enilria
OAG Changes 9/1/2020:AA Adds PHX-BIL/BIS/BNA/CVG/TUL/YYC,CLT-FSD,JFK-SJD;AS to JAC;DL Drops BZN-SEA,Reverses Carib Cuts
Tue Sep 01, 2020 2:04 pm
FAQ
SOURCE: OAG
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
4B ATL-GLH SEP 0.8>0[1.0] OCT 0.8>0.4[1.0] NOV 0.6>0.3[0.8]
4B BNA-GLH SEP 0>0.9[0] OCT 0>0.8[0] NOV 0>0.6[0]
4B IAH-VCT OCT 1.5>2[1.9]
4O CUN-MIA SEP 0.6>0[0]
4O DFW-MEX SEP 2>0[1.4]
4O GDL-LAS SEP 0.4>0[0.9]
4O GDL-LAX SEP 0.6>0[1.5]
4O GDL-ORD SEP 0.6>0[1.0]
4O GDL-SAT SEP 0.4>0[1.0]
4O GDL-SFO SEP 0.6>0[1.0]
4O IAH-MEX SEP 2>0[1.5]
4O IAH-MTY SEP 1.0>0[0.7]
4O JFK-MEX SEP 1.0>0[3]
4O LAS-MEX SEP 0.6>0[1.0]
4O LAS-MTY SEP 1.0>0[0.6]
4O LAX-MEX SEP 2>0[1.7]
4O LAX-MTY SEP 0.6>0[0]
4O MCO-MEX SEP 1.0>0[1.0]
4O MEX-MIA SEP 1.0>0[1.2]
4O MEX-ORD SEP 2>0[1.4]
4O MEX-SAT SEP 2>0[1.7]
4O MTY-SAT SEP 1.0>0[0.8]
Cape Air data has been iffy since the Tecname was added
9K ACK-BOS OCT 8>6[12] NOV 7>3[8] DEC 7>3[9] JAN 7>3[7] FEB 7>3[7] MAR 7>3[7] APR 7>3[8] MAY 7>3[10]
9K ACK-EWB OCT 1.9>0.9[3] NOV 2>0.6[2] DEC 2>0.6[2] JAN 2>0.5[2] FEB 2>0.6[0.9] MAR 2>0.6[0.8] APR 2>0.6[0.9] MAY 2>0.5[1.0]
9K ACK-HYA OCT 9>8[9] NOV 7>5[7] DEC 7>5[7] JAN 7>5[7] FEB 7>5[7] MAR 7>5[7] APR 7>5[7] MAY 7>5[6]
9K ACK-JFK OCT 1.0>0.4[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] APR 0.4>0[0.4] MAY 1.0>0[0.6]
9K ACK-MVY OCT 0.1>1.3[0.3] NOV 0.1>2[0.1] DEC 0.2>2[0.2] JAN 1.0>2[1.0] FEB 1.1>2[1.1] MAR 1.2>2[1.2] APR 0.7>2[0.8] MAY 0.1>2[0.2]
9K BOS-MVY OCT 6>4[8] NOV 5>2[5] DEC 5>2[5] JAN 4>2[4] FEB 4>2[4] MAR 4>2[4] APR 4>2[4] MAY 4>2[6]
9K BOS-PVC NOV 3>2[3] DEC 3>2[3] JAN 3>2[3] FEB 3>2[3] MAR 3>2[3] APR 3>2[0] MAY 3>2[4]
AA ABE-CLT OCT 4>3[3]
AA ABE-ORD OCT 1.8>0.8[2.0]
AA ABI-DFW OCT 6>4[7]
AA ABQ-DFW OCT 7>6[8]
AA ABQ-LAX OCT 2>0[3]
AA ABQ-ORD OCT 1.7>1.0[2.0]
AA ABQ-PHX OCT 4>2[4]
AA ACT-DFW OCT 5>3[5]
AA AGS-CLT OCT 5>4[6]
AA AGS-DCA OCT 0.8>0[0]
AA AGS-DFW OCT 1.8>1.0[1.0]
AA ALB-DCA OCT 3>1.0[4]
AA ALB-ORD OCT 2>1.9[3]
AA ALB-PHL OCT 5>1.5[5]
AA ALO-ORD OCT 1.7>0.8[1.9]
AA AMA-DFW OCT 7>5[7]
AA ANU-MIA OCT 1.0>0.7[1.0]
AA ASE-DFW NOV 1.0>1.9[1.3] DEC 2>3[2]
AA ATL-CLT OCT 8>6[8]
AA ATL-DCA OCT 4>0[4]
AA ATL-DFW OCT 8>6[8]
AA ATL-LAX OCT 2>0[3]
AA ATL-LGA OCT 4>0[5]
AA ATL-MIA OCT 7>1.6[8]
AA ATL-ORD OCT 5>2[5]
AA ATL-PHL OCT 5>1.4[5]
AA ATL-PHX OCT 1.8>0.8[1.9]
AA ATW-ORD OCT 3>2[3]
AA AUA-MIA OCT 1.9>1.3[2]
AA AUS-BOS OCT 1.3>0[0]
AA AUS-CLT OCT 5>4[5]
AA AUS-DFW OCT 10>6[11]
AA AUS-JFK OCT 1.6>0[1.0]
AA AUS-LAX OCT 3>0[4]
AA AUS-MIA OCT 4>1.5[3]
AA AUS-ORD OCT 4>1.1[4]
AA AUS-PHL OCT 1.6>0[3]
AA AUS-PHX OCT 4>2.0[4]
AA AUS-SJC OCT 1.4>0[0]
AA AVL-CLT OCT 7>5[8]
AA AVL-LGA OCT 0.8>0[0.3]
AA AVL-PHL OCT 0.8>0[1.0]
AA AVP-CLT OCT 5>4[4]
AA AVP-ORD OCT 1.8>1.2[2.0]
AA AZO-ORD OCT 2>0.8[3]
AA BAQ-MIA OCT 1.0>0.7[0.8]
AA BDA-MIA OCT 0.8>0.4[1.0]
AA BDA-PHL OCT 0.8>0[0.9]
AA BDL-CLT OCT 5>3[6]
AA BDL-DCA OCT 5>0[6]
AA BDL-DFW OCT 1.6>0.8[1.8]
AA BDL-LAX OCT 0.7>0[0.8]
AA BDL-MIA OCT 0.8>0[1.0]
AA BDL-ORD OCT 4>2[4]
AA BDL-PHL OCT 5>1.4[5]
AA BFL-DFW OCT 1.8>1.0[1.0]
AA BGI-MIA SEP 0.5>0[2] OCT 1.8>0.6[2]
AA BGR-DCA OCT 3>1.4[3]
AA BGR-PHL OCT 4>1.4[5]
AA BHM-CLT OCT 6>4[7]
AA BHM-DCA OCT 2>0[3]
AA BHM-DFW OCT 6>4[5]
AA BHM-MIA OCT 1.9>1.5[2]
AA BHM-ORD OCT 1.8>0.8[1.8]
AA BHM-PHL OCT 2>0[3]
**AA BIL-PHX NOV 0>0.9[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0]
**AA BIS-PHX NOV 0>0.9[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0]
AA BMI-DFW OCT 1.8>1.0[1.7]
AA BMI-ORD OCT 2>0.8[3]
AA BNA-CLT OCT 8>6[8]
AA BNA-DCA OCT 4>1.0[6]
AA BNA-DFW OCT 8>6[7]
AA BNA-JFK OCT 1.6>0[2]
AA BNA-LAX OCT 1.6>0[1.8]
AA BNA-LGA OCT 4>0[5]
AA BNA-MIA OCT 4>1.4[2]
AA BNA-ORD OCT 7>3[9]
AA BNA-PHL OCT 5>1.4[5]
**AA BNA-PHX NOV 0>0.5[0] DEC 0>0.5[0] JAN 0>0.6[0] FEB 0>0.6[0] MAR 0>0.5[0]
AA BOG-MIA OCT 3>1.5[3]
AA BOI-ORD OCT 0.9>0.4[1.0]
AA BON-MIA OCT 0.4>0.1[0.5]
AA BOS-CLT OCT 9>7[9]
AA BOS-DCA OCT 12>5[12] NOV 14>13[10]
AA BOS-DFW OCT 7>5[6]
AA BOS-IND OCT 1.5>0[0]
AA BOS-JFK OCT 5>0[1.0]
AA BOS-LAX OCT 5>0[4]
AA BOS-LGA OCT 10>1.6[11] NOV 11>10[8]
AA BOS-MDT OCT 0.8>0[1.0]
AA BOS-MIA OCT 6>1.6[5]
AA BOS-ORD OCT 7>3[9]
AA BOS-PHL OCT 12>6[9]
AA BOS-PHX OCT 4>1.6[4]
AA BOS-RDU OCT 4>0[0]
AA BOS-ROC OCT 2>0[3]
AA BOS-SYR OCT 0.8>0[1.0]
AA BPT-DFW OCT 3>2[3]
AA BRO-DFW OCT 4>2[4]
AA BTR-CLT OCT 3>2.0[3]
AA BTR-DFW OCT 6>4[6]
AA BTV-CLT OCT 3>2.0[2.0]
AA BTV-DCA OCT 2>0[3]
AA BTV-PHL OCT 4>1.4[4]
AA BUF-CLT OCT 3>1.6[3]
AA BUF-DCA OCT 3>0[3]
AA BUF-ORD OCT 4>2[4]
AA BUF-PHL OCT 5>1.4[5]
AA BUR-DFW OCT 1.8>1.0[2.0]
AA BUR-PHX OCT 4>2.0[5]
AA BWI-CLT OCT 8>6[9]
AA BWI-DFW OCT 4>3[4]
AA BWI-JFK OCT 4>0[1.0]
AA BWI-MIA OCT 1.6>0[1.0]
AA BWI-ORD OCT 4>1.5[4]
AA BWI-PHL OCT 2>0[4]
AA BZE-MIA OCT 1.0>0.7[1.0]
AA CAE-CLT OCT 6>5[8]
AA CAE-DCA OCT 2>0[3]
AA CAE-DFW OCT 3>2.0[3]
AA CAE-LGA OCT 0.8>0[1.0]
AA CAE-MIA OCT 0.8>0[0]
AA CAE-PHL OCT 2>0[3]
AA CAK-CLT OCT 5>4[5]
AA CAK-DCA OCT 0.8>0[1.0]
AA CAK-LGA OCT 0.7>0[0.9]
AA CAK-ORD OCT 0.8>0[2.0]
AA CAK-PHL OCT 1.7>0.7[2]
AA CHA-CLT OCT 6>5[7]
AA CHA-DCA OCT 0.7>0[0.9]
AA CHA-DFW OCT 3>2.0[3]
AA CHO-CLT OCT 7>5[8]
AA CHO-LGA OCT 1.5>0[1.8]
AA CHO-ORD OCT 1.6>0.6[3]
AA CHO-PHL OCT 1.7>0.1[1.9]
AA CHS-CLT OCT 8>6[9]
AA CHS-DCA OCT 4>0.6[4]
AA CHS-LGA OCT 0.2>0[1.0]
AA CHS-MIA OCT 2>0.7[4]
AA CHS-ORD OCT 1.0>0.5[1.0]
AA CHS-PHL OCT 4>1.4[4]
AA CID-CLT OCT 3>2.0[2.0]
AA CID-ORD OCT 5>2.0[6]
AA CID-PHX NOV 0.4>1.8[0] DEC 1.0>2[0.4] JAN 1.0>2[1.0] FEB 1.0>2[1.0] MAR 0.9>1.9[1.0]
AA CLE-CLT OCT 6>5[7]
AA CLE-DCA OCT 3>0[3]
AA CLE-DFW OCT 4>3[5]
AA CLE-JFK OCT 1.6>0[1.0]
AA CLE-LGA OCT 3>0[3]
AA CLE-MIA OCT 1.8>0[2]
AA CLE-ORD OCT 6>2[7]
AA CLE-PHL OCT 5>1.4[5]
AA CLL-DFW OCT 4>3[4]
AA CLO-MIA OCT 1.0>0.6[1.0]
AA CLT-CMH OCT 7>6[8]
AA CLT-CRW OCT 4>3[5]
AA CLT-CUN FEB 3>4[3] MAR 3>4[3]
AA CLT-CVG OCT 6>5[7]
AA CLT-DAB OCT 4>3[4]
AA CLT-DAY OCT 6>4[6]
AA CLT-DCA OCT 8>5[9]
AA CLT-DEN OCT 6>5[6]
AA CLT-DFW OCT 10>9[10]
AA CLT-DTW OCT 6>4[6]
AA CLT-EWN OCT 5>4[5]
AA CLT-EWR OCT 8>5[8]
AA CLT-FAY OCT 5>4[6]
