SpaceshipDC10
Why did Wardair retire/sell their 747-200s instead of the older -100s?
Sat Apr 25, 2020 5:29 pm
The picture below triguered the question.
Back in 1986/87, Wardair removed from their fleet the two 742s they had received brand new less than ten years earlier. They were both newer and GE-powered compared to the -100s, which could count as fleet simplification since they had then DC-10s and A300s with such engines.
https://www.planespotters.net/airline/Wardair-Canada
FlyCaledonian
Re: Why did Wardair retire/sell their 747-200s instead of the older -100s?
Sat Apr 25, 2020 6:05 pm
Depends if they were owned or leased. If the latter they maybe didn't like the leasing charges.
Or, if they were owned and needed the money the 747-200s could be seen as having the higher value, so made more sense to sell those, especially if between the 747-100s and DC-10s they had the aircraft to cover their network needs.
Let's Go British Caledonian!
SueD
Sat Apr 25, 2020 6:44 pm
You know they went to your namesake sakes C-GXRA became G-GLYN and C-GXRD became G-NIGB
Wardair were transiting from an APEX -Visiting Families and Friends business towards a more scheduled operation (with increased frequencies and smaller aircraft )Didn’t go to plan !
C- FDJC remained in Canada and moved to Nationair on collapse (Did you know this frame has an unusual distinction in changing its Boeing customer code whilst on the production line - Should have gone to Braniff as a 747-127 (N602BN in Green ntu) but left directly to Wardair as a 1D1
C- FFUN also went to Nationair
C- FTOB an ex AIr Canada machine also had a short stint with Wardair
The 3 DC10s were also to leave the fleet in 1989
The replacement fleet would be 3 A300s primarily for trunk domestic and a dozen A310s for the Trans Atlantic schedules - On closing the A310s and crews would transfer the Canadian
skipness1E
Sat Apr 25, 2020 6:56 pm
They were worth more and Wardair were trying to finance their A310 purchase so liquidity came in useful.
CanadianNorth
Sat Apr 25, 2020 7:32 pm
The replies so far line up fairy well with how I understood the story as well.
Wardair for many years operated primarily vacation type charters, for which the 747s were a good fit. In the mid to late 1980s they pushed hard to get into the scheduled airline market, but one of the challenges was their main competitors operated fairly high frequencies on the trunk routes with connections to dozens of outstations and Wardair's fleet of 747s and DC-10s just wasn't suitable for this type of flying. The solution was they placed orders for A310s, MD-88s and F-100s, and also acquired some second hand A300s as filler.
The money for all of these orders had to come from somewhere, so they sold off a couple of 747s, and my guess is they likely found the -200s were worth more on the used market and for the flying they had at the time the -100s were probably good enough for now.
HS-748, like a 747 but better!
Dominion301
Sat Apr 25, 2020 11:39 pm
They did indeed. Max Ward wrote in his fantastic autobiography that they sold the 747s for more than they paid for them. They actually did the same thing with their 707 and 727.
It’s too bad WD never pursued being TS as a sked airline instead of trying to take on AC and CP.
jimbo737
Sat Apr 25, 2020 11:51 pm
Wardair rarely made money operating the airline.
They made a ton of money trading iron though.
Eventually, there was nothing more to trade.
Max then schooled Rhys Eyton, selling him a near bankrupt airline and walking away like a bandit.
SpaceshipDC10
Sat Apr 25, 2020 11:59 pm
Interesting details here. I knew WD was about to transition to scheduled services with smaller aircraft, but I didn't consider the two -211Bs were sold for that matter.
For my part I know it, and I also know there's more to it than that. After it was NTUd by Braniff, it should have been delivered to Universal Airlines, hence the "D1", however that airline collapsed, and it ended up at Wardair a couple of years later. For some reason, C-FFUN, which was a former CO -124, was also changed to -1D1 even if Universal was long gone when it joined Wardair. WD's customer code was "11".
AB330
Sun Apr 26, 2020 1:58 am
Just out of curiosty did both of Wardair B747-211B end up with PAL?
SpaceshipDC10
Sun Apr 26, 2020 2:29 pm
It came in when the first -200B left, and remained until the end.
They left between May '88 and April '89s.
I always thought they were temporary until enough A310s were delivered.
FlyCaledonian
Sun Apr 26, 2020 5:54 pm
I was aware. BCal picked up a right mixed bag of secondhand 747s in the 1980s for growth. I do wonder if they would have been disposed of first once the MD-11s came on stream but that's a totally other thread!
I suspect that Wardair, a bit like PanAm, got a good deal on the A310-300s from Airbus. Going with a small longhaul twin made sense given that AC was doing the same by converting some of its 767-233s to ER models (as well as taking new builds).
northstardc4m
Sun Apr 26, 2020 10:45 pm
The Wardair A310 order is possibly involved in the Karlheinz Schreiber / "Airbus Affair" which involved Air Canada's A320 order. Wardair had ordered and canceled the A310 once already, then put options in on 767-200ERs, before dropping those and ordering 12 A310-300s.
https://www.thecanadianencyclopedia.ca/ ... s-revealed
Those who would give up Essential Liberty to purchase a little Temporary Safety, deserve neither Liberty nor Safety.
SpaceshipDC10
Mon Apr 27, 2020 11:41 am
If I remember correctly, the original A310's order by Wardair was for the short range version, the only one available at the time. When they later ordered again the type, they had some with the longest range possible (-308s).
longhauler
Mon Apr 27, 2020 1:43 pm
Wardair, like most airlines, always played A against B and as far as getting the best deals, Mr Ward was a master. But, internally, a longer range version was always required, of either type. The base need was LGW-YVR.
However, we had heard that Mr Ward rode in an AC 767-200 with PW engines and decided the “racket” did not meet the WD standard and revised his order to the A310-304. (Anyone that had ridden in an older 767 would understand.)
When the 747-200s were sold, it was at a profit. Just like about any sale/repurchase experienced by Wardair. It was assumed the DC-10s would cover the gap, that eventually the 747-133 of AC filled. But realistically, there were no routes in the WD system that a 747-100 couldn’t fly that a -200 could.
SpaceshipDC10
Mon Apr 27, 2020 8:12 pm
Of course, with such base need the A312 couldn't fit in their requirement. Were the -304s capable to handle it without restrictions?
OK, so even Germany, even though I don't remember whether they flew there from the West Coast and with 747s could be reached.
longhauler
Tue Apr 28, 2020 2:23 am
I flew several. I don’t recall any load restrictions. But don’t forget, WD’s configuration was only 196 passengers in a two class layout. Then 188 when the J sleeper seats were installed.
I recall the DC-10s flying from the continent to YVR, but I’d be surprised if a 747-100 couldn’t as well.
SpaceshipDC10
Tue Apr 28, 2020 11:06 am
Oh yes, there's that. WD wasn't cramming as many people on board as later airlines with their 250 to 264 configurations such as 2T, QN and TS.
