enilria
OAG Changes 8/4/2020:SEPTEMBER SLIDE;AA Drops LAX-YVR;AM Drops AUS;AS Adds SAN-SBA;
Tue Aug 04, 2020 11:48 am
FAQ
SOURCE: OAG
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
3E ATL-MKL OCT 0>0.8[0.9] NOV 0>0.9[0.8] JAN 0>0.8[0.9] FEB 0>0.9[0.8]
3E BRL-ORD OCT 0>1.7[2] NOV 0>1.7[2] DEC 0>1.7[2] JAN 0>1.7[2] FEB 0>1.7[2]
3E BRL-STL OCT 0>1.7[1.9] NOV 0>1.7[1.9] DEC 0>1.7[1.9] JAN 0>1.7[1.9] FEB 0>1.7[1.8]
9K ACK-BOS JUN 7>9[10]
9K ACK-HPN JUN 0>0.2[0.4]
9K ACK-HYA JUN 4>10[9]
9K AUG-BOS JUN 3>4[4]
9K BHB-BOS JUN 3>1.1[1.0]
9K BOS-MVY JUN 4>10[7]
9K BOS-PVC JUN 3>5[5]
9K BOS-RKD JUN 3>4[4]
9K HPN-MVY JUN 0>0.2[0.4]
9K HPN-PVC JUN 0>0.2[0.4]
**9K MBL-ORD OCT 0>2[0] NOV 0>2[0] DEC 0>2[0] JAN 0>2[0] FEB 0>2[0] MAR 0>2[0] APR 0>2[0] MAY 0>2[0] JUN 0>2[0]
9R BOG-HAY SEP 0.3>0[0] OCT 0.3>0[0] NOV 0.3>0[0] DEC 0.3>0[0] JAN 0.3>0[0] FEB 0.3>0[0] MAR 0.3>0[0] APR 0.3>0[0] MAY 0.3>0[0] JUN 0.3>0[0]
9X HNL-JHM SEP 3>2[0] OCT 3>2[0] NOV 3>2[1.9] DEC 3>2[3]
9X HNL-MKK OCT 13>12[0] NOV 13>12[0.1] DEC 13>12[0.0]
9X MKK-OGG OCT 11>9[0.4] NOV 11>9[0.1] DEC 11>9[0]
AA ABE-ORD SEP 1.7>1.0[2]
AA ABI-DFW SEP 6>5[7]
AA ABQ-DFW SEP 7>5[8]
AA ABQ-LAX SEP 2>0.7[3]
AA ABQ-ORD SEP 1.7>0.7[2]
AA ABQ-PHX SEP 3>2[4]
AA ACT-DFW SEP 5>3[5]
AA AGS-DCA SEP 0.7>0[0]
AA AGS-DFW SEP 1.7>1.0[1.0]
AA ALB-DCA SEP 3>0.9[4]
AA ALB-PHL SEP 5>3[5]
AA AMA-DFW SEP 7>5[7]
AA AMS-DFW OCT 0.2>0.7[0]
AA AMS-PHL OCT 0.8>0.3[1.0]
AA ANU-MIA SEP 1.0>0.8[1.0]
AA ART-PHL SEP 1.9>1.4[1.8]
AA ASE-DFW SEP 2.0>1.1[2]
AA ATL-CLT SEP 8>6[8]
AA ATL-DCA SEP 4>0.6[4]
AA ATL-DFW SEP 8>6[8]
AA ATL-LAX SEP 2>0[3]
AA ATL-LGA SEP 4>0[5] OCT 5>4[5]
AA ATL-MIA SEP 6>1.4[8] OCT 8>7[8]
AA ATL-ORD SEP 5>3[5]
AA ATL-PHL SEP 5>3[5]
AA ATL-PHX SEP 1.5>0.7[1.6]
AA AUA-MIA SEP 1.7>1.3[2]
AA AUS-BOS SEP 1.2>0[0]
AA AUS-CLT SEP 4>3[5]
AA AUS-DFW SEP 10>7[11] OCT 11>10[11]
AA AUS-JFK SEP 1.5>0[1.0]
AA AUS-LAX SEP 3>0.5[4]
AA AUS-MIA SEP 3>1.5[3]
AA AUS-ORD SEP 3>2[4]
AA AUS-PHL SEP 1.5>0.0[2]
AA AUS-PHX SEP 3>1.9[4]
AA AUS-SJC SEP 1.3>0[0]
AA AVL-CLT SEP 6>5[8]
AA AVL-LGA SEP 0.7>0[0.3]
AA AZO-ORD SEP 2>1.1[3]
AA BAQ-MIA SEP 0.7>0.5[0.9]
AA BDA-MIA SEP 0.7>0.5[1.0]
AA BDL-CLT SEP 5>3[6]
AA BDL-DCA SEP 5>0.8[6] OCT 6>5[6]
AA BDL-DFW SEP 1.7>0.3[1.9]
AA BDL-LAX SEP 0.7>0[0.9] OCT 0.9>0.7[0.8]
AA BDL-MIA SEP 1.0>0.3[1.0]
AA BDL-ORD SEP 4>2[4]
AA BDL-PHL SEP 5>3[5]
AA BFL-DFW SEP 1.7>1.0[1.0]
AA BFL-PHX SEP 3>1.9[3]
AA BGI-MIA SEP 0.7>0.5[2]
AA BGR-DCA SEP 3>1.2[3]
AA BGR-LGA SEP 0.7>0[1.1] OCT 0.2>0.0[1.1]
AA BGR-PHL SEP 4>3[5]
AA BHM-CLT SEP 6>4[7]
AA BHM-DCA SEP 2>0[3]
AA BHM-DFW SEP 6>4[5]
AA BHM-MIA SEP 1.7>1.3[2]
AA BHM-ORD SEP 1.7>1.4[1.8]
AA BHM-PHL SEP 2>0[3]
AA BMI-DFW SEP 1.7>1.0[1.6]
AA BMI-ORD SEP 2>0.7[3]
AA BNA-CLT SEP 8>6[8]
AA BNA-DCA SEP 4>1.0[6]
AA BNA-DFW SEP 8>6[7]
AA BNA-JFK SEP 1.5>0[2]
AA BNA-LAX SEP 1.5>0.7[1.9]
AA BNA-MIA SEP 3>1.5[2]
AA BNA-ORD SEP 7>3[9] OCT 9>7[9]
AA BNA-PHL SEP 5>3[5]
AA BOG-MIA SEP 1.5>1.0[3]
AA BOI-DFW SEP 1.9>3[3] OCT 2>3[3]
AA BOI-ORD SEP 1.0>0.6[1.0]
AA BOS-CLT SEP 8>6[9]
AA BOS-DCA SEP 12>4[11] OCT 14>12[12]
AA BOS-DFW SEP 7>4[6]
AA BOS-IND SEP 1.4>0[0]
AA BOS-JFK SEP 4>0[1.0] OCT 6>5[1.0]
AA BOS-LAX SEP 4>0.7[4] OCT 6>5[4]
AA BOS-LGA SEP 9>1.6[11] OCT 11>10[11]
AA BOS-MDT SEP 0.7>0[1.0]
AA BOS-MIA SEP 6>2.0[5] OCT 7>6[5]
AA BOS-ORD SEP 7>4[9] OCT 8>7[9]
AA BOS-PHL SEP 12>6[9] OCT 14>13[9]
AA BOS-PHX SEP 3>1.6[4]
AA BOS-RDU SEP 3>0[0] OCT 5>4[0]
AA BOS-ROC SEP 2>0[3]
AA BOS-SYR SEP 0.7>0[1.0]
AA BPT-DFW SEP 2>1.7[3]
AA BRO-DFW SEP 4>3[4]
AA BTR-CLT SEP 3>1.9[3]
AA BTR-DFW SEP 6>4[6]
AA BTV-CLT SEP 3>1.9[2.0]
AA BTV-DCA SEP 2>0.4[3]
AA BTV-ORD SEP 1.5>0.7[2.0] OCT 0.4>0.2[0.1]
AA BTV-PHL SEP 4>2[4]
AA BUF-CLT SEP 3>1.9[3]
AA BUF-DCA SEP 3>0.9[3]
AA BUF-PHL SEP 5>3[5]
AA BUR-DFW SEP 1.7>1.0[1.9]
AA BUR-PHX SEP 4>2[3]
AA BWI-CLT SEP 8>6[9]
AA BWI-JFK SEP 4>0[1.0] OCT 5>4[1.0]
AA BWI-MIA SEP 1.7>0.3[1.0]
AA BWI-ORD SEP 4>3[4]
AA BWI-PHL SEP 2>0[4]
AA BZE-MIA SEP 1.0>0.8[1.1]
AA CAE-CLT SEP 6>4[8]
AA CAE-DCA SEP 2>0[3]
AA CAE-DFW SEP 3>2[3]
AA CAE-LGA SEP 0.7>0[1.0]
AA CAE-MIA SEP 0.7>0[0]
AA CAE-PHL SEP 2>0.2[3]
AA CAK-DCA SEP 0.7>0[1.0]
AA CAK-LGA SEP 0.6>0[0.9]
AA CAK-ORD SEP 0.7>0[2.0]
AA CAK-PHL SEP 1.8>1.1[2.0]
AA CHA-CLT SEP 6>4[7]
AA CHA-DCA SEP 0.6>0[0.9]
AA CHA-DFW SEP 3>2[3]
AA CHO-CLT SEP 7>4[8]
AA CHO-LGA SEP 1.4>0[1.9]
AA CHO-ORD SEP 1.5>0.6[3]
AA CHO-PHL SEP 1.7>1.0[1.8]
AA CHS-CLT SEP 8>6[9]
AA CHS-DCA SEP 4>0.9[4]
AA CHS-DFW SEP 3>2[3]
AA CHS-LGA SEP 0.2>0[1.0]
AA CHS-MIA SEP 2>0.8[4]
AA CHS-PHL SEP 4>2[4]
AA CID-CLT SEP 3>1.9[2]
AA CID-DFW SEP 4>3[4]
AA CID-ORD SEP 5>3[5]
AA CLE-CLT SEP 6>5[7]
AA CLE-DCA SEP 3>0.8[3]
AA CLE-DFW SEP 4>3[5]
AA CLE-JFK SEP 1.5>0[1.0]
AA CLE-LGA SEP 3>0[3]
AA CLE-MIA SEP 1.5>0[2]
AA CLE-ORD SEP 6>3[7]
AA CLE-PHL SEP 5>2[5]
AA CLL-DFW SEP 4>3[4]
AA CLO-MIA SEP 0.7>0.5[1.0]
AA CLT-CMH SEP 7>5[8]
AA CLT-CVG SEP 6>5[7]
AA CLT-DAY SEP 6>4[6]
AA CLT-DCA SEP 8>6[9]
AA CLT-DEN SEP 5>4[6]
AA CLT-DFW SEP 10>9[10]
AA CLT-DTW SEP 5>4[6]
AA CLT-EWR SEP 8>5[8]
AA CLT-FAY SEP 5>4[7]
AA CLT-FLL SEP 6>5[7]
AA CLT-FLO SEP 3>1.9[4]
AA CLT-FWA SEP 2>3[2]
AA CLT-GCM SEP 0.5>0[0.7]
AA CLT-GNV SEP 4>3[4]
AA CLT-GSO SEP 8>6[9]
AA CLT-GSP SEP 7>6[9]
AA CLT-HPN SEP 3>0[4]
AA CLT-HTS SEP 2>1.4[3]
AA CLT-IAD SEP 6>3[7]
AA CLT-ILM SEP 8>6[9]
AA CLT-IND SEP 7>6[8]
AA CLT-ITH SEP 1.5>1.1[0]
AA CLT-JAN SEP 3>1.9[4]
AA CLT-JAX SEP 7>6[8]
AA CLT-JFK SEP 4>3[5]
AA CLT-LEX SEP 4>3[5]
AA CLT-LGA SEP 9>6[10]
AA CLT-LYH SEP 5>3[7]
AA CLT-MCI SEP 3>2[4]
AA CLT-MCO SEP 10>8[10]
AA CLT-MEM SEP 6>4[6]
AA CLT-MGM SEP 3>2[3]
AA CLT-MKE SEP 4>3[5]
AA CLT-MLB SEP 3>2[3]
AA CLT-MSN SEP 3>2.0[2]
AA CLT-MSP SEP 4>2[4]
AA CLT-MSY SEP 5>4[7]
AA CLT-MYR SEP 8>6[8]
AA CLT-OAJ SEP 5>4[6]
AA CLT-OMA SEP 3>1.9[3]
AA CLT-ORD SEP 9>7[10]
AA CLT-ORF SEP 7>6[8]
AA CLT-PGV SEP 3>2[5]
AA CLT-PHF SEP 5>3[6]
AA CLT-PIT SEP 8>6[9]
AA CLT-PVD SEP 5>3[5]
AA CLT-PWM SEP 3>2[2]
AA CLT-RDU SEP 8>6[9]
AA CLT-RIC SEP 7>6[8]
AA CLT-ROA SEP 7>5[8]
AA CLT-SAN SEP 3>2[4]
AA CLT-SAT SEP 3>2[4]
AA CLT-SAV SEP 8>6[8]
AA CLT-SBY SEP 3>2[2.0]
AA CLT-SDF SEP 7>5[8]
AA CLT-SEA SEP 3>1.2[3]
AA CLT-SFO SEP 4>3[5]
AA CLT-SGF SEP 3>2[4]
AA CLT-STL SEP 5>4[6]
AA CLT-SYR SEP 4>3[4]
AA CLT-TLH SEP 4>3[4]
AA CLT-TPA SEP 8>6[9]
AA CLT-TRI SEP 4>3[6]
AA CLT-TYS SEP 6>5[8]
AA CLT-XNA SEP 4>2[4]
AA CLT-YUL SEP 1.5>0[2]
AA CLT-YYZ SEP 4>1.7[5]
AA CMH-DCA SEP 3>0.9[5]
AA CMH-JFK SEP 1.5>0[1.0]
AA CMH-LAX SEP 0.7>0[1.6]
AA CMH-LGA SEP 4>0[6] OCT 5>4[6]
AA CMH-MIA SEP 3>1.5[4]
AA CMH-ORD SEP 7>4[9]
AA CMH-PHL SEP 6>3[6] OCT 7>6[6]
AA CMH-PHX SEP 1.5>0.7[1.7]
AA CMI-DFW SEP 1.7>0.3[2]
AA CMI-ORD SEP 4>1.9[6]
AA COS-DFW SEP 6>5[5]
AA COS-ORD SEP 0.9>0.5[1.0]
AA COU-DFW SEP 3>2[3]
AA COU-ORD SEP 2>1.5[3]
AA CRP-DFW SEP 7>5[8]
AA CRW-DCA SEP 0.7>0[1.0]
AA CRW-PHL SEP 0.7>0[1.0]
AA CTG-MIA SEP 0.7>0.5[1.0]
AA CUN-MIA SEP 3>2[5]
AA CUR-MIA SEP 0.7>0.5[1.0]
AA CVG-DCA SEP 2>1.0[3]
AA CVG-DFW SEP 5>4[5]
AA CVG-JFK SEP 0.7>0[1.0]
AA CVG-LGA SEP 1.4>0[1.9]
AA CVG-MIA SEP 2>0.8[3]
AA CVG-ORD SEP 6>3[7] OCT 7>6[7]
AA CVG-PHL SEP 5>1.7[5] OCT 6>5[5]
AA CWA-ORD SEP 2>1.6[3]
AA DAY-DCA SEP 3>0.7[4]
