enilria
OAG Changes 9/15/2020:AI Adds DELEWR,Cuts DELORD;DL Adds Winter LAXRNO;EK Suspends MCO;FI/KL/UA Suspend Long Haul Routes
Tue Sep 15, 2020 2:03 pm
FAQ
SOURCE: OAG
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
2E HOM-KEB NOV 0.5>0[0] APR 0.5>0[0.5] JUN 0.5>0[0.5]
2E HOM-SOV NOV 0.5>0[7] APR 0.5>0[0.5] JUN 0.5>0[0.5]
2E KEB-PGM NOV 0.5>0[0] APR 0.5>0[0.5] JUN 0.5>0[0.5]
2E PGM-SOV NOV 0.5>0[0] APR 0.5>0[0.5] JUN 0.5>0[0.5]
4B ABQ-CNM DEC 0.7>0[1.6]
4B ATL-MSL NOV 1.5>1.1[4] DEC 0.7>0[3]
4B BNA-GLH JAN 0>0.4[0]
4B BNA-MSL DEC 1.4>0.4[0]
4B BOS-MSS NOV 2>0[3] FEB 0>2[3]
4B CDR-DEN NOV 0.7>0[2] DEC 0>0.4[1.7] JAN 0>0.5[2]
4B CEZ-DEN NOV 0.7>0[3] DEC 0>0.8[3] JAN 0>1.8[3]
4B CEZ-PHX JAN 0>0.8[1.0]
4B CNM-DFW NOV 0.8>0.4[1.0]
4B DEN-MCK DEC 1.1>0.8[1.6] JAN 0>1.3[2]
4B DFW-GLH JAN 0>1.3[2]
4B IAH-VCT OCT 1.5>0.8[2]
4B IWD-MSP DEC 0.7>0[0]
4B IWD-ORD DEC 1.1>0.4[0] JAN 0>0.8[0]
4B LAX-MCE NOV 1.1>0[3]
4B LAX-PSP OCT 0>1.0[0]
4B MCE-SMF NOV 0.7>0[1.4]
4B PDT-PDX DEC 1.1>0.4[3]
4B PHX-PSP OCT 0>1.0[0]
4B PHX-SOW OCT 0.9>2[1.0] NOV 0.4>0[3]
8E OME-UNK JAN 0.8>0[0.9] FEB 0.9>0[1.0]
8E OME-WBB JAN 0.8>0[0.9] FEB 0.9>0[1.0]
8E SMK-UNK JAN 1.2>0.4[1.3] FEB 1.3>0.4[1.5]
8E SMK-WBB JAN 1.2>0.4[1.3] FEB 1.3>0.4[1.5]
9K ACK-BOS OCT 1.5>0[6]
9K ACK-EWB DEC 0.6>0[2] MAR 0.6>0[0.8] APR 0.6>0[0.9]
9K ACK-HYA OCT 3>1.0[8]
9K ACK-MVY OCT 1.2>0[1.3]
9K AUG-BOS OCT 1.7>0[3]
9K BHB-BOS OCT 1.2>0[2]
9K BOS-HYA OCT 0.6>0[1.0]
9K BOS-LEB OCT 0.6>0[4]
9K BOS-MVY OCT 0.3>0[4]
9K BOS-PVC OCT 0.3>0[3] APR 1.7>1.2[3]
9K BOS-RKD OCT 1.7>0[3]
9K BOS-SLK OCT 1.7>0[3]
9K HPN-LEB OCT 0.3>0[2] DEC 1.5>1.2[1.9]
9K IRK-STL OCT 0.6>0[3] APR 2>0.8[3]
9K JFK-MVY OCT 0.6>0[0.6]
9X HNL-JHM JAN 0>2[3] FEB 0>2[3]
9X HNL-LNY JAN 0>1.7[0] FEB 0>1.7[0]
9X HNL-MKK JAN 0>11[0.0] FEB 0>11[0]
9X HNM-OGG JAN 0>2[0] FEB 0>2[0]
9X KOA-OGG JAN 0>6[0] FEB 0>6[0]
9X LNY-OGG JAN 0>3[0] FEB 0>3[0]
9X LUP-MKK JAN 0>2[0] FEB 0>2[0]
9X MKK-OGG JAN 0>9[0] FEB 0>9[0]
9X MUE-OGG JAN 0>2[0] FEB 0>2[0]
AA ABE-ORD NOV 1.5>1.0[2] JAN 2>1.5[1.5]
AA ABQ-DFW OCT 5>4[6]
AA ABQ-LAX NOV 1.6>2[3] JAN 3>2[3]
AA AGU-DFW OCT 1.9>1.0[1.9]
AA ALO-ORD OCT 0.8>0.4[0.8]
*AA ANC-LAX JUN 0.9>0[0]
AA ART-PHL OCT 0.6>0.4[1.7]
AA ASE-DFW JAN 4>5[2] FEB 4>5[3] MAR 4>5[3]
AA ASE-LAX DEC 1.0>0.5[0]
AA ASE-ORD DEC 1.0>1.5[0] JAN 1.0>2[0.5] FEB 1.1>2[1.1] MAR 1.0>2[1.0]
AA ASE-PHX DEC 0.5>1.0[0] JAN 1.0>2[0.5] FEB 1.0>2[1.1] MAR 1.0>2[0.9]
AA ATL-ORD OCT 1.9>1.0[2]
AA AZO-ORD OCT 0.6>0.4[0.8]
AA BDL-ORD OCT 1.9>1.4[2]
AA BGR-CLT NOV 1.0>1.9[1.0] DEC 1.0>1.5[0.6]
AA BHM-DFW OCT 4>3[4]
AA BHM-ORD OCT 0.6>0.4[0.8]
AA BMI-ORD OCT 0.6>0.1[0.8]
AA BNA-ORD OCT 1.8>0.9[3]
AA BTR-DFW JAN 7>6[5]
AA BUF-ORD OCT 1.7>1.2[2] MAR 3>2[3]
AA BWI-ORD OCT 1.1>0.6[1.5]
AA CAE-DFW OCT 2.0>1.0[2.0]
AA CID-ORD OCT 1.4>1.1[2.0]
AA CLE-JFK JAN 2>1.6[0.4]
AA CLE-ORD OCT 1.5>0.7[2]
AA CLL-DFW DEC 1.1>0.9[4] JAN 4>2[3]
AA CLT-RAP NOV 0.1>1.0[0.3]
AA CMH-ORD OCT 1.7>0.8[2]
AA CRP-DFW JAN 8>7[7]
AA CVG-DFW OCT 3>2[4]
AA CVG-ORD OCT 1.7>0.8[2]
AA DAY-DFW OCT 3>2[3]
AA DAY-ORD OCT 0.7>0.1[1.1] NOV 3>2[5] JAN 4>3[4]
AA DBQ-ORD OCT 0.9>0.7[1.1]
AA DEN-LAX NOV 1.9>2[3]
AA DFW-ELP OCT 5>4[6]
AA DFW-EVV OCT 1.4>0.6[2]
AA DFW-EYW JAN 1.1>2[1.4] FEB 1.0>2[1.4] MAR 1.0>2[1.1] APR 1.0>2[1.2] MAY 1.0>2[1.1] JUN 1.0>2[0.2]
AA DFW-GDL OCT 1.9>1.4[1.9]
AA DFW-GPT NOV 0.9>1.3[3] JAN 3>2[3]
AA DFW-GRK JAN 7>6[6]
AA DFW-GSO OCT 1.6>0.9[1.9]
AA DFW-GSP OCT 1.5>0.6[1.9]
AA DFW-HOU OCT 3>1.9[4] JAN 9>8[7]
AA DFW-HSV OCT 3>1.9[4]
AA DFW-IAH OCT 4>3[6]
AA DFW-ICT OCT 4>2[4]
AA DFW-LBB JAN 8>7[7]
AA DFW-LEX OCT 2>1.4[2]
AA DFW-LIT OCT 5>4[6]
AA DFW-MAF JAN 8>7[7]
AA DFW-MEM OCT 5>3[6]
AA DFW-MSY OCT 5>3[6]
AA DFW-MTY OCT 4>1.9[4]
AA DFW-OKC OCT 5>3[6]
AA DFW-ORF OCT 1.9>1.4[2.0]
AA DFW-PNS OCT 5>4[6]
AA DFW-QRO OCT 1.0>0.6[1.0]
AA DFW-SDF OCT 4>3[4]
AA DFW-SJT JAN 6>5[5]
AA DFW-SRQ JAN 1.2>2[1.9] FEB 1.0>2[1.3] MAR 1.0>2[0.9] APR 1.0>2[1.2] MAY 1.0>2[1.1] JUN 1.0>2[1.0]
AA DFW-TYS OCT 3>1.8[3]
AA DFW-XNA OCT 5>4[6]
AA DFW-YUM NOV 1.0>1.9[1.0] DEC 1.0>2[1.0] JAN 1.0>2[1.9] FEB 1.0>2[1.3] MAR 1.0>2[0.9]
AA DFW-ZCL JAN 0.3>0.1[0.5]
AA DSM-ORD OCT 1.4>0.3[2]
AA DTW-ORD OCT 1.8>0.7[3]
AA ELP-PHX JAN 5>4[5]
AA EWR-ORD OCT 1.5>1.2[2.0]
AA FNT-ORD OCT 0.9>0.4[1.2]
AA FSD-ORD OCT 0.8>0.5[2]
AA GRR-ORD OCT 1.8>1.5[2] NOV 7>6[8]
AA GSO-ORD OCT 0.5>0.3[0.8]
AA IAH-ORD OCT 0.9>0.7[1.2]
AA ICT-ORD OCT 1.0>0.6[1.2]
AA IND-ORD OCT 1.7>1.0[3]
AA LAN-ORD OCT 1.4>1.0[1.6]
AA LAX-PDX NOV 1.7>2[3] JAN 3>1.7[3]
AA LAX-SEA OCT 2>3[4] JAN 4>2[4]
AA LAX-SFO APR 8>7[8]
AA LAX-SJC JAN 6>5[5] APR 5>4[6]
AA LAX-SLC OCT 0.9>0.3[1.0] NOV 2>3[3] JAN 4>3[3]
AA LAX-SMF APR 4>3[4]
AA LAX-TUS JAN 3>2[3] APR 3>2[3]
AA LEX-ORD OCT 0.8>0.2[1.0] JAN 3>2[3]
AA LGB-PHX OCT 1.1>0.6[2.0] NOV 2.0>1.5[3] DEC 2>1.7[3] JAN 3>2[3] FEB 2>1.6[3] APR 3>2[3]
AA LSE-ORD OCT 1.5>1.0[2]
AA MCI-ORD OCT 1.7>1.1[2]
AA MDT-ORD OCT 0.9>0.4[1.5]
AA MEM-ORD OCT 0.5>0.2[1.2] NOV 2>2.0[5] JAN 5>4[4] MAR 2>1.7[3] APR 5>4[3]
AA MIA-RTB NOV 0.2>0.4[0.3] FEB 0.5>1.0[0.3] MAR 0.2>1.0[0.3] APR 0.3>1.0[0.3] MAY 0.3>1.0[0] JUN 0.3>1.0[0]
AA MKE-ORD OCT 1.3>0.7[2]
AA MLI-ORD OCT 0.8>0.3[1.4] NOV 2>1.8[4] JAN 4>2[3]
AA MSN-ORD OCT 1.3>0.6[1.8]
AA MSN-PHL JAN 2>0.9[1.8]
AA MSP-ORD OCT 1.3>0.2[2]
AA MSY-ORD OCT 1.2>1.0[1.5]
AA OMA-ORD OCT 1.4>0.8[2] JAN 6>5[5]
AA ORD-PIA OCT 1.4>0.7[1.6]
AA ORD-PIT OCT 1.4>0.9[2]
AA ORD-PVD MAR 2>1.5[1.7]
AA ORD-RDU OCT 1.8>1.3[2]
AA ORD-RIC OCT 0.9>0.4[1.4]
AA ORD-ROC OCT 0.9>0.5[1.0]
AA ORD-SDF OCT 0.8>0.6[1.1]
AA ORD-STL OCT 1.8>1.0[2]
AA ORD-TOL JAN 3>2[3]
AA ORD-TUL OCT 0.6>0.4[1.0] JAN 2>1.4[3]
AA ORD-TVC OCT 1.6>1.1[2]
AA ORD-TYS OCT 1.2>0.8[1.7]
