PepeTheFrog
Boeing reshapes leadership, signals production cut
Tue Apr 21, 2020 10:39 pm
Boeing has simplified its top leadership, I'm guessing it will allow Boeing to react faster while the pandemic drags on.
Boeing reduced the size of its top leadership team Tuesday and enlarged the already extensive authority of number two executive Greg Smith.
The changes, driven by new CEO Dave Calhoun, are billed in a company statement as “preparing now for the post-pandemic industry footprint.”
Boeing also signaled it will have to cut production, because it believes the post pandemic aviation market will be much smaller.
In a message to employees earlier this month Calhoun warned that when the world emerges from the pandemic, the size of the commercial jet market is likely to be significantly smaller.
“We will need to balance the supply and demand accordingly as the industry goes through the recovery process for years to come,” he told employees.
This means Boeing will have to cut production to match the need for fewer airplanes.
https://www.seattletimes.com/business/b ... footprint/
So, how will the post pandemic Boeing look like? Any insight on the new production rates?
Good moaning!
Weatherwatcher1
Re: Boeing reshapes leadership, signals production cut
Wed Apr 22, 2020 1:16 am
Consolidating executive council leadership increases the influence of the engineering leaders. I would think the retirement of people with business and finance backgrounds from the powerful executive council would be commended on this website.
Cointrin330
Wed Apr 22, 2020 1:55 am
The road ahead will be long, complex, and extremely challenging for this icon of American business, power, and symbol of American greed, arrogance, and in many ways, all that is wrong with the country. It could do with a little bit of humbling and better leadership.
lightsaber
Wed Apr 22, 2020 2:37 am
The issue is first an abrupt pain for the supply chain.
This isn't about developing new product, it is about reducing cost.
We knew this was going to happen. This is a focused team. The fact we have new names means this happens fast.
Lightsaber
Flu+Covid19 is bad. Consider a flu vaccine, if not for yourself, to protect someone you care about.
Sooner787
Wed Apr 22, 2020 9:35 pm
At what point does Boeing consider consolidating all 787 production into a single factory?
I assume 10 a month production is still enough to keep PAE & CHS lines open, but what rate
is the tipping point?
iamlucky13
Wed Apr 22, 2020 11:01 pm
I doubt they've worked that out yet.
Unfortunately (depending which state one has closer ties to) as I recall, the 787-10 center fuselage sections don't fit in the 747 LCF. If it turns out to make sense to consolidate, that could significantly affect Everett employment.
Palumboism
Thu Apr 23, 2020 1:15 am
I believe it will happen in 2020. One of the industry analysts estimates the rate for the 787 will go down to four a month and that seems realistic. I think Charleston is already producing four a month.
Footprint is a commonly used term in manufacturing to indicate what you are producing where. The footprint for the 787 will be changing soon.
Phosphorus
Thu Apr 23, 2020 8:24 am
For those ignorant on the subject (like me), if 787 Charleston factory was (suddenly) a stand-alone company -- what components would it need to buy from Washington state parts of Boeing?
AN4 A40 L4T TU3 TU5 IL6 ILW I93 F50 F70 100 146 ARJ AT7 DH4 L10 CRJ ERJ E90 E95 DC-9 MD-8X YK4 YK2 SF3 S20 319 320 321 332 333 343 346 722 732 733 734 735 73G 738 739 744 74M 757 767 777
Ceterum autem censeo, Moscovia esse delendam
Noshow
Thu Apr 23, 2020 8:28 am
The Charleston site is sized for possible enormous growth.
But what would be left at Everett? The 747, 767 and 777-300ER/F are not hot sellers anymore. The 777X might be delayed or slow selling first? NMA? Everett needs work too.
seahawk
Thu Apr 23, 2020 8:36 am
Everett could be closed.
skipness1E
Thu Apr 23, 2020 9:14 am
Unlikely as the skills base is in WA and won’t move in sufficient numbers.
IWMBH
Thu Apr 23, 2020 9:16 am
It doesn't make sense to close the whole factory.
With the 767 (including the KC-46) and the 777(X)-line they will have work for years to come.
The 747-line will also be open for another 2 years with the UPS order, and by then the economy is probably on its way back up.
The 787-line could be closed though, doesn't make sense to spread the production over two factories when you'll planning to bring down the amount of planes built.
Blerg
Thu Apr 23, 2020 9:24 am
Could we see Boeing split in the future? Maybe separate commercial aviation from military one?