AA DAY-DFW SEP 4>3[4]
AA DAY-LGA SEP 2>0[3]
AA DAY-ORD SEP 4>1.6[5]
AA DAY-PHL SEP 3>2[5]
AA DCA-DFW SEP 9>6[9]
AA DCA-DSM SEP 1.4>0[1.8]
AA DCA-DTW SEP 2>0.9[3]
AA DCA-GRR SEP 1.5>0.9[1.8]
AA DCA-GSO SEP 1.9>0[3]
AA DCA-GSP SEP 1.9>0.4[3]
AA DCA-HPN SEP 3>0[4] OCT 5>4[4]
AA DCA-HSV SEP 3>0[3]
AA DCA-IND SEP 5>1.0[6] OCT 6>5[6]
AA DCA-JAN SEP 0.7>0[1.0]
AA DCA-JAX SEP 3>1.0[4]
AA DCA-JFK SEP 3>0[0.8]
AA DCA-LAN SEP 0.7>0[1.0]
AA DCA-LAS SEP 0.7>0[1.0]
AA DCA-LAX SEP 2.0>1.0[2]
AA DCA-LGA SEP 9>4[8] OCT 11>10[8]
AA DCA-LIT SEP 0.7>0[1.0]
AA DCA-MCI SEP 2>0.8[3]
AA DCA-MCO SEP 4>1.0[4]
AA DCA-MEM SEP 2>1.0[3]
AA DCA-MGM SEP 0.7>0[1.0]
AA DCA-MHT SEP 2>0.2[4]
AA DCA-MIA SEP 7>2[9] OCT 9>8[9]
AA DCA-MSP SEP 2>0.8[3]
AA DCA-MSY SEP 3>0.6[4]
AA DCA-MYR SEP 0.8>0.6[0.4]
AA DCA-OKC SEP 0.7>0[1.0]
AA DCA-ORD SEP 8>5[9]
AA DCA-ORF SEP 2>0.9[3]
AA DCA-PBI SEP 0.9>0.2[1.9]
AA DCA-PHX SEP 2>1.0[3]
AA DCA-PIT SEP 3>0.5[4]
AA DCA-PNS SEP 2>1.3[2]
AA DCA-PVD SEP 5>0.9[6] OCT 6>5[6]
AA DCA-PWM SEP 4>1.7[5]
AA DCA-RDU SEP 5>0[6] OCT 6>5[6]
AA DCA-ROC SEP 3>1.1[3]
AA DCA-SAV SEP 1.7>0.3[2]
AA DCA-SDF SEP 2>1.0[3]
AA DCA-SRQ SEP 1.0>0.8[1.0]
AA DCA-STL SEP 3>0[5]
AA DCA-SYR SEP 2>0.7[4]
AA DCA-TLH SEP 0.7>0[1.0]
AA DCA-TPA SEP 4>2[3]
AA DCA-TYS SEP 2>0[3]
AA DCA-XNA SEP 0.7>0[0.9]
AA DCA-YYZ SEP 1.4>0[1.9]
AA DEN-DFW SEP 11>8[9] OCT 12>11[10]
AA DEN-LAX SEP 3>1.7[3]
AA DEN-MIA SEP 1.7>0.8[2]
AA DEN-ORD SEP 4>1.7[5]
AA DEN-PHL SEP 2>1.0[3]
AA DEN-PHX SEP 3>2[3]
AA DFW-DSM SEP 5>4[3]
AA DFW-DTW SEP 5>4[5]
AA DFW-DUB SEP 0.8>0.4[0.9]
AA DFW-ELP SEP 8>6[9]
AA DFW-EWR SEP 4>2.0[5]
AA DFW-FSM SEP 4>3[5]
AA DFW-GGG SEP 2>1.7[3]
AA DFW-GNV SEP 1.6>1.0[2.0]
AA DFW-GPT SEP 3>2[3]
AA DFW-GRI SEP 3>1.9[2]
AA DFW-GRK SEP 6>5[7]
AA DFW-GRR SEP 3>1.9[3]
AA DFW-GSO SEP 3>2[2]
AA DFW-GSP SEP 3>1.9[3]
AA DFW-HOU SEP 8>6[8]
AA DFW-HRL SEP 3>2[3]
AA DFW-HSV SEP 5>4[5]
AA DFW-IAD SEP 2>1.5[4]
AA DFW-IAH SEP 9>6[9]
AA DFW-ICT SEP 6>5[7]
AA DFW-IND SEP 5>3[5]
AA DFW-JAN SEP 6>4[7]
AA DFW-JAX SEP 5>4[5]
AA DFW-JFK SEP 3>0[2]
AA DFW-JLN SEP 3>2[3]
AA DFW-LAS SEP 11>8[10] OCT 12>11[10]
AA DFW-LAX SEP 14>11[15] OCT 15>14[15]
AA DFW-LBB SEP 7>5[7]
AA DFW-LEX SEP 3>2[3]
AA DFW-LFT SEP 5>4[5]
AA DFW-LGA SEP 11>5[12] OCT 13>11[12]
AA DFW-LIT SEP 8>5[9]
AA DFW-MAF SEP 7>5[8]
AA DFW-MCI SEP 7>6[8]
AA DFW-MCO SEP 9>8[10]
AA DFW-MEM SEP 7>6[8]
AA DFW-MEX SEP 3>2[5]
AA DFW-MFE SEP 7>5[8]
AA DFW-MGM SEP 3>2[3]
AA DFW-MHK SEP 3>1.8[3]
AA DFW-MIA SEP 11>9[10]
AA DFW-MKE SEP 4>2[4]
AA DFW-MLU SEP 3>2.0[3]
AA DFW-MOB SEP 4>2[4]
AA DFW-MRY SEP 1.7>1.0[1.0]
AA DFW-MSN SEP 3>2[3]
AA DFW-MSP SEP 6>4[6]
AA DFW-MSY SEP 7>6[8]
AA DFW-OAX SEP 1.0>0.8[1.0]
AA DFW-OKC SEP 8>6[9]
AA DFW-OMA SEP 5>3[4]
AA DFW-ONT SEP 5>4[6]
AA DFW-ORD SEP 13>10[14]
AA DFW-ORF SEP 3>2.0[2]
AA DFW-PBI SEP 3>2[3]
AA DFW-PHL SEP 9>6[9] OCT 10>9[9]
AA DFW-PHX SEP 12>10[12]
AA DFW-PIT SEP 4>3[5]
AA DFW-PSP SEP 1.9>3[1.7] OCT 2>3[1.9]
AA DFW-RAP NOV 2>3[2.0] DEC 2>3[2]
AA DFW-RDU SEP 5>4[6]
AA DFW-RIC SEP 3>2[3]
AA DFW-ROW SEP 3>1.8[3]
AA DFW-RSW SEP 3>2[3]
AA DFW-SAF SEP 4>3[4]
AA DFW-SAN SEP 9>7[9]
AA DFW-SAT SEP 10>7[11]
AA DFW-SBP SEP 1.7>1.0[1.0]
AA DFW-SDF SEP 6>4[6]
AA DFW-SEA SEP 8>6[8]
AA DFW-SFO SEP 8>5[9]
AA DFW-SGF SEP 7>6[7]
AA DFW-SHV SEP 6>5[6]
AA DFW-SJC SEP 3>2[4]
AA DFW-SJT SEP 5>4[6]
AA DFW-SLC SEP 6>5[6]
AA DFW-SNA SEP 8>5[8]
AA DFW-SPS SEP 3>1.7[4]
AA DFW-STL SEP 7>5[8]
AA DFW-SUX SEP 0.7>0[0.9]
AA DFW-SWO SEP 2>1.7[3]
AA DFW-TLH SEP 3>2[3]
AA DFW-TPA SEP 7>6[6]
AA DFW-TRC SEP 0.7>0.5[2]
AA DFW-TRI SEP 1.7>1.0[1.8]
AA DFW-TUL SEP 8>6[9]
AA DFW-TUS SEP 6>5[6]
AA DFW-TXK SEP 3>2[4]
AA DFW-TYS SEP 5>3[4]
AA DFW-XNA SEP 8>6[9]
AA DFW-YUL SEP 0.7>0[1.0]
*AA DFW-YVR SEP 2>0.2[1.8] OCT 2>0[1.6] NOV 2>0[1.5] DEC 2>0[1.8]
AA DFW-YYZ SEP 2>0[3]
AA DSM-ORD SEP 5>3[7]
AA DSM-PHL SEP 1.5>0[1.0]
AA DTW-LGA SEP 3>0[4] OCT 5>4[4]
AA DTW-MIA SEP 1.5>0[1.7]
AA DTW-ORD SEP 5>3[7]
AA DTW-PHL SEP 5>2[5]
AA DTW-PHX SEP 1.9>1.2[1.6]
AA ELH-MIA SEP 0.7>0.1[0]
AA ELP-LAX SEP 2>0[3]
AA ELP-PHX SEP 4>3[5]
AA ERI-ORD SEP 0.7>0[1.0]
AA EVV-ORD SEP 1.5>0[2]
AA EWR-MIA SEP 3>1.5[3]
AA EWR-ORD SEP 5>3[6]
AA EWR-PHX SEP 3>0[3]
AA EYW-MIA SEP 3>1.6[5]
AA EYW-PHL SEP 0.3>1.0[0] OCT 0.8>1.0[0.1]
AA FAR-ORD SEP 3>1.7[1.9]
AA FAT-PHX SEP 4>3[5]
AA FLG-PHX SEP 3>2[4]
AA FLL-ORD SEP 1.5>0[0.0]
AA FLL-PHL SEP 4>3[3]
AA FNT-ORD SEP 3>1.5[4]
AA FPO-MIA SEP 0.7>0[1.1]
AA FWA-ORD SEP 3>1.6[4]
AA FWA-PHL SEP 1.7>1.0[1.0]
AA GCM-MIA SEP 0.7>0.5[1.5]
AA GEO-MIA SEP 0.7>0.5[1.0]
AA GGT-MIA SEP 0.7>0.5[0.8]
AA GJT-PHX SEP 2>1.7[3]
AA GND-MIA SEP 0.7>0[0.9]
AA GNV-MIA SEP 1.5>0.5[1.7]
AA GRB-ORD SEP 4>2[5]
AA GRR-ORD SEP 7>3[7] OCT 8>7[8]
AA GRR-PHL SEP 3>1.6[2]
AA GSO-LGA SEP 1.9>0[3]
AA GSO-MIA SEP 1.5>0.5[2]
AA GSO-ORD SEP 1.7>1.0[2]
AA GSO-PHL SEP 3>1.2[4]
AA GSP-MIA SEP 1.9>0.5[2]
AA GSP-ORD SEP 2>1.4[2]
AA GSP-PHL SEP 3>1.3[3]
AA GUA-MIA SEP 1.3>1.5[1.9]
AA GYE-MIA SEP 1.0>1.3[1.4]
AA HAV-MIA SEP 4>2[6]
AA HMO-PHX SEP 0.7>0.5[1.0]
AA HNL-LAX SEP 4>2[4]
AA HPN-ORD SEP 2>0[3] OCT 3>2[3]
AA HSV-ORD SEP 1.5>0.7[1.6]
AA IAD-LAX SEP 1.5>0[1.0]
AA IAH-LAX SEP 2>0.6[2]
AA IAH-MIA SEP 5>1.5[5] OCT 6>5[5]
AA IAH-ORD SEP 2>1.4[3]
AA IAH-PHL SEP 3>1.2[2]
AA IAH-PHX SEP 3>1.9[4]
AA ILM-LGA SEP 2>0[3]
AA ILM-ORD SEP 0.7>0.4[0.1]
AA ILM-PHL SEP 3>1.6[3]
AA IND-JFK SEP 0.7>0[1.0]
AA IND-LAX SEP 0.7>0[1.0]
AA IND-LGA SEP 1.5>0[2]
AA IND-MIA SEP 3>1.5[3]
AA IND-ORD SEP 6>3[8] OCT 8>7[8]
AA IND-PHL SEP 5>3[6]
AA ISP-PHL SEP 3>0.4[3]
AA JAC-ORD SEP 1.9>1.2[2.0] OCT 0.4>0.2[0.1]
AA JAX-MIA SEP 5>1.0[5] OCT 6>5[5]
AA JAX-ORD SEP 1.4>0[1.9]
AA JAX-PHL SEP 3>2.0[3]
AA JFK-LAS SEP 1.5>0[1.0]
AA JFK-LAX SEP 9>5[10] OCT 12>10[11]
AA JFK-MIA SEP 6>1.9[7] OCT 8>7[7]
AA JFK-ORD SEP 3>0[3]
AA JFK-ORF SEP 1.5>0[3]
AA JFK-PHL SEP 4>0[0] OCT 5>4[0]
AA JFK-PHX SEP 5>2[5]
AA JFK-PIT SEP 3>0[1.0]
AA JFK-RDU SEP 3>0[2]
AA JFK-RIC SEP 2>0[0]
AA JFK-SAN SEP 0.7>0[0]
AA JFK-SAT SEP 0.7>0[1.0]
AA JFK-SFO SEP 4>1.8[5]
AA JFK-YUL SEP 1.5>0[1.0]
AA JFK-YYZ SEP 1.5>0[2]
AA JLN-ORD SEP 1.5>0[2]
AA KIN-MIA SEP 2.0>1.5[3]
AA KOA-PHX SEP 1.0>0[0.7]
AA LAS-LAX SEP 6>2[7] OCT 7>6[7]
AA LAS-MIA SEP 3>1.4[1.1]
AA LAS-ORD SEP 4>2[5]
AA LAS-PHL SEP 3>1.6[4]
AA LAS-PHX SEP 5>3[5]
AA LAX-LIH SEP 1.7>1.0[1.7]
AA LAX-MCO SEP 2>0[2]
AA LAX-MEX SEP 0.7>0.5[1.0]
AA LAX-MIA SEP 8>5[7]
AA LAX-MSY SEP 1.5>0[0.9]
AA LAX-OGG SEP 2>1.0[2]
AA LAX-OKC SEP 1.5>0[2]
AA LAX-OMA SEP 1.5>0[1.9]
AA LAX-ORD SEP 8>5[10]
AA LAX-PDX SEP 2>0.7[3]
AA LAX-PHL SEP 6>3[6] OCT 7>6[6]
AA LAX-RDU SEP 0.7>0[1.0]
AA LAX-RNO SEP 4>0[4] OCT 5>4[4]
AA LAX-SAN SEP 4>0[5] OCT 1.2>0[5]
AA LAX-SAT SEP 2>0[3]
AA LAX-SDF SEP 0.7>0[0.9] OCT 0.2>0[0.8]
AA LAX-SEA SEP 3>1.5[4]
AA LAX-SFO SEP 6>3[7] OCT 8>7[7]
AA LAX-SJC SEP 4>0[5] OCT 6>5[5]
AA LAX-SLC SEP 3>0.7[3]
AA LAX-SMF SEP 3>0[4]
AA LAX-STL SEP 1.5>0[1.6]
AA LAX-STS SEP 0.7>0[1.0]
AA LAX-TUL SEP 0.7>0[1.0]
AA LAX-TUS SEP 2>0[3]
AA LAX-XNA SEP 1.5>0[1.9]
**AA LAX-YVR SEP 2>0[2] OCT 3>0[2] NOV 3>0[1.9] DEC 3>0[2] JAN 2>0[2] FEB 2>0[1.9] MAR 2>0[2.0] APR 2>0[0] MAY 2>0[0]
AA LBB-PHX SEP 0.7>0[1.0]
AA LEX-ORD SEP 3>2.0[3]
AA LEX-PHL SEP 2>1.0[3]
AA LGA-MCO SEP 1.5>0[1.0]
