  • 1
  • 2
  • 3
  • 4
  • 5
  • 13
787pk
Re: PIA A320 (flight PK8303) crashes in Karachi
Fri May 22, 2020 11:53 am
So far 2 survivors are getting reported to be taken to hospital and 1 declared badly injured but will survive.
Polot
Mortyman wrote:
Sad News
If they had so little fuel, I Wonder why they didn't try to land without the front gir deployed... It has been done before ...
My guess is if the fuel starvation is true that they were so focused on the landing gear they were not paying attention to the fuel, or even considering that they were burning more than usual due to the increased drag.
garpd
Fri May 22, 2020 11:58 am
brodeurprice wrote:
https://twitter.com/DanyalGilani/status/1263786354753798144?ref_src=twsrc%5Etfw%7Ctwcamp%5Etweetembed%7Ctwterm%5E1263786354753798144&ref_url=https%3A%2F%2Fwww.dawnnews.tv%2Fnews%2F1132074
This video off of twitter is unsettling to say the least...
Rip to all those on board and on the ground who lost their lives
Look at the blades on that engine. Next to no damaged. That generally means the engine was not operating (spinning) on impact. Generally.
arpdesign.wordpress.com
brodeurprice
Fri May 22, 2020 12:04 pm
That’s an interesting observation, good eye ! Thanks for point it out.
morrisond
Fri May 22, 2020 12:07 pm
zeke wrote:
bennett123 wrote:
Zeke
Would undercarriage issue result in running out of fuel.
Surely they don't cut the fuel upload that close.
I am assuming they would have attempted a gravity gear extension to get the nose wheel down, the fuel consumption after the go around would be around 3 times higher with the gear down and gear doors extended. 30 minutes of normal reserve turns into 10 minutes with gear down and doors out. Reserve fuel is normally calculated in a clean configuration at 1500 ft.
A passenger aircraft would only deploy with 30 minutes reserve? That seems like pushing it awfully close to the line.
Isn't the minimum something like 45 min plus Airline reserve?
According to this Document the old standard was consumption increased by about 2.8 times so Zeke's rule of thumb of 3 seems pretty good.
https://safetyfirst.airbus.com/app/them ... factor.pdf
I would have to guess it's not quite as bad though as only 2 gear down and they would not have flying at speeds up to 250knots where that rule of thumb would apply.
morrisond
Fri May 22, 2020 12:09 pm
Polot wrote:
Mortyman wrote:
Sad News
According to the document I posted above the ECAM would have been telling them they were experiencing higher fuel burn and it should have been screaming at them about the low fuel state (if there was one).
HEXC
Fri May 22, 2020 12:22 pm
IWMBH wrote:
I don't think these survivors where passengers, if you look at the pictures I think we can presume no one survived.
A person reports having had a close relative on the flight who seems to have survived. Apparently she was in contact with that passenger after the crash.
https://twitter.com/zainabimam/status/1 ... 87680?s=20
asuflyer
Fri May 22, 2020 12:23 pm
ATC recording has pilot saying he lost an engine:
https://twitter.com/breakingavnews/stat ... 3141218304
casinterest
Fri May 22, 2020 12:26 pm
Sounds like Engines, but is hard to make out.
Where ever you go, there you are.
maint123
Fri May 22, 2020 12:29 pm
IWMBH wrote:
maint123 wrote:
Pakistan has had 5 airforce crashes this year and now this civilian airliner crash. It's a bad year for aviation in Pakistan.
If I remember, another PIA flight crashed 3 or 4 years back in Pakistan ?
There last fatal crash was back in 2006 when PK688 crashed. But, there have been two write-offs since then.
Not really -
"In 2016, a Pakistan International Airlines (PIA) plane carrying 48 people, including famous pop singer-turned-Islamic preacher Junaid Jamshed, his wife and Deputy Commissioner Chitral Osama Warraich, crashed and burst into flames in a hilly area near Abbottabad after facing engine problems.
In 2012, a Bhoja Airline plane, a Boeing 737 carrying 121 passengers and six crew members, crashed near Islamabad just just before touchdown.
The worst aviation tragedy on Pakistani soil came in July 2010 when an Airbus 321 passenger jet operated by the private airline Airblue crashed into hills overlooking Islamabad. The flight was coming from Karachi.
All 152 people on board were killed in the accident, which occurred amid heavy rain and poor visibility."
The 2 in 2012 and 2010 are private Pakistani airlines.
Many airlines in some countries share maintenance facilities. Could be a factor.
