enilria
OAG Changes for 7/21/2020:AUGUST SINKING;EK Drops EWR-DXB; DL Drops MLI-MSP; Big Cuts for DL/NK
Tue Jul 21, 2020 4:15 pm
FAQ
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
2D GEO-JFK AUG 0.5>0.3[0] SEP 0.1>0.3[0]
3M ELH-FLL AUG 1.1>0.7[2] SEP 1.2>0.8[1.8]
3M FLL-GGT AUG 0.6>0.4[1.7] SEP 0.8>0.5[1.1]
3M FLL-TLH AUG 0.7>0.4[1.2] SEP 0.7>0.4[1.6]
4B PHX-SOW AUG 2>3[3] SEP 0>1.0[3] OCT 0>0.7[3]
9K BNA-MWA AUG 1.7>0[0] SEP 1.8>0[0] OCT 1.6>0[0] NOV 1.8>0[0] DEC 1.7>0[0] JAN 1.5>0[0.2] FEB 1.9>0[1.7] MAR 1.7>0[1.7] APR 1.7>0[1.7]
9K BNA-OWB AUG 1.9>0[0] SEP 2>0[0] OCT 1.9>0[0] NOV 2>0[0] DEC 2>0[0] JAN 1.8>0[0.6] FEB 2>0[2] MAR 1.9>0[2] APR 2>0[2]
9K BOS-RUT AUG 3>0[3] SEP 3>0[3] OCT 3>0[3] NOV 3>0[3] DEC 3>0[3] JAN 3>0[3] FEB 3>0[3] MAR 3>0[3] APR 3>0[3]
9K MWA-STL AUG 3>0[5] SEP 4>0[5] OCT 3>0[5] NOV 4>0[5] DEC 3>0[5] JAN 3>0[5] FEB 4>0[3] MAR 3>0[3] APR 4>0[4]
9K ORD-UIN AUG 3>0[0] SEP 3>0[0] OCT 2>0[0] NOV 3>0[0] DEC 3>0[0] JAN 2>0[2] FEB 3>0[3] MAR 3>0[3] APR 3>0[3]
9K OWB-STL AUG 1.0>0[3] SEP 1.0>0[3] OCT 1.0>0[3] NOV 1.0>0[3] DEC 1.0>0[3] JAN 0.9>0[2] FEB 1.1>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[1.0]
9K STL-UIN AUG 3>0[0] SEP 3>0[0] OCT 3>0[0] NOV 3>0[0] DEC 3>0[0] JAN 2>0[2] FEB 3>0[3] MAR 3>0[3] APR 3>0[3]
9R BOG-HAY AUG 0>0.3[0] SEP 0>0.3[0] OCT 0>0.3[0] NOV 0>0.3[0] DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0] APR 0>0.3[0]
AA BGI-MIA AUG 1.0>0.7[3]
AA DFW-FAI APR 0.9>0[0]
AA DFW-FSD AUG 1.9>3[2]
AA DFW-GSO OCT 4>3[3] NOV 4>3[3] DEC 4>3[2] JAN 4>3[1.9] FEB 4>3[1.9]
AA DFW-MSO AUG 1.1>1.8[1.1]
AA GIG-MIA DEC 1.8>1.0[1.0] JAN 1.8>0.9[1.0] FEB 2>1.1[1.0]
AA ORD-RAP SEP 0.2>0.7[1.0]
AA ORD-SJC AUG 2>0.6[2]
AA ORD-SMF AUG 0.8>0.5[1.0]
AC ATL-YYZ AUG 5>4[5]
AC AUS-YYZ AUG 1.8>1.4[1.8]
AC BNA-YYZ AUG 1.9>1.5[3]
AC BOS-YOW AUG 1.9>1.5[1.8]
AC BOS-YUL AUG 5>4[5]
AC BOS-YYZ AUG 7>5[7]
AC CLT-YYZ AUG 1.9>1.5[2]
AC DCA-YUL AUG 1.9>1.5[2]
AC DEN-YUL AUG 1.1>0.6[2]
AC DEN-YVR AUG 2>1.4[3]
AC DEN-YYZ AUG 1.9>1.5[3]
AC DFW-YUL AUG 1.0>0.7[1.0]
AC EWR-YOW AUG 3>2[3]
AC EWR-YVR AUG 1.9>1.5[1.0]
AC EWR-YYZ AUG 7>6[7]
AC FLL-YUL AUG 1.2>0.8[2]
AC FLL-YYZ AUG 1.1>0.7[2]
AC IAD-YUL AUG 1.0>0.7[2]
AC IAD-YYZ AUG 2>1.7[3]
AC IAH-YUL AUG 1.9>1.5[2]
AC LAS-YUL AUG 1.9>1.5[2]
AC LAS-YYC AUG 1.0>0.7[1.0]
AC LAX-YUL AUG 3>2[3]
AC LAX-YVR AUG 6>5[6]
AC LAX-YYZ AUG 5>4[6]
AC LGA-YUL AUG 8>6[8]
AC LGA-YYZ AUG 12>10[12]
AC MCO-YUL AUG 1.8>1.1[3]
AC MCO-YYZ AUG 2>1.5[3]
AC ORD-YUL AUG 5>4[5]
AC ORD-YYZ AUG 8>6[8]
AC PHL-YYZ AUG 5>4[4]
AC PIT-YYZ AUG 4>3[4]
AC RDU-YYZ AUG 3>2[4]
AC SAN-YVR AUG 3>2[3]
AC SAN-YYZ AUG 1.0>0.7[1.0]
AC SEA-YYZ AUG 1.9>1.5[2]
AC SFO-YUL AUG 3>2[3]
AC SFO-YYC AUG 1.9>1.5[2]
AF MIA-PAP AUG 0.5>0[0.9]
AS ANC-RDB AUG 0.4>0[0.5] SEP 0.5>0[0.4] OCT 0.4>0[0.4] NOV 0.4>0[0.5] DEC 0.4>0[0.4] JAN 0.4>0[0.4] FEB 0.5>0[0.4] MAR 0.4>0[0.3] APR 0.5>0[0.4]
AS ANC-SCC AUG 3>1.7[1.9] SEP 3>1.4[2] OCT 2>1.3[3] NOV 3>1.4[2] DEC 2>1.3[2] JAN 2>1.2[3] FEB 3>1.5[2] MAR 2>1.3[2] APR 2>1.4[3]
Got to be a lot of permanent cuts to fund all these adds
*AS BZN-LAX NOV 0>0.5[0] DEC 0>0.5[0] JAN 0>0.5[0] FEB 0>0.6[0] MAR 0>0.5[0] APR 0>0.5[0]
*AS CUN-PDX NOV 0>0.5[0] DEC 0>0.4[0] JAN 0>0.4[0] FEB 0>0.5[0]
*AS CUN-SAN OCT 0>0.2[0] NOV 0>0.6[0] DEC 0>0.6[0] JAN 0>0.5[0] FEB 0>0.6[0] MAR 0>0.2[0]
*AS EUG-LAX SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>0.9[0] FEB 0>1.1[0] MAR 0>1.0[0] APR 0>1.0[0]
*AS FLL-PDX OCT 0>0.2[0] NOV 0>0.6[0] DEC 0>0.6[0] JAN 0>0.5[0] FEB 0>0.6[0] MAR 0>0.5[0] APR 0>0.6[0]
*AS FLL-SAN NOV 0>0.5[0] DEC 0>0.4[0] JAN 0>0.4[0] FEB 0>0.5[0] MAR 0>0.4[0] APR 0>0.4[0]
*AS KOA-LAX NOV 0>0.2[0] FEB 0>0.3[0] MAR 0>0.4[0] APR 0>0.4[0]
*AS LAX-LIH NOV 0>0.3[0] DEC 0>0.2[0] FEB 0>0.4[0] MAR 0>0.5[0] APR 0>0.6[0]
*AS LAX-MFR SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>0.9[0] FEB 0>1.1[0] MAR 0>1.0[0] APR 0>1.0[0]
*AS LAX-RSW OCT 0>0.2[0] NOV 0>0.6[0] DEC 0>0.6[0] JAN 0>0.5[0] FEB 0>0.6[0] MAR 0>0.2[0]
*AS LAX-TPA OCT 0>0.3[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>0.9[0] FEB 0>1.1[0] MAR 0>1.0[0] APR 0>1.0[0]
*AS MSO-SAN FEB 0>0.8[0] MAR 0>1.0[0] APR 0>1.0[0]
*AS MSO-SFO FEB 0>0.8[0] MAR 0>1.0[0] APR 0>1.0[0]
*AS MSO-SJC FEB 0>0.8[0] MAR 0>1.0[0] APR 0>1.0[0]
AS PIT-SEA SEP 0.6>1.0[1.0]
*AS RSW-SEA OCT 0>0.2[0] NOV 0>0.6[0] DEC 0>0.6[0] JAN 0>0.5[0] FEB 0>0.6[0] MAR 0>0.2[0]
*AS SFO-TPA NOV 0>0.3[0] DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0]
AY HEL-MIA OCT 0.3>0[0.1]
B5 MDR-WIL AUG 0>1.9[0] SEP 0>2[0] OCT 0>1.9[0] NOV 0>2[0] DEC 0>2[0] JAN 0>1.8[0] FEB 0>2[0] MAR 0>1.9[0] APR 0>2[0]
This is a schedule extension so I would compare to prior year. Also MAR is a partial month, so ignore.
