Antaras
Bamboo wants to invest in 4 Embraer E-jets for VCS service
Fri Jul 10, 2020 3:48 am
Vietnamese article: https://vnexpress.net/bamboo-airways-muon-bay-con-dao-tu-thang-8-4126041.html
Bamboo Airways said it has researched and reported to the Aviation Department about the operation plan of Embraer's aircraft line, with a configuration of 110 - 120 seats to fly to Con Dao (VCS, a small airport with 1800m runway).
Representative of Bamboo Airways said that the above plan is waiting for the approval of Aviation Department. "If approved, Bamboo Airways plans to operate return flights from the North and the Central to Con Dao from August 1," the representative said. The airline is also planning to invest in buying four new Embraer jets to serve the plan.
Even though it said that it would "order new aircraft", it is impossible for QH to order the aircraft now and receive those airframes immediately from August (next month).
Btw, Royal Air Maroc is returning its 4 E190 back to the lessors. QH might take up those airframes.
How do you think about that?
Edit signature
This is a block of text that can be added to posts you make. There is a 255 character limit.
ghost77
Re: Bamboo wants to invest in 4 Embraer E-jets for VCS service
Fri Jul 10, 2020 5:54 am
Many Embraer 190s out there are ready to be leased ex Air Canada, American, JetBlue, RAM and many more airlines getting rid of them! Good for Bamboo that will give home to 4 frames.
g77
Antaras
Fri Jul 10, 2020 6:04 am
g77
In fact as Vietnamese carriers cannot register airframes which are older than 10 y/o, and most AC/AA/Jetblue frames are too old, I don't think that QH would take any from these carriers.
However, RAM's airframes are just more than 5 years old, and RAM are discarding exactly 4 airframes, so it makes perfect sense that Bamboo had a call with Nordic Aviation for a nice lease contract for those airframes (Emb Serial 19000680, *681, *682 and *684)
Edit signature
ghost77
Fri Jul 10, 2020 6:13 am
Oh, nice to know that! NAC is in desperately need to allocate those frames! Good and fast move!
g77
VSMUT
Fri Jul 10, 2020 7:45 am
Antaras wrote:
g77
The article does say 110-120 seats, which suggests an E195, not E190. There is a fair bunch of young E190s and E195s available within short notice, not least those from Azul but also Helvetica who are replacing then with E2s.
Antaras
Fri Jul 10, 2020 9:09 am
VSMUT wrote:
Antaras wrote:
g77
In other article QH said it wants E190/195, so I believe that there is still a chance for the E190.
Edit signature
N14AZ
Fri Jul 10, 2020 9:15 am
How I wish they or somebody else would improve the air traffic connections to Northern Vietnam... :-/
Antaras
Fri Jul 10, 2020 9:22 am
QH could use those regional jets to DIN (Dien Bien Phu), which is a small but important airport in Northern Vietnam region
Edit signature
N14AZ
Fri Jul 10, 2020 9:31 am
That wouldn’t help me since there are already two flights a day to Dien Bien Phu from HAN. I was referring to the Son La province... but I guess that’s off-topic :-/
VSMUT
Fri Jul 10, 2020 9:41 am
They wanted (and applied for) A319 service. It seems clear that they want to fly the biggest plane possible.
PlymSpotter
Fri Jul 10, 2020 9:53 am
This would certainly upset VASCO with their ATRs
The A319 would make sense from a fleet commonality perspective. It should be able to handle the runway distances in most conditions, so I wonder if there are other physical characteristics, such as pavement strength, which are prohibitive here. Or, if it's just protectionism.
Antaras
Fri Jul 10, 2020 10:19 am
Seems like VN (VASCO's parent) is speeding up its regional-jet order (rumoured as E175/190-E2) as QH seems too serious on those VASCO-exclusive routes.
Have a look at VCS'air picture:
Only one single runway. No taxi or exit way. Two heads are surrounded by sea. Besides that, the runway is too narrow even though its length is pretty fine (1830m/4233ft)
Besides that, VCS runway surface was said too soft to hold A319's load.
QH will test its only A319 on VCS next week. Let's wait!
Edit signature
Antaras
Fri Jul 10, 2020 10:27 am
No. Sơn La is "sanwiched" between Điện Biên and Hà Nội (Hanoi).
There are just hundred of miles between Sơn La and HAN or DIN, and I think an airport in Sơn La is unnecessary.
Edit signature
N14AZ
Fri Jul 10, 2020 11:03 am
I know. I travel to Son La twice a year since 2012. It‘s always a PIAS (... or neck...) because it takes one working day to drive to Son La from Hanoi. I took the flight to Dien Bien twice and continued the trip from there by car but all in all it’s the same duration.
