enilria
OAG Changes 10/27/2020:DL PSP-SEA,CUN-CVG/RDU,EYWLGA Daily;UA Adds BER Breaks Curse,Extends Sun Adds;4B BWIORF,EUGPDX
Tue Oct 27, 2020 7:46 pm
FAQ
SOURCE: OAG
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
2D GYE-JFK DEC 0.3>0.5[0] JAN 0.3>0.6[0] FEB 0.3>0.6[0] MAR 0.2>0.5[0]
2D GYE-MIA DEC 0.3>0.6[0] JAN 0.3>0.6[0] FEB 0.3>0.6[0] MAR 0.3>0.5[0]
**3M CAE-FLL JAN 0>0.3[0] FEB 0>0.2[0] MAR 0>0.3[0] APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0]
**3M CAE-MCO JAN 0>0.3[0] FEB 0>0.2[0] MAR 0>0.3[0] APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0]
**3M CAE-TPA JAN 0>0.3[0] FEB 0>0.2[0] MAR 0>0.3[0] APR 0>0.3[0] MAY 0>0.3[0] JUN 0>0.3[0]
3M ELH-FLL JAN 0.6>0.3[1.7]
3M FLL-GGT JAN 0.6>0.4[1.2]
3/week?
**3M FLL-JAX JAN 0>0.4[0] FEB 0>0.4[0] MAR 0>0.3[0] APR 0>0.4[0] MAY 0>0.4[0] JUN 0>0.4[0]
**3M JAX-TPA JAN 0>0.4[0] FEB 0>0.4[0] MAR 0>0.3[0] APR 0>0.4[0] MAY 0>0.4[0] JUN 0>0.4[0]
**4B BWI-ORF DEC 0>1.0[0] JAN 0>1.0[0] FEB 0>1.0[0]
**4B EUG-PDX NOV 0>2[0] DEC 0>2[0] JAN 0>2[0] FEB 0>2[0]
4B PDT-PDX NOV 0.8>1.7[0]
4B PDX-RDM NOV 1.7>0.8[1.6] JAN 2>1.0[0] FEB 2>1.0[0]
4B PHX-SOW JAN 1.7>1.3[3]
9K ACK-BOS JUN 5>8[10]
9K ACK-HYA JUN 7>8[7]
9K ACK-JFK JUN 0>1.0[0.6]
9K AUG-BOS JUN 1.0>4[3]
9K BOS-LEB JUN 0>1.4[5]
9K BOS-MVY JUN 7>10[6]
9K BOS-PWM JUN 0>4[0.4]
9K BOS-RKD JUN 1.5>4[3]
9K BOS-SLK JUN 1.0>3[3]
9K JFK-MVY JUN 0>1.0[0.6]
AA ABQ-LAX DEC 2>3[3] JAN 2>3[3]
AA ALB-ORD DEC 1.6>2[3]
AA ATW-ORD DEC 2>3[3]
AA AZO-ORD DEC 2>3[2]
AA BGI-MIA NOV 1.7>1.0[3]
AA BGR-PHL NOV 1.0>0.7[3]
AA BHM-PHL MAR 1.3>1.7[1.8]
AA BNA-ORD DEC 5>6[8]
AA BWI-ORD NOV 1.1>1.8[3] DEC 3>4[4]
AA CAK-PHL MAR 0.7>1.1[1.9]
AA CDG-DFW DEC 1.0>0.0[1.3]
AA CHS-PHL NOV 1.0>0.7[4]
AA CLE-ORD DEC 4>5[7]
AA CLT-GCM NOV 0.3>0[1.6]
