enilria
OAG Changes 8/25/2020:Cuts Begin for 21;DL DROPS NUMEROUS ROUTES INTL ROUTES FOR SUMMER 2021, Adds SEA-ONT,MSP-TVC
Tue Aug 25, 2020 1:44 pm
FAQ
SOURCE: OAG
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
2D JFK-SJD SEP 0.3>0[0] OCT 0.3>0[0]
3M FLL-NAS SEP 0>0.3[0] OCT 0>0.3[0]
4B CNM-DFW SEP 0.5>1.0[1.0] OCT 0.5>1.0[1.0] NOV 0.5>0.8[0.9]
There continue to be issues with 9K and the TECNAM appearing correctly
9K HPN-MVY SEP 1.0>0[1.9] OCT 0.4>0[0.9]
9K HPN-PVC SEP 0.3>0[0.1]
9K HYA-MVY SEP 2>1.0[2] OCT 0.8>0.4[1.1]
9K JFK-MVY SEP 1.0>0[0.5] OCT 1.0>0.6[1.0]
9K MBL-ORD OCT 0>2[0] NOV 0>2[0] DEC 0>2[0] JAN 0>2[0] FEB 0>2[0] MAR 0>2[0] APR 0>2[0] MAY 0>2[0] JUN 0>2[0]
9R BOG-HAY SEP 0.3>0[0] OCT 0.3>0[0] NOV 0.3>0[0] DEC 0.3>0[0] JAN 0.3>0[0] FEB 0.3>0[0] MAR 0.3>0[0] APR 0.3>0[0] MAY 0.3>0[0] JUN 0.3>0[0]
AA BDA-PHL NOV 1.0>0.1[0.9] DEC 1.0>0.5[1.0]
AA CLT-EYW OCT 2>3[1.0] NOV 2>3[1.4] DEC 2>4[3]
AA CLT-SJD NOV 0.1>0.4[0.1] DEC 0.1>0.6[0.1] JAN 0.2>1.0[0.1] FEB 0.1>1.0[0.2] MAR 0.1>1.0[0.1]
AA CLT-STT NOV 1.0>1.4[0.4] DEC 1.0>1.5[0.6] JAN 1.0>2.0[0.9] FEB 1.0>2.0[0.9] MAR 1.0>2.0[1.0]
*AA CLT-STX JAN 0.3>1.0[0.3] FEB 0.1>1.0[0.2] MAR 0.1>1.0[0.1]
AA CUR-MIA SEP 0.5>0[1.0] NOV 2>1.1[1.0] DEC 2>1.5[1.5]
AA DFW-OGG SEP 1.0>0[1.0]
UA adds SAL flights and AA cuts. Tells me there are incentives involved.
**AA DFW-SAL NOV 0.6>0.1[0] DEC 0.7>0[0.4] JAN 0.7>0[0.6] FEB 0.6>0[0.6] MAR 0.5>0[0.6] APR 0.6>0[0] MAY 0.6>0[0]
AA DFW-SJO SEP 1.0>0.7[1.0]
*AA DFW-STT DEC 0.1>0.6[0.1] JAN 0.2>1.0[0.1] FEB 0.1>1.0[0.2] MAR 0.1>1.0[0.1]
AA EZE-MIA SEP 0.8>0.2[1.9]
AA GCM-MIA NOV 1.4>1.9[2] JAN 1.2>2[2] FEB 1.6>2[3]
AA GEO-JFK NOV 1.0>0.1[0] DEC 1.0>0.5[0.5]
AA GEO-MIA SEP 0.5>0[1.0]
AA HNL-PHX SEP 1.0>0[2]
AA KOA-LAX SEP 1.0>0[1.0]
AA LAX-LIH SEP 1.0>0[1.7]
AA LAX-OGG SEP 1.0>0[2]
AA OGG-PHX SEP 1.0>0[1.1]
**AA PVG-SEA APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0]
AC LAX-YYZ SEP 0.7>0.4[5]
AF CDG-DTW NOV 1.0>0.7[0.9] DEC 1.0>0.7[1.0] FEB 0.9>0.6[0.6] MAR 1.0>0.7[1.0]
AF CDG-IAD OCT 0.8>0.6[1.5] NOV 1.6>0.9[1.5] DEC 1.5>1.0[1.6] JAN 1.6>0.9[1.5] FEB 1.6>0.9[1.5] MAR 1.5>1.1[1.6]
AF CDG-IAH NOV 1.0>0.7[0.9] DEC 1.0>0.7[1.0] JAN 0.9>0.5[0.9] FEB 0.9>0.6[0.9] MAR 1.0>0.7[1.0]
AF CDG-JFK NOV 5>4[4] DEC 5>4[4] JAN 5>4[4] FEB 5>4[4] MAR 5>4[4]
AF CDG-LAX SEP 1.9>1.4[2]
AF CDG-ORD NOV 0.7>0.4[0.7] DEC 0.7>0.5[0.7] MAR 0.7>0.5[0.7]
*AF CDG-SEA NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4] FEB 0.4>0[0.4] MAR 0.5>0.1[0.5]
AF LAX-PPT SEP 0.4>0[0.4]
AI DEL-ORD SEP 0.3>0.7[1.0] OCT 0.4>0.8[1.0]
AM MEX-ORD SEP 1.0>1.3[2]
AM MEX-SAT SEP 1.0>1.3[1.0]
AS ANC-SCC SEP 1.5>3[2] OCT 1.5>3[3] NOV 1.5>3[2] DEC 1.3>3[2] JAN 1.3>2[3] FEB 1.4>3[2] MAR 1.4>3[2] APR 1.4>3[3] MAY 1.3>2[1.8] JUN 1.4>3[2]
AS HNL-PDX SEP 1.0>0[1.0]
AS HNL-SAN SEP 0.7>0[1.0]
AS HNL-SJC SEP 0.3>0[0.6]
AS KOA-SAN SEP 0.6>0[0.4]
AS KOA-SEA SEP 1.0>0[1.4]
AS KOA-SJC SEP 0.4>0[0.4]
AS LAX-PVR DEC 1.0>1.3[1.5] JAN 1.0>1.3[1.2] FEB 1.0>1.3[1.1]
AS LIH-SAN SEP 0.7>0[0.6]
AS LIH-SEA SEP 1.0>0[1.6]
AS LIH-SJC SEP 0.6>0[0.6]
AS OGG-PDX SEP 1.0>0[1.0]
AS OGG-SAN SEP 1.0>0[1.0]
AS OGG-SEA SEP 2>1.0[2]
AS OGG-SJC SEP 0.6>0[0.6]
B5 MDR-WIL SEP 2>0[0] OCT 2>0[0] NOV 2>0[0] DEC 2>0[0] JAN 2>0[0] FEB 2>0[0] MAR 2>0[0] APR 2>0[0] MAY 2>0[0]
Big cuts...
B6 ACK-BOS SEP 0.4>0.1[0.8]
B6 ACK-DCA SEP 0.4>0.1[0.3]
B6 ATL-BOS SEP 1.3>1.0[4]
B6 AUA-BOS SEP 0.5>0.3[1.4]
B6 AUS-EWR SEP 2.0>0.5[0]
B6 AUS-FLL SEP 0.4>0[1.0]
B6 AUS-JFK SEP 0.5>0.3[1.9]
B6 BNA-BOS SEP 0.5>0.2[3]
B6 BNA-JFK SEP 0.5>0.3[0]
B6 BOG-FLL SEP 1.0>0.2[1.0]
B6 BOS-CLE SEP 1.0>0.5[3]
B6 BOS-CLT SEP 0.9>0.5[3]
B6 BOS-DCA SEP 3>1.0[13]
B6 BOS-DEN SEP 1.0>0.8[1.9]
B6 BOS-DFW SEP 0.9>0.5[1.9]
B6 BOS-DTW SEP 0.9>0.5[3]
B6 BOS-EWR SEP 0.9>0[6]
B6 BOS-FLL SEP 3>2[5]
B6 BOS-IAH SEP 0.5>0.3[0]
B6 BOS-JAX SEP 0.5>0.3[3]
B6 BOS-JFK SEP 3>2[6]
B6 BOS-MSP SEP 0.5>0.3[3]
B6 BOS-PBI SEP 1.0>0.7[3]
B6 BOS-PDX SEP 0.3>0[1.1]
B6 BOS-PHL SEP 1.0>0[7]
B6 BOS-SAN SEP 1.4>1.0[3]
B6 BOS-SEA SEP 0.9>0.5[1.9]
B6 BOS-SFO SEP 3>2[5]
B6 BOS-SJU SEP 2.0>1.1[2.1]
B6 BOS-SLC SEP 0.7>0[0.6]
B6 BOS-STI SEP 1.0>0.7[1.2]
B6 BOS-SYR SEP 0.6>0.3[1.0]
B6 CHS-EWR SEP 1.0>0.4[0]
B6 CTG-FLL SEP 0.4>0[0.6]
B6 CTG-JFK SEP 0.5>0.1[0.4]
B6 DCA-FLL SEP 0.9>0.6[5]
B6 DCA-RSW SEP 0.3>0[1.0]
B6 DFW-JFK SEP 1.0>0.3[0]
B6 DTW-JFK SEP 1.0>0.3[0]
B6 EWR-JAX SEP 1.0>0.4[0]
B6 EWR-PHX SEP 2>0.8[0]
B6 EWR-SAN SEP 0.9>0.3[0]
B6 EWR-SFO SEP 1.9>0.7[0]
B6 EWR-SJU SEP 3.3>2.0[1.2]
B6 FLL-HAV SEP 2>0[3]
B6 FLL-MDE SEP 0.7>0.2[1.0]
B6 FLL-NAS SEP 1.0>0.3[4]
B6 FLL-PHL SEP 0.4>0.1[1.9]
B6 FLL-SJO SEP 0.4>0[1.0]
B6 FLL-SJU SEP 2.0>1.5[5]
B6 GND-JFK SEP 0.4>0[0.9]
B6 HDN-JFK FEB 0>0.2[0]
B6 IAH-JFK SEP 0.5>0.3[0]
B6 JFK-MSP SEP 1.0>0.3[0]
B6 JFK-MSY SEP 0.5>0.3[3]
B6 JFK-NAS SEP 0.4>0[1.2]
B6 JFK-ORD SEP 1.0>0.6[2]
B6 JFK-SAN SEP 0.9>0.5[3]
B6 JFK-SDQ SEP 4>3[6]
B6 JFK-SEA SEP 0.7>0.4[1.9]
B6 JFK-SFO SEP 3>2[6]
B6 JFK-SJU SEP 2.9>1.9[5]
B6 JFK-SLC SEP 0.7>0.4[2]
B6 MCO-PHL SEP 1.9>0.6[0]
B6 PBI-PHL SEP 2>0.1[0]
B6 PHL-RSW SEP 1.0>0.1[0]
B6 PHL-SJU SEP 1.0>0.3[0]
B6 PHL-TPA SEP 1.0>0.1[0]
BA ATL-LHR OCT 0.9>0.6[1.0]
BA AUS-LHR OCT 1.0>0.2[1.0]
BA BNA-LHR OCT 0.9>0.1[0.9]
BA BOS-LHR OCT 3>1.2[4]
BA BWI-LHR OCT 0.9>0.1[1.0]
BA DEN-LHR OCT 1.0>0.6[1.0]
BA EWR-LHR OCT 1.7>1.0[2]
BA IAD-LHR OCT 1.8>1.0[2]
BA IAH-LHR SEP 0.4>0[2] OCT 1.7>0.6[1.9]
BA JFK-LHR OCT 7>4[8]
BA LAS-LGW OCT 0.8>0[0.7]
BA LAX-LHR OCT 3>1.9[3]
BA LGW-MCO OCT 1.8>0.7[1.8]
BA LGW-TPA OCT 1.0>0.2[1.0]
BA LHR-MIA OCT 2>1.2[3]
BA LHR-MSY OCT 0.8>0.1[0.7]
BA LHR-ORD OCT 2>1.2[2]
BA LHR-PHL OCT 1.3>1.0[1.5]
BA LHR-PHX OCT 0.9>0.5[1.0]
BA LHR-PIT OCT 0.4>0[0.6]
BA LHR-SAN OCT 0.9>0.2[1.0]
BA LHR-SEA SEP 1.0>0.4[2] OCT 1.8>1.0[1.9]
BA LHR-SFO OCT 1.7>1.0[2]
BA LHR-SJC OCT 0.9>0.1[1.0]
CA EWR-PEK NOV 0.7>0[0.6] DEC 0.7>0[0.6] JAN 0.7>0[0.5] FEB 0.7>0[0.6] MAR 0.7>0.1[0.1]
CA JFK-PEK NOV 1.7>1.0[1.4] DEC 1.7>1.0[1.4] JAN 1.7>1.0[1.4] FEB 1.7>1.0[1.4] MAR 1.7>1.1[0.5]
CA LAX-PEK OCT 0.6>0.2[3] NOV 3>1.0[2] DEC 3>1.0[2] JAN 3>1.0[2] FEB 3>1.0[1.9] MAR 3>1.3[0.8]
CM IAD-PTY SEP 0.9>0.1[2]
CM JFK-PTY SEP 0.9>0.4[3]
CM LAX-PTY SEP 0.6>0.2[3]
CM MCO-PTY SEP 1.8>0.3[5]
CM MIA-PTY SEP 1.9>0.5[6]
CM ORD-PTY SEP 0.4>0[1.8]
CM PTY-SFO SEP 0.2>0[1.7]
DL basically gave up on a lot of Intl through the Winter. Anything that shows 0 in JUN I'm assuming is gone for 2021. Not a lot of vaccine hope in the DL HQ it seems.
There are a lot of DL route drops that appear to operate at Thanksgiving or Christmas. I'm assuming they have good bookings for these as of now and they will judge how many people cancel before they decide to operate those flights or not.
