enilria
OAG Changes 6/7/2020: JULY SHANKED;AA Exits ORH;AS Adds BOI-SFO,Drops MSY-SFO,SAN-SBP/SMF;NK Out of AVL;F9 PHLMCO 6x/day
Sun Jun 07, 2020 11:48 am
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
3E BRL-ORD JUL 0>1.7[2] AUG 0>1.7[2] SEP 0>1.7[2]
3E BRL-STL JUL 0>1.7[1.8] AUG 0>1.7[1.9] SEP 0>1.7[1.9]
3E IWD-MSP JUL 0>0.5[1.0]
3E IWD-ORD JUL 0>1.0[1.9]
3M CHS-FLL JUL 0.5>0[0] AUG 0.6>0[0] SEP 0.6>0[0] OCT 0.6>0[0] NOV 0.6>0[0] DEC 0.6>0[0] JAN 0.6>0[0] FEB 0.6>0[0] MAR 0.6>0[0]
3M CHS-MCO JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0] OCT 1.0>0[0] NOV 1.0>0[0] DEC 1.0>0[0] JAN 1.0>0[0] FEB 1.0>0[0] MAR 1.0>0[0]
3M CHS-TPA JUL 0.4>0[0] AUG 0.4>0[0] SEP 0.4>0[0] OCT 0.4>0[0] NOV 0.4>0[0] DEC 0.4>0[0] JAN 0.4>0[0] FEB 0.4>0[0] MAR 0.4>0[0]
3M FLL-TLH JUL 1.5>0[1.0]
3M HSV-MCO JUL 1.0>0[1.0]
3M TLH-TPA JUL 1.5>0[1.3]
4B ATL-MSL SEP 0.1>4[4] NOV 0>4[3] JAN 0>0.4[4]
4B IWD-MSP SEP 0.0>0.9[0] OCT 0>0.8[0] NOV 0>0.9[0] DEC 0>0.9[0]
4B IWD-ORD SEP 0.6>1.9[0] OCT 0.5>1.8[0] NOV 0.5>1.9[0] DEC 0.5>1.9[0] JAN 0>0.2[0]
4B PDT-PDX SEP 0.1>4[3] OCT 0>3[4] JAN 0>0.4[3]
4O CUN-JFK JUL 1.0>0[0] AUG 0.7>0[0]
4O CUN-LAX JUL 1.0>0[1.1] AUG 0.7>0[1.1]
4O CUN-MIA JUL 0.6>0[0] AUG 0.6>0[0]
4O DFW-MEX JUL 2>0.2[1.9] AUG 2>0.5[1.8]
4O GDL-LAS JUL 0.5>0[1.0] AUG 0.4>0[1.0]
4O GDL-LAX JUL 0.6>0[2] AUG 0.6>0[2]
4O GDL-ORD JUL 0.6>0[1.0] AUG 0.6>0[1.0]
4O GDL-SAT JUL 0.4>0[1.1] AUG 0.4>0[1.1]
4O GDL-SFO JUL 0.6>0[1.0] AUG 0.6>0[1.0]
4O IAH-MEX JUL 2>0.2[1.9] AUG 2>0.4[1.7]
4O IAH-MTY JUL 1.0>0[1.0] AUG 1.0>0[1.0]
4O JFK-MEX JUL 1.0>0[3] AUG 1.0>0[3]
4O LAS-MEX JUL 0.6>0[1.1] AUG 0.6>0[1.0]
4O LAS-MTY JUL 1.0>0[0.5] AUG 1.0>0[0.6]
4O LAX-MEX JUL 2>0[2] AUG 1.9>0.5[1.9]
4O LAX-MTY JUL 0.6>0[0] AUG 0.6>0[0]
4O MCO-MEX JUL 1.0>0[1.3] AUG 1.0>0[1.2]
4O MEX-MIA JUL 1.0>0.1[1.8] AUG 1.0>0.3[1.8]
4O MEX-ORD JUL 2>0[2] AUG 2>0.3[2.0]
4O MEX-SAT JUL 2>0.2[1.8] AUG 2>0.5[1.8]
4O MTY-SAT JUL 1.0>0[0.9] AUG 1.0>0[0.8]
8E KKA-SKK JUL 0.8>1.3[0.9] AUG 0.8>1.3[0.9] SEP 0.9>1.3[0.9] OCT 0.9>1.3[0.9] NOV 0.8>1.2[0.9] DEC 0.8>1.2[0.9] JAN 0.8>1.2[0.9] FEB 0.9>1.3[0.9] MAR 0.9>1.3[0.9]
8E KKA-UNK JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0] FEB 0>0.4[0] MAR 0>0.4[0]
8E KVL-OTZ JUL 0.4>0.8[0.9] AUG 0.4>0.8[0.9] SEP 0.4>0.9[0.9] OCT 0.4>0.9[0.9] NOV 0.4>0.8[0.9] DEC 0.4>0.8[0.9] JAN 0.4>0.8[0.9] FEB 0.4>0.9[0.9] MAR 0.4>0.9[0.9]
8E KVL-WTK JUL 0>0.4[0.5] AUG 0>0.4[0.5] SEP 0>0.4[0.5] OCT 0>0.4[0.5] NOV 0>0.4[0.5] DEC 0>0.4[0.5] JAN 0>0.4[0.5] FEB 0>0.4[0.5] MAR 0>0.4[0.5]
8E OME-SHH JUL 0.8>1.3[1.0] AUG 0.8>1.3[1.0] SEP 0.9>1.3[1.0] OCT 0.9>1.3[1.0] NOV 0.8>1.2[1.0] DEC 0.8>1.2[1.0] JAN 0.8>1.2[1.0] FEB 0.9>1.3[1.0] MAR 0.9>1.3[1.0]
8E OME-TNC JUL 0.4>0[0.4] AUG 0.4>0[0.4] SEP 0.4>0[0.4] OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4] FEB 0.4>0[0.4] MAR 0.4>0[0.4]
8E OTZ-WLK JUL 0>1.7[1.9] AUG 0>1.7[1.9] SEP 0>1.7[1.8] OCT 0>1.7[1.9] NOV 0>1.5[1.9] DEC 0>1.6[1.8] JAN 0>1.6[1.9] FEB 0>1.7[1.9] MAR 0>1.7[1.8]
8E OTZ-WTK JUL 0.8>1.3[1.4] AUG 0.8>1.3[1.4] SEP 0.9>1.3[1.3] OCT 0.9>1.3[1.4] NOV 0.8>1.2[1.4] DEC 0.8>1.2[1.3] JAN 0.8>1.2[1.4] FEB 0.9>1.3[1.4] MAR 0.9>1.3[1.3]
8E SHH-WAA JUL 0>0.4[0] AUG 0>0.4[0] SEP 0>0.4[0] OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0] FEB 0>0.4[0] MAR 0>0.4[0]
8E SKK-UNK JUL 0.8>1.3[0.9] AUG 0.8>1.3[0.9] SEP 0.9>1.3[0.9] OCT 0.9>1.3[0.9] NOV 0.8>1.2[0.9] DEC 0.8>1.2[0.9] JAN 0.8>1.2[0.9] FEB 0.9>1.3[0.9] MAR 0.9>1.3[0.9]
8E TNC-WAA JUL 0.4>0.1[0.4] AUG 0.4>0.1[0.4] SEP 0.4>0.1[0.4] OCT 0.4>0.1[0.4] NOV 0.4>0.1[0.4] DEC 0.4>0.1[0.4] JAN 0.4>0.1[0.4] FEB 0.4>0.1[0.4] MAR 0.4>0.1[0.4]
9X HNL-LNY JUL 0>2[0] AUG 0>2[0] SEP 0>2[0] OCT 0>2[0] NOV 0>2[0] DEC 0>2[0]
AA ABE-CLT JUL 3>1.7[3]
AA ABE-ORD JUL 1.7>0.9[2.0]
AA ABE-PHL JUL 2>0[4]
AA ABI-DFW JUL 6>4[7]
AA ABQ-DFW JUL 7>5[8]
AA ABQ-LAX JUL 1.6>0.7[3]
AA ABQ-ORD JUL 1.7>0.9[2.0]
AA ABQ-PHX JUL 3>1.8[5]
AA ACK-DCA JUL 1.5>1.2[1.6]
AA ACK-LGA JUL 0.8>0.5[1.0]
AA ACT-DFW JUL 4>3[6]
AA AGS-CLT JUL 5>4[6]
AA AGS-DCA JUL 0.8>0[0]
AA AGS-DFW JUL 1.6>0.8[1.0]
AA AGU-DFW JUL 1.8>1.0[2.0]
AA ALB-DCA JUL 3>1.0[4]
AA ALB-ORD JUL 3>1.4[3]
AA ALB-PHL JUL 5>3[6]
AA AMA-DFW JUL 6>5[7]
AA ANC-LAX JUL 0.8>0[0.7]
AA ASE-DFW JUL 1.8>1.1[2]
AA ASE-LAX JUL 0.8>0[1.0]
AA ATH-ORD JUL 0.8>0[1.0]
AA ATL-CLT JUL 7>5[8]
AA ATL-DCA JUL 3>1.0[4]
AA ATL-DFW JUL 7>6[8]
AA ATL-LAX JUL 2>0[3]
AA ATL-LGA JUL 4>0[5]
AA ATL-MIA JUL 6>3[8]
AA ATL-ORD JUL 5>2[5]
AA ATL-PHL JUL 4>3[6]
AA ATL-PHX JUL 0.8>0[1.6]
AA ATW-ORD JUL 3>2[3]
AA AUA-CLT JUL 0.8>0.5[2]
AA AUA-MIA JUL 1.6>0.8[2]
AA AUS-BOS JUL 1.3>0[0]
AA AUS-CLT JUL 4>3[5]
AA AUS-DFW JUL 10>7[11]
AA AUS-JFK JUL 1.5>0[1.0]
AA AUS-LAX JUL 3>0[4]
AA AUS-MIA JUL 4>2[3]
AA AUS-ORD JUL 3>1.7[4]
AA AUS-PHL JUL 1.6>0.8[2.0]
AA AUS-PHX JUL 3>1.8[4]
AA AUS-SJC JUL 1.3>0[0]
AA AVL-CLT JUL 6>4[8]
AA AVL-DFW JUL 1.8>1.0[1.0]
AA AVL-LGA JUL 0.8>0[0.3]
AA AVP-CLT JUL 4>3[4]
AA AVP-ORD JUL 1.7>0.9[1.9]
AA AVP-PHL JUL 2>0[3]
AA AZO-ORD JUL 2>1.4[3]
AA BAQ-MIA JUL 0.8>0[1.0]
AA BCN-ORD JUL 0.8>0[1.0]
AA BDA-JFK JUL 0.8>0[1.0]
AA BDL-CLT JUL 5>4[6]
AA BDL-DCA JUL 5>1.0[6]
AA BDL-LAX JUL 0.8>0[1.0]
AA BDL-ORD JUL 4>1.9[4]
AA BDL-PHL JUL 4>3[5]
AA BFL-PHX JUL 3>1.8[3]
AA BGI-CLT JUL 0.8>0[1.0]
AA BGR-CLT JUL 1.3>1.0[1.0]
AA BGR-DCA JUL 3>1.4[3]
AA BGR-LGA JUL 1.1>0.1[1.1]
AA BGR-ORD JUL 0.9>0.5[1.1]
AA BGR-PHL JUL 4>3[5]
AA BHM-CLT JUL 6>4[7]
AA BHM-DCA JUL 2>0.8[3]
AA BHM-DFW JUL 6>4[7]
AA BHM-MIA JUL 1.8>1.0[2]
AA BHM-ORD JUL 1.6>0.7[1.9]
AA BHM-PHL JUL 2>1.2[3]
AA BIS-DFW JUL 1.8>1.0[1.8]
AA BJX-DFW JUL 3>1.5[3]
AA BMI-ORD JUL 2>1.6[3]
AA BNA-CLT JUL 6>4[7]
AA BNA-DCA JUL 4>1.0[5]
AA BNA-DFW JUL 7>6[7]
AA BNA-JFK JUL 0.8>0[2]
AA BNA-LAX JUL 1.6>0[2]
AA BNA-LGA JUL 4>1.5[4]
AA BNA-MIA JUL 3>1.8[3]
AA BNA-ORD JUL 7>4[8]
AA BNA-PHL JUL 5>3[5]
AA BOG-DFW JUL 0.8>0[1.0]
AA BOG-MIA JUL 1.6>0[3]
AA BOI-DFW JUL 3>2[2.0]
AA BOS-CLT JUL 8>6[9]
AA BOS-DCA JUL 9>5[11]
AA BOS-DFW JUL 7>5[7]
AA BOS-IND JUL 1.5>0[0]
AA BOS-JFK JUL 2>0[0.6]
AA BOS-LAX JUL 4>0.5[5]
AA BOS-LGA JUL 9>3[10]
AA BOS-MDT JUL 0.7>0[0.9]
AA BOS-MIA JUL 7>4[6]
AA BOS-ORD JUL 7>4[8]
This seems an odd increase vs the prior year
*AA BOS-PHL JUL 10>6[11] SEP 12>14[9] OCT 12>14[9] NOV 12>14[10] DEC 12>14[9] JAN 12>14[9] FEB 12>14[10] MAR 12>14[11]
AA BOS-PHX JUL 3>1.8[4]
AA BOS-RDU JUL 4>0[0]
AA BOS-ROC JUL 2>0[3]
AA BOS-SYR JUL 0.7>0[0.9]
AA BPT-DFW JUL 3>1.8[3]
AA BTR-CLT JUL 3>1.7[3]
AA BTR-DFW JUL 5>3[6]
AA BTV-DCA JUL 3>1.0[3]
AA BTV-ORD JUL 1.6>0.8[1.9]
AA BTV-PHL JUL 4>3[4]
AA BUF-CLT JUL 3>1.7[3]
AA BUF-DCA JUL 3>1.0[3]
AA BUF-ORD JUL 3>2[5]
AA BUF-PHL JUL 5>3[5]
AA BUR-DFW JUL 1.8>1.0[2.0]
AA BUR-PHX JUL 4>1.8[4]
AA BWI-CLT JUL 8>6[8]
AA BWI-JFK JUL 1.6>0[1.0]
AA BWI-ORD JUL 3>1.6[4]
AA BWI-PHL JUL 2>1.6[4]
AA BZN-DFW JUL 1.9>1.2[1.9]
AA CAE-CLT JUL 6>4[7]
AA CAE-DCA JUL 2>1.0[4]
AA CAE-DFW JUL 3>1.8[2]
AA CAE-LGA JUL 0.8>0[1.0]
AA CAK-CLT JUL 4>3[5]
AA CAK-DCA JUL 0.8>0[1.0]
AA CAK-LGA JUL 0.8>0[0.9]
AA CAK-ORD JUL 1.6>0[2.0]
AA CDG-JFK JUL 0.8>0[1.0]
AA CHA-CLT JUL 5>3[6]
AA CHA-DCA JUL 0.7>0[0.9]
AA CHA-DFW JUL 3>1.8[3]
AA CHO-CLT JUL 7>3[7]
AA CHO-LGA JUL 1.5>0.7[2.0]
AA CHO-ORD JUL 1.6>0.5[3]
AA CHO-PHL JUL 1.6>0.8[1.9]
AA CHS-CLT JUL 7>5[9]
AA CHS-DCA JUL 4>1.8[4]
AA CHS-DFW JUL 4>3[4]
AA CHS-LGA JUL 0.2>0[0.9]
AA CHS-MIA JUL 3>1.0[5]
AA CHS-PHL JUL 4>2[5]
AA CID-DFW JUL 4>3[4]
AA CID-ORD JUL 4>2[6]
AA CLE-CLT JUL 6>4[6]
AA CLE-DCA JUL 3>1.0[3]
AA CLE-LGA JUL 3>0[4]
AA CLE-MIA JUL 3>1.8[3]
AA CLE-ORD JUL 6>3[7]
AA CLE-PHL JUL 5>3[6]
AA CLL-DFW JUL 3>2[4]
AA CLO-MIA JUL 0.8>0[1.0]
AA CLT-CMH JUL 7>5[8]
AA CLT-CRW JUL 4>3[5]
AA CLT-CUN JUL 1.8>0.8[3]
AA CLT-CVG JUL 6>4[7]
AA CLT-DAB JUL 4>2[4]
AA CLT-DAY JUL 5>4[6]
AA CLT-DCA JUL 8>6[9]
AA CLT-DEN JUL 5>4[6]
AA CLT-DFW JUL 9>7[10]
AA CLT-DSM JUL 3>2[3]
AA CLT-DTW JUL 5>3[6]