B6 ABQ-JFK JAN 0.2>0.7[0.6] FEB 0>1.1[0.7] MAR 0>0.9[1.0]
B6 ALB-FLL JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 ALB-MCO JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 ANU-JFK JAN 0.2>0.4[0.5] FEB 0>0.5[0.4] MAR 0>0.4[0.5]
B6 ATL-BOS JAN 1.1>3[4] MAR 0>3[5]
B6 ATL-FLL JAN 0.5>1.4[3] FEB 0>1.7[2] MAR 0>1.4[2]
B6 ATL-JFK JAN 0.6>1.7[2] FEB 0>2[1.6] MAR 0>1.6[2]
B6 ATL-MCO JAN 0.2>0.6[1.0] FEB 0>0.8[1.0] MAR 0>0.6[1.0]
B6 AUA-BOS JAN 0.5>2[1.7] FEB 0>3[2] MAR 0>3[2]
B6 AUA-FLL JAN 0.2>0.5[0.7] MAR 0>0.5[0.6]
B6 AUA-JFK JAN 0.5>1.6[1.5] FEB 0>2[1.8] MAR 0>1.6[2]
B6 AUS-BOS JAN 0.9>2[1.7] FEB 0>3[1.8] MAR 0>2[1.9]
B6 AUS-EWR JAN 0.6>1.8[0] FEB 0>2[0] MAR 0>1.7[0]
B6 AUS-FLL JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.4]
B6 AUS-JFK JAN 0.5>1.4[1.9] FEB 0>1.7[1.9] MAR 0>1.4[2]
B6 AUS-LAX JAN 0.3>0.9[0] FEB 0>1.1[0] MAR 0>0.9[0]
B6 AUS-MCO JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 BDL-FLL JAN 0.6>1.8[1.9] FEB 0>2[1.9] MAR 0>1.7[2]
B6 BDL-MCO JAN 0.6>2[2] MAR 0>2[3]
B6 BDL-PBI JAN 0.3>1.5[1.7] MAR 0>1.7[2]
B6 BDL-RSW JAN 0.3>0.9[1.7] FEB 0>1.1[2.0] MAR 0>0.9[1.0]
B6 BDL-SJU JAN 0.6>1.8[1.9] FEB 0>2.2[1.9] MAR 0>1.7[2.0]
B6 BDL-TPA JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 BGI-JFK JAN 0.5>1.8[1.9] MAR 0>1.9[2]
B6 BNA-BOS JAN 0.5>1.6[1.4] FEB 0>2[1.6] MAR 0>1.7[2]
B6 BNA-FLL JAN 0.3>0.9[1.0] FEB 0>1.1[1.2] MAR 0>0.9[1.0]
B6 BNA-JFK JAN 0.5>1.4[0] FEB 0>1.7[0] MAR 0>1.4[0]
B6 BOG-FLL JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 BOS-BUF JAN 0.9>3[3] FEB 0>4[3] MAR 0>3[4]
B6 BOS-BUR JAN 0.3>0.9[0.7] FEB 0>1.1[0.9] MAR 0>0.9[1.0]
B6 BOS-BWI JAN 1.4>4[4] FEB 0>5[4] MAR 0>4[5]
B6 BOS-CHS JAN 0.3>1.4[1.1] FEB 0>1.9[2.0] MAR 0>1.5[2]
B6 BOS-CLE JAN 1.1>3[3] FEB 0>4[2] MAR 0>3[4]
B6 BOS-DCA JAN 5>13[13] FEB 0>15[13] MAR 0>12[13]
B6 BOS-DEN JAN 0.6>1.7[1.7] FEB 0>2[1.8] MAR 0>1.6[1.9]
B6 BOS-DFW JAN 0.9>2[1.6] FEB 0>3[1.4] MAR 0>2[1.7]
B6 BOS-FLL JAN 1.6>5[6] MAR 0>4[6]
B6 BOS-GCM MAR 0>0.2[0.3]
B6 BOS-IAH JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 BOS-JAX JAN 0.6>1.7[2] FEB 0>2[1.9] MAR 0>1.6[2]
B6 BOS-JFK JAN 1.9>6[5] FEB 0>8[5] MAR 0>6[7]
B6 BOS-LAS JAN 1.2>4[4] FEB 0>4[3] MAR 0>3[4]
B6 BOS-LAX JAN 1.3>3[4] MAR 0>3[4]
B6 BOS-LGA JAN 3>8[5] FEB 0>10[5] MAR 0>8[5]
B6 BOS-LIR MAR 0>0.2[0.3]
B6 BOS-MCO JAN 2>7[6] FEB 0>9[8] MAR 0>7[8]
B6 BOS-MSP JAN 0.6>1.7[3] MAR 0>1.6[3]
B6 BOS-MSY JAN 0.5>1.6[1.6] FEB 0>2[1.9] MAR 0>1.7[2]
B6 BOS-NAS JAN 0.0>0.5[0.4] FEB 0>0.9[1.3] MAR 0>0.7[1.8]
B6 BOS-PBI JAN 1.5>5[5] FEB 0>7[6] MAR 0>6[7]
B6 BOS-PHL JAN 2>6[7] FEB 0>8[6] MAR 0>6[7]
B6 BOS-PHX JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 BOS-PIT JAN 1.4>4[5] FEB 0>5[4] MAR 0>4[5]
B6 BOS-PLS JAN 0.0>0.3[0.1] FEB 0>0.5[0.4] MAR 0>0.4[0.5]
B6 BOS-PUJ JAN 0.1>0.5[0.3] FEB 0>0.8[0.3] MAR 0>0.6[0.4]
B6 BOS-RDU JAN 1.5>4[5] FEB 0>5[4] MAR 0>4[5]
B6 BOS-RIC JAN 1.1>3[3] MAR 0>3[4]
B6 BOS-ROC JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 BOS-RSW JAN 1.6>6[5] FEB 0>8[7] MAR 0>6[7]
B6 BOS-SAN JAN 0.9>3[3] FEB 0>3[2] MAR 0>2[2.0]
B6 BOS-SAV JAN 0.5>2[1.2] FEB 0>3[1.9] MAR 0>2[1.9]
B6 BOS-SDQ JAN 0.4>1.2[1.9] FEB 0>1.4[1.1] MAR 0>1.1[1.0]
B6 BOS-SEA JAN 0.6>1.7[1.9] FEB 0>2[1.8] MAR 0>1.6[1.9]
B6 BOS-SFO JAN 1.5>4[5] MAR 0>4[5]
B6 BOS-SJU JAN 1.0>2.8[3.6] FEB 0>3.5[3.1] MAR 0>2.7[3.3]
B6 BOS-SLC JAN 0.2>0.7[0.8] FEB 0>1.1[0.9] MAR 0>0.9[1.0]
B6 BOS-SRQ JAN 0.3>1.5[1.0] FEB 0>2[1.6] MAR 0>1.7[1.5]
B6 BOS-STI JAN 0.5>1.4[1.1] FEB 0>1.7[1.0] MAR 0>1.4[1.0]
B6 BOS-STT JAN 0.0>0.6[0.1] FEB 0>1.1[0.8] MAR 0>0.9[1.0]
B6 BOS-SXM JAN 0.0>0.4[0.1] FEB 0>0.5[0.3] MAR 0>0.5[0.4]
B6 BOS-SYR JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 BOS-TPA JAN 1.2>4[4] MAR 0>5[6]
B6 BOS-UVF JAN 0.0>0.2[0.1] FEB 0>0.3[0.2] MAR 0>0.3[0.2]
B6 BQN-JFK JAN 0.3>0.9[1.5] FEB 0>1.1[1.6] MAR 0>0.9[1.4]
B6 BQN-MCO JAN 0.3>0.9[1.5] MAR 0>0.9[1.0]
B6 BUF-FLL JAN 0.2>0.8[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 BUF-JFK JAN 1.6>5[5] FEB 0>6[4] MAR 0>4[5]
B6 BUF-LAX JAN 0.2>0.5[0.6] FEB 0>0.6[0.7] MAR 0>0.5[0.7]
B6 BUF-MCO JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 BUR-JFK JAN 0.6>1.7[1.6] FEB 0>2[1.7] MAR 0>1.6[1.7]
B6 BZN-LAX JAN 0.1>0.4[0] FEB 0>0.5[0] MAR 0>0.4[0]
B6 CHS-EWR JAN 0.3>0.9[0] FEB 0>1.1[0] MAR 0>0.9[0]
B6 CHS-FLL JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 CHS-JFK JAN 0.6>1.8[2.0] FEB 0>2[2.0] MAR 0>1.7[3]
B6 CLE-FLL JAN 0.1>0.7[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 CLE-RSW JAN 0.3>0.9[0] FEB 0>1.1[0] MAR 0>0.9[0]
B6 CTG-FLL JAN 0.2>0.5[0.7] MAR 0>0.5[0.6]
B6 CTG-JFK JAN 0.3>0.9[1.0] FEB 0>1.1[0.8] MAR 0>0.9[0.5]
B6 CUN-FLL JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 CUN-JFK JAN 0.7>2[1.4] FEB 0>3[1.7] MAR 0>2[2.0]
B6 CUN-MCO JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 CUR-JFK FEB 0>0.3[0.4] MAR 0>0.2[0.4]
B6 DCA-FLL JAN 1.9>5[6] FEB 0>7[6] MAR 0>5[6]
B6 DCA-MCO JAN 1.3>4[4] MAR 0>3[4]
B6 DCA-PBI JAN 0.6>1.8[1.9] FEB 0>2[1.9] MAR 0>1.7[1.9]
B6 DCA-RSW JAN 0.3>1.9[2] MAR 0>2[3]
B6 DCA-SJU JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 DCA-TPA JAN 0.3>0.9[0] FEB 0>1.1[0] MAR 0>0.9[0]
B6 DEN-JFK JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 DFW-JFK JAN 0.6>1.8[0] FEB 0>2[0] MAR 0>1.7[0]
B6 DTW-JFK JAN 0.6>1.8[0] FEB 0>2[0] MAR 0>1.7[0]
B6 EWR-JAX JAN 0.3>0.9[0] FEB 0>1.1[0] MAR 0>0.9[0]
B6 EWR-LAS JAN 0.6>1.8[0] FEB 0>2[0] MAR 0>1.7[0]
B6 EWR-LAX JAN 1.6>4[0] FEB 0>5[0] MAR 0>4[0]
B6 EWR-MCO JAN 1.9>5[7] FEB 0>7[6] MAR 0>5[6]
B6 EWR-PBI JAN 1.3>3[3] MAR 0>3[4]
B6 EWR-PHX JAN 0.6>1.8[0] FEB 0>2[0] MAR 0>1.7[0]
B6 EWR-RSW JAN 0.5>2[1.9] MAR 0>2[3]
B6 EWR-SAN JAN 0.3>0.9[0] FEB 0>1.1[0] MAR 0>0.9[0]
B6 EWR-SDQ AUG 1.0>1.2[1.0] JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 EWR-SFO JAN 0.6>1.8[0] FEB 0>2[0] MAR 0>1.7[0]
B6 EWR-SJU JAN 0.6>2.1[2.3] MAR 0>2.1[2.5]
B6 EWR-SRQ JAN 0.3>0.9[0] FEB 0>1.1[0] MAR 0>0.9[0]
B6 EWR-STI JAN 0.3>1.4[1.9] MAR 0>1.5[2.0]
B6 EWR-TPA JAN 0.5>2[2] MAR 0>2[3]
