rmoore7734
Single pilot jets with enough range to Hawaii
Wed Jul 15, 2020 4:58 pm
Looks like the SJ30x (2,500 nm range) could do the job based on interactive range map https://www.syberjet.com/tools/range-map from ACV airport for example.
The SJ30x is still in development at this time.
Question, could the highly modified Citation S/II with the Williams FJ44 engine & auxiliary fuel tank with winglets get the job done as well or any other existing SP jet ?
Here is a picture of the beast here https://www.airliners.net/photo/Untitle ... II/1299889
zuckie13
Re: Single pilot jets with enough range to Hawaii
Wed Jul 15, 2020 5:05 pm
The problem is with a couple of their assumptions here:
"Zero wind and ISA temperatures are assumed" - good luck getting zero wind - you'll likely have a head wind getting out there.
"Extended over water flights may require additional equipment that may reduce the range of the aircraft." - in other words - if you have what you need to fly from mainland to Hawaii, you wont' make it to Hawaii - not to mention probably the extra fuel you will need above their assumptions.
Probably going to be a close but not quite kind of scenario - especially if you are carrying passengers.
lightsaber
Wed Jul 15, 2020 5:06 pm
Unfortunately, with required diversion margins, a bit more range us required.
Lightsaber
Flu+Covid19 is bad. Consider a flu vaccine, if not for yourself, to protect someone you care about.
rmoore7734
Wed Jul 15, 2020 6:30 pm
lightsaber wrote:
Unfortunately, with required diversion margins, a bit more range is required.
Lightsaber
Thx for reply, any idea of bare minimum range requirements for diversion margins ?
barney captain
To give yourself a fighting chance, you would need to depart from somewhere closer than ACV......OAK for example.
Southeast Of Disorder
rmoore7734
Wed Jul 15, 2020 6:34 pm
Looks like difference is 10 miles acv to Ito 2,335 mi vs 2325 from oak.
32andBelow
Wed Jul 15, 2020 6:47 pm
Cold bay. Or adak
GalaxyFlyer
Wed Jul 15, 2020 6:55 pm
You’ll also have to factor in fuel for ETP diversions at an acceptable flight level depressurised. The best answer is to choose F100. Or, pack on a lot of extra oxygen to divert at something like F240 or below. Doubtful any early Citation could do it. You’d need to be able to fly about 1200nm plus reserves from the mid-point at F100. Its fairly common to have a -90 knot wind factor, too.
barney captain
Wed Jul 15, 2020 6:58 pm
Ah, my bad, I interpreted ACV as VCV......need more coffee.
rmoore7734
Wed Jul 15, 2020 7:00 pm
Cold bay. Or adak
Adak to lih is 1964 nm or 2261 Miles
Cold bay to lih Is 2001 nm or 2302.71 miles
I picked Lihue because it would be closest to Hawaii.
Perhaps headwinds could be avoided going this route with adak coming in closest.
rmoore7734
Wed Jul 15, 2020 7:22 pm
I did happen upon this https://www.guardianjet.com/hal/userfil ... 11_SII.pdf
On page 3 for this super s/II it says unique 2700 nm range perhaps this could do it say with no passengers ?
Max Q
Wed Jul 15, 2020 7:56 pm
Just barely making it is not a plan..
GGg
rmoore7734
Wed Jul 15, 2020 8:03 pm
Understand but this one looks like it does not have winglets and if it did perhaps another 100 plus nm could be achieved. Medivac Learjet 36a have 2800 nm range and I heard they do California to Hawaii runs sometimes
GalaxyFlyer
Wed Jul 15, 2020 9:40 pm
Perhaps, but I’d like to see how big a “wet” footprint they have. Even a 3,100nm CL300 has days where it’s challenged to not have a wet footprint without raising the divert level to F130.
Today, a F400/430 plan has -18 winds (AD ACV-PHTO is 2417) and essentially zero component on a F100, so possible. Wouldn’t plan on it.
rmoore7734
Wed Jul 15, 2020 10:53 pm
:lol:
GalaxyFlyer wrote:
[quote="rmoore7734"
Thanks, wish I understood the “technicals” as well as you but if the super s-II was flown single-pilot you could strap a nice size oxygen tank in the empty co-pilot seat in event of depressurization lol.
