enilria
OAG Changes 6/21/2020:August Under Fire;AA Adds DFW-MYR;F9 Builds CVG;DL Drops LAS-LGB/PDX/SAN/SJC/SNA;UA Out of SMX
Sun Jun 21, 2020 11:54 am
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
4B ALS-DEN SEP 0.2>4[4]
4B ATL-GLH SEP 0.0>0.9[1.0] OCT 0>0.9[1.0] NOV 0>0.7[0.8]
4B BOS-MSS SEP 0.1>3[3] NOV 0>2[3]
4B BWI-JST SEP 0.1>1.7[2] OCT 0>1.7[2]
4B CDR-DEN SEP 0.1>1.9[2] OCT 0>1.8[2] NOV 0>1.3[1.7]
4B CEZ-DEN SEP 0.1>3[3] NOV 0>2[3]
4B CEZ-PHX NOV 0>0.7[0.9]
4B DEN-MCK SEP 0.1>1.9[2] OCT 0>1.8[2] NOV 0>1.8[1.7] DEC 0>1.8[2] JAN 0>0.3[2]
4B DFW-GLH SEP 0.1>2[2] NOV 0>1.4[1.7]
4B DFW-VCT SEP 0.1>1.3[1.9]
4B IAH-VCT SEP 0.1>1.7[1.9]
4B LAX-MCE SEP 0.1>3[3] NOV 0>1.9[3]
4B MCE-SMF SEP 0.0>1.0[0] OCT 0>1.0[1.4] NOV 0>0.7[1.4]
4B PHX-SOW SEP 0.1>3[3] NOV 0>1.9[3]
9X HNL-MKK AUG 7>12[0] SEP 6>12[0] OCT 6>12[0] NOV 6>12[0.1] DEC 6>12[0.0]
9X KOA-OGG AUG 5>7[0] SEP 4>6[0] OCT 4>6[0] NOV 4>6[0] DEC 4>6[0]
9X MKK-OGG AUG 6>11[0] SEP 6>11[0] OCT 6>11[0.4] NOV 6>11[0.1] DEC 6>11[0]
AA BZN-DFW NOV 1.0>1.4[1.3] DEC 1.5>2[1.5] JAN 1.2>2[1.2] FEB 1.0>2[1.0] MAR 1.0>2[1.0] APR 1.0>2[1.0]
AA DFW-JAC OCT 1.2>2[0.9] NOV 1.0>2[0.9] DEC 1.5>2.0[1.4] JAN 1.2>2[1.2] FEB 1.1>2[1.1] MAR 1.1>2[1.1] APR 1.0>2[0]
AA DFW-MSO OCT 1.0>1.8[1.0] NOV 1.0>2[1.0] DEC 1.0>2[1.0] JAN 1.0>2[1.0] FEB 1.0>2[1.0] MAR 1.0>2[1.0] APR 1.0>2[1.0]
**AA DFW-MYR DEC 0>1.0[0.1] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0.1] APR 0.1>1.0[0.1]
AA DFW-RNO OCT 2>3[3] NOV 2>3[3] DEC 2>3[3] JAN 2>3[3] FEB 2>3[2] MAR 2>3[3]
AA MIA-PLS AUG 1.4>2.0[3]
AC BOS-YVR SEP 0.8>0[0.5] OCT 0.4>0[0]
AC BWI-YUL SEP 1.5>0[2] OCT 1.5>0.2[1.5]
AC IAD-YUL SEP 1.8>1.0[2] OCT 1.8>1.0[1.9]
AC IAD-YYZ SEP 3>2[3] OCT 3>2[3]
AC PDX-YVR SEP 4>3[4]
AF CDG-MIA AUG 0>0.3[1.0]
AM MEX-SEA AUG 1.0>0[1.0] SEP 1.0>0[1.0]
AN HHR-PHX AUG 0.4>0.2[0.4] SEP 0.4>0.2[0.4]
*B6 AUS-EWR AUG 0>1.7[0] SEP 0>2[0] OCT 0>2[0] NOV 0>2[0] DEC 0>2[0] JAN 0>2[0] FEB 0>0.7[0]
*B6 CHS-EWR AUG 0>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>0.4[0]
*B6 CLE-RSW OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>0.4[0]
*B6 DCA-TPA OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>0.4[0]
*B6 DFW-JFK AUG 0>1.8[0] SEP 0>2[0] OCT 0>2[0] NOV 0>2[0] DEC 0>2[0] JAN 0>2[0] FEB 0>0.7[0]
*B6 DTW-JFK AUG 0>1.8[0] SEP 0>2[0] OCT 0>2[0] NOV 0>2[0] DEC 0>2[0] JAN 0>2[0] FEB 0>0.7[0]
*B6 EWR-JAX AUG 0>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>0.4[0]
*B6 EWR-LAS AUG 0>1.7[0] SEP 0>2[0] OCT 0>2[0] NOV 0>2[0] DEC 0>2[0] JAN 0>2[0] FEB 0>0.7[0]
*B6 EWR-LAX AUG 0>3[0] SEP 0>3[0] OCT 0>3[0] NOV 0>3[0] DEC 0>3[0] JAN 0>3[0] FEB 0>1.1[0]
*B6 EWR-PHX AUG 0>1.7[0] SEP 0>2[0] OCT 0>2[0] NOV 0>2[0] DEC 0>2[0] JAN 0>2[0] FEB 0>0.7[0]
*B6 EWR-SAN AUG 0>0.8[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>0.4[0]
*B6 EWR-SFO AUG 0>1.8[0] SEP 0>2[0] OCT 0>2[0] NOV 0>2[0] DEC 0>2[0] JAN 0>2[0] FEB 0>0.7[0]
*B6 EWR-SRQ AUG 0>0.8[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>0.4[0]
*B6 FLL-PDX OCT 0>0.3[0] NOV 0>0.3[0] DEC 0>0.3[0] JAN 0>0.3[0]
*B6 FLL-PIT OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>0.4[0]
*B6 FLL-SEA OCT 0>0.4[0] NOV 0>0.4[0] DEC 0>0.4[0] JAN 0>0.4[0]
*B6 JFK-MSP AUG 0>1.7[0] SEP 0>2[0] OCT 0>2[0] NOV 0>2[0] DEC 0>2[0] JAN 0>2[0] FEB 0>0.7[0]
*B6 LGA-RSW AUG 0>0.8[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>0.4[0]
*B6 LGA-TPA AUG 0>0.8[0] SEP 0>1.0[0] OCT 0>2[0] NOV 0>2[0] DEC 0>2[0] JAN 0>2[0] FEB 0>0.7[0]
*B6 MCO-PHL AUG 0>1.7[0] SEP 0>2[0] OCT 0>2[0] NOV 0>2[0] DEC 0>2[0] JAN 0>2[0] FEB 0>0.7[0]
*B6 MCO-SFO OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>0.4[0]
*B6 ORD-PBI OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>0.4[0]
*B6 PBI-PHL AUG 0>1.7[0] SEP 0>2[0] OCT 0>2[0] NOV 0>2[0] DEC 0>2[0] JAN 0>2[0] FEB 0>0.7[0]
*B6 PBI-PIT OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>0.4[0]
*B6 PHL-RSW AUG 0>0.8[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>0.4[0]
*B6 PHL-SJU AUG 0>0.8[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0]
*B6 PHL-TPA AUG 0>0.8[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>0.4[0]
*B6 PVD-RSW OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>0.4[0]
*B6 PVD-TPA OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>0.4[0]
CM IAD-PTY AUG 1.0>0.8[2]
CM JFK-PTY AUG 1.0>0.8[3]
DL's schedule systemwide ASM % over prior year:
JAN 106%
FEB 107%
MAR 90%
APR 20%
MAY 13%
JUN 17%
JUL 30%
AUG 54%
DL ABE-ATL AUG 3>1.0[3]
DL ABE-DTW AUG 3>2[3]
DL ABQ-ATL AUG 3>2[3]
DL ABQ-LAX AUG 3>2[3]
DL ABQ-MSP AUG 1.0>0[1.0]
DL ABY-ATL AUG 3>2[3]
DL AEX-ATL AUG 4>2[4]
DL AGS-ATL AUG 9>6[8]
DL ALB-ATL AUG 4>2[4]
DL ALB-DTW AUG 4>3[4]
DL ALB-MSP AUG 1.0>0[1.0]
DL AMS-BOS AUG 2>1.0[2] SEP 2>1.0[2] OCT 1.7>1.0[1.8]
DL AMS-DTW AUG 2>1.0[4]
DL AMS-JFK AUG 1.0>1.7[2] SEP 1.0>2[2] OCT 1.2>1.9[2]
DL AMS-MSP AUG 2>0.7[3] SEP 2>1.0[3] OCT 2>1.3[3]
DL AMS-PDX AUG 1.0>0[1.0]
DL AMS-SEA AUG 2>1.0[2] SEP 2>1.0[2] OCT 1.7>1.0[1.7]
DL AMS-SLC AUG 1.0>0[1.0]
DL ANC-SEA AUG 6>5[6]
DL ANC-SLC AUG 0.7>0[0.8]
DL ASE-ATL APR 1.0>0[0]
DL ASE-LAX JAN 0.6>1.1[1.2] FEB 0.5>1.0[1.0] MAR 0.5>0.9[0.9] APR 0.5>0[0]
DL ATL-ATW AUG 2>1.0[2.0]
DL ATL-AUS AUG 9>6[9]
DL ATL-AVL AUG 8>5[8]
DL ATL-BDL AUG 7>5[7]
DL ATL-BHM AUG 11>8[10]
DL ATL-BMI AUG 3>2[3]
DL ATL-BNA AUG 11>7[10]
DL ATL-BOS AUG 12>8[12]
DL ATL-BQK AUG 3>2[3]
Weren't these ATL-Europes just put back in a week ago?