B6 FLL-GCM JAN 0.1>0.6[0.6] FEB 0>1.1[0.8] MAR 0>0.8[1.0]
B6 FLL-GYE JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 FLL-HAV JAN 0.9>2[3] MAR 0>2[3]
B6 FLL-HPN JAN 0.6>1.8[2] FEB 0>2[2.0] MAR 0>1.7[2]
B6 FLL-JFK JAN 3>8[8] FEB 0>10[8] MAR 0>8[9]
B6 FLL-KIN JAN 0.3>1.5[2] FEB 0>2[1.8] MAR 0>1.7[2]
B6 FLL-LAS JAN 0.6>1.8[1.6] FEB 0>2[1.4] MAR 0>1.7[1.1]
B6 FLL-LAX JAN 1.6>5[4] FEB 0>6[3] MAR 0>4[3]
B6 FLL-LGA JAN 0.6>1.8[4] FEB 0>2[4] MAR 0>1.7[4]
B6 FLL-LIM JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 FLL-MBJ JAN 0.3>0.9[1.3] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 FLL-MDE JAN 0.2>0.6[0.9] FEB 0>0.8[0.7] MAR 0>0.6[0.5]
B6 FLL-MSY JAN 0.3>0.9[1.0] FEB 0>1.1[1.4] MAR 0>0.9[1.1]
B6 FLL-ORD JAN 0.2>0.8[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 FLL-ORH JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 FLL-PAP JAN 0.3>1.3[1.3] FEB 0>1.7[1.6] MAR 0>1.4[1.6]
B6 FLL-PDX JAN 0.1>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0]
B6 FLL-PHL JAN 0.3>1.4[1.8] MAR 0>1.5[2]
B6 FLL-PHX JAN 0.2>0.6[1.0] FEB 0>0.8[1.0] MAR 0>0.6[1.0]
B6 FLL-PIT JAN 0.3>0.9[0] FEB 0>1.1[0] MAR 0>0.9[0]
B6 FLL-PLS JAN 0.1>0.7[0.7] FEB 0>1.1[0.8] MAR 0>0.9[1.0]
B6 FLL-POS JAN 0.1>0.4[0.5] FEB 0>0.5[0.7] MAR 0>0.4[0.5]
B6 FLL-PVD JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 FLL-RDU JAN 0.5>1.7[2] MAR 0>1.7[2]
B6 FLL-RIC JAN 0.3>1.5[2] MAR 0>1.7[2]
B6 FLL-SAN JAN 0.2>0.7[0.6] FEB 0>1.1[0.8] MAR 0>0.9[1.0]
B6 FLL-SDQ JAN 0.1>0.7[1.0] FEB 0>1.1[0.8] MAR 0>0.9[1.0]
B6 FLL-SEA JAN 0.2>0.4[0] FEB 0>0.5[0] MAR 0>0.4[0]
B6 FLL-SFO JAN 1.0>3[2] FEB 0>3[2] MAR 0>3[2]
B6 FLL-SJO JAN 0.2>0.6[1.0] FEB 0>0.8[1.0] MAR 0>0.6[1.0]
B6 FLL-SJU JAN 1.3>3.6[5] MAR 0>3.5[4]
B6 FLL-SLC JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 FLL-SWF JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 FLL-UIO JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 GCM-JFK JAN 0.3>1.0[1.0] FEB 0>1.4[1.0] MAR 0>1.1[1.0]
B6 GND-JFK JAN 0.3>0.9[0.9] FEB 0>1.1[0.9] MAR 0>0.9[0.7]
B6 GYE-JFK JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 HPN-PBI JAN 1.3>4[5] FEB 0>4[5] MAR 0>3[5]
B6 HPN-RSW JAN 0.3>1.5[1.7] MAR 0>1.7[2]
B6 HPN-TPA JAN 0.6>1.8[1.0] FEB 0>2[1.0] MAR 0>1.7[1.0]
B6 IAH-JFK JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 JFK-KIN JAN 0.6>1.8[3] FEB 0>2[3] MAR 0>1.7[3]
B6 JFK-LAX JAN 3>9[9] FEB 0>11[10] MAR 0>8[10]
B6 JFK-LIR JAN 0.1>0.5[0.8] MAR 0>0.6[0.7]
B6 JFK-MBJ JAN 0.3>2[2] FEB 0>3[1.6] MAR 0>3[2]
B6 JFK-MCO JAN 2>8[7] FEB 0>10[9] MAR 0>8[9]
B6 JFK-MSP JAN 0.6>1.8[0] FEB 0>2[0] MAR 0>1.7[0]
B6 JFK-MSY JAN 0.3>1.5[1.1] MAR 0>1.7[2]
B6 JFK-ONT JAN 0.2>0.5[0.7] FEB 0>0.6[0.8] MAR 0>0.5[0.9]
B6 JFK-ORD JAN 0.6>1.7[1.8] FEB 0>2[2.0] MAR 0>1.6[2.0]
B6 JFK-ORH JAN 0.1>0.7[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 JFK-PAP JAN 0.3>0.9[1.3] FEB 0>1.1[1.3] MAR 0>0.9[1.4]
B6 JFK-PBI JAN 1.5>4[5] MAR 0>4[5]
B6 JFK-PDX JAN 0.2>0.5[0.7] MAR 0>0.5[0.8]
B6 JFK-PHX JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 JFK-PLS JAN 0.3>0.9[1.0] MAR 0>0.9[1.0]
B6 JFK-POP JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 JFK-POS JAN 0.3>0.9[1.2] FEB 0>1.1[1.6] MAR 0>0.9[1.2]
B6 JFK-PSE JAN 0.3>0.8[0.8] FEB 0>0.9[0.9] MAR 0>0.8[0.5]
B6 JFK-PSP JAN 0.2>0.6[0.8] MAR 0>0.6[0.8]
B6 JFK-PUJ JAN 0.3>1.5[1.0] FEB 0>2[1.0] MAR 0>1.7[1.2]
B6 JFK-RNO JAN 0.2>0.5[0.6] FEB 0>0.6[0.7] MAR 0>0.5[0.7]
B6 JFK-RSW JAN 0.6>4[2] FEB 0>6[4] MAR 0>4[6]
B6 JFK-SAN JAN 1.0>3[1.9] FEB 0>3[1.8] MAR 0>3[1.9]
B6 JFK-SAV JAN 0.6>1.8[2] FEB 0>2[2.0] MAR 0>1.7[2]
B6 JFK-SDQ JAN 1.5>4[6] FEB 0>5[4] MAR 0>4[5]
B6 JFK-SEA JAN 0.6>1.7[1.6] FEB 0>2[1.8] MAR 0>1.6[1.9]
B6 JFK-SJC JAN 0.2>0.5[0.7] FEB 0>0.6[0.7] MAR 0>0.5[0.7]
B6 JFK-SJO JAN 0.1>0.4[0.4] FEB 0>0.5[0.4] MAR 0>0.4[0.5]
B6 JFK-SJU JAN 1.7>5[6] MAR 0>5[5]
B6 JFK-SLC JAN 0.6>1.8[2.0] MAR 0>1.7[2]
B6 JFK-SMF JAN 0.2>0.5[0.8] FEB 0>0.6[0.9] MAR 0>0.5[1.0]
B6 JFK-SRQ JAN 0.3>0.9[1.0] FEB 0>1.1[1.6] MAR 0>0.9[1.9]
B6 JFK-SXM JAN 0.3>0.9[0.9] FEB 0>1.1[1.0] MAR 0>0.9[1.1]
B6 JFK-SYR JAN 0.6>1.8[2] MAR 0>1.7[2]
B6 JFK-TPA JAN 0.8>3[3] MAR 0>3[4]
B6 JFK-UVF JAN 0.4>1.0[1.0] FEB 0>1.3[1.0] MAR 0>1.0[1.1]
B6 LAS-LAX JAN 0.6>1.8[0] FEB 0>2[0] MAR 0>1.7[0]
B6 LAX-RNO JAN 0.3>0.9[0] FEB 0>1.1[0] MAR 0>0.9[0]
B6 LAX-SEA JAN 0.3>0.9[0] FEB 0>1.1[0] MAR 0>0.9[0]
B6 LAX-SFO JAN 0.6>1.8[0] FEB 0>2[0] MAR 0>1.7[0]
B6 LAX-SLC JAN 0.6>1.8[0] FEB 0>2[0] MAR 0>1.7[0]
B6 LGA-MCO JAN 0.6>1.8[3] FEB 0>2[3] MAR 0>1.7[3]
B6 LGA-PBI JAN 0.6>1.8[3] FEB 0>2[3] MAR 0>1.7[3]
B6 LGA-RSW JAN 0.3>0.9[0] FEB 0>1.1[0] MAR 0>0.9[0]
B6 LGA-TPA JAN 0.6>1.8[0] FEB 0>2[0] MAR 0>1.7[0]
B6 MBJ-MCO JAN 0.2>0.7[0.8] MAR 0>0.7[1.0]
B6 MCO-NAS JAN 0.2>0.6[0.8] MAR 0>0.6[0.7]
B6 MCO-ORH JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 MCO-PHL JAN 0.6>1.8[0] FEB 0>2[0] MAR 0>1.7[0]
B6 MCO-PSE JAN 0.3>0.9[1.4] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 MCO-PVD JAN 0.5>1.6[1.9] FEB 0>2[2.0] MAR 0>1.7[2]
B6 MCO-RIC JAN 0.6>1.8[1.6] MAR 0>1.7[2]
B6 MCO-SDQ JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 MCO-SFO JAN 0.3>0.9[0] FEB 0>1.1[0] MAR 0>0.9[0]
B6 MCO-SJO JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 MCO-SJU JAN 1.3>3.6[6] MAR 0>3.5[4.0]
B6 MCO-SLC JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 MCO-SWF JAN 0.3>0.8[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 MCO-SYR JAN 0.3>0.9[1.0] FEB 0>1.1[1.2] MAR 0>0.9[1.1]
B6 ORD-PBI JAN 0.3>0.9[0] FEB 0>1.1[0] MAR 0>0.9[0]
B6 PBI-PHL JAN 0.6>1.8[0] FEB 0>2[0] MAR 0>1.7[0]
B6 PBI-PIT JAN 0.3>0.9[0] FEB 0>1.1[0] MAR 0>0.9[0]
B6 PBI-PVD JAN 0.3>0.9[1.0] FEB 0>1.1[1.0] MAR 0>0.9[1.0]
B6 PHL-RSW JAN 0.3>0.9[0] FEB 0>1.1[0] MAR 0>0.9[0]
B6 PHL-SJU JAN 0.3>0.9[0] FEB 0>1.1[0] MAR 0>0.9[0]
B6 PHL-TPA JAN 0.3>0.9[0] FEB 0>1.1[0] MAR 0>0.9[0]
B6 PVD-RSW JAN 0.3>0.9[0] FEB 0>1.1[0] MAR 0>0.9[0]
B6 PVD-TPA JAN 0.3>0.9[0] FEB 0>1.1[0] MAR 0>0.9[0]
B6 SJU-TPA JAN 0.3>0.9[1.7] FEB 0>1.1[1.6] MAR 0>0.9[1.0]
BA JFK-LCY AUG 0.8>0[0.1] SEP 0.9>0.2[0.9]
CI HNL-TPE AUG 0.4>0[0.4] SEP 0.5>0.1[0.4]
