enilria
OAG Changes 5/10/2020: JUNE DECIMATION; DL Suspends BUR/CAK/HPN/LGB/MDW/MHT/OAK/PVD/SWF Till Fall
Sun May 10, 2020 11:46 am
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
3M BIM-FLL JUN 0.9>0.6[1.4]
3M ELH-FLL JUN 2>1.4[4]
3M EYW-FLL JUN 2>1.7[3]
3M EYW-MCO JUN 1.7>1.1[2]
3M EYW-TPA JUN 3>1.6[3]
3M FLL-FPO JUN 0.9>0.6[3]
3M FLL-GGT JUN 1.4>0.9[1.7]
3M FLL-GHB JUN 0.6>0.4[0.8]
3M FLL-MCO JUN 1.8>1.3[2]
3M FLL-MHH JUN 0.7>0.5[4]
3M FLL-PNS JUN 0.9>0.5[1.0]
3M FLL-TLH JUN 1.3>0.9[1.4]
3M FLL-TPA JUN 1.8>1.3[2]
3M MCO-PNS JUN 1.5>1.1[1.7]
3M NAS-TPA JUN 0.9>0.5[1.0]
3M PNS-TPA JUN 1.5>0.9[1.7]
3M TLH-TPA JUN 1.4>1.1[1.5]
4B CVN-DFW JUN 3>0[3] JUL 3>0[3] AUG 3>0[3]
4B MSP-TVF JUN 3>0[3] JUL 3>0[3] AUG 3>0[3]
4M EZE-MIA JUN 1.0>0[1.1]
8E ABL-OTZ JUN 0.4>0.9[0.9] JUL 0.4>0.8[0.9] AUG 0.4>0.8[0.9] SEP 0.4>0.9[0.9] OCT 0.4>0.9[0.9] NOV 0.4>0.8[0.9] DEC 0.4>0.8[0.9] JAN 0.4>0.8[0.9] FEB 0.4>0.9[0.9]
8E ABL-SHG JUN 0.4>0.9[0.5] JUL 0.4>0.8[0.5] AUG 0.4>0.8[0.5] SEP 0.4>0.9[0.5] OCT 0.4>0.9[0.5] NOV 0.4>0.8[0.5] DEC 0.4>0.8[0.5] JAN 0.4>0.8[0.5] FEB 0.4>0.9[0.5]
8E BKC-DRG JUN 0.4>0.9[0.9] JUL 0.4>0.8[0.9] AUG 0.4>0.8[0.9] SEP 0.4>0.9[0.9] OCT 0.4>0.9[0.9] NOV 0.4>0.8[0.9] DEC 0.4>0.8[0.9] JAN 0.4>0.8[0.9] FEB 0.4>0.9[0.9]
8E BKC-OTZ JUN 0.4>0.9[0.9] JUL 0.4>0.8[0.9] AUG 0.4>0.8[0.9] SEP 0.4>0.9[0.9] OCT 0.4>0.9[0.9] NOV 0.4>0.8[0.9] DEC 0.4>0.8[0.9] JAN 0.4>0.8[0.9] FEB 0.4>0.9[0.9]
8E DRG-OTZ JUN 0.4>0.9[0.9] JUL 0.4>0.8[0.9] AUG 0.4>0.8[0.9] SEP 0.4>0.9[0.9] OCT 0.4>0.9[0.9] NOV 0.4>0.8[0.9] DEC 0.4>0.8[0.9] JAN 0.4>0.8[0.9] FEB 0.4>0.9[0.9]
8E ELI-GLV JUN 0.4>0.9[0.9] JUL 0.4>0.8[0.9] AUG 0.4>0.8[0.9] SEP 0.4>0.9[0.9] OCT 0.4>0.9[0.9] NOV 0.4>0.8[0.9] DEC 0.4>0.8[0.9] JAN 0.4>0.8[0.9] FEB 0.4>0.9[0.9]
8E ELI-OME JUN 0.4>0.9[0.9] JUL 0.4>0.8[0.9] AUG 0.4>0.8[0.9] SEP 0.4>0.9[0.9] OCT 0.4>0.9[0.9] NOV 0.4>0.8[0.9] DEC 0.4>0.8[0.9] JAN 0.4>0.8[0.9] FEB 0.4>0.9[0.9]
8E GAM-OME JUN 0.9>1.3[1.6] JUL 0.8>1.3[1.7] AUG 0.8>1.3[1.6] SEP 0.9>1.3[1.6] OCT 0.9>1.3[1.7] NOV 0.8>1.2[1.6] DEC 0.8>1.2[1.6] JAN 0.8>1.2[1.7] FEB 0.9>1.3[1.6]
8E GAM-SVA JUN 0.9>1.3[0.9] JUL 0.8>1.3[0.9] AUG 0.8>1.3[0.9] SEP 0.9>1.3[0.9] OCT 0.9>1.3[0.9] NOV 0.8>1.2[0.9] DEC 0.8>1.2[0.9] JAN 0.8>1.2[0.9] FEB 0.9>1.3[0.9]
8E GLV-WMO JUN 0.4>0.9[0.9] JUL 0.4>0.8[0.9] AUG 0.4>0.8[0.9] SEP 0.4>0.9[0.9] OCT 0.4>0.9[0.9] NOV 0.4>0.8[0.9] DEC 0.4>0.8[0.9] JAN 0.4>0.8[0.9] FEB 0.4>0.9[0.9]
8E IAN-ORV JUN 0.4>0.9[0.9] JUL 0.4>0.8[0.9] AUG 0.4>0.8[0.9] SEP 0.4>0.9[0.9] OCT 0.4>0.9[0.9] NOV 0.4>0.8[0.9] DEC 0.4>0.8[0.9] JAN 0.4>0.8[0.9] FEB 0.4>0.9[0.9]
8E IAN-OTZ JUN 0.4>0.9[0.9] JUL 0.4>0.8[0.9] AUG 0.4>0.8[0.9] SEP 0.4>0.9[0.9] OCT 0.4>0.9[0.9] NOV 0.4>0.8[0.9] DEC 0.4>0.8[0.9] JAN 0.4>0.8[0.9] FEB 0.4>0.9[0.9]
8E KKA-OME JUN 0.4>0.9[0.9] JUL 0.4>0.8[0.9] AUG 0.4>0.8[0.9] SEP 0.4>0.9[0.9] OCT 0.4>0.9[0.9] NOV 0.4>0.8[0.9] DEC 0.4>0.8[0.9] JAN 0.4>0.8[0.9] FEB 0.4>0.9[0.9]
8E KKA-SKK JUN 0.4>0.9[0.9] JUL 0.4>0.8[0.9] AUG 0.4>0.8[0.9] SEP 0.4>0.9[0.9] OCT 0.4>0.9[0.9] NOV 0.4>0.8[0.9] DEC 0.4>0.8[0.9] JAN 0.4>0.8[0.9] FEB 0.4>0.9[0.9]
8E KTS-TLA JUN 0.4>0.9[0.9] JUL 0.4>0.8[0.9] AUG 0.4>0.8[0.9] SEP 0.4>0.9[0.9] OCT 0.4>0.9[0.9] NOV 0.4>0.8[0.9] DEC 0.4>0.8[0.9] JAN 0.4>0.8[0.9] FEB 0.4>0.9[0.9]
8E KVL-OTZ JUN 0.9>0.4[0.9] JUL 0.8>0.4[0.9] AUG 0.8>0.4[0.9] SEP 0.9>0.4[0.9] OCT 0.9>0.4[0.9] NOV 0.8>0.4[0.9] DEC 0.8>0.4[0.9] JAN 0.8>0.4[0.9] FEB 0.9>0.4[0.9]
8E KVL-PHO JUN 0.9>0.4[0.4] JUL 0.8>0.4[0.4] AUG 0.8>0.4[0.4] SEP 0.9>0.4[0.4] OCT 0.9>0.4[0.4] NOV 0.8>0.4[0.4] DEC 0.8>0.4[0.4] JAN 0.8>0.4[0.4] FEB 0.9>0.4[0.4]
8E OBU-OTZ JUN 0.4>0.9[0.5] JUL 0.4>0.8[0.5] AUG 0.4>0.8[0.5] SEP 0.4>0.9[0.5] OCT 0.4>0.9[0.5] NOV 0.4>0.8[0.5] DEC 0.4>0.8[0.5] JAN 0.4>0.8[0.5] FEB 0.4>0.9[0.5]
8E OBU-SHG JUN 0.4>0.9[0.9] JUL 0.4>0.8[0.9] AUG 0.4>0.8[0.9] SEP 0.4>0.9[0.9] OCT 0.4>0.9[0.9] NOV 0.4>0.8[0.9] DEC 0.4>0.8[0.9] JAN 0.4>0.8[0.9] FEB 0.4>0.9[0.9]
8E OME-SHH JUN 0.4>0.9[1.0] JUL 0.4>0.8[1.0] AUG 0.4>0.8[1.0] SEP 0.4>0.9[1.0] OCT 0.4>0.9[1.0] NOV 0.4>0.8[1.0] DEC 0.4>0.8[1.0] JAN 0.4>0.8[1.0] FEB 0.4>0.9[1.0]
8E OME-SVA JUN 0.9>1.3[1.6] JUL 0.8>1.3[1.7] AUG 0.8>1.3[1.6] SEP 0.9>1.3[1.6] OCT 0.9>1.3[1.7] NOV 0.8>1.2[1.6] DEC 0.8>1.2[1.6] JAN 0.8>1.2[1.7] FEB 0.9>1.3[1.6]
8E OME-TLA JUN 0.4>0.9[0.9] JUL 0.4>0.8[0.9] AUG 0.4>0.8[0.9] SEP 0.4>0.9[0.9] OCT 0.4>0.9[0.9] NOV 0.4>0.8[0.9] DEC 0.4>0.8[0.9] JAN 0.4>0.8[0.9] FEB 0.4>0.9[0.9]
8E OME-UNK JUN 0.4>0.9[0.9] JUL 0.4>0.8[0.9] AUG 0.4>0.8[0.9] SEP 0.4>0.9[0.9] OCT 0.4>0.9[0.9] NOV 0.4>0.8[0.9] DEC 0.4>0.8[0.9] JAN 0.4>0.8[0.9] FEB 0.4>0.9[0.9]
8E OME-WAA JUN 0.4>0.9[0.9] JUL 0.4>0.8[0.9] AUG 0.4>0.8[0.9] SEP 0.4>0.9[0.9] OCT 0.4>0.9[0.9] NOV 0.4>0.8[0.9] DEC 0.4>0.8[0.9] JAN 0.4>0.8[0.9] FEB 0.4>0.9[0.9]
8E OME-WMO JUN 0.4>0.9[0.9] JUL 0.4>0.8[0.9] AUG 0.4>0.8[0.9] SEP 0.4>0.9[0.9] OCT 0.4>0.9[0.9] NOV 0.4>0.8[0.9] DEC 0.4>0.8[0.9] JAN 0.4>0.8[0.9] FEB 0.4>0.9[0.9]
8E ORV-OTZ JUN 0.4>0.9[0.9] JUL 0.4>0.8[0.9] AUG 0.4>0.8[0.9] SEP 0.4>0.9[0.9] OCT 0.4>0.9[0.9] NOV 0.4>0.8[0.9] DEC 0.4>0.8[0.9] JAN 0.4>0.8[0.9] FEB 0.4>0.9[0.9]
8E OTZ-PHO JUN 0.9>1.3[1.3] JUL 0.8>1.3[1.3] AUG 0.8>1.3[1.3] SEP 0.9>1.3[1.3] OCT 0.9>1.3[1.3] NOV 0.8>1.2[1.3] DEC 0.8>1.2[1.3] JAN 0.8>1.2[1.3] FEB 0.9>1.3[1.3]
8E OTZ-WLK JUN 0.9>0[1.8] JUL 0.8>0[1.9] AUG 0.8>0[1.9] SEP 0.9>0[1.8] OCT 0.9>0[1.9] NOV 0.8>0[1.9] DEC 0.8>0[1.8] JAN 0.8>0[1.9] FEB 0.9>0[1.9]
8E SHH-WAA JUN 0.4>0[0] JUL 0.4>0[0] AUG 0.4>0[0] SEP 0.4>0[0] OCT 0.4>0[0] NOV 0.4>0[0] DEC 0.4>0[0] JAN 0.4>0[0] FEB 0.4>0[0]
8E SKK-UNK JUN 0.4>0.9[0.9] JUL 0.4>0.8[0.9] AUG 0.4>0.8[0.9] SEP 0.4>0.9[0.9] OCT 0.4>0.9[0.9] NOV 0.4>0.8[0.9] DEC 0.4>0.8[0.9] JAN 0.4>0.8[0.9] FEB 0.4>0.9[0.9]
8E SMK-UNK JUN 0.4>1.3[1.3] JUL 0.4>1.3[1.4] AUG 0.4>1.3[1.4] SEP 0.4>1.3[1.3] OCT 0.4>1.3[1.4] NOV 0.4>1.2[1.4] DEC 0.4>1.2[1.3] JAN 0.4>1.2[1.4] FEB 0.4>1.3[1.4]
8E SMK-WBB JUN 0.4>1.3[1.3] JUL 0.4>1.3[1.4] AUG 0.4>1.3[1.4] SEP 0.4>1.3[1.3] OCT 0.4>1.3[1.4] NOV 0.4>1.2[1.4] DEC 0.4>1.2[1.3] JAN 0.4>1.2[1.4] FEB 0.4>1.3[1.4]
9K HPN-LEB JUN 2>1.1[2]
AA ABQ-LAX JUL 2>1.6[3]
AA ALO-ORD JUN 1.5>0.9[2]
AA ART-PHL JUN 1.7>0.8[2]
AA ATH-ORD JUN 0.6>0[1.0]
*AA BZN-LAX JUL 0.8>0[0] AUG 1.0>0[0] SEP 0.3>0[0]
AA DEN-LAX JUL 2>0.8[3] AUG 3>2[3]
AA DFW-GCK JUN 2>1.0[2]
AA DFW-GRI JUN 2>1.0[3]
AA DFW-MAD JUN 1.0>0.6[1.8]
AA DUB-ORD JUN 0.7>0[1.0]
AA ELP-LAX JUL 2>0.8[3] AUG 3>1.9[3]
*AA FCA-LAX JUL 0.8>0[1.0] AUG 1.0>0[1.0] SEP 0.3>0[0.1]
AA IAH-LAX JUL 2>0.8[3] AUG 3>1.9[3]
*AA JAC-PHX JUL 0.8>0[1.0] AUG 1.0>0[0.6] SEP 0.3>0[0]
AA LAX-OKC JUL 1.6>0.8[2] AUG 2>1.5[2]
AA LAX-OMA JUL 1.6>0.8[2] AUG 2>1.5[2]
AA LAX-PDX JUL 2>0.8[3] AUG 3>1.8[3]
AA LAX-RNO JUL 3>1.6[4] AUG 4>3[4]
AA LAX-SAN JUL 4>1.8[5] AUG 5>4[5]
AA LAX-SAT JUL 1.6>0.7[3] AUG 2>1.8[3]
AA LAX-SEA JUL 3>2[5]
AA LAX-SFO JUL 6>5[8]
AA LAX-TUS JUL 2>1.7[3]
AA LAX-XNA JUL 1.5>0.7[2] AUG 1.9>1.4[2]
*AA MSN-PHX JUN 1.0>0.1[0] JUL 0.2>0[0]
AA OAK-PHX JUN 1.0>0.1[3] JUL 0.2>2[3] AUG 1.8>3[3]
*AA PDX-PHL JUL 0.8>0[1.0] AUG 0.5>0[0.6]
**AC ANC-YVR JUN 2>0[2] JUL 1.0>0[2] AUG 1.0>0[2] SEP 1.0>0[0.6]
AC ATL-YYZ JUN 5>0[5]
AC AUS-YYZ JUN 1.9>0[1.9]
AC BDL-YUL JUN 1.0>0[0.8]
AC BDL-YYZ JUN 3>0[3]
**AC BNA-YUL JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0] OCT 0.8>0[0]
AC BNA-YYZ JUN 2>0[3]
**AC BOS-YHZ JUN 2>0[1.8] JUL 2>0[2] AUG 2>0[2] SEP 2>1.5[1.9]
AC BOS-YOW JUN 1.7>0[1.5]
AC BOS-YUL JUN 5>1.3[5]
**AC BOS-YVR JUN 0.4>0[0.3] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0.8[0.5]
**AC BOS-YYC JUN 0.3>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 0.2>0[0]
AC BOS-YYZ JUN 7>2[7]
AC BWI-YUL JUN 2>0[1.9]
AC BWI-YYZ JUN 3>0[3]
AC CLE-YYZ JUN 4>0[4]
*AC CLT-YYZ JUN 2>0[2] JUL 2>0[2]
AC CMH-YYZ JUN 4>0[4]
AC CVG-YYZ JUN 3>0[3]
**AC DCA-YOW JUN 1.9>0[1.7] JUL 1.9>0[1.7] AUG 1.8>0[1.7] SEP 1.9>1.4[1.7]
AC DCA-YUL JUN 2>0.3[2]
AC DCA-YYZ JUN 4>1.3[4]
AC DEN-YUL JUN 1.9>0.3[2]
AC DEN-YVR JUN 3>0.3[2]
AC DEN-YYZ JUN 2>1.0[3]
AC DFW-YUL JUN 1.0>0[1.0]
AC DFW-YVR JUN 1.0>0[1.0]
AC DFW-YYZ JUN 4>0[4]
AC DTW-YYZ JUN 4>0[5]
AC EWR-YOW JUN 3>0[3]
AC EWR-YUL JUN 4>1.3[4]
AC EWR-YVR JUN 1.0>0.3[1.0]
AC EWR-YYC JUN 1.0>0[1.0]
AC EWR-YYZ JUN 7>2[7]
AC FLL-YUL JUN 1.8>0.4[2]
AC FLL-YYZ JUN 1.8>0.4[2]
AC HNL-YVR JUN 0.6>0[0.6]
AC IAD-YUL JUN 2>0[2]
AC IAD-YYZ JUN 3>1.0[3]
AC IAH-YUL JUN 2.0>0[2]
**AC IAH-YYC JUN 2>0[2] JUL 2>0[2] AUG 2>0[2] SEP 2>1.5[1.9]
AC IAH-YYZ JUN 3>1.0[3]
**AC IND-YYZ JUN 2>0[3] JUL 2>0[3] AUG 2>0[3] SEP 2>0[3] OCT 2>0[3] NOV 2>0[2] DEC 2>0[2.0] JAN 2>0[2] FEB 2>0[2]
AC LAS-YUL JUN 2>0[2]
AC LAS-YVR JUN 2>0[1.5]
AC LAS-YYC JUN 1.0>0[1.0]
AC LAS-YYZ JUN 2>0[2]
AC LAX-YUL JUN 3>0.3[3]
AC LAX-YVR JUN 5>1.0[6]
**AC LAX-YYC JUN 2>0[2] JUL 2>0[2] AUG 2>0[2] SEP 2>1.5[2]
AC LAX-YYZ JUN 5>1.3[5]
AC LGA-YUL JUN 8>2[8]
AC LGA-YYZ JUN 12>3[12]
AC MCI-YYZ JUN 1.0>0[1.0]
AC MCO-YUL JUN 3>0[3]
AC MCO-YYZ JUN 3>0.4[3]
AC MEM-YYZ JUN 1.0>0[1.0]
AC MIA-YUL JUN 1.1>0[1.0]
AC MIA-YYZ JUN 2.0>0[2]
AC MKE-YYZ JUN 1.9>0[1.7]
**AC MSP-YYZ JUN 3>0[3] JUL 3>0[3] AUG 3>0[3] SEP 3>2[4]
AC MSY-YYZ JUN 1.0>0[1.0]