DL ABE-ATL OCT 3>1.0[3]
DL ABE-DTW OCT 3>2[3]
DL ABQ-ATL OCT 3>1.0[3]
DL ABQ-LAX OCT 3>1.8[3]
DL ACC-JFK DEC 0.5>0.8[0.6]
DL AEX-ATL OCT 4>3[4]
DL AGS-ATL OCT 9>6[7] NOV 9>8[7]
DL ALB-ATL OCT 3>1.0[3]
DL AMS-DTW OCT 1.3>1.0[4] NOV 1.8>1.0[3] DEC 2.0>1.0[3] JAN 2>1.0[3] FEB 1.9>1.0[3] MAR 2>1.2[3] APR 3>2[4] MAY 3>2[1.0]
DL AMS-JFK NOV 1.5>1.0[2] DEC 1.5>1.0[3] JAN 1.6>1.0[2] MAR 1.6>1.2[2]
**DL AMS-MCO APR 1.0>0[0.9] MAY 1.0>0[0] JUN 1.0>0[0]
*DL AMS-MSP OCT 0.5>0[3] NOV 1.9>0[1.9] DEC 2.0>0[2.0] JAN 1.8>0[1.8] FEB 2.0>0[1.9] MAR 2>0.3[2]
*DL AMS-PDX OCT 0.3>0[1.0] NOV 0.9>0[0.9] DEC 0.9>0[1.0] JAN 0.7>0[0.7] FEB 0.7>0[0.7] MAR 0.7>0.1[1.0] APR 1.0>0.6[0.9] MAY 1.0>0.6[0] JUN 1.0>0.6[0]
*DL AMS-SLC OCT 0.2>0[1.0] NOV 0.9>0[0.9] DEC 0.8>0[0.8] JAN 0.9>0[0.9] FEB 0.9>0[0.9] MAR 1.0>0.2[1.0]
**DL AMS-TPA APR 0.7>0[0.4] MAY 1.0>0[0] JUN 1.0>0[0]
DL ANC-SEA OCT 3>4[3]
DL APN-DTW OCT 0.7>1.7[1.0]
DL APN-PLN OCT 1.0>0[0.7] NOV 0.7>0.5[0.7]
**DL ASE-ATL DEC 0.4>0[0.4] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 0.9>0[0.9]
**DL ASE-LAX DEC 0.7>0[0.6] JAN 1.1>0[1.2] FEB 1.0>0[1.0] MAR 0.9>0[0.9]
*DL ATH-JFK MAR 0>0.7[0]
DL ATL-ATW OCT 2>0.7[1.7]
DL ATL-AUS OCT 8>5[7] NOV 8>7[7]
DL ATL-AVL OCT 8>5[7]
DL ATL-BCN APR 1.0>0.0[0.9]
DL ATL-BDA JAN 0.7>1.0[0.7] FEB 0.7>1.0[0.7] MAR 0.7>1.0[0.9] APR 0.7>1.0[1.0] MAY 0.7>1.0[1.0] JUN 0.7>1.0[0.3]
DL ATL-BDL OCT 6>4[6]
DL ATL-BHM OCT 11>7[10] NOV 11>10[10]
DL ATL-BMI OCT 3>2[3]
DL ATL-BNA OCT 11>6[11] NOV 11>9[10]
DL ATL-BOG SEP 0.7>0[1.0]
DL ATL-BOS OCT 12>7[12] NOV 12>11[11]
DL ATL-BQK OCT 3>2[3]
This looks gone long term
**DL ATL-BRU NOV 0.6>0[0.5] DEC 0.3>0[0.3] JAN 0.5>0[0.3] FEB 0.6>0[0.5] MAR 0.6>0[0.5] APR 1.0>0[0.5] MAY 1.0>0[0] JUN 1.0>0[0]
DL ATL-BTR OCT 7>4[7] NOV 7>6[7]
DL ATL-BUF OCT 5>2[5]
DL ATL-BUR OCT 1.8>0[1.7] NOV 1.9>1.4[1.6]
DL ATL-BWI OCT 9>5[10] NOV 9>8[10]
DL ATL-BZE SEP 0.3>0[0.7] OCT 0.5>0[0.8] NOV 1.0>0.3[0.9]
DL ATL-BZN DEC 0.8>0.4[0.7]
DL ATL-CAE OCT 8>7[7]
DL ATL-CHA OCT 10>8[9]
DL ATL-CHO OCT 5>3[5]
DL ATL-CID OCT 3>0[3] NOV 3>2[3]
DL ATL-CLE OCT 8>6[7]
DL ATL-CMH OCT 8>6[8]
DL ATL-COS OCT 1.0>0[1.0] NOV 1.0>0.8[0.9]
DL ATL-CRW OCT 5>4[5]
DL ATL-CSG OCT 4>3[4]
DL ATL-CVG OCT 8>6[8]
DL ATL-DAB OCT 5>4[5]
DL ATL-DAL OCT 5>4[5]
DL ATL-DAY OCT 4>3[4]
DL ATL-DCA OCT 11>6[11] NOV 11>10[11]
DL ATL-DEN OCT 8>5[7]
DL ATL-DFW OCT 9>6[8] NOV 9>8[8]
DL ATL-DHN OCT 4>3[4]
DL ATL-DTW OCT 11>9[11]
DL ATL-DUB APR 1.0>0.0[0.9]
**DL ATL-DUS OCT 0.2>0[0.9] NOV 0.7>0[0.7] DEC 0.6>0[0.6] JAN 0.7>0[0.7] FEB 0.7>0[0.7] MAR 0.7>0[0.7] APR 1.0>0[0.6] MAY 1.0>0[0] JUN 1.0>0[0]
DL ATL-ECP OCT 6>5[6]
DL ATL-ELP OCT 3>2[3]
DL ATL-EVV OCT 4>3[4]
DL ATL-EZE SEP 0.3>0[0.9]
DL ATL-FAY OCT 5>4[5]
*DL ATL-FCO OCT 0.2>0[1.0] NOV 0.7>0[0.7] DEC 0.7>0[0.7] JAN 0.6>0[0.6] FEB 0.6>0[0.6] MAR 0.7>0.2[0.7]
DL ATL-FLL OCT 12>6[11] NOV 12>10[12]
DL ATL-FRA NOV 0.9>0.6[0.9] DEC 0.9>0.6[0.9] JAN 1.0>0.6[1.0] FEB 1.0>0.6[1.0] MAR 1.0>0.6[1.0]
DL ATL-FWA OCT 4>3[4]
DL ATL-GCM OCT 0.3>0[0.8] NOV 1.1>0.4[1.1]
DL ATL-GNV OCT 7>4[7]
DL ATL-GPT OCT 5>4[5]
DL ATL-GRB OCT 1.8>0.7[1.7]
DL ATL-GRR OCT 5>3[5]
DL ATL-GSO OCT 8>7[8]
DL ATL-GTR OCT 4>2[4]
DL ATL-GUA SEP 0.7>0.5[1.0] OCT 1.0>0.7[1.0] DEC 1.4>1.0[1.4]
DL ATL-HHH OCT 3>1.7[3]
DL ATL-HND NOV 1.0>0.6[0] DEC 1.0>0.6[0]
DL ATL-HNL OCT 0.2>0[0.9] NOV 1.0>0.8[0.9]
DL ATL-HOU OCT 6>4[6]
DL ATL-HPN OCT 6>0[6] NOV 6>5[6]
DL ATL-IAD OCT 7>5[7]
DL ATL-ICN NOV 1.0>0.7[1.0] DEC 1.0>0.7[1.0]
DL ATL-ILM OCT 5>4[5]
DL ATL-IND OCT 9>6[9] NOV 9>8[9]
DL ATL-JAC JAN 0.4>1.0[0.4] FEB 0.7>1.0[0.7]
DL ATL-JAN OCT 8>4[6] NOV 8>7[6]
DL ATL-JAX OCT 11>7[11] NOV 11>10[11]
DL ATL-JFK OCT 8>5[8]
DL ATL-JNB JAN 1.0>0.5[1.0] FEB 1.0>0.4[0.9] MAR 1.0>0.5[1.0] APR 1.0>0.7[0.9] MAY 1.0>0.7[0] JUN 1.0>0.7[0]
This also looks gone long term
**DL ATL-KIN NOV 1.0>0.1[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[1.0] MAY 1.0>0[0.4] JUN 1.0>0[0.4]
DL ATL-LAS OCT 8>6[9]
DL ATL-LAX OCT 10>9[10]
DL ATL-LEX OCT 8>6[7]
DL ATL-LFT OCT 4>3[4]
DL ATL-LGA OCT 15>7[14] NOV 15>13[14]
DL ATL-LHR OCT 1.3>1.0[2] NOV 1.9>1.0[1.9] DEC 1.9>1.0[1.9] JAN 2>1.0[2] FEB 2>1.0[2] MAR 2>1.2[2]
DL ATL-LIM SEP 0.5>0[1.0]
I'm kinda aurprised to see this one gone long term
**DL ATL-LIR NOV 1.1>0.1[1.0] DEC 1.5>0[1.4] JAN 2>0[2] FEB 2>0[2] MAR 2>0[2] APR 1.0>0[0.7] MAY 1.0>0[0.4] JUN 1.0>0[0.1]
DL ATL-LIT OCT 7>4[6]
DL ATL-LOS DEC 0.6>0.8[0.7]
DL ATL-MAD APR 1.0>0.0[0.6]
Big cuts on MBJ
*DL ATL-MBJ NOV 3>0.6[3] DEC 4>0.1[4] JAN 4>0[4] FEB 4>0[4] MAR 4>1.2[4] APR 4>2[3] MAY 4>2[1.0] JUN 4>2[0.9]
DL ATL-MCI OCT 8>6[7]
DL ATL-MCO OCT 16>8[16] NOV 16>14[17]
DL ATL-MDT OCT 3>1.8[3]
DL ATL-MDW OCT 7>3[7] NOV 7>6[6]
DL ATL-MEM OCT 10>6[10] NOV 10>9[10]
DL ATL-MGM OCT 7>4[6]
DL ATL-MIA OCT 10>5[10] NOV 10>9[10]
DL ATL-MKE OCT 7>6[7]
DL ATL-MLB OCT 5>3[4]
DL ATL-MLI OCT 3>2[3]
DL ATL-MLU OCT 4>3[4]
DL ATL-MSN OCT 4>1.6[4]
DL ATL-MSP OCT 11>8[11]
DL ATL-MSY OCT 10>6[10] NOV 10>9[10]
*DL ATL-MTJ DEC 0.4>0[0.3] JAN 0.2>0[0.3]
DL ATL-MTY OCT 0.8>0.5[1.9]
DL ATL-MUC NOV 0.9>0.4[0.9] DEC 0.9>0.5[0.9] JAN 0.7>0.4[0.7] FEB 0.7>0.4[0.7] MAR 0.7>0.5[1.0]
DL ATL-MYR OCT 5>4[4]
DL ATL-NAS NOV 2>1.7[4] JAN 4>3[4] FEB 4>3[4] MAR 4>2[4] APR 4>2[4] MAY 4>2[0.5] JUN 4>2[0.9]
DL ATL-OKC OCT 6>4[5]
DL ATL-OMA OCT 5>4[5]
DL ATL-ONT OCT 1.8>1.5[1.7]
DL ATL-ORD OCT 9>6[10]
DL ATL-ORF OCT 8>7[8]
DL ATL-PBI OCT 9>5[9] NOV 10>9[10]
DL ATL-PDX OCT 3>4[3]
DL ATL-PHX OCT 5>4[6]
DL ATL-PIT OCT 8>5[7] NOV 8>7[7]
*DL ATL-PLS SEP 0.3>0.1[0.7] OCT 0.6>0[0.8] NOV 1.1>0.4[1.0]
DL ATL-PNS OCT 8>6[8]
DL ATL-PUJ NOV 1.1>0.2[1.2] DEC 1.5>0.4[1.4] JAN 2>1.0[2] FEB 2>1.0[2] MAR 2>0.4[2] APR 2>0[2] MAY 2>0[1.0] JUN 2>0[0.4]
DL ATL-PVD OCT 3>0[3] NOV 3>2[3]
Looks long term gone
**DL ATL-PVG OCT 0.2>0[0.9] NOV 1.0>0[0.9] DEC 1.0>0[0.8] JAN 1.0>0[0.8] FEB 1.0>0[0.9] MAR 1.0>0[0] APR 1.0>0[0] MAY 1.0>0[0] JUN 1.0>0[0]
DL ATL-PVR NOV 0.1>0.3[0.3] APR 0.7>1.0[0.6] MAY 0.7>1.0[0] JUN 0.7>1.0[0]
DL ATL-PWM OCT 3>1.0[3]
DL ATL-RDU OCT 11>8[12] NOV 11>10[12]
DL ATL-RIC OCT 9>6[8]
DL ATL-ROA OCT 5>3[5]
DL ATL-ROC OCT 3>1.0[3]
DL ATL-RST OCT 2>0[1.7] NOV 2>1.5[1.6]
DL ATL-RSW OCT 8>5[7] NOV 8>7[7]
DL ATL-SAN OCT 7>3[6]
DL ATL-SAT OCT 7>4[7]
DL ATL-SAV OCT 10>8[10]
DL ATL-SBN OCT 4>3[4]
DL ATL-SCL SEP 0.4>0[1.0]
DL ATL-SDF OCT 9>7[8]
DL ATL-SFO OCT 7>5[6]
DL ATL-SGF OCT 4>3[4]
DL ATL-SHV OCT 7>4[6]
DL ATL-SJC OCT 3>0[3] NOV 3>2[3]
So odd it operates in NOV and then gone. I assume there are bookings that might show up?