AA ORD-XNA OCT 1.0>0.7[1.2]
AA PHL-SRQ JAN 1.0>0.4[0.6]
AA PHL-TYS JAN 3>2[2]
AF CDG-LAX OCT 1.8>1.4[1.8]
AF LAX-PPT OCT 0.4>0[0.4]
AI BOM-EWR NOV 1.0>0.4[1.0] DEC 1.0>0.4[1.0] JAN 1.0>0.5[1.0] FEB 1.0>0.4[1.1] MAR 1.0>0.4[0.9] APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0]
**AI DEL-EWR NOV 0>0.4[0] DEC 0>0.5[0] JAN 0>0.4[0] FEB 0>0.4[0] MAR 0>0.4[0]
AI DEL-IAD APR 0.4>0[0.4] MAY 0.4>0[0.4] JUN 0.4>0[0.4]
AI DEL-JFK NOV 1.0>0.4[1.0] DEC 1.0>0.4[1.0] JAN 1.0>0.5[1.0] FEB 1.0>0.4[1.1] MAR 1.0>0.4[0.9] APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[0.9]
**AI DEL-ORD MAR 1.0>0.7[0.9] APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0[1.0]
AI DEL-SFO APR 1.3>0.4[1.3] MAY 1.3>0.5[1.3] JUN 1.3>0.4[1.2]
AM GDL-LAX OCT 1.0>0[1.0] NOV 1.0>0[1.0] DEC 1.0>0.5[1.0] JAN 1.0>0.3[1.6]
AR EZE-JFK OCT 0.4>0.1[0.4]
AS LAX-SEA MAR 14>13[11]
AS SEA-SUN OCT 0.4>0.2[0.5] APR 1.4>0.3[1.3] MAY 1.4>0[0] JUN 1.4>1.0[0]
AV JFK-MDE OCT 0.1>0.5[0.1]
AV MDE-MIA OCT 0.2>0.6[0.2]
AY HEL-JFK OCT 1.0>0[1.0]
AZ JFK-MXP OCT 0.5>0.2[0.5]
B5 MDR-WIL NOV 2>0[0] APR 2>0[0]
**B6 AUA-EWR NOV 0>0.4[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.9[0]
B6 BGI-BOS DEC 0.2>0[0.2]
B6 BGI-JFK OCT 0.7>0.3[0.7] NOV 1.8>0.3[1.8] DEC 2>0.3[1.7]
**B6 BOS-BZN JAN 0.0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0]
B6 BOS-PBI OCT 2>1.7[2]
B6 BOS-RSW OCT 2>3[2]
**B6 BZN-JFK JAN 0.1>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0]
**B6 CHS-LAX DEC 0>0.5[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.9[0]
I doubt these fly at these capacity levels
**B6 CUN-EWR NOV 0>0.8[0] DEC 0>2[0] JAN 0>2[0] FEB 0>2[0] MAR 0>2[0] APR 0>1.8[0]
**B6 CUN-LAX NOV 0>0.8[0] DEC 0>2[0] JAN 0>2[0] FEB 0>2[0] MAR 0>2[0] APR 0>1.8[0]
**B6 CUN-RDU NOV 0>0.4[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.9[0]
**B6 CUN-SFO NOV 0>0.8[0] DEC 0>2[0] JAN 0>2[0] FEB 0>2[0] MAR 0>2[0] APR 0>1.8[0]
**B6 CUN-TPA NOV 0>0.4[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.9[0]
B6 EWR-LAX DEC 6>5[0]
**B6 EWR-MBJ NOV 0>0.4[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.9[0]
**B6 EWR-NAS NOV 0>0.4[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.9[0]
**B6 EWR-PLS NOV 0>0.4[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.9[0]
**B6 EWR-PUJ NOV 0>0.4[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.9[0]
B6 EWR-SRQ OCT 0.5>0.3[0.5]
**B6 EWR-SXM NOV 0>0.4[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.9[0]
B6 FLL-HPN OCT 1.0>0.5[1.0]
B6 FLL-NAS OCT 1.0>0.6[1.0]
B6 FLL-PHL OCT 0.7>0.4[0.7]
B6 FLL-PHX OCT 0.5>0.3[0.5]
B6 FLL-PIT OCT 1.0>0.5[1.0]
**B6 FLL-PSP JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.2[0]
B6 HPN-TPA OCT 1.0>0.5[1.0]
Similarly doubt this stuff flies at these frequency levels
**B6 LAS-RIC DEC 0>0.5[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.9[0]
**B6 LAX-LIR JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0] APR 0>0.2[0]
**B6 LAX-PBI NOV 0>0.4[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.9[0]
**B6 LAX-RDU DEC 0>0.5[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.9[0]
**B6 LAX-RIC DEC 0>0.5[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.9[0]
**B6 LAX-SJO DEC 0>0.5[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.9[0]
**B6 MBJ-RDU NOV 0>0.4[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.9[0]
B6 PBI-PIT OCT 1.0>0.4[1.0]
**B6 RDU-RSW NOV 0>0.4[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.9[0]
**B6 RDU-SJU NOV 0>0.4[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.9[0]
**B6 RIC-TPA NOV 0>0.4[0] DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>0.9[0]
CM IAD-PTY OCT 1.0>0.7[1.0]
CM JFK-PTY OCT 1.0>1.4[1.0]
CM MCO-PTY OCT 2>1.4[2]
CM ORD-PTY OCT 0.4>0[0.4]
CM PTY-SFO OCT 0.3>0[0.3]
CX EWR-HKG OCT 0.2>0[0.2]
CX HKG-JFK OCT 1.4>0.7[1.6]
CX HKG-LAX OCT 1.5>1.0[2]
D7 HNL-KIX OCT 1.0>0.2[1.0]
DL ACC-JFK OCT 0.7>1.0[0.6] NOV 0.7>1.0[0.6] JAN 0.8>1.0[0.6] FEB 0.7>1.0[0.6] MAR 0.6>1.0[0.5] APR 0.7>1.0[0.6] MAY 0.7>1.0[0.5] JUN 0.7>1.0[0]
DL APN-DTW NOV 1.1>1.7[1.0]
DL APN-PLN NOV 0.5>0[0.8]
DL ATL-BQK JAN 3>2[3]
DL ATL-CHA JAN 10>8[9]
DL ATL-CRW DEC 4>3[4]
DL ATL-CSG JAN 4>3[3]
DL ATL-DHN JAN 4>3[4]
DL ATL-JNB APR 0.7>1.0[1.0] MAY 0.7>1.0[0.8] JUN 0.7>1.0[0]
DL ATL-LOS JAN 0.7>1.0[0.7] FEB 0.6>1.0[0.7] MAR 0.5>1.0[0.5] APR 0.6>1.0[0.6] MAY 0.6>1.0[0.5] JUN 0.6>1.0[0.6]
DL ATL-NAS OCT 1.0>0[1.0]
DL ATL-PVD NOV 2>0.7[3] DEC 3>1.0[3] JAN 3>1.0[2] FEB 3>1.0[3]
DL ATL-TRI APR 7>5[6]
DL ATL-VLD NOV 1.5>1.2[3] DEC 1.3>1.0[3] JAN 3>1.9[3] MAR 1.4>1.1[3]
DL BOS-RIC JAN 3>2[2]
DL COS-SLC NOV 2>3[2]
DL CUN-JFK NOV 2>3[2] DEC 3>4[2.0] JAN 3>4[2] FEB 3>4[3] MAR 3>4[3]
Reversing an earlier odd cut
*DL CUN-MSP JAN 1.2>3[1.8] FEB 1.0>3[3] MAR 1.0>3[3]
DL CVG-SLC NOV 2>3[1.7] DEC 1.4>2[1.5]
DL DTW-FWA NOV 3>1.7[3]
DL DTW-LAN APR 5>4[5]
DL DTW-MQT NOV 1.7>1.0[1.9]
*DL DTW-PUJ DEC 0>0.5[0.1] JAN 0>1.0[0.1] FEB 0>1.0[0.1] MAR 0>1.0[0.2] APR 0>0.2[0.1]
DL DTW-PVD NOV 3>1.5[4] DEC 3>2[3] JAN 3>2[3] FEB 3>2[3]
DL DTW-TYS JAN 4>2[4]
DL EUG-SLC NOV 2>3[2] DEC 2>3[1.9] JAN 2.0>3[2] FEB 2>3[2] MAR 1.9>3[1.7] APR 2>3[2] MAY 2>3[1.9] JUN 2>3[1.0]
DL IAD-JFK JAN 3>2[4]
DL INL-MSP MAR 1.6>1.2[1.6]
DL JFK-LOS JAN 0>0.6[0.4] FEB 0>0.6[0.5] MAR 0.1>0.5[0.4]
**DL JFK-SAL DEC 0>0.4[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0]
DL LAS-LAX JAN 7>6[7] APR 7>6[7]
**DL LAX-RNO DEC 0>0.8[0] JAN 0>2[0] FEB 0>2[0] MAR 0>2[0] APR 0>2[0] MAY 0>2[0] JUN 0>2[0]
DL LAX-SJD NOV 1.2>1.6[1.0] DEC 1.8>2[1.0]
DL LWS-SLC NOV 3>1.9[3]
DL MCO-MIA JAN 5>4[0]
DL MFR-SEA NOV 2>3[3] DEC 2.0>3[2.0] JAN 2>3[1.9] FEB 1.9>3[2] MAR 2.0>3[1.9] APR 2>3[3] MAY 2>3[3] JUN 2>3[1.5]