AC OGG-YVR JUN 0.4>0[0.4]
AC ORD-YUL JUN 5>2[5]
AC ORD-YVR JUN 2>0.3[1.9]
AC ORD-YYZ JUN 8>2[8]
AC PDX-YVR JUN 4>0.6[4]
AC PDX-YYC JUN 1.0>0[1.0]
**AC PDX-YYZ JUL 1.0>0[1.0] AUG 1.0>0[0.7] SEP 1.0>0[0.1] OCT 0.4>0[0]
**AC PHL-YUL JUN 3>0[1.8] JUL 3>0[1.9] AUG 3>0[1.9] SEP 3>2[1.8]
AC PHL-YYZ JUN 5>0[4]
AC PHX-YVR JUN 1.0>0[1.0]
AC PHX-YYC JUN 1.0>0[0]
**AC PHX-YYZ JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0.8[1.0]
*AC PIT-YUL JUN 1.0>0[1.0] JUL 1.0>0[1.0]
AC PIT-YYZ JUN 4>0[4] JUL 4>0[4]
**AC PVD-YYZ JUN 1.0>0[0.6] JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[0.9] OCT 0.4>0[0.1]
AC RDU-YUL JUN 1.0>0[0.9]
AC RDU-YYZ JUN 3>0[4]
AC RSW-YYZ JUN 0.5>0[0.4]
AC SAN-YVR JUN 3>0[3]
AC SAN-YYZ JUN 1.0>0[1.0]
**AC SAV-YYZ JUN 1.0>0[0.7] JUL 1.0>0[0.9] AUG 1.0>0[0.8] SEP 1.0>0[0.9] OCT 0.8>0[0.8] FEB 1.0>0[0]
**AC SEA-YUL JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0] OCT 1.0>0[0] NOV 1.0>0[0] DEC 1.0>0[0] JAN 1.0>0[0] FEB 1.0>0[0]
AC SEA-YVR JUN 6>2[6]
AC SEA-YYZ JUN 2.0>0[1.5]
AC SFO-YEG JUN 1.0>0[1.0]
AC SFO-YUL JUN 2>0.3[2]
AC SFO-YVR JUN 5>1.0[5]
AC SFO-YYC JUN 2>0[2]
AC SFO-YYZ JUN 4>1.3[5]
AC SJC-YVR JUN 3>0[3]
**AC SJC-YYZ JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0] OCT 1.0>0[0] NOV 1.0>0[0] DEC 1.0>0[0] JAN 1.0>0[0] FEB 1.0>0[0]
AC SMF-YVR JUN 1.0>0[1.0]
**AC SNA-YVR JUN 0.5>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0.8[0]
AC STL-YYZ JUN 2>0[3]
AC TPA-YYZ JUN 1.4>0[1.4]
AF ATL-CDG JUN 1.3>0.4[2]
AF BOS-CDG JUN 1.1>0[1.5]
AF CDG-DFW JUN 0.4>0[0.4]
AF CDG-DTW JUN 0.5>0[1.0]
AF CDG-IAD JUN 1.3>0[1.8]
AF CDG-IAH JUN 0.5>0[1.0]
AF CDG-JFK JUN 3>0.9[4]
AF CDG-LAX JUN 1.6>0.9[2]
AF CDG-MIA JUN 0.5>0[1.0]
AF CDG-MSP JUN 0.5>0[1.0]
AF CDG-SEA JUN 0.5>0[0.9]
AF CDG-SFO JUN 1.6>0[1.9]
AF JFK-ORY JUN 0.5>0[1.0]
AF LAX-PPT JUN 0.2>0[0.4]
AS ABQ-PDX JUN 1.0>0[1.0]
AS ABQ-SEA JUN 2>1.0[2]
*AS ADK-ANC JUN 0.3>0[0.3] JUL 0.3>0[0.3] AUG 0.3>0[0.3] SEP 0.3>0[0.3] OCT 0.3>0[0.3] NOV 0.3>0[0.3] DEC 0.3>0[0.3] JAN 0.3>0[0.3] FEB 0.3>0[0.3]
*AS ADK-CDB JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0] NOV 0>0.3[0] DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0]
AS ADQ-ANC JUN 1.9>1.0[1.8]
AS ALW-SEA JUN 2>1.0[3]
AS ANC-BET JUN 2>0.7[2]
AS ANC-BRW JUN 0.5>0.7[0.5]
*AS ANC-CDB JUN 0>0.3[0] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0] NOV 0>0.3[0] DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0]
AS ANC-FAI JUN 5>3[6]
AS ANC-HNL JUN 1.0>0[1.0]
AS ANC-JNU JUN 4>2[4]
AS ANC-LAX JUN 1.8>1.0[1.8]
AS ANC-OME JUN 1.5>1.0[1.5]
AS ANC-ORD JUN 1.3>0[1.5]
AS ANC-OTZ JUN 1.5>1.0[1.5]
AS ANC-PDX JUN 4>0[4]
AS ANC-SEA JUN 20>10[20] JUL 21>12[21] AUG 20>12[20] SEP 18>12[17]
AS ATL-SEA JUN 3>2[2]
AS AUS-PDX JUN 1.4>1.0[1.0]
AS AUS-SAN JUN 2>1.0[1.0]
AS AUS-SFO JUN 1.9>1.0[1.8]
AS AUS-SJC JUN 2>1.0[1.8]
AS BIL-PDX JUN 1.0>0[1.0]
AS BIL-SEA JUN 2>1.0[2]
AS BLI-SEA JUN 4>1.0[5]
AS BNA-SEA JUN 2>1.0[2]
AS BOI-GEG JUN 3>0[2]
AS BOI-LAX JUN 2>1.0[0]
AS BOI-PDX JUN 9>2[8]
AS BOI-SAN JUN 2>1.0[1.0]
AS BOI-SEA JUN 11>4[9]
AS BOI-SJC JUN 2>1.0[1.0]
AS BOI-SMF JUN 1.0>0[1.0]
AS BOS-LAX JUN 1.0>0[1.8]
AS BOS-PDX JUN 2>0[2]
AS BOS-SAN JUN 2>1.0[1.0]
AS BOS-SEA JUN 4>2[3]
AS BOS-SFO JUN 1.9>1.0[2.0]
AS BRW-FAI JUN 0.5>0[0.5]
AS BRW-SCC JUN 1.0>0[1.0]
AS BUR-PDX JUN 2>1.0[3]
AS BUR-SEA JUN 4>3[5]
AS BWI-LAX JUN 1.0>0[1.0]
AS BWI-PDX JUN 1.0>0[0.8]
AS BWI-SAN JUN 1.0>0[1.0]
AS BWI-SEA JUN 2>1.0[1.8]
AS BWI-SFO JUN 1.0>0[1.0]
AS BZN-PDX JUN 1.4>0[1.6]
AS BZN-SEA JUN 4>3[3]
AS CMH-SEA JUN 1.4>1.0[1.0]
AS DAL-LAX JUN 3>0[3]
AS DAL-PDX JUN 3>0[2.0]
AS DAL-SEA JUN 4>2[2]
AS DAL-SFO JUN 3>1.0[3]
AS DCA-PDX JUN 1.0>0[1.0]
AS DEN-SEA JUN 6>3[6]
AS DFW-SEA JUN 3>2[4]
AS DTW-SEA JUN 2>1.0[1.8]
AS EAT-SEA JUN 3>1.0[4]
AS EUG-PDX JUN 2>0[3]
AS EUG-SEA JUN 5>2[4]
AS EWR-LAX JUN 3>2[3]
AS EWR-SEA JUN 3>2[3]
AS EWR-SFO JUN 3>2[3]
AS EWR-SJC JUN 0.9>0[0.8]
AS FAI-SCC JUN 0.4>0.1[0.3]
AS FAI-SEA JUN 5>2[5]
AS FAT-PDX JUN 2>0[2]
AS FAT-SAN JUN 4>1.0[3]
AS FAT-SEA JUN 3>1.0[3]
AS FCA-PDX JUN 1.0>0[0.8]
AS FCA-SEA JUN 3>1.0[3]
AS GDL-SJC JUN 1.0>0[1.0]
AS GEG-LAX JUN 2>1.0[0]
AS GEG-PAE JUN 1.0>0[0]
AS GEG-PDX JUN 8>2[9]
*AS GEG-SEA JUN 14>6[14] JUL 14>6[14] AUG 14>6[16] SEP 16>6[17]
AS GEG-SFO JUN 2>1.0[0]
AS GTF-SEA JUN 2>1.0[2.0]
AS HLN-SEA JUN 2>1.0[1.0]
AS HNL-LAX JUN 1.0>0[1.0]
AS HNL-OAK JUN 0.4>0[0.7]
AS HNL-PDX JUN 1.0>0.6[1.2]
AS HNL-SEA JUN 3>2[3]
AS HNL-SFO JUN 1.0>0[1.0]
AS IAD-LAX JUN 2>0[2.0]
AS IAD-SEA JUN 3>2[1.8]
AS IAD-SFO JUN 2>1.0[2.0]
AS IAH-SEA JUN 2>1.0[2]
AS IND-SEA JUN 2>1.0[1.0]
AS JFK-LAX JUN 5>2[5]
AS JFK-SEA JUN 3>2[3]
AS JFK-SFO JUN 4>2[4]
AS JNU-KTN JUN 1.0>0.5[0.8]
AS JNU-SEA JUN 6>3[5]
AS KOA-OAK JUN 0.4>0[1.0]
AS KOA-PDX JUN 0.6>0[0.2]
AS KOA-SAN JUN 1.0>0[0.9]
AS KOA-SEA JUN 2>1.0[2]
AS KOA-SJC JUN 1.0>0[0.9]
AS KTN-SEA JUN 4>1.5[5]
AS KTN-SIT JUN 1.0>0[1.0]
AS LAS-LAX JUN 2>0[4]
AS LAS-PAE JUN 2>0[2]
AS LAS-PDX JUN 4>2[4]
AS LAS-SEA JUN 8>3[8]
AS LAS-SFO JUN 4>3[6]
AS LAX-LIR JUN 1.0>0.6[1.0]
AS LAX-LTO JUN 0.4>0.1[0.6]
AS LAX-MSO JUN 1.0>0[0]
AS LAX-MZT JUN 0.7>0.4[0.6]
AS LAX-OGG JUN 1.0>0[1.0]
AS LAX-ORD JUN 1.0>0[1.0]
AS LAX-PAE JUN 2>0[4]
AS LAX-PDX JUN 7>4[8]
AS LAX-SEA JUN 13>7[14]
AS LAX-SFO JUN 14>8[11]
AS LAX-SJC JUN 7>4[4]
AS LAX-SJD JUN 3>2[1.9]
AS LAX-STS JUN 3>1.0[3]
AS LAX-ZIH JUN 0.4>0.1[0.5]
AS LIH-OAK JUN 0.6>0[0.4]
AS LIH-PDX JUN 0.4>0[0.2]
AS LIH-SAN JUN 1.0>0[0.9]
AS LIH-SEA JUN 2>1.0[1.6]
AS LIH-SJC JUN 1.0>0[1.0]
AS MCI-PDX JUN 1.0>0[1.0]
AS MCI-SEA JUN 3>2[2]
AS MCO-PDX JUN 1.0>0[1.0]
AS MCO-SAN JUN 1.0>0[0.7]
AS MCO-SFO JUN 1.0>0[1.0]
AS MFR-PDX JUN 6>2[6]
AS MFR-SEA JUN 4>2[4]
AS MKE-SEA JUN 2>1.0[1.0]
AS MSO-PDX JUN 2>0[1.0]
AS MSO-SEA JUN 4>2[4]
AS MSP-PDX JUN 1.0>0[1.0]
AS MSP-SEA JUN 3>2[3]
AS MSY-SEA JUN 1.6>1.0[1.2]
AS OAK-OGG JUN 0.6>0[1.0]
AS OAK-PDX JUN 3>0[3]
AS OGG-PDX JUN 2>0.4[2]
AS OGG-SAN JUN 2>0.7[1.0]
AS OGG-SEA JUN 3>1.0[2]
AS OGG-SFO JUN 1.0>0[1.0]
AS OGG-SJC JUN 1.0>0.4[1.0]
AS OMA-PDX JUN 1.0>0[1.0]
AS OME-OTZ JUN 0.5>0[0.5]
AS ONT-PDX JUN 2>1.0[2]
AS ORD-PDX JUN 2>1.0[1.5]
AS ORD-SEA JUN 6>4[5]
AS ORD-SFO JUN 1.9>1.0[2]
AS PAE-PDX JUN 3>0[4]
AS PAE-PHX JUN 2>1.0[1.0]
AS PAE-SAN JUN 2>0[2]
AS PAE-SFO JUN 2>0[2]
AS PAE-SJC JUN 2>0[2]
AS PAE-SNA JUN 2>0[1.0]
AS PDX-PHX JUN 2>1.0[2.0]
AS PDX-RDM JUN 4>1.0[5]
AS PDX-RNO JUN 4>0[4]
AS PDX-SAN JUN 4>3[4]
AS PDX-SBA JUN 1.0>0[1.0]
*AS PDX-SEA JUN 17>10[18] JUL 17>12[18] AUG 17>12[21] SEP 18>12[22]
AS PDX-SFO JUN 8>5[8]
AS PDX-SJC JUN 5>3[5]
AS PDX-SLC JUN 4>1.0[3]
AS PDX-SMF JUN 4>1.0[4]
AS PDX-SNA JUN 4>3[4]
AS PDX-STS JUN 2>0[1.8]
AS PDX-YVR JUN 2>0[1.8]
AS PHL-SFO JUN 1.0>0[1.0]
AS PHX-SEA JUN 6>4[6]
AS PHX-SFO JUN 1.9>1.0[0]
AS PIT-SEA JUN 2>1.0[1.0]
AS PSC-SEA JUN 7>3[6]
AS PSP-SFO JUN 4>2[4]
AS PUW-SEA JUN 4>1.0[4]
AS PVR-SAN JUN 0.4>0.1[0.5]
AS PVR-SFO JUN 1.1>0.1[1.2]
AS PVR-SJC JUN 1.0>0.1[0]
AS RDM-SAN JUN 1.0>0[0]
AS RDM-SEA JUN 5>2[5]
AS RDU-SEA JUN 2>1.0[1.0]
AS RNO-SEA JUN 4>2[4]
AS SAN-SEA JUN 9>6[8]
AS SAN-SFO JUN 7>4[5]
AS SAN-SJC JUN 6>4[4]
AS SAN-SJD JUN 2>1.0[1.9]
AS SAN-SMF JUN 3>2[4]
AS SAN-STS JUN 2>1.0[1.0]
AS SAT-SEA JUN 2>1.0[1.0]
AS SBA-SEA JUN 2>1.0[1.0]
AS SEA-SFO JUN 13>7[12]
AS SEA-SIT JUN 1.5>0[1.4]
AS SEA-SJC JUN 9>5[8]
AS SEA-SLC JUN 5>3[5]
AS SEA-SMF JUN 6>4[6]
AS SEA-SNA JUN 8>6[8]
AS SEA-STL JUN 2>1.0[2]
AS SEA-STS JUN 3>1.0[1.0]
AS SEA-SUN JUN 1.0>0.1[0.8]
AS SEA-TPA JUN 2>1.0[1.1]
AS SEA-YEG JUN 2>1.0[2]
AS SEA-YKM JUN 3>1.0[4]
AS SEA-YLW JUN 2>1.0[2]
AS SEA-YVR JUN 7>3[6]
AS SEA-YYC JUN 3>1.0[3]
AS SEA-YYJ JUN 3>1.0[4]
AS SFO-SJD JUN 1.1>0[1.0]
AS SFO-SLC JUN 2>1.0[1.0]
AS SFO-SNA JUN 7>3[6]
AS SJC-SJD JUN 2>1.0[1.0]
AS SNA-STS JUN 2>0[1.0]
AZ BOS-FCO JUN 1.0>0[1.0]
AZ FCO-IAD JUN 0.7>0[0.7]
AZ FCO-JFK JUN 3>1.0[3]
AZ FCO-LAX JUN 1.0>0[1.0]
AZ FCO-MIA JUN 1.0>0[1.0]
AZ FCO-ORD JUN 1.0>0[1.0]
AZ FCO-SFO JUN 0.4>0[0]
AZ JFK-MXP JUN 1.0>0[1.0]
BA ATL-LHR JUN 1.0>0[1.0]
BA AUS-LHR JUN 1.0>0[1.0]
BA BNA-LHR JUN 1.0>0[1.0]
BA BOS-LHR JUN 4>1.0[4]
BA BWI-LHR JUN 1.0>0[1.0]
BA CHS-LHR JUN 0.3>0[0.3]
BA DEN-LHR JUN 1.0>0[1.0]
BA DFW-LHR JUN 1.0>0[1.0]
BA EWR-LHR JUN 2>0[2]
BA IAD-LHR JUN 2>1.0[2]
BA IAH-LHR JUN 2>0[2]
BA JFK-LGW JUN 1.0>0[1.0]
BA JFK-LHR JUN 8>2[8]
BA LAS-LGW JUN 0.9>0[0.8]
BA LAS-LHR JUN 1.0>0[1.0]
BA LAX-LHR JUN 3>1.0[3]
BA LGW-MCO JUN 1.4>0[1.9]
BA LGW-TPA JUN 1.0>0[1.0]
BA LHR-MIA JUN 2>0[3]
BA LHR-ORD JUN 2>1.0[2]
BA LHR-PHL JUN 1.4>0[1.4]
BA LHR-SEA JUN 2>0[2]
BA LHR-SFO JUN 2>1.0[2]
CI HNL-TPE JUN 0.4>0.2[0.4]
CX BOS-HKG JUN 0.3>0[1.0]
CX EWR-HKG JUN 0.3>0[1.0]
CX HKG-JFK JUN 1.0>0.0[3]
CX HKG-ORD JUN 0.3>0[1.0]
CX HKG-SEA JUN 0.2>0[0.6]
D7 HNL-KIX JUN 1.0>0[1.0]
DI AUS-LGW JUN 0.4>0.2[0.4]
DI BOS-LGW JUN 1.0>0.5[1.0]
DI DEN-LGW JUN 0.4>0.2[0.4]
DI JFK-LGW JUN 3>1.4[2]
DI LAX-LGW JUN 1.3>0.7[1.0]
DI LGW-MCO JUN 0.7>0.4[0.9]
DI LGW-MIA JUN 0.9>0.5[1.0]
DI LGW-ORD JUN 0.6>0.3[0.6]
DI LGW-SEA JUN 0.6>0.3[0.6]
DI LGW-SFO JUN 0.9>0.5[0.7]
DI LGW-TPA JUN 0.4>0.2[0.3]
DL ABE-ATL JUN 3>0[3]
DL ABE-DTW JUN 3>1.0[3]
DL ABQ-ATL JUN 2>0[3]
DL ABQ-LAX JUN 3>0.0[1.7]
DL ABQ-MSP JUN 1.0>0[1.0]
