Max Q wrote:Anyway, a story I thought worth mentioning as I don’t think many people knew it and I’m curious to see if anyone can photo shop a Cathay DC10 ?
SpaceshipDC10 wrote:Max Q wrote:Anyway, a story I thought worth mentioning as I don’t think many people knew it and I’m curious to see if anyone can photo shop a Cathay DC10 ?
It's not completely unfamiliar to me, but I couldn't give much detail since I head/read about it last century.
LAXintl wrote:The book "From Betsy to Boeing" about CX and its aircraft provides color on this order but also gives credit that the L-1011 was evaluated to be technically superior when the order was placed in 1974 for two frames.
Interestingly, while CX operated quite a few TriStars, it only ever ordered those two frames directly from Lockheed, with all remaining fleet members being acquired under lease or second-hand purchases.
Another tidbit from the book is the L-1011 was highly regarded by both crew and customers in surveys and the fleet enjoyed higher dispatch reliability than the B747-200/300, though on paper it had higher per block hour maintenance cost which was driven largely by accounting book value write down requirements the company had to employ with the fleet.
Max Q wrote:That looks outstanding actually
Thanks for that
FlyHossD wrote:Very nice - well done, actually.
B595 wrote:But it fits with the fact that was mentioned up thread, that the DC-10-30 just was more versatile than any L1011 variant. It seems Lockheed really made an outsize competitive error by not engineering more room for growth into the L1011.
raylee67 wrote:BA was "asked" by the UK govt to buy the L10 too.
While the pressure to buy L10 over DC10 may be true, I don't think it really bothers CX a lot. The only routes that DC10 can fly and L10 cannot is SYD and MEL. And when the longer range L15 arrives, CX did not buy it too for the longer range routes. Besides, it has only ordered 2 new L10. It keeps voluntarily adding used L10 then, mostly ex-EA, to its fleet. It shows that CX genuinely like the aircraft at the end.
L10 also started the love affair between CX and RR. For a while, all aircraft in CX fleet is powered by RR engines. CX launched the RR powered 744, A333, 772A and 773A. It is, by then, not pressured any more to choose RR for all those aircraft types. But it did. And it did so with great fanfare. CX ordered the A343 rather late (compare to many competitors in the region) and one of the reasons is that A343 does not offer RR engines. CX only went for it after it carefully tried the A340 type out by leasing 4 new A342 from PR.
So I would say, although CX may have started the relationship with L10 and RR reluctantly, it was very happy with both at the end. And it probably doesn't feel that it has lost anything by not being able to get the DC10.
klm617 wrote:Wasn't the original order placed by BEA not British Airways ?
SpaceshipDC10 wrote:I don't recall whether CX only had -1s or some -100s, however, some 40 years, DL converted several of their Tristars to -250 variant, which gave'em a range comparable to the DC-10-30. I'm sure CX would have considered all the options if they really wanted such Trijets.
B595 wrote:SpaceshipDC10 wrote:I don't recall whether CX only had -1s or some -100s, however, some 40 years, DL converted several of their Tristars to -250 variant, which gave'em a range comparable to the DC-10-30. I'm sure CX would have considered all the options if they really wanted such Trijets.
Point taken about the -250, but they were very late to the game:
The DC-10-30 was produced in ‘72,
The L1011-500 was produced in ‘78,
Delta did the -250 upgrades in ‘86-‘88.
So it took Lockheed years to produce a true equivalent to the -30 (I don’t count the -500 as a true equivalent). I have to think that if the engineering of the L1011 allowed them to bring an answer earlier, they would have. But maybe this can’t be laid entirely at the foot of the airframe engineering. Maybe it just took time (too much time) for RR to develop an RB211 powerful enough for the -250.
FlyCaledonian wrote:The -250 upgrade was available to all frames from 1052 upwards, although anything other than a -200 (fitted with RB211-524B engines) required a full re-engine (from the RB211-22B of the -1/-100 to the RB211-524BI). The engines, lengthened wing, active-load-control ailerons and other system upgrades had all been developed for the -500 so these were all modifications to the baseline models. You can't blame RR because the engine was available once the -500 came online (and more powerful engines in the form of the RB211-524C/-524D were developed for the 747-200/-300/SP).
For whatever reason no other operators wanted to undertake the -250 mods. Even though you had airlines like British Airways or Saudia with -200s that could have received the mods without new engines.
SpaceshipDC10 wrote:FlyCaledonian wrote:The -250 upgrade was available to all frames from 1052 upwards, although anything other than a -200 (fitted with RB211-524B engines) required a full re-engine (from the RB211-22B of the -1/-100 to the RB211-524BI). The engines, lengthened wing, active-load-control ailerons and other system upgrades had all been developed for the -500 so these were all modifications to the baseline models. You can't blame RR because the engine was available once the -500 came online (and more powerful engines in the form of the RB211-524C/-524D were developed for the 747-200/-300/SP).
Perhaps no other airlines really needed these capabilies compared to DL and their ATL hub following deregulation. Also BA had the -500s for a while, then through BR acquisition they got a proper mid-size long-range fleet.
Perhaps no other airlines really needed these capabilities compared to DL and their ATL hub following deregulation. Also BA had the -500s for a while, then through BR acquisition they got a proper mid-size long-range fleet.
tnair1974 wrote:SpaceshipDC10 wrote:FlyCaledonian wrote:The -250 upgrade was available to all frames from 1052 upwards, although anything other than a -200 (fitted with RB211-524B engines) required a full re-engine (from the RB211-22B of the -1/-100 to the RB211-524BI). The engines, lengthened wing, active-load-control ailerons and other system upgrades had all been developed for the -500 so these were all modifications to the baseline models. You can't blame RR because the engine was available once the -500 came online (and more powerful engines in the form of the RB211-524C/-524D were developed for the 747-200/-300/SP).
McDonald Douglas proposed a RR powered DC-10 to British Airways similar to the long range -30 and -40 versions. But IIRC, this proposal was not offered until relatively late; if true, that option would have been after Cathy Pacific chose L-1011s.
As we know, British Airways selected the L-1011-500 instead, so DC-10s with RR engines never came to be. Perhaps fleet commonality was a major factor in the decision, as having -500s complimented BA's earlier medium range TriStars (as it turns out, British European Airways ordered those baseline L-1011s before the BEA/BOAC merger that formed BA). This was despite the DC-10 being a generally superior long range airliner as Max Q touched on earlier.
PM wrote:It's a long time since I read it but Beyond Lion Rock by Gavin Young is a good history of Cathay Pacific and certainly deals with the DC-10 / L1011 story.
SpaceshipDC10 wrote:B595 wrote:But it fits with the fact that was mentioned up thread, that the DC-10-30 just was more versatile than any L1011 variant. It seems Lockheed really made an outsize competitive error by not engineering more room for growth into the L1011.
B-HOP wrote:Apart from 2 that came directly from the factory (HHK/HHL) are -100, all the other were -1, -100 only managed to do Sydney with serious payload restrictions and was pulled away from the route soon after.
