enilria
OAG 9/8/2020:OH THE HUMANITY;AA+DAB-DFW/PHL;AM Cuts;DL+LAXSAL,Suspends PVG?;NK Exits IAG/PBG/GSO?;UA Suspends ITH/MHT
Tue Sep 08, 2020 2:15 pm
FAQ
SOURCE: OAG
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
2E HOM-KEB FEB 0.5>0[0.5]
2E HOM-SOV FEB 0.5>0[0.5]
2E KEB-PGM FEB 0.5>0[0.5]
2E PGM-SOV FEB 0.5>0[0.5]
3E FOD-STL OCT 3>2[3] NOV 3>2[2] JAN 3>2[3] FEB 3>2[3]
3M BHB-BOS OCT 0.9>0.7[0.9]
3M EYW-FLL OCT 1.1>0.9[1.1]
3M FLL-FPO NOV 1.0>0.7[3] DEC 1.0>0.7[0.8] JAN 1.0>0.7[0.4] FEB 1.0>0.6[1.1] MAR 1.0>0.5[0.7] APR 1.0>0.6[0.7] JUN 1.0>0.7[0.5]
3M FLL-GGT MAR 1.5>1.0[1.3]
3M FLL-GHB NOV 0.3>0[0.3] DEC 0.6>0.3[0.4] FEB 0.6>0.3[0.4] MAR 0.5>0.2[0.6] APR 0.6>0.3[0.7] JUN 0.6>0.3[0.3]
3M FLL-MCO OCT 0.6>1.0[0.6]
3M FLL-MHH NOV 0.9>0.5[2] DEC 0.8>0.5[0] FEB 0.9>0.3[0.8] MAR 0.8>0.2[0.7] APR 0.9>0.6[0.9] MAY 0.9>0.6[0.4] JUN 0.8>0.3[0.5]
**3M FLL-NAS NOV 0>0.3[0] DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0] APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0]
4B ABQ-CNM NOV 1.4>0.7[2]
4B ATL-GLH OCT 0.4>0[0.8] NOV 0.3>0[1.0]
4B ATL-MSL DEC 1.7>0.7[3] JAN 0.2>0[4]
4B BNA-GLH NOV 0.6>0[0]
4B BNA-MSL NOV 1.7>1.1[0] JAN 0.3>0[0]
4B BWI-JST OCT 1.7>0.8[1.7]
4B CDR-DEN NOV 1.3>0.7[2]
4B CEZ-DEN NOV 2>0.7[3]
4B CEZ-PHX NOV 0.7>0[1.0]
4B DEN-MCK NOV 1.7>0.8[2] DEC 1.7>1.1[1.6] JAN 0.3>0[2]
4B DFW-GLH NOV 1.3>0[2]
4B DFW-VCT OCT 1.7>0.4[1.5]
4B IAH-VCT OCT 2>1.5[1.5]
4B IWD-ORD OCT 1.8>1.3[1.8] NOV 1.8>1.2[0] DEC 1.8>1.1[0] JAN 0.2>0[0]
4B JST-PIT OCT 3>1.8[3]
4B LAX-MCE NOV 1.4>1.1[3]
4B MCE-SMF OCT 2>1.0[2] NOV 1.4>0.7[1.4]
4B PDT-PDX NOV 3>2[4] DEC 3>1.1[3] JAN 0.4>0[4]
4B PHX-SOW NOV 0.7>0.4[3]
7Q EWR-VRB OCT 0.3>0[0.3] NOV 0.3>0[0.3] DEC 0.3>0[0.3]
There have been ongoing issues with the TECNAM appearing correctly
9K ACK-BOS OCT 6>1.5[8]
9K ACK-EWB OCT 0.9>0[1.9] NOV 0.6>0[3] JAN 0.5>0[2] FEB 0.6>0[3] MAY 0.5>0[0.8] JUN 1.8>0.8[1.0]
9K ACK-HPN OCT 0.4>0[0.4] JUN 0.2>0[0.3]
9K ACK-HYA OCT 8>3[9] NOV 5>6[9]
9K ACK-MVY JUN 0.2>0[0.2]
9K AUG-BOS OCT 3>1.7[3]
9K BHB-BOS OCT 2>1.2[2]
9K BOS-HYA OCT 1.0>0.6[1.0]
9K BOS-LEB OCT 4>0.6[4] NOV 4>2[4] DEC 4>3[4] JAN 4>2[4] FEB 4>3[4] MAR 4>3[4] APR 4>3[4] MAY 4>2[4] JUN 4>2[5]
9K BOS-MVY OCT 4>0.3[6]
9K BOS-PVC OCT 3>0.3[3] JAN 2>1.6[3] MAY 2>1.6[0] JUN 5>3[4]
9K BOS-RKD OCT 3>1.7[3]
9K BOS-SLK OCT 3>1.7[3]
9K HPN-LEB OCT 2>0.3[2] NOV 2>0.9[2] DEC 2>1.5[1.9] JAN 2>0.8[2] FEB 2>0.9[2] MAR 2>1.5[1.9] APR 2>0.9[2] MAY 2>0.8[1.9] JUN 2>0.8[1.2]
9K HPN-MVY JUN 0.2>0[0.3]
9K HPN-PVC JUN 0.2>0[0]
9K HYA-MVY OCT 0.4>0[0.4]
9K IRK-STL OCT 3>0.6[3] NOV 3>2[3] DEC 3>2[3] JAN 3>2[3] FEB 3>2[3] MAR 3>2[3] APR 3>2[3] MAY 3>0[3] JUN 3>2[3]
9X ACK-EWB OCT 0.6>0[0.6]
9X ACK-HYA OCT 1.1>0[1.1]
9X ACK-OWD OCT 0.7>0[0.7]
9X ACK-PVD OCT 0.4>0[0.4]
9X AOO-BWI OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0.5[1.0]
9X AOO-PIT OCT 3>1.5[3] NOV 3>0.4[3] DEC 3>1.5[3]
9X BNA-MEM OCT 3>1.7[3] NOV 3>1.8[3] DEC 3>1.8[2]
9X BWI-DUJ OCT 2>0[2] NOV 2>0[2] DEC 2>1.0[1.9]
9X BWI-LNS OCT 1.8>0.9[1.8] NOV 1.9>0[1.9] DEC 1.9>0[1.8]
9X BWI-MGW OCT 2>0.9[2] NOV 2>0[2] DEC 2>0[1.9]
9X DFW-ELD OCT 1.7>1.3[1.7] NOV 1.7>1.3[1.8] DEC 1.7>1.3[1.7]
9X DFW-HOT OCT 3>1.8[3] NOV 3>1.8[3] DEC 3>1.8[2]
9X DFW-HRO OCT 1.7>1.0[1.7] NOV 1.7>1.0[1.6] DEC 1.7>1.0[1.5]
9X DSI-MEM OCT 0.3>0[0.3] NOV 0.3>0[0.4] DEC 0.3>0[0.3]
9X DSI-TPA OCT 0.3>0[0.3] NOV 0.3>0[0.4] DEC 0.3>0[0.5]
9X DUJ-PIT OCT 3>0[3] NOV 3>0[4] DEC 3>1.4[3]
9X EYW-PBI OCT 0.3>0[0.3] NOV 0.3>0[0.3] DEC 0.3>0[0.3]
9X HNL-LNY DEC 2>1.6[0]
9X HRO-MEM OCT 1.0>0.7[1.0] NOV 1.0>0.7[1.0] DEC 1.0>0.7[1.0]
9X HYA-OWD OCT 0.2>0[0.2]
9X LNS-PIT OCT 2>1.1[2] NOV 2>0[3] DEC 2>0[2]
9X MGW-PIT OCT 3>1.9[3] NOV 3>0.3[4] DEC 3>0.4[3]
9X PBI-TPA OCT 2>0[2] NOV 2>1.7[3] DEC 2>1.8[2]
AA ABE-ORD OCT 0.8>0[1.8] DEC 2>1.1[1.9] FEB 2>1.2[1.1] MAR 2>1.1[0.9]
AA ABI-DFW OCT 4>2[6] NOV 7>5[7] DEC 7>6[6] FEB 7>6[6] MAR 7>6[5]
AA ABQ-LAX NOV 3>1.6[3] DEC 3>1.9[3] MAR 3>2.0[3]
AA ABQ-ORD OCT 1.0>0.7[1.7]
AA ABQ-PHX NOV 4>3[4] DEC 4>3[4] FEB 4>3[5] MAR 4>2[4]
AA ACT-DFW OCT 3>1.3[5]
AA ALB-ORD MAR 3>1.8[3]
AA AMA-DFW OCT 5>3[7] NOV 8>7[7] DEC 8>7[6] MAR 8>7[6]
Are these because PHL has not gotten CBP arrival approval?
**AA AMS-DFW NOV 0>0.9[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>0.8[0]
**AA AMS-PHL OCT 0.3>0[0.3] NOV 1.0>0[1.0] DEC 1.0>0[0.8] JAN 1.0>0[0.9] FEB 1.0>0[0.8] MAR 1.0>0.2[0.7]
AA ART-PHL OCT 1.7>0.6[1.9]
AA ASE-DFW OCT 1.0>1.7[1.0] JAN 3>4[2]
AA ASE-ORD NOV 0>0.4[0.1] DEC 0.5>1.0[0]
AA ATL-ORD OCT 2>1.9[5]
**AA ATW-CLT NOV 0>0.9[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0]
AA ATW-ORD MAR 3>2[3]
AA AVP-ORD OCT 1.2>0.7[1.8] DEC 1.9>1.4[1.9]
AA AZO-ORD MAR 3>2[3]
AA BGR-ORD OCT 0.3>0.1[0.4]
AA BHM-DFW NOV 7>6[6] DEC 7>6[5] MAR 7>6[5]
AA BHM-ORD OCT 0.8>0.6[1.8]
AA BIS-DFW OCT 2.0>1.5[2]
AA BMI-ORD OCT 0.8>0.6[2] MAR 3>2[3]
AA BNA-MIA OCT 1.4>1.0[4]
AA BNA-ORD OCT 3>1.8[7] NOV 8>7[9] DEC 8>7[8] MAR 8>5[7]
AA BOG-DFW OCT 1.0>0.7[1.0]
AA BOG-MIA OCT 1.5>1.1[3]
AA BOS-DCA OCT 5>3[12] NOV 13>12[12] MAR 14>13[9]
AA BOS-JFK NOV 5>4[1.0] MAR 6>3[3]
AA BOS-MIA OCT 1.6>1.3[6]
AA BOS-PHL OCT 6>5[12] MAR 14>13[10]
AA BOS-ROC MAR 3>1.9[3]
AA BTR-DFW NOV 7>5[7] DEC 7>5[6] FEB 7>6[5] MAR 7>5[5]
AA BUF-ORD MAR 4>3[3]
AA BUF-PHL OCT 1.4>1.1[5]
AA BWI-JFK MAR 5>3[0.9]
AA BWI-ORD OCT 1.5>1.1[4] DEC 5>4[4] MAR 5>4[3]
AA BZN-ORD NOV 0>0.4[0.1] DEC 0.5>1.0[0]
AA CHS-ORD OCT 0.5>0.2[1.0]
AA CID-ORD OCT 2.0>1.4[5]
AA CLE-JFK MAR 1.7>0.6[0]
AA CLE-ORD OCT 2>1.5[6] NOV 6>5[7] MAR 7>4[5]
AA CLL-DFW OCT 3>1.6[4] NOV 4>1.5[4] DEC 4>1.1[4] FEB 4>3[4] MAR 4>3[3]
AA CLT-IAD OCT 4>3[6]
AA CLT-JFK OCT 3>2[5]
AA CMH-JFK MAR 1.9>1.1[0.9]
AA CMH-ORD NOV 8>7[9] MAR 8>7[8]
AA CMI-ORD OCT 0.5>0.3[4] MAR 5>4[4]
AA CRP-DFW OCT 5>3[7] NOV 8>7[8] DEC 8>6[7] FEB 8>7[7] MAR 8>6[6]
AA CVG-DFW OCT 4>3[5]
AA CVG-ORD NOV 7>6[8] MAR 7>6[6]
**AA DAB-DFW DEC 0>0.5[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0]
**AA DAB-PHL DEC 0>0.5[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0]
AA DAY-ORD OCT 1.1>0.7[4] NOV 5>3[5] DEC 4>2[5] FEB 4>3[4] MAR 4>3[3]
AA DAY-PHL OCT 1.4>1.0[3]
AA DBQ-ORD OCT 1.1>0.9[2]
AA DCA-EYW MAR 0.4>0.1[1.4]
AA DCA-JFK MAR 4>3[1.9]
AA DCA-RSW NOV 0.9>0.7[0]
AA DEN-LAX OCT 2.0>0.8[3] NOV 3>1.9[3] DEC 3>2[3]
**AA DFW-DUB NOV 0>0.9[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>0.8[0]
AA DFW-EGE OCT 0.6>0.3[1.0] FEB 2>3[3] MAR 2>3[2]
AA DFW-ELP OCT 6>5[8] NOV 9>7[9] DEC 9>7[8] MAR 9>8[8]
AA DFW-EVV OCT 2>1.4[2.0]
AA DFW-GGG OCT 2>0.9[3] NOV 3>1.9[3] DEC 3>2[2] FEB 3>2[3] MAR 3>2[2]
AA DFW-GPT OCT 2.0>1.6[3] NOV 3>0.9[3] DEC 3>1.0[2] FEB 3>1.7[3] MAR 3>0.4[2]
AA DFW-GRK OCT 5>4[7] NOV 7>5[7] DEC 7>5[6] FEB 7>6[7] MAR 7>6[6]
AA DFW-GSO DEC 3>2[3] MAR 3>2[1.8]
AA DFW-HOU OCT 4>3[8] NOV 8>7[8] DEC 9>7[6] FEB 9>8[8] MAR 9>6[7]
AA DFW-IAD OCT 1.9>1.1[3]
AA DFW-IAH OCT 6>4[9]
AA DFW-ICN OCT 1.0>0.6[1.0]
AA DFW-ICT MAR 6>5[6]
AA DFW-JAC OCT 1.2>1.7[2]
AA DFW-LBB OCT 5>4[7] NOV 8>6[7] DEC 8>6[6] FEB 8>7[7] MAR 8>6[6]
AA DFW-LIT NOV 9>8[9] DEC 9>7[8] MAR 9>8[7]
AA DFW-LRD OCT 2>1.5[4]
AA DFW-MAF NOV 8>6[8] DEC 8>6[7] FEB 8>7[7] MAR 8>5[6]
AA DFW-MEM OCT 6>5[8]
AA DFW-MFE OCT 5>4[7] NOV 8>6[8] DEC 8>7[7] FEB 8>7[7] MAR 8>6[6]
AA DFW-MSY OCT 6>5[8]
AA DFW-MTJ JAN 1.3>2[1.5]
AA DFW-OKC OCT 6>5[9] NOV 9>8[9] MAR 9>8[8]
AA DFW-PNS OCT 6>5[6] NOV 6>5[5] DEC 6>5[4] MAR 6>5[4]
AA DFW-ROW OCT 1.8>1.4[3]
AA DFW-SAV NOV 3>2[2] DEC 3>2[1.9] MAR 3>2[3]
AA DFW-SEA OCT 7>8[8]
AA DFW-SGF OCT 6>4[8] MAR 8>7[6]
AA DFW-SHV OCT 5>4[7]
AA DFW-SJT OCT 4>0.7[5] NOV 6>4[6] DEC 6>4[6] FEB 6>4[5] MAR 6>4[4]
AA DFW-SJU NOV 1.5>2.0[1.0]
AA DFW-SPS OCT 2>1.4[4]
AA DFW-TYR OCT 3>1.6[4]
AA DFW-XNA NOV 9>7[9] MAR 9>8[8]
AA DSM-ORD OCT 2>1.4[5] NOV 5>4[7] MAR 7>5[6]
AA DTW-MIA MAR 2>1.5[1.9]
AA DTW-ORD OCT 3>1.8[5] NOV 6>4[8] DEC 6>5[6] MAR 7>4[5]
**AA DUB-PHL OCT 0.3>0[0.3] NOV 1.0>0[1.0] DEC 1.0>0[0.9] JAN 1.0>0[0.9] FEB 1.0>0[1.0] MAR 1.0>0.2[0.8]
AA ELP-LAX MAR 3>2[3]
AA ELP-ORD OCT 1.1>0.4[1.8] MAR 2>1.6[1.8]
AA ELP-PHX OCT 3>1.7[4] NOV 5>3[5] DEC 5>3[5] FEB 5>4[5] MAR 5>3[5]
AA EVV-ORD DEC 2>1.5[1.9] MAR 2>1.5[1.9]
AA EWR-ORD OCT 2.0>1.5[5]
AA EYW-PHL OCT 0.9>0.5[0.9]
AA FAR-ORD OCT 1.3>0.2[3] NOV 3>1.5[3] DEC 3>2[2] MAR 3>2[3]
AA FNT-ORD OCT 1.2>0.9[3] MAR 3>2[3]
AA FSD-ORD OCT 2>0.8[3] NOV 3>2[3] DEC 3>2[3] MAR 3>2[1.8]