*DL ATL-BRU AUG 1.0>0[1.0] SEP 1.0>0[0.8] OCT 0.7>0.1[0.7]
DL ATL-BTR AUG 6>3[6]
DL ATL-BTV AUG 1.0>0[1.4]
DL ATL-BUF AUG 5>3[5]
DL ATL-BWI AUG 11>7[11]
DL ATL-BZN APR 1.0>0[0]
DL ATL-CAE AUG 8>7[8]
DL ATL-CDG AUG 1.0>2[2] SEP 1.0>2[2] OCT 1.0>1.8[2]
DL ATL-CHA AUG 10>8[10]
DL ATL-CHO AUG 5>3[5]
DL ATL-CHS AUG 11>8[10]
DL ATL-CID AUG 3>1.0[3]
DL ATL-CLE AUG 8>6[8]
DL ATL-CLT AUG 9>7[9]
DL ATL-CMH AUG 8>6[8]
DL ATL-CRW AUG 5>3[5]
DL ATL-CSG AUG 4>3[4]
DL ATL-CUN AUG 6>5[6]
DL ATL-DAB AUG 6>4[5]
DL ATL-DAY AUG 4>3[4]
DL ATL-DCA AUG 12>7[11]
DL ATL-DEN AUG 9>6[9]
DL ATL-DFW AUG 8>7[10]
DL ATL-DHN AUG 4>2[4]
DL ATL-DTW AUG 11>10[12]
*DL ATL-DUS AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.9>0.2[0.9]
DL ATL-EGE APR 1.1>0[0]
DL ATL-ELH AUG 0.7>0[0.4]
DL ATL-ELP AUG 3>2[3]
DL ATL-EWR AUG 11>7[12]
DL ATL-FAY AUG 5>4[5]
DL ATL-FLL AUG 12>9[12]
DL ATL-GCM AUG 1.2>0[1.1]
DL ATL-GDL AUG 1.0>0[1.0]
DL ATL-GGT AUG 0.7>0[0.6]
DL ATL-GIG OCT 0.3>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0.4[1.0]
DL ATL-GNV AUG 7>5[7]
DL ATL-GPT AUG 5>4[5]
DL ATL-GRB AUG 1.8>1.0[1.7]
DL ATL-GRR AUG 5>3[5]
DL ATL-GRU AUG 1.0>0.5[1.0]
DL ATL-GSO AUG 9>7[8]
DL ATL-GSP AUG 9>7[8]
DL ATL-GUA AUG 2.0>0.7[2.0]
DL ATL-HDN APR 1.0>0[0]
DL ATL-HOU AUG 7>4[6]
DL ATL-HSV AUG 7>6[7]
DL ATL-IAD AUG 7>5[7]
DL ATL-IAH AUG 8>6[8]
DL ATL-ICT AUG 3>2[3]
DL ATL-IND AUG 10>6[9]
DL ATL-JAC AUG 0.4>0[0.4] APR 1.0>0[0]
DL ATL-JAN AUG 8>5[7]
DL ATL-JAX AUG 11>8[12]
DL ATL-JFK AUG 8>6[8]
DL ATL-JNB AUG 1.0>0[1.0]
DL ATL-KIN AUG 1.0>0.6[1.0]
DL ATL-LAS AUG 8>6[8]
DL ATL-LAX AUG 12>9[12]
DL ATL-LEX AUG 8>6[8]
DL ATL-LFT AUG 4>3[4]
DL ATL-LGA AUG 16>10[16]
DL ATL-LIT AUG 7>5[7]
DL ATL-MBJ AUG 3>2[3]
DL ATL-MCI AUG 8>6[8]
DL ATL-MCO AUG 16>10[16]
DL ATL-MDT AUG 3>1.0[3]
DL ATL-MEM AUG 10>7[10]
DL ATL-MEX AUG 5>3[5]
DL ATL-MGM AUG 7>4[6]
DL ATL-MIA AUG 10>7[11]
DL ATL-MKE AUG 8>5[8]
DL ATL-MLB AUG 4>3[4]
DL ATL-MLI AUG 3>2[3]
DL ATL-MLU AUG 4>3[4]
DL ATL-MOB AUG 7>5[7]
DL ATL-MSN AUG 4>3[4]
DL ATL-MSP AUG 11>9[11]
DL ATL-MSY AUG 10>7[10]
DL ATL-MTY AUG 1.8>0[2.0]
DL ATL-NAS AUG 4>1.0[4]
DL ATL-OKC AUG 6>5[6]
DL ATL-OMA AUG 6>5[5]
DL ATL-ONT AUG 3>2[1.8]
DL ATL-ORD AUG 11>7[11]
DL ATL-ORF AUG 9>6[9]
DL ATL-PBI AUG 10>7[10]
DL ATL-PHL AUG 10>7[9]
DL ATL-PHX AUG 5>4[5]
DL ATL-PIT AUG 9>6[8]
DL ATL-PNS AUG 8>6[8]
DL ATL-PSP APR 0.6>0.4[0]
DL ATL-PTY AUG 1.0>0.4[1.0]
DL ATL-PWM AUG 3>2[3]
DL ATL-RDU AUG 11>8[12]
DL ATL-RIC AUG 10>6[10]
DL ATL-ROA AUG 5>3[5]
DL ATL-ROC AUG 3>2[3]
DL ATL-RST AUG 1.9>0[1.8]
DL ATL-RSW AUG 7>6[7]
DL ATL-SAL AUG 1.0>0.2[1.0]
DL ATL-SAN AUG 7>5[7]
DL ATL-SAP AUG 1.0>0.4[1.0]
DL ATL-SAT AUG 7>5[8]
DL ATL-SAV AUG 11>9[10]
DL ATL-SBN AUG 4>3[4]
DL ATL-SDF AUG 9>6[8]
DL ATL-SDQ AUG 1.0>0[1.0]
DL ATL-SEA AUG 10>8[9]
DL ATL-SFO AUG 9>7[9]
DL ATL-SGF AUG 4>3[4]
DL ATL-SHV AUG 7>4[6]
DL ATL-SJC AUG 3>1.0[2]
DL ATL-SJU AUG 4>3.0[4]
DL ATL-SLC AUG 9>11[9]
DL ATL-SNA AUG 4>2[3]
DL ATL-SRQ AUG 6>5[6]
DL ATL-STL AUG 8>6[8]
*DL ATL-STR AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.9>0.2[0.9]
DL ATL-SYR AUG 3>2[3]
DL ATL-TGU AUG 1.0>0[0.9]
DL ATL-TLH AUG 7>6[7]
DL ATL-TPA AUG 13>9[13]
DL ATL-TRI AUG 7>5[6]
DL ATL-TUL AUG 5>3[5]
DL ATL-TUS AUG 1.8>1.0[1.8]
DL ATL-TYS AUG 9>7[8]
DL ATL-UIO AUG 1.0>0[1.0]
DL ATL-VLD AUG 3>2[3]
DL ATL-VPS AUG 7>6[7]
DL ATL-XNA AUG 6>4[6]
DL ATL-YUL AUG 5>2[5]
DL ATL-YVR AUG 1.0>0[1.0]
DL ATL-YYZ AUG 7>3[7]
DL ATW-DTW AUG 4>3[4]
DL ATW-MSP AUG 4>3[4]
DL AUS-BOS AUG 1.9>0[0.9]
DL AUS-CVG AUG 0.8>0[0.8]
DL AUS-DTW AUG 4>2[3]
DL AUS-JFK AUG 3>1.0[3]
DL AUS-LAX AUG 3>2[3]
DL AUS-MSP AUG 3>2[3]
DL AUS-RDU AUG 1.0>0[0.8]
DL AUS-SEA AUG 1.9>0[1.0]
DL AZO-DTW AUG 5>3[4]
DL AZO-MSP AUG 1.7>1.0[1.7]
DL BCN-JFK AUG 1.0>0.6[1.0]
DL BDA-BOS AUG 1.0>0[1.0]
DL BDA-JFK AUG 1.0>0[1.0]
DL BDL-CLE AUG 0.8>0[0.9]
DL BDL-CVG AUG 0.9>0[0.8]
DL BDL-DTW AUG 5>3[5]
DL BDL-MSP AUG 4>2[4]
DL BDL-RDU AUG 1.0>0[0.9]
DL BGM-DTW AUG 3>2[3]
DL BHM-DTW AUG 3>0[3]
DL BHM-LGA AUG 3>0[2]
DL BIL-MSP AUG 4>2[4]
DL BIS-MSP AUG 6>4[6]
DL BNA-BOS AUG 4>2[4]
DL BNA-JFK AUG 3>0[3]
DL BNA-LAX AUG 1.8>1.0[1.7]
DL BNA-LGA AUG 6>3[6]
DL BNA-MSP AUG 5>4[5]
DL BNA-RDU AUG 1.8>0[1.8]
DL BNA-SEA AUG 1.0>0[1.0]
DL BOI-LAX AUG 1.8>1.0[1.8]
DL BOI-MSP AUG 3>2[3]
DL BOI-SEA AUG 7>4[5]
DL BOI-SLC AUG 5>4[6]
DL BOS-BUF AUG 3>0[3]
DL BOS-CDG AUG 1.0>0.6[1.0]
DL BOS-CHS AUG 1.0>0[1.1]
DL BOS-CLE AUG 3>0[3]
DL BOS-CMH AUG 3>0[3]
DL BOS-CVG AUG 5>0[4]
DL BOS-DCA AUG 5>0[0]
DL BOS-DTW AUG 7>5[7]
*DL BOS-DUB AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[0.8]
DL BOS-EWR AUG 4>0[0]
DL BOS-IND AUG 4>0[4]
DL BOS-JAX AUG 3>0[3]
DL BOS-JFK AUG 8>4[8]
DL BOS-LAX AUG 3>1.0[3]
DL BOS-LGA AUG 14>4[14]
DL BOS-LHR AUG 1.0>0[1.0]
DL BOS-MCI AUG 3>0[1.8]
DL BOS-MCO AUG 3>2[3]
DL BOS-MIA AUG 2>0[0]
DL BOS-MKE AUG 1.8>0[1.8]
DL BOS-ORD AUG 5>0[0]
DL BOS-ORF AUG 1.0>0[1.0]
DL BOS-PHL AUG 5>0[5]
DL BOS-PIT AUG 4>0[4]
DL BOS-RDU AUG 6>3[6]
DL BOS-RIC AUG 3>0[3]
DL BOS-SEA AUG 4>2[3]
DL BOS-SFO AUG 1.8>0[1.8]
DL BOS-SLC AUG 3>2[3]
DL BOS-TPA AUG 3>1.0[3]
DL BRU-JFK AUG 1.0>0[1.0]
DL BTV-JFK AUG 3>0[3]
DL BTV-LGA AUG 2>0[2]
DL BUF-JFK AUG 5>0[5]
DL BUF-LGA AUG 4>0[4]
DL BUF-MSP AUG 1.0>0[2.0]
DL BWI-CVG AUG 3>0[3]
DL BWI-DTW AUG 5>4[5]
DL BWI-JFK AUG 4>0[4]
DL BWI-MSP AUG 3>2[3]
DL BWI-RDU AUG 1.6>0[1.7]
DL BWI-SLC AUG 1.8>1.0[1.7]
DL BZN-SEA AUG 2>0[0.1]
DL CAE-LGA AUG 1.8>0[1.7]
*DL CDG-CVG AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.9>0.2[0.9]
DL CDG-DTW SEP 1.8>1.0[2] OCT 1.7>1.0[1.8]