CI ONT-TPE AUG 1.0>0[1.0] SEP 1.1>0.2[1.0]
CON ANC-UUK AUG 1.3>0[0] SEP 1.3>0[0] OCT 1.2>0[0] NOV 1.4>0[0] DEC 1.2>0[0] JAN 1.2>0[1.0] FEB 1.5>0[1.0] MAR 1.3>0[0.9] APR 1.3>0[1.3]
CZ CAN-JFK AUG 1.5>0[2] SEP 1.4>0.2[1.2]
CZ CAN-LAX AUG 1.0>0.1[1.0] SEP 1.0>0.3[1.0]
CZ CAN-SFO AUG 1.0>0[0.9] SEP 0.9>0.1[0.7]
CZ SFO-WUH AUG 0.4>0[0.5] SEP 0.5>0.1[0.4]
DI BOS-LGW NOV 0.8>0[1.0] DEC 0.8>0[1.0] JAN 0.6>0[0.8] FEB 0.7>0.1[0.9]
DI JFK-LGW NOV 2>0.8[3] DEC 3>1.0[3] JAN 2>0.9[2] FEB 2>1.1[2]
DI LAX-LGW NOV 1.0>0.5[1.1] JAN 0.8>0.4[0.9] FEB 1.0>0.6[0.9]
DI LGW-MCO NOV 0.6>0.4[0.7] FEB 0.9>0.5[0.6]
DI LGW-MIA NOV 0.8>0.3[0.9] DEC 0.8>0.4[1.0] JAN 0.7>0.4[0.8] FEB 1.0>0.5[0.8]
DI LGW-SFO NOV 0.4>0[0.6] DEC 0.5>0[0.6] JAN 0.4>0[0.6] FEB 0.6>0.1[0.6]
DI LGW-TPA NOV 0.3>0[0.3] DEC 0.4>0[0.4] JAN 0.3>0[0.4] FEB 0.3>0[0.3]
Huge cuts to August as mentioned in the analyst call
DL ABE-ATL AUG 2>0[3]
DL ABE-DTW AUG 3>1.9[3]
DL ABQ-ATL AUG 3>1.0[3]
DL ABQ-LAX AUG 3>1.2[3]
DL ABQ-MSP AUG 0.6>0[1.0]
DL ABY-ATL AUG 3>1.9[3]
DL AEX-ATL AUG 3>1.9[4]
DL AGS-ATL AUG 8>6[8]
DL ALB-ATL AUG 3>1.9[4]
DL ALB-MSP AUG 0.7>0[1.0]
DL ANC-SEA AUG 4>3[6]
DL ATL-ATW AUG 1.7>1.0[2.0]
DL ATL-AUA AUG 1.1>0.8[1.2]
DL ATL-AUS AUG 7>5[9]
DL ATL-AVL AUG 7>5[8]
DL ATL-BDL AUG 6>4[7]
DL ATL-BHM AUG 10>7[10]
DL ATL-BMI AUG 3>1.9[3]
DL ATL-BNA AUG 9>6[10]
DL ATL-BOS AUG 10>8[12]
DL ATL-BQK AUG 3>1.9[3]
DL ATL-BTR AUG 5>3[6]
DL ATL-BTV AUG 0.7>0[1.4]
DL ATL-BUF AUG 4>3[5]
DL ATL-BUR AUG 1.4>0[1.9]
DL ATL-BWI AUG 9>5[11]
DL ATL-BZE AUG 0.6>0.4[1.1]
DL ATL-CAE AUG 8>7[8]
DL ATL-CHA AUG 9>8[10]
DL ATL-CHO AUG 4>3[5]
DL ATL-CHS AUG 10>8[10]
DL ATL-CID AUG 2>0[3]
DL ATL-CLE AUG 7>6[8]
DL ATL-CLT AUG 9>7[9]
DL ATL-CMH AUG 7>6[8]
DL ATL-COS AUG 0.7>0[1.0]
DL ATL-CRW AUG 4>3[5]
DL ATL-DAB AUG 5>3[5]
DL ATL-DCA AUG 10>7[11]
DL ATL-DEN AUG 7>5[9]
DL ATL-DFW AUG 8>7[10]
DL ATL-DHN AUG 3>1.9[4]
DL ATL-ECP AUG 6>5[6]
DL ATL-ELP AUG 3>1.0[3]
DL ATL-EWR AUG 9>7[12]
DL ATL-FLL AUG 11>6[12]
DL ATL-GCM AUG 1.0>0.6[1.1]
DL ATL-GDL AUG 0.7>0[1.0]
DL ATL-GNV AUG 6>4[7]
DL ATL-GRB AUG 1.6>1.0[1.7]
DL ATL-GRR AUG 4>3[5]
DL ATL-GTR AUG 3>1.9[4]
DL ATL-HHH AUG 3>2[3]
DL ATL-HND AUG 0.8>0.4[0] SEP 1.0>0.6[0]
DL ATL-HOU AUG 6>4[6]
DL ATL-HPN AUG 5>0[7]
DL ATL-HSV AUG 8>6[7]
DL ATL-IAD AUG 7>5[7]
DL ATL-IAH AUG 7>5[8]
DL ATL-ICN AUG 0.9>0.7[1.0] SEP 1.0>0.8[1.0]
DL ATL-ICT AUG 3>1.9[3]
DL ATL-ILM AUG 5>3[5]
DL ATL-IND AUG 8>6[9]
DL ATL-JAN AUG 7>4[7]
DL ATL-JAX AUG 10>7[12]
DL ATL-JFK AUG 7>6[8]
DL ATL-KIN AUG 0.9>0.5[1.0]
DL ATL-LAS AUG 7>6[8]
DL ATL-LAX AUG 10>9[12]
DL ATL-LEX AUG 7>6[8]
DL ATL-LGA AUG 13>8[16]
DL ATL-LIR AUG 1.0>0.5[1.1]
DL ATL-LIT AUG 6>4[7]
DL ATL-MBJ AUG 3>1.2[3]
DL ATL-MCI AUG 7>6[8]
DL ATL-MCO AUG 14>7[16]
DL ATL-MDT AUG 2>1.0[3]
DL ATL-MDW AUG 5>1.6[7]
DL ATL-MEM AUG 9>6[10]
DL ATL-MGM AUG 6>4[6]
DL ATL-MIA AUG 9>6[11]
DL ATL-MKE AUG 6>5[8]
DL ATL-MLB AUG 4>1.9[4]
DL ATL-MLI AUG 3>1.9[3]
DL ATL-MOB AUG 7>4[7]
DL ATL-MSN AUG 3>1.9[4]
DL ATL-MSP AUG 10>9[11]
DL ATL-MSY AUG 9>5[10]
DL ATL-MTY AUG 1.4>0.4[2.0]
DL ATL-NAS AUG 2>0.8[4]
DL ATL-OAK AUG 0.7>0[0.6]
DL ATL-OKC AUG 5>4[6]
DL ATL-OMA AUG 5>4[5]
DL ATL-ONT AUG 1.8>1.0[1.8]
DL ATL-ORD AUG 8>6[11]
DL ATL-ORF AUG 7>6[9]
DL ATL-PBI AUG 8>5[10]
DL ATL-PHL AUG 8>6[9]
DL ATL-PHX AUG 5>3[5]
DL ATL-PIT AUG 7>5[8]
DL ATL-PNS AUG 7>6[8]
DL ATL-PTY AUG 0.6>0.4[1.0]
DL ATL-PVD AUG 2>0[3]
DL ATL-PWM AUG 3>1.9[3]
DL ATL-RDU AUG 10>8[12]
DL ATL-RIC AUG 8>5[10]
DL ATL-ROA AUG 4>3[5]
DL ATL-ROC AUG 3>1.0[3]
DL ATL-RST AUG 1.5>0[1.8]
DL ATL-RSW AUG 7>5[7]
DL ATL-SAN AUG 6>3[7]
DL ATL-SAT AUG 6>4[8]
DL ATL-SAV AUG 9>8[10]
DL ATL-SBN AUG 4>1.9[4]
DL ATL-SDF AUG 8>7[8]
DL ATL-SFO AUG 6>4[9]
DL ATL-SHV AUG 6>4[6]
DL ATL-SJC AUG 2>0.9[2]
DL ATL-SJD AUG 0.9>0.5[0.9]
DL ATL-SJO AUG 1.7>0.6[2]
DL ATL-SJU AUG 2.8>1.9[4]
DL ATL-SLC AUG 8>10[9]
DL ATL-SMF AUG 3>1.9[2]
DL ATL-SNA AUG 3>1.0[3]
DL ATL-STL AUG 7>5[8]
DL ATL-SYR AUG 3>1.9[3]
DL ATL-TLH AUG 7>4[7]
DL ATL-TPA AUG 11>7[13]
DL ATL-TRI AUG 6>4[6]
DL ATL-TUL AUG 4>3[5]
DL ATL-TUS AUG 1.6>1.0[1.8]
DL ATL-TYS AUG 8>7[8]
DL ATL-UIO AUG 0.7>0.3[1.0]
DL ATL-UVF AUG 1.0>0.7[1.1]
DL ATL-VLD AUG 3>1.9[3]
DL ATL-VPS AUG 7>5[7]
DL ATL-XNA AUG 5>4[6]
DL ATL-YUL AUG 4>0[5]
DL ATL-YVR AUG 0.7>0[1.0]
DL ATL-YYZ AUG 5>0[7]
DL AUA-JFK AUG 1.0>0.7[1.0]
DL AUS-BOS AUG 1.4>0.7[0.9]
DL AUS-CVG AUG 0.6>0[0.8]
DL AUS-DTW AUG 3>1.0[3]
DL AUS-JFK AUG 2>1.0[3]
DL AUS-LAX AUG 3>1.0[3]
DL AUS-MSP AUG 3>1.9[3]
DL AUS-RDU AUG 0.7>0[0.8]
DL AUS-SEA AUG 1.4>0.5[1.0]
DL AZO-DTW AUG 4>3[4]
DL AZO-MSP AUG 1.5>0[1.7]
DL BDL-CLE AUG 0.6>0[0.9]
DL BDL-CVG AUG 0.6>0[0.8]
DL BDL-DTW AUG 4>3[5]
DL BDL-MSP AUG 3>1.9[4]
DL BDL-RDU AUG 0.7>0[0.9]
DL BGM-DTW AUG 3>1.0[3]
DL BHM-DTW AUG 2>0[3]
DL BHM-LGA AUG 2>0[2]
DL BIL-MSP AUG 1.9>1.2[4]
DL BIS-MSP AUG 6>4[6]
DL BNA-BOS AUG 3>1.0[4]
DL BNA-JFK AUG 3>1.8[3]
DL BNA-LAX AUG 1.6>1.0[1.7]
DL BNA-LGA AUG 5>3[6]
DL BNA-MSP AUG 5>3[5]
DL BNA-RDU AUG 1.4>0[1.8]
*DL BOG-JFK SEP 0.2>0[0] OCT 1.0>0[0] NOV 1.0>0.5[0]
DL BOI-LAX AUG 1.6>1.0[1.8]
DL BOI-SEA AUG 6>5[5]
DL BOS-BUF AUG 2>0[3]
DL BOS-CHS AUG 0.7>0[1.1]
DL BOS-CLE AUG 2>1.1[3]
DL BOS-CMH AUG 2>1.1[3]
DL BOS-CVG AUG 3>0.5[4]
DL BOS-DCA AUG 4>2[0]
DL BOS-DTW AUG 6>4[7]
DL BOS-EWR AUG 3>0[0]
DL BOS-FLL AUG 0.9>0.6[1.0]
DL BOS-IND AUG 3>1.1[4]
DL BOS-JAX AUG 2>0.5[3]
DL BOS-JFK AUG 7>4[8]
DL BOS-LAS AUG 0.9>0.5[1.0]
DL BOS-LAX AUG 3>1.0[3]
DL BOS-LGA AUG 11>4[14]
DL BOS-MCI AUG 2>0[1.8]
DL BOS-MCO AUG 3>1.0[3]
DL BOS-MIA AUG 1.5>0[0]
DL BOS-MKE AUG 1.4>0[1.8]
DL BOS-MSP AUG 5>4[6]
DL BOS-ORD AUG 3>1.6[0]
DL BOS-ORF AUG 0.7>0[1.0]
DL BOS-PHL AUG 4>1.6[5]
DL BOS-PIT AUG 3>1.6[4]
DL BOS-RDU AUG 5>4[6]
DL BOS-RIC AUG 2>0.5[3]
DL BOS-SEA AUG 3>1.9[3]
DL BOS-SFO AUG 1.4>0[1.8]
DL BOS-TPA AUG 3>1.0[3]
DL BTV-JFK AUG 2>0[3]
DL BTV-LGA AUG 1.4>0[2]
DL BUF-DTW AUG 4>3[5]
DL BUF-JFK AUG 4>0[5]
DL BUF-LGA AUG 3>0[4]
DL BUF-MSP AUG 0.7>0[2.0]
DL BUR-SLC AUG 4>1.0[4]
DL BWI-CVG AUG 1.9>0[3]
DL BWI-JFK AUG 3>0[4]
DL BWI-MSP AUG 3>1.9[3]
DL BWI-RDU AUG 1.5>0[1.7]