AA CLT-FLL OCT 7>6[7]
AA CLT-FLO OCT 3>2[4]
**AA CLT-FSD NOV 0>0.9[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0]
AA CLT-GNV OCT 4>3[4]
AA CLT-GSO OCT 8>6[9]
AA CLT-GSP OCT 8>6[9]
AA CLT-HPN OCT 3>1.3[4]
AA CLT-HSV OCT 4>3[4]
AA CLT-HTS OCT 3>1.9[3]
AA CLT-HVN OCT 1.7>1.0[0.1]
AA CLT-IAD OCT 6>4[7]
AA CLT-ILM OCT 8>6[9]
AA CLT-IND OCT 7>6[8]
AA CLT-ITH OCT 1.8>1.0[0.1]
AA CLT-JAN OCT 4>2[4]
AA CLT-JAX OCT 7>6[8]
AA CLT-JFK OCT 5>3[5]
AA CLT-LAX OCT 7>5[7]
AA CLT-LEX OCT 5>3[5]
AA CLT-LGA OCT 9>6[10]
AA CLT-LIT OCT 4>3[5]
AA CLT-LYH OCT 5>4[7]
AA CLT-MCI OCT 4>3[4]
AA CLT-MCO OCT 10>7[10]
AA CLT-MDT OCT 5>4[6]
AA CLT-MEM OCT 6>4[6]
AA CLT-MGM OCT 3>1.7[3]
AA CLT-MHT OCT 4>3[4]
AA CLT-MKE OCT 4>3[5]
AA CLT-MOB OCT 4>3[5]
AA CLT-MSN OCT 3>2[2.0]
AA CLT-MSP OCT 4>3[4]
AA CLT-MSY OCT 6>4[7]
AA CLT-MYR OCT 8>6[8]
AA CLT-NAS SEP 0.7>0.3[1.1]
AA CLT-OAJ OCT 6>4[6]
AA CLT-OMA OCT 3>2[3]
AA CLT-ORD OCT 9>7[10]
AA CLT-ORF OCT 8>6[8]
AA CLT-PBI OCT 5>4[5]
AA CLT-PGV OCT 3>2[5]
AA CLT-PHF OCT 5>4[6]
AA CLT-PHL OCT 9>6[9]
AA CLT-PHX OCT 8>6[8]
AA CLT-PIT OCT 8>6[9]
AA CLT-PLS OCT 0.8>0.1[0.1]
AA CLT-PNS OCT 5>4[5]
AA CLT-PUJ OCT 1.1>1.7[1.1] NOV 1.2>2[1.2] DEC 1.7>2[0.9]
AA CLT-PVD OCT 4>3[5]
AA CLT-PWM OCT 3>2.0[2]
AA CLT-RDU OCT 8>5[9]
AA CLT-RIC OCT 7>6[8]
AA CLT-ROA OCT 7>4[8]
AA CLT-SAN OCT 4>2.0[4]
AA CLT-SAV OCT 8>6[8]
AA CLT-SBY OCT 3>2[2]
AA CLT-SDF OCT 7>5[8]
AA CLT-SFO OCT 5>3[5]
AA CLT-SGF OCT 3>2[4]
AA CLT-STL OCT 5>4[7]
AA CLT-SYR OCT 4>3[4]
AA CLT-TLH OCT 4>3[4]
AA CLT-TPA OCT 8>7[9]
AA CLT-TRI OCT 5>3[6]
AA CLT-TYS OCT 6>5[8]
AA CLT-XNA OCT 3>2.0[4]
AA CLT-YUL OCT 1.6>0[2.0]
AA CLT-YYZ OCT 4>1.5[5]
AA CMH-DCA OCT 3>1.0[5]
AA CMH-DFW OCT 5>4[5]
AA CMH-JFK OCT 1.6>0[1.0]
AA CMH-LAX OCT 0.8>0[1.5]
AA CMH-LGA OCT 4>0[6]
AA CMH-MIA OCT 3>1.4[4]
AA CMH-ORD OCT 8>2[8]
AA CMH-PHL OCT 6>1.4[6]
AA CMH-PHX OCT 1.8>1.0[1.8]
AA CMI-DFW OCT 1.6>0.8[2]
AA CMI-ORD OCT 4>0.5[6]
AA COS-ORD OCT 0.9>0.4[1.0]
AA COU-DFW OCT 3>2[3]
AA COU-ORD OCT 2>0[3]
AA CRP-DFW OCT 7>5[8]
AA CRW-DCA OCT 0.8>0[1.0]
AA CRW-PHL OCT 0.8>0[1.0]
AA CTG-MIA OCT 1.0>0.7[1.0]
AA CUN-DFW JAN 6>7[6] FEB 6>7[6] MAR 6>8[7]
AA CUN-JFK OCT 0.4>0.2[0.1]
AA CUN-MIA OCT 3>2[5]
AA CUN-PHL OCT 1.0>1.7[1.1]
AA CUN-PHX OCT 0.6>0.2[0.3]
AA CUN-RDU DEC 0>0.5[0]
AA CUR-MIA OCT 1.6>0.6[1.0]
AA CVG-DCA OCT 2>0[3]
AA CVG-JFK OCT 0.8>0[1.0]
AA CVG-LGA OCT 1.5>0[1.9]
AA CVG-MIA OCT 3>0.7[3]
AA CVG-ORD OCT 6>2[7]
AA CVG-PHL OCT 5>1.3[5]
**AA CVG-PHX NOV 0>0.5[0] JAN 0>0.6[1.0] FEB 0>0.6[1.0] MAR 0>0.5[1.0]
AA CWA-ORD OCT 2>1.2[3]
AA DAY-DCA OCT 3>1.0[4]
AA DAY-LGA OCT 2>0[3]
AA DAY-ORD OCT 4>1.1[5]
AA DAY-PHL OCT 3>1.4[4]
AA DBQ-ORD OCT 2>1.1[3]
AA DCA-DFW OCT 9>5[9]
AA DCA-DSM OCT 1.5>0[1.8]
AA DCA-DTW OCT 2>0.8[3]
AA DCA-ECP OCT 0.8>0[0]
AA DCA-EYW NOV 0.3>1.0[0.5] DEC 0.3>0.6[0.7]
AA DCA-GRR OCT 1.4>0[1.9]
AA DCA-GSO OCT 2>0[3]
AA DCA-GSP OCT 2>0.1[3]
AA DCA-HPN OCT 4>0[4]
AA DCA-HSV OCT 3>0[3]
AA DCA-ILM OCT 0.8>0[1.0]
AA DCA-IND OCT 5>1.0[6]
AA DCA-JAN OCT 0.8>0[1.0]
AA DCA-JAX OCT 3>0[4]
AA DCA-JFK OCT 3>0[1.0]
AA DCA-LAN OCT 0.8>0[1.0]
AA DCA-LAS OCT 0.8>0[1.0]
AA DCA-LAX OCT 1.8>1.0[2]
AA DCA-LGA OCT 10>4[8]
AA DCA-LIT OCT 0.8>0[1.0]
AA DCA-MCI OCT 2>0[3]
AA DCA-MCO OCT 4>1.0[4]
AA DCA-MEM OCT 2>0.1[3]
AA DCA-MGM OCT 0.8>0[1.0]
AA DCA-MHT OCT 2>0[4]
AA DCA-MIA OCT 8>2[9]
AA DCA-MSP OCT 2>0.8[3]
AA DCA-MSY OCT 3>0.6[4]
AA DCA-MYR OCT 0.9>0.3[0.3]
AA DCA-OKC OCT 0.8>0[1.0]
AA DCA-ORD OCT 8>4[9]
AA DCA-ORF OCT 2>0.8[3]
AA DCA-PBI OCT 0.8>0[2.0]
AA DCA-PHL OCT 3>1.7[3]
AA DCA-PHX OCT 3>1.0[3]
AA DCA-PIT OCT 3>0[5]
AA DCA-PNS OCT 1.8>1.0[2]
AA DCA-PVD OCT 5>0.8[6]
AA DCA-PWM OCT 4>1.5[5]
AA DCA-RDU OCT 5>0[6]
AA DCA-ROC OCT 2>0[3]
AA DCA-SAV OCT 1.6>0[2]
AA DCA-SDF OCT 2>0[3]
AA DCA-SRQ OCT 0.9>0.2[1.0]
AA DCA-STL OCT 3>0[5]
AA DCA-SYR OCT 2>0[4]
AA DCA-TLH OCT 0.8>0[1.0]
AA DCA-TPA OCT 4>1.2[3]
AA DCA-TYS OCT 2>0[3]
AA DCA-XNA OCT 0.8>0[0.9]
AA DCA-YYZ OCT 1.5>0[1.8]
AA DEN-DFW OCT 11>8[10]
AA DEN-LAX OCT 3>2.0[3]
AA DEN-MIA OCT 1.8>0.9[2]
AA DEN-ORD OCT 4>2[5]
AA DEN-PHL OCT 3>0.7[3]
AA DEN-PHX OCT 4>3[4]
AA DFW-DSM OCT 5>3[4]
AA DFW-EGE OCT 1.0>0.6[0.3]
AA DFW-ELP OCT 8>6[9]
AA DFW-EWR OCT 4>2[5]
AA DFW-FSM OCT 4>3[5]
AA DFW-GGG OCT 3>2[3]
AA DFW-GNV OCT 1.8>1.0[2.0]
AA DFW-GPT OCT 3>2.0[3]
AA DFW-GRI OCT 3>2[2]
AA DFW-GRK OCT 7>5[6]
AA DFW-GSO OCT 3>1.9[3]
AA DFW-GSP OCT 2>1.9[2]
AA DFW-GUA OCT 1.0>0.6[1.1]
AA DFW-HOU OCT 8>4[8]
AA DFW-HRL OCT 3>2.0[3]
AA DFW-HSV OCT 5>4[5]
AA DFW-IAD OCT 3>1.9[4]
AA DFW-IAH OCT 9>6[9]
AA DFW-ICT OCT 6>4[7]
AA DFW-IND OCT 5>4[5]
AA DFW-JAC OCT 2>1.2[0.9]
AA DFW-JAN OCT 6>4[7]
AA DFW-JAX OCT 6>5[6]
AA DFW-JFK OCT 3>0[2]
AA DFW-LAS OCT 11>8[10]
AA DFW-LAW OCT 4>2[4]
AA DFW-LAX OCT 14>9[15]
AA DFW-LBB OCT 7>5[7]
AA DFW-LFT OCT 5>3[5]
AA DFW-LGA OCT 11>6[12]
AA DFW-LIT OCT 8>6[9]
AA DFW-LRD OCT 4>2[5]
AA DFW-MAF OCT 7>4[8]
AA DFW-MCI OCT 8>6[8]
AA DFW-MCO OCT 11>8[10]
AA DFW-MEM OCT 8>6[8]
AA DFW-MFE OCT 7>5[8]
AA DFW-MGM OCT 3>2.0[3]
AA DFW-MHK OCT 3>2.0[3]
AA DFW-MIA OCT 11>8[10]
AA DFW-MKE OCT 4>2[4]
AA DFW-MLU OCT 3>2[3]
AA DFW-MOB OCT 4>2[4]
AA DFW-MRY NOV 1.0>1.9[0.9] DEC 1.0>2[1.0]
AA DFW-MSP OCT 6>4[6]
AA DFW-MSY OCT 8>6[8]
AA DFW-OKC OCT 9>6[9]
AA DFW-OMA OCT 5>3[4]
AA DFW-ORD OCT 13>8[14]
AA DFW-ORF OCT 3>2.0[2]
AA DFW-PBI OCT 3>2.0[3]
AA DFW-PDX OCT 5>4[4]
AA DFW-PHL OCT 9>7[9]
AA DFW-PHX OCT 11>8[12]
AA DFW-PIA OCT 2>1.2[2]
AA DFW-PIT OCT 5>4[5]
AA DFW-RDU OCT 6>5[6]
AA DFW-RIC OCT 3>2.0[3]
AA DFW-ROW OCT 3>1.8[3]
AA DFW-RSW OCT 4>3[3]
AA DFW-SAF OCT 5>3[4]
AA DFW-SAL OCT 0.5>0[0]
AA DFW-SAN OCT 9>6[9]
AA DFW-SAT OCT 10>7[11]
AA DFW-SAV OCT 3>2.0[2]
AA DFW-SBP OCT 1.8>1.0[1.0]
AA DFW-SDF OCT 6>4[6]
AA DFW-SEA OCT 8>7[8]
AA DFW-SFO OCT 8>5[9]
AA DFW-SGF OCT 8>6[7]
AA DFW-SHV OCT 7>5[6]
AA DFW-SJC OCT 4>3[4]
AA DFW-SJD OCT 3>4[4] JAN 4>5[4] FEB 4>5[4] MAR 4>5[4]
AA DFW-SJT OCT 5>4[6]
AA DFW-SLC OCT 7>5[5]
AA DFW-SNA OCT 8>6[8]
AA DFW-SPS OCT 4>2[3]
AA DFW-SRQ OCT 1.8>1.0[0.9]
AA DFW-STL OCT 7>6[8]
AA DFW-SUX OCT 0.8>0[1.0]