DL MFR-SLC NOV 2>3[2] DEC 2>3[1.9] JAN 2.0>3[2] FEB 2>3[2] MAR 2>3[1.7] APR 2>3[2] MAY 2>3[1.9] JUN 2>3[1.0]
DL MSP-PVR DEC 0.5>0.7[0.1]
DL RDM-SLC NOV 2>3[2] DEC 2>3[1.9] JAN 2.0>3[2.0] FEB 2>3[2] MAR 2>3[1.7] APR 2>3[2] MAY 2>3[1.8] JUN 2>3[1.0]
DL SJD-SLC NOV 0.4>0.7[0.6] DEC 0.6>1.0[0.5]
DL SLC-TUL NOV 1.2>2[1.0] DEC 1.0>2[1.0] JAN 1.0>2[1.2] FEB 1.0>2[1.1] MAR 1.0>2.0[0.9] APR 1.0>2[1.0] MAY 1.0>1.9[1.0] JUN 1.0>2[1.0]
EI BDL-DUB OCT 1.0>0.6[1.0]
EI BNA-ORD JAN 1.1>0.6[0]
EI BOS-SNN OCT 1.0>0.6[1.0]
EI DUB-EWR OCT 1.0>0.6[1.0]
EI DUB-IAD OCT 1.0>0.6[1.0]
EI DUB-LAX OCT 1.0>0.6[1.0]
EI DUB-MCO OCT 0.9>0.5[0.9]
EI DUB-PHL OCT 1.0>0.6[1.0]
EI DUB-SEA OCT 0.9>0.5[0.9]
EI DUB-SFO OCT 1.0>0.6[1.0]
EI JFK-SNN OCT 1.0>0.6[1.0]
EK ATH-EWR OCT 1.0>0[1.0] NOV 1.0>0[1.0]
**EK DXB-MCO JAN 0.7>0[0.7] FEB 0.7>0[0.8] MAR 0.7>0[0.7] APR 0.7>0[0.7] MAY 0.7>0[0]
EK JFK-MXP OCT 1.0>0[1.0] NOV 1.0>0[1.0]
EY AUH-IAD OCT 0.8>0.5[0.8]
EY AUH-JFK OCT 1.0>0.8[1.0]
EY AUH-ORD OCT 1.0>0.8[1.0]
F2 MBA-MDR JUN 0.5>0[0]
F2 MDR-WIL DEC 2>1.0[0]
F9 ALB-MCO NOV 0.3>0.1[0.4]
F9 ATL-CVG NOV 0.7>0.3[0.5]
F9 ATL-EWR NOV 0.9>0.4[0]
F9 ATL-ISP NOV 0.4>0.1[0.6]
F9 ATL-MCO NOV 1.9>1.4[1.5]
F9 ATL-MIA NOV 1.9>0.9[0.5]
F9 ATL-PHL NOV 1.6>1.1[0.5]
F9 ATL-RDU NOV 0.9>0.4[0]
F9 ATL-SLC NOV 0.4>0.1[0.6]
F9 ATL-TPA NOV 0.9>0.4[0.4]
F9 ATL-TTN NOV 0.9>0.4[1.0]
F9 AUS-LAS NOV 1.0>0.7[1.0]
F9 AUS-MCO NOV 0.9>0.5[0.5]
F9 AUS-MIA NOV 0.4>0.2[0]
F9 AUS-SAN NOV 0.4>0.1[0.6]
F9 BNA-DEN NOV 1.0>0.7[1.0]
F9 BNA-MCO NOV 0.8>0.5[0.6]
F9 BOS-MCO NOV 1.0>0.8[1.0]
F9 BOS-MIA NOV 0.9>0.4[0]
F9 BOS-PHL NOV 0.5>0.2[0]
F9 BOS-RSW NOV 0.5>0.2[0]
F9 BOS-TPA NOV 0.4>0.2[0]
F9 BUF-MCO NOV 0.8>0.5[1.0]
F9 BWI-MCO NOV 0.9>0.6[0.5]
F9 CLE-CUN NOV 0.5>0.2[0.1]
F9 CLE-LAS NOV 1.1>1.4[1.0]
F9 CLE-TPA NOV 1.6>1.3[1.5]
F9 CLT-LAS NOV 0.6>0.4[1.0]
F9 CLT-MCO NOV 0.9>0.6[0.6]
F9 CLT-TTN NOV 0.5>0.2[0.6]
F9 CUN-EWR NOV 0.9>0.4[0]
F9 CVG-DEN NOV 1.7>1.4[1.0]
F9 CVG-DFW NOV 0.7>0.3[0]
F9 CVG-MCO NOV 3>2.0[1.0]
F9 CVG-MIA NOV 0.5>0.2[0.4]
F9 CVG-TPA NOV 1.5>1.2[0.7]
F9 DEN-MSY NOV 1.0>0.7[1.0]
F9 DEN-ONT NOV 0.9>0.7[1.0]
F9 DEN-SMF NOV 1.0>0.7[0.6]
F9 DEN-STL NOV 1.0>0.7[1.9]
F9 DEN-TPA NOV 1.0>0.8[1.0]
F9 DFW-MCO NOV 0.8>0.6[0.6]
F9 DFW-MIA NOV 0.5>0.2[0]
F9 DFW-PHL NOV 0.3>0.1[0.5]
F9 DTW-MIA NOV 0.7>0.4[0]
F9 DTW-PHX NOV 0.6>0.4[0]
F9 EWR-MCO NOV 1.9>1.0[0]
F9 EWR-MIA NOV 1.8>0.9[0]
F9 EWR-MYR NOV 0.4>0.1[0]
F9 EWR-ORD NOV 0.3>0[0]
F9 EWR-PBI NOV 0.7>0.4[0]
F9 EWR-PHX NOV 0.6>0.4[0]
F9 EWR-RSW NOV 0.4>0.1[0]
F9 EWR-SJU NOV 0.9>0.4[0]
F9 EWR-TPA NOV 0.9>0.4[0]
F9 HSV-MCO NOV 0.4>0.2[0.5]
F9 IAD-MCO NOV 0.6>0.4[0.6]
F9 IAH-MCO NOV 0.4>0.1[0.5]
F9 ISP-MIA NOV 0.9>0.4[0]
F9 ISP-PBI NOV 1.5>1.0[0.5]
F9 ISP-RSW NOV 0.8>0.6[0]
F9 ISP-TPA NOV 1.4>0.9[0.6]
F9 LAS-LAX NOV 0.8>1.3[1.0]
F9 LAS-MCO NOV 0.7>1.0[1.3]
F9 LAS-MIA NOV 0.6>0.4[1.0]
F9 LAS-ONT NOV 0.6>0.2[0]
F9 LAS-ORD NOV 1.0>0.7[1.0]
F9 LAS-PHL NOV 0.6>0.4[1.3]
F9 LAS-RDU NOV 0.6>0.4[1.0]
F9 LAS-SAN NOV 0.8>1.0[0.9]
F9 LAS-SJC NOV 1.6>1.1[1.0]
F9 LAS-SLC NOV 1.5>1.1[1.0]
F9 LAS-SMF NOV 1.0>0.7[1.0]
F9 LAS-SNA NOV 1.0>0.7[0]
F9 LAS-STL NOV 1.0>0.8[1.0]
F9 LAS-TPA NOV 0.6>0.4[1.0]
F9 LGA-MIA NOV 0.9>0.4[0]
F9 MCO-MSP NOV 0.4>0.1[1.0]
F9 MCO-MSY NOV 0.8>0.5[0.3]
F9 MCO-ONT NOV 0.8>0.4[1.0]
F9 MCO-ORD NOV 1.0>0.7[1.2]
F9 MCO-PVD NOV 0.8>0.6[0.6]
F9 MCO-PWM NOV 0.6>0.4[0.5]
F9 MCO-RDU NOV 1.0>0.7[0.9]
F9 MCO-TTN NOV 1.6>1.3[1.0]
F9 MIA-ORD NOV 0.8>0.4[0]
F9 MIA-PHL NOV 1.6>1.0[0.8]
F9 MIA-RDU NOV 0.9>0.4[0.4]
F9 MIA-SJU NOV 0.9>0.4[0]
F9 MIA-TTN NOV 0.7>0.4[0]
F9 MSY-PHL NOV 0.9>0.6[0.8]
F9 ORD-PHL NOV 0.5>0.2[0]
F9 ORD-PUJ NOV 0.6>0.4[0]
F9 ORD-RSW NOV 0.4>0.1[0]
F9 ORD-TPA NOV 0.5>0.2[0.5]
F9 ORD-TTN NOV 0.3>0[1.0]
F9 PBI-PHL NOV 0.7>0.4[0]
F9 PBI-TTN NOV 0.9>0.6[0.5]
F9 PHL-PHX NOV 0.6>0.4[0]
F9 PHL-RDU NOV 0.7>0.4[0.5]
F9 PHL-TPA NOV 1.6>1.1[1.0]
F9 PHX-SJC NOV 0.8>0.5[0]
F9 RDU-TTN NOV 0.5>0.2[0.6]
F9 TPA-TTN NOV 0.8>0.4[0.6]
FI BOS-KEF OCT 0.9>0.7[0.9]
*FI DEN-KEF NOV 0.7>0[0.9] DEC 0.7>0[0.7]
*FI EWR-KEF OCT 0.2>0[0.2] NOV 1.0>0[1.0] DEC 0.9>0[1.0]
FI IAD-KEF OCT 0.9>0.2[0.9]
FI JFK-KEF OCT 0.9>0.5[0.9]
FI KEF-MCO OCT 0.6>0.2[0.6]
*FI KEF-ORD OCT 0.2>0[0.2] NOV 0.9>0[1.0] DEC 0.8>0[0.8]
FI KEF-SEA OCT 0.9>0.5[0.9]
GV AKN-KLL NOV 1.6>1.2[0.5] FEB 1.6>0.3[1.9]
GV AKN-WSN NOV 1.1>0.3[1.8] FEB 1.1>0.3[0.5]
GV AUK-KOT NOV 1.9>1.5[1.9] FEB 1.9>1.5[2]
GV BET-EMK NOV 0.4>0[0.4] FEB 0.4>0[0.4]
GV BET-KOT NOV 1.9>1.5[1.9] FEB 1.9>1.5[2]
GV BET-MYU FEB 0.2>0[0]
GV CDB-KVC NOV 0.8>0[1.8] FEB 0.9>0[1.9]
GV DLG-KLL FEB 0.9>0[1.0]
GV DLG-WSN NOV 0.8>0[1.8] FEB 0.9>0[0]
GV MYU-OOK FEB 0.2>0[0]
HA HNL-OGG JAN 26>25[27]
HI GCN-GCW NOV 0.7>0[0.8] JAN 0.7>0[0.7]
HZ RZH-VVO NOV 0>0.7[0] DEC 0>0.7[0]
IB BCN-JFK OCT 0.4>0.2[0.4]
JL BOS-NRT OCT 1.0>0.6[1.0]
JL DFW-HND OCT 1.0>0.5[1.0]
JL HND-HNL OCT 2>0.0[2]
JL HND-JFK OCT 2.0>0.5[2.0]
JL HND-LAX OCT 1.0>0.3[1.0]
JL HND-ORD OCT 1.0>0.5[1.0]
JL HND-SFO OCT 1.0>0[1.0]
JL HNL-KIX OCT 1.0>0.0[1.0]
JL HNL-NGO OCT 1.0>0[1.0]
JL HNL-NRT OCT 2>0[2]
JL KIX-LAX OCT 1.0>0.2[1.0]
JL KOA-NRT OCT 1.0>0[1.0]
JL LAX-NRT OCT 1.0>0.6[1.0]
JL NRT-SAN OCT 1.0>0[1.0]
JL NRT-SEA OCT 1.0>0[1.0]
JL NRT-SFO OCT 1.0>0.6[1.0]
K3 KTN-MTM JAN 0.4>0[0]
KE BOS-ICN NOV 0.7>0[0.7]
KE HNL-ICN OCT 0.2>0[1.0] NOV 1.0>0[1.1]
KE IAD-ICN NOV 1.0>0.6[1.0]
KE ICN-JFK NOV 2>1.0[2]
KE ICN-LAS NOV 0.7>0[0.7]
KE ICN-LAX NOV 2>1.4[2]
KE ICN-ORD NOV 1.0>0.7[1.0]
KE ICN-SEA NOV 0.7>0.4[1.0]
KE ICN-SFO OCT 1.1>0.7[2] NOV 2>0.7[2]
KL AMS-ATL NOV 2>1.3[1.2] DEC 2>1.4[1.9] JAN 2>1.4[2] FEB 2>1.4[2] MAR 1.9>1.4[1.9]
*KL AMS-BOS NOV 0.4>0[0.5] DEC 0.4>0[0.4] JAN 0.5>0[0.4] FEB 0.4>0[0.5] MAR 0.5>0.1[0.4]