DL BWI-SLC AUG 1.6>1.0[1.7]
DL BZN-MSP AUG 3>2[3]
*DL BZN-SEA AUG 1.5>0[0.1] SEP 2>0[0] OCT 1.9>0[0] NOV 2.0>0.8[0]
DL BZN-SLC AUG 3>4[5]
DL CAE-LGA AUG 1.4>0[1.7]
DL CHA-DTW AUG 2>0[3]
DL CHA-LGA AUG 0.7>0[1.0]
DL CHO-LGA AUG 1.9>0[2]
DL CHS-DTW AUG 2>0[3]
DL CHS-LGA AUG 2>0.5[3]
DL CID-DTW AUG 3>1.9[4]
DL CLE-DTW AUG 7>5[5]
DL CLE-JFK AUG 3>0[4]
DL CLE-LGA AUG 5>3[5]
DL CLE-RDU AUG 0.6>0[0.9]
DL CLE-SLC AUG 0.7>0[0.9]
DL CLT-CVG AUG 1.9>0[2]
DL CLT-JFK AUG 3>0[4]
DL CLT-LGA AUG 6>4[7]
DL CLT-MSP AUG 3>1.9[4]
DL CMH-DTW AUG 7>5[6]
DL CMH-JFK AUG 2>0[3]
DL CMH-LAX AUG 0.6>0[1.0]
DL CMH-LGA AUG 5>3[5]
DL CMH-RDU AUG 1.4>0[1.7]
DL CMH-SLC AUG 0.7>0[0.8]
DL CUN-DTW AUG 0.7>0.4[1.0]
DL CUN-JFK AUG 1.9>1.0[2.0]
DL CUN-LAX AUG 0.9>0.7[1.1]
DL CUN-SLC AUG 0.3>1.0[0.8]
DL CVG-DCA AUG 2>1.1[4]
DL CVG-DEN AUG 0.7>0[1.0]
DL CVG-DFW AUG 1.8>0[3]
DL CVG-EWR AUG 1.8>0[3]
DL CVG-FLL AUG 0.7>0[0.8]
DL CVG-IAH AUG 1.3>0[1.5]
DL CVG-JFK AUG 0.7>0[1.0]
DL CVG-LAS AUG 0.9>0[1.0]
DL CVG-LAX AUG 1.6>0.9[1.8]
DL CVG-LGA AUG 5>3[5]
DL CVG-MCI AUG 1.3>0[1.5]
DL CVG-MCO AUG 1.7>1.0[2]
DL CVG-ORD AUG 3>0[4]
DL CVG-PHL AUG 1.8>0[2]
DL CVG-RDU AUG 1.3>0[1.8]
DL CVG-SEA AUG 0.7>0[1.0]
DL CVG-SFO AUG 0.6>0[1.0]
DL CVG-STL AUG 1.3>0[1.5]
DL CVG-YYZ AUG 1.3>0[1.5]
DL CWA-MSP AUG 3>1.9[3]
DL DAY-MSP AUG 3>0[4]
DL DCA-DTW AUG 6>3[7]
DL DCA-JFK AUG 4>1.6[5]
DL DCA-LEX AUG 0.6>0[0.8]
DL DCA-LGA AUG 7>3[10]
DL DCA-MSN AUG 0.6>0[0.8]
DL DCA-MSP AUG 5>3[6]
DL DCA-OMA AUG 0.6>0[0.8]
DL DCA-RDU AUG 3>0[3]
DL DEN-JFK AUG 2>1.7[3]
DL DEN-LGA AUG 1.6>0[2]
DL DEN-MSP AUG 5>4[6]
DL DEN-SLC AUG 5>4[8]
DL DFW-DTW AUG 5>4[5]
DL DFW-JFK AUG 2>1.0[3]
DL DFW-LAX AUG 3>1.9[4]
DL DFW-LGA AUG 5>3[6]
DL DFW-MSP AUG 5>4[7]
DL DLH-MSP AUG 5>3[6]
DL DSM-DTW AUG 3>1.9[4]
DL DSM-LGA AUG 1.4>0[1.8]
DL DSM-SLC AUG 0.7>0[0.9]
DL DTW-ELM AUG 4>1.9[5]
DL DTW-EVV AUG 3>1.9[3]
DL DTW-EWR AUG 5>4[6]
DL DTW-FLL AUG 4>1.9[4]
DL DTW-GRR AUG 6>5[7]
DL DTW-GSO AUG 2>0[3]
DL DTW-GSP AUG 2>0[3]
DL DTW-HND AUG 0.9>0.5[0] SEP 1.0>0.7[0]
DL DTW-HPN AUG 3>0[4]
DL DTW-HSV AUG 0.7>0[1.0]
DL DTW-IAD AUG 4>3[5]
DL DTW-IAH AUG 4>3[5]
DL DTW-IND AUG 7>5[6]
DL DTW-ITH AUG 2>1.0[3]
DL DTW-JAX AUG 1.4>0[1.8]
DL DTW-LAN AUG 4>3[5]
DL DTW-LAS AUG 4>3[5]
DL DTW-LAX AUG 6>5[6]
DL DTW-LEX AUG 3>1.9[4]
DL DTW-LGA AUG 7>5[7]
DL DTW-LIT AUG 0.6>0[0.9]
DL DTW-MBS AUG 4>3[5]
DL DTW-MCO AUG 5>3[5]
DL DTW-MDW AUG 3>0[4]
DL DTW-MEM AUG 3>1.9[3]
DL DTW-MIA AUG 1.7>1.0[1.9]
DL DTW-MKE AUG 4>3[5]
DL DTW-MLI AUG 1.4>0[1.8]
DL DTW-MQT AUG 1.7>1.0[1.8]
DL DTW-MSN AUG 5>3[6]
DL DTW-MSP AUG 7>6[8]
DL DTW-MSY AUG 2>0.9[3]
DL DTW-MTY AUG 0.6>0[0.9]
DL DTW-OKC AUG 1.4>0[1.8]
DL DTW-OMA AUG 3>1.0[4]
DL DTW-ORD AUG 6>4[6]
DL DTW-PBI AUG 0.7>0[0.9]
DL DTW-PDX AUG 1.6>1.0[1.7]
DL DTW-PVD AUG 3>0[4]
DL DTW-RIC AUG 4>1.9[4]
DL DTW-ROC AUG 4>3[4]
DL DTW-RSW AUG 1.9>1.0[2]
DL DTW-SAN AUG 3>1.9[3]
DL DTW-SAT AUG 3>1.2[3]
DL DTW-SAV AUG 0.7>0[1.0]
DL DTW-SBN AUG 4>3[5]
DL DTW-SCE AUG 3>1.9[3]
DL DTW-SDF AUG 4>3[5]
DL DTW-SEA AUG 6>5[7]
DL DTW-SFO AUG 4>3[5]
DL DTW-SJC AUG 0.7>0[0.8]
DL DTW-SMF AUG 0.6>0[0.8]
DL DTW-SNA AUG 0.5>0[0.9]
DL DTW-STL AUG 4>3[6]
DL DTW-TPA AUG 4>1.9[4]
DL DTW-TYS AUG 4>1.9[4]
DL DTW-YUL AUG 3>1.0[4]
DL DTW-YYZ AUG 4>1.9[5]
DL EWR-MSP AUG 5>3[5]
DL EWR-RDU AUG 2>0[3]
DL FAR-MSP AUG 7>5[7]
DL FLL-JFK AUG 4>1.9[4]
DL FLL-LGA AUG 4>1.9[5]
DL FLL-MSP AUG 0.8>0[0.8]
DL FLL-RDU AUG 0.7>0[1.0]
DL FLL-SLC AUG 0.7>0[1.0]
DL FSD-MSP AUG 6>5[7]
DL FWA-MSP AUG 0.7>0[1.0]
DL GEG-MSP AUG 3>1.9[3]
DL GEG-SEA AUG 8>6[8]
DL GFK-MSP AUG 5>3[6]
DL GRR-LGA AUG 2>0[3]
DL GRR-MSP AUG 4>3[5]
DL GSO-LGA AUG 4>0.9[4]
DL GSP-LGA AUG 2>0[3]
DL HLN-MSP AUG 0.6>0[1.0]
DL HLN-SLC AUG 3>1.9[3]
DL HND-LAX AUG 0.8>0.4[1.0] SEP 1.0>0.6[1.0]
DL HND-SEA AUG 0.9>0.5[0] SEP 1.0>0.7[0]
DL HNL-SLC AUG 0.6>0.4[1.0]
DL IAD-JFK AUG 4>3[4]
DL IAD-MSP AUG 3>1.9[3]
DL IAD-SEA AUG 1.6>1.0[1.0]
DL IAH-JFK AUG 1.5>0[0]
DL IAH-LGA AUG 4>3[4]
DL IAH-MSP AUG 4>3[5]
DL ICN-SEA AUG 1.1>0.7[1.0] SEP 1.2>0.8[1.0]
DL ICT-MSP AUG 3>1.9[4]
DL IND-JFK AUG 2>0[3]
DL IND-LAX AUG 0.6>0[1.0]
DL IND-LGA AUG 4>3[4]
DL IND-MCO AUG 0.7>0[1.0]
DL IND-MSP AUG 4>3[5]
DL IND-RDU AUG 1.5>0[1.7]
DL IND-SEA AUG 0.7>0[1.0]
DL JAX-JFK AUG 2>1.7[3]
DL JAX-LGA AUG 2>0[3]
DL JAX-MSP AUG 0.6>0[0.8]
DL JFK-LAS AUG 4>1.9[5]
DL JFK-LAX AUG 8>6[9]
DL JFK-MBJ AUG 0.9>0.6[1.0]
DL JFK-MCO AUG 4>1.9[5]
DL JFK-MIA AUG 3>1.9[4]
DL JFK-MSP AUG 4>3[4]
DL JFK-MSY AUG 2>0.9[3]
DL JFK-ORD AUG 4>3[5]
DL JFK-ORF AUG 2>0[3]
DL JFK-PDX AUG 1.6>0.6[3]
DL JFK-PHX AUG 1.6>0.6[2]
DL JFK-PIT AUG 2>1.6[3]
DL JFK-PWM AUG 2>0[3]
DL JFK-RDU AUG 4>3[5]
DL JFK-RIC AUG 2>0[3]
DL JFK-ROC AUG 2>0[3]
DL JFK-SAN AUG 2>1.0[3]
DL JFK-SAT AUG 0.7>0[1.0]
DL JFK-SAV AUG 1.7>1.0[3]
DL JFK-SEA AUG 4>3[5]
DL JFK-SFO AUG 6>3[7]
DL JFK-SJC AUG 0.6>0[1.0]
DL JFK-SJU AUG 2.6>1.4[3.0]
DL JFK-SYR AUG 2>0[3]
DL JFK-TPA AUG 4>1.9[4]
DL JFK-YUL AUG 2>0[3]
DL JFK-YYZ AUG 3>1.0[4]
DL LAN-MSP AUG 1.0>0[1.0]
DL LAS-LAX AUG 6>5[7]
DL LAS-MSP AUG 5>4[6]
DL LAS-SEA AUG 5>3[5]
DL LAX-MCI AUG 1.4>0[1.8]
DL LAX-MCO AUG 2>1.0[3]
DL LAX-MEM AUG 0.6>0[0.9]
DL LAX-MSP AUG 6>5[8]
DL LAX-MSY AUG 2>0.9[3]
DL LAX-OMA AUG 0.6>0[0]
DL LAX-PHX AUG 5>3[5]
DL LAX-PVR AUG 0.9>0.7[1.0]
DL LAX-RDU AUG 0.7>0[1.3]
DL LAX-SAN AUG 4>0[5]
DL LAX-SAT AUG 1.5>0[2.0]
DL LAX-SEA AUG 8>6[9]
DL LAX-SFO AUG 7>5[8]
DL LAX-SJC AUG 6>4[7]
DL LAX-SLC AUG 7>6[8]
DL LAX-SMF AUG 5>3[5]
DL LAX-SYD AUG 0.8>0.4[1.0] SEP 1.0>0.6[1.0]
DL LAX-TPA AUG 0.7>0[1.3]
DL LAX-TUS AUG 3>1.7[3]
DL LEX-LGA AUG 0.7>0[1.0]
DL LEX-MSP AUG 0.7>0[0.9]
DL LGA-MCI AUG 4>1.0[4]
DL LGA-MCO AUG 4>3[5]
DL LGA-MEM AUG 2>0.5[3]
DL LGA-MIA AUG 3>1.7[4]
DL LGA-MKE AUG 3>1.6[5]
DL LGA-MSN AUG 2>0[3]
DL LGA-MSP AUG 6>4[7]
DL LGA-MSY AUG 2>0.5[3]
DL LGA-OMA AUG 1.9>0[3]
DL LGA-ORD AUG 10>5[12]
DL LGA-ORF AUG 3>1.1[4]
DL LGA-PBI AUG 3>1.0[4]
DL LGA-PIT AUG 6>3[7]
DL LGA-PWM AUG 3>0[4]
DL LGA-RDU AUG 6>3[7]
DL LGA-RIC AUG 4>3[4]
DL LGA-ROC AUG 3>0[3]
DL LGA-RSW AUG 1.5>0[2.0]
DL LGA-SAV AUG 2>0[3]
DL LGA-SDF AUG 3>1.6[3]
DL LGA-SRQ AUG 0.7>0[1.0]
