rph99
Weird Flight Plan? FDX 1311
Fri Jul 24, 2020 1:20 am
Was watching some flight activity on Flightradar24 and noticed a 757 from Denver to Memphis taking an interesting route to Memphis. No other flights headed to that part of country are following such a plan.
Thoughts?
https://flightaware.com/live/flight/FDX ... /KDEN/KMEM
joeblow10
Re: Weird Flight Plan? FDX 1311
Fri Jul 24, 2020 1:26 am
Thoughts?
No intel from me, but interestingly, looks like it did the exact same thing last Thursday
Dominion301
Fri Jul 24, 2020 1:31 am
joeblow10 wrote:
Thoughts?
There was a thread about these types of flights, including this particular flight about a week ago. It’s apparently a sweep flight to pick up any overflow cargo on the way to MEM or to cover IROPS. As such, it takes “the scenic route” to get there.
B6JFKH81
Fri Jul 24, 2020 1:34 am
Sweep flights discussed here:
viewtopic.php?f=3&t=1448621
BTVB6Flyer
It’s called a sweep route or sweep run. It purposely goes out of the way and over cities. So if they have to ‘divert’ and pick up packages from cities along the way from airports that have aircraft go tech, they can.
For example here they can hit PHX, ABQ, ELP, DFW/AFW, IAH, OKC, MSY etc leading all the way to MEM.
Pretty common and lots of threads about it here on A.net
slcguy
Mon Jul 27, 2020 7:18 pm
Flight 1311 has been known to divert as far west as SLC once in awhile! Usually operated by a 757 or maybe A306, now they may have 763 in the mix too on the sweep flights. Never seen DC/MD10 ,MD11 or 777 used on sweeps, probably too much airplane(expensive) to fly on long roundabout routes not knowing if they will be needed.
dfwjim1
Mon Jul 27, 2020 7:27 pm
Interesting discussion...is there an "assigned" crew that handles these type of flights or are they just randomly assigned to them?
slcguy
Mon Jul 27, 2020 7:33 pm
The flights are probably bid by pilot senority like any other, the pilots that want them get them. Sounds like a more fun day (or night in this case) than just routine out and backs from MEM.
mhockey31091
Tue Jul 28, 2020 1:18 am
I've been jumpseating on FedEx one night when the flight was a sweep flight, I think it was just the designated city pairing. I would assume they pick the flights with relatively light loads and those are the "lucky" crews.
aemoreira1981
Tue Jul 28, 2020 12:49 pm
FedEx sweep flights---in the event that one plane goes tech at an outstation, the sweep flight can divert to that airfield. The Boeing 757/767 or Airbus A300 are most ideal for sweep flights. UPS does something similar called "hot spares"...where aircraft are pre-flighted and fueled ahead of time, so that if a plane goes tech on the ground at an outstation, the spare is in the air within 30 minutes to rescue the packages.
ssteve
Tue Jul 28, 2020 4:23 pm
It really makes fiscal sense for this to loiter in the air and not on the ground? Must be a pretty tight window in which they determine whether it needs to divert.
wn676
Tue Jul 28, 2020 6:55 pm
I’m guessing that the cost of missing a delivery guarantee more than justifies the cost of flying an aircraft that is already carrying a revenue load on a more circuitous route, and also saves the time it would take to get a hot spare off the ground and to a station.
Tiny, unreadable text leaves ample room for interpretation.
