Wingtips56
PAE/Paine Field 10-week suspension
Sat May 16, 2020 11:53 pm
Apologies if this is already posted, but I didn't find it.
It appears that airline flights will be suspended at PAE/Paine Field, Everett, Washington, for 10 weeks: 22 May through 31 July for maintenance and repairs. Rather than work around the COVID-19 reduced schedules, the operator decided to just close it down and get it all done.
My source: The Sacramento Bee, but they picked it up from the Associated Press. https://www.sacbee.com/news/article242784576.html
Worked for WestAir, Apollo Airways, Desert Pacific, Western, AirCal and American Airlines (Retired). Flight Memory: 181 airports, 92 airlines, 78 a/c types, 403 routes, 58 countries (by air), 6 continents. 1,119,414 passenger miles.
Home airport : CEC
DL747400
Re: PAE/Paine Field 10-week suspension
Sun May 17, 2020 12:21 am
Makes sense to get the work done now. With so many people not traveling at present, I don't see this affecting any significant number of people.
From First to Worst: The history of Airliners.net.
All posts reflect my opinions, not those of my employer or any other company.
enilria
Sun May 17, 2020 1:58 am
I suspect AS suggested this
ericm2031
Sun May 17, 2020 2:38 am
I must have missed it, but didn't realize UA has been running PAE-PDX-DEN as a tag flight (but you can't book a connection in PDX and have to go to DEN first, as is the same with the other UA tag flights vs AS tag flights). It would make more sense to me to stop at a ton of other smaller airports between PAE and DEN and consolidate, than a large city like PDX. Now that I'm looking at it more, it's also surprising UA is only running 1 E75 on PDX-DEN (vs much smaller airports running same frequency and gauge, but no WN competition).
With regards to the construction...if this is new ramp space, what happened that would have caused a pre-COVID crisis 4 month construction project on a brand new ramp?
alasizon
Sun May 17, 2020 3:07 am
I believe only the immediate ground around the terminal is new, the rest I believe is the existing asphalt. Perhaps the asphalt needs repair which cuts off access to the terminal?
mwthekoopinator
Sun May 17, 2020 3:16 am
The ramp is new, but the asphalt is too soft for the E175, causing them to sink into the ground a bit. They've broken several shear pins on pushback thanks to that. This should completely redo all that new pavement so planes don't sink anymore.
FATFlyer
Sun May 17, 2020 3:05 pm
The Seattle Times said they will replace the asphalt with concrete.
"Travel is fatal to prejudice, bigotry, and narrow-mindedness." - Mark Twain
madpropsyo
Sun May 17, 2020 4:20 pm
Oof, you'll never skip an opportunity to take a shot at AS will you?
mxaxai
Sun May 17, 2020 5:13 pm
Presumably Boeing will be unaffected by this? Since the construction is focused around the ramp and not the runways & taxiways.
Cubsrule
Sun May 17, 2020 5:42 pm
How’s it a shot? Presumably AS and the airport had been in touch about the pavement issues. Of course AS would suggest making the repairs during a period of historically low demand (and also historically low road traffic, which takes away a big part of PAE’s appeal). If the issue had been at, say, DAL, you can almost guarantee WN would have done the same thing.
ericm2031
Sun May 17, 2020 5:58 pm
Sounds like a pretty poor design then considering WN was planning on using 737s and AS was always expected to upgauge in the future as well.
alasizon
Sun May 17, 2020 6:26 pm
Sounds like a very poor design or a manufacturing defect. I can't imagine the original design called for asphalt that didn't meet normal standards.
wedgetail737
Sun May 17, 2020 7:06 pm
I was hoping for additional ramp space for the likes of Kenmore Air or San Juan Airlines, where they can be consolidated into one terminal.