AA CLT-JFK NOV 1.0>0.8[5]
AA CMI-ORD DEC 4>5[5]
AA CWA-ORD DEC 2>3[2]
AA DCA-ORD DEC 8>9[8]
AA DFW-GPT JAN 1.7>0.8[3]
AA DFW-HKG DEC 0.5>0[1.0]
AA DFW-MAD DEC 1.0>0.0[1.4]
AA DSM-PHL MAR 1.0>1.3[0.9]
AA EVV-ORD DEC 1.2>2[1.9]
AA EWR-ORD DEC 4>5[6]
AA EZE-JFK DEC 0.5>0[1.0]
AA GCM-MIA NOV 0.3>0[1.5]
AA GRU-JFK DEC 0.5>0[1.0]
AA GSO-ORD DEC 1.4>1.9[1.8]
AA IAH-ORD DEC 2>1.6[3]
AA JFK-YUL DEC 1.8>1.2[0.9]
AA KIN-MIA NOV 2>1.6[4]
AA LAX-PDX DEC 2>3[3]
AA LAX-SFO NOV 1.4>1.8[7]
AA LSE-ORD DEC 2>3[3] JAN 2>3[3]
AA MAO-MIA DEC 0.4>0[0.7]
AA MCI-ORD DEC 5>6[6]
AA MCO-ORD DEC 3>4[4]
AA MGA-MIA NOV 0.8>0[3]
AA MKE-ORD DEC 3>4[4]
AA ORD-PIA DEC 1.9>3[3]
AA ORD-PVD DEC 2.0>3[3]
AA ORD-SYR DEC 3>4[4]
AA ORD-TOL DEC 1.3>2[3] JAN 2>3[3]
AA PHL-RDU NOV 1.8>1.2[6]
AM JFK-MTY JAN 0.7>0[1.0]
AM LAS-MTY JAN 0.2>0[0.6]
AM LAX-MTY DEC 0.5>0[0.9] JAN 1.0>0[1.0]
AS ABQ-SEA DEC 2.0>1.0[1.1]
AS ADQ-ANC DEC 1.8>1.3[1.6]
AS ANC-BET DEC 1.9>1.4[2]
AS ANC-BRW DEC 0.5>1.0[0.5]
AS ANC-HNL DEC 1.0>0.5[1.0]
AS ANC-JNU DEC 4>1.9[4]
AS ANC-LAX DEC 1.0>0.3[0.8]
AS ANC-OME DEC 1.4>0.9[1.5]
AS ANC-ORD DEC 0.5>0[0.4]
AS ANC-OTZ DEC 1.5>1.0[1.5]
AS ANC-PDX DEC 4>1.0[2]
AS ANC-PHX DEC 1.0>0.1[0.5]
AS ANC-SCC DEC 1.3>1.5[2]
AS ANC-SEA DEC 14>10[13]
AS ATL-SEA DEC 3>1.0[1.9]
AS AUS-PDX DEC 1.0>0[1.0]
AS AUS-SAN DEC 1.8>1.0[1.0]
AS AUS-SEA DEC 3>1.3[1.9]
AS AUS-SFO DEC 2.0>0.9[1.7]
AS AUS-SJC DEC 2.0>0.9[1.7]
AS BIL-PDX DEC 2.0>1.0[1.0]
AS BLI-SEA DEC 4>1.9[4]
AS BNA-SEA DEC 2>1.5[1.9]
AS BOI-GEG DEC 4>1.9[2]
AS BOI-PAE DEC 1.0>0[0]
AS BOI-PDX DEC 9>4[7] JAN 9>8[7]
AS BOI-SEA DEC 11>9[10]
AS BOI-SFO DEC 2.0>1.4[0]
AS BOI-SJC DEC 2>0.9[1.0]
AS BOS-LAX DEC 1.0>0[1.0]
AS BOS-PDX DEC 1.5>0[1.4] JAN 1.1>0.9[1.5]
AS BOS-SAN DEC 1.0>0[0.9]