KL AMS-IAD NOV 1.0>0.6[1.0] DEC 1.0>0.5[1.0] JAN 1.0>0.6[1.0] FEB 1.0>0.6[1.1] MAR 1.0>0.6[0.9]
*KL AMS-LAS NOV 0.4>0[0.5] DEC 0.5>0[0.4] JAN 0.4>0[0.5] FEB 0.4>0[0.3] MAR 0.4>0.1[0.3]
*KL AMS-MIA NOV 0.4>0[0.1] DEC 0.4>0[0.4] JAN 0.4>0[0.5] FEB 0.4>0[0.4] MAR 0.4>0[0.4]
*KL AMS-MSP NOV 0.6>0[0.6] DEC 0.5>0[0.5] JAN 0.6>0[0.6] FEB 0.6>0[0.6] MAR 0.5>0.1[0.5]
KL AMS-ORD NOV 0.7>1.0[1.0] DEC 0.7>1.0[0.7] JAN 0.7>1.0[0.7] FEB 0.7>1.0[0.8] MAR 0.7>1.0[0.7]
KL AMS-SFO NOV 1.0>0.6[1.6] DEC 1.0>0.5[1.0] JAN 1.0>0.6[1.0] FEB 1.0>0.6[1.1] MAR 1.1>0.7[0.9]
LA GRU-JFK OCT 0.5>0.3[0.6]
LA JFK-LIM OCT 0.7>0.5[0.7]
LA JFK-SCL OCT 0.5>0.4[0.5]
LA LAX-LIM OCT 0.6>0.4[0.6]
M5 BFI-FRD OCT 0>0.5[3] DEC 2>3[1.9] JAN 0>0.5[2] FEB 0>0.5[2] MAR 0>0.5[1.9] APR 0>0.5[1.9]
M5 BFI-PAE OCT 0>0.5[0.6] NOV 0>0.5[0] DEC 0>0.5[0] JAN 0>0.5[0] FEB 0>0.5[0] MAR 0>0.5[0] APR 0>0.5[0]
M5 CXH-LKE OCT 0>0.7[0.5] NOV 0>0.7[0.3]
M5 ESD-FRD OCT 0.5>0[2] NOV 1.5>0.5[2.0] DEC 1.5>1.0[1.5]
M5 FRD-PAE OCT 0>0.5[0.4] NOV 0>0.5[0] DEC 0>0.5[0] JAN 0>0.5[0] FEB 0>0.5[0] MAR 0>0.5[0] APR 0>0.5[0]
MF FOC-LAX OCT 0>0.2[0]
MS CAI-JFK NOV 1.0>0.5[1.0] DEC 1.0>0.7[1.0] JAN 1.0>0.6[1.0] FEB 1.0>0.6[1.1] MAR 1.0>0.6[0.9]
NH HND-HNL OCT 1.0>0[1.0]
NH HND-IAD OCT 1.0>0.4[1.0]
NH HND-IAH OCT 1.0>0.5[1.0]
NH HND-JFK OCT 1.0>0[1.0]
NH HND-LAX OCT 2>0.5[2]
NH HND-ORD OCT 1.0>0[1.0]
NH HND-SEA OCT 1.0>0[1.0]
NH HND-SFO OCT 1.0>0[1.0]
NH HND-SJC OCT 1.0>0[1.0]
NH HNL-NRT OCT 2>0.1[2]
NH JFK-NRT OCT 1.0>0.7[1.0]
NH NRT-SFO OCT 1.0>0.5[1.0]
This is a schedule extension and probably means almost nothing. Compare MAR to prior year.
NK ACY-FLL FEB 0.9>3[3] APR 0>1.3[3]
NK ACY-MCO FEB 0.9>3[2] MAR 0>3[2] APR 0>1.2[3]
NK ACY-MYR FEB 0.3>1.0[0.8] MAR 0>1.0[0.8] APR 0>0.4[1.0]
NK ACY-PBI FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK ACY-RSW FEB 0.6>2[1.9] MAR 0>2[1.7] APR 0>0.9[2]
NK ACY-TPA FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK ATL-AUS FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK ATL-BOS FEB 0.2>0.9[0.4] MAR 0>1.0[0.4] APR 0>0.4[0.5]
NK ATL-BWI FEB 0.5>1.9[1.8] MAR 0>2[1.7] APR 0>0.9[2]
NK ATL-CLE FEB 0.3>1.0[0.8] MAR 0>1.0[0.8] APR 0>0.4[1.0]
NK ATL-DFW FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK ATL-DTW FEB 0.6>2[2] MAR 0>2[1.9] APR 0>0.9[2]
NK ATL-EWR OCT 1.0>1.2[1.8] FEB 0.6>2[1.1] MAR 0>2[0.9] APR 0>0.9[1.0]
NK ATL-FLL FEB 1.8>6[5] MAR 0>6[5] APR 0>3[6]
NK ATL-IAH FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK ATL-LAS FEB 0.6>2[2] APR 0>0.9[2]
NK ATL-LAX FEB 0.6>2[1.1] MAR 0>1.9[0.9] APR 0>0.9[1.0]
NK ATL-MCO FEB 0.6>2[1.9] MAR 0>2[1.8] APR 0>0.9[2]
NK ATL-MSP FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK ATL-MSY FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK ATL-ORD FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK ATL-PHL FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK ATL-TPA FEB 0.6>2[2] MAR 0>2[1.9] APR 0>0.9[2]
NK AUS-BNA FEB 0.2>0.9[0] MAR 0>1.0[0] APR 0>0.4[0.2]
NK AUS-BWI FEB 0.2>0.9[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK AUS-CUN FEB 0.1>0.5[0] MAR 0>0.6[0.1] APR 0>0.2[0.6]
NK AUS-DEN FEB 0.3>0.9[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK AUS-DTW FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK AUS-EWR FEB 0.3>1.0[0] MAR 0>1.0[0] APR 0>0.4[0.2]
NK AUS-FLL FEB 0.2>0.9[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK AUS-LAS FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK AUS-LAX FEB 0.2>0.9[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK AUS-MCO FEB 0.5>1.5[1.1] MAR 0>1.6[1.0] APR 0>0.7[1.6]
NK AUS-MSY FEB 0.2>0.9[1.1] APR 0>0.4[1.0]
NK AUS-ORD FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK AXM-FLL FEB 0.1>0.4[0.5] APR 0>0.2[0.4]
NK BAQ-FLL FEB 0.1>0.4[0] MAR 0>0.4[0] APR 0>0.2[0]
NK BDL-FLL FEB 1.0>3[1.9] MAR 0>3[1.8] APR 0>1.3[2]
NK BDL-MCO FEB 0.9>3[1.8] MAR 0>3[1.7] APR 0>1.3[2]
NK BDL-MYR FEB 0>0.2[0] MAR 0>0.9[0.3] APR 0>0.4[0.8]
NK BDL-RSW FEB 0.3>1.0[0.8] MAR 0>1.0[0.8] APR 0>0.4[1.0]
NK BDL-TPA FEB 0.6>2[1.1] MAR 0>1.9[1.5] APR 0>0.9[2]
NK BGA-FLL FEB 0.1>0.4[0] MAR 0>0.5[0]
NK BNA-BWI FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK BNA-CUN FEB 0.1>0.4[0] MAR 0>0.4[0.0] APR 0>0.2[0.5]
NK BNA-EWR FEB 0.3>1.0[0] MAR 0>1.0[0] APR 0>0.4[0.7]
NK BNA-FLL FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK BNA-LAS FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK BNA-LAX FEB 0.2>0.9[0] MAR 0>1.0[0] APR 0>0.4[0.7]
NK BNA-MCO FEB 0.4>1.4[1.1] MAR 0>1.4[1.0] APR 0>0.6[1.5]
NK BNA-MSY FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK BNA-TPA FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK BOG-FLL FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK BOG-MCO FEB 0.3>1.0[1.1] APR 0>0.4[1.0]
NK BOS-BWI FEB 1.3>4[0.2] MAR 0>4[0] APR 0>1.7[0]
NK BOS-EWR FEB 0.6>2[0] MAR 0>2[0] APR 0>0.9[0]
NK BOS-FLL FEB 0.6>2[2] MAR 0>2[1.9] APR 0>0.9[2]
NK BOS-LAS FEB 0.3>1.0[1.1] MAR 0>0.9[1.0] APR 0>0.4[1.0]
NK BOS-MCO FEB 0.6>2[1.9] MAR 0>2[1.7] APR 0>0.9[2]
NK BOS-MSY FEB 0.2>0.9[0.8] MAR 0>0.9[0.8] APR 0>0.4[1.0]
NK BOS-MYR FEB 0.3>1.0[1.1] APR 0>0.4[1.1]
NK BOS-PBI FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK BOS-RSW FEB 0.6>2[1.3] MAR 0>2[1.5] APR 0>0.9[2]
NK BOS-SJU FEB 0.3>1.0[1.1] APR 0>0.4[1.0]
NK BOS-TPA FEB 0.3>1.0[1.1] MAR 0>0.9[1.0] APR 0>0.4[1.0]
NK BQN-FLL FEB 0.3>1.0[1.1] APR 0>0.4[1.0]
NK BQN-MCO FEB 0.3>1.0[0.7] MAR 0>1.0[0.7] APR 0>0.4[1.0]
NK BUR-LAS FEB 0.6>2[1.9] MAR 0>2[1.9] APR 0>0.9[2]
NK BWI-CLT FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK BWI-CUN FEB 0.2>0.9[0.8] MAR 0>1.0[0.8] APR 0>0.4[1.0]
NK BWI-DEN FEB 0.2>0.9[0.8] MAR 0>1.0[0.8] APR 0>0.4[1.0]