AA LGA-MEM SEP 1.4>0[1.7]
AA LGA-MIA SEP 10>3[12] OCT 12>10[12]
AA LGA-MSP SEP 1.9>0[1.9]
AA LGA-OKC SEP 0.7>0[0]
AA LGA-ORD SEP 10>5[12] OCT 12>11[12]
AA LGA-ORF SEP 3>0[4]
AA LGA-PHL SEP 3>0.0[4]
AA LGA-PIT SEP 4>0[6] OCT 6>5[6]
AA LGA-PWM SEP 1.5>0[1.1]
AA LGA-RDU SEP 5>0[7] OCT 6>5[7]
AA LGA-RIC SEP 2.0>0[4]
AA LGA-ROA SEP 0.7>0[1.0]
AA LGA-SDF SEP 1.3>0[1.7]
AA LGA-STL SEP 3>0[4]
AA LGA-TYS SEP 1.5>0[1.9] OCT 0.4>0[1.9]
AA LGA-XNA SEP 1.3>0[1.7]
AA LGA-YUL SEP 2>0[3]
AA LGA-YYZ SEP 3>0[4]
AA LGB-PHX SEP 2>1.7[3]
AA LIH-PHX SEP 0.7>0[0.7]
AA LIM-MIA SEP 1.7>0.8[2]
AA LIR-MIA SEP 1.0>0.5[1.0]
AA LSE-ORD SEP 3>2[3]
AA MBJ-MIA SEP 1.7>1.3[2]
AA MCI-MIA SEP 1.5>0[2]
AA MCI-ORD SEP 6>3[7] OCT 7>6[7]
AA MCI-PHL SEP 3>1.2[2]
AA MCO-MIA SEP 10>3[6] OCT 12>10[7]
AA MCO-ORD SEP 3>1.4[4]
AA MCO-PHL SEP 8>6[6]
AA MCO-PHX SEP 3>1.2[1.6]
AA MDE-MIA SEP 0.7>0.5[1.1]
AA MDT-ORD SEP 3>2[4]
AA MDT-PHL SEP 5>2[5]
AA MEM-MIA SEP 1.7>0.8[2]
AA MEM-ORD SEP 4>3[4]
AA MEM-PHL SEP 2>0[2.0]
AA MEM-PHX SEP 1.5>0.7[1.9]
AA MEX-MIA SEP 3>2[4]
AA MEX-PHX SEP 0.7>0.4[1.0]
AA MGA-MIA SEP 1.0>0[1.0]
AA MHT-PHL SEP 5>2[6]
AA MIA-MSP SEP 1.7>0.3[2.0]
AA MIA-MSY SEP 3>1.5[4]
AA MIA-MTY SEP 1.0>0.8[1.0]
AA MIA-NAS SEP 3>1.0[6]
AA MIA-OKC SEP 0.7>0[0]
AA MIA-ORD SEP 8>4[9] OCT 9>8[9]
AA MIA-ORF SEP 3>1.5[4]
AA MIA-PAP SEP 1.0>0.8[1.0]
AA MIA-PHL SEP 5>3[6]
AA MIA-PHX SEP 3>2[3]
AA MIA-PIT SEP 3>1.5[3]
AA MIA-PLS SEP 1.0>0.8[2]
AA MIA-PNS SEP 3>1.0[3]
AA MIA-POP SEP 1.0>0.8[1.0]
AA MIA-POS SEP 0.7>0[2]
AA MIA-PTY SEP 0.7>0.5[2]
AA MIA-PUJ SEP 1.0>0.8[1.1]
AA MIA-RDU SEP 4>1.5[3]
AA MIA-RIC SEP 1.7>0.8[2]
AA MIA-SAN SEP 0.7>0[1.0]
AA MIA-SAP SEP 1.0>0.8[1.1]
AA MIA-SAT SEP 1.0>0.3[1.0]
AA MIA-SAV SEP 2>0.8[2]
AA MIA-SDF SEP 1.7>0.8[2]
AA MIA-SDQ SEP 3>2[4]
AA MIA-SEA SEP 0.7>0[0.8]
AA MIA-SFO SEP 3>0.8[3]
AA MIA-SJO SEP 2>0.5[2]
AA MIA-STI SEP 1.0>0.8[1.0]
AA MIA-STL SEP 1.5>0[3]
AA MIA-SXM SEP 1.0>0.8[1.0]
AA MIA-TGU SEP 1.0>0.8[1.0]
AA MIA-TLH SEP 3>0.8[3]
AA MIA-TPA SEP 6>2[5] OCT 8>7[5]
AA MIA-TYS SEP 1.5>0[2]
AA MIA-UIO SEP 1.0>0.8[2]
AA MIA-UVF SEP 0.9>0.7[1.0]
AA MIA-XNA SEP 0.7>0[0]
AA MIA-YUL SEP 0.7>0[1.0]
AA MIA-YYZ SEP 2>0[3]
AA MKE-ORD SEP 4>3[4]
AA MKE-PHL SEP 4>2[3]
AA MKE-PHX SEP 1.7>1.0[1.7]
AA MSN-ORD SEP 5>3[6]
AA MSN-PHL SEP 1.7>0.3[1.6]
AA MSP-ORD SEP 6>3[6]
AA MSP-PHL SEP 3>1.9[3]
AA MSP-PHX SEP 3>1.9[3]
AA MSY-PHL SEP 2>1.0[3]
AA MYR-PHL SEP 3>1.7[1.7]
AA OKC-ORD SEP 3>1.6[3]
AA OMA-ORD SEP 5>3[5]
AA OMA-PHL SEP 1.7>0.2[1.0] OCT 1.8>1.4[1.0]
AA ONT-PHX SEP 4>3[5]
AA ORD-ORF SEP 3>1.5[2]
AA ORD-PBI SEP 0.7>0[1.0]
AA ORD-PHL SEP 11>8[8] OCT 12>11[9]
AA ORD-PHX SEP 8>6[9]
AA ORD-PIA SEP 3>1.9[3]
AA ORD-PIT SEP 5>2[6]
AA ORD-PVD SEP 2>1.4[3]
AA ORD-RAP SEP 1.2>1.7[1.0]
AA ORD-RDU SEP 5>2[5]
AA ORD-RIC SEP 3>1.7[4]
AA ORD-RNO SEP 1.6>0.5[2.0]
AA ORD-ROC SEP 4>3[4]
AA ORD-SAN SEP 3>2[5]
AA ORD-SAT SEP 2>1.1[1.9]
AA ORD-SCE SEP 1.5>1.1[2.0]
AA ORD-SDF SEP 4>2[5]
AA ORD-SEA SEP 5>2[4]
AA ORD-SFO SEP 4>2[5]
AA ORD-SGF SEP 4>3[5]
AA ORD-SLC SEP 3>1.8[3]
AA ORD-SMF SEP 0.4>0.7[1.0]
AA ORD-SNA SEP 4>2[4]
AA ORD-STL SEP 5>3[6]
AA ORD-TOL SEP 2>1.3[3]
AA ORD-TPA SEP 2>1.0[2]
AA ORD-TUL SEP 3>0.9[3]
AA ORD-TUS SEP 1.5>0.4[1.7]
AA ORD-TVC SEP 6>3[5]
AA ORD-TYS SEP 3>2[3]
AA ORD-XNA SEP 5>2[5]
AA ORD-YUL SEP 1.5>0[2.0]
AA ORD-YYC SEP 0.7>0[1.1]
AA ORD-YYZ SEP 4>1.0[5]
AA ORF-PHL SEP 5>3[6]
AA PBI-PHL SEP 5>3[3]
AA PDX-PHX SEP 3>1.9[3]
AA PHF-PHL SEP 3>1.6[3]
AA PHL-PHX SEP 6>4[7]
AA PHL-PIT SEP 5>4[5]
AA PHL-PVD SEP 4>3[5]
AA PHL-PWM SEP 5>2[4]
AA PHL-RDU SEP 6>3[6] OCT 7>6[6]
AA PHL-RIC SEP 6>3[6] OCT 7>6[6]
AA PHL-ROC SEP 5>2[5]
AA PHL-RSW SEP 5>3[3]
AA PHL-SAN SEP 2>1.4[2]
AA PHL-SAV SEP 3>1.5[3]
AA PHL-SBY SEP 3>1.8[4]
AA PHL-SCE SEP 4>1.9[4]
AA PHL-SDF SEP 3>1.1[3]
AA PHL-SEA SEP 2>0.7[2]
AA PHL-SFO SEP 4>1.3[4]
AA PHL-STL SEP 4>2[4]
AA PHL-SWF SEP 3>2[4]
AA PHL-SYR SEP 4>2[5]
AA PHL-TPA SEP 6>5[4]
AA PHL-TYS SEP 3>1.5[3]
AA PHL-YUL SEP 4>1.9[4]
AA PHL-YYZ SEP 4>1.9[5]
AA PHX-PSP SEP 4>3[5]
AA PHX-RDU SEP 0.7>0[1.0]
AA PHX-ROW SEP 0.7>0[1.0]
AA PHX-SAF SEP 0.7>0[1.7]
AA PHX-SAN SEP 5>3[5]
AA PHX-SAT SEP 3>1.9[4]
AA PHX-SBA SEP 4>3[4]
AA PHX-SEA SEP 3>1.7[3]
AA PHX-SFO SEP 4>2[4]
AA PHX-SJC SEP 4>2[4]
AA PHX-SLC SEP 4>3[4]
AA PHX-SMF SEP 4>3[4]
AA PHX-SNA SEP 4>2[5]
AA PHX-TUS SEP 5>4[7]
AA PHX-YUM SEP 3>1.7[4]
AA PHX-YVR SEP 0.7>0[1.0] OCT 0.2>0[1.0]
AA PIT-RDU SEP 0.7>0[1.0]
AF ATL-CDG SEP 1.4>1.0[2] OCT 1.5>1.2[2]
AF CDG-JFK SEP 3>2[4]
**AM AUS-MEX DEC 0.4>0[0.9] JAN 0.9>0[0.9] FEB 0.9>0[0.9] MAR 0.8>0[0.8] APR 0.9>0[0.7] MAY 0.9>0[0] JUN 0.8>0[0]
AM BJX-DTW SEP 0.9>0[0.7]
AM DFW-MEX SEP 1.0>0[1.0]
AM DTW-MTY SEP 1.0>0[1.0]
AM DTW-QRO SEP 0.9>0[0.7]
AM GDL-ORD SEP 0.4>0[1.0]
AM GDL-SFO SEP 0.4>0[0.9]
AM GDL-SLC SEP 1.0>0[1.0]
AM IAH-MEX SEP 3>1.0[3]
AM JFK-MTY SEP 1.0>0[1.0]
AM LAS-MEX SEP 1.0>0.3[1.3]
AM LAS-MTY SEP 0.3>0[0.4]
AM LAX-MTY SEP 1.0>0[1.0]
AM MCO-MEX SEP 1.3>0.5[1.2]
AM MEX-MIA SEP 3>0.8[2]
AM MEX-SFO SEP 2>0.7[2]
AS ANC-SCC SEP 1.7>3[2] OCT 1.4>3[3] NOV 1.3>2[2] DEC 1.3>3[2] JAN 1.3>2[3] FEB 1.4>3[2] MAR 1.4>3[2] APR 1.4>3[3] MAY 1.3>2[1.8] JUN 1.4>3[2]
**AS SAN-SBA NOV 0>0.4[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0]
AS SEA-SUN SEP 0.7>0.5[0.6]
AY HEL-JFK SEP 0.6>0[1.0]
AZ BOS-FCO SEP 1.0>0.3[1.0]
AZ FCO-JFK SEP 3>1.0[3]
AZ JFK-MXP SEP 1.0>0.4[1.0]
B5 MDR-WIL SEP 2>0[0] OCT 2>0[0] NOV 2>0[0] DEC 2>0[0] JAN 2>0[0] FEB 2>0[0] MAR 2>0[0] APR 2>0[0] MAY 2>0[0]
B6 ABQ-JFK SEP 0.5>0[0.8]
B6 ACK-BOS SEP 1.0>0.4[0.8]
B6 ACK-LGA SEP 0.4>0.1[0.2]
B6 ALB-MCO SEP 0.6>0.3[1.0]
B6 ATL-BOS SEP 2>1.3[4]
B6 AUA-BOS SEP 1.2>0.5[1.4]
B6 AUA-FLL SEP 0.4>0[1.0]
B6 AUA-JFK SEP 1.8>1.1[1.7]
B6 AUS-BOS SEP 1.4>0.7[1.7]
B6 AUS-JFK SEP 1.0>0.5[1.9]
B6 BDL-FLL SEP 1.7>0.5[1.6]
B6 BDL-MCO SEP 1.3>0.7[3]
B6 BDL-PBI SEP 0.6>0[1.4]
B6 BDL-SJU SEP 1.7>0.7[1.1]
B6 BGI-JFK SEP 1.0>0.6[1.7]
B6 BNA-BOS SEP 1.4>0.5[3]
B6 BOS-BUF SEP 1.0>0.5[4]
B6 BOS-BWI SEP 1.0>0[5]
B6 BOS-CHS SEP 1.4>0.9[3]
B6 BOS-CLT SEP 1.2>0.9[3]
B6 BOS-DCA SEP 4>3[13]
B6 BOS-DEN SEP 1.5>1.0[1.9]
B6 BOS-DFW SEP 1.5>0.9[1.9]
B6 BOS-DTW SEP 1.2>0.9[3]
B6 BOS-EWR SEP 1.6>0.9[6]
B6 BOS-JAX SEP 1.0>0.5[3]
B6 BOS-JFK SEP 4>3[6]
B6 BOS-LGA SEP 3>0[5]
B6 BOS-MCO SEP 4>1.7[6]
B6 BOS-MSP SEP 1.0>0.5[3]
B6 BOS-MSY SEP 1.0>0.4[1.9]
B6 BOS-MVY SEP 0.9>0.1[0.6]
B6 BOS-ORD SEP 3>2[5]
B6 BOS-PBI SEP 1.7>1.0[3]
B6 BOS-PDX SEP 0.5>0.3[1.1]
B6 BOS-PHL SEP 1.8>1.0[7]
B6 BOS-PHX SEP 0.7>0.4[1.0]
B6 BOS-PIT SEP 2>0.9[6]
B6 BOS-RDU SEP 3>1.9[6]
B6 BOS-RIC SEP 1.0>0.5[4]
B6 BOS-ROC SEP 0.5>0.3[1.0]
B6 BOS-RSW SEP 1.9>1.0[3]
B6 BOS-SAN SEP 2>1.4[3]
B6 BOS-SAV SEP 1.4>0.7[1.6]
B6 BOS-SDQ SEP 1.7>1.0[2]
B6 BOS-SEA SEP 2>0.9[1.9]
B6 BOS-SJC SEP 0.5>0[0.8]
B6 BOS-SJU SEP 4.0>2.0[2.1]
B6 BOS-STI SEP 1.6>1.0[1.2]
B6 BOS-TPA SEP 2>1.4[4]
B6 BTV-JFK SEP 1.0>0.4[3]
B6 BUF-FLL SEP 0.4>0[0.8]
B6 BUF-JFK SEP 1.7>1.0[6]
B6 BUF-LAX SEP 0.4>0[0.7]
B6 BUF-MCO SEP 0.6>0[1.0]
B6 BUR-JFK SEP 0.5>0[1.6]
B6 BZN-JFK SEP 0.4>0.1[0]
B6 CHS-FLL SEP 0.4>0[1.0]
B6 CHS-JFK SEP 2>0.5[2]
B6 CUN-JFK SEP 2>1.0[1.9]
B6 CUN-MCO SEP 1.5>0.3[1.0]
B6 CUR-JFK SEP 0.3>0[0.3]
B6 DCA-FLL SEP 1.4>0.9[5]
B6 DCA-MCO SEP 1.0>0.5[4]
