0[1.0]
EK DXB-LAX MAY 1.0>0[1.0] JUN 1.0>0[1.0]
EK DXB-MCO JUN 1.0>0[0.7]
EK DXB-SEA JUN 1.0>0.3[1.0]
EK JFK-MXP MAY 0.4>0[1.0]
EW FRA-LAS MAY 0.6>0.3[0]
EY AUH-IAD MAY 1.0>0.5[1.0]
EY AUH-JFK MAY 1.0>0.6[1.0]
EY AUH-LAX MAY 0.6>0[0.5]
EY AUH-ORD MAY 1.0>0.6[1.0]
F9 extended their schedule from early NOV to JAN. Changes prior to that are versus their prior filed schedule.
This the first wholesale reduction we have seen for the AUG/SEP timeframe. This is very relevant because CARES Act participants can't layoff till October 1 and if you have no data on route performance prior to October, an airline isn't likely to add it back (keep the jobs) on Octover 1.
F9 ALB-MCO NOV 0.1>0.4[0.5] DEC 0>0.5[0.2] JAN 0>0.4[0.6]
**F9 ATL-AUS AUG 0.2>0[0.6] SEP 0.3>0[0.6] OCT 0.3>0[0.5]
F9 ATL-CVG AUG 0.7>1.0[0.4] SEP 0.6>1.0[0.4] OCT 0.6>1.0[0.5] NOV 0.2>0.4[0.2]
**F9 ATL-LAX AUG 0.4>0[0.4] SEP 0.6>0[0.4] OCT 0.6>0[0.5]
F9 ATL-MCO AUG 1.3>2[1.1] SEP 1.0>2[1.5] OCT 1.0>2[1.5] NOV 0.3>2[1.8] DEC 0>2[1.8] JAN 0>2[1.9]
F9 ATL-MIA NOV 0.6>2[0.7] DEC 0>2[1.0] JAN 0>2[1.0]
F9 ATL-PHL NOV 0.3>1.0[0.5] DEC 0>1.0[0.5] JAN 0>1.0[0.6]
**F9 ATL-SAT AUG 0.2>0[0.4] SEP 0.3>0[0.4] OCT 0.3>0[0.5]
**F9 ATL-SFO AUG 0.3>0[0.6] SEP 0.4>0[0.6] OCT 0.4>0[0.5]
F9 ATL-TPA NOV 0.3>1.0[0.4] DEC 0>1.0[0.5] JAN 0>1.0[0.4]
**F9 AUS-CLE AUG 0.4>0[0.3] SEP 0.6>0[0.3] OCT 0.6>0[0.3]
F9 AUS-IAD AUG 0.1>0.4[0.6] SEP 0>0.4[0.6] OCT 0>0.4[0.6]
F9 AUS-MCO NOV 0.3>1.0[0.5] DEC 0>1.0[0.5] JAN 0>1.0[0.4]
F9 AUS-MIA NOV 0.1>0.5[0] DEC 0>0.5[0] JAN 0>0.6[0]
**F9 AUS-MSY AUG 0.3>0[0.4] SEP 0.4>0[0.4] OCT 0.4>0[0.5]
**F9 AUS-PHL AUG 0.2>0[0.5] SEP 0.3>0[0.6] OCT 0.3>0[0.5]
F9 BDL-MIA NOV 0>0.3[0.6] JAN 0>0.4[0.3]
F9 BIL-DEN NOV 0.1>0.3[0.4] DEC 0>0.3[0.4] JAN 0>0.3[0.2]
F9 BMI-MCO DEC 0>0.5[0.4] JAN 0>0.4[0.3]
F9 BNA-DEN NOV 0.3>1.0[0.8] DEC 0>1.0[0.5] JAN 0>1.0[0.5]
F9 BNA-LAS NOV 0.1>0.5[0.7] JAN 0>0.4[0.6]
**F9 BNA-TTN AUG 0.2>0[0.4] SEP 0.3>0[0.4] OCT 0.3>0[0.5]
**F9 BOS-DEN AUG 0.3>0[1.0] SEP 0.4>0[1.0] OCT 0.4>0[1.0]
F9 BOS-MIA NOV 0.3>1.0[0.6] DEC 0>1.0[0.6] JAN 0>1.0[0.5]
**F9 BOS-PHL AUG 0.7>0[0] SEP 1.0>0[0] OCT 1.0>0[0] NOV 0.3>0[0]
**F9 BOS-RDU AUG 0.4>0[0.6] SEP 0.6>0[0.6] OCT 0.6>0[0.5]
**F9 BOS-SJU AUG 0.7>0[0] SEP 1.0>0[0] OCT 1.0>0[0] DEC 0>1.0[0] JAN 0>1.0[0]
F9 BTV-MCO NOV 0>0.2[0.3] DEC 0>0.3[0.4] JAN 0>0.3[0.4]
F9 BUF-MCO NOV 0.2>0.8[1.0] DEC 0>1.0[0.9] JAN 0>1.0[0.9]
F9 BWI-MCO AUG 0.9>0.7[0.4] SEP 1.0>0.7[0.4] OCT 1.0>0.7[0.5] NOV 0.3>0.9[0.5] DEC 0>1.0[0.5] JAN 0>1.0[0.6]
F9 BWI-MIA AUG 0.9>0.7[0] SEP 1.0>0.7[0] OCT 1.0>0.7[0]
F9 BWI-SAL NOV 0.3>0[0]
**F9 BWI-SJU AUG 0.7>0[0] SEP 1.0>0[0] OCT 1.0>0[0] DEC 0>1.0[0] JAN 0>1.0[0]
F9 BZN-DEN NOV 0.2>0.5[0.6] DEC 0>0.5[0.6] JAN 0>0.6[0.5]
**F9 CHS-CLE AUG 0.2>0[0.3] SEP 0.3>0[0.3] OCT 0.3>0[0.3]
**F9 CHS-TTN AUG 0.3>0[0.5] SEP 0.4>0[0.6] OCT 0.4>0[0.5]
**F9 CLE-CUN AUG 0.2>0.5[0.2] SEP 0.1>0.4[0.1] OCT 0.2>0.4[0.1] NOV 0.0>0.5[0.3] DEC 0>0.5[0.4] JAN 0>0.6[0.4]
F9 CLE-LAS NOV 0.3>1.0[1.3] DEC 0>1.0[1.4] JAN 0>1.0[1.5]
F9 CLE-MCO NOV 0.6>2[1.5] DEC 0>2[1.5] JAN 0>2[1.4]
F9 CLE-MIA NOV 0>0.4[0.6] JAN 0>0.6[0.5]
**F9 CLE-MSP AUG 0.3>0[0.6] SEP 0.4>0[0.6] OCT 0.4>0[0.1]
F9 CLE-PBI JAN 0>0.4[0.6]
**F9 CLE-SEA AUG 0.4>0[0.6]
F9 CLE-SRQ JAN 0>0.6[0.4]
F9 CLT-DEN NOV 0.3>1.0[1.0] DEC 0>1.0[0.5] JAN 0>1.0[0.9]
F9 CMH-DEN NOV 0.1>0.4[0.5] DEC 0>0.5[0.4] JAN 0>0.4[0.3]
F9 CMH-MCO AUG 0.1>0.3[0.3] NOV 0>0.3[0.4] DEC 0>0.3[0.5] JAN 0>0.3[0.4]
F9 COS-LAS AUG 0.9>0.7[1.3] SEP 1.0>0.7[1.3] OCT 1.0>0.7[1.3] NOV 0.3>1.1[1.4] DEC 0>1.2[1.5] JAN 0>1.3[1.4]
**F9 COS-MCO AUG 0.2>0[0.6] SEP 0.3>0[0.1] OCT 0.3>0[0.5] DEC 0>0.3[0.5] JAN 0>0.3[0.4]
F9 COS-PHX AUG 0.9>0.7[1.0] SEP 1.0>0.7[1.0] OCT 1.0>0.7[1.0] NOV 0.3>0.7[1.2] DEC 0>0.7[1.5] JAN 0>0.7[1.4]
F9 CUN-EWR NOV 0.3>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0]
F9 CUN-PHL NOV 0.2>0.8[0.6] DEC 0>1.0[0.6] JAN 0>1.0[0.6]
F9 CVG-DEN NOV 0.3>1.0[0.8] DEC 0>1.0[0.2] JAN 0>1.0[0.6]
**F9 CVG-DFW AUG 0.2>0[0.1] SEP 0.3>0[0] OCT 0.3>0[0]
**F9 CVG-LAX AUG 0.3>0[0.5] SEP 0.4>0[0.6] OCT 0.4>0[0.5]
F9 CVG-MCO NOV 0.3>1.6[1.5] DEC 0>2[1.4] JAN 0>2[1.5]
F9 CVG-MIA DEC 0>1.0[0.5] JAN 0>1.0[0.5]
**F9 CVG-MSP AUG 0.2>0[0.4] SEP 0.3>0[0.4] OCT 0.3>0[0.1]
F9 CVG-RSW NOV 0.1>0.8[1.0] DEC 0>1.0[1.3] JAN 0>1.0[1.3]
**F9 CVG-SAN AUG 0.2>0[0.3] SEP 0.3>0[0.0] OCT 0.3>0[0]
F9 CVG-TPA NOV 0.1>0.8[0.6] DEC 0>1.0[0.6] JAN 0>1.0[0.6]
F9 DEN-DFW SEP 3>2[2] NOV 0.6>2[1.6] DEC 0>2[1.4] JAN 0>2[1.4]
F9 DEN-DSM NOV 0.2>0.5[0.6] DEC 0>0.5[0.6] JAN 0>0.6[0.5]
F9 DEN-DTW AUG 0.8>0.5[0.9] SEP 1.0>0.4[1.0] OCT 1.0>0.5[1.0]
F9 DEN-ELP NOV 0.2>0.4[0.5] DEC 0>0.5[0.4] JAN 0>0.4[0.3]
F9 DEN-FAR AUG 0.5>0.3[0.4] SEP 0.6>0.3[0.4] OCT 0.6>0.3[0.4]
F9 DEN-FAT NOV 0.2>0.6[0.4] DEC 0>0.5[0.3] JAN 0>0.6[0.3]
F9 DEN-FSD NOV 0.2>0.5[0.5] JAN 0>0.6[0.4]
F9 DEN-GEG AUG 0.5>0.3[0.4] SEP 0.5>0.3[0.4]
F9 DEN-IAH AUG 1.1>1.9[2] SEP 0.8>2[2] OCT 0.9>2[2] NOV 0.3>2[1.4] DEC 0>2[1.0] JAN 0>2[1.0]
F9 DEN-ICT NOV 0.1>0.4[0.5] JAN 0>0.4[0.6]
F9 DEN-IND NOV 0.3>1.0[0.8] DEC 0>1.0[0.5] JAN 0>1.0[0.6]
F9 DEN-LIT NOV 0.1>0.4[0.5] DEC 0>0.5[0.3] JAN 0>0.4[0.3]
F9 DEN-MCO NOV 0.5>1.7[2] DEC 0>1.7[2] JAN 0>1.7[2]
F9 DEN-MEM NOV 0.2>0.5[0.5] DEC 0>0.5[0.4] JAN 0>0.6[0.3]
F9 DEN-MSP NOV 0.3>1.0[2] DEC 0>1.0[2.0] JAN 0>1.0[2]
F9 DEN-MSY AUG 0.8>1.0[1.0] SEP 0.7>1.0[1.0] OCT 0.7>1.0[1.0] NOV 0.2>1.0[0.8] DEC 0>1.0[0.5] JAN 0>1.0[0.6]
F9 DEN-OKC NOV 0.1>0.4[0.4] DEC 0>0.5[0.3] JAN 0>0.4[0.3]
F9 DEN-ONT NOV 0.3>1.0[1.0] DEC 0>1.0[0.8] JAN 0>1.0[0.7]
F9 DEN-PDX NOV 0.6>1.4[1.4] DEC 0>1.0[0.9] JAN 0>1.0[0.7]
F9 DEN-PNS NOV 0.1>0.5[0.4] DEC 0>0.5[0.4] JAN 0>0.6[0.3]
F9 DEN-PSP DEC 0>0.5[0.4] JAN 0>0.4[0.3]
**F9 DEN-PWM AUG 0.4>0[0.4] SEP 0.6>0[0.4] OCT 0.6>0[0.4]
F9 DEN-RNO AUG 0.5>0.3[0.4] SEP 0.5>0.3[0.4]
F9 DEN-SAT NOV 0.2>0.5[0.8] JAN 0>0.6[0.5]
**F9 DEN-SBA AUG 0.2>0[0.4] SEP 0.3>0[0.4] OCT 0.3>0[0.5]
F9 DEN-SEA NOV 0.6>1.0[1.2] JAN 0>0.6[0.5]
F9 DEN-SLC NOV 0.9>3[2] DEC 0>3[2] JAN 0>3[2]