AA CLT-ECP JUL 1.9>3[2]
AA CLT-EWN JUL 4>2[5]
AA CLT-EWR JUL 7>5[8]
AA CLT-FAY JUL 5>3[6]
AA CLT-FLL JUL 6>4[7]
AA CLT-FLO JUL 3>2[4]
AA CLT-GCM JUL 0.9>0[1.4]
AA CLT-GNV JUL 4>1.7[4]
AA CLT-GRR JUL 4>2[3]
AA CLT-GSO JUL 8>6[9]
AA CLT-GSP JUL 8>5[9]
AA CLT-HHH JUL 4>3[3]
AA CLT-HPN JUL 3>1.5[4]
AA CLT-HSV JUL 3>2[4]
AA CLT-HTS JUL 3>2.0[3]
AA CLT-IAD JUL 6>3[7]
AA CLT-IAH JUL 4>3[4]
AA CLT-ILM JUL 7>5[9]
AA CLT-IND JUL 7>5[8]
AA CLT-JAN JUL 3>1.8[4]
AA CLT-JAX JUL 7>5[8]
AA CLT-JFK JUL 5>3[6]
AA CLT-LAS JUL 4>3[5]
AA CLT-LAX JUL 6>5[7]
AA CLT-LEX JUL 4>3[5]
AA CLT-LGA JUL 8>5[10]
AA CLT-LHR JUL 0.8>0[2]
AA CLT-LYH JUL 5>3[6]
AA CLT-MCI JUL 3>2[4]
AA CLT-MCO JUL 9>6[10]
AA CLT-MDT JUL 5>4[6]
AA CLT-MEM JUL 5>4[6]
AA CLT-MEX JUL 1.0>0.7[1.0]
AA CLT-MGM JUL 3>1.7[3]
AA CLT-MHT JUL 4>2[4]
AA CLT-MKE JUL 5>3[5]
AA CLT-MSN JUL 3>2[2.0]
AA CLT-MSP JUL 3>2[4]
AA CLT-MSY JUL 5>4[6]
AA CLT-MUC JUL 0.8>0[1.0]
AA CLT-MYR JUL 7>5[8]
AA CLT-NAS JUL 1.6>0.8[3]
AA CLT-OAJ JUL 5>3[6]
AA CLT-OMA JUL 3>1.7[3]
AA CLT-ORD JUL 8>7[10]
AA CLT-ORF JUL 8>5[8]
AA CLT-PBI JUL 4>3[4]
AA CLT-PGV JUL 4>2[4]
AA CLT-PHF JUL 6>3[6]
AA CLT-PHL JUL 8>6[9]
AA CLT-PHX JUL 7>6[8]
AA CLT-PIA JUL 1.8>0.8[2]
AA CLT-PIT JUL 8>5[8]
AA CLT-PLS JUL 0.8>0.2[1.4]
AA CLT-PUJ JUL 0.8>0.5[3]
AA CLT-PVD JUL 5>3[5]
AA CLT-RDU JUL 7>5[8]
AA CLT-RIC JUL 8>5[8]
AA CLT-ROA JUL 6>4[7]
AA CLT-ROC JUL 3>2[4]
AA CLT-SAN JUL 4>2[4]
AA CLT-SAT JUL 3>2.0[4]
AA CLT-SAV JUL 7>5[9]
AA CLT-SDF JUL 7>5[8]
AA CLT-SEA JUL 3>1.7[4]
AA CLT-SFO JUL 4>3[5]
AA CLT-SGF JUL 3>1.8[4]
AA CLT-SLC JUL 1.0>0.7[1.0]
AA CLT-SRQ JUL 4>3[4]
AA CLT-STL JUL 5>3[6]
AA CLT-SXM JUL 0.8>0.5[1.9]
AA CLT-SYR JUL 4>3[4]
AA CLT-TLH JUL 4>1.8[4]
AA CLT-TPA JUL 8>6[8]
AA CLT-TRI JUL 4>3[5]
AA CLT-TYS JUL 6>4[7]
AA CLT-YYZ JUL 4>3[5]
AA CMH-DCA JUL 3>1.0[4]
AA CMH-DFW JUL 4>3[5]
AA CMH-JFK JUL 0.8>0[1.0]
AA CMH-LAX JUL 0.8>0[1.8]
AA CMH-LGA JUL 4>1.3[5]
AA CMH-MIA JUL 3>2[4]
AA CMH-ORD JUL 7>4[9]
AA CMH-PHL JUL 5>3[5]
AA CMH-PHX JUL 0.8>0[1.9]
AA CMI-ORD JUL 4>2[5]
AA COS-ORD JUL 0.9>0.5[1.0]
AA COS-PHX JUL 1.6>0[0] AUG 1.1>0.8[0]
AA COU-ORD JUL 3>1.7[4]
AA CRP-DFW JUL 6>5[7]
AA CRW-DCA JUL 0.8>0[1.0]
AA CTG-MIA JUL 0.8>0[1.0]
AA CUN-DFW JUL 5>3[6]
AA CUN-MIA JUL 3>2[5]
AA CUU-DFW JUL 1.8>1.0[3]
AA CVG-DCA JUL 3>1.0[3]
AA CVG-JFK JUL 0.8>0[1.0]
AA CVG-LGA JUL 1.6>0[1.8]
AA CVG-MIA JUL 3>1.8[3]
AA CVG-ORD JUL 7>4[7]
AA CVG-PHL JUL 4>2[6]
AA CWA-ORD JUL 2>1.7[3]
AA CYS-DFW JUL 0.8>0[1.9]
AA DAY-DCA JUL 3>1.0[3]
AA DAY-DFW JUL 4>2[3]
AA DAY-LGA JUL 1.6>0[3]
AA DAY-ORD JUL 4>1.9[5]
AA DAY-PHL JUL 3>2[5]
AA DBQ-ORD JUL 3>1.4[3]
AA DCA-DFW JUL 9>7[9]
AA DCA-DSM JUL 1.7>1.0[1.8]
AA DCA-DTW JUL 2>1.0[3]
AA DCA-GRR JUL 1.5>0.8[1.8]
AA DCA-GSO JUL 2>0[3]
AA DCA-GSP JUL 2>0[3]
AA DCA-HSV JUL 3>1.0[3]
AA DCA-IND JUL 5>1.6[5]
AA DCA-JAN JUL 0.8>0[1.0]
AA DCA-JAX JUL 3>1.0[4]
AA DCA-JFK JUL 2>0[0.1]
AA DCA-LAN JUL 0.8>0[1.0]
AA DCA-LGA JUL 9>5[8]
AA DCA-MCI JUL 2>1.0[2]
AA DCA-MCO JUL 3>1.8[4]
AA DCA-MEM JUL 3>1.0[3]
AA DCA-MGM JUL 0.8>0[1.0]
AA DCA-MHT JUL 3>1.0[3]
AA DCA-MIA JUL 8>6[9]
AA DCA-MSP JUL 2>1.0[3]
AA DCA-MSY JUL 3>1.0[4]
AA DCA-OKC JUL 0.8>0[1.0]
AA DCA-ORD JUL 8>6[8]
AA DCA-ORF JUL 2>1.0[3]
AA DCA-PBI JUL 1.8>1.0[1.0]
AA DCA-PHX JUL 3>1.8[3]
AA DCA-PIT JUL 3>1.0[4]
AA DCA-PVD JUL 5>1.0[6]
AA DCA-PWM JUL 4>1.8[5]
AA DCA-RDU JUL 5>1.0[5]
AA DCA-ROC JUL 3>1.0[3]
AA DCA-SAV JUL 1.9>1.0[2]
AA DCA-SDF JUL 3>1.0[3]
AA DCA-STL JUL 3>1.0[4]
AA DCA-SYR JUL 3>1.0[3]
AA DCA-TPA JUL 3>1.8[3]
AA DCA-TYS JUL 2>0.8[3]
AA DCA-YYZ JUL 1.5>0.8[1.8]
AA DEN-DFW JUL 9>8[9]
AA DEN-MIA JUL 1.8>1.0[2]
AA DEN-ORD JUL 5>2[5]
AA DEN-PHL JUL 1.6>0.8[3]
AA DEN-PHX JUL 3>1.8[4]
AA DFW-DRO JUL 3>2[4]
AA DFW-DSM JUL 4>3[4]
AA DFW-DUB JUL 0.8>0.4[1.0]
AA DFW-EGE JUL 1.8>1.0[2]
AA DFW-ELP JUL 8>6[8]
AA DFW-EWR JUL 4>3[4]
AA DFW-FAR JUL 1.6>0.8[1.9]
AA DFW-FAT JUL 4>3[2]
AA DFW-FLL JUL 6>5[6]
AA DFW-FSD JUL 3>1.8[2]
AA DFW-FSM JUL 3>2[4]
AA DFW-GDL JUL 1.8>1.0[3]
AA DFW-GGG JUL 3>1.8[3]
AA DFW-GJT JUL 3>1.5[3]
AA DFW-GNV JUL 1.8>1.0[1.9]
AA DFW-GPT JUL 3>1.8[3]
AA DFW-GRI JUL 3>1.6[3]
AA DFW-GRK JUL 6>5[7]
AA DFW-GRR JUL 3>1.7[3]
AA DFW-GRU JUL 0.3>0[1.0]
AA DFW-GSO JUL 3>1.8[3]
AA DFW-GSP JUL 3>1.5[3]
AA DFW-HOU JUL 7>4[8]
AA DFW-HRL JUL 3>1.8[3]
AA DFW-HSV JUL 5>3[6]
AA DFW-IAD JUL 3>2[3]
AA DFW-IAH JUL 8>6[10]
AA DFW-ICT JUL 5>4[6]
AA DFW-IND JUL 5>3[5]
AA DFW-JAN JUL 6>4[7]
AA DFW-JAX JUL 4>3[5]
AA DFW-JFK JUL 1.4>0[2]
AA DFW-LAS JUL 10>8[10]
AA DFW-LAW JUL 3>1.8[4]
AA DFW-LAX JUL 14>10[15]
AA DFW-LBB JUL 7>5[8]
AA DFW-LEX JUL 3>2[3]
AA DFW-LFT JUL 4>3[6]
AA DFW-LGA JUL 11>7[12]
AA DFW-LHR JUL 1.8>1.0[4]
AA DFW-LIM JUL 0.4>0[1.0]
AA DFW-LIT JUL 7>4[8]
AA DFW-LRD JUL 3>2[5]
AA DFW-MAF JUL 7>5[8]
AA DFW-MCI JUL 7>6[7]
AA DFW-MCO JUL 9>7[9]
AA DFW-MEI JUL 0.8>0[1.0]
AA DFW-MEM JUL 6>5[8]
AA DFW-MEX JUL 3>1.8[5]
AA DFW-MFE JUL 7>5[8]
AA DFW-MGM JUL 3>1.8[3]
AA DFW-MHK JUL 3>1.5[3]
AA DFW-MKE JUL 4>3[4]
AA DFW-MSN JUL 3>1.8[3]
AA DFW-MSO JUL 1.0>1.5[1.1]
AA DFW-MSP JUL 5>4[6]
AA DFW-MSY JUL 7>6[8]
AA DFW-MTJ JUL 1.8>1.1[3]
AA DFW-MTY JUL 3>1.8[5]
AA DFW-OAX JUL 0.8>0[1.0]
AA DFW-OKC JUL 8>6[9]
AA DFW-ONT JUL 6>4[6]
AA DFW-ORD JUL 13>9[14]
AA DFW-ORF JUL 3>2.0[3]
AA DFW-PDX JUL 5>3[5]
AA DFW-PHL JUL 8>7[9]
AA DFW-PHX JUL 11>10[12]
AA DFW-PIB JUL 1.5>0[1.0] AUG 1.0>0.8[1.0]
AA DFW-PIT JUL 4>3[4]
AA DFW-PNS JUL 5>4[6]
AA DFW-PVR JUL 2>1.8[4]
AA DFW-RDU JUL 5>4[6]
AA DFW-RIC JUL 3>2[3]
AA DFW-ROW JUL 3>1.5[2]
AA DFW-RSW JUL 4>2[3]
AA DFW-SAF JUL 4>3[4]
AA DFW-SAN JUL 9>7[9]
AA DFW-SAT JUL 10>6[11]
AA DFW-SAV JUL 3>1.8[3]
AA DFW-SDF JUL 5>4[6]
AA DFW-SEA JUL 9>6[9]
AA DFW-SFO JUL 8>6[10]
AA DFW-SGF JUL 7>5[8]
AA DFW-SGU JUL 0.8>0[0]
AA DFW-SHV JUL 6>4[7]
AA DFW-SJT JUL 5>3[5]
AA DFW-SLP JUL 1.8>1.0[3]
AA DFW-SMF JUL 4>3[5]
AA DFW-SNA JUL 8>6[8]
AA DFW-SPS JUL 3>1.8[4]
AA DFW-STL JUL 7>5[7]
AA DFW-TLH JUL 3>1.8[3]
AA DFW-TPA JUL 6>5[7]
AA DFW-TRI JUL 1.6>0.8[0]
AA DFW-TUL JUL 8>6[9]
AA DFW-TUS JUL 6>5[6]
AA DFW-TXK JUL 3>1.8[4]
AA DFW-TYR JUL 4>2[4]
AA DFW-TYS JUL 4>3[5]
AA DFW-VPS JUL 5>4[6]
AA DFW-XNA JUL 8>5[8]
AA DFW-YVR JUL 3>1.8[3]
AA DFW-YYZ JUL 3>1.0[3]
AA DRO-PHX JUL 3>1.0[3]
AA DSM-MIA JUL 0.2>0[0]
AA DSM-ORD JUL 6>3[7]
AA DTW-LGA JUL 4>0[4]
AA DTW-ORD JUL 6>3[6]
AA DTW-PHL JUL 4>2[5]
AA DUB-ORD JUL 0.8>0[1.0]
AA ELP-LAX JUL 0.8>0[3]
AA ELP-ORD JUL 1.7>1.4[1.9]
AA ELP-PHX JUL 4>1.8[5]
AA EUG-LAX JUL 1.6>0[2]
AA EVV-ORD JUL 1.7>0.9[3]
AA EWR-MIA JUL 3>1.8[3]
AA EWR-ORD JUL 5>3[6]
AA EWR-PHX JUL 2>0[4]
AA EYW-MIA JUL 4>3[4]
AA EZE-JFK JUL 0.8>0[1.0]
AA EZE-MIA JUL 0.8>0[1.8]
AA FAR-ORD JUL 3>1.4[3]
AA FAT-LAX JUL 2>0[3]
AA FAT-PHX JUL 4>1.8[5]
AA FLG-PHX JUL 3>1.0[4]
AA FLL-PHL JUL 3>1.9[4]
AA FNT-ORD JUL 3>1.4[4]
AA FPO-MIA JUL 0.8>0[2]
AA FSD-ORD JUL 2>1.4[3]
AA FWA-ORD JUL 3>1.7[3]
AA GCM-MIA JUL 0.8>0[2]
AA GEG-PHX JUL 1.8>1.0[1.9]
AA GIG-MIA JUL 0.8>0[1.0]
AA GJT-PHX JUL 1.8>1.0[2.0]
AA GNV-MIA JUL 1.4>0[1.7]
AA GRB-ORD JUL 3>2[4]
AA GRR-ORD JUL 7>4[7]
AA GRR-PHL JUL 2>1.8[3]
AA GRU-JFK JUL 0.8>0[1.0]
AA GRU-MIA JUL 0.8>0[2]
AA GSO-LGA JUL 2>0.5[3]
AA GSO-MIA JUL 1.5>1.0[2]
AA GSO-ORD JUL 2>0.9[3]
AA GSO-PHL JUL 4>2[4]
AA GSP-MIA JUL 1.8>1.0[2]
AA GSP-ORD JUL 2>0.8[3]
AA HNL-LAX JUL 4>1.8[5]
AA HPN-ORD JUL 2>1.6[3]
AA HSV-ORD JUL 1.5>0.7[1.8]
AA HVN-PHL JUL 2>1.8[3]
AA IAD-LAX JUL 1.6>0[1.8]
AA IAH-LAX JUL 0.8>0[3]
AA IAH-MIA JUL 5>3[5]
AA IAH-ORD JUL 3>1.7[4]
AA IAH-PHL JUL 2>1.0[3]
AA IAH-PHX JUL 3>1.8[4]
AA ICT-ORD JUL 3>1.4[3]
AA ILM-LGA JUL 2>0.5[3]
AA ILM-PHL JUL 3>1.9[3]
AA IND-JFK JUL 0.8>0[1.0]
AA IND-LAX JUL 0.8>0[1.0]
AA IND-LGA JUL 1.6>0[2.0]
AA IND-MIA JUL 3>2[3]
AA IND-ORD JUL 7>3[8]
AA IND-PHL JUL 5>3[5]
AA IPT-PHL JUL 1.6>1.0[3]
AA ITH-PHL JUL 1.4>1.8[3]
AA JAC-LAX JUL 0.8>0[1.0]
AA JAC-ORD JUL 1.6>0.8[2.0]
AA JAN-MIA JUL 0.2>0[0]
AA JAX-MIA JUL 5>3[5]
AA JAX-ORD JUL 3>1.7[3]