**DL ATL-SJO NOV 1.3>0.1[2] DEC 2>0[2] JAN 2>0[2] FEB 2>0[2] MAR 2>0[2] APR 2>0[1.7] MAY 2>0[0.5] JUN 2>0[0.2]
DL ATL-SNA OCT 3>1.6[3]
DL ATL-SRQ OCT 6>4[6]
DL ATL-STL OCT 8>5[8]
*DL ATL-STR OCT 0.2>0[0.9] NOV 0.7>0[0.7] DEC 0.6>0[0.6] JAN 0.7>0[0.7] FEB 0.7>0[0.7] MAR 0.7>0[0.6] APR 1.0>0.0[0] MAY 1.0>0.7[0] JUN 1.0>0.7[0]
DL ATL-STT SEP 2.4>1.2[0.9]
DL ATL-SXM SEP 0.3>0[0.7] OCT 0.6>0[0.7] NOV 1.0>0.5[0.7]
DL ATL-SYR OCT 3>1.0[3]
DL ATL-TPA OCT 13>7[13] NOV 13>11[12]
DL ATL-TRI OCT 7>4[6]
DL ATL-TUL OCT 5>3[4]
DL ATL-TUS OCT 2>1.0[1.8]
DL ATL-TYS OCT 9>7[8]
DL ATL-UIO SEP 0.3>0[1.0]
**DL ATL-UVF OCT 1.0>0.7[0.8] NOV 1.1>0.2[1.1] DEC 1.1>0[1.1] JAN 1.2>0[1.1] FEB 1.1>0[1.2] MAR 1.1>0[1.1] APR 1.1>0[1.1] MAY 1.2>0[0.2] JUN 1.1>0[0.3]
DL ATL-VPS OCT 7>6[7]
DL ATL-XNA OCT 5>4[5]
DL ATL-YUL OCT 5>0[5] NOV 5>4[4]
DL ATL-YVR OCT 1.0>0[0.4] NOV 1.0>0.8[0.4]
DL ATL-YYZ OCT 6>0[6] NOV 6>5[6]
DL AUS-DTW OCT 4>1.0[3]
DL AUS-JFK OCT 3>1.0[3]
DL AUS-LAX OCT 3>1.8[3]
DL AUS-MSP OCT 3>1.0[3]
DL AUS-SEA OCT 1.8>0.7[0.8]
DL AZO-MSP OCT 1.7>0.9[1.6]
DL BCN-JFK MAR 1.0>0.7[0.9]
DL BDL-DTW OCT 5>4[5]
DL BDL-MSP OCT 4>1.8[4]
**DL BER-JFK MAY 1.0>0[0] JUN 1.0>0[0]
DL BGM-DTW OCT 3>1.0[3]
DL BHM-DTW OCT 3>0[3] NOV 3>2[2]
DL BHM-LGA OCT 3>0[2] NOV 3>2[2]
DL BIS-MSP OCT 7>5[6]
DL BMI-DTW OCT 0>1.0[0] NOV 0>0.2[0]
DL BNA-BOS OCT 4>1.0[3]
DL BNA-DTW OCT 6>5[6]
DL BNA-JFK OCT 3>0[3] NOV 3>2[2]
DL BNA-LGA OCT 5>3[5]
DL BNA-MSP OCT 5>4[5]
DL BOI-LAX OCT 1.8>1.0[1.7]
DL BOI-MSP OCT 2>3[1.8]
DL BOI-SEA OCT 7>6[6]
DL BOI-SLC OCT 5>4[6]
**DL BOM-JFK DEC 0.7>0[0.3] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[0.5] MAY 1.0>0[0] JUN 1.0>0[0]
DL BOS-CDG DEC 0.8>0.5[0.8]
DL BOS-CLE OCT 3>0.8[2] NOV 3>2.0[2]
DL BOS-CMH OCT 3>0[3] NOV 3>2[2]
DL BOS-DCA OCT 5>0[5] NOV 5>4[5]
DL BOS-DTW OCT 7>4[6]
*DL BOS-DUB OCT 0.3>0[0.8] NOV 1.0>0[0] DEC 1.0>0[0.3] MAR 0.1>0.5[0.6]
**DL BOS-EDI MAY 1.0>0[0] JUN 1.0>0[0]
DL BOS-EWR OCT 4>0[4] NOV 4>3[4]
**DL BOS-FCO JUN 1.0>0[0]
DL BOS-FLL OCT 1.0>0.7[1.0]
DL BOS-IND OCT 4>0[3] NOV 4>3[3]
DL BOS-JAX OCT 3>0[2] NOV 3>2[2]
DL BOS-JFK OCT 8>3[8] NOV 8>7[7]
DL BOS-LAS OCT 1.0>0.7[1.0]
DL BOS-LAX OCT 3>1.8[2]
DL BOS-LGA OCT 14>4[14] NOV 14>11[13]
DL BOS-LHR NOV 1.0>0.7[1.0] DEC 1.0>0.7[1.0] JAN 1.0>0.7[1.0] FEB 1.0>0.7[1.0] MAR 1.0>0.7[1.0]
**DL BOS-LIS MAY 1.0>0[0] JUN 1.0>0[0]
DL BOS-MBJ DEC 0.4>0[0.3] JAN 0.2>0[0.2]
DL BOS-MCI OCT 3>0[2] NOV 3>2[2]
DL BOS-MCO OCT 3>1.0[3]
DL BOS-MKE OCT 1.8>0[1.7] NOV 1.9>1.4[1.6]
DL BOS-MSP OCT 6>4[5]
DL BOS-NAS DEC 0.4>0[0.3]
DL BOS-ORD OCT 5>0[4] NOV 5>4[4]
DL BOS-PHL OCT 6>0[5] NOV 6>4[5]
DL BOS-PIT OCT 5>0.8[4] NOV 5>4[4]
DL BOS-RDU OCT 6>3[5]
DL BOS-SFO OCT 1.8>0[1.7] NOV 1.0>0.8[1.0]
DL BOS-TPA OCT 3>1.0[3]
DL BRU-JFK NOV 0.9>0.7[0.9] DEC 1.0>0.7[0.9] JAN 1.0>0.7[1.0] FEB 1.0>0.7[1.0] MAR 1.0>0.7[1.0]
DL BTV-JFK OCT 3>0[3] NOV 3>2[3]
DL BUF-DTW OCT 5>3[4]
DL BUF-JFK OCT 5>1.0[5] NOV 5>4[4]
DL BUF-LGA OCT 4>0[3] NOV 4>3[3]
DL BUR-SLC OCT 5>2[5]
DL BWI-CVG OCT 3>0[2] NOV 3>2.0[2]
DL BWI-DTW OCT 5>4[4]
DL BWI-JFK OCT 4>0[4] NOV 4>3[4]
DL BWI-MSP OCT 3>2[3]
DL BWI-SLC OCT 1.8>1.0[1.7]
DL BZN-LAX DEC 0.7>0.4[0.6]
DL BZN-MSP JAN 2>3[2] FEB 2>3[2] MAR 2>3[3]
DL BZN-SLC OCT 3>4[3]
DL CAE-LGA OCT 1.8>0[1.6] NOV 1.9>1.4[1.5]
*DL CDG-CVG OCT 0.2>0[0.9] NOV 0.6>0[0.7] DEC 0.6>0[0.6] JAN 0.7>0[0.7] FEB 0.7>0[0.7] MAR 0.7>0.1[0.7] APR 1.0>0.6[0.6] MAY 1.0>0.6[0] JUN 1.0>0.6[0]
**DL CDG-IND APR 0.7>0[0.5] MAY 0.8>0[0] JUN 1.0>0[0]
DL CDG-JFK OCT 1.3>1.0[1.8] NOV 2.0>1.0[1.0] DEC 2>1.0[1.0] JAN 2>1.0[1.0] FEB 1.9>1.0[0.9] MAR 1.7>1.0[1.0]
*DL CDG-LAX OCT 0.2>0[1.0] NOV 0.7>0[0.8] DEC 0.8>0[0.7] JAN 0.6>0[0.6] FEB 0.6>0[0.6] MAR 0.7>0.2[0.7]
*DL CDG-MSP OCT 0.3>0[1.0] NOV 0.9>0[0.9] DEC 0.5>0[0.6] JAN 0.9>0[0.8] FEB 0.9>0[0.9] MAR 0.9>0.2[1.0]
*DL CDG-RDU OCT 0.2>0[0.9] NOV 0.6>0[0.7] DEC 0.6>0[0.6] JAN 0.7>0[0.7] FEB 0.7>0[0.7] MAR 0.7>0.1[0.7] APR 1.0>0.7[0.6] MAY 1.0>0.7[0] JUN 1.0>0.7[0]
DL CDG-SEA NOV 1.0>0.6[1.0] DEC 1.0>0.5[1.0]
DL CHA-DTW OCT 3>0[2] NOV 3>2[2]
DL CHS-DTW OCT 3>0[3] NOV 3>2[3]
DL CHS-JFK OCT 3>0.7[3]
DL CHS-LGA OCT 3>0[3] NOV 3>2[3]
DL CID-DTW OCT 4>1.0[4]
DL CLE-JFK OCT 4>0[3] NOV 4>3[3]
DL CLE-LGA OCT 5>1.8[5] NOV 5>4[5]
DL CLT-CVG OCT 3>0[2] NOV 3>2.0[2]
DL CLT-JFK OCT 4>0[4] NOV 4>3[3]
DL CLT-LGA OCT 7>3[7] NOV 7>6[6]
DL CLT-MSP OCT 4>3[4]
DL CMH-JFK OCT 3>0[3] NOV 3>2[2]
DL CMH-LAX OCT 0.9>0[0.8] NOV 0.9>0.7[0.7]
DL CMH-LGA OCT 5>1.8[5] NOV 5>4[5]
*DL CPH-JFK MAY 0.4>0[0] JUN 1.0>0[0]
DL CUN-MSP NOV 1.0>0.8[1.0]
DL CVG-DCA OCT 3>1.8[2]
DL CVG-DEN OCT 1.0>0[1.0] NOV 1.0>0.8[0.8]
DL CVG-DFW OCT 2>0[2] NOV 2>1.9[2]
DL CVG-EWR OCT 2>1.5[2]
DL CVG-FLL OCT 1.0>0[0.8] NOV 1.0>0.8[0.9]
DL CVG-JFK OCT 1.0>0[1.0] NOV 1.0>0.8[1.0]
DL CVG-LAX OCT 1.8>0.9[1.7]
DL CVG-MCO OCT 3>1.0[3]
DL CVG-ORD OCT 4>0[3] NOV 4>3[3]
DL CVG-PHL OCT 2>0[2] NOV 2>1.9[2]
DL CVG-PHX NOV 1.0>0.8[0.8]
DL CVG-RDU OCT 1.7>0[1.6] NOV 1.7>1.3[1.5]
DL CVG-SEA OCT 1.0>0[0.5]
DL CVG-SFO OCT 0.9>0[0.8] NOV 0.9>0.7[0.8]
DL CVG-SLC OCT 2>3[1.7]
DL CVG-YYZ OCT 1.7>0[1.5] NOV 1.7>1.3[1.4]
DL CWA-DTW OCT 1.8>1.0[1.8]
DL CWA-MSP OCT 3>2[3]
DL DAY-MSP OCT 3>0[3] NOV 3>2[2]
DL DCA-DTW OCT 6>4[5]
DL DCA-JFK OCT 5>3[5]
DL DCA-LEX OCT 0.8>0[0.8] NOV 0.9>0.7[0.8]
DL DCA-LGA OCT 8>3[9] NOV 8>7[8]
DL DCA-MSN OCT 0.8>0[0.8] NOV 0.9>0.7[0.8]
DL DCA-MSP OCT 6>4[5]
DL DCA-OMA OCT 0.8>0[0.8] NOV 0.9>0.7[0.8]
DL DEN-DTW OCT 4>3[4]
DL DEN-JFK OCT 3>1.5[3]
DL DEN-LAX OCT 4>3[4]
DL DEN-LGA OCT 1.8>0[1.8] NOV 1.9>1.4[1.8]
DL DEN-MSP OCT 6>4[5]
DL DEN-SEA OCT 4>3[4]
DL DEN-SLC OCT 6>4[6]
DL DFW-DTW OCT 6>4[5]
DL DFW-LAX OCT 4>2[3]
DL DFW-LGA OCT 5>3[5]
DL DFW-MSP OCT 6>4[6]
DL DLH-MSP OCT 6>4[6]
DL DSM-DTW OCT 4>2[4]
DL DTW-ELM OCT 5>1.7[5]
DL DTW-EVV OCT 3>2[3]
DL DTW-EWR OCT 6>4[6]
*DL DTW-FRA OCT 0.3>0[1.0] NOV 0.9>0[0.9] DEC 0.5>0[0.6] JAN 0.9>0[0.8] FEB 1.0>0[1.0] MAR 1.0>0[1.0] APR 1.0>0.0[0.9]
DL DTW-GRB OCT 4>3[4]
DL DTW-GRR OCT 7>5[6]
DL DTW-GSO OCT 3>0[3] NOV 3>2[3]
DL DTW-GSP OCT 3>0.8[3] NOV 3>2[3]
DL DTW-HND NOV 1.0>0.4[0] DEC 1.0>0.4[0]
DL DTW-IAD OCT 5>3[5]
DL DTW-IAH OCT 5>3[5]
DL DTW-IND OCT 7>5[6]
DL DTW-ITH OCT 3>1.0[3]
DL DTW-JAX OCT 1.9>0[1.7] NOV 1.9>1.4[1.7]
DL DTW-JFK OCT 4>3[4]
DL DTW-LAN OCT 5>3[4]
DL DTW-LAX OCT 7>4[6]
DL DTW-LEX OCT 4>2[4]
DL DTW-LGA OCT 7>4[7]
*DL DTW-LHR OCT 0.3>0[2] NOV 1.0>0[1.8] DEC 1.0>0[1.6] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 1.0>0.2[1.0]
**DL DTW-MBJ DEC 0.5>0[0.5] JAN 1.1>0[1.1] FEB 1.1>0[1.2] MAR 1.1>0[1.1] APR 1.0>0[0.9] MAY 1.0>0[0] JUN 1.0>0[0]
DL DTW-MBS OCT 5>3[5]
DL DTW-MCI OCT 4>3[4]
DL DTW-MDW OCT 4>0[4] NOV 4>3[4]
DL DTW-MEM OCT 3>2[3]
DL DTW-MIA OCT 2>1.0[1.8]
DL DTW-MKE OCT 5>3[5]
DL DTW-MLI OCT 1.8>0[1.9] NOV 1.9>1.4[1.8]
DL DTW-MSN OCT 6>3[5]
DL DTW-MSP OCT 8>6[8]
**DL DTW-MUC MAY 1.0>0[0] JUN 1.0>0[0]
DL DTW-MYR OCT 1.0>0.7[0.8]
*DL DTW-NGO NOV 0.6>0[0.6] DEC 0.6>0[0.6] JAN 0.6>0[0.6] FEB 0.6>0[0.5] MAR 0.6>0.1[0.5] APR 1.0>0.4[0] MAY 1.0>0.5[0] JUN 1.0>0.4[0]
DL DTW-OKC OCT 1.8>0[1.7] NOV 1.9>1.4[1.6]
DL DTW-OMA OCT 4>2[3]
DL DTW-ORD OCT 7>4[6]
DL DTW-PHL OCT 5>4[5]
DL DTW-PHX OCT 4>3[3]
DL DTW-PIT OCT 5>4[5]
**DL DTW-PKX OCT 0.2>0[0] NOV 1.0>0[0] DEC 1.0>0[0] JAN 1.0>0[0] FEB 1.0>0[0] MAR 1.0>0[0] APR 1.0>0[0] MAY 1.0>0[0] JUN 1.0>0[0]
DL DTW-PVD OCT 4>0[3] NOV 4>3[3]
**DL DTW-PVR DEC 0.4>0.0[0.3] JAN 0.5>0[0.5] FEB 0.4>0[0.4] MAR 0.4>0[0.5] APR 0.4>0[0.1] MAY 0.5>0[0] JUN 0.4>0[0]
DL DTW-RDU OCT 5>4[4]
DL DTW-RIC OCT 4>2[4]
DL DTW-ROC OCT 4>3[4]
DL DTW-SAN OCT 3>1.6[3]
DL DTW-SAT OCT 3>1.0[3]
DL DTW-SBN OCT 5>4[4]