AA DFW-SWO OCT 3>2[3]
AA DFW-TLH OCT 3>2.0[3]
AA DFW-TRC OCT 1.0>0.7[2]
AA DFW-TRI OCT 1.8>1.0[2]
AA DFW-TUL OCT 8>6[9]
AA DFW-TUS OCT 7>5[6]
AA DFW-TXK OCT 4>2[4]
AA DFW-TYR OCT 4>3[5]
AA DFW-TYS OCT 5>3[4]
AA DFW-XNA OCT 8>6[9]
AA DFW-YUL OCT 0.8>0[1.0]
AA DFW-YYZ OCT 2>0[3]
AA DRO-PHX OCT 2>1.2[3]
AA DSM-ORD OCT 5>2[7]
AA DSM-PHL OCT 1.6>0[1.0]
AA DTW-LGA OCT 4>0[4]
AA DTW-MIA OCT 1.6>0[1.7]
AA DTW-ORD OCT 5>3[8]
AA DTW-PHL OCT 5>1.4[5]
AA DTW-PHX OCT 1.8>1.0[1.9]
AA ELH-MIA OCT 1.1>0.6[0]
AA ELP-LAX OCT 2>0[3]
AA ELP-ORD OCT 1.8>1.1[2.0]
AA ELP-PHX OCT 4>3[5]
AA ERI-ORD OCT 0.8>0[1.0]
AA EVV-ORD OCT 1.6>0[2.0]
AA EWR-MIA OCT 3>1.6[3]
AA EWR-ORD OCT 5>2.0[6]
AA EWR-PHX OCT 3>0[3]
AA EYW-MIA OCT 4>1.5[5]
AA FAR-ORD OCT 3>1.3[3]
AA FAR-PHX NOV 0.4>0.9[0]
AA FAT-PHX OCT 5>3[5]
AA FLG-PHX OCT 4>3[4]
AA FLL-ORD OCT 1.6>0.1[0]
AA FLL-PHL OCT 3>2[4]
AA FNT-ORD OCT 3>1.2[4]
AA FPO-MIA OCT 0.8>0.6[1.0]
AA FSD-ORD OCT 3>2[3]
AA FWA-ORD OCT 3>1.2[4]
AA FWA-PHL OCT 1.5>0.7[1.0]
AA GCM-MIA OCT 1.4>0.6[1.6]
AA GEO-JFK OCT 0.8>0[0]
AA GEO-MIA OCT 0.8>0.5[1.0]
AA GGT-MIA OCT 1.0>1.3[0.9]
AA GJT-PHX OCT 3>2[3]
AA GND-MIA OCT 0.8>0.6[1.0]
AA GNV-MIA OCT 1.7>0.6[1.7]
AA GRB-ORD OCT 4>2[5]
AA GRR-ORD OCT 7>2[8]
AA GRR-PHL OCT 3>0.7[2]
AA GRR-PHX NOV 0.4>0.9[0]
AA GSO-LGA OCT 2>0[3]
AA GSO-MIA OCT 1.8>0.7[2]
AA GSO-ORD OCT 1.8>0.8[2.0]
AA GSO-PHL OCT 3>1.3[4]
AA GSP-MIA OCT 1.6>0[2]
AA GSP-ORD OCT 3>0.9[1.7]
AA GSP-PHL OCT 3>0.7[3]
AA GUA-MIA OCT 2>1.4[2]
AA GYE-MIA OCT 1.1>1.6[2]
AA HAV-MIA SEP 1.0>0[6] OCT 5>1.2[6]
AA HMO-PHX OCT 1.0>0.7[1.0]
AA HNL-LAX OCT 4>1.8[4]
AA HPN-ORD OCT 2>0[3]
AA HSV-ORD OCT 1.6>0[1.5]
AA IAD-LAX OCT 1.6>0[0.8]
AA IAH-LAX OCT 2>0[2.0]
AA IAH-MIA OCT 5>1.6[5]
AA IAH-ORD OCT 3>1.2[3]
AA IAH-PHL OCT 3>0.7[2]
AA IAH-PHX OCT 4>1.9[4]
AA ICT-ORD OCT 3>1.2[3]
AA ILM-LGA OCT 2>0[3]
AA ILM-PHL OCT 3>1.3[3]
AA IND-JFK OCT 0.8>0[1.0]
AA IND-LAX OCT 0.8>0[1.0]
AA IND-LGA OCT 1.6>0[2]
AA IND-MIA OCT 3>1.5[3]
AA IND-ORD OCT 7>3[8]
AA IND-PHL OCT 5>1.4[5]
AA ISP-PHL OCT 2>1.1[3]
AA JAX-MIA OCT 5>0.7[5]
AA JAX-ORD OCT 1.5>0[2]
AA JAX-PHL OCT 3>1.4[3]
AA JFK-LAS OCT 1.6>0[1.0]
AA JFK-LAX OCT 10>5[11]
AA JFK-MBJ OCT 0.6>0[0]
AA JFK-MIA OCT 7>2.0[7]
AA JFK-ORD OCT 3>0[3]
AA JFK-ORF OCT 1.6>0[3]
AA JFK-PHL OCT 4>0[0]
AA JFK-PHX OCT 5>3[5]
AA JFK-PIT OCT 3>0[1.0]
AA JFK-RDU OCT 3>0[2]
AA JFK-RIC OCT 2>0[0]
AA JFK-SAN OCT 0.8>0[0]
AA JFK-SAT OCT 0.8>0[1.0]
AA JFK-SFO OCT 4>1.3[5]
**AA JFK-SJD DEC 0>0.5[0] JAN 0>0.7[0] FEB 0>0.9[0] MAR 0>1.0[0]
AA JFK-YUL OCT 1.6>0[1.0]
AA JFK-YYZ OCT 1.6>0[2]
AA JLN-ORD OCT 1.6>0[1.9]
AA KIN-MIA OCT 3>2.0[3]
AA KOA-LAX OCT 1.0>0.2[1.0]
AA LAS-LAX OCT 6>3[7]
AA LAS-MIA OCT 3>1.5[1.0]
AA LAS-ORD OCT 4>2[5]
AA LAS-PHL OCT 3>1.5[3]
AA LAS-PHX OCT 5>3[6]
AA LAX-LIH OCT 1.8>1.0[1.7]
AA LAX-MCO OCT 2>0[1.9]
AA LAX-MEX OCT 0.8>0[1.0]
AA LAX-MIA OCT 8>4[7]
AA LAX-MSY OCT 1.6>0[0.8]
AA LAX-OGG OCT 2>1.0[3]
AA LAX-OKC OCT 1.6>0[2]
AA LAX-OMA OCT 1.6>0[2]
AA LAX-ORD OCT 8>5[10]
AA LAX-PDX OCT 2>0[3]
AA LAX-PHL OCT 6>3[6]
AA LAX-PHX OCT 8>7[6]
AA LAX-RDU OCT 0.8>0[1.0]
AA LAX-RNO OCT 4>0[4]
AA LAX-SAT OCT 2>0[3]
AA LAX-SFO OCT 7>2[7]
AA LAX-SJC OCT 5>0[5]
AA LAX-SLC OCT 3>1.0[3]
AA LAX-SMF OCT 3>0[4]
AA LAX-STL OCT 1.6>0[1.5]
AA LAX-STS OCT 0.8>0[1.0]
AA LAX-TUL OCT 0.8>0[1.0]
AA LAX-TUS OCT 2>0[3]
AA LAX-XNA OCT 1.6>0[1.9]
AA LBB-PHX OCT 0.8>0[0.9]
AA LEX-ORD OCT 3>1.0[3]
AA LEX-PHL OCT 3>1.3[3]
AA LGA-MCO OCT 1.6>0[1.0]
AA LGA-MEM OCT 1.5>0[1.7]
AA LGA-MIA OCT 10>2[12] NOV 12>11[10]
AA LGA-MSP OCT 2>0[1.9]
AA LGA-OKC OCT 0.8>0[0]
AA LGA-ORF OCT 3>0[4]
AA LGA-PHL OCT 3>0.0[4]
AA LGA-PIT OCT 5>0[6]
AA LGA-PWM OCT 1.6>0[1.0]
AA LGA-RDU OCT 5>0[7]
AA LGA-RIC OCT 2>0[4]
AA LGA-ROA OCT 0.8>0[1.0]
AA LGA-SDF OCT 1.4>0[1.7]
AA LGA-STL OCT 3>0[4]
AA LGA-XNA OCT 1.4>0[1.7]
AA LGA-YUL OCT 2>0[3]
AA LGA-YYZ OCT 3>0[4]
AA LGB-PHX OCT 3>2.0[3]
AA LIH-PHX OCT 0.8>0[0.9]
AA LIM-MIA OCT 1.8>0.8[2]
AA LIR-MIA OCT 1.2>0.7[1.0]
AA LIT-ORD OCT 2>0.9[3]
AA LSE-ORD OCT 3>2[3]
AA MCI-MIA OCT 1.6>0[2]
AA MCI-ORD OCT 6>2[7]
AA MCI-PHL OCT 2>0.7[2]
AA MCI-PHX OCT 1.8>1.0[1.0]
AA MCO-MIA OCT 10>2[7] NOV 12>11[6]
AA MCO-ORD OCT 4>1.6[4]
AA MCO-PHX OCT 3>1.0[1.9]
AA MDE-MIA OCT 1.5>0.6[1.0]
AA MDT-ORD OCT 4>1.5[4]
AA MDT-PHL OCT 5>1.4[6]
AA MEM-MIA OCT 1.8>0.7[2]
AA MEM-ORD OCT 4>1.2[5]
AA MEM-PHL OCT 2>0[2]
AA MEM-PHX OCT 1.8>1.0[2.0]
AA MEX-MIA OCT 3>1.4[4]
AA MEX-PHX OCT 0.8>0[1.0]
AA MGA-MIA OCT 1.6>0.6[1.0]
AA MHK-ORD OCT 2>0[3]
AA MHT-ORD OCT 1.9>1.2[2.0]
AA MHT-PHL OCT 5>1.4[6]
AA MIA-MID OCT 0.8>0.6[1.0]
AA MIA-MSP OCT 1.6>0[2]
AA MIA-MSY OCT 4>1.5[4]
AA MIA-MTY OCT 1.0>0.7[1.0]
AA MIA-NAS SEP 1.0>0.5[6] OCT 5>2[6]
AA MIA-OKC OCT 0.8>0[0]
AA MIA-ORD OCT 8>4[9]
AA MIA-ORF OCT 3>1.5[4]
AA MIA-PAP OCT 1.8>1.3[1.0]
AA MIA-PEI OCT 0.3>0[0.5]
AA MIA-PHL OCT 5>3[6]
AA MIA-PHX OCT 4>1.7[3]
AA MIA-PIT OCT 3>1.5[3]
AA MIA-PLS NOV 2>3[3] DEC 2>3[3] JAN 2>3[3]
AA MIA-PNS OCT 3>0.7[3]
AA MIA-POP OCT 1.0>0.7[1.0]
AA MIA-POS OCT 1.6>0.5[2]
AA MIA-PTY SEP 0.5>0[2] OCT 1.8>0.5[2]
AA MIA-PUJ OCT 1.8>0.7[1.0] NOV 2>1.4[1.0] DEC 2>1.5[1.5]
AA MIA-RDU OCT 4>1.4[4]
AA MIA-RIC OCT 1.8>0.7[1.7]
AA MIA-SAL OCT 1.0>1.3[1.0]
AA MIA-SAN OCT 0.8>0[1.0]
AA MIA-SAP OCT 0.9>0.6[1.0]
AA MIA-SAT OCT 0.8>0[1.0]
AA MIA-SAV OCT 2>0.7[2]
AA MIA-SDF OCT 1.8>0.7[2]
AA MIA-SDQ OCT 4>3[4]
AA MIA-SFO OCT 3>0.8[3]
AA MIA-SJU OCT 3.0>3.8[5]
AA MIA-SKB OCT 0.8>0.6[1.0]
AA MIA-STL OCT 1.6>0[3]
AA MIA-STX OCT 1.0>1.8[1.0]
AA MIA-SXM OCT 1.0>0.7[1.0]
AA MIA-TGU OCT 0.9>0.5[1.0]
AA MIA-TLH OCT 3>0.7[3]
AA MIA-TPA OCT 7>2[5]
AA MIA-TYS OCT 1.6>0[2]
AA MIA-UIO OCT 1.8>0.7[2]
AA MIA-UVF OCT 1.0>0.7[1.0]
AA MIA-XNA OCT 0.8>0[0]
AA MIA-YUL OCT 0.8>0[1.0]
AA MIA-YYZ OCT 2>0[3]
AA MKE-ORD OCT 4>2[4]
AA MKE-PHL OCT 4>1.4[3]
AA MKE-PHX OCT 1.8>1.0[1.9]
AA MLI-ORD OCT 3>1.4[4]
AA MQT-ORD OCT 1.0>0.7[1.0]
AA MSN-ORD OCT 5>1.8[6]
AA MSN-PHL OCT 1.6>0[1.5]
AA MSN-PHX NOV 0.4>1.8[0.3] DEC 1.0>2[0.5] JAN 1.0>2[1.0] FEB 1.0>2[1.0] MAR 1.0>2.0[1.0]
AA MSP-ORD OCT 6>2[6]
AA MSP-PHL OCT 3>1.4[3]