AA JAX-PHL JUL 2>1.8[3]
AA JFK-LAS JUL 0.8>0[1.2]
AA JFK-LAX JUL 9>5[10]
AA JFK-LHR JUL 1.7>0.9[4]
AA JFK-MAD JUL 0.8>0[1.0]
AA JFK-MIA JUL 7>4[5]
AA JFK-ORD JUL 0.7>0[2]
AA JFK-ORF JUL 0.8>0[3]
AA JFK-PHX JUL 4>3[4]
AA JFK-PIT JUL 0.8>0[1.0]
AA JFK-RDU JUL 1.6>0[2]
AA JFK-RIC JUL 0.8>0[0]
AA JFK-SAN JUL 0.8>0[0]
AA JFK-SAT JUL 0.8>0[1.0]
AA JFK-SFO JUL 4>1.2[4]
AA JFK-YUL JUL 0.8>0[1.0]
AA JLN-ORD JUL 1.5>0[2]
AA KIN-MIA JUL 1.8>1.0[3]
AA KOA-LAX JUL 1.6>0.8[2]
AA KOA-PHX JUL 0.9>0[1.1]
AA LAN-ORD JUL 1.7>0.9[1.9]
AA LAS-LAX JUL 6>1.4[7]
AA LAS-MIA JUL 3>2[2]
AA LAS-ORD JUL 4>2[4]
AA LAS-PHL JUL 3>1.8[4]
AA LAS-PHX JUL 4>1.8[5]
AA LAX-LHR JUL 0.8>0[2]
AA LAX-LIH JUL 2>0.8[3]
AA LAX-MCO JUL 3>0[4]
AA LAX-MIA JUL 8>5[8]
AA LAX-OGG JUL 3>1.8[4]
AA LAX-OKC JUL 0.8>0[2]
AA LAX-OMA JUL 0.8>0[2]
AA LAX-ORD JUL 9>5[10]
AA LAX-PDX JUL 0.8>0[3]
AA LAX-PHL JUL 6>4[7]
AA LAX-PHX JUL 6>5[7]
AA LAX-RDM JUL 0.8>0[1.7]
AA LAX-RDU JUL 0.8>0[1.5]
AA LAX-RNO JUL 1.6>0[4]
AA LAX-SAN JUL 1.8>0[5]
AA LAX-SAT JUL 0.7>0[3]
AA LAX-SDF JUL 0.8>0[0.9]
AA LAX-SEA JUL 2>0.5[5]
AA LAX-SFO JUL 5>1.6[8]
AA LAX-SJC JUL 4>0[5]
AA LAX-SLC JUL 2>0[3]
AA LAX-SMF JUL 3>0[4]
AA LAX-STL JUL 1.6>0[2]
AA LAX-STS JUL 0.8>0[1.0]
AA LAX-TUL JUL 0.8>0[1.0]
AA LAX-TUS JUL 1.7>0.8[3]
AA LAX-XNA JUL 0.7>0[2]
AA LAX-YVR JUL 1.6>0[2]
AA LBB-PHX JUL 1.3>0[1.0]
AA LEX-ORD JUL 3>1.7[3]
AA LGA-MCO JUL 1.5>0.8[1.0]
AA LGA-MEM JUL 1.6>0[1.7]
AA LGA-MIA JUL 10>7[10]
AA LGA-MSP JUL 1.5>0[1.8]
AA LGA-MVY JUL 0.8>0.5[1.0]
AA LGA-OKC JUL 0.8>0[0]
AA LGA-ORD JUL 10>5[12]
AA LGA-ORF JUL 3>0[4]
AA LGA-PHL JUL 3>1.0[3]
AA LGA-PIT JUL 5>1.4[5]
AA LGA-PWM JUL 1.8>0.1[1.9]
AA LGA-RDU JUL 5>1.2[6]
AA LGA-RIC JUL 2>0[4]
AA LGA-ROA JUL 0.8>0.5[1.0]
AA LGA-SDF JUL 1.5>0[1.7]
AA LGA-STL JUL 3>1.6[4]
AA LGA-TYS JUL 1.4>0[1.9]
AA LGA-XNA JUL 1.5>0[1.7]
AA LGA-YUL JUL 2>0[3]
AA LGA-YYZ JUL 3>0[3]
AA LGB-PHX JUL 3>1.0[3]
AA LHR-PHL JUL 0.8>0[2]
AA LHR-RDU JUL 0.8>0[1.0]
AA LIH-PHX JUL 0.9>0[1.1]
AA LIM-MIA JUL 1.6>0.8[2]
AA LIT-ORD JUL 3>1.5[4]
AA LSE-ORD JUL 3>1.4[4]
AA MAD-MIA JUL 0.8>0[1.0]
AA MAD-PHL JUL 0.8>0[1.0]
AA MAF-PHX JUL 1.6>0[1.0]
AA MCI-MIA JUL 1.8>1.0[2]
AA MCI-ORD JUL 6>3[6]
AA MCI-PHL JUL 3>1.8[3]
AA MCO-MIA JUL 10>6[6]
AA MCO-ORD JUL 4>1.9[5]
AA MCO-PHL JUL 6>4[7]
AA MCO-PHX JUL 3>1.8[3]
AA MDE-MIA JUL 0.8>0[2]
AA MDT-ORD JUL 3>1.4[4]
AA MDT-PHL JUL 4>3[5]
AA MEI-ORD JUL 0.8>0[1.0]
AA MEM-MIA JUL 1.8>1.0[2]
AA MEM-ORD JUL 4>3[5]
AA MEM-PHL JUL 2>1.6[3]
AA MEM-PHX JUL 1.6>0[1.9]
AA MEX-MIA JUL 3>2[4]
AA MFR-PHX JUL 1.8>1.0[1.0]
AA MGA-MIA JUL 1.5>0.8[1.8]
AA MHH-MIA JUL 0.8>0[1.0]
AA MHK-ORD JUL 2>1.2[3]
AA MHT-ORD JUL 1.7>0.9[2.0]
AA MHT-PHL JUL 5>2[6]
AA MIA-MSP JUL 1.8>1.0[2]
AA MIA-MSY JUL 3>1.8[4]
AA MIA-MTY JUL 0.8>0[1.0]
AA MIA-NAS JUL 3>1.6[7]
AA MIA-ORD JUL 8>5[9]
AA MIA-ORF JUL 3>1.8[4]
AA MIA-PHL JUL 6>5[6]
AA MIA-PHX JUL 3>2[3]
AA MIA-PIT JUL 3>1.8[3]
AA MIA-PLS JUL 1.6>0.3[3]
AA MIA-PNS JUL 2>1.6[3]
AA MIA-RDU JUL 4>3[3]
AA MIA-SAV JUL 1.8>1.0[2]
AA MIA-SCL JUL 0.8>0[1.0]
AA MIA-SDF JUL 1.8>1.0[2.0]
AA MIA-SFO JUL 4>3[4]
AA MIA-STL JUL 1.6>1.0[1.7]
AA MIA-TLH JUL 3>2[4]
AA MIA-TPA JUL 7>4[6]
AA MIA-TYS JUL 1.8>1.0[2]
AA MIA-YUL JUL 0.8>0[1.0]
AA MIA-YYZ JUL 0.8>0[3]
AA MKE-PHL JUL 4>1.8[4]
AA MKE-PHX JUL 1.8>1.0[1.8]
AA MLI-ORD JUL 3>2[4]
AA MRY-PHX JUL 3>1.8[4]
AA MSN-ORD JUL 4>2[6]
AA MSN-PHL JUL 1.6>1.0[1.7]
AA MSP-ORD JUL 5>3[7]
AA MSP-PHX JUL 3>1.8[3]
AA MSY-ORD JUL 2>0.9[1.6]
AA MTJ-PHX JUL 0.8>0[1.0]
AA MYR-PHL JUL 3>1.8[2]
AA OKC-ORD JUL 3>1.7[5]
AA OKC-PHL JUL 0.8>0[0.9]
AA OMA-ORD JUL 5>3[6]
AA OMA-PHX JUL 1.0>1.8[1.0]
AA ONT-PHX JUL 4>1.0[5]
AA ORD-ORF JUL 3>1.4[3]
AA ORD-PDX JUL 1.7>1.4[1.9]
Also odd...
*AA ORD-PHL JUL 9>7[9] SEP 10>12[8] OCT 10>12[9] NOV 10>12[8] DEC 10>12[8] JAN 10>12[7] FEB 10>12[7] MAR 10>12[8]
AA ORD-PHX JUL 8>4[8]
AA ORD-PIT JUL 5>2[6]
AA ORD-PVD JUL 3>1.6[3]
AA ORD-RDU JUL 3>1.9[5]
AA ORD-RIC JUL 3>1.7[5]
AA ORD-RNO JUL 1.6>0.5[1.9]
AA ORD-ROC JUL 3>2[4]
AA ORD-RST JUL 3>1.7[4]
AA ORD-RSW JUL 0.9>1.7[1.0]
AA ORD-SAN JUL 3>2[4]
AA ORD-SAT JUL 2>1.6[3]
AA ORD-SDF JUL 4>2[5]
AA ORD-SEA JUL 5>1.7[5]
AA ORD-SFO JUL 4>2[5]
AA ORD-SGF JUL 4>3[5]
AA ORD-SJC JUL 2>0.7[3]
AA ORD-SLC JUL 3>1.9[3]
AA ORD-SMF JUL 0.8>0.5[1.0]
AA ORD-SNA JUL 4>2[5]
AA ORD-STL JUL 6>3[6]
AA ORD-SYR JUL 3>1.4[4]
AA ORD-TOL JUL 2>1.4[3]
AA ORD-TUL JUL 3>0.9[3]
AA ORD-TUS JUL 1.7>0.6[1.9]
AA ORD-TVC JUL 5>4[6]
AA ORD-TYS JUL 3>1.7[4]
AA ORD-XNA JUL 5>3[5]
AA ORD-YQB JUL 0.8>0.5[1.0]
AA ORD-YVR JUL 0.8>0[1.0]
AA ORD-YYC JUL 1.6>0.8[2.0]
AA ORD-YYZ JUL 4>2[5]
AA ORF-PHL JUL 4>2[6]
**AA ORH-PHL JUL 1.0>0[0.9] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0]
AA PDX-PHX JUL 3>1.8[3]
AA PHF-PHL JUL 2>1.6[3]
AA PHL-PHX JUL 6>5[7]
AA PHL-PIT JUL 5>4[6]
AA PHL-PVD JUL 4>2[5]
AA PHL-PWM JUL 4>2[4]
AA PHL-RDU JUL 5>4[6]
AA PHL-RIC JUL 5>3[6]
AA PHL-ROC JUL 5>3[6]
AA PHL-RSW JUL 3>1.9[3]
AA PHL-SAN JUL 2>0.8[3]
AA PHL-SAV JUL 2>1.4[3]
AA PHL-SBY JUL 3>1.3[4]
AA PHL-SCE JUL 3>1.8[5]
AA PHL-SDF JUL 3>1.4[4]
AA PHL-SEA JUL 2>0[3]
AA PHL-SFO JUL 4>1.6[5]
AA PHL-SRQ JUL 0.2>0.4[0.3]
AA PHL-STL JUL 4>2[5]
AA PHL-SYR JUL 4>2[5]
AA PHL-TPA JUL 5>3[6]
AA PHL-TYS JUL 3>1.4[3]
AA PHL-YQB JUL 1.8>1.0[2]
AA PHL-YUL JUL 4>2[5]
AA PHL-YYZ JUL 4>1.9[5]
AA PHL-ZRH JUL 0.4>0[1.0]
AA PHX-PSP JUL 4>1.8[5]
AA PHX-RAP JUL 0.8>0[0]
AA PHX-RDU JUL 0.7>0[1.0]
AA PHX-RNO JUL 4>1.8[5]
AA PHX-ROW JUL 0.8>0[1.0]
AA PHX-SAF JUL 1.8>0.2[1.0]
AA PHX-SAN JUL 4>1.8[6]
AA PHX-SAT JUL 3>1.8[4]
AA PHX-SBA JUL 4>1.8[4]
AA PHX-SBP JUL 3>1.8[4]
AA PHX-SEA JUL 3>1.8[4]
AA PHX-SFO JUL 4>1.8[4]
AA PHX-SGU JUL 3>1.0[0]
AA PHX-SJC JUL 4>1.8[5]
AA PHX-SJD JUL 1.8>1.0[3]
AA PHX-SLC JUL 3>1.8[4]
AA PHX-SMF JUL 4>1.8[5]
AA PHX-SNA JUL 4>1.8[5]
AA PHX-STL JUL 1.8>1.0[2]
AA PHX-STS JUL 1.8>1.0[1.0]
AA PHX-TUS JUL 6>3[7]
AA PHX-YUM JUL 4>1.2[4]
AA PHX-YVR JUL 0.8>0[1.0]
AA PIT-RDU JUL 1.6>0[1.0]
AC IAD-YUL AUG 2>1.0[2]
AC LGA-YUL AUG 8>7[8]
AC LGA-YYZ AUG 12>11[12]
AC ORD-YYZ AUG 8>7[8]
AC PDX-YVR AUG 4>3[4]
AC SEA-YVR AUG 6>5[6]
AC SFO-YVR AUG 5>4[5]
AC SFO-YYZ AUG 5>4[5]
AD FLL-VCP JUL 1.0>0.6[1.4]
AD MCO-VCP JUL 1.0>0.6[1.1]
AS ABQ-PDX JUL 1.0>0[1.0]
AS ABQ-SEA JUL 2>1.0[2]
AS ADQ-ANC JUL 1.9>1.0[1.9]
AS ALW-SEA JUL 2>1.0[3]
AS ANC-BET JUL 2>1.0[2]
AS ANC-BRW JUL 0.5>1.0[0.5]
AS ANC-FAI JUL 5>3[6]
AS ANC-JNU JUL 4>2[4]
AS ANC-LAX JUL 2>1.0[2]
AS ANC-OME JUL 1.5>0.7[1.5]
AS ANC-ORD JUL 1.6>1.0[1.5]
AS ANC-OTZ JUL 1.5>0.7[1.5]
AS ANC-PDX JUL 4>2[4]
AS ANC-SEA JUL 12>15[21]
AS ATL-SEA JUL 3>2[2]
AS AUS-PDX JUL 2>1.0[1.0]
AS AUS-SAN JUL 2>1.0[1.0]
AS AUS-SEA JUL 3>2[2]
AS AUS-SFO JUL 2>1.0[1.9]
AS AUS-SJC JUL 2>1.0[1.8]
AS BIL-SEA JUL 2>3[2]
AS BLI-SEA JUL 4>1.0[5]
AS BNA-SEA JUL 2>1.0[2]
AS BOI-GEG JUL 3>1.0[2] SEP 3>4[2] OCT 3>4[2] NOV 3>4[2] DEC 3>4[2] JAN 3>4[1.9] FEB 3>4[1.8] MAR 3>4[2]
AS BOI-LAX JUL 2>1.0[0]
AS BOI-PDX JUL 9>4[8]
AS BOI-SAN SEP 1.3>2[1.0] OCT 1.0>2[1.0] NOV 1.4>2[1.0]
AS BOI-SEA JUL 11>8[10]
City dwellers escaping to the less populated areas I guess
**AS BOI-SFO SEP 0>2.0[0] OCT 0>2[0] NOV 0>2[0] DEC 0>2[0] JAN 0>2[0] FEB 0>2[0] MAR 0>2[0]
AS BOI-SJC JUL 2>1.0[1.0]
AS BOI-SMF JUL 1.0>0[1.0]
AS BOS-PDX JUL 2>0[2]
AS BOS-SAN JUL 2>0[1.0]
AS BOS-SEA JUL 4>3[3]
AS BOS-SFO JUL 2>1.0[2]
AS BRW-FAI JUL 0.5>0[0.5]
AS BRW-SCC JUL 1.0>0[1.0]
AS BUR-PDX JUL 2>1.0[3] NOV 2>3[2] DEC 2>3[2] JAN 2>3[2] FEB 2>3[2] MAR 2>3[2]
AS BUR-SEA JUL 5>3[5]
AS BWI-SEA JUL 2>1.0[2]
**AS BWI-SFO JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 0.3>0[1.0]
AS CMH-SEA JUL 2>1.0[1.0]
AS DAL-LAX JUL 3>0[3]
AS DAL-PDX JUL 3>0[1.9]
AS DAL-SEA JUL 4>3[2]
AS DAL-SFO JUL 3>1.0[3]
AS DCA-PDX JUL 1.0>0[1.0]
AS DEN-SEA JUL 6>4[6]
AS DFW-SEA JUL 4>3[4]
AS DTW-SEA JUL 2>1.0[2]
AS EAT-SEA JUL 3>1.0[4]
AS EUG-PDX JUL 2>0[3]
AS EUG-SEA JUL 5>4[4]
AS EWR-LAX JUL 3>1.0[3]