DL LGA-STL AUG 5>3[5]
DL LGA-SYR AUG 1.9>0[3]
DL LGA-TPA AUG 3>1.9[4]
DL LGA-TYS AUG 1.9>0[3]
DL LGA-XNA AUG 0.6>0[0.8]
DL LGA-YUL AUG 3>0[4]
DL LGB-SLC AUG 3>1.9[4]
DL MBS-MSP AUG 0.9>0[0.9]
DL MCI-MSP AUG 5>4[5]
DL MCI-SEA AUG 0.7>0[1.0]
DL MCO-MIA AUG 4>0[0]
DL MCO-MSP AUG 4>1.3[4]
DL MCO-RDU AUG 2>0[3]
DL MCO-SEA AUG 0.7>0[0.8]
DL MCO-SLC AUG 2>1.7[2]
DL MDW-MSP AUG 5>0[6]
DL MEM-MSP AUG 2>0.2[3]
DL MIA-MSP AUG 1.7>1.0[1.8]
DL MIA-RDU AUG 1.5>0[0.1]
DL MIA-SLC AUG 0.7>0[0]
DL MIA-TPA AUG 4>0[0]
DL MKE-MSP AUG 5>4[5]
DL MKE-SEA AUG 0.7>0[1.0]
**DL MLI-MSP AUG 1.8>0[1.8] SEP 1.9>0[1.9] OCT 1.2>0[1.9] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 0.9>0[1.0] FEB 1.1>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[1.0]
DL MSN-MSP AUG 5>4[5]
DL MSN-SLC AUG 0.6>0[0.8]
DL MSO-MSP AUG 1.9>1.2[2.0]
DL MSP-MSY AUG 0.7>0[1.0]
DL MSP-OKC AUG 3>1.9[3]
DL MSP-OMA AUG 6>3[6]
DL MSP-ORD AUG 6>5[7]
DL MSP-ORF AUG 0.6>0[1.0]
DL MSP-PHX AUG 4>3[5]
DL MSP-PSC AUG 1.7>1.0[1.9]
DL MSP-RIC AUG 1.4>0[3]
DL MSP-ROC AUG 0.6>0[0.9]
DL MSP-SAT AUG 3>1.2[3]
DL MSP-SBN AUG 1.5>0[3]
DL MSP-SDF AUG 3>1.0[3]
DL MSP-SFO AUG 5>3[7]
DL MSP-SJC AUG 2>0[2]
DL MSP-SLC AUG 6>7[6]
DL MSP-SNA AUG 2>1.0[3]
DL MSP-STL AUG 5>1.9[6]
DL MSP-SYR AUG 0.6>0[1.0]
DL MSP-TPA AUG 1.7>1.0[1.9]
DL MSP-TUL AUG 1.4>0[1.8]
DL MSP-TVC AUG 3>1.4[4]
DL MSP-TYS AUG 0.7>0[1.0]
DL MSP-XNA AUG 1.2>0[1.5]
DL MSP-YUL AUG 1.4>0[1.8]
DL MSP-YVR AUG 1.5>0[2.0]
DL MSP-YWG AUG 3>0.9[4]
DL MSP-YYC AUG 2>1.0[3]
DL MSP-YYZ AUG 3>0[4]
DL OAK-SLC AUG 4>1.0[5]
DL OGG-SEA AUG 0.7>0.5[1.0]
DL OKC-SLC AUG 2>1.9[3]
DL OMA-SLC AUG 2>3[3]
DL ORD-RDU AUG 2>0[3]
DL ORD-SEA AUG 3>1.9[3]
DL PDX-SEA AUG 7>6[8]
DL PDX-SLC AUG 5>4[6]
DL PHL-RDU AUG 2>0[3]
DL PHX-SEA AUG 3>4[4]
DL PIT-RDU AUG 0.6>0[1.0]
DL PIT-SLC AUG 0.6>0[0.9]
DL PSC-SEA AUG 4>3[4]
DL PSP-SLC AUG 3>1.9[2]
DL RAP-SLC AUG 1.7>1.0[2.0]
DL RDU-SEA AUG 0.7>0[1.0]
DL RDU-TPA AUG 2>0[3]
DL SAN-SEA AUG 4>3[5]
DL SEA-SFO AUG 6>4[8]
DL SEA-SJC AUG 5>4[6]
DL SEA-SLC AUG 7>6[8]
DL SEA-SMF AUG 5>4[5]
DL SEA-SNA AUG 4>2[5]
DL SEA-TPA AUG 0.7>0[0]
DL SEA-YVR AUG 5>3[7]
DL SEA-YYC AUG 2>0[3]
DL SLC-SUN AUG 3>1.9[3]
DL SLC-YVR AUG 1.5>0[2]
DL SLC-YYC AUG 1.5>0[2.0]
DL SLC-YYZ AUG 0.7>0[1.0]
**EK DXB-EWR AUG 1.0>0[1.0] SEP 1.0>0[0.9] OCT 1.0>0[0.7] NOV 1.0>0[0.8] DEC 1.0>0[1.0] JAN 0.9>0[1.0] FEB 1.1>0.1[1.0]
F4 CBA-CPX AUG 0>3.9[0] SEP 0>4[0] OCT 0>3.9[0] NOV 0>4[0] DEC 0>4[0] JAN 0>3.6[0] FEB 0>4[0] MAR 0>3.9[0] APR 0>4[0]
F4 CBA-VQS AUG 0>2.5[0] SEP 0>2.7[0] OCT 0>2.4[0] NOV 0>2.7[0] DEC 0>2.5[0] JAN 0>2.3[0] FEB 0>2.9[0] MAR 0>2.5[0] APR 0>2.6[0]
HPK ACK-HPN AUG 1.2>0[0] SEP 1.4>0[0] OCT 1.2>0[0] NOV 0.3>0[0]
HPK BOS-HPN AUG 0.6>0[0] SEP 0.6>0[0] OCT 0.5>0[0]
HPK HPN-MVY AUG 0.4>0[0] SEP 0.5>0[0] OCT 0.4>0[0]
HPK HPN-NPT AUG 0.3>0[0] SEP 0.3>0[0] OCT 0.3>0[0]
HY JFK-TAS AUG 0.5>0.1[0.4]
HZ RZH-VVO AUG 0>0.7[0] SEP 0>0.6[0]
IB BOS-MAD AUG 1.0>0[1.0]
IB IAD-MAD AUG 0.7>0[0]
IB JFK-MAD AUG 2>1.0[2]
IB LAX-MAD AUG 1.0>0[1.0]
IB MAD-MIA AUG 1.9>1.0[2]
IB MAD-SFO AUG 0.4>0[0.4]
JQ HNL-MEL APR 0>0.3[0]
JQ HNL-SYD APR 0>0.5[0]
KAI KOA-OAK AUG 0.3>0[0.3] SEP 0.3>0[0.3] OCT 0.3>0[0.3] NOV 0.3>0[0.3] DEC 0.3>0[0.3] JAN 0.3>0[0.3] FEB 0.3>0[0.3] MAR 0.3>0[0.3] APR 0.3>0[0.3]
KG DEN-TEX OCT 0>0.3[0.5] NOV 0>1.0[0.3] DEC 0>1.0[1.3] JAN 0>0.9[1.2] FEB 0>1.1[1.7] MAR 0>0.6[1.7]
KL AMS-LAS AUG 0.5>0[0.4] SEP 0.6>0.1[0.4]
KL AMS-MSP AUG 0.5>0[0.6] SEP 0.6>0.1[0.6]
KL AMS-SLC AUG 0.4>0[0.4] SEP 0.3>0[0.4]
MF FOC-JFK AUG 0.4>0[0.4] SEP 0.4>0.1[0.4]
Huge cut
NK ACY-ATL AUG 0.5>0[1.0]
NK ACY-FLL AUG 2>0.8[1.3]
NK ACY-MCO AUG 2>0.5[2]
NK ACY-MYR AUG 1.0>0.1[1.0]
NK ACY-RSW AUG 1.0>0.3[1.0]
NK ACY-TPA AUG 1.0>0.3[1.0]
NK ATL-AUS AUG 0.7>0[1.0]
NK ATL-BOS AUG 0.8>0.6[1.0]
NK ATL-BWI AUG 2>0.8[3]
NK ATL-DFW AUG 1.7>1.0[2]
NK ATL-DTW AUG 1.7>1.0[3]
NK ATL-EWR AUG 1.7>1.0[1.0]
NK ATL-FLL AUG 4>1.9[4]
NK ATL-IAH AUG 1.0>0.7[1.0]
NK ATL-LAS AUG 1.7>0.7[2]
NK ATL-MCO AUG 1.5>0.7[2]
NK ATL-MSP AUG 1.0>0.6[1.0]
NK ATL-MSY AUG 0.7>0.2[1.0]
NK ATL-TPA AUG 1.7>0.7[3]
NK AUS-BNA AUG 0.5>0[0]
NK AUS-BWI AUG 0.6>0[1.0]
NK AUS-CUN AUG 0.3>0[0]
NK AUS-DEN AUG 0.5>0[1.0]
NK AUS-DTW AUG 0.5>0[1.0]
NK AUS-EWR AUG 0.7>0[0]
NK AUS-LAS AUG 0.8>0.5[1.0]
NK AUS-MCO AUG 1.0>0.6[1.0]
NK AUS-MSY AUG 0.7>0[1.0]
NK AUS-ORD AUG 0.7>0[1.0]
NK BAQ-FLL AUG 0.4>0.1[0]
NK BDL-FLL AUG 0.9>0.2[1.0]
NK BDL-MCO AUG 1.2>0.5[2]
NK BDL-MYR AUG 1.6>0.5[1.3]
NK BGA-FLL AUG 0.4>0.1[0]
NK BNA-BWI AUG 0.7>0[0]
NK BNA-CUN AUG 0.2>0[0]
NK BNA-EWR AUG 0.8>0.1[0]
NK BNA-FLL AUG 0.8>0.4[0]
NK BNA-MCO AUG 1.0>0.3[0]
NK BNA-MSY AUG 0.7>0[0]
NK BNA-TPA AUG 0.7>0[0]
NK BOG-MCO AUG 1.0>0.3[1.0]
NK BOS-BWI AUG 3>1.3[2]
NK BOS-CLE AUG 0.4>0[1.0]
NK BOS-DTW AUG 0.4>0[1.0]
NK BOS-FLL AUG 1.7>0.6[2]
NK BOS-LAS AUG 0.9>0.5[1.0]
NK BOS-MCO AUG 1.5>0.7[2]
NK BOS-MSY AUG 0.5>0[1.0]
NK BOS-MYR AUG 1.3>0.5[1.0]
NK BOS-ORD AUG 0.7>0.3[1.0]
NK BOS-RSW AUG 0.4>0[0]
NK BQN-FLL AUG 0.9>0.3[0.6]
NK BUR-LAS AUG 1.3>0.5[3]
NK BUR-SEA AUG 0.7>0[0]
NK BWI-CLT AUG 0.5>0[1.0]
NK BWI-CUN AUG 0.5>0[1.0]
NK BWI-DEN AUG 0.4>0[1.0]
NK BWI-DFW AUG 0.8>0.5[1.0]
NK BWI-DTW AUG 0.7>0[1.0]
NK BWI-FLL AUG 3>1.0[3]
NK BWI-IAH AUG 1.1>0.1[1.0]
NK BWI-LAS AUG 1.0>0.6[1.0]
NK BWI-MBJ AUG 0.5>0[1.0]
NK BWI-MCO AUG 3>1.0[2]
NK BWI-MSP AUG 0.7>0[1.0]
NK BWI-MSY AUG 0.7>0[1.0]
NK BWI-MYR AUG 1.7>0.5[1.6]
NK BWI-ORD AUG 1.4>0.4[2]
NK BWI-RDU AUG 0.5>0[1.6]
NK BWI-SAL AUG 0.7>0[0]
NK BWI-SEA AUG 0.7>0[1.0]
NK BWI-SJU AUG 1.5>0.7[1.4]
NK BWI-TPA AUG 1.6>0.2[1.6]
NK CAK-MCO AUG 0.9>0.6[1.0]
NK CLE-CUN AUG 0.3>0[0]
NK CLE-EWR AUG 0.8>0.1[0]
NK CLE-FLL AUG 1.7>0.7[1.0]
NK CLE-LAS AUG 1.7>0.7[1.0]
NK CLE-LAX AUG 1.0>0.7[1.0]
NK CLE-MCO AUG 2.0>0.6[1.6]
NK CLE-MSY AUG 0.3>0[0.4]
NK CLE-MYR AUG 0.9>0.6[1.0]
NK CLE-RSW AUG 0.3>0[0]
NK CLE-TPA AUG 0.7>0.5[0]
NK CLT-EWR AUG 0.8>0.1[1.0]
NK CLT-FLL AUG 0.8>0.5[1.0]
NK CLT-MCO AUG 0.9>0.5[1.0]
NK CMH-FLL AUG 1.0>0.6[1.0]
NK CMH-LAS AUG 0.9>0.5[1.0]
NK CMH-MCO AUG 1.2>0.6[1.0]
NK CMH-MSY AUG 0.3>0[0.4]
NK CRW-MCO AUG 0.3>0.1[0]