FlyingElvii
Thu Jul 16, 2020 5:48 am
Ask the Cirrus Driver in the widespread BRS parachute video about that. And he had a bladder added.
FlyingElvii
Thu Jul 16, 2020 5:50 am
rmoore7734 wrote:
:lol:
GalaxyFlyer wrote:
[quote="rmoore7734"
Pack the seats away, Send them via FedEx, and add a couple of bladders.
GalaxyFlyer
Thu Jul 16, 2020 3:07 pm
pp
rmoore7734 wrote:
:lol:
GalaxyFlyer wrote:
[quote="rmoore7734"
So, how about any pax?
rmoore7734
Thu Jul 16, 2020 4:06 pm
GalaxyFlyer wrote:
[s]pp[/s [quote="GalaxyFlyer"
[/quote][/quote]
I was thinking pilot only like your own personal jet not hauling anyone else.
nws2002
Thu Jul 16, 2020 4:21 pm
A Lear 36 will barely (just barely and highly dependent on configuration and specific aircraft weights) make it if you lose an engine or have a pressurization issue at the equal time point (ETP). Remember there are zero diversion points between the mainland and Hawaii, so if something happens you have to be able to turn around and come back or continue on. It is way more than just being able to carry enough fuel to make it across.
sixtyseven
Thu Jul 16, 2020 4:30 pm
Do these jets fall under ETOPS requirements? And can you do single pilot ETOPS?
Stand-by for new ATIS message......
Braniff747SP
Thu Jul 16, 2020 4:34 pm
To the best of my knowledge, ETOPS only applies to 121 ops. The rule doesn't apply to private jets.
The 747 will always be the TRUE queen of the skies!
32andBelow
Thu Jul 16, 2020 4:35 pm
You do wonder how wise such a flight would be. A single pilot have a medical event might have a chance with a quick diversion but 5 hours over the ocean would be tough.
Varsity1
Thu Jul 16, 2020 5:23 pm
ETOPS applies to 135 as well.
The sovereign is the smallest "realistic" Hawaii airplane. Some weird stuff might squeeze out there on perfect days, but the 680 is widely regarded as the smallest practical. It has a still air range of 3200nm.
The biggest issue is a depressurization at the ETP. Descend to 10,000ft and make land.
"PPRuNe will no longer allow discussions regarding Etihad Airlines, its employees, executives, agents, or other representatives. Such threads will be deleted." - ME3 thug airlines suing anyone who brings negative information public..
PA110
Thu Jul 16, 2020 6:10 pm
That might work for the return journey, but Mainland USA to Hawaii is usually bucking headwinds. In the winter time, significant enough to weight-restrict commercial some flights.
Look, it's been swell, but the swelling's gone down.
rmoore7734
[/quote]
Looks like a citation latitude with 2850 nm range with 5 passengers & 2 pilots did a California to Hawaii run in 2015
https://txtav.com/en/newsroom/2015/07/c ... al-flights
rmoore7734
Thu Jul 16, 2020 6:29 pm
When I play with range map For the latitude with same 5 pax 2 pilots you get 2650 nm
https://txtav.com/en/range-map
Varsity1
Thu Jul 16, 2020 6:47 pm
https://txtav.com/en/newsroom/2015/07/c ... al-flights[/quote]
Like I said, sometimes smaller stuff will squeeze out there. I have heard of CJ-3's ferried out there from Socal before. The 680 can do it practically, though still limited or unable on the worst days.
rmoore7734
Thu Jul 16, 2020 6:53 pm
Yes and it was flown in July before winter headwind season
sixtyseven
Sat Jul 18, 2020 12:01 am
So you can do single pilot ETOPS? Crazy to me.