DL CDG-JFK AUG 2>1.0[1.0] SEP 2>1.0[1.9] OCT 2>1.3[1.8]
*DL CDG-LAX AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
DL CDG-MSP AUG 1.0>0[1.0]
DL CDG-RDU AUG 1.0>0[1.0]
DL CDG-SEA AUG 1.0>0[1.0]
DL CHA-DTW AUG 3>1.0[3]
DL CHA-LGA AUG 1.0>0[1.0]
DL CHO-LGA AUG 2>0[2]
DL CHS-DTW AUG 3>0[3]
DL CHS-JFK AUG 3>1.0[3]
DL CHS-LGA AUG 3>0[3]
DL CID-DTW AUG 4>2[4]
DL CID-MSP AUG 4>3[4]
DL CLE-DTW AUG 7>5[5]
DL CLE-JFK AUG 4>0[4]
DL CLE-LGA AUG 5>2[5]
DL CLE-RDU AUG 0.8>0[0.9]
DL CLE-SLC AUG 1.0>0[0.9]
DL CLT-CVG AUG 3>0[2]
DL CLT-JFK AUG 4>0[4]
DL CLT-LGA AUG 7>3[7]
DL CLT-MSP AUG 4>2[4]
DL CMH-DTW AUG 7>5[6]
DL CMH-JFK AUG 3>0[3]
DL CMH-LAX AUG 1.0>0[1.0]
DL CMH-LGA AUG 5>2[5]
DL CMH-RDU AUG 1.8>0[1.7]
DL CMH-SLC AUG 1.0>0[0.8]
DL COD-SLC AUG 0.4>1.0[1.3]
DL CPR-SLC AUG 1.0>2[2]
DL CVG-DCA AUG 3>0[4]
DL CVG-DEN AUG 1.0>0[1.0]
DL CVG-DFW AUG 2>0[3]
DL CVG-EWR AUG 2>0[3]
DL CVG-IAH AUG 1.7>0[1.5]
DL CVG-JFK AUG 1.0>0[1.0]
DL CVG-LAX AUG 1.8>1.0[1.8]
DL CVG-LGA AUG 5>2[5]
DL CVG-MCI AUG 1.7>0[1.5]
DL CVG-ORD AUG 3>0[4]
DL CVG-PHL AUG 2>0[2]
DL CVG-RDU AUG 1.7>0[1.8]
DL CVG-SEA AUG 1.0>0[1.0]
DL CVG-SFO AUG 1.0>0[1.0]
DL CVG-STL AUG 1.7>0[1.5]
DL CVG-YYZ AUG 1.7>0[1.5]
DL CWA-MSP AUG 3>2[3]
DL DAY-MSP AUG 4>0[4]
DL DCA-DTW AUG 7>4[7]
DL DCA-JFK AUG 5>0[5]
DL DCA-LEX AUG 0.8>0[0.8]
DL DCA-LGA AUG 8>3[10]
DL DCA-MSN AUG 0.8>0[0.8]
DL DCA-MSP AUG 6>3[6]
DL DCA-OMA AUG 0.8>0[0.8]
DL DCA-RDU AUG 3>0[3]
DL DEN-DTW AUG 4>3[4]
DL DEN-JFK AUG 3>2[3]
DL DEN-LAX AUG 4>3[4]
DL DEN-LGA AUG 2>1.0[2]
DL DEN-MSP AUG 6>4[6]
DL DEN-SEA AUG 4>3[4]
DL DFW-DTW AUG 5>4[5]
DL DFW-JFK AUG 3>1.0[3]
DL DFW-LAX AUG 4>2[4]
DL DFW-LGA AUG 6>2[6]
DL DFW-MSP AUG 6>4[7]
DL DLH-MSP AUG 6>3[6]
DL DSM-DTW AUG 4>3[4]
DL DSM-LGA AUG 1.8>0[1.8]
DL DSM-MSP AUG 5>4[5]
DL DSM-SLC AUG 1.0>0[0.9]
DL DTW-ELM AUG 5>3[5]
DL DTW-EWR AUG 6>4[6]
DL DTW-FLL AUG 4>3[4]
*DL DTW-FRA AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
DL DTW-FWA AUG 1.9>3[3]
DL DTW-GRB AUG 4>3[4]
DL DTW-GRR AUG 7>5[7]
DL DTW-GSO AUG 3>0[3]
DL DTW-GSP AUG 3>0[3]
DL DTW-HSV AUG 1.0>0[1.0]
DL DTW-IAH AUG 5>3[5]
DL DTW-IND AUG 7>5[6]
DL DTW-ITH AUG 3>1.0[3]
DL DTW-JAX AUG 1.9>0[1.8]
DL DTW-JFK AUG 5>4[5]
DL DTW-LAN AUG 5>3[5]
DL DTW-LAS AUG 5>4[5]
DL DTW-LAX AUG 7>5[6]
DL DTW-LEX AUG 4>2[4]
DL DTW-LGA AUG 8>5[7]
DL DTW-LIT AUG 0.8>0[0.9]
DL DTW-MBS AUG 5>3[5]
DL DTW-MCI AUG 4>3[4]
DL DTW-MEM AUG 3>2[3]
DL DTW-MEX AUG 1.0>0.7[2]
DL DTW-MKE AUG 5>3[5]
DL DTW-MLI AUG 1.8>0[1.8]
DL DTW-MSN AUG 6>3[6]
DL DTW-MSP AUG 8>6[8]
DL DTW-MSY AUG 3>2[3]
DL DTW-MTY AUG 0.8>0[0.9]
DL DTW-OKC AUG 1.8>0[1.8]
DL DTW-OMA AUG 4>2[4]
DL DTW-ORD AUG 7>4[6]
DL DTW-PBI AUG 0.9>0[0.9]
DL DTW-PHX AUG 4>3[4]
DL DTW-PIT AUG 5>4[5]
*DL DTW-PVG AUG 1.0>0.1[1.0] SEP 1.0>0.1[1.0] OCT 1.0>0.4[1.0]
DL DTW-RDU AUG 5>4[4]
DL DTW-RIC AUG 4>3[4]
DL DTW-SAN AUG 4>2[3]
DL DTW-SAT AUG 3>2[3]
DL DTW-SAV AUG 1.0>0[1.0]
DL DTW-SBN AUG 5>3[5]
DL DTW-SCE AUG 3>2[3]
DL DTW-SDF AUG 5>3[5]
DL DTW-SFO AUG 5>3[5]
DL DTW-SJC AUG 1.4>0[0.8]
DL DTW-SLC AUG 4>5[4]
DL DTW-SMF AUG 0.9>0[0.8]
DL DTW-SNA AUG 0.7>1.0[0.9]
DL DTW-STL AUG 5>3[6]
DL DTW-TPA AUG 4>3[4]
DL DTW-TVC AUG 6>4[6]
DL DTW-TYS AUG 5>3[4]
DL DTW-YUL AUG 4>2[4]
DL DTW-YVR AUG 0.2>0[0.3]
DL DTW-YYZ AUG 5>3[5]
DL EDI-JFK AUG 1.0>0.5[1.0]
DL EKO-SLC AUG 1.0>1.9[1.8]
DL EUG-SEA AUG 3>2[3]
DL EWR-MSP AUG 6>3[5]
DL EWR-RDU AUG 3>0[3]
DL EWR-SLC AUG 1.4>1.0[1.4]
DL FAI-MSP AUG 1.0>0[1.0]
DL FAR-MSP AUG 7>5[7]
DL FAT-SLC AUG 4>3[3]
DL FLL-JFK AUG 4>2[4]
DL FLL-LGA AUG 5>3[5]
DL FLL-RDU AUG 1.0>0[1.0]
DL FLL-SLC AUG 1.0>0[1.0]
DL FRA-JFK AUG 1.0>0[1.0]
DL FSD-MSP AUG 8>5[7]
DL FWA-MSP AUG 1.0>0[1.0]
DL GEG-MSP AUG 3>2[3]
DL GEG-SEA AUG 9>6[8]
DL GEG-SLC AUG 5>4[4]
DL GFK-MSP AUG 6>3[6]
DL GJT-SLC AUG 2>3[3]
DL GRB-MSP AUG 4>3[4]
DL GRR-LGA AUG 3>0[3]
DL GRR-MSP AUG 5>3[5]
DL GRU-JFK AUG 1.0>0.4[1.0]
DL GSO-LGA AUG 4>1.0[4]
DL GSP-LGA AUG 3>0[3]
DL GUA-LAX AUG 1.0>0[1.0]
DL HLN-MSP AUG 1.0>0[1.0]
DL HNL-LAX AUG 4>3[4]
DL IAD-JFK AUG 4>3[4]
DL IAD-MSP AUG 3>2[3]
DL IAD-SEA AUG 1.8>1.0[1.0]
DL IAH-JFK AUG 2>0[0]
DL IAH-LGA AUG 5>2[4]
DL IAH-MSP AUG 6>3[5]
DL ICT-MSP AUG 4>2[4]
DL IDA-SLC AUG 4>3[4]
DL IND-JFK AUG 3>0[3]
DL IND-LAX AUG 1.0>0[1.0]
DL IND-LGA AUG 5>2[4]
DL IND-MCO AUG 1.0>0[1.0]
DL IND-MSP AUG 5>4[5]
DL IND-RDU AUG 1.7>0[1.7]
DL IND-SEA AUG 1.0>0[1.0]
DL JAC-LAX AUG 0.3>0[0.3]
DL JAC-MSP AUG 0.7>1.0[1.0]
DL JAX-JFK AUG 3>0[3]
DL JAX-LGA AUG 3>0[3]
DL JAX-MSP AUG 0.9>0[0.8]
DL JFK-LAS AUG 5>3[5]
DL JFK-LAX AUG 10>5[9]
DL JFK-LHR AUG 2>1.0[2]
DL JFK-MAD AUG 1.0>0.6[1.0]
DL JFK-MCO AUG 5>4[5]
DL JFK-MEX AUG 1.5>1.0[1.0]
DL JFK-MIA AUG 4>2[4]
DL JFK-MSP AUG 4>3[4]
DL JFK-MSY AUG 3>1.0[3]
DL JFK-NAS AUG 1.0>0[2.0]
DL JFK-ORD AUG 5>3[5]
DL JFK-ORF AUG 3>0[3]
DL JFK-PDX AUG 3>1.0[3]
DL JFK-PHX AUG 2>1.0[2]
DL JFK-PIT AUG 3>0[3]
DL JFK-PWM AUG 3>0[3]
DL JFK-RDU AUG 5>0[5]
DL JFK-RIC AUG 3>0[3]
DL JFK-ROC AUG 3>0[3]
DL JFK-SAN AUG 3>2[3]
DL JFK-SAT AUG 1.0>0[1.0]
DL JFK-SAV AUG 3>1.0[3]
DL JFK-SDQ AUG 3>2[3]
DL JFK-SEA AUG 5>3[5]
DL JFK-SFO AUG 7>3[7]
DL JFK-SJC AUG 0.8>0[1.0]
DL JFK-SJU AUG 3.0>2.0[3.0]
DL JFK-SLC AUG 5>4[5]
DL JFK-STI AUG 3>2[3]
DL JFK-SXM AUG 1.0>0[1.0]
DL JFK-SYR AUG 3>0[3]
DL JFK-TPA AUG 4>2[4]
DL JFK-YUL AUG 3>0[3]
DL JFK-YYZ AUG 4>1.0[4]
DL JFK-ZRH AUG 1.0>0[1.0]
DL KOA-SEA AUG 1.0>0.6[1.0]
DL LAS-LAX AUG 7>5[7]
Interesting to see DL exit LAS leisure to the West when leisure is all that's flying now