AA FSD-PHX NOV 1.0>1.9[0.9] DEC 1.0>2[0.9] JAN 1.0>2[1.3] FEB 1.0>2[1.0] MAR 1.0>2[0.8]
AA FWA-ORD OCT 1.2>0.8[3]
AA GGT-MIA NOV 1.0>1.9[1.0] DEC 1.5>2[1.0]
AA GRR-ORD OCT 2>1.8[7] MAR 7>5[5]
AA GSO-ORD OCT 0.8>0.5[1.8] MAR 2>1.0[1.7]
AA GYE-MIA NOV 1.0>1.9[2] DEC 1.5>2[1.9]
AA IAH-MIA OCT 1.6>1.1[5]
AA IAH-ORD OCT 1.2>0.9[3] NOV 3>2[4]
AA IND-ORD OCT 3>1.7[7] NOV 7>6[8] MAR 8>7[6]
AA JAC-ORD NOV 0>0.4[0.1] DEC 0.5>1.0[0]
AA JAX-MIA MAR 6>5[5]
AA JFK-LAX OCT 5>3[10] NOV 11>9[11] FEB 12>10[11] MAR 11>9[10]
AA JFK-MIA OCT 2.0>1.3[7]
AA JFK-PIT MAR 4>3[0.9]
AA JFK-RDU NOV 4>3[2] MAR 4>2.0[1.9]
AA JFK-SFO OCT 1.3>0.5[4] FEB 5>4[4] MAR 5>3[4]
AA JFK-YUL MAR 1.9>1.1[0.9]
AA JFK-YYZ MAR 1.7>0.9[0]
AA LAS-LAX OCT 3>1.2[6]
AA LAX-OKC NOV 1.8>1.4[2]
AA LAX-PDX NOV 3>1.7[3] DEC 3>1.8[3] MAR 3>2[3]
AA LAX-RNO NOV 5>3[4]
AA LAX-SEA OCT 4>2[4]
AA LAX-SFO OCT 2>0.7[7] NOV 7>6[7] MAR 8>6[7] MAY 8>7[5]
AA LAX-SJC NOV 5>4[5] DEC 6>4[5] MAR 6>4[5]
AA LAX-SLC NOV 4>2[3]
AA LAX-SMF NOV 4>2[4] MAR 4>2[4]
Interesting to see it reloaded for sale
**AA LAX-SYD NOV 0>0.4[1.0] DEC 0>0.6[1.0] JAN 0>0.6[1.0] FEB 0>0.6[1.1] MAR 0.2>0.6[0.9]
AA LAX-TUS DEC 3>2[3] MAR 3>2[3]
AA LEX-ORD OCT 1.0>0.8[3] DEC 3>2[3]
AA LGB-PHX OCT 2.0>1.1[3] NOV 3>2.0[3] DEC 3>2[3] FEB 3>2[3] MAR 3>1.6[3]
AA LIT-ORD OCT 0.9>0.6[2]
AA LSE-ORD OCT 2>1.5[3] DEC 3>2[3]
AA MCI-MIA MAR 2>1.4[2]
AA MCI-ORD MAR 7>6[5]
AA MCI-PHL OCT 0.7>0.5[2]
AA MDT-ORD OCT 1.5>0.9[4]
AA MDT-PHL OCT 1.4>1.0[5]
AA MEM-ORD OCT 1.2>0.5[4] NOV 4>2[5] DEC 5>3[4] FEB 5>3[3] MAR 5>2[3]
AA MIA-MSY OCT 1.5>1.0[4]
AA MIA-MVD NOV 0>0.3[0.7] JAN 1.0>0.3[1.0] FEB 1.0>0.3[1.1] MAR 1.0>0.4[0.9]
AA MIA-ORF OCT 1.5>1.0[3] MAR 3>2[3]
AA MIA-PEI NOV 0.4>0[0.5]
AA MIA-RDU OCT 1.4>1.1[4]
AA MIA-SAL NOV 1.0>1.9[1.0] DEC 1.5>2[1.0] JAN 1.2>2[1.0] FEB 1.0>2[1.1] MAR 1.0>2[0.9] APR 1.0>2[1.0] MAY 1.0>2[0]
AA MIA-STL MAR 3>2[3]
AA MIA-STX NOV 1.5>2.0[1.0] DEC 1.5>2.0[1.4]
AA MIA-TPA OCT 2>1.2[7] MAR 8>6[4]
AA MKE-ORD OCT 2>1.3[4]
AA MKE-PHL OCT 1.4>1.1[4]
AA MLI-ORD OCT 1.4>0.8[3] NOV 3>2[4] DEC 4>2[3] FEB 4>3[3] MAR 4>1.6[3]
AA MSN-ORD OCT 1.8>1.3[5]
AA MSN-PHL NOV 1.8>1.3[1.6] DEC 2>0.2[1.6] FEB 2>1.1[2] MAR 2>1.5[1.8]
AA MSP-ORD OCT 2>1.3[6]
AA MYR-PHL OCT 1.3>0.9[3]
AA MZT-PHX MAR 1.3>1.0[1.2]
AA OKC-ORD OCT 1.2>0.4[3] MAR 4>3[3]
AA OMA-ORD OCT 2>1.4[5] DEC 6>5[5] FEB 6>5[5] MAR 6>4[4]
AA ORD-PIA MAR 3>2[3]
AA ORD-PIT OCT 2>1.4[5] NOV 5>4[6] DEC 6>5[5]
AA ORD-PVD MAR 3>2[1.7]
AA ORD-RIC OCT 1.4>0.9[4]
AA ORD-SAV OCT 0.8>0.6[1.0]
AA ORD-SDF OCT 1.1>0.8[4]
AA ORD-SGF MAR 5>4[4]
AA ORD-SLC OCT 1.9>1.4[3]
Another flight moved from PHL
*AA ORD-SRQ NOV 0>0.9[0] DEC 0>1.0[0.3] JAN 0>1.0[0.5] FEB 0>1.0[1.1] MAR 0>1.0[0.9]
AA ORD-STL OCT 2>1.8[5]
AA ORD-SYR OCT 2>1.6[4] MAR 4>3[4]
AA ORD-TOL DEC 3>2[3] MAR 3>2[3]
AA ORD-TUL OCT 1.0>0.6[3] NOV 3>2[3] DEC 3>1.6[3] FEB 2>1.5[3] MAR 2>1.6[2]
AA ORD-TVC OCT 2>1.6[6]
AA ORD-TYS OCT 1.7>1.2[3]
AA PHF-PHL OCT 1.3>1.0[2]
AA PHL-PVD OCT 1.4>1.1[4] DEC 5>4[4]
AA PHL-PWM OCT 1.4>0.8[5]
AA PHL-ROA OCT 0.7>0.4[1.6]
AA PHL-ROC OCT 1.4>1.0[5]
AA PHL-SAV OCT 1.3>1.0[3]
AA PHL-SBY OCT 1.4>1.1[3]
AA PHL-SCE OCT 1.4>1.1[4]
AA PHL-SJU NOV 1.1>2.0[1.0] DEC 1.5>2.0[1.0]
*AA PHL-SLC DEC 0>0.4[0.0] JAN 0>0.7[0.4] FEB 0>0.7[0.2] MAR 0>0.7[0]
*AA PHL-SRQ NOV 0.9>0.3[0.3] DEC 1.0>0.1[0.2] FEB 1.0>0.5[1.1] MAR 1.0>0.5[1.0]
AA PHL-SWF OCT 1.4>1.1[3]
AA PHL-TYS OCT 1.3>1.0[3] DEC 3>2[3]
AA PHX-TUS MAR 6>5[6]
AC EWR-YVR OCT 1.4>1.0[1.4]
AF JFK-ORY OCT 0.7>0.2[0.7]
AF MIA-PAP OCT 0.5>0.1[0.5]
AI DEL-EWR OCT 0>0.4[0]
AJ ELH-FXE OCT 0.3>0[0.3] NOV 0.3>0[0.3] DEC 0.3>0[0.3]
AJ FXE-GHB OCT 0.6>0[0.6] NOV 0.6>0[0.6] DEC 0.5>0[0.6]
AJ FXE-TCB OCT 0.4>0[0.4] NOV 0.4>0[0] DEC 0.4>0[0]
**AM BJX-DTW OCT 0.8>0[0.8] NOV 0.9>0[0.9] DEC 0.9>0[0.7] JAN 0.9>0[0.9] FEB 0.9>0[1.0] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 1.0>0[0] JUN 1.0>0[0]
**AM DFW-MEX OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0] FEB 1.0>0[1.1] MAR 1.0>0[0.9] APR 1.0>0[1.0] MAY 1.0>0[0.7] JUN 1.0>0[0]
AM DTW-MTY OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[0.9] JAN 1.0>0.7[0.8]
**AM DTW-QRO OCT 0.8>0[0.8] NOV 0.9>0[0.9] DEC 0.9>0[0.7] JAN 0.9>0[0.9] FEB 0.9>0[1.0] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 1.0>0[0] JUN 1.0>0[0]
AM GDL-ORD DEC 1.0>1.3[1.0] JAN 0.6>1.3[1.6]
AM GDL-SFO DEC 1.0>0.7[0.9]
AM GDL-SLC OCT 1.0>0[1.0] NOV 1.0>0.8[1.0]
AM GDL-SMF DEC 1.0>1.3[1.0] JAN 0.6>1.3[1.4]
AM IAH-MEX OCT 3>1.0[3] NOV 3>1.0[3] DEC 3>1.5[3]
AM JFK-MEX DEC 0>0.5[2.0] JAN 0>0.3[3]
Moved to DL with LAX
*AM JFK-MTY OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0.7[1.0]
AM LAS-MEX OCT 1.0>0.3[1.0] NOV 1.0>0.3[1.0] DEC 1.0>0.6[1.1]
*AM LAS-MTY OCT 0.3>0[0.3] NOV 0.3>0[0.3] DEC 0.3>0[0.3]
AM LAX-MEX DEC 0>0.5[1.0] JAN 0>0.3[1.6]
*AM LAX-MTY OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0.5[0.9]
AM MCO-MEX OCT 1.3>0.6[1.3] NOV 1.3>0.6[1.1] DEC 1.3>1.5[1.2]
AM MEX-MIA OCT 3>1.4[3] NOV 3>1.4[2] DEC 3>1.7[2.0] JAN 3>2[3]
AM MEX-ORD NOV 1.0>1.3[1.3] DEC 1.0>1.8[1.0] JAN 1.0>1.4[2]
AM MEX-SAT OCT 1.0>1.3[1.0] NOV 1.0>1.3[1.0] DEC 1.0>1.7[1.2] JAN 1.0>1.3[1.5]
*AM MEX-SEA OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0.7[1.0]
AM MEX-SFO OCT 2.0>0.7[2.0] NOV 2>0.7[2] DEC 2>1.5[2]
AN ABQ-SVC OCT 2>0[2]
AN HHR-PHX OCT 0.4>0[0.4]
AN PHX-SVC OCT 1.0>0[1.0]
AS ANC-SCC OCT 3>1.5[3] NOV 3>1.4[3] DEC 3>1.3[2] JAN 2>1.3[2] FEB 3>1.3[3] MAR 3>1.4[2] APR 3>1.4[3] MAY 2>1.3[2] JUN 3>1.4[1.9]
AS BOS-PDX OCT 0.9>0[0.9] NOV 1.4>0.7[2]
AS DFW-SEA OCT 4>3[4]
AS FLL-SFO DEC 0.5>1.0[0.3]
AS HDN-SAN APR 0.4>0.2[0.4] MAY 0.5>0[0] JUN 0.4>0[0]
AS HDN-SEA APR 0.4>0.2[0.4] MAY 0.5>0[0] JUN 0.4>0[0]
AS IAD-SEA OCT 1.7>1.1[1.7] NOV 2>1.7[1.9]
AS MCO-SFO OCT 0.9>0[0.9] NOV 1.0>0.4[1.0]
AS MSP-PDX OCT 0.9>0[0.9] NOV 1.0>0.4[1.0]
AS PDX-PHX OCT 3>2.0[3] NOV 3>2[2]
AS PDX-PSP DEC 1.6>2[1.9]
AS PHL-SEA OCT 1.9>1.0[1.9] NOV 2>1.4[2]
AS PVR-SEA DEC 0.9>1.1[1.1]
AS RNO-SEA OCT 3>4[3]
AS SBA-SEA NOV 1.0>1.4[1.0] DEC 1.0>2[1.0]
AS SEA-TUS OCT 1.9>3[1.9] NOV 2>3[1.1]
B5 MDR-WIL OCT 0>2[0] NOV 0>2[0] DEC 0>2[0] JAN 0>2[0] MAR 0>2[0] APR 0>2[0] MAY 0>2[0]
B6 BOS-SDQ OCT 0.9>1.1[1.0]
BW JFK-KIN OCT 1.0>2.0[1.0]
CX HKG-LAX OCT 2>1.5[2]
CZ CAN-LAX NOV 0.8>1.0[0.9]
DL AMS-SLC APR 1.0>0.7[1.0]
DL ATL-BQK DEC 3>2[3] MAR 3>1.9[3]
DL ATL-BZE DEC 1.2>0.8[0.9]
DL ATL-CHA MAR 10>8[9]
DL ATL-CRW MAR 5>4[4]
DL ATL-CSG NOV 4>3[4] DEC 4>3[4] MAR 4>3[3]
DL ATL-CUN DEC 5>6[4] JAN 5>7[5] FEB 5>7[6] MAR 6>7[5]
DL ATL-DHN NOV 3>2[4] DEC 4>2[4] FEB 4>3[4] MAR 4>3[4]
DL ATL-DUB MAY 1.0>0.7[0.8]
DL ATL-GTR MAR 4>3[3]
DL ATL-MGM NOV 6>5[7] DEC 6>5[6] MAR 7>5[6]
DL ATL-MTY DEC 1.5>0.5[1.7] JAN 1.8>0.8[1.5] FEB 1.9>0.9[1.9] MAR 1.9>0.9[1.7]
*DL ATL-MUC OCT 0.5>0[0.5] NOV 0.4>0[1.0] DEC 0.5>0[0.9] JAN 0.4>0[0.9] FEB 0.4>0[0.8] MAR 0.5>0[0.7]
DL ATL-OAJ DEC 4>3[3] MAR 4>3[3]
DL ATL-PLS DEC 1.4>1.0[1.0]
DL ATL-ROA MAR 5>4[4]
DL ATL-SHV OCT 4>3[4]
DL ATL-TRI DEC 6>5[5] MAR 7>6[5]
DL ATL-VLD NOV 3>1.5[3] DEC 3>1.3[3] FEB 3>1.6[3] MAR 3>1.4[3]
DL ATW-DTW MAR 4>3[3]
DL AUS-SEA NOV 1.6>1.2[0.9]
DL AZO-MSP MAR 0.9>0.6[0.8]
DL BDA-JFK MAR 1.0>0.7[0.9] APR 1.0>0.7[1.0] MAY 1.0>0.7[1.0]
DL BIS-MSP MAR 7>6[5]
DL BOS-BUF DEC 0.2>0[2] MAR 3>1.2[2]
*DL BOS-CDG NOV 0.6>0[1.0] DEC 0.5>0[0.7] JAN 0.6>0[0.8] FEB 0.6>0[0.8] MAR 0.6>0[0.7]
DL BOS-CMH NOV 2>1.7[3]
DL BOS-DUB APR 1.0>0.8[0.7]
DL BOS-MKE MAR 1.9>1.5[1.6]
DL BOS-PHL MAR 6>4[5]
DL BOS-PIT MAR 5>4[4]
DL BOS-PUJ DEC 0.4>0[0]
DL BOS-RIC NOV 2>1.2[3] DEC 3>1.8[2] MAR 3>1.3[2]
DL CDG-LAX APR 1.0>0.7[0.7]
DL CDG-MSP APR 1.0>0.7[1.0]
DL CDG-SLC APR 1.0>0.7[0.9]
DL CHO-LGA DEC 0.6>0.4[2]
DL CID-DTW MAR 3>2[3]
DL CMH-DTW MAR 7>6[5]
DL CUN-DTW NOV 1.3>2[0.7] DEC 2>3[1.1]
DL CUN-JFK NOV 1.7>2[2] DEC 2>3[2.0]
DL CUN-LAX NOV 1.0>1.4[1.0] DEC 1.4>2[1.0] JAN 1.1>2[1.4] FEB 1.0>2[1.2] MAR 1.1>2[0.9]
Interesting they would reduce that
*DL CUN-MSP JAN 3>1.2[1.8] FEB 3>1.0[3] MAR 3>1.0[3]
DL CWA-DTW MAR 1.9>1.3[1.6]
DL CWA-MSP MAR 2>1.6[1.7]
DL DLH-MSP MAR 5>4[4]
DL DTW-ELM MAR 5>4[4]
DL DTW-HPN DEC 1.6>1.2[3] MAR 4>3[3]
DL DTW-IAD DEC 4>3[4]
DL DTW-ICN NOV 1.0>1.3[1.0]
DL DTW-LAN DEC 4>3[4] MAR 5>4[4]
DL DTW-MBS MAR 5>4[4]
*DL DTW-MTY NOV 0.3>0[1.0] DEC 0.5>0[0.8]
*DL DTW-NAS DEC 0.4>0[0] JAN 0.2>0[0.4]
Didn't this just get added back?
