Chugach
ANC-CDB loaded on AS, starts 5/16
Sat May 09, 2020 5:12 pm
AS will start ANC-CDB on May 16, 2x weekly as has been reported in some other threads.
The flight will continue on to ADK, meaning the ANC-ADK nonstop will discontinue after this week.
Good on AS for standing up this service so quickly.
32andBelow
Re: ANC-CDB loaded on AS, starts 5/16
Sat May 09, 2020 6:05 pm
How did they get tsa screening worked out?
Chugach
Sat May 09, 2020 7:03 pm
No idea, but I’d wager that they would probably fly out from ANC. Since this flight is combined with ADK, maybe one set of TSA agents will handle both cities?
32andBelow
Sat May 09, 2020 7:09 pm
Yah but does cdb have any screening equipment?
This is still not going to be anywhere near enough lift for DUT/KVC/SDP. Good luck buying a ticket to ADK. They will also lose out on their EAS contract. Or a portion of it.
TWA902fly
Sat May 09, 2020 7:18 pm
ADK does not have screening equipment - everyone has to check in 4 hours prior to the flight so everything can get searched by hand. The TSA agents that fly in on a flight flies out on one day, and works the flight a few days later, and the next one, its a week long rotation. The police officer comes from ANC and does not stay on ADK. I assume a similar arrangement can happen on Cold Bay.
This information is true as of last August when we flew out to ADK, spoke with both the TSA agent and police officer on the flight.
'902
life wasn't worth the balance, or the crumpled paper it was written on
chrisp390
Sat May 09, 2020 7:41 pm
What on earth is in cold bay to justify this flight? Last I saw 100 people live there, the Alaska flight will have this many seats available on one flight.
joeblow10
Sat May 09, 2020 7:47 pm
Uh - have you flown in Alaska before? You realize Adak is the same sort of setup?
With the loss of Ravn - somebody has to step in to fill the gap in remote Alaska. This doesn’t nearly accomplish that, but at least it allows some connectivity to a few rural villages.
32andBelow
Sat May 09, 2020 8:04 pm
Now look up king cove, sand point, Dutch harbor, and a Akutan. Then google crab fishing, and trident seafoods.
ricq
Sat May 09, 2020 8:46 pm
Looks like they are charging in the $500 - $650 range (first few weeks at least) for rt ANC-CDB on a 737-700 with middle seats currently blocked off (in the seat preview window).
32andBelow
Sat May 09, 2020 8:48 pm
Sounds accurate. And they’ll fill it in 3 seconds. Summer fishing season is starting
ytib
Sat May 09, 2020 8:49 pm
Here is the DOT approval for adding the CDB stop as part of the ADK EAS service.
Full document: https://www.regulations.gov/document?D= ... -8556-0248
Decision
The Department will approve Alaska Airlines’ request, which meets the three conditions necessary for approval under authority assigned under 14 CFR Part 385.12(h)(3) of the Department’s Regulations: (1) the alternate service pattern is equal or greater than that determined to be essential; (2) the communities affected do not object to the alternate service pattern; and (3) the alternate service pattern will not increase Alaska Airlines’ subsidy. Because the Department is allowing the alternate service pattern and not requiring it, Alaska Airlines may revert to the original service pattern at any time. This Order is issued under authority delegated to the Director, Office of Aviation Analysis in 14 CFR Part 385.12(h)(3).
318, 319, 320, 321, 332, 333, 388, 707, 717, 722, 732, 733, 734, 73Q, 735, 73G, 738, 7M8, 739, 752, 753, 742, 74L, 744, 762, 763, 772, 77L, 77W, 789, 142, CN1, CR2, CR7, DC8, DH2, DH8, D8Q, D10, D95, EM2, ER3, ER4, E70, 100, J31, M11, M83, M88, M90, SF3
Chugach
Sat May 09, 2020 9:05 pm
'902
Thanks for the insight!