AA MSP-PHX OCT 4>2.0[3]
AA MSY-PHL OCT 3>0.7[3]
AA MSY-PHX NOV 0.4>0.9[0]
AA MYR-PHL OCT 3>1.3[1.6]
AA NAS-PHL OCT 0.6>0[0.6]
AA OKC-ORD OCT 3>1.2[3]
AA OKC-PHX OCT 1.8>1.0[1.9]
AA OMA-ORD OCT 5>2[5]
AA OMA-PHL OCT 1.4>0[1.0]
AA ONT-PHX OCT 4>3[5]
AA ORD-ORF OCT 3>1.2[2]
AA ORD-PBI OCT 0.8>0.3[1.6]
AA ORD-PDX OCT 1.8>1.1[1.8]
AA ORD-PHL OCT 11>5[9]
AA ORD-PHX OCT 8>4[9]
AA ORD-PIA OCT 3>1.6[3]
AA ORD-PIT OCT 5>2[6]
AA ORD-PSP OCT 1.0>0.3[1.3]
AA ORD-PVD OCT 3>1.2[3]
AA ORD-PWM OCT 1.9>1.3[1.8]
AA ORD-RAP OCT 0.8>1.0[1.0]
AA ORD-RDU OCT 5>2[5]
AA ORD-RIC OCT 4>1.4[4]
AA ORD-RNO OCT 1.7>1.0[1.2]
AA ORD-ROC OCT 4>1.0[4]
AA ORD-RST OCT 3>1.2[4]
AA ORD-RSW OCT 1.8>1.0[1.9]
AA ORD-SAN OCT 4>1.8[4]
AA ORD-SAT OCT 2>0[1.9]
AA ORD-SDF OCT 4>1.1[5]
AA ORD-SFO OCT 5>1.8[5]
AA ORD-SGF OCT 4>2[5]
AA ORD-SJC OCT 2>0[1.8]
AA ORD-SLC OCT 3>1.9[3]
AA ORD-SMF OCT 0.8>0[1.0]
AA ORD-SNA OCT 4>1.1[4]
AA ORD-STL OCT 5>2[5]
AA ORD-SUX OCT 1.7>1.1[3]
AA ORD-SYR OCT 4>2[4]
AA ORD-TOL OCT 2>0.8[3]
AA ORD-TPA OCT 3>1.5[2.0]
AA ORD-TUL OCT 3>1.0[3]
AA ORD-TUS OCT 1.7>0.7[1.9]
AA ORD-TVC OCT 6>2[5]
AA ORD-TYS OCT 3>1.7[3]
AA ORD-XNA OCT 5>1.2[6]
AA ORD-YUL OCT 1.6>0[2.0]
AA ORD-YYC OCT 0.8>0[1.0]
AA ORD-YYZ OCT 4>0.8[5]
AA ORF-PHL OCT 5>1.4[6]
AA PBI-PHL OCT 4>3[3]
AA PDX-PHX OCT 4>2.0[3]
AA PHF-PHL OCT 2>1.3[3]
AA PHL-PHX OCT 7>3[7]
AA PHL-PIT OCT 5>1.4[6]
AA PHL-PNS OCT 0.9>0.7[1.0]
AA PHL-PUJ OCT 0>0.8[1.1] NOV 0>0.9[1.1] DEC 0.1>0.9[1.1]
AA PHL-PVD OCT 4>1.4[5]
AA PHL-PWM OCT 5>1.4[4]
AA PHL-RDU OCT 6>1.4[6]
AA PHL-RIC OCT 6>1.4[6]
AA PHL-ROA OCT 1.6>0.7[1.6]
AA PHL-ROC OCT 5>1.4[5]
AA PHL-RSW OCT 4>2[3]
AA PHL-SAN OCT 3>0.7[2]
AA PHL-SAV OCT 3>1.3[3]
AA PHL-SBY OCT 3>1.4[4]
AA PHL-SCE OCT 4>1.4[4]
AA PHL-SDF OCT 3>1.3[3]
AA PHL-SFO OCT 4>0.7[4]
AA PHL-SJU OCT 0.9>1.7[1.0]
AA PHL-SRQ OCT 0.8>0[0.3]
AA PHL-STL OCT 4>1.4[5]
AA PHL-SWF OCT 3>1.4[4]
AA PHL-SYR OCT 4>1.4[5]
AA PHL-TPA OCT 5>4[5]
AA PHL-TYS OCT 3>1.3[3]
AA PHL-YUL OCT 4>0.7[4]
AA PHL-YYZ OCT 4>1.3[5]
AA PHX-PSP OCT 5>3[5]
AA PHX-RDU OCT 0.8>0[1.0]
AA PHX-RNO OCT 4>3[5]
AA PHX-ROW OCT 0.8>0[1.0]
AA PHX-SAF OCT 0.8>0[1.8]
AA PHX-SAN OCT 5>3[5]
AA PHX-SAT OCT 4>2.0[4]
AA PHX-SBA OCT 4>3[4]
AA PHX-SBP OCT 4>3[4]
AA PHX-SFO OCT 4>2.0[4]
AA PHX-SJC OCT 4>1.9[5]
AA PHX-SLC OCT 4>3[4]
AA PHX-SMF OCT 5>3[5]
AA PHX-SNA OCT 4>2[5]
**AA PHX-TUL NOV 0>0.9[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0]
AA PHX-TUS OCT 6>4[7]
AA PHX-YUM OCT 4>2.0[5]
**AA PHX-YYC NOV 0>0.9[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0]
AA PIT-RDU OCT 0.8>0[1.0]
AS AUS-SEA OCT 2>3[2] NOV 2>3[2.0]
AS BOS-SEA OCT 2>3[3] NOV 2>3[2] DEC 2>3[2] JAN 2>3[1.8] FEB 2>3[1.9] MAR 2>3[2] APR 2>3[1.3]
**AS JAC-SAN DEC 0>0.4[0] JAN 0>0.6[0] FEB 0>0.6[0] MAR 0>0.7[0] APR 0>0.3[0]
**AS JAC-SEA DEC 0>0.4[0] JAN 0>0.6[0] FEB 0>0.6[0] MAR 0>0.7[0] APR 0>0.3[0]
**AS JAC-SJC JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0]
AS MCO-SEA OCT 2>3[2] NOV 2>3[2] DEC 2>3[2] JAN 2>3[2]
AS ONT-SEA OCT 2>4[2] NOV 2>4[3] DEC 3>4[3] JAN 3>4[3] FEB 3>4[3] MAR 3>4[3] APR 3>4[3]
AS RDU-SEA OCT 1.0>1.9[1.0] NOV 1.4>2[1.0]
AS SEA-SJD OCT 0.8>1.3[0.6] NOV 1.4>2[1.3]
AV BOG-IAD SEP 0.6>0.3[1.0]
AV BOG-JFK SEP 1.0>0.6[3]
AV BOG-MIA SEP 2>1.1[4]
AZ BOS-FCO SEP 0.3>0.1[1.0] OCT 0.4>0.2[0.9]
October Gutted
B6 ABQ-JFK OCT 1.0>0.4[0.9]
B6 ACK-DCA OCT 0.3>0[0.1]
B6 ACK-JFK OCT 0.7>0.4[0.8]
B6 ALB-FLL OCT 1.0>0.3[1.0]
B6 ALB-MCO OCT 1.0>0.3[1.0]
B6 ANU-JFK OCT 0.6>0.3[0.5]
B6 ATL-BOS OCT 4>1.0[4]
B6 ATL-FLL OCT 2>1.0[2]
B6 ATL-JFK OCT 4>2.0[2]
B6 ATL-MCO OCT 1.0>0.3[1.0]
B6 AUA-BOS OCT 1.6>0.8[1.6]
B6 AUA-FLL OCT 0.5>0.3[1.0]
B6 AUS-BOS OCT 3>0.6[1.8]
B6 AUS-EWR OCT 2>0.6[0]
B6 AUS-FLL OCT 1.0>0.5[1.0]
B6 AUS-JFK OCT 3>0.8[1.8]
B6 AUS-LAX OCT 0.8>0.5[0]
B6 AUS-MCO OCT 1.0>0.4[1.0]
B6 BDA-BOS OCT 0.8>0.3[1.0]
B6 BDL-FLL OCT 1.7>0.6[1.9]
B6 BDL-MCO OCT 3>0.9[2]
B6 BDL-SJU OCT 1.8>0.5[1.0]
B6 BDL-TPA OCT 1.0>0.5[1.0]
B6 BGI-JFK SEP 0.6>0.2[1.7] OCT 1.6>0.7[1.7]
B6 BNA-BOS OCT 2>0.6[3]
B6 BNA-FLL OCT 1.0>0.5[1.5]
B6 BNA-JFK OCT 1.9>0.6[0]
B6 BOG-FLL SEP 0.2>0[1.0] OCT 1.0>0.5[1.0]
B6 BOG-MCO OCT 0.8>0[0.8]
B6 BOS-BUF OCT 3>0.6[4]
B6 BOS-BUR OCT 1.0>0[0.7]
B6 BOS-BWI OCT 5>0[5] NOV 5>4[5]
B6 BOS-CHS OCT 2>1.0[2]
B6 BOS-CLE OCT 3>0.6[3]
B6 BOS-CLT OCT 4>0.6[3]
B6 BOS-CUN OCT 0.5>0.2[0.3]
B6 BOS-DCA OCT 15>2[13] NOV 15>12[13]
B6 BOS-DEN OCT 2>0.7[1.8]
B6 BOS-DFW OCT 3>0.6[1.8]
B6 BOS-DTW OCT 4>0.6[3]
B6 BOS-EWR OCT 6>0[6] NOV 6>5[5]
B6 BOS-FLL OCT 5>3[6]
B6 BOS-IAH OCT 1.0>0.6[0.2]
B6 BOS-JAX OCT 1.8>0.7[3]
B6 BOS-JFK OCT 6>2[6]
B6 BOS-LAS OCT 4>1.8[4]
B6 BOS-LAX OCT 5>4[4]
B6 BOS-LGA OCT 9>0[5] NOV 9>7[5]
B6 BOS-MBJ OCT 0.3>0[0.1]
B6 BOS-MCO OCT 7>1.8[7] NOV 7>6[8]
B6 BOS-MSP OCT 3>0.3[3]
B6 BOS-MSY OCT 2>0.5[2.0]
B6 BOS-ORD OCT 4>1.8[5]
B6 BOS-PBI OCT 4>2[4]
B6 BOS-PDX OCT 0.8>0[1.0]
B6 BOS-PHL OCT 7>0[7] NOV 7>6[7]
B6 BOS-PHX OCT 1.6>0.3[1.0]
B6 BOS-PIT OCT 5>1.0[6]
B6 BOS-PUJ OCT 0.2>0[0.1]
B6 BOS-RDU OCT 5>2[6]
B6 BOS-RIC OCT 4>0.7[4]
B6 BOS-ROC OCT 1.0>0.3[1.0]
B6 BOS-RSW OCT 3>2[3]
B6 BOS-SAN OCT 4>1.0[3]
B6 BOS-SAV OCT 1.8>0.5[1.6]
B6 BOS-SEA OCT 2.0>0.6[1.9]
B6 BOS-SFO OCT 6>3[6]
B6 BOS-SJC OCT 0.9>0[0.7]
B6 BOS-SLC OCT 0.8>0[0.6]
B6 BOS-SMF OCT 0.5>0[0]
B6 BOS-SRQ OCT 1.0>0.7[1.0]
B6 BOS-STI OCT 1.0>0.5[1.0]
B6 BOS-SYR OCT 1.0>0.3[1.0]
B6 BOS-TPA OCT 3>2[4]
B6 BTV-JFK OCT 3>0.5[3]
B6 BUF-FLL OCT 0.9>0.1[0.7]
B6 BUF-JFK OCT 5>1.2[6]
B6 BUF-LAX OCT 0.7>0.1[0.7]
B6 BUF-MCO OCT 1.0>0.5[1.0]
B6 BUR-JFK OCT 1.8>0[1.5]
B6 CHS-EWR OCT 1.0>0.7[0]
B6 CHS-FLL OCT 0.7>0.1[1.0]
B6 CHS-JFK OCT 2>0.6[2]
B6 CLE-FLL OCT 0.7>0.4[1.0]
B6 CLE-RSW OCT 1.0>0.3[0]
B6 CTG-FLL OCT 0.6>0[0.6]
B6 CTG-JFK OCT 0.7>0.2[0.4]
B6 CUN-FLL OCT 1.0>1.8[1.0]
B6 CUN-JFK OCT 3>2[1.8]
B6 CUN-MCO OCT 1.9>1.1[1.0]
B6 CUR-JFK OCT 0.3>0[0.3]
B6 DCA-FLL OCT 7>0.7[5] NOV 6>5[6]
B6 DCA-MCO OCT 4>0.7[4]
B6 DCA-PBI OCT 2>0.2[1.2]
B6 DCA-RSW OCT 1.0>0.5[1.2]
B6 DCA-SJU OCT 1.0>0.4[1.0]
B6 DCA-TPA OCT 1.0>0.6[0]
B6 DEN-JFK OCT 3>1.0[1.0]
B6 DFW-JFK OCT 2>0.6[0]
B6 DTW-JFK OCT 2>0.6[0]