**DL LAS-LGB SEP 3>0[0] OCT 3>0[0.3] NOV 3>0[2] DEC 3>0[3] JAN 3>0[2] FEB 3>0[2] MAR 3>0[2] APR 3>0[0.1]
DL LAS-MSP AUG 6>4[6]
**DL LAS-PDX AUG 3>0[0] SEP 3>0[0] OCT 3>0[0] NOV 3>0[0] DEC 3>0[0] JAN 3>0[0.2] FEB 3>0[0] MAR 3>0[0.0] APR 3>0[1.0]
**DL LAS-SAN AUG 3>0[4] SEP 3>0[4] OCT 3>0[4] NOV 3>0[4] DEC 3>0[3] JAN 3>0[3] FEB 3>0[3] MAR 3>0[3] APR 3>0[2.0]
DL LAS-SEA AUG 6>4[5]
**DL LAS-SJC AUG 3>0[3] SEP 4>0[4] OCT 4>0[3] NOV 4>0[3] DEC 4>0[3] JAN 4>0[3] FEB 4>0[3] MAR 4>0[3] APR 4>0[2]
DL LAS-SLC AUG 5>4[5]
**DL LAS-SNA AUG 4>0[4] SEP 4>0[4] OCT 4>0[4] NOV 4>0[4] DEC 4>0[4] JAN 4>0[4] FEB 4>0[4] MAR 4>0[4] APR 4>0[2]
DL LAX-MCI AUG 1.8>0[1.8]
DL LAX-MCO AUG 3>2[3]
DL LAX-MEM AUG 0.8>0[0.9]
DL LAX-MEX AUG 2>1.0[3]
DL LAX-MSP AUG 7>6[8]
DL LAX-MSY AUG 3>1.0[3]
DL LAX-OMA AUG 0.8>0[0]
DL LAX-PDX AUG 5>4[5]
DL LAX-PHX AUG 5>4[5]
DL LAX-RDU AUG 1.4>0[1.3]
DL LAX-SAN AUG 5>0[5]
DL LAX-SAT AUG 2>0[2.0]
DL LAX-SEA AUG 9>7[9]
DL LAX-SFO AUG 8>5[8]
DL LAX-SJC AUG 7>4[7]
DL LAX-SJD AUG 2>1.2[1.8]
DL LAX-SJO AUG 1.0>0[1.0]
DL LAX-SLC AUG 8>6[8]
DL LAX-SMF AUG 5>4[5]
DL LAX-TPA AUG 1.4>1.0[1.3]
DL LAX-TUS AUG 3>2[3]
DL LEX-LGA AUG 1.0>0[1.0]
DL LEX-MSP AUG 1.0>0[0.9]
DL LGA-MCI AUG 5>2[4]
DL LGA-MCO AUG 5>4[5]
DL LGA-MEM AUG 3>0[3]
DL LGA-MIA AUG 4>3[4]
DL LGA-MKE AUG 5>0[5]
DL LGA-MSN AUG 3>0[3]
DL LGA-MSP AUG 7>5[7]
DL LGA-MSY AUG 3>0[3]
DL LGA-OMA AUG 3>0[3]
DL LGA-ORD AUG 12>4[12]
DL LGA-ORF AUG 4>0[4]
DL LGA-PBI AUG 4>1.0[4]
DL LGA-PIT AUG 7>3[7]
DL LGA-PWM AUG 4>0[4]
DL LGA-RDU AUG 7>4[7]
DL LGA-RIC AUG 4>2[4]
DL LGA-ROC AUG 4>0[3]
DL LGA-RSW AUG 3>0[2.0]
DL LGA-SAV AUG 3>0[3]
DL LGA-SDF AUG 4>0[3]
DL LGA-SRQ AUG 1.0>0[1.0]
DL LGA-STL AUG 5>2[5]
DL LGA-SYR AUG 3>0[3]
DL LGA-TPA AUG 4>2[4]
DL LGA-TYS AUG 3>0[3]
DL LGA-XNA AUG 0.8>0[0.8]
DL LGA-YUL AUG 4>0[4]
DL LGB-SLC AUG 0>3[4]
DL LHR-MSP AUG 1.0>0[1.0]
DL LIH-SEA AUG 1.0>0.4[0.9]
DL LWS-SLC AUG 2>3[3]
DL MCI-MSP AUG 5>4[5]
DL MCI-SEA AUG 1.0>0[1.0]
DL MCO-MIA AUG 5>0[0]
DL MCO-RDU AUG 3>1.0[3]
DL MCO-SLC AUG 3>2[2]
DL MEM-MSP AUG 3>1.0[3]
DL MEX-MSP AUG 1.0>0[1.0]
DL MFR-SEA AUG 3>2[3]
DL MIA-MSP AUG 2>1.0[1.8]
DL MIA-RDU AUG 2>0[0.1]
DL MIA-SLC AUG 1.0>0[0]
DL MIA-TPA AUG 5>0[0]
DL MKE-MSP AUG 5>4[5]
DL MKE-SEA AUG 1.0>0[1.0]
DL MOT-MSP AUG 5>4[5]
DL MSN-MSP AUG 5>4[5]
DL MSN-SLC AUG 0.8>0[0.8]
DL MSP-OKC AUG 3>2[3]
DL MSP-OMA AUG 7>4[6]
DL MSP-ORD AUG 7>5[7]
DL MSP-ORF AUG 1.0>0[1.0]
DL MSP-PDX AUG 5>4[5]
DL MSP-PHL AUG 5>4[5]
DL MSP-PHX AUG 5>4[5]
DL MSP-PIT AUG 4>3[4]
DL MSP-PSC AUG 2>1.0[1.9]
DL MSP-RAP AUG 6>4[5]
DL MSP-RDU AUG 4>3[4]
DL MSP-RIC AUG 1.8>0[3]
DL MSP-ROC AUG 1.0>0[0.9]
DL MSP-RST AUG 4>2[4]
DL MSP-SAN AUG 4>3[4]
DL MSP-SAT AUG 3>2[3]
DL MSP-SBN AUG 3>0[3]
DL MSP-SDF AUG 3>2[3]
DL MSP-SFO AUG 6>4[7]
DL MSP-SJC AUG 3>1.0[2]
DL MSP-SLC AUG 6>7[6]
DL MSP-SNA AUG 3>1.0[3]
DL MSP-STL AUG 5>3[6]
DL MSP-SYR AUG 1.0>0[1.0]
DL MSP-TUL AUG 1.8>0[1.8]
DL MSP-TVC AUG 4>3[4]
DL MSP-TYS AUG 1.0>0[1.0]
DL MSP-XNA AUG 1.5>0[1.5]
DL MSP-YUL AUG 1.8>0[1.8]
DL MSP-YWG AUG 4>2[4]
DL MSP-YYZ AUG 4>0[4]
DL OKC-SLC AUG 3>2[3]
DL ORD-RDU AUG 3>0[3]
DL ORD-SEA AUG 3>2[3]
DL ORD-SLC AUG 4>3[4]
DL PDX-SEA AUG 8>6[8]
DL PDX-SLC AUG 6>4[6]
DL PHL-RDU AUG 3>0[3]
DL PHX-SLC AUG 5>4[5]
DL PIH-SLC AUG 2>3[3]
DL PIT-RDU AUG 0.8>0[1.0]
DL PIT-SLC AUG 1.0>0[0.9]
DL PSC-SEA AUG 4>3[4]
*DL PVG-SEA AUG 1.0>0.1[1.0] SEP 1.0>0.1[1.0] OCT 1.0>0.4[0.9]
DL PVR-SLC AUG 0.4>0[0.5]
DL RAP-SLC AUG 2>1.0[2.0]
DL RDM-SEA AUG 3>2[3]
DL RDU-SEA AUG 1.0>0[1.0]
DL RDU-TPA AUG 3>1.0[3]
DL RNO-SLC AUG 5>4[5]
DL SAN-SEA AUG 5>3[5]
DL SAN-SLC AUG 5>4[5]
DL SEA-SFO AUG 8>4[8]
DL SEA-SJC AUG 6>4[6]
DL SEA-SLC AUG 8>6[8]
DL SEA-SMF AUG 5>4[5]
DL SEA-SNA AUG 5>3[5]
DL SEA-TPA AUG 1.0>0[0]
DL SEA-YVR AUG 6>3[7]
DL SEA-YYC AUG 3>0[3]
DL SFO-SLC AUG 5>4[5]
DL SGU-SLC AUG 3>4[0]
DL SJC-SLC AUG 5>4[5]
DL SJD-SLC AUG 0.8>0[0.6]
DL SLC-SMF AUG 5>4[5]
DL SLC-SNA AUG 5>4[5]
DL SLC-SUN AUG 3>2[3]
DL SLC-TWF AUG 2>3[3]
DL SLC-YYZ AUG 1.0>0[1.0]
EI BOS-DUB APR 1.0>2[2]
EI DUB-JFK APR 1.0>2[2]
F9 ALB-MCO DEC 0.5>0.7[0.2] JAN 0.4>1.0[0.6] FEB 0.4>1.0[0.6] MAR 0.4>1.0[0.5] APR 0.4>0.9[0.7]
F9 ALB-TPA DEC 0>0.3[0] JAN 0>0.6[0] FEB 0>0.6[0] MAR 0>0.5[0] APR 0>0.6[0]
F9 moves on CVG post-DL
F9 ATL-CVG AUG 0.7>1.0[0.4] SEP 1.0>0.7[0.4] OCT 1.0>0.7[0.5] NOV 0.4>0.7[0.2] DEC 0>0.7[0] JAN 0>0.7[0] FEB 0>0.7[0] MAR 0>0.7[0]
F9 BUF-MCO DEC 1.0>1.3[0.9] JAN 1.0>1.6[0.9] FEB 1.0>1.6[0.9] MAR 1.0>1.6[1.0] APR 0.6>1.2[1.2]
**F9 BUF-MIA DEC 0>0.2[0] JAN 0>0.4[0] FEB 0>0.4[0] MAR 0>0.4[0] APR 0>0.4[0]
F9 CVG-DEN AUG 1.1>2[1.1] SEP 1.0>1.8[1.0] OCT 1.0>1.7[1.0] NOV 1.0>1.7[0.8] DEC 1.0>1.7[0.2] JAN 1.0>1.7[0.6] FEB 1.0>1.7[0.6] MAR 1.0>1.7[0.5] APR 1.0>1.7[0.7]
**F9 CVG-DFW AUG 0>1.0[0.1] SEP 0>0.7[0] OCT 0>0.7[0] NOV 0>0.7[0] DEC 0>0.7[0] JAN 0>0.7[0] FEB 0>0.7[0] MAR 0>0.7[0] APR 0>0.7[0.1]
F9 CVG-LAS AUG 0.5>1.2[1.0] SEP 0.6>1.1[1.2] OCT 0.6>1.2[1.3] NOV 0.8>1.2[1.1]
F9 CVG-LAX APR 0>0.6[0.1]
F9 CVG-MCO AUG 1.0>2[1.1] SEP 1.0>2[1.0] OCT 1.0>2[1.0] NOV 1.6>3[1.5] DEC 2>3[1.4] JAN 2>3[1.5] FEB 2>3[1.6] MAR 2>3[1.5] APR 1.4>3[1.4]
**F9 CVG-MIA AUG 0>0.6[0] SEP 0>0.5[0] OCT 0>0.6[0.4] DEC 1.0>0.5[0.5] JAN 1.0>0.6[0.5] FEB 1.0>0.6[0.4] MAR 1.0>0.5[0.5] APR 0.4>0.6[0.4]
F9 CVG-PHL APR 0>0.4[0]
F9 CVG-RSW NOV 0.8>1.4[1.0] DEC 1.0>2[1.3] JAN 1.0>2[1.3] FEB 1.0>2[1.3] MAR 1.0>2[1.3] APR 0.6>2[1.0]
F9 CVG-TPA NOV 0.8>1.5[0.6] DEC 1.0>2[0.6] JAN 1.0>2[0.6] FEB 1.0>2[0.6] MAR 1.0>2[0.6] APR 0.7>2[0.6]
**F9 ISP-LAS MAR 0>0.4[0] APR 0>1.0[0]
F9 ISP-MCO NOV 1.6>2[1.5] DEC 2>3[2] JAN 2>4[2] FEB 2>4[1.8] MAR 2>4[1.9] APR 1.4>3[2.0]