AS EWR-PDX JUL 1.0>0[1.0]
AS EWR-SAN JUL 1.0>0[1.0]
AS EWR-SEA JUL 3>2[3]
AS EWR-SFO JUL 3>1.0[4]
AS EWR-SJC JUL 0.9>0[0.9]
AS FAI-SCC JUL 0.4>0[0.4]
AS FAI-SEA JUL 5>4[5]
AS FAT-PDX JUL 2>1.0[2]
AS FAT-SAN JUL 4>1.0[3]
AS FAT-SEA JUL 3>4[3]
AS FCA-SEA JUL 3>4[3]
AS GEG-PDX JUL 8>4[9]
*AS GEG-SAN SEP 1.0>2[1.0] OCT 1.0>2[1.0] NOV 1.0>2[1.0] DEC 1.0>2[1.0] JAN 1.0>2[1.0] FEB 1.0>2[1.0] MAR 1.0>2[1.0]
AS GEG-SEA JUL 6>10[14]
AS GEG-SFO JUL 2>1.0[0]
AS HLN-SEA JUL 2>1.0[1.0]
AS HNL-LAX JUL 1.0>0.1[1.0]
AS HNL-OAK JUL 0.4>0[0.7]
AS HNL-SEA JUL 3>2[3]
AS HNL-SFO JUL 1.0>0[1.0]
AS IAD-SEA JUL 3>1.0[2]
AS IAD-SFO JUL 2>1.0[2]
AS IND-SEA JUL 2>1.0[1.0]
AS JFK-PDX JUL 1.0>0[1.0]
AS JFK-SEA JUL 3>2[3]
AS JFK-SFO JUL 4>2[4]
AS JNU-SEA JUL 6>4[6]
AS KOA-OAK JUL 0.4>0[1.0]
AS KOA-PDX JUL 0.6>0[0]
AS KOA-SEA JUL 3>1.0[2]
AS LAS-LAX JUL 2>0[4]
AS LAS-PDX JUL 4>3[4]
AS LAS-SEA JUL 8>4[8]
AS LAX-LIR JUL 1.0>0.6[1.0]
AS LAX-OGG JUL 1.0>0.1[1.0]
Big frequency increase
*AS LAX-PDX JUL 6>4[8] NOV 8>10[7] DEC 8>10[7] JAN 8>10[7] FEB 8>10[7] MAR 8>10[7]
AS LAX-SEA JUL 13>10[14]
AS LAX-SFO JUL 13>8[11]
AS LAX-SJC JUL 7>4[4]
AS LAX-SJD JUL 3>2[2]
AS LAX-SJO JUL 0.3>0[0.6]
AS LAX-STS JUL 3>1.0[3]
AS LIH-OAK JUL 0.6>0[0.4]
AS LIH-PDX JUL 0.4>0[0]
AS LIH-SEA JUL 2>1.0[1.6]
AS MCI-PDX JUL 1.0>0[1.0]
AS MCI-SEA JUL 3>2[2]
AS MCO-SAN NOV 1.0>2[0.8] DEC 1.0>2[0.8] JAN 1.0>2[1.0] FEB 1.0>2[1.0] MAR 1.0>2[1.0]
AS MCO-SFO JUL 1.0>0[1.0]
AS MFR-PDX JUL 6>3[6]
AS MSP-PDX JUL 1.0>0[1.0]
*AS MSY-SFO NOV 0.4>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[0.9] FEB 1.0>0[0.9] MAR 1.0>0[1.0]
AS OAK-OGG JUL 0.6>0[1.0]
AS OAK-PDX JUL 3>1.0[3]
AS OAK-SEA JUL 4>3[4]
AS OGG-PDX JUL 2>1.0[2]
AS OGG-SAN JUL 2>1.0[1.0]
AS OGG-SEA JUL 3>2[2]
AS OGG-SFO JUL 1.0>0[1.0]
AS OMA-PDX JUL 1.0>0[1.0]
AS OME-OTZ JUL 0.5>0[0.5]
AS ONT-PDX NOV 2>3[2] DEC 2>3[2] JAN 2>3[1.9] FEB 2>3[1.8] MAR 2>3[1.9]
AS ORD-PDX JUL 2>1.0[2]
AS ORD-SEA JUL 5>4[5]
AS ORD-SFO JUL 2>1.0[2]
AS PDX-RDM JUL 4>2[5]
AS PDX-RNO JUL 4>2[4]
AS PDX-SAN SEP 4>6[4] OCT 4>6[4] NOV 4>6[4] DEC 4>6[4] JAN 4>6[4] FEB 4>6[4] MAR 4>6[4]
AS PDX-SEA JUL 12>15[18]
AS PDX-SFO JUL 8>5[9]
AS PDX-SJC JUL 5>3[5]
AS PDX-SLC JUL 4>2[3]
AS PDX-SMF JUL 4>2[4]
AS PDX-SNA JUL 4>3[4]
AS PDX-STS JUL 2>1.0[2]
AS PDX-YVR JUL 2>1.0[2]
AS PHL-SEA JUL 2>1.0[2]
AS PHL-SFO JUL 1.0>0[1.0]
AS PIT-SEA JUL 2>1.0[1.0]
AS PSC-SEA JUL 7>4[6]
AS PSP-SEA JUL 1.0>2[1.0]
AS PSP-SFO JUL 4>2[4]
AS PUW-SEA JUL 4>1.0[4]
AS PVR-SAN NOV 0.5>1.0[0.5] DEC 0.5>1.0[0.5] JAN 0.5>1.0[0.5] FEB 0.4>1.0[0.4] MAR 0.4>1.0[0.5]
AS RDM-SEA JUL 5>3[5]
AS RDU-SEA JUL 2>1.0[1.0]
*AS SAN-SBP JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0]
AS SAN-SEA JUL 9>6[8] NOV 9>10[8] DEC 9>10[8] JAN 9>10[7] FEB 9>10[8] MAR 9>10[8]
AS SAN-SFO JUL 7>4[5]
AS SAN-SJC JUL 6>4[4]
**AS SAN-SMF JUL 3>2[4] AUG 3>0[4] SEP 4>0[4] OCT 4>0[4] NOV 4>0[4] DEC 3>0[4] JAN 3>0[3] FEB 3>0[3] MAR 3>0[4]
AS SAN-STS JUL 2>1.0[1.0]
AS SAT-SEA JUL 2>1.0[1.5]
AS SBA-SEA JUL 2>1.0[1.0]
AS SBA-STS JUL 0>1.0[0]
AS SEA-SFO JUL 13>7[13]
AS SEA-SJC JUL 9>5[8]
AS SEA-SLC JUL 5>4[5]
AS SEA-SMF JUL 6>4[6]
AS SEA-SNA JUL 8>4[8]
AS SEA-STL JUL 2>1.0[2]
AS SEA-STS JUL 3>1.0[1.5]
AS SEA-SUN JUL 1.0>0.8[1.0] AUG 1.0>0.7[1.0]
AS SEA-TPA JUL 2>1.0[1.0]
AS SEA-YEG JUL 2>1.0[2]
AS SEA-YKM JUL 3>1.0[4]
AS SEA-YLW JUL 2>1.0[2]
AS SEA-YVR JUL 7>3[6]
AS SEA-YYC JUL 3>1.0[3]
AS SEA-YYJ JUL 3>1.0[4]
AS SFO-SLC JUL 2>1.0[1.0]
AS SFO-SNA JUL 7>4[6]
AS SJC-SJD JUL 2>1.0[1.0]
AS SNA-STS JUL 2>0[1.0]
B6 BOG-FLL AUG 2>0[1.0] SEP 1.3>1.0[1.0]
B6 BOG-MCO AUG 1.0>0[1.0]
B6 CTG-FLL AUG 1.0>0[1.0] SEP 0.7>0.4[0.6]
B6 CTG-JFK AUG 1.4>0[0.9] SEP 0.8>0.5[0.4]
B6 FLL-GCM AUG 0.4>0[1.0]
B6 FLL-MDE AUG 1.0>0.0[1.0]
B6 GCM-JFK AUG 0.6>0[0.7]
B6 GEO-JFK OCT 0.2>0[0] NOV 1.0>0[0] DEC 1.0>0[0]
B6 GUA-JFK OCT 0.2>0[0] NOV 1.0>0[0] DEC 1.0>0[0]
They aren't leaving ORH??? 3/week the rest of the year. Massport must be holding a gun to their head.
*B6 JFK-ORH SEP 1.0>0.6[1.0] OCT 1.0>0.4[1.0] NOV 1.0>0.4[1.0] DEC 1.0>0.4[1.0]
B6 JFK-PWM AUG 4>0[3] SEP 3>0[2] OCT 0.8>0[0.8]
BA AUS-LHR JUL 1.0>0[1.0]
BA BNA-LHR JUL 1.0>0[1.0]
BA BOS-LHR JUL 4>1.0[4]
BA BWI-LHR JUL 1.0>0[1.0]
BA DEN-LHR JUL 1.0>0[1.0]
BA EWR-LHR JUL 2>0[2]
BA IAD-LHR JUL 2>1.0[2]
BA IAH-LHR JUL 2>0[2]
BA JFK-LGW JUL 1.0>0[1.0]
BA JFK-LHR JUL 8>2[8]
BA LAS-LGW JUL 0.7>0[0.9]
BA LAS-LHR JUL 1.0>0[1.0]
BA LAX-LHR JUL 3>1.0[3]
BA LGW-MCO JUL 2>0[2]
BA LGW-TPA JUL 1.0>0[1.0]
BA LHR-MIA JUL 2>1.0[3]
BA LHR-MSY JUL 0.9>0[0.7]
BA LHR-PHL JUL 1.4>0[1.4]
BA LHR-PHX JUL 1.0>0[1.0]
BA LHR-PIT JUL 0.6>0[0.6]
BA LHR-SAN JUL 1.0>0[1.0]
BA LHR-SEA JUL 2>1.0[2]
BA LHR-SFO JUL 2>1.0[2]
BA LHR-SJC JUL 1.0>0[1.0]
BR IAH-TPE JUL 0.9>0.4[1.0]
BR JFK-TPE JUL 1.0>0.4[1.0]
BR LAX-TPE JUL 3>0.5[3]
BR SFO-TPE JUL 3>0.5[3]
CI HNL-TPE JUL 0.4>0[0.4]
CI JFK-TPE JUL 0.5>0[0.6]
CM IAD-PTY JUL 0.9>0.4[3]
CM JFK-PTY JUL 0.9>0.4[4]
CM MCO-PTY JUL 0.7>0.4[5]
CM ORD-PTY JUL 0.4>0[3]
CM PTY-SFO JUL 0.3>0[2]
CX BOS-HKG JUL 1.0>0.7[1.0]
CX EWR-HKG JUL 1.0>0[1.0]
CX HKG-JFK JUL 4>0.4[3]
CX HKG-LAX JUL 3>0.9[3]
CX HKG-ORD JUL 1.0>0.8[1.0]
CX HKG-SEA JUL 1.0>0[1.0]
CX HKG-SFO JUL 3>0.5[3]
D7 HNL-KIX JUL 0.6>0[0.6]
DL ATL-BOG JUL 0.5>0[1.0] AUG 1.0>0[1.0]
DL ATL-DTW JUL 7>9[12]
They got approval to close it, but are increasing service
*DL ATL-FNT JUL 0.5>1.0[3]
DL ATL-FSM JUL 0.5>1.0[1.8]
DL ATL-HAV AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
DL ATL-HND JUL 1.0>0[0]
DL ATL-ICN JUL 1.0>0.4[1.0]
DL ATL-LIM JUL 0.5>0[1.0]
DL ATL-PLS JUL 1.0>0.3[1.3]
DL ATL-SFO JUL 3>4[9]
DL ATL-SLC JUL 8>9[10]
DL ATL-SYR JUL 0.5>1.0[3]
DL BWI-DTW JUL 1.5>1.9[4]
DL DTW-ERI JUL 0.5>1.0[3]
DL DTW-HND JUL 1.0>0.4[0]
DL DTW-ICN JUL 1.0>2[1.0]
Delta gives up on most of Japan till October
DL DTW-NGO JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[0.9] OCT 0.7>0.2[0.7]
DL DTW-PVG JUL 1.0>0[1.0]
DL GTF-SLC JUL 2>3[3] AUG 2>3[3]
DL HAV-MIA AUG 2>0[2] SEP 2>0[1.8] OCT 2>0.5[1.7]
DL HND-HNL JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0] OCT 1.0>0.3[0]
DL HND-LAX JUL 1.0>0[1.0]
DL HND-MSP JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
DL HND-PDX JUL 1.0>0[0] AUG 1.0>0[0] SEP 1.0>0[0] OCT 1.0>0.3[0]
DL HNL-KIX JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[0.9]
DL HNL-NGO JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[0.9] OCT 0.7>0.2[0.7]
DL ICN-MSP JUL 1.0>0[1.0] AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[0.8]
DL ICN-SEA JUL 1.0>2[1.0]
DL LAX-PDX JUL 2.0>3[5]
DL LAX-PVG JUL 1.0>0[1.0]
DL LAX-SYD JUL 1.0>0.5[1.0]
DL MSP-SLC JUL 5>6[6]
DL PVG-SEA JUL 1.0>0[1.0]
EK BOS-DXB JUL 1.0>0.7[1.0]
EK DFW-DXB JUL 1.0>0.5[1.0]
EK DXB-EWR AUG 1.0>0[1.0]
EK DXB-IAD JUL 1.0>0.4[1.0]
EK DXB-JFK JUL 1.5>1.0[2] AUG 2>1.0[2]
EK DXB-SEA JUL 0.6>0.4[1.0]
F9 ATL-PHL NOV 1.0>1.6[0.5] DEC 1.0>2[0.5] JAN 1.0>2[0.6] FEB 1.0>2[0.6] MAR 1.0>2[0.5]
**F9 BOS-PHL JUL 0>0.6[0] AUG 0>0.6[0] SEP 0>0.5[0] OCT 0>0.6[0] NOV 0>0.6[0] DEC 0>0.5[0]
F9 BOS-RSW AUG 0.2>0.6[0] OCT 0>0.3[0] NOV 0>0.6[0] DEC 0>0.6[0] JAN 0>0.6[0] FEB 0>0.6[0] MAR 0>0.6[0]
F9 BOS-TPA AUG 0.1>0.4[0] OCT 0>0.2[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0] FEB 0>0.4[0] MAR 0>0.4[0]
F9 CUN-PHL NOV 0.8>0.6[0.6] DEC 1.0>0.8[0.6]
F9 DFW-MIA AUG 0.2>0.6[0] OCT 0>0.3[0] NOV 0>0.6[0] DEC 0>0.5[0] JAN 0>0.6[0] FEB 0>0.6[0] MAR 0>0.5[0]
F9 EWR-MYR AUG 0.1>0.4[0] OCT 0>0.2[0] NOV 0>0.4[0] DEC 0>0.5[0] JAN 0>0.4[0] FEB 0>0.4[0] MAR 0>0.4[0]
F9 EWR-PBI AUG 0.1>0.4[0] OCT 0>0.3[0]
F9 EWR-RSW AUG 0.1>0.4[0] OCT 0>0.2[0] NOV 0>0.4[0] DEC 0>0.5[0] JAN 0>0.4[0] FEB 0>0.4[0] MAR 0>0.4[0]
F9 ISP-PBI AUG 0.2>0.6[0.4] OCT 0>0.3[0.5]
F9 ISP-RSW AUG 0.2>0.6[0] OCT 0>0.3[0] NOV 0.6>0.8[0.6]
F9 LAX-MCO AUG 0.3>1.0[0] SEP 0>0.3[0] OCT 0>0.5[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0]
Wow, is this their most flown route?