Ishrion
Fri May 22, 2020 12:30 pm
Karachi Airport appears to be continuing normal operations. This video captured footage of the crash site while they were landing:
https://twitter.com/wpcion/status/12638 ... 13889?s=21
Draken21fx
Fri May 22, 2020 12:31 pm
Dont know how genuine the recording is and I am not really good with accents but I get the impression the pilot says: "We lost engines" not engine (which is pretty important detail in this case).
edu2703
Fri May 22, 2020 12:32 pm
maint123
Fri May 22, 2020 12:35 pm
Polot wrote:
Mortyman wrote:
Sad News
Or since they were going in for a belly landing, too much fuel could have been ejected to avoid a serious fire.
LH658
edu2703 wrote:
One of the videos shows the plane crashing, but the footage is horrible quality.
Normally alternate fuel plus 30 minutes reserve, if they had HDD as the alternate thats only 81 nm away.
Fri May 22, 2020 12:37 pm
LH658 wrote:
Towards the end looks like something else in the sky as well above the crash.
Superboi
Fri May 22, 2020 12:40 pm
maint123 wrote:
Polot wrote:
Mortyman wrote:
Sad News
This seems a very possible scenario
mxaxai
Fri May 22, 2020 12:42 pm
Looks like they only needed some 100 - 200m extra to miss the houses and crashland on airport ground (which would be relatively free of obstacles). Or deviated a bit to the right, for example by choosing runway 25R.
mxaxai
Fri May 22, 2020 12:43 pm
The A320 cannot dump fuel.
AntonioMartin
Fri May 22, 2020 12:44 pm
Reports are confusing so far...some sources claim 107 people missing, others claimed no one survived, others claim there are survivors indeed...who knows but Im praying for the best under the circumstances..
maint123
Fri May 22, 2020 12:48 pm
Ok.
At the start of the audio recording, before the the first approach, the pilot says he is comfortable now ,we can make it . Does not seem to be normal landing talk. I suspect miscalculation in initial fuel load.
https://twitter.com/i/status/1263801039809110016
At 18:16 in the video you can see the densely populated area where the jet would have come down. It is right under the flight path. I always arrive in Karachi during in the early hours of the morning but this was one of the times I got there during daylight.
https://youtu.be/HYYujUxFkp8
Polot
It’s going to be confusing since the plane crashed into likely occupied buildings/streets. With that when it comes to “survivors” you have to sort out who was on the plane and who was on the ground.
IWMBH
Fri May 22, 2020 12:50 pm
The mayor of Karachi confirmed that there where no survivors on board
https://news.sky.com/story/pakistan-int ... i-11992696
AirlineCritic
Fri May 22, 2020 1:00 pm
Sad day. Thinking about the people impacted by this.
But maybe we are jumping to conclusions quite quickly here. As we know, information in the first few moments is quite error-prone. We have reports of go-around, gear problems, and engines going out. All or none of these may turn out to be true.
If the reports about go-around and gear problem are true, it is possible that something else happened that eventually doomed the flight. Zeke suggests running out of fuel. Possible, but historically we've also had many incidents where one problem leads to too much attention paid to it and pilots missing something else, which then leads to an accident.
It is also possible that whatever caused the gear problem worsened and caused the aircraft to drop. Hydraulics? Electrical? Fire?
It is also possible that there's a crew error while preparing for a gear-up landing, e.g., flying too slow and stalling.
bennett123
Fri May 22, 2020 1:04 pm
If he had lost both engines, (which the ATC tape appears to indicate) would the pilot normally call a mayday?.
SamH123
Fri May 22, 2020 1:07 pm
The view out the window of the crash scene from a later flight shows fairly light grey smoke
I'm not an expert but surely that would imply they had minimal fuel
edit: actually I've seen other photos with thicker smoke, I take this back
Blankbarcode
Fri May 22, 2020 1:09 pm
https://twitter.com/omar_quraishi/statu ... 33346?s=20
Alleged footage of a survivor being pulled out. Being reported Zafar Masud.
Leaked passenger lists (while I don't agree with them being released so soon) shows someone with that name sitting in 1C.
enilria
Fri May 22, 2020 1:14 pm
Polot wrote:
Mortyman wrote:
Sad News
Landing gear problems make a lot of sense for an aircraft that would have been parked for quite a while until today or yesterday. Those fluids can create big problems if they are not dealt with after storage.
Blankbarcode
Fri May 22, 2020 1:16 pm
enilria wrote:
Polot wrote:
Mortyman wrote:
Sad News
Haven't even thought of that, very good point. Curious if we'll be seeing an increase in issues (hopefully not causing crashes) like this in the future.
Blankbarcode
Fri May 22, 2020 1:24 pm
https://twitter.com/PlaneSpottersPK/sta ... 30752?s=20
Photos circulating of allegedly the aircraft in question after 1st approach, black marks under the engines, RAT deployed.