B6 DCA-MVY SEP 0.4>0.0[0]
B6 DCA-SJU SEP 1.0>0.6[1.0]
B6 DEN-JFK SEP 1.5>1.0[1.2]
B6 EWR-PBI SEP 1.0>0.4[2]
B6 EWR-SDQ SEP 2>1.4[1.0]
B6 EWR-SRQ SEP 1.0>0[0]
B6 FLL-HPN SEP 1.0>0[1.9]
B6 FLL-JAX SEP 1.0>0[3]
B6 FLL-JFK SEP 5>3[6]
B6 FLL-LAX SEP 3>1.5[3]
B6 FLL-LGA SEP 1.0>0.6[5]
B6 FLL-LIM SEP 0.6>0.3[1.0]
B6 FLL-ORD SEP 0.5>0.3[0.9]
B6 FLL-PHL SEP 1.0>0.4[1.9]
B6 FLL-PHX SEP 0.3>0[1.0]
B6 FLL-PLS SEP 0.3>0[1.0]
B6 FLL-POS SEP 0.3>0[0.6]
B6 FLL-PUJ SEP 0.4>0.1[1.1]
B6 FLL-PVD SEP 0.5>0.3[1.0]
B6 FLL-SAN SEP 0.4>0.1[0.6]
B6 FLL-SFO SEP 1.5>0.9[2]
B6 FLL-SJO SEP 0.7>0.4[1.0]
B6 FLL-SJU SEP 3.0>2.0[5]
B6 FLL-SLC SEP 0.5>0.3[0.8]
B6 FLL-SWF SEP 0.6>0[1.0]
B6 FLL-UIO SEP 0.5>0.3[1.1]
B6 GND-JFK SEP 0.9>0.4[0.9]
B6 HPN-MCO SEP 2.0>0[3]
B6 HPN-RSW SEP 0.6>0[1.0]
B6 HPN-TPA SEP 0.5>0[1.0]
B6 HYA-JFK SEP 1.0>0.1[0.1]
B6 JAX-JFK SEP 1.0>0.5[3]
B6 JFK-KIN SEP 2>1.1[3]
B6 JFK-LAS SEP 2>1.3[4]
B6 JFK-LAX SEP 6>4[11]
B6 JFK-LIR SEP 0.4>0[0.2]
B6 JFK-MCO SEP 4>2[8]
B6 JFK-MSY SEP 1.1>0.5[3]
B6 JFK-NAS SEP 1.0>0.4[1.2]
B6 JFK-ONT SEP 0.5>0[0.8]
B6 JFK-PBI SEP 3>1.0[4]
B6 JFK-PDX NOV 0.6>1.0[0.7] DEC 0.7>1.0[0.8] JAN 0.6>1.0[0.7] FEB 0.6>1.0[0.6] MAR 0.5>1.0[0.8] APR 0.5>0.9[0.7]
B6 JFK-PLS SEP 1.0>0.4[0.8]
B6 JFK-POP SEP 1.0>0.5[1.0]
B6 JFK-POS SEP 0.4>0.1[1.1]
B6 JFK-ROC SEP 2>1.0[3]
B6 JFK-RSW SEP 1.7>0.9[2]
B6 JFK-SAV SEP 1.5>0.7[2]
B6 JFK-SDQ SEP 5>4[6]
B6 JFK-SEA SEP 1.0>0.7[1.9]
B6 JFK-SFO SEP 4>3[6]
B6 JFK-SJC SEP 0.4>0[0.9] NOV 0.7>1.0[0.7] JAN 0.6>1.0[0.7] FEB 0.6>1.0[0.7] MAR 0.5>1.0[0.7] APR 0.5>0.9[1.0]
B6 JFK-SJO SEP 0.3>0[0]
B6 JFK-SJU SEP 4>2.9[5]
B6 JFK-SLC SEP 1.0>0.7[2]
B6 JFK-SMF SEP 0.4>0[1.0]
B6 JFK-SRQ SEP 0.8>0[1.0]
B6 JFK-STI SEP 6>4[6]
B6 JFK-SXM SEP 0.7>0.1[1.0]
B6 JFK-SYR SEP 1.0>0.5[2]
B6 JFK-TPA SEP 1.7>0.7[3]
B6 JFK-UVF SEP 1.1>0.3[1.0]
B6 LAS-LGB SEP 1.0>0[3]
B6 LAX-MCO SEP 0.5>0.1[0.6]
B6 LGA-MCO SEP 1.0>0.6[4]
B6 LGA-PBI SEP 0.5>0[3]
B6 LGA-RSW SEP 1.0>0[0]
B6 LGA-TPA SEP 1.0>0[0] NOV 3>2[0] DEC 3>2[0]
B6 LGB-PDX SEP 0.5>0[1.0]
B6 LGB-RNO SEP 0.5>0.3[1.0]
B6 LGB-SEA SEP 0.5>0[2]
B6 LGB-SLC SEP 2>0.5[3]
B6 MBJ-MCO SEP 0.9>0[1.1]
B6 MCO-NAS SEP 0.3>0[0.7]
B6 MCO-RIC SEP 1.0>0.7[1.0]
B6 MCO-SJO SEP 0.3>0[1.0]
B6 MCO-SJU SEP 5>3.0[6]
B6 MCO-SLC SEP 0.5>0.3[0.8]
B6 MCO-SWF SEP 0.4>0[1.0]
B6 MCO-SYR SEP 0.5>0[1.0]
B6 PVD-TPA NOV 1.5>1.0[0] DEC 1.5>1.0[0]
BA LGW-MCO SEP 1.9>1.0[1.9] NOV 1.0>0.8[1.2] DEC 1.0>0.4[1.0] JAN 1.0>0.4[1.0] FEB 1.0>0.4[1.0] MAR 1.1>0.6[1.1]
BA LGW-TPA SEP 1.0>0[1.0]
*BA LHR-MCO OCT 0>0.2[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0]
CX EWR-HKG SEP 0.8>0[0.9] OCT 0.9>0.2[0.9]
CX HKG-JFK SEP 3>1.8[3] OCT 4>3[3]
CX HKG-SEA SEP 0.6>0[1.0] OCT 0.7>0.2[0.8]
CX HKG-SFO SEP 3>0.7[3] OCT 3>1.5[3]
DL ABQ-LAX SEP 1.2>2[3]
DL ALB-ATL SEP 1.8>1.0[3]
DL ATH-JFK SEP 1.0>0[2.0]
DL ATL-BOG OCT 1.0>0.7[1.0] NOV 1.0>0.7[1.0]
DL ATL-ELP SEP 1.0>1.8[2]
DL ATL-EZE OCT 1.0>0.5[0.8] NOV 1.0>0.6[0.9]
DL ATL-GRU OCT 1.0>0.6[1.0] NOV 1.0>0.7[1.0]
DL ATL-LIM OCT 1.0>0.6[1.0] NOV 1.0>0.7[1.0]
DL ATL-LIR SEP 0.4>0.2[1.0]
DL ATL-SCL OCT 1.0>0.6[1.0] NOV 1.0>0.7[1.0]
DL ATL-SJO SEP 0.5>0.2[2]
DL ATL-STT OCT 2.2>3.0[0.8]
DL ATL-UIO OCT 1.0>0.4[1.0] NOV 1.0>0.4[1.0]
DL BNA-JFK SEP 1.0>0.8[3]
DL BNA-LGA SEP 1.2>2[5]
DL CUN-MCO JAN 0.1>1.0[1.0]
DL DTW-FWA SEP 3>2[3]
DL DTW-MQT SEP 1.8>1.0[1.9]
DL DTW-MTY OCT 0.9>0[1.0] NOV 0.9>0.3[0.8]
DL DTW-PDX SEP 1.0>0.6[1.4]
DL GRU-JFK OCT 1.0>0.5[1.0] NOV 1.0>0.6[1.0]
DL GSO-LGA SEP 0.9>0[4]
DL HNL-SLC SEP 0.4>0[0.8]
DL JFK-MEX SEP 1.0>3[2] OCT 1.0>3[2]
DL JFK-SLC SEP 4>3[4]
DL LAX-MEX SEP 1.0>3[4] OCT 1.0>3[4]
DL LAX-SJO OCT 0.9>0[0.8] NOV 1.0>0.3[0.9]
DL LGA-MSP SEP 4>3[6]
DL LGA-TPA SEP 1.5>1.0[4]
DL LWS-SLC SEP 3>2[3]
DL MEM-MSP SEP 1.0>1.8[3]
DL MSP-TPA SEP 1.0>0.6[1.7]
DL PHL-SLC SEP 1.0>0.7[0.9]
EI BNA-ORD JUN 1.0>0.8[0]
F4 CBA-CPX SEP 4>0[0] OCT 4>0[0] NOV 4>0[0] DEC 4>0[0] JAN 4>0[0] FEB 4>0[0] MAR 4>0[0] APR 4>0[0] MAY 4>0[0] JUN 4>0[0]
F4 CBA-VQS SEP 2.6>0[0] OCT 2.6>0[0] NOV 2.5>0[0] DEC 2.6>0[0] JAN 2.5>0[0] FEB 2.6>0[0] MAR 2.6>0[0] APR 2.6>0[0] MAY 2.5>0[0] JUN 2.6>0[0]
F9 ABQ-DEN SEP 0.3>0.1[0.5]
F9 ATL-EWR SEP 0.5>0[0]
F9 ATL-ISP SEP 0.3>0[0.6]
F9 ATL-LAS SEP 0.7>0.9[1.5]
F9 ATL-LGA SEP 0.7>0.5[1.0]
F9 ATL-MCO SEP 1.3>0.6[1.5]
F9 ATL-MIA SEP 1.2>0.6[0.4]
F9 ATL-RDU SEP 0.5>0[0]
F9 ATL-SLC SEP 0.3>0[0.6]
F9 ATL-TPA SEP 0.5>0[0]
F9 ATL-TTN SEP 0.5>0[1.0]
F9 AUS-LAS SEP 0.7>0.5[1.0]
F9 AUS-MCO SEP 0.5>0[0.6]
F9 AUS-ORD SEP 0.2>0[0.4]
F9 AUS-SAN SEP 0.3>0[0.6]
F9 AUS-TPA SEP 0.3>0[0.4]
F9 BDL-MCO SEP 0.2>0.0[0.5]
F9 BDL-RDU SEP 0.3>0[0.4]
F9 BNA-DEN SEP 0.7>0.5[1.0]
F9 BNA-ORD SEP 0.2>0[0.3]
F9 BOS-MCO SEP 0.7>0.5[1.0]
F9 BOS-MIA SEP 0.5>0[0]
F9 BOS-PHL SEP 0.3>0[0]
F9 BWI-MCO SEP 0.5>0.3[0.4]
F9 BWI-MIA SEP 0.5>0.3[0]
F9 CLE-DEN SEP 1.3>1.5[1.1]
F9 CLE-LAS SEP 1.3>1.5[1.0]
F9 CLE-RDU SEP 0.2>0[0.6]
F9 CLT-MCO SEP 0.6>0.2[0.6]
F9 CLT-TTN SEP 0.3>0[0.6]
F9 CUN-DEN SEP 0.6>0.2[0.6]
F9 CUN-EWR SEP 0.5>0[0]
F9 CVG-DFW SEP 0.5>0.3[0]
F9 CVG-MCO SEP 1.5>1.2[1.0]
F9 CVG-MIA SEP 0.3>0[0]
F9 DEN-DTW SEP 0.7>0.9[1.0]
F9 DEN-EWR SEP 0.8>0.6[0]
F9 DEN-IND SEP 0.7>0.5[1.0]
F9 DEN-MSP SEP 1.5>2[2]
F9 DEN-MSY SEP 0.7>0.5[1.0]
F9 DEN-ONT SEP 0.8>0.6[0.9]
F9 DEN-PDX SEP 1.5>1.0[2]
F9 DEN-PHL SEP 1.2>1.5[1.0]
F9 DEN-SMF SEP 0.7>0.5[0.6]
F9 DEN-STL SEP 1.0>0.6[1.9]
F9 DFW-MCO SEP 0.2>0[0.6]
F9 DTW-MIA SEP 0.2>0[0]
F9 EWR-MCO SEP 1.2>0.5[0]
F9 EWR-MIA SEP 0.5>0[0]
F9 EWR-ORD SEP 0.5>0.0[0]
F9 EWR-RDU SEP 0.3>0[0]
F9 EWR-TPA SEP 0.5>0[0]
F9 IAH-MCO SEP 0.2>0[0.4]
F9 ISP-MIA SEP 0.5>0[0]
F9 ISP-RDU SEP 0.3>0[0.4]
F9 LAS-LAX SEP 1.2>1.8[0.7]
F9 LAS-MCO SEP 0.6>1.0[1.2]
F9 LAS-ONT SEP 0.3>0[0]
F9 LAS-SAN SEP 0.8>1.0[0.9]
F9 LAS-SFO SEP 0.7>0.5[1.0]
F9 LAS-SJC SEP 0.7>0.5[0.9]
F9 LAS-SMF SEP 1.3>1.8[1.0]
F9 LAS-SNA SEP 0.7>0.5[0]
F9 LAX-PHX SEP 0.5>0.3[0]
F9 LGA-MCO SEP 0.5>0[0]
F9 MCO-MEM SEP 0.2>0[0.3]
F9 MCO-MSP SEP 0.2>0[0.9]
F9 MCO-ONT SEP 0.3>0[0.9]
F9 MCO-RDU SEP 0.6>0.2[1.0]
F9 MCO-SAT SEP 0.2>0[0.4]
F9 MIA-ORD SEP 0.3>0[0]
F9 MIA-RDU SEP 0.5>0[0]
F9 MIA-TTN SEP 0.2>0[0]
F9 MYR-TTN SEP 0.2>0[0.4]
F9 ORD-PHL SEP 0.3>0.0[0]
F9 ORD-TTN SEP 0.5>0[1.0]
F9 PHL-RDU SEP 0.7>0.3[0.4]
F9 PHX-SJC SEP 0.5>0[0]
F9 RDU-SYR SEP 0.2>0[0.4]
F9 RDU-TTN SEP 0.3>0[0.6]
F9 TPA-TTN SEP 0.3>0[0.6]
FJ LAX-NAN SEP 0.7>0[1.0]
FJ NAN-SFO SEP 0.3>0[0.4]
G3 FOR-MCO DEC 1.0>0[0]
G4 ABE-FLL SEP 0.3>0[0]
G4 ABQ-AUS SEP 0.3>0.1[0]
G4 ALB-MYR SEP 0.3>0.1[0.3]
G4 ALB-SFB SEP 0.3>0[0.3]
G4 AUS-AVL SEP 0.3>0.1[0]
G4 AUS-LAS SEP 0.3>0.1[0.4]
G4 AVL-DEN SEP 0.3>0.1[0.3]
G4 AVL-EWR SEP 0.5>0.3[0.6]
G4 AVL-FLL SEP 1.6>0.5[2]
G4 AVL-PIE SEP 1.0>0.5[1.4]
G4 AVL-SFB SEP 0.8>0.5[0.8]
G4 AZA-BOI SEP 0.3>0.1[0]
G4 AZA-FAR SEP 0.7>0.3[0.3]
G4 AZA-OAK SEP 0.3>0.1[0.3]
G4 AZA-TVC SEP 0.3>0.1[0]
G4 BLI-LAS SEP 1.5>0.6[2]
G4 BLV-VPS SEP 1.1>0.8[0.9]
G4 BNA-DSM SEP 0.3>0.1[0]
G4 BNA-MDT SEP 0.3>0.1[0.3]
G4 CVG-EWR SEP 0.3>0[0.3]
G4 CVG-LAX SEP 0.3>0.1[0.3]
G4 CVG-ORF SEP 0.3>0.1[0]
G4 CVG-VPS SEP 1.4>1.1[0.9]
G4 DSM-SFB SEP 0.3>0.1[0.3]
G4 EWR-SAV SEP 0.3>0[0.0]
G4 EWR-VPS SEP 0.3>0.1[0.3]
G4 FAT-LAS SEP 1.7>0.6[1.7]
G4 GRR-LAS SEP 0.5>0.3[0.6]
G4 GRR-PIE SEP 0.7>0.3[0.5]
G4 GRR-SFB SEP 0.5>0.3[0.7]
G4 GSO-SFB SEP 0.3>0.1[0.3]