B6 EWR-FLL OCT 4>3[4]
B6 EWR-JAX OCT 1.0>0.7[0]
B6 EWR-LAX OCT 4>3[0]
B6 EWR-MCO OCT 5>4[6]
B6 EWR-PBI OCT 2>1.1[2]
B6 EWR-PHX OCT 2>0.6[0]
B6 EWR-SAN OCT 1.0>0.6[0]
B6 EWR-SDQ OCT 1.0>1.4[1.0]
B6 EWR-SFO OCT 2>1.0[0]
B6 EWR-SRQ OCT 1.0>0.5[0]
B6 EWR-STI OCT 1.6>2[1.0]
B6 FLL-GCM OCT 0.5>0.1[0.7]
B6 FLL-GYE OCT 1.0>0.6[1.0]
B6 FLL-HAV OCT 3>1.9[3]
B6 FLL-HPN OCT 1.8>1.0[1.9]
B6 FLL-JAX OCT 4>0.4[3]
B6 FLL-JFK OCT 9>4[6]
B6 FLL-KIN OCT 1.8>1.0[2]
B6 FLL-LAS OCT 2.0>1.0[1.1]
B6 FLL-LGA OCT 2>0.7[4]
B6 FLL-LIM SEP 0.3>0[1.0] OCT 1.0>0.6[1.0]
B6 FLL-MBJ OCT 2.0>1.0[1.1]
B6 FLL-MDE SEP 0.2>0[1.0] OCT 1.0>0.4[0.9]
B6 FLL-MSY OCT 0.7>0.3[0.7]
B6 FLL-NAS OCT 3>1.0[4]
B6 FLL-ORD OCT 0.7>0.5[0.9]
B6 FLL-ORH OCT 1.0>0[1.0]
B6 FLL-PAP OCT 1.2>2[2]
B6 FLL-PDX OCT 0.3>0[0]
B6 FLL-PHL OCT 1.0>0.7[1.9]
B6 FLL-PHX OCT 0.7>0.5[1.0]
B6 FLL-POS OCT 0.6>0.1[0.5]
B6 FLL-PVD OCT 1.0>0.4[1.0]
B6 FLL-RDU OCT 1.6>0.7[1.7]
B6 FLL-RIC OCT 0.8>0.6[1.2]
B6 FLL-SAN OCT 0.6>0.4[0.5]
B6 FLL-SDQ OCT 1.0>0.7[1.2]
B6 FLL-SFO OCT 3>1.6[2]
B6 FLL-SJO OCT 0.7>0.4[1.0]
B6 FLL-SJU OCT 4>2.0[5]
B6 FLL-SLC OCT 0.8>0.4[0.7]
B6 FLL-SWF OCT 1.0>0[1.0]
B6 FLL-SXM OCT 0.5>0.2[1.0]
B6 FLL-UIO OCT 1.0>0.4[1.0]
B6 GND-JFK OCT 0.9>0.2[0.7]
B6 GYE-JFK OCT 1.0>0.6[0]
B6 HPN-MCO OCT 3>1.0[3]
B6 HPN-PBI OCT 3>1.2[4]
B6 HPN-RSW OCT 2>1.0[1.0]
B6 IAH-JFK OCT 2>0.7[0.2]
B6 JAX-JFK OCT 3>0.7[3]
B6 JFK-KIN OCT 3>1.1[3]
B6 JFK-LAS OCT 5>2[4]
B6 JFK-LAX OCT 11>5[11] NOV 11>10[12]
B6 JFK-MCO OCT 9>3[7]
B6 JFK-MSP OCT 2>0.6[0]
B6 JFK-MSY OCT 2>0.7[3]
B6 JFK-MVY OCT 0.7>0.3[0.5]
B6 JFK-NAS OCT 1.1>0.5[1.0]
B6 JFK-ONT OCT 1.0>0[0.7]
B6 JFK-ORD OCT 4>1.0[2]
B6 JFK-ORH OCT 0.4>0[1.0]
B6 JFK-PAP OCT 1.0>1.3[2]
B6 JFK-PBI OCT 5>2[4]
B6 JFK-PDX OCT 0.8>0.6[0.5]
B6 JFK-PHX OCT 2>0.8[1.0]
B6 JFK-PLS OCT 1.0>0.3[0.9]
B6 JFK-POP OCT 1.0>0.7[1.0]
B6 JFK-POS OCT 1.0>0.2[1.0]
B6 JFK-PSP OCT 0.5>0[0.4]
B6 JFK-RDU OCT 4>0.9[3]
B6 JFK-RNO OCT 0.5>0[0.5]
B6 JFK-ROC OCT 3>1.2[3]
B6 JFK-SAN OCT 2>0.6[3]
B6 JFK-SAV OCT 2>0.8[2]
B6 JFK-SDQ OCT 4>3[4]
B6 JFK-SEA OCT 2.0>0.5[1.8]
B6 JFK-SFO OCT 7>3[6]
B6 JFK-SJC OCT 1.0>0[0.8]
B6 JFK-SJO OCT 0.4>0.1[0]
B6 JFK-SJU OCT 5>2.7[4]
B6 JFK-SLC OCT 2>0.4[2]
B6 JFK-SMF OCT 2>0.3[1.0]
B6 JFK-SRQ OCT 1.0>0.5[1.0]
B6 JFK-STI OCT 5>4[5]
B6 JFK-SXM OCT 1.0>0.2[1.0]
B6 JFK-SYR OCT 2>0.6[2]
B6 JFK-TPA OCT 3>2[3]
B6 JFK-UVF OCT 1.0>0.2[1.0]
B6 LAS-LGB OCT 0.2>0[3]
B6 LAX-RNO OCT 0.8>0.5[0]
B6 LAX-SEA OCT 0.8>0.5[0]
B6 LAX-SLC OCT 1.6>0.8[0]
B6 LGA-MCO OCT 2>0.7[4]
B6 LGA-PBI OCT 2>1.0[3]
B6 LGA-RSW OCT 1.0>0.4[0]
B6 LGA-TPA OCT 2>0.4[0]
B6 MBJ-MCO OCT 1.9>0.2[1.0]
B6 MCO-NAS OCT 0.8>0[0.9]
B6 MCO-ORH OCT 1.0>0[1.0]
B6 MCO-PHL OCT 2>0.6[0]
B6 MCO-PVD OCT 1.0>0.4[1.9]
B6 MCO-RIC OCT 1.2>0.8[1.2]
B6 MCO-SDQ OCT 1.0>0.4[1.0]
B6 MCO-SFO OCT 1.0>0.2[0]
B6 MCO-SJO OCT 1.0>0.1[1.0]
B6 MCO-SLC OCT 0.7>0.4[0.7]
B6 MCO-SWF OCT 1.0>0[1.0]
B6 MCO-SYR OCT 1.0>0.5[1.0]
B6 ORD-PBI OCT 1.0>0.3[0]
B6 PBI-PHL OCT 2>0.6[0]
B6 PBI-PVD OCT 1.0>0.3[0.9]
B6 PHL-RSW OCT 1.0>0.6[0]
B6 PHL-TPA OCT 1.0>0.6[0]
B6 PVD-RSW OCT 1.0>0.6[0]
B6 PVD-TPA OCT 1.0>0.7[0]
B6 SJU-TPA OCT 1.0>0.6[1.2]
BW FLL-KIN SEP 1.0>0.7[1.0]
BW FLL-MBJ SEP 0.2>0[0]
BW FLL-POS SEP 0.7>0.5[0.8]
BW GEO-JFK SEP 1.1>0.9[1.4]
BW JFK-MBJ SEP 0.9>0.7[1.0]
BW JFK-POS SEP 3>1.9[3]
BW MIA-POS SEP 1.0>0.8[1.0]
CI HNL-TPE NOV 0.4>0[0.3] DEC 0.3>0[0.3]
CI JFK-TPE OCT 0.5>0.1[0.5]
CI LAX-TPE OCT 1.1>0.5[1.1]
CI ONT-TPE OCT 0.2>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0]
CI SFO-TPE OCT 1.0>0.3[1.0]
DE FRA-LAS OCT 0.3>0[0.6] NOV 0.3>0[0.4] DEC 0.3>0[0.5] JAN 0.3>0[0.4] FEB 0.3>0[0.4] MAR 0.3>0.0[0.5]
DE FRA-SEA OCT 0.4>0[0.6] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4] FEB 0.4>0[0.4] MAR 0.5>0.1[0.4]
DL ABE-ATL OCT 1.0>0.5[3]
DL ABE-DTW OCT 2>3[3]
DL ABQ-ATL OCT 1.0>0.7[3]
DL ABQ-LAX OCT 1.8>1.0[3]
DL ATL-BQK OCT 2>3[3]
**DL ATL-CTG DEC 0.4>0[0.4] JAN 0.2>0[0.5]
DL ATL-DSS SEP 0>0.4[0]
DL ATL-GGT DEC 0.2>0.5[1.0]
DL ATL-GTR OCT 2>3[4]
DL ATL-GUA SEP 0.5>0[1.0] DEC 1.0>1.4[1.4]
DL ATL-ICT OCT 3>2.0[3]
Looks like Jamaica, Bahamas, and Costa Rica flying came back
*DL ATL-KIN NOV 0.1>0.9[1.0] MAY 0>1.0[0.4] JUN 0>1.0[0.4]
*DL ATL-LIR NOV 0.1>0.9[1.0] APR 0>1.0[0.7] MAY 0>1.0[0.4] JUN 0>1.0[0.1]
DL ATL-LOS SEP 0.4>0[0.6]
*DL ATL-MBJ NOV 0.6>3[3] DEC 0.1>4[4] MAR 1.2>4[4] APR 2>4[3] MAY 2>4[1.0] JUN 2>4[0.9]
*DL ATL-NAS JAN 3>4[4] FEB 3>4[4] MAR 2>4[4] APR 2>4[4] MAY 2>4[0.5] JUN 2>4[0.9]
DL ATL-PTY SEP 0.2>0[1.0] OCT 0.6>0.3[1.0]
DL ATL-PUJ NOV 0.2>1.1[1.2] DEC 0.4>1.5[1.4] JAN 1.0>2[2] FEB 1.0>2[2] MAR 0.4>2[2] MAY 0>2[1.0] JUN 0>2[0.4]
DL ATL-PVR DEC 0.6>0.4[0.6]
**DL ATL-RNO APR 1.0>0[0.5] MAY 1.0>0[0] JUN 1.0>0[0]
DL ATL-SJO NOV 0.1>1.2[2] APR 0>2[1.7] MAY 0>2[0.5] JUN 0>2[0.2]
DL ATL-SJU MAR 3.0>3.7[3.9] APR 3.0>3.7[3.8] MAY 3.0>3.7[1.4] JUN 3.0>3.7[0.7]
DL ATL-UVF NOV 0.2>0.9[1.1] JAN 0>1.2[1.1] FEB 0>1.1[1.2] MAY 0>1.2[0.2] JUN 0>1.1[0.3]
DL AUS-BOS OCT 1.9>0[1.0] NOV 1.9>1.4[0.9]
DL BDL-DTW OCT 4>3[5]
DL BIS-MSP OCT 5>6[6]
Wasn't this added a week ago?
**DL BMI-DTW OCT 1.0>0[0] NOV 0.2>0[0]
DL BNA-SEA OCT 1.0>0.7[0.8]
DL BOI-LAX OCT 1.0>2[1.7]
DL BOS-CHS OCT 1.0>0.6[1.0] NOV 1.0>0.8[1.0]
DL BOS-CVG OCT 5>0.5[3] NOV 5>4[3]
DL BOS-LAS OCT 0.7>0.5[1.0]
DL BOS-LGA OCT 4>3[14]
DL BOS-RIC OCT 3>0.5[2] NOV 3>2[2]
DL BOS-SEA OCT 4>2.0[1.7]
**DL BZN-SEA APR 2>0[2] MAY 2>0[1.0] JUN 2>0[0]
DL CLE-LGA OCT 1.8>1.0[5]
DL CLT-LGA OCT 3>2.0[7]
DL CUN-DTW OCT 1.2>2[0.7]
DL CUN-MSP MAY 3>1.0[0] JUN 3>1.0[0]
DL CVG-DCA OCT 1.8>0.5[2]
DL CVG-EWR OCT 1.5>1.0[2]
DL CVG-LAS OCT 1.0>0.7[1.0]
DL DFW-JFK OCT 3>0[2] NOV 3>2[2]
DL DFW-LGA OCT 3>2[5]
DL DTW-FLL OCT 4>3[4]
DL DTW-GSP OCT 0.8>0.5[3]
*DL DTW-MBJ FEB 0>1.1[1.2] APR 0>1.0[0.9] MAY 0>1.0[0] JUN 0>1.0[0]
DL DTW-MCO OCT 6>4[6]
DL DTW-MSY OCT 3>0.7[3]
DL DTW-MYR OCT 0.7>0.5[0.8]
DL DTW-OMA OCT 2>1.5[3]
DL DTW-RIC OCT 2>1.0[4]
DL DTW-RSW OCT 3>1.7[3]
DL DTW-SAT OCT 1.0>2[3]
DL DTW-TPA OCT 3>1.7[4]
DL DTW-TVC OCT 4>3[5]
DL FLL-RDU OCT 1.0>0.7[1.0]
DL FLL-SLC OCT 1.0>0.6[1.0] NOV 1.0>0.8[0.9]
AM Replace?