DL ABQ-SLC JUN 3>1.0[3]
DL ABR-MSP JUN 2>1.0[2]
DL ABY-ATL JUN 3>1.0[3]
DL AEX-ATL JUN 4>1.0[4]
DL AGS-ATL JUN 7>2[8]
DL ALB-ATL JUN 4>0[4]
DL ALB-DTW JUN 4>2[4]
DL ALB-MSP JUN 1.0>0[1.0]
DL ANC-ATL JUN 1.0>0[1.0]
DL ANC-MSP JUN 2>0[3] AUG 2>3[3]
DL ANC-SEA JUN 6>3[5]
DL ANC-SLC JUN 0.8>0[0.6]
DL APN-PLN JUN 0.7>0[0.7]
DL ASE-SLC JUN 2.0>1.0[2]
DL ATL-ATW JUN 1.9>0[2]
DL ATL-AUA JUN 1.1>0.3[1.2]
DL ATL-AUS JUN 8>2[8]
DL ATL-AVL JUN 7>1.0[8]
DL ATL-AVP JUN 1.0>0[1.0]
DL ATL-BDA JUN 1.0>0.3[1.0]
DL ATL-BDL JUN 7>2[7]
DL ATL-BHM JUN 10>3[10]
DL ATL-BMI JUN 3>1.0[3]
DL ATL-BNA JUN 10>3[10]
DL ATL-BOS JUN 12>3[12]
DL ATL-BQK JUN 3>1.0[3]
DL ATL-BTR JUN 6>1.0[7]
DL ATL-BTV JUN 1.0>0[1.8]
DL ATL-BUF JUN 5>1.0[5]
It looks like BUR/CAK/HPN/LGB/MDW/MHT/OAK/PVD/SWF are suspended until SEP
*DL ATL-BUR JUN 1.7>0[0] JUL 1.9>0[1.5] AUG 1.9>0[1.9]
DL ATL-BWI JUN 11>3[11]
DL ATL-BZE JUN 1.1>0[1.1]
DL ATL-CAE JUN 8>2[8]
*DL ATL-CAK JUN 3>0[3] JUL 3>0[3] AUG 3>0[3]
DL ATL-CHA JUN 9>3[10]
DL ATL-CHO JUN 5>1.0[5]
DL ATL-CHS JUN 10>3[10]
DL ATL-CID JUN 3>0[3]
DL ATL-CLE JUN 8>3[8]
DL ATL-CMH JUN 8>2.0[9]
DL ATL-COS JUN 1.0>0[0.9]
DL ATL-CRW JUN 4>1.0[5]
DL ATL-CSG JUN 4>1.0[4]
DL ATL-CUN JUN 6>0.7[6]
DL ATL-CVG JUN 7>3[8]
DL ATL-DAB JUN 6>1.0[5]
DL ATL-DAL JUN 4>1.0[5]
DL ATL-DAY JUN 4>0[4]
DL ATL-DCA JUN 11>3[11]
DL ATL-DEN JUN 9>3[8]
DL ATL-DFW JUN 8>3[10]
DL ATL-DHN JUN 4>1.0[4]
DL ATL-DSM JUN 3>0[3]
DL ATL-DTW JUN 11>4[12]
DL ATL-ECP JUN 6>2[6]
DL ATL-ELH JUN 1.1>0[0.9]
DL ATL-ELP JUN 3>1.0[3]
DL ATL-EVV JUN 4>1.0[4]
DL ATL-EWN JUN 2.0>1.0[2]
DL ATL-EWR JUN 10>3[12]
DL ATL-EYW JUN 4>1.0[5]
*DL ATL-EZE JUL 1.0>0[1.0] AUG 1.0>0[1.0]
DL ATL-FAY JUN 5>2[5]
DL ATL-FLL JUN 13>4[13]
DL ATL-FNT JUN 3>1.0[3]
DL ATL-FSD JUN 1.0>0[1.0]
DL ATL-FSM JUN 1.7>1.0[1.9]
DL ATL-FWA JUN 4>0[4]
DL ATL-GCM JUN 1.1>0.3[1.2]
DL ATL-GDL JUN 1.0>0[0.9]
DL ATL-GGT JUN 1.1>0[1.0]
DL ATL-GNV JUN 6>2[7]
DL ATL-GPT JUN 4>2.0[5]
DL ATL-GRB JUN 1.7>0[1.8]
DL ATL-GRR JUN 5>0[5]
DL ATL-GSO JUN 8>2[8]
DL ATL-GSP JUN 9>3[8]
DL ATL-GTR JUN 3>1.0[4]
DL ATL-GUA JUN 1.9>0.4[2]
DL ATL-HAV JUN 1.0>0[1.0]
DL ATL-HHH JUN 3>1.0[3]
DL ATL-HOU JUN 6>2[6]
*DL ATL-HPN JUN 6>0[6] JUL 6>0[6] AUG 6>0[7]
DL ATL-HSV JUN 7>2[7]
DL ATL-IAD JUN 7>3[7]
DL ATL-IAH JUN 7>3[8]
DL ATL-ICN JUN 1.0>0[1.0]
DL ATL-ICT JUN 3>1.0[3]
DL ATL-ILM JUN 6>2[6]
DL ATL-IND JUN 9>3[9]
DL ATL-JAC JUN 0.4>0[0.4]
DL ATL-JAN JUN 7>2.0[7]
DL ATL-JAX JUN 11>4[13]
DL ATL-JFK JUN 7>3[8]
DL ATL-KIN JUN 1.0>0.4[1.0]
DL ATL-LAS JUN 7>2.0[8]
DL ATL-LAX JUN 12>5[12]
DL ATL-LEX JUN 7>2[8]
DL ATL-LFT JUN 4>1.0[5]
DL ATL-LGA JUN 15>5[16]
DL ATL-LIR JUN 1.1>0.3[1.1]
DL ATL-LIT JUN 7>2[7]
DL ATL-LNK JUN 1.0>0[0.8]
DL ATL-MBJ JUN 3>0.4[3]
DL ATL-MCI JUN 8>2.0[9]
DL ATL-MCO JUN 16>4[17]
DL ATL-MDT JUN 3>0[3]
*DL ATL-MDW JUN 7>0[6] JUL 7>0[6] AUG 7>0[7]
DL ATL-MEM JUN 10>3[10]
DL ATL-MEX JUN 5>1.1[5]
DL ATL-MGM JUN 6>1.0[6]
*DL ATL-MHT JUN 1.0>0[1.0] JUL 1.0>0[0.9] AUG 1.0>0[1.0]
DL ATL-MIA JUN 10>4[12]
DL ATL-MKE JUN 7>2[7]
DL ATL-MLB JUN 4>1.0[4]
DL ATL-MLI JUN 3>1.0[3]
DL ATL-MLU JUN 3>1.0[4]
DL ATL-MOB JUN 6>1.0[7]
DL ATL-MSN JUN 3>0[4]
DL ATL-MSP JUN 10>5[11]
DL ATL-MSY JUN 10>3[10]
DL ATL-MTY JUN 1.6>0[2]
DL ATL-MYR JUN 5>1.0[4]
DL ATL-NAS JUN 4>0.5[4]
DL ATL-OAJ JUN 4>2[4]
*DL ATL-OAK JUN 0.8>0[0.6] JUL 0.8>0[0.8] AUG 0.9>0[0.6]
DL ATL-OKC JUN 6>1.0[6]
DL ATL-OMA JUN 6>1.0[5]
DL ATL-ONT JUN 2>0[1.3]
DL ATL-ORD JUN 11>4[11]
DL ATL-ORF JUN 9>2[9]
DL ATL-PBI JUN 10>4[11]
DL ATL-PDX JUN 5>1.0[4]
*DL ATL-PHF JUN 3>0[3] JUL 3>0[3] AUG 3>0[3]
DL ATL-PHL JUN 9>3[10]
DL ATL-PHX JUN 6>2.0[6]
DL ATL-PIA JUN 2>1.0[3]
DL ATL-PIT JUN 8>3[8]
DL ATL-PLS JUN 1.1>0.4[1.3]
DL ATL-PNS JUN 9>3[9]
DL ATL-PTY JUN 1.0>0.3[1.0]
DL ATL-PUJ JUN 1.9>0.3[3]
This one is surprising
*DL ATL-PVD JUN 3>0[3] JUL 3>0[3] AUG 3>0[3]
*DL ATL-PVG JUN 1.0>0[1.0] JUL 1.0>0.0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[0.9] OCT 1.0>0.2[0.9]
DL ATL-PVR JUN 0.7>0[1.2]
DL ATL-PWM JUN 3>0[3]
DL ATL-RDU JUN 10>3[12]
DL ATL-RIC JUN 9>3[10]
DL ATL-ROA JUN 5>1.0[5]
DL ATL-ROC JUN 3>0[3]
DL ATL-RST JUN 1.7>0[1.8]
DL ATL-RSW JUN 8>3[8]
DL ATL-SAL JUN 1.0>0.4[1.0]
DL ATL-SAN JUN 5>1.0[6]
DL ATL-SAP JUN 1.0>0.4[1.0]
DL ATL-SAT JUN 7>2.0[7]
DL ATL-SAV JUN 10>2[10]
DL ATL-SBN JUN 4>0[4]
DL ATL-SDF JUN 9>2[8]
DL ATL-SDQ JUN 1.0>0[1.0]
DL ATL-SEA JUN 8>4[8]
DL ATL-SFO JUN 8>2[8]
DL ATL-SGF JUN 5>1.0[5]
DL ATL-SHV JUN 6>2[6]
DL ATL-SJC JUN 3>0[3]
DL ATL-SJD JUN 1.1>0[1.2]
DL ATL-SJO JUN 2>0.4[2]
DL ATL-SJU JUN 3.8>0.7[3.8]
DL ATL-SLC JUN 7>5[9]
DL ATL-SMF JUN 3>1.0[3]
DL ATL-SNA JUN 3>0[3]
DL ATL-SRQ JUN 7>2[7]
DL ATL-STL JUN 7>2[8]
DL ATL-STT JUN 1.9>0.4[1.8]
DL ATL-SXM JUN 1.1>0.3[1.0]
DL ATL-SYR JUN 3>0[3]
DL ATL-TGU JUN 1.0>0[1.0]
DL ATL-TLH JUN 6>2[7]
DL ATL-TPA JUN 12>4[13]
DL ATL-TRI JUN 6>1.0[6]
DL ATL-TUL JUN 5>1.0[5]
DL ATL-TUS JUN 1.8>0[1.9]
DL ATL-TYS JUN 8>2[8]
DL ATL-UIO JUN 1.0>0.3[1.0]
DL ATL-UVF JUN 1.1>0.3[1.2]
DL ATL-VLD JUN 3>1.0[3]
DL ATL-VPS JUN 7>2[7]
DL ATL-XNA JUN 5>1.0[6]
DL ATL-YUL JUN 5>0[5]
DL ATL-YVR JUN 1.0>0[1.0]
DL ATL-YYZ JUN 6>0[6]
DL ATW-DTW JUN 4>1.0[4]
DL ATW-MSP JUN 4>1.0[4]
DL AUA-JFK JUN 1.0>0[1.0]
DL AUS-BOS JUN 1.8>0[0.8] DEC 1.9>1.1[0.6]
DL AUS-CVG JUN 0.8>0[0.8]
DL AUS-DTW JUN 4>1.0[3]
DL AUS-JFK JUN 3>0[3]
DL AUS-LAX JUN 3>0[3]
DL AUS-MSP JUN 3>1.0[3]
DL AUS-RDU JUN 0.9>0[0.8]
DL AUS-SEA JUN 1.9>0[1.0]
DL AUS-SLC JUN 3>1.0[3]
DL AVP-DTW JUN 3>1.0[3]
DL AZO-DTW JUN 5>1.0[1.8]
DL AZO-MSP JUN 1.6>0[0.6]
DL BDA-BOS JUN 1.0>0[1.0]
DL BDA-JFK JUN 1.0>0[1.0]
DL BDL-CLE JUN 0.8>0[0.8]
DL BDL-CVG JUN 0.9>0[0.8]
DL BDL-DTW JUN 5>2[4]
DL BDL-MSP JUN 4>1.0[4]
DL BDL-RDU JUN 0.9>0[0.9]
DL BGM-DTW JUN 3>1.0[3]
DL BGR-DTW JUN 0>1.0[0.1]
DL BGR-LGA JUN 4>0[4]
DL BHM-DTW JUN 3>0[3]
DL BHM-LGA JUN 3>0[2]
DL BIL-MSP JUN 4>0[3]
DL BIL-SLC JUN 4>2[4]
DL BIS-MSP JUN 6>2[6]
DL BJI-MSP JUN 2>1.0[2]
DL BNA-BOS JUN 4>0[4]
DL BNA-DTW JUN 5>1.0[5]
DL BNA-JFK JUN 3>0[3]
DL BNA-LAX JUN 1.7>0[1.8]
DL BNA-LGA JUN 5>1.0[5]
DL BNA-MSP JUN 3>1.0[5]
DL BNA-RDU JUN 1.7>0[1.8]
DL BNA-SEA JUN 1.0>0[1.0]
DL BNA-SLC JUN 0.8>0[1.2]
*DL BOG-JFK JUN 0.9>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0] OCT 1.0>0.2[0]
DL BOI-LAX JUN 1.8>0[1.6]
DL BOI-MSP JUN 1.4>0[3]
DL BOI-SEA JUN 7>3[5]
DL BOS-BUF JUN 3>0[2] DEC 3>1.7[1.7]
DL BOS-CHS JUN 1.0>0[1.2]
DL BOS-CLE JUN 3>0[3]
DL BOS-CMH JUN 3>0[3]
DL BOS-CVG JUN 4>0[3]
DL BOS-DCA JUN 5>0[0]
DL BOS-DTW JUN 6>3[6]
DL BOS-EWR JUN 4>0[0]
DL BOS-FLL JUN 1.0>0[1.0]
DL BOS-IND JUN 4>0[3]
DL BOS-JAX JUN 3>0[3]
DL BOS-JFK JUN 7>3[8]
DL BOS-LAS JUN 1.0>0[1.0]
DL BOS-LAX JUN 3>0[3]
*DL BOS-LGA JUN 13>3[13] DEC 13>10[11]
DL BOS-MCI JUN 3>0[1.7] DEC 3>2[2]
DL BOS-MCO JUN 3>0[3]
DL BOS-MIA JUN 1.9>0[0]
DL BOS-MKE JUN 1.8>0[1.8]
DL BOS-MSP JUN 6>2.0[6]
DL BOS-ORD JUN 4>0[0]
DL BOS-ORF JUN 1.0>0[1.0]
DL BOS-PHL JUN 5>0[5]
DL BOS-PIT JUN 4>0[4] DEC 5>4[4]
DL BOS-RDU JUN 5>0[6]
DL BOS-RIC JUN 3>0[3]
DL BOS-SEA JUN 4>0[3] DEC 4>3[1.3]
DL BOS-SFO JUN 1.7>0[1.7]
DL BOS-SLC JUN 3>1.0[3]
DL BOS-TPA JUN 3>0[3]
DL BRD-MSP JUN 1.7>1.0[1.7]
DL BTM-SLC JUN 1.9>1.0[1.8]
DL BTV-DTW JUN 4>1.0[3]
DL BTV-JFK JUN 3>0[3]
DL BTV-LGA JUN 1.9>0[2]
DL BUF-DTW JUN 5>2[5]
DL BUF-JFK JUN 5>0[5]
DL BUF-LGA JUN 3>0[3]
DL BUF-MSP JUN 1.0>0[1.7]
*DL BUR-SLC JUN 5>0[4] JUL 5>0[4] AUG 5>0[4]
DL BWI-CVG JUN 2>0[2]
DL BWI-DTW JUN 5>1.0[5]
DL BWI-JFK JUN 4>0[4] DEC 4>3[3]
DL BWI-MSP JUN 4>1.0[4]
DL BWI-RDU JUN 1.5>0[1.6]
DL BWI-SLC JUN 1.7>0[1.8]
DL BZN-MSP JUN 1.5>0[3]
DL BZN-SEA JUN 2>0[0.0]
DL BZN-SLC JUN 5>2.0[4]
DL CAE-LGA JUN 1.7>0[1.4]
DL CHA-DTW JUN 1.8>0[1.7]
DL CHA-LGA JUN 1.0>0[1.0]
DL CHO-LGA JUN 2>0[2]
DL CHS-DTW JUN 1.9>0[2]
DL CHS-JFK JUN 3>0[3]
DL CHS-LGA JUN 3>0[3]
DL CID-DTW JUN 4>0[4]
DL CID-MSP JUN 4>1.0[4]
DL CLE-DTW JUN 6>2[5]
DL CLE-JFK JUN 4>0[4]
DL CLE-LGA JUN 5>0[5]
DL CLE-MSP JUN 4>1.0[4]
DL CLE-RDU JUN 0.8>0[0.8]
DL CLE-SLC JUN 1.0>0[0.8]
DL CLT-CVG JUN 2>0[2]
DL CLT-DTW JUN 4>2.0[4]
DL CLT-JFK JUN 4>0[4]
DL CLT-LGA JUN 7>0[7]
DL CLT-MSP JUN 4>0[4]
DL CLT-SLC JUN 1.0>0[1.0]
DL CMH-DTW JUN 6>2[6]
DL CMH-JFK JUN 3>0[3]
DL CMH-LAX JUN 1.0>0[0.8]
DL CMH-LGA JUN 5>0[5]
DL CMH-MSP JUN 4>1.0[4]
DL CMH-RDU JUN 1.7>0[1.6]
DL CMH-SLC JUN 1.0>0[0.2]
*DL COD-SLC JUN 0>0.4[1.3] JUL 0>0.5[1.3] AUG 0>0.4[1.3] SEP 0>0.4[1.3]
DL COS-SLC JUN 3>2.0[3]
DL CPR-SLC JUN 2.0>0.7[2]
DL CUN-DTW JUN 1.3>0[1.3]
DL CUN-JFK JUN 1.9>0[2]
DL CUN-LAX JUN 1.1>0[1.1]
DL CUN-MSP JUN 0.5>0[0.5]
DL CUN-SLC JUN 1.0>0[1.0]
DL CVG-DCA JUN 3>0[3]
DL CVG-DEN JUN 1.0>0[1.0]
DL CVG-DFW JUN 2>0[2]
DL CVG-DTW JUN 5>2[5]
DL CVG-EWR JUN 2>0[2]
DL CVG-FLL JUN 1.0>0[1.1]
DL CVG-IAH JUN 1.5>0[1.5]
DL CVG-JFK JUN 1.0>0[1.0]
DL CVG-LAS JUN 1.0>0[1.0]
DL CVG-LAX JUN 1.7>0[1.8]
DL CVG-LGA JUN 5>1.0[5]
DL CVG-MCI JUN 1.5>0[1.5]
DL CVG-MCO JUN 2>0[3]
DL CVG-MSP JUN 5>2.0[5]
DL CVG-ORD JUN 3>0[3]
DL CVG-PHL JUN 2>0[2]
DL CVG-RDU JUN 1.6>0[1.8]
DL CVG-RSW JUN 1.0>0[1.0]
DL CVG-SEA JUN 1.0>0[0.9]
DL CVG-SFO JUN 0.9>0[0.9]
DL CVG-SLC JUN 1.9>1.0[1.9]
DL CVG-STL JUN 1.6>0[1.5]
DL CVG-TPA JUN 0.5>0[1.1]
DL CVG-YYZ JUN 1.6>0[1.5]
DL CWA-DTW JUN 1.7>0[1.8]