DL DTW-SCE OCT 3>2[3]
DL DTW-SDF OCT 5>3[5]
DL DTW-SFO OCT 5>3[4]
*DL DTW-SJD MAY 0.5>0[0] JUN 0.4>0[0]
DL DTW-STL OCT 5>3[5]
DL DTW-TPA OCT 4>3[4]
DL DTW-TVC OCT 5>4[5]
DL DTW-TYS OCT 5>2[4]
DL DTW-YUL OCT 4>1.0[4]
DL DTW-YYZ OCT 5>2[5]
DL DUB-JFK NOV 0.9>0.7[0.9] DEC 0.9>0.7[0.9] JAN 1.0>0.7[1.0] MAR 1.0>0.7[1.0]
*DL EDI-JFK OCT 0.3>0[1.0] NOV 0.9>0[0.9] DEC 0.9>0[0.9] JAN 0.6>0[0.5] FEB 0.6>0[0.6] MAR 0.6>0[1.0] APR 1.0>0.0[0]
DL EGE-SLC DEC 0.3>0[0.3]
DL EWR-MSP OCT 6>4[5]
DL EWR-SLC OCT 1.0>0.7[1.0]
DL FAR-MSP OCT 8>5[7]
DL FCA-LAX JAN 0.1>0.3[0.2]
DL FCA-MSP JAN 1.1>1.3[1.2]
DL FCO-JFK JUN 1.0>2[0]
DL FLL-JFK OCT 4>1.7[3]
DL FLL-LGA OCT 5>2[5]
DL FLL-MSP OCT 1.0>0[0.7] NOV 1.0>0.8[1.1]
DL FRA-JFK NOV 0.9>0.7[0.9] DEC 0.9>0.7[0.9] JAN 1.0>0.7[1.0] FEB 1.0>0.7[1.0] MAR 1.0>0.7[1.0]
DL FSD-MSP OCT 7>5[6]
DL GEG-MSP OCT 2>3[2]
DL GEG-SEA OCT 9>7[8]
DL GFK-MSP OCT 6>3[6]
**DL GLA-JFK MAY 0.4>0[0] JUN 1.0>0[0]
DL GRB-MSP OCT 4>3[4]
DL GRR-LGA OCT 3>0[2] NOV 3>2[2]
DL GRR-MSP OCT 5>4[5]
DL GSO-LGA OCT 4>0[4] NOV 4>3[4]
DL GSP-LGA OCT 3>0[2] NOV 3>2[2]
DL GTF-MSP OCT 1.0>0.7[1.0]
DL GUA-LAX NOV 0.3>0[0.9] DEC 1.4>0.5[1.4]
DL HLN-MSP OCT 0.9>0[0.9] NOV 0.9>0.7[0.8]
DL HLN-SLC OCT 3>2[3]
DL HND-HNL OCT 0.3>0[0] NOV 1.0>0[0] DEC 1.0>0.2[0] JAN 1.0>0.6[0] FEB 1.0>0.6[0] MAR 1.0>0.6[0.1]
DL HND-LAX NOV 1.0>0.4[1.0] DEC 1.0>0.4[1.0]
*DL HND-MSP OCT 0.3>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 1.0>0.1[1.0] APR 1.0>0.7[0.4] MAY 1.0>0.7[0] JUN 1.0>0.7[0]
*DL HND-PDX OCT 0.3>0[0] NOV 1.0>0[0] DEC 1.0>0[0] JAN 1.0>0[0] FEB 1.0>0[0] MAR 1.0>0.1[0.1] APR 1.0>0.7[0] MAY 1.0>0.7[0] JUN 1.0>0.7[0]
DL HND-SEA NOV 1.0>0.6[0] DEC 1.0>0.6[0]
**DL HNL-KIX OCT 0.3>0[0.9] NOV 1.0>0[1.0] DEC 1.0>0[1.1] JAN 1.0>0[1.1] FEB 1.0>0[0.9] MAR 1.0>0[1.0] APR 1.0>0[0.1] MAY 1.0>0[0] JUN 1.0>0[0]
**DL HNL-NGO OCT 0.2>0[0.7] NOV 0.7>0[0.7] DEC 0.8>0[0.8] JAN 0.8>0[0.7] FEB 0.7>0[0.7] MAR 0.7>0[0.7] APR 0.7>0[0.0] MAY 0.7>0[0] JUN 1.0>0[0]
DL HNL-SLC OCT 0.9>0[0.9] NOV 0.9>0.7[0.9]
*DL HRL-MSP DEC 0.4>0[0.4] JAN 0.9>0[0.9] FEB 0.9>0[0.9] MAR 0.9>0[0.9]
DL IAD-JFK OCT 4>3[4]
DL IAD-SEA OCT 1.9>0[0.9] NOV 1.9>1.4[0.8]
DL IAD-SLC OCT 1.0>0.7[0.8]
DL IAH-JFK OCT 2>0[0.3] NOV 2>1.5[2.0]
DL IAH-MSP OCT 5>3[4]
*DL ICN-MSP OCT 0.3>0[0.8] NOV 1.0>0[0.8] DEC 1.0>0[1.0] JAN 1.0>0[0.9] FEB 1.0>0[0.9] MAR 1.0>0.1[0.9] APR 1.0>0.7[0] MAY 1.0>0.7[0] JUN 1.0>0.7[0]
DL ICN-SEA NOV 1.0>0.6[0.9] DEC 1.0>0.6[1.0]
DL ICT-MSP OCT 3>2[3]
DL IDA-SLC OCT 4>3[4]
DL IND-JFK OCT 3>0[3] NOV 3>2[2]
DL IND-LAX OCT 0.9>0[0.9] NOV 0.9>0.7[0.8]
DL IND-LGA OCT 5>1.8[4] NOV 5>4[4]
DL IND-MSP OCT 5>4[5]
DL IND-SLC OCT 1.0>0.7[0.9]
DL JAC-SEA DEC 0.3>0[0.3]
DL JAC-SLC JAN 3>4[3] FEB 3>4[3]
DL JAX-JFK OCT 3>0.7[3]
DL JAX-LGA OCT 3>0[3] NOV 3>2[3]
DL JFK-KEF APR 0.7>0.0[0] JUN 1.0>0.7[0]
DL JFK-LAS OCT 5>1.8[5] NOV 5>4[4]
DL JFK-LHR OCT 1.5>1.0[2] NOV 3>1.0[2] DEC 3>1.0[2] JAN 3>1.0[2] FEB 3>1.0[2] MAR 3>1.2[2]
*DL JFK-LIS OCT 0.2>0[0.9] NOV 0.7>0[0.7] DEC 0.7>0[0.7] JAN 0.6>0[0.6] FEB 0.6>0[0.6]
**DL JFK-MBJ NOV 1.0>0.1[1.0] DEC 1.4>0[1.3] JAN 2.0>0[1.3] FEB 2>0[1.2] MAR 2>0[1.1] APR 1.0>0[1.1] MAY 1.0>0[0] JUN 1.0>0[0]
DL JFK-MCO OCT 4>1.7[4]
DL JFK-MIA OCT 4>1.0[4]
DL JFK-MSY OCT 3>0.9[3]
DL JFK-MXP NOV 1.0>0.7[1.0] DEC 1.0>0.7[1.0] JAN 1.0>0.7[1.0] FEB 1.0>0.7[1.0] MAR 1.0>0.7[1.0]
DL JFK-NAS NOV 1.0>0.8[1.3]
DL JFK-NCE APR 1.0>0.0[0.7]
DL JFK-ORD OCT 5>2[5]
DL JFK-PDX OCT 1.8>0.7[1.6]
DL JFK-PHX OCT 2>0.7[1.9]
DL JFK-PIT OCT 3>0[3] NOV 3>2[3]
**DL JFK-PRG MAY 1.0>0[0] JUN 1.0>0[0]
DL JFK-PWM OCT 3>0[3] NOV 3>2[3]
DL JFK-RDU OCT 5>3[5]
DL JFK-RIC OCT 3>0[3] NOV 3>2[3]
DL JFK-ROC OCT 3>1.0[3]
DL JFK-SAN OCT 3>1.0[3]
DL JFK-SAT OCT 1.0>0[1.0] NOV 1.0>0.8[1.0]
DL JFK-SAV OCT 2>0.7[2]
DL JFK-SEA OCT 5>3[4]
DL JFK-SFO OCT 7>3[7] NOV 7>6[7]
DL JFK-SLC OCT 4>3[4]
**DL JFK-SNN MAY 0.8>0[0] JUN 1.0>0[0]
DL JFK-STI JAN 3>2[3] FEB 3>2[3] MAR 3>2[3] APR 3>2[3] MAY 3>2[1.0] JUN 3>2[0.7]
**DL JFK-STT SEP 0.7>0[0.1] NOV 0.9>0.2[0.3] DEC 0.5>0[0.7] JAN 1.0>0[0.9] FEB 1.0>0[0.9] MAR 1.0>0[0.9] APR 1.0>0[1.0] MAY 1.0>0[0] JUN 1.0>0[0]
DL JFK-TLV NOV 1.7>1.0[1.0]
DL JFK-TPA OCT 4>1.7[4]
DL JFK-VCE APR 1.0>0.0[0]
DL JFK-YUL OCT 3>0[3] NOV 3>2[3]
DL JFK-YYZ SEP 0.2>0[4] OCT 4>0[4] NOV 4>3[4]
DL JFK-ZRH NOV 0.9>0.7[0.9] DEC 0.9>0.7[0.9] JAN 1.0>0.7[1.0] FEB 1.0>0.7[1.0] MAR 1.0>0.7[1.0]
DL KIX-SEA APR 1.0>0[0] MAY 1.0>0[0] JUN 1.0>0[0]
DL KOA-SEA OCT 1.0>0[0.7] NOV 1.0>0.8[0.7]
DL LAN-MSP OCT 1.0>0[1.0] NOV 1.0>0.8[1.0]
DL LAS-LAX OCT 7>5[7]
DL LAS-SLC OCT 5>4[5] APR 5>4[5] MAY 5>4[2] JUN 5>4[2]
DL LAX-LIH OCT 0.5>0.7[0.5]
DL LAX-MCI OCT 1.8>0[1.7] NOV 1.9>1.4[1.5]
DL LAX-MCO OCT 3>2[2]
DL LAX-MSP OCT 7>5[6]
DL LAX-MSY OCT 3>0.9[3]
DL LAX-PHX OCT 6>4[5]
*DL LAX-PVG OCT 0.3>0[0.9] NOV 1.0>0[0.9] DEC 1.0>0[0.9] JAN 1.0>0[0.9] FEB 1.0>0[0.8] MAR 1.0>0.2[0]
DL LAX-SAT OCT 2>0[1.8] NOV 2>1.5[1.6]
DL LAX-SFO OCT 8>5[7]
DL LAX-SJC OCT 7>3[6] NOV 7>6[6]
DL LAX-SJD OCT 0.7>2[1.0] NOV 1.0>1.6[1.0]
**DL LAX-SJO NOV 0.3>0[0.9] DEC 1.0>0[1.0] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 1.0>0[1.0] APR 1.0>0[0.5] MAY 1.0>0[0.6] JUN 1.0>0[0]
DL LAX-SLC OCT 8>6[7]
DL LAX-SMF OCT 6>3[5]
DL LAX-SUN JAN 0.1>0.3[0.2]
DL LAX-SYD NOV 1.0>0.7[1.0]
DL LAX-TUS OCT 3>1.0[3]
DL LGA-MCO OCT 5>2[4]
DL LGA-MEM OCT 3>0[2] NOV 3>2[2]
DL LGA-MIA OCT 4>1.0[4] NOV 5>4[4]
DL LGA-MKE OCT 5>0[4] NOV 5>4[4]
DL LGA-MSN OCT 3>0[2] NOV 3>2[2]
DL LGA-MSP OCT 7>3[6] NOV 7>6[6]
DL LGA-MSY OCT 3>0[3] NOV 3>2[3]
DL LGA-OMA OCT 3>0[2] NOV 3>2.0[2]
DL LGA-ORD OCT 12>4[10] NOV 13>10[10]
DL LGA-ORF OCT 4>0[4] NOV 4>3[4]
DL LGA-PBI OCT 4>0.7[4]
DL LGA-PIT OCT 7>3[7] NOV 7>6[6]
DL LGA-PWM OCT 4>0[4] NOV 4>3[3]
DL LGA-RDU OCT 7>3[7] NOV 7>6[7]
DL LGA-RIC OCT 4>2[4]
DL LGA-ROC OCT 4>0[3] NOV 4>3[3]
DL LGA-RSW OCT 3>0[3] NOV 3>2[3]
DL LGA-SAV OCT 3>0[3] NOV 3>2[2]
DL LGA-SDF OCT 4>0[3] NOV 4>3[3]
DL LGA-STL OCT 5>2[5]
DL LGA-SYR OCT 3>0[3] NOV 3>2.0[3]
DL LGA-TPA OCT 4>1.0[4]
DL LGA-TYS OCT 3>0[2] NOV 3>2.0[2]
DL LGA-XNA OCT 0.8>0[0.8] NOV 0.9>0.7[0.7]
DL LGA-YUL OCT 4>0[4] NOV 4>3[3]
DL LGB-SLC OCT 5>2[5]
*DL LHR-MSP OCT 0.3>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 1.0>0.2[1.0]
**DL LHR-PDX APR 0.2>0[0.2] MAY 1.0>0[0] JUN 1.0>0[0]
**DL LHR-SLC OCT 0.3>0[0.6] NOV 1.0>0[0] DEC 0.9>0[0.3] JAN 0.9>0[0.9] FEB 0.9>0[0.9] MAR 0.9>0[1.0] APR 1.0>0[0.9] MAY 1.0>0[0] JUN 1.0>0[0]
DL LIH-SEA OCT 1.0>0[0.7] NOV 1.0>0.8[0.7]
*DL MBJ-MSP MAY 1.0>0[0] JUN 1.0>0[0]
DL MBS-MSP OCT 0.9>0[0.9] NOV 0.9>0.7[0.8]
DL MCI-MSP OCT 5>4[5]
DL MCO-RDU OCT 3>1.0[3]
DL MCO-SEA OCT 1.0>0.6[0.5]
DL MCO-SLC OCT 3>2[3]
DL MDW-MSP OCT 6>0[6] NOV 6>5[6]
DL MEM-MSP OCT 3>2[3]
DL MFR-SLC OCT 2>3[2.0]
DL MIA-MSP OCT 2>1.0[1.7]
DL MKE-MSP OCT 5>4[5]
DL MKE-SEA OCT 1.0>0[0.9] NOV 0.9>0.7[0.8]
DL MKE-SLC OCT 1.0>0.7[0.8]
DL MSN-MSP OCT 6>4[5]
DL MSP-MSY OCT 1.0>0.7[1.3]
DL MSP-OKC OCT 3>2[2]
DL MSP-OMA OCT 7>3[6]
DL MSP-ORD OCT 7>5[6]
DL MSP-PHL OCT 5>4[4]
DL MSP-PHX OCT 5>3[5]
DL MSP-PIT OCT 4>3[4]
DL MSP-PSC OCT 2>1.0[1.8]
*DL MSP-PUJ MAY 0.7>0[0] JUN 0.7>0[0]
*DL MSP-PVR MAY 1.0>0[0] JUN 1.0>0[0]
DL MSP-RAP OCT 5>4[5]
DL MSP-RDU OCT 4>3[4]
DL MSP-RIC OCT 1.8>0[1.7] NOV 1.9>1.4[1.8]
DL MSP-RST OCT 4>3[4]
DL MSP-SAN OCT 4>3[4]
DL MSP-SAT OCT 3>1.0[3]
DL MSP-SBN OCT 2>0[1.9] NOV 2>1.5[1.8]
DL MSP-SDF OCT 3>1.0[3]
DL MSP-SFO OCT 6>4[5]
DL MSP-SJC OCT 3>0[3] NOV 2>1.5[1.7]
*DL MSP-SJD APR 1.0>0[0.3] MAY 1.0>0[0] JUN 1.0>0[0]
DL MSP-SLC OCT 5>7[5]
DL MSP-SNA OCT 3>1.0[3]
DL MSP-STL OCT 5>4[5]
DL MSP-TPA OCT 2>0.7[1.8]
DL MSP-TUL OCT 1.8>0[1.8] NOV 1.9>1.4[1.7]