*DL DTW-PVG OCT 0.3>0[0.3] NOV 1.0>0[1.0]
DL DTW-RIC MAR 3>2[3]
DL DTW-SDF MAR 5>4[3]
DL DTW-TYS DEC 4>3[4] MAR 5>4[3]
DL EDI-JFK MAY 1.0>0.7[0]
**DL GDL-SLC NOV 0>0.8[0] DEC 0>1.0[0] JAN 0>1.0[0]
DL GEG-LAX NOV 1.0>0.7[1.0] MAR 1.0>0.8[0.9]
DL IAD-JFK DEC 4>3[3] MAR 3>2[3]
DL ICN-SEA NOV 0.6>0.8[1.0]
DL JFK-LIS APR 1.0>0.8[0.7]
DL LAN-MSP MAR 1.0>0.7[0.9]
DL LAS-LAX OCT 5>4[5] NOV 6>5[7] MAR 7>5[6]
DL LAX-PHX OCT 4>3[4] NOV 5>4[5] DEC 5>3[4] MAR 6>4[5]
UA Response
**DL LAX-SAL DEC 0>0.4[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0]
DL LAX-SAN MAR 5>4[5]
DL LAX-SFO OCT 5>3[5] NOV 7>6[8]
DL LAX-SJC OCT 3>2[3] NOV 6>5[7] MAR 7>6[5]
DL LAX-SMF NOV 5>3[5] MAR 6>4[4]
DL LAX-TUS DEC 3>2[3] MAR 3>2[3]
DL LGA-PIT OCT 3>2.0[3]
DL LGA-RIC OCT 1.7>1.0[2]
DL MKE-SLC DEC 1.0>0.8[0.6]
DL MSP-PVR APR 1.0>0.7[1.3]
DL MSP-SBN MAR 1.0>0.8[0.9]
**DL ONT-SEA NOV 0.4>2.0[0] DEC 0>2[0] JAN 0>2[0] FEB 0>2[0] MAR 0>2[0] APR 0>2[0] MAY 0>2[0] JUN 0>2[0]
DL PHL-RDU DEC 0.6>0.3[3]
What's up with the PVGs suspended?
**DL PVG-SEA OCT 0.3>0[0.3] NOV 1.0>0[1.0]
DL PVR-SEA DEC 0.4>0[0.1]
EK BOS-DXB NOV 1.0>0.6[1.0]
EK DFW-DXB OCT 0.6>0.1[0.6] NOV 1.0>0.6[1.0]
**EK DXB-EWR APR 1.0>0[1.0] MAY 1.0>0[0] JUN 1.0>0[0]
EK DXB-IAD NOV 1.0>0.6[1.0] DEC 1.0>0.7[1.0] JAN 1.0>0.7[1.0] FEB 1.0>0.7[1.1] MAR 1.0>0.7[0.9]
EK DXB-IAH NOV 1.0>0.4[1.0] DEC 1.0>0.7[1.0] JAN 1.0>0.7[1.0] FEB 1.0>0.7[1.1] MAR 1.0>0.7[0.9]
EK DXB-JFK NOV 2>1.0[2] DEC 2>1.0[1.9] JAN 2>1.0[2] FEB 2>1.0[2] MAR 2>1.1[1.9]
EK DXB-LAX NOV 1.0>0.6[1.0] DEC 1.0>0.7[1.0] JAN 1.0>0.7[1.0] FEB 1.0>0.7[1.1] MAR 1.0>0.7[0.9]
EK DXB-MCO NOV 0.7>0[0.7] DEC 0.7>0[0.7]
EK DXB-ORD NOV 1.0>0.7[1.0]
EK DXB-SEA OCT 0.6>0.1[0.6] NOV 1.0>0.4[1.0]
EK DXB-SFO OCT 0.5>0.1[0.5] NOV 1.0>0.4[1.0] DEC 1.0>0.7[1.0] JAN 1.0>0.7[1.0] FEB 1.0>0.7[1.1] MAR 1.0>0.7[0.9]
F2 MBA-MDR OCT 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] JUN 0>0.5[0]
F2 MDR-WIL OCT 0>4[0] NOV 0>2[0] DEC 0>2[0] JAN 0>2[0] FEB 0>2[0] MAR 0>2[0] APR 0>2[0] MAY 0>2[0] JUN 0>2[0]
FJ LAX-NAN OCT 0.7>0[0.7] NOV 0.7>0[1.0]
FJ NAN-SFO OCT 0.3>0[0.3] NOV 0.3>0[0.5]
G3 FOR-MCO DEC 1.0>0[0]
G4 AUS-LAS DEC 0>0.3[0.5] JAN 0>0.3[0.5]
G4 AZA-SMX DEC 0>0.3[0] JAN 0>0.3[0]
G4 BNA-BZN DEC 0>0.3[0] JAN 0>0.3[0]
G4 BOI-PSP DEC 0>0.3[0] JAN 0>0.3[0]
G4 BOS-SRQ DEC 0>0.3[0] JAN 0>0.3[0]
G4 DEN-PVU DEC 0>0.3[0] JAN 0>0.3[0]
G4 EUG-PSP DEC 0>0.4[0] JAN 0>0.3[0]
G4 HOU-PGD DEC 0>0.3[0] JAN 0>0.3[0]
G4 MDW-PGD DEC 0>0.3[0] JAN 0>0.3[0]
HI GCN-GCW FEB 0.7>0[0.8]
HZ RZH-VVO OCT 0>0.5[0]
KAI KOA-OAK OCT 0.3>0[0.3] NOV 0.3>0[0.3] DEC 0.3>0[0.3] JAN 0.3>0[0.3] FEB 0.3>0[0.3] MAR 0.3>0[0.2] APR 0.3>0[0.3] MAY 0.3>0[0.3] JUN 0.3>0[0.3]
KE BOS-ICN OCT 0.9>0.5[0.9]
KE DFW-ICN OCT 0.7>0.5[0.7]
KE HNL-ICN OCT 1.0>0.2[1.0]
KE HNL-NRT OCT 1.0>0.2[1.0]
KE IAD-ICN OCT 1.0>0.6[1.0]
KE ICN-JFK OCT 2.0>1.2[2.0]
KE ICN-LAS OCT 0.7>0.2[0.7]
KE ICN-LAX OCT 2>1.5[2]
KE ICN-ORD OCT 1.0>0.8[1.0]
KE ICN-SEA OCT 0.9>0.5[0.9]
KE ICN-SFO OCT 2>1.1[2]
KG AIA-DEN OCT 1.7>0[1.7] NOV 1.7>0[1.8] DEC 1.7>0[1.6] JAN 1.7>0[1.7] FEB 1.7>0[1.9] MAR 1.7>0[1.6] APR 1.7>0[1.8] MAY 1.7>0[1.7] JUN 1.7>0[1.7]
LA BOS-GRU JAN 0.7>0.4[0.7] FEB 0.7>0.4[0.8] MAR 0.7>0.5[0.7]
LF BWI-MCN NOV 0.9>0.6[1.7]
LF CEC-OAK OCT 0>1.0[0] NOV 0>0.5[1.0]
LH BOS-FRA OCT 1.0>0.8[1.0]
LH CLT-MUC OCT 0.6>0.2[0.6]
LH DEN-MUC OCT 0.8>0.2[0.8]
LH DFW-FRA OCT 0.5>0.2[0.5]
LH DTW-FRA OCT 0.5>0.2[0.5]
LH EWR-MUC OCT 0.8>0.6[0.8]
LH FRA-LAX OCT 1.0>0.8[1.0]
LH FRA-MCO OCT 0.5>0.2[0.5]
LH FRA-PHL OCT 0.5>0.2[0.5]
LH FRA-SFO OCT 0.5>0.2[0.5]
LH MUC-SFO OCT 0.8>0.6[0.8]
LV EWR-ORY DEC 0>0.8[0.5] JAN 0>0.5[0.6] MAR 0>0.4[0.5]
LX LAX-ZRH OCT 0.6>0.3[0.6]
LX MIA-ZRH OCT 0.8>0.5[0.8]
LY BOS-TLV OCT 0.4>0.1[0.4]
LY ORD-TLV OCT 0.4>0.1[0.4]
LY SFO-TLV OCT 0.4>0.1[0.4]
M5 BFI-ESD OCT 1.7>0[1.7]
M5 BFI-FRD OCT 3>0[3]
M5 BFI-PAE OCT 0.6>0[0.6]
M5 CXH-LKE OCT 0.5>0[0.5]
M5 ESD-FRD OCT 2>0.5[2]
M5 ESD-PAE OCT 0.3>0[0.3]
M5 FRD-PAE OCT 0.4>0[0.4]
October hacked
NK ACY-ATL OCT 0.6>0[0.6]
NK ACY-FLL OCT 2>1.0[2]
NK ACY-MCO OCT 2>0.6[2]
NK ACY-MYR OCT 1.0>0.2[1.0]
NK ACY-RSW OCT 0.8>0.6[0.8]
NK ACY-TPA OCT 0.8>0.3[0.8]
NK ATL-AUS OCT 0.8>0[0.8]
NK ATL-BOS OCT 0.8>0[0.8]
NK ATL-BWI OCT 3>0.9[3]
NK ATL-CLE OCT 1.0>0.7[1.0]
NK ATL-DFW OCT 1.8>1.0[1.8]
NK ATL-EWR OCT 1.8>1.0[1.8]
NK ATL-FLL OCT 4>3[4]
NK ATL-IAH OCT 1.0>0.7[1.0]
NK ATL-MCO OCT 1.5>0.9[1.5]
NK ATL-MSP OCT 0.9>0.6[0.9]
NK ATL-MSY OCT 0.9>0.5[0.9]
NK ATL-PHL OCT 1.0>0.6[1.0]
NK ATL-TPA OCT 1.7>0.6[1.7]
NK AUS-BNA OCT 0.6>0[0.6]
NK AUS-BWI OCT 0.7>0[0.7]
NK AUS-CUN OCT 0.4>0[0.4]
NK AUS-DEN OCT 0.6>0[0.6]
NK AUS-DTW OCT 0.6>0[0.6]
NK AUS-EWR OCT 0.8>0[0.8]
NK AUS-LAS OCT 0.9>0.6[0.9]
NK AUS-LAX OCT 0.7>1.0[0.7]
NK AUS-MSY OCT 0.8>0[0.8]
NK AUS-ORD OCT 0.8>0[0.8]
NK BAQ-FLL OCT 0.3>0[0.3]
NK BDL-FLL OCT 0.8>0[0.8]
NK BDL-MCO OCT 1.3>0.7[1.3]
NK BDL-MYR OCT 1.8>0.6[1.8]
NK BGA-FLL OCT 0.4>0[0.4]
NK BNA-BWI OCT 0.8>0[0.8]
NK BNA-CUN OCT 0.2>0[0.2]
NK BNA-EWR OCT 0.8>0[0.8]
NK BNA-FLL OCT 0.9>0.6[0.9]
NK BNA-LAX OCT 0.8>1.0[0.8]
NK BNA-MCO OCT 1.0>0.5[1.0]
NK BNA-MSY OCT 0.8>0[0.8]
NK BNA-TPA OCT 0.8>0[0.8]
NK BOG-MCO OCT 0.8>0[0.8]
NK BOS-BWI OCT 3>0.3[3]
NK BOS-CLE OCT 0.5>0[0.5]
NK BOS-DTW OCT 0.5>0[0.5]
NK BOS-FLL OCT 1.7>0.9[1.7]
NK BOS-LAS OCT 0.8>0.2[0.8]
NK BOS-MCO OCT 1.5>0.9[1.5]
NK BOS-MSY OCT 0.6>0[0.6]
NK BOS-MYR OCT 1.2>0.7[1.2]
NK BOS-ORD OCT 0.6>0[0.6]
NK BOS-RSW OCT 0.5>0[0.5]
NK BUR-LAS OCT 1.5>0.6[1.5]
NK BUR-SEA OCT 0.8>0[0.8]
NK BWI-CLT OCT 0.6>0[0.6]
NK BWI-CUN OCT 0.7>0[0.7]
NK BWI-DEN OCT 0.5>0[0.5]
NK BWI-DFW OCT 0.8>0[0.8]
NK BWI-DTW OCT 0.8>0[0.8]
NK BWI-FLL OCT 3>1.8[3]
NK BWI-IAH OCT 1.2>0[1.2]
**NK BWI-JAX OCT 0.6>0.1[0.6] NOV 0.8>0[0.7] DEC 0.9>0[0.8] JAN 0.8>0[0.8] FEB 0.2>0[0.8]
NK BWI-LAS OCT 0.9>0.6[0.9]
NK BWI-LAX OCT 1.0>0.7[1.0]
NK BWI-MBJ OCT 0.6>0[0.6]
NK BWI-MCO OCT 3>1.2[3]
NK BWI-MSP OCT 0.8>0[0.8]
NK BWI-MSY OCT 0.8>0[0.8]
NK BWI-MYR OCT 1.5>0.7[1.5]
NK BWI-ORD OCT 1.6>0[1.6]
NK BWI-RDU OCT 0.6>0[0.6]
NK BWI-SAL OCT 0.8>0[0.8]
NK BWI-SEA OCT 0.8>0[0.8]
NK BWI-SJU OCT 1.5>0.7[1.5]
NK BWI-TPA OCT 1.6>0[1.6]
NK CAK-MCO OCT 0.7>0.2[0.7]
NK CLE-CUN OCT 0.4>0.1[0.4]
NK CLE-EWR OCT 0.8>0[0.8]
NK CLE-FLL OCT 1.8>0.7[1.8]
NK CLE-LAS OCT 1.8>1.0[1.8]
NK CLE-LAX OCT 1.0>0.7[1.0]
NK CLE-MCO OCT 2>0.9[2]
NK CLE-MSY OCT 0.3>0[0.3]
NK CLE-MYR OCT 0.9>0.7[0.9]
NK CLE-TPA OCT 0.9>0.6[0.9]
NK CLT-EWR OCT 0.8>0[0.8]
NK CLT-FLL OCT 0.8>0[0.8]
NK CLT-MCO OCT 0.9>0.6[0.9]
NK CMH-FLL OCT 0.9>0.6[0.9]
NK CMH-LAS OCT 0.9>0.6[0.9]
NK CMH-MCO OCT 1.2>0.6[1.2]
NK CMH-MSY OCT 0.3>0[0.3]
NK CRW-MCO OCT 0.4>0.0[0.4]
NK CTG-MCO OCT 0.2>0[0.2]
NK CUN-DTW OCT 0.6>0.3[0.6]
NK CUN-MSY OCT 0.5>0[0.5]
NK CUN-ORD OCT 0.6>0.4[0.6]
NK CUN-PHL OCT 0.6>0.4[0.6]
NK CUN-PIT OCT 0.2>0[0.2]
NK DEN-DTW OCT 0.9>0.6[0.9]
NK DEN-FLL OCT 1.6>1.0[1.6]
NK DEN-IAH OCT 0.9>0.6[0.9]
NK DEN-LAS OCT 1.5>1.2[1.5]
NK DEN-MCO OCT 0.8>0[0.8]
NK DEN-MSP OCT 1.0>0.7[1.0]
NK DEN-ORD OCT 1.6>1.0[1.6]
NK DFW-DTW OCT 1.0>0.7[1.0]
NK DFW-FLL OCT 3>1.8[3]