NK BWI-DFW FEB 0.3>1.0[1.1] APR 0>0.4[0.8]
NK BWI-DTW FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK BWI-FLL FEB 1.3>4[3] MAR 0>4[3] APR 0>1.7[3]
NK BWI-IAH FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK BWI-LAS FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK BWI-LAX FEB 0.3>1.0[1.0] MAR 0>1.0[0.8] APR 0>0.4[1.0]
NK BWI-MBJ FEB 0.2>0.9[0.8] MAR 0>1.0[0.8] APR 0>0.4[1.0]
NK BWI-MCO FEB 1.3>4[3] MAR 0>4[3] APR 0>1.7[3]
NK BWI-MSP FEB 0.3>1.0[0.2] MAR 0>1.0[0.5] APR 0>0.4[1.0]
NK BWI-MSY FEB 0.3>1.0[1.1] APR 0>0.4[1.0]
NK BWI-ORD FEB 0.3>1.0[0.2] MAR 0>1.0[0.5] APR 0>0.4[1.0]
NK BWI-RDU FEB 0.2>0.9[0.2] MAR 0>1.0[0.5] APR 0>0.4[1.0]
NK BWI-RSW FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK BWI-SAL FEB 0.3>1.0[0] MAR 0>1.0[0] APR 0>0.4[0]
NK BWI-SJU FEB 0.6>2.0[1.1] MAR 0>2.0[0.9] APR 0>0.9[1.0]
NK BWI-TPA FEB 0.6>2[1.1] MAR 0>2[1.0] APR 0>0.9[1.0]
NK CAK-MCO FEB 0.2>0.9[0.8] MAR 0>0.9[0.8] APR 0>0.4[1.0]
NK CAK-RSW FEB 0.1>0.4[0.5] MAR 0>0.4[0.5] APR 0>0.2[0.6]
NK CAK-TPA FEB 0.2>0.6[0.3] MAR 0>0.5[0.3] APR 0>0.2[0.5]
NK CLE-CUN FEB 0.1>0.5[0] MAR 0>0.5[0.3] APR 0>0.2[0.6]
NK CLE-EWR FEB 0.3>1.0[0] MAR 0>1.0[0] APR 0>0.4[0]
NK CLE-FLL FEB 1.0>3[2] MAR 0>3[1.6] APR 0>1.3[1.6]
NK CLE-LAS FEB 0.6>2[1.0] MAR 0>1.9[0.9] APR 0>0.9[1.0]
NK CLE-LAX FEB 0.3>1.0[1.1] APR 0>0.4[1.0]
NK CLE-MCO FEB 0.8>3[2] MAR 0>3[2] APR 0>1.1[3]
NK CLE-MSY FEB 0.1>0.4[0.3] MAR 0>0.4[0.3] APR 0>0.2[0.5]
NK CLE-MYR MAR 0>0.4[0]
NK CLE-RSW FEB 0.3>1.0[0.8] MAR 0>0.9[0.8] APR 0>0.4[1.0]
NK CLE-TPA FEB 0.3>1.0[0.8] MAR 0>1.0[0.8] APR 0>0.4[1.0]
NK CLO-FLL FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK CLT-EWR FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK CLT-FLL FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK CLT-MCO FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK CMH-FLL FEB 0.6>2[1.1] MAR 0>2[0.9] APR 0>0.9[1.0]
NK CMH-LAS FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK CMH-MCO FEB 0.6>2[1.1] MAR 0>2[0.9] APR 0>0.9[1.0]
NK CMH-RSW FEB 0.3>1.0[0.8] MAR 0>1.0[0.8] APR 0>0.4[1.0]
NK CMH-TPA FEB 0.6>2[0.8] MAR 0>2[0.8] APR 0>0.9[1.0]
NK CRW-MCO FEB 0.1>0.4[0] MAR 0>0.4[0.2] APR 0>0.2[0.4]
NK CTG-FLL FEB 0.2>0.6[0.6] MAR 0>0.6[0.5] APR 0>0.2[0.6]
NK CUN-DFW OCT 0.9>1.5[0.9] FEB 0.2>0.9[0.3] MAR 0>1.0[0.3] APR 0>0.4[0.5]
NK CUN-DTW FEB 0.2>0.9[0.8] MAR 0>1.0[0.8] APR 0>0.4[1.0]
NK CUN-FLL OCT 1.0>2[1.0] NOV 1.0>1.6[1.0] FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK CUN-MSY FEB 0.2>0.6[0] MAR 0>0.5[0] APR 0>0.2[0]
NK CUN-ORD FEB 0.2>0.9[0.8] MAR 0>1.0[0.8] APR 0>0.4[1.0]
NK CUN-PHL FEB 0.2>0.9[0] MAR 0>1.0[0] APR 0>0.4[1.0]
NK CUN-PIT FEB 0.1>0.4[0] MAR 0>0.4[0.2] APR 0>0.2[0.5]
NK DEN-DTW FEB 0.2>0.9[0.8] MAR 0>1.0[0.8] APR 0>0.4[1.1]
NK DEN-FLL FEB 0.6>2[2] MAR 0>2[1.9] APR 0>0.9[2]
NK DEN-IAH FEB 0.3>1.0[1.3] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK DEN-LAS FEB 0.6>2[1.1] MAR 0>1.9[1.5] APR 0>0.9[2]
NK DEN-MCO FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK DEN-MSP FEB 0.3>1.0[0] MAR 0>1.0[0] APR 0>0.4[0]
NK DEN-ORD FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK DFW-DTW FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK DFW-FLL FEB 1.0>3[4] APR 0>1.3[3]
NK DFW-LAS OCT 2>3[3] FEB 1.0>3[3] APR 0>1.3[4]
NK DFW-LAX FEB 0.6>2[1.9] MAR 0>2[1.7] APR 0>0.9[2]
NK DFW-LGA FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK DFW-MCO FEB 0.6>2[2] MAR 0>2[1.9] APR 0>0.9[2]
NK DFW-ORD FEB 0.3>1.0[1.1] APR 0>0.4[1.0]
NK DFW-PHL FEB 0.3>1.0[1.1] APR 0>0.4[0.7]
NK DFW-PHX FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK DFW-TPA FEB 0.2>0.9[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK DTW-FLL OCT 1.8>2[3] FEB 1.0>3[3] APR 0>1.3[3]
NK DTW-IAH FEB 0.2>0.9[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK DTW-LAS FEB 1.2>4[4] APR 0>1.7[4]
NK DTW-LAX FEB 0.3>1.0[1.1] APR 0>0.4[1.0]
NK DTW-LGA FEB 0.6>2[2] MAR 0>2[1.9] APR 0>0.9[2]
NK DTW-MBJ FEB 0.1>0.4[0.4] APR 0>0.2[0.5]
NK DTW-MCI FEB 0.3>1.0[0.2] MAR 0>0.9[0.5] APR 0>0.4[1.0]
NK DTW-MCO FEB 1.2>4[4] MAR 0>4[3] APR 0>1.7[4]
NK DTW-MSP FEB 0.3>1.0[0.2] MAR 0>1.0[0.5] APR 0>0.4[1.0]
NK DTW-MSY FEB 0.3>1.0[1.1] MAR 0>0.9[1.5] APR 0>0.4[2]
NK DTW-MYR MAR 0>0.9[0.4] APR 0>0.4[0.9]
NK DTW-PBI FEB 0.2>0.6[0.2] MAR 0>0.5[0.4] APR 0>0.2[0.6]
NK DTW-RSW FEB 0.8>3[3] APR 0>1.3[3]
NK DTW-TPA FEB 1.0>3[4] APR 0>1.3[3]
NK EWR-FLL FEB 1.0>3[3] MAR 0>3[2] APR 0>1.3[3]
NK EWR-IAH FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK EWR-LAS FEB 0.6>2[1.1] MAR 0>2[0.9] APR 0>0.9[1.0]
NK EWR-MCO FEB 1.3>4[3] MAR 0>4[3] APR 0>1.7[3]
NK EWR-MSY FEB 0.3>1.0[1.1] APR 0>0.4[1.0]
NK EWR-MYR OCT 0.9>1.1[3] FEB 1.0>3[0.6] MAR 0>3[0.6] APR 0>1.3[0.6]
NK EWR-PBI FEB 0.6>2[0] MAR 0>2[0] APR 0>0.9[0]
NK EWR-RSW FEB 0.6>2[1.1] MAR 0>2[0.9] APR 0>0.9[1.0]
NK EWR-SJU FEB 0.6>2.0[1.1] MAR 0>2.0[1.9] APR 0>0.9[2.1]
NK EWR-TPA FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK FLL-GUA FEB 0.5>1.6[1.1] MAR 0>1.6[0.9] APR 0>0.7[1.0]
NK FLL-GYE FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK FLL-IAH FEB 0.6>2[1.1] MAR 0>2[1.1] APR 0>0.9[1.5]
NK FLL-IND FEB 0.3>1.0[0] MAR 0>1.0[0] APR 0>0.4[0]
NK FLL-KIN FEB 0.2>0.9[0.8] MAR 0>1.0[0.7] APR 0>0.4[0.7]
NK FLL-LAS FEB 0.6>1.3[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK FLL-LAX FEB 0.3>1.0[1.0] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK FLL-LBE FEB 0.2>0.9[0.8] MAR 0>1.0[0.8] APR 0>0.4[1.0]
NK FLL-LGA FEB 1.3>4[4] APR 0>1.7[4]
NK FLL-LIM FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK FLL-MBJ FEB 0.3>1.0[0.8] MAR 0>1.0[0.7] APR 0>0.4[1.0]
NK FLL-MCO FEB 0.6>2[2] MAR 0>2[1.9] APR 0>0.9[2]