F9 DEN-SMF NOV 0.3>1.0[0.5] DEC 0>1.0[0.5] JAN 0>1.0[0.6]
F9 DEN-STL AUG 1.3>1.5[2] SEP 1.0>1.4[1.9] OCT 1.0>1.4[1.9] NOV 0.3>1.1[1.1] DEC 0>0.8[0.5] JAN 0>0.9[0.6]
F9 DEN-TPA NOV 0.3>1.0[1.4] DEC 0>1.0[1.5] JAN 0>1.0[1.6]
F9 DEN-TYS AUG 0.5>0.3[0.6] SEP 0.6>0.3[0.6] OCT 0.6>0.3[0.5] NOV 0.2>0.4[0.5] DEC 0>0.5[0.4] JAN 0>0.4[0.3]
**F9 DFW-EWR AUG 0.7>0[0] SEP 1.0>0[0] OCT 1.0>0[0] NOV 0.3>0[0]
F9 DFW-LAS AUG 0.8>0.5[0.6] SEP 1.0>0.5[0.6] OCT 1.0>0.6[0.5] NOV 0.3>0.8[0.6] DEC 0>1.0[0.5] JAN 0>1.0[0.5]
F9 DFW-MCO AUG 0.8>0.5[0.6] SEP 1.0>0.4[0.6] OCT 1.0>0.5[0.5] NOV 0.3>0.8[0.6] DEC 0>1.0[0.5] JAN 0>1.0[0.5]
F9 DFW-PHL NOV 0.1>0.4[0.5] JAN 0>0.4[0.6]
F9 DTW-MIA NOV 0.2>0.8[0.3] DEC 0>1.0[0.5] JAN 0>1.0[0.6]
**F9 DTW-PHX AUG 0.4>0[0] SEP 0.5>0[0] OCT 0.6>0[0] NOV 0.2>0.6[0.3] DEC 0>1.0[0.5] JAN 0>1.0[0.6]
**F9 DTW-RDU AUG 0.3>0[0.5] SEP 0.4>0[0.1] OCT 0.4>0[0]
**F9 ELP-ORD AUG 0.2>0[0.1] SEP 0.3>0[0] OCT 0.3>0[0]
**F9 EWR-ONT AUG 0.7>0[0] SEP 1.0>0[0] OCT 1.0>0[0] NOV 0.3>0[0]
F9 EWR-RDU AUG 0.9>0.6[0] SEP 1.0>0.6[0] OCT 1.0>0.6[0]
**F9 EWR-SDQ AUG 0.7>0[0] SEP 1.0>0[0] OCT 1.0>0[0] NOV 0.3>0[0]
**F9 EWR-STI AUG 0.7>0[0] SEP 1.0>0[0] OCT 1.0>0[0] NOV 0.3>0[0]
F9 EWR-TPA NOV 0.3>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0]
F9 GEG-LAS NOV 0>0.4[0.6] DEC 0>0.5[0.7] JAN 0>0.6[0.7]
F9 GRR-MCO NOV 0.1>0.7[0.6] DEC 0>1.0[0.5] JAN 0>1.0[0.6]
F9 GRR-RSW JAN 0>0.4[0.6]
F9 GRR-TPA JAN 0>0.4[0.6]
**F9 GUA-MIA AUG 0.4>0[0] SEP 0.6>0[0] OCT 0.6>0[0]
**F9 GUA-ONT AUG 0.4>0[0] SEP 0.6>0[0] OCT 0.6>0[0]
F9 HSV-MCO NOV 0.1>0.4[0.3] DEC 0>0.5[0.3] JAN 0>0.4[0.3]
F9 IAD-MCO NOV 0.1>0.8[0.2] DEC 0>1.0[0.4] JAN 0>1.0[0.5]
F9 IAH-PHL AUG 0.5>0.3[0.6] SEP 0.6>0.3[0.6] OCT 0.6>0.3[0.6]
**F9 IAH-RDU AUG 0.2>0[0.3] SEP 0.3>0[0.3] OCT 0.3>0[0.5]
**F9 ILG-MCO AUG 0.3>0[0] SEP 0.4>0[0] OCT 0.4>0[0] DEC 0>0.5[0] JAN 0>0.4[0]
F9 IND-MCO NOV 0.1>0.8[0.6] DEC 0>1.0[0.6] JAN 0>1.0[0.6]
F9 ISP-MIA NOV 0.3>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0]
F9 ISP-PBI NOV 0>1.0[0.7] DEC 0>1.5[1.0] JAN 0>1.6[1.0]
F9 ISP-RDU AUG 0.4>0.6[0.4] SEP 0.3>0.6[0.4] OCT 0.3>0.6[0.5]
**F9 JAN-MCO AUG 0.2>0[0.3] SEP 0.3>0[0.3] OCT 0.3>0[0.3]
F9 JAX-PHL NOV 0.1>0.5[0.6] JAN 0>0.6[0.5]
**F9 JAX-TTN AUG 0.2>0[0.4] SEP 0.3>0[0.4] OCT 0.3>0[0.5]
F9 LAS-LAX AUG 0.9>0.7[0] SEP 1.0>0.7[0.7] OCT 1.0>0.7[1.0] NOV 0.3>0.7[0.6] DEC 0>0.7[0.8] JAN 0>0.7[1.5]
F9 LAS-OMA NOV 0.1>0.5[0.7] DEC 0>0.5[0.8] JAN 0>0.6[0.8]
F9 LAS-ONT AUG 0.9>0.7[0] SEP 1.0>0.7[0] OCT 1.0>0.7[0] NOV 0.3>0.6[0] DEC 0>0.5[0] JAN 0>0.6[0]
F9 LAS-PDX NOV 0.2>0.7[0.3] DEC 0>0.7[0.6] JAN 0>0.7[0.6]
F9 LAS-PHX AUG 1.2>0.6[0] SEP 1.4>0.5[1.2] OCT 1.4>0.6[1.5] NOV 0.5>1.3[1.7] DEC 0>1.7[1.8] JAN 0>1.7[2]
F9 LAS-RNO NOV 0.2>0.7[0.3] DEC 0>0.7[0.6] JAN 0>0.7[0.6]
F9 LAS-SAN AUG 0.9>0.7[0.7] SEP 1.0>0.7[0.9] OCT 1.0>0.7[0.8] NOV 0.3>0.7[0.9] DEC 0>0.7[1.0] JAN 0>0.7[1.1]
F9 LAS-SAT NOV 0.2>0.5[0.8] DEC 0>0.5[0.4] JAN 0>0.4[0.5]
F9 LAS-SEA NOV 0.2>0.7[0.3] DEC 0>0.7[0.6] JAN 0>0.7[0.6]
F9 LAS-SFO NOV 0.3>1.6[1.0] DEC 0>2[1.0] JAN 0>2[1.2]
F9 LAS-SJC NOV 0.3>1.6[0.9] DEC 0>2[0.7] JAN 0>2[1.2]
F9 LAS-SLC AUG 0.9>0.6[0.4] SEP 1.0>0.5[0.9] OCT 1.0>0.6[1.0] NOV 0.3>1.5[0.8] DEC 0>2[0.6] JAN 0>2[0.8]
F9 LAS-SMF NOV 0.3>1.0[1.0] DEC 0>1.0[0.8] JAN 0>1.0[1.3]
**F9 LAX-PHL AUG 0.7>0[0] SEP 1.0>0[0] OCT 1.0>0[0] NOV 0.3>0[0]
F9 LAX-PHX AUG 0.9>0.7[0] SEP 1.0>0.7[0] OCT 1.0>0.7[0] NOV 0.3>0.7[0] DEC 0>0.7[0] JAN 0>0.7[0]
F9 MCO-MEM NOV 0.2>0.5[0.3] DEC 0>0.5[0.4] JAN 0>0.6[0.3]
F9 MCO-MSN NOV 0>0.4[0.1] DEC 0>0.5[0.2] JAN 0>0.6[0.4]
F9 MCO-MSP NOV 0.1>0.4[0.8] JAN 0>0.4[0.6]
F9 MCO-MSY NOV 0.2>0.8[0.4] DEC 0>1.0[0.5] JAN 0>1.0[0.5]
F9 MCO-OKC NOV 0>0.3[0.1] DEC 0>0.5[0.3] JAN 0>0.4[0.3]
F9 MCO-ONT AUG 0.9>0.7[0.8] SEP 1.0>0.7[0.9] OCT 1.0>0.7[1.0] NOV 0.3>0.9[1.0] DEC 0>1.0[0.6] JAN 0>1.0[0.2]
F9 MCO-ORD NOV 0.3>1.0[1.4] DEC 0>1.0[1.5] JAN 0>1.0[1.5]
F9 MCO-ORF NOV 0.1>0.5[0.4] DEC 0>0.5[0.4] JAN 0>0.6[0.4]
F9 MCO-PHL NOV 1.0>4[3] DEC 0>4[3] JAN 0>4[3]
F9 MCO-PWM NOV 0.1>0.7[0.4] DEC 0>1.0[0.5] JAN 0>1.0[0.5]
F9 MCO-SAT NOV 0.1>0.5[0.4] JAN 0>0.6[0.4]
F9 MCO-STL NOV 0.3>1.6[1.0] DEC 0>2[1.0] JAN 0>2[1.0]
**F9 MIA-ONT AUG 0.7>0[0] SEP 1.0>0[0] OCT 1.0>0[0] NOV 0.3>0[0]
**F9 MIA-SAL AUG 0.3>0[0] SEP 0.4>0[0] OCT 0.4>0[0]
F9 MIA-SDQ AUG 0.8>0.3[0] SEP 1.0>0.3[0] OCT 1.0>0.3[0] DEC 0>0.3[0] JAN 0>0.3[0]
F9 MIA-SJU NOV 0.3>1.0[0.2] DEC 0>1.0[0.5] JAN 0>1.0[0.4]
F9 MIA-TTN NOV 0.1>0.8[0] DEC 0>1.0[0] JAN 0>1.0[0]
F9 MKE-RSW NOV 0>0.4[0.6] DEC 0>0.5[1.0] JAN 0>0.6[1.0]
**F9 MKE-TPA AUG 0.4>0[0.1] SEP 0.5>0[0] OCT 0.6>0[0] DEC 0>0.5[1.0] JAN 0>0.6[1.0]
F9 MSP-TPA JAN 0>0.4[0.6]
**F9 ONT-SAL AUG 0.3>0[0] SEP 0.4>0[0] OCT 0.4>0[0]
**F9 ONT-SEA AUG 0.3>0[0] SEP 0.4>0[0] OCT 0.4>0[0]
**F9 ORD-PHL AUG 0.3>0[0] SEP 0.4>0[0] OCT 0.4>0[0]
F9 ORD-RSW NOV 0>0.3[0.6] DEC 0>0.5[1.0] JAN 0>0.4[1.0]
F9 ORD-SJU AUG 1.0>0.3[0] SEP 1.0>0[0] OCT 1.0>0[0] DEC 0>1.0[0] JAN 0>1.0[0]
**F9 ORD-TPA AUG 0.7>0[0.4] SEP 1.0>0[0.4] OCT 1.0>0[0.5] DEC 0>0.5[0.4] JAN 0>0.6[0.8]
F9 PBI-PHL DEC 0>1.0[0.9] JAN 0>1.0[0.6]
F9 PBI-TTN NOV 0.2>0.8[1.0] DEC 0>1.0[1.5] JAN 0>1.0[1.4]
F9 PHL-RDU AUG 0.6>1.0[0.4] SEP 0.4>1.0[0.4] OCT 0.4>1.0[0.5] NOV 0.1>0.6[0.2] DEC 0>0.5[0] JAN 0>0.4[0]
F9 PHL-SJU AUG 1.7>1.0[1.7] SEP 2.0>1.0[2.0] OCT 2.0>1.0[2.0] NOV 0.6>1.0[2.1] DEC 0>1.0[2.0] JAN 0>1.0[2.0]
F9 PHL-SRQ DEC 0>0.3[0.5] JAN 0>0.3[0.4]
F9 PHL-TPA NOV 0.3>1.0[1.5] DEC 0>1.0[2.0] JAN 0>1.0[2.0]
F9 PHX-SAN AUG 0.9>0.7[0] SEP 1.0>0.7[0] OCT 1.0>0.7[0] NOV 0.3>0.7[0.6] DEC 0>0.7[0.8] JAN 0>0.7[0.8]
F9 PHX-SJC NOV 0.3>0.9[0] DEC 0>0.7[0] JAN 0>0.7[0]
F9 PHX-SLC AUG 0.9>0.6[0] SEP 1.0>0.5[0] OCT 1.0>0.6[0] NOV 0.3>0.7[0.6] DEC 0>0.7[0.8] JAN 0>0.7[0.8]
F9 PVD-RSW NOV 0>0.4[0.2] JAN 0>0.6[0.4]
**F9 PWM-RDU AUG 0.4>0[0.4] SEP 0.6>0[0.4] OCT 0.6>0[0.4]
F9 PWM-RSW JAN 0>0.4[0.6]
F9 RSW-SYR JAN 0>0.4[0.6]
**F9 SJU-TPA AUG 0.4>0[0] SEP 0.6>0[0] OCT 0.6>0[0]
Is this all G4 flying?