G4 HOU-SAV SEP 0.3>0.1[0]
G4 HOU-VPS SEP 0.3>0.1[0]
G4 LAS-MEM SEP 0.8>0.5[0.3]
G4 LAS-MFE SEP 0.8>0.3[1.2]
G4 LAS-MFR SEP 0.5>0.3[0.3]
G4 LAS-OAK SEP 0.7>0.3[0.9]
G4 LAS-RNO SEP 1.1>0.5[1.0]
G4 LAS-SCK SEP 1.7>0.7[1.7]
G4 LAS-SMX SEP 0.6>0.3[0.6]
G4 LAX-TUL SEP 0.3>0.1[0.3]
G4 MDW-TYS SEP 0.3>0.1[0]
G4 MEM-PBI SEP 0.3>0[0]
G4 MSY-SDF SEP 0.2>0[0]
G4 MYR-SWF SEP 0.3>0.1[0.0]
G4 PBI-TYS SEP 0.3>0[0]
G4 SAV-SWF SEP 0.3>0[0]
G4 SFB-TYS SEP 1.0>0.5[1.3]
G4 SFB-USA SEP 0.5>0.3[0.8]
G4 SRQ-TYS SEP 0.3>0[0]
HZ RZH-VVO SEP 0.7>0[0] OCT 0.6>0[0]
J5 AGN-JNU SEP 0>1.4[1.1] OCT 0>1.3[0] NOV 0>1.3[1.0] DEC 0>1.3[0.6] JAN 0>1.3[1.0] FEB 0>1.3[1.0] MAR 0>1.3[1.0] APR 0>1.3[1.0] MAY 0>1.3[1.4] JUN 0>1.3[0.9]
J5 AGN-TKE SEP 0>0.5[1.1] OCT 0>0.4[0] NOV 0>0.4[1.0] DEC 0>0.4[0.6] JAN 0>0.4[1.0] FEB 0>0.4[1.0] MAR 0>0.4[1.0] APR 0>0.4[1.0] MAY 0>0.4[0.8] JUN 0>0.4[0]
J5 HNH-JNU SEP 1.5>2[4] OCT 1.0>1.9[0] NOV 1.0>1.8[3] DEC 1.0>1.9[3] JAN 1.0>1.8[3] FEB 1.0>1.9[3] MAR 1.0>1.9[4] APR 1.0>1.9[5] MAY 1.0>1.8[6] JUN 1.0>1.9[1.7]
J5 HNS-JNU OCT 1.0>4[0] NOV 1.0>4[3] DEC 1.0>4[3] JAN 1.0>4[3] FEB 1.0>4[3] MAR 1.0>4[3] APR 1.0>4[3] MAY 1.0>4[8] JUN 1.0>4[1.3]
J5 HNS-SGY SEP 0.5>1.4[0.1] OCT 0>0.9[0] NOV 0>0.8[1.0] DEC 0>0.9[1.0] JAN 0>0.8[1.0] FEB 0>0.9[1.0] MAR 0>0.9[1.0] APR 0>0.9[0.6] MAY 0>0.8[0.0] JUN 0>0.9[0.4]
J5 JNU-PEC SEP 0>0.7[0.9] OCT 0>0.7[0] NOV 0>0.7[0.8] DEC 0>0.7[0.8] JAN 0>0.7[0.8] FEB 0>0.7[0.9] MAR 0>0.7[0.8] APR 0>0.7[0.9] MAY 0>0.7[1.6] JUN 0>0.7[0.5]
J5 JNU-SGY SEP 1.0>1.4[5] OCT 0>0.9[0] NOV 0>0.8[3] DEC 0>0.9[3] JAN 0>0.8[3] FEB 0>0.9[3] MAR 0>0.9[3] APR 0>0.9[3] MAY 0>0.8[7] JUN 0>0.9[1.3]
J5 JNU-SIT OCT 0>1.9[0.5] NOV 0>1.8[1.9] JAN 0>1.8[1.9] FEB 0>1.9[2] MAR 0>1.9[2] APR 0>1.9[2] MAY 0>1.8[3] JUN 0>1.9[0.4]
J5 KAE-SIT OCT 0>0.9[0] NOV 0>0.8[1.0] DEC 0>0.9[1.0] JAN 0>0.8[1.0] FEB 0>0.9[1.0] MAR 0>0.9[1.0] APR 0>0.9[1.0] MAY 0>0.8[1.0] JUN 0>0.9[0]
J5 KLW-SIT OCT 0>1.0[0.5] NOV 0>1.0[0.5] MAY 0>1.0[2.0] JUN 0>1.0[0.4]
KAI KOA-OAK JUN 0>0.3[0]
KE BOS-ICN SEP 1.0>0.4[0.7]
KE DFW-ICN SEP 0.7>0.4[0.7]
KE HNL-ICN SEP 1.0>0[1.0]
KE HNL-NRT SEP 1.0>0.0[1.0]
KE IAD-ICN SEP 1.0>0.6[1.0]
KE ICN-JFK SEP 2.0>1.0[2]
KE ICN-LAS SEP 0.7>0[0.7]
KE ICN-LAX SEP 3>1.5[2]
KE ICN-ORD SEP 1.0>0.7[1.0]
KE ICN-SEA SEP 1.0>0.4[1.0]
KE ICN-SFO SEP 2>0.7[2]
LO BUD-JFK SEP 1.0>0[0.6] OCT 0.9>0.1[0.5]
LO EWR-WAW SEP 0.9>0[0.6] OCT 0.8>0.1[0.6]
LO IAD-WAW SEP 0.4>0[0] OCT 0.4>0.1[0]
LO JFK-WAW SEP 1.4>1.0[1.4]
LO KRK-ORD SEP 0.7>0.1[0.4] OCT 0.5>0.1[0.2]
LO LAX-WAW SEP 1.0>0[0.9] OCT 0.9>0.1[0.8]
LO MIA-WAW SEP 0.6>0[0.6] OCT 0.5>0.1[0.5]
LO ORD-WAW SEP 1.5>0.9[1.6] OCT 1.3>0.9[1.5]
LO SFO-WAW SEP 0.6>0[0] OCT 0.6>0.2[0]
NZ AKL-HNL SEP 0.7>0[0.7] OCT 0.7>0.1[0.6]
NZ AKL-IAH SEP 0.7>0[0.7] OCT 0.8>0.2[0.8]
NZ AKL-LAX SEP 2>1.0[1.9] OCT 2.0>1.2[1.9]
NZ AKL-ORD SEP 0.4>0[0.4] OCT 0.4>0.1[0.4]
NZ AKL-SFO SEP 0.7>0.4[0.7] OCT 0.7>0.5[0.7]
O2 ACK-HPN SEP 0>1.3[0] OCT 0>1.3[0] NOV 0>1.3[0] DEC 0>0.3[0]
O2 BOS-HPN SEP 0>0.6[0] OCT 0>0.5[0] NOV 0>0.6[0]
O2 HPN-MVY SEP 0>0.4[0] OCT 0>0.5[0] NOV 0>0.4[0]
O2 HPN-NPT SEP 0>0.3[0] OCT 0>0.3[0] NOV 0>0.3[0]
P2 KIS-MDR SEP 1.0>0[0] OCT 1.0>0[0] NOV 1.0>0[0] DEC 1.0>0[0] JAN 1.0>0[0] FEB 1.0>0[0] MAR 1.0>0[0] APR 1.0>0[0] MAY 1.0>0[0] JUN 1.0>0[0]
P2 MDR-WIL SEP 4>0[0] OCT 3>0[0] NOV 3>0[0] DEC 3>0[0] JAN 3>0[0] FEB 3>0[0] MAR 3>0[0] APR 3>0[0] MAY 3>0[0] JUN 3>0[0]
PD BOS-YTZ JUN 0>6[0.4]
PD EWR-YTZ JUN 0>12[0.8]
PD IAD-YTZ JUN 0>3[0.3]
PD MDW-YTZ JUN 0>5[0.3]
Q5 FAI-HKB SEP 0>0.7[0.4] OCT 0>0.6[0.4] NOV 0>0.7[0.4] DEC 0>0.6[0.4] JAN 0>0.6[0.5] FEB 0>0.6[0.4] MAR 0>0.7[0.4] APR 0>0.7[0.4] MAY 0>0.6[0.4] JUN 0>0.7[0.4]
Q5 HKB-TKJ SEP 0>0.2[0.4] OCT 0>0.2[0.4] NOV 0>0.2[0.4] DEC 0>0.2[0.4] JAN 0>0.2[0.5] FEB 0>0.2[0.4] MAR 0>0.2[0.4] APR 0>0.2[0.4] MAY 0>0.2[0.4] JUN 0>0.2[0.4]
RLI ACK-DXR SEP 0>0.2[0] OCT 0>0.2[0] NOV 0>0.2[0] DEC 0>0.2[0] JAN 0>0.2[0] FEB 0>0.2[0] MAR 0>0.2[0] APR 0>0.2[0] JUN 0>0.2[0]
SK CPH-SCR JAN 0.3>0[0] FEB 0.3>0[0] MAR 0.2>0[0]
SY BNA-LAX SEP 0.3>0[0.1]
SY BOS-MSN OCT 0.3>0[0]
SY BOS-MSP SEP 0.6>0.1[0.1]
SY BWI-MSP SEP 0.5>0.1[0]
SY EWR-MSN OCT 0.3>0[0]
SY EWR-MSP SEP 0.7>0.1[0.8]
SY LAS-MSP SEP 3>1.8[3]
SY LAX-MSP SEP 1.8>1.1[1.8]
SY MSP-ORD SEP 0.5>0.1[0.9]
SY MSP-PDX SEP 0.8>0.3[0.9]
SY MSP-PHX SEP 1.1>0.8[1.1]
SY MSP-PVD SEP 0.2>0[0.8]
SY MSP-SAN SEP 0.5>0.3[0.8]
SY MSP-SEA SEP 1.3>0.6[1.6]
SY MSP-SFO SEP 1.1>0.5[1.5]
TP BOS-PDL SEP 0.4>0.7[0]
TP EWR-LIS SEP 1.0>1.8[1.0]
TP EWR-OPO SEP 0.3>0.6[0.9]
TS FLL-YVR JAN 0.3>0[0.3] FEB 0.3>0[0.3] MAR 0.3>0[0.3] APR 0.3>0[0]
UA ABQ-DEN SEP 4>3[4]
UA ABQ-IAH SEP 4>1.9[4]
UA ABQ-ORD SEP 1.8>0.5[1.9]
UA ABQ-SFO SEP 1.6>0.7[2]
UA ACV-DEN SEP 0.8>0[1.0]
UA ACV-LAX SEP 1.8>1.0[2.0]
UA ACV-SFO SEP 3>2[3]
UA AEX-IAH SEP 2>0.9[3]
UA AGU-IAH SEP 1.5>1.0[2]
UA AKL-SFO SEP 0.3>0[0.4]
UA ALB-EWR SEP 2>0[4]
UA ALB-IAD SEP 3>1.9[3]
UA ALB-ORD SEP 4>1.6[4]
UA AMA-DEN SEP 1.8>1.0[1.8]
UA AMA-IAH SEP 2>1.8[3]
UA ANC-ORD SEP 0.8>0[1.0]
UA ASE-DEN SEP 6>4[6]
UA ASE-IAH SEP 0.7>0[1.0]
UA ASE-LAX SEP 0.8>0[1.1]
UA ATL-DEN SEP 4>3[4]
UA ATL-EWR SEP 7>3[6]
UA ATL-IAD SEP 4>1.9[4]
UA ATL-IAH SEP 6>3[7]
UA ATL-ORD SEP 7>3[6]
UA ATL-SFO SEP 1.7>0.0[1.7]
UA ATW-DEN SEP 0.8>0[1.0]
UA ATW-ORD SEP 9>4[5]
UA ATY-ORD SEP 0.9>0.7[1.0]
UA AUA-EWR SEP 1.3>0.7[2]
UA AUS-DEN SEP 5>3[5]
UA AUS-EWR SEP 4>0.7[4]
UA AUS-IAD SEP 3>1.0[3]
UA AUS-IAH SEP 8>3[9]
UA AUS-LAX SEP 1.5>0[1.9]
UA AUS-ORD SEP 4>3[4]
UA AUS-SFO SEP 4>1.0[4]
UA AVL-EWR SEP 0.8>0[1.0]
UA AVL-IAD SEP 3>1.8[2]
UA AVL-ORD SEP 4>2.0[4]
UA AVP-IAD SEP 2>0[2]
UA BDL-DEN SEP 1.8>1.0[1.0]
UA BDL-IAD SEP 4>1.9[4]
UA BDL-IAH SEP 1.5>0[1.0]
UA BDL-ORD SEP 4>3[4]
UA BFL-DEN SEP 1.7>1.0[2]
UA BFL-SFO SEP 1.0>0.7[1.0]
UA BGR-EWR SEP 1.5>0[3]
UA BGR-ORD SEP 1.8>1.0[2]
UA BHM-DEN SEP 1.8>1.0[2.0]
UA BHM-IAH SEP 5>3[5]
UA BHM-ORD SEP 3>1.5[4]
UA BIL-DEN SEP 4>2[4]
UA BIS-DEN SEP 3>2[4]
UA BIS-ORD SEP 1.5>0[2]
UA BJX-IAH SEP 4>2[4]
UA BNA-DEN SEP 4>3[4]
UA BNA-EWR SEP 5>1.7[7]
UA BNA-IAD SEP 3>1.6[3]
UA BNA-IAH SEP 5>3[6]
UA BNA-ORD SEP 7>4[7]
UA BNA-SFO SEP 1.4>0[1.7]
UA BOG-IAH SEP 1.5>0.6[2]
UA BOI-DEN SEP 5>3[4]
UA BOI-IAH SEP 1.5>0[1.0]
UA BOI-LAX SEP 1.7>0.6[2.0]
UA BOI-ORD SEP 3>1.9[2]
UA BOI-SFO SEP 5>3[5]
UA BOS-DEN SEP 4>3[5]
UA BOS-EWR SEP 10>2[11]
UA BOS-IAD SEP 4>1.9[4]
UA BOS-IAH SEP 3>1.9[4]
UA BOS-LAX SEP 1.7>0.5[2.0]
UA BOS-ORD SEP 7>4[8]
UA BOS-SFO SEP 6>2.0[6]
UA BRO-IAH SEP 4>3[5]
UA BRU-EWR SEP 0.9>0.4[1.0]
UA BRU-ORD SEP 0.9>0.6[1.0]
UA BTR-IAH SEP 6>3[7]
UA BTV-EWR SEP 3>0[6]
UA BTV-IAD SEP 4>1.9[3]
UA BTV-ORD SEP 4>1.5[4]
UA BUF-EWR SEP 5>1.0[7]
UA BUF-IAD SEP 4>1.9[3]
UA BUF-ORD SEP 4>2.0[5]
UA BUR-DEN SEP 3>1.0[3]
UA BUR-SFO SEP 5>1.0[5]
UA BWI-IAH SEP 1.7>1.0[3]
UA BWI-LAX SEP 0.8>0[1.0]
UA BWI-ORD SEP 4>2[3]
UA BWI-SFO SEP 1.7>0.6[1.7]
UA BZN-DEN SEP 3>2[4]
UA CAE-IAD SEP 3>1.6[3]
UA CAE-ORD SEP 2>1.9[3]
UA CAK-IAD SEP 2>0[0]
UA CAK-ORD SEP 4>1.9[5]
UA CHO-IAD SEP 3>1.6[3]
UA CHO-ORD SEP 3>1.0[2]
UA CHS-DEN SEP 0.8>0[1.0]
UA CHS-EWR SEP 4>1.6[4]
UA CHS-IAD SEP 3>1.9[3]
UA CHS-IAH SEP 1.8>1.0[2]
UA CHS-ORD SEP 3>1.6[3]
UA CID-DEN SEP 4>2[2]
UA CID-ORD SEP 7>3[5]
UA CLE-DEN SEP 4>2[3]