AS BOS-SEA DEC 3>1.9[2]
AS BOS-SFO DEC 1.5>0[1.4] JAN 1.1>0.9[1.5]
AS BRW-FAI DEC 0.5>0[0.5]
AS BRW-SCC DEC 0.9>0[0.9]
AS BUR-PDX DEC 3>1.0[1.9]
AS BUR-SEA DEC 4>2[4]
AS BWI-SEA DEC 1.5>1.0[1.1]
AS CMH-SEA DEC 1.0>0.6[1.0]
AS DAL-LAX DEC 3>0.9[3]
AS DAL-PDX DEC 3>0[3]
AS DAL-SEA DEC 4>1.0[4]
AS DAL-SFO DEC 3>0.9[3]
AS DCA-PDX DEC 1.0>0[0.9]
AS DCA-SEA DEC 2>0.9[1.9]
AS DCA-SFO DEC 1.0>0[0.9]
AS DEN-PDX DEC 2>1.0[0]
AS DEN-SEA DEC 5>3[5]
AS EAT-SEA DEC 3>2.0[4]
AS EUG-PDX DEC 2.0>0[3]
AS EWR-LAX DEC 3>0.8[3]
AS EWR-PDX DEC 1.0>0[0.9]
AS EWR-SAN DEC 1.0>0[0.9]
AS EWR-SEA DEC 2>1.0[2]
AS EWR-SFO DEC 3>0.8[3]
AS EWR-SJC DEC 0.8>0[0.8]
AS FAI-SCC DEC 0.3>0[0.3]
AS FAI-SEA DEC 4>2.0[3]
AS FAT-LAX DEC 2.0>0.8[0]
AS FAT-PDX DEC 2>0.9[1.7]
AS FAT-SAN DEC 4>1.7[3]
AS FCA-PDX DEC 1.0>0[0]
AS FLL-LAX DEC 1.5>1.0[1.8]
AS FLL-SAN JAN 0.4>0.7[0] FEB 0.4>0.6[0] MAR 0.4>0.7[0] APR 0.4>0.7[0] MAY 0.4>0.7[0] JUN 0.4>0.7[0]
*AS FLL-SFO JAN 0.1>0.7[0.5] FEB 0>0.7[0.2] MAR 0>0.7[0.2] APR 0>0.7[0.6] MAY 0>0.4[0.5]
AS GEG-PAE DEC 1.0>0[0.9]
AS GEG-PDX DEC 8>4[7]
AS GEG-SAN DEC 2>1.4[1.0]
AS GEG-SEA DEC 14>11[16]
AS GEG-SFO DEC 1.9>1.0[0]
AS GTF-SEA DEC 2.0>0.9[1.6]
AS HLN-SEA DEC 2.0>0.9[1.0]
AS HNL-LAX DEC 1.0>0.8[1.0]
AS HNL-OAK DEC 0.4>0[0.6]
AS HNL-PDX DEC 1.0>0[1.0]
AS HNL-SEA DEC 3>1.8[3]
AS HNL-SFO DEC 1.0>0[1.0]
AS HNL-SJC DEC 1.0>0.5[0.7]
AS IAD-LAX DEC 2.0>0[1.8]
AS IAD-SEA DEC 3>1.0[1.1]
AS IAD-SFO DEC 2>0[1.7]
AS IAH-SEA DEC 2>1.0[1.9]
AS JAC-SEA DEC 0.4>0.2[0]
AS JFK-LAX DEC 5>0[5]
AS JFK-PDX DEC 1.0>0[1.0]
AS JFK-SEA DEC 3>1.0[3]
AS JFK-SFO DEC 4>0.8[4]
AS JNU-SEA DEC 3>2[4]
AS JNU-SIT DEC 1.8>1.0[1.8]
AS KOA-PDX DEC 1.0>0.5[0.8]
AS KOA-SAN DEC 1.0>0.5[0.6]
AS KOA-SEA DEC 3>1.8[1.9]
AS KOA-SJC DEC 1.0>0.5[0.6]