F9 ISP-PBI NOV 1.2>1.5[0.7] DEC 1.5>2[1.0] JAN 1.6>2[1.0] FEB 1.6>2[1.0] MAR 1.6>2[1.0] APR 1.2>1.6[0.7]
F9 ISP-TPA NOV 0.8>1.4[0.8] DEC 1.0>2[1.0] JAN 1.0>2[1.0] FEB 1.0>2[1.0] MAR 1.0>2[1.0] APR 0.6>1.6[0.9]
F9 MCO-PVD DEC 1.0>1.5[1.0] JAN 1.0>2[1.0] FEB 1.0>2[1.0] MAR 1.0>2[1.0] APR 0.6>1.6[1.0]
**F9 MIA-PVD DEC 0>0.4[0] JAN 0>0.7[0] FEB 0>0.7[0] MAR 0>0.7[0] APR 0>0.7[0]
F9 PVD-TPA DEC 0.5>0.8[0.5] JAN 0.6>1.0[0.6] FEB 0.6>1.0[0.6] MAR 0.6>1.0[0.5] APR 0.2>0.6[0.4]
FI BOS-KEF AUG 2>1.0[1.9] SEP 1.4>1.0[1.5]
FI DEN-KEF AUG 1.6>0.6[1.0] SEP 1.2>0.8[1.0]
FI EWR-KEF AUG 1.0>0.6[1.0] SEP 1.0>0.8[1.0]
FI IAD-KEF AUG 2>1.0[1.8] SEP 1.4>1.0[1.0]
FI JFK-KEF AUG 1.6>1.0[1.9]
FI KEF-MSP AUG 1.0>0.5[1.0]
FI KEF-ORD AUG 1.6>0.7[1.8] SEP 1.2>0.8[1.4]
FI KEF-SEA AUG 2>1.0[2] SEP 1.6>1.1[1.5]
GV ATT-BET AUG 0.9>1.3[1.4] SEP 0.9>1.4[1.4] OCT 0.9>1.4[1.4] NOV 0.9>1.4[1.4] DEC 0.9>1.4[1.4] JAN 0.9>1.3[1.4] FEB 0.9>1.4[1.4] MAR 0.9>1.4[1.4] APR 0.9>1.4[1.4]
GV ATT-KUK AUG 0.9>1.3[1.4] SEP 0.9>1.4[1.4] OCT 0.9>1.4[1.4] NOV 0.9>1.4[1.4] DEC 0.9>1.4[1.4] JAN 0.9>1.3[1.4] FEB 0.9>1.4[1.4] MAR 0.9>1.4[1.4] APR 0.9>1.4[1.4]
GV BET-KSM AUG 0>0.8[0] SEP 0>0.9[0] OCT 0>0.9[0] NOV 0>0.9[0] DEC 0>0.9[0] JAN 0>0.8[0] FEB 0>0.9[0] MAR 0>0.9[0] APR 0>0.9[0]
GV BET-MOU AUG 0>0.8[0] SEP 0>0.9[0] OCT 0>0.9[0] NOV 0>0.9[0] DEC 0>0.9[0] JAN 0>0.8[0] FEB 0>0.9[0] MAR 0>0.9[0] APR 0>0.9[0]
GV BET-NUP AUG 0.9>1.3[1.4] SEP 0.9>1.4[1.4] OCT 0.9>1.4[1.4] NOV 0.9>1.4[1.4] DEC 0.9>1.4[1.4] JAN 0.9>1.3[1.4] FEB 0.9>1.4[1.4] MAR 0.9>1.4[1.4] APR 0.9>1.4[1.4]
GV KSM-MOU AUG 0>0.8[0] SEP 0>0.9[0] OCT 0>0.9[0] NOV 0>0.9[0] DEC 0>0.9[0] JAN 0>0.8[0] FEB 0>0.9[0] MAR 0>0.9[0] APR 0>0.9[0]
GV KUK-NUP AUG 0.9>1.3[1.4] SEP 0.9>1.4[1.4] OCT 0.9>1.4[1.4] NOV 0.9>1.4[1.4] DEC 0.9>1.4[1.4] JAN 0.9>1.3[1.4] FEB 0.9>1.4[1.4] MAR 0.9>1.4[1.4] APR 0.9>1.4[1.4]
I4 CGA-KLW AUG 0>1.0[3] SEP 0>1.0[3] OCT 0>1.0[3] NOV 0>1.0[3] DEC 0>1.0[3] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>1.0[0]
IB BCN-BOS AUG 0.6>0[0.4]
IB BCN-JFK AUG 0.6>0[0.5]
IB BCN-SFO AUG 0.4>0[0.4]
IB BOS-MAD AUG 1.0>0[1.0]
IB IAD-MAD AUG 0.7>0[0]
IB JFK-MAD AUG 2>1.0[2]
IB LAX-MAD AUG 1.0>0[1.0]
IB MAD-MIA AUG 2>1.0[2]
IB MAD-ORD AUG 1.0>0.7[1.0]
IB MAD-SFO AUG 0.4>0[0.4]
KQ JFK-NBO AUG 1.0>0[1.0] SEP 0.8>0[0.8] OCT 0.7>0.2[0.7]
MF FOC-JFK AUG 0.5>0.0[0.4]
MF LAX-TAO AUG 0.4>0[0.5]
MF LAX-XMN AUG 0.4>0.2[0.4]
MS CAI-IAD AUG 0.6>0.3[0.5]
MS CAI-JFK AUG 1.0>0.4[1.0]
NK BOS-BWI AUG 5>4[2] SEP 5>4[1.8] OCT 5>4[1.7] NOV 5>4[1.9]
PS JFK-KBP AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.9>0.2[1.0]
QF BNE-LAX AUG 1.0>0[1.4] SEP 1.0>0[1.4] OCT 1.0>0.2[1.4]
QF BNE-ORD AUG 0.6>0[0] SEP 0.6>0[0] OCT 0.6>0.1[0]
QF BNE-SFO AUG 0.4>0[0] SEP 0.4>0[0] OCT 0.4>0.1[0]
QF DFW-SYD AUG 1.0>0[0.9] SEP 1.0>0[0.9] OCT 1.0>0.2[0.8]
QF HNL-SYD AUG 0.7>0[0.6] SEP 0.7>0[0.7] OCT 0.7>0.2[0.7]
QF JFK-LAX AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
QF LAX-MEL AUG 1.1>0[1.3] SEP 1.1>0[1.3] OCT 1.2>0.3[1.3]
QF LAX-SYD AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
QF MEL-SFO AUG 0.6>0[0.6] SEP 0.6>0[0.6] OCT 0.6>0.1[0.6]
QF SFO-SYD AUG 1.0>0[0.9] SEP 1.0>0[0.9] OCT 1.0>0.2[0.8]
SS JFK-ORY AUG 1.0>0[0] SEP 1.0>0[0] OCT 1.0>0[0] NOV 1.0>0[0] DEC 1.0>0[0] JAN 1.0>0[0] FEB 1.0>0[0] MAR 0.8>0[0]
SU IAD-SVO AUG 0.5>0[0.5] SEP 0.3>0.1[0.2]
SU JFK-SVO AUG 3>2[3]
SU MIA-SVO AUG 0.6>0[0.6] SEP 0.6>0.3[0.6]
TK ATL-IST AUG 0.7>0[0.7]
TK BOS-IST AUG 1.0>0[1.0]
TP LIS-ORD SEP 1.0>0[0.7]
TP LIS-SFO SEP 0.7>0[0.7]
TS FLL-YUL AUG 0.7>0.3[0.3]
Interesting the CARES Docket approved stations closures are only out till the end of the CARES timeline. I wonder why?
**UA ABE-ORD AUG 2>0[3] SEP 3>0[3]
UA AMS-ORD SEP 0>0.3[1.0] OCT 0.3>0.6[1.0]
**UA AZO-ORD AUG 2>0[2] SEP 3>0[3]
**UA CHA-ORD AUG 4>0[2] SEP 4>0[3]
UA CLE-EWR SEP 8>7[7]
**UA DEN-SMX OCT 1.0>0[0] NOV 1.0>0[0] DEC 1.0>0[0] JAN 1.0>0[0] FEB 1.0>0[0]
**UA EWR-EYW AUG 1.0>0[1.0] SEP 1.0>0[1.0]
**UA EWR-MYR AUG 2.0>0[1.7] SEP 0.2>0[0.3]
**UA FAI-ORD AUG 0.9>0[1.0] SEP 1.0>0[1.0]
UA HHH-IAD AUG 0.6>0[2]
**UA IAD-ITH AUG 4>0[3] SEP 4>0[3]
UA IAH-PBI DEC 0.8>1.0[1.5] JAN 0.5>1.0[1.2] FEB 0.5>1.0[1.0] MAR 0.5>1.0[2.0] APR 0.5>1.0[1.0]
**UA LAN-ORD AUG 3>0[3] SEP 3>0[3]
**UA LAX-SMX OCT 1.0>0[0] NOV 1.0>0[0] DEC 1.0>0[0] JAN 1.0>0[0] FEB 1.0>0[0] MAR 1.0>0[0] APR 1.0>0[0]
UA MYR-ORD AUG 0.6>0[0.8]
UA ORD-PNS SEP 2>1.5[1.0]
UA ORD-RAP OCT 2>1.5[1.2] NOV 2>1.5[1.0] DEC 2>1.5[1.0] JAN 2>1.5[0.2] FEB 2>1.5[0] MAR 2>1.5[0] APR 2>1.5[0]
UA ORD-SBN SEP 10>9[5] OCT 10>9[5] APR 10>9[5]
UA ORD-SDF SEP 7>5[6]
**UA SFO-SMX OCT 1.0>0[0] NOV 1.0>0[0] DEC 1.0>0[0] JAN 1.0>0[0] FEB 1.0>0[0]
UX JFK-MAD APR 0.7>0.5[0]
VA BNE-LAX AUG 0.5>0[0.8]
VA LAX-MEL AUG 0.4>0[0.7]
VA LAX-SYD AUG 0.5>0[0.9]
VS ATL-LHR AUG 1.0>0.1[1.0]
VS ATL-MAN AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 0.8>0.1[0.9]
VS BOS-LHR AUG 2>0[2] SEP 2>0[2] OCT 2.0>1.2[1.9]
VS GLA-MCO AUG 0.3>0[0.3] SEP 0.4>0[0.3] OCT 0.5>0[0.4]
VS IAD-LHR AUG 1.0>0[1.0]
VS JFK-LHR AUG 5>1.0[6] SEP 5>3[6] OCT 5>3[5]
VS JFK-MAN AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.2[1.0]
VS LAS-LHR AUG 1.0>0[1.0]
VS LAX-LHR AUG 2>1.0[2] SEP 2>0.9[2] OCT 2>1.2[2.0]
VS LAX-MAN AUG 0.4>0[0.4] SEP 0.4>0[0.4] OCT 0.3>0[0.4]
VS LHR-MIA AUG 1.0>0.2[1.0]
VS LHR-SEA AUG 1.5>0[1.0] SEP 1.6>1.0[1.0] OCT 1.4>1.0[1.0]
VS LHR-SFO AUG 2>0.4[1.8] SEP 2>1.0[1.9] OCT 2>1.2[1.9]
Less long-haul, more short-haul?
