mcdu
Delta has a hail encounter.
Wed Jul 08, 2020 12:47 am
Delta found the hail in the east coast storms yesterday. That radome looks a mess. Wonder if the ATC audio is available for this event?
https://simpleflying.com/delta-a319-nose-damage/
DTWLAX
Re: Delta has a hail encounter.
Wed Jul 08, 2020 2:47 am
n7371f
Wed Jul 08, 2020 3:30 am
Yep. And ABC News, always a sucker for anything "emergency" involving a plane, made it sound like life and death with David Tree.
deyoe1118
Wed Jul 08, 2020 3:34 am
It was a bird strike, not hail per Delta flight ops and MTC
Aircraft 3142 (N342NB)
flight152
Wed Jul 08, 2020 3:43 am
That’s not even close what a bird strike looks like.
uadc8contrail
Wed Jul 08, 2020 3:47 am
the picture that mcdu posted is definately hail, not a bird strike
Bus Driver
adambrau
Wed Jul 08, 2020 3:58 am
Was at the gate working on AF007 JFK-CDG and saw a whole bunch of emergency vehicles streams by T1. A little later I saw what I thought was a DL A320 stopped midway down a runway and that was where the Emergency vehicles eventually surrounded the plane. Was curious but busy. There were storms in the area so makes sense. Glad all are safe.
JFK Friendly
Boeing757rb211
Wed Jul 08, 2020 4:42 am
Wow while not unheard of at all,,, Still quite impressive the damage caused. This is gonna be a VERY expensive repair (not that hail cant of course do massive damage at high speeds) but this should run what.... $50,000 or even more JUST to replace the Radome on the 319 + All the internal Navigation equipment that was actually broken or damaged, And whatever damage there is to the surrounding Radome Housing, Front/Side Windscreens Leading edges of the wings and tail area and of course any external and possible internal engine damage from this incredible. Anyone know any ballpark figures for some of the things things that may need replacing or fixing? And is it at all possible with Aviations' current trajectory/climate being that this is a pre-merger Northwest Airlines A319 18+ Years old,,, If its possible they may just part it out or get rid of it ?
deyoe1118
Wed Jul 08, 2020 4:53 am
Got friends in both MTC and OCC that confirm bird strike. That's all I can say so think what you want otherwise.
catiii
Wed Jul 08, 2020 5:30 am
Having flown through roughly the same weather and landing shortly after the aircraft in question, I’d find it hard to believe it was a bird no matter what DL us saying.
jfklganyc
Wed Jul 08, 2020 9:29 am
Maybe they hit a pterodactyl?
AKL321NX
Wed Jul 08, 2020 9:45 am
A swarm of very cold hummingbirds maybe
TYWoolman
Wed Jul 08, 2020 12:03 pm
Don't have an answer but that's one hail of a litany of questions and curious myself! Glad plane landed safely. Good work, pilots!
bigb
Wed Jul 08, 2020 12:38 pm
gon2fly
Wed Jul 08, 2020 12:44 pm
When I first saw this on the news yesterday I told my wife there is no way that is a bird strike. Lack of any blood and the peppered 'hits' def looked like hail damage. Day later.....it's hail damage. You hit a bird and it's pretty much not your fault. You fly through hail and it's pretty much always your fault. Pilots will wish they had hit a bird.....
nwadeicer
Wed Jul 08, 2020 12:45 pm
The one things that jumps out of that news article is only 43 passengers on a Florida to NYC flight...
I miss the Red Tail
N766UA
Wed Jul 08, 2020 1:31 pm
Unless it’s an old airbus. Radar on those things is notoriously bad.
ltbewr
Wed Jul 08, 2020 1:38 pm
There has been some intense storms in the NYC region with significant hail. I wonder why this flight continued to NYC with an intense storm, that didn't just stay outside the storm zone for a while until the front passed. It would have been much safer.
clrd4t8koff
Wed Jul 08, 2020 1:41 pm
Well apparently they lied to you. Perhaps your definition of a friend needs to be refined. Sounds like you heard rumor mill gossip from a random employee who you deem a "friend."