**F9 MCO-PHL DEC 4>5[3] JAN 4>6[3] FEB 4>6[3] MAR 4>6[3]
F9 MIA-PHL NOV 1.0>1.6[1.2] DEC 1.0>2[1.3] JAN 1.0>3[1.0] FEB 1.0>3[1.0] MAR 1.0>3[1.3]
F9 MSY-PHL NOV 0.5>0.8[0.9] DEC 0.5>1.0[0.7] JAN 0.4>1.0[0.4] FEB 0.4>1.0[0.4] MAR 0.4>1.0[0.5]
F9 MYR-PHL AUG 0.1>0.3[0.4]
F9 ORD-PHL JUL 0>0.6[0] AUG 0>0.6[0] SEP 0>0.5[0] OCT 0>0.6[0] NOV 0>0.6[0] DEC 0>0.5[0]
F9 ORD-RSW AUG 0.2>0.5[0.1] OCT 0>0.3[0]
F9 ORD-TPA AUG 0.1>0.5[0.4] OCT 0>0.2[0.5]
F9 PBI-PHL AUG 0.1>0.3[0]
**F9 PHL-PHX NOV 0>0.6[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0]
F9 PHL-RSW NOV 1.6>1.0[1.6] DEC 2>1.5[2.0]
F9 PHL-SJU DEC 1.0>1.5[2.0] MAR 1.0>1.6[2.0]
F9 PHL-SRQ DEC 0.3>0.5[0.5] JAN 0.3>0.6[0.4] FEB 0.3>0.6[0.4] MAR 0.3>0.6[0.5]
F9 PHL-TPA NOV 1.0>1.6[1.5] DEC 1.0>2[2.0] JAN 1.0>3[2.0] FEB 1.0>3[2] MAR 1.0>3[2]
F9 PHX-SAN DEC 0.7>1.0[0.8] JAN 0.7>1.0[0.8] FEB 0.7>1.0[0.8] MAR 0.7>1.0[0.9]
FI ANC-KEF JUL 0.3>0[0.3] AUG 0.3>0[0.3] SEP 0.2>0[0.3]
FI DEN-KEF JUL 1.0>1.6[1.0] AUG 1.0>1.6[1.0] SEP 1.0>1.2[1.0]
HA AKL-HNL JUL 0.4>0[0.7]
HA BNE-HNL JUL 0.5>0[0.4]
HA HNL-KIX AUG 2.0>1.0[1.0]
HA HNL-SYD JUL 1.0>0[1.0]
J5 HNH-JNU JUL 7>3[6] AUG 6>3[6] SEP 3>1.5[4] OCT 1.1>0.1[0] NOV 1.0>0[3] DEC 1.0>0[3] JAN 1.0>0[3] FEB 1.0>0[3] MAR 1.0>0[4]
J5 HNS-JNU JUL 8>4[8] AUG 7>4[7] SEP 5>4[4] OCT 0.3>0.1[0]
J5 HNS-SGY JUL 0>0.5[0] AUG 0>0.5[0] SEP 0>0.5[0.1]
J5 JNU-KAE JUL 2>1.0[1.9] AUG 2>1.0[2] OCT 1.0>0[0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0]
J5 JNU-SGY JUL 6>1.0[7] AUG 5>1.0[7] SEP 4>1.0[5] OCT 0.2>0[0]
J5 JNU-SIT JUL 3>2[3] AUG 3>2[3] OCT 1.1>0[0.5] NOV 1.0>0[1.9] DEC 1.0>0[1.9] JAN 1.0>0[1.9] FEB 1.0>0[2] MAR 1.0>0[2]
J5 KAE-SIT OCT 1.0>0[0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0]
J5 KLW-SIT JUL 2>1.0[1.9] AUG 2>1.0[2]
KE BOS-ICN JUL 1.0>0[0.7] AUG 1.0>0[0.7]
KE DFW-ICN JUL 0.7>0.4[0.7] AUG 0.7>0.5[0.7]
KE HNL-ICN JUL 1.0>0[1.0] AUG 1.0>0[1.0]
KE HNL-NRT JUL 1.0>0.0[1.0]
KE IAD-ICN JUL 1.0>0.7[1.0] AUG 1.0>0.7[1.0]
KE ICN-JFK JUL 2.0>1.0[2] AUG 2>1.0[2]
KE ICN-LAS JUL 0.7>0[0.7] AUG 0.7>0[0.7]
KE ICN-LAX JUL 3>1.6[2] AUG 3>1.6[2]
KE ICN-ORD JUL 1.0>0.7[1.0] AUG 1.0>0.7[1.0]
KE ICN-SEA JUL 1.0>0.4[1.0] AUG 1.0>0.4[1.0]
KE ICN-SFO JUL 2>1.0[2] AUG 2>1.0[2]
KG AIA-DEN OCT 1.7>3[1.7]
KL AMS-ATL JUL 1.0>0.7[1.0]
KL AMS-BOS JUL 0.8>0.4[0.6]
KL AMS-IAD JUL 0.9>0.2[1.0]
KL AMS-IAH JUL 0.9>0.5[1.0]
KL AMS-JFK JUL 3>2[3]
KL AMS-LAX JUL 1.9>1.0[1.9]
KL AMS-SFO JUL 1.6>0.4[1.7]
LA GRU-JFK JUL 0.4>0[0]
LF BKW-CLT NOV 0>0.9[1.6]
LF BKW-PKB NOV 0>0.9[1.6]
LF BWI-MCN NOV 0>0.9[1.7]
NK ATL-EWR JUL 1.0>2[1.0] AUG 1.0>2[1.0] SEP 1.0>2[1.0] OCT 1.0>2[1.0] NOV 1.0>2[1.0] DEC 0.5>1.0[1.0]
**NK AVL-MCO AUG 0.9>0[0.6] SEP 0.8>0[0.5] OCT 0.7>0[0.4] NOV 0.8>0[0.8] DEC 0.4>0[1.0]
NK BDL-FLL NOV 1.4>1.9[1.6] DEC 1.0>1.5[1.8]
NK BDL-MCO NOV 1.7>2[1.9] DEC 0.8>1.3[1.8]
NK BDL-TPA NOV 0.4>0.9[0.9] DEC 0.5>1.0[1.0]
NK BOS-MSY AUG 1.6>1.0[1.0] SEP 1.4>0.8[0.8] OCT 1.5>0.7[0.7] NOV 1.6>0.8[0.9] DEC 0.7>0.4[0.8]
**NK CLE-EWR JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>0.5[0]
NK CLE-FLL DEC 1.0>1.5[1.3]
NK CLT-EWR AUG 0.9>1.9[1.0] SEP 1.0>2[1.0] OCT 1.0>2[1.0] NOV 1.0>2[1.0] DEC 0.5>1.0[1.0]
NK CMH-FLL NOV 1.0>1.4[1.0] DEC 0.5>1.0[1.0]
NK CMH-MCO NOV 1.2>1.6[1.0] DEC 0.5>1.0[1.0]
NK CMH-TPA NOV 0.4>0.9[0.7] DEC 0.5>1.0[0.8]
NK EWR-FLL DEC 1.2>1.7[3]
NK EWR-MCO JUL 2>3[4] AUG 3>4[4] SEP 3>4[3] OCT 3>4[3] NOV 3>4[3] DEC 1.5>1.9[3]
NK EWR-MYR JUL 1.0>3[1.0] AUG 1.1>3[1.0] SEP 1.2>3[0.6] OCT 1.2>3[0.5] NOV 0.9>3[0.6] DEC 0.3>1.2[0.5]
NK FLL-IND NOV 0>0.4[0] DEC 0>0.5[0]
NK FLL-LAS NOV 1.4>1.8[1.3] DEC 0.5>1.0[1.0]
NK FLL-PIT DEC 1.0>1.5[2.0]
NK FLL-PUJ DEC 0.3>0.5[0.3]
NK FLL-RDU NOV 1.0>1.4[0.9] DEC 0.5>1.0[0.8]
NK FLL-SJU NOV 2.0>2.9[2.2] DEC 1.0>1.9[2.6]
NK IND-TPA NOV 0.6>1.0[0.6] DEC 0.4>0.8[1.0]
NK MCO-MSY DEC 1.0>1.5[1.0]
NK MCO-PHL NOV 3>4[3] DEC 1.5>2[3]
NK MCO-PIT DEC 1.4>1.9[1.0]
NK PHL-TPA NOV 0.4>0.9[0.2] DEC 0.5>1.0[0.5]
NZ AKL-LAX AUG 1.8>0.7[1.8]
S4 BOS-PDL JUL 1.0>0.7[1.4] AUG 1.0>0.7[1.5] SEP 1.0>0.7[1.3] OCT 0.8>0.6[0.8]
SS MIA-ORY JUL 0.9>0[0.6] AUG 0.9>0[0.6] SEP 0.7>0[0.4] OCT 0.6>0[0.5] NOV 0.6>0[0.5] DEC 0.7>0[0.6] JAN 0.8>0[0.7] FEB 0.9>0[0.7] MAR 0.7>0[0.6]
TK EWR-IST JUL 1.0>0.5[0]
TP EWR-LIS AUG 2>0.4[1.0]
TP EWR-OPO AUG 1.1>0.1[0.9]
TP IAD-LIS AUG 1.3>0.3[0.7]
TP JFK-LIS JUL 1.0>0.0[1.0] AUG 1.0>0[1.0]
TP LIS-ORD AUG 1.0>0[0.7]
TP LIS-SFO AUG 0.7>0[0.7]
UA ABE-ORD JUL 1.8>0.1[3]
UA ABQ-DEN JUL 4>1.9[5]
UA ABQ-IAH JUL 4>1.9[4]
UA ABQ-ORD JUL 0.8>0[1.0]
UA ABQ-SFO JUL 1.6>0.8[3]
UA ACK-BGR JUL 0.1>0.4[0]
UA ACK-EWR JUL 3>0[3]
UA ACK-IAD JUL 0.1>0.4[0]
UA ACV-DEN JUL 0.8>0[1.0]
UA ACV-LAX JUL 1.7>0.8[2]
UA ACV-SFO JUL 3>2.0[3]
UA AEX-IAH JUL 2>0.4[1.8]
UA AGU-IAH JUL 1.7>0[2]
UA ALB-EWR JUL 2>0[4]
UA ALB-IAD JUL 3>1.8[3]
UA ALB-ORD JUL 4>1.9[4]
UA AMA-DEN JUL 1.8>0.9[2.0]
UA AMA-IAH JUL 2>0[3]
UA ANC-DEN JUL 1.8>0.9[2]
UA ANC-EWR JUL 0.8>0[1.0]
UA ANC-IAH JUL 0.8>0[1.0]
UA ANC-LAX JUL 0.8>0[0]
UA ANC-ORD JUL 1.7>0[2]
UA ANC-SFO JUL 0.8>0[1.0]
UA ASE-DEN JUL 7>3[8]
UA ASE-IAH JUL 0.8>0[1.0]
UA ASE-LAX JUL 1.7>0[2]
UA ATL-DEN JUL 4>1.8[4]
UA ATL-EWR JUL 6>3[6]
UA ATL-IAD JUL 4>1.8[4]
UA ATL-IAH JUL 6>3[7]
UA ATL-ORD JUL 7>2[7]
UA ATL-SFO JUL 1.7>0.6[1.7]
UA ATW-DEN JUL 0.8>0[1.0]
UA ATW-ORD JUL 7>3[5]
UA ATY-ORD JUL 0.8>0.6[0]
UA AUA-EWR JUL 1.8>0.8[2]
UA AUA-IAH JUL 0.2>0[0.3]
UA AUS-DEN JUL 4>1.6[5]
UA AUS-EWR JUL 4>0.8[4]
UA AUS-IAD JUL 3>0.8[3]
UA AUS-IAH JUL 8>3[9]
UA AUS-LAX JUL 1.7>0[2.0]
UA AUS-ORD JUL 4>1.6[4]
UA AUS-SFO JUL 4>0.8[4]
UA AVL-EWR JUL 0.8>0[1.1]
UA AVL-IAD JUL 3>1.8[2]
UA AVL-ORD JUL 3>1.0[3]
UA AVP-IAD JUL 1.7>0[2]
UA AVP-ORD JUL 1.7>1.0[3]
UA AZO-ORD JUL 1.7>0.1[3]
UA BDL-DEN JUL 0.8>0[1.0]
UA BDL-IAD JUL 4>1.8[4]
UA BDL-IAH JUL 1.7>0[1.0]
UA BDL-ORD JUL 4>1.7[4]
UA BFF-PIR JUL 0.2>1.0[0]
UA BFL-DEN JUL 1.7>0.9[1.9]
UA BFL-SFO JUL 0.9>0.7[1.0]
UA BGR-EWR JUL 1.8>0[3]
UA BGR-ORD JUL 1.8>0[2]
UA BHM-DEN JUL 1.7>0.8[1.9]
UA BHM-IAH JUL 4>2[5]
UA BHM-ORD JUL 3>0.8[4]
UA BIL-DEN JUL 5>1.9[5]
UA BIL-ORD JUL 0.8>0[1.0]
UA BIS-DEN JUL 4>1.9[4]
UA BIS-ORD JUL 1.7>0[1.9]
UA BJX-IAH JUL 4>1.0[4]
UA BNA-DEN JUL 4>1.6[4]
UA BNA-EWR JUL 5>3[6]
UA BNA-IAD JUL 3>1.8[3]
UA BNA-IAH JUL 5>2.0[5]
UA BNA-ORD JUL 5>4[7]
UA BNA-SFO JUL 1.7>0[1.5]
UA BOG-EWR JUL 1.7>0[2] AUG 1.5>0[1.6] SEP 1.0>0.8[1.0]
UA BOG-IAH JUL 1.7>0[2] AUG 2>0[2] SEP 2>1.5[2]
UA BOI-DEN JUL 5>1.9[5]
UA BOI-IAH JUL 1.7>0[1.0]
UA BOI-LAX JUL 1.7>0.6[2.0]
UA BOI-ORD JUL 3>0.9[2]
UA BOI-SFO JUL 5>3[5]
UA BOS-DEN JUL 4>1.5[5]
UA BOS-EWR JUL 9>3[10]
UA BOS-IAD JUL 4>1.8[4]
UA BOS-IAH JUL 4>1.7[5]
UA BOS-LAX JUL 1.6>0[2.0]
UA BOS-ORD JUL 8>3[9]
UA BOS-SFO JUL 6>1.8[7]
UA BRO-IAH JUL 4>2[4]
UA BTR-IAH JUL 5>3[6]
UA BTV-DEN JUL 0.2>0[0.3]
UA BTV-EWR JUL 3>0[4]
UA BTV-IAD JUL 4>1.8[4]
UA BTV-ORD JUL 4>1.6[4]
UA BUF-EWR JUL 5>0.8[7]
UA BUF-IAD JUL 4>1.8[4]
UA BUF-ORD JUL 4>2.0[6]
UA BUR-DEN JUL 3>0.9[3]
UA BUR-SFO JUL 5>1.9[6]
UA BWI-DEN JUL 1.7>0.8[1.9]
UA BWI-IAH JUL 1.7>0.8[1.9]
UA BWI-LAX JUL 0.8>0[1.0]
UA BWI-SFO JUL 1.7>0.8[1.9]
UA BZE-IAH JUL 1.9>0.6[2]
UA BZN-DEN JUL 5>2[4]
UA BZN-EWR JUL 0.8>0[1.0]
UA BZN-IAH JUL 0.9>0[1.3]
UA BZN-ORD JUL 1.0>0.6[1.4]
UA CAE-IAD JUL 3>1.7[3]
UA CAE-ORD JUL 3>1.0[3]
UA CAK-IAD JUL 3>0[0]
UA CAK-ORD JUL 3>1.8[4]
UA CHA-ORD JUL 3>0.1[1.8]
UA CHO-IAD JUL 3>1.6[2]
UA CHO-ORD JUL 1.7>0.8[1.9]
UA CHS-DEN JUL 0.9>0.1[1.0]
UA CHS-EWR JUL 3>0.8[4]
UA CHS-IAD JUL 3>1.8[4]
UA CHS-IAH JUL 3>1.0[2.0]
UA CHS-ORD JUL 4>1.7[4]
UA CID-DEN JUL 3>0.8[3]
UA CID-ORD JUL 6>2[5]
UA CKB-IAD JUL 1.0>0.7[1.0]
UA CLE-DEN JUL 3>0.8[4]
UA CLE-EWR JUL 6>3[7]
UA CLE-IAD JUL 4>1.8[4]
UA CLE-IAH JUL 4>1.6[5]
UA CLE-LAX JUL 1.6>0[1.8]
UA CLE-MCO JUL 0.9>0[1.0]
UA CLE-ORD JUL 7>3[8]
UA CLE-SFO JUL 1.7>0.6[2.0]
UA CLL-IAH JUL 2>0.5[2]
UA CLT-DEN JUL 1.7>0[2]
UA CLT-EWR JUL 5>1.7[5]
UA CLT-IAD JUL 3>1.8[4]
UA CLT-IAH JUL 4>1.9[4]
UA CLT-ORD JUL 4>1.6[5]
UA CMH-DEN JUL 1.7>0.8[2.0]
UA CMH-EWR JUL 6>1.8[7]
UA CMH-IAD JUL 4>1.8[4]
UA CMH-IAH JUL 3>1.7[4]
UA CMH-ORD JUL 6>3[7]
UA CMH-SFO JUL 0.8>0[1.0]
UA CNY-VEL JUL 0>0.8[0]
UA COD-DEN JUL 3>1.8[4]
UA COS-DEN JUL 9>2.0[9]
UA COS-IAH JUL 3>0.8[3]