DL CWA-MSP JUN 3>1.0[3]
DL DAY-DTW JUN 4>2[4]
DL DAY-MSP JUN 3>0[3]
DL DCA-DTW JUN 6>2[6]
DL DCA-JFK JUN 5>0[5]
DL DCA-LAX JUN 1.0>0[1.0]
DL DCA-LEX JUN 0.8>0[0.8]
DL DCA-LGA JUN 8>1.9[10]
DL DCA-MSN JUN 0.8>0[0.8]
DL DCA-MSP JUN 6>2.0[6]
DL DCA-OMA JUN 0.8>0[0.8]
DL DCA-RDU JUN 3>0[3]
DL DCA-SLC JUN 1.0>0[1.0]
DL DEN-DTW JUN 4>1.0[4]
DL DEN-JFK JUN 3>0[3]
DL DEN-LAX JUN 4>2.0[4]
DL DEN-LGA JUN 1.9>0[2]
DL DEN-MSP JUN 6>1.0[6]
DL DEN-SEA JUN 4>1.0[4]
DL DEN-SLC JUN 6>3[7]
DL DFW-DTW JUN 5>1.0[5]
DL DFW-JFK JUN 3>0[3]
DL DFW-LAX JUN 4>1.0[4]
DL DFW-LGA JUN 6>1.0[6]
DL DFW-MSP JUN 5>2.0[6]
DL DFW-SLC JUN 4>2.0[5]
DL DLH-MSP JUN 6>1.0[6]
DL DSM-DTW JUN 4>1.0[4]
DL DSM-LGA JUN 1.7>0[1.7]
DL DSM-MSP JUN 5>2.0[5]
DL DSM-SLC JUN 1.0>0[1.0]
DL DTW-ELM JUN 5>2[5]
DL DTW-ERI JUN 3>1.0[3]
DL DTW-ESC JUN 1.7>1.0[1.7]
DL DTW-EVV JUN 3>1.0[3]
DL DTW-EWR JUN 5>1.0[6]
DL DTW-FLL JUN 4>2.0[4]
DL DTW-FWA JUN 3>1.0[3]
DL DTW-GRB JUN 4>1.0[4]
DL DTW-GRR JUN 6>2[6]
DL DTW-GSO JUN 3>0[3]
DL DTW-GSP JUN 3>0[3]
DL DTW-HND JUN 1.0>0[0]
*DL DTW-HPN JUN 3>0[4] JUL 3>0[3] AUG 4>0[4]
DL DTW-HSV JUN 1.0>0[1.0]
DL DTW-IAD JUN 4>2[4]
DL DTW-IAH JUN 5>1.0[5]
DL DTW-IND JUN 6>2[6]
DL DTW-ITH JUN 3>1.0[3]
DL DTW-JAX JUN 1.9>0[1.8]
DL DTW-JFK JUN 5>2.0[5]
DL DTW-LAN JUN 4>1.0[4]
DL DTW-LAS JUN 5>1.0[5]
DL DTW-LAX JUN 7>3[6]
DL DTW-LEX JUN 4>1.0[4]
DL DTW-LGA JUN 7>3[7]
DL DTW-LIT JUN 0.8>0[0.8]
DL DTW-LSE JUN 1.0>0[1.0]
DL DTW-MBS JUN 5>1.0[5]
DL DTW-MCI JUN 4>1.0[4]
DL DTW-MCO JUN 4>2.0[6]
DL DTW-MDT JUN 4>1.0[4]
*DL DTW-MDW JUN 4>0[4] JUL 4>0[4] AUG 4>0[4]
DL DTW-MEM JUN 3>0[3]
DL DTW-MEX JUN 0.9>0[1.0]
*DL DTW-MHT JUN 3>0[3] JUL 3>0[3] AUG 3>0[3]
DL DTW-MIA JUN 2.0>1.0[2]
DL DTW-MKE JUN 5>1.0[6]
DL DTW-MLI JUN 1.7>0[1.8]
DL DTW-MQT JUN 1.8>0.7[1.8]
DL DTW-MSN JUN 5>1.0[5]
DL DTW-MSP JUN 7>3[8]
DL DTW-MSY JUN 3>0[3]
DL DTW-MTY JUN 0.9>0[0.8]
DL DTW-MYR JUN 1.0>0[1.1]
DL DTW-OKC JUN 1.7>0[1.8]
DL DTW-OMA JUN 3>0[4]
DL DTW-ORD JUN 5>2[6]
DL DTW-ORF JUN 4>2[3]
DL DTW-PBI JUN 1.0>0[1.0]
DL DTW-PDX JUN 1.7>0[1.7]
DL DTW-PHL JUN 5>1.0[5]
DL DTW-PHX JUN 4>2.0[4]
DL DTW-PIT JUN 5>2.0[5]
*DL DTW-PKX JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0] OCT 1.0>0.2[0]
DL DTW-PLN JUN 4>1.1[3]
*DL DTW-PVD JUN 4>0[4] JUL 4>0[4] AUG 4>0[4]
DL DTW-PWM JUN 2>1.0[3]
DL DTW-RDU JUN 4>2[4]
DL DTW-RIC JUN 4>0[3]
DL DTW-ROC JUN 4>2[4]
DL DTW-SAN JUN 3>1.0[3]
DL DTW-SAT JUN 3>0.0[3]
DL DTW-SAV JUN 1.0>0[1.1]
DL DTW-SBN JUN 5>1.0[4]
DL DTW-SCE JUN 3>1.0[3]
DL DTW-SDF JUN 5>1.0[5]
DL DTW-SEA JUN 6>3[6]
DL DTW-SFO JUN 3>1.0[4]
DL DTW-SJC JUN 1.0>0[0.8]
DL DTW-SMF JUN 0.8>0[0.4]
DL DTW-SNA JUN 0.7>0[0.9]
DL DTW-STL JUN 4>1.0[5]
*DL DTW-SWF JUN 2.0>0[2] JUL 2>0[2] AUG 2>0[2]
DL DTW-SYR JUN 3>2[4]
DL DTW-TPA JUN 4>2.0[4]
DL DTW-TVC JUN 6>1.0[5]
DL DTW-TYS JUN 4>1.0[4]
DL DTW-YOW JUN 1.8>1.0[1.8]
DL DTW-YUL JUN 4>1.0[4]
DL DTW-YYZ JUN 5>2[5]
DL EKO-SLC JUN 1.8>0.7[1.8]
DL EUG-SEA JUN 3>2.0[3]
DL EUG-SLC JUN 2.0>1.0[2]
DL EWR-MSP JUN 5>1.0[5]
DL EWR-RDU JUN 3>0[3]
DL EWR-SLC JUN 1.3>0[1.5]
DL FAI-MSP JUN 1.0>0[1.0]
DL FAI-SEA JUN 2.0>1.0[1.8]
DL FAR-MSP JUN 7>2[7]
DL FAT-SLC JUN 4>2[3]
DL FCA-MSP JUN 1.4>0[1.4]
DL FCA-SLC JUN 3>2.0[3]
DL FLL-JFK JUN 4>1.0[4]
DL FLL-LGA JUN 5>0[5]
DL FLL-RDU JUN 1.0>0[1.0]
DL FLL-SLC JUN 1.0>0[1.0]
DL FSD-MSP JUN 7>2[7]
DL FWA-MSP JUN 1.0>0[1.0]
DL GEG-LAX JUN 1.0>0[1.0]
DL GEG-MSP JUN 2>0[3]
DL GEG-SEA JUN 8>3[8]
DL GEG-SLC JUN 4>3[4]
DL GFK-MSP JUN 6>1.0[5]
DL GJT-SLC JUN 4>1.0[3]
DL GRB-MSP JUN 4>0[4]
DL GRR-LGA JUN 3>0[3]
DL GRR-MSP JUN 4>0[5]
DL GSO-LGA JUN 4>0[4]
DL GSP-LGA JUN 3>0[2]
DL GTF-MSP JUN 1.0>0[1.0]
DL GTF-SLC JUN 4>1.0[3]
DL GUA-LAX JUN 1.0>0[1.0]
DL HAV-MIA JUN 1.9>0[2]
DL HIB-MSP JUN 1.7>1.0[1.7]
DL HLN-MSP JUN 1.0>0[0.9]
DL HLN-SLC JUN 3>1.0[3]
DL HND-LAX JUN 1.0>0[1.0]
DL HND-SEA JUN 1.0>0.6[0]
DL HNL-LAX JUN 3>1.0[4]
DL HNL-SEA JUN 2.0>1.0[2.0]
DL HNL-SLC JUN 1.0>0[1.0]
DL IAD-JFK JUN 4>0[4]
DL IAD-MSP JUN 3>1.0[3]
DL IAD-SEA JUN 1.2>0[1.0]
DL IAD-SLC JUN 1.0>0[0.9]
DL IAH-JFK JUN 1.9>0[0]
DL IAH-LGA JUN 4>0[4]
DL IAH-MSP JUN 5>1.0[6]
DL IAH-SLC JUN 3>1.0[3]
DL ICN-SEA JUN 1.0>0.5[1.0]
DL ICT-MSP JUN 4>0[3]
DL IDA-SLC JUN 4>2[4]
DL IND-JFK JUN 3>0[3]
DL IND-LAX JUN 1.0>0[0.9]
DL IND-LGA JUN 4>0[4]
DL IND-MCO JUN 1.0>0[1.0]
DL IND-MSP JUN 4>1.0[5]
DL IND-RDU JUN 1.5>0[1.6]
DL IND-SEA JUN 1.0>0[0.9]
DL IND-SLC JUN 1.0>0[0.9]
DL INL-MSP JUN 2>1.1[2.0]
DL JAC-LAX JUN 0.3>0[0.3]
DL JAC-SLC JUN 3>1.0[4]
DL JAX-JFK JUN 3>0[3]
DL JAX-LGA JUN 2>0[3]
DL JAX-MSP JUN 0.5>0[0.9]
DL JFK-LAS JUN 5>0[5]
DL JFK-MBJ JUN 1.0>0[1.0]
DL JFK-MCO JUN 5>1.0[5]
DL JFK-MEX JUN 1.7>0[1.0]
DL JFK-MIA JUN 4>0.9[4]
DL JFK-MSP JUN 4>1.0[4]
DL JFK-MSY JUN 3>0[3]
DL JFK-NAS JUN 1.9>0[2]
DL JFK-ORD JUN 5>0[5]
DL JFK-ORF JUN 3>0[3]
DL JFK-PDX JUN 3>0[3]
DL JFK-PHX JUN 3>0[3]
DL JFK-PIT JUN 3>0[3]
DL JFK-PUJ JUN 1.0>0[2]
DL JFK-PWM JUN 3>0[3] DEC 1.6>2[1.6]
DL JFK-RDU JUN 5>0[5]
DL JFK-RIC JUN 3>0[3]
DL JFK-ROC JUN 3>0[3]
DL JFK-SAN JUN 4>0[4]
DL JFK-SAT JUN 1.0>0[1.0]
DL JFK-SAV JUN 1.9>0[2]
DL JFK-SDQ JUN 3>0.7[3]
DL JFK-SEA JUN 5>1.0[5]
DL JFK-SFO JUN 7>1.0[7]
DL JFK-SJC JUN 0.8>0[1.0]
DL JFK-SJU JUN 2.9>0.3[3.0]
DL JFK-SLC JUN 5>2.0[5]
DL JFK-STI JUN 3>0.7[3]
DL JFK-STT JUN 1.0>0[1.0]
DL JFK-SXM JUN 0.9>0[1.0]
DL JFK-SYR JUN 3>0[3]
DL JFK-TPA JUN 4>1.0[4]
DL JFK-YUL JUN 3>0[3] DEC 3>2[2]
DL JFK-YYZ JUN 4>1.0[4]
DL JNU-SEA JUN 1.0>0.8[1.0]
DL KOA-SEA JUN 1.0>0[1.0]
DL KTN-SEA JUN 1.0>0.8[0.8]
DL LAN-MSP JUN 1.0>0[1.0]
DL LAS-LAX JUN 6>3[7]
*DL LAS-LGB JUN 3>0[0] JUL 3>0[0] AUG 3>0[0]
DL LAS-MSP JUN 6>1.0[7]
DL LAS-PDX JUN 1.9>0[0]
DL LAS-SAN JUN 3>0[3]
DL LAS-SEA JUN 6>2[5]
DL LAS-SJC JUN 4>0[3]
DL LAS-SLC JUN 4>2[5]
DL LAS-SNA JUN 4>0[4]
DL LAX-MCI JUN 1.7>0[1.8]
DL LAX-MCO JUN 3>0[3]
DL LAX-MEM JUN 0.8>0[0.8]
DL LAX-MEX JUN 3>0[1.0]
DL LAX-MSP JUN 7>3[8]
DL LAX-MSY JUN 3>0[3]
DL LAX-OGG JUN 3>1.0[3]
DL LAX-OMA JUN 0.8>0[0]
DL LAX-PDX JUN 5>2.0[5]
DL LAX-PHX JUN 5>2[5]
DL LAX-PVG JUN 1.0>0[1.0]
DL LAX-PVR JUN 1.0>0.3[1.0]
DL LAX-RDU JUN 1.7>0[1.5]
DL LAX-SAN JUN 5>0[5]
DL LAX-SAT JUN 1.9>0[1.9]
DL LAX-SEA JUN 9>3[9]
DL LAX-SFO JUN 7>3[8]
DL LAX-SJC JUN 7>2[7]
DL LAX-SJD JUN 1.9>0.3[2]
DL LAX-SJO JUN 1.0>0[1.0]
DL LAX-SLC JUN 7>3[8]
DL LAX-SMF JUN 5>2.0[5]
DL LAX-SYD JUN 1.0>0.4[1.0]
DL LAX-TPA JUN 1.3>0[1.6]
DL LAX-TUS JUN 3>1.0[3]
DL LEX-LGA JUN 1.0>0[1.0]
DL LEX-MSP JUN 1.0>0[1.0]
DL LGA-MCI JUN 4>0[4]
DL LGA-MCO JUN 5>0[6]
DL LGA-MEM JUN 3>0[2]
*DL LGA-MHT JUN 1.0>0[1.0] JUL 1.0>0[1.0] AUG 1.0>0[1.0]
DL LGA-MIA JUN 5>0[5]
DL LGA-MKE JUN 4>0[5]
DL LGA-MSN JUN 3>0[2]
DL LGA-MSP JUN 4>2.0[6]
DL LGA-MSY JUN 3>0[3]
DL LGA-OMA JUN 2>0[2]
DL LGA-ORD JUN 12>1.9[12]
DL LGA-ORF JUN 4>0[4]
DL LGA-PBI JUN 4>0[4]
DL LGA-PIT JUN 7>0[7]
DL LGA-PWM JUN 4>0[4]
DL LGA-RDU JUN 7>1.0[7]
DL LGA-RIC JUN 4>0[4]
DL LGA-ROC JUN 3>0[3]
DL LGA-RSW JUN 3>0[2]
DL LGA-SAV JUN 3>0[3]
DL LGA-SDF JUN 3>0[3]
DL LGA-SRQ JUN 1.0>0[1.0]
DL LGA-STL JUN 5>0[5]
DL LGA-SYR JUN 2>0[3]
DL LGA-TPA JUN 4>0[4]
DL LGA-TYS JUN 2>0[3]
DL LGA-XNA JUN 0.8>0[0.8]
DL LGA-YOW JUN 1.8>0[1.8] DEC 1.9>1.5[1.5]
DL LGA-YUL JUN 4>0[4]
*DL LGB-SLC JUN 5>0[4] JUL 5>0[4] AUG 5>0[4]
DL LIH-SEA JUN 1.0>0[0.9]
DL LNK-MSP JUN 3>1.0[3]
DL LSE-MSP JUN 2.0>0.7[2]
DL LWS-SLC JUN 3>1.0[3]
DL MBS-MSP JUN 0.8>0[0.8]
DL MCI-SEA JUN 1.0>0[1.0]
DL MCI-SLC JUN 3>1.0[3]
DL MCO-MIA JUN 4>0[0]
DL MCO-MSP JUN 4>1.0[4]
DL MCO-RDU JUN 3>0[3]
DL MCO-SEA JUN 1.5>0[1.0]
DL MCO-SLC JUN 3>0[3]
*DL MDW-MSP JUN 6>0[6] JUL 6>0[6] AUG 6>0[6]
DL MEM-MSP JUN 2>0[3]
DL MEX-MSP JUN 0.8>0[0.8]
DL MEX-SLC JUN 1.0>0.4[1.0]
DL MFR-SEA JUN 3>2.0[3]
DL MFR-SLC JUN 2.0>1.0[2]
DL MIA-MSP JUN 1.9>0[2.0]
DL MIA-RDU JUN 1.9>0[0.2]
DL MIA-TPA JUN 4>0[0]
DL MKE-MSP JUN 5>2.0[5]
DL MKE-SEA JUN 1.0>0[1.0]
DL MKE-SLC JUN 1.0>0[1.0]
DL MLI-MSP JUN 1.8>0[1.6]
DL MOT-MSP JUN 6>2[5]
DL MQT-MSP JUN 1.0>0[1.0]
DL MSN-MSP JUN 5>1.0[5]
DL MSN-SLC JUN 0.8>0[0.8]
DL MSO-MSP JUN 1.5>0[2]
DL MSO-SLC JUN 4>2[4]
DL MSP-MSY JUN 1.0>0[1.0]
DL MSP-OKC JUN 3>1.0[3]
DL MSP-OMA JUN 6>2[6]
DL MSP-ORD JUN 6>2[6]
DL MSP-ORF JUN 1.0>0[0.9]
DL MSP-PDX JUN 5>1.0[5]
DL MSP-PHL JUN 5>1.0[5]
DL MSP-PHX JUN 5>1.0[5]
DL MSP-PIA JUN 0.8>0[0.8]
DL MSP-PIT JUN 4>1.0[4]
DL MSP-PSC JUN 1.9>0[1.7]
DL MSP-RAP JUN 6>2.0[5]
DL MSP-RDU JUN 4>1.0[4]
DL MSP-RHI JUN 3>1.1[3]
DL MSP-RIC JUN 1.8>0[1.9]
DL MSP-ROC JUN 0.9>0[1.0]
DL MSP-RST JUN 4>1.0[4]
DL MSP-SAN JUN 3>1.0[4]
DL MSP-SAT JUN 3>1.0[3]
DL MSP-SBN JUN 3>0[3]
DL MSP-SDF JUN 3>0[3]
DL MSP-SEA JUN 7>2[7]
DL MSP-SFO JUN 6>1.0[6]
DL MSP-SJC JUN 2>0[3]
DL MSP-SMF JUN 1.4>0[2]
DL MSP-SNA JUN 3>0[3]
DL MSP-STL JUN 3>0[6]
DL MSP-SYR JUN 1.0>0[1.0]
DL MSP-TPA JUN 2.0>1.0[2]
DL MSP-TUL JUN 1.8>0[1.8]
DL MSP-TVC JUN 2>0[2]
DL MSP-TYS JUN 1.0>0[1.0]
DL MSP-XNA JUN 1.5>0[1.5]
DL MSP-XWA JUN 3>1.0[0]
DL MSP-YEG JUN 2.0>1.0[2]
DL MSP-YUL JUN 1.7>0[1.8]
DL MSP-YVR JUN 1.9>0[2]
DL MSP-YWG JUN 4>1.0[4]
*DL MSP-YXE JUN 1.9>0[2] JUL 2.0>0[2] AUG 2>0[2]
DL MSP-YYC JUN 3>1.0[3]
DL MSP-YYZ JUN 3>0[3]
DL MSY-SLC JUN 1.0>0[1.0]
*DL OAK-SLC JUN 4>0[5] JUL 5>0[5] AUG 5>0[5]
DL OGG-SEA JUN 1.0>0[1.0]