Wacker1000
Wed Jul 08, 2020 1:54 pm
Odd that there is no visible damage to the fuselage or leading edges.
txjim
Wed Jul 08, 2020 2:06 pm
Curious as to why JFK was a diversion from LGA. Is there a runway or pattern consideration that made JFK a better choice?
mcdu
Wed Jul 08, 2020 2:14 pm
DL seems to have these type of events on a regular basis. Didn’t they have the same thing happen twice around DEN in the past couple of years?
bigb
Wed Jul 08, 2020 2:25 pm
Longer and more favorable runways, clear of weather, bigger DL maintenance presence.
LX015
Wed Jul 08, 2020 2:48 pm
Ask and ye shall receive...
https://youtu.be/SNFhd5r0teE
AWACSooner
Wed Jul 08, 2020 2:52 pm
Well, since NY/NJ/CT are pretty much issuing mandatory 14-day quarantines for any state south of the Mason-Dixon line...
AA757223
Wed Jul 08, 2020 3:43 pm
On the ground at JFK they said “we briefly lost all aircraft controls.” That’s wild. Glad everything worked out
Boeing757100
Wed Jul 08, 2020 3:50 pm
Again! Does any1 else remember a couple years ago another A320 family aircraft took a beating from hail and landed in Denver?
HII
Wed Jul 08, 2020 3:57 pm
I bet quite a few of the pax were saying their own Hail Mary's. :duck:
FCOTSTW
Wed Jul 08, 2020 4:34 pm
Some other detailed description and a close-up picture of the nose over here:
http://www.avherald.com/h?article=4d9a5e87&opt=0
RetiredWeasel
Wed Jul 08, 2020 4:36 pm
Delta has a some experience in repairing hail damaged radomes. 744 going into Incheon a few years back:
https://www.bizjournals.com/twincities/ ... it-of.html
tb727
Wed Jul 08, 2020 5:41 pm
Weather radar doesn't paint hail. The newer radar RDR-4000 on 320 series delivered the last 3-4 years does have a hazard function depicting where hail may be. Both radar systems I use tend to make things look worse than they are generally speaking. On the older ones as you get closer it looks better. If you are still painting stuff 60 miles out and closer in auto, it's probably there at your altitude.
OA412
Wed Jul 08, 2020 6:15 pm
They don't. There were a couple of hail incidents in 2015. Nothing since then until this one.
Hughes Airwest - Top Banana In The West
Tn55337
Wed Jul 08, 2020 8:09 pm
Is this one a write off? :-)
deltairlines
Wed Jul 08, 2020 10:18 pm
There was golf ball sized hail in the NYC metro that day. We somehow avoided most of the storms (I live about 8 miles southwest of EWR) but the radar around the metro area was pretty grim.
saab805
Wed Jul 08, 2020 11:08 pm
This was the AA one in 2018.
https://www.kob.com/business-news/ameri ... s/4935112/
saab805
Wed Jul 08, 2020 11:19 pm
Radome repair will be around half that. But your point is accurate, it depends what other components were damaged (weather radar, etc. )
sadde
Wed Jul 08, 2020 11:39 pm
Lol why is everyone so obsessed with this question
DTWLAX
Thu Jul 09, 2020 12:32 am
You need to catch up on some Covid news. NY, NJ and CT are requiring people flying in from FL go into a mandatory quarantine. Why will people fly unless it is absolutely necessary or for an emergency?
Also, DL is still blocking middle seats on planes and flying only about 60% of plane capacity, so there is no way that plane was going to be full.
PSU.DTW.SCE
Thu Jul 09, 2020 3:55 am
It will fly again.
Considering a few things - with flying down there is a large amount of rotable parts in inventory and/or could be taken off of aircraft in storage.
Secondly, the maintenance labor is more or less paid for right now with wages under the CARES act.
They will likely inspect, repair, and replace whatever is necessary. The aircraft will have to fly out of JFK either way.
50/50 chance they either repair it and get it back into service in JFK, or just repair enough to get a ferry permit to send it out to someplace like ATL for the time being.
September11
Thu Jul 09, 2020 4:19 am
I suppose insurance will cover the damage in this incident
Airliners.net of the Future
2175301
Thu Jul 09, 2020 4:35 am
Unlikely. The cost of this repair is probably less than the deductible.
FlyHappy
Thu Jul 09, 2020 4:54 am
I've never thought about this - what is a typical "deductible" for an aircraft/airline like this?
Do deductibles vary, or are they standardized as on autos?
alasizon
Thu Jul 09, 2020 5:11 am
Most airlines self-insure with deductibles well in the $1M-$2.5M range depending on the incident.