NK FLL-MDE FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK FLL-MGA FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK FLL-MSP FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK FLL-MSY FEB 0.6>2[2] MAR 0>2[1.9] APR 0>0.9[2]
NK FLL-MYR FEB 0.6>2.0[1.1] MAR 0>2[0.9] APR 0>0.9[1.0]
NK FLL-ORD FEB 1.0>3[3] APR 0>1.3[3]
NK FLL-PAP OCT 1.3>1.9[0.8] NOV 0.9>1.2[0.7] FEB 0.3>1.0[0.8] MAR 0>1.0[0.8] APR 0>0.4[1.0]
NK FLL-PHL FEB 1.3>4[3] MAR 0>4[3] APR 0>1.7[3]
NK FLL-PIT FEB 1.0>3[2] MAR 0>3[1.9] APR 0>1.3[2]
NK FLL-PTY FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK FLL-RDU FEB 0.6>2[1.1] MAR 0>2[0.9] APR 0>0.9[1.0]
NK FLL-RIC FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK FLL-SAL FEB 0.3>1.0[0.5] MAR 0>1.0[0.5] APR 0>0.5[0.6]
NK FLL-SAP FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK FLL-SDQ FEB 0.6>2[1.1] MAR 0>2[0.9] APR 0>0.9[1.0]
NK FLL-SJO FEB 0.6>2[2] MAR 0>2[1.9] APR 0>0.9[2]
NK FLL-SJU FEB 1.3>4[4.0] MAR 0>4[2.6] APR 0>1.7[2.1]
NK FLL-STI FEB 0.2>0.6[0.6] APR 0>0.3[0.6]
NK FLL-STT FEB 0.3>1.0[1.1] APR 0>0.4[1.0]
NK FLL-TPA FEB 0.6>2[2] MAR 0>2[1.9] APR 0>0.9[2]
NK GUA-IAH FEB 0.2>0.6[0.6] APR 0>0.2[0.6]
NK GUA-MCO FEB 0.3>1.0[0.6] MAR 0>1.0[0.5] APR 0>0.4[0.6]
NK IAH-LAS FEB 1.0>3[2] MAR 0>3[1.9] APR 0>1.3[2]
NK IAH-LAX FEB 1.0>3[1.9] MAR 0>3[1.7] APR 0>1.3[2]
NK IAH-MCO FEB 1.0>3[3] APR 0>1.3[3]
NK IAH-MSY FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK IAH-ORD FEB 0.6>2[1.9] MAR 0>2[1.7] APR 0>0.9[2]
NK IAH-SAL FEB 0.1>0.4[0.4] APR 0>0.2[0.5]
NK IAH-SAN FEB 0.3>1.0[1.1] APR 0>0.4[1.0]
NK IAH-SAP FEB 0.2>0.6[0.6] APR 0>0.3[0.6]
NK IAH-TPA FEB 0.2>0.9[0.8] MAR 0>1.0[0.8] APR 0>0.4[1.0]
NK IND-LAS FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK IND-MCO FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK IND-RSW FEB 0.2>0.9[1.1] APR 0>0.4[1.0]
NK IND-TPA FEB 0.5>1.9[1.1] MAR 0>2[0.9] APR 0>0.9[1.0]
NK LAS-LAX FEB 0.9>3[1.9] MAR 0>3[2] APR 0>1.3[3]
NK LAS-MCI FEB 0.3>1.0[1.1] APR 0>0.4[1.0]
NK LAS-MCO FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.1]
NK LAS-MSP FEB 0.5>1.9[1.9] MAR 0>1.9[1.7] APR 0>0.9[2]
NK LAS-MSY FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK LAS-OAK FEB 1.2>4[3] MAR 0>4[3] APR 0>1.7[3]
NK LAS-ORD FEB 0.9>3[3] APR 0>1.3[3]
NK LAS-PDX FEB 0.5>1.9[1.9] MAR 0>2[1.7] APR 0>0.9[2]
NK LAS-PHL FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK LAS-PIT FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK LAS-SAN FEB 1.0>3[3] APR 0>1.3[3]
NK LAS-SEA FEB 1.0>3[2] MAR 0>3[1.7] APR 0>1.3[2]
NK LAS-SMF FEB 1.0>3[3] APR 0>1.3[3]
NK LAS-SNA FEB 0.3>1.0[0] MAR 0>1.0[0] APR 0>0.4[0]
NK LAS-TPA FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK LAX-MCI FEB 0.2>0.9[0.8] MAR 0>0.9[0.8] APR 0>0.4[1.0]
NK LAX-MSP FEB 0.3>1.0[1.0] MAR 0>0.9[0.8] APR 0>0.4[1.0]
NK LAX-MSY FEB 0.3>1.0[1.1] APR 0>0.4[1.0]
NK LAX-OAK FEB 0.6>2[1.1] MAR 0>2[0.9] APR 0>0.9[1.0]
NK LAX-ORD FEB 0.6>2[2] MAR 0>2[1.9] APR 0>0.9[2]
NK LAX-PHL FEB 0.3>1.0[1.1] APR 0>0.4[1.0]
NK LAX-PIT FEB 0.3>1.0[1.1] APR 0>0.4[1.0]
NK LAX-SJD MAR 0>0.9[0] APR 0>0.4[0]
NK LBE-MCO FEB 0.3>1.0[1.1] APR 0>0.4[1.0]
NK LBE-MYR MAR 0>0.9[0.2] APR 0>0.4[0.8]
NK LBE-RSW FEB 0.2>0.6[0.5] MAR 0>0.6[0.5] APR 0>0.2[0.6]
NK LBE-TPA FEB 0.1>0.4[0.3] MAR 0>0.4[0.3] APR 0>0.2[0.5]
NK LGA-MCO FEB 0.6>2[1.1] MAR 0>2[0.9] APR 0>0.9[1.0]
NK LGA-MYR FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK LGA-TPA FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK MBJ-MCO FEB 0.1>0.4[0.4] APR 0>0.2[0.5]
NK MCI-MCO FEB 0.4>1.3[1.1] MAR 0>1.2[1.0] APR 0>0.6[1.0]
NK MCO-MDE FEB 0.1>0.4[0.3] MAR 0>0.5[0.3]
NK MCO-MSP FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK MCO-MSY FEB 1.0>3[0.8] MAR 0>3[1.2] APR 0>1.3[1.4]
NK MCO-ORD FEB 0.6>2[2] MAR 0>2[1.9] APR 0>0.9[2]
NK MCO-PHL FEB 1.5>5[3] MAR 0>5[3] APR 0>2[4]
NK MCO-PIT FEB 1.2>4[1.9] MAR 0>4[1.9] APR 0>1.7[2]
NK MCO-RDU FEB 0.4>1.8[1.1] MAR 0>2[0.9] APR 0>0.9[1.0]
NK MCO-RIC FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK MCO-SJO FEB 0.3>1.0[1.1] APR 0>0.4[1.0]
NK MCO-SJU FEB 1.3>4[2.6] MAR 0>4[3.0] APR 0>1.7[3.1]
NK MSP-MSY FEB 0.2>0.6[0.5] APR 0>0.2[0.6]
NK MSP-PHX FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK MSP-RSW FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK MSP-TPA FEB 0.3>1.0[1.1] APR 0>0.4[1.0]
NK MSY-ORD FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK MSY-RDU FEB 0.3>1.0[1.1] APR 0>0.4[1.0]
NK MSY-SAP FEB 0.1>0.4[0] MAR 0>0.4[0] APR 0>0.2[0]
NK MSY-TPA FEB 0.3>1.0[1.1] MAR 0>0.9[1.4] APR 0>0.4[1.4]
NK MYR-ORD FEB 0>0.2[0] MAR 0>0.9[0.1] APR 0>0.4[0.8]
NK MYR-PHL MAR 0>0.5[0.3] APR 0>0.3[0.5]
NK MYR-PIT MAR 0>0.4[0] APR 0>0.2[0.3]
NK OAK-SNA FEB 0.6>2[0] MAR 0>2[0] APR 0>0.9[0]
NK ORD-PHX FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK ORD-RSW FEB 0.5>1.9[1.9] MAR 0>2[1.7] APR 0>0.9[2]
NK ORD-SAN FEB 0.2>0.9[0.8] MAR 0>1.0[0.8] APR 0>0.4[1.0]
NK ORD-TPA FEB 0.5>1.9[1.9] MAR 0>2[1.7] APR 0>0.9[2]
NK PHL-RSW FEB 0.3>1.0[0.6] MAR 0>1.0[0.5] APR 0>0.4[0.5]
NK PHL-SJU FEB 0.6>2.0[0.8] MAR 0>2.0[0.8] APR 0>0.9[2.1]
NK PHL-TPA FEB 0.6>2[0.4] MAR 0>2[0.5] APR 0>0.9[0.7]
NK PHX-SEA FEB 0.3>1.0[1.1] MAR 0>1.0[0.9] APR 0>0.4[1.0]
NK PIT-RSW FEB 0.3>1.0[0.8] MAR 0>0.9[0.8] APR 0>0.4[1.0]
NK PIT-TPA FEB 0.3>1.0[1.1] MAR 0>0.9[1.0] APR 0>0.4[1.0]
NK SJU-TPA FEB 0.3>1.0[0.8] MAR 0>1.0[0.8] APR 0>0.4[1.0]
NZ AKL-LAX OCT 1.0>0.5[1.2] NOV 1.0>0.4[2.0] DEC 1.0>0.5[1.6] JAN 1.0>0.4[2.0] FEB 1.0>0.4[2] MAR 1.1>0.6[1.9]
NZ AKL-SFO OCT 0.5>0[0.5] NOV 0.4>0[0.7] DEC 0.5>0[0.7] JAN 0.4>0[1.0] FEB 0.4>0[1.1] MAR 0.5>0.1[0.8]
PD BOS-YTZ OCT 3>0[4] NOV 4>3[6] DEC 3>1.9[5] JAN 3>0.4[5] FEB 2>1.8[4]
