ltbewr wrote:There are a lot of small cities, remote towns, islands that this will be a great for, especially for relatively large cargo items.
I wonder if this model and version can be used in winter environments, has improved de-icing systems that would expand its use year round into the northern USA including Alaska, Canada, Northern Europe, Russia, parts of China.
ATRs have been flying safely in Scandinavia, Canada and Russia for decades. There have even been some in Greenland from time to time.
Unless plans have changed, these will replace the existing contractor operated FedEx ATRs all over the world.
SXDFC wrote:Will it be possible to retrofit older ATRs to be able to accommodate containers?
The large cargo door (LCD) conversion has been around for 18 years. First was an ATR 72-202 converted in 2002. The big downside is that the conversion adds about a ton of weight, eating into the payload. By building them as freighters from new, you should make up some of that by omitting any of the passenger-specific fittings.
Boeing757rb211 wrote:It will be interesting to see how the 900 nm Range will work with a full payload and fuel, and with climbing to cruise altitude during abnormal events like a large storm in the way that would take too long to fly around. But it looks pretty damn good.
900 nm is no problem for a fully loaded ATR 72. With 7 tons of cargo it should do almost 1400 nm. 6 tons will give you enough fuel for 1800 nm. At 5 tons of payload, you can fill the tanks completely and reach out as far as 2300 nm.