GalaxyFlyer
Sat Jul 18, 2020 12:09 am
No, you can’t. ETOPS is a air carrier rule, doesn’t apply to private operators and no air carrier operates single pilot, by regulation. Single-engine Cessnas are ferried across oceans and they’re not ETOPS. If you own a single-pilot certified CJ-3, weather is good, go for Hilo, but you’re ETOPS, by definition. There are several larger bizjets owner-operated, husband and wife teams that fly all over the world, again not ETOPS. Military doesn’t use ETOPS, either. Lastly, Part 135 ETOPS starts with operations beyond 180 minutes from suitable diversion airports, so the vast majority of bizjet overwater legs aren’t ETOPS, either.
Don’t confuse ETOPS with overwater planning and using ETPs to fuel plan for diverts under various emergencies. Two different things.
26point2
Sat Jul 18, 2020 2:09 am
This is a ridiculous idea and debating it, winglets or not, Is only an academic exercise at best.
Is the SJ30 even certified? Regardless, all the reasons this is a terrible idea have been mentioned. Wet footprint, contingency planning. FANS 1A equip requirements, etc.
I’ve seen the Air Ambulance Lear 36 in PHNL a few times In years past. They usually would come from VNY by way of Adak, AK to avoid the wind. Not sure how they made a profit running that route regularly. I haven’t seen that plane in Hawaii for over 15 years so they might have wised up and now use a Hawker? ....slightly better but not by much.
There are small fleets of Honda Jets and PC-12s based in Hawaii. They only fly inter island and not to the mainland. Obviously they made it but certainly with bladder tanks.
bomber996
Sat Jul 18, 2020 3:31 am
He had a mechanical malfunction and wasn't able to get fuel from to be fed from his auxiliary tanks. He knew a few hours before he ran out that he was going to run dry. He was an experienced ferry pilot, not just some Yahoo. He did it right, his equipment failed him. Dude works at one of the majors in the US now.
Peace :box:
"We've recently upped our standards, so up yours." - Federal Aviation Administration
rmoore7734
Sat Jul 18, 2020 11:03 am
[quote="GalaxyFlyer"]No, you can’t. ETOPS is a air carrier rule, doesn’t apply to private operators and no air carrier operates single pilot, by regulation. Single-engine Cessnas are ferried across oceans and they’re not ETOPS. If you own a single-pilot certified CJ-3, weather is good, go for Hilo.
Wow if you use a cj-3+ you would definitely have to pull out passenger seats and put in a bladder tank.
2040 nm range without It
https://cessna.txtav.com/en/citation/cj3
rmoore7734
Sat Jul 18, 2020 11:15 am
[quote="26point2"]
Another reason to use adak, you have midway island as an emergency diversion airport going down to Hawaii via Adak.
GalaxyFlyer
Sat Jul 18, 2020 1:51 pm
As was posted above, they’ve been ferried out there, how I can’t say. Having been in the business close-up, don’t take much stock in websites or brochures.
DiamondFlyer
Sat Jul 18, 2020 2:01 pm
SJ-30 has been certified since 2005, there's around 8 that have been built.
From my cold, dead hands
goboeing
Sat Jul 18, 2020 3:04 pm
Not only would I not want to be the single pilot of an airplane that is going to fly for six hours, and have to sit in discomfort for far too long and ration water intake . . . but I would not want to be a passenger on an airplane where there was only one pilot up front for six hours doing so.
GalaxyFlyer
Sat Jul 18, 2020 3:18 pm
Ferry pilots do it all the time—it’s about 18 hours to HNL in Cessna 206 and maybe 12-13 in a light twin
goboeing
Sun Jul 19, 2020 12:29 am
They sure do, but that is not a routine operation for anyone except them.
They do that for the purposes of repositioning an airplane across a body of water that it does not even have the capability to cross until it is reconfigured with extra fuel tanks.
Experienced ferry pilots are also a niche and don't fly 6-18 hour flights day in and day out. They airline into Point A, ferry the airplane to Point B, and airline home.
The thread starter points to airplanes that would be designed to do 6 hours in normal operations -- making ferry pilots a different discussion entirely.