NK CTG-MCO AUG 0.3>0.1[0.3]
NK CUN-DFW AUG 0.5>0[1.0]
NK CUN-DTW AUG 0.5>0[0.2]
NK CUN-IAH AUG 0.6>0.2[1.0]
NK CUN-MSY AUG 0.4>0[0]
NK CUN-ORD AUG 0.5>0[0.6]
NK CUN-PHL AUG 0.5>0[0]
NK CUN-PIT AUG 0.2>0[0]
NK DEN-DTW AUG 1.0>0.6[1.0]
NK DEN-FLL AUG 1.5>0.6[1.0]
NK DEN-IAH AUG 1.0>0.6[1.0]
NK DEN-LAS AUG 1.5>0.7[2]
NK DEN-MCO AUG 0.7>0[1.0]
NK DEN-MSP AUG 1.0>0.7[1.0]
NK DEN-ORD AUG 1.5>1.0[2]
NK DFW-FLL AUG 2>1.0[3]
NK DFW-LAS AUG 2>1.7[4]
NK DFW-LAX AUG 3>1.9[4]
NK DFW-LGA AUG 1.0>0.6[1.0]
NK DFW-MCO AUG 1.7>0.7[3]
NK DFW-MSY AUG 0.8>0.3[1.0]
NK DFW-ORD AUG 1.5>0.7[2]
NK DFW-PHL AUG 1.0>0.6[1.0]
NK DFW-TPA AUG 1.0>0.5[1.0]
NK DTW-FLL AUG 2>0.8[2]
NK DTW-LAS AUG 3>1.0[3]
NK DTW-LAX AUG 1.5>1.0[2]
NK DTW-LGA AUG 1.4>0[2]
NK DTW-MCI AUG 0.7>0[1.0]
NK DTW-MCO AUG 2>0.7[3]
NK DTW-MSP AUG 0.7>0[1.0]
NK DTW-MSY AUG 0.8>0.3[1.0]
NK DTW-MYR AUG 1.0>0.6[1.0]
NK DTW-RDU AUG 0.5>0[1.0]
NK DTW-RSW AUG 0.6>0.2[0.9]
NK DTW-TPA AUG 0.9>0.6[0.9]
NK EWR-FLL AUG 3>1.2[2]
NK EWR-IAH AUG 1.0>0.6[1.0]
NK EWR-LAS AUG 1.0>0.7[1.0]
NK EWR-MCO AUG 3>1.2[4]
NK EWR-MSY AUG 0.7>0[1.0]
NK EWR-MYR AUG 3>0.9[1.0]
NK EWR-RSW AUG 0.9>0.5[0]
NK EWR-SJU AUG 1.7>1.0[0]
NK EWR-TPA AUG 1.0>0.7[0]
NK FLL-GUA AUG 1.4>1.0[1.0]
NK FLL-IAG AUG 0.2>0[0.3]
NK FLL-IAH AUG 1.7>1.0[2]
NK FLL-KIN AUG 0.6>0.4[1.0]
NK FLL-LAS AUG 1.5>1.0[1.0]
NK FLL-LGA AUG 3>1.2[4]
NK FLL-MCO AUG 1.4>0[2]
NK FLL-MSY AUG 1.6>0.4[2]
NK FLL-MYR AUG 1.6>0.2[1.3]
NK FLL-ORD AUG 2>1.2[2]
NK FLL-PBG AUG 0.2>0[0.3]
NK FLL-PHL AUG 3>1.0[2]
NK FLL-PIT AUG 1.7>0.7[1.0]
NK FLL-RDU AUG 0.9>0.5[1.0]
NK FLL-RIC AUG 0.8>0.5[1.0]
NK FLL-SDQ AUG 1.7>1.0[1.0]
NK FLL-SJO AUG 1.7>1.0[2]
NK FLL-SJU AUG 1.7>1.0[1.3]
NK FLL-TPA AUG 1.4>0[1.0]
NK GUA-IAH AUG 0.3>0[0.6]
NK GUA-MCO AUG 0.7>0[0.6]
NK IAH-LAS AUG 2>0.8[2]
NK IAH-LAX AUG 3>1.2[2]
NK IAH-MCO AUG 2>0.6[2]
NK IAH-MSY AUG 0.7>0.2[1.0]
NK IAH-OAK AUG 0.9>0.6[1.0]
NK IAH-ORD AUG 1.7>0.6[2]
NK IAH-SAL AUG 0.3>0[0.4]
NK IAH-SAN AUG 0.9>0.2[1.0]
NK IAH-SAP AUG 0.3>0[0.4]
NK IAH-TPA AUG 0.6>0.2[1.0]
NK IND-LAS AUG 0.7>0.4[1.0]
NK IND-MCO AUG 0.8>0.4[1.0]
NK IND-RSW AUG 0.2>0[0]
NK IND-TPA AUG 0.2>0[0]
NK LAS-LAX AUG 2>1.0[3]
NK LAS-MCI AUG 1.6>0.5[1.0]
NK LAS-MCO AUG 1.0>0.6[1.0]
NK LAS-MSP AUG 1.0>0.6[1.0]
NK LAS-MSY AUG 0.8>0.5[1.0]
NK LAS-OAK AUG 3>1.1[4]
NK LAS-ORD AUG 3>1.9[3]
NK LAS-PDX AUG 2>0.8[3]
NK LAS-PHL AUG 1.0>0.6[1.0]
NK LAS-PIT AUG 1.0>0.6[1.0]
NK LAS-SAN AUG 3>1.1[4]
NK LAS-SEA AUG 2>1.0[4]
NK LAS-SMF AUG 3>0.9[3]
NK LAS-TPA AUG 1.0>0.6[1.0]
NK LAX-MSP AUG 0.6>0.1[1.0]
NK LAX-MSY AUG 0.9>0.5[1.0]
NK LAX-OAK AUG 1.7>0.7[2]
NK LAX-PHL AUG 1.0>0.7[1.0]
NK LAX-PIT AUG 0.6>0.5[1.0]
NK LBE-MYR AUG 0.7>0.3[1.4] SEP 1.5>1.2[1.0]
NK LGA-MCO AUG 1.0>0.6[0]
NK LGA-MYR AUG 1.7>0.6[2]
NK LGA-ORD AUG 1.0>0.6[2]
NK MBJ-MCO AUG 0.3>0[0.6]
NK MCI-MCO AUG 1.2>0.6[1.0]
NK MCO-MDE AUG 0.4>0.1[0.3]
NK MCO-MSP AUG 1.0>0.3[1.0]
NK MCO-MSY AUG 1.6>0.5[1.0]
NK MCO-MYR AUG 0.2>0[0.3]
NK MCO-ORD AUG 1.0>0.6[1.0]
NK MCO-PHL AUG 3>1.2[3]
NK MCO-PIT AUG 2>0.6[1.0]
NK MCO-RDU AUG 1.1>0[1.0] SEP 1.7>1.3[0.9]
NK MCO-RIC AUG 0.7>0[1.0]
NK MCO-SAL AUG 0.2>0[0.3]
NK MCO-SAP AUG 0.2>0[0.3]
NK MCO-SJO AUG 0.7>0[1.0]
NK MCO-SJU AUG 3.4>2.2[3.2]
NK MSP-MSY AUG 0.3>0[0.6]
NK MSY-ORD AUG 0.8>0.3[1.0]
NK MSY-PHL AUG 0.4>0[0.6]
NK MSY-RDU AUG 0.7>0[1.0]
NK MSY-SAP AUG 0.3>0[0]
NK MSY-TPA AUG 0.8>0.1[1.0]
NK MYR-ORD AUG 0.9>0.6[1.0]
NK MYR-PHL AUG 1.1>0.6[1.0]
NK MYR-PIT AUG 1.3>0.6[1.0]
NK OAK-ORD AUG 0.8>0.4[1.0]
NK ORD-RDU AUG 0.5>0[1.0]
NK ORD-RSW AUG 0.7>0.5[1.0]
NK ORD-SEA AUG 0.7>0[1.0]
NK PHL-SJU AUG 1.5>1.0[1.0]
NK PIT-TPA AUG 0.3>0[0]
P2 KIS-MDR AUG 0>1.0[0] SEP 0>1.0[0] OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>0.9[0] FEB 0>1.1[0] MAR 0>1.0[0] APR 0>1.0[0]
P2 MDR-WIL AUG 0>4[0] SEP 0>3[0] OCT 0>3[0] NOV 0>3[0] DEC 0>3[0] JAN 0>3[0] FEB 0>3[0] MAR 0>3[0] APR 0>3[0]
PR CEB-LAX AUG 0.4>0[0] SEP 0.5>0.1[0]
PR HNL-MNL AUG 0.7>0.3[0.7] SEP 0.8>0.5[0.6]
PR JFK-MNL AUG 1.0>0.1[1.0] SEP 1.0>0.4[0.8]
PR LAX-MNL AUG 1.9>0.7[2] SEP 2>1.2[2]
PR MNL-SFO AUG 1.4>0.5[1.7] SEP 1.6>1.0[1.4]
Q5 FAI-HKB AUG 0.6>0[0.4] SEP 0.7>0[0.4] OCT 0.6>0[0.4] NOV 0.7>0[0.4] DEC 0.6>0[0.4] JAN 0.6>0[0.5] FEB 0.8>0[0.4] MAR 0.6>0[0.4] APR 0.7>0[0.4]
Q5 HKB-TKJ AUG 0.2>0[0.4] SEP 0.2>0[0.4] OCT 0.2>0[0.4] NOV 0.2>0[0.4] DEC 0.2>0[0.4] JAN 0.2>0[0.5] FEB 0.3>0[0.4] MAR 0.2>0[0.4] APR 0.2>0[0.4]
RLI ACK-DXR AUG 0.2>0[0] SEP 0.2>0[0] OCT 0.2>0[0] NOV 0.2>0[0] DEC 0.2>0[0] JAN 0.2>0[0] FEB 0.2>0[0] MAR 0.2>0[0] APR 0.2>0[0]
SK CPH-SCR DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0]
*SY FLL-MSP NOV 0>0.4[0] DEC 0>0.5[0] JAN 0>0.4[0] FEB 0>0.4[0]
UA BOG-EWR AUG 0.7>0[1.6] SEP 1.0>0.2[1.0]
UA GUM-HNL AUG 0.5>1.0[0.5] SEP 0.5>1.0[0.5] OCT 0.5>1.0[0.5] NOV 0.5>1.0[0.5] DEC 0.5>1.0[0.5] JAN 0.5>0.9[0.5] FEB 0.6>1.1[0.5] MAR 0.5>1.0[0.5] APR 0.5>1.0[0.5]
UP FLL-FPO AUG 1.5>0.9[1.7]
UP FLL-NAS AUG 3>1.1[3]
VS ATL-LHR AUG 1.0>0.5[1.0]
VS LHR-MCO AUG 1.0>0[0]
VS LHR-SFO AUG 1.0>0.7[1.8]
VS MAN-MCO AUG 1.0>0[1.7]
VW LRD-MEX AUG 0.3>0[0]
WN BOI-GEG AUG 0>0.2[1.7]
WN BUR-HOU AUG 0.9>0.7[1.0]
WN GEG-SEA AUG 0>0.6[0]
WN RNO-SEA AUG 0>0.2[0]
YR BLD-PGA AUG 1.0>0[1.0] SEP 1.0>0[1.0]
YR GCN-PGA AUG 1.0>0[1.0] SEP 1.0>0[1.0]
enilria
Re: OAG Changes for 7/21/2020:AUGUST SINKING;EK Drops EWR-DXB; DL Drops MLI-MSP; Big Cuts for DL/NK
Tue Jul 21, 2020 4:16 pm
I am going to look at other data sources over the next few weeks both because of the day change and cost. I would like to get it back to Sunday, but if I find a better solution I will move to that. FYI... For now it will remain on Tuesday or Wednesday...
enilria
Tue Jul 21, 2020 4:20 pm
Kinda surprising to see EK drop EWR-DXB with B6 moving more heavily into EWR
Miamiairport
Tue Jul 21, 2020 4:30 pm
I'm thinking the huge NK cuts means future demand in general is slowing as well as cancellations rising. NK even as an ULCC would go broke with 60% load factors on $29 fares.
holeham
Any day you can do it’s fine. Really appreciate all of the hard work and time you put into this, Enilria.