NK DFW-LAS OCT 3>2[3]
NK DFW-LAX OCT 3>1.6[3]
NK DFW-LGA OCT 0.8>0[0.8]
NK DFW-MCO OCT 1.8>1.0[1.8]
NK DFW-MSY OCT 0.8>0.5[0.8]
NK DFW-ORD OCT 1.5>0.7[1.5]
NK DFW-PHL OCT 0.8>0[0.8]
NK DFW-PHX OCT 1.0>0.7[1.0]
NK DFW-TPA OCT 0.9>0.7[0.9]
NK DTW-FLL OCT 3>1.8[3]
NK DTW-LAS OCT 4>2[4]
NK DTW-LGA OCT 1.6>0.5[1.6]
NK DTW-MCI OCT 0.8>0[0.8]
NK DTW-MCO OCT 3>2.0[3]
NK DTW-MSP OCT 0.8>0[0.8]
NK DTW-MSY OCT 0.9>0.5[0.9]
NK DTW-PHL OCT 0.7>0[0.7]
NK DTW-RDU OCT 0.6>0[0.6]
NK DTW-RSW OCT 0.7>1.2[0.7]
NK DTW-TPA OCT 0.9>1.2[0.9]
NK EWR-FLL OCT 3>2[3]
NK EWR-IAH OCT 0.9>0.7[0.9]
NK EWR-MCO OCT 3>1.4[3]
NK EWR-MSY OCT 0.8>0[0.8]
NK EWR-MYR OCT 3>0.9[3]
NK EWR-RSW OCT 0.8>0.2[0.8]
NK EWR-SJU OCT 1.8>1.0[1.8]
NK EWR-TPA OCT 0.8>0.2[0.8]
NK FLL-GUA OCT 1.5>1.0[1.5]
NK FLL-GYE OCT 0.9>0.7[0.9]
**NK FLL-IAG OCT 0.2>0[0.2] NOV 0.6>0[0.3] DEC 0.8>0[0.6] JAN 0.7>0[0.7]
NK FLL-KIN OCT 0.7>0.3[0.7]
NK FLL-LAS OCT 1.6>1.0[1.6]
NK FLL-LAX OCT 1.0>0.7[1.0]
NK FLL-LBE OCT 0.6>0[0.6]
NK FLL-LGA OCT 3>1.8[3]
NK FLL-MBJ OCT 0.7>0.3[0.7]
NK FLL-MGA OCT 1.0>0.5[1.0]
NK FLL-MSY OCT 1.8>1.0[1.8]
NK FLL-MYR OCT 1.6>0[1.6]
NK FLL-ORD OCT 2>1.8[2]
NK FLL-PAP OCT 0.8>1.3[0.8]
**NK FLL-PBG OCT 0.2>0[0.2] NOV 0.6>0[0.3] DEC 0.8>0[0.6] JAN 0.7>0[0.7]
NK FLL-PHL OCT 3>0.9[3]
NK FLL-PIT OCT 1.7>0.9[1.7]
NK FLL-RDU OCT 0.9>0.6[0.9]
NK FLL-RIC OCT 0.9>0.6[0.9]
NK FLL-SAP OCT 0.9>0.4[0.9]
NK FLL-SDQ OCT 1.8>1.0[1.8]
NK FLL-SJO OCT 1.8>0.9[1.8]
NK FLL-SJU OCT 1.8>1.0[1.8]
NK FLL-TPA OCT 1.6>0.8[1.6]
**NK GSO-MCO NOV 0.4>0[0.4] DEC 0.9>0[0.7] JAN 0.8>0[1.0] FEB 0.2>0[1.1]
NK GUA-IAH OCT 0.4>0[0.4]
NK GUA-MCO OCT 0.8>0[0.8]
NK IAG-MYR OCT 0.4>0.1[0.4] NOV 0.2>0[0.6]
NK IAH-LAS OCT 3>1.7[3]
NK IAH-LAX OCT 3>1.7[3]
NK IAH-MCO OCT 3>0.6[3]
NK IAH-MSY OCT 0.9>0.3[0.9]
NK IAH-OAK OCT 0.7>0[0.7]
NK IAH-ORD OCT 1.7>0.6[1.7]
NK IAH-SAL OCT 0.3>0[0.3]
NK IAH-SAN OCT 0.8>0[0.8]
NK IAH-TPA OCT 0.6>0[0.6]
NK IND-LAS OCT 0.9>0.6[0.9]
NK LAS-LAX OCT 2>1.0[2]
NK LAS-MCI OCT 1.7>0.6[1.7]
NK LAS-MCO OCT 0.9>0.6[0.9]
NK LAS-MSP OCT 0.9>0.7[0.9]
NK LAS-MSY OCT 0.9>0.7[0.9]
NK LAS-OAK OCT 3>1.2[3] DEC 3>4[3] JAN 3>4[3] FEB 0.9>1.2[3]
NK LAS-ORD OCT 3>1.6[3]
NK LAS-PDX OCT 3>1.0[3]
NK LAS-PHL OCT 0.9>0.6[0.9]
NK LAS-PIT OCT 0.9>0.6[0.9]
NK LAS-SAN OCT 3>0.7[3]
NK LAS-SEA OCT 3>1.2[3]
NK LAS-SMF OCT 3>0.7[3]
**NK LAS-SNA NOV 0>0.5[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>0.3[0]
NK LAS-TPA OCT 0.9>0.6[0.9]
NK LAX-MSP OCT 0.6>0[0.6]
NK LAX-MSY OCT 0.9>0.6[0.9]
NK LAX-OAK OCT 1.8>0.7[1.8]
NK LAX-PHL OCT 0.9>0.5[0.9]
NK LAX-PIT OCT 0.7>0.4[0.7]
NK LBE-MCO OCT 0.8>0.6[0.8]
NK LBE-MYR OCT 1.1>0.6[1.1]
NK LGA-MYR OCT 1.7>0.6[1.7]
NK LGA-ORD OCT 0.8>0[0.8]
NK MBJ-MCO OCT 0.3>0[0.3]
NK MCI-MCO OCT 1.2>0.6[1.2]
NK MCO-MDE OCT 0.4>0[0.4]
NK MCO-MSP OCT 0.8>0.6[0.8]
NK MCO-MSY OCT 1.7>0.9[1.7]
NK MCO-MYR OCT 0.3>0[0.3]
NK MCO-ORD OCT 0.9>0.6[0.9]
NK MCO-PHL OCT 3>1.3[3]
NK MCO-PIT OCT 1.7>0.7[1.7]
NK MCO-RDU OCT 1.3>0[1.3]
NK MCO-RIC OCT 0.8>0[0.8]
NK MCO-SAL OCT 0.3>0[0.3]
NK MCO-SAP OCT 0.2>0[0.2]
NK MCO-SJO OCT 0.8>0[0.8]
NK MCO-SJU OCT 3.4>1.9[3.4]
NK MSP-MSY OCT 0.4>0[0.4]
NK MSY-ORD OCT 0.9>0.5[0.9]
NK MSY-PHL OCT 0.5>0[0.5]
NK MSY-RDU OCT 0.8>0[0.8]
NK MSY-SAP OCT 0.3>0[0.3]
NK MSY-TPA OCT 0.8>0.2[0.8]
NK MYR-ORD OCT 0.8>0.6[0.8]
NK MYR-PHL OCT 0.9>0.6[0.9]
NK MYR-PIT OCT 1.3>0.7[1.3]
NK OAK-ORD OCT 0.8>0[0.8]
**NK OAK-SNA NOV 0>0.9[0] DEC 0>2[0] JAN 0>2[0] FEB 0>0.6[0]
NK ORD-RDU OCT 0.6>0[0.6]
NK ORD-RSW OCT 0.7>0.4[0.7]
NK ORD-SEA OCT 0.8>0[0.8]
NK ORD-TPA OCT 0.7>0.9[0.7]
NK PHL-SJU OCT 1.6>1.0[1.6]
*NZ AKL-HNL NOV 0.4>0[0.7] DEC 0.6>0[0.5] JAN 0.7>0[0.6] FEB 0.4>0[0.7] MAR 0.4>0.0[0.4]
*NZ AKL-IAH NOV 0.7>0[0.8] DEC 1.0>0[0.7] JAN 1.0>0[0.9] FEB 0.9>0[1.0] MAR 0.8>0.1[0.8]
NZ AKL-LAX NOV 1.8>1.0[2.0] DEC 1.9>1.0[1.6] JAN 1.8>1.0[2.0] FEB 1.9>1.0[2] MAR 1.8>1.1[1.9]
*NZ AKL-ORD NOV 0.4>0[0.4] DEC 0.6>0[0.4] JAN 0.7>0[0.6] FEB 0.5>0[0.8] MAR 0.4>0.1[0.5]
NZ AKL-SFO NOV 0.7>0.4[0.7] DEC 0.9>0.5[0.7] JAN 1.0>0.4[1.0] FEB 0.9>0.4[1.1] MAR 0.8>0.5[0.8]
O2 ACK-HPN OCT 1.3>0[1.3] NOV 1.3>0[0] DEC 0.3>0[0]
O2 BOS-HPN OCT 0.5>0[0.5] NOV 0.6>0[0]
O2 HPN-MVY OCT 0.5>0[0.5] NOV 0.4>0[0]
O2 HPN-NPT OCT 0.3>0[0.3] NOV 0.3>0[0]
OS IAD-VIE OCT 1.0>0.5[1.0]
OS ORD-VIE OCT 1.0>0.8[1.0]
OZ HNL-ICN OCT 1.0>0.2[1.0]
OZ ICN-JFK OCT 2.0>1.2[2.0]
OZ ICN-LAX OCT 2>1.5[2]
OZ ICN-SEA OCT 0.9>0.5[0.9]
OZ ICN-SFO OCT 1.0>0.6[1.0]
P2 KIS-MDR OCT 0>1.0[0] NOV 0>1.0[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0]
P2 MDR-WIL OCT 0>3[0] NOV 0>3[0] DEC 0>3[0] JAN 0>3[0] FEB 0>3[0] MAR 0>3[0] APR 0>3[0] MAY 0>3[0] JUN 0>3[0]
PD BOS-YTZ OCT 4>3[4] DEC 5>3[5] FEB 4>2[4] MAY 5>4[0]
PD EWR-YTZ OCT 9>6[9] DEC 10>7[10] FEB 8>6[9] MAY 11>8[0] JUN 12>11[0]
PD IAD-YTZ OCT 2>1.6[2] DEC 2>1.3[2] FEB 0.8>0.4[1.2] MAY 3>1.9[0]
PD MDW-YTZ OCT 3>2[3] DEC 3>1.9[4] FEB 2>1.5[2] MAY 5>3[0]
PR MNL-SFO OCT 0.9>0.7[0.9]
Q6 GUA-LAX OCT 0.4>0[0.4]
Q6 IAD-SAL OCT 0.6>0[0.6]
Q6 JFK-SAL OCT 0.4>0[0.4]
Q6 LAX-SAL OCT 0.6>0[0.6]
SQ EWR-SIN OCT 0.2>0[0.2] NOV 1.0>0[1.0]
SQ HKG-SFO OCT 0.2>0[0.2] NOV 1.0>0[1.0]
SQ IAH-MAN NOV 0.7>0[0.7]
SQ LAX-NRT OCT 0.2>0[0.2] NOV 1.0>0[1.0]
SQ LAX-SIN NOV 1.0>0.4[1.5]
SQ SEA-SIN NOV 0.7>0[0.6]
SQ SFO-SIN OCT 0.3>0[0.3] NOV 1.4>0[1.5]
TJ ACK-HPN OCT 1.3>0[1.3] NOV 0.9>0[1.3] DEC 0.6>0[0.8]
TJ ACK-TEB OCT 1.1>0[1.1] NOV 0.8>0[1.2] DEC 0.4>0[0.6]
TJ HPN-MVY OCT 0.5>0[0.5] NOV 0.3>0[0.5]
TJ MVY-TEB OCT 0.4>0[0.4] NOV 0.2>0[0.4]
TOM BHX-SFB APR 0.3>0[0]
TOM LGW-SFB APR 0.3>0[0]
TOM MAN-SFB APR 0.6>0[0]
TP BOS-LIS OCT 0.7>0.5[0.7]
UA ABE-ORD OCT 3>1.0[3]
UA ABQ-DEN OCT 5>3[5]
UA ABQ-IAH OCT 5>2[5]
UA ABQ-ORD OCT 1.8>0.5[1.8]
UA ABQ-SFO OCT 1.8>0.7[1.8]
UA ACV-DEN OCT 1.0>0.3[1.0]
UA ACV-LAX OCT 2>0.7[2]
UA ACV-SFO OCT 3>1.7[3]
UA AEX-IAH OCT 3>1.5[3]
UA AGU-IAH OCT 2>0.5[2]
UA AKL-SFO OCT 0.6>0[0.6]
UA ALB-IAD OCT 3>1.7[3]
UA ALB-ORD OCT 4>1.6[4]
UA AMA-DEN OCT 2>1.0[2]
UA AMA-IAH OCT 3>1.5[3]
UA AMS-IAD OCT 0.3>0[0.3]
UA ANC-ORD OCT 0.8>0[0.8]
UA ASE-IAH APR 0.2>0[3]
UA ASE-LAX OCT 1.0>0[1.0]
UA ASE-ORD OCT 0.2>1.1[0.2] APR 0.3>0[5]
UA ASE-SFO APR 0.2>0[1.9]
UA ATL-DEN OCT 4>3[4]
UA ATL-EWR OCT 8>4[8]
UA ATL-IAD OCT 4>1.6[4]
UA ATL-IAH OCT 7>3[7]
UA ATL-ORD OCT 8>3[8]
UA ATL-SFO OCT 2>0[2]
UA ATW-DEN OCT 1.0>0[1.0]
UA ATW-ORD OCT 10>3[10]
UA ATY-ORD OCT 1.0>0.7[1.0]
UA AUA-EWR OCT 1.8>0.7[1.8]
UA AUS-DEN OCT 5>3[5]
UA AUS-EWR OCT 5>1.5[5]
UA AUS-IAD OCT 3>1.0[3]
UA AUS-IAH OCT 10>3[10]
UA AUS-LAX OCT 2>0.7[2]
UA AUS-ORD OCT 5>2[5]
UA AUS-SFO OCT 5>1.5[5]
UA AVL-EWR OCT 1.0>0[1.0]
UA AVL-IAD OCT 3>1.7[3]
UA AVL-ORD OCT 4>2[4]
UA AVP-IAD OCT 3>0[3]
UA AZO-ORD OCT 3>1.6[3]
UA BCN-EWR OCT 0.3>0[0.3]
UA BDL-DEN OCT 2>1.0[2]
UA BDL-IAD OCT 4>1.7[4]
UA BDL-IAH OCT 2>0[2]
UA BDL-ORD OCT 5>3[5]
UA BFL-DEN OCT 1.8>1.0[1.8]
UA BGR-EWR OCT 2>0[2]
UA BGR-ORD OCT 1.5>0.7[1.5]
UA BHM-IAH OCT 5>3[5]
UA BHM-ORD OCT 4>1.5[4]
UA BIL-DEN OCT 5>3[5]
UA BIS-DEN OCT 4>2[4]
UA BIS-ORD OCT 2>0[2]
UA BJX-IAH OCT 4>2[4]
UA BNA-DEN OCT 5>3[5]
UA BNA-EWR OCT 6>2[6]