DL MSP-TUS NOV 1.0>0.8[0.9]
**DL MSP-TVC OCT 0.0>1.0[0] NOV 0>0.2[0]
DL MSP-XNA OCT 1.5>0[1.6] NOV 1.6>1.2[1.5]
DL MSP-YUL OCT 1.8>0[1.7] NOV 1.0>0.8[0.9]
DL MSP-YVR OCT 2>0[1.7] NOV 2>1.5[1.7]
DL MSP-YWG OCT 4>0.4[4] NOV 4>3[4]
DL MSP-YYC OCT 3>0.4[3]
DL MSP-YYZ OCT 4>0[3] NOV 4>3[3]
DL OAK-SLC OCT 5>2[5]
DL OGG-SEA OCT 1.0>0[1.0] NOV 1.0>0.8[1.0]
DL OMA-SLC OCT 2>3[1.7]
**DL ONT-SEA OCT 0>2[0] NOV 0>0.5[0]
DL ORD-RDU OCT 3>0[2] NOV 3>2[2]
DL ORD-SEA OCT 3>2[3]
DL ORD-SLC OCT 4>3[4]
DL PDX-SEA OCT 8>6[8]
DL PDX-SLC OCT 6>4[5]
DL PHL-SLC OCT 1.0>0.7[1.0]
DL PHX-SLC OCT 5>4[5]
DL PIT-SLC OCT 0.9>0[0.9] NOV 0.9>0.7[0.8]
*DL PKX-SEA OCT 0.2>0[0] NOV 1.0>0[0] DEC 1.0>0[0] JAN 1.0>0[0] FEB 1.0>0[0] MAR 1.0>0.2[0]
DL PSC-SEA OCT 4>3[4]
DL PSP-SLC OCT 3>2[3]
DL RAP-SLC OCT 2>1.0[1.7]
DL RDM-SLC OCT 2>3[2.0]
DL RDU-SLC OCT 1.0>0.7[0.8]
DL RDU-TPA OCT 3>1.0[3]
DL RNO-SLC OCT 5>4[5]
DL SAN-SEA OCT 5>3[5]
DL SAN-SLC OCT 5>4[5]
DL SEA-SFO OCT 7>4[7]
DL SEA-SJC OCT 6>3[5]
*DL SEA-SJD APR 1.0>0[0.4] MAY 1.0>0[0] JUN 1.0>0[0]
DL SEA-SLC OCT 8>6[8]
DL SEA-SMF OCT 5>4[5]
DL SEA-SNA OCT 4>2[5]
DL SEA-YVR OCT 6>1.0[7] NOV 5>4[6]
DL SEA-YYC OCT 3>0[3] NOV 2>1.5[2]
DL SFO-SLC OCT 5>4[5]
DL SJC-SLC OCT 5>4[5]
DL SLC-SMF OCT 5>4[5]
DL SLC-SUN OCT 3>2[3] JAN 3>4[3] FEB 3>4[3] MAR 3>4[3]
DL SLC-TPA OCT 1.0>0.7[0.8]
DL SLC-TUL OCT 1.0>2[1.0] NOV 1.0>1.2[1.0]
DL SLC-WYS OCT 0.4>1.0[0.4] NOV 0>0.2[0]
DL SLC-YVR OCT 2>0[1.7] NOV 2>1.5[1.7]
DL SLC-YYC OCT 2>0[1.8] NOV 2>1.5[1.7]
DL SLC-YYZ OCT 1.0>0[1.0] NOV 1.0>0.8[0.9]
EK ATH-EWR SEP 1.0>0.5[1.0]
EK BOS-DXB OCT 1.0>0.6[1.0]
EK DFW-DXB OCT 1.0>0.6[1.0]
EK DXB-IAD OCT 1.0>0.7[1.0]
EK DXB-JFK OCT 2>1.2[2]
EK DXB-LAX SEP 1.0>0.6[1.0] OCT 1.0>0.6[1.0]
EK DXB-MCO OCT 0.7>0.2[0.7]
EK DXB-ORD OCT 1.0>0.8[1.0]
EK DXB-SEA SEP 0.5>0.2[1.0] OCT 1.0>0.6[1.0]
EK DXB-SFO SEP 0.5>0.2[1.0] OCT 1.0>0.5[1.0]
EK JFK-MXP SEP 1.0>0.5[1.0]
EY AUH-IAD OCT 1.0>0.8[1.0]
EY AUH-LAX OCT 0.5>0.1[0.5]
F2 MBA-MDR SEP 1.0>0[0] OCT 1.0>0[0] DEC 0.4>0[0] JAN 1.0>0[0] FEB 1.0>0[0] MAR 1.0>0[0] JUN 0.5>0[0]
F2 MDR-WIL SEP 4>0[0] OCT 4>0[0] NOV 2>0[0] DEC 2>0[0] JAN 2>0[0] FEB 2>0[0] MAR 2>0[0] APR 2>0[0] MAY 2>0[0] JUN 2>0[0]
FI JFK-KEF SEP 0.2>0[1.5]
HA BOS-HNL SEP 0.3>0[0.8]
HA CTS-HNL SEP 0.2>0[0.4]
HA FUK-HNL SEP 0.3>0[0]
HA HND-HNL SEP 1.3>0[1.6]
HA HND-KOA SEP 0.2>0[0.4]
HA HNL-ICN SEP 0.3>0[0.7]
HA HNL-ITO SEP 12>10[14]
HA HNL-JFK SEP 0.5>0[1.0]
HA HNL-KIX SEP 0.5>0[1.0]
HA HNL-KOA SEP 14>9[19]
HA HNL-LAS SEP 1.3>0[3]
HA HNL-LAX SEP 2>1.1[3]
HA HNL-LGB SEP 0.5>0[1.0]
HA HNL-LIH SEP 14>9[18]
HA HNL-NRT SEP 0.5>0[2.0]
HA HNL-OAK SEP 0.5>0[0.9]
HA HNL-OGG SEP 19>12[27]
HA HNL-PHX SEP 0.5>0[1.0]
HA HNL-PPG SEP 0.2>0[0.2]
HA HNL-SJC SEP 0.5>0[1.0]
HA HNL-SMF SEP 0.7>0.4[1.0]
HA ITO-OGG SEP 1.5>1.0[2]
HA KOA-LAX SEP 0.5>0[1.0]
HA KOA-LIH SEP 0.5>0[1.0]
HA KOA-OGG SEP 2>1.0[3]
HA LAX-LIH SEP 0.5>0[1.0]
HA LAX-OGG SEP 0.5>0[1.0]
HA LIH-OAK SEP 0.5>0[1.0]
HA LIH-OGG SEP 3>1.0[3]
HA OAK-OGG SEP 0.5>0[1.0]
HA OGG-PDX SEP 0.5>0[1.0]
HA OGG-SAN SEP 0.5>0[1.0]
HA OGG-SEA SEP 0.5>0[1.0]
HA OGG-SFO SEP 0.5>0[1.0]
HA OGG-SJC SEP 0.5>0[1.0]
HA OGG-SMF SEP 0.5>0[1.0]
HU BOS-PEK SEP 1.0>0.8[1.0]
HU PEK-SEA SEP 1.0>0.8[1.0]
HZ RZH-VVO SEP 0.7>0[0] OCT 0.6>0[0]
I4 CGA-KLW SEP 4>3[3] OCT 4>3[3] NOV 4>3[3] DEC 4>3[3] JAN 4>3[0] FEB 4>3[0] MAR 4>3[0] APR 4>3[0] MAY 4>3[0] JUN 4>3[0]
I4 KLW-KTN SEP 4>3[5] OCT 4>3[5] NOV 4>3[3] DEC 4>3[3] JAN 4>3[3] FEB 4>3[3] MAR 4>3[3] APR 4>3[3] MAY 4>3[3] JUN 4>3[0]
J5 HNS-JNU OCT 4>3[0] NOV 4>3[3] DEC 4>3[3] JAN 4>3[3] FEB 4>3[3] MAR 4>3[3] APR 4>3[3] MAY 4>3[8] JUN 4>3[1.3]
J5 JNU-KAE OCT 0.9>1.9[0] NOV 0.8>1.8[1.0] DEC 0.9>1.9[1.0] JAN 0.8>1.8[1.0] FEB 0.9>1.9[1.0] MAR 0.9>1.9[1.0] APR 0.9>1.9[1.0] MAY 0.8>1.8[2.0] JUN 0.9>1.9[0.9]
J5 JNU-KLW OCT 0>0.9[0] NOV 0>0.8[0] DEC 0>0.9[0] JAN 0>0.8[0] FEB 0>0.9[0] MAR 0>0.9[0] APR 0>0.9[0] MAY 0>0.8[0] JUN 0>0.9[0]
J5 JNU-SIT SEP 2.0>1.0[2] OCT 1.9>1.0[0.5] NOV 1.8>1.0[1.9] DEC 1.9>1.0[1.9] JAN 1.8>1.0[1.9] FEB 1.9>1.0[2] MAR 1.9>1.0[2] APR 1.9>1.0[2] MAY 1.8>1.0[3] JUN 1.9>1.0[0.4]
J5 KLW-SIT SEP 1.0>0.0[1.2] OCT 1.0>0.1[0.5] NOV 1.0>0.2[0.5] DEC 1.0>0.1[1.0] JAN 1.0>0.2[1.0] FEB 1.0>0.1[1.0] MAR 1.0>0.1[1.0] APR 1.0>0.1[1.0] MAY 1.0>0.2[2.0] JUN 1.0>0.1[0.4]
KAI KOA-OAK JUN 0>0.3[0]
KG AIA-DEN JAN 3>1.7[1.7] FEB 3>1.7[1.7] MAR 3>1.7[1.7] APR 3>1.7[1.7] MAY 3>1.7[1.7]
KG CVN-DEN NOV 0>1.7[0] DEC 0>1.7[0]
KL AMS-SFO OCT 0.8>0.6[1.6]
LA BOS-GRU NOV 0.7>0[0.7] DEC 0.7>0[0.7]
LA GRU-MCO NOV 1.0>0.4[1.0] DEC 1.0>0.4[1.0]
LA GRU-MIA NOV 2>1.0[2] DEC 2>1.0[2]
LA LAX-SCL OCT 0.2>0[0.5] NOV 1.0>0[0.6] DEC 1.0>0[0.7]
LA LIM-MCO OCT 0.2>0[1.0] NOV 1.0>0.4[1.0] DEC 1.0>0.4[1.0]
LA LIM-MIA NOV 3>2[2]
LA MIA-SCL NOV 1.4>1.0[1.4] DEC 1.4>1.0[1.6]
LH MUC-SFO SEP 0.7>0.5[1.0]
LY BOS-TLV SEP 0.4>0[0.4]
LY ORD-TLV SEP 0.4>0[0]
LY SFO-TLV SEP 0.4>0[0.4]
NK BOG-FLL SEP 1.0>0.7[1.0]
NK CLO-FLL SEP 1.0>0.7[1.0]
NK CUN-IAH SEP 0.4>0.7[0.5]
NK DTW-MCO SEP 1.0>1.5[3]
NK EWR-IAH SEP 0.3>0.7[1.0]
NK FLL-GUA SEP 1.0>0.7[0.9]
NK FLL-MDE SEP 1.0>0.7[0.8]
NK FLL-PTY SEP 1.0>0.6[1.0]
NK FLL-STT SEP 1.0>0.6[0.8]
NK IAH-LAX SEP 1.2>1.6[2]
P2 KIS-MDR SEP 1.0>0[0] OCT 1.0>0[0] NOV 1.0>0[0] DEC 1.0>0[0] JAN 1.0>0[0] FEB 1.0>0[0] MAR 1.0>0[0] APR 1.0>0[0] MAY 1.0>0[0] JUN 1.0>0[0]
P2 MDR-WIL SEP 4>0[0] OCT 3>0[0] NOV 3>0[0] DEC 3>0[0] JAN 3>0[0] FEB 3>0[0] MAR 3>0[0] APR 3>0[0] MAY 3>0[0] JUN 3>0[0]
QR BOS-DOH SEP 1.0>0.6[1.0]
RJ AMM-ORD SEP 1.1>0[1.1]
RLI ACK-DXR SEP 0>0.2[0] OCT 0>0.2[0] NOV 0>0.2[0] DEC 0>0.2[0] JAN 0>0.2[0] FEB 0>0.2[0] MAR 0>0.2[0] APR 0>0.2[0] JUN 0>0.2[0]
S4 BOS-TER SEP 0.2>0[0.3]
SK ARN-EWR SEP 1.0>0.6[1.0]
SK ARN-ORD SEP 1.0>0.6[1.0]
SK BOS-CPH SEP 1.0>0.6[0.9]
SK CPH-LAX SEP 0.9>0.6[0]
SK CPH-SCR JAN 0.3>0[0] FEB 0.3>0[0] MAR 0.2>0[0]
SK CPH-SFO SEP 1.0>0.7[1.0]
SK EWR-OSL SEP 1.0>0.6[1.0]
SN BRU-JFK SEP 0.4>0[1.0]
SU JFK-SVO SEP 2>0.3[3] OCT 3>0.6[3]
SU LAX-SVO SEP 1.0>0.1[1.0] OCT 1.0>0.2[1.0]
SU MIA-SVO SEP 0.3>0[0.6] OCT 0.6>0.1[0.5]
TOM BHX-SFB APR 0>0.3[0.2]
TOM LGW-SFB APR 0>0.3[0.2]
TOM MAN-SFB APR 0>0.6[0.5]
TP EWR-LIS SEP 1.8>1.0[1.0]
TP LIS-MIA OCT 1.1>0.6[1.0]
TS FLL-YQB NOV 0.5>0[0.5] DEC 0.7>0.3[0.6]
TS FLL-YUL NOV 0.5>0.7[0.5] DEC 0.8>1.1[0.8] JAN 1.0>1.4[1.0] FEB 1.0>1.4[1.0] MAR 1.0>1.4[1.0] APR 1.0>1.5[0]
TS FLL-YYZ FEB 0.7>0.9[0.7] MAR 0.7>1.0[0.7] APR 0.7>1.0[0.0]
TS MCO-YUL MAR 0.4>0.7[0.4] APR 0.4>0.7[0]
TS MCO-YYZ DEC 0.3>0.6[0.3] JAN 0.5>0.9[0.4] FEB 0.4>0.9[0.4] MAR 0.4>0.9[0.4] APR 0.4>0.8[0]
UA BOM-EWR SEP 0.9>0.1[0.8]
UA BZE-IAH SEP 1.0>0.1[1.1]
UA COS-DEN SEP 3>4[9]
UA CPT-EWR NOV 0.4>0[0]
UA DEL-EWR SEP 1.0>0[0.8]
UA DEN-KOA SEP 0.4>0.2[1.0]
UA DEN-LIH SEP 0.6>0.3[1.0]
UA DEN-OGG SEP 1.0>0.5[1.0]
UA EWR-SAL SEP 0.2>0.4[0] APR 0.1>1.0[0] MAY 0.2>1.0[0] JUN 0.5>1.0[0]
UA EWR-SAP APR 0.1>1.0[0] MAY 0.2>1.0[0] JUN 0.5>1.0[0]
UA EWR-SJO JUN 2>3[0]
UA EWR-SJU APR 2.3>4[1.0] MAY 2.0>3.1[0.8] JUN 2.9>3.9[0]
UA EWR-STI APR 1.0>3[0] MAY 1.8>3[0] JUN 2>3[0]
UA EWR-YYZ SEP 0.7>0.0[4]
**UA GUA-IAD APR 0.3>1.0[0] MAY 0.0>1.0[0] JUN 0.2>1.0[0]
UA GUA-IAH MAY 2>3[0.4] JUN 3>4[0.5]
**UA GUA-LAX APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0]
UA GUM-HNL SEP 1.0>0.5[0.5] OCT 1.0>0.5[0.5] NOV 1.0>0.5[0.5] DEC 1.0>0.5[0.5] JAN 1.0>0.5[0.5] FEB 1.0>0.5[0.5] MAR 1.0>0.5[0.5] APR 1.0>0.5[0.5] MAY 1.0>0.5[0.5] JUN 1.0>0.5[0.5]
UA HNL-LAX SEP 2.0>1.5[3]
UA HNL-ORD SEP 0.9>0.7[1.0]
**UA IAD-SAL APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0]
UA IAD-SJU APR 1.3>2.0[0] MAY 1.0>1.8[0] JUN 1.0>1.9[0]
UA IAD-YYZ SEP 1.9>1.0[4]