G4 ABE-BNA MAY 0.4>0[0.2]
G4 ABE-MDW MAY 0.2>0[0]
G4 ABE-MYR MAY 0.4>0[0.4]
G4 ABE-PGD MAY 0.6>0[0.5]
G4 ABE-PIE MAY 0.8>0[0.4]
G4 ABE-SAV MAY 0.3>0[0]
G4 ABE-SFB MAY 1.7>0[1.5]
G4 ABE-SRQ MAY 0.3>0[0]
G4 ABQ-LAS MAY 0.3>0[0.3]
G4 ALB-PIE MAY 0.3>0[0.4]
G4 ALB-SFB MAY 0.3>0[0.4]
G4 ATW-AZA MAY 0.3>0[0.3]
G4 ATW-BNA MAY 0.3>0[0]
G4 ATW-LAS MAY 0.3>0[0.3]
G4 ATW-PGD MAY 0.3>0[0]
G4 ATW-PIE MAY 0.3>0[0.3]
G4 ATW-SFB MAY 0.3>0[0.3]
G4 AUS-CVG MAY 0.3>0[0.3]
G4 AUS-IND MAY 0.3>0[0.3]
G4 AUS-LAS MAY 0.3>0[0.6]
G4 AUS-MEM MAY 0.3>0[0.3]
G4 AUS-PIT MAY 0.3>0[0.3]
G4 AVL-BOS MAY 0.2>0[0]
G4 AVL-BWI MAY 0.3>0[0.3]
G4 AVL-DEN MAY 0.2>0[0.3]
G4 AVL-EWR MAY 0.5>0[0.7]
G4 AVL-FLL MAY 2>0[2]
G4 AVL-PBI MAY 0.3>0[0]
G4 AVL-PGD MAY 0.5>0[0.5]
G4 AVL-PIE MAY 1.4>0[1.3]
G4 AVL-SFB MAY 2>0[1.0]
G4 AVL-SRQ MAY 0.3>0[0.3]
G4 AZA-BIL MAY 0.4>0[0.3]
G4 AZA-BIS MAY 0.4>0[0.5]
G4 AZA-BLI MAY 0.4>0[0.4]
G4 AZA-BZN MAY 0.3>0[0.3]
G4 AZA-CID MAY 0.5>0[0.4]
G4 AZA-CVG MAY 0.3>0[0.3]
G4 AZA-DSM MAY 0.4>0[0.5]
G4 AZA-EUG MAY 0.3>0[0.3]
G4 AZA-FAR MAY 0.6>0[0.5]
G4 AZA-FCA MAY 0.2>0[0.2]
G4 AZA-FSD MAY 0.6>0[0.6]
G4 AZA-GRI MAY 0.3>0[0.4]
G4 AZA-GRR MAY 0.4>0[0.4]
G4 AZA-GTF MAY 0.3>0[0.3]
G4 AZA-ICT MAY 0.3>0[0.3]
G4 AZA-IDA MAY 0.3>0[0.4]
G4 AZA-LAS MAY 0.4>0[0.5]
G4 AZA-MLI MAY 0.3>0[0.3]
G4 AZA-MOT MAY 0.3>0[0.3]
G4 AZA-MSO MAY 0.3>0[0.3]
G4 AZA-OAK MAY 0.3>0[0.5]
G4 AZA-OGD MAY 0.3>0[0.3]
G4 AZA-OMA MAY 0.3>0[0.3]
G4 AZA-PIA MAY 0.5>0[0.5]
G4 AZA-PSC MAY 0.3>0[0.3]
G4 AZA-PVU MAY 1.9>0[1.5]
G4 AZA-RAP MAY 0.4>0[0.5]
G4 AZA-RFD MAY 0.4>0[0.4]
G4 AZA-SBN MAY 0.3>0[0.3]
G4 AZA-SCK MAY 0.3>0[0.3]
G4 AZA-SGF MAY 0.5>0[0.5]
G4 AZA-TVC MAY 0.3>0[0]
G4 BGR-PIE MAY 0.4>0[0.4]
G4 BGR-SFB MAY 0.5>0[0.6]
G4 BIL-LAS MAY 0.3>0[0.3]
G4 BIS-LAS MAY 0.4>0[0.4]
G4 BIS-SFB MAY 0.2>0[0.2]
G4 BLI-LAS MAY 1.9>0[2]
G4 BLI-LAX MAY 0.3>0[0.3]
G4 BLI-OAK MAY 0.4>0[0.6]
G4 BLI-PSP MAY 0.4>0[0.5]
G4 BLI-SAN MAY 0.3>0[0.3]
G4 BLV-JAX MAY 0.2>0[0.3]
G4 BLV-LAS MAY 0.3>0[0.3]
G4 BLV-PGD MAY 0.4>0[0.4]
G4 BLV-PIE MAY 0.7>0[0.5]
G4 BLV-SFB MAY 0.5>0[0.5]
G4 BLV-SRQ MAY 0.3>0[0]
G4 BLV-VPS MAY 1.3>0[0.9]
G4 BMI-PIE MAY 0.3>0[0.3]
G4 BMI-SFB MAY 0.3>0[0.3]
G4 BNA-CID MAY 0.4>0[0.2]
G4 BNA-CLE MAY 0.3>0[0.2]
G4 BNA-DSM MAY 0.3>0[0]
G4 BNA-GRR MAY 0.3>0[0]
G4 BNA-MDT MAY 0.3>0[0]
G4 BNA-PGD MAY 0.3>0[0.4]
G4 BNA-PIE MAY 0.3>0[0.3]
G4 BNA-RIC MAY 0.3>0[0.3]
G4 BNA-SFB MAY 0.3>0[0.2]
G4 BNA-SRQ MAY 0.3>0[0.3]
G4 BNA-SYR MAY 0.3>0[0.3]
G4 BNA-XNA MAY 0.3>0[0]
G4 BOI-LAS MAY 0.3>0[0.3]
G4 BOI-LAX MAY 0.3>0[0.3]
G4 BOS-GRR MAY 0.3>0[0]
G4 BOS-TYS MAY 0.2>0[0]
G4 BOS-VPS MAY 0.2>0[0]
G4 BWI-SAV MAY 0.3>0[0.3]
G4 BWI-SRQ MAY 0.3>0[0.3]
G4 BWI-TYS MAY 0.2>0[0.2]
G4 BWI-VPS MAY 0.2>0[0.3]
G4 BZN-LAS MAY 0.3>0[0.3]
G4 CHA-PIE MAY 0.3>0[0.3]
G4 CHA-SFB MAY 0.3>0[0.3]
G4 CHS-CLE MAY 0.3>0[0]
G4 CHS-CVG MAY 0.3>0[0.3]
G4 CHS-IND MAY 0.3>0[0.3]
G4 CHS-LCK MAY 0.3>0[0]
G4 CHS-PGD MAY 0.2>0[0]
G4 CHS-PIT MAY 0.3>0[0.3]
G4 CID-LAS MAY 0.3>0[0.3]
G4 CID-PGD MAY 0.3>0[0.3]
G4 CID-PIE MAY 0.3>0[0.3]
G4 CID-SFB MAY 0.3>0[0.3]
G4 CKB-SFB MAY 0.3>0[0.3]
G4 CLE-JAX MAY 0.3>0[0.3]
G4 CLE-PGD MAY 0.3>0[0.4]
G4 CLE-PIE MAY 0.2>0[0.3]
G4 CLE-SAV MAY 0.7>0[0.5]
G4 CLE-SFB MAY 0.3>0[0.3]
G4 CLE-SRQ MAY 0.3>0[0.3]
G4 CVG-EWR MAY 0.3>0[0.5]
G4 CVG-FLL MAY 1.5>0[1.0]
G4 CVG-JAX MAY 0.3>0[0.3]
G4 CVG-LAS MAY 0.6>0[0.6]
G4 CVG-LAX MAY 0.5>0[0.6]
G4 CVG-MSY MAY 0.4>0[0.3]
G4 CVG-MYR MAY 0.4>0[0.4]
G4 CVG-PBI MAY 0.3>0[0]
G4 CVG-PGD MAY 1.5>0[1.1]
G4 CVG-PIE MAY 1.7>0[1.1]
G4 CVG-SAV MAY 0.8>0[0.5]
G4 CVG-SFB MAY 1.6>0[1.1]
G4 CVG-SRQ MAY 0.6>0[0.5]
G4 CVG-VPS MAY 1.3>0[1.0]
G4 DAY-PGD MAY 0.3>0[0]
G4 DAY-PIE MAY 0.3>0[0.3]
G4 DAY-SFB MAY 0.3>0[0.3]
G4 DAY-VPS MAY 0.2>0[0]
G4 DSM-LAS MAY 0.7>0[0.6]
G4 DSM-PGD MAY 0.4>0[0.3]
G4 DSM-PIE MAY 0.6>0[0.4]
G4 DSM-SFB MAY 0.5>0[0.4]
G4 ELM-PIE MAY 0.3>0[0.3]
G4 ELM-SFB MAY 0.4>0[0.5]
G4 ELP-LAS MAY 0.4>0[0.4]
G4 EUG-LAS MAY 0.3>0[0.4]
G4 EUG-LAX MAY 0.3>0[0.3]
G4 EUG-OAK MAY 0.3>0[0.3]
G4 EVV-SFB MAY 0.3>0[0.3]
G4 EVV-VPS MAY 0.2>0[0.2]
G4 EWR-SAV MAY 0.3>0[0.3]
G4 EWR-TYS MAY 0.3>0[0.5]
G4 EWR-VPS MAY 0.3>0[0.3]
G4 FAR-LAS MAY 0.4>0[0.4]
G4 FAT-LAS MAY 1.6>0[1.6]
G4 FCA-LAS MAY 0.3>0[0.3]
G4 FLL-GSP MAY 0.3>0[0.4]
G4 FLL-IND MAY 0.9>0[0.7]
G4 FLL-LCK MAY 0.3>0[0.3]
G4 FLL-LEX MAY 0.4>0[0.4]
G4 FLL-MEM MAY 0.5>0[0.5]
G4 FLL-ORF MAY 0.3>0[0.3]
G4 FLL-PBG MAY 0.3>0[0.3]
G4 FLL-SDF MAY 0.5>0[0.5]
G4 FLL-SYR MAY 0.3>0[0.3]
G4 FLL-TYS MAY 0.8>0[0.8]
G4 FLL-USA MAY 1.6>0[1.1]
G4 FNT-PGD MAY 0.3>0[0.4]
G4 FNT-PIE MAY 0.5>0[0.5]
G4 FNT-SFB MAY 0.5>0[0.7]
G4 FSD-LAS MAY 0.6>0[0.6]
G4 FSD-PIE MAY 0.3>0[0.2]
G4 FSD-SFB MAY 0.4>0[0.3]
G4 FWA-PGD MAY 0.5>0[0.4]
G4 FWA-PIE MAY 0.6>0[0.6]
G4 FWA-SFB MAY 0.3>0[0.5]
G4 GFK-LAS MAY 0.3>0[0.3]
G4 GJT-LAS MAY 0.3>0[0.3]
G4 GPT-SFB MAY 0.3>0[0.3]
G4 GRI-LAS MAY 0.3>0[0.3]
G4 GRR-JAX MAY 0.3>0[0]
G4 GRR-LAS MAY 0.6>0[0.5]
G4 GRR-PGD MAY 0.4>0[0.4]
G4 GRR-PIE MAY 1.0>0[1.0]
G4 GRR-SAV MAY 0.3>0[0]
G4 GRR-SFB MAY 1.4>0[1.1]
G4 GRR-SRQ MAY 0.3>0[0.3]
G4 GSO-PIE MAY 0.3>0[0.3]
G4 GSO-SFB MAY 0.3>0[0.4]
G4 GSP-PIE MAY 0.3>0[0.5]
G4 GSP-SFB MAY 0.3>0[0.3]
G4 GTF-LAS MAY 0.3>0[0.3]
G4 HGR-PIE MAY 0.2>0[0.2]
G4 HGR-SFB MAY 0.3>0[0.3]
G4 HTS-PIE MAY 0.7>0[0.6]
G4 HTS-SFB MAY 0.6>0[0.8]