UA BNA-IAD OCT 3>1.6[3]
UA BNA-IAH OCT 6>3[6]
UA BNA-ORD OCT 8>3[8]
UA BNA-SFO OCT 1.8>0[1.8]
UA BOG-EWR OCT 0.2>0[0.2]
UA BOG-IAH OCT 2>0.5[2]
UA BOI-DEN OCT 6>3[6]
UA BOI-IAH OCT 2>0[2]
UA BOI-LAX OCT 2>1.0[2]
UA BOI-ORD OCT 3>2.0[3]
UA BOI-SFO OCT 6>3[6]
UA BOS-DEN OCT 5>3[5]
UA BOS-EWR OCT 12>2[12]
UA BOS-IAD OCT 5>1.7[5]
UA BOS-IAH OCT 5>2.0[5]
UA BOS-LAX OCT 2>0.7[2]
UA BOS-ORD OCT 8>4[8]
UA BOS-SFO OCT 7>3[7]
UA BRO-IAH OCT 4>3[4]
UA BRU-EWR OCT 1.0>0.4[1.0]
UA BRU-ORD OCT 1.0>0.5[1.0]
UA BTR-IAH OCT 7>3[7]
UA BTV-EWR OCT 4>2.0[4]
UA BTV-IAD OCT 4>1.7[4]
UA BTV-ORD OCT 4>1.6[4]
UA BUF-EWR OCT 6>3[6]
UA BUF-IAD OCT 4>1.7[4]
UA BUF-ORD OCT 5>2[5]
UA BUR-DEN OCT 3>1.0[3]
UA BUR-SFO OCT 6>0.7[6]
UA BWI-IAH OCT 1.8>1.0[1.8]
UA BWI-LAX OCT 1.0>0[1.0]
UA BWI-ORD OCT 4>3[4]
UA BWI-SFO OCT 1.8>0[1.8]
UA BZE-IAH OCT 1.4>0.5[1.4]
UA BZN-DEN OCT 4>3[4]
UA BZN-LAX OCT 1.0>0[1.0]
UA CAE-IAD OCT 3>1.7[3]
UA CAE-IAH OCT 1.0>0[1.0]
UA CAE-ORD OCT 3>2[3]
UA CAK-IAD OCT 3>0[3]
UA CAK-IAH OCT 1.0>0[1.0]
UA CAK-ORD OCT 4>3[4]
UA CDG-IAD OCT 0.3>0[0.3]
UA CDG-ORD OCT 0.3>0[0.3]
UA CDG-SFO OCT 0.3>0[0.3]
UA CHA-ORD OCT 4>1.0[4]
UA CHO-IAD OCT 3>1.7[3]
UA CHO-ORD OCT 3>1.0[3]
UA CHS-EWR OCT 5>1.7[5]
UA CHS-IAD OCT 4>1.7[4]
UA CHS-IAH OCT 3>1.0[3]
UA CHS-ORD OCT 4>1.6[4]
UA CID-DEN OCT 4>2[4]
UA CID-ORD OCT 8>2[8]
UA CLE-DEN OCT 4>2[4]
UA CLE-EWR OCT 8>2[8]
UA CLE-IAD OCT 4>1.7[4]
UA CLE-IAH OCT 5>2[5]
UA CLE-LAX OCT 2>0[2]
UA CLE-MCO OCT 0.7>1.0[0.7]
UA CLE-ORD OCT 9>4[9]
UA CLE-SFO OCT 1.0>0.7[1.0]
UA CLL-IAH OCT 3>1.7[3]
UA CLT-EWR OCT 6>3[6]
UA CLT-IAD OCT 4>1.6[4]
UA CLT-IAH OCT 4>2.0[4]
UA CLT-ORD OCT 5>3[5]
UA CMH-EWR OCT 8>1.8[8]
UA CMH-IAD OCT 4>1.5[4] DEC 4>3[4] MAR 4>3[4]
UA CMH-IAH OCT 4>1.9[4]
UA CMH-ORD OCT 8>3[8]
UA CMH-SFO OCT 1.0>0[1.0]
UA CNY-DEN OCT 1.7>2[1.7]
UA COS-DEN OCT 10>5[10]
UA COS-IAH OCT 4>2[4]
UA COS-LAX OCT 2>0[2]
UA COS-ORD OCT 3>2.0[3]
UA COU-DEN OCT 1.0>0[1.0]
UA COU-ORD OCT 3>2.0[3]
UA CPR-DEN OCT 7>4[7]
UA CRP-IAH OCT 7>3[7]
UA CRW-ORD OCT 3>1.6[3]
UA CTU-SFO OCT 0.4>0[0.4]
UA CUN-DEN OCT 1.4>1.0[1.4]
UA CUN-EWR OCT 1.9>1.5[1.9]
UA CUN-IAD OCT 1.1>0.7[1.1]
UA CUN-IAH OCT 6>3[6]
UA CUN-LAX OCT 1.4>0.5[1.4]
UA CUN-ORD OCT 1.5>0.7[1.5]
UA CUN-SFO OCT 1.5>1.0[1.5]
UA CVG-EWR OCT 5>2.0[5]
UA CVG-IAD OCT 4>1.7[4]
UA CVG-IAH OCT 4>2.0[4]
UA CVG-ORD OCT 7>3[7]
UA CWA-ORD OCT 3>2[3]
UA CZM-IAH OCT 0.4>0.2[0.4]
UA DAY-DEN OCT 1.8>0[1.8]
UA DAY-IAD OCT 3>1.7[3]
UA DAY-ORD OCT 7>3[7]
UA DCA-EWR OCT 13>2.0[13]
UA DCA-IAH OCT 7>3[7]
UA DCA-ORD OCT 14>4[14]
UA DCA-SFO OCT 1.0>0[1.0]
UA DEN-DFW OCT 6>4[6]
UA DEN-DRO OCT 8>5[8]
UA DEN-DSM OCT 6>3[6]
UA DEN-EAR OCT 1.8>1.0[1.8]
UA DEN-EGE OCT 1.8>1.0[1.8]
UA DEN-ELP OCT 5>1.7[5]
UA DEN-EWR OCT 9>5[9]
UA DEN-FAR OCT 4>3[4]
UA DEN-FAT OCT 5>3[5]
UA DEN-FCA OCT 3>2[3]
UA DEN-FLG OCT 2>1.0[2]
UA DEN-FRA OCT 1.0>0[1.0]
UA DEN-FSD OCT 5>2.0[5]
UA DEN-GCC OCT 3>1.6[3]
UA DEN-GEG OCT 3>2.0[3]
UA DEN-GJT OCT 7>4[7]
UA DEN-GSP OCT 1.0>0.1[1.0]
UA DEN-GTF OCT 3>2[3]
UA DEN-HDN OCT 1.0>2[1.0]
UA DEN-HLN OCT 2>1.0[2]
**UA DEN-HOB OCT 1.0>0[1.0] NOV 1.0>0[0.2] DEC 1.0>0[0.9] JAN 1.0>0[1.0] FEB 1.0>0.6[1.1]
UA DEN-HSV OCT 2>1.0[2]
UA DEN-IAD OCT 8>5[8]
UA DEN-IAH OCT 11>6[11]
UA DEN-ICT OCT 5>3[5]
UA DEN-IDA OCT 4>3[4]
UA DEN-IND OCT 3>2.0[3]
UA DEN-JAX OCT 1.0>0.3[1.0]
UA DEN-KOA OCT 1.0>0.5[1.0]
UA DEN-LAS OCT 6>4[6]
UA DEN-LAX OCT 8>6[8]
UA DEN-LBB OCT 2>1.0[2]
UA DEN-LGA OCT 7>3[7]
UA DEN-LHR OCT 0.3>0[0.3]
UA DEN-LIH OCT 1.0>0.5[1.0]
UA DEN-LIT OCT 3>1.0[3]
UA DEN-LNK OCT 4>1.0[4]
UA DEN-MAF OCT 4>1.9[4]
UA DEN-MCI OCT 6>3[6]
UA DEN-MCO OCT 5>3[5]
UA DEN-MEM OCT 3>1.0[3]
UA DEN-MIA OCT 0.2>0[0.2]
UA DEN-MKE OCT 3>2.0[3]
UA DEN-MLI OCT 1.8>0[1.8]
UA DEN-MRY OCT 2>1.0[2]
UA DEN-MSN OCT 4>2[4]
UA DEN-MSP OCT 4>3[4]
UA DEN-MSY OCT 3>2.0[3]
UA DEN-MTJ OCT 4>2[4]
UA DEN-NRT OCT 1.0>0[1.0]
UA DEN-OKC OCT 6>3[6]
UA DEN-OMA OCT 6>4[6]
UA DEN-ONT OCT 3>1.0[3]
UA DEN-ORD OCT 10>7[10]
UA DEN-ORF OCT 1.0>0[1.0]
UA DEN-PAE OCT 3>0.9[3]
UA DEN-PDX OCT 5>3[5]
UA DEN-PHL OCT 3>2.0[3]
UA DEN-PHX OCT 5>4[5]
UA DEN-PRC OCT 2>1.0[2]
UA DEN-PSC OCT 3>2.0[3]
UA DEN-PSP OCT 4>3[4]
UA DEN-RAP OCT 7>3[7]
UA DEN-RDM OCT 3>2.0[3]
UA DEN-RIC OCT 2>1.0[2]
UA DEN-RIW OCT 1.8>1.0[1.8]
UA DEN-RKS OCT 2>1.0[2]
UA DEN-RNO OCT 4>3[4]
UA DEN-SAF OCT 4>0.7[4]
UA DEN-SAN OCT 5>3[5]
UA DEN-SAT OCT 4>3[4]
UA DEN-SAV OCT 1.0>0[1.0]
UA DEN-SBA OCT 4>1.8[4]
UA DEN-SBP OCT 3>2[3]
UA DEN-SDF OCT 1.8>1.0[1.8]
UA DEN-SEA OCT 6>4[6]
UA DEN-SFO OCT 9>6[9]
UA DEN-SGF OCT 4>3[4]
UA DEN-SGU OCT 3>2[3]
UA DEN-SHR OCT 1.8>1.0[1.8]
UA DEN-SHV OCT 1.0>0[1.0]
UA DEN-SJC OCT 5>2.0[5]
UA DEN-SLC OCT 7>5[7]
UA DEN-SMF OCT 5>3[5]
UA DEN-SNA OCT 4>1.9[4]
UA DEN-STL OCT 6>2[6]
UA DEN-STS OCT 1.0>0[1.0]
UA DEN-SYR OCT 1.0>0[1.0]
UA DEN-TUL OCT 4>1.5[4]
UA DEN-TUS OCT 5>3[5]
UA DEN-TYS OCT 2>1.0[2]
UA DEN-XNA OCT 4>0.9[4]
UA DEN-XWA OCT 4>2[4]
UA DEN-YEG OCT 2>0.8[2]
UA DEN-YVR OCT 2>0.7[2]
UA DEN-YWG OCT 2>0[2]
UA DEN-YYC OCT 3>1.0[3]
UA DEN-YYZ OCT 1.8>0[1.8]
UA DFW-EWR OCT 7>2[7]
UA DFW-IAD OCT 3>1.7[3]
UA DFW-IAH OCT 8>3[8]
UA DFW-ORD OCT 7>3[7]
UA DFW-SFO OCT 4>1.0[4]
UA DLH-ORD OCT 3>2.0[3]
UA DSM-IAH OCT 3>1.0[3]
UA DSM-ORD OCT 6>3[6]
UA DTW-EWR OCT 7>3[7]
UA DTW-IAD OCT 4>1.6[4]
UA DTW-IAH OCT 5>2[5]
UA DTW-ORD OCT 8>4[8]
UA DTW-SFO OCT 1.0>0[1.0]
UA DUB-EWR OCT 1.0>0.6[1.0]
UA DUB-IAD OCT 0.2>0[0.2]
UA DUB-SFO OCT 0.9>0[0.9]
UA EDI-EWR OCT 0.3>0[0.3]
UA ELP-IAH OCT 5>3[5]
UA ELP-ORD OCT 1.0>0.6[1.0]
UA ERI-ORD OCT 3>1.6[3]
UA EUG-LAX OCT 2>0.7[2]
UA EUG-ORD OCT 1.0>0[1.0]
UA EUG-SFO OCT 4>3[4]
UA EVV-ORD OCT 3>2[3]
UA EWR-FCO OCT 0.3>0[0.3]
UA EWR-FLL OCT 7>4[7]
UA EWR-GRR OCT 4>0[4]
UA EWR-GRU OCT 1.0>0.4[1.0]
UA EWR-GSO OCT 4>0[4]
UA EWR-GSP OCT 3>0[3]
UA EWR-GUA OCT 0.6>0.3[0.6]
UA EWR-GVA OCT 0.3>0[0.3]
UA EWR-HAV OCT 1.0>0[1.0]
UA EWR-HKG OCT 1.0>0[1.0]
UA EWR-HND OCT 1.0>0[1.0]
UA EWR-HNL OCT 1.0>0[1.0]
UA EWR-IAD OCT 7>3[7]
UA EWR-IAH OCT 9>4[9]
UA EWR-IND OCT 8>2[8]
UA EWR-JAX OCT 4>1.5[4]
UA EWR-LAS OCT 6>2[6]
UA EWR-LAX OCT 12>4[12]
UA EWR-LHR OCT 6>1.0[6]
UA EWR-LIS OCT 0.3>0[0.3]
UA EWR-MAD OCT 0.3>0[0.3]
UA EWR-MBJ OCT 1.2>0.7[1.2]
UA EWR-MCI OCT 4>0.9[4]
UA EWR-MCO OCT 9>4[9]
UA EWR-MEM OCT 3>0[3]
UA EWR-MEX OCT 3>1.0[3]
UA EWR-MIA OCT 4>3[4]
UA EWR-MKE OCT 5>0[5]
UA EWR-MSN OCT 2>0[2]
UA EWR-MSP OCT 6>1.0[6]
UA EWR-MSY OCT 5>1.6[5]
UA EWR-MUC OCT 1.0>0.4[1.0]
UA EWR-MXP OCT 0.3>0[0.3]
UA EWR-NAS OCT 1.2>0.2[1.2]
UA EWR-OKC OCT 1.0>0[1.0]
UA EWR-OMA OCT 1.8>0[1.8]
UA EWR-ORD OCT 12>5[12]
UA EWR-ORF OCT 6>2[6]
UA EWR-PBI OCT 5>1.7[5]
UA EWR-PDX OCT 2>0[2]
UA EWR-PEK OCT 0.3>0[0.3]
UA EWR-PHX OCT 4>1.7[4]
UA EWR-PIT OCT 10>2[10]
UA EWR-PLS OCT 0.4>0.2[0.4]
UA EWR-POP OCT 0.2>0.5[0.2]
UA EWR-POS OCT 0.7>0[0.7]
UA EWR-PTY OCT 1.0>0[1.0]
UA EWR-PUJ OCT 1.1>0.7[1.1]
UA EWR-PVD OCT 5>3[5]
UA EWR-PVG OCT 0.3>0[0.3]
UA EWR-PWM OCT 7>2[7]
UA EWR-RDU OCT 8>3[8]
UA EWR-RIC OCT 7>3[7]
UA EWR-ROC OCT 5>3[5]
UA EWR-RSW OCT 3>1.8[3]
UA EWR-SAL OCT 0.6>0.3[0.6]