There are actually plans to open Son La airport again:
https://www.vir.com.vn/acv-proposes-100 ... 69407.html
Sorry moderators, feel free to delete if it’s too much off-topic
Antaras
Fri Jul 10, 2020 11:11 am
I think that the best solution for the gov is to revive the Nà Sản Airport.
As a large number of regional jet would arrive Vietnam in the next decade, big investment is unnecessary
Edit signature
PlymSpotter
Fri Jul 10, 2020 1:25 pm
Antaras wrote:
Have a look at VCS'[url=https://www.google.com/maps/place/C%E1%BA%A3ng+H%C3%A0ng+kh%C3%B4ng+C%C3%B4n+%C4%90%E1%BA%A3o/@8.7315464,106.6301117,1397m/data=!3m1!1e3!4m5!3m4!1s0x3198abff5a3aba87:0x21cb9025e9389d77!8m2!3d8.7312583!4d106.6286917]air picture
Yes I did have a look at GE beforehand - dimensionally it all appears to be fine for operations with an A319.
Proximity to the sea would not be an issue - safety areas have been provided at each end of the pavement. Granted they are probably not fully compliant with ICAO standards, but they look to be in line with regional norms, which is good enough for hundreds of other airports with medium sized jet operations. Multiple runway exits aren't necessary and nor are (parallel) taxiways required for operations with a jet like the A319 - the turning areas look perfectly sufficient. Remember that wheelbase is key for turning circles - the A319's is only ~30cm longer than the ATR 72's, and shorter than the E190 and E195s. References online suggest the runway at VCS is 100ft / 30m wide - again that's compatible for A319 / A320 operations. In theory ICAO only approve so long as the MTOW is restricted to 68,000kg, but in practice this is not always actioned anyway.
^This, as I thought, could well be the real reason. Do you happen to know the PCN they promulgate?
IndianicWorld
Fri Jul 10, 2020 1:32 pm
Seems that the mantra of keeping a simplified fleet is going out the door. Was once a cornerstone of starting a carrier, but in this carriers case it has been a hard airline to read but good luck to them.
lightsaber
Fri Jul 10, 2020 2:25 pm
VSMUT wrote:
Antaras wrote:
g77
There is no shortage of available E-190/195. Prices are going to favor the buyer. If RAM offered a good deal, excellent. Otherwise, it it a buyer's market.
Lightsaber
Flu+Covid19 is bad. Consider a flu vaccine, if not for yourself, to protect someone you care about.
JeremyXWB
Fri Jul 10, 2020 2:38 pm
I'm really starting to get worried about QH being too over-ambitious on their expansion plans in such a short time and ended up biting off more than they can chew
WOW Air and Primera ring any bells?
Antaras
Fri Jul 10, 2020 2:50 pm
In fact this is a SAFE move from QH.
Stop farming the international market and start caring a trendy (and underserved) domestic route.
VCS is becoming the hottest destination in Vietnam and the route is operated exclusively by VN/VASCO with small ATR72 and damn-expensive tickets.
In Vietnam we say that if QH successfully step on VCS (and break VN/0V monopolism on the route) it would become the second big revolution of the market, after the introduction of VJ breaking the monopolism of VN/BL in the whole market.
Edit signature
MEA-707
Fri Jul 10, 2020 3:46 pm
Apart from the RAM machines, there are other candidates too. If they call Azul I am sure they are happy to offload either some 195s which are 3-10 years old or some new 195E2s.
nobody has ever died from hard work, but why take the risk?
VSMUT
Fri Jul 10, 2020 3:49 pm
Lightsaber
The RAM planes are supposedly leased from NAC. But I doubt they would be in consideration for a new customer that fast (especially since both announcements happened on the same day, the Bamboo announcement possibly a bit before), and it seems very likely that NAC has a few E-jets available already. The NAC website claims they have a portfolio of 150 E-jets, including those at airlines like Air Canada, Azul and FlyBe, who have all been shedding E-jets. Azul in particular will replace all 56(?) E1s by 2022, and even though LOT and Moxy have claimed some, there are likely still a bunch available.
MEA-707 wrote:
Apart from the RAM machines, there are other candidates too. If they call Azul I am sure they are happy to offload either some older 195s or some new 195E2s. Also GTLK, a Russian lessor, has 6 parked in the Netherlands and still looking for an operator. Given the old Soviet-Vietnamese ties that deal can also be made easily.
Old planes are an issue. Vietnam doesn't allow the import of planes older than 10 years.
Insertnamehere
Fri Jul 10, 2020 4:48 pm
AA recently retired their E190s, could those be bought?
zkojq
Fri Jul 10, 2020 4:58 pm
+1
Is it me or do we have threads every fortnight about planes which Bamboo wants to buy?