WN ABQ-AUS AUG 0.8>0[1.2] SEP 1.1>0.7[1.3]
WN ABQ-BWI AUG 1.8>1.0[2.0]
WN ABQ-HOU AUG 1.9>1.4[3]
WN ABQ-MCI AUG 0.6>0[0.9] SEP 0.9>0.5[0.9]
WN ABQ-SAN AUG 0.8>0[1.9] SEP 1.1>0.7[1.8]
WN ABQ-SJC AUG 0.6>0[0.9] SEP 0.9>0.5[1.0]
WN ALB-BWI AUG 6>5[6]
WN ALB-DEN AUG 0.3>1.0[0.2] SEP 0>0.4[0.1]
WN ALB-MCO AUG 0.8>0[1.2] SEP 1.0>0.6[1.2]
WN ALB-TPA AUG 0.7>0[1.0] SEP 1.0>0.6[0.3]
WN ATL-AUS AUG 3>2[3]
WN ATL-DCA AUG 4>3[4]
WN ATL-HOU AUG 6>4[5]
WN ATL-IAD AUG 2>1.7[1.9]
WN ATL-IND AUG 2>3[3]
WN ATL-LAS AUG 3>1.7[1.9]
WN ATL-LAX AUG 3>0.8[2.0] SEP 3>1.7[1.9]
WN ATL-LGA AUG 4>3[5]
WN ATL-MCI AUG 3>1.7[4]
WN ATL-MDW AUG 6>4[6]
WN ATL-OAK AUG 1.1>0.3[1.0] SEP 1.1>0.7[1.0]
WN ATL-SAN AUG 0.8>0[1.0] SEP 1.1>0.7[1.0]
WN AUS-DAL AUG 8>7[9] SEP 9>8[9]
WN AUS-ELP AUG 1.8>1.4[3]
WN AUS-HRL AUG 0.6>0[0.9] SEP 0.9>0.5[0.9]
WN AUS-LAX AUG 2>3[3]
WN AUS-LBB AUG 0.6>0[0.9] SEP 0.9>0.5[0.9]
WN AUS-MCI AUG 0.7>0[0.9] SEP 1.0>0.6[0.9]
WN AUS-SAN AUG 2>1.6[3]
WN AUS-SJC AUG 1.7>0[3] SEP 3>1.6[3]
WN AUS-SMF AUG 0.7>0[1.0] SEP 0.9>0.5[1.0]
WN AUS-STL AUG 3>2[1.9]
WN BDL-BWI AUG 5>4[5]
WN BDL-MCO AUG 1.4>1.9[2] SEP 1.0>1.4[2.0]
WN BDL-TPA AUG 1.1>0.3[1.2] SEP 1.0>0.6[1.0]
WN BHM-HOU AUG 1.7>1.4[2]
WN BHM-LAS AUG 0.4>1.1[0.0] SEP 0.1>0.5[0.1]
WN BHM-MDW AUG 1.4>0.7[2.0]
WN BNA-OMA AUG 0.2>0[0.1]
WN BNA-ORF AUG 0.5>0.3[0.3]
WN BNA-RSW AUG 0>0.3[0]
WN BNA-SAN AUG 2>1.7[2]
WN BNA-SJC AUG 0.3>1.0[0.2] SEP 0>0.4[1.0]
WN BOI-GEG AUG 1.2>0[1.7] SEP 1.7>1.0[1.0]
WN BOI-PHX AUG 0.8>0[1.0] SEP 1.1>0.7[1.0]
WN BOI-SAN AUG 0.7>0[1.0] SEP 1.0>0.6[1.0]
WN BOI-SMF AUG 0.7>0[1.0] SEP 1.0>0.6[1.0]
WN BOS-BWI AUG 8>6[9] SEP 10>8[8]
WN BOS-CMH AUG 1.2>0[1.7] SEP 1.6>1.0[1.0]
WN BOS-DAL AUG 0.2>0[1.1]
WN BOS-DEN AUG 3>2[3]
WN BOS-HOU AUG 0.7>0[1.1] SEP 0.9>0.5[1.1]
WN BOS-STL AUG 4>3[4]
WN BUF-LAS AUG 0.8>0[1.1] SEP 1.1>0.7[1.1]
WN BUF-PHX AUG 0.7>0[1.0] SEP 1.0>0.6[0.7]
WN BUR-DAL AUG 0.7>0[1.0] SEP 0.9>0.5[1.0]
WN BUR-LAS AUG 9>6[10] SEP 11>10[10]
WN BUR-MDW AUG 0.7>0[0.9] SEP 0.9>0.5[0.8]
WN BUR-OAK AUG 10>6[13] SEP 13>10[13]
WN BUR-PDX AUG 0.7>0[1.0] SEP 0.9>0.5[0.7]
WN BUR-PHX AUG 6>4[6] SEP 6>5[6]
WN BUR-SJC AUG 9>6[11] SEP 11>9[11]
WN BUR-SMF AUG 8>4[10] SEP 10>8[10]
WN BWI-CUN AUG 1.4>2[1.3] SEP 1.1>1.5[1.1]
WN BWI-HOU AUG 5>4[4]
WN BWI-MBJ AUG 1.8>1.0[2]
WN BWI-MCO AUG 10>8[9] SEP 11>10[8]
WN BWI-MEM AUG 1.2>0.7[1.1]
WN BWI-MHT AUG 5>4[6] SEP 6>5[5]
WN BWI-MSP AUG 1.8>0.7[2] SEP 3>2.0[2.0]
WN BWI-PVD AUG 6>5[6] SEP 7>6[6]
WN BWI-PWM AUG 5>4[5]
WN BWI-RDU AUG 6>5[6] SEP 7>6[6]
WN BWI-SAN AUG 3>2[3]
WN BWI-SAT AUG 2>1.7[1.5]
WN BWI-SEA AUG 0.7>0[1.0] SEP 1.0>0.6[1.0]
WN BWI-SJC AUG 1.0>0.3[1.0] SEP 1.0>0.6[1.0]
WN BWI-SLC AUG 1.2>0.5[1.1] SEP 1.0>0.6[1.0]
WN BWI-SMF AUG 1.0>0.3[1.0] SEP 1.0>0.6[1.0]
WN CHS-DAL AUG 0.8>0.6[1.0]
WN CHS-HOU AUG 0.7>0[1.0] SEP 0.9>0.5[1.0]
WN CLE-MDW AUG 4>3[5]
WN CLE-MKE AUG 1.1>0[1.5] SEP 1.6>1.0[1.6]
WN CLE-PHX AUG 0.7>1.4[1.0] SEP 1.0>1.4[1.0]
WN CLT-MDW AUG 1.8>0.7[3] SEP 3>2[3]
WN CMH-DCA AUG 1.5>1.0[1.8]
WN CMH-FLL AUG 0.7>0[1.0] SEP 1.1>0.7[1.0]
WN CMH-MDW AUG 5>4[6] SEP 6>5[6]
WN CMH-PHX AUG 0.8>1.4[1.0] SEP 1.1>1.5[1.0]
WN DAL-DTW AUG 0.7>0[1.0] SEP 1.0>0.6[1.0]
WN DAL-HOU AUG 16>13[18] SEP 18>17[18]
WN DAL-LBB AUG 4>3[5]
WN DAL-LGA AUG 4>3[5]
WN DAL-MAF AUG 4>3[5]
WN DAL-MSY AUG 6>5[7]
WN DAL-ONT AUG 0.7>0[1.0] SEP 1.0>0.6[1.0]
WN DAL-PDX AUG 0.2>0[1.0]
WN DAL-PHL AUG 0.7>0[1.0] SEP 1.0>0.6[1.0]
WN DAL-RDU AUG 0.7>0[1.0] SEP 1.0>0.6[1.0]
WN DAL-SAT AUG 8>7[9] SEP 9>8[9]
WN DAL-SDF AUG 0.7>0[1.0] SEP 0.9>0.5[1.0]
WN DAL-SEA AUG 0.2>0[1.0]
WN DAL-SNA AUG 0>0.7[0.8] SEP 0>0.4[0.9]
WN DCA-HOU AUG 2>1.7[3]
WN DCA-MCI AUG 1.7>1.0[1.8]
WN DCA-MCO AUG 1.8>1.0[2] SEP 2>1.7[1.3]
WN DCA-MKE AUG 1.7>1.0[1.8]
WN DCA-MSY AUG 1.8>1.0[2] SEP 2>1.7[2]
WN DCA-TPA AUG 1.7>1.0[2]
WN DEN-GRR AUG 1.3>1.6[1.0]
WN DEN-JAX AUG 1.0>1.3[1.0]
WN DEN-LBB AUG 0.7>0[1.0] SEP 0.9>0.5[1.0]
WN DEN-SJD AUG 0.4>1.0[0.3] SEP 0.1>0.5[0.1]
WN DEN-SNA AUG 4>5[3]
WN DTW-PHX AUG 0.7>0[1.0] SEP 1.0>0.6[1.0]
WN ECP-STL AUG 1.0>0.8[0.5]
WN ELP-LAX AUG 1.4>0[1.7] SEP 1.9>1.1[1.7]
WN ELP-SAN AUG 0.7>0[1.0] SEP 1.0>0.6[1.0]
WN ELP-SAT AUG 1.5>0[2] SEP 2>1.2[2.0]
WN FLL-IND AUG 0.7>0[1.0] SEP 1.1>0.7[1.0]
WN FLL-RDU AUG 0.7>0[1.0] SEP 1.1>0.7[1.0]
WN FLL-SAT AUG 0.2>0[1.0]
WN FLL-SJU AUG 2.0>1.3[2.1] SEP 2.0>1.6[1.4]
WN FLL-TPA AUG 4>3[4]
WN GEG-PHX AUG 0.7>0[1.0] SEP 1.0>0.6[0.7]
WN GEG-SJC AUG 0.7>0[1.0] SEP 0.9>0.5[1.0]
WN GEG-SMF AUG 0.7>0[1.0] SEP 1.0>0.6[1.0]
WN HOU-HRL AUG 4>3[5]
WN HOU-IND AUG 1.8>1.2[1.9]
WN HOU-LAX AUG 4>3[5]
WN HOU-MAF AUG 3>2[4]
WN HOU-MCI AUG 3>2[3]
WN HOU-MKE AUG 1.7>1.0[1.0]
WN HOU-MSY AUG 8>5[9] SEP 9>8[9]
WN HOU-OAK AUG 2>1.7[2]
WN HOU-OKC AUG 4>3[4]
WN HOU-ONT AUG 0>0.7[0] SEP 0>0.4[0]
WN HOU-PIT AUG 1.4>0.7[1.0]
WN HOU-SJD AUG 1.7>1.0[1.1]
WN HOU-SNA AUG 0>0.7[1.0] SEP 0>0.4[1.0]
WN IND-MCI AUG 1.1>0[1.8] SEP 1.6>1.0[1.8]
WN IND-MDW AUG 1.0>0.3[1.2] SEP 1.0>0.6[1.4]
WN IND-RSW AUG 0.9>0[1.1] SEP 1.2>0.8[0.3]
WN IND-STL AUG 0>1.3[0] SEP 0>0.8[0]
WN ISP-MCO AUG 3>1.9[3]
WN ISP-PBI AUG 0.8>0[2.0] SEP 1.0>0.6[2.0]
WN ISP-TPA AUG 0.7>0[1.0] SEP 0.9>0.5[1.0]
WN JAX-MDW AUG 0.7>0[1.0] SEP 1.0>0.6[1.0]
WN LAS-LAX AUG 9>7[11] SEP 10>9[10]
WN LAS-MCO AUG 2>1.0[1.9] SEP 3>2[1.5]
WN LAS-MSY AUG 1.7>1.0[1.9]
WN LAS-OAK AUG 8>6[8] SEP 9>8[9]
WN LAS-OMA AUG 3>2[3]
WN LAS-PDX AUG 4>3[4]
WN LAS-PHX AUG 10>7[10] SEP 11>9[10]
WN LAS-PIT AUG 2>1.7[1.7]
WN LAS-RDU AUG 0.7>0[1.0] SEP 1.0>0.6[1.0]
WN LAS-RNO AUG 9>6[9] SEP 11>9[9]
WN LAS-SAN AUG 10>7[10] SEP 12>10[10]
WN LAS-SDF AUG 0.7>0[1.0] SEP 1.0>0.6[1.0]
WN LAS-SEA AUG 3>1.8[3]
WN LAS-SFO AUG 5>4[6]
WN LAS-SJC AUG 10>7[10] SEP 12>10[10]
WN LAS-SLC AUG 5>4[5]
WN LAS-SMF AUG 8>5[8] SEP 9>8[8]
WN LAS-TUL AUG 0.8>1.0[1.1]
WN LAX-MCI AUG 2>1.6[3]
WN LAX-MKE AUG 0.7>0[1.0] SEP 0.9>0.5[1.0]
WN LAX-MSY AUG 1.7>0[1.8] SEP 3>1.6[1.9]
WN LAX-OAK AUG 10>7[13] SEP 12>10[12]
WN LAX-PHX AUG 7>5[8] SEP 8>7[8]
WN LAX-RNO AUG 2>1.7[3]
WN LAX-SAT AUG 1.3>0[1.8] SEP 1.8>1.1[1.8]
WN LAX-SFO AUG 7>5[8]
WN LAX-SJC AUG 9>6[10] SEP 10>9[10]
WN LAX-SMF AUG 7>6[8]
WN LAX-TUS AUG 1.8>1.0[2]
WN LGA-MDW AUG 7>5[6]
WN LGA-STL AUG 3>2[3]
WN LGA-TPA AUG 1.2>0[1.7] SEP 1.7>1.0[1.0]
WN MCI-MDW AUG 7>6[8]
WN MCI-MKE AUG 1.3>0.7[1.8]
WN MCI-MSP AUG 1.1>0[1.7] SEP 1.6>1.0[1.4]
WN MCI-MSY AUG 0.8>0[1.1] SEP 1.1>0.7[1.1]
WN MCI-PDX AUG 0.2>0[1.0]
WN MCI-RDU AUG 0.6>0[0.9] SEP 0.9>0.5[0.9]
WN MCI-SAN AUG 0.8>0[1.7] SEP 1.1>0.7[1.7]
WN MCI-SAT AUG 0.7>0[1.0] SEP 0.9>0.5[1.0]
WN MCI-SEA AUG 0.2>0[1.0]
WN MCO-MHT AUG 1.5>2[1.2] SEP 1.2>1.5[0.5]
WN MCO-MKE AUG 3>2[2]
WN MCO-ORF AUG 1.0>0.3[1.2] SEP 1.0>0.6[1.1]
WN MCO-RDU AUG 2>1.2[2]
WN MCO-ROC AUG 0.2>0[1.0]
WN MCO-SAN AUG 0.9>0.3[0.0] SEP 0.9>0.5[0.0]
WN MDW-MSP AUG 6>5[7] SEP 7>6[6]
WN MDW-OMA AUG 4>3[4]
WN MDW-ORF AUG 0.9>0.7[1.3]
WN MDW-PHL AUG 5>4[6]
WN MDW-PIT AUG 4>3[5]
WN MDW-RSW AUG 3>4[2]
WN MDW-SMF AUG 1.7>1.0[1.1]
WN MDW-STL AUG 7>5[7] SEP 8>7[7]
WN MSP-OAK AUG 0.7>0[0.1] SEP 1.0>0.6[0.0]
WN MSY-SAN AUG 0.6>0[0.9] SEP 0.9>0.5[0.9]
WN MSY-SAT AUG 1.5>0[1.7] SEP 2>1.3[1.7]
WN OAK-ONT AUG 6>4[6] SEP 6>5[6]
WN OAK-PDX AUG 6>4[6] SEP 7>5[6]
WN OAK-SAN AUG 10>6[11] SEP 11>10[12]
WN OAK-SAT AUG 0.6>0[0.2] SEP 0.9>0.5[0.1]
WN OAK-SEA AUG 6>4[6] SEP 7>6[6]
WN OAK-SLC AUG 2>1.7[3]
WN OMA-PHX AUG 1.1>1.7[1.1] SEP 1.1>1.5[1.2]
WN ONT-PDX AUG 0.7>0[1.0] SEP 0.9>0.5[1.0]
WN ONT-PHX AUG 6>5[6]
WN ONT-SFO AUG 2>0[4] SEP 3>2[4]
WN ONT-SMF AUG 6>5[7]