Chugach
Sat May 09, 2020 9:06 pm
This isn’t about serving Cold Bay, it’s about Dutch Harbor. CDB just happens to be the nearest runway to DUT that can handle a modern 737.
OA940
Sat May 09, 2020 9:50 pm
Pardon my sillyness, but what exactly is preventing 737s from flying into DUT? I mean AS did it with 732s, and 737s fly into similarly-sized runways nowadays as well (SDU is a good example). Is it a wingspan issue or something?
A350/CSeries = bae
Chugach
Sat May 09, 2020 10:37 pm
As an aside, I believe Cold Bay will supplant Adak as the smallest community in the USA with commercial scheduled mainline jet service. Cold Bay has a population of 108.
32andBelow
Sat May 09, 2020 10:49 pm
You realize sand point and king cove residents will book as well. This thing is gonna be a mess. King cove is fairly large. And there is lots of fishing in both king cove and and point. Not to mention akutan which has a trident plant.
32andBelow
Sat May 09, 2020 10:50 pm
The approach has you fly right around a mountain and half the year there is snow and ice.
Chugach
Sun May 10, 2020 12:13 am
DUT is narrow (only 100 feet wide) and has no ILS and no straight in approach or departure, all in a region that has some of the most notorious flying conditions anywhere in the world.
A 73G could probably do it from a performance standpoint, but I believe the other issue is the ramp there is too small for a next-gen 737.
TWA902fly
Sun May 10, 2020 4:49 am
'902
No problem. Adak was one of the most absurd places I've ever been. We have a penchant for places like Adak, Svalbard, Molokai, but Adak - with its abandoned military infrastructure is just absurd. Once that Alaska Airlines 737 that we flew in on left (that had 9 passengers on it including the TSA agent and police officer), we were completely cut off from the world. We stayed in a rented "townhouse" that was the only inhabitable one on the "street", all the other ones were in various states of being retaken by nature. Imagine cookie cutter suburbia, except you wake up and there's been an apocalypse, and you were the only one to survive. All of this set in the magical scenery of the Aleutian islands.
'902
sprxUSA
Sun May 10, 2020 5:01 am
TWA902fly wrote:
'902
'902
Did you swing by the abandoned McDonald's, assuming it is still there. It would have been interesting to be there during its heyday.
Gem State Airlines..."we have a gem of an airline"
32andBelow
Sun May 10, 2020 5:13 am
sprxUSA wrote:
'902
There’s lots of photos of these track homes on google. I recommend everyone Check them out.
They recently just auctioned a bunch of furniture and things from adak.
TWA902fly
Sun May 10, 2020 5:54 am
sprxUSA wrote:
'902
Sure did! It was surreal, just like everything else on that island.
'902
FlyHappy
Sun May 10, 2020 6:35 am
Enlighten me - why a mess? What is the dropoff from the former RAVN service - is it lack of frequency?
32andBelow
Sun May 10, 2020 8:18 am
Because your dropping 180 people into a village with no air terminal. Then they all have to get connecting flights to various other villages. Cold bay has hardly any lodging should the weather go down.
Ravn/penair would fly directly into DUT 2-3 times a day. And to SDP 1 a day and CDB one a day.
It’s going to take like 10 trips in a king air to move all the dut passengers. Then you have passengers coming from dut. To you need to make 10 trips in the morning DUT-CDB to move people to make the 737. Then in the afternoon you need 10 more trips CDB-DUT to move the people to DUT.
Penair had 90-135 seats year round and up to 300 seats a day to DUT during busy season.
FlyHappy
Sun May 10, 2020 3:12 pm
Ah - thanks for that!
I was very much wondering about the link between those villages you mentioned and Cold Bay. King Air's, eh? Who operates those services, where are those aircraft and pilots based?
300 seat per day to Dutch Harbor - dang.
BTW - this thread got me reading late into the night about the Aleutian fishing/canning industry and the "Alaska Marine Highway". Fascinating stuff.
