enilria
DL Was Losing $100m/Day in Late March
Wed Apr 22, 2020 4:41 pm
A video I saw clarified that Delta was losing $100m per day at the end of March. I wonder where they are now? $50m? $25m?
https://www.thestreet.com/video/delta-i ... lion-a-day
NWAESC
Re: DL Was Losing $100m/Day in Late March
Wed Apr 22, 2020 4:44 pm
Roughly $50M/day per Bastain on CNBC earlier today.
"Nothing ever happens here, " I said. "I just wait."
LCDFlight
Wed Apr 22, 2020 4:50 pm
Delta is a $40B/ year company. So their basic cost structure is $100M/day when they run a full schedule. If their demand fell 90%... math becomes real tough.
tphuang
Wed Apr 22, 2020 5:05 pm
he said $50 million by end of June. A week ago, they were in the $60 to 70 million range. April cuts are not as severe as May/June cuts, so I think the burn rate will be in this range until May at least and then it should drop a little bit. Also, it helps that cash refund should at some point be offset or exceeded by bookings. My guess is $65 to 70 million per day in April, maybe $55 to 60 million a day in May and then $50 to 60 million a day in June.
usdcaguy
Wed Apr 22, 2020 5:34 pm
Terrible numbers. Hard to believe a $1.5B monthly loss is the target. I don't see the airlines getting past September without more money from the government. Layoffs are a given. If I were Bastian, I would be having each department go through their contracts to determine what they can cancel at this point. Of course, that won't be enough. You have to wonder if Ch. 11 will be on the table again so they can renegotiate their agreements to match the needs of a smaller airline and then build up once the pandemic is over.
0newair0
Wed Apr 22, 2020 5:49 pm
Back half of April is the May schedule. Jun schedule will have less cuts than May. Part of cash burn reduction is based on assumption revenue will start to slowly come back.
That's not how this works! That's not how any of this works!
panamair
Wed Apr 22, 2020 5:54 pm
On the earnings call today, they said that they should be hitting the $50m a day mark starting in May. They also said they are starting to see cash sales equal refunds now, so coming out of negative net sales as refunds ease up.
0newair0
Wed Apr 22, 2020 5:55 pm
The experience reduction exercises were already done. Delta has $10 billion in liquidity and this could get pushed up to $15 billion. Layoffs will happen after September 30 as needed, but none are currently planned because the truth is no one knows what is going to happen 6 months from now. Everyone's having hard enough time figuring out what's going on 6 days from now.
Lootess
Wed Apr 22, 2020 5:56 pm
Well June hasn't been fully loaded, and with 250 more aircraft going to be parked soon, the math is simple.
It's not shrinking to profitability, it's shrinking to weather the storm.
tphuang
Wed Apr 22, 2020 6:04 pm
That's fair. Cash burn is not just cost - revenues, but also cash refund from cancellations. So second half of April will have more losses even if the cuts are as deep as May.
The problem is that when there is a little more demand in the market (airlines are saying it's minimal still) and airlines schedule a few more flights, you don't burn any less cash. That's why I don't forsee DL actually running more flights in June than May. You don't cut 50% of your cost with as much fixed costs as DL unless you cut out vast majority of capex and basically stop flying. The reason they are having 50% less cost is because they cut 90% of schedule.
0newair0
Wed Apr 22, 2020 6:06 pm
The information I offered has nothing to do with the current state of the published schedule.
NWAESC
Wed Apr 22, 2020 7:59 pm
0newair0 wrote:
...because the truth is no one knows what is going to happen 6 months from now. Everyone's having hard enough time figuring out what's going on 6 days from now.
+1
At this point, I’d just like to be out of fire drill mode...
B757Forever
Wed Apr 22, 2020 11:51 pm
NWAESC wrote:
+1
I hear ya NWAESC. That's why I took an April LOA. I might extend it to include May also. I'm hoping the picture may be a little less fuzzy for my return to work in June...
The Rolls Royce Dart. Noise = Shaft Horsepower.
catiii
Thu Apr 23, 2020 12:29 am
Any additional federal funding will be tied to not laying off employees. Every CEO, CFO, FP&A, etc team at every carrier has already gone through every contract to change payment terms, reduce spending, etc.
geologyrocks
Thu Apr 23, 2020 1:25 am
Has any airline considered running multi-stop flights? Is this a refund avoidment issue? If you have three flights all leaving at the same time to go to MLU, AEX, and LFT...could you just run 1 of them to all 3?
0newair0
Thu Apr 23, 2020 1:30 am
Yes, Alaska is doing this.
MIflyer12
Thu Apr 23, 2020 1:43 am
There were lots of remarks regarding reductions in cash burn, liquidity moves, unencumbered assets and what not on today's earnings call. Grab the audio or the transcript.
https://ir.delta.com/home/default.aspx
WassbiKhalifa
Thu Apr 23, 2020 4:54 am
I started with DL in 1984. Running flights that went ATL-MOB-SHV-MLU-DFW were the norm back then. It makes a lot of sense to run those types of flights again in my opinion.
panamair
Thu Apr 23, 2020 5:44 am
This thread should probably be consolidated with this one:
viewtopic.php?f=3&t=1444999
since they both are discussing DL’s Q1 performance
usdcaguy
Sat Apr 25, 2020 4:03 pm
Interesting idea. It would have the added affect of giving people in places like MOB flights to other small cities. But the way our country works now is that most business is in the top 20 cities like NY, LA, Houston, Chicago, Atlanta, etc., so the airlines now offer a zillion competitive services between those cities, so they can't really add three stops to small places while hoping to attract passengers. They could, however, add tags like TUL-OKC to flights like ATL-TUL. etc., which was done in the past. The demand for the shorter tags, however, is likely very low given the higher speed limits we have now on the road.
wv399
Sat Apr 25, 2020 5:52 pm
Alaska and JetBlue have added multi-stop flights.
BravoOne
Sat Apr 25, 2020 6:40 pm
Current schedule projections shows 3000 pilots are in excess. Working with alpa to determine if a early out program is feeaseable. Obviously 3000 off the top would be preferable but no one beleieves that will happen. Furlough notices to go out around July 1st and be effective in Sept. Flying not projected to return to present levels until Dec. 2022. All MD88/MD90's parked by next week.
Looking hard a 767 & 777 sell offs. 737MAX is a real rumor based on getting rid of the 717.
This information comes from an internal meeting with senior Line Check Airman which is a common Delta method of information dissemination for the pilot group. Sometimes spot on, and other times not so accurate.