WN PDX-SJC AUG 5>3[5] SEP 6>5[6]
WN PDX-SMF AUG 4>3[5]
WN PHL-PHX AUG 0.7>0[1.0] SEP 1.0>0.6[1.0]
WN PHL-TPA AUG 0.8>0[1.1] SEP 1.0>0.6[1.0]
WN PHX-PIT AUG 0.7>1.4[1.0] SEP 1.0>1.4[0.7]
WN PHX-SAN AUG 9>7[10] SEP 11>9[10]
WN PHX-SEA AUG 4>3[4]
WN PIT-TPA AUG 1.4>1.8[2]
WN PNS-STL AUG 0.2>0[0.2]
WN PVD-TPA AUG 0.8>0[1.1] SEP 1.0>0.6[1.0]
WN RDU-TPA AUG 1.4>0.3[1.9] SEP 2.0>1.2[1.6]
WN RNO-SAN AUG 2>1.7[3]
WN RNO-SJC AUG 1.6>0[1.6] SEP 2>1.5[3]
WN RSW-STL AUG 1.4>2[1.1] SEP 1.1>1.5[1.0]
WN SAN-SAT AUG 1.4>0[1.6] SEP 2.0>1.2[2.0]
WN SAN-SFO AUG 6>5[7]
WN SAN-SJC AUG 12>8[15] SEP 15>12[15]
WN SAN-SLC AUG 1.2>0[1.8] SEP 1.7>1.0[1.8]
WN SAN-SMF AUG 12>8[14] SEP 14>12[14]
WN SAN-TUS AUG 1.5>0[1.9] SEP 2.0>1.2[1.8]
WN SEA-SJC AUG 5>3[5] SEP 5>4[4]
WN SEA-SMF AUG 5>3[5] SEP 6>5[5]
WN SJC-SLC AUG 0.7>0[1.8] SEP 0.9>0.5[1.4]
WN SJC-SNA AUG 8>6[10] SEP 9>8[9]
WN SJC-TUS AUG 0.6>0[0.8] SEP 0.9>0.5[0.9]
WN SLC-SMF AUG 0.7>0[1.1] SEP 0.9>0.5[1.2]
WN SLC-STL AUG 0.5>1.2[0.0] SEP 0>0.4[0.0]
X4 JNU-YXY AUG 0.4>0[0] SEP 0.4>0[0]
Chuska
Re: OAG Changes 6/21/2020:August Under Fire;AA Adds DFW-MYR;F9 Builds CVG;DL Drops LAS-LGB/PDX/SAN/SJC/SNA;UA Out of SMX
Sun Jun 21, 2020 12:21 pm
Good Morning Enilria,
UA never made it in to SMX, was originally set to start June 4. SMX, like many other cities, lost all of their major carrier service a few years ago, now only served by Allegiant. Thru the 1990's and 2000's they had AA*, DL*, and UA* with over 20 flights per day. Was looking forward to seeing it return but not happening for awhile.
Thanks again!
MIflyer12
Sun Jun 21, 2020 12:22 pm
JAN 106%
FEB 107%
MAR 90%
APR 20%
MAY 13%
JUN 17%
JUL 30%
AUG 54%
Thanks for this weekly work.
I have to ask - since this report focuses on flights and not seats or seat-miles - is this really seat-miles as % of a year ago, or flight count?
mxaxai
Sun Jun 21, 2020 12:55 pm
Last week:
*DL ATL-BCN AUG 0>0.4[1.0] SEP 0>0.4[1.0] OCT 0>0.3[0.8]
*DL ATL-DUB AUG 0>0.4[1.0] SEP 0>0.4[1.0] OCT 0>0.3[0.8]
*DL ATL-FCO AUG 0>0.4[2]
DL ATL-GIG AUG 1.0>0[1.0] SEP 1.0>0[1.0] OCT 1.0>0.3[1.0]
*DL ATL-MAD AUG 0>0.4[1.0] SEP 0>0.4[1.0] OCT 0>0.3[0.9]
This week:
I'm guessing that DL wants to push their central European traffic through the AMS & CDG hubs whereas southern and western Europe need direct service to avoid excessive detours?
nonrevelite
Sun Jun 21, 2020 1:03 pm
Thanks again!
SMX is being pushed pack to March 2021. Still on the schedule from SFO and DEN next year.
Airlines : 6E 9W AA AC AI AM AQ AT B6 BA BR CI CM CO CX EA EK ET EY FL GF GF HA HP HX JQ K2 K6 KA KE KL KU LO MA MH N7 NH NW OV OZ PE PI QF QR RJ SG TG TK UA UH UL US VS WN YT ZK
Aircraft : Over 60 types including the B-17
Airports : Over 150
jayunited
Sun Jun 21, 2020 1:05 pm
Thanks again enilria as always I appreciate all the hard work you put into these threads every Sunday.
I think the European reductions are to be expected because it would seem as though most of Europe is on a downward trend with COVID, while here in the US we are seeing cases rise in certain states.
What shocked me are the August LAX cuts by both DL and WN. They were both the last 2 holdout at LAX operating more flights than AA and UA both of whom cut LAX early. I know LAX is a huge O&D airport for most airlines. However, with so much capacity removed thanks to the AA and UA reductions I didn't think we would see any further by DL or WN at LAX especially during the summer months. I know LA has a diversified economy but is the lack of tourist and perhaps the lack of business from Hollywood studios hitting them harder than first expected?
Midwestindy
Sun Jun 21, 2020 1:06 pm
mxaxai wrote:
Last week:
This week:
STR & DUS are much more business oriented routes, int'l business travel won't be back by August or September most likely.
BCN, MAD, FCO, and DUB are large VFR destinations, large Expat locations, or have a lot of international students coming to the US universities in the fall
Status for 2019/2020: AAdvantage Platinum, Delta Gold, Southwest A-List
Midwestindy
Sun Jun 21, 2020 1:17 pm
UA & AA's august schedules aren't finalized yet, and an LAX spokesperson expects flights to triple in August, so we'll see what they decide to do:
https://www.ocregister.com/2020/06/12/f ... son-nears/
DL is actually operating a fairly large LAX operation in August, at close to 100 departures (they were only at ~170 last August)
enilria
Sun Jun 21, 2020 1:18 pm
Thanks again!
Thanks. Too many things for me to remember!
MIflyer12 wrote:
JAN 106%
FEB 107%
MAR 90%
APR 20%
MAY 13%
JUN 17%
JUL 30%
AUG 54%
ASM and not only domestic
Good catch. That is odd. Of course Americans are not allowed into Europe and Europeans are not allowed into the USA currently which seems like an issue.
Thanks again!
Perhaps, but March 2021 is an eternity from now.
I have a theory. I have always thought that a lot of LAX medium and short haul is really interline to foreign flags. That's all dead now. Could that be a factor?
SANFan
Sun Jun 21, 2020 1:55 pm
The lack of a cruise industry is I'm sure affecting also pax trafffic in and out of LAX, just as it's having an impact on SEA and other cruise gateways in the country. Those ginormous ships of today take a lot of people every week to fill and none of the people are flying to or from cruises right now... Gulp...
bb
ericm2031
Sun Jun 21, 2020 2:08 pm
The exemptions granted were only granted until the end of the timeline (9/31, some earlier), but as far as I know, nobody has any obligation to keep service beyond that. So it looks like DL has completely pulled their's from the schedule (except for ASE I believe from an update a couple weeks ago) while UA has only gone until 9/31, but I guess could extend at any point if there really is no obligation after that point.
DL didn't cut more, they just cut from their full pre-COVID schedule that was published before.
MIflyer12
Sun Jun 21, 2020 2:20 pm
bb
That's a hard one to suss out. First, you'd need to the fraction of cruise passengers are arriving/departing by air vs. driving. Then one would want the combined passenger total for the LA/Long beach facilities. It may be a fairly small fraction in the scope of LAX operations and O&D traffic.
tphuang
Sun Jun 21, 2020 2:40 pm
Good morning and thanks again enilria
What's the rules regarding slot usage at this time? Looks like DCA/LGA flights are loaded in without reduction elsewhere. Since these flights are loaded into Jan/Feb, did they grab additional slots there?
Big moves at JFK, I'm counting already 99 flights a day in late July. August will probably get them to over 120 flights a day here. It really helps JetBlue that leisure, transcon and Carribbean stuff is coming back so much quicker than short business and TATL flights. When we get to October, it might be in JetBlue's best interest to lobby against continued slot waivers. I really could see them operating close to 80% of their JFK/LGA/DCA slots by December.
JAN 106%
FEB 107%
MAR 90%
APR 20%
MAY 13%
JUN 17%
JUL 30%
AUG 54%
So with 54% ASM loaded in (probably a larger fraction than that of their usual # of flights), I'm seeing basically around 75 flights a day out of both LGA/JFK on peak days. Not sure how much higher they can go than that while within perimeter business and LH international demand are at minimal for at least the next few months.