UA EWR-SAN OCT 4>1.7[4]
UA EWR-SAT OCT 1.8>1.0[1.8]
UA EWR-SAV OCT 5>1.0[5]
UA EWR-SDF OCT 3>0[3]
UA EWR-SDQ OCT 3>2[3]
UA EWR-SEA OCT 3>1.0[3]
UA EWR-SFO OCT 15>4[15]
UA EWR-SJO OCT 1.0>0.6[1.0]
UA EWR-SJU OCT 4>2.0[4]
UA EWR-SLC OCT 1.0>0[1.0]
UA EWR-SMF OCT 1.0>0[1.0]
UA EWR-SNA OCT 3>0[3]
UA EWR-STI OCT 3>2[3]
UA EWR-STL OCT 5>2[5]
UA EWR-STT OCT 0.2>0.6[0.2]
UA EWR-SYR OCT 3>2.0[3]
UA EWR-TLV OCT 1.6>2[1.6]
UA EWR-TPA OCT 6>3[6]
UA EWR-TXL OCT 0.3>0[0.3]
UA EWR-TYS OCT 0.9>0[0.9]
UA EWR-XNA OCT 0.7>0[0.7]
UA EWR-YHZ OCT 3>0[3]
UA EWR-YQB OCT 4>0[4]
UA EWR-YUL OCT 3>0[3]
UA EWR-YYZ OCT 4>0[4]
UA EWR-ZRH OCT 1.0>0[1.0]
AA moved flights from PHL to ORD/DFW and UA moves flights from ORD to IAD
**UA EYW-IAD NOV 0>0.6[0] DEC 0>0.8[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>0.9[0] APR 0>1.0[0]
UA EYW-ORD OCT 0>1.0[0] NOV 0>1.0[1.1] DEC 1.7>1.0[1.1] JAN 2>1.0[1.7] FEB 2>1.0[1.5] MAR 2>0.9[1.8] APR 2>1.0[2]
UA EZE-IAH OCT 1.0>0.3[1.0]
UA FAR-ORD OCT 4>2.0[4]
UA FAT-LAX OCT 4>1.7[4]
UA FAT-ORD OCT 1.0>0[1.0]
UA FAT-SFO OCT 4>1.3[4]
UA FCA-ORD OCT 0>1.0[0]
UA FLL-IAH OCT 5>2.0[5]
UA FLL-ORD OCT 3>2[3]
UA FLL-SFO OCT 1.0>0[1.0]
UA FRA-IAD OCT 2>1.0[2]
UA FRA-IAH OCT 1.0>0.4[1.0]
UA FRA-ORD OCT 2>1.0[2]
UA FRA-SFO OCT 2>1.0[2]
UA FSD-ORD OCT 5>3[5]
UA FWA-ORD OCT 3>2[3]
UA GCM-IAH OCT 0.2>0[0.2]
UA GDL-IAH OCT 4>2[4]
UA GEG-ORD OCT 1.0>0[1.0]
UA GEG-SFO OCT 3>1.0[3]
UA GIG-IAH OCT 1.0>0[1.0]
UA GPT-IAH OCT 4>1.9[4]
UA GRB-ORD OCT 5>3[5]
UA GRK-IAH OCT 3>0.9[3]
UA GRR-IAD OCT 1.0>0[1.0]
UA GRR-IAH OCT 1.0>0[1.0]
UA GRR-ORD OCT 7>3[7]
UA GRU-IAD OCT 0.3>0[0.3]
UA GRU-ORD OCT 0.3>0[0.3]
UA GSO-IAD OCT 3>1.7[3]
UA GSO-ORD OCT 4>2.0[4]
UA GSP-IAD OCT 4>1.7[4]
UA GSP-IAH OCT 2>1.0[2]
UA GSP-ORD OCT 3>1.5[3]
UA GUA-IAD OCT 0.7>0.3[0.7]
UA GUA-IAH OCT 2>1.0[2]
UA GUA-LAX OCT 0.6>0.3[0.6]
UA HAV-IAH OCT 1.0>0[1.0]
UA HKG-SFO OCT 1.3>0[1.3]
UA HND-IAD OCT 0.3>0[0.3]
UA HND-LAX OCT 1.0>0[1.0]
UA HND-ORD OCT 1.0>0[1.0]
UA HND-SFO OCT 1.0>0[1.0]
UA HNL-IAH OCT 1.0>0.5[1.0]
UA HNL-LAX OCT 4>2[4]
UA HNL-MAJ OCT 0.5>0.1[0.5]
UA HNL-NRT OCT 1.0>0[1.0]
UA HNL-SFO OCT 5>2[5]
UA HOB-IAH OCT 1.8>0.4[1.8]
**UA HPN-ORD OCT 3>0[3] NOV 3>0[3] DEC 3>0[3]
UA HRL-IAH OCT 5>3[5]
UA HSV-IAD OCT 3>1.7[3]
UA HSV-IAH OCT 4>1.7[4]
UA HSV-ORD OCT 3>1.6[3]
UA IAD-IAH OCT 5>4[5]
UA IAD-ILM OCT 3>1.7[3]
UA IAD-IND OCT 4>1.6[4]
**UA IAD-ITH OCT 4>0[4] NOV 4>0[3] DEC 4>0[1.9] JAN 4>0[2] FEB 4>0[2] MAR 4>0.5[2]
UA IAD-JAX OCT 3>1.7[3]
UA IAD-LAS OCT 3>1.7[3]
UA IAD-LAX OCT 7>2[7]
UA IAD-LEX OCT 2>0[2]
UA IAD-LGA OCT 4>1.6[4]
UA IAD-LHR OCT 1.5>1.0[1.5]
UA IAD-MCI OCT 3>0.7[3]
UA IAD-MCO OCT 4>1.7[4]
UA IAD-MDT OCT 4>1.7[4]
**UA IAD-MHT OCT 3>0[3] NOV 3>0[3] DEC 3>0[3] JAN 3>0[2] FEB 3>0[2] MAR 3>0.4[2]
UA IAD-MIA OCT 0.5>1.7[0.5]
UA IAD-MSN OCT 2>0[2]
UA IAD-MSP OCT 2>1.0[2]
UA IAD-MSY OCT 3>1.5[3]
UA IAD-OKC OCT 2>0[2]
UA IAD-ORD OCT 6>4[6]
UA IAD-ORF OCT 4>1.6[4]
UA IAD-PBI OCT 1.0>0.7[1.0]
UA IAD-PDX OCT 1.0>0[1.0]
UA IAD-PEK OCT 0.3>0[0.3]
UA IAD-PHL OCT 4>1.6[4]
UA IAD-PIT OCT 4>1.6[4]
UA IAD-PUJ OCT 0.2>0[0.2]
UA IAD-PVD OCT 4>1.7[4]
UA IAD-PWM OCT 4>1.7[4]
UA IAD-RDU OCT 4>1.6[4]
UA IAD-RIC OCT 4>1.6[4]
UA IAD-ROA OCT 4>1.7[4]
UA IAD-ROC OCT 4>1.6[4]
UA IAD-SAL OCT 0.8>0.3[0.8]
UA IAD-SAN OCT 3>1.7[3]
UA IAD-SAT OCT 3>1.0[3]
UA IAD-SAV OCT 3>1.6[3]
UA IAD-SCE OCT 3>1.7[3]
UA IAD-SDF OCT 3>1.7[3]
UA IAD-SEA OCT 3>1.0[3]
UA IAD-SFO OCT 7>3[7]
UA IAD-SHD OCT 2>0.7[2]
UA IAD-SJU OCT 1.0>0.4[1.0]
UA IAD-SMF OCT 1.0>0[1.0]
UA IAD-SRQ OCT 1.0>1.7[1.0]
UA IAD-STL OCT 3>1.6[3] DEC 3>2[3] MAR 3>2[3]
UA IAD-SYR OCT 4>1.7[4]
UA IAD-TPA OCT 3>1.6[3]
UA IAD-TYS OCT 3>1.7[3]
UA IAD-YOW OCT 3>0.6[3]
UA IAD-YUL OCT 3>0.7[3]
UA IAD-YYZ OCT 4>1.0[4]
UA IAH-ICT OCT 4>3[4]
UA IAH-IND OCT 5>1.9[5]
UA IAH-JAN OCT 6>3[6]
UA IAH-JAX OCT 4>2[4]
UA IAH-LAS OCT 7>2.0[7]
UA IAH-LAX OCT 9>5[9]
UA IAH-LCH OCT 4>1.7[4]
UA IAH-LEX OCT 1.0>0[1.0]
UA IAH-LFT OCT 6>3[6]
UA IAH-LGA OCT 7>3[7]
UA IAH-LHR OCT 0.5>0[0.5]
UA IAH-LIM OCT 1.0>0.5[1.0]
UA IAH-LIR OCT 1.3>0.5[1.3]
UA IAH-LIT OCT 6>3[6]
UA IAH-LRD OCT 3>1.5[3]
UA IAH-MAF OCT 6>3[6]
UA IAH-MCI OCT 5>3[5]
UA IAH-MCO OCT 6>3[6]
UA IAH-MEM OCT 6>3[6]
UA IAH-MEX OCT 6>3[6]
UA IAH-MFE OCT 7>3[7]
UA IAH-MIA OCT 4>3[4]
UA IAH-MID OCT 1.0>0[1.0]
UA IAH-MKE OCT 1.8>1.0[1.8]
UA IAH-MLM OCT 1.0>0[1.0]
UA IAH-MLU OCT 1.9>0.7[1.9]
UA IAH-MOB OCT 4>3[4]
UA IAH-MSP OCT 5>2[5]
UA IAH-MSY OCT 8>3[8]
UA IAH-MTY OCT 7>2.0[7]
UA IAH-MUC OCT 0.9>0[0.9]
UA IAH-NAS OCT 0.2>0[0.2]
UA IAH-NRT OCT 1.0>0[1.0]
UA IAH-OAX OCT 0.4>0[0.4]
UA IAH-OKC OCT 7>3[7]
UA IAH-OMA OCT 4>2[4]
UA IAH-ORD OCT 10>6[10]
UA IAH-ORF OCT 2>0[2]
UA IAH-PBC OCT 1.0>0.3[1.0]
UA IAH-PBI OCT 1.0>0[1.0]
UA IAH-PDX OCT 3>1.0[3]
UA IAH-PHL OCT 5>2.0[5]
UA IAH-PHX OCT 5>2[5]
UA IAH-PIT OCT 6>2[6]
UA IAH-PNS OCT 5>3[5]
UA IAH-POS OCT 1.0>0.5[1.0]
UA IAH-PSP OCT 0.6>0[0.6]
UA IAH-PTY OCT 3>0.3[3]
UA IAH-PVR OCT 1.4>2[1.4]
UA IAH-QRO OCT 4>2.0[4]
UA IAH-RDU OCT 4>2[4]
UA IAH-RIC OCT 3>0[3]
UA IAH-RNO OCT 1.0>0[1.0]
UA IAH-RSW OCT 2>1.0[2]
UA IAH-SAL OCT 2>1.0[2]
UA IAH-SAN OCT 5>2.0[5]
UA IAH-SAP OCT 1.2>2[1.2]
UA IAH-SAT OCT 7>3[7]
UA IAH-SAV OCT 2>1.0[2]
UA IAH-SCL OCT 0.3>0[0.3]
UA IAH-SDF OCT 4>1.0[4]
UA IAH-SEA OCT 5>2.0[5]
UA IAH-SFO OCT 9>5[9]
UA IAH-SGF OCT 2>0[2]
UA IAH-SHV OCT 4>1.6[4]
UA IAH-SJC OCT 2>1.0[2]
UA IAH-SJO OCT 2>1.0[2]
UA IAH-SLC OCT 5>2[5]
UA IAH-SLP OCT 2>1.0[2]
UA IAH-SMF OCT 3>1.0[3]
UA IAH-SNA OCT 4>2[4]
UA IAH-STL OCT 5>3[5]
UA IAH-STT OCT 0>0.6[0]
UA IAH-SYD OCT 0.3>0[0.3]
UA IAH-TAM OCT 1.0>0.5[1.0]
UA IAH-TPA OCT 5>2[5]
UA IAH-TUL OCT 6>3[6]
UA IAH-TUS OCT 3>1.0[3]
UA IAH-TYS OCT 4>3[4]
UA IAH-VER OCT 1.0>0.2[1.0]
UA IAH-VPS OCT 3>2[3]
UA IAH-XNA OCT 5>3[5]
UA IAH-YEG OCT 1.0>0[1.0]
UA IAH-YVR OCT 1.0>0[1.0]
UA IAH-YYC OCT 2>0[2]
UA IAH-YYZ OCT 3>0[3]
UA ICT-ORD OCT 4>1.9[4]
UA ILM-ORD OCT 2>0[2]
UA IND-ORD OCT 10>4[10]
UA IND-SFO OCT 1.8>0.7[1.8]
UA ITO-LAX OCT 1.0>0[1.0]
UA JAN-ORD OCT 1.0>0[1.0]
UA JAX-ORD OCT 3>2.0[3]
UA KIX-SFO OCT 0.3>0[0.3]
UA KOA-LAX OCT 1.2>0.5[1.2]
UA KOA-SFO OCT 2>1.7[2]
UA LAN-ORD OCT 3>1.6[3]
UA LAS-LAX OCT 5>3[5]
UA LAS-ORD OCT 5>3[5]
UA LAS-SFO OCT 9>4[9]
UA LAX-LHR OCT 0.3>0[0.3]
UA LAX-LIH OCT 1.2>0.5[1.2]
UA LAX-MCO OCT 2>0.7[2]
UA LAX-MEL OCT 0.3>0[0.3]
UA LAX-MFR OCT 2>0.7[2]
UA LAX-MRY OCT 5>0.7[5]
UA LAX-MSN OCT 1.0>0[1.0]
UA LAX-NRT OCT 0.3>0[0.3]
UA LAX-OGG OCT 2>0.7[2]
UA LAX-ORD OCT 10>5[10]
UA LAX-PHX OCT 4>1.7[4]
UA LAX-PVG OCT 0.3>0[0.3]
UA LAX-PVR OCT 0.0>0.3[0.0]
UA LAX-RDD OCT 1.0>0[1.0]
UA LAX-RDM OCT 1.0>0.7[1.0]
UA LAX-RNO OCT 3>1.9[3]
UA LAX-SAL OCT 0.7>0.3[0.7]
UA LAX-SAN OCT 4>1.7[4]
UA LAX-SAT OCT 1.8>0[1.8]
UA LAX-SBA OCT 3>0[3]
UA LAX-SBP OCT 3>1.0[3]
UA LAX-SFO OCT 12>5[12]
UA LAX-SJD OCT 1.0>0.3[1.0]
UA LAX-SLC OCT 1.8>1.0[1.8]
UA LAX-SMF OCT 3>0.7[3]
UA LAX-SYD OCT 0.6>0.4[0.6]
UA LAX-YVR OCT 1.0>0[1.0]
UA LEX-ORD OCT 4>1.6[4]
UA LGA-ORD OCT 14>4[14]
UA LHR-ORD OCT 3>1.0[3]
UA LHR-SFO OCT 1.3>1.0[1.3]
UA LIH-SFO OCT 2>1.0[2]