DL OKC-SLC JUN 3>1.0[2]
DL OMA-SLC JUN 3>1.0[3]
DL ONT-SLC JUN 5>3[3]
DL ORD-RDU JUN 3>0[3]
DL ORD-SEA JUN 3>1.0[3]
DL ORD-SLC JUN 4>1.0[4]
DL PDX-SEA JUN 8>3[8]
DL PDX-SLC JUN 6>3[6]
*DL PEK-SEA SEP 0>1.0[0.8] OCT 0>0.8[0.9]
DL PHL-RDU JUN 3>0[2]
DL PHL-SLC JUN 1.0>0[1.2]
DL PHX-SEA JUN 4>2[4]
DL PHX-SLC JUN 4>3[5]
DL PIH-SLC JUN 3>0.7[3]
DL PIT-RDU JUN 0.8>0[0.7]
DL PIT-SLC JUN 1.0>0[1.0]
*DL PKX-SEA JUN 1.0>0[0] JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0] OCT 1.0>0.2[0]
DL PSC-SEA JUN 4>2[4]
DL PSP-SLC JUN 2.0>1.0[2]
DL PVR-SLC JUN 0.5>0[0.6]
DL RAP-SLC JUN 1.9>0[1.8]
DL RDM-SEA JUN 3>2.0[3]
DL RDM-SLC JUN 2.0>1.0[2]
DL RDU-SEA JUN 1.0>0[1.0]
DL RDU-SLC JUN 0.9>0[1.0]
DL RDU-TPA JUN 3>0[3]
DL RNO-SLC JUN 4>2[5]
DL SAN-SEA JUN 5>2[5]
DL SAN-SLC JUN 5>3[5]
DL SAT-SLC JUN 3>2.0[3]
DL SBA-SLC JUN 3>1.0[0]
DL SEA-SFO JUN 8>2[8]
DL SEA-SIT JUN 1.0>0.8[1.0]
DL SEA-SJC JUN 6>2[6]
DL SEA-SLC JUN 7>3[8]
DL SEA-SMF JUN 5>2[5]
DL SEA-SNA JUN 5>0[5]
DL SEA-TPA JUN 0.8>0[0]
DL SEA-YVR JUN 6>3[7]
DL SEA-YYC JUN 3>0[3]
DL SFO-SLC JUN 5>3[5]
DL SGU-SLC JUN 4>2.0[0]
DL SJC-SLC JUN 4>3[5]
DL SJD-SLC JUN 0.5>0[0.6]
DL SLC-SMF JUN 5>3[5]
DL SLC-SNA JUN 4>3[5]
DL SLC-STL JUN 3>1.0[3]
DL SLC-SUN JUN 3>1.0[3]
DL SLC-TPA JUN 1.0>0[0.8]
DL SLC-TUL JUN 1.8>1.0[1.8]
DL SLC-TUS JUN 3>2[3]
DL SLC-TWF JUN 3>0.7[3]
DL SLC-WYS JUN 1.7>1.0[1.7]
DL SLC-YVR JUN 1.9>0[2.0]
DL SLC-YYC JUN 1.9>0[1.8]
DL SLC-YYZ JUN 1.0>0[1.0]
DY AMS-JFK JUN 1.0>0.5[1.0]
DY ATH-JFK JUN 0.6>0.3[0]
DY AUS-CDG JUN 0.4>0.2[0]
DY BCN-FLL JUN 0.4>0.2[0.3]
DY BCN-JFK JUN 1.0>0.5[0]
DY BCN-LAX JUN 0.9>0.5[0.8]
DY BCN-ORD JUN 0.5>0.3[0.5]
DY BCN-SFO JUN 0.6>0.3[0]
DY BOS-CDG JUN 0.7>0.4[0.6]
DY BOS-FCO JUN 0.6>0.3[0.6]
DY CDG-DEN JUN 0.6>0.3[0.4]
DY CDG-FLL JUN 0.4>0.2[0.4]
DY CDG-JFK JUN 1.3>0.7[1.0]
DY CDG-LAX JUN 1.1>0.6[1.1]
DY CDG-ORD JUN 0.7>0.4[0]
DY CDG-SFO JUN 0.4>0.2[0]
DY DEN-FCO JUN 0.4>0.2[0]
DY FCO-JFK JUN 1.0>0.5[0]
DY FCO-LAX JUN 0.7>0.4[0.6]
DY FCO-ORD JUN 0.6>0.3[0]
DY FCO-SFO JUN 0.4>0.2[0]
DY JFK-OSL JUN 0.6>0.3[0.7]
DY LAX-MAD JUN 0.4>0.2[0.6]
EI BOS-MSP JUN 0.0>0.3[0]
FJ LAX-NAN JUN 0.3>0[1.0]
FJ NAN-SFO JUN 0.3>0[0.5]
G3 BSB-MCO DEC 1.0>0.5[1.0]
G3 BSB-MIA DEC 1.0>0.4[0.6]
G4 ABE-PIE JUN 0.9>0.7[0.7]
G4 ABE-SFB JUN 1.8>0.8[1.6]
G4 ANC-BLI JUN 0.3>0[0.3]
G4 AVL-BOS JUN 0.3>0[0]
G4 AVL-FLL JUN 1.9>0.7[2]
G4 AVL-PIE JUN 1.5>0.7[1.6]
G4 AVL-SFB JUN 2>0.8[1.2]
G4 AZA-FAR JUN 0.6>0.4[0.6]
G4 AZA-FSD JUN 0.7>0.4[0.7]
G4 AZA-PVU JUN 2>0.8[1.6]
G4 BLI-LAS JUN 1.8>0.7[2]
G4 BLV-SFB JUN 0.7>0.4[0.7]
G4 BLV-VPS JUN 1.7>0.7[1.3]
G4 BNA-GPT JUN 0.3>0[0]
G4 BNA-GSO JUN 0.3>0[0]
G4 BNA-ORF JUN 0.3>0[0]
G4 BOS-GRR JUN 0.3>0[0]
G4 BOS-TYS JUN 0.3>0[0]
G4 BOS-VPS JUN 0.3>0[0]
G4 CHS-SDF JUN 0.3>0[0]
G4 CLE-SAV JUN 1.0>0.7[1.1]
G4 CVG-FLL JUN 1.8>0.8[1.2]
G4 CVG-MEM JUN 0.3>0[0]
G4 CVG-MYR JUN 0.7>0.4[0.6]
G4 CVG-PGD JUN 1.6>0.7[1.2]
G4 CVG-PIE JUN 2>0.7[1.3]
G4 CVG-SAV JUN 1.1>0.7[1.0]
G4 CVG-SFB JUN 1.8>0.8[1.3]
G4 CVG-SRQ JUN 1.0>0.7[0.6]
G4 CVG-VPS JUN 1.8>0.8[1.5]
G4 DSM-MDW JUN 0.3>0[0]
G4 DSM-MEM JUN 0.3>0[0]
G4 ELM-MYR JUN 0.2>0[0]
G4 FAT-LAS JUN 1.7>0.8[1.7]
G4 FLL-IND JUN 1.0>0.7[0.7]
G4 FLL-MEM JUN 0.7>0.4[0.6]
G4 FLL-SDF JUN 0.7>0.4[0.6]
G4 FLL-TYS JUN 1.0>0.7[1.0]
G4 FLL-USA JUN 1.6>0.7[1.6]
G4 GPT-SFB JUN 0.3>0[0.3]
G4 GRR-PIE JUN 0.9>0.7[1.0]
G4 GRR-SFB JUN 1.5>0.7[1.3]
G4 HTS-PIE JUN 1.0>0.7[1.0]
G4 HTS-SFB JUN 0.7>0.4[0.7]
G4 IND-PGD JUN 0.6>0.4[0.7]
G4 IND-PIE JUN 1.1>0.7[1.0]
G4 LAS-LAX JUN 0.3>0[0.4]
G4 LAS-MEM JUN 1.1>0.7[0.7]
G4 LAS-MFE JUN 1.4>0.7[1.3]
G4 LAS-RNO JUN 1.9>0.8[1.0]
G4 LAS-SAN JUN 0.8>0.5[0]
G4 LAS-SCK JUN 1.7>0.8[1.7]
G4 LAS-SMX JUN 0.5>0.3[0.6]
G4 LCK-MYR JUN 1.1>0.7[1.0]
G4 LCK-ORF JUN 0.3>0[0]
G4 LCK-PGD JUN 0.6>0.4[0.7]
G4 LCK-PIE JUN 0.7>0.4[0.7]
G4 LEX-PGD JUN 0.6>0.4[0.6]
G4 LEX-SFB JUN 1.0>0.7[1.0]
G4 MDT-SFB JUN 1.0>0.7[1.0]
G4 MEM-PBI JUN 0.3>0[0]
G4 MEM-PIT JUN 0.3>0[0]
G4 MFE-SFB JUN 0.7>0.4[0.7]
G4 MYR-PVD JUN 0.3>0[0]
G4 MYR-SWF JUN 0.6>0.3[0.4]
G4 MYR-TYS JUN 0.2>0[0]
G4 ORF-PIT JUN 0.3>0[0]
G4 PGD-SAV JUN 0.2>0[0]
G4 PIA-PIE JUN 0.7>0.4[0.6]
G4 PIE-PIT JUN 0.7>0.4[0.7]
G4 PIE-SGF JUN 1.0>0.7[0.7]
G4 PIE-TYS JUN 1.3>0.7[1.3]
G4 PIE-USA JUN 1.3>0.7[1.3]
G4 RFD-SFB JUN 0.6>0.4[0.7]
G4 SAN-SCK JUN 0.3>0.1[0.3]
G4 SAN-TUL JUN 0.3>0[0]
G4 SAV-SWF JUN 0.3>0[0]
G4 SDF-SFB JUN 0.7>0.4[0.7]
G4 SFB-SGF JUN 0.7>0.4[0.7]
G4 SFB-TYS JUN 1.7>0.7[1.6]
G4 SFB-USA JUN 1.0>0.7[1.0]
G4 SWF-VPS JUN 0.3>0[0]
JQ HNL-MEL JUN 0.3>0[0.5] JUL 0.4>0[0.5]
JQ HNL-SYD JUN 0.4>0[0.8] JUL 0.4>0[0.9]
KE HNL-NRT JUN 1.0>0[1.0]
KL AMS-BOS JUN 0>0.3[0.4]
LF PGA-PHX JUN 1.3>2[1.3] JUL 1.3>1.7[1.0] AUG 1.3>1.7[1.0] SEP 1.3>1.6[1.0]
LO ORD-WAW JUN 1.6>2[1.6]
NK returning some June?
NK ATL-BWI JUN 0>0.5[3]
NK ATL-CLE JUN 0>0.3[1.0]
NK ATL-DFW JUN 0>0.5[2]
NK ATL-FLL JUN 0>0.5[4]
NK ATL-LAS JUN 0>0.4[1.4]
NK ATL-LAX JUN 0>0.5[1.0]
NK ATL-MCO JUN 0>0.5[2.0]
NK ATL-ORD JUN 0>0.5[1.0]
NK BDL-MYR JUN 0>0.2[1.3]
NK BNA-MCO JUN 0>0.4[0]
NK BOS-MYR JUN 0>0.3[1.0]
NK BWI-ORD JUN 0>0.5[2]
NK CUN-DFW JUN 0>0.2[1.0]
NK DEN-ORD JUN 0>0.3[2]
NK DFW-ORD JUN 0>0.5[2]
NK DFW-PHL JUN 0>0.4[1.0]
NK DTW-FLL JUN 0>0.2[2]
NK DTW-LAX JUN 0>0.5[2]
NK DTW-MYR JUN 0>0.3[1.0]
NK FLL-IAH JUN 0>0.3[2]
NK LAS-LAX JUN 0>0.5[3]
NK LAS-MCI JUN 0>0.4[1.0]
NK MCI-MCO JUN 0>0.4[1.0]
NK MCO-ORD JUN 0>0.5[1.0]
NK MCO-PIT JUN 0.1>0.5[1.0]
NK MYR-ORD JUN 0>0.2[1.0]
NK ORD-TPA JUN 0>0.4[1.0]
OB MIA-VVI JUN 0.8>0.6[0.6] JUL 1.0>0.7[0.6]
QF BNE-LAX JUN 1.0>0[1.4] JUL 1.0>0[1.5]
QF BNE-ORD JUN 0.6>0[0] JUL 0.6>0[0]
QF DFW-SYD JUN 0.9>0[0.9] JUL 1.0>0[0.8]
QF HNL-SYD JUN 0.7>0[0.6] JUL 0.7>0[0.7]
QF JFK-LAX JUN 1.0>0[1.0] JUL 1.0>0[1.0]
QF LAX-MEL JUN 1.4>0.0[1.3] JUL 1.2>0[1.3]
QF LAX-SYD JUN 1.0>0[1.0] JUL 1.0>0[1.0]
QF SFO-SYD JUN 1.0>0[0.9] JUL 1.0>0[1.0]
S4 BOS-PDL JUN 0.8>0.6[1.2]
SV JED-LAX JUN 0>0.2[0.7]
SV JFK-RUH JUN 0>0.2[0.4]
TN CDG-LAX JUN 1.0>0.5[0.9]
TN LAX-PPT JUN 1.6>0.9[1.6]
UA ABE-ORD JUN 1.9>0.9[3]
UA ABQ-DEN JUN 5>1.5[5]
UA ABQ-IAH JUN 4>1.7[4]
UA ABQ-ORD JUN 0.9>0[1.1]
UA ABQ-SFO JUN 1.6>0[3]
UA ACK-EWR JUN 3>0.4[1.1]
UA ACV-DEN JUN 0.9>0[0.8]
UA ACV-LAX JUN 1.8>0[2]
UA ACV-SFO JUN 3>1.8[3]
UA AEX-IAH JUN 3>0.4[1.8]
UA ALB-EWR JUN 3>0[4]
UA ALB-IAD JUN 3>1.0[3]
UA ALB-ORD JUN 4>1.6[4]
UA AMA-DEN JUN 1.8>0.9[2]
UA AMA-IAH JUN 3>0[3]
UA ANC-DEN JUN 1.8>0.6[1.8]
UA ANC-EWR JUN 0.9>0[0.4]
UA ANC-IAH JUN 0.9>0[0.8]
UA ANC-LAX JUN 0.4>0[0]
UA ANC-ORD JUN 1.8>0[2]
UA ANC-SFO JUN 0.9>0[0.8]
UA ASE-DEN JUN 7>1.7[7] JUL 8>7[8]
UA ASE-IAH JUN 0.9>0[0.8]
UA ASE-LAX JUN 1.3>0[1.7]
UA ASE-ORD JUN 1.0>0[1.0]
UA ASE-SFO JUN 0.9>0[0.8]
UA ATL-DEN JUN 4>0.9[4]
UA ATL-EWR JUN 6>1.5[6]
UA ATL-IAD JUN 4>1.0[4]
UA ATL-IAH JUN 6>2.0[6]
UA ATL-ORD JUN 7>1.9[7]
UA ATL-SFO JUN 1.8>0[1.8]
UA ATW-DEN JUN 0.9>0[1.0]
UA ATW-ORD JUN 7>2[5]
UA ATY-ORD JUN 0.9>0[0]
UA AUS-DEN JUN 4>1.0[5]
UA AUS-EWR JUN 4>0[4]
UA AUS-IAD JUN 3>0[3]
UA AUS-IAH JUN 8>1.9[9] JUL 9>8[9]
UA AUS-LAX JUN 1.8>0[2.0]
UA AUS-ORD JUN 4>1.0[4]
UA AUS-SFO JUN 5>0[5]
UA AVL-EWR JUN 0.9>0[1.2]
UA AVL-IAD JUN 3>1.0[2]
UA AVL-ORD JUN 4>0.7[4]
UA AVP-IAD JUN 1.8>0[2]
UA AVP-ORD JUN 1.8>0.8[3]
UA AZO-ORD JUN 1.7>0.7[1.1]
UA BDL-DEN JUN 0.9>0[1.0]
UA BDL-IAD JUN 4>1.0[4]
UA BDL-IAH JUN 1.8>0[1.0]
UA BDL-ORD JUN 4>1.7[4]
UA BFF-DEN JUN 1.8>1.0[1.7]
UA BFF-PIR JUN 0.1>1.0[0]
UA BFL-DEN JUN 1.9>0.6[2]
UA BFL-SFO JUN 1.0>0.6[1.0]
UA BGR-EWR JUN 1.9>0[3]
UA BGR-IAD JUN 1.9>0.9[0]
UA BGR-ORD JUN 1.9>0[1.8]
UA BHM-DEN JUN 1.8>0[2]
UA BHM-IAH JUN 5>2.0[5]
UA BHM-ORD JUN 3>0[4]
UA BIL-DEN JUN 6>1.6[5]
UA BIL-ORD JUN 0.9>0[0.9]
UA BIS-DEN JUN 4>1.6[4]
UA BIS-ORD JUN 1.8>0[2]
UA BNA-DEN JUN 4>0.9[4]
UA BNA-EWR JUN 5>1.5[6]
UA BNA-IAD JUN 3>1.0[3]
UA BNA-IAH JUN 5>2.0[5]
UA BNA-ORD JUN 5>2.0[7]
UA BNA-SFO JUN 1.8>0[1.6]
UA BOI-DEN JUN 6>1.5[5]
UA BOI-IAH JUN 1.8>0[1.0]
UA BOI-LAX JUN 1.8>0[2]
UA BOI-ORD JUN 3>1.0[2]
UA BOI-SFO JUN 6>2[5]
UA BOS-DEN JUN 5>0[5]
UA BOS-EWR JUN 9>1.5[10] JUL 10>9[10]
UA BOS-IAD JUN 5>1.0[4]
UA BOS-IAH JUN 5>1.0[5]
UA BOS-LAX JUN 1.7>0[2]
UA BOS-ORD JUN 8>1.9[8] JUL 9>8[9]
UA BOS-SFO JUN 6>1.0[6] JUL 7>6[7]
UA BRO-IAH JUN 4>1.7[4]
UA BTR-IAH JUN 5>1.6[7]
UA BTV-DEN JUN 0.3>0[0.3]
UA BTV-EWR JUN 3>0[4]
UA BTV-IAD JUN 4>1.0[4]
UA BTV-ORD JUN 4>1.7[4]
UA BUF-EWR JUN 6>0[6] JUL 6>5[7]
UA BUF-IAD JUN 4>1.0[4]
UA BUF-ORD JUN 5>1.7[6]
UA BUR-DEN JUN 3>0.6[3]
UA BUR-SFO JUN 5>1.5[6]
UA BWI-DEN JUN 1.8>0[2]
UA BWI-IAH JUN 1.8>0[2.0]
UA BWI-LAX JUN 0.9>0[1.0]
UA BWI-ORD JUN 3>2.0[4]
UA BWI-SFO JUN 1.8>0[1.7]
UA BZN-DEN JUN 5>2.0[4]
UA BZN-EWR JUN 0.4>0[0.8]
UA BZN-IAH JUN 0.6>0[0.6]
UA BZN-LAX JUN 0.9>0[1.4]
UA BZN-ORD JUN 1.2>0[2] NOV 0.5>1.0[1.0]
UA BZN-SFO JUN 1.0>0[1.3]
UA CAE-IAD JUN 3>1.0[3]
UA CAE-ORD JUN 3>0.7[3]
UA CAK-IAD JUN 3>0[0]
UA CAK-ORD JUN 4>1.0[4]
UA CGI-ORD JUN 1.6>1.0[0.8]
UA CHA-ORD JUN 3>0.5[1.9]
UA CHO-IAD JUN 3>1.0[2]
UA CHO-ORD JUN 1.8>0[2]
UA CHS-DEN JUN 1.0>0[0.8]
UA CHS-EWR JUN 4>0[4]
UA CHS-IAD JUN 4>1.0[4]
UA CHS-IAH JUN 3>1.0[2]
UA CHS-MYR JUN 0.1>0.5[0]
UA CHS-ORD JUN 4>0.5[4]
UA CID-DEN JUN 3>0[3]
UA CID-ORD JUN 6>1.5[5]
UA CKB-IAD JUN 1.0>0.7[1.0]