UA IAH-MGA SEP 1.0>0[0.6]
UA IAH-SAL APR 2>3[0] MAY 2>3[0.5] JUN 3>4[0.9]
*UA IAH-SAP APR 1.0>3[0] MAY 1.0>3[0] JUN 1.9>3[0.4]
UA IAH-SJO APR 2>3[0] MAY 2>3[0.4]
UA IAH-SJU APR 2.0>3.0[0] MAY 2.0>3.0[0] JUN 2.0>3.0[0.5]
UA ICN-SFO SEP 0.7>1.0[1.7]
UA ITO-LAX SEP 0.4>0.2[0.7]
UA KOA-LAX SEP 0.7>0.4[1.1]
UA KOA-SFO SEP 1.7>1.4[2]
UA LAX-LIH SEP 0.4>0.2[1.1]
UA LAX-OGG SEP 1.0>0.5[2]
**UA LAX-SAL APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0]
UA LIH-SFO SEP 1.0>0.5[1.2]
UA OGG-SFO SEP 2.0>1.5[4]
UA ORD-SJO APR 0.4>0.1[0]
UA ORD-SJU APR 1.4>2.0[0] MAY 1.1>2.0[0] JUN 1.1>2.0[0]
UA ORD-YQB SEP 0.9>0[2] OCT 0.8>0[1.7]
UA ORD-YUL SEP 1.0>0.7[3]
UA ORD-YYC SEP 1.0>0.0[3]
UA ORD-YYZ SEP 3>1.9[7]
UE BKL-LUK SEP 1.5>0.9[0] OCT 1.4>0.8[0] NOV 1.4>0.8[0] DEC 1.5>1.0[0] JAN 1.4>0.8[0] FEB 1.4>0.9[0] MAR 1.5>0.9[0] APR 1.5>0.9[0] MAY 1.4>0.8[0] JUN 1.5>0.9[0]
UE LUK-PDK SEP 0>0.9[0] OCT 0>0.8[0] NOV 0>0.8[0] DEC 0>1.0[0] JAN 0>0.8[0] FEB 0>0.9[0] MAR 0>0.9[0] APR 0>0.9[0] MAY 0>0.8[0] JUN 0>0.9[0]
VW MEX-MFE SEP 0.8>0.6[0.7] OCT 0.9>0.5[0.7] NOV 0.9>0.6[0.7] DEC 0.8>0.5[0.7] JAN 0.9>0.6[0.7] FEB 0.9>0.6[0.7] MAR 0.8>0.6[0.7] APR 0.9>0.6[0.7] MAY 0.9>0.6[0.7] JUN 0.8>0.6[0.7]
WN ABQ-AUS OCT 0.8>0[1.2]
WN ABQ-BWI OCT 0.8>0[2]
WN ABQ-DAL OCT 4>3[5]
WN ABQ-HOU OCT 1.7>0[3]
WN ABQ-LAS OCT 3>2[4]
WN ABQ-LAX OCT 1.5>0[2]
WN ABQ-MCI OCT 0.6>0[1.0]
WN ABQ-OAK OCT 1.4>0[3]
WN ABQ-SAN OCT 0.8>0[1.7]
WN ALB-DEN OCT 0.6>0[0]
WN ALB-MCO OCT 0.9>0[1.2]
WN ALB-MDW OCT 1.8>1.0[2.0]
WN ALB-TPA OCT 0.2>0[1.0]
WN AMA-DAL OCT 3>2[4]
WN AMA-HOU OCT 0.6>0[0.1]
WN ATL-AUS OCT 2>1.0[3]
WN ATL-CLE OCT 1.4>0[1.9]
WN ATL-CMH OCT 2>1.8[3]
WN ATL-DAL OCT 5>3[5]
WN ATL-DCA OCT 3>1.0[4]
WN ATL-FLL OCT 4>3[4]
WN ATL-IND OCT 3>2[3]
WN ATL-JAX OCT 2>1.9[2.0]
WN ATL-MCI OCT 2>1.0[3]
WN ATL-MCO OCT 5>4[6]
WN ATL-MKE OCT 1.3>0[1.9]
WN ATL-PBI OCT 0.9>0[1.0]
WN ATL-PHL OCT 2>1.0[1.6]
WN ATL-PHX OCT 1.6>1.0[3]
WN ATL-PIT OCT 1.3>0[3]
WN ATL-RDU OCT 3>2[3]
WN ATL-SAT OCT 1.6>0.9[2]
WN ATL-STL OCT 4>1.7[4]
WN ATL-TPA OCT 4>3[5]
WN AUS-BWI OCT 3>2[3]
WN AUS-DAL OCT 8>4[9]
WN AUS-DCA OCT 0.8>0[1.0]
WN AUS-DEN OCT 5>4[6]
WN AUS-ELP OCT 1.4>0[3]
WN AUS-FLL OCT 0.6>0[0.6]
WN AUS-HOU OCT 4>3[5]
WN AUS-LAS OCT 4>2[4]
WN AUS-LAX OCT 2>1.0[3]
WN AUS-LGB OCT 0.8>0[0]
WN AUS-MCI OCT 0.8>0[1.0]
WN AUS-MCO OCT 1.5>0[3]
WN AUS-MSY OCT 2>1.0[3]
WN AUS-PHX OCT 4>3[5]
WN AUS-RDU OCT 0.6>0[0]
WN AUS-SAN OCT 1.6>1.0[2]
WN AUS-SJC OCT 1.4>0[3]
WN AUS-STL OCT 1.6>1.0[1.9]
WN AUS-TPA OCT 0.9>0[1.8]
WN BDL-BWI OCT 4>3[5]
WN BDL-DEN OCT 0.8>0[1.0]
WN BDL-MCO OCT 1.7>0.8[2]
WN BDL-MDW OCT 2>1.0[3]
WN BDL-STL OCT 0.8>0[1.0]
WN BDL-TPA OCT 0.9>0[1.0]
WN BHM-BWI OCT 0.9>0[1.1]
WN BHM-DEN OCT 0.2>1.0[0]
WN BHM-HOU OCT 1.4>0[1.6]
WN BHM-LAS OCT 0.8>0[0]
WN BHM-MCO OCT 1.8>1.0[1.8]
WN BHM-MDW OCT 0.8>0[1.8]
WN BNA-BOS OCT 3>2[4]
WN BNA-BUR OCT 0.8>0[0]
WN BNA-BWI OCT 6>4[6]
WN BNA-CHS OCT 1.4>2[1.8]
WN BNA-CLE OCT 3>2[3]
WN BNA-CLT OCT 1.4>0[1.9]
WN BNA-CMH OCT 1.8>1.0[3]
WN BNA-DAL OCT 5>4[5]
WN BNA-DTW OCT 3>2[3]
WN BNA-JAX OCT 3>2[3]
WN BNA-LAS OCT 3>2[4]
WN BNA-LGA OCT 4>3[3]
WN BNA-MDW OCT 7>4[7]
WN BNA-MSP OCT 1.3>0[1.8]
WN BNA-MSY OCT 3>2[4]
WN BNA-OAK OCT 0.8>0[1.0]
WN BNA-OKC OCT 0.8>0[0.1]
WN BNA-PHL OCT 3>2[3]
WN BNA-PNS OCT 2>1.2[2]
WN BNA-RDU OCT 3>2[2]
WN BNA-RSW OCT 0.8>0[0]
WN BNA-SAN OCT 1.8>1.0[3]
WN BNA-SAT OCT 3>2[1.9]
WN BNA-SJC OCT 0.6>0[1.0]
WN BNA-STL OCT 4>3[3]
WN BNA-TPA OCT 4>2[3]
WN BOI-DEN OCT 3>2[2]
WN BOI-LAS OCT 3>2[2]
WN BOI-PHX OCT 0.8>0[0.9]
WN BOI-SAN OCT 0.8>0[0.9]
WN BOI-SJC OCT 0.6>0[1.0]
WN BOI-SMF OCT 0.8>0[1.0]
WN BOS-BWI OCT 7>4[9]
WN BOS-DEN OCT 1.8>1.0[2.0]
WN BOS-MDW OCT 4>1.0[5]
WN BOS-STL OCT 2>0[4]
WN BUF-DEN OCT 0.8>0[0]
WN BUF-MCO OCT 1.7>0.8[2]
WN BUF-MDW SEP 1.3>2[3] OCT 2>1.2[3]
WN BUF-PHX OCT 0.8>0[1.0]
WN BUF-TPA OCT 1.1>0[1.3]
WN BUR-DAL OCT 0.8>0[1.0]
WN BUR-HOU OCT 0.6>0[1.0]
WN BUR-LAS OCT 6>4[10]
WN BUR-OAK OCT 7>4[13]
WN BUR-PHX OCT 5>4[7]
WN BUR-SFO OCT 4>2[5]
WN BUR-SJC OCT 5>3[11]
WN BUR-SLC OCT 0.6>0[0.9]
WN BUR-SMF OCT 5>2[10]
WN BWI-CHS OCT 3>1.9[3]
WN BWI-CLE OCT 3>2[3]
WN BWI-CLT OCT 3>2[3]
WN BWI-CMH OCT 3>2[4]
WN BWI-DAL OCT 4>3[4]
WN BWI-DEN OCT 6>4[5]
WN BWI-DTW OCT 3>2[3]
WN BWI-FLL OCT 8>5[7]
WN BWI-GSP OCT 0.8>0[0]
WN BWI-IND OCT 3>2[4]
WN BWI-LAX OCT 2>1.0[3]
WN BWI-MBJ OCT 1.0>1.8[2.0]
WN BWI-MCI OCT 3>2[3]
WN BWI-MCO OCT 10>9[8]
WN BWI-MDW OCT 6>5[7]
WN BWI-MEM OCT 0.8>0[1.1]
WN BWI-MKE OCT 3>2[3]
WN BWI-MSP OCT 0.8>0[1.8]
WN BWI-MSY OCT 3>1.0[4]
WN BWI-OKC OCT 0.8>0[1.0]
WN BWI-ORF OCT 4>3[4]
WN BWI-PHX OCT 3>2[3]
WN BWI-PIT OCT 3>1.9[3]
WN BWI-PVD OCT 5>4[6]
WN BWI-PWM OCT 4>3[4]
WN BWI-RDU OCT 5>3[6]
WN BWI-ROC OCT 3>2[3]
WN BWI-RSW OCT 4>3[3]
WN BWI-SDF OCT 3>1.9[4]
WN BWI-STL OCT 3>2[4]
WN BWI-TPA OCT 7>5[6]
WN CHS-MDW OCT 1.6>1.0[2.0]
WN CLE-DEN OCT 1.6>1.0[1.7]
WN CLE-LAS OCT 0.8>0[0.3]
WN CLE-MCO OCT 0.2>0[0.3]
WN CLE-MDW OCT 3>2[5]
WN CLE-PHX OCT 0.8>0[1.1]
WN CLE-STL OCT 2.0>0[3]
WN CLT-HOU OCT 0.6>0[1.0]
WN CLT-MDW OCT 1.6>1.0[3]
WN CMH-DAL OCT 0.8>0[1.1]
WN CMH-DCA OCT 0.9>0[1.9]
WN CMH-DEN OCT 1.6>1.0[1.0]
WN CMH-HOU OCT 0.8>0[1.0]
WN CMH-LAS SEP 1.2>1.9[2.0] OCT 1.8>1.2[2]
WN CMH-MCO OCT 3>1.8[3]
WN CMH-MDW OCT 4>1.9[6]
WN CMH-PHX OCT 1.6>1.0[1.0]
WN CMH-RSW OCT 1.0>0.8[1.1]
WN CMH-STL OCT 1.4>0[1.9]
WN CMH-TPA OCT 1.9>1.0[3]
WN CRP-HOU OCT 3>2[4]
WN CVG-DEN OCT 0.8>0[1.0]
WN CVG-MDW OCT 3>1.0[4]
WN DAL-DCA OCT 4>1.0[5]
WN DAL-DEN OCT 9>6[7]
WN DAL-DTW OCT 0.8>0[1.0]
WN DAL-HOU OCT 15>9[19] NOV 18>17[16]
WN DAL-IND OCT 1.8>1.0[1.3]
WN DAL-LAX OCT 4>3[5]
WN DAL-LBB OCT 4>3[5]
WN DAL-LGA OCT 3>1.0[5]
WN DAL-MAF OCT 4>3[5]
WN DAL-MCI OCT 5>3[6]
WN DAL-MCO OCT 5>4[5]
WN DAL-MEM OCT 1.9>1.0[3]
WN DAL-MKE OCT 0.8>0[1.0]
WN DAL-MSP OCT 0.8>0[1.0]
WN DAL-MSY OCT 6>3[7]
WN DAL-ONT OCT 0.8>0[1.0]
WN DAL-PHL OCT 0.8>0[1.0]
WN DAL-PHX OCT 7>5[6]
WN DAL-PIT OCT 0.9>0[1.0]
WN DAL-PNS SEP 1.4>2[1.0]
WN DAL-RDU OCT 0.9>0[1.0]
WN DAL-RSW OCT 0.8>0[0]
WN DAL-SAN OCT 3>2[4]
WN DAL-SAT OCT 8>4[9]
WN DAL-SDF OCT 0.8>0[1.0]
WN DAL-SJC OCT 2>1.0[2]
WN DAL-SNA OCT 0.8>0[0.9]
WN DAL-STL OCT 5>4[6]
WN DAL-TPA OCT 3>2[3]
WN DCA-FLL OCT 1.5>0[2.0]
WN DCA-HOU OCT 2>0[3]
WN DCA-MCI OCT 0.9>0[1.9]
WN DCA-MCO OCT 1.2>0[2.0]
WN DCA-MDW OCT 5>3[6]
WN DCA-MKE OCT 0.9>0[1.9]
WN DCA-MSY OCT 1.0>0[2]
WN DCA-OKC OCT 0.8>0[1.0]
WN DCA-OMA OCT 0.8>0[1.0]
WN DCA-PVD OCT 1.7>1.0[2]
WN DCA-STL OCT 3>1.0[4]
WN DCA-TPA OCT 1.0>0[2]
WN DEN-DTW OCT 1.5>1.0[2]
WN DEN-ELP OCT 0.6>0[1.0]
WN DEN-GRR OCT 1.2>2[1.0]
WN DEN-HOU OCT 8>7[7]
WN DEN-IAD OCT 2>1.0[3]
WN DEN-ICT OCT 0.2>1.0[0]
WN DEN-IND OCT 4>3[4]
WN DEN-JAX OCT 0.8>0[1.0]
WN DEN-LAS OCT 9>7[9]
WN DEN-LAX OCT 6>3[7]
WN DEN-LGA OCT 2>1.0[3]
WN DEN-LGB OCT 0.5>2[0.3] NOV 0>0.2[0.3]
WN DEN-MCI OCT 6>3[7]
WN DEN-MCO OCT 5>3[4]
WN DEN-MDW OCT 9>7[9]
WN DEN-MSP OCT 5>3[5]
WN DEN-MSY OCT 3>2[2]
WN DEN-OAK OCT 5>4[5]
WN DEN-PDX OCT 4>3[5]
WN DEN-PHL OCT 3>2[2]
WN DEN-RDU OCT 1.6>1.0[1.9]
WN DEN-RNO SEP 2>3[2]
WN DEN-SAN OCT 6>3[6]
WN DEN-SEA OCT 5>3[4]
WN DEN-SFO OCT 4>2[5]
WN DEN-SLC OCT 5>3[6]
WN DEN-SMF OCT 5>3[5]
WN DEN-SNA OCT 4>3[4]
WN DEN-STL OCT 5>3[6]
WN DEN-TPA OCT 3>2[3]
WN DEN-TUL OCT 3>2[2]
WN DEN-TUS OCT 3>2[1.9]
WN DSM-LAS OCT 0.8>0[1.0]
WN DTW-LAS OCT 0.8>0[0.3]
WN DTW-PHX OCT 0.8>0[0.6]
WN DTW-STL OCT 1.4>0[3]
WN ECP-HOU SEP 1.5>2[1.1] OCT 1.0>1.2[1.0]
WN ECP-STL OCT 0.8>0[0.1]
WN ELP-HOU OCT 3>1.0[3]
WN ELP-LAS OCT 2>1.0[2]
WN ELP-SAT OCT 0.9>0[2]
WN FLL-IND OCT 0.4>0[1.1]
WN FLL-MCI OCT 0.8>0[1.0]
WN FLL-MSY OCT 0.8>0[1.7]
WN FLL-PHX OCT 0.8>0[1.1]