PanAm788
Fri May 22, 2020 1:25 pm
On AVHerald, they are speculating that on the first approach the gear was not fully locked and the engines made contact with the ground, damaging them. This led them to flameout on the go-around, not fuel starvation. There is even a picture that allegedly shows the plane going around with the RAT deployed and the engines with black skidmarks on the bottom. Would post it here but don't know how. Anyway here is the AVHerald link. http://avherald.com/h?article=4d7a6e9a&opt=0
JibberJim
Fri May 22, 2020 1:27 pm
Given the out of service in recent times, is there anything where the likely first use of full thrust in the first go-around caused a common fuel/engine problem?
IWMBH
Fri May 22, 2020 1:30 pm
Blankbarcode wrote:
https://twitter.com/PlaneSpottersPK/status/1263810587152330752?s=20
Maybe fuel contamination? Just hard to tell with the information we have now.
TutiFruiti
Fri May 22, 2020 1:31 pm
ATC Pilot conversation of Karachi PIA crash
https://youtu.be/LMYnO4p4Mns
rfields5421
Fri May 22, 2020 1:36 pm
Mayday call would only add to problems and not be any help.
The aircraft was already in an emergency situation will the full attention of ATC. Mayday is only to notify ATC and other pilots on the frequency of the emergency. That had already been done.
I'm concerned that the crew was working so hard to solve the gear problem that they did not focus on flying the aircraft correctly. Too often both cockpit crew have been focused on resolving an issue, and allowed another item to become so critical that the flight crashed.
Not all who wander are lost.
Antarius
Fri May 22, 2020 1:41 pm
zeke wrote:
bennett123 wrote:
Zeke
Understood. That's still expected to be sufficient time though right? As in, if they were into their reserves at original approach, wouldn't they have declared a fuel emergency immediately on missed approach?
2020: SFO DFW IAH HOU CLT MEX BIS MIA GUA ORD DTW LGA BOS LHR DUB BFS BHD STN OAK PHL ISP JFK SJC DEN SJU LAS TXL GDL
migs
Fri May 22, 2020 1:43 pm
mxaxai wrote:
AvHerald wrote:
While on second final approach the crew declared Mayday repeatedly reporting they had lost both engines
That seems odd. Even without engines the plane is still controllable, no reason to dive into a residential area.
Controllable perhaps, but avoiding any kind of structure in a densely populated environment while losing speed and height is extremely improbable, especially in approach configuration. Flame out probably unlikely but who are we to say at this early stage.
May all who perished rest in peace.
migs
Fri May 22, 2020 1:46 pm
Unlikely to be fuel contamination after having already been airborne for a substantial amount of time.
Viper911
Looks pretty normal to me, the dark spots look like oil streaks, similar to the pic attached.
https://cdn.planespotters.net/16523/vh-vnk-tiger-airways-australia-airbus-a320-232_PlanespottersNet_492189_41500b17c9_o.jpg
Viper911
by738
Fri May 22, 2020 1:47 pm
those engines look scraped
Blankbarcode
Fri May 22, 2020 1:48 pm
agreed, there's definitely some texture there in the photos
ikolkyo
Fri May 22, 2020 1:51 pm
Viper911
I think the Avherald photo is older considering the tweet it came from, these photos are I believe some of the last moments of the aircraft and they look a lot more than just oil streak to me. The engines look like they had contact with the ground. I could very well be wrong but that is what it looks like to me.
Link: https://twitter.com/planespotterspk/sta ... 30752?s=21
AYVN
Fri May 22, 2020 1:54 pm
Bellylanded and then go around.
garpd
Fri May 22, 2020 1:56 pm
Pay close attention to behind the engines, the off white fuselage lends a good look at what looks like white smoke trailing the No.1 engine.
owaisusmani
Fri May 22, 2020 1:57 pm
In the above photos, the RAT is also clearly visible as deployed. So both engines flamed out? fuel exhaust? double bird strike?
FluidFlow
Fri May 22, 2020 1:58 pm
They must have initiated the go around before they touched down but too late to actually make a go around. Somehow a weird decision. If the gear was not in place, they should have made a go around way earlier so the engines do not ever be close to the ground. That late to make a go around with no gear deployed can only damage the aircraft. At that moment just go through with the belly landing and that is it.
Viper911
Fri May 22, 2020 2:00 pm
Viper911
Seems so, the photos you linked are indeed looking suspicious! Definitely more than your average oil streaks.
Viper911
User001
Fri May 22, 2020 2:01 pm
Zooming in on those photos, the engines certainly look shredded underneath as if they have had contact with the ground. The RAT is deployed and there is a streak of white smoke coming from the engine, so, I think those photos are genuine.
  • 1
  • 2
  • 3
  • 4
  • 5
  • 13