UA CLE-DEN JUN 3>0[4]
UA CLE-EWR JUN 6>1.3[7] JUL 7>6[7]
UA CLE-IAD JUN 4>1.0[4]
UA CLE-IAH JUN 4>0[5]
UA CLE-LAX JUN 1.7>0[1.8]
UA CLE-ORD JUN 7>2.0[9] JUL 8>7[8]
UA CLE-SFO JUN 1.8>0[2.0]
UA CLL-IAH JUN 2>0.4[2]
UA CLT-DEN JUN 1.8>0[2]
UA CLT-EWR JUN 5>1.0[5]
UA CLT-IAD JUN 4>1.0[4]
UA CLT-IAH JUN 4>2[4]
UA CLT-ORD JUN 4>1.0[5]
UA CMH-DEN JUN 1.8>0[2]
UA CMH-EWR JUN 6>1.0[7] JUL 7>6[7]
UA CMH-IAD JUN 4>1.0[4]
UA CMH-IAH JUN 3>0[4]
UA CMH-ORD JUN 6>1.9[7]
UA CMH-SFO JUN 0.9>0[0.8]
UA CMX-ORD JUN 1.9>1.0[2]
UA CNY-DEN JUN 1.7>1.0[1.7]
UA COD-DEN JUN 4>0.7[3]
UA COS-DEN JUN 9>1.7[10] JUL 10>9[9]
UA COS-IAH JUN 3>0[3]
UA COS-LAX JUN 1.8>0[2]
UA COS-ORD JUN 3>0[3]
UA COU-DEN JUN 0.9>0[1.0]
UA COU-ORD JUN 1.8>0.6[3]
UA CPR-DEN JUN 5>2[5]
UA CRP-IAH JUN 6>1.7[5]
UA CRW-ORD JUN 3>0.7[3]
UA CTU-SFO JUN 0.4>0[0.4]
UA CVG-DEN JUN 1.8>0[2]
UA CVG-EWR JUN 4>0.5[5]
UA CVG-IAD JUN 4>1.0[4]
UA CVG-IAH JUN 3>0[4]
UA CVG-ORD JUN 6>1.9[7]
UA CWA-ORD JUN 3>0.6[3]
UA DAY-DEN JUN 1.8>0[2]
UA DAY-IAD JUN 3>1.0[1.9]
UA DAY-ORD JUN 5>1.5[6]
UA DCA-EWR JUN 11>1.5[7] JUL 12>11[7]
UA DCA-IAH JUN 7>2.0[8] JUL 8>7[8]
UA DCA-ORD JUN 13>2.0[14] JUL 14>12[14]
UA DCA-SFO JUN 0.9>0[1.0]
UA DDC-PUB JUN 0.9>0[0]
UA DEC-ORD JUN 1.8>0.5[0]
UA DEC-SPI JUN 0.1>0.5[0]
UA DEN-DFW JUN 5>2.0[5]
UA DEN-DIK JUN 1.8>0.9[1.7]
UA DEN-DRO JUN 6>1.6[7]
UA DEN-DSM JUN 5>2.0[5]
UA DEN-DTW JUN 1.8>0[2]
UA DEN-EAR JUN 1.7>0[1.8]
UA DEN-EGE JUN 1.9>1.0[2]
UA DEN-ELP JUN 4>0[4]
UA DEN-EUG JUN 3>2.0[3]
UA DEN-EWR JUN 9>2.0[9] JUL 10>9[9]
UA DEN-FAR JUN 4>1.6[4]
UA DEN-FAT JUN 5>2.0[3]
UA DEN-FCA JUN 4>0.8[3]
UA DEN-FLG JUN 1.9>0.6[2]
UA DEN-FLL JUN 1.8>0[2.0]
UA DEN-FSD JUN 5>2.0[5]
UA DEN-GCC JUN 3>0.7[2]
UA DEN-GEG JUN 1.9>1.0[3]
UA DEN-GJT JUN 5>0[5] JUL 6>5[5]
UA DEN-GRR JUN 1.8>0[2]
UA DEN-GSP JUN 0.9>0[0.8]
UA DEN-GTF JUN 3>0.2[3]
UA DEN-GUC JUN 1.9>0.4[1.8]
UA DEN-HDN JUN 3>1.0[3]
UA DEN-HLN JUN 1.9>0.3[2]
UA DEN-HNL JUN 1.8>0[1.0]
UA DEN-HOB JUN 0.9>0[0]
UA DEN-HSV JUN 1.8>0[2]
UA DEN-HYS JUN 1.8>1.0[1.7]
UA DEN-IAD JUN 7>2.0[8]
UA DEN-IAH JUN 10>3[11] JUL 11>10[11]
UA DEN-ICT JUN 5>1.0[4]
UA DEN-IDA JUN 4>1.6[4]
UA DEN-IND JUN 3>0.9[3]
UA DEN-JAC JUN 5>2.0[4]
UA DEN-JAX JUN 0.9>0[1.0]
UA DEN-JMS JUN 1.3>0.6[1.4]
UA DEN-KOA JUN 0.9>0[1.0]
UA DEN-LAR JUN 1.8>1.0[1.7]
UA DEN-LAS JUN 6>2.0[6]
UA DEN-LAX JUN 8>2.0[8] JUL 8>7[8]
UA DEN-LBB JUN 1.8>0[2]
UA DEN-LBF JUN 1.8>1.0[1.7]
UA DEN-LBL JUN 1.6>0[0.8]
UA DEN-LGA JUN 6>0[7] JUL 6>5[7]
UA DEN-LIH JUN 0.9>0[1.0]
UA DEN-LIT JUN 3>0[3]
UA DEN-LNK JUN 4>1.0[3]
UA DEN-MAF JUN 4>1.6[4]
UA DEN-MCI JUN 6>1.9[5]
UA DEN-MCO JUN 5>1.0[5]
UA DEN-MEM JUN 3>0[3]
UA DEN-MFR JUN 3>1.0[3]
UA DEN-MKE JUN 4>1.0[3]
UA DEN-MLI JUN 1.8>0[2]
UA DEN-MOT JUN 3>0.5[3]
UA DEN-MRY JUN 1.8>0[2]
UA DEN-MSN JUN 3>1.0[3]
UA DEN-MSO JUN 3>0.7[4]
UA DEN-MSP JUN 4>0.9[4]
UA DEN-MSY JUN 1.8>0[3]
UA DEN-MTJ JUN 4>1.6[4]
UA DEN-OGG JUN 0.9>0[1.0]
UA DEN-OKC JUN 5>1.0[6]
UA DEN-OMA JUN 5>1.6[5]
UA DEN-ONT JUN 3>0.6[2]
UA DEN-ORD JUN 10>3[11] JUL 11>10[11]
UA DEN-ORF JUN 0.9>0[1.0]
UA DEN-PAE JUN 2>0.6[2]
UA DEN-PDX JUN 5>1.8[5]
UA DEN-PHL JUN 3>0[3]
UA DEN-PHX JUN 4>2.0[4]
UA DEN-PIR JUN 1.7>0[1.8]
UA DEN-PIT JUN 3>0[3]
UA DEN-PNS JUN 0.3>0[0.3]
UA DEN-PSC JUN 2>0.5[3]
UA DEN-PSP JUN 3>1.9[3]
UA DEN-PUB JUN 1.7>1.0[1.7]
UA DEN-PWM JUN 0.9>0[0.3]
UA DEN-RAP JUN 7>2[7] JUL 8>7[7]
UA DEN-RDM JUN 3>1.0[3]
UA DEN-RDU JUN 1.8>0[2]
UA DEN-RIC JUN 1.8>0[2]
UA DEN-RIW JUN 1.7>0[0]
UA DEN-RKS JUN 3>0.7[2]
UA DEN-RNO JUN 3>1.9[3]
UA DEN-RSW JUN 1.2>0[0.5]
UA DEN-SAF JUN 3>0.5[3]
UA DEN-SAN JUN 5>2.0[5]
UA DEN-SAT JUN 4>0[4]
UA DEN-SAV JUN 0.9>0[0.3]
UA DEN-SBA JUN 4>0.9[4]
UA DEN-SBP JUN 3>1.0[2]
UA DEN-SDF JUN 1.8>0[2]
UA DEN-SEA JUN 6>2[6]
UA DEN-SFO JUN 10>3[10] JUL 11>10[11]
UA DEN-SGF JUN 4>1.5[4]
UA DEN-SGU JUN 1.9>0.7[0]
UA DEN-SHR JUN 0.8>0[0]
UA DEN-SHV JUN 0.9>0[1.0]
UA DEN-SJC JUN 5>1.6[5]
UA DEN-SLC JUN 6>2.0[7]
UA DEN-SLN JUN 0.9>0[0]
UA DEN-SMF JUN 4>2.0[5]
UA DEN-SNA JUN 4>2.0[4]
UA DEN-STL JUN 5>0[5] JUL 6>5[5]
UA DEN-STS JUN 1.8>0[1.0]
UA DEN-SYR JUN 1.0>0[0.8]
UA DEN-TPA JUN 3>0[3]
UA DEN-TUL JUN 4>0[4]
UA DEN-TUS JUN 5>1.9[4]
UA DEN-TVC JUN 1.2>0[0.5]
UA DEN-TYS JUN 1.8>0[2]
UA DEN-VEL JUN 1.6>0.9[1.7]
UA DEN-VPS JUN 0.9>0[0.2]
UA DEN-XNA JUN 4>0[3]
UA DEN-XWA JUN 4>0.6[0]
UA DEN-YEG JUN 1.8>0[2]
UA DEN-YVR JUN 3>0[3]
UA DEN-YWG JUN 1.8>0[2.0]
UA DEN-YYC JUN 3>0[4]
UA DEN-YYZ JUN 1.8>0[2]
UA DFW-EWR JUN 4>1.0[5]
UA DFW-IAD JUN 3>1.0[3]
UA DFW-IAH JUN 7>2.0[8] JUL 8>7[8]
UA DFW-ORD JUN 6>2.0[7]
UA DFW-SFO JUN 3>0[4]
UA DLH-ORD JUN 4>0.7[4]
UA DSM-IAH JUN 3>0[3]
UA DSM-ORD JUN 5>2.0[5]
UA DTW-EWR JUN 6>1.0[6] JUL 7>6[6]
UA DTW-IAD JUN 4>1.0[4]
UA DTW-IAH JUN 5>0[5]
UA DTW-ORD JUN 7>2.0[7]
UA DTW-SFO JUN 0.9>0[1.0]
UA DVL-JMS JUN 1.3>0.6[1.4]
UA EAR-LBF JUN 0.1>1.0[0]
UA EAR-ORD JUN 0.4>0[0]
UA EAU-ORD JUN 1.9>1.0[2]
UA ECP-IAH JUN 3>0.8[2]
UA ECP-ORD JUN 0.3>0[0.3]
UA EGE-ORD JUN 0.9>0[0]
UA ELP-IAH JUN 5>1.9[4]
UA ELP-ORD JUN 0.9>0[1.1]
UA ERI-ORD JUN 1.7>0.7[2]
UA EUG-LAX JUN 1.8>0[1.9]
UA EUG-ORD JUN 0.9>0[0.8]
UA EUG-SFO JUN 4>1.6[4]
UA EVV-ORD JUN 3>0.6[3]
UA EWR-EYW JUN 1.0>0[1.0]
UA EWR-FLL JUN 6>1.3[6]
UA EWR-GRR JUN 3>0[3]
UA EWR-GSO JUN 3>0[4]
UA EWR-GSP JUN 3>0[3]
UA EWR-HNL JUN 0.9>0[1.0]
UA EWR-IAD JUN 6>2.0[6]
UA EWR-IAH JUN 8>2.0[9] JUL 9>8[9]
UA EWR-IND JUN 6>1.0[6] JUL 7>6[6]
UA EWR-JAX JUN 3>0[4]
UA EWR-LAS JUN 5>0[7] JUL 6>5[6]
UA EWR-LAX JUN 10>3[11] JUL 11>10[11]
UA EWR-MCI JUN 3>0[4]
UA EWR-MCO JUN 8>1.4[9] JUL 9>8[9]
UA EWR-MEM JUN 3>0[3]
UA EWR-MIA JUN 4>1.3[4]
UA EWR-MKE JUN 3>0[4]
UA EWR-MSN JUN 1.8>0[1.9]
UA EWR-MSP JUN 5>0[5] JUL 6>5[5]
UA EWR-MSY JUN 3>0[4]
UA EWR-MYR JUN 3>0[1.2]
UA EWR-OKC JUN 0.9>0[1.0]
UA EWR-OMA JUN 1.7>0[3]
UA EWR-ORD JUN 10>2[10] JUL 11>9[10]
UA EWR-ORF JUN 5>0[5] JUL 6>5[5]
UA EWR-PBI JUN 5>1.3[5]
UA EWR-PDX JUN 1.8>0[2.0]
UA EWR-PHX JUN 3>0[3]
UA EWR-PIT JUN 6>1.5[7]
UA EWR-PNS JUN 0.9>0[0.8]
UA EWR-PQI JUN 1.5>0[1.7]
UA EWR-PVD JUN 3>0[3]
UA EWR-PWM JUN 6>0[5] JUL 5>4[6]
UA EWR-RAP JUN 0.3>0[0.1]
UA EWR-RDU JUN 7>1.5[8] JUL 8>7[8]
UA EWR-RIC JUN 6>0.5[6]
UA EWR-ROC JUN 3>0[4]
UA EWR-RSW JUN 2>1.3[2]
UA EWR-SAN JUN 4>0[3]
UA EWR-SAT JUN 1.8>0[2]
UA EWR-SAV JUN 4>0[3]
UA EWR-SDF JUN 3>0[3]
UA EWR-SEA JUN 4>0[4]
UA EWR-SFO JUN 13>3[14] JUL 14>13[14]
UA EWR-SLC JUN 0.9>0[1.0]
UA EWR-SMF JUN 0.9>0[1.0]
UA EWR-SNA JUN 3>0[3]
UA EWR-SRQ JUN 0.9>0[1.3]
UA EWR-STL JUN 4>1.0[6]
UA EWR-SYR JUN 3>0[3]
UA EWR-TPA JUN 5>1.3[6]
UA EWR-TVC JUN 0.9>0[0.9]
UA EWR-TYS JUN 0.9>0[1.0]
UA EWR-XNA JUN 0.8>0[0.8]
UA EWR-YHZ JUN 3>0[3]
UA EWR-YQB JUN 3>0[3]
UA EWR-YUL JUN 3>0[3]
UA EWR-YVR JUN 0.9>0[0.4]
UA EWR-YYZ JUN 4>0[4]
UA EYW-RSW JUN 0.1>1.0[0]
UA FAI-ORD JUN 0.9>0[1.0]
UA FAR-ORD JUN 3>0[4]
UA FAT-LAX JUN 4>0[4]
UA FAT-ORD JUN 0.9>0[1.0]
UA FAT-SFO JUN 4>1.6[4]
UA FCA-LAX JUN 0.4>0[0.5]
UA FCA-ORD JUN 1.0>0[1.0]
UA FCA-SFO JUN 0.5>0[0.5]
UA FLL-IAD JUN 1.9>1.0[2]
UA FLL-IAH JUN 4>1.0[5]
UA FNT-ORD JUN 3>0.7[4]
UA FSD-ORD JUN 5>2.0[4]
UA FWA-ORD JUN 3>1.0[3]
UA GCC-SHR JUN 0.1>0.7[0]
UA GEG-IAH JUN 0.9>0[0]
UA GEG-ORD JUN 0.9>0[1.0]
UA GEG-SFO JUN 3>0[3]
UA GJT-MTJ JUN 0.1>0.9[0]
UA GPT-IAH JUN 3>1.5[2]
UA GRB-ORD JUN 4>0.6[5]
UA GRK-IAH JUN 3>0.4[2.0]
UA GRR-IAD JUN 0.9>0[1.0]
UA GRR-IAH JUN 0.9>0[1.0]
UA GRR-ORD JUN 6>1.7[7]
UA GSO-IAD JUN 3>1.0[3]
UA GSO-ORD JUN 3>1.0[3]
UA GSP-IAD JUN 4>1.0[3]
UA GSP-IAH JUN 1.9>1.0[2]
UA GSP-ORD JUN 3>1.6[3]
UA GTF-ORD JUN 0.9>0[0.8]
UA HHH-IAD JUN 1.2>0[2]
UA HHH-ORD JUN 0.3>0[0.3]
UA HHH-SAV JUN 0.1>1.0[0]
UA HNL-IAD JUN 0.9>0[1.0]
UA HNL-IAH JUN 0.9>0[1.0]
UA HNL-LAX JUN 5>0.9[5]
UA HNL-ORD JUN 0.9>0[1.0]
UA HNL-SFO JUN 5>1.9[5]
UA HOB-IAH JUN 1.7>0.4[1.8]
UA HPN-ORD JUN 3>0[3]
UA HRL-IAH JUN 4>1.5[4]
UA HSV-IAD JUN 1.9>1.0[2]
UA HSV-IAH JUN 3>1.6[3]
UA HSV-ORD JUN 2>0[1.8]
UA HYS-SLN JUN 0.1>1.0[1.7]
UA IAD-IAH JUN 5>3[5]
UA IAD-ILM JUN 3>1.0[2.0]
UA IAD-IND JUN 4>1.0[4]
UA IAD-ITH JUN 4>1.0[3]
UA IAD-JAX JUN 3>1.0[3]
UA IAD-LAS JUN 3>0[2]
UA IAD-LAX JUN 6>1.0[7] JUL 7>6[8]
UA IAD-LEX JUN 1.8>0[2]
UA IAD-LGA JUN 3>1.0[4]
UA IAD-LWB JUN 0.9>0[0.7]
UA IAD-MCI JUN 3>0[2]
UA IAD-MCO JUN 4>1.0[4]
UA IAD-MDT JUN 3>1.0[3]
UA IAD-MHT JUN 1.8>0[3]
UA IAD-MSN JUN 1.8>0[0]
UA IAD-MSP JUN 2>0[2]
UA IAD-MSY JUN 3>1.0[2]
UA IAD-OKC JUN 1.7>0[1.0]
UA IAD-ORD JUN 6>3[6]
UA IAD-ORF JUN 4>1.0[4]
UA IAD-PBG JUN 1.8>1.0[1.7]
UA IAD-PBI JUN 0.9>0[0]
UA IAD-PDX JUN 0.9>0[1.0]
UA IAD-PHL JUN 4>1.0[0]
UA IAD-PHX JUN 0.9>0[1.0]
UA IAD-PIT JUN 4>1.0[4]
UA IAD-PQI JUN 0.1>0.9[0]
UA IAD-PVD JUN 4>0[4]
UA IAD-PWM JUN 4>1.0[4]
UA IAD-RDU JUN 4>1.0[4]
UA IAD-RIC JUN 4>1.0[4]
UA IAD-ROA JUN 4>1.0[2]
UA IAD-ROC JUN 4>1.0[3]
UA IAD-RSW JUN 1.9>1.0[0]
UA IAD-SAN JUN 3>1.0[3]
UA IAD-SAT JUN 1.8>0[2]
UA IAD-SAV JUN 3>1.0[3]
UA IAD-SCE JUN 1.6>1.0[2]
UA IAD-SDF JUN 3>1.0[2]
UA IAD-SEA JUN 3>0[4]
UA IAD-SFO JUN 6>1.0[7] JUL 7>6[7]
UA IAD-SHD JUN 1.8>0[1.0]
UA IAD-SMF JUN 0.9>0[1.0]
UA IAD-STL JUN 3>0[3]
UA IAD-SYR JUN 4>1.0[3]
UA IAD-TPA JUN 3>1.0[3]
UA IAD-TVC JUN 0.9>0[0.1]
UA IAD-TYS JUN 3>1.0[4]
UA IAD-YOW JUN 3>0[3]
UA IAD-YUL JUN 3>0[3]