First to fly the 787-9
VSMUT
Fri Jul 10, 2020 6:07 pm
Too old. Again, Vietnam doesn't allow aircraft older than 10 years.
jsnww81
Fri Jul 10, 2020 6:14 pm
Very interesting! The growth in Vietnam's domestic market has been really significant in the past 5-10 years. With almost 100 million citizens and rising disposable income, plus difficult geography that makes overland transportation impractical, I wouldn't be surprised to see it evolve into something similar to Japan. There are already plenty of widebodies on the SGN-HAN core route, and they're starting to show up on routes to Da Nang and Haiphong now as well.
I've gone from knowing nothing about the Con Dao islands a year ago to now seeing them mentioned in lots of travel blogs and guides. VASCO was flying SGN-VCS ten times a day with ATRs up until the virus outbreak in March. Not surprising that Bamboo sees an opportunity!
Antaras
Sat Jul 11, 2020 12:14 am
MoU for 50 A321neo, MoU for 20 more B789.
Planned for 12 777X.
In the past: 50 B737max9 and then 50 B737max8.
Edit signature
Antaras
Sat Jul 11, 2020 6:33 am
If AA is retiring young airframes which are younger than 10 y/o then YES.
Otherwise, CAAV says NO.
For what I heard in-house, QH is also finding some airframes for wet-lease operation besides owned/dry-leased airframes.
Edit signature
Tankdiver
Sat Jul 11, 2020 7:39 am
I have family in VCS, hearing this news kind of makes me depressed. In the pass two years there seen an explosion of tourism to this pristine island. Near every flights by VASCO ATR72 were full. They went from three flight daily to something like eight flights a day. They even added high speed ferry service to the island recently. I knew jet service will eventually come, but I was hoping it wouldn't.
Antaras
Sat Jul 11, 2020 8:07 am
Yes, I don't want this beautiful island to be destroyed by the tourism boom on the island.
The authorities have to take action to protect the beauti as well as the unique wildness of the island. Please don't turn Côn Đảo into the second Phú Quốc (PQC).
However, QH's plan is necessary as the demand is increasing. VASCO shouldn't hold this goldmine forever.
0V's tickets are becoming ridiculous expensive and now the price for SGN-VCS almost the same as HAN-SGN tickets, even though it is just a short domestic route operated by the small ATRs
Edit signature
jsnww81
Sun Jul 12, 2020 2:33 am
I haven't been to Con Dao, but I do hope it's preserved better than was done on Phu Quoc, which in just a few short years seemed to turn completely into a playground for Chinese and Russian tourists.
On Phu Quoc they built a replacement airport that could handle long-haul flights. Is there any possibility that would happen on Con Dao? The islands are quite small and there doesn't appear to be much land available.
Antaras
Sun Jul 12, 2020 4:04 am
Well, the PQC airport is almost bigger than the whole Con Dao island :D
There are plans to extend the VCS runway (up to 2500m in length) to handle narrowbodies such as the A320/B737 families as well as rebuild the terminal to increase the capacity. But there is no plan to turn VCS into a international airport yet.
Edit signature
Antaras
Sun Jul 12, 2020 9:28 am
Days ago QH has summitted its flight schedule to the authorities for the service between VCS and mainland airports including DAD and HAN. Suprisingly no SGN yet.
@Diễn Đàn Hàng Không
How many airframes are needed for this?
Edit signature
VSMUT
Sun Jul 12, 2020 1:19 pm
Completely by chance I met a former class mate from flying school the other day. Turns out he is involved. It is indeed the E195, and they are wet-leased from a non-Vietnamese carrier.
Antaras
Sun Jul 12, 2020 2:07 pm
Of course there's no Vietnamese carrier operating the E195, so of course the lessor has to be "non-Vietnamese" :D
I also knew that QH would wet-lease the airframes for 6 months (short-term) and then dry-lease/acquire more airframes for long-term ops.
If QH order the aircraft right now with Embraer, any chance for the aircraft would be delivered in the next 6 months?
Edit signature
lightsaber
Sun Jul 12, 2020 3:18 pm
Embraer has NTU Azul E2-195s available. If buying new, why settle for prior generation?
Antaras
Sun Jul 12, 2020 4:22 pm
lightsaber wrote:
I think so. Ntu airframes are QH's favor.
- Its 789s are Hainan's ntu
- One if uts A321neo is Primera ntu
Now: Azul and other carriers E195-E2 ntus?
Edit signature
jsnww81
Sun Jul 12, 2020 6:11 pm
Interesting to hear - would this require reclaiming land from the ocean? It looks like the VCS runway is pretty hemmed in by the coast on both sides.