G4 IAG-PGD MAY 0.4>0[0.4]
G4 IAG-PIE MAY 0.3>0[0.3]
G4 IAG-SFB MAY 0.3>0[0.4]
G4 ICT-LAS MAY 0.3>0[0.3]
G4 ICT-VPS MAY 0.5>0[0]
G4 IDA-LAS MAY 0.3>0[0.3]
G4 IND-JAX MAY 0.3>0[0.3]
G4 IND-LAS MAY 0.3>0[0.4]
G4 IND-PBI MAY 0.3>0[0]
G4 IND-PGD MAY 0.6>0[0.7]
G4 IND-PIE MAY 1.0>0[0.9]
G4 IND-SAV MAY 0.3>0[0.3]
G4 IND-SFB MAY 0.7>0[0.7]
G4 IND-SRQ MAY 0.5>0[0.4]
G4 IND-VPS MAY 0.3>0[0.3]
G4 JAX-ORF MAY 0.3>0[0.2]
G4 JAX-PIT MAY 0.3>0[0.4]
G4 LAS-LRD MAY 0.3>0[0.3]
G4 LAS-MEM MAY 1.0>0[0.7]
G4 LAS-MFE MAY 1.3>0[1.0]
G4 LAS-MFR MAY 0.3>0[0.4]
G4 LAS-MLI MAY 0.3>0[0.3]
G4 LAS-MOT MAY 0.5>0[0.4]
G4 LAS-MRY MAY 0.3>0[0.3]
G4 LAS-MSO MAY 0.3>0[0.3]
G4 LAS-OAK MAY 0.9>0[1.0]
G4 LAS-OKC MAY 0.3>0[0.3]
G4 LAS-OMA MAY 0.3>0[0.3]
G4 LAS-PIA MAY 0.3>0[0.4]
G4 LAS-PSC MAY 0.3>0[0.4]
G4 LAS-RAP MAY 0.3>0[0.3]
G4 LAS-RDM MAY 0.3>0[0]
G4 LAS-RFD MAY 0.3>0[0.3]
G4 LAS-RNO MAY 1.3>0[0.9]
G4 LAS-SAT MAY 0.3>0[0.3]
G4 LAS-SBN MAY 0.3>0[0.3]
G4 LAS-SCK MAY 1.6>0[1.7]
G4 LAS-SGF MAY 0.3>0[0.4]
G4 LAS-SHV MAY 0.3>0[0.4]
G4 LAS-SMX MAY 0.5>0[0.5]
G4 LAS-TUL MAY 0.3>0[0.3]
G4 LAS-TYS MAY 0.3>0[0.3]
G4 LAS-XNA MAY 0.4>0[0.4]
G4 LAX-MEM MAY 0.3>0[0.3]
G4 LAX-MFR MAY 0.3>0[0.3]
G4 LAX-OKC MAY 0.2>0[0.3]
G4 LAX-SGF MAY 0.3>0[0.3]
G4 LAX-TUL MAY 0.2>0[0.3]
G4 LCK-MYR MAY 0.5>0[0.6]
G4 LCK-PGD MAY 0.5>0[0.5]
G4 LCK-PIE MAY 0.5>0[0.5]
G4 LCK-SAV MAY 0.5>0[0.3]
G4 LCK-SFB MAY 0.5>0[0.6]
G4 LCK-SRQ MAY 0.3>0[0.3]
G4 LCK-VPS MAY 0.2>0[0.2]
G4 LEX-PGD MAY 0.5>0[0.5]
G4 LEX-PIE MAY 0.5>0[0.4]
G4 LEX-SFB MAY 0.8>0[0.8]
G4 LIT-SFB MAY 0.3>0[0.3]
G4 MCI-PIE MAY 0.3>0[0.3]
G4 MCI-VPS MAY 0.5>0[0.5]
G4 MDT-PGD MAY 0.3>0[0.3]
G4 MDT-PIE MAY 0.4>0[0.5]
G4 MDT-SFB MAY 0.9>0[1.1]
G4 MDT-SRQ MAY 0.2>0[0.3]
G4 MEM-PIE MAY 0.3>0[0.3]
G4 MEM-SFB MAY 0.3>0[0.5]
G4 MEM-VPS MAY 0.2>0[0.2]
G4 MFE-SFB MAY 0.3>0[0.2]
G4 MLI-PIE MAY 0.3>0[0.3]
G4 MLI-SFB MAY 0.3>0[0.3]
G4 MSO-OAK MAY 0.2>0[0.2]
G4 MSY-USA MAY 0.3>0[0.4]
G4 MYR-SWF MAY 0.3>0[0.2]
G4 OKC-VPS MAY 0.4>0[0.6]
G4 OMA-PIE MAY 0.2>0[0.2]
G4 OMA-SFB MAY 0.3>0[0.3]
G4 ORF-PIE MAY 0.3>0[0.3]
G4 ORF-SFB MAY 0.3>0[0.4]
G4 OWB-SFB MAY 0.4>0[0.4]
G4 PBG-PIE MAY 0.2>0[0.2]
G4 PBG-SFB MAY 0.4>0[0.5]
G4 PBI-PIT MAY 0.3>0[0]
G4 PBI-TYS MAY 0.3>0[0]
G4 PBI-USA MAY 0.3>0[0]
G4 PGD-PIA MAY 0.4>0[0.4]
G4 PGD-PIT MAY 0.5>0[0.5]
G4 PGD-PSM MAY 0.4>0[0.4]
G4 PGD-PVD MAY 0.3>0[0.3]
G4 PGD-RDU MAY 0.3>0[0.3]
G4 PGD-RFD MAY 0.3>0[0.3]
G4 PGD-RIC MAY 0.3>0[0]
G4 PGD-SBN MAY 0.3>0[0.3]
G4 PGD-SDF MAY 0.3>0[0.4]
G4 PGD-SPI MAY 0.3>0[0.3]
G4 PGD-SWF MAY 0.2>0[0.3]
G4 PGD-TOL MAY 0.3>0[0.3]
G4 PGD-TYS MAY 0.4>0[0.5]
G4 PGD-USA MAY 0.3>0[0.3]
G4 PIA-PIE MAY 0.4>0[0.4]
G4 PIA-SFB MAY 0.3>0[0.2]
G4 PIE-PIT MAY 0.5>0[0.6]
G4 PIE-RFD MAY 0.4>0[0.5]
G4 PIE-RIC MAY 0.3>0[0.3]
G4 PIE-ROA MAY 0.4>0[0.3]
G4 PIE-SBN MAY 0.3>0[0.3]
G4 PIE-SCE MAY 0.3>0[0]
G4 PIE-SDF MAY 0.3>0[0.4]
G4 PIE-SGF MAY 0.6>0[0.6]
G4 PIE-SWF MAY 0.3>0[0.3]
G4 PIE-SYR MAY 0.6>0[0.6]
G4 PIE-TOL MAY 0.3>0[0.4]
G4 PIE-TVC MAY 0.3>0[0]
G4 PIE-TYS MAY 1.1>0[1.1]
G4 PIE-USA MAY 1.1>0[1.0]
G4 PIT-SAV MAY 0.5>0[0.3]
G4 PIT-SFB MAY 0.3>0[0.4]
G4 PIT-SRQ MAY 0.3>0[0.3]
G4 PIT-VPS MAY 0.2>0[0.2]
G4 PSM-SFB MAY 0.3>0[0.3]
G4 PVU-TUS MAY 0.3>0[0.3]
G4 RFD-SFB MAY 0.3>0[0.3]
G4 RIC-SFB MAY 0.3>0[0.3]
G4 RIC-SRQ MAY 0.3>0[0.3]
G4 ROA-SFB MAY 0.5>0[0.5]
G4 ROC-SFB MAY 0.3>0[0.3]
G4 SAV-SDF MAY 0.3>0[0.4]
G4 SBN-SFB MAY 0.3>0[0.5]
G4 SCE-SFB MAY 0.3>0[0]
G4 SDF-SFB MAY 0.4>0[0.5]
G4 SDF-VPS MAY 0.3>0[0.2]
G4 SFB-SGF MAY 0.5>0[0.6]
G4 SFB-SHV MAY 0.2>0[0.2]
G4 SFB-SWF MAY 0.3>0[0.3]
G4 SFB-SYR MAY 0.3>0[0.4]
G4 SFB-TOL MAY 0.3>0[0.4]
G4 SFB-TRI MAY 0.3>0[0.3]
G4 SFB-TUL MAY 0.4>0[0.4]
G4 SFB-TVC MAY 0.3>0[0]
G4 SFB-TYS MAY 1.7>0[1.6]
G4 SFB-USA MAY 0.9>0[0.9]
G4 SFB-XNA MAY 0.4>0[0.5]
G4 SGF-VPS MAY 0.3>0[0.2]
G4 SRQ-SYR MAY 0.2>0[0.3]
G4 SRQ-TYS MAY 0.3>0[0]
G4 TYS-VPS MAY 0.3>0[0.2]
G4 USA-VPS MAY 0.2>0[0.2]
G4 VPS-XNA MAY 0.5>0[0.5]
GV AKN-DLG MAY 1.7>0.8[0]
GV AKN-UGB MAY 0.5>0.3[0.5]
GV AKN-WSN MAY 1.1>0.8[1.9]
GV ATT-BET MAY 0.4>1.0[1.4]
GV ATT-KUK MAY 0.4>0.2[1.4]
GV AUK-EMK MAY 1.8>1.4[1.9]
GV AUK-KOT MAY 1.8>1.4[1.9]
GV AUK-SXP MAY 4>3[4]
GV BET-EMK MAY 0.4>0.2[0.4]
GV BET-KOT MAY 1.8>1.1[1.9]
GV BET-KSM MAY 0>0.2[0]
GV BET-MOU MAY 0>0.2[0]
GV BET-NME MAY 0.5>0.3[0.5]
GV BET-NUP MAY 0.4>0.2[1.4]
GV BET-SCM MAY 1.9>1.4[1.9]
GV BET-VAK MAY 1.9>1.4[1.9]
GV CLP-DLG MAY 0.9>0.7[0.9]
GV CLP-KMO MAY 0.9>0.7[0.9]
GV DLG-KEK MAY 1.4>1.0[0]
GV DLG-KMO MAY 1.9>1.2[1.9]
GV DLG-KNW MAY 1.4>1.0[0]
GV DLG-TOG MAY 1.0>0.7[1.4]
GV DLG-TWA MAY 1.0>0.7[1.4]
GV DLG-WSN MAY 0.8>0.5[1.9]
GV EMK-SXP MAY 4>3[4]
GV HPB-SCM MAY 1.9>1.4[1.9]
GV HPB-VAK MAY 1.9>1.4[1.9]
GV KEK-KNW MAY 1.4>1.0[0]
GV KOT-KSM MAY 0>0.2[0]
GV KOT-MOU MAY 0>0.2[0]
GV KUK-NUP MAY 0.4>0.2[1.4]
GV NME-OOK MAY 0.5>0.3[0.5]
GV TNK-WWT MAY 0.5>0.3[0.5]
GV TOG-TWA MAY 1.0>0.7[1.4]
HU BOS-PEK MAY 0.9>0[1.0]
HU ORD-PEK MAY 0.5>0[0.5]
HU PEK-SEA MAY 0.9>0[0.8]
IB BCN-BOS MAY 0.6>0.3[0.5]
IB BCN-JFK MAY 0.6>0.3[0]
IB BCN-SFO MAY 0.4>0.2[0.3]
IB BOS-MAD MAY 1.0>0.5[1.0]
IB IAD-MAD MAY 0.6>0.3[0]
IB JFK-MAD MAY 2>1.1[2]
IB LAX-MAD MAY 0.7>0.4[0.7]
IB MAD-MIA MAY 2>1.1[2]
IB MAD-ORD MAY 1.0>0.5[1.0]
IB MAD-SFO MAY 0.4>0.2[0.5]
This looks like all flights to me.