**DL GDL-LAX OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0]
*DL HND-LAX SEP 0.4>0[1.0] OCT 0.5>0.1[1.0]
DL HNL-LAX SEP 2>1.3[4] OCT 3>2[3]
DL IDA-SLC OCT 3>4[4]
**DL IND-MEM OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>0.6[0]
*DL JFK-MBJ NOV 0.1>0.9[1.0] DEC 0>1.4[1.3] JAN 0>2.0[1.3] FEB 0>2[1.2] MAR 0>2[1.1] APR 0>1.0[1.1] MAY 0>1.0[0] JUN 0>1.0[0]
DL JFK-MSP OCT 4>3[4]
DL JFK-STI JAN 2>3[3] FEB 2>3[3] MAR 2>3[3] APR 2>3[3] MAY 2>3[1.0] JUN 2>3[0.7]
*DL JFK-STT NOV 0.2>0.9[0.3] DEC 0>0.5[0.7] JAN 0>1.0[0.9] FEB 0>1.0[0.9] MAY 0>1.0[0] JUN 0>1.0[0]
DL JFK-SYR OCT 3>1.0[3]
DL KOA-LAX OCT 0.7>0.5[0.8]
DL LAS-MSP OCT 6>5[6]
DL LAS-SEA OCT 5>4[5]
DL LAS-SLC APR 4>5[5] MAY 4>5[2] JUN 4>5[2]
DL LAX-LIH OCT 0.7>0[0.5]
DL LAX-MCO OCT 2>1.5[2]
DL LAX-OGG OCT 1.7>0.7[1.5]
DL LAX-RDU OCT 1.0>0.5[1.0] NOV 1.0>0.8[1.0]
DL LAX-SJD NOV 1.6>1.2[1.0]
*DL LAX-SJO DEC 0>0.5[1.0] APR 0>1.0[0.5] MAY 0>1.0[0.6] JUN 0>1.0[0]
DL LAX-SYD OCT 0.5>0.7[1.0]
DL LAX-TPA OCT 1.0>0.5[1.0] NOV 1.0>0.8[0.9]
DL LGA-STL OCT 2>0.9[5]
DL MCO-MSP OCT 4>3[3]
DL MCO-RDU OCT 1.0>0.7[3]
DL MCO-SLC OCT 2>1.5[3]
DL MIA-MSP OCT 1.0>0.7[1.7]
DL MSP-MSY OCT 0.7>0.5[1.3]
DL MSP-TPA OCT 0.7>1.0[1.8]
DL PVR-SLC JAN 0.7>1.0[0.7] FEB 0.7>1.0[0.7] APR 0.7>1.0[0.5] MAY 0.7>1.0[0] JUN 0.7>1.0[0]
DL RDU-SEA OCT 1.0>0.7[1.0]
DL RDU-TPA OCT 1.0>0.7[3]
DL SJD-SLC OCT 0.5>0[0.5]
DL SLC-TPA OCT 0.7>1.0[0.8]
DL SLC-WYS OCT 1.0>0.4[0.4] NOV 0.2>0[0]
EK ATH-EWR SEP 0.5>0[1.0]
EK JFK-MXP SEP 0.5>0[1.0]
F9 ABQ-DEN OCT 0.5>0.1[0.5]
F9 ALB-MCO OCT 0.3>0[0.4]
F9 ALB-RDU OCT 0.3>0[0.5]
F9 ATL-CVG OCT 0.7>0.1[0.5]
F9 ATL-EWR OCT 0.9>0[0]
F9 ATL-ISP OCT 0.5>0[0.5]
F9 ATL-LAS OCT 0.6>1.0[1.5]
F9 ATL-LGA OCT 1.0>0.7[1.0]
F9 ATL-MCO OCT 1.9>1.0[1.5]
F9 ATL-MIA OCT 1.9>0.6[0.5]
F9 ATL-RDU OCT 0.9>0[0]
F9 ATL-SLC OCT 0.5>0[0.5]
F9 ATL-TPA OCT 0.9>0[0.4]
F9 ATL-TTN OCT 0.9>0[1.0]
F9 AUS-LAS OCT 1.0>0.6[1.0]
F9 AUS-MCO OCT 0.9>0.3[0.5]
F9 AUS-MIA OCT 0.3>0[0]
F9 AUS-ORD OCT 0.4>0[0.5]
F9 AUS-SAN OCT 0.5>0[0.5]
F9 AUS-TPA OCT 0.5>0[0.5]
F9 BDL-RDU OCT 0.5>0[0.5]
F9 BNA-DEN OCT 1.0>0.6[1.0]
F9 BNA-LAS OCT 0.5>0.3[0.8]
F9 BNA-ORD OCT 0.4>0[0.3]
F9 BOS-MCO OCT 1.0>0.6[1.0]
F9 BOS-MIA OCT 0.9>0[0]
F9 BOS-PHL OCT 0.5>0[0]
F9 BOS-RSW OCT 0.3>0[0]
F9 BOS-TPA OCT 0.2>0[0]
F9 BUF-RDU OCT 0.3>0[0.0]
F9 BWI-MCO OCT 0.7>0.4[0.5]
F9 BWI-MIA OCT 0.7>0.3[0]
F9 CID-DEN OCT 0.3>0.5[0.7]
F9 CLE-LAS OCT 1.1>1.6[1.0]
F9 CLE-PHX OCT 0.6>1.0[0.6]
F9 CLE-RDU OCT 0.4>0[0.1]
F9 CLT-MCO OCT 0.9>0.3[0.5]
F9 CLT-TTN OCT 0.5>0[0.5]
F9 CMH-DEN OCT 0.3>0.6[0.5]
F9 CMH-MCO OCT 0.3>0[0.3]
F9 COS-LAS OCT 0.7>1.0[1.3]
F9 CUN-DEN OCT 0.9>0.2[0.5]
F9 CUN-EWR OCT 0.9>0[0]
F9 CVG-DFW OCT 0.7>0.0[0]
F9 CVG-MCO OCT 2.0>1.5[1.0]
F9 CVG-MIA OCT 0.5>0[0.4]
F9 CVG-RSW OCT 0.5>0.7[0.5]
F9 DEN-DTW OCT 0.5>0.9[1.0]
F9 DEN-ELP OCT 0.4>0.2[0.5]
F9 DEN-EWR OCT 1.0>0.6[0]
F9 DEN-HSV OCT 0.3>0[0.5]
F9 DEN-IND OCT 1.0>0.7[1.0]
F9 DEN-LAS OCT 3>4[4]
F9 DEN-MIA OCT 0.7>1.0[1.0]
F9 DEN-MSP OCT 1.1>2[2]
F9 DEN-ONT OCT 1.0>0.6[1.0]
F9 DEN-PDX OCT 1.9>1.1[2]
F9 DEN-PNS OCT 0.3>0.6[0.5]
F9 DEN-RSW OCT 0.3>0.7[0.5]
F9 DEN-SEA OCT 1.7>1.2[2]
F9 DEN-SMF OCT 1.0>0.6[0.5]
F9 DEN-SNA OCT 1.0>1.3[1.5]
F9 DEN-STL OCT 1.4>1.0[1.9]
F9 DEN-SYR OCT 0.3>0.0[0.5]
F9 DEN-TYS OCT 0.3>0.6[0.5]
F9 DFW-MIA OCT 0.3>0[0]
F9 DFW-PHL OCT 0.3>0[0.5]
F9 DTW-MIA OCT 0.4>0[0]
F9 DTW-TTN OCT 0.3>0[0.5]
F9 EWR-MCO OCT 1.9>0.6[0]
F9 EWR-MIA OCT 1.8>0.3[0]
F9 EWR-MYR OCT 0.2>0[0]
F9 EWR-ORD OCT 0.9>0[0]
F9 EWR-PBI OCT 0.3>0[0]
F9 EWR-RDU OCT 0.5>0[0]
F9 EWR-RSW OCT 0.2>0[0]
F9 EWR-SJU OCT 1.0>0.1[0]
F9 EWR-TPA OCT 0.9>0[0]
F9 IAH-MCO OCT 0.4>0[0.5]
F9 IAH-PHL OCT 0.3>0[0.6]
F9 ISP-MCO OCT 1.0>1.6[0.8]
F9 ISP-MIA OCT 0.9>0[0]
F9 ISP-RDU OCT 0.5>0[0.5]
F9 LAS-LAX OCT 0.8>1.6[1.0]
F9 LAS-MCO OCT 0.1>1.0[1.2]
F9 LAS-ONT OCT 0.6>0[0]
F9 LAS-PHX OCT 0.6>1.1[1.5]
F9 LAS-SAN OCT 0.8>1.2[0.8]
F9 LAS-SFO OCT 1.0>2.0[1.0]
F9 LAS-SJC OCT 1.0>0.6[1.0]
F9 LAS-SMF OCT 1.1>0.6[1.0]
F9 LAS-SNA OCT 1.0>0.6[0]
F9 LAX-MCO OCT 0.5>0.9[0]
F9 LGA-MCO OCT 0.9>0.2[0]
F9 LGA-MIA OCT 0.9>0[0]
F9 MCO-MSP OCT 0.4>0[1.0]
F9 MCO-MSY OCT 0.5>0.3[0.3]
F9 MCO-ONT OCT 0.6>0[1.0]
F9 MCO-ORD OCT 1.0>0.6[1.2]
F9 MCO-RDU OCT 0.9>0.5[0.9]
F9 MCO-SJU OCT 1.1>1.5[1.8]
F9 MIA-ORD OCT 0.6>0.2[0]
F9 MIA-PHL OCT 1.0>0.7[0.8]
F9 MIA-RDU OCT 0.9>0[0.4]
F9 MIA-SJU OCT 0.9>0.3[0]
F9 MIA-TTN OCT 0.4>0[0]
F9 MYR-TTN OCT 0.4>0[0.5]
F9 ORD-PHL OCT 0.5>0[0]
F9 ORD-RSW OCT 0.3>0[0]
F9 ORD-TPA OCT 0.2>0[0.5]
F9 ORD-TTN OCT 0.9>0[1.0]
F9 PHL-RDU OCT 0.9>0.6[0.5]
F9 PHL-TPA OCT 1.0>0.6[1.0]
F9 PHX-SFO OCT 0>0.3[0]
F9 PHX-SJC OCT 0.9>0.3[0]
F9 RDU-SYR OCT 0.4>0[0.4]
F9 RDU-TTN OCT 0.5>0[0.5]
F9 TPA-TTN OCT 0.5>0[0.5]
FI DEN-KEF OCT 0.7>0.2[0.9]
FI EWR-KEF OCT 0.9>0.2[1.0]
FI KEF-MCO OCT 0.9>0.6[1.0]
FI KEF-MSP OCT 0.7>0.2[0.8]
FI KEF-ORD OCT 0.8>0.2[1.0]
G3 FOR-MCO DEC 0>1.0[0]
G4 ABE-SAV OCT 0.3>0[0.3]
G4 ABE-SFB OCT 1.2>0.9[1.3]
G4 ABQ-AUS OCT 0.4>0[0.3]
G4 ALB-SFB OCT 0.3>0[0.3]
G4 AUS-DSM OCT 0.3>0[0]
G4 AUS-GRR OCT 0.3>0[0]
G4 AUS-IND OCT 0.3>0[0.3]
G4 AUS-LAS OCT 0.3>0[0.5]
G4 AUS-MEM OCT 0.3>0[0]
G4 AUS-TYS OCT 0.3>0[0]
G4 AVL-EWR OCT 0.6>0.3[0.7]
G4 AVL-FLL OCT 2>1.0[2]
G4 AVL-PIE OCT 1.9>0.9[1.6]
G4 AVL-SFB OCT 1.7>0.9[1.7]
G4 AZA-FAR OCT 0.9>0.6[0.9]
G4 AZA-GJT OCT 0.3>0[0.3]
G4 AZA-TVC OCT 0.3>0[0]
G4 BIS-LAS OCT 0.6>0.3[0.3]
G4 BLI-LAS OCT 1.6>0.9[2]
G4 BLI-LAX OCT 0.3>0[0.3]
G4 BLI-OAK OCT 0.4>0[0.4]
G4 BNA-MDT OCT 0.3>0[0.3]
G4 CVG-ORF OCT 0.3>0[0]
G4 CVG-PIE OCT 1.0>0.7[1.2]
G4 CVG-VPS OCT 1.4>1.0[0.9]
G4 DSM-LAS OCT 0.5>0.3[0.5]
G4 FAT-LAS OCT 1.7>0.9[1.7]
G4 FLL-PBG OCT 0.4>0[0.3]
G4 FLL-USA OCT 0.9>0.6[1.0]
G4 GRR-PIE OCT 0.9>0.6[0.7]
G4 GSO-SFB OCT 0.3>0[0.3]
G4 HTS-PGD OCT 0.3>0[0]
G4 IND-JAX OCT 0.3>0[0.3]
G4 IND-PGD OCT 0.9>0.6[0.9]
G4 JAX-ORF OCT 0.3>0[0.3]
G4 LAS-MEM OCT 0.8>0.6[0.5]
G4 LAS-MFE OCT 0.9>0.6[1.0]
G4 LAS-MFR OCT 0.6>0.3[0.3]
G4 LAS-OAK OCT 0.8>0.5[0.8]
G4 LAS-RNO OCT 1.3>0.6[1.0]
G4 LAS-SAT OCT 0.3>0[0.3]
G4 LAS-SCK OCT 1.7>0.9[1.7]
G4 LAX-MTJ JAN 0.3>0[0.3]
G4 LAX-TUL OCT 0.3>0[0.3]
G4 MEM-PBI OCT 0.3>0[0]
G4 MSY-SDF OCT 0.3>0[0.3]
G4 MYR-SWF OCT 0.3>0[0]
G4 PBI-TYS OCT 0.3>0[0]
G4 PBI-USA OCT 0.3>0[0]
G4 PGD-RIC OCT 0.2>0[0]
G4 PIE-RIC OCT 0.3>0[0.3]
G4 PIE-USA OCT 1.0>0.6[1.2]
G4 SAV-SWF OCT 0.3>0[0]
G4 SFB-TYS OCT 1.7>0.8[1.7]
G4 SFB-USA OCT 0.7>0.5[0.7]
G4 SHV-VPS OCT 0.3>0[0]
G4 SRQ-TYS OCT 0.3>0[0]
HA HNL-ITO SEP 10>5[14]
HA HNL-KOA SEP 9>5[19]
HA HNL-LIH SEP 9>5[18]
HA HNL-LNY SEP 3>2[5]
HA HNL-MKK SEP 4>3[3]
HA HNL-OGG SEP 12>6[27]
HA ITO-OGG SEP 1.0>0[2]
HA KOA-OGG SEP 1.0>0[3]
HA LIH-OGG SEP 1.0>0[3]
HU BOS-PEK SEP 0.8>0.5[1.0]
HU PEK-SEA SEP 0.8>0.5[1.0]
IB BCN-JFK SEP 0.3>0.1[0.4]
IB JFK-MAD SEP 0.8>0.6[2]
IB MAD-MIA SEP 0.8>0.6[2]
IB MAD-ORD OCT 0.5>0.2[1.0]
JQ HNL-MEL JUN 0>0.3[0]
JQ HNL-SYD JUN 0>0.4[0]