UA CLE-EWR SEP 7>1.6[7]
UA CLE-IAD SEP 4>1.9[4]
UA CLE-IAH SEP 4>1.9[5]
UA CLE-LAX SEP 1.5>0[2]
UA CLE-MCO SEP 0.8>0[1.0]
UA CLE-ORD SEP 8>4[8]
UA CLE-SFO SEP 1.0>0.7[1.1]
UA CLL-IAH SEP 2>1.8[3]
UA CLT-DEN SEP 1.8>1.0[2]
UA CLT-EWR SEP 5>2[6]
UA CLT-IAD SEP 4>1.8[4]
UA CLT-IAH SEP 3>1.9[5]
UA CLT-ORD SEP 4>1.8[5]
UA CMH-EWR SEP 7>1.7[7]
UA CMH-IAD SEP 4>1.6[4]
UA CMH-IAH SEP 3>1.9[4]
UA CMH-ORD SEP 7>4[7]
UA CMH-SFO SEP 0.8>0[1.0]
UA COD-DEN SEP 3>2[3]
UA COS-DEN SEP 8>3[9]
UA COS-IAH SEP 3>1.0[4]
UA COS-LAX SEP 1.5>0[2.0]
UA COS-ORD SEP 2>1.9[3]
UA COU-DEN SEP 0.8>0[1.0]
UA COU-ORD SEP 3>2.0[3]
UA CPR-DEN SEP 5>2[5]
UA CRP-IAH SEP 6>3[6]
UA CRW-ORD SEP 3>1.9[3]
UA CTU-SFO SEP 0.3>0[0.4]
UA CUN-DEN SEP 0.9>0.7[0.1]
UA CUN-EWR SEP 2>1.0[1.3]
UA CUN-IAH SEP 4>3[4]
UA CUN-LAX SEP 0.8>0.4[1.0]
UA CUN-ORD SEP 1.0>0.7[1.1]
UA CUN-SFO SEP 0.9>0.4[0.4]
UA CVG-EWR SEP 4>1.7[6]
UA CVG-IAD SEP 4>1.9[3]
UA CVG-IAH SEP 3>1.9[4]
UA CVG-ORD SEP 6>4[7]
UA CWA-ORD SEP 3>2.0[3]
UA DAY-DEN SEP 1.4>0[1.8]
UA DAY-IAD SEP 3>1.9[2]
UA DAY-ORD SEP 6>3[6]
UA DCA-EWR SEP 11>3[7]
UA DCA-IAH SEP 6>3[7]
UA DCA-ORD SEP 12>4[14]
UA DCA-SFO SEP 0.8>0[1.0]
UA DEN-DFW SEP 5>3[6]
UA DEN-DIK SEP 1.6>0.9[1.7]
UA DEN-DRO SEP 6>3[7]
UA DEN-DSM SEP 5>2[5]
UA DEN-DTW SEP 1.7>1.0[2]
UA DEN-EAR SEP 1.6>0.8[1.9]
UA DEN-EGE SEP 1.7>1.0[2.0]
UA DEN-ELP SEP 4>2[5]
UA DEN-EUG SEP 3>2[3]
UA DEN-EWR SEP 8>5[8]
UA DEN-FAR SEP 4>2[4]
UA DEN-FAT SEP 4>2[4]
UA DEN-FLG SEP 1.7>1.0[2]
UA DEN-FLL SEP 1.0>0.0[1.0]
UA DEN-FRA SEP 0.8>0[1.0]
UA DEN-FSD SEP 4>2[5]
UA DEN-GCC SEP 2>1.0[2]
UA DEN-GEG SEP 3>2[2]
UA DEN-GJT SEP 5>2[5]
UA DEN-GSP SEP 0.8>0[1.0]
UA DEN-GTF SEP 3>2[3]
UA DEN-HLN SEP 1.8>1.0[2]
UA DEN-HNL SEP 1.8>1.0[1.0]
UA DEN-HOB SEP 0.8>0[0]
UA DEN-HSV SEP 1.5>0[1.9]
UA DEN-IAD SEP 6>5[7]
UA DEN-IAH SEP 10>6[10]
UA DEN-ICT SEP 4>1.8[4]
UA DEN-IDA SEP 4>2[4]
UA DEN-IND SEP 3>2[3]
UA DEN-JAC SEP 4>2[4]
UA DEN-JAX SEP 0.8>0[1.0]
UA DEN-KOA SEP 0.9>0.4[1.0]
UA DEN-LAS SEP 5>1.8[6]
UA DEN-LAX SEP 7>5[8]
UA DEN-LBB SEP 1.7>1.0[1.8]
UA DEN-LGA SEP 6>3[7]
UA DEN-LIH SEP 0.9>0.6[1.0]
UA DEN-LIT SEP 3>1.0[3]
UA DEN-LNK SEP 3>1.0[3]
UA DEN-MAF SEP 4>1.8[4]
UA DEN-MCI SEP 5>2[5]
UA DEN-MCO SEP 3>2[3]
UA DEN-MEM SEP 3>1.0[3]
UA DEN-MFR SEP 3>2.0[3]
UA DEN-MKE SEP 3>2[3]
UA DEN-MLI SEP 1.4>0[2]
UA DEN-MOT SEP 3>1.9[3]
UA DEN-MRY SEP 1.8>1.0[2]
UA DEN-MSN SEP 3>2[3]
UA DEN-MSP SEP 4>3[4]
UA DEN-MSY SEP 1.8>1.0[3]
UA DEN-MTJ SEP 4>2[4]
UA DEN-NRT SEP 0.8>0[1.0]
UA DEN-OKC SEP 5>2[6]
UA DEN-OMA SEP 5>3[5]
UA DEN-ONT SEP 2>1.0[2.0]
UA DEN-ORD SEP 9>6[11]
UA DEN-ORF SEP 0.8>0[1.0]
UA DEN-PAE SEP 3>1.0[2]
UA DEN-PDX SEP 4>3[5]
UA DEN-PHL SEP 3>1.9[3]
UA DEN-PHX SEP 4>2[5]
UA DEN-PIT SEP 3>2.0[3]
UA DEN-PRC SEP 1.8>1.0[1.0]
UA DEN-PSC SEP 3>2[3]
UA DEN-PSP SEP 3>1.8[3]
UA DEN-RAP SEP 7>2[7]
UA DEN-RDM SEP 3>2[3]
UA DEN-RIC SEP 1.8>1.0[2]
UA DEN-RKS SEP 1.9>1.0[2]
UA DEN-RNO SEP 4>3[3]
UA DEN-RSW SEP 0.8>0[0]
UA DEN-SAF SEP 3>0.6[3]
UA DEN-SAN SEP 4>1.7[5]
UA DEN-SAT SEP 4>2.0[4]
UA DEN-SAV SEP 0.8>0[0]
UA DEN-SBA SEP 3>1.8[4]
UA DEN-SBP SEP 3>2.0[2]
UA DEN-SDF SEP 1.8>1.1[2]
UA DEN-SEA SEP 5>3[6]
UA DEN-SFO SEP 9>6[9]
UA DEN-SGF SEP 3>2[4]
UA DEN-SHR SEP 1.8>1.0[0]
UA DEN-SHV SEP 0.8>0[1.0]
UA DEN-SJC SEP 4>2[5]
UA DEN-SLC SEP 6>2[7]
UA DEN-SMF SEP 4>2[5]
UA DEN-SNA SEP 4>1.8[4]
UA DEN-STL SEP 5>3[5]
UA DEN-STS SEP 0.8>0[1.0]
UA DEN-SYR SEP 0.8>0[1.0]
UA DEN-TUL SEP 4>2[5]
UA DEN-TUS SEP 3>1.8[3]
UA DEN-TVC SEP 1.0>0.2[0.1]
UA DEN-TYS SEP 1.5>0[2.0]
UA DEN-XNA SEP 3>0[3]
UA DEN-XWA SEP 2>1.0[0]
UA DEN-YEG SEP 1.5>0[2]
UA DEN-YVR SEP 1.5>0[3]
UA DEN-YWG SEP 1.5>0[2]
UA DEN-YYC SEP 3>1.0[4]
UA DEN-YYZ SEP 1.4>0[2]
UA DFW-EWR SEP 6>1.6[5]
UA DFW-IAD SEP 3>1.0[3]
UA DFW-IAH SEP 7>3[8]
UA DFW-ORD SEP 6>4[7]
UA DFW-SFO SEP 3>1.0[4]
UA DLH-ORD SEP 3>2.0[4]
UA DSM-IAH SEP 2>1.0[3]
UA DSM-ORD SEP 5>4[6]
UA DTW-EWR SEP 6>3[7]
UA DTW-IAD SEP 4>1.9[3]
UA DTW-IAH SEP 4>1.9[5]
UA DTW-ORD SEP 7>3[8]
UA DTW-SFO SEP 0.8>0[1.0]
UA DUB-EWR SEP 0.9>0.6[1.0]
UA DUB-SFO SEP 0.8>0[0]
UA ELP-IAH SEP 4>3[6]
UA ELP-ORD SEP 1.8>0.5[1.0]
UA ERI-ORD SEP 2>1.9[2]
UA EUG-LAX SEP 1.5>0[1.8]
UA EUG-ORD SEP 0.8>0[1.0]
UA EUG-SFO SEP 4>2[4]
UA EVV-ORD SEP 3>1.9[3]
UA EWR-FLL SEP 5>3[6]
UA EWR-GRR SEP 3>0[4]
UA EWR-GRU SEP 0.9>0.4[1.0]
UA EWR-GSO SEP 3>0[4]
UA EWR-GSP SEP 2>0[3]
UA EWR-GUA SEP 0.8>0.6[0.1]
UA EWR-HAV SEP 0.8>0[1.0]
UA EWR-HKG SEP 0.8>0[1.0]
UA EWR-HND SEP 0.8>0[0]
UA EWR-HNL SEP 0.8>0[1.0]
UA EWR-IAD SEP 6>3[6]
UA EWR-IAH SEP 8>4[10]
UA EWR-IND SEP 6>1.7[6]
UA EWR-JAX SEP 4>1.7[4]
UA EWR-LAS SEP 6>1.0[7]
UA EWR-LAX SEP 10>4[11]
UA EWR-LHR SEP 5>1.0[5]
UA EWR-MBJ SEP 1.1>0.7[0.1]
UA EWR-MCI SEP 3>0[4]
UA EWR-MCO SEP 8>4[9]
UA EWR-MEM SEP 2>0[4]
UA EWR-MEX SEP 2>1.0[3]
UA EWR-MKE SEP 4>0[4]
UA EWR-MSN SEP 1.5>0[2]
UA EWR-MSP SEP 5>1.0[5]
UA EWR-MSY SEP 3>0.7[4]
UA EWR-MUC SEP 0.9>0.4[1.0]
UA EWR-NAS SEP 1.0>0[1.0]
UA EWR-OKC SEP 0.8>0[1.0]
UA EWR-OMA SEP 1.4>0[3]
UA EWR-ORD SEP 10>5[11]
UA EWR-ORF SEP 5>1.9[5]
UA EWR-PBI SEP 4>1.7[4]
UA EWR-PDX SEP 0.8>0[1.9]
UA EWR-PHX SEP 3>1.0[3]
UA EWR-PIT SEP 8>3[8]
UA EWR-POP SEP 0.1>0.4[0.1]
UA EWR-POS SEP 0.8>0[1.0]
UA EWR-PTY SEP 0.8>0[1.0]
UA EWR-PUJ SEP 1.0>0.7[1.0]
UA EWR-PVD SEP 4>0[3]
UA EWR-PWM SEP 6>1.0[6]
UA EWR-RDU SEP 7>3[8]
UA EWR-RIC SEP 6>1.0[6]
UA EWR-ROC SEP 4>1.0[4]
UA EWR-SAL SEP 0.1>0.4[0]
UA EWR-SAN SEP 3>1.0[3]
UA EWR-SAP SEP 0.1>0.3[0]
UA EWR-SAT SEP 1.7>0.7[2.0]
UA EWR-SAV SEP 4>0.7[3]
UA EWR-SDF SEP 2>0.2[3]
UA EWR-SDQ SEP 3>2[2]
UA EWR-SEA SEP 3>1.0[4]
UA EWR-SFO SEP 13>4[13]
UA EWR-SJO SEP 0.9>0.5[1.0]
UA EWR-SLC SEP 0.8>0[1.0]
UA EWR-SMF SEP 0.8>0[1.0]
UA EWR-SNA SEP 2>0[3]
UA EWR-SRQ SEP 1.0>0.7[1.0]
UA EWR-STL SEP 5>3[6]
UA EWR-STT SEP 0>0.5[0.1]
UA EWR-SYR SEP 2>0[4]
UA EWR-TPA SEP 5>3[6]
UA EWR-TYS SEP 0.7>0[1.0]
UA EWR-XNA SEP 0.6>0[0.9]
UA EWR-YHZ SEP 2>0[3]
UA EWR-YQB SEP 3>0[3]
UA EWR-YUL SEP 2>0[3]
UA EWR-YYZ SEP 3>0.7[4]
UA EWR-ZRH SEP 0.8>0[1.0]
UA EZE-IAH SEP 0.8>0[1.0]
UA FAR-ORD SEP 4>1.9[4]
UA FAT-LAX SEP 3>0.7[4]
UA FAT-ORD SEP 0.8>0[1.0]
UA FAT-SFO SEP 4>1.9[4]
UA FLL-IAH SEP 3>2.0[4]
UA FLL-ORD SEP 1.2>1.9[1.1]
UA FRA-IAD SEP 1.8>1.0[2]
UA FRA-IAH SEP 0.8>0.3[1.0]
UA FRA-ORD SEP 1.7>0.9[2]
UA FRA-SFO SEP 1.8>1.0[2]
UA FSD-ORD SEP 4>3[5]
UA FWA-ORD SEP 3>2.0[3]
UA GDL-IAH SEP 4>2[4]
UA GEG-ORD SEP 0.8>0[1.0]
UA GEG-SFO SEP 3>1.0[2]
UA GIG-IAH SEP 0.8>0[1.0]
UA GPT-IAH SEP 4>1.9[3]
UA GRK-IAH SEP 2>0.8[3]
UA GRR-IAD SEP 0.8>0[1.0]
UA GRR-IAH SEP 0.8>0[1.8]
UA GRR-ORD SEP 6>4[7]
UA GSO-IAD SEP 3>1.6[3]
UA GSO-ORD SEP 3>1.5[4]
UA GSP-IAD SEP 3>1.9[3]
UA GSP-IAH SEP 3>1.0[2.0]
UA GSP-ORD SEP 3>2.0[3]
UA GUA-IAD SEP 0.1>0.3[0]
UA GUA-LAX SEP 0.1>0.3[0]
UA GUM-HNL SEP 1.0>0.5[0.5] OCT 1.0>0.5[0.5] NOV 1.0>0.5[0.5] DEC 1.0>0.5[0.5] JAN 1.0>0.5[0.5] FEB 1.0>0.5[0.5] MAR 1.0>0.5[0.5] APR 1.0>0.5[0.5] MAY 1.0>0.5[0.5] JUN 1.0>0.5[0.5]
UA HAV-IAH SEP 0.8>0[1.0]
UA HKG-SFO SEP 0.9>0.7[1.0]
UA HND-LAX SEP 0.8>0[0]
UA HND-ORD SEP 0.9>0.4[0]
UA HND-SFO SEP 0.8>0[1.0]
UA HNL-IAH SEP 1.0>0.4[1.0]
UA HNL-LAX SEP 3>2.0[3]
UA HNL-MAJ SEP 0.4>0.0[0.6]
UA HNL-NRT SEP 0.8>0[1.0]
UA HNL-SFO SEP 4>2[5]
UA HOB-IAH SEP 1.5>0.4[1.9]
UA HPN-ORD SEP 2>0[3]
