ERAUMBA wrote:The article states that the alerting system being out of service did not impact the Atlas Air emergency landing. It must be a slow news day in Honolulu.
kalvado wrote:ERAUMBA wrote:The article states that the alerting system being out of service did not impact the Atlas Air emergency landing. It must be a slow news day in Honolulu.
It didn't impact Atlas event because there was no accident requiring actual massive emergency response. Which is not an excuse at all.
Antarius wrote:ERAUMBA wrote:The article states that the alerting system being out of service did not impact the Atlas Air emergency landing. It must be a slow news day in Honolulu.
That's because the Atlas landing ended up being a non-issue. As in, the aircraft came back and landed successfully.
Had the aircraft overshot the runway or had its gear collapse or <insert possible outcome of emergency>, this could have been a much more serious issue.
ERAUMBA wrote:Antarius wrote:ERAUMBA wrote:The article states that the alerting system being out of service did not impact the Atlas Air emergency landing. It must be a slow news day in Honolulu.
How?
I am interested to hear your explanation.
As someone that was based in HNL for nearly five years as a widebody F/O, I am familiar with the combined Military/Civil airport infrastructure you speak of.
Are you insinuating that an aircraft could crash there and no one would know? Or are you inferring that there’s no other way of communication from the tower cab other than the the radio frequencies??
I have never been in a tower cab that does not have multiple phone lines, local airport authority radio, and, at minimum, a cellular telephone.
Again, a non-issue, even as reported by the local news. An otherwise slow news day on the island.
How?
The primary crash network allows everyone on the federal level to be notified at one time, including the FAA tower, Hickam tower and airfield, the Joint Dispatch Center and Aircraft Rescue and Firefighting.
Because the system has been down, each agency has to be called one by one — using a landline.
Aviation expert Peter Forman said that alone is going to cause a delay.
And those wasted minutes “could be the difference between life and death so that’s really important.”
The secondary crash network is a separate system to notify all state level responders: Airport medical staff, the Sheriffs Division, and the airport duty manager, to name a few. Sources say it took multiple attempts before it worked.
How?