PD EWR-YTZ OCT 6>0[9] NOV 9>5[13] DEC 7>4[10] JAN 8>0.9[11] FEB 6>4[9] MAR 8>7[7] APR 10>8[9] MAY 8>7[0]
PD IAD-YTZ OCT 1.6>0[2] NOV 1.6>0.9[3] DEC 1.3>0.7[2] JAN 0.9>0.2[3] MAR 1.2>0.9[0.7]
PD MDW-YTZ OCT 2>0[3] NOV 3>1.8[5] DEC 1.9>1.2[4] JAN 1.8>0.1[4]
PR CEB-LAX NOV 0.4>0[0] DEC 0.5>0.0[0] JAN 0.4>0.0[0] FEB 0.4>0.1[0] MAR 0.4>0.2[0]
PR JFK-MNL NOV 1.0>0.3[0.7] DEC 1.0>0.4[0.7] JAN 1.0>0.4[1.0] FEB 1.0>0.4[1.1] MAR 1.0>0.5[0.9]
PR LAX-MNL OCT 1.0>0.7[1.2] NOV 2>1.0[2] DEC 2>1.4[1.8] JAN 2>1.5[2] FEB 2>1.4[3] MAR 2>1.5[2]
PR MNL-SFO OCT 0.7>0.4[0.9] NOV 2>0.6[1.5] DEC 2>0.9[1.3] JAN 2>1.0[2] FEB 2>1.0[2] MAR 2>1.1[1.6]
TN CDG-LAX NOV 0.6>0[0.7] DEC 0.7>0.5[0.6]
TN LAX-PPT NOV 1.2>0.4[1.5] DEC 1.3>0.7[1.1] JAN 1.2>0.8[1.3] FEB 1.1>0.7[1.2] MAR 1.1>0.8[1.1]
TP EWR-OPO APR 0.9>0.3[0.7] MAY 0.9>0.3[0] JUN 0.9>0.4[0.3]
*UA AKL-SFO NOV 1.0>0[0.6] DEC 1.0>0[1.0] JAN 1.0>0[1.0] FEB 1.0>0[1.1] MAR 1.0>0.2[0.9]
UA BHM-IAH APR 5>4[5]
UA BTR-IAH APR 7>6[7]
UA CHS-IAD MAR 3>2[3]
UA COS-DEN JAN 10>9[9]
UA CRP-IAH APR 7>6[7]
UA CUN-EWR OCT 1.5>2[1.9]
UA CUN-IAH OCT 3>4[6]
UA CUN-SFO OCT 1.0>0.5[1.5]
*UA EWR-HKG NOV 1.0>0[1.0] DEC 1.0>0[1.0] JAN 1.0>0[1.0] FEB 1.0>0[0.6] MAR 1.0>0.2[0.4]
*UA EWR-LIM NOV 0.6>0[0.9] DEC 0.9>0[0.6] JAN 0.6>0[0.8] FEB 0.6>0[0.7] MAR 1.0>0.1[0.5]
UA FAT-SFO JAN 4>3[4]
*UA GRU-IAD NOV 1.0>0[1.0] DEC 1.0>0[0.8] JAN 1.0>0[1.0] FEB 1.0>0[1.1] MAR 1.0>0.2[0.9]
*UA GRU-ORD NOV 1.0>0[1.0] DEC 1.0>0[0.9] JAN 1.0>0[1.0] FEB 1.0>0[1.1] MAR 1.0>0.2[0.9]
UA HKG-SFO NOV 2>1.0[1.2] DEC 2>1.0[1.9] JAN 2>1.0[2.0] FEB 2>1.0[2] MAR 2>1.2[1.7]
UA IAD-MBJ NOV 0>0.3[0]
UA IAD-NAS NOV 0>0.3[0] DEC 0.1>0.3[0] JAN 0.2>0.4[0.5]
*UA IAD-PEK NOV 1.0>0[1.0] DEC 1.0>0[0.9] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 1.0>0.2[0.9]
UA IAD-PUJ JAN 0.3>0.5[1.0] FEB 0.1>0.4[0.3]
UA IAD-STL JAN 3>2[3] MAR 2>1.8[3]
UA IAH-ICT APR 4>3[4]
UA IAH-LIT APR 6>5[6]
UA IAH-MGA OCT 1.0>0.5[1.0]
UA IAH-PNS APR 5>4[5]
UA IAH-SAP OCT 2>1.0[1.2]
*UA IAH-SYD NOV 1.0>0[0.7] DEC 1.0>0[0.9] JAN 1.0>0[1.0] FEB 1.0>0[1.1] MAR 1.0>0.2[0.9]
UA IAH-TGU OCT 1.0>0.5[1.0]
*UA LAX-MEL NOV 1.0>0[1.0] DEC 1.0>0[0.5] JAN 1.0>0[0.9] FEB 1.0>0[1.1] MAR 1.0>0.2[0.5]
UA LAX-SUN JAN 1.0>0.4[0.4] FEB 1.0>0.4[1.1] MAR 0.9>0.5[0.9]
UA LAX-SYD NOV 1.0>0.4[0.6] DEC 1.0>0.5[0.9] JAN 1.0>0.4[1.0] FEB 1.0>0.4[1.1] MAR 1.0>0.5[0.9]
*UA MEL-SFO NOV 0.4>0[0.1] DEC 0.5>0[0.4] JAN 0.4>0[0.4] FEB 0.4>0[0.4] MAR 0.4>0.1[0.4]
UA MKE-ORD JUN 8>7[9]
UA MTJ-SFO JAN 0.5>0.3[0.4]
*UA ORD-PEK NOV 1.0>0[1.0] DEC 1.0>0[0.9] JAN 1.0>0[1.0] FEB 1.0>0[1.0] MAR 1.0>0.2[0.9]
*UA PVG-SFO NOV 2>1.0[2] DEC 2>1.0[1.9] JAN 2>1.0[2] FEB 2>1.0[2] MAR 2>1.2[1.7]
UA SFO-SUN JAN 1.0>0.3[0.4] FEB 1.0>0.4[1.1] MAR 0.9>0.4[0.9]
UP FLL-FPO DEC 1.1>0[0.8] JAN 1.4>0.1[1.7] MAR 0.3>0.1[0.7]
UP FLL-NAS OCT 2>1.1[3] JAN 4>2[5]
UP MCO-NAS OCT 0.9>0.5[1.0] JAN 1.6>0.3[1.7]
UP MHH-PBI JAN 0.7>0[0.9]
UP MIA-NAS OCT 2>1.1[2] DEC 3>0.6[3] JAN 3>0.8[3]
UX MAD-MIA OCT 0.6>0.4[0.6]
VB DFW-MTY OCT 0>0.3[0] NOV 0>0.3[0] DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0] APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0]
VB MEX-SAT OCT 0>0.3[0] NOV 0>0.3[0] DEC 0>0.3[0] JAN 0>0.3[0] FEB 0>0.3[0] MAR 0>0.3[0] APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0]
VS BOS-LHR OCT 0.5>0[0.5]
VS IAD-LHR OCT 0.2>0[0.2]
VS JFK-LHR OCT 3>1.4[3]
VS JFK-MAN OCT 0.2>0[0.2]
VS LAS-LHR OCT 0.2>0[0.2]
VS LHR-MCO OCT 0.6>0[0.6]
VS LHR-MIA OCT 0.7>0.4[0.7]
VS LHR-SEA OCT 0.2>0[0.2]
VS LHR-SFO OCT 0.5>0[0.5]
VS MAN-MCO OCT 0.6>0[0.6]
WN DEN-HDN APR 0.4>0.2[0]
WN IND-RSW OCT 1.1>1.5[1.1]
WS ATL-YYC OCT 0.9>0[0.9]
WS BNA-YYZ OCT 1.0>0[1.0]
WS BOS-YYZ OCT 1.7>0[1.7]
WS DEN-YYC OCT 0.3>0[0.4]
WS FLL-YYZ OCT 1.1>0[1.2]
WS HNL-YVR OCT 0.9>0[0.9]
WS IAH-YYC OCT 1.4>0[1.5]
WS JFK-YYC OCT 0.7>0[0.7]
WS KOA-YVR OCT 0.2>0[0.2]
WS LAS-YEG OCT 0.5>0[0.5]
WS LAS-YVR OCT 1.4>0[1.5]
WS LAS-YWG OCT 0.2>0[0.2]
WS LAS-YYC OCT 3>0[3]
WS LAS-YYZ OCT 1.5>0[1.5]
WS LAX-YEG OCT 0.8>0[0.9]
WS LAX-YVR OCT 2>0[3]
WS LAX-YYC OCT 1.5>0.3[1.8]
WS LAX-YYZ OCT 1.5>0[1.5]
WS LGA-YYZ OCT 6>0[6] NOV 6>5[7]
WS MCO-YYC OCT 0.4>0[0.4]
WS MCO-YYZ OCT 1.3>0[1.7]
WS MIA-YYZ OCT 0.2>0[0.2]
WS OGG-YVR OCT 1.0>0[1.0]
WS PDX-YYC OCT 0.9>0[0.9]
WS PHX-YEG OCT 0.8>0[0.9]
WS PHX-YVR OCT 0.3>0[0.4]
WS PHX-YYC OCT 1.9>0.2[2.0]
WS PSP-YVR OCT 1.2>0[1.2]
WS PSP-YYC OCT 1.4>0.2[1.5]
WS RSW-YYZ OCT 0.6>0[0.7]
WS SAN-YYC OCT 0.4>0[0.5]
WS SNA-YVR OCT 0.8>0[0.8]
WS TPA-YYZ OCT 0.4>0[0.5]
XL GYE-JFK OCT 0.2>0[0.2]
Y4 AGU-MDW OCT 0.4>0.2[0.4]
Y4 BJX-DFW OCT 0.3>0[0.3]
Y4 BJX-FAT OCT 0.4>0[0.4]
Y4 BJX-LAS OCT 0.5>0[0.5]
Y4 BJX-LAX OCT 0.7>0.5[0.7]
Y4 BJX-MDW OCT 0.7>0.3[0.7]
Y4 BJX-SJC OCT 0.3>0[0.3]
Y4 DFW-DGO OCT 0.3>0[0.3]
Y4 DFW-ZCL OCT 0.3>0[0.3]
Y4 GDL-JFK OCT 0.6>0[0.6]
Y4 GDL-LAS OCT 1.0>0.7[1.0]
Y4 GDL-LAX OCT 4>3[4]
Y4 GDL-ONT OCT 1.0>0.5[1.0]
Y4 GDL-RNO OCT 0.6>0.3[0.6]
Y4 GDL-SJC OCT 1.3>1.0[1.3]
Y4 GDL-SMF OCT 1.3>1.0[1.3]
Y4 LAS-MEX OCT 1.0>0.6[1.0]
Y4 LAX-MEX OCT 2>1.0[2]
Y4 LAX-MLM OCT 0.7>0.3[0.7]
Y4 LAX-OAX OCT 0.5>0.2[0.5]
Y4 LAX-ZCL OCT 0.7>0.4[0.7]
Y4 MCO-MEX OCT 0.5>0[0.5]
Y4 MDW-MLM OCT 1.3>0.9[1.3]
Y4 MDW-ZCL OCT 0.6>0.3[0.6]
Y4 MEX-MIA OCT 0.3>0[0.3]
Y4 MEX-ORD OCT 1.2>0.9[1.2]
Y4 MEX-SAT OCT 1.0>0.4[1.0]
Y4 ORD-QRO OCT 0.3>0[0.3]
Y4 PHX-PVR OCT 0.3>0[0.3]
Y4 SJC-ZCL OCT 0.3>0[0.3]
YR BLD-GCW NOV 1.0>0[0]
enilria
Re: OAG Changes 9/15/2020:AI Adds DELEWR,Cuts DELORD;DL Adds Winter LAXRNO;EK Suspends MCO;FI/KL/UA Suspend Long Haul Ro
Tue Sep 15, 2020 2:04 pm
Ran out of space, but I would call this week: MORE OF THE SAME
SESGDL
Tue Sep 15, 2020 2:12 pm
My favorite thread, thanks for continuing to do this each week!
