thebigz
ET using B738(!) ARN-ADD
Sun Oct 25, 2020 8:40 am
According to Flightradar24 (https://www.flightradar24.com/data/flights/et714) (https://www.flightradar24.com/data/flights/et715) Ethiopian used a B738 instead of the ordinary Dreamliner or 777 on the ADD-ARN-OSL-ARN-ADD route this weekend.
The flying time was a whopping 7:30 on the way to Stockholm and 7:29 on the way back. They did not stop for fuel so I guess the load must have been very low.
If I am not mistaken this would make it one of the longest scheculed B738 route ever with standard config (Not ferry/BBJ). The distance according to GCMAP is 3108 nm to compare with 3283 nm BSB-MCO flown by GOL and 3132 nautical miles FOR-MCO.
A long time ago ET regularly did come to ARN with the B738 but then the flight to/from ADD included a fuel stop in CAI.
But incredible that they operate it nonstop!
MIflyer12
Re: ET using B738(!) ARN-ADD
Sun Oct 25, 2020 10:43 am
thebigz wrote:
If I am not mistaken this would make it one of the longest scheculed B738 route ever with standard config...
Can one really call it scheduled when it's an aircraft sub?
leleko747
Sun Oct 25, 2020 11:10 am
Please keep in mind that both o these flights were nonstop when operated by the B737 MAX 8.
When operated by the B737-800, there was a fuel stop in Punta Cana.
I wonder when people will understand:
Embraer 190 or simply E190, not ERJ-190. E-Jets are NOT ERJs!
Boeing 747-8, not Boeing 747-800. Same goes for 787.
Airbus A320, not Airbus 320.
Airbii does not exist.
Sun Oct 25, 2020 12:36 pm
Given the facts of ADD airport (elevation 2,334 m / 7,625 ft, weather etc.), I think it's a glitch/error... If you re-play the flight, a message will pop-up, that "part of this flight track was out our coverage" -which perfectly happens around Luxor, a perfect refuelling stop!
DY and X3 used to fly B738 from OSL, respectively HAM, to Dubai - and even with 1/3 capacity blocked, they needed many times a fuel stop on the return....
ARNPEK
Sun Oct 25, 2020 12:43 pm
I can't remember when they changed but ET operated a 737-800 with a fuel stop for many years on between ADD and ARN. It was eventually up-gauged to 787 and the tag on to OSL was added.
Avgeek21
Sun Oct 25, 2020 4:26 pm
I’ve done over 8hrs with a healthy load on a 738. And that was East to West too, into headwinds. Airtime far out stretched ground distance covered because of the headwinds. And it included holding. The domino’s need to work with you but it can go far. North-south here like ET will work in your favor too.
LifelinerOne
Sun Oct 25, 2020 6:54 pm
Although using the regular flight-nr, Ethiopian’s ET-AQO (which was deployed to Stockholm in this case) has often been used by the Ethiopian government for flights. So, this particular plane has the tendency to pop-up at strange airports once in a while.
Only Those Who Sleep Don't Make Mistakes
EIBPI
Sun Oct 25, 2020 7:21 pm
It definitely didn’t land in Luxor or anywhere else along the way (or you’ll have to explain how it did it in 25 minutes).
Revelation
Sun Oct 25, 2020 7:31 pm
Stellar performance by the Apollo-era Boeing 737-800!
ZKCIF
Sun Oct 25, 2020 9:21 pm
As this flight frequently flies above my town (Kaunas, Lithuania), I have been tracking it for more than a decade. and I can assure You that during the last maybe twelve years, I have seen 738s at least 30 times. I can list the registrations of the 738s which have done that before (mostly, from 2010 to 2015, after which they switched to 788/789 for 95 percent of the time). So, this route has been flown by (at least):
ET-ANZ
ET-AOA
AT-AOB
ET-APF
ET-APK
ET-APL
ET-APM
ET-APO
ET-AQM
Overall, this flight has featured about 10 types in the last 10 years; this could even be the world record.
was edited for clarity
berari
Sun Oct 25, 2020 10:46 pm
The tracking is accurate, it flew nonstop to ARN. Looking through other operations using the B788, the elapsed time nonstop to ARN is consistent.
Where ET needs a fuel stop, CAI is almost always the chosen intermediate point. We have seen it on the 738s to MAD, and sometimes to DME. It is worth noting that ET regularly operated the 738 to DME when it was nonstop.
Someone83
Mon Oct 26, 2020 7:21 am
Shouldn't the flight time ADD-ARN been longer that 7:30 if they added a fuel stop enroute?
BTW DY used to block about 1/6 of the seats on DXB-OSL ;)
ZKCIF
Thu Nov 05, 2020 9:04 pm
Look who's here today.
73G ET-ARD
https://www.flightradar24.com/ETH715/25f756d6
seansasLCY
Thu Nov 05, 2020 9:20 pm
73G ET-ARD
What is the business class like on their 737? I flew the 788 and 789 from ARN before and it was decent. I’m guessing it’s not a flat bed.
ZKCIF
Thu Nov 05, 2020 9:31 pm
From
https://milelion.com/2018/01/25/milelio ... ss-review/
I am quoting:
It’s not winning any marks for luxury, but the product on offer was good enough for a short 2 hour hop. Quality airlines are in scarce supply in Africa, and it says quite a bit that Ethiopian proudly trumpets the fact that it’s a Skytrax Four Star airline. If you need to connect within Africa, this is probably as good as it gets.
Fri Nov 06, 2020 2:56 pm
I don't wanna start a new topic - so please excuse!
KENYA AIRWAYS just flew B738 5Y-CYA from NBO to FCO in 07:26hrs - pretty close to the ET flight time...
https://www.flightradar24.com/data/flights/kq7500
berari
Fri Nov 06, 2020 3:01 pm
That's how they initially started services to FCO. And then they stopped. And then they did again with their 788s.
