phatfarmlines
SJU West Terminal
Mon Aug 10, 2020 1:40 am
Is there any history to these gates, shown in this 1994 Google Earth snapshot built beyond Terminal E to the west (encased in the red box in the linked photo)? This facility would be partially covering the apron which will eventually be used by American Eagle's remote operations, so I imagine this facility was demolished after the opening of the rebuilt Terminal C in the mid-90's. A guide I found has these gates labeled as part of "Terminal F". My memory escapes me that these gates existed, let alone called "Terminal F".
SJU West Terminal
Source: Google Earth
SJU Guide 1990 (1 of 2)
SJU Guide 1990 (2 of 2)
Source: User "mpar21" - flickr.com
SJU OAG Map from October 1991
SJU OAG Map from April 1995
Source: DepartedFlights.com
luckyone
Re: SJU West Terminal
Mon Aug 10, 2020 2:12 am
I went through SJU about 15 times in 2009-2010. If my memory is correct, the gates mentioned indeed appear to be where the E and F-Gates would have been. I remember being puzzled about the layout because unlike the rest of SJU in which each finger concourse extended from the main terminal, the F gates were accessed through the E Gates, all of which were part of the AA operation. Sometime around mid-2010 they stopped using the F Gates. To the best of my memory the D-Gates were where the ATRs flew out of. There would be around a dozen parked at any one time. E and F was where the bigger AA jets were parked.
DeltaRules
Mon Aug 10, 2020 4:23 pm
I seem to remember AA operating from Gates 1-3 and the Eagle flights left from below Gate 1. Did AA expand when DL/US/TW move to 30-41? We traveled to SJU quite a bit when I was a kid and I remember in the '90s DL was at 33 and 35, US at 37, TW at 39, NW and UA on the even side of that pier. (US later added 38 and I distinctly remember leaving on an A330 from there.)
There was also a time IIRC where the 19-27 concourse was closed and eventually reopened.
A310/319/320/321/333, ARJ, BN2, B717/722/73S/733/734/735/73G/738/739/744/757/753/767/763/764/777, CR1/2/7/9, DH6, 328, EM2/ERJ/E70/E75/E90, F28/100, J31, L10/12/15, DC9/D93/D94/D95/M80/M88/M90/D10, SF3, SST
PRAirbus
Mon Aug 10, 2020 8:31 pm
I recall reading the "west terminal" was mothballed with no date to reopen; I doubt it will open anytime soon especially now during the pandemic. jetBlue is the largest airline in SJU with their own terminal. Wonder if AA and B6 will move together in SJU as part of their future "alliance" in the Northeast.
phatfarmlines
Tue Aug 11, 2020 12:46 pm
That's how I remember it. AA in Terminals D & E, all other airlines in Terminal B until the rebuilt Terminal C reopened.
That is correct. When AA downsized SJU to a focus operation, AE abandoned the remote ramp operation and consolidated operations out of Terminal D.
I do recall a discussion about opening up a separate AE ticketing facility, which I presume would have involved said mothballed west terminal. Pictures are hard to come by, both inside, outside, and aerial, of SJU during the 1970's-early 1990's of the facilities and how the airport evolved over time.
luckyone
Tue Aug 11, 2020 5:55 pm
Prior to the remodeling, C was where JetBlue (I think) AirTran, Spirit, LIAT, Frontier and several other smaller carriers would fly out of. The other majors -- Delta, United, US, Air Canada-- used B. I don't remember where COPA operated from, but I want to say C, because I don't think B at the time was connected to immigration.
phatfarmlines
Wed Aug 12, 2020 12:53 am
Terminal B at one point did have customs/immigration processing. I do remember a hallway partition on the north side of the concourse (this would have been in 1996) which would have been before or right at the opening of the rebuilt Terminal C.
luckyone
Wed Aug 12, 2020 3:46 pm
Well that's interesting. When I was going through there regularly there was no divided hallway, though this was after the connector to C was built.
tistpaa727
Wed Aug 12, 2020 4:54 pm
Grew up on St. Thomas and used to fly through SJU often in the 80s and early 90s...I don't recall those jet bridges just that the end of the terminal was all American Eagle with mostly Shorts 360 I believe packing the apron. All but one flight from STT to SJU was on a prop (DC-3 or Shorts 360). Those DC-3 flights were awesome!
Found this image https://www.airliners.net/photo/American-Eagle-Flagship-Airlines/Short-360/58059/L from 1997 where you can see the jet bridges right behind the plane with what appear to be AA vehicles/equipment. Not sure if you could fit a plane at the closes jet bridge given where the Eagle flight is parked.
Don't sweat the little things.