UA LIT-ORD OCT 4>1.5[4]
UA LNK-ORD OCT 5>3[5]
UA MBJ-ORD OCT 0.2>0[0.2]
UA MBS-ORD OCT 3>1.6[3]
UA MCI-ORD OCT 6>3[6]
UA MCI-SFO OCT 2>0[2]
UA MCO-ORD OCT 8>3[8]
UA MCO-SFO OCT 3>0.8[3]
UA MDT-ORD OCT 4>2.0[4]
UA MEM-ORD OCT 4>2[4]
UA MEX-ORD OCT 1.8>1.0[1.8]
UA MEX-SFO OCT 3>1.0[3]
UA MFR-SFO OCT 4>3[4]
UA MIA-ORD OCT 2>1.9[2]
UA MIA-SFO OCT 0.2>0[0.2]
UA MKE-ORD OCT 9>4[9] MAR 9>8[8]
UA MLI-ORD OCT 5>3[5]
UA MRY-SFO OCT 2>0[2]
UA MSN-ORD OCT 8>4[8]
UA MSN-SFO OCT 1.0>0[1.0]
UA MSP-ORD OCT 8>3[8]
UA MSP-SFO OCT 2>0.7[2]
UA MSY-ORD OCT 3>1.9[3]
UA MSY-SFO OCT 1.0>0[1.0]
UA MTJ-ORD OCT 0.2>0[0.2]
UA MTY-ORD OCT 2>0[2]
UA MUC-ORD OCT 1.0>0[1.0]
UA MUC-SFO OCT 1.0>0.5[1.0]
UA OGG-SFO OCT 4>2.0[4]
UA OKC-ORD OCT 4>1.5[4]
UA OKC-SFO OCT 1.0>0[1.0]
UA OMA-ORD OCT 5>3[5]
UA OMA-SFO OCT 2>0[2]
UA ONT-SFO OCT 6>2[6]
UA ORD-PBI OCT 2>0[2]
UA ORD-PDX OCT 4>1.0[4]
UA ORD-PEK OCT 0.3>0[0.3]
UA ORD-PHL OCT 6>3[6]
UA ORD-PHX OCT 5>3[5]
UA ORD-PIA OCT 5>3[5]
UA ORD-PIT OCT 7>2[7]
UA ORD-PNS OCT 1.0>0[1.0]
UA ORD-PSC OCT 1.0>0[1.0]
UA ORD-PSP OCT 0.2>0[0.2]
UA ORD-PUJ OCT 0.2>0[0.2]
UA ORD-PVD OCT 3>1.0[3]
UA ORD-PVG OCT 0.3>0[0.3]
UA ORD-PWM OCT 3>2.0[3]
UA ORD-RAP OCT 2>1.0[2]
UA ORD-RDM OCT 0.8>0[0.8]
UA ORD-RDU OCT 6>3[6]
UA ORD-RIC OCT 6>3[6]
UA ORD-RNO OCT 1.0>0[1.0]
UA ORD-ROA OCT 4>1.5[4]
UA ORD-ROC OCT 4>2.0[4]
UA ORD-RSW OCT 4>2.0[4]
UA ORD-SAN OCT 5>2[5]
UA ORD-SAT OCT 4>1.5[4]
UA ORD-SAV OCT 3>1.0[3]
UA ORD-SBA OCT 1.0>0[1.0]
UA ORD-SBN OCT 10>3[10]
UA ORD-SCE OCT 3>1.6[3]
UA ORD-SDF OCT 6>3[6]
UA ORD-SEA OCT 4>2.0[4]
UA ORD-SFO OCT 12>6[12]
UA ORD-SGF OCT 4>1.6[4]
UA ORD-SJC OCT 1.0>0[1.0]
UA ORD-SJD OCT 1.0>0.5[1.0]
UA ORD-SLC OCT 3>1.5[3]
UA ORD-SMF OCT 3>1.0[3]
UA ORD-SNA OCT 3>0.9[3]
UA ORD-SPI OCT 3>2.0[3]
UA ORD-SRQ OCT 2>1.6[2]
UA ORD-STL OCT 9>3[9] NOV 9>8[8] DEC 9>8[8] MAR 9>8[8]
UA ORD-SYR OCT 5>2.0[5]
UA ORD-TPA OCT 4>2.0[4]
UA ORD-TUL OCT 4>1.5[4]
UA ORD-TVC OCT 4>3[4]
UA ORD-TYS OCT 5>2.0[5]
UA ORD-XNA OCT 5>2[5]
UA ORD-YOW OCT 3>0[3]
UA ORD-YUL OCT 3>0[3]
UA ORD-YVR OCT 2>0[2]
UA ORD-YWG OCT 2>0[2]
UA ORD-YYC OCT 3>0[3]
UA ORD-YYZ OCT 6>1.5[6]
UA ORD-ZRH OCT 0.3>0[0.3]
UA PDX-SFO OCT 8>4[8]
UA PEK-SFO OCT 1.0>0[1.0]
UA PHL-SFO OCT 1.9>0[1.9]
UA PHX-SFO OCT 4>3[4]
UA PIT-SFO OCT 2>0[2]
UA PSC-SFO OCT 2>0[2]
UA PSP-SFO OCT 5>3[5]
UA PVG-SFO OCT 1.3>0[1.3]
UA PVR-SFO OCT 0.5>0.7[0.5]
UA RDD-SFO OCT 3>1.0[3]
UA RDM-SFO OCT 4>3[4]
UA RDU-SFO OCT 2>0[2]
UA RNO-SFO OCT 4>3[4]
UA SAN-SFO OCT 9>3[9]
UA SAT-SFO OCT 1.0>0[1.0]
UA SBA-SFO OCT 7>2[7]
UA SBP-SFO OCT 5>1.6[5]
UA SEA-SFO OCT 7>5[7]
UA SFO-SIN OCT 1.3>0[1.3]
UA SFO-SJD OCT 1.1>0.7[1.1]
UA SFO-SLC OCT 5>3[5]
UA SFO-SMF OCT 5>3[5]
UA SFO-SNA OCT 7>2[7]
UA SFO-STL OCT 1.0>0[1.0]
UA SFO-STS OCT 1.0>0.7[1.0]
UA SFO-TPA OCT 2>0[2]
UA SFO-TPE OCT 1.0>0[1.0]
UA SFO-TUS OCT 4>1.6[4]
UA SFO-XNA OCT 1.0>0[1.0]
UA SFO-YVR OCT 4>1.7[4]
UA SFO-YYC OCT 2>0[2]
UA SFO-YYZ OCT 2>0[2]
UA SFO-ZRH OCT 0.6>0[0.6]
UP FLL-FPO OCT 1.7>0.1[1.7] NOV 1.7>0.4[1.7] DEC 1.7>1.1[0.8] FEB 1.7>0[1.8] MAR 1.6>0.3[0.7] MAY 1.7>0.3[0.9]
UP FLL-NAS OCT 3>2[3] NOV 3>2[3] DEC 4>3[4] FEB 4>3[3] MAR 4>2[2] MAY 4>2[4]
UP MCO-NAS NOV 1.2>0.6[1.0] DEC 1.7>0.3[1.3] FEB 1.7>0.4[1.1] MAR 1.7>0.3[0.7] MAY 1.7>0.5[1.5]
UP MHH-PBI OCT 0.9>0[0.9] NOV 0.9>0[0.9] DEC 0.8>0.2[0.4] FEB 0.9>0[0.9] MAR 0.8>0[0.5] MAY 0.9>0.2[0.8]
UP MIA-NAS FEB 3>0.7[2] MAR 3>0.5[2] MAY 3>1.2[3]
V8 ANC-ILI OCT 1.9>0[1.9]
V8 ILI-KNK OCT 0.2>0[0.2] NOV 0.2>0[0.2] DEC 0.2>0[0.2] JAN 0.2>0[0.2] FEB 0.2>0[0.2] MAR 0.2>0[0.2] APR 0.2>0[0.2] MAY 0.2>0[0.2] JUN 0.2>0[0.2]
V8 ILI-NNL OCT 0.2>0[0.2] NOV 0.2>0[0.2] DEC 0.2>0[0.2] JAN 0.2>0[0.2] FEB 0.2>0[0.2] MAR 0.2>0[0.2] APR 0.2>0[0.2] MAY 0.2>0[0.2] JUN 0.2>0[0.2]
V8 ILI-PDB OCT 0.2>0[0.2] NOV 0.2>0[0.2] DEC 0.2>0[0.2] JAN 0.2>0[0.2] FEB 0.2>0[0.2] MAR 0.2>0[0.2] APR 0.2>0[0.2] MAY 0.2>0[0.2] JUN 0.2>0[0.2]
V8 ILI-PTA OCT 0.2>0[0.2] NOV 0.2>0[0.2] DEC 0.2>0[0.2] JAN 0.2>0[0.2] FEB 0.2>0[0.2] MAR 0.2>0[0.2] APR 0.2>0[0.2] MAY 0.2>0[0.2] JUN 0.2>0[0.2]
V8 KNK-PDB OCT 0.2>0[0.2] NOV 0.2>0[0.2] DEC 0.2>0[0.2] JAN 0.2>0[0.2] FEB 0.2>0[0.2] MAR 0.2>0[0.2] APR 0.2>0[0.2] MAY 0.2>0[0.2] JUN 0.2>0[0.2]
V8 NNL-PTA OCT 0.2>0[0.2] NOV 0.2>0[0.2] DEC 0.2>0[0.2] JAN 0.2>0[0.2] FEB 0.2>0[0.2] MAR 0.2>0[0.2] APR 0.2>0[0.2] MAY 0.2>0[0.2] JUN 0.2>0[0.2]
VW LRD-MEX OCT 0.4>0.2[0.4]
WN ATL-MEM OCT 2>3[2]
WN BOI-LAS OCT 2>3[2]
WN BUR-LAS NOV 8>7[10]
WN BUR-OAK NOV 9>8[13]
WN BUR-SJC NOV 8>7[11]
WN BUR-SMF NOV 8>7[11]
WN BWI-FLL NOV 10>9[8]
WN BWI-MCO NOV 11>10[8]
WN BWI-TPA OCT 5>6[5]
WN CLT-MDW OCT 1.0>1.6[1.0]
WN CMH-MDW OCT 1.9>2[1.9]
WN DAL-HOU NOV 17>15[19] FEB 15>14[20] MAR 15>14[18]
WN DEN-DSM OCT 1.0>1.5[1.0]
WN DEN-PHX NOV 11>10[11]
WN DEN-RNO OCT 2>3[2]
WN DEN-TUS OCT 2>3[2]
WN LAS-SLC OCT 2>3[2]
WN LAX-PHX NOV 8>7[8]
WN LAX-SFO NOV 6>5[8]
WN MDW-MHT OCT 1.0>1.5[1.0]
WN MDW-ORF OCT 0>0.5[0]
WN MDW-PIT OCT 1.0>1.5[1.0]
WN PHX-SJD OCT 0.8>1.0[0.8]
WN SAN-SJC NOV 11>9[15]
WN SAN-SMF NOV 10>9[15]
WN SJC-SNA NOV 7>6[10]
WO LAS-YYZ NOV 0>0.3[0] DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.5[0] MAR 0>0.5[0] APR 0>0.5[0]
WO MCO-YYZ DEC 0>0.3[0] JAN 0>0.6[0] FEB 0>0.7[0] MAR 0>0.7[0] APR 0>0.6[0]
WO TPA-YYZ JAN 0>0.3[0] FEB 0>0.5[0] MAR 0>0.5[0] APR 0>0.5[0]
WS MCO-YYZ OCT 1.7>1.3[1.7]
YR BLD-GCW OCT 0.7>0[0.7] FEB 1.0>0[1.1] MAR 0.4>0[0.9]
Z3 AKN-EGX OCT 0.6>0[0.6] NOV 0.6>0[0] DEC 0.7>0[0] JAN 0.6>0[0] FEB 0.6>0[0] MAR 0.7>0[0] APR 0.7>0[0] MAY 0.6>0[0.4] JUN 0.7>0[0.4]
Z3 AKN-IGG OCT 0.6>0[0.6] NOV 0.6>0[0] DEC 0.6>0[0] JAN 0.5>0[0] FEB 0.6>0[0.8] MAR 0.6>0[0.6] APR 0.6>0[0.7] MAY 0.5>0[0.4] JUN 0.6>0[0.4]
Z3 CLP-DLG OCT 0.4>0[0.4] NOV 0.4>0[0.4] DEC 0.4>0[0.4] JAN 0.4>0[0.4] FEB 0.4>0[0.5] MAR 0.5>0[0.4] APR 0.4>0[0.4] MAY 0.4>0[0.4] JUN 0.4>0[0.4]
Z3 DLG-KEK OCT 1.4>0[1.4] NOV 1.4>0[1.5] DEC 1.5>0[1.4] JAN 1.4>0[1.4] FEB 1.4>0[1.6] MAR 1.5>0[1.3] APR 1.5>0[1.5] MAY 1.4>0[1.4] JUN 1.5>0[1.4]
Z3 DLG-KGK OCT 1.4>0[1.4] NOV 1.4>0[1.5] DEC 1.5>0[1.4] JAN 1.4>0[1.4] FEB 1.4>0[1.6] MAR 1.5>0[1.3] APR 1.5>0[1.5] MAY 1.4>0[1.4] JUN 1.5>0[1.4]
Z3 DLG-KMO OCT 1.4>0[1.4] NOV 1.4>0[1.5] DEC 1.5>0[1.4] JAN 1.4>0[1.4] FEB 1.4>0[1.6] MAR 1.5>0[1.3] APR 1.5>0[1.5] MAY 1.4>0[1.4] JUN 1.5>0[1.4]
Z3 DLG-KNW OCT 1.4>0[1.4] NOV 1.4>0[1.5] DEC 1.5>0[1.4] JAN 1.4>0[1.4] FEB 1.4>0[1.6] MAR 1.5>0[1.3] APR 1.5>0[1.5] MAY 1.4>0[1.4] JUN 1.5>0[1.4]
enilria
Re: OAG 9/8/2020:OH THE HUMANITY;AA+DAB-DFW/PHL;AM Cuts;DL+LAXSAL,Suspends PVG?;NK Exits IAG/PBG/GSO?;UA Suspends ITH/MH
Tue Sep 08, 2020 2:17 pm
I think we are really starting to see the post-CARES station closures as I suspected back in April. Unlike AA, most carriers are going to do this in the dark of the night highlighted only on a.net. I expect much more.
enilria
Tue Sep 08, 2020 2:20 pm
I have to assume this is an error or re-addition of a tech stop. They would have way too much egg on their face with DOT to suspend PVG after getting DOT to risk inflaming things further with China to get them back in.
