AmericanAir88 wrote:WN: I could see them trying to get more destinations and/or slots. A bigger LGA means bigger opportunities. I think an LGA-LAS flight could be a game changer for tourists.
AmericanAir88 wrote:The LGA Terminal B headhouse is finally opening this weekend! I am so excited to try out the new headhouse soon. It is very impressive to drive by. It is said that it is 50% bigger than the old headhouse.
The pictures look amazing. http://www.salamancapress.com/news/state/walsh-construction-celebrates-unveiling-of-laguardia-airports-new-terminal-b-headhouse/article_1fbe78c4-5a9d-5e50-b597-c8c32b101f24.html
What will this new Laguardia hold for airlines:
AA: I have no idea what AA will do. What do you guys think? I personally would like AA to add more to JFK in the short term. T8 needs to get crowded again.
UA: UA will probably stay the same. LGA is a spillway for their EWR operations. Maybe more IAH/DEN flights.
NK and F9: Will probably move back to Terminal B (once the west opens) as Delta is getting their own remodel. F9 could bring back Denver.
B6: I have no idea why B6 is in the marine air terminal (A). In my opinion, B6 should move back to Terminal B and let Terminal A become a regional concourse similar to LAX.
WS/AC: Probably no change except maybe WS moving to Terminal B.
DL: TBD
Let me know what you think.
CaptainObvious1 wrote:AmericanAir88 wrote:WN: I could see them trying to get more destinations and/or slots. A bigger LGA means bigger opportunities. I think an LGA-LAS flight could be a game changer for tourists.
There is an obvious reason there are no flights LGA-LAS, unless it is on a Saturday it is too far for LGA flights.
If weekday LGA-LAS flights were possible that would be a game changer. It would mean the perimeter rule is no longer in existence.
Captain Obvious.
AmericanAir88 wrote:CaptainObvious1 wrote:AmericanAir88 wrote:WN: I could see them trying to get more destinations and/or slots. A bigger LGA means bigger opportunities. I think an LGA-LAS flight could be a game changer for tourists.
Captain Obvious.
The perimeter rule makes sense, but with flights already to DEN, would it really hurt that much to change the rules to allow some SWA flights to LAS?
Also, isn't AA flying to PHX, BZN, EGE, FCA, JAC, MTJ, AUA, and NAS? All are past the perimeter rule.
aemoreira1981 wrote:The Port Authority really should modify the perimeter rule to be anywhere in the USA or pre-cleared airports in Canada...if you have the slots. The limitation might be runway length. Some trans-cons could definitely shift to LGA. A real wild-card could be Air Canada...as if you eliminate the perimeter rule, would they consider A321 YVR-LGA service? This would not hurt JFK as JFK could see more international destinations open up.
Captain Obvious.
AmericanAir88 wrote:The perimeter rule makes sense, but with flights already to DEN, would it really hurt that much to change the rules to allow some SWA flights to LAS?
AmericanAir88 wrote:The pictures look amazing. http://www.salamancapress.com/news/state/walsh-construction-celebrates-unveiling-of-laguardia-airports-new-terminal-b-headhouse/article_1fbe78c4-5a9d-5e50-b597-c8c32b101f24.html
evank516 wrote:aemoreira1981 wrote:The Port Authority really should modify the perimeter rule to be anywhere in the USA or pre-cleared airports in Canada...if you have the slots. The limitation might be runway length. Some trans-cons could definitely shift to LGA. A real wild-card could be Air Canada...as if you eliminate the perimeter rule, would they consider A321 YVR-LGA service? This would not hurt JFK as JFK could see more international destinations open up.
AC pulled out of JFK some time ago, so relaxing the perimeter rule to allow YVR-LGA wouldn't hurt JFK in the slightest except for the fact that DL would probably move their summer JFK-YVR flight to LGA if it comes back. They consolidated to EWR and LGA from what I recall with EWR handling their beyond perimeter flights to YVR and YYC and LGA handling their shorter flights within the perimeter.
aemoreira1981 wrote:evank516 wrote:aemoreira1981 wrote:The Port Authority really should modify the perimeter rule to be anywhere in the USA or pre-cleared airports in Canada...if you have the slots. The limitation might be runway length. Some trans-cons could definitely shift to LGA. A real wild-card could be Air Canada...as if you eliminate the perimeter rule, would they consider A321 YVR-LGA service? This would not hurt JFK as JFK could see more international destinations open up.
Do keep in mind though that YVR-EWR is on a wide-body. The smallest wide-bodies in the AC fleet are the A330-300 and the Boeing 787-8 (at suspension, AC548/9 was flown on a mix of B788/B789 equipment in a move ultimately forcing CX off the JFK-YVR city pair).
Leej wrote:Apologies but can somebody explain to me what a 'headhouse' is? Can't access the article.Would it be what the rest of the planet calls a terminal? I know LGA has been undergoing some tremendous works of late...