Thanks.
PHLspecial
Tue Jul 21, 2020 4:31 pm
Thanks for your hard work. Interesting B6 is banking in Jan for everything to return to normal. Hope that is true. I didn't expect EK to drop EWR but I guess its cheaper to keep operations at one airport. Would be shocked to see that route come back in the near future.
Ishrion
Tue Jul 21, 2020 4:33 pm
It's coming back in February though, right?
While I haven't found a bookable date in February, the nonstop seems to be available daily from March 28, 2021, unless it hasn't been fully updated?
EWR-ATH-DXB is still bookable for the last few months of this year and into 2021.
enilria
Tue Jul 21, 2020 4:48 pm
Thanks.
I'd say it is more that they just want a schedule out there to draw in bookings. Who knows what will fly.
Everything points to EWR coming back better than JFK, but who knows...
kavok
Tue Jul 21, 2020 4:57 pm
Thank you again for doing this. Always appreciate and look forward to the thread, whichever day it occurs on.
hiflyeras
Tue Jul 21, 2020 4:58 pm
NK might as well pull out of SEA with a schedule like that...1x SEA-LAS. What's the point?
Bigant0408
Tue Jul 21, 2020 5:11 pm
Like others mentioned thank you for your weekly post. It’s going feel weird not seeing them on Sunday’s but nonetheless glad you’ll still be posting. Im surprised AC cuts aren't as deep as I thought it would be for August.
The man who sleeps on the floor doesn’t fall out of bed
tphuang
Tue Jul 21, 2020 5:20 pm
I think the DL Aug numbers is actually the average of their Aug/Sep numbers.
32andBelow
Tue Jul 21, 2020 5:21 pm
It doesn’t really matter if you use contractors
hollywoodcory
Tue Jul 21, 2020 5:23 pm
I think AC has updated their schedule since then, as it doesn't match this:
https://www.aircanada.com/ca/en/aco/hom ... html#/na-1
For example, YVR-LAX & SFO are only planned once daily, not 5x. No US flights are planned from YYC.
MIflyer12
Tue Jul 21, 2020 5:25 pm
Looking at a late-August Monday, F9 is 1x, WN is 2x, DL is 3x and AS is 6x.
shadez
Tue Jul 21, 2020 5:36 pm
Interesting to see SY enter FLL. Wonder what opportunity they see right now. GPT and PHL also appear as options from FLL on their website, but aren't bookable.
enilria
Tue Jul 21, 2020 5:41 pm
Perhaps the Reason before was gate availability driven. Or maybe they will do Amazon there and need to rotate pilots.
jasoncrh
Tue Jul 21, 2020 5:50 pm
NOt really surprising to see them drop EWR. I dont think that EK was really counting on, or has ever counted on, many connections at EWR from B6 to make EWR work. Most of the new destinations at EWR on B6 either already have EK flights (LAX and SFO), or are timed more for local markets and not for connectivity to / from the Emirates flight. Emirates receives most of its B6 flow at BOS and JFK, where there are more B6 flights that allow for connectivity.
Nicknuzzii
Tue Jul 21, 2020 5:52 pm
They didn’t drop EWR, they dropped one of the 2 daily flights. EWR-ATH-DXB remains.
SANFan
Tue Jul 21, 2020 5:53 pm
I'd also like to thank you Enilria for keeping going with this monumental task you've undertaken for all of us here at A.net. It's enough work and time devoted by you during a "regular" year but 2020 is certainly nothing near normal. PLUS now the day of the week shift on top of everything else...
Sunday, as most people have said, is really nice but whatever day it ends up being, thank you again for your effort! It's very much appreciated.
bb
slcdeltarumd11
Tue Jul 21, 2020 6:01 pm
Thank you for still doing these. Can't even imagine the amount of work it now takes.
Lots of cuts, but I'm not surprised . The airlines were too optomistic about August and the fall.
tjerome
Tue Jul 21, 2020 6:16 pm
I believe everything for DL is for September and not August.
The initial August schedule was loaded a couple of weeks ago and there were some recent reductions from that (1,000 flight increase from July now reduced to 500 flights over July), but for example BOS-SFO. That was definitely NOT in the original August schedule that came out a couple of weeks ago. It can't be reduced now if it was already removed a couple of weeks ago.
Chuska
Tue Jul 21, 2020 6:56 pm
I'm guessing these are all a misfile for Cape Air as they are all EAS markets. Anyone have more info?
Thanks Enilria. I've always liked the song "Tuesday Afternoon" by the Moody Blues. Works for me.
clrd4t8koff
Tue Jul 21, 2020 7:03 pm
That's interesting. TLH was one of the stations 3M was pulling out of. Guess they decided TLH was warranted?
https://www.usatoday.com/story/travel/a ... 281252002/
LotsaRunway
Is DL stopping PVD flights again?
jonair8
Tue Jul 21, 2020 7:47 pm
It was something I looked forward to on Sundays, but even if it is on Tuesday or Wednesday, thank you for making these threads. Very valuable data here that cannot as easily be found anywhere else. Keep up the good work.
PVD757
Tue Jul 21, 2020 7:48 pm
Yes, the hiatus was extended through 9/30.
FSDan
Tue Jul 21, 2020 7:57 pm
How did this one sneak in there? I had to look up SCR and it looks like it's Scandinavia Mountains Airport in Sweden?
This is my signature until I think of a better one.
kavok
Tue Jul 21, 2020 8:06 pm
To state the obvious, we are seeing the domestic schedule changes for August and now September in these threads. And while all very interesting, I will be more curious to see which legacy puts out their updated October domestic schedule first.
As we all know, the CARES act required service be maintained by carriers to most markets until Oct 1. But post Oct 1, carriers are free to drop stations from the schedule as they please. So I will be curious to see if there are massive station drops in October, by whom, and to what degree... or if the schedules in October look more similar to September. There is still probably a few weeks to go before October schedules come out... but then things could get very interesting. As a fan on the industry, I am hoping for the best.
clrd4t8koff
Tue Jul 21, 2020 8:27 pm
Wonder if PVD will lose service all together. If 10/1 airlines can drop stations as they please and DL has canceled services to PVD thru 9/30 then it looks like 10/1 will be the final nail in the coffin for DL @ PVD. I hope I’m wrong.
Acey559
Tue Jul 21, 2020 10:35 pm
Sad to see what appears to be a permanent cut of MLI-MSP. We have had MSP service as long as I can remember, from the Saab to the Avro RJ100. I’ll miss having that option.
In Dixie Land I'll take my stand to live and die in Dixie.
freakyrat
Tue Jul 21, 2020 11:22 pm
DL has not resumed a lot of MSP flying in the Midwest. SBN is normally 2 daily flights and is stuck at 0.
Dominion301
Tue Jul 21, 2020 11:32 pm
Definitely. AC will operate at most 1/4 of this transborder schedule. YYC and YOW transborder are both gone until at least Labour Day.
kavok
Tue Jul 21, 2020 11:42 pm
I think it is more to do with DL just offering a lot less service period. And for the smaller cities in the Midwest, that often means only MSP service or only DTW service, and not both. And logically, the small cities in the western Midwest tend to retain MSP, while those in the eastern Midwest retain DTW. Hence no MSP-SBN for now.
IPFreely
Tue Jul 21, 2020 11:44 pm
Is the SEA hub experiment over?
9 destinations wiped off the map:
And another 17 destinations reduced, some to less than 1 flight/day:
LotsaRunway
Tue Jul 21, 2020 11:46 pm
They could do that now if they wanted. It’s a Boston area airport that’s covered by service to Logan. I don’t think they really want to drop PVD permanently. It’s just an easy drop while their hands are bound.
Flflyer83
Tue Jul 21, 2020 11:51 pm
It’s been a few years since WN has served any of these markets.
MIflyer12
Wed Jul 22, 2020 12:02 am
I'm going to wonder out loud if the DOT will update its 4/7/20 Show Cause order to mandate service beyond 9/30/20. Stayed tuned thru 8/1/20.
VIII. DURATION
The Department tentatively determined that the Service Obligation imposed under this Order
would extend through September 30, 2020.37 The Department tentatively chose this date for the
initial term of the Service Obligation because carriers accepting financial assistance under the
CARES Act must maintain certain levels of employment until that date. The Department also
stated that if the Department finds that it is necessary to extend the Service Obligation, it would
notify covered carriers of that extension no later than August 1, 2020.
https://www.transportation.gov/sites/do ... 0FINAL.PDF
sprxUSA
Wed Jul 22, 2020 12:03 am
WN flew BOI-GEG up until this April, and continuously before that from 5/95. But it only lasts for Aug then gone 4 good after that.
Gem State Airlines..."we have a gem of an airline"
NWAESC
Wed Jul 22, 2020 12:04 am
Nice to see MDW opening back up!
"Nothing ever happens here, " I said. "I just wait."
acavpics
Wed Jul 22, 2020 12:13 am
Since when wasthe SEA hub an "experiment"?
Dieuwer
Wed Jul 22, 2020 12:17 am
I imagine plenty of these origination points can be served via DTW and MSP.
I mean, CVG-SEA-Asia can also be served CVG-DTW-Asia.
tphuang
Wed Jul 22, 2020 12:21 am
Not sure if this will show up here next week, but JonNYC just tweeted that another 10% cut for domestic flights is coming for AA in August. Bookings must be looking really bad right now.
kavok
Wed Jul 22, 2020 12:23 am
VIII. DURATION
Interesting. I was not aware of that clause. Is there any additional funds that must be provided to the airlines for extending the date, or could the DOT theoretically just extend the Service Obligation date indefinitely until the Covid situation goes away?
FlyPNS1
Wed Jul 22, 2020 12:31 am
AA had been the most aggressive of the legacies in adding capacity, so I would expect more cuts from them in particular. Their current August schedule was very aggressive and would only work if demand had kept rapidly rising, but that is no longer the case it seems.
alfa164
Wed Jul 22, 2020 12:57 am
AA took a chance and offered-up lots of flights, apparently hoping to grab a larger share of the market if travel resumed quickly. Now they face the possibility of their customers being p.o.'ed when those flights are cancelled. Some posters had predicted that already, and it probably stands a good chance to happen.
I'm going to have a smokin' hot body again!
I have decided to be cremated....
Cointrin330
Wed Jul 22, 2020 1:43 am
A bit surprising yes, but for the foreseeable future, there is not much to speak of in terms of traffic, given the pandemic situation generally, and more specifically, in the US, and the though to markets EK caters to. This also means ATH will have no link to the USA outside of the Summer travel season, where in a normal operating environment, DL is double daily from JFK, UA flies from EWR, and AA flies from PHL and ORD, with the recently announced JFK route to be added (possibly at the expense of PHL). And then there is DY, which in recent years, added up to four flights a week from JFK as well. Guessing EK will be parking a boatload of A380s for the long term and will need the 77W for other markets to cover.
JRL3289
Wed Jul 22, 2020 1:51 am
How can people be "p.o.'ed" when the bookings never materialize? If people need to fly, they'll be accommodated on the new schedule. Giveng the situation in the southern and western parts of the country, though, I don't think AA will hear any substantial amount of hemming and hawing about schedule cuts.
wedgetail737
Wed Jul 22, 2020 2:15 am
You beat me to it. Not that I would miss them if they left.
phxa340
Wed Jul 22, 2020 2:23 am
Am I missing something here but how is Delta able to manage only 3 daily flights between Atlanta and Phoenix ? That seems very low compared to similar sized cities.
Users browsing this forum: aschachter, Baidu [Spider], Bing [Bot], cs03, FLJ, fsx98, Google Adsense [Bot], hervebkk, Jose747, KliptWings, Majestic-12 [Bot], N14AZ, Nicknuzzii, Noshow, scbriml, SheikhDjibouti, SpoonNZ, TaromA380, windian425, wxtech, ZKCIF and 403 guests