WN FLL-PIT OCT 0.9>0[1.0]
WN FLL-TPA OCT 3>2[4]
WN GEG-PHX OCT 0.8>0[1.0]
WN GEG-SJC OCT 0.6>0[0.6]
WN GEG-SMF OCT 0.8>0[1.0]
WN HAV-TPA SEP 0.6>0[1.1] OCT 1.0>0.8[1.1]
WN HNL-ITO SEP 3>2[0]
WN HNL-KOA SEP 3>2[4] OCT 4>3[4]
WN HNL-LIH SEP 3>2[0] OCT 4>3[0]
WN HNL-OGG SEP 4>3[4] OCT 6>4[4]
WN HNL-SAN SEP 1.0>0[0]
WN HNL-SJC SEP 1.0>0[1.0]
WN HNL-SMF SEP 1.0>0[0]
WN HOU-HRL OCT 3>2[4]
WN HOU-LBB OCT 0.6>0[0.1]
WN HOU-LGA OCT 2>0[3]
WN HOU-LIT OCT 0.6>0[0]
WN HOU-MAF OCT 3>2[4]
WN HOU-MCI OCT 1.8>1.0[3]
WN HOU-MEM OCT 1.4>0[1.9]
WN HOU-MKE OCT 0.8>0[1.0]
WN HOU-MSY OCT 6>3[9]
WN HOU-OMA OCT 0.8>0[1.0]
WN HOU-ONT OCT 0.8>0[0]
WN HOU-PIT OCT 0.8>0[1.3]
WN HOU-PNS SEP 1.3>2[1.0] OCT 1.0>1.2[1.0]
WN HOU-RDU OCT 0.8>0[1.0]
WN HOU-SAN OCT 3>2[3]
WN HOU-SAT OCT 4>3[5]
WN HOU-SDF OCT 0.8>0[1.0]
WN HOU-SJC OCT 0.8>0[1.0]
WN HOU-SMF OCT 0.8>0[0]
WN HOU-SNA OCT 0.8>0[1.0]
WN HOU-STL OCT 3>2[4]
WN HOU-TPA OCT 3>2[3]
WN HOU-TUL OCT 2>0[3]
WN ICT-LAS OCT 0.8>0[1.0]
WN ICT-PHX OCT 0.8>0[1.0]
WN IND-LAS OCT 2>1.2[2]
WN IND-MCO OCT 4>3[3]
WN IND-PHX OCT 1.8>1.0[1.5]
WN IND-RSW OCT 1.8>0.8[1.4]
WN IND-STL OCT 1.3>0[0]
WN IND-TPA OCT 2>1.8[2]
WN ISP-MCO OCT 1.0>0.8[2]
WN ISP-PBI OCT 0.9>0[1.9]
WN ISP-TPA OCT 0.2>0[1.0]
WN JAX-MDW OCT 0.9>0[0.9]
WN KOA-OAK SEP 0.6>0[0]
WN KOA-SJC SEP 0.4>0[0]
WN LAS-LAX OCT 7>4[10]
WN LAS-LGB OCT 0.9>2[0.8]
WN LAS-LIT OCT 0.8>0[1.0]
WN LAS-MCI OCT 3>2[4]
WN LAS-MDW OCT 8>7[9]
WN LAS-OAK OCT 7>6[9]
WN LAS-OKC OCT 1.8>1.0[2]
WN LAS-ONT OCT 4>2[4]
WN LAS-PDX OCT 3>2[4]
WN LAS-PHX OCT 8>6[11]
WN LAS-RDU OCT 0.8>0[1.0]
WN LAS-RNO OCT 7>3[9]
WN LAS-SAN OCT 8>4[10]
WN LAS-SAT OCT 3>2[4]
WN LAS-SDF OCT 0.8>0[1.0]
WN LAS-SEA OCT 1.8>1.0[2]
WN LAS-SFO OCT 3>1.0[6]
WN LAS-SJC OCT 7>3[10]
WN LAS-SLC OCT 4>2[5]
WN LAS-SMF OCT 7>4[8]
WN LAS-SNA OCT 6>3[5]
WN LAS-TUS OCT 4>2[4]
WN LAX-MCI OCT 1.6>1.0[3]
WN LAX-MDW OCT 4>3[6]
WN LAX-OAK OCT 7>4[12]
WN LAX-PHX OCT 7>3[8]
WN LAX-RNO OCT 1.6>1.0[3]
WN LAX-SAT OCT 0.6>0[1.7]
WN LAX-SFO OCT 5>3[7]
WN LAX-SJC OCT 6>3[11]
WN LAX-SLC OCT 1.8>1.0[3]
WN LAX-SMF OCT 6>4[8]
WN LAX-STL OCT 1.6>1.0[3]
WN LAX-TUS OCT 1.0>0[3]
WN LGA-MCI OCT 0.8>0[1.9]
WN LGA-MDW OCT 6>3[6]
WN LGA-MSY OCT 0.6>0[1.1]
WN LGA-STL OCT 2>1.0[3]
WN LGB-OAK OCT 4>3[4]
WN LGB-SJC OCT 4>0[4]
WN LGB-SMF OCT 4>3[4]
WN LIH-OAK SEP 0.4>0[0]
WN LIH-SJC SEP 0.6>0[0]
WN LIT-PHX OCT 0.7>0[1.0]
WN LIT-STL OCT 1.6>1.0[1.9]
WN MCI-MCO OCT 2>1.0[2]
WN MCI-MDW OCT 6>3[8]
WN MCI-MKE OCT 0.8>0[1.9]
WN MCI-MSY OCT 0.8>0[0.8]
WN MCI-PHX OCT 4>2[4]
WN MCI-RSW OCT 0.2>0[0]
WN MCI-SAN OCT 0.8>0[1.4]
WN MCI-STL OCT 2>1.0[3]
WN MCO-MDW OCT 8>6[7]
WN MCO-MEM OCT 1.0>0[1.3]
WN MCO-MHT OCT 1.5>0[1.9]
WN MCO-MKE OCT 3>2[2]
WN MCO-MSY OCT 2>0.8[4]
WN MCO-ORF OCT 0.8>0[0.9]
WN MCO-PHL OCT 2>1.0[3]
WN MCO-PIT OCT 4>1.8[3]
WN MCO-PVD OCT 3>1.8[3]
WN MCO-RDU OCT 1.9>1.0[1.8]
WN MCO-ROC OCT 0.8>0[1.0]
WN MCO-SAT OCT 0.9>0[1.8]
WN MCO-SDF OCT 2>1.2[2.0]
WN MCO-SJU OCT 3.5>2.0[3.0]
WN MCO-STL OCT 4>3[4]
WN MDW-MSP OCT 5>4[7]
WN MDW-MSY OCT 3>2[4]
WN MDW-OAK OCT 3>2[4]
WN MDW-OMA OCT 3>2[5]
WN MDW-ORF OCT 0.9>0[1.3]
WN MDW-PHL OCT 4>1.0[5]
WN MDW-PIT OCT 3>1.0[5]
WN MDW-RDU OCT 3>2[4]
WN MDW-SAN OCT 3>2[4]
WN MDW-SAT OCT 2>0[3]
WN MDW-SDF OCT 3>2[4]
WN MDW-SEA OCT 1.5>1.0[1.5]
WN MDW-SFO OCT 1.5>1.0[1.5]
WN MDW-SJC OCT 1.5>0.9[1.7]
WN MDW-SLC SEP 1.2>1.9[2] OCT 1.8>1.2[2]
WN MDW-STL OCT 6>3[7]
WN MDW-TPA OCT 5>3[4]
WN MDW-TUS OCT 0.8>0[1.0]
WN MEM-TPA OCT 0.6>0[1.0]
WN MHT-TPA OCT 0.8>0[1.0]
WN MKE-PHX OCT 2>1.0[1.9]
WN MKE-RSW OCT 0.8>0[0.1]
WN MSP-PHX OCT 1.8>1.0[2]
WN MSP-STL OCT 2.0>0[3]
WN MSY-OAK OCT 0.6>0[1.0]
WN MSY-PHX OCT 1.6>1.0[1.0]
WN MSY-SAT OCT 0.8>0[1.9]
WN MSY-STL OCT 1.4>0[2]
WN MSY-TPA OCT 1.7>1.0[3]
WN OAK-OGG SEP 2>0[2]
WN OAK-ONT OCT 4>3[7]
WN OAK-SAN OCT 7>3[11]
WN OAK-SLC OCT 1.6>1.0[3]
WN OAK-SNA OCT 5>3[7]
WN OAK-STL OCT 0.6>0[1.0]
WN OGG-SJC SEP 1.0>0[1.0]
WN OGG-SMF SEP 1.0>0[0]
WN OKC-PHX OCT 3>2[1.9]
WN OKC-STL OCT 1.6>1.0[1.9]
WN OMA-PHX SEP 1.0>1.8[1.2] OCT 1.6>1.2[1.9]
WN OMA-STL OCT 3>1.9[3]
WN ONT-PHX OCT 5>2[6]
WN ONT-SMF OCT 5>4[7]
WN PDX-PHX SEP 1.5>2[3] OCT 3>1.2[2]
WN PDX-SJC OCT 3>2[5]
WN PDX-SMF OCT 3>2[4]
WN PDX-STL OCT 0.8>0[0.9]
WN PHL-PHX OCT 0.8>0[1.0]
WN PHL-STL OCT 2>1.0[2]
WN PHX-PIT OCT 0.8>0[1.0]
WN PHX-RDU OCT 0.8>0[0.6]
WN PHX-RNO OCT 1.8>1.0[2]
WN PHX-SAN OCT 7>3[10]
WN PHX-SDF OCT 0.8>0[1.0]
WN PHX-SEA OCT 3>1.0[3]
WN PHX-SFO OCT 4>2[4]
WN PHX-SJC OCT 6>3[6]
WN PHX-SJD OCT 1.5>0.8[0]
WN PHX-SLC OCT 4>2[5]
WN PHX-SNA OCT 5>3[7]
WN PHX-STL OCT 3>2[3]
WN PHX-TPA OCT 0.8>0[1.0]
WN PHX-TUL OCT 0.8>0[1.0]
WN PIT-RSW OCT 0.9>0[1.0]
WN PIT-STL OCT 1.4>0[1.1]
WN PIT-TPA OCT 2>1.0[2]
WN PNS-STL OCT 0.2>0[0]
WN PVD-TPA OCT 0.2>0[1.7]
WN RDU-STL OCT 1.6>1.0[1.9]
WN RDU-TPA OCT 0.8>0[1.5]
WN RNO-SAN OCT 1.4>0[3]
WN RSW-STL SEP 1.2>1.9[1.0] OCT 1.8>1.2[1.0]
WN SAN-SAT OCT 0.8>0[1.6]
WN SAN-SFO OCT 5>3[7]
WN SAN-SMF OCT 8>4[14] NOV 11>10[12]
WN SAN-TUS OCT 1.5>0[1.9]
WN SAT-STL OCT 1.4>0[1.8]
WN SAT-TPA OCT 0.6>0[0.9]
WN SDF-TPA OCT 1.0>0[1.1]
WN SEA-SJC OCT 3>1.7[4]
WN SEA-STL OCT 0.8>0[1.0]
WN SFO-STL OCT 0.5>0[0.6]
WN SJC-SNA OCT 6>3[9]
WN SJC-STL OCT 0.8>0[0.6]
WN SLC-STL OCT 0.6>0[0.5]
WN SMF-SNA OCT 5>4[6]
WN STL-TPA OCT 3>1.0[2]
WN STL-TUL OCT 1.6>1.0[1.9]
WO AZA-YEG DEC 0>0.4[0.3] JAN 0>0.6[0.3] FEB 0>0.6[0.3] MAR 0>0.5[0.3] APR 0>0.5[0.3]
WO LAS-YEG NOV 0>0.3[1.0] DEC 0>0.4[1.0] JAN 0>0.6[1.0] FEB 0>0.6[1.0] MAR 0>0.5[1.0] APR 0>0.5[1.0]
enilria
Re: OAG Changes 8/25/2020:Cuts Begin for 21;DL DROPS NUMEROUS ROUTES INTL ROUTES FOR SUMMER 2021, Adds SEA-ONT,MSP-TVC
Tue Aug 25, 2020 1:46 pm
The DL intl cuts are so dramatic that while it is not too surprising given the staff reductions, I am a little surprised they would do them now. I almost wonder if they filed this schedule by mistake and will roll it back, but time will tell...
chonetsao
Tue Aug 25, 2020 1:52 pm
Looks at BA and DL cuts, 2020 Summer Transatlantic season is officially RIP.
The next round would be winter cuts. As enilria said about DL's prediction on vaccine, I somewhat agree, and I think I won't be surprised to see 2020/2021 Winter/Spring schedule get cut as deep as the 2020 summer as well.
Iggy500
Tue Aug 25, 2020 2:04 pm
I agree. That’s a big oof for DL.
panamair
Tue Aug 25, 2020 2:06 pm
They already had a press release last week about the planned TATL and TPAC operation for W20-21 and S21:
https://news.delta.com/delta-brings-bac ... ummer-2021
DL isn’t even the first of the US3 to adjust their W20-21 and S21 long-haul flying..AA already released their initial plans back in early July:
https://news.aa.com/news/news-details/2 ... fault.aspx
PSU.DTW.SCE
Tue Aug 25, 2020 2:07 pm
DL made a big press release announcing their winter 2021 and summer 2021 TPAC and TATL flying last week and then subsequently loaded the changes this past weekend.
It was buried in some of the Delta-specific threads on the forum but worth mentioned in this one as well.
The summary table in the press release shows the routes they plan to fly:
airlinepeanuts
Tue Aug 25, 2020 2:11 pm
KAI doing KOA-OAK? Is that a misfile? What equipment? Is that Mokulele?
PSU.DTW.SCE
Tue Aug 25, 2020 2:12 pm
MSP-TVC has been flown seasonally for decades, and typically sees mainline in the summer months.
DL did not operate MSP-TVC in Covid Summer 2020, along with LGA-TVC, or ATL-TVC and connected everything through DTW.
Tourism was very strong still this summer in Northern Michigan, and it looks like they are bringing back MSP-TVC for the fall.