UA IAD-YVR JUN 0.4>0[0.1]
UA IAD-YYZ JUN 4>0[4]
UA IAH-ICT JUN 4>1.9[4]
UA IAH-IND JUN 5>0[4]
UA IAH-JAN JUN 4>1.6[4]
UA IAH-JAX JUN 4>1.9[4]
UA IAH-LAS JUN 6>1.0[6]
UA IAH-LAX JUN 10>2.0[10] JUL 10>9[10]
UA IAH-LBB JUN 3>1.6[3]
UA IAH-LCH JUN 2>1.6[1.9]
UA IAH-LEX JUN 0.9>0[0.2]
UA IAH-LFT JUN 5>1.6[4]
UA IAH-LGA JUN 7>1.0[8] JUL 8>7[8]
UA IAH-LIT JUN 5>1.6[6]
UA IAH-LRD JUN 3>1.4[3]
UA IAH-MAF JUN 7>2.0[7]
UA IAH-MCI JUN 4>2.0[3]
UA IAH-MCO JUN 7>2[7]
UA IAH-MEM JUN 6>2.0[5]
UA IAH-MFE JUN 6>1.5[7] JUL 7>6[7]
UA IAH-MIA JUN 4>0.9[4]
UA IAH-MKE JUN 1.8>0[1.9]
UA IAH-MLU JUN 1.8>0.6[1.8]
UA IAH-MOB JUN 4>1.6[4]
UA IAH-MOT JUN 0.3>0[0.3] JUL 0.3>0[0.2]
UA IAH-MSP JUN 4>0[4]
UA IAH-MSY JUN 7>1.9[7] JUL 8>7[8]
UA IAH-MTJ JUN 0.9>0[0.8]
UA IAH-OKC JUN 7>2.0[8] JUL 8>7[8]
UA IAH-OMA JUN 4>0[3]
UA IAH-ONT JUN 0.9>0[0.8]
UA IAH-ORD JUN 9>4[9]
UA IAH-ORF JUN 1.8>0[2.0]
UA IAH-PDX JUN 3>0[3]
UA IAH-PHL JUN 4>0[4]
UA IAH-PHX JUN 4>1.0[4]
UA IAH-PIT JUN 4>0[5]
UA IAH-PNS JUN 5>1.6[4]
UA IAH-RDU JUN 4>1.0[4]
UA IAH-RIC JUN 1.8>0[2.0]
UA IAH-RNO JUN 0.9>0[1.0]
UA IAH-SAN JUN 5>1.0[5]
UA IAH-SAT JUN 7>2.0[8] JUL 8>7[8]
UA IAH-SAV JUN 1.8>1.0[2]
UA IAH-SDF JUN 3>0[3]
UA IAH-SEA JUN 5>0[5]
UA IAH-SFO JUN 9>3[9] JUL 10>9[10]
UA IAH-SGF JUN 1.8>0[2]
UA IAH-SHV JUN 4>1.6[4]
UA IAH-SJC JUN 1.8>0[2.0]
UA IAH-SLC JUN 4>0[5]
UA IAH-SMF JUN 2>0[2]
UA IAH-SNA JUN 4>1.0[4]
UA IAH-STL JUN 4>0[5]
UA IAH-TPA JUN 4>1.0[5]
UA IAH-TUL JUN 6>1.9[7]
UA IAH-TUS JUN 3>1.0[2]
UA IAH-TYS JUN 4>1.0[3]
UA IAH-VPS JUN 3>0.7[3]
UA IAH-XNA JUN 4>1.7[4]
UA IAH-YVR JUN 1.8>0[1.8]
UA IAH-YYC JUN 1.5>0[1.7]
UA IAH-YYZ JUN 3>0[3]
UA ICT-ORD JUN 4>1.9[4]
UA ILM-ORD JUN 0.9>0[1.3]
UA IND-ORD JUN 9>2.0[8] JUL 9>8[8]
UA IND-SFO JUN 1.8>0[1.5]
UA ITO-LAX JUN 0.9>0[0.9]
UA JAC-LAX JUN 0.9>0[0.6]
UA JAC-ORD JUN 2>0[1.9]
UA JAC-SFO JUN 0.9>0[0.9]
UA JAX-ORD JUN 3>1.0[3]
UA KOA-LAX JUN 2>0[2]
UA KOA-SFO JUN 3>0.6[3]
UA LAN-ORD JUN 3>0.6[3]
UA LAS-LAX JUN 5>0[5] JUL 6>5[4]
UA LAS-ORD JUN 5>1.0[5]
UA LAS-SFO JUN 6>1.9[8]
UA LAX-LIH JUN 2>0[2]
UA LAX-MCO JUN 1.8>0[1.9]
UA LAX-MFR JUN 1.8>0[1.9]
UA LAX-MRY JUN 4>0[4]
UA LAX-MSN JUN 0.9>0[1.0]
UA LAX-MSO JUN 0.5>0[0.5]
UA LAX-OGG JUN 3>0[3]
UA LAX-ORD JUN 9>2.0[10] JUL 10>9[10]
UA LAX-PHX JUN 3>0[3]
UA LAX-PRC JUN 0.9>0.2[1.0]
UA LAX-PSP JUN 0.5>0[1.0]
UA LAX-RAP JUN 0.3>0[0.1]
UA LAX-RDD JUN 0.9>0[1.0]
UA LAX-RDM JUN 1.3>0[1.0]
UA LAX-RNO JUN 2>0[2]
UA LAX-SAN JUN 4>0[5]
UA LAX-SAT JUN 1.8>0[1.8]
UA LAX-SBA JUN 3>0[3]
UA LAX-SBP JUN 3>0[3]
UA LAX-SEA JUN 1.8>0[3]
UA LAX-SFO JUN 10>4[11] JUL 11>10[12]
UA LAX-SLC JUN 1.8>0[2]
UA LAX-SMF JUN 3>0[3]
UA LAX-YVR JUN 1.8>0[1.8]
UA LBL-PUB JUN 0.1>1.0[0.8]
UA LEX-ORD JUN 3>1.6[4]
UA LGA-ORD JUN 13>2.0[15] JUL 14>12[15]
UA LIH-SFO JUN 1.9>0.7[2]
UA LIT-ORD JUN 3>0[3]
UA LNK-ORD JUN 4>1.6[4]
UA LWB-ORD JUN 1.3>1.0[1.0]
UA MBS-MKG JUN 0.1>0.5[0]
UA MBS-ORD JUN 3>0.5[3]
UA MCI-ORD JUN 5>1.9[6]
UA MCI-SFO JUN 1.8>0[2.0]
UA MCO-ORD JUN 5>1.0[6]
UA MCO-SFO JUN 3>0[3]
UA MDT-ORD JUN 4>1.7[4]
UA MEM-ORD JUN 3>0[4]
UA MFR-SFO JUN 4>1.6[4]
UA MIA-ORD JUN 1.8>0[2]
UA MKE-SFO JUN 0.9>0[0]
UA MKG-ORD JUN 3>0.5[2]
UA MLI-ORD JUN 4>1.7[4]
UA MRY-SFO JUN 1.9>0.7[2]
UA MSN-ORD JUN 7>2.0[8] JUL 8>7[8]
UA MSN-SFO JUN 0.9>0[1.0]
UA MSO-ORD JUN 1.0>0[1.0]
UA MSO-SFO JUN 0.9>0[0.8]
UA MSP-ORD JUN 8>2.0[8] JUL 8>7[9]
UA MSP-SFO JUN 1.8>0[1.7]
UA MSY-ORD JUN 3>0[2]
UA MTJ-ORD JUN 1.0>0[1.0]
UA MYR-ORD JUN 1.2>0.5[1.2]
UA OGG-ORD JUN 0.9>0[0.9]
UA OGG-SFO JUN 4>0.9[5]
UA OGS-ORD JUN 0.7>0[0.7]
UA OKC-ORD JUN 3>0[3]
UA OKC-SFO JUN 0.9>0[1.0]
UA OMA-ORD JUN 5>1.9[5]
UA OMA-SFO JUN 1.8>0[1.8]
UA ONT-SFO JUN 5>0.6[6]
UA ORD-ORF JUN 3>1.9[4]
UA ORD-PAH JUN 1.9>0.9[1.8]
UA ORD-PDX JUN 4>0[4]
UA ORD-PHL JUN 6>1.9[6]
UA ORD-PHX JUN 4>1.0[4]
UA ORD-PIA JUN 5>1.6[5]
UA ORD-PIT JUN 6>2.0[6]
UA ORD-PNS JUN 1.8>0[2]
UA ORD-PSC JUN 0.9>0[0]
UA ORD-PVD JUN 3>0[3]
UA ORD-PWM JUN 3>1.0[2]
UA ORD-RAP JUN 1.9>0[3]
UA ORD-RDM JUN 0.9>0[0.8]
UA ORD-RDU JUN 5>2.0[6]
UA ORD-RIC JUN 5>1.9[4]
UA ORD-RNO JUN 0.9>0[1.0]
UA ORD-ROA JUN 3>1.6[3]
UA ORD-ROC JUN 4>1.6[4]
UA ORD-RST JUN 2>0.6[3]
UA ORD-RSW JUN 2>1.0[2]
UA ORD-SAN JUN 5>1.0[4]
UA ORD-SAT JUN 4>1.0[4]
UA ORD-SAV JUN 3>0[3]
UA ORD-SBA JUN 0.9>0[0]
UA ORD-SBN JUN 6>1.6[4]
UA ORD-SCE JUN 3>0.7[3]
UA ORD-SDF JUN 6>1.7[6]
UA ORD-SEA JUN 4>0.9[5]
UA ORD-SFO JUN 12>3[13] JUL 13>11[13]
UA ORD-SGF JUN 4>0[4]
UA ORD-SJC JUN 0.9>0[1.7]
UA ORD-SLC JUN 4>0[3]
UA ORD-SLN JUN 0.9>0[0.8]
UA ORD-SMF JUN 3>0[3]
UA ORD-SNA JUN 3>0[3]
UA ORD-SPI JUN 2>0.5[3]
UA ORD-STL JUN 7>1.9[8] JUL 8>7[8]
UA ORD-SYR JUN 5>1.7[5]
UA ORD-TPA JUN 3>1.0[3]
UA ORD-TUL JUN 3>0[4]
UA ORD-TUS JUN 0.9>0[0.6]
UA ORD-TVC JUN 5>1.8[4]
UA ORD-TYS JUN 4>1.6[5]
UA ORD-XNA JUN 4>0.6[4]
UA ORD-YHZ JUN 0.9>0[0.8]
UA ORD-YOW JUN 3>0[0.5]
UA ORD-YQB JUN 0.9>0[2]
UA ORD-YUL JUN 3>0[3]
UA ORD-YVR JUN 3>0[4]
UA ORD-YWG JUN 1.8>0[2]
UA ORD-YYC JUN 3>0[3]
UA ORD-YYZ JUN 6>0[7] JUL 7>6[7]
UA OTH-SFO JUN 1.0>0.6[1.0]
UA PDX-SFO JUN 7>2.0[7] JUL 8>7[8]
UA PHL-SFO JUN 1.8>0[2.0]
UA PHX-SFO JUN 4>1.0[5]
UA PIT-SFO JUN 1.8>0[2.0]
UA PSC-SFO JUN 1.8>0[1.0]
UA PSP-SFO JUN 3>1.0[3]
UA RAP-SFO JUN 0.3>0[0.1]
UA RDD-SFO JUN 3>1.0[3]
UA RDM-SFO JUN 5>1.6[5]
UA RDU-SFO JUN 1.8>0[2.0]
UA RIW-RKS JUN 0.1>0.7[0]
UA RNO-SFO JUN 5>2.0[4]
UA SAN-SFO JUN 8>2.0[8] JUL 9>8[8]
UA SAT-SFO JUN 0.9>0[1.0]
UA SBA-SFO JUN 6>1.6[5]
UA SBP-SFO JUN 5>1.6[4]
UA SEA-SFO JUN 8>2.0[9] JUL 8>7[9]
UA SFO-SLC JUN 5>1.0[5]
UA SFO-SMF JUN 5>1.0[5]
UA SFO-SNA JUN 6>2.0[7]
UA SFO-STL JUN 1.8>0[2.0]
UA SFO-STS JUN 1.0>0.5[1.0]
UA SFO-TPA JUN 1.8>0[1.8]
UA SFO-TUS JUN 3>1.7[3]
UA SFO-YVR JUN 5>0[5]
UA SFO-YYC JUN 1.8>0[2.0]
UA SFO-YYZ JUN 0.9>0[2]
VB GDL-IAH SEP 0>0.3[0] OCT 0>0.3[0] NOV 0>0.3[0] DEC 0>0.3[0.5] JAN 0>0.3[0.1] FEB 0>0.3[0]
VB GDL-LAX SEP 1.0>1.7[1.0] OCT 0.7>1.7[1.5] NOV 0>1.7[1.0] DEC 0>1.7[1.4] JAN 0>1.7[1.5] FEB 0>1.7[1.4]
VB MLM-ORD DEC 0>0.2[0.3]
VB MTY-SAT NOV 0>0.3[0] DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0]
WK LAS-ZRH JUN 0.4>0.1[0.6]
WN gives up on Intl for a while
WN ATL-CUN OCT 0.2>0[0.5]
WN AUA-BWI AUG 0.3>0[0.5] SEP 0.3>0[0.1] OCT 0.4>0[0.3]
WN AUA-FLL AUG 0.7>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0]
WN BWI-NAS AUG 0.5>1.0[0.2] SEP 0.1>1.0[0.1] OCT 0.2>1.0[0.3]
WN BWI-PUJ AUG 0.7>0[1.5] SEP 1.0>0[1.0] OCT 1.1>0[1.1]
WN BZE-HOU AUG 0.7>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0]
WN CUN-FLL AUG 0.7>0[1.2] SEP 1.0>0[1.0] OCT 1.0>0[1.0]
WN CUN-MDW AUG 0.8>0[1.2] SEP 1.0>0[1.1] OCT 1.2>0[1.1]
WN CUN-STL AUG 0.2>0[0.2] OCT 0.8>0[1.0]
WN CZM-HOU AUG 0.7>0[0] SEP 0.4>0[0] OCT 0.8>0[0]
WN DEN-PVR OCT 0.2>0[0.1]
WN FLL-GCM AUG 0.5>0[1.0] SEP 0.3>0[0.3] OCT 0.5>0[0.7]
WN FLL-HAV AUG 2>0[3] SEP 3>0[3] OCT 3>0[3]
WN FLL-MBJ AUG 1.4>0[2] SEP 1.2>0[2] OCT 1.5>0[2]
WN FLL-NAS AUG 1.4>0[2] SEP 2>0[2] OCT 1.9>0[2]
WN FLL-PLS AUG 0.5>0[1.0] SEP 0.3>0[0.3] OCT 0.3>0[0.3]
WN FLL-PUJ AUG 0.7>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0]
WN FLL-SJO AUG 0.7>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0]
WN HOU-LIR AUG 0.5>0[1.1] SEP 0.3>0[0.3] OCT 0.3>0[0.3]
WN HOU-MBJ AUG 0.2>0[0.5] SEP 0.3>0[0.3] OCT 0.8>0[1.0]
WN HOU-PVR AUG 0.7>0[1.1] SEP 1.0>0[1.0] OCT 1.0>0.7[1.0]
WN HOU-SJO AUG 0.7>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0]
*WN LAS-LGB JUN 0>0.9[3] JUL 0>1.2[3] AUG 0.4>0.7[3]
WN LAX-SJD AUG 0.2>0[0.7] SEP 0.3>0[0.7] OCT 0.3>0[0.7]
WN MBJ-MDW AUG 0.2>0[0.3] SEP 0.3>0[0.6] OCT 0.3>0[0.3]
WN MDW-PUJ AUG 0.2>0[0.2] SEP 0.3>0[0.3] OCT 0.3>0[0.3]
WN OAK-SJD AUG 0.2>0[0.3] SEP 0.3>0[0.3] OCT 0.3>0[0.7]
WN OGG-SAN AUG 0.7>0[0] SEP 1.0>0[0] OCT 1.0>0[0]
WN PVR-SAN AUG 0.2>0[0.1] OCT 0.2>0[0.3]
WN SAN-SJD AUG 0.7>0[1.0] SEP 1.0>0[1.0] OCT 0.8>0[1.0]
WN SJD-SMF OCT 0.2>0[0.1]
WO AZA-YEG JUL 0.3>0[0] AUG 0.3>0[0]
WO LAS-YEG JUL 0.8>0[1.0] AUG 0.9>0[1.0]
WO LAS-YHM JUL 0.6>0[0.5] AUG 0.5>0[0.6]
WO LAS-YWG JUL 0.3>0[0] AUG 0.3>0[0]
WO LAS-YXX JUL 0.3>0[0.3] AUG 0.3>0[0.3]
WS ATL-YYC JUN 0.9>0.2[1.0]
WS AUS-YYC JUN 0.2>0[0.3]
WS BNA-YYC JUN 0.4>0[0.4]
WS BNA-YYZ JUN 1.1>0[1.4]
WS BOS-YYC JUN 0.8>0[0]
WS BOS-YYZ JUN 1.7>0[3]
WS DEN-YYC JUN 0.5>0[0.6]
WS FLL-YYZ JUN 0.6>0[0.9]
WS HNL-YVR JUN 0.9>0[1.0]
WS IAH-YYC JUN 1.5>0[1.8]
WS JFK-YYC JUN 0.7>0[1.0]
WS LAS-YEG JUN 0.5>0[0.6]
WS LAS-YVR JUN 1.4>0[1.6]
WS LAS-YWG JUN 0.2>0[0.3]
WS LAS-YYC JUN 3>0.0[3]
WS LAS-YYZ JUN 1.6>0[1.9]
WS LAX-YEG JUN 0.9>0[1.0]
WS LAX-YVR JUN 3>0.2[3]
WS LAX-YYC JUN 1.6>0.2[2]
WS LAX-YYZ JUN 1.6>0[2]
WS LGA-YYZ JUN 6>0.2[7] JUL 7>6[7]
WS MCO-YYC JUN 0.3>0[0.2]
WS MCO-YYZ JUN 1.7>0.0[2.0]
WS OGG-YVR JUN 0.9>0[1.0]
WS PDX-YYC JUN 1.7>0[1.0]
WS PHX-YYC JUN 1.6>0[2]
WS PSP-YVR JUN 0.3>0[0.4]
WS PSP-YYC JUN 0.6>0[0.7]
WS RSW-YYZ JUN 0.4>0[0.4]
WS SAN-YVR JUN 0.3>0[0.3]
WS SAN-YYC JUN 0.3>0[0.5]
WS SFO-YVR JUN 1.7>0[2]
WS SFO-YYC JUN 1.6>0[2]
WS SNA-YVR JUN 0.9>0[1.0]
WS TPA-YYZ JUN 0.4>0[0.4]
jfklganyc
Re: OAG Changes 5/10/2020: JUNE DECIMATION; DL Suspends BUR/CAK/HPN/LGB/MDW/MHT/OAK/PVD/SWF Till Fall
Sun May 10, 2020 11:53 am
I saw LGB and couldnt help but chuckle given the other thread.