JL BOS-NRT MAY 1.0>0[1.0]
JL DFW-HND MAY 1.0>0[0]
JL HND-HNL MAY 2>0[0]
JL HND-JFK MAY 2.0>0[1.0]
JL HND-LAX MAY 1.0>0.2[0]
JL HND-ORD MAY 1.0>0.1[0]
JL HND-SFO MAY 1.0>0[1.0]
JL HNL-KIX MAY 1.0>0[1.0]
JL HNL-NGO MAY 1.0>0[1.0]
JL HNL-NRT MAY 2>0[4]
JL KIX-LAX MAY 1.0>0[1.0]
JL KOA-NRT MAY 1.0>0[1.0]
JL LAX-NRT MAY 1.0>0[1.0]
JL NRT-SAN MAY 1.0>0[1.0]
JL NRT-SEA MAY 1.0>0[1.0]
JL NRT-SFO MAY 1.0>0[0]
KL AMS-ATL MAY 0.9>0.4[1.0] JUN 1.0>0.4[1.0]
KL AMS-AUS MAY 0.4>0[0] JUN 0.4>0[0] JUL 0.4>0[0] AUG 0.5>0[0] SEP 0.4>0[0] OCT 0.4>0.0[0]
KL AMS-BOS MAY 0.6>0[0.5] JUN 0.9>0[0.4]
KL AMS-IAD MAY 0.9>0[1.0] JUN 1.0>0[1.0]
KL AMS-IAH MAY 0.9>0[1.0] JUN 1.0>0[1.0]
KL AMS-JFK MAY 3>1.0[3] JUN 3>1.0[3]
KL AMS-LAS MAY 0.6>0[0] JUN 0.6>0[0.3]
KL AMS-LAX MAY 1.3>0.4[2] JUN 2>1.4[1.9]
KL AMS-MSP MAY 0.5>0[0.6] JUN 0.7>0[0.6]
KL AMS-ORD JUN 1.0>0.4[1.0]
KL AMS-SFO MAY 1.6>0[1.6] JUN 1.8>0[1.6]
KL AMS-SLC MAY 0.5>0[0.5] JUN 0.6>0[0.4]
KU JFK-KWI MAY 1.0>0[1.0] JUN 1.0>0.4[1.0] JUL 1.0>0.5[1.0] AUG 1.0>0.6[1.0] SEP 1.0>0.6[1.0] OCT 1.0>0.7[1.0]
L0 ACK-DXR MAY 0.2>0[0] JUN 0.2>0[0] JUL 0.2>0[0] AUG 0.2>0[0] SEP 0.2>0[0] OCT 0.2>0[0.5] NOV 0.2>0[0.2] DEC 0.2>0[0.2] JAN 0.2>0[0.2]
LA MIA-UIO MAY 1.0>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0]
LF BKW-PKB JUN 1.7>0.5[1.2]
LF BNA-IND JUN 1.2>0[0] JUL 1.7>0[0] AUG 1.7>0[0] SEP 1.7>0[0]
LF IND-PIT JUN 0.7>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0]
LF IND-STL JUN 1.2>0[0] JUL 1.7>0[0] AUG 1.7>0[0] SEP 1.7>0[0]
LF LAS-PGA MAY 0.6>0[1.0] JUN 0.6>0[1.0]
LF LAS-SBA MAY 1.0>0[1.5] JUN 1.0>0[1.6]
LF LAS-SBP MAY 0.6>0[0] JUN 0.6>0[0]
LF OAK-SBA MAY 1.0>0[1.5] JUN 1.0>0[1.8]
LF PSP-SMF MAY 1.0>0[0] JUN 1.0>0[0]
LF SBA-SMF MAY 1.7>0[1.0] JUN 1.7>0[1.0]
Looks to me like LH rolled cancels forward to mid-May
LH ATL-FRA MAY 0.9>0.5[1.0]
LH AUS-FRA MAY 0.6>0.3[0.7]
LH BOS-FRA MAY 1.6>0.9[1.6]
LH BOS-MUC MAY 0.9>0.5[1.0]
LH CLT-MUC MAY 0.9>0.5[1.0]
LH DEN-FRA MAY 0.9>0.5[1.0]
LH DEN-MUC MAY 0.9>0.5[1.0]
LH DFW-FRA MAY 0.9>0.5[1.0]
LH DTW-FRA MAY 0.9>0.5[1.0]
LH EWR-FRA MAY 1.0>0.7[1.0]
LH EWR-MUC MAY 0.9>0.5[1.0]
LH FRA-IAD MAY 1.8>0.9[2]
LH FRA-IAH MAY 0.9>0.5[1.0]
LH FRA-JFK MAY 1.8>0.9[2]
LH FRA-LAX MAY 1.8>0.9[1.9]
LH FRA-MCO MAY 0.9>0.5[1.0]
LH FRA-MIA MAY 0.9>0.5[1.0]
LH FRA-ORD MAY 1.8>1.1[2]
LH FRA-PHL MAY 0.9>0.5[1.0]
LH FRA-SAN MAY 0.6>0.3[0.7]
LH FRA-SEA MAY 0.9>0.5[1.0]
LH FRA-SFO MAY 0.9>0.5[1.0]
LH FRA-TPA MAY 0.8>0.4[0.8]
LH IAD-MUC MAY 0.9>0.5[1.0]
LH JFK-MUC MAY 0.9>0.5[1.0]
LH LAX-MUC MAY 0.9>0.5[1.0]
LH MUC-ORD MAY 1.8>0.9[1.8]
LH MUC-SFO MAY 0.9>0.5[1.0]
LX BOS-ZRH MAY 0.9>0.5[1.0]
LX EWR-ZRH MAY 1.0>0.7[1.0]
LX GVA-JFK MAY 0.9>0.5[1.0]
LX JFK-ZRH MAY 1.8>0.9[2]
LX LAX-ZRH MAY 0.9>0.5[1.0]
LX MIA-ZRH MAY 1.4>0.6[1.5]
LX ORD-ZRH MAY 1.1>0.6[1.2]
LX SFO-ZRH MAY 0.9>0.5[1.0]
MF FOC-JFK MAY 0.4>0.0[0.4]
MF LAX-TAO MAY 0.4>0[0.4]
Looks like to me they cxld everything till mid-May
NH HND-HNL MAY 1.0>0.5[1.0]
NH HND-IAD MAY 1.0>0.5[0]
NH HND-IAH MAY 1.0>0.5[0]
NH HND-JFK MAY 1.0>0.5[1.0]
NH HND-LAX MAY 2>1.0[1.0]
NH HND-ORD MAY 1.0>0.5[1.0]
NH HND-SEA MAY 1.0>0.5[0]
NH HND-SFO MAY 0.5>0.3[0]
NH HND-SJC MAY 1.0>0.5[0]
NH HNL-NRT MAY 2>1.0[2]
NH JFK-NRT MAY 1.0>0.5[1.0]
NH NRT-ORD MAY 1.0>0.7[1.0]
NH NRT-SFO MAY 1.0>0.5[1.0]
OS EWR-VIE MAY 0.9>0.5[1.0]
OS IAD-VIE MAY 0.9>0.5[1.0]
OS JFK-VIE MAY 0.9>0.5[1.0]
OS LAX-VIE MAY 0.6>0.3[1.0]
OS ORD-VIE MAY 0.9>0.5[1.0]
QR DFW-DOH MAY 0.7>0.5[1.0]
QR DOH-JFK MAY 1.0>0[2]
RLI ACK-DXR MAY 0>0.2[0] JUN 0>0.2[0] JUL 0>0.2[0] AUG 0>0.2[0] SEP 0>0.2[0] OCT 0>0.2[0] NOV 0>0.2[0] DEC 0>0.2[0] JAN 0>0.2[0]
S4 BOS-PDL MAY 0.7>0[0.9]
S4 BOS-TER JUN 0.4>0.2[0.3]
SU JFK-SVO MAY 3>1.5[3]
SU LAX-SVO MAY 1.0>0.5[1.0]
SU MIA-SVO MAY 0.6>0.3[0.5]
SV IAD-JED JUN 0.6>0[0.4]
SV IAD-RUH JUN 0.4>0[0.6]
SV JED-JFK JUN 0.6>0[0.6]
SV JED-LAX JUN 0.6>0[0.7]
SV JFK-RUH JUN 0.4>0[0.4]
TK ATL-IST MAY 0.7>0.3[0.7]
TK BOS-IST MAY 1.0>0.4[1.0]
TK EWR-IST MAY 0.2>0[0] JUN 1.0>0.1[0]
TK IAD-IST MAY 1.4>0.5[1.0]
TK IAH-IST MAY 1.0>0.4[1.0]
TK IST-JFK MAY 3>1.1[3]
TK IST-LAX MAY 1.0>0.4[1.0]
TK IST-MIA MAY 1.0>0.4[1.0]
TK IST-ORD MAY 1.4>0.5[1.0]
TK IST-SFO MAY 1.0>0.4[1.0]
TN CDG-LAX MAY 0.8>0.5[0.7]
TN LAX-PPT MAY 1.4>0.7[1.5]
TP BOS-LIS JUN 1.0>1.4[1.0]
TP EWR-LIS JUN 1.5>1.9[1.0]
TP LIS-MIA JUN 1.5>1.9[1.0]
TS FLL-YUL MAY 0.6>0[0.1]
TS FLL-YYZ MAY 0.3>0[0.1]
TS MCO-YUL MAY 0.5>0[0.1]
TS MSY-YUL MAY 0.3>0[0]
I had not seen this announced, but appears UA dropped "all" intl for May and most Summer only intl just as AA did. DL has not joined yet.
UA AGU-IAH MAY 0.8>0[2]
**UA AMS-IAD MAY 0.4>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
**UA AMS-IAH MAY 0.4>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
UA AMS-ORD MAY 0.4>0[1.0]
**UA AMS-SFO JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
UA AUA-EWR MAY 1.4>0[2]
UA BCN-EWR MAY 0.4>0[1.0]
**UA BDA-EWR MAY 0.4>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 0.5>0[0.6]
UA BJX-IAH MAY 2>1.0[4]
UA BOG-EWR MAY 0.4>0[1.0]
UA BOG-IAH MAY 1.3>0[2]
UA BOM-EWR MAY 0.4>0[1.0]
UA BQN-EWR MAY 0.9>0.4[1.0]
UA BRU-EWR MAY 0.4>0[1.0]
UA BRU-IAD MAY 0.4>0[1.0]
UA BRU-ORD MAY 0.4>0[1.0]
UA BZE-IAH MAY 1.3>0[1.1]
UA CDG-EWR MAY 0.4>0[1.3]
UA CDG-IAD MAY 0.4>0[1.0]
**UA CDG-ORD MAY 0.4>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
**UA CDG-SFO MAY 0.4>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
UA CUN-DEN MAY 0.8>0[2]
UA CUN-EWR MAY 1.2>0[3]
UA CUN-IAD MAY 0.4>0[1.0]
UA CUN-IAH MAY 3>0[5]
UA CUN-LAX MAY 0.8>0[2]
UA CUN-ORD MAY 0.8>0[2]
UA CUN-SFO MAY 0.6>0[1.4]
UA CUU-IAH MAY 0.4>0[1.0]
UA CZM-IAH MAY 0.5>0[0.8]
UA DEL-EWR MAY 0.4>0[0]
UA DEN-FCA NOV 3>2[2.0]
UA DEN-FRA MAY 0.4>0[1.0]
UA DEN-GTF JAN 3>2[2]
UA DEN-GUC DEC 1.0>1.5[1.4] JAN 1.0>2[2]
UA DEN-HDN NOV 1.0>2[1.9] DEC 1.0>3[3] JAN 1.0>3[3]
UA DEN-LHR MAY 0.4>0[1.0]
UA DEN-MSO NOV 2>3[3] DEC 2>3[3] JAN 2>3[3]
UA DEN-NRT MAY 0.4>0[1.0]
UA DEN-PVR MAY 0.2>0[0.4]
UA DEN-SJD MAY 0.5>0[0.4]
UA DUB-EWR MAY 0.4>0[1.0]
**UA DUB-IAD JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.8>0.2[0.8]
**UA DUB-ORD JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0]
UA EDI-EWR MAY 0.4>0[1.0]
**UA EDI-IAD JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0]
**UA EDI-ORD JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0]
UA EWR-FCO MAY 0.4>0[1.0]
**UA EWR-GLA JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0]
UA EWR-GRU MAY 0.4>0[1.0]
UA EWR-GUA MAY 0.4>0[0]
UA EWR-GVA MAY 0.4>0[1.0]
UA EWR-HAV MAY 0.4>0[1.0]
UA EWR-HKG MAY 0.4>0[1.0]
UA EWR-HND MAY 0.4>0[0]
UA EWR-LHR MAY 3>1.0[5]
UA EWR-LIM MAY 0.4>0[1.0]
UA EWR-LIS MAY 0.4>0[1.0]
UA EWR-MAD MAY 0.4>0[1.0]
**UA EWR-MAN MAY 0.4>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
UA EWR-MBJ MAY 0.9>0[1.0]