Ishrion
Tue Sep 08, 2020 2:21 pm
That's likely, although PHL-MAD/LHR are still available from October 24 while AMS/DUB were switched to DFW for the winter.
If PHL doesn't receive funneling status soon, AA may gradually delay the resumption of PHL-MAD/LHR as well.
usairways85
Tue Sep 08, 2020 2:49 pm
Yes, that is very likely the reason.
Yet, AA has flown PHL-AMS for cargo the past month and will increase to daily this week. AA will also restart PHL-DUB (3x weekly) cargo only flights this week.
ScottB
Tue Sep 08, 2020 2:54 pm
IAG & PBG are reliant on Canadians crossing the border to avoid all the taxes on transborder travel; it makes sense that NK would suspend these markets until the Canadian government lifts the requirement for 14-day isolation or quarantine for returning Canadians.
I have to imagine they're seeing even more weakness in point-to-point routes which are virtually all vacation travel within a single day's drive.
panamair
Tue Sep 08, 2020 2:59 pm
They are not suspending PVG; it’s a continuation of their current practice of stopping at ICN for a crew change, hence why you see a corresponding increase in ICN-DTW and ICN-SEA service.
MIflyer12
Tue Sep 08, 2020 3:03 pm
IMHO, more interesting than the October cuts (heavy by UA/AA/NK) are the November/December and beyond cuts.
drdisque
Tue Sep 08, 2020 3:10 pm
UA leaving LAN and AZO in the schedule for October after cuts when everyone on here said they wouldn't be coming back.
Stations UA is cutting indef. starting OCT: HOB, MHT, ITH, much smaller list than AA.
UA may get held into HOB or maybe they will negotiate with 4B or AN to take over the station.
enilria
Tue Sep 08, 2020 3:17 pm
Wasn't it supposed to go daily? Why would they do a tech stop on a daily flight? Wasn't the issue crew not be stranded for many days?
Agreed. Post-CARES we are starting to see the new steady state.
I'm not so sure this is a final list. I expect we will see a lot more stations go.
panamair
Tue Sep 08, 2020 3:25 pm
I believe they have always been aiming to resume PVG at daily from both DTW and SEA but are currently limited by China’s capacity caps which only allow 4x weekly each for DL and UA. DL chose to split their 4x weekly PVG by 2x to DTW and 2x to SEA while UA is putting all of their 4x weekly into the SFO gateway
freakyrat
Tue Sep 08, 2020 3:43 pm
UA SBN-ORD OCT 10>3[10] Here is the deal for UA in October at SBN: Monday and Friday 4 flights, Tuesday, Wednesday and Saturday 2 flights, Thursday and Sunday 3 flights.
fiddlerkrt
Tue Sep 08, 2020 3:52 pm
Thanks, enilria, for all this hard work. Hard to take in everything each week!
I doubt AA will be flying LAX-SYD anytime soon. SYD is currently capped at 350 international arrivals a day and the restrictions on international travel are very strict.
Ishrion
Tue Sep 08, 2020 4:01 pm
AA's already operating daily cargo-only LAX-SYD flights on the 777-300ER. Might as well add some passenger revenue to the flight despite the cap.
fiddlerkrt
Tue Sep 08, 2020 4:20 pm
That makes sense to me. Isn't UA doing something similar to LAX and SFO from SYD?
FlyingElvii
Tue Sep 08, 2020 4:23 pm
Boutique regarding BNA.
There was just a local article a week or so ago about Boutique restarting Greenville and MSL from Nashville. What happened???
SteveXC500
Tue Sep 08, 2020 4:28 pm
It is interesting, but now it's also $2,000 RT for Main Cabin in March (on Saturday). Sad.
jb1087xna
Tue Sep 08, 2020 4:38 pm
Thanks as always for your work in compiling this!
Not a UA flier by any means but, IMHO, smart to bring this back. DL has my loyalty but since they haven't resumed MSP yet, and haven't connected us to SLC for roughly 10 years now, they're making it a bit of a pain to get out west.
VS4ever
Tue Sep 08, 2020 4:39 pm
Airlineroute seems to concur with that theory of adding pax revenue.
https://www.routesonline.com/news/38/ai ... -nov-2020/
That feeling when you sit at the end of a runway, brakes are released and the raw power takes over. Now that is a thing of beauty and it never gets old.
TonyClifton
Tue Sep 08, 2020 4:44 pm
Looks like a daily freq increase on DTW-CUN as a slight offset. Pushing connections through Detroit instead?
Nicknuzzii
Tue Sep 08, 2020 4:45 pm
Nice to see AI add EWR-DEL. Is AI still flying to JFK?
MIflyer12
Tue Sep 08, 2020 4:46 pm
It's way too early to buy international travel for March - for more than a few reasons. But, anyone feeling compelled to buy MSP-CUN, Sun Country will do it for less.
Chuska
Tue Sep 08, 2020 4:54 pm
UA still has HOB-IAH, not leaving HOB. HOB-DEN was a second route for HOB that just started less than a year ago, good to see that there is some light somewhere in the tunnel as HOB-DEN is showing a return in Feb. [0.6]
Chuska
Tue Sep 08, 2020 5:14 pm
These are all misfiles for Advanced Air. They are having a schedule change in October but these three routes are still operating. I don't think the Boutique Air (4B) changes are showing correctly either.
jayunited
Tue Sep 08, 2020 5:17 pm
I think it is probably a misfile but at the same time the stop at ICN is a tech stop. DL's PVG flights operate with a different flight number than their ICN flights there are no passengers disembarking boarding their PVG flights at ICN. I don't see DL suspending SEA/DTW-PVG they along with UA fought to hard to have those flights reinstated. However, LAX-PVG probably won't happen any time soon on either carrier because for now both DL and UA can only operate 4x weekly flights to China. And now with China requiring all US citizens to present a negative COVID test prior to boarding their outbound flight to China I'm going to go out on a limb and say it will be a while before any US carrier seeks to add additional frequencies to China.
ua900
Tue Sep 08, 2020 5:23 pm
:checkmark: :checkmark: :checkmark:
As always, thanks for the list. Was hoping to fly into TXL on UA one last time but alas.
If you're married to DL flying, it can be had on DL in Business during that timeframe for $1,200 RT ($1,500 if you don't want overnight) fwiw.
If you can stomach Sun Country, that starts at $372 RT, AA at $428 RT and UA around $550 RT.
2020: AMS | BRU | DEN | DFW | EWR | FRA | GUA | IAH | LAX | LIM | MCO | MUC | ORD | PTY | SAL | SCL | SFO | TXL
Dominion301
Tue Sep 08, 2020 5:46 pm
Exactly. 80% of the pax on those flights are us Canadians. I expect IAG and PBG are suspensions as opposed to complete market withdrawals. The border restrictions are probably going to extend well into 2021 at the earliest.
Case in point for PD as this didn't make the OAG report in time: Porter have just announced they're now extending their full network suspension to November 12th.
https://www.newswire.ca/news-releases/p ... 02108.html
On the flip side, UA are showing 0.6 for YOW-IAD in October. Given this appears to be their October adjustments, it appears this will be YOW's first transborder ops for the first time since mid-June.
Thanks enilria as usual.
madpropsyo
That's one weird route.
CPS001
Tue Sep 08, 2020 5:50 pm
Yeah DEL-JFK and BOM-EWR are the NYC flights as of now.
Dominion301
For all the ridicule with BER's delays and now the place would be over capacity from day 1, now thanks to the delays/gong show, ironically BER will open way, way under capacity.
350 a day? Don't you mean a week?
HNLSLCPDX
Tue Sep 08, 2020 5:52 pm
Does this put both AM and DL on the GDL-SLC route going forward?
LotsaRunway
Tue Sep 08, 2020 5:57 pm
Thanks again for the weekly listing, even if it is depressing. Is it any more difficult for you to do these on a weekday?
Re-purposing close-in flights? I wonder if they are really hoping for decent loads with limited advanced booking time. If some are re-adds after the last round of cuts, wouldn't they have already accommodated passengers?
enilria
Tue Sep 08, 2020 6:03 pm
Interesting
I didn't realize the limit is airline specific. I thought route specific. Are the Chinese carriers also limited on an airline basis?
No idea. Could be a filing issue.
Seems like old times
I always ask. New equipment type perhaps?
So it sounds like it isn't a misfile. I think they had filed the service to switch back to nonstop and that's not happening, so the nonstops disappear and the tags are added which we don't see since thy don't touch the USA.
Yellowstone is the one place doing better now than before.
I doubt airlines want 350 per day.
Here are the busiest airports in the world for September...grain of salt, some airlines (Air Asia I'm looking at you) probably aren't filing their actual schedule...
ATL 523 dpt/day
CGK 498
DFW 481
ORD 450
CAN 440
DEN 415
CTU 379
KMG 376
SZX 368
CLT 366
PEK 353
madpropsyo
Tue Sep 08, 2020 6:19 pm
Yeah it makes sense for the summer but DEC/JAN is tough. I suppose there must be more skiing traffic out of BNA than you'd think.
ScottB
Tue Sep 08, 2020 6:27 pm
No he means a day. That number is the count of arriving passengers not flights. The source I could find showed a limit of 450, though.
https://www.smh.com.au/national/federal ... 55901.html
EDIT: The number of 350 is correct, of course, based on the statement from the Australian PM's office:
https://www.pm.gov.au/media/national-cabinet-7aug2020
IAHWorldflyer
Tue Sep 08, 2020 7:09 pm
UA took a butcher knife to the October schedule this weekend. EWR was really diced. 4x a day EWR-LAX! 4x a day EWR-IAH, and 2x a day to LAS. That's limping the hub along.
It kinda makes me mad that they have a full compliment of flights for sale in November ( 12/day EWR-LAX), but will likely cut those back in 4 weeks. They have no intention of running the full schedule, yet it is loaded and for sale, until it isn't anymore.
Nicknuzzii
Tue Sep 08, 2020 7:11 pm
I believe for some reason the OAG made EWR look a lot worse than what it’s actually planned to be. As of now EWR should have about 170 flights on peak days in October.
SteveXC500
Tue Sep 08, 2020 7:17 pm
Not sure I'd say it's way too early. I've bought Cancun out of MSP, six months out. It's spring break and we travel well for it. When I've bought, it's almost never gone down in price either.
panamair
Tue Sep 08, 2020 8:59 pm
Sorry didn’t mean to imply that China set the capacity cap for specific US airlines. Earlier this summer, China first allowed the US side only 4 weekly flights in total; UA and DL were the only two which expressed an interest to restart China flights so the DOT divided it equally between the two. Later in August, China allowed this to double to 8 weekly flights....again, since the only two candidates were UA and DL, each one then got a total of 4x weekly flights (2 new weekly flights in addition to the 2x weekly from the first round). The Chinese carriers are now limited to 8x weekly flights as well; the Chinese government decided how to allocate those limited weekly flights across the Chinese carriers.
FlyingElvii
Tue Sep 08, 2020 9:03 pm
Given all of the big money movement into the Nashville area by people fleeing from both coasts over the last 4 years, it is not that weird....
panamair
Tue Sep 08, 2020 9:05 pm
Sorry if I wasn’t clear...When I said the “corresponding increase in ICN-DTW and ICN-SEA”, I was referring to what is showing in the OAG changes above. It isn’t actually new capacity that can be booked for the local ICN-DTW or ICN-SEA segments, since as you said, the ICN stop is purely a tech stop on these two routes.
fiddlerkrt
Tue Sep 08, 2020 9:37 pm
Yes that's right, 350 international passengers per day since 14-day hotel quarantine is mandatory. MEL is not accepting any international passengers since the source of infections for the most recent wave was traced back to a breach in hotel quarantine. There is no limit on departing passengers but Australian citizens are currently banned from travelling overseas unless they receive an exemption from the government.
jonair8
Tue Sep 08, 2020 10:04 pm
Thanks again for the thread this week. It's a pleasure to look at, even if there are sad, deep deep cuts in it.
DL actually had me worried because originally this was bookable only for October. Glad to see it's not seasonal or just a one off thing now. AS definitely responded already, and it was needed, because AS usually downgrades this from 3 737s to 2 E75s during winter, which is too small. Good luck to both, and for once something is growing in the IE.
Sad to see how much UA is cutting SFO next month. Don't know numbers wise if this is more or less than any other hubs as far as flights flown or seats offered for the month especially since it relies a lot on Asia, but they're making SFO a hard hub to use for domestic west coast stuff, especially their (once) large CR2 operation.
drdisque
Tue Sep 08, 2020 10:18 pm
Yes, they're leaning on DEN a lot more for West to West flows since it also works for East-West which SFO doesn't.
ericm2031
Tue Sep 08, 2020 11:27 pm
It's probably about the same as what they are flying right now, maybe more. It just looks bad as it is a cut from the previously published full flight schedule.
Dominion301
Wed Sep 09, 2020 2:39 am
Thanks, that makes a lot more sense. Even 350 flights/week / 2 = 175 inboud = 25 / day, which in this environment would be ridiculous.
many321
Wed Sep 09, 2020 4:13 am
Glad to see DL after pulling out last summer (2019), they've quickly come back since many in the Salvadoran community in the LA area weren't keen with Avianca or Q6 since their service is lackluster and that's been charitable.
Knowing that UA is also starting their LAX -SAL flights lets see who wins this battle.
DaCubbyBearBar
Wed Sep 09, 2020 8:39 am
THANK YOU for providing us with all the information to see it .... OCTOBER IS A MASSACRE
I am me and no one else...so my opinions are mine
aerace
Wed Sep 09, 2020 11:56 am
Not sure if this is a filing error, but AA is showing daily for PHL through April. Seems quite off-brand at the moment if AA is reducing winter Florida service from the northeast.
EA CO AS
Wed Sep 09, 2020 6:23 pm
LAXCUN has always been a difficult market; many have tried it, most have done poorly. The yields aren't great, and most west coast travelers go to either Hawaii or SJD/PVR/MZT. CUN is generally a big draw for the east coast/midwest.