Jeremy
Ishrion
Tue Sep 15, 2020 2:29 pm
Amazing increase for DFW-EYW.
First launched in early 2019 as a Saturday-only E-175. Now it looks to be a year-round 2x daily A319.
ericm2031
Tue Sep 15, 2020 2:34 pm
This looks to be a new route and 1st international destination out of LAX for NK.
williaminsd
Tue Sep 15, 2020 2:48 pm
I am noticing some increased love for RNO over the last month or so and the new LAX service on AA is yet another example. Nothing much reflected this year, but 2021 could be big for the airport.
Also noted from the report... is Boutique (4B) pulling out of MCE completely? Maybe that's where the equipment for PSP is coming from...
As always, thank you enilria.
In the land of lies, telling the truth is a crime...
usflyer msp
Tue Sep 15, 2020 2:49 pm
Yikes. Looks like AA is essentially shutting down ORD in October.
Thanks for the post, Enilra.
enilria
Tue Sep 15, 2020 2:51 pm
Jeremy
Nice of you to say. :)
I saw that. EYW is seeing a lot of refugees from lockdown. I saw SUN seems to be going the other way. The politics in SUN are probably different on tourists.
Nice catch
IDK. I see all sorts of flipping and flopping from the smaller carriers.
kavok
Tue Sep 15, 2020 2:59 pm
Thanks for the update as always Enilria!
Interesting to see DL make a “schedule reduction” at PVD (and not total drop). In previous weeks/months, DL basically had the PreCovid schedule as a placeholder for PVD flights, and would then drop all flights as the date approached. The fact that this time they are simply reducing flights, as opposed to dropping them altogether suggests that DL will finally be resuming service to Rhode Island (2x daily to DTW, 1x daily to ATL). Good to see, if the assumption is correct.
MIflyer12
Tue Sep 15, 2020 3:33 pm
How many flights a day (on avg) will AA be operating from ORD in October?
Midwestindy
Tue Sep 15, 2020 3:37 pm
I think it's an error, they cut all non-hub Wednesday flying from ORD except SEA (similar to PHL & MIA), and I'm assuming that messed up the data.
ORD & IND
AA & DL
DylanHarvey
Tue Sep 15, 2020 3:42 pm
I’m surprised JNB keeps getting postponed on DL.
chicawgo
Tue Sep 15, 2020 3:44 pm
That’s what I thought too but I did a bunch of dummy bookings and they have Generally 2x daily to all those places minus Tuesday and Wednesday. Not sure which is correct but maybe it’s messing with these numbers?
USAirALB
Tue Sep 15, 2020 3:53 pm
Air India is closing IAD?
RJ85, F70, E135, E140, E145, E70, E75, E90, CR2, CR7, CR9, 717, 732, 733, 734, 735, 73G, 738, 739, 744ER, 752, 753, 762, 763ER, 772, 77E, 77W, 789, 319, 320, 321, 332, 333, 343, 359, 388
MIAFLLPBIFlyer
Tue Sep 15, 2020 4:03 pm
I would expect ORD & IAD to be filed at some point in the future. Especially Chicago, I cannot see AI walking away from.
macsog6
Tue Sep 15, 2020 4:16 pm
[quote="williaminsd"]I am noticing some increased love for RNO over the last month or so and the new LAX service on AA is yet another example. Nothing much reflected this year, but 2021 could be big for the airport.
RNO occasionally picks up added flights as the winter approaches and the ski resorts open. Seems that some carriers are betting on the resorts being able to open with lessened Covid-19 restrictions and being outside in the fresh air decreases the risk of virus transmission per some sources.
Let it snow, let it snow...
Sixty Plus Years of Flying! "I fly because it releases my mind from the tyranny of petty things." - Saint Ex
775899
Tue Sep 15, 2020 4:19 pm
Or perhaps they are ceding the ORD route to UA?
Chuska
Tue Sep 15, 2020 4:21 pm
I dont think most of the 4B changes are correct, showing several other markets down to 0 as well (ABQ-CNM, CDR/CEZ-DEN). These markets, as well as MCE, are all EAS, shouldn't be changing without a replacement. LAX-PSP-PHX is odd although it does link the PHX and LAX operations. Wish 4B would link up some of there other holes like between ABQ and DEN.
Chuska
Tue Sep 15, 2020 4:43 pm
I don't think the AA flights are showing correctly either. I've noticed the past several weeks that the markets I regularly follow are not agreeing with AA.com like, for example, ABQ-LAX above. AA.com has always, and still shows 3 flights for Nov., I have no idea how they came up with 1.6>2, and Jan. is still showing 3 all month. AA currently is not running ABQ-LAX and has not done their Nov. final schedule yet, I'm expecting ABQ-LAX to stay at 0, maybe 1.0 with some luck. So I wouldn't believe many, if any of the Nov. AA changes in this report, something with the OAG isn't running right. Enilria, I know its not your fault, we all really appreciate what you do!!!
Jshank83
Tue Sep 15, 2020 5:00 pm
Agree with this. That must have messed up the numbers because STL is listed at .8 and it actually is 2.6
VTORD
Tue Sep 15, 2020 5:10 pm
Thanks enilria!
Is it possible that they have simply not filed S21 properly? DEL-ORD, BOM-EWR and DEL-JFK are all showing 0 flights Apr '21 onwards. Are we reading too much into this given UA's route announcement or am I not reading this correctly? I find it strange that they would cut these 3 all at once.
aerace
Tue Sep 15, 2020 5:22 pm
In last week's OAG, PHL-SRQ was showing as cut back for Nov/Dec, just like it is this week for Jan. It is still currently bookable as daily Nov 1 onward. So strange.
jayunited
Tue Sep 15, 2020 5:27 pm
I wouldn't say AA is shutting down ORD, it is more like they are right sizing it to fit COVID demand.
Keep in mind after COVID hit and UA took down our entire schedule and AA became the largest operator at ORD. AA hasn't been the largest operator at ORD for years but back in April of this year they were operating more flights, had more capacity than UA. AA as some point had to come to the realization that they have too much capacity in the Chicagoland market.
With the summer travel season behind us now is the time for airlines to start flying a more realistic and less optimistic domestic schedule especially if they want to keep their burn rates headed in the right direction.
I still believe the darkest days this industry will face are head of us, meaning January through early March of 2021, when leisure travel historically is at it lowest point. Historically in the month of October until a week or two before Thanksgiving leisure traffic falls off domestically. Even if there is a viable vaccine January and February 2021 will not be pretty if there is no uptick in leisure domestic traffic during the 2020 holiday season Q4 2020 will not be pretty. Depending on how things pan out in the leisure markets airlines could be in for a very long dark period (October through early March) where excess capacity will do more harm than good. I will be keeping my eye on the TSA numbers to see if how much of a drop in daily passenger screenings there could be as we head into the fall season verses the summer season.
Airlines have to remain vigilant and make sure they keep their burn rates on a downward trajectory.
rjbesikof
Tue Sep 15, 2020 5:48 pm
These look like the Pacific and Long Haul SA cuts. What has been zeroed out on the Europe end of things this winter? And what intl routes besides ORD-DEL are they planning to operate this winter aside from what is operating now?
LAXdude1023
Tue Sep 15, 2020 6:20 pm
IAH comes out soared in cuts sans SYD which is totally understandable.
IAH, we never get much but we don’t lose much either. In this day I consider that a victory.
FOR THE LOVE OF GOD BRING BACK THE PAYWALL!!!!
enilria
Tue Sep 15, 2020 6:27 pm
Thanks enilria!
I have no idea, but I don't think cuts after MAR would be real. They would cut it now if it were going away.
I think the carriers are filing lots of schedule changes versus once per week in the past and that increases the chance that the schedule update catches them in the middle of the process. Typically they delete overlapping flights and then add the new flights. It is supposed to happen without much of a gap, but I would guess we are seeing snapshots in between the deletes and the adds sometimes.
LASVegan
Tue Sep 15, 2020 11:49 pm
Looks like NK is planning to get somewhat back to normal in the spring. Hope it sticks.
LASVegan
phxa340
Wed Sep 16, 2020 5:46 am
Statistically, not a chance. They are just a throwing out a schedule to see what sticks. There’s no chance they fly all of this. Even with prices at zero, demand would still be subdued.
DaCubbyBearBar
Wed Sep 16, 2020 9:32 am
First of all, Enilria, THANK YOU for making Tuesday my favorite day of the week now!!! 2020 is a weird year.. LOL. At least this update seems to be a little less on the bloodshed side of life. Frontier looks like they are waving the white flag for November though...
I am me and no one else...so my opinions are mine
jb1087xna
Wed Sep 16, 2020 11:44 am
Thanks for the post as always!
Good for TUL! (Though ATL is down y/o/y I believe.) I continue to be in envy of the TUL route, being here around XNA.
APR? Why even bother adjusting that at this point?
VTORD
Wed Sep 16, 2020 12:46 pm
Thanks! Yeah that makes sense.