UA EWR-MEX MAY 1.1>0[3]
UA EWR-MUC MAY 0.4>0[1.0]
UA EWR-MXP MAY 0.4>0[1.0]
UA EWR-NAS MAY 1.4>0[1.1]
**UA EWR-NCE JUL 1.0>0[0] AUG 1.0>0[0] SEP 0.3>0[0]
UA EWR-NRT MAY 0.4>0[1.0]
UA EWR-PEK MAY 0.4>0[1.0]
UA EWR-PLS MAY 0.4>0[1.0]
UA EWR-POS MAY 0.4>0[1.0]
UA EWR-PTY MAY 0.9>0[1.0]
UA EWR-PUJ MAY 0.9>0[2]
UA EWR-PVG MAY 0.4>0[1.0]
UA EWR-SDQ MAY 1.6>0[2]
UA EWR-SJO MAY 0.8>0[1.0]
UA EWR-SJU MAY 1.3>0.8[1.3]
**UA EWR-SNN JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.7>0[0.8]
UA EWR-STI MAY 0.8>0[1.0]
UA EWR-TLV MAY 1.4>1.0[2]
UA EWR-TXL MAY 0.4>0[1.0]
UA EWR-ZRH MAY 0.4>0[1.0]
UA EZE-IAH MAY 0.6>0[1.0]
UA FRA-IAD MAY 1.3>0.9[2]
UA FRA-IAH MAY 0.4>0[1.0]
UA FRA-ORD MAY 0.8>0[2]
UA FRA-SFO MAY 0.8>0[2]
UA GCM-IAH MAY 0.5>0[1.1]
UA GDL-IAH MAY 2>1.0[4]
UA GIG-IAH MAY 0.4>0[1.0]
**UA GRU-IAD MAY 0.4>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
UA GRU-ORD MAY 0.4>0[1.0]
UA GUA-IAH MAY 1.4>0.4[2]
UA GVA-IAD MAY 0.4>0[1.0]
UA HAV-IAH MAY 0.4>0[1.0]
UA HKG-SFO MAY 0.8>0[1.0] JUN 2>0.9[1.0] JUL 2>1.0[1.0] AUG 2>1.0[1.0] SEP 2>1.0[1.0] OCT 2>1.3[1.2]
UA HND-IAD MAY 0.4>0[0]
UA HND-LAX MAY 0.4>0[0]
UA HND-ORD MAY 0.4>0[0]
UA HND-SFO MAY 0.4>0[1.0]
UA HNL-NRT MAY 0.4>0[1.0]
UA IAD-LHR MAY 1.2>0[3]
UA IAD-MEX MAY 0.4>0[1.0]
UA IAD-MUC MAY 0.4>0[1.0]
**UA IAD-PEK MAY 0.4>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
UA IAD-SJU MAY 0.4>0[0]
UA IAD-ZRH MAY 0.4>0[1.0]
UA IAH-LHR MAY 0.8>0[2]
UA IAH-LIM MAY 0.4>0[1.0]
UA IAH-LIR MAY 0.8>0[2]
UA IAH-MBJ MAY 0.2>0[0.4]
UA IAH-MEX MAY 3>1.1[6]
UA IAH-MGA MAY 0.4>0[0.6]
UA IAH-MID MAY 0.4>0[0.5]
UA IAH-MLM MAY 0.4>0[1.0]
UA IAH-MTY MAY 3>1.0[7]
UA IAH-MUC MAY 0.4>0[1.0]
UA IAH-NAS MAY 0.8>0[2]
UA IAH-NRT MAY 0.4>0[1.0]
UA IAH-PBC MAY 0.4>0[1.0]
UA IAH-POS MAY 0.4>0[1.0]
UA IAH-PTY MAY 1.7>0[3]
UA IAH-PVR MAY 1.4>0[1.4]
UA IAH-QRO MAY 1.5>0[4]
UA IAH-RTB MAY 0.3>0[0.7]
UA IAH-SAL MAY 1.3>0.5[2]
UA IAH-SAP MAY 0.4>0[1.0]
UA IAH-SCL MAY 0.4>0[1.0]
UA IAH-SJD MAY 1.7>0[3]
UA IAH-SJO MAY 1.4>0.4[2]
UA IAH-SJU MAY 0.8>0[1.3]
UA IAH-SLP MAY 0.8>0[2]
UA IAH-SYD MAY 0.2>0[0.6]
UA IAH-TAM MAY 0.4>0[1.0]
UA IAH-TGU MAY 0.9>0.5[1.0]
UA IAH-UIO MAY 0.4>0[1.0]
UA IAH-VER MAY 0.4>0[1.0]
UA ICN-SFO MAY 0.7>0[1.5] JUN 1.7>0.9[1.7] JUL 1.7>1.0[1.7] AUG 1.7>1.0[1.7] SEP 1.7>1.0[1.7] OCT 1.5>1.0[1.6]
UA KIX-SFO MAY 0.4>0[1.0]
**UA LAX-LHR MAY 0.4>0[1.0] JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
UA LAX-MEL MAY 0.2>0[1.0]
UA LAX-NRT MAY 0.4>0[1.0]
UA LAX-PVG MAY 0.4>0[1.0]
**UA LAX-SCK MAY 1.7>0[0] JUN 2>0[0] JUL 2>0[0] AUG 2>0[1.0] SEP 2>0[2] OCT 2>0[2] NOV 2>0[2.0] DEC 2>0[2.0] JAN 2>0[2.0]
UA LAX-SJD MAY 0.4>0[0.3]
UA LHR-ORD MAY 1.6>0.9[3]
UA LHR-SFO MAY 0.8>0[2]
UA MEX-ORD MAY 0.7>0[1.9]
UA MEX-SFO MAY 1.7>0[2]
UA MTY-ORD MAY 0.8>0[2]
UA MUC-ORD MAY 0.4>0[1.0]
UA MUC-SFO MAY 0.4>0[1.0]
UA NAS-ORD MAY 0.2>0[0.4]
UA ORD-PEK MAY 0.4>0[1.0]
UA ORD-PUJ MAY 0.4>0[1.0]
UA ORD-PVG MAY 0.4>0[1.0]
UA ORD-SJU MAY 0.4>0[1.0]
UA ORD-SUN DEC 0>0.5[0.4]
UA PEK-SFO MAY 0.4>0[1.0]
UA PVG-SFO MAY 0.8>0[2] JUN 2>0.9[2] JUL 2>1.0[2] AUG 2>1.0[2] SEP 2>1.0[2] OCT 2>1.3[2]
UA PVR-SFO MAY 0.4>0[1.0]
UA SFO-SIN MAY 0.8>0[2] JUN 2>0.9[2] JUL 2>1.0[2] AUG 2>1.0[2] SEP 2>1.0[2] OCT 2>1.3[2]
UA SFO-SJD MAY 0.5>0[1.3]
UA SFO-TLV MAY 0.4>0[1.0]
UA SFO-TPE MAY 0.4>0[1.0]
UX JFK-MAD MAY 0.6>0[0.8]
UX MAD-MIA MAY 1.0>0[1.0]
VR IAD-SID MAY 0.4>0[0] JUN 0.4>0[0] JUL 0.4>0.1[0]
VS ATL-LHR MAY 0.9>0.7[1.0]
VS BOS-LHR MAY 1.8>1.3[2]
VS IAD-LHR MAY 0.9>0.7[1.0]
VS JFK-LHR MAY 5>4[6]
VS JFK-MAN MAY 0.9>0.7[1.0]
VS LAS-LHR MAY 0.9>0.7[1.0]
VS LHR-MIA MAY 0.9>0.7[1.0]
VS LHR-SEA MAY 1.4>1.1[1.0]
VS LHR-SFO MAY 1.8>1.4[1.8]
VS MAN-MCO MAY 1.5>1.2[1.6]
VW LRD-MEX JUN 0.4>0[0] JUL 0.4>0[0] AUG 0.5>0[0] SEP 0.4>0[0] OCT 0.4>0[0] NOV 0.4>0[0] DEC 0.4>0[0] JAN 0.4>0[0]
WG MIA-YYZ MAY 0.2>0[0.2]
WN ABQ-BWI MAY 1.0>0.5[1.0]
WN ABQ-DAL MAY 3>2[5]
WN ABQ-DEN MAY 2.0>1.5[3]
WN ABQ-LAS MAY 2.0>1.5[4]
WN ABQ-LAX MAY 1.0>0.1[2]
WN ABQ-OAK MAY 3>0.1[3] JUN 3>2[3]
WN ABQ-PHX MAY 4>1.5[5]
WN ALB-BWI MAY 4>2[4]
WN ALB-MCO MAY 1.0>0.1[2.0]
WN ALB-MDW MAY 2.0>1.0[2]
WN AMA-DAL MAY 3>2.0[4]
WN ATL-BNA MAY 1.0>0.0[4]
WN ATL-DAL MAY 3>2[5]
WN ATL-DCA MAY 3>1.0[4]
WN ATL-DEN MAY 3>1.6[3]
WN ATL-FLL MAY 2.0>1.5[5]
WN ATL-GSP MAY 3>2.0[3]
WN ATL-IAD MAY 1.9>1.0[3]
WN ATL-JAX MAY 1.0>2.0[3]
WN ATL-LGA MAY 3>0.1[5]
WN ATL-MEM MAY 1.9>1.0[0]
WN ATL-MSY MAY 2>1.1[3]
WN ATL-OAK MAY 1.0>0.1[1.0]
WN ATL-RDU MAY 3>1.5[3]
WN ATL-RIC MAY 3>2[3]
WN AUS-BNA MAY 3>1.6[3]
WN AUS-BWI MAY 2.0>0.1[3]
WN AUS-DAL MAY 5>3[9]
WN AUS-DCA MAY 1.0>0.1[1.0]
WN AUS-HOU MAY 3>2[5]
WN AUS-LAS MAY 2>1.6[3]
WN AUS-MCO MAY 1.9>1.5[2]
WN AUS-OAK MAY 1.0>0.1[1.1] JUN 0.9>0.7[1.3]
WN AUS-STL MAY 2.0>1.0[2.0]
WN BDL-BWI MAY 1.2>2[7]
WN BDL-MCO MAY 2>1.1[3]
WN BDL-MDW MAY 1.0>0.1[3]
WN BHM-DAL MAY 2.0>1.0[1.9]
WN BHM-MCO MAY 1.9>1.0[2]
WN BNA-BOS MAY 2>1.5[3]
WN BNA-DAL MAY 3>1.6[5]
WN BNA-DCA MAY 3>2[4]
WN BNA-DEN MAY 4>3[5]
WN BNA-ECP MAY 3>2[2]
WN BNA-LGA MAY 2>0.2[3]
WN BNA-OAK MAY 1.0>0.1[1.1]
WN BNA-PHX MAY 2>1.6[4]
WN BNA-PNS MAY 2>0.6[2.0]
WN BNA-RDU MAY 2.0>1.5[3]
WN BNA-SAN MAY 1.0>0.1[1.9]
WN BNA-SAT MAY 2.0>0.1[1.9]
WN BNA-SJC MAY 1.0>0.0[0]
WN BNA-TPA MAY 2>1.6[5]
WN BOI-DEN MAY 3>1.1[2]
WN BOI-OAK MAY 3>1.0[2.0]
WN BOS-BWI MAY 5>3[9]
WN BOS-DEN MAY 2.0>1.0[3]
WN BOS-MDW MAY 4>3[4]
WN BOS-STL MAY 2>1.1[3]
WN BUF-MCO MAY 2>1.2[3]
WN BUR-DEN MAY 4>2[1.9]
WN BUR-LAS MAY 4>3[10]
WN BUR-OAK MAY 4>3[11]
WN BUR-PHX MAY 4>2[6]
WN BUR-SFO MAY 4>1.0[4]
WN BUR-SJC MAY 4>2[10]
WN BUR-SMF MAY 4>2[8]
WN BWI-CLE MAY 3>1.9[3]
WN BWI-CMH MAY 3>1.5[4]
WN BWI-CVG MAY 3>1.5[3]
WN BWI-DAL MAY 3>1.2[4]
WN BWI-DEN MAY 3>1.7[4]
WN BWI-DTW MAY 2.0>1.5[2]
WN BWI-HOU MAY 3>2[4]
WN BWI-IND MAY 3>2[3]
WN BWI-ISP MAY 3>1.1[4]
WN BWI-JAX MAY 3>2.0[4]
WN BWI-LAX MAY 2>1.1[2]
WN BWI-LGA MAY 0>1.9[0] JUN 0>0.4[0]
WN BWI-MDW MAY 6>4[7]
WN BWI-MKE MAY 2>1.1[3]
WN BWI-MSY MAY 3>1.2[3]
WN BWI-OAK MAY 1.0>0.0[1.0]
WN BWI-OKC MAY 1.0>0.0[1.0] JUN 1.0>0.8[1.0]
WN BWI-ORF MAY 4>3[5]
WN BWI-PBI MAY 3>2[3]
WN BWI-PHX MAY 2>1.1[3]
WN BWI-RDU MAY 4>3[6]
WN BWI-ROC MAY 3>2[3]
WN BWI-SAN MAY 1.1>0.1[3]
WN BWI-SDF MAY 3>2[4]
WN BWI-SJC MAY 1.0>0.0[0.9] JUN 1.0>0.8[0.9]
WN BWI-SMF MAY 1.0>0.1[1.0]
WN BWI-STL MAY 3>2[4]
WN BWI-TPA MAY 5>3[7]
WN CLE-DEN MAY 1.9>0.1[1.0] JUN 2.0>1.6[1.5]
WN CMH-DCA MAY 1.0>0.0[1.9]
WN CMH-MCO MAY 3>1.6[3]
WN CVG-MDW MAY 3>1.5[5]
WN DAL-DCA MAY 3>2[5]
WN DAL-DEN MAY 4>3[7]
WN DAL-ECP MAY 2>1.1[2]
WN DAL-ELP MAY 3>2[4]
WN DAL-FLL MAY 2>1.6[3]
WN DAL-HOU MAY 7>5[19]
WN DAL-LBB MAY 3>2[5]
WN DAL-LGA MAY 3>0.2[5]
WN DAL-LIT MAY 3>2.0[3]
WN DAL-MAF MAY 3>2.0[4]
WN DAL-MCO MAY 4>3[4]
WN DAL-MSY MAY 3>2[7]
WN DAL-OMA MAY 1.0>0.1[1.2]
WN DAL-SAT MAY 5>4[9]
WN DAL-STL MAY 3>4[6]
WN DCA-HOU MAY 1.1>0.1[3]