Chugach
Sun May 10, 2020 3:22 pm
In related news, DLG now starts on 5/18 and AKN on 5/19.
longhauler
Sun May 10, 2020 3:54 pm
This thread brings back a lot of memories.
When I was a young lad, I spent all my money on taking “adventure” trips. In the Spring of 1975, I flew on a Reeve Aleutian DC-6B, ANC-CDB. Returning via SDP on the same day. I feared the DC-6 was quickly leaving the North American skies carrying passengers. (I think Mackey was the only other option and at the time, they couldn’t guarantee a CV440 sub wouldn’t happen).
If I recall, RV was using the YS-11 into DUT.
Living near YYZ, I got to ANC by, YYZ-YEG-ANC on AC/NW and returned ANC-ORD-YYZ on NW/AC.
SyracuseAvGeek
Sun May 10, 2020 4:00 pm
The turn in ADK with the nonstop used to be about 3hrs, not he turn in ADK is only 1hr. Will this cause delays as they fly the TSA into the city?
"I haven't been everywhere yet, but it's on my list."
32andBelow
Sun May 10, 2020 5:01 pm
I guess all those penair employees in cdb AKN and DLG just hit the jackpot and got hired by Alaska. Since penair would turn Alaska in akn/DLG
Chugach
Sun May 10, 2020 5:08 pm
I think it’s always been an hour turn. It was noted up thread that TSA does one week hitches in ADK.
Chugach
Sun May 10, 2020 5:14 pm
I believe they also hired the Ravn employees at ADQ, as they ground handled AS there.
There was an article recently where AS was quoted as saying they were trying to buy the Penair terminals in AKN and DLG. AS already owned the ADQ terminal, and CDB has a terminal that is owned by the Aleutians East Borough ( https://www.aleutianseast.org/index.asp ... F0C7061FE8 and https://www.kucb.org/post/renovations-u ... t#stream/0 )
snowzilla
Sun May 10, 2020 5:21 pm
I wonder if Alaska will use the “new” terminal in Cold Bay...
hiflyeras
Sun May 10, 2020 5:37 pm
What a great memory that must be! When I was just out of college I did something similar...in 1979 I flew to MIA so I could take a Provincetown-Boston Airlines DC-3 to Key West. Such a beautiful trip flying low down the Keys! Unlike ADK though I stayed a couple of weeks. ;)
32andBelow
Sun May 10, 2020 5:39 pm
Did they ever pave the ramp there?
snowzilla
Sun May 10, 2020 5:44 pm
They put taxiway D and a ramp in finally, and it turns out Alaska will use that terminal.
32andBelow
Sun May 10, 2020 8:12 pm
They were trying to get penair to pay for it for a while and penair told them no.
evank516
Sun May 10, 2020 8:35 pm
EYW was, until recently, 4,801 x 100 feet and handled multiple 73Gs per day, length and width are not issues from a performance standpoint. It's airport conditions. If there's obstructions such as terrain and also snow and ice, you have other factors to worry about where the aircraft now requires more runway.
NameOmitted
Sun May 10, 2020 10:50 pm
FlyHappy wrote:
If you are into this sort of thing, the State has regional long-range transportation plans that are just a blast. The State maintains ships, a railroad, airports, a shipyard (leased to private industry for operation), barge landings, dredging, winter ice roads, and easements for snow machines (with wayfinding tripods placed in fall and removed in spring).
We've got it all in one form or another. It makes for interesting, if dry, reading.
TWA902fly
Mon May 11, 2020 6:53 am
See my post in one of the responses above.
The schedule usually had a 1 hour turn in ADK. For example - when I flew it last August, the flight was scheduled to arrive ADK at 4:15pm, and depart ADK at 5:15pm. The TSA agents that flew into ADK did NOT work the flight out. The schedule operates Wednesday and Saturday, the agents that fly in on Saturday (for example), work the Wednesday and following Saturday flights. They do not work the same flight they came in on. They fly back to ANC on the second flight - it is a week long rotation. The police officer comes and goes on the same flight.
'902