K3 CGA-KTB OCT 0.5>0.9[0.8] NOV 0.5>0.9[0.8] DEC 0.5>0.9[0] JAN 0.5>0.9[0] FEB 0.5>0.9[0] MAR 0.5>1.0[0.6] APR 0.5>0.9[0.5] MAY 0.5>0.9[0.5] JUN 0.5>0.9[0.5]
K3 CGA-KTN OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0] JAN 0.4>0[0] FEB 0.4>0[0] MAR 0.4>0[0.4] APR 0.4>0[0.4] MAY 0.4>0[0.4] JUN 0.4>0[0.4]
K3 KTB-KTN OCT 1.3>1.7[1.3] NOV 1.2>1.5[1.2] DEC 1.3>1.7[0.8] JAN 1.2>1.6[0.8] FEB 1.3>1.7[0.8] MAR 1.3>1.7[1.3] APR 1.3>1.7[1.3] MAY 1.3>1.7[1.2] JUN 1.3>1.7[1.3]
KQ JFK-NBO NOV 0.7>0.5[0.7] DEC 0.8>0.5[0.9] JAN 0.9>0.5[0.9] FEB 0.7>0.4[0.7] MAR 0.7>0.5[0.7]
LA BEL-MIA JAN 0.3>0[0.3] FEB 0.3>0[0.3] MAR 0.3>0.1[0.3]
LA BOS-GRU DEC 0>0.3[0.7]
LA FOR-MIA JAN 0.7>0[0.7] FEB 0.7>0[0.7] MAR 0.7>0.1[0.7]
LA GRU-MCO FEB 1.0>0.7[1.3] MAR 1.0>0.8[1.0]
LA GRU-MIA JAN 2>1.0[2] FEB 2>1.0[2] MAR 2>1.1[2]
LA JFK-LIM SEP 0.4>0[1.0]
LA JFK-SCL SEP 0>0.2[1.0]
LA LAX-LIM SEP 0.4>0[1.7] OCT 0.8>0.6[1.7] NOV 1.7>0.5[1.7] DEC 1.7>1.0[1.7] JAN 1.7>1.0[1.7] FEB 1.7>1.0[1.7] MAR 1.7>1.1[1.7]
LA LAX-SCL SEP 0>0.3[0.7] JAN 1.0>0.4[0.7] FEB 1.0>0.4[0.6] MAR 1.0>0.4[0.6]
LA LIM-MCO JAN 1.0>0.5[1.0] FEB 1.0>0.4[1.0] MAR 1.0>0.5[1.0]
LA LIM-MIA SEP 1.0>0.5[1.9] NOV 2>1.3[2] DEC 3>2.0[2] JAN 3>2[2] FEB 3>2[2] MAR 3>2[2]
LA MIA-SCL JAN 1.4>1.0[1.7] FEB 1.4>1.0[1.5] MAR 1.4>1.0[1.4]
**LV EWR-ORY SEP 1.0>0[0.7] OCT 0.9>0[0.7] NOV 0.7>0[0.6] DEC 0.8>0[0.6] JAN 0.5>0[0.4] FEB 0.4>0[0.6] MAR 0.4>0[0.5]
LY EWR-TLV SEP 1.4>0[1.2]
LY JFK-TLV SEP 3>0[2.0]
LY LAX-TLV SEP 0.7>0[0.6]
LY MIA-TLV SEP 0.5>0[0.4]
MU JFK-PVG OCT 2.0>0.6[1.9]
MU LAX-NKG OCT 0.5>0.1[0.5]
MU LAX-PVG OCT 2.0>0.4[1.8]
MU ORD-PVG OCT 0.9>0.2[0.7]
MU PVG-SFO OCT 1.0>0.2[1.0]
NK ATL-LAS SEP 0.8>1.0[2]
NK CUN-DFW SEP 0.3>0.5[0.8]
NK FLL-MGA SEP 1.0>0.7[1.0]
NK FLL-SJO SEP 1.0>0.7[2.0]
OB MIA-VVI SEP 0.5>0.3[0.6]
Q6 GUA-LAX SEP 0.4>0.2[0.4]
Q6 IAD-SAL SEP 0.6>0.2[0.6]
Q6 JFK-SAL SEP 0.4>0.2[0.4]
Q6 LAX-SAL SEP 0.6>0.2[0.6]
SQ FRA-JFK NOV 1.0>0[1.0]
SU MIA-SVO NOV 0.7>0.4[0.6] DEC 0.7>0.4[0.7] JAN 0.7>0.5[0.7] FEB 0.7>0.4[0.7] MAR 0.6>0.4[0.7]
SV IAD-RUH NOV 0.6>0.3[0.4] DEC 0.6>0.3[0.5] JAN 0.5>0.3[0.6] FEB 0.6>0.3[0.6]
SV JED-JFK NOV 0.6>0.3[0.6] DEC 0.6>0.3[0.5] JAN 0.5>0.3[0.6] FEB 0.6>0.3[0.6]
SV JED-LAX NOV 0.4>0[0.4] DEC 0.4>0[0.6] JAN 0.4>0[0.6] FEB 0.4>0[0.4] MAR 0.4>0.0[0.4]
SV JFK-RUH NOV 0.6>0.3[0.4] DEC 0.6>0.3[0.5] JAN 0.6>0.3[0.4] FEB 0.6>0.3[0.4]
SY BNA-LAX OCT 0.3>0[0] NOV 0.3>0[0]
SY BNA-MSN OCT 0.3>0[0]
SY BOS-MSP OCT 0.6>0[0]
SY BWI-MSP OCT 0.6>0.3[0]
SY DFW-MSP OCT 0.6>0.3[0.1]
SY EWR-MSP OCT 0.8>0[0.9]
SY HNL-LAX NOV 0.3>0[0]
SY LAS-MSP OCT 3>2.0[3]
SY LAX-MSP OCT 1.7>1.2[1.4]
SY MCO-MSP OCT 2>1.9[2]
SY MSN-SEA OCT 0.3>0[0]
SY MSP-ORD OCT 0.6>0[0.9]
SY MSP-PDX OCT 0.7>0.3[0.7]
SY MSP-PHX OCT 1.8>1.2[1.7]
SY MSP-RSW OCT 1.8>1.4[1.6]
SY MSP-SEA OCT 1.0>0.6[1.3]
SY MSP-SFO OCT 1.1>0.6[1.2]
TK ATL-IST OCT 0.7>0.5[0.7]
TK BOS-IST OCT 1.0>0.6[1.0]
TK EWR-IST OCT 0.7>0[0]
TK IAD-IST OCT 1.4>0.9[1.0]
TK IAH-IST OCT 1.0>0.5[1.0]
TK IST-JFK OCT 3>1.2[3]
TK IST-LAX OCT 1.5>0.9[1.0]
TK IST-MIA OCT 1.0>0.7[1.0]
TK IST-ORD OCT 1.3>1.0[1.0]
TK IST-SFO OCT 1.1>0.7[1.0]
TP EWR-LIS OCT 1.8>1.2[1.0]
TS FLL-YUL OCT 0.3>0[0.1]
UA AGU-IAH SEP 1.0>0[2]
UA BOM-EWR SEP 0.1>0.9[0.8]
UA CUN-EWR SEP 1.0>1.9[1.3]
UA DEL-EWR SEP 0>1.0[0.8]
UA DEN-KOA SEP 0.2>0[1.0]
UA DEN-LIH SEP 0.3>0[1.0]
UA DEN-OGG SEP 0.5>0[1.0]
UA EWR-GUA SEP 0.6>0.3[0.1] APR 0>1.0[0]
UA EWR-SAL SEP 0.4>0.1[0]
UA EWR-SJU APR 4>5[1.0] MAY 3.1>4[0.8] JUN 3.9>5[0]
UA GUA-IAH SEP 1.9>1.0[2]
UA HNL-IAH SEP 0.2>0[1.0]
UA HNL-LAX SEP 1.5>1.0[3]
UA HNL-ORD SEP 0.7>0.4[1.0]
UA IAH-LIR SEP 0.9>0.6[1.0]
UA IAH-PTY SEP 0.3>0.1[3]
UA IAH-SJO SEP 0.9>0.7[2]
UA IAH-STT SEP 0.5>0.1[0]
UA IAH-UIO SEP 1.0>0.6[1.0] OCT 1.0>0.5[1.0]
UA IAH-VER SEP 0.4>0[1.0]
UA ITO-LAX SEP 0.2>0[0.7]
UA KOA-LAX SEP 0.4>0[1.1]
UA KOA-SFO SEP 1.4>1.0[2]
UA LAX-LIH SEP 0.2>0[1.1]
UA LAX-OGG SEP 0.5>0[2]
UA LIH-SFO SEP 0.5>0[1.2]
UA OGG-SFO SEP 1.5>1.0[4]
UP FLL-FPO SEP 0.9>0.7[1.7] APR 1.3>0.3[1.0] MAY 1.3>1.7[0.7]
UP FLL-NAS APR 3>0.9[4] MAY 3>4[4] JUN 3>4[4]
UP MCO-NAS SEP 1.1>0.7[1.2] APR 1.4>0.3[1.6]
UP MHH-PBI SEP 0.8>0.3[0.9] MAY 0.3>0.9[0.9] JUN 0.3>0.8[0.9]
UP MIA-NAS SEP 2>1.7[3] APR 1.9>0.7[3] MAY 1.8>3[3] JUN 1.9>2[3]
VH MDE-MIA SEP 0.5>0.2[0.6]
WN ATL-PHL OCT 1.0>1.4[1.6]
WN ATL-RSW OCT 2>3[1.7]
WN ATL-STL OCT 1.7>2[4]
WN BHM-MCO OCT 1.0>1.4[1.8]
WN BNA-CMH OCT 1.0>1.4[3]
WN BNA-ECP OCT 2>3[2]
WN BNA-PNS OCT 1.2>1.6[2]
WN BUF-MDW OCT 1.2>1.6[3]
WN BWI-CHS OCT 1.9>3[3]
WN BWI-RSW OCT 3>4[3]
WN CHS-DAL OCT 1.0>1.4[1.0]
WN CHS-MDW OCT 1.0>1.4[2.0]
WN CLE-DEN OCT 1.0>1.4[1.7]
WN CLE-MCO DEC 0.1>0.5[0.4]
WN CLE-RSW DEC 0>0.5[0.1]
WN CMH-LAS OCT 1.2>1.6[2]
WN CMH-RSW NOV 1.4>2[3] DEC 1.6>2[3]
WN DAL-ECP OCT 1.2>1.6[1.0]
WN DAL-MEM OCT 1.0>1.4[3]
WN DAL-PNS OCT 1.2>1.6[1.0]
WN DEN-ICT OCT 1.0>1.4[0]
WN DEN-MEM OCT 1.0>1.4[1.0]
WN ECP-HOU OCT 1.2>1.6[1.0]
WN HOU-PNS OCT 1.2>1.6[1.0]
WN HOU-RSW DEC 0>0.5[0]
WN IAD-MCO DEC 0>0.5[0.1]
WN IND-RSW OCT 0.8>1.1[1.4] NOV 1.4>2[3] DEC 1.1>2[2]
WN IND-TPA OCT 1.8>2[2]
WN MCI-STL OCT 1.0>1.4[3]
WN MCO-MSY OCT 0.8>1.1[4]
WN MCO-PHX OCT 1.0>1.4[1.1]
WN MDW-OKC OCT 1.0>1.4[1.1]
WN MDW-SLC OCT 1.2>1.6[2]
WN MDW-TPA OCT 3>4[4]
WN MKE-PHX OCT 1.0>1.4[1.9]
WN MKE-RSW NOV 1.0>1.9[1.6] DEC 1.0>2[1.7]
WN MKE-TPA OCT 1.0>1.4[1.1]
WN PIT-RSW NOV 1.0>1.9[1.7] DEC 1.0>2[1.7]
WN RSW-STL OCT 1.2>1.6[1.0]
Y4 BJX-DFW SEP 0.3>0[0]
Y4 BJX-FAT SEP 0.4>0[0]
Y4 BJX-LAS SEP 0.4>0[0]
Y4 BJX-LAX SEP 0.7>0.4[0.6]
Y4 BJX-MDW SEP 0.7>0.3[0.7]
Y4 DFW-DGO SEP 0.3>0[0.4]
Y4 DFW-ZCL SEP 0.3>0[0]
**Y4 FAT-MEX APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0]
Y4 GDL-JFK SEP 0.6>0[0.6]
Y4 GDL-LAS SEP 1.1>0.7[1.0]
Y4 GDL-LAX SEP 4>3[4]
Y4 GDL-ONT SEP 1.0>0.4[1.0]
Y4 GDL-RNO SEP 0.6>0.3[0.4]
**Y4 IAH-MEX APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0]
Y4 LAS-MEX SEP 1.0>0.7[1.0]
Y4 LAX-MEX SEP 2>1.4[1.3]
Y4 LAX-MLM SEP 0.7>0.3[0.9]
Y4 LAX-OAX SEP 0.4>0.1[0.4]
Y4 LAX-ZCL SEP 0.7>0.4[0.7]
Y4 MCO-MEX SEP 0.4>0.1[0.9]
Y4 MDW-MLM SEP 1.3>1.0[1.0]
Y4 MDW-ZCL SEP 0.6>0.3[0.4]
Y4 MEX-MIA SEP 0.3>0[1.0]
**Y4 MEX-ONT APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0]
Y4 MEX-ORD SEP 1.1>0.8[1.0]
Y4 MEX-SAT SEP 1.0>0.4[1.0]
**Y4 MEX-SJC APR 0>0.4[0] MAY 0>0.4[0] JUN 0>0.4[0]
**Y4 MEX-SMF APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0]
Y4 ORD-QRO SEP 0.3>0[0.3]
Y4 PHX-PVR SEP 0.3>0[0.3]
Y4 SJC-ZCL SEP 0.3>0[0.3]
enilria
Re: OAG Changes 9/1/2020:AA Adds PHX-BIL/BIS/BNA/CVG/TUL/YYC,CLT-FSD,JFK-SJD;AS to JAC;DL Drops BZN-SEA,Reverses Carib C
Tue Sep 01, 2020 2:05 pm
I'm wondering what was up with the DL Carib cuts? Perhaps they filed an invalid equipment type? Are all those routes on the same type? Otherwise is it possible they really changed their minds? BMI-DTW was just added right? And is now gone. I guess things are changing that fast?