WN DCA-MCI MAY 1.0>0.1[1.9]
WN DCA-MCO MAY 1.1>0.6[2]
WN DCA-MDW MAY 4>2[6]
WN DCA-MKE MAY 1.0>0.6[1.9]
WN DCA-OKC MAY 1.0>0.0[1.0]
WN DCA-OMA MAY 1.0>0.0[1.0]
WN DCA-PVD MAY 2.0>0.1[2]
WN DCA-STL MAY 3>1.1[4]
WN DEN-GEG MAY 3>1.0[1.9]
WN DEN-HOU MAY 5>3[7]
WN DEN-IAD MAY 3>1.1[3]
WN DEN-LAX MAY 5>3[7]
WN DEN-LGA MAY 3>0.2[3]
WN DEN-MCO MAY 3>2[3]
WN DEN-MDW MAY 6>3[9]
WN DEN-MSY MAY 2.0>0.6[3]
WN DEN-OAK MAY 4>3[5]
WN DEN-OKC MAY 3>2.0[3]
WN DEN-OMA MAY 3>2[3]
WN DEN-ONT MAY 4>1.5[1.9]
WN DEN-PDX MAY 3>2[5]
WN DEN-PHL MAY 3>1.5[2]
WN DEN-PIT MAY 1.9>1.0[1.0]
WN DEN-SEA MAY 4>3[3]
WN DEN-SFO MAY 3>1.1[3]
WN DEN-SJC MAY 3>2[4]
WN DEN-SMF MAY 4>3[4]
WN DEN-SNA MAY 3>2[5]
WN DEN-TUS MAY 3>1.1[2]
WN DSM-STL MAY 3>2.0[1.9]
WN DTW-MDW MAY 3>1.5[4]
WN ECP-HOU MAY 1.0>0.1[1.1]
WN ECP-STL MAY 2.0>1.0[1.1]
WN ELP-PHX MAY 3>1.0[3]
WN FLL-MCO MAY 3>1.5[4]
WN FLL-MSY MAY 2.0>1.5[3]
WN FLL-TPA MAY 3>2.0[5]
WN GEG-OAK MAY 1.9>1.0[1.8]
WN GRR-MDW MAY 3>2[3]
WN HOU-LGA MAY 1.1>0.1[3]
WN HOU-MSY MAY 4>2[10]
WN HOU-OAK MAY 1.0>0.1[2]
WN HOU-OKC MAY 3>2[4]
WN HOU-PHX MAY 4>1.7[5]
WN HOU-PNS MAY 1.0>0.5[1.0]
WN HOU-SAT MAY 5>3[5]
WN HOU-TPA MAY 2>1.6[3]
WN ICT-STL MAY 3>1.9[1.9]
WN IND-LAS MAY 2>1.5[3]
WN IND-MCO MAY 2>1.1[4]
WN ISP-MCO MAY 2>1.1[2]
WN LAS-MAF MAY 1.0>0.1[1.1]
WN LAS-MSY MAY 1.0>0.1[2]
WN LAS-OAK MAY 3>2[8]
WN LAS-OMA MAY 2>1.5[3]
WN LAS-ONT MAY 3>1.0[4]
WN LAS-PHX MAY 5>4[10]
WN LAS-SAN MAY 4>3[11]
WN LAS-SAT MAY 2>1.5[4]
WN LAS-SEA MAY 2>1.1[3]
WN LAS-SFO MAY 4>3[6]
WN LAS-SJC MAY 4>3[10]
WN LAS-SMF MAY 4>3[8]
WN LAS-SNA MAY 3>2[6]
WN LAS-TUS MAY 3>1.0[3]
WN LAX-OAK MAY 4>3[11]
WN LAX-PHX MAY 4>3[8]
WN LAX-SFO MAY 4>1.1[9]
WN LAX-SJC MAY 4>2[10]
WN LAX-SMF MAY 4>2[8]
WN LGA-MCI MAY 1.0>0.0[1.9]
WN LGA-MSY MAY 1.0>0.0[1.0]
WN LGA-STL MAY 2>0.2[3]
WN LGA-TPA MAY 1.0>0.1[1.7]
WN LGB-OAK MAY 4>1.5[4]
WN LGB-SJC MAY 4>2[4]
WN LGB-SMF MAY 4>3[4]
WN LIT-STL MAY 1.9>1.0[1.9]
WN MCI-MCO MAY 2>1.1[2]
WN MCI-MDW MAY 5>4[7]
WN MCI-PHX MAY 3>1.6[4]
WN MCI-STL MAY 2.0>1.0[4]
WN MCO-MEM MAY 1.0>0.1[1.1]
WN MCO-MHT MAY 2>1.1[2]
WN MCO-MSY MAY 2>1.1[5]
WN MCO-PHL MAY 2>1.2[3]
WN MCO-PHX MAY 1.0>0.1[1.3]
WN MCO-PIT MAY 3>2[4]
WN MCO-PVD MAY 2>1.2[4]
WN MCO-SAN MAY 1.0>0.0[0.9]
WN MCO-SAT MAY 1.0>0.1[1.9]
WN MCO-SJU MAY 2.0>1.1[4]
WN MCO-STL MAY 3>2[5]
WN MDW-MEM MAY 1.9>1.0[1.9]
WN MDW-MHT MAY 1.0>0.1[3]
WN MDW-MSP MAY 5>3[6]
WN MDW-MSY MAY 3>2[4]
WN MDW-OAK MAY 2>1.1[3]
WN MDW-PHL MAY 3>2[5]
WN MDW-PIT MAY 3>2[4]
WN MDW-PVD MAY 2>1.5[3]
WN MDW-RDU MAY 2>1.5[4]
WN MDW-SAN MAY 2>1.6[4]
WN MDW-SAT MAY 2.0>1.0[2.0]
WN MDW-SDF MAY 3>2.0[4]
WN MDW-SEA MAY 2.0>1.5[2]
WN MDW-SFO MAY 1.0>0.1[1.9]
WN MDW-SJC MAY 1.0>0.5[1.7]
WN MDW-SMF MAY 1.0>0.1[1.0]
WN MDW-STL MAY 3>1.6[7]
WN MDW-TPA MAY 4>3[5]
WN MKE-TPA MAY 3>1.5[1.1]
WN OAK-ONT MAY 4>2[7]
WN OAK-SEA MAY 4>2[6]
WN OAK-SNA MAY 4>2[7]
WN OAK-STL MAY 1.0>0.0[1.0] JUN 0.9>0.7[1.0]
WN ONT-PHX MAY 4>1.5[6]
WN ONT-SFO MAY 3>1.0[0]
WN ONT-SJC MAY 4>1.0[5]
WN ONT-SMF MAY 4>2[6]
WN PDX-SJC MAY 2>1.6[5]
WN PHX-SAN MAY 5>4[10]
WN PHX-SAT MAY 3>1.6[3]
WN PHX-SFO MAY 3>1.1[5]
WN PHX-SJC MAY 3>1.6[7]
WN PHX-SMF MAY 4>2[5]
WN PHX-SNA MAY 4>2[6]
WN PHX-STL MAY 2>1.6[3]
WN SAN-SFO MAY 4>3[7]
WN SAN-SJC MAY 6>4[13]
WN SAN-SMF MAY 6>5[13]
WN SEA-SJC MAY 2.0>1.5[4]
WN SEA-SMF MAY 2>1.6[4]
WN SEA-STL MAY 1.0>0.1[1.0]
WN SJC-SNA MAY 4>3[11]
WN SJC-STL MAY 1.0>0.1[1.0]
WN SLC-STL MAY 1.0>0.0[0] JUN 0.9>0.7[0]
WN SMF-SNA MAY 4>2[6]
WN STL-TUL MAY 1.9>1.0[1.9]
Assume this is 100% cancelled
WS ATL-YYC MAY 0.9>0[1.0]
WS AUS-YYC MAY 0.3>0[0.3]
WS BNA-YYC MAY 0.3>0[0.4]
WS BNA-YYZ MAY 1.1>0[1.5]
WS BOS-YYC MAY 0.6>0[0]
WS BOS-YYZ MAY 1.7>0[3]
WS DEN-YYC MAY 0.4>0[0.4]
WS FLL-YYZ MAY 0.7>0[1.1]
WS HNL-YVR MAY 0.9>0[1.0]
WS IAH-YYC MAY 1.5>0[1.7]
WS JFK-YYC MAY 0.7>0[0.9]
WS LAS-YEG MAY 0.5>0[0.6]
WS LAS-YVR MAY 1.5>0[1.9]
WS LAS-YWG MAY 0.3>0[0.3]
WS LAS-YYC MAY 3>0[3]
WS LAS-YYZ MAY 1.8>0[2]
WS LAX-YEG MAY 0.9>0[1.0]
WS LAX-YVR MAY 3>0[3]
WS LAX-YYC MAY 1.7>0[2]
WS LAX-YYZ MAY 1.6>0[2]
WS LGA-YYZ MAY 6>0[7] JUN 7>6[7]
WS MCO-YYC MAY 0.3>0[0.3]
WS MCO-YYZ MAY 1.8>0[2]
WS OGG-YVR MAY 0.9>0[1.0]
WS PDX-YYC MAY 0.9>0[1.0]
WS PHX-YEG MAY 0.4>0[0.5]
WS PHX-YYC MAY 1.7>0[2]
WS PSP-YVR MAY 0.6>0[0.8]
WS PSP-YYC MAY 0.8>0[1.4]
WS RSW-YYZ MAY 0.6>0[0.6]
WS SAN-YVR MAY 0.3>0[0.3]
WS SAN-YYC MAY 0.4>0[0.5]
WS SFO-YVR MAY 1.4>0[1.5]
WS SFO-YYC MAY 1.4>0[1.5]
WS SNA-YVR MAY 0.9>0[1.0]
WS TPA-YYZ MAY 0.5>0[0.7]
YR BLD-PGA MAY 1.0>0.4[1.0]
YR GCN-PGA MAY 1.0>0.4[1.0]
United1
Re: OAG Changes 4/19/2020:F9 Cuts AUG/SEP;DL Exits JAXRDU;UA Follows AA by Decimating Int'l for May and Summer, Drops SC
Sun Apr 19, 2020 12:00 pm
UA is operating some International service In May...
SFO-SYD/NRT
IAH-GRU
ORD-LHR
IAD-FRA
EWR-AMS/LHR/FRA/TLV
There are a few cities in Mexico as well as a few Central America flights operating as well. We’ve been discussing it over on the fleet thread.
I know the voices in my head aren't real but sometimes their ideas are just awesome!!!
ZazuPIT
Sun Apr 19, 2020 12:22 pm
It's depressing to scroll through these cuts. I suspect the skies will be pretty much empty this summer.
enilria
Sun Apr 19, 2020 12:25 pm
Hopefully just Summer
SFO-SYD/NRT
IAH-GRU
ORD-LHR
IAD-FRA
EWR-AMS/LHR/FRA/TLV
I didn't see any media coverage on this. When it was it announced?
chonetsao
Sun Apr 19, 2020 12:26 pm
I am so surprised to see some European airlines keep some of the May schedule. I mean didn't US still require international arrives into certain airports? I just don't see how BA and IB operated so many flights as they intended to in May.
Stranger thing is that it seems to me that TAP is to increase flight between LIS and USA in June!
However, the Air China zero out flight between China and USA in May is very concerning.
MIflyer12
Sun Apr 19, 2020 12:44 pm
The listed 13 is plenty of variety. It includes all of the top 15 U.S. int'l gateways for 12 months ending June '19 except FLL, IAH and MCO.
https://www.dhs.gov/news/2020/03/17/fac ... ies-europe
patrickw421
Sun Apr 19, 2020 12:56 pm
From what I saw on weibo (Chinese Twitter), CA is still keeping one weekly (Sunday) LAX-PEK, with a stop in TSN. All international routes to China is limited to 1 weekly and flights to PEK need to make a stop in nearby city for quarantine reasons.
For those who read Chinese, the list of international routes in May by CA can be found here: http://m.weibo.cn/detail/4494440875972612
United1
Sun Apr 19, 2020 1:04 pm
SFO-SYD/NRT
IAH-GRU
ORD-LHR
IAD-FRA
EWR-AMS/LHR/FRA/TLV
Most of the long haul service I mentioned above never stopped operating. New in May for passenger service is ORD-LHR, IAD-FRA and EWR-AMS...which also never technically stopped operating but were cargo only for a while.