UA COS-LAX JUL 1.7>0[2.0]
UA COS-ORD JUL 3>0[3]
UA COU-DEN JUL 0.8>0[1.0]
UA CPR-DEN JUL 5>2[5]
UA CRP-IAH JUL 6>3[5]
UA CRW-ORD JUL 3>1.0[3]
UA CUN-DEN JUL 0.9>0[1.1]
UA CUN-EWR JUL 4>0[5]
UA CUN-IAD JUL 1.9>0[2]
UA CUN-IAH JUL 6>1.8[7]
UA CUN-LAX JUL 3>0[3]
UA CUN-ORD JUL 1.8>0[2]
UA CUN-SFO JUL 1.9>0[2]
UA CUU-IAH JUL 0.8>0[1.0]
UA CVG-EWR JUL 4>1.7[5]
UA CVG-IAD JUL 3>1.8[4]
UA CVG-IAH JUL 3>1.6[4]
UA CVG-ORD JUL 6>3[7]
UA CWA-ORD JUL 3>0.9[3]
UA CZM-IAH JUL 1.0>0[1.1]
UA DAY-DEN JUL 1.7>0[1.9]
UA DAY-IAD JUL 3>1.0[1.9]
UA DAY-ORD JUL 5>1.9[6]
UA DCA-EWR JUL 11>3[7]
UA DCA-IAH JUL 7>3[8]
UA DCA-ORD JUL 12>3[14]
UA DCA-SFO JUL 0.8>0[1.0]
UA DDC-DEN JUL 0.9>1.3[0]
UA DDC-HYS JUL 0>0.3[0]
UA DDC-PUB JUL 0.8>0[0]
UA DEN-DFW JUL 5>2[5]
UA DEN-DIK JUL 1.7>0.9[1.7]
UA DEN-DRO JUL 6>1.9[7]
UA DEN-DSM JUL 5>1.8[5]
UA DEN-DTW JUL 1.7>0[2]
UA DEN-EAR JUL 1.6>0.6[1.9]
UA DEN-EGE JUL 1.8>1.0[1.9]
UA DEN-ELP JUL 4>0[3]
UA DEN-EUG JUL 3>2[3]
UA DEN-EWR JUL 9>4[9]
UA DEN-FAR JUL 4>1.9[4]
UA DEN-FAT JUL 5>2.0[3]
UA DEN-FCA JUL 4>2.0[4]
UA DEN-FLG JUL 1.8>0.9[2]
UA DEN-FLL JUL 1.7>0[1.9]
UA DEN-FSD JUL 5>2[5]
UA DEN-GCC JUL 3>1.0[2]
UA DEN-GJT JUL 5>1.8[5]
UA DEN-GRR JUL 1.7>0.8[2]
UA DEN-GSP JUL 0.8>0[1.0]
UA DEN-GTF JUL 3>1.7[3]
UA DEN-HDN JUL 3>1.8[3]
UA DEN-HLN JUL 1.7>0.9[2]
UA DEN-HNL JUL 1.7>0.8[1.0]
UA DEN-HOB JUL 0.8>0[0]
UA DEN-HSV JUL 1.7>0[1.9]
UA DEN-HYS JUL 1.7>1.3[1.7]
UA DEN-IAD JUL 6>4[8]
UA DEN-IAH JUL 10>5[11]
UA DEN-ICT JUL 4>1.0[4]
UA DEN-IDA JUL 4>1.9[4]
UA DEN-IND JUL 3>1.8[3]
UA DEN-JAC JUL 5>2[4]
UA DEN-JAX JUL 0.8>0[1.0]
UA DEN-KOA JUL 0.8>0[1.0]
UA DEN-LAS JUL 5>1.7[6]
UA DEN-LAX JUL 7>4[8]
UA DEN-LBB JUL 1.7>0[1.9]
UA DEN-LBL JUL 1.5>0.6[0.9]
UA DEN-LGA JUL 5>0.8[7]
UA DEN-LIH JUL 0.8>0[1.0]
UA DEN-LIT JUL 3>0[3]
UA DEN-LNK JUL 3>1.0[3]
UA DEN-MAF JUL 4>1.7[4]
UA DEN-MCI JUL 5>2[4]
UA DEN-MCO JUL 4>1.6[5]
UA DEN-MEM JUL 3>0.7[3]
UA DEN-MFR JUL 3>1.8[3]
UA DEN-MKE JUL 4>1.8[3]
UA DEN-MLI JUL 1.7>0[2]
UA DEN-MOT JUL 3>1.8[3]
UA DEN-MRY JUL 1.7>0[2]
UA DEN-MSN JUL 3>1.0[3]
UA DEN-MSO JUL 3>1.7[4]
UA DEN-MSP JUL 4>1.7[4]
UA DEN-MSY JUL 1.7>0.8[3]
UA DEN-MTJ JUL 4>1.9[4]
UA DEN-OKC JUL 5>1.8[6]
UA DEN-OMA JUL 5>1.9[5]
UA DEN-ONT JUL 3>0.9[2]
UA DEN-ORD JUL 10>5[11]
UA DEN-ORF JUL 0.8>0[1.0]
UA DEN-PAE JUL 1.5>0[2]
UA DEN-PDX JUL 5>2.0[5]
UA DEN-PHL JUL 3>0.8[3]
UA DEN-PHX JUL 4>2[4]
UA DEN-PIR JUL 1.6>0.6[1.9]
UA DEN-PIT JUL 3>0.8[3]
UA DEN-PNS JUL 0.2>0[0.3]
UA DEN-PSC JUL 2>1.8[3]
UA DEN-PSP JUL 3>1.2[3]
UA DEN-PWM JUL 0.8>0[0.3]
UA DEN-RAP JUL 7>2[7]
UA DEN-RDM JUL 3>1.8[3]
UA DEN-RDU JUL 1.7>0.6[2.0]
UA DEN-RIC JUL 1.7>0[2]
UA DEN-RIW JUL 1.6>0[0]
UA DEN-RKS JUL 2>1.0[2]
UA DEN-RNO JUL 3>2[3]
UA DEN-RSW JUL 1.0>0[0.3]
UA DEN-SAF JUL 3>0.9[3]
UA DEN-SAN JUL 5>1.7[5]
UA DEN-SAT JUL 3>1.7[4]
UA DEN-SAV JUL 0.8>0[0.3]
UA DEN-SBA JUL 4>1.0[4]
UA DEN-SBP JUL 3>1.0[2]
UA DEN-SDF JUL 1.7>0[2]
UA DEN-SEA JUL 5>2[6]
UA DEN-SFO JUL 10>5[11]
UA DEN-SGF JUL 4>1.9[4]
UA DEN-SGU JUL 1.8>1.0[0]
UA DEN-SHV JUL 0.8>0[1.0]
UA DEN-SJC JUL 4>1.9[5]
UA DEN-SLC JUL 6>2[7]
UA DEN-SLN JUL 0.8>0[0]
UA DEN-SMF JUL 4>2[5]
UA DEN-SNA JUL 4>2[4]
UA DEN-STL JUL 5>1.7[5]
UA DEN-STS JUL 1.7>0[1.0]
UA DEN-SYR JUL 0.9>0[1.0]
UA DEN-TPA JUL 3>0.7[3]
UA DEN-TUL JUL 3>0.8[4]
UA DEN-TUS JUL 5>2[4]
UA DEN-TVC JUL 1.0>0[1.0]
UA DEN-TYS JUL 1.7>0[2.0]
UA DEN-VEL JUL 1.6>0.8[1.7]
UA DEN-VPS JUL 0.8>0[0.1]
UA DEN-XNA JUL 3>0[3]
UA DEN-XWA JUL 3>0.9[0]
UA DEN-YEG JUL 1.7>0[2.0]
UA DEN-YVR JUL 3>0[3]
UA DEN-YWG JUL 1.7>0[2]
UA DEN-YYC JUL 3>0[4]
UA DEN-YYZ JUL 1.7>0[2.0]
UA DFW-EWR JUL 4>2[4]
UA DFW-IAD JUL 3>1.0[3]
UA DFW-IAH JUL 7>3[8]
UA DFW-ORD JUL 6>3[6]
UA DFW-SFO JUL 3>0.8[4]
UA DLH-ORD JUL 3>1.7[3]
UA DSM-IAH JUL 2>0.8[3]
UA DSM-ORD JUL 5>3[5]
UA DTW-EWR JUL 6>3[6]
UA DTW-IAD JUL 3>1.8[4]
UA DTW-IAH JUL 4>1.6[5]
UA DTW-ORD JUL 7>2[8]
UA DTW-SFO JUL 0.8>0[1.0]
UA EAR-LBF JUL 0.2>1.0[0]
UA EAR-ORD JUL 0.8>0[0]
UA ECP-IAH JUL 3>1.8[2]
UA ECP-ORD JUL 0.2>0[0.3]
UA EGE-ORD JUL 0.8>0[0]
UA ELP-IAH JUL 4>2[4]
UA ELP-ORD JUL 0.8>0[0.8]
UA ERI-ORD JUL 1.7>1.0[1.9]
UA EUG-LAX JUL 1.7>0[1.9]
UA EUG-ORD JUL 0.8>0[1.0]
UA EUG-SFO JUL 4>1.9[4]
UA EVV-ORD JUL 3>0.9[3]
UA EWR-EYW JUL 0.9>0[1.1]
UA EWR-FLL JUL 5>2[6]
UA EWR-GRR JUL 3>0[4]
UA EWR-GSO JUL 3>0[4]
UA EWR-GSP JUL 2>0[3]
UA EWR-GUA JUL 0.8>0[1.0]
UA EWR-HAV JUL 0.8>0[1.0]
UA EWR-HNL JUL 0.8>0[1.0]
UA EWR-IAD JUL 6>2[6]
UA EWR-IAH JUL 8>3[9]
UA EWR-IND JUL 6>1.7[6]
UA EWR-JAX JUL 3>0.8[4]
UA EWR-LAS JUL 5>1.7[6]
UA EWR-LAX JUL 10>4[11]
UA EWR-LIR JUL 0.2>0[0.1]
UA EWR-MBJ JUL 3>0.9[2]
UA EWR-MCI JUL 3>0[4]
UA EWR-MCO JUL 8>3[9]
UA EWR-MEM JUL 2>0[3]
UA EWR-MEX JUL 2>0[3]
UA EWR-MIA JUL 4>2[4]
UA EWR-MKE JUL 3>0[4]
UA EWR-MSN JUL 1.7>0[1.8]
UA EWR-MSP JUL 5>1.7[5]
UA EWR-MSY JUL 3>0.8[4]
UA EWR-MYR JUL 3>0[2]
UA EWR-NAS JUL 1.7>0.8[1.0]
UA EWR-OKC JUL 0.8>0[1.0]
UA EWR-OMA JUL 1.6>0[3]
UA EWR-ORD JUL 9>5[10]
UA EWR-ORF JUL 5>0.8[5]
UA EWR-PBI JUL 4>3[5]
UA EWR-PDX JUL 1.7>0[2]
UA EWR-PHX JUL 3>0.7[3]
UA EWR-PIT JUL 6>3[7]
UA EWR-PLS JUL 0.8>0[1.0]
UA EWR-PNS JUL 0.8>0[1.0]
UA EWR-POP JUL 0.8>0[1.0]
UA EWR-POS JUL 0.8>0[1.0]
UA EWR-PQI JUL 1.5>0[1.7]
UA EWR-PTY JUL 1.1>0[1.3]
UA EWR-PUJ JUL 3>0.8[4]
UA EWR-PVD JUL 2>0[3]
UA EWR-PWM JUL 4>0.8[6]
UA EWR-RAP JUL 0.2>0[0.3]
UA EWR-RDU JUL 7>3[8]
UA EWR-RIC JUL 5>1.0[6]
UA EWR-ROC JUL 3>0.8[4]
UA EWR-RSW JUL 2>3[2.0]
UA EWR-SAL JUL 0.5>0[0.1]
UA EWR-SAN JUL 3>0.7[3]
UA EWR-SAP JUL 0.4>0[0.1]
UA EWR-SAT JUL 1.7>0.8[2.0]
UA EWR-SAV JUL 4>0.8[3]
UA EWR-SDF JUL 2>0[3]
UA EWR-SDQ JUL 2>0.8[2]
UA EWR-SEA JUL 3>0.7[4]
UA EWR-SFO JUL 13>4[14]
UA EWR-SJD JUL 0.2>0[0.3]
UA EWR-SJO JUL 1.8>0[2]
UA EWR-SJU JUL 1.7>0.8[2.0]
UA EWR-SLC JUL 0.8>0[1.0]
UA EWR-SMF JUL 0.8>0[1.0]
UA EWR-SNA JUL 2>0[3]
UA EWR-SRQ JUL 0.8>0[1.1]
UA EWR-STI JUL 1.7>0.8[1.0]
UA EWR-STL JUL 4>1.7[6]
UA EWR-SYR JUL 2>0[3]
UA EWR-TPA JUL 5>2[6]
UA EWR-TVC JUL 0.9>0[1.0]
UA EWR-TYS JUL 0.8>0[1.0]
UA EWR-XNA JUL 0.7>0[0.8]
UA EWR-YHZ JUL 3>0[3]
UA EWR-YQB JUL 3>0[3]
UA EWR-YUL JUL 3>0[3]
UA EWR-YVR JUL 0.8>0[1.0]
UA EWR-YYZ JUL 3>0[4]
UA FAI-ORD JUL 0.8>0[1.0]
UA FAR-ORD JUL 3>0.8[4]
UA FAT-LAX JUL 3>0.8[4]
UA FAT-ORD JUL 0.8>0[1.0]
UA FAT-SFO JUL 4>1.9[4]
UA FCA-LAX JUL 0.8>0[1.0]
UA FCA-ORD JUL 0.9>0.2[1.1]
UA FLL-IAH JUL 4>1.5[5]
UA FLL-ORD JUL 1.0>1.8[1.0]
UA FNT-ORD JUL 3>1.0[3]
UA FSD-ORD JUL 4>1.9[4]
UA FWA-ORD JUL 3>1.0[2]
UA GCM-IAH JUL 1.0>0[1.3]
UA GDL-IAH JUL 4>1.0[4]
UA GEG-IAH JUL 0.8>0[0]
UA GEG-ORD JUL 0.8>0[1.0]
UA GEG-SFO JUL 2>0.8[3]
UA GPT-IAH JUL 3>1.7[3]
UA GRB-ORD JUL 4>2[5]
UA GRK-IAH JUL 3>0.5[3]
UA GRR-IAD JUL 0.8>0[1.0]
UA GRR-IAH JUL 0.8>0[0.9]
UA GRR-ORD JUL 6>3[7]
UA GSO-IAD JUL 3>1.7[3]
UA GSO-ORD JUL 3>1.0[3]
UA GSP-IAD JUL 4>1.8[3]
UA GSP-IAH JUL 1.8>1.0[2]
UA GSP-ORD JUL 3>1.9[3]
UA GTF-ORD JUL 0.8>0[1.0]
UA GUA-IAD JUL 0.2>0[0.1]
UA GUA-IAH JUL 3>1.8[2]
UA HAV-IAH JUL 0.8>0[1.0]
UA HHH-IAD JUL 1.0>0[2]
UA HHH-ORD JUL 0.2>0[0.3]
UA HKG-SFO JUL 0.8>0.6[1.0]
UA HNL-IAD JUL 0.8>0[1.0]
UA HNL-IAH JUL 0.8>0[1.0]
UA HNL-LAX JUL 5>1.0[5]
UA HNL-SFO JUL 5>2.0[5]
UA HOB-IAH JUL 1.6>0.5[1.9]
UA HPN-ORD JUL 2>0[3]
UA HRL-IAH JUL 4>3[4]
UA HSV-IAD JUL 1.8>0.9[2]
UA HSV-IAH JUL 3>1.9[3]
UA HSV-ORD JUL 2>0.8[1.8]
UA HYS-SLN JUL 0.2>1.0[1.7]
UA IAD-IAH JUL 5>3[5]
UA IAD-ILM JUL 3>0.6[2]
UA IAD-IND JUL 4>1.8[4]
UA IAD-ITH JUL 3>0.2[3]
UA IAD-JAX JUL 3>1.8[3]
UA IAD-LAS JUL 3>0[2]
UA IAD-LAX JUL 6>1.8[8]
UA IAD-LEX JUL 1.7>0[2]
UA IAD-LGA JUL 3>1.8[4]
UA IAD-MCI JUL 3>0.7[2]
UA IAD-MCO JUL 4>1.8[4]
UA IAD-MDT JUL 3>1.6[3]
UA IAD-MEX JUL 0.8>0[1.0]
UA IAD-MHT JUL 1.7>0[2]
UA IAD-MSN JUL 1.7>0[0]
UA IAD-MSP JUL 2>0.7[2]
UA IAD-MSY JUL 3>1.0[2]
UA IAD-OKC JUL 1.6>0[1.0]
UA IAD-ORD JUL 6>4[6]
UA IAD-ORF JUL 4>1.8[4]
UA IAD-PDX JUL 0.8>0[1.0]
UA IAD-PHL JUL 4>1.8[0.0]
UA IAD-PHX JUL 0.8>0[1.0]
UA IAD-PIT JUL 4>1.8[4]
UA IAD-PQI JUL 0.2>0.9[0]
UA IAD-PVD JUL 3>1.7[4]
UA IAD-PWM JUL 4>1.8[4]
UA IAD-RDU JUL 4>1.8[4]
UA IAD-RIC JUL 4>1.8[4]
UA IAD-ROA JUL 3>1.6[2]
UA IAD-ROC JUL 3>1.8[3]
UA IAD-SAN JUL 3>0.9[3]
UA IAD-SAT JUL 1.7>0.8[2]
UA IAD-SAV JUL 3>1.8[3]
UA IAD-SCE JUL 1.6>1.0[1.9]
UA IAD-SDF JUL 3>1.7[2]