Ishrion
Tue Aug 25, 2020 2:14 pm
I think that’s Kona Shuttle operated by KaiserAir’s 737s
Leaving the forums. You may know where to find me.
kavok
Tue Aug 25, 2020 2:15 pm
I think a lot of the international drops (in addition to there obviously being lower demand) is also forced by a reduction in fleet size. With all of the 777 and other frames exiting the system, there simply isn’t enough widebodies to serve all of the routes, even if they wanted to.
Future long haul international growth by DL will likely be somewhat dictated by the delivery rates of the new A350s and A330s.
DLASFlyer
Tue Aug 25, 2020 2:16 pm
Big ski cuts for DL. No more Aspen, Steamboat or Telluride. Only one route left for EGE, one for SUN and two for JAC after December.
MIflyer12
Tue Aug 25, 2020 2:20 pm
With ~2,000 pilot furloughs on top of ~1,800 pilot voluntary separations I don't think there's any doubt that DL is planning to be a lot smaller. We'll see which carriers persist in scheduling ~75% of last year's capacity and then cancelling just a month ahead (or even day of flight).
On the other hand I don't think 'gone for good' is a term I would use right now in the case of specific routes -- not until DL announces it's closing a station.
FSDan
Tue Aug 25, 2020 2:29 pm
Looks like DL is pulling completely out of Costa Rica? That has to be a misfile... Seems they're also cutting almost all capacity to major leisure destinations like SJD, PVR, MBJ, and PUJ...
This is my signature until I think of a better one.
PSU.DTW.SCE
Exactly, these are unprecedented times. Nothing is really "gone for good" at this point, it just means they are not going to fly it for Winter, or Summer 2021.
Makes sense that a lot of secondary and/or seasonal Europe flying is not going to operate and instead its going to be concentrated around their core hubs, gateways, and JV hubs.
The reality is Summer 2021 International is going to be way down no matter what. There is no scenario or trajectory toward anywhere near a normal amount of International travel demand next summer. We are still battling the virus on a global scale, border closures, quareteen protocols, and travel restrictions and the like are still going to exist in the months ahead, but hopefully some things become more certain or ease-up.
These seasonal flights to secondary Europe destinations disproportionately rely upon American tourists and VFR. A huge chunk of these involve traveling families, retirees, and tour groups/package deals. A lot of these people fall into at-risk categories and aren't going to be in a huge hurry to be a first-mover at returning to international travel.
DL has said publicly, their goal is to be "60-65%" for Summer 2021. That in reality means at about 50% for international and about 75-80% for domestic.
tphuang
Tue Aug 25, 2020 2:30 pm
HI enilria, thanks for the hardwork this is great stuff
interesting start time. There should be a lot of pent up VFR demand from west coast to PVG, but I'm not sure if there is enough business demand to carry this flight with so many carriers on the route.
Big cuts...
you are right, really big cuts for JetBlue this close-in. I did not expect it would be this large. Leisure demand in September out of northeast must be even weaker than they expected.
These are pretty large cuts from CA so early in the booking cycle. CA typically fills large portion of their cabin with connection traffic to rest of Asia.
Again, makes me wonder how US3 will be able to sustain some of the TPAC capacity that they have announced they will keep operating.
Big cuts on MBJ
JetBlue is going to be dancing in the streets with some of these DL Jamaica and JFK island cuts. Wow, they are basically out of Jamaica outside of 2 flights from ATL. That is shocking.
Not a surprise that that JFK-BOM and ATL-PVG are gone from the summer. I guess 2022 at the earliest. Is there any reason for them to restart JFK-BOM again?
mxaxai
Tue Aug 25, 2020 2:33 pm
Regarding BA, I don't understand why they maintain 1x weekly service to many smaller destinations like AUS, MSY, BNA or SJC. Is the nonstop yield so good - even at such low frequencies - that they don't just route people through AA's hubs?
jfklganyc
Tue Aug 25, 2020 2:35 pm
B6 :(
There June plan wasnt working and they have changed course
hiflyeras
Tue Aug 25, 2020 2:38 pm
These are massive cuts for every single carrier. It’s just mind-boggling...especially B6 and WN. The two with a lot of optimism seem to have hit a brick wall of reality. And poor Hawaii...yet another month of failure to relaunch.
PSU.DTW.SCE
Tue Aug 25, 2020 2:42 pm
Carriers can have a lot of optimism but that doesn't matter in this environment.
The demand curve isn't under normal market conditions and can't be easily stimulated by normal means.
Its not a "if you fly it, they will come" environment, nor even fire-saling tickets either.
The normal drivers of travel and purposes of trips just aren't there in the near-term.
We've had a lot of discussion in the booking trends thread, but the reality is that we are looking now really at outside of the potential for a few minor demand spikes around the holidays, the demand really isn't going to rachet upward significantly until Q2 2021.
TropicalSky
Tue Aug 25, 2020 2:44 pm
man DAL just gutted JAMAICA from basically every station
GCT64
Tue Aug 25, 2020 2:46 pm
DL certainly seems to be more responsible than others by giving TATL travellers a lot more warning to adjust their plans.
I note that some of the other carriers have just cancelled all / most the flights on a route as close in as September - that is really annoying and disruptive if you're a traveller.
(and I don't doubt that the other airlines will have to take the same cuts on TATL as DL, just they will leave it later to announce. DL are unlikely to be an outlier (although to allude to another thread, they may be allowing their JV partners to operate a disproportionate share of the flights))
Flown in: A20N,A21N,A30B,A306,A310,A319,A320,A321,A332,A333,A343,A346,A359,A388,BA11,BU31,(..56 more types..),VC10,WESX
NWAESC
Tue Aug 25, 2020 2:52 pm
Nice to see PVD coming back to life.
"Nothing ever happens here, " I said. "I just wait."
MIflyer12
Tue Aug 25, 2020 2:56 pm
[quote]
Care to check back in April and see if that's starting as planned today? A new intercontinental route scheduled more than six months away is nothing but hopes and prayers at this point.
USAirALB
Tue Aug 25, 2020 3:05 pm
Thanks as always!
Some interesting notes:
-I don't think CLT-SJD/STX have ever had daily service, but were always Saturday-only service. SJD might have daily service at one point but it didn't last.
-I also don't remember the last time CLT had twice daily CLT-STT service.
Like CLT's Germany service, I always assumed that ATL's Germany service was similar in that it was propped up by corporate contracts. I know the STR flight catered to MB/Porsche, and carried a substantial amount of GSA traffic. I'm wondering if the STR suspension has something to do with a corporate account telling DL that the flight is essentially worthless until next year.
The DL DUS flight was the last remaining year-round nonstop to the US. Sad to see it gone, but frankly I am surprised to see it last as long as it did. Hopefully it will come back in some shape or form.
I know AA mentioned the possibility of running CLT-Secondary Germany with the A321XLR, but that was pre-COVID of course.
RJ85, F70, E135, E140, E145, E70, E75, E90, CR2, CR7, CR9, 717, 732, 733, 734, 735, 73G, 738, 739, 744ER, 752, 753, 762, 763ER, 772, 77E, 77W, 789, 319, 320, 321, 332, 333, 343, 359, 388
Ishrion
Tue Aug 25, 2020 3:09 pm
Really nice to see AA increase this route to daily. It just launched in December 2019 although it's now on the A319 after the 757 was retired.
airlinepeanuts
Tue Aug 25, 2020 3:17 pm
Ahh! Makes sense! Thanks
N757ST
A lot of these b6 cuts seem to be related to the quarenteen directives of a few northeastern states. Florida and Arizona seem to be on the back side of this thing.... as long as there isn't a second wave I could see considerable adds as the quarenteens get cut. Arizona has to average 800 or less cases a day and florida in the mid 2000s. As soon as that happens, the flood gates could open on NYC-Florida travel.
fpetrutiu
Tue Aug 25, 2020 3:24 pm
I think it is an error. According to their announcements, this is really not the case. See the article below from yesterday. They were all over the news with their expansion plan yesterday, even on CNN.
https://www.streetinsider.com/Corporate ... 73080.html
Florin
Orlando, FL
panamair
Tue Aug 25, 2020 3:27 pm
I don't think the Jamaica cuts are correct. I still see JFK-MBJ available for booking in Oct, Nov, Dec (peak holiday period even shows 2 flights a day), Jan, Feb, March, etc.
I also see LAX-SJO available in late December, January....
Chuska
Tue Aug 25, 2020 3:39 pm
This flight normally runs daily all the time, must have been a previous schedule misfile. In either case, there's going to be a lot more demand for it if AA goes thru with chopping ROW-DFW (CNM is the next closest to ROW but still 75 miles away).
enilria
Tue Aug 25, 2020 4:05 pm
>the airline plans to increase flying in the trans-Atlantic market from winter 2020-2021 to summer 2021.
Well, Delta is saying they plan to fly more in Summer 2021 than this Winter. That's saying VERY LITTLE. If they didn't do that I think the shareholders would fire them all.
No idea. I wouldn't be surprised if they rolled back some of this. The Holiday ops followed by suspensions are odd, but I've seen Delta do that before.
Agreed on the customer friendly-ness, just surprised they would not scoop up bookings by over-selling Summer 2021.
enilria
Tue Aug 25, 2020 4:07 pm
It feels like this schedule is "what are we definitely flying" and then they will layer stuff onto it. Perhaps there is a layer already added.
SANFan
Tue Aug 25, 2020 4:14 pm
I think the ".1" frequency might be a bit misleading. Those October counts and service don't begin until 10/25 -- when the winter sked kicks in -- so in most cases, I think the Oct frequencies are only representing about a weeks worth of flights. Without looking at BA's flight skeds, my guess is that the ".1" translates to more like at least 2 weekly flights... Just my assumption. Enilria will need to confirm.
bb
Lootess
Tue Aug 25, 2020 4:17 pm
I trust the Delta official press release of their winter/summer 21 schedule: https://news.delta.com/delta-brings-back-more-flights-across-atlantic-and-pacific-winter-and-summer-2021
ATL-DUS was an automotive industry route, name Mercedes-Benz. Just like ATL-STR but that one has more revenue, namely Mercedes and Porsche legs to stand on hence why that one is staying afloat during hard times.
DUS will return someday, Mercedes-Benz USA HQ is in ATL.
PSU.DTW.SCE
Tue Aug 25, 2020 4:30 pm
Probably to legitimize it with the various non-customer stakeholders that yes they are going to be much smaller next summer.
Those stakeholders knew there would be fewer aircraft with the announced 777 and 763 retirements.
This helps show why there will be furloughs and layoffs across various employee groups.
Its not just smoke and mirrors.
Releasing a schedule now helps give better certainty.
Also has implications with the JV partner flying that we will all see in the weeks/months ahead.
DL probably also doesn't want to unnecessarily start incurring potential refund exposure if they start taking bookings for flights/markets/routes they will not operate.
FlyPNS1
Tue Aug 25, 2020 4:33 pm
Interesting to see the close in adds by WN at PNS. Looking at the schedules, it looks like WN was close to overselling (relative to the limited seating capacity) some of the HOU and DAL flights and realized they needed another section in September. WN will have more daily weekday flights this September (6 flights) at PNS, than they did last September (4 flights).
mn2018
Tue Aug 25, 2020 6:15 pm
Noticed DTW - BMI is coming back on October 1. Seems pretty surprising to add this route again in the middle of a pandemic. The huge Rivian auto plant starting up near BMI must be a big factor.
chonetsao
Tue Aug 25, 2020 6:49 pm
mxaxai wrote:
BA cuts...
Like SANfan said, it is not 1 weekly flights to many places. What happened is that the winter season starts around 24th/25th October, and BA so far only mde cuts into summer season. So there is one week worth of flights in end of October.
Suppose 0.1 frequency is an average daily frequency, that translate to 0.7 weekly, as October has more than 4 weeks, So that is 2.8 - 3 frequencies for the whole October. Which makes sense as BA has not formally cut the winter/spring schedule yet. I hope that helps and I hope enilria can confirm later.
LAX772LR
Tue Aug 25, 2020 6:51 pm
If long-term accurate (which I suspect it's not) then it may just be utilization.
There's also the limitation that none of these secondary (and even a few FAA large-hubs, e.g. SAN/TPA/etc) are yet cleared by the US to receive nonstop TATLs; so BA may just be bumming the schedules waiting for that.
I say all this considering that most of these routes were daily or 4xW when the last adjustment was made, only two or three weeks ago, but not killed off per the likes of PIT/PDX/CHS/YYC.
BA744PHX
Tue Aug 25, 2020 6:53 pm
This is not rocket science regarding BA, its a simple google.com/flights or ba.com search and you will see its only the last week of the month.
It's just that simple.
avi8
Tue Aug 25, 2020 7:14 pm
I like how UA is being opportunistic and is seizing market share in Central America. I guess having hubs at Central America’s biggest O/D cities helps.
avi8
klm617
Tue Aug 25, 2020 8:46 pm
WOW DTW picks up BMI nonstops this hasn't been served in eons.
the truth does matter, guys. too bad it's often quite subjective. the truth is beyond the mere facts and figures. it's beyond good and bad, right and wrong...
keithvh2001
Tue Aug 25, 2020 8:50 pm
2 thoughts on TVC-MSP being added for October:
(1) There was one February in the early 2010s where I flew TVC-MSP (MSP as my destination, no connection) on Delta. It definitely hasn't always been year-around, but there was at least one winter it was around.
(2) Cape Air is starting MBL-ORD on October 1st. Only an 11-seat plane.
But, more interestingly, those flights will code share with American. Ludington and Manistee aren't the biggest places in the world, but it's fair to say they are part of TVC's catchment area. The American code-share means those folk don't necessarily need to make the 1 hour trip to GRR or MKG or TVC if they're flying west or south and need to connect anyway.
I wonder if Delta's add of TVC-MSP is partially a defensive move against that.
klm617
Tue Aug 25, 2020 8:51 pm
This is an a.net myth ATL-STR has nothing to do with automotive traffic it is just the icing on the cake. ATL-STR was started almost 40 years ago before those plants and HQs were even there. STR is all about military moving from the Southern US dtste to bases in Southern Germany.
enilria
Tue Aug 25, 2020 10:13 pm
bb
I think you are correct. It is a partial month.
It's probably about CARES as is the AA announcement.
I think like the national parks, TVC is the type of place people feel safe to go to in COVID so it is seeing some longer seasons on flights.
The auto traffic is J. Military is Y. It's more than icing.
wedgetail737
Wed Aug 26, 2020 12:06 am
It's too bad SEA-KIX isn't in the cards anymore.
FSDan
Wed Aug 26, 2020 12:53 am
Not to rain on the parade, but this looks to me like DL probably just extended September cuts into early November and hasn't cut further out yet. Hopefully they will be back in PVD as soon as traffic starts to return, as Providence is it's own decent-sized area and not just some Boston suburb...
DTWLAX
Wed Aug 26, 2020 1:41 am
It is surprising that DL cut off MSP completely from AMS, CDG and LHR until next summer. When was the last time (pre-Covid) MSP did not have a flight to AMS?
DDR
Wed Aug 26, 2020 2:37 am
With DL making so many cuts everywhere else, they are obviously keeping SEA flights that aren’t profitable in order to keep gates.
acavpics
Wed Aug 26, 2020 2:51 am
SO what are all the "numerous routes" that they've cut for next summer? I went to the posted link on DL's news hub and saw that many of the existing ones are still listed at daily frequency for summer 2021.