Polot wrote:Most of the people in this thread have completely missed the point. The new terminal is just providing more space for the passengers with modern amenities and security in mind. The airfield is still the same size. The airspace is still the same.
LGA is still slot restricted, and the new terminal does not allow for more slots (that is an airfield and airspace limitation, not a terminal limitation). Growth is going to have to occur at someone else’s expense. There is still little political will in the PANYNJ to remove the perimeter rule.AmericanAir88 wrote:The perimeter rule makes sense, but with flights already to DEN, would it really hurt that much to change the rules to allow some SWA flights to LAS?
Yes because they can’t show favoritism. If they allow LAS just so SWA can fly it then they have set precedence and Airlines A, B, and C are going to be demanding that they be allowed to fly to X, Y, Z (all outside the perimeter) too.
DEN is only allowed because that was the only city outside the perimeter that actually had LGA flights at the time the perimeter rule was implemented, and any carrier is free to fly the route.
bpat777 wrote:Leej wrote:Apologies but can somebody explain to me what a 'headhouse' is? Can't access the article.Would it be what the rest of the planet calls a terminal? I know LGA has been undergoing some tremendous works of late...
Correct the headhouse is kinda a fancy term for the ticketing and baggage claim area.
Cointrin330 wrote:Polot wrote:Most of the people in this thread have completely missed the point. The new terminal is just providing more space for the passengers with modern amenities and security in mind. The airfield is still the same size. The airspace is still the same.
Exactly, and on point. The future of LGA is intact and it will continue to operate as a key preferred choice for business travelers who need to reach Manhattan as quickly as possible. The new terminals improve the passenger experience dramatically, but it does not change the fact that the land LGA sits on is small, with no room to grow, and the airport remains in the middle of one of the most congested airways in the country (once traffic resumes that is). Perimeter rule issues are not going to go away any time soon, in that you may see more weekend services and potentially down the road, one or two regular services but not much more. The runways are short and space is at a premium. Every inch LGA sits on matters.
JFKalumni wrote:Cointrin330 wrote:Polot wrote:Most of the people in this thread have completely missed the point. The new terminal is just providing more space for the passengers with modern amenities and security in mind. The airfield is still the same size. The airspace is still the same.
It may be possible to relax the perimeter rule in the future especially considering Cuomo’s ambitious nature to improve LGA by all means. LGA is a businessman’s airport with no direct service to the west coast. With today’s A220’s and A321’s, the west coast is reachable even with LGA’s 7,000ft runways.
Only problem I see is smaller markets will lose access to LGA in favor of larger hubs via slot allocation.
It's possible yes....and I forgot to mention (and agree with you) that the pandemic may result in airlines shedding some slots used for regional services that may not come back and apply them toward transcon, at which point, the competition will be fierce with DL, AA, B6, and UA all vying for this.
deltairlines wrote:JFKalumni wrote:Cointrin330 wrote:
And therein lies the problem. Those folks in Buffalo, Rochester and Syracuse would likely see some of their LGA service cut in favor of those Outside-Perimeter markets, and they'll raise hell with Cuomo over that. And even though it's a PANYNJ rule (and not federal like DCA), there would be a lot of politicians in the Northeast that wouldn't be too happy losing their link to LGA.
Truth be told, for West Coast, JFK isn't that bad. On a good day (rare), I can get from LGA to Penn Station in 20 minutes by cab, but it's often in the 40 minute range. I typically budget about 50 minutes to get from JFK to Penn Station (via Jamaica/LIRR). However, LGA sees a good bit of same-day/maybe one overnight business traffic, while West Coast traffic tends to be more than just a single night, which makes time a little less of a commodity.
Makes sense, access to LGA is not a right and all other small cities can make a one stop connection to LGA. I remember years back US had a lot of Dash-8-100's using up valuable slots for a handful of passengers, not a wise use of limited resources. Small cities in the Northeast can connect through PHL to LGA. The slots LGA has is all its ever going to have, so let the slots be used for moving the greater number of people.
JFK is not bad at all. Me personally I find it easier to travel to EWR than JFK or LGA. NJ Transit from Penn station to EWR or the Newark Express bus from the Port Authority bus terminal is 25 minutes.
I’m glad LGA has installed new bridges from the terminal to East Elmhurst but it’s only a matter of time before people start complaining about increased traffic on Ditmars Blvd.
My real wish is to have the new Airtrain travel down the Grand Central / Van Wyck to the Jamaica Airtrain station. Take some pressure off both airports by having a simple connection between the two.
Exactly.
Add LAX/SFO/SJU/BQN/LAS/SEA/YVR/YYC
Routes that are sure to make money in the NYC area
Exactly.
This keeps getting brought up, but I don't know why people are so obsessed with removing perimeter rules at LGA? We have a s good setup right now where the inner and preferred airport don't take up all the business traffic. Removing perimeter rule would just crowd LGA more and empty out JFK?. Why would you want that? If anything, it'd be better to get rid of LGA and consolidate all traffic at EWR and JFK. Then people would actually be able to easily take airtrain + subway to get to the airport instead of having to take uber everytime.