Not sure if, or why there would need to be, a press release etc but they are bookable on United.com. The three “new” routes start roughly the middle of May.
Central America/Mexico service is:
EWR - BQN/SJU/STT
IAH - BJX/GDL/GUA/MEX/MTY/SAL/SJO/TGU
Lots of the Latin America routes are less than daily.
ChrisNH38
Sun Apr 19, 2020 1:07 pm
With their blood tests being done, EK plans to come into BOS with the A380 straight away. They say.
https://my.flightradar24.com/ChrisNH
HVNandrew
Sun Apr 19, 2020 1:22 pm
Thanks for the updates Enilria.
AC's YUL transborder service is down to virtually nothing right now. It had looked like YUL-LGA/EWR/BOS/DCA/LAX would still fly on very reduced schedules during the crisis, but over the last few weeks even that limited service has dwindled down to nothing. This coming Friday there is one scheduled flight from YUL to each of LGA, EWR, BOS and DCA and nothing the following week again until Friday. Not sure why those once weekly flights are still scheduled. It looks like in May some service is scheduled to be restored, though given how much has been cut over the last few weeks and the extended border closure, I am not sure how much of that will actually go ahead as planned.
jayunited
Sun Apr 19, 2020 1:23 pm
Enilria I'm not sure if there has been media coverage, UA announced some changes on Flying Together.
On Flying Together UA announced GLA, SNN, MAN, NCE, PMO and BDA were all canceled for the summer season. Perhaps a mistake was made when they filed the changes but UA has told employees all other international changes are on only effective through June 3, and they are still working on the remainder of the summer schedule. Hopefully with next weeks OAG report they will correct the mistake because this isn't what was told to employees on Friday evening when they loaded the changes into the system.
Thank you for all your hard work putting this thread together every Sunday I do appreciate it.
Nicknuzzii
Sun Apr 19, 2020 1:28 pm
I Interesting for F9 to cut so many routes already.
CriticalPoint
Sun Apr 19, 2020 1:37 pm
enilria wrote:
SFO-SYD/NRT
IAH-GRU
ORD-LHR
IAD-FRA
EWR-AMS/LHR/FRA/TLV
It was announced internally....don’t know if there was a press release. lol in the UA fleet and route thread
Dominion301
Sun Apr 19, 2020 1:43 pm
The only Washington-area service AC have planned for May is 1x YYZ-IAD. They're actually increasing (at this point) transborder capacity in May. Here's the link to all AC changes from 'normal' ops: https://app.meltwater.com/mwTransition/ ... newsletter
It gets updated (i.e., downward frequency adjustments) it seems like every 3 or 4 days.
For G4, are they suspending all ops in May?
tphuang
Sun Apr 19, 2020 1:47 pm
Good morning enilria, thanks for doing the hard work again.
I also find it quite surprising AF is keeping MIA-PAP around still.
I'd imagine JAX-RDU will be first of many routes get chopped on a more permanent basis among the major airlines.
It looks like F9 is just canceling a lot of flights permanently. Looks like they will be significantly smaller by next year. Kind of makes me wonder the future of this airline.
kondoo
Sun Apr 19, 2020 1:53 pm
Same applies for Latin Carriers. LATAM still planning to operate most of its May-Summer schedule? Are they getting as much cash as they can just to cancel later?
aaflyer777
Sun Apr 19, 2020 2:14 pm
This just seems bizarre, why are they adding frequencies???
Cointrin330
Sun Apr 19, 2020 2:23 pm
Indeed, this is such a great thread and a lot of work goes into it each week.
I was booked on PMO-EWR for June 10th. Got an email from UA last week that the flight was cancelled. UA processed a refund in less than 24 hours. Two weeks later, still waiting for AA to refund my JFK-FCO flight for May, which was cancelled in March.
CIDFlyer
Sun Apr 19, 2020 2:24 pm
So looks like G4 is taking the month of May off? Does that mean they aren’t taking a stimulus package? How does that work?
TYSflyer
Sun Apr 19, 2020 2:29 pm
Right now many of their flights are still available for purchase on their website. Will be interesting to see if this is a misfile or if they truly cancel all flying for the month of May with a schedule load soon. I will say they did very little flying in April with numerous close in cancellations.
usflyer msp
Sun Apr 19, 2020 2:51 pm
Why not. G4 owns their fleet so they don't need revenue to support aircraft payments. Everything except for crews and HQ staff is contracted out so they would not receive much from the "payroll support" grant section of the relief bill. It may be a better move for them to just shut down and keep a skeleton staff until tourism demand returns. I would not be shocked to see SY do the same.
Nicknuzzii
Sun Apr 19, 2020 2:57 pm
Potentially cancelling other flights to the US?
GoncaloRibas
Sun Apr 19, 2020 3:00 pm
TP is still updating their flights for the month of June, they are adding some new flights with new flight numbers to then withdraw the old flights
enilria
Sun Apr 19, 2020 3:12 pm
I think they just haven't cut May fully yet.
Blood tests? What?
Who knows
Presumably they can't get the CARES loans and such unless they reopen stations. Same for NK.
Or they just filed their plans from 3 months ago by mistake.
or that...
hiflyeras
Sun Apr 19, 2020 3:49 pm
DL is still showing a crazy amount of flights on some city pairings. Is this still a work in progress? I'd hope so.
DL ATL-EWR DEC 11>9[9] JAN 10>9[9]]
TW870
Sun Apr 19, 2020 3:52 pm
Thank you enilria as always for this important thread.
On the Delta front, it looks like they did another round of May trims on top of those registered in a last couple of weeks. Doing this incrementally likely helps them manage customer service workload, as they can keep the rebooking workload consistent as they do the cuts slowly. My guess is we'll see the June international cuts in the next week or two.
So depressing, and I cannot wait until we can be talking about what gets added back!
Bingo1
Sun Apr 19, 2020 3:54 pm
Thanks as always Enilria.
There's is ONE and ONLY ONE nice thing about all these cuts. I get to see route frequencies listed that we seldom, if ever see. Especially in markets that I normally don't follow.
For example I didn't realize the quantity of flights on BA on JFK-LHR. It's no wonder that is the most valuable airline route in the world.
Planecrzy
sspontak
Sun Apr 19, 2020 4:00 pm
These schedules are for September-January so there are too far in advance and may still be reduced based on demand. Too soon to know for sure.
Rdh3e
Sun Apr 19, 2020 4:03 pm
Only one of those is May... The rest are too far in the future to guess at what demand will be.
Ishrion
Thanks as always! TAP is pretty optimistic? Recently added 3 new long-haul routes and now adding more frequencies?
twicearound
Sun Apr 19, 2020 4:17 pm
Blood tests? What?
Who knows
or that...
EK is doing rapid tests for covid-19 at the airport before pax can board their flights. It's been in the news.
sprxUSA
Sun Apr 19, 2020 4:40 pm
No shock to see OO/UA end SCK-LAX. That was a crap flight when things were good. I think it is over already anyway.
Gem State Airlines..."we have a gem of an airline"
Cubsrule
Sun Apr 19, 2020 4:50 pm
Correct, and the May change is basically consistent with DL’s overall domestic strategy, which is cutting the longer flights and keeping something closer to normal frequency to the closest hub. I have not been following AA and UA closely enough to know if they are doing something similar but it seems like a sensible strategy to me.
Abeam79
Sun Apr 19, 2020 5:02 pm
F9 is owned by Indigo and these holding firms never hold on to assets, when they have no need to do what they can or done turning them around they sell it off or liquidate the assets. With these cuts It doesn't look like they will be wanting to invest much more in their airline division IMO.
knope2001
Sun Apr 19, 2020 5:13 pm
Thanks, as always, enilria!
At Frontier it looks like nearly everything will be gone come August except Denver, Florida and Vegas. The only outliers I find:
PHL-ATL/CUN/DFW/IAH/JAX/LAX/RDU
EWR-CUN/RDU
PHX-SAN/SJC/SLC
ATL-CVG
RDU-ISP
AUS-IAD
Certainly Frontier has long realigned its network seasonally, and you certainly can't fault an airline for retreating to long-time strengths at a time like this. But it's still kind of remarkable to see nearly nothing else of the massive web they've built over the years being retained. Lord knows what air travel demand will look like four months from now anyway. But I thought it was notable to see how (except for a handful of Philly routes) pretty much it's Denver, Florida and Vegas.
AA94
Sun Apr 19, 2020 5:28 pm
Can't speak for other airlines, but at mine we are loading schedule changes incrementally so as not to overload customer support functions with customers requiring changes/refunds.
acavpics
Sun Apr 19, 2020 6:03 pm
I'm really dying to know what the schedule for next Christmas/Holday season will look like across the country and the world.
tphuang
Sun Apr 19, 2020 6:32 pm
Just taking a look at the frontier changes again. Not only are there a lot of changes, there seems to be a change in their strategy also. I see a lot more daily or twice daily routes and a lot of fewer 2/3/4x weekly type of routes. Again, everything seems to focus on DEN/LAS/Florida/CUN and quite a few on PHL. Looks like EWR is almost all gone. That was fast. ONT is almost completely gone. LAX is almost gone. DFW is almost gone. BOS is almost completely gone. ATL is done to almost just Florida. CLE/CVG/CMH seem to just be down to Florida/DEN/CUN.
I'm not really sure what you call this strategy. Seems like they are looking to quite acquired by someone. I know they were supposed to have agreed to the CARES money, but I don't know if they will actually go ahead with it and keep the employees.
Same with G4, seems like they just decided to stop flying. the minimum service requirements were really unfair against these 2 airlines. I always thought they were the most likely to not accept the terms.
Enilria, do you still see any route operational for G4 in May?
Amazing stuff WN is still operating so many LGB flights in May. What are they thinking. I'm 90% sure B6 will be down to under 5 flights a day at LGB. WN can have all the slots at LGB. I think there will be more available gates at LAX coming out of this.
mcogator
Sun Apr 19, 2020 7:05 pm
All that's left on LAX-MCO is UA. Not sure why they are the last ones standing on this route, as I thought DL would be. DL just got rid of their last one, as I received the email about my May flight last night around 1am pst. Now I'm connecting in ATL.
“Traveling – it leaves you speechless, then turns you into a storyteller.” – Ibn Battuta
phllax
Sun Apr 19, 2020 7:15 pm
enilria wrote:
The stuff not dropped is now the more interesting part
*AF MIA-PAP MAY 0.5>0.2[0.6]
This flight is a lifeline for the French Caribbean. Cargo and other essential food stuffs are what is keeping it going.
United1
Sun Apr 19, 2020 7:20 pm
UA and AA handle most of Disney's corporate travel but LAX/SFO-MCO are not operating right now on UA.
AA 2279 looks like it's still running.
DesertAir
Sun Apr 19, 2020 7:41 pm
Central Valley towns need another model for air service. Fares are too high. I don't see why Allegiant doesn't run a daily to LAX.
DDR
Sun Apr 19, 2020 7:53 pm
What blood test? No way would I ever submit to a blood test to an airline in order to travel. I can’t believe the US government would allow this.
braniff2hav
Sun Apr 19, 2020 8:14 pm
I didn't see this picked up. Might have missed it.
F9 is operating service DEN->MSY->PNS->DEN
OPerates 24Apr and 01May and then goes away.
LOL the fare MSY PNS is $103.10 but if you go through to DEN the fare is $78.10. unhuh
braniff2hav
Sun Apr 19, 2020 8:19 pm
I'm surprised that TP is not soon launching service LIS to JNB and/or CPT.
United1
Sun Apr 19, 2020 8:32 pm
They did blood tests on one flight out of Tunisia.
There isn't a mention of it on their website currently but looks like they are making passengers go through a thermal (temperature) check.
ericm2031
Sun Apr 19, 2020 9:12 pm
UA hasn't put in the May domestic cuts yet, I heard it will happen tonight. Right now LAX is only doing hub flying and I would expect that to continue.
Aircellist
Sun Apr 19, 2020 10:02 pm
Thanks for that impressive work, Enilria!
Looks like only LH and its family are sustaining a bit more than a bare skeleton (if only) of international flights to the USA…
"When I find out I was wrong, I change my mind. What do you do?" -attributed to John Maynard Keynes
FSDan
Sun Apr 19, 2020 11:00 pm
EWR-CUN/RDU
PHX-SAN/SJC/SLC
ATL-CVG
RDU-ISP
AUS-IAD
I noticed that too. The RDU focus city in particular is getting slashed, along with a lot of East-West stuff that doesn't touch LAS, DEN, or MCO.
This is my signature until I think of a better one.
Dominion301
Sun Apr 19, 2020 11:12 pm
Also keeps the MIA-based 320s slightly active. Are there two AF 320s based at MIA?