What's DL's game plan if slot waivers don't get extended at end of october or even if it expires in end of Jan/Feb?
big moves here by F9 at CVG, ISP and PVD. I suppose CVG is anticipating a DL retreat there and ISP is anticipating WN retreat there. Still seems optimistic that Florida can support this much additional capacity at a time when economy is down.
Any guesses on when we will see a retaliation from UA on JetBlue's EWR buildup?
MrPeanut
Sun Jun 21, 2020 2:54 pm
Most of Europe is still closed to Americans or requires a 14 day quarantine. The ramp up in European routes will not begin until this changes.
AWACSooner
Sun Jun 21, 2020 3:02 pm
No surprise on DL canning most of their LAS focus ops...as it’s no secret it’s low yielding
Scarebus34
Sun Jun 21, 2020 3:42 pm
MIflyer12 wrote:
bb
How many people actually fly into LAX for a cruise? Probably not many... I always thought cruises that depart from California are mostly for the locals.
AirFiero
Sun Jun 21, 2020 3:50 pm
Scarebus34 wrote:
MIflyer12 wrote:
bb
We live in the Bay Area, and have traveled at least 5 times to the LA area for a cruise. I don’t think we ever flew into LAX, but we know others that have. I’d bet plenty of people do.
evank516
Sun Jun 21, 2020 3:54 pm
Good to see DL bringing back LGA-MCI/STL. Guess since WN is keeping it so will they. Really hoping for an upgauge here though.
holeham
Sun Jun 21, 2020 4:02 pm
It looks like an overall reduction by WN in August flying period. I see very few adds both short-haul and long-haul for the month or am I not reading this right?
jb1087xna
Sun Jun 21, 2020 4:30 pm
Thanks as always for the Sunday read.
Glad to see the slow build back here. One nugget, one of those four flights will be operated by Republic instead of Endeavor and I believe this will be the first time that DL has regularly scheduled service to XNA on an E175. Ironically Skywest has had quite a few of them that stop here on delivery/ferry flights.
kavok
Sun Jun 21, 2020 4:56 pm
It is also worth noting that pre Covid, Las Vegas would host a significant number of business conventions and conferences. These events are almost all cancelled, and will remain that way for quite some time. The people going to LAS in their near term are primary leisure or VFR, which is obviously far lower yielding than the business conference/convention traffic. As DL catered more to the business traffic, and the LCC handled more of the leisure, it is no surprise to see DL reducing LAS flights.
aemoreira1981
Sun Jun 21, 2020 6:34 pm
What surprises me is a lot of B6 non-hub to non-hub flying that's planned as well as new route adds from JFK.
Nicknuzzii
Sun Jun 21, 2020 6:42 pm
[photoid][/photoid]
EWR is considered a B6 base now.
altairF28
Sun Jun 21, 2020 7:11 pm
Nicknuzzii wrote:
[photoid][/photoid]
But PBI, RSW and TPA aren't. Those added flights are non-hub to non-hub, although with cases spiking here in Florida and at least one state talking about a mandatory 14-day quarantine for anyone entering the state from Florida B6 may end up not starting some of these.
A detour is a choice between two tasks, each with its own pros and cons
SCQ83
Sun Jun 21, 2020 7:26 pm
Midwestindy wrote:
mxaxai wrote:
Last week:
This week:
It should be a mix of market (STR, DUS and BRU are small markets) and distance to other stations served by DL.
Stuttgart to Frankfurt Airport is 1h13' by train or 200 km. by car
Düsseldorf to Frankfurt Airport is 1h22' by train or 219 km. by car
Brussels to Paris CDG is 1h36' by train
Dieuwer
Sun Jun 21, 2020 7:32 pm
DL BOS-LHR AUG 1.0>0[1]
Looks like Skyteam is imploding in BOS. JetBlue must be laughing out load and high fiving eachother.
OneWorld also will gladly take market share from DL.
HNLSLCPDX
Sun Jun 21, 2020 7:43 pm
That’s a little dramatic. VS is not even part of SkyTeam. AZ, KL, AF, KE, will all eventually return. DL’s non-SkyTeam JV partners of LA, WS, and VS will come back too. And I expect DL to rebound and eventually get back to a similar level at BOS once things return to “normal”.
Judge1310
Sun Jun 21, 2020 7:51 pm
Nicknuzzii wrote:
[photoid][/photoid]
Until there's an official press release or company-published memo, that's not the case. As other posters have indicated, B6's EWR flights can easily be crewed via already established bases. Most may not realise this, but to create a new crew base/domicile is not simply a case of just adding flights and done. There are far more logistics that are involved in such an endeavour.
IADFCO
Sun Jun 21, 2020 7:54 pm
A mock IAD-FCO reservation for Aug 1 returning Aug 15 shows AZ 619/618, codeshared as DL 6686/6677. This is the (formerly) usual IAD-FCO Alitalia nonstop. I wonder whether it's just from a legacy/nonupdated schedule or it's real. No traces of the other (formerly) usual United nonstop.
MO11
Sun Jun 21, 2020 8:13 pm
You're probably not interpreting it right. Remember that the number to the left of the chevron is the number of flights that were in the August schedule last week. This was a "COVID never happened" schedule. The number to the right is the updated August schedule (now adjusted for COVID). There is no comparison between the July and August schedules.
FlyingElvii
Sun Jun 21, 2020 8:17 pm
Also big cuts ar LGA, it seems, for August. They must not see biz travel returning. Just guessing, but it looks like most of those cuts are YX flying?
CIDFlyer
Sun Jun 21, 2020 8:29 pm
Nice to see CID-Atlanta and CID-DTW back
Nicknuzzii
Sun Jun 21, 2020 8:39 pm
Judge1310 wrote:
Nicknuzzii wrote:
[photoid][/photoid]
http://blueir.investproductions.com/inv ... -143034427
jonair8
Sun Jun 21, 2020 8:43 pm
enilria wrote:
FAQ
JAN 106%
FEB 107%
MAR 90%
APR 20%
MAY 13%
JUN 17%
JUL 30%
AUG 54%
Really good information here, thank you so much for compiling these every week. Providing the ASM % YOY is especially valuable, and I think that the information that you give here a lot of times is way more valuable than any public information anywhere else.
That being said, DL (surprisingly) never really considered LAS an official focus city, instead focusing more officially on SJC, AUS, BOS, and RDU in recent times, according to their press releases. The last time I traveled to LAS, I was surprised at the amount of DL E7W activity there. DL does not expect their business traffic to fully recover for another 2-3 years, so hopefully we will one day see these return when that happens, since LAS is a very popular destination on the west coast for conventions and conferences as others mentioned. The LAS point to point loads must be too low and forecasted to stay that way without their business travelers or their high value customers flying leisure. However, some thought DL's shrinkage would mean the end of those recently announced focus cities, but they're all mentioned by Ed Bastian as markets they are committed to, except for BNA, CVG, and SJC. Seeing August's ASM be almost twice as much as July's shows things are on the mend and Delta is ready to play ball.
https://thepointsguy.com/news/delta-air ... ocus-city/
umichman
Sun Jun 21, 2020 8:46 pm
DL is restoring CVG service to LAX/LAS/MCO/TPA/FLL/RSW in August. That doesn't look like a retreat. Perhaps they got wind of the F9 adds and is defending CVG. Also, it's not the airport's behind these decisions, it's the carriers. F9 added the flights because they saw an opportunity, not because CVG directed them to add the flights.
panamair
Sun Jun 21, 2020 9:48 pm
In these times, you have to look at month to month changes, not a comparison to what was put into the schedule pre-Covid-19. This is the first time DL has adjusted the August schedule since loading it originally under Pre-COVID-19, so naturally you see cuts. However, this is an increase of about 20-25 flights a day from July.
jfklganyc
Sun Jun 21, 2020 9:54 pm
altairF28 wrote:
Nicknuzzii wrote:
[photoid][/photoid]
PBI is a pilot and FA base for B6
Nicknuzzii
Sun Jun 21, 2020 10:02 pm
Even with the spike of cases bookings are only going up!
incitatus
Sun Jun 21, 2020 10:45 pm
It looks like intercontinental cargo shipping rates are coming down from the stratosphere. Unless passenger traffic picks up, the long-haul fleets will stay idle.
I do not consume Murdoch products including the Wall Street Journal
mxaxai
Sun Jun 21, 2020 11:03 pm
With the economy crashing, urgent PPE cargo becoming less and passenger fleets slowly returning to service, we'll likely see cargo rates dropping well below their pre-COVID levels. Not today, but within the next 3-6 months.
evank516
Sun Jun 21, 2020 11:09 pm
They're cuts compared to pre-COVID levels, but actually there's some increases happening at LGA. MCI and STL are returning in August and both are operated by YX.
AVLAirlineFreq
Mon Jun 22, 2020 1:10 am
I'm curious what booking patterns are like with the big three US legacy carriers allowing passengers to book through June 30 without a change fee, and what they will be like after that date.
aemoreira1981
Mon Jun 22, 2020 2:25 am
jfklganyc wrote:
altairF28 wrote:
Nicknuzzii wrote:
[photoid][/photoid]
Look at the adds from PHL though...that's what I call non-hub to non-hub as well. I didn't know that Newark was now a hub for B6.
That said, for Mint flying trans-con, UA is typically almost all wide-body on LAX-EWR and SFO-EWR. If the p.s. B752s do not return, and the 737 MAX 10 isn't ready any time soon, United will have a lot of fare pressure as B6 can offer the same international product as B6 but with a smaller plane to fill. I also see the end for any 364-seat B772s on transcon to and from EWR, with primarily B789 and B78X transcon.
tphuang
Mon Jun 22, 2020 2:39 am
This is still far enough from August where we don't know their final capacity. It could end up being a lot smaller than 54% of their 2019 size. But if they are running a 54% schedule (higher in terms of number of flights), flying only about 25 to 30% of their slots at LGA is pretty slow in terms of bringing things back. This really speaks for the slowness in the return of New York pure business market demand. Again, how do they go from this to using up 80% of their LGA slots by the time slot waiver is over?
I think my comment was not clear. I'm saying F9 made these decisions based on their belief that DL will retreat at CVG.
Judge1310
Mon Jun 22, 2020 3:03 am
Nicknuzzii wrote:
Judge1310 wrote:
Nicknuzzii wrote:
[photoid][/photoid]
Thanks for the link about the initial communication regarding the addition of flight by B6, but, maybe I overlooked it, I still see no where about a "base" being established by B6 at EWR. Do direct me to where I can obtain such info...
rjbesikof
Mon Jun 22, 2020 7:16 am
Looks like DL is going to go back to nonstop China in August. Does anyone know why they are terminating the crew stop in ICN? Also totally unrelated to this, what is AA's plan for resuming China when it is set to come back in October?
Nicknuzzii
Mon Jun 22, 2020 11:58 am
It literally lists EWR as a focus city right on the map.
N766UA
Mon Jun 22, 2020 12:56 pm
jfklganyc wrote:
altairF28 wrote:
Nicknuzzii wrote:
[photoid][/photoid]
JetBlue does not have a pilot base in PBI.
PSU.DTW.SCE
Mon Jun 22, 2020 1:50 pm
That's what they loaded for sale and in a perfect world, if everything goes right, borders open-up, governments loosen restrictions then that is what they would like to fly.
In reality, who knows what they will be allowed to fly in 6-10 weeks from now.
That's what they want to do, that's what they are going to sell for now, but there is pretty good chance they will still have to do a crew-stop ICN. A lot can change between now and then.
KarlB737
Mon Jun 22, 2020 2:28 pm
Courtesy: Aviation Week
Delta Will Add Flights Through August Before ‘Pause
https://aviationweek.com/air-transport/airlines-lessors/delta-will-add-flights-through-august-pause