If you don't like how slots are getting used at LGA. Make some rules on minimum aircraft size.
JFKalumni wrote:tphuang wrote:JFKalumni wrote:
Exactly.
LGA has too many RJ flights between itself and small cities around the country that may not come back. Also, do you really need hourly service between LGA-DCA and LGA-BOS, especially considering the new revamped Acela train service coming online soon?
Eliminate the excess overlap in certain markets and utilize those slots for other areas.
Here’s a money maker:
Eliminate the perimeter rule and start LGA-SJU/BQN. B6 would make an absolute killing on that route.
Exactly.
TTailedTiger wrote:tphuang wrote:JFKalumni wrote:
Exactly.
How would removing the perimeter rule make LGA more crowded? Airlines have a fixed number of slots to utilize. A 737 is the same size no matter what route it is on. If a 737 operating LGA-MCI gets moved to LGA-LAX, it's still the same amount of passengers in the terminal.
The 737/A320s will be replacing RJs that now operate to smaller markets. JFK will just become a lot more idle.
B6 doesn't have enough slots to waste them on LGA-SJU/BQN. It's a terrible idea.
We have LGA slots being used this way because the markets demand it that way and because the existing slot holders value their slots. Their is no evidence LGA right now sees higher % of RJ than other major markets around the country.
Removing perimeter rule basically just help DL and hurt JetBlue. It's terrible for traffic around LGA. Maybe you think it's a good thing to destroy New York's hometown airline with such a move. But I doubt the politicians will think the same way.
There was a time before regional jets when LGA was all mainline and it managed just fine. JFK is still needed for international flights and hub airlines will still need domestic flights to feed them. JFK would be just fine if LGA is set free.
Insertnamehere wrote:Does anyone know if they are going to add ferry access to LGA? With the NYC ferry already heading up to Astoria and heading as far as Far rockaway, I don't see why they couldn't build a ferry stop and allow people to connect. They did have it in some renderings I believe.
There isn't much traffic in the Northeast even going to LGA now. A lot of it went away when Delta took over from US Airways. Those props going around the Northeast were quickly turned into 76-seat RJs going to STL, MCI, DFW, IAH, MKE and more. The only real destinations in the Northeast now with flights to LGA are PHL (to feed from the rest of AA's network in PHL), PWM (which is a bear of a drive and is a popular destination both ways), BGR (seasonal, with this being the gateway to Acadia), BOS, BUF, BTV, ROC, SYR, DCA. As I said, BUF/ROC/SYR aren't going anywhere for political reasons. BOS and DCA have some demand. Even with the new Acela, I'd still fly to BOS (and I'm coming from Hell's Kitchen). The train from New York to Boston will still have secondary status up to New Haven (since Metro North owns those tracks), then grade crossings and bridges through Connecticut mean it can't chop off a lot of time there. DCA is a different story, but that was already getting cut back - Delta hasn't flown it hourly in a long time. Not to mention that LGA is a DL hub and DCA is an American hub so there is through connectivity now on both sides. That really only leaves BTV - which can also get political since it's really the easiest way for those in North Country to get to NYC, especially when the ferry is running across Lake Champlain.
Next is aircraft utilization. Are we 100% sure that an A321 can make it cross-country Westbound on a 7000 ft runway year round? Add in some 90+ degree days (like right now), or add some rain, or add some snow and that's a big ask. Just because AA and B6 have the transcon 321s, it doesn't mean they are necessarily lighter - those business/first class seats weigh a lot more than your normal set of domestic First Class seats. As for Delta, they were running 767s to LAX/SFO. I doubt they will have any 767-capable gates in their remodeled terminal, so that means 757s, which if/when things come back, there are only so many of those between LAX-BOS/DCA as well as any trans-Atlantic flying they might use them on.
Captain Obvious.
xdlx wrote:CaptainObvious1 wrote:AmericanAir88 wrote:WN: I could see them trying to get more destinations and/or slots. A bigger LGA means bigger opportunities. I think an LGA-LAS flight could be a game changer for tourists.
Captain Obvious.
Well we know how well ACY attracted those tourist...
TonyClifton wrote:I’d like to see loosening of the perimeter rule. If JFK takes the hit, so be it, let folks decide what airport they want to fly into. You can’t prop JFK up and jam LGA full of RJs.
Sightseer wrote:TonyClifton wrote:I’d like to see loosening of the perimeter rule. If JFK takes the hit, so be it, let folks decide what airport they want to fly into. You can’t prop JFK up and jam LGA full of RJs.
I'm honestly a little surprised there haven't been rumblings about introducing a few beyond-perimeter exemptions for LGA like what was done at DCA several years back, where the then-US4 were allowed to drop service to a "large" within-perimeter airport and use that slot pair to serve a beyond-perimeter one. Instituting something similar at LGA would allow small markets to keep their service while opening up non-stops to new markets.