TropicalSky
Tue Sep 01, 2020 2:14 pm
NAS has been B739 for a few yrs now since the the MD80'S were being retired....don't know with type will be used now post COVID
chonetsao
Tue Sep 01, 2020 2:16 pm
Interesting this round AA only cut domestic flights. I wonder when the October international cuts will come in.
Ishrion
Tue Sep 01, 2020 2:20 pm
AA said it finalized its October schedule on August 29, so all those international flights (such as LHR-RDU/PHX/CLT/RDU, PHL-DUB/AMS, CLT-MUC) are still set to resume in late-October.
Sounds like they're optimistic for those U.S. airports to become approved gateways for European flights. If not, they'll likely make further changes closer to the resumption dates.
enilria
There are teams divided up in network planning at all the legacies. There used to be Atlantic, Pacific, Latin, and then domestic was usually divided up by hub or geography. I think with the layoffs a lot of those teams are now combined, but you can see which team completed a month in the schedule update because each team does an update separately unless they all happen to finish the same week.
PSU.DTW.SCE
Tue Sep 01, 2020 2:23 pm
The DL Carribean flying that was was showing as cut in last week's OAG thread and now back is flown with a mix of equipment types, depending on the route. Its mostly 738, 739, & 752, but its a variety of equipment types.
All the stuff still was loaded for sale, so it must've been some other mis-file reason.
OzarkD9S
Tue Sep 01, 2020 2:25 pm
Domestic cuts were pretty brutal overall. Almost couldn't finish the rest of the data. As for international, its pretty bare-bones as it is, not a whole lot left to cut is there?
Next up: STL DEN PSP DEN STL
usflyer msp
Tue Sep 01, 2020 2:46 pm
I think PHL got the worst. It looks like most flights are only operating a little more than 1x per day.
MIflyer12
Tue Sep 01, 2020 3:29 pm
It may have been reported here earlier but Bloomberg said that October capacity was down 55% y-o-y, even after the leisure adds. This should reflect that. 3Q down 60%; 2Q was down 76% in ASMs.
https://www.bloomberg.com/news/articles ... -15-cities
DaCubbyBearBar
Tue Sep 01, 2020 3:34 pm
The B6 and F9 reductions are painful to read...WOW
I am me and no one else...so my opinions are mine
chonetsao
Tue Sep 01, 2020 3:36 pm
For AA the confirmed international cut is until September. October cuts are not barebone yet. Still have rooms available for cut.
ericm2031
Tue Sep 01, 2020 3:51 pm
Although WN increased Florida from many places, the adds from CLE/MKE/CMH/IND/PIT may be reactions to UA's new p2p flying they announced
UWPAviation
Tue Sep 01, 2020 4:10 pm
WN always operates those routes from MKE. Now that fall is coming up WN adds those routes from MKE seasonally. Not a reaction to UA but standard WN adds for MKE.
CMHtraveler
Tue Sep 01, 2020 4:21 pm
The routes are year round at CMH but the frequency increases are nice to see after September’s brutal suspensions/reductions
holeham
TPA got spanked by AA in the MIA-TPA route going from 7 down to 2.
Miamiairport
Tue Sep 01, 2020 4:49 pm
I fly that route quite a bit to see family (I'm just not into 4.5 hours of Turnpike driving). Those flights tended to be packed with paxs going to South/Central America and the Caribbean. No surpise that route has been whacked. The last time I flew that route over July 4th weekend the return was on a 321, which was packed in both cabins
RDUDDJI
Tue Sep 01, 2020 5:00 pm
True, and you can add AA to that list this week. Sad to see.
Sometimes we don't realize the good times when we're in them
Dominion301
Tue Sep 01, 2020 5:03 pm
It's been 2 or 3 winters since AA's flown YYC-PHX, and of all the times to bring it back, they're doing it now. Interesting. I guess they're banking on both AC and WS not flying to PHX winter 2020-21. I checked equipment and it's on a Mesa CR9, so it's not a lot of extra capacity to bank on a few Alberta snowbirds making the trek down to their winter homes.
Also FWIW, now that AA have extended their schedule to late July 2021, they actually show YOW-PHL returning 2x daily on Piedmont ERJs as of 06APR21.
Brickell305
Tue Sep 01, 2020 5:09 pm
Per Crankfyflier, B6 went from planning to operate 37% of last year’s schedule in Sep to 28% of last year’s schedule. October is currently at 44% of last year’s schedule but that could obviously change.
MaverickM11
Tue Sep 01, 2020 5:37 pm
What is this? Cargo?
I don't take responsibility at all
777Mech
Tue Sep 01, 2020 6:46 pm
It's a route they've flown in the past, usually rotates with JFK.
jonair8
Tue Sep 01, 2020 7:26 pm
Thanks again for posting the quality content every week.
Big bold move by AS going to 4x daily. This hasn’t happened since before the 2008 recession. Back then it was 4x 734, with sometimes a mix of 73G and before that, the M80. Now it’s 1x 320 and 3x 739 instead of downgrading it all to E75s during the winter. With DL recently adding this market AS is eager to keep DL out of yet another one of their routes.
This route is always very sporadic even though it was seasonal. DL always changes when it would start, when it would end, and how often it would go each day or even each week. Not too surprised this one is going.
avi8
Tue Sep 01, 2020 7:44 pm
Indeed. GUA and SAL are opening up their airports this month. SJO already opened but they’re being very strict with who gets in.
avi8
ericm2031
Tue Sep 01, 2020 8:43 pm
I know they were flown before, but these are increases from what they were selling last week and increases from last year.
Midwestindy
Tue Sep 01, 2020 8:56 pm
The Southwest & Florida are carrying the domestic market right now, crazy to even see some yoy growth
Status for 2019/2020: AAdvantage Platinum, Delta Gold, Southwest A-List
panamair
Tue Sep 01, 2020 10:15 pm
This is actually the resumption of the ATL-LOS service in Sept. except the flight will have a “technical” intermediate stop in DSS. I believe this is because they are going to use the 763ER to LOS for now. Traditionally ATL-LOS has been served nonstop with the A332 but I am guessing they don’t want to have an oddball or two A332 flying around just for this service 3x weekly (just my guess). In any case ATL-DSS-LOS (DL248) has been loaded starting Sept 8 with the 763ER.
The DSS market continues to be served from JFK and is increasing to 3x weekly in Sept.
Chuska
Wed Sep 02, 2020 1:48 am
All the protesting A.netters did about AA dropping ROW in the "AA goes forward with suspending service to 15 small airports in October" thread paid off, ROW no longer on the hit list. Actually Roswell city officials get the credit for saving their service. SUX and JLN have also been sparred (JLN had no change in their schedule this go-around).
wedgetail737
Wed Sep 02, 2020 1:56 am
I'm not too surprised to see DL eliminate the SEA-BZN route. But I see DL is bringing back a couple of additional longer-haul, domestic routes like SEA-BNA and SEA-RDU.
I'm a little surprised that HU is bringing back SEA-PEK...but I thought there were flight restrictions between the US and PRC.
sldispatcher
Wed Sep 02, 2020 2:49 am
UAL should post October official between tonight and Thursday correct?
crownvic
Wed Sep 02, 2020 3:02 am
With the way AA is cutting PHL domestically, by the time the international flights resume, they'll be NOTHING to feed them!
Chuska
Wed Sep 02, 2020 10:12 am
These plus 9 others are set for suspension on Oct. 7.
Eniliria, can you try running the AA portion again? Its not showing the suspension of many of the 12 smaller cities plus the frequency of flights out of cities like ABQ are not agreeing with what was updated in AA.com on Aug. 29. Really appreciate it.
DaCubbyBearBar
Wed Sep 02, 2020 10:18 am
Yeah... BOS-RDU down to ZERO from four...OUCH .. Overall their domestic reductions I am reclassifying as BRUTAL!
graham697
Wed Sep 02, 2020 8:26 pm
DCA feels almost like its going back to being a spoke.
FSDan
Wed Sep 02, 2020 9:15 pm
You know that's not going to last long-term, though. As soon as D.C. travel starts picking back up, AA will protect their valuable DCA slots and re-add service. Given that DCA was one of their top 3 most profitable hubs pre-COVID, I don't see them pivoting away from it long term. It's not a connecting hub, though, so with O&D demand dropping due to COVID DCA took a bigger hit than the interior connecting hubs for the time being.
This is my signature until I think of a better one.
CIDFlyer
Wed Sep 02, 2020 9:53 pm
AA at ORD and PHL really takes a hit. Pretty clear AA wants to funnel Almost everything through CLT and DFW as AA has said before. Nice to see the PHX adds at least. And also nice to see FSD-CLT, it will capitalize on DL cutting FSD-ATL for southern and Florida flows.
PHLspecial
Thu Sep 03, 2020 3:48 am
ORD and PHL are quite expensive hubs if not running at capacity. Not surprised to see PHX and CLT with strong domestic positioning. Wouldn't be surprised to see PHL the last to grow since it would be still the experimental international routes hub.
graham697
Thu Sep 03, 2020 1:07 pm
Oh I know, I'm just a spolied hub flyer and not used connecting anymore. :)
N717TW
Thu Sep 03, 2020 1:10 pm
Is it me or is the Air-Shuttle finally dead after a good 60 year run? This feels like another situation where Covid-19 is going to push out a relic of another time and accelerate the pattern already in motion.
DL is running both legs in Oct with 3 weekday turns and AA has 2 to BOS and 4 to DCA. The competitive advantage the Shuttles had over the train (faster travel time and hourly schedules) was already diminished and they seemed to be on their last legs anyways. We are now looking at a full six+ months with them gone and who knows when/if the regular commuting pattern between the three cities will restart.
graham697
Thu Sep 03, 2020 3:55 pm
Yeah, I feel like the only shuttle that has a good chance of returning on a semi-hourly frequence will be BOS-DCA and the quasi-shuttle/slot squat LGA-ORD. Acela is just better and easier if people return to work in the city centers. I guess that is the other big variable.
enilria
Thu Sep 03, 2020 8:35 pm
I don't think AA has removed any of those cities from their schedules. Am I wrong? I thought they "zeroed them out" for new sales.
It doesn't work like that. I don't have access to the live database. As I just said, I don't think they are deleted. I think they are zeroed out which is interesting.
It's been edging toward death since the Acela.
Miamiairport
Fri Sep 04, 2020 1:26 pm
The Shuttles were introduced before the Security requirements that came with 9/11 and when Amtrak was running the MetroLiner train, which wasn't much of a step up over the Regional trains. From 1995 to 1997 I was working in NYC but going to grad school at the University of MD (long story) so I was up and down on the MetroLiner 2x a week. The only difference was that the MetroLiner has fewer stops and would not sell more tickets than actually seats. I remember at times Amtrak would be short of cars so would borrow trains from MARC (Maryland's commuter rail line).
B0pp0
Sat Sep 05, 2020 11:00 am
Hasn't BOS-RDU on AA technically not even launched? I wonder if it even will if we ever come out of all this.
Can we say at this point that BOS-RDU is devolving from a strong route with diverse traffic to being basically VFR? To believe we at one point would've had five airlines on that route had NK not pulled out after AA announced their return.