UA HSV-IAD SEP 3>1.9[2.0]
UA HSV-IAH SEP 3>1.8[4]
UA HSV-ORD SEP 3>0.9[1.9]
UA IAD-IAH SEP 5>4[4]
UA IAD-ILM SEP 3>1.9[2]
UA IAD-IND SEP 4>1.9[4]
UA IAD-JAX SEP 3>1.9[3]
UA IAD-LAS SEP 2>0[2.0]
UA IAD-LAX SEP 5>2[7]
UA IAD-LEX SEP 1.6>0.1[2]
UA IAD-LGA SEP 4>1.9[4]
UA IAD-MCI SEP 3>1.0[2]
UA IAD-MCO SEP 4>1.9[4]
UA IAD-MDT SEP 4>1.7[3]
UA IAD-MEX SEP 0.8>0[1.0]
UA IAD-MHT SEP 1.5>0[3]
UA IAD-MSN SEP 1.5>0[0]
UA IAD-MSY SEP 3>1.0[2]
UA IAD-OKC SEP 1.5>0[1.0]
UA IAD-ORD SEP 6>4[5]
UA IAD-ORF SEP 4>1.9[4]
UA IAD-PDX SEP 0.8>0[1.0]
UA IAD-PHL SEP 4>1.9[0.0]
UA IAD-PHX SEP 0.8>0[1.0]
UA IAD-PIT SEP 4>1.9[4]
UA IAD-PVD SEP 4>1.9[3]
UA IAD-PWM SEP 4>1.9[4]
UA IAD-RDU SEP 4>1.8[4]
UA IAD-RIC SEP 4>1.9[4]
UA IAD-ROA SEP 3>1.6[2]
UA IAD-ROC SEP 4>1.9[3]
UA IAD-SAL SEP 0.1>0.3[0]
UA IAD-SAN SEP 3>1.0[3]
UA IAD-SAT SEP 3>1.0[2.0]
UA IAD-SAV SEP 3>1.9[3]
UA IAD-SCE SEP 3>1.8[2]
UA IAD-SDF SEP 3>1.9[1.9]
UA IAD-SEA SEP 3>1.5[3]
UA IAD-SFO SEP 5>3[7]
UA IAD-SHD SEP 1.7>0.7[1.0]
UA IAD-SMF SEP 0.8>0[1.0]
UA IAD-STL SEP 3>1.9[3]
UA IAD-SYR SEP 4>1.9[3]
UA IAD-TPA SEP 3>1.9[3]
UA IAD-TYS SEP 3>1.9[3]
UA IAD-YOW SEP 2>0[3]
UA IAD-YUL SEP 2>0[3]
UA IAD-YYZ SEP 3>1.9[4]
UA IAH-IND SEP 4>1.9[5]
UA IAH-JAN SEP 5>3[6]
UA IAH-JAX SEP 4>2.0[4]
UA IAH-LAS SEP 5>1.9[6]
UA IAH-LAX SEP 9>4[9]
UA IAH-LBB SEP 3>2.0[3]
UA IAH-LCH SEP 3>1.8[3]
UA IAH-LEX SEP 0.9>0.1[0]
UA IAH-LFT SEP 6>3[6]
UA IAH-LGA SEP 6>3[8]
UA IAH-LIM SEP 0.9>0.4[1.0]
UA IAH-LIT SEP 5>3[6]
UA IAH-LRD SEP 3>1.7[3]
UA IAH-MAF SEP 6>3[7]
UA IAH-MBJ SEP 0.3>0.1[0.1]
UA IAH-MCI SEP 4>3[5]
UA IAH-MCO SEP 5>3[6]
UA IAH-MEM SEP 5>3[5]
UA IAH-MEX SEP 5>3[6]
UA IAH-MFE SEP 6>3[7]
UA IAH-MIA SEP 3>2.0[3]
UA IAH-MID SEP 0.8>0[0.5]
UA IAH-MKE SEP 1.4>0[3]
UA IAH-MLM SEP 0.8>0[1.0]
UA IAH-MLU SEP 1.6>0.7[1.8]
UA IAH-MOB SEP 4>3[4]
UA IAH-MSP SEP 4>1.9[5]
UA IAH-MSY SEP 7>3[8]
UA IAH-MTY SEP 6>1.9[7]
UA IAH-MUC SEP 0.8>0[1.0]
UA IAH-NAS SEP 0.2>0[0.4]
UA IAH-NRT SEP 0.8>0[1.0]
UA IAH-OKC SEP 6>3[8]
UA IAH-OMA SEP 3>1.9[4]
UA IAH-ORD SEP 9>6[9]
UA IAH-ORF SEP 1.5>0[1.9]
UA IAH-PBC SEP 0.9>0.5[1.0]
UA IAH-PDX SEP 3>1.0[2]
UA IAH-PHL SEP 4>2.0[4]
UA IAH-PHX SEP 4>1.9[4]
UA IAH-PIT SEP 5>1.9[6]
UA IAH-PNS SEP 5>3[6]
UA IAH-POS SEP 0.8>0[1.0]
UA IAH-PTY SEP 2>0.7[3]
UA IAH-QRO SEP 3>1.9[4]
UA IAH-RDU SEP 4>2.0[4]
UA IAH-RIC SEP 1.5>0[2]
UA IAH-RNO SEP 0.8>0[1.0]
UA IAH-SAN SEP 4>2.0[5]
UA IAH-SAP SEP 1.2>2[1.0]
UA IAH-SAT SEP 6>3[8]
UA IAH-SAV SEP 1.8>1.0[1.9]
UA IAH-SDF SEP 3>1.1[4]
UA IAH-SEA SEP 4>1.9[5]
UA IAH-SFO SEP 8>4[8]
UA IAH-SGF SEP 1.5>0[2.0]
UA IAH-SHV SEP 3>1.8[4]
UA IAH-SJC SEP 1.5>0[1.8]
UA IAH-SJO SEP 2.0>0.9[2]
UA IAH-SJU SEP 1.1>2.0[1.0]
UA IAH-SLC SEP 4>1.9[5]
UA IAH-SLP SEP 1.8>1.0[2]
UA IAH-SMF SEP 2>0.9[1.9]
UA IAH-SNA SEP 3>1.9[4]
UA IAH-STL SEP 4>3[5]
UA IAH-STT SEP 0.1>0.5[0]
UA IAH-TAM SEP 0.8>0.6[1.0]
UA IAH-TPA SEP 4>2.0[4]
UA IAH-TUL SEP 6>3[7]
UA IAH-TUS SEP 3>1.0[2]
UA IAH-VER SEP 0.8>0.4[1.0]
UA IAH-XNA SEP 5>3[5]
UA IAH-YVR SEP 1.5>0[1.1]
UA IAH-YYC SEP 1.8>0.0[2]
UA IAH-YYZ SEP 2>0[3]
UA ICN-SFO SEP 1.2>0.7[1.7]
UA ICT-ORD SEP 4>1.9[4]
UA ILM-ORD SEP 1.5>0[2.0]
UA IND-ORD SEP 8>4[9]
UA ITO-LAX SEP 0.6>0.4[0.7]
UA JAC-ORD SEP 1.9>1.1[2]
UA JAN-ORD SEP 0.8>0[0]
UA JAX-ORD SEP 2>1.9[3]
UA KOA-LAX SEP 1.1>0.7[1.1]
UA LAS-LAX SEP 5>1.6[6]
UA LAS-ORD SEP 4>3[5]
UA LAS-SFO SEP 6>3[8]
UA LAX-LIH SEP 1.1>0.4[1.1]
UA LAX-MCO SEP 1.7>0.7[1.0]
UA LAX-MFR SEP 1.5>0[2.0]
UA LAX-MRY SEP 4>0.7[5]
UA LAX-MSN SEP 0.8>0[1.0]
UA LAX-OGG SEP 1.9>1.0[2]
UA LAX-ORD SEP 8>5[10]
UA LAX-PHX SEP 3>0.5[4]
UA LAX-PSP SEP 0.8>0[1.0]
UA LAX-PVR SEP 0>0.3[0]
UA LAX-RDD SEP 0.8>0[1.0]
UA LAX-RDM SEP 0.8>0[1.0]
UA LAX-RNO SEP 3>2[3]
UA LAX-SAL SEP 0.1>0.3[0]
UA LAX-SAN SEP 4>1.7[5]
UA LAX-SAT SEP 1.4>0[1.9]
UA LAX-SBA SEP 2>0[4]
UA LAX-SBP SEP 3>0.7[4]
UA LAX-SFO SEP 10>6[10]
UA LAX-SJD SEP 0.9>0.3[0]
UA LAX-SLC SEP 1.7>1.0[2]
UA LAX-SMF SEP 3>0.7[3]
UA LAX-YVR SEP 1.5>0[2]
UA LEX-ORD SEP 4>1.9[4]
UA LGA-ORD SEP 12>5[15]
UA LHR-ORD SEP 3>1.0[3]
UA LIT-ORD SEP 3>2.0[3]
UA LNK-ORD SEP 4>3[4]
UA MBS-ORD SEP 3>1.9[3]
UA MCI-ORD SEP 5>3[6]
UA MCI-SFO SEP 1.5>0[1.7]
UA MCO-ORD SEP 4>3[4]
UA MCO-SFO SEP 1.7>0.7[2]
UA MDT-ORD SEP 4>2.0[4]
UA MEM-ORD SEP 3>1.9[4]
UA MEX-ORD SEP 1.6>1.0[1.9]
UA MEX-SFO SEP 2>1.0[2]
UA MFR-SFO SEP 4>2.0[4]
UA MKE-ORD SEP 8>5[9]
UA MLI-ORD SEP 5>3[4]
UA MRY-SFO SEP 1.8>1.0[2]
UA MSN-ORD SEP 7>5[8]
UA MSN-SFO SEP 0.8>0[1.1]
UA MSO-SFO SEP 1.0>0.2[1.0]
UA MSP-ORD SEP 7>4[9]
UA MSP-SFO SEP 1.8>0.7[1.1]
UA MSY-ORD SEP 2>1.0[3]
UA MTJ-ORD SEP 0.9>0[1.2]
UA MTY-ORD SEP 1.5>0[2]
UA MUC-ORD SEP 0.8>0[1.0]
UA MUC-SFO SEP 0.8>0.3[1.0]
UA OGG-SFO SEP 4>2.0[4]
UA OKC-ORD SEP 4>1.9[4]
UA OKC-SFO SEP 0.8>0[1.0]
UA OMA-ORD SEP 4>3[5]
UA OMA-SFO SEP 1.5>0[1.7]
UA ONT-SFO SEP 5>2[5]
UA ORD-ORF SEP 4>1.9[4]
UA ORD-PDX SEP 3>1.0[4]
UA ORD-PHL SEP 6>3[7]
UA ORD-PHX SEP 4>3[5]
UA ORD-PIA SEP 5>3[5]
UA ORD-PIT SEP 6>4[6]
UA ORD-PNS SEP 1.5>0[1.0]
UA ORD-PSC SEP 0.8>0[0]
UA ORD-PVD SEP 3>1.9[3]
UA ORD-PWM SEP 3>1.7[3]
UA ORD-RAP SEP 3>1.0[3]
UA ORD-RDM SEP 0.8>0[1.0]
UA ORD-RDU SEP 5>2[6]
UA ORD-RIC SEP 5>1.9[5]
UA ORD-RNO SEP 0.8>0[1.0]
UA ORD-ROA SEP 3>2.0[3]
UA ORD-ROC SEP 3>2.0[4]
UA ORD-RST SEP 2>0[3]
UA ORD-SAN SEP 4>3[5]
UA ORD-SAT SEP 3>1.9[3]
UA ORD-SAV SEP 2>1.0[4]
UA ORD-SBA SEP 0.8>0[0]
UA ORD-SBN SEP 9>4[5]
UA ORD-SCE SEP 3>2.0[4]
UA ORD-SDF SEP 6>4[6]
UA ORD-SEA SEP 4>1.9[5]
UA ORD-SFO SEP 10>6[11]
UA ORD-SGF SEP 4>2.0[5]
UA ORD-SJC SEP 1.5>0[1.7]
UA ORD-SLC SEP 4>1.9[3]
UA ORD-SMF SEP 2>1.0[3]
UA ORD-SNA SEP 2>1.0[3]
UA ORD-SPI SEP 3>1.0[3]
UA ORD-STL SEP 8>4[8]
UA ORD-SYR SEP 4>2.0[5]
UA ORD-TPA SEP 3>2.0[3]
UA ORD-TUL SEP 4>3[4]
UA ORD-TUS SEP 0.8>0[0]
UA ORD-TVC SEP 5>3[5]
UA ORD-TYS SEP 4>1.9[5]
UA ORD-XNA SEP 4>1.9[4]
UA ORD-YOW SEP 1.4>0[0]
UA ORD-YUL SEP 2>1.0[3]
UA ORD-YVR SEP 2>0[3]
UA ORD-YWG SEP 1.5>0[3]
UA ORD-YYC SEP 2>1.0[3]
UA ORD-YYZ SEP 5>3[7]
UA PDX-SFO SEP 6>3[7]
UA PEK-SFO SEP 0.8>0[1.0]
UA PHL-SFO SEP 1.5>0[1.0]
UA PHX-SFO SEP 4>1.7[5]
UA PIT-SFO SEP 1.5>0[1.1]
UA PSC-SFO SEP 1.5>0[1.0]
UA PSP-SFO SEP 4>1.7[3]
UA PVR-SFO SEP 0.3>0.7[0.1]
UA RDD-SFO SEP 3>1.0[3]
UA RDM-SFO SEP 4>2[4]
UA RDU-SFO SEP 1.5>0[1.0]
UA RNO-SFO SEP 4>1.9[4]
UA SAN-SFO SEP 7>3[7]
UA SAT-SFO SEP 0.8>0[1.0]
UA SBA-SFO SEP 5>3[5]
UA SBP-SFO SEP 4>2.0[4]
UA SFO-SIN SEP 0.8>0[2]
UA SFO-SJD SEP 0.9>0.7[1.0]
UA SFO-SLC SEP 4>1.9[4]
UA SFO-SMF SEP 4>2[4]
UA SFO-SNA SEP 6>3[7]
UA SFO-STL SEP 0.8>0[1.1]
UA SFO-STS SEP 1.0>0.7[1.0]
UA SFO-TPA SEP 0.8>0[1.1]
UA SFO-TPE SEP 0.8>0[1.0]
UA SFO-TUS SEP 3>1.7[3]
UA SFO-YVR SEP 4>2[5]
UA SFO-YYC SEP 1.5>0[2]
UA SFO-YYZ SEP 1.5>0[2]
UA SFO-ZRH SEP 0.7>0[1.0]
WN GEG-SEA SEP 1.2>0.7[0]
WN LGB-SJC SEP 0.9>0.5[4]
WO AZA-YEG OCT 0.2>0[0.3]
WO FLL-YHM OCT 0.2>0[0.3]
WO LAS-YEG SEP 0.5>0[1.0] OCT 0.6>0[1.0]
WO LAS-YHM SEP 0.3>0[0.6] OCT 0.5>0[0.6]
WO LAS-YXX OCT 0.2>0[0.3]
WO MCO-YHM OCT 0.2>0[0.5]
Western727
Re: OAG Changes 8/4/2020:SEPTEMBER SLIDE;AA Drops LAX-YVR;AM Drops AUS;AS Adds SAN-SBA;
Tue Aug 04, 2020 12:15 pm
Many thanks, Enilria, for doing this once again. Being in AUS, I share your intrigue with AM's MEX-AUS cuts...pretty telling.