UA IAD-SEA JUL 3>0.7[4]
UA IAD-SFO JUL 6>2[7]
UA IAD-SHD JUL 1.7>0.6[1.0]
UA IAD-SJU JUL 0.8>0[1.0]
UA IAD-SMF JUL 0.8>0[1.0]
UA IAD-STL JUL 3>0.7[3]
UA IAD-STT JUL 0.8>0[1.0]
UA IAD-SYR JUL 3>1.8[3]
UA IAD-TPA JUL 3>1.8[3]
UA IAD-TVC JUL 0.9>0[0.1]
UA IAD-TYS JUL 3>1.8[4]
UA IAD-YOW JUL 3>0[3]
UA IAD-YUL JUL 3>0[3]
UA IAD-YVR JUL 0.3>0[0.1]
UA IAD-YYZ JUL 3>0.8[4]
UA IAH-ICT JUL 4>1.9[4]
UA IAH-IND JUL 4>1.7[4]
UA IAH-JAC JUL 0.2>0[0.1]
UA IAH-JAN JUL 4>3[4]
UA IAH-JAX JUL 4>2[4]
UA IAH-LAS JUL 5>1.7[6]
UA IAH-LAX JUL 9>4[10]
UA IAH-LBB JUL 3>1.7[3]
UA IAH-LEX JUL 0.8>0[0]
UA IAH-LFT JUL 5>3[5]
UA IAH-LGA JUL 7>2[8]
UA IAH-LIR JUL 3>0.6[2]
UA IAH-LIT JUL 5>1.9[6]
UA IAH-LRD JUL 3>1.5[3]
UA IAH-MAF JUL 6>3[7]
UA IAH-MCI JUL 4>2[4]
UA IAH-MCO JUL 6>2[7]
UA IAH-MEM JUL 5>2[5]
UA IAH-MEX JUL 5>2[6]
UA IAH-MFE JUL 6>3[7]
UA IAH-MIA JUL 4>1.8[4]
UA IAH-MID JUL 0.8>0[1.0]
UA IAH-MKE JUL 1.7>0[1.8]
UA IAH-MLM JUL 0.8>0[1.0]
UA IAH-MLU JUL 1.8>0.5[1.9]
UA IAH-MOB JUL 4>3[4]
UA IAH-MSP JUL 4>1.7[4]
UA IAH-MSY JUL 7>3[8]
UA IAH-MTJ JUL 0.8>0.2[1.0]
UA IAH-MTY JUL 6>1.0[7]
UA IAH-NAS JUL 1.7>0.8[2]
UA IAH-OAX JUL 0.8>0[1.0]
UA IAH-OKC JUL 7>3[8]
UA IAH-OMA JUL 3>0.6[3]
UA IAH-ONT JUL 0.8>0[1.0]
UA IAH-ORD JUL 8>4[9]
UA IAH-ORF JUL 1.7>0[2.0]
UA IAH-PBC JUL 0.8>0[1.0]
UA IAH-PDX JUL 3>0.8[3]
UA IAH-PHL JUL 4>1.7[5]
UA IAH-PHX JUL 4>1.6[4]
UA IAH-PIT JUL 4>1.7[5]
UA IAH-PNS JUL 4>1.9[4]
UA IAH-POS JUL 0.8>0[1.0]
UA IAH-PTY JUL 3>1.7[2]
UA IAH-PVR JUL 1.9>1.0[1.3]
UA IAH-QRO JUL 3>0.8[4]
UA IAH-RDU JUL 3>1.8[4]
UA IAH-RIC JUL 1.7>0[1.9]
UA IAH-RNO JUL 0.8>0[1.0]
UA IAH-RTB JUL 0.9>0[1.1]
UA IAH-SAL JUL 3>1.8[3]
UA IAH-SAN JUL 4>1.7[5]
UA IAH-SAT JUL 7>3[8]
UA IAH-SAV JUL 1.7>1.0[1.9]
UA IAH-SDF JUL 2>0.8[3]
UA IAH-SEA JUL 4>1.4[5]
UA IAH-SFO JUL 9>4[10]
UA IAH-SGF JUL 1.7>0[2.0]
UA IAH-SHV JUL 4>1.7[4]
UA IAH-SJC JUL 1.7>0[2]
UA IAH-SJD JUL 3>1.0[2]
UA IAH-SJO JUL 3>1.8[3]
UA IAH-SJU JUL 1.7>0.6[2.0]
UA IAH-SLC JUL 3>1.7[4]
UA IAH-SLP JUL 1.7>0.8[2]
UA IAH-SMF JUL 2>0[3]
UA IAH-SNA JUL 4>1.8[4]
UA IAH-STL JUL 4>1.6[5]
UA IAH-STT JUL 0.9>0.4[1.0]
UA IAH-TAM JUL 0.8>0[1.0]
UA IAH-TPA JUL 4>1.8[5]
UA IAH-TUL JUL 6>3[7]
UA IAH-TUS JUL 3>1.0[2]
UA IAH-TYS JUL 4>1.0[4]
UA IAH-VER JUL 0.8>0[1.0]
UA IAH-VPS JUL 3>1.0[3]
UA IAH-XNA JUL 4>1.8[3]
UA IAH-YVR JUL 1.7>0[2]
UA IAH-YYC JUL 1.5>0[1.7]
UA IAH-YYZ JUL 3>0[3]
UA ICT-ORD JUL 4>1.6[4]
UA ILM-ORD JUL 0.8>0[1.1]
UA IND-ORD JUL 8>3[8]
UA IND-SFO JUL 1.7>0.6[1.5]
UA ITO-LAX JUL 0.8>0.4[1.0]
UA JAC-ORD JUL 1.9>0.8[2]
UA JAX-ORD JUL 3>1.0[3]
UA KOA-LAX JUL 1.9>0.6[2]
UA KOA-SFO JUL 3>1.6[3]
UA LAN-ORD JUL 3>0.1[3]
UA LAS-LAX JUL 5>1.7[4]
UA LAS-ORD JUL 4>1.6[5]
UA LAS-SFO JUL 6>2[8]
UA LAX-LIH JUL 1.9>0.5[2]
UA LAX-MCO JUL 1.7>0.6[2]
UA LAX-MFR JUL 1.7>0[2]
UA LAX-MRY JUL 4>0.6[4]
UA LAX-MSN JUL 0.8>0[1.0]
UA LAX-MSO JUL 0.5>0[1.0]
UA LAX-OGG JUL 3>0.8[3]
UA LAX-ORD JUL 9>4[10]
UA LAX-PHX JUL 3>0[3]
UA LAX-PVR JUL 0.2>0[0.1]
UA LAX-RAP JUL 0.2>0[0.3]
UA LAX-RDD JUL 0.8>0[1.0]
UA LAX-RDM JUL 1.7>0[1.0]
UA LAX-RNO JUL 3>0.8[2]
UA LAX-SAN JUL 3>1.7[5]
UA LAX-SAT JUL 1.7>0[1.9]
UA LAX-SBA JUL 3>0[3]
UA LAX-SBP JUL 3>0.8[3]
UA LAX-SEA JUL 1.7>0[2]
UA LAX-SFO JUL 10>4[12]
UA LAX-SJD JUL 1.0>0[1.3]
UA LAX-SLC JUL 1.7>0.8[2]
UA LAX-SMF JUL 3>0.8[3]
UA LAX-YVR JUL 1.7>0[2]
UA LBL-PUB JUL 0.2>1.0[0.9]
UA LEX-ORD JUL 3>1.7[4]
UA LGA-ORD JUL 12>3[15]
UA LIH-SFO JUL 1.9>1.0[2]
UA LIT-ORD JUL 2>1.4[3]
UA LNK-ORD JUL 4>1.9[4]
UA MBS-ORD JUL 3>0.9[2]
UA MCI-ORD JUL 5>3[6]
UA MCI-SFO JUL 1.7>0[1.8]
UA MCO-ORD JUL 4>3[5]
UA MCO-SFO JUL 3>0.7[3]
UA MDT-ORD JUL 4>1.9[4]
UA MEM-ORD JUL 3>1.3[4]
UA MEX-ORD JUL 1.6>0[1.9]
UA MEX-SFO JUL 3>0[2]
UA MFR-SFO JUL 4>1.9[4]
UA MKE-ORD JUL 8>3[9]
UA MKE-SFO JUL 0.9>0[0.0]
UA MKG-ORD JUL 3>1.8[2]
UA MLI-ORD JUL 4>3[4]
UA MRY-SFO JUL 1.8>0.6[1.9]
UA MSN-ORD JUL 7>3[8]
UA MSN-SFO JUL 0.8>0[1.0]
UA MSO-ORD JUL 0.9>0[1.1]
UA MSP-ORD JUL 7>3[9]
UA MSP-SFO JUL 1.7>0.8[1.6]
UA MSY-ORD JUL 2>0.8[2]
UA MTJ-ORD JUL 0.9>0.2[1.1]
UA MTJ-SFO JUL 0.2>0[0]
UA MTY-ORD JUL 1.7>0[2]
UA MYR-ORD JUL 1.1>0.1[1.3]
UA OGG-ORD JUL 0.8>0[1.0]
UA OGG-SFO JUL 4>1.8[5]
UA OKC-ORD JUL 2>1.6[3]
UA OKC-SFO JUL 0.8>0[1.0]
UA OMA-ORD JUL 4>3[5]
UA OMA-SFO JUL 1.7>0[1.7]
UA ONT-SFO JUL 5>1.8[6]
UA ORD-ORF JUL 3>2[4]
UA ORD-PDX JUL 3>0.7[4]
UA ORD-PHL JUL 6>3[6]
UA ORD-PHX JUL 4>1.6[4]
UA ORD-PIA JUL 4>3[4]
UA ORD-PIT JUL 5>3[6]
UA ORD-PNS JUL 1.7>0[2.0]
UA ORD-PSC JUL 0.8>0[0]
UA ORD-PUJ JUL 0.8>0[1.0]
UA ORD-PVD JUL 2>0.8[3]
UA ORD-PWM JUL 3>1.0[2]
UA ORD-RAP JUL 1.8>0.8[3]
UA ORD-RDM JUL 0.8>0[1.0]
UA ORD-RDU JUL 5>3[6]
UA ORD-RIC JUL 5>2[4]
UA ORD-RNO JUL 0.8>0[1.0]
UA ORD-ROA JUL 3>1.8[3]
UA ORD-ROC JUL 4>1.9[4]
UA ORD-RST JUL 2>0.1[3]
UA ORD-RSW JUL 1.9>1.0[2]
UA ORD-SAN JUL 4>1.6[4]
UA ORD-SAT JUL 3>1.8[4]
UA ORD-SAV JUL 3>0.8[3]
UA ORD-SBA JUL 0.8>0[0]
UA ORD-SBN JUL 6>2[4]
UA ORD-SCE JUL 3>1.0[3]
UA ORD-SDF JUL 5>3[6]
UA ORD-SEA JUL 4>1.5[5]
UA ORD-SFO JUL 12>4[13]
UA ORD-SGF JUL 3>1.7[4]
UA ORD-SJC JUL 0.8>0[1.5]
UA ORD-SJU JUL 0.9>0[1.1]
UA ORD-SLC JUL 3>1.7[3]
UA ORD-SLN JUL 0.8>0.6[0.9]
UA ORD-SMF JUL 3>0.6[3]
UA ORD-SNA JUL 2>1.4[3]
UA ORD-SPI JUL 2>0.9[2]
UA ORD-STL JUL 7>3[8]
UA ORD-SYR JUL 4>1.7[5]
UA ORD-TPA JUL 3>1.0[3]
UA ORD-TUL JUL 3>1.5[4]
UA ORD-TUS JUL 0.8>0[0]
UA ORD-TVC JUL 5>2.0[4]
UA ORD-TYS JUL 4>1.9[4]
UA ORD-XNA JUL 4>1.6[4]
UA ORD-YHZ JUL 0.8>0[1.0]
UA ORD-YOW JUL 3>0[0]
UA ORD-YQB JUL 0.8>0[1.9]
UA ORD-YUL JUL 3>0.8[3]
UA ORD-YVR JUL 3>0[4]
UA ORD-YWG JUL 1.7>0[2]
UA ORD-YYC JUL 3>0.8[3]
UA ORD-YYZ JUL 6>1.7[7]
UA PDX-SFO JUL 7>2[8]
UA PHL-SFO JUL 1.7>0[2]
UA PHX-SFO JUL 4>1.8[4]
UA PIT-SFO JUL 1.7>0[1.9]
UA PSC-SFO JUL 1.7>0[1.0]
UA PSP-SFO JUL 3>1.8[3]
UA PVR-SFO JUL 1.1>0[1.4]
UA RAP-SFO JUL 0.2>0[0.3]
UA RDD-SFO JUL 3>1.8[3]
UA RDM-SFO JUL 5>1.9[5]
UA RDU-SFO JUL 1.7>0[2]
UA RIW-RKS JUL 0.1>1.0[0]
UA RNO-SFO JUL 4>2[4]
UA SAN-SFO JUL 8>4[8]
UA SAT-SFO JUL 0.8>0[1.0]
UA SBA-SFO JUL 6>2[6]
UA SBP-SFO JUL 4>1.9[4]
UA SEA-SFO JUL 7>5[9]
UA SFO-SIN JUL 0.8>0[2]
UA SFO-SJD JUL 1.3>0[1.4]
UA SFO-SLC JUL 4>3[5]
UA SFO-SMF JUL 4>1.8[5]
UA SFO-SNA JUL 6>3[7]
UA SFO-STL JUL 1.7>0[2]
UA SFO-STS JUL 0.9>0.6[1.0]
UA SFO-TPA JUL 1.7>0[2]
UA SFO-TUS JUL 3>2.0[3]
UA SFO-YVR JUL 4>1.7[5]
UA SFO-YYC JUL 1.7>0[1.9]
UA SFO-YYZ JUL 0.8>0[2]
UX JFK-MAD JUL 1.0>0.6[1.0]
UX MAD-MIA JUL 1.0>0.6[1.0]
VS ATL-LHR JUL 0.6>0.4[1.0]
VS ATL-MAN JUL 0.6>0.4[1.0]
VS BOS-LHR JUL 1.2>0.7[2]
VS IAD-LHR JUL 0.6>0.4[1.0]
VS JFK-LHR JUL 3>1.8[6]
VS JFK-MAN JUL 0.6>0.4[1.0]
VS LAS-LHR JUL 0.6>0.4[1.0]
VS LAX-LHR JUL 1.9>0.9[2]
*VS LGW-MCO JUL 1.4>0[1.9] AUG 3>0[2] SEP 1.5>0[1.3] OCT 1.1>0[1.6]
*VS LHR-MCO JUL 0>0.8[0] AUG 0>2[0] SEP 0>1.2[0] OCT 0.2>1.0[0]
VS LHR-MIA JUL 0.6>0.4[1.0]
VS LHR-SEA JUL 1.0>0.6[1.0]
VS LHR-SFO JUL 1.2>0.8[1.9]
VS MAN-MCO JUL 1.1>0.4[1.4] AUG 2.0>1.0[1.7] SEP 1.4>1.0[1.1] OCT 1.5>1.0[1.1]
WN ATL-FLL JUL 2>3[4]
WN ATL-MDW JUL 3>4[5]
WN ATL-PIT JUL 1.0>1.9[2]
WN ATL-RSW JUL 1.0>1.9[1.7] AUG 1.6>1.9[1.8]
WN AUS-LAX JUL 1.0>1.9[1.7]
WN BNA-CHS JUL 1.0>1.9[1.4] AUG 1.2>1.5[1.1]
WN BNA-DEN JUL 4>5[6]
WN BNA-ECP JUL 3>4[2]
WN BNA-JAX JUL 1.0>1.9[3]
WN BNA-ORF JUL 0>0.9[0.3] AUG 0.2>0.5[0.3]
WN BNA-PNS JUL 1.9>3[2]
WN BUF-DEN JUL 1.0>1.9[1.0] AUG 1.0>1.3[0.2]
WN BWI-PWM JUL 3>4[4]
WN BWI-RSW JUL 4>5[3]
WN DAL-ECP JUL 2.0>3[2]
WN DAL-FLL JUL 1.7>3[3]
WN DAL-PHX JUL 4>5[6]
WN DAL-PNS JUL 1.0>1.8[1.3] AUG 1.0>1.3[1.1]
WN DAL-SMF JUL 1.0>1.2[1.0]
WN DAL-STL JUL 4>5[6]
WN DEN-RNO JUL 1.0>1.9[2]
WN DEN-SLC JUL 4>5[6]
WN DEN-TUL JUL 1.0>1.9[2]
WN FLL-MDW JUL 2>3[4]
WN HOU-JAX JUL 1.0>1.9[1.0] AUG 1.0>1.3[1.0]
WN HOU-MCI JUL 1.0>1.9[3]
WN LAS-MDW JUL 6>7[8]
WN LAS-OAK JUL 5>6[9]
WN LAS-SLC JUL 3>4[5]
WN LAX-PHX JUL 4>5[8]
WN OAK-PHX JUL 4>6[6]
WN RSW-STL JUL 1.0>1.9[1.4] AUG 1.1>1.4[1.1]
enilria
Re: OAG Changes 6/7/2020: JULY SHANKED;AA Exits ORH;AS Adds BOI-SFO,Drops MSY-SFO,SAN-SBP/SMF;NK Out of AVL;F9 PHLMCO 6x
Sun Jun 07, 2020 11:49 am
"SHANKED (past tense of 'shank'): slash or stab, especially with a makeshift knife"
ChrisNH38
Sun Jun 07, 2020 12:11 pm
KE showing no eagerness to return to BOS...at least not apparently.