That aside, the mess continuues
jrkmsp
Sun May 10, 2020 12:14 pm
Interesting that DL seems to be canceling its plan to move to PKX for a while, with a planned resumption of PEK in September and October. Maybe they’ll move at the IATA summer/winter split.
chonetsao
Sun May 10, 2020 12:21 pm
The Australian - USA market is temporarily dead.
It also looks CX is not operating any flight between US and Hong Kong in June. Is that a mis file?
tphuang
Sun May 10, 2020 12:34 pm
Good morning enilria and thanks for the hard work.
DL’s early June cuts on coastal hubs + focus cities. In May they made another cut closer in. Again, SEA has far away the most service with LAX trailing quite a bit. I think it’s clear at this point DL is fully intend on fighting it out at AS and getting as many seat flown as possible.
SEA - 60 flights to 30 destinations
LAX - 39 flights to 19 destinations
BOS - 15 flights to ATL/DTW/MSP/SLC/JFK/LGA
RDU - 7 flights to ATL/DTW/MSP/LGA
RDU - 9 flights to ATL/DTW/MSP/LGA
This has to be a mistake right?
I believe they said due to booking trends, they are restoring some June capacity so they are cutting 90% instead of 95% of capacity.
From the southwest thread, “WN is restarting service to CUN, SJD, MBJ, HAV, and NAS on June 7. PVR is tentatively scheduled for Oct. 8 and the rest Oct. 30.”
weird that FLL-HAV is showing 0s here and same with FLL/HOU-MBJ and LAX/OAK/SAN-SJD
Chuska
Sun May 10, 2020 12:35 pm
AA reinstating some Eagle flights back to LAX effective July 7 (other than the few to PHX and SFO mentioned last week). They're showing up as fractions (ELP-LAX .8, ABQ-LAX 1.6) since they're not starting til July 7 but they will be daily flights (ELP-1, ABQ-2, ...).
LAX-OKC was an Eagle market and is now showing as mainline A319!
Mucho Gracias Enilria!
lavalampluva
Sun May 10, 2020 12:37 pm
Is this a tag? :?:
Remind me to send a thank you note to Mr. Boeing.
EIDL
Sun May 10, 2020 1:29 pm
MSP isn't an allowed port of entry currently right? EI likely have a specific customer for MSP pushing for service, cargo or pax, so tagging to BOS would be sensible
jfklganyc
Sun May 10, 2020 1:30 pm
They need SEA as a pacific gateway.
They need JFK as an Atlantic gateway.
They need LGA to supplement JFK.
Beyond that everything else coastal is gone going forward
ZazuPIT
Sun May 10, 2020 1:38 pm
Does anyone really think Norwegian is going to actually operate all those flights listed in June??? Seems unlikely to me.
pmanni1
Sun May 10, 2020 2:01 pm
Wow DL at CVG dropped 20 routes which is just about everything.
rajincajun01
Sun May 10, 2020 2:09 pm
DL has to keep as many seats in/out of SEA as possible as that is how SEA allocates gates. If they cancel and AS doesn’t, AS will gain gates.
A319 A320 A321 A332 B1900 B717 B727 B737 B757 B767 B777 B787 CR2 CR7 CRJ9 E120 ERJ135 ERJ145 L1011 MD80 SF340 AvGeek Superstore
MIflyer12
Sun May 10, 2020 2:15 pm
What's the look-back period for the next SEA gate allocation?
SELMER40
Sun May 10, 2020 2:32 pm
September and October are LOW season in most of these markets even in good times.
Teaching this old dog a new trick
a350lover
Sun May 10, 2020 2:42 pm
Could authorities see in all these routes still being offered any sign of "commercial fraud" by Norwegian?
It is quite impossible Norwegian will be able to fly a route like BCN-LAX when they have internally informed crews at both ends of these routes they are not longer needed and their bases shut down. Crews haven't been fired yet, but the inner agreements between the Norwegian Group and its subsidiaries have been cancelled. So, what's the point in selling tickets days after that decision was made?
I know many airlines everywhere are making difficult for customers to get refunds, instead they offer vouchers for future bookings with the airline. This situation with Norwegian looks to me quite ugly: if you want to fly LAX-LGW and pay for that, it doesn't make any sense you could end up with a $400 voucher to fly on an airline which operates right now just a little bunch of short-haul routes in Norway. Well, you could always book 20 rides for Oslo-Bergen, one after another...
Midwestindy
Sun May 10, 2020 3:14 pm
These aren't reflecting reduced frequencies, it is showing that DY has pushed the start date of these routes back until mid/late-June.
You could say the same about nearly every other carrier as well, hardly any US carrier has updated its July schedule yet, and DL didn't put out its June schedule until Saturday morning....I certainly wouldn't consider that commercial fraud
Status for 2019/2020: AAdvantage Platinum, Delta Gold, Southwest A-List
CIDFlyer
Sun May 10, 2020 3:25 pm
Looks like DL rolling forward it’s May Schedule. UA has some deep cuts as well some cities lose DEN and IAH flights all together. Of note near me I see my hometown loses its 3 DEN flights. DL still one flight a day to MSP. DSM losing IAH
a350lover
Sun May 10, 2020 3:33 pm
Correct. All airlines are more or less doing the same. However, DL is more likely to be able to amend the booking and offer reroutings for their passengers than an airline which has been refunded this week as an operator which flies just 7 planes to domestic places in Norway until minimum next year.
I suspect Norwegian is getting customers money but 100% they know they won't fly any of those frequencies, and either they could offer any realistic alternative route.
DTWLAX
Sun May 10, 2020 3:35 pm
DL has no flights ATL-SNA. I thought they would at least keep a couple of flights a week.
KL adding BOS?
Chuska
Sun May 10, 2020 3:41 pm
DL will be down to just one per day out of ABQ, a SkyWest flight to SLC. The regionals are really saving AA, DL, and UA for the CARES Act at cities that traditionally had mainline flights.
enilria
Sun May 10, 2020 3:45 pm
EI misfiled a B6 code share I'm sure.
NK said in their call they were looking at increasing June/July.
DL and AS both have not cut SEA as much as it needs to be cut. DL is trying to kill AS. Sucks.
No idea if they misfiled
Is this a tag? :?:
No. It's an A320 and an A330 is on BOS-DUB. I think they just didn't file the "duplicate" field indicating it is a code share appearing under another carrier's filing.
A lot of this flying that appears to come back in SEP is just wishful thinking.
If you look, everything is cut in half. They probably just pushed the restart 15 days.
joeblow10
Sun May 10, 2020 3:48 pm
Obviously I totally get why carriers are cutting flights, but the lack of connectivity these reductions have led to is stunning. June looks to be slightly better than May, but this month, I can't even connect where I'm going on UA. Next month there is one option where I'm at daily via DEN
TW870
Sun May 10, 2020 4:12 pm
Am I right in deducing that DL is actually a little smaller in June than it was in May? It looks like several smaller stations are just being cut back to service to the closes hub in order to maintain CARES eligibility. I commute out of DAY, for example, and we had ATL in May but it is gone for June, with DTW being the only link to the system.
Also, what is the scoop on DL restarting LAX-SYD in June? Is that for real, or something that will get trimmed closer in?
Enilria thank you as always for this herculean task!
maps4ltd
Sun May 10, 2020 4:22 pm
Is CVG-CDG still on for July? I'm supposed to fly STL-CVG-CDG-FCO and I have a nagging hunch that something will change.
Delta Gold Medallion
tphuang
Sun May 10, 2020 4:56 pm
I see 163 flights a day by AS out of SEA. A lot of flights. That seems like it will have to be trimmed further.
As for DL, I mean this just shows they are clearly valuing the need to keep SEA large through this. Outside of BK, I see no possibility of them giving up or downsizing SEA. In fact, I'd expect their SEA operation to recover to pre-COVID size fairly quickly. Which are definitely not the case for BOS/CVG/RDU. Even LAX will take a while to regain its old size based on what they are doing here.
DL seems to view SEA as an integral part of their network to capture demand from PNW and AK.
32andBelow
Sun May 10, 2020 4:59 pm
ANC-PDX cancelled for June.
pezzy669
Sun May 10, 2020 5:05 pm
It appears DL is starting to do the cuts at smaller stations. I purchased a bunch of fire sale flights ATL-MSP-BJI (Bemidji) for the summer to go to my parents lake house - ultra small station with only 2 daily CR2 flights to MSP and no other carriers. Was surprised to see DL maintaining the 2 flights to BJI up until today but this time they cut it down to one daily which royally screwed up my schedule for June so that trip is going to be cancelled - feeling my scheduled trips in July and Aug are going to be the same story.
AirFiero
Sun May 10, 2020 5:06 pm
Thanks as always enilria. But I might need to change my “coffee with enilria” to vodka.
jayunited
Sun May 10, 2020 5:29 pm
Not sure how I feel about UA adding flights in June to the state of Hawaii. Hawaii has asked tourist to stay away for the time being but yet UA is adding flights in June.
AA seems to have come to their senses and have canceled their planned June resumption or their ORD-DUB and ORD-ATH routes.
As always thank you enilria I appreciate your dedication to these threads every Sunday.
vmanAA738
Sun May 10, 2020 5:48 pm
June cuts at CVG:
--air canada to toronto gone
--delta to atlanta cut from 7/daily to 3/daily; salt lake city down to 1/daily; minneapolis down to 2/daily; LGA down to 1 daily; detroit down to 2/daily
--delta to austin, hartford, boston, baltimore, charlotte, washington national, denver, dallas, newark, ft lauderdale, houston, jfk, las vegas, LA, kansas city, orlando, chicago, philadelphia, raleigh, ft myers, seattle, san francisco, st louis, tampa, toronto eliminated
--allegiant cutting back their june sun flights
--united eliminates houston and denver; cut newark to less than daily; washington dulles & chicago down to 1 and 2 daily
Basically Delta is shutting down nearly all of its p2p flying at Cincinnati......if you want to go anywhere you're gonna have to connect somewhere unless it's NYC.
Never thought I would see the day where Delta was down to 9 flights a day at CVG.......
Cointrin330
Sun May 10, 2020 6:00 pm
Isn't DY voluntarily grounded until 2021? Doubt you will see ANY DY TATL service for the rest of 2020 and probably unlikely they will ever fly again.
oosnowrat
Sun May 10, 2020 6:01 pm
That is a SkyWest prorate station. Might even be an EAS route, which would explain why it wasn't cut sooner.
TW870
Sun May 10, 2020 6:33 pm
I'll be curious to see where the ASM rock bottom is in major global markets. I can't keep all the airlines cuts lined up in my head, but I think the overall ASM footprint will be smaller for U.S. domestic in June that it was for May - even though total boardings will likely be higher. I think it will be also interesting to see where the rock bottoms are as a comparison to how countries and regions have done with the response to the pandemic. I would assume that you will see Asia-Europe, and especially markets like Germany-South Korea, Taiwain, Singapore, etc., hit bottom and rebound far earlier than other markets because of the success that those places have had in controlling the virus.
aaway
Sun May 10, 2020 6:51 pm
In the current environment, I'd find it surprising that the Port wouldn't temporarily waive the usage requirement. LAWA has done this for LAX - in place until the end of May, but likely to be extended. I believe another poster commented above that the aggressive scheduling may be more indicative of SEA's place strategically to DL.
"The greatest mistake you can make in life is to continually be afraid you will make one." - Elbert Hubbard
hiflyeras
Sun May 10, 2020 7:17 pm
AS appears to be adding flights over their May schedule. Do they see some demand or are they calculating that this is the amount they need for next year's SEA gate allocation? People are getting itchy to get out of their houses, particularly in the Puget Sound area. We were the first in the US to feel the effects of covid and many people started self-quarantining in early March, before the 'official' requests from local and state government. I know a number of people that are starting to think about travel out of SEA later this summer and fall.
hiflyeras
please delete
tphuang
Sun May 10, 2020 8:02 pm
if they are doing 163 departures out of SEA alone, that's at least 325 flights they have going in and out of SEA a daily basis. I'm sure they have non-SEA flights. Their number of flight will probably be only 60% down, which is a huge increase over May.
Even if people in Seattle area are looking to get out, i doubt demand has gone back to 40% of 2019 level.
It seems crazy to me SEA will have that many flights. Probably more flights than JFK/LGA/EWR combined or more flights than LAX.
hiflyeras
Sun May 10, 2020 8:23 pm
Agree that it seems crazy! I don't think they'll actually operate all of those flights...I'm sure a lot will be cancelled in the end. Maybe call it an 'aspirational' schedule by both AS and DL. ;-)
kearnet
Sun May 10, 2020 8:32 pm
I think I can safely assume BA PHX - LHR is also axed for June?
C402 9K | B1900D US | ATR72 AA | DHC8 US | CRJ2 US | E175 UA | E190 B6 | D93 US | M88 US/AA | 732 US | 733 US/WN | 734 US | 73G WN | B738 FJ/QF | B752 US/AA | B762 DL | B77W EK | F28 US | F100 US | A319 US | A320 B6 | A332 FJ | A380 EK
FlyingElvii
Sun May 10, 2020 8:39 pm
vmanAA738 wrote:
June cuts at CVG:
Just Six at Indy.
Everything gone, including LGA.
Argenbright/DGS folks getting lay-off and terminations.
paulsaz
Sun May 10, 2020 9:17 pm
PHX-LHR is scheduled to resume Oct 2020.
All opinions are my own and do not reflect on my employer in any way.
NWAESC
Sun May 10, 2020 9:19 pm
What functions do Argenbright/DGS handle for DL at IND? Will DL be insourcing that work?
"Nothing ever happens here, " I said. "I just wait."
rjbesikof
Sun May 10, 2020 9:56 pm
I think that after this, Delta will scale down Tokyo. Of the 7 destinations that had Tokyo service on Delta, 3 were on the West Coast, 2 were in the North, 1 was in the South, and 1 was in Hawaii. That's a lot of overlap for a long haul international destination that is not a hub for any of Delta's partners.
BenflysDTW
Sun May 10, 2020 10:35 pm
I noticed that Delta added DTW-BGR which is a route they cut back in January of 2018. They brought it back last summer for a dozen or so round trips in the summer flying on only on Saturday’s.
After this they pulled it out of the schedule for good.
Now it seems to be daily for the entire month of June. No service from JFK/LGA which may explain this.
Very strange if you ask me.
Boof02671
Sun May 10, 2020 10:40 pm
I see your losing all your ATL flights.
LabQuest
Sun May 10, 2020 10:41 pm
Is there a European version of this list? What kind of cuts are we seeing over there?
kearnet
Sun May 10, 2020 11:22 pm
Thanks for the reply. Now I know I can get my money back to use for my apartment move.
AVLAirlineFreq
Sun May 10, 2020 11:30 pm
Thanks for doing this, enilria.
Although I admit that whereas I used to eagerly anticipate this early in the day, it wasn't until after 5:00 PM today when I went looking for it. :(
PSU.DTW.SCE
Sun May 10, 2020 11:31 pm
I noticed for June, that the SkyWest OO routes that were pro-rate/at-risk and non-EAS for DL are switching to Endeavor 9E. The CR2 markets like ERI, AVP, SCE. I haven’t looked at all of them but a sample.
I believe Skywest said they are removing 55 CR2s from Delta flying by then end of 2020. A subset of those aircraft are owned by DL but at least 30 are owned by OO
NWAESC
Mon May 11, 2020 1:09 am
Been gone for over a month now...