Thanks for this information - I find the evolution of domestic aviation in Vietnam really interesting, and it's hard to find information on it without being a Vietnamese speaker (although Google Translate has been really helpful!)
EMBSPBR
Sun Jul 12, 2020 6:15 pm
lightsaber wrote:
Embraer has NTU Azul E2 available.
No, we don’t ...
lightsaber
Mon Jul 13, 2020 1:05 am
EMBSPBR wrote:
No, we don’t ...
Azul took up their E2-195s! That is great news!
Lightsaber
EMBSPBR
Mon Jul 13, 2020 1:23 am
lightsaber wrote:
EMBSPBR wrote:
No, we don’t ...
Lightsaber
I either didn't understand you or you didn't understand me.
As far as I know NTU means "no take unit".
There is no aircraft in production for Azul that was not assigned to it.
Of the 75 planes ordered, 59 had their delivery postponed until 2023.
To date, Azul has received 6 E-195-E2 with three more to be delivered by the end of this year.
The other deliveries scheduled for this year and postponed did not go into production.
Antaras
Mon Jul 13, 2020 6:33 am
EMBSPBR wrote:
lightsaber wrote:
EMBSPBR wrote:
No, we don’t ...
Lightsaber
Any chance for QH to fill in those production slots as if it actually orders the aircraft?
Edit signature
Antaras
Mon Jul 13, 2020 10:27 am
In-house information say that CAAV approved Bamboo to operate HAN-VCS and DAD-VCS from August, using wet-lease aircraft.
Edit signature
lightsaber
Mon Jul 13, 2020 11:46 am
EMBSPBR wrote:
lightsaber wrote:
EMBSPBR wrote:
No, we don’t ...
Lightsaber
If Azul is accepting the deliveries this year, than I am mistaken. We are talking the same planes. From prior reports, Azul was restructuring and unable to accept deliveries. (NTU or "Not taken up", of in production planes). You post implies that has reversed, that is great news.
As to Bamboo, if they want CF-34 powered aircraft, they are available 2nd hand.
I would like to know how Embraer could efficiently reschedule the 7 postponed Helvetic deliveries that were pushed from this year to next year. All long lead time items (engines, landing gear, avionics) would have most of their cost already spent.
https://www.ch-aviation.com/portal/news/92736
Lightsaber
PlymSpotter
Mon Jul 13, 2020 1:13 pm
An extension is completely unnecessary, unless you want to operate flights well over 1,000nm.
The A320 / B737 can already operate short haul sectors from the length currently provided. In fact, the A319 / A320 has better runway performance than the E195 - if they were concerned about this area then I'd have expected them to select the E190 instead. If pavement strength is an issue, it will require addressing separately.
Antaras
Mon Jul 13, 2020 2:48 pm
The gov wants to upgrade VCS into rate 4C (currently 3C). One of the solution is to upgrade the runway?
Edit signature
SA280
Mon Jul 13, 2020 9:51 pm
The issue is not runway length or performance. It's PCN.
PlymSpotter
Mon Jul 13, 2020 10:08 pm
Well, as Code 4 runways begin at 1,800m, a runway extension is the only solution to this 'problem'.
Practically though, the government will find that a key difference between Code 3 and Code 4 design standards is that risk assessors take a much dimmer view of Code 4 runways with non standard safety areas. So sticking their nose into Code 4 territory is potentially going to require them to create another 480m of land before a single extra meter of runway is gained. It makes very little sense to me.
Antaras
Tue Jul 14, 2020 7:03 am
Base on ACV's data: PCN 20/F/B/W/T
Edit signature
PlymSpotter
Tue Jul 14, 2020 12:28 pm
Well, I've seen worse. It is still pretty low mind.
If the guidelines are to be respected (I know, potentially a big if), that PCN will give the E195 a maximum weight of just under 42,000kg. With an OEW of 28,700kg, that provides around 13,000kg headroom. Factor crew and ballpark fuel burn of 2000kg / hour (plus 45 min reserves), that would leave DAD with around 9,000kg of payload and HAN with 7,500kg. With 116 seats and 100% LF, that would give you a Pax+Bag allowance of 77.5kg for DAD and 64.5kg for HAN, or with 124 seats the Pax+Bag allowance would be 72.5kg and 60.5kg respectively.
It's reasonably tight in my book, but doable considering the local demographic.
This also leads me to wonder if the wet lease operator would consider recertifying the aircraft as the lighter 195 STD, which shaves 2,000kg off the LR and 3,500kg of the AR's MTOW. That approach would still give you almost 7,000kg more weight than VCS can handle and reduce variable costs.