tphuang
Sun Jun 07, 2020 12:16 pm
Good morning enilria. This is quite the interesting load of updates.
Seems like AA's adds to PHL-BOS/ORD are directly related to F9 entrance into those markets.
There is a lot of capacity been added by NK/F9 to basically the same markets. It would be interesting to see what happens.
Just picking a couple of examples.
EWR-MYR saw NK going to 3x daily to counter F9 going to 3x weekly in that market? Really? what kind of demand could there be for that route in July.
PHL-MCO sees F9 going to 5x and then 6 daily this winter and NK upping to 4x daily. Again, that's pretty crazy in this demand environment.
Also a lot of increases from NK at EWR. Looks like someone wants to be noticed. I can't see this NK/F9 battle ending up well.
AS looks to be bringing some focus back to PDX.
enilria
Sun Jun 07, 2020 12:19 pm
If so it seems like a really disproportionate response.
Here's an interesting question. How are the "slots" that aren't really slots at EWR being handled in this environment? If you add flights now can you keep them later?
FlyPNS1
Some of the WN adds definitely reveal where WN sees summer growth. The DAL and BNA increases are more capacity than PNS saw last year! Granted WN is still down overall because other weekend routes from PNS to AUS/MDW/MCI/STL are cancelled.
MIflyer12
Sun Jun 07, 2020 12:20 pm
Summer demand, as is the case for lots of coastal destinations in the east. The entry shows 2 flights last year.
tphuang
Sun Jun 07, 2020 12:35 pm
Regarding PHL, I think F9 made the adds because it thinks AA is weak. And AA added those flights to give a warning to F9. I doubt these schedules will actually get run. There probably will be quite a few moves by ULCC to challenge legacies in their hubs. It'd be interesting to see how legacies react. Neither UA/DL has reacted to NK doubling their EWR-ATL flights.
As for EWR-MYR, there simply isn't that much demand there right now. Or else, UA would not have cut all their flights for July.
It seems NK is making a gambit to gain more EWR time slots.
MastaHanky
Sun Jun 07, 2020 12:46 pm
Interesting that DL is going 2x on DTW-ICN instead of resuming MSP-ICN.
RL757PVD
Sun Jun 07, 2020 1:48 pm
UA ACK-BGR? Are they running IAD-ACK-BGR?
ZazuPIT
Sun Jun 07, 2020 1:50 pm
Looks like AA is right-sizing their schedule after being criticized for flying so many near empty flights;, lots of cuts. I suspect DFW's newly bestowed title as the world's busiest airport won't last.
panamair
Sun Jun 07, 2020 1:55 pm
It’s not actually a second DTW-ICN per se as it’s really a DTW-ICN-PVG flight (notice that DTW-PVG is axed). They are using ICN as a technical stop for the PVG flight for a crew change to avoid having the crew layover in China. They are not selling seats for the local DTW-ICN on that flight. Same goes for the second SEA-ICN (and the cancellation of SEA-PVG).
Good to see that they are planning on some Pacific increases in July (in line with what Bastian said earlier this week about TPAC being the most promising of international right now). DTW-HND, ATL-ICN and LAX-SYD are showing some signs of life in July after being shelved for the last two months..
AirFiero
Sun Jun 07, 2020 1:58 pm
Now that it is ok for tens of thousands of people to protest or riot in the streets, I think we will see air travel pick up a lot sooner than later.
Still need vodka to get through it, though. ;)
joeblow10
Sun Jun 07, 2020 1:59 pm
PHL/TTN-Florida are some of the most successful group of routes for F9... 6x a day good? No idea. But the demand is there
Agree with the post above - the ULCCs are challenging the legacies and this is the perfect time to pounce. They don’t actually have to run all the frequencies if they don’t sell, but I’m sure it has the legacies sweating a little
kavok
Sun Jun 07, 2020 2:02 pm
Thanks Enilria as always!
It is interesting that the recently approved Delta station drops (from the CARES exemption) didn’t make this week’s schedule change, especially since press releases were already made in the affected markets about the service suspensions.
NWAESC
Sun Jun 07, 2020 2:13 pm
I noticed that too. Funny how the press release about AA adding flights sparked a rally for airline stocks, while this shows the opposite.
FlyPNS1
Sun Jun 07, 2020 2:25 pm
I think you’re misreading the file. Up until this week, AA was still selling a July schedule that was effectively last years schedule. They’re now bring the schedule in line with demand (or their perception of demand), however compared with June they are adding flights. However
, Enilria’s analysis isn’t comparing June against July.
tphuang
Sun Jun 07, 2020 2:26 pm
UA is running a more robust domestic schedule at IAD than I expected. Especially the shorter ranged stuff. Quite an interesting move since I had expected IAD to be the one station they bring back more slowly due to lack of competitive pressure there. They must be doing it because IAD is more profitable than their other coastal hubs.
Midwestindy
Sun Jun 07, 2020 2:38 pm
Opportunistic....NK should be thanking WN right now, lots of frequency & route adds to places they couldn't have entered a few months ago
jasoncrh
Yes
quote="RL757PVD"]UA ACK-BGR? Are they running IAD-ACK-BGR?[/quote]
NWAESC
Sun Jun 07, 2020 2:47 pm
I hear ya. My post was more general comment on how the press releases from AA/general reporting by the media are creating one message while the schedule loads tell another.
alasizon
Sun Jun 07, 2020 2:53 pm
AA is still running the most flights out of the US3 and is still growing quite a bit comparing June to July. The articles about AA adding flights was really about June vs July and the reductions are a lot less than if you compare where the June schedule was overlayed.
SANFan
Sun Jun 07, 2020 3:00 pm
As usual, I have no idea how much should be read into anything published for the end of the year 2020 but I will say that seeing this:
3>0[4]
does gobsmack me! I will await further comment 'til the late summer to see if this holds up...
Enilria, thanks for putting in the tremendous amount of effort this takes! Now more than ever in the past, what a huge job this must be; you've got to be replacing keyboards every month! It is appreciated by all of us here this morning.
bb
delta767
So is it official that AVL was cut and GSO stays? Or no official word from NK yet?
DeltaPSCFlyer
Sun Jun 07, 2020 3:03 pm
The inter-island quarantine in Hawai'i is being lifted 6/15, so that explains the 9X flight changes. Nothing yet for WN inter-island, probably next week.
nc3rd
I think youre still missing the point. The announcement that got all the press is still accurate. The flight reductions are from a near 100% scehdule.
DTWLAX
Sun Jun 07, 2020 3:08 pm
If DL is not selling seats for DTW-ICN on the second flight, why is it being listed as DTW-ICN instead of PVG? Even if it is a technical stop, shouldn't it be listed as DTW-PVG since the tickets are being sold for that route?
klm617
Sun Jun 07, 2020 3:11 pm
So here is a question. Why would Delta not sell space on that second SEA/DTW-ICN flights ?
AVLAirlineFreq
Sun Jun 07, 2020 3:43 pm
AVL still showing on the NK route map but isn't bookable for any flights. GSO bookable for flights beginning in late November. But as I said on this thread last week, I doubt NK will be back in AVL.
32andBelow
Sun Jun 07, 2020 3:56 pm
AS 15 a day SEA ANC. That’s pretty good. You need a covid test to go to Alaska rn.
mercure1
Probably the only other hub (other than IAH) which can help serve the building Sunbelt demand (DL and AA hubs are in much better spots).
LAXBUR
Sun Jun 07, 2020 4:13 pm
RE: BOI-SFO
80% of Idaho’s inbound growth is from California. Most has been from the LA/OC Area. With telecommuting here to stay, the Boise Area is expecting continued growth. I’m guessing an increased share of that will be from the Bay Area.
FlyingElvii
Sun Jun 07, 2020 4:21 pm
Ishrion wrote:
A breakdown of AA's changes in this: https://twitter.com/JTGenter/status/1269638725044142081
Ouch.....
Starting to see some anecdotal stuff out of the regionals, as well, with Late August/September schedule bids coming out.
Just from what I have read, Expressjet is getting crushed. I can’t see UA operating EX and Commutair both for much longer. EX is the bigger company, with more infrastructure. Republic seems to be the least affected by downgrades, (Single type) though they still have a lot of airplanes parked.
I have been looking for signs as to what the big three is planning for the regionals, but there just isn’t much out there. At this point, I think it would be a good guess that Oct 1st is going to be brutal.
FlyingElvii
Sun Jun 07, 2020 4:24 pm
Much lower Per Passenger cost for connecting traffic than EWR.
LCDFlight
Sun Jun 07, 2020 4:26 pm
DTW-PVG is currently prohibited by the Chinese government until further notice.
There is significant demand to/from China (which is usually tech industry, VFR or students anyway). So demand is not greatly affected. But literally zero flights USA-China nonstop. There is considerable pent up demand. Yields appear to be 300% of normal. China prohibits USA-China nonstops by US carriers. US prohibits China-USA nonstops by Chinese carriers. That's where we are right now.
sagechan
Sun Jun 07, 2020 4:38 pm
The July cuts are from AA's standard placeholder schedule, it's quite a few more flights then we're flown in June, but significant cuts from pre-covid schedules.
AmericanAir88
Sun Jun 07, 2020 4:39 pm
AA is still suspending a lot out of JFK. I am surprised by the suspension of JFK-DFW and JFK-ORD.
I hope AA starts to pick up steam again in JFK. AA has a great terminal and gateway for NY fliers.
ZazuPIT
Sun Jun 07, 2020 4:42 pm
I figured as much. I flew BNA-DFW-BNA this week. Saw some signs of life, but normal seems a long way off.
DeltaRules
Sun Jun 07, 2020 4:47 pm
Not bad for a station that was on their short list to be suspended.
freakyrat
Sun Jun 07, 2020 4:48 pm
DL is adding one SBN ATL flight back in in July. UA is actually operating 3 SBN ORD flights on select days in July.
NWAESC
Sun Jun 07, 2020 4:51 pm
enilria wrote:
I hadn't seen the release. FNT and the others are official? Just as they add flights.
Yep.
https://news.delta.com/delta-suspend-fl ... -us-cities
YOW as well (I believe that was mentioned on an earlier thread).
By my count, that makes 24 stations suspended (temporarily or indefinitely) by DL. Have any other carriers come close to that?
FlyingElvii
Sun Jun 07, 2020 5:04 pm
NWAESC wrote:
Yep.
This is from APC on June 1. Not sure if it means the August or September schedule bid:
“DELTA Massive Displacement Bid Posted
Delta's Surplus Bid was awarded just a short time ago. Roughly 2300 pilots now have no aircraft assignment as there weren't enough positions.
The Most Junior Captain on property now is a 2001 Hire. Prior to this bid, the most junior captain was a 2018 hire.
Total Displacements per this bid are 6,964.“
sprxUSA
Sun Jun 07, 2020 5:19 pm
Well it is a new route for them that they (9X/MW) didn't operate before.
wedgetail737
Sun Jun 07, 2020 5:56 pm
Since when did AS fly the SBA-STS route???
I'm sure all these flights are extremely fluid routes and frequencies. I'm sure many of these routes will show themselves in August or September.
ericm2031
Sun Jun 07, 2020 6:15 pm
Looks like this will be a tag to PDX, although SBA-STS-SBA isn't bookable on its own, which there probably is demand for...the non-stop is still showing 20 minutes later, so I'm guessing it didn't fully load correctly or they're still playing with the schedule.
kavok
NWAESC wrote:
Yep.
I will be curious to see how far out in the schedule these stations get dropped for. As in, will it just be no flights in July on the schedule, or July to September? Or will it be like YOW where all flights are zeroed out through the winter? Obviously going forward anything could change, but I think the initial end date selected could provide some clues as to whether the drop is intended to be temporary or permanent.
CIDFlyer
Sun Jun 07, 2020 6:25 pm
Actually compared to June they are running more flights. You can’t really compare the schedule of July 2019 to July 2020. You have to compare June 2020 to July 2020. DFW is supposed to have about 560 flights compared to the 400 or so now. CLT also is going from 320 to 450. Examples: CID - DFW is currently 2x moving to 3x in July. DSM currently 1x to DFW moving to 3x in July. ECP-CLT current 1.8 moving to 3x July. And so forth. Atlanta will only have about 450 flights on DL so DFW will still be running ahead of them.
chonetsao
Sun Jun 07, 2020 6:45 pm
I don't think this is end of July schedule rejuggling. Next weekend US CDC supposed to inform public about the extension of any European travel ban, as it is said to be reviewed every 30 days. 12th June should be the next.
I think there is a good chance that the current EU Travel Ban will stay. If that becomes reality, more cuts in US-EU flights will be coming.
continental004
Sun Jun 07, 2020 7:02 pm
Didn't SAN-SBP just begin?
I see this route coming back once hotels, etc. open for in-state tourism. In the meantime there's Amtrak.
Users browsing this forum: AC_B777, ba9216c, Bing [Bot], bval, dcajet, Flyerqf, FLYKTPA, Google [Bot], Google Adsense [Bot], Heavierthanair, mikebeau, nickya340, NPeterman, oakleaf1, shamrocka330, Shuttle, Singapore 777, SkyLife, stefanJ, SunsetLimited, twincommander and 134 guests