Jack @ AUS
jasoncrh
Tue Aug 04, 2020 12:34 pm
This is really good. Thank you. I’ve been looking forward to this. Would recommend double checking and looking for August too. AA made tons of changes (several of my flights were chopped in august over the weekend) as did UA. Good work!
factsonly
Tue Aug 04, 2020 12:41 pm
One of the very few AA increases listed for this autumn.
Interesting how this relatively new (2018) seasonal AA route has performed in COVID times:
- 1. Operated as a B77W freight-only service in spring,
- 2. One of first AA TATL routes to turn to daily B788 pax in summer.
- 3. Now extended with an increased frequency into the autumn.
Could we be seeing early signs that AA may go year-round DFW-AMS.
reednavy
Tue Aug 04, 2020 12:47 pm
EI between BNA & ORD?
Ishrion
Tue Aug 04, 2020 1:06 pm
AA launched DFW-AMS in May 2017 on the 763. In 2018/19, the route was on the 772. 2020 was the first season it was on the 788 and it’s now scheduled on the 789 for 2021.
I’m guessing they’re temporarily shifting the PHL-AMS flight to DFW just for October as noted in the OAG changes since PHL still isn’t a designated gateway for European arrivals.
enilria
Tue Aug 04, 2020 1:14 pm
I have never been able to report changes inside the current month. Thanks...
AVENSAB727
Tue Aug 04, 2020 1:24 pm
Nice to see NZ resume IAH in October.
Always look on the bright side of Life!
tphuang
Tue Aug 04, 2020 1:28 pm
Thanks enilria, really appreciate your hard work every week.
CanadianRedneck
Tue Aug 04, 2020 1:32 pm
Thank you for this, AA at DCA is looking pretty slim in August.
ZazuPIT
Tue Aug 04, 2020 1:38 pm
The second time in a couple months this has shown up. Obviously a misfile? Thanks enilria for putting this together. It's getting uglier by the week.
MIflyer12
Tue Aug 04, 2020 1:39 pm
Those are some pretty good whacks to LAX by AA. Does anybody think the Sept schedule updates are now 'complete' by AA/DL/UA/WN/AS at LAX? It would be interesting to see daily departure counts. Seats and/or ASMs would be even better - if somebody wants to be an over-achiever. :P
Miamiairport
Tue Aug 04, 2020 1:47 pm
I was at DCA/AA yesterday, a Monday. The place was so empty it was eerie. My flight from MIA was about 25% full. I was at the AC for about 2 hours on a connection. Other than a little bird flying around I was the only one other than a couple that came in a few minutes before I left.
Really, it was something out of the Twilight Zone.
Brickell305
Tue Aug 04, 2020 1:55 pm
It looks like someone took a sledgehammer to the AA, B6 and UA schedules.
tphuang
Tue Aug 04, 2020 1:56 pm
As with DL at LGA, AA is going to have to take some losses here when slot waiver goes away. I don't see why slot waiver will stay in place until when business demand comes back to like 70% of pre-COVID.
I think we will see more cuts up until end of this month. They even cut August this past weekend. I think LAX will be a lot smaller next year compared to 2019 for AA.
jb1087xna
Tue Aug 04, 2020 2:16 pm
Thanks as always for your work on this!
This feels somewhat bullish given DL's trends..? Am I missing something? I don't see anything that AM filed this week that would point to those locations shifting traffic to DL's metal.
vmanAA738
Tue Aug 04, 2020 2:20 pm
This flight has an interesting history to it.
Aeromexico first attempted this flight in January 2007 using a 737 4x/week, marking Austin's first international service. Then in May 2007, they announced that the flight was increasing from 4x/week to daily, but would be downgauging to an E145 operated by Aeromexico Connect. However, that same month, they threatened to pull out of Austin by July 1 entirely because the federal government blocked Aeromexico moving the flight to the evening because they didn't want to add customs agents to Austin to cover an evening shift [At the time they only had customs agents for daytime flights---Austin was a significantly smaller back then]. The dispute wasn't resolved and Aeromexico pulled out.
[In the meantime, VivaAerobus tried Austin-Mexico again flying to Cancun and Puerto Vallarta using the South Terminal [they were the ones that opened that building] from Austin in May 2008, but by May 2009 had pulled out citing Swine Flu [????] of all things.]
Then, in November 2016, Aeromexico [Aeromexico Connect] re-started the service using an E170 4x/week. This was quickly expanded to a daily flight in March 2017 and by September 2017 upgauged to an E190 with first class introduced to the route.
Since then, they kept capacity and frequency flat on the route, which I guess meant that they thought the Austin-Mexico City market was either tapped out or not worth chasing after remaining customers who may have been lower-yielding or they didn't get enough feed from Delta's focus city to expand [because why would Delta route connecting passengers through here when it's O&D focused]. They tried re-starting the flight last month 3x/week, but I guess they didn't think the flight was worth keeping around long-term because of COVID and so for the second time Aeromexico has pulled out of Austin.
This time, it's not the complete death of Austin-Mexico service [albeit it's to Cancun and Cabo and I'm not sure if these have resumed operating] but unfortunate nonetheless.
EDIT: Also forgot to mention the current Aeromexico bankruptcy---that probably has something to do with this if Austin was loss-making to save cash.
USAirALB
Tue Aug 04, 2020 2:26 pm
Interesting to see AA out of LAX-YVR.
IIRC, they originally launched the route as Eagle (CR7s?), and then eventually upgraded it to all E75s and threw in an A319 on the evening run. I can't remember specifically but I feel that AA was 3-5 times daily at one point on the route.
That said, the route is notoriously low-yielding. AS, who ran the route for years (and at one point I think flew the route a whopping 6 times daily) threw in the towel a couple of years back. DL also did the route at some point with E75s IIRC.
I think this leaves AC/UA/WS on the market. I wonder if AS would be willing to give it another go.
RJ85, F70, E135, E140, E145, E70, E75, E90, CR2, CR7, CR9, 717, 732, 733, 734, 735, 73G, 738, 739, 744ER, 752, 753, 762, 772, 77E, 77W, 789, 319, 320, 321, 332, 333, 343, 359, 388
Alias1024
Tue Aug 04, 2020 2:29 pm
AA seems to have pulled a complete 180 from just a month or two ago when they were flying far more capacity than DL or UA. LAX has been absolutely gutted for American.
JAMBOJET
Tue Aug 04, 2020 2:37 pm
Thanks Enilria!
FlyingElvii
Tue Aug 04, 2020 3:11 pm
Capital Vacation month, on top of everything else. DC is usually a ghost town, but for tourists in August. Not much business getting done, but lots of corporate yacht parties on the Chesapeake.
MrPeanut
Tue Aug 04, 2020 3:20 pm
Truly not unexpected. Money losing hubs cannot be sustained during economic downturns. Although not yet announced, I would fully expect the likes of ATL, CMH, IND, RDU, MSY to not come back either. Outer stations with strong AA loyalty such as OKC/TUL/BNA have a much better chance to remain. The big question mark in my mind is SLC, DEN, IAH. DEN is highly competitive and low fares so I could see this going away. SLC and IAH being competitor hubs means DL/UA have better scale to make those routes work.
Average airfares out of LAX dropped 11% from 2012 to 2019 (17th largest decline over this time period). So fares in general out of LAX were under pressure over the past several years due to all the competition thereby making it even more difficult for AA to compete.
ScottB
Tue Aug 04, 2020 3:22 pm
AA chose to swing with the fences because they're playing with the house's money. If the recovery in travel were to be faster than DL and UA were anticipating, AA stood to gain significant market share while avoiding Chapter 11. In the event of an L-shaped recovery, AA is probably going into bankruptcy whether they chose to be aggressive or conservative.
MIflyer12
Tue Aug 04, 2020 3:34 pm
There's been a fair amount of discussion - here and in the 'press' - about AA how zigged while DL/UA zagged. I think we need to see AA flight counts vs. 2019 for Aug and Sept before we have confidence they've actually changed strategy. (Whether AA announces something of the form 'We'll be at xx% of 2019 capacity,' or it comes from a 3rd party is yet to be seen.) Enilria's ongoing work gives us an overview each week (Thanks! It's always good to have data.) but we don't get the aggregate of a carrier that was operating ~6,000 flights a day in peak 2019.
SanBdlFly
Tue Aug 04, 2020 3:42 pm
Thanks enrilia! Nice to see AA resume BDL-LAX in October and the new SAN add on AS to SBA.
panamair
Tue Aug 04, 2020 4:04 pm
No increase in frequency (both markets are currently at 3x daily between DL and AM in August with DL doing one and AM operating two). DL is apparently taking over the AM flights in both those markets starting Sept based on the current published schedules. The AM flights have been zeroed out in the various GDS but not cut yet so that’s probably why you don’t see the cuts show up here.
N292UX
Tue Aug 04, 2020 4:13 pm
DFW & CLT are going to be pretty busy for AA in September, probably 75% what it usually is
StrandedAtMKG
Tue Aug 04, 2020 4:25 pm
Looks like AA took a machete to the schedule at GRR.
I share your intrigue at the LAX-YVR flight, too. Given how much content Hollywood films in Vancouver it's probably a pretty profitable destination under normal circumstances...but these are not normal circumstances.
hiflyeras
Tue Aug 04, 2020 4:31 pm
I am sure that AS is giving LAX-YVR another look. They have the staff already in place in YVR so adding one or two flights daily seems it could be a possibility.
hiflyeras
Tue Aug 04, 2020 4:35 pm
We have a Thanksgiving trip booked on DL to MEX...n/s on AM code-share SEA-MEX which I'm starting to doubt will return by mid-November. I'm dreading the email from DL with a horrible routing via ATL or JFK! ;) Connecting in LAX wouldn't be as bad but we were hoping for the n/s redeye out of SEA as it saves us a day.
RL757PVD
Tue Aug 04, 2020 4:58 pm
Considering BDL is losing both DFW and MIA after labor day, I wouldn't hold your breath for LAX for October, however, it wasnt on the permanently canceled list from last week like SDF was so there is promise for the future. If I was a betting person thought I don't think it will be back before next April.
Experience is what you get when what you thought would work out didn't!
MIflyer12
Tue Aug 04, 2020 5:01 pm
Or SLC.
flyboy7974
Tue Aug 04, 2020 5:44 pm
Correct, DFW-AMS/DUB extended only until PHL starts service hopefully Oct 24.
hiflyeras
Tue Aug 04, 2020 9:09 pm
MIflyer12 wrote:
Or SLC.
Thanks! Forgot about that option...definitely preferable to the alternatives. And I'd love to see the new terminal as it should be open by November!
usflyer msp
Tue Aug 04, 2020 9:25 pm
AA is still flying more capacity than UA or DL. They are just continuing the existing LAX/WAS/NYC cuts into the fall. DFW and CLT are continuing their faster than conterparts recovery.
SESGDL
Tue Aug 04, 2020 9:47 pm
AA's cuts extend far beyond just LAX/WAS/NYC. Did you not look at the list? With flying stuck at 25-30% of 2019 levels, AA's looking to lose a lot of money if it doesn't pare back its strategy of flying a lot of capacity. They originally intended for flying to start picking up, that hasn't happened.
Jeremy
usflyer msp
Tue Aug 04, 2020 9:50 pm
Jeremy
Remember the cuts are year to year not month to month. The September 2020 schedule is not all that significantly different from the August 2020 schedule.
enilria
Tue Aug 04, 2020 11:18 pm
Yes, they didn't file the "duplicate" marker.
I think SEP will be the worst since APR. Hope I'm wrong.
I bet more cuts.
They pulled a lot of YVR
I think AA knows SEP will be really bad
usflyer msp wrote:
Jeremy
When it is all said and done I bet it is worse. Leisure dead due to school and business just dead.
Dominion301
Tue Aug 04, 2020 11:53 pm
Didn’t AC first serve AUS briefly at the end of the tech boom in 2000? Also, didn’t AUS have seasonal weekend CUN long before 2007?
AA was never more than 2x daily on LAX-YVR. You’re probably thinking of AS before they bailed.
I doubt they’ll look very hard until our mandatory 14 day quarantine ends with you guys, which won’t be anytime soon.
AA are really gutting YVR at least until the end of the year and appear to have no service until October.
Chugach
Wed Aug 05, 2020 1:04 am
I wouldn’t be surprised if AS jumps back in on LAX-YVR once the OW integration is complete and the pandemic is under control (meaning everyday citizens can cross the border).
tphuang
Wed Aug 05, 2020 1:08 am
This may shock people but Canadians can actually fly back and forth across the border for vfr reasons pretty easily right now.
hiflyeras
Wed Aug 05, 2020 1:48 am
LOL just shows how egocentric we are in the US...it's all about us! ;) Looks like it's just the land border crossings that are closed...and not air travel for Canadians.
https://www.cbc.ca/news/business/u-s-tr ... -1.5607741
alo2yyz
Wed Aug 05, 2020 2:30 am
Aside from the mandatory, enforced-by-random-police-checks 14-day quarantine, that is. Loads of fun for folks who live in tiny YYZ/YVR apartments without so much as a balcony.
alasizon
Wed Aug 05, 2020 3:18 am
Jeremy
A good portion of AA's cuts also have to do with Labor Day weekend and the fact that their schedule transition for September is the 9th so some of the cuts are really just cuts for Labor Day weekend and bringing the August schedule forward to the 8th. That is most of the MIA and PHX cuts - I didn't check the ORD cuts.
SANFan
Wed Aug 05, 2020 3:19 am
Like others, I'm thinking this is another route that will move from column "AA" to column "AS".
Yes AS did try it on at least one occasion, and dropped it, but now with AA gone, they may see a few $$ on the route to help with their LAX expansion. Unless I'm missing someone, I don't think OW will be represented on the route once AA leaves, right?.
Needless to say, I'm very happy to see AS adding SAN-SBA as the carrier also builds its operation in their SoCal focus city!
bb
alasizon
Wed Aug 05, 2020 3:29 am
bb
This is going back a number of years in my memory now but I seem to recall when AS cut LAX-YVR that there was some discussion about how it was very much a loss leader at LAX for them. I can't imagine that is going to change much, even with AA out of the market. While I would love to see AS in the market because I think they are the best carrier to service the market, I think there needs to be some well demonstrated recovery and improvement in fare levels before they will jump in.
usflyer msp
Wed Aug 05, 2020 4:37 am
bb
I have always had the impression that YVR-US traffic, even during good times, has never had great yields and is extremely seasonal.
Chasensfo
Wed Aug 05, 2020 5:09 am
Interesting, so LOT is planning a September start for SFO. Did not see that coming, figured it'd be next year.
alggag
Wed Aug 05, 2020 6:14 am
I had booked UA IAH-YYC in September hoping that everything would be settled by then. Flight got pulled so I opted to just cancel outright. :(
EA CO AS
Wed Aug 05, 2020 6:35 am
No debate on the latter, but don't be so quick to call leisure dead because of school starting; with many school districts returning to online learning, one thing they heard loud and clear was that the kids needed a flexible online schedule so working parents could help the kids after work hours and on weekends. The end result is that most of the online curriculum out there allows kids to learn from anywhere, at anytime, as long as there's a reliable internet connection.
More than a few of my friends who are parents have perked up at this and started planning fall/winter trips knowing they can take the kids' Chromebooks wherever they go on vacation and get the work done on the trip. I know my wife and I are definitely eyeing some winter travel with our kiddos even though school will be in full swing; the Chromebook will just go with us.