Noshow
Thu Apr 23, 2020 10:16 am
Everett just got the new wing factory. It doesn't make sense to close it at all. All the infrastructure is there and the engineers.
However one day Renton might close whenever the final MAX got built.
IWMBH
Thu Apr 23, 2020 11:37 am
I think the successor will lean heavily on the MAX's exciting infrastructure.
That railroad that transports 737 frames to the factory much cheaper then flying them there (I presume).
So, why wouldn't they use it in the future?
morrisond
Thu Apr 23, 2020 1:18 pm
I wonder if they could take over 787 Wing Production in Everett from Japan? America first.
WayexTDI
Thu Apr 23, 2020 1:43 pm
Who said Spirit would get the 737 replacement fuselage?
Phosphorus
Thu Apr 23, 2020 1:44 pm
When MAX is over (one way or the other), we can speculate that a new narrow-body will be designed by Boeing. Do we expect it to retain same fuselage dimensions, as MAX? Railroad gauge might be a limiting factor to retain existing supply chain arrangements, one would assume.
lightsaber
Thu Apr 23, 2020 1:52 pm
There is a contract with Mitsubishi. They own much of the engineering on the wings. They own the wingbox design.
I don't understand the obsession with the MAX production ending. It will lose backlog, but thousands will still be produced. Boeing is late, so cancelations are easier, but there will be future orders. I suspect there will be a future narrowbody built there.
Lightsaber
TexStones
Thu Apr 23, 2020 3:00 pm
Boeing isn't about to close any production facilities.
787 will eventually consolidate at Charleston. NMA will occupy the existing 787 line at Everett. MAX will eventually transition to NSA at Renton. A second NSA line may be established at Charleston.
morrisond
Thu Apr 23, 2020 3:01 pm
Lightsaber
I agree with you on the MAX .
I was just throwing that out on the 787 Wing - just more curious than anything whether or not the factory could produce it. If Volumes are too low Mitsubishi might sell it to Boeing as it won't economical for them to produce anymore.
I would have to guess that Wing factory was built for NMA as well as 777X - with neither likely to be built in volume for some time - they need to find work for it or it won't be economical.
There could be a lot of consolidation of production facilities to get to Economical production numbers.
Palumboism
Thu Apr 23, 2020 4:25 pm
None.
The midbody and aft section are both made in Charleston and shipped to Everett on the Dreamlifter and the forward section is made in Wichita by Spirit. Charleston has it's own final assembly like, paint, and delivery center.
It is actually incredibly expensive to airlift the aft section and midbody across the country to Everett. Moving all final assembly to Charleston is a huge cost savings and I believe Boeing will make this move in 2020.
morrisond
Thu Apr 23, 2020 4:32 pm
Palumboism wrote:
None.
That would make sense to me. I would have to guess that on average the employees in Everett are older and a lot more expensive as well. They should be closer to retirement so a lot more likely to take the buyout if they see the writing on the wall.
Palumboism
Thu Apr 23, 2020 6:32 pm
morrisond wrote:
Palumboism wrote:
None.
Everett is unionized (IAM) and Charleston is non union. There's a huge cost savings there too.
Phosphorus
Thu Apr 23, 2020 8:04 pm
Thanks for all the answers! So, if the management believed that situation was dire, and push came to shove, a "project Ark" company could be centered around Charleston 787 assembly line. This company could put on its balance sheet a fair amount of historical Boeing group losses, in order to make sure that (to quote an infamous song) "the Feds might be screaming, but we shall be beaming, for we'll pay no taxes again!". A relatively quiet business, with well-defined product, pretty clear lifecycle timelines, etc.
The rest of Boeing could fend off for itself, being centered around Washington State assets, with BDS providing revenue and profit, needed to sort out MAX, nurture 777X through COVID pandemic and subsequent restart of aircraft orders, see through sunset of 747 program, etc. A very busy and nervous place, with high stakes, big possible achievements and ever bigger possible failures. If very successful, at some point this Boeing can buy back the Charleston-centered 787 company.
Just a hypothetical construct, but not impossible to pull of, if the chips fall down.
kjeld0d
Thu Apr 23, 2020 8:27 pm
Perhaps they will professionally foster B2B synergy, progressively right-shore agile web-readiness, or professionally iterate enterprise supply chains? Could also assertively empower progressive internal or "organic" sources, phosfluorescently strategize technically sound mindshare, interactively conceptualize accurate communities, and credibly expedite leveraged technology.