AS KTN-SEA DEC 3>1.9[3]
AS KTN-SIT DEC 1.0>0[1.0]
AS LAS-LAX DEC 1.9>0.7[4]
AS LAS-PAE DEC 2.0>0.9[1.9]
AS LAS-PDX DEC 4>3[3]
AS LAS-SFO DEC 4>3[7]
AS LAX-LIR DEC 0.8>0.6[0.8]
AS LAX-MSO DEC 1.0>0.5[0]
AS LAX-MZT DEC 0.8>0.5[0.9]
AS LAX-OGG DEC 1.0>0.7[1.0]
AS LAX-ORD DEC 1.0>0[1.0]
AS LAX-PAE DEC 2.0>0[2]
AS LAX-PDX DEC 9>4[7]
AS LAX-SEA DEC 13>8[13] JAN 14>13[13]
AS LAX-SFO DEC 14>4[10] JAN 14>12[10]
AS LAX-SJC DEC 7>1.9[4] JAN 7>6[4]
AS LAX-SJO DEC 0.7>0.5[0.7]
AS LAX-STS DEC 3>1.7[3]
AS LAX-ZIH DEC 0.7>0.4[0.9]
AS LAX-ZLO DEC 0.3>0.1[0.4]
AS LIH-OAK DEC 0.5>0[0.6]
AS LIH-PDX DEC 1.0>0.5[0.8]
AS LIH-SAN DEC 1.0>0.5[0.7]
AS LIH-SJC DEC 1.0>0.5[0.7]
AS MCI-PDX DEC 1.0>0[0.9]
AS MCI-SEA DEC 3>1.0[1.9]
AS MCO-SAN DEC 2.0>1.0[0.8]
AS MCO-SEA DEC 3>2[2]
AS MCO-SFO DEC 1.0>0.2[0.9]
AS MFR-PDX DEC 6>1.9[5]
AS MRY-SAN DEC 2>0.9[1.0]
AS MSP-PDX DEC 1.0>0[1.0]
AS MSP-SEA DEC 2.0>1.0[1.9]
AS MSY-SEA DEC 2>1.0[1.9]
AS OAK-OGG DEC 0.5>0[1.0]
AS OAK-PDX DEC 3>1.0[2]
AS OAK-SEA DEC 4>3[4]
AS OGG-PDX DEC 2.0>1.0[1.9]
AS OGG-SAN DEC 1.5>1.0[1.0]
AS OGG-SFO DEC 1.0>0[0.9]
AS OGG-SJC DEC 1.0>0.6[1.0]
AS OME-OTZ DEC 0.5>0[0.5]
AS ONT-PDX DEC 3>1.0[1.9]
AS ORD-PDX DEC 2.0>1.0[1.5]
AS ORD-SEA DEC 5>3[4]
AS ORD-SFO DEC 2.0>0.9[1.4]
AS PAE-PDX DEC 2>0[3]
AS PAE-PHX DEC 2.0>1.0[1.9]
AS PAE-SAN DEC 2.0>1.0[1.9]
AS PAE-SFO DEC 2.0>0[1.9]
AS PAE-SJC DEC 2.0>0[1.9]
AS PDX-PHX DEC 3>2[1.9]
AS PDX-RDM DEC 4>1.9[4]
AS PDX-RNO DEC 4>2[3]
AS PDX-SAN DEC 6>3[4]
AS PDX-SBP DEC 1.0>0[0]
AS PDX-SEA DEC 18>16[19]
AS PDX-SFO DEC 8>3[7] JAN 8>7[7]
AS PDX-SJC DEC 5>1.9[6]
AS PDX-SLC DEC 4>1.9[2]
AS PDX-SMF DEC 4>3[4]
AS PDX-SNA DEC 4>3[4]
AS PDX-STS DEC 2.0>1.0[1.4]
AS PDX-YVR DEC 1.0>0[1.0]
AS PHL-SEA DEC 2>1.0[1.9]
AS PHL-SFO DEC 1.0>0[0.1]
AS PHX-SFO DEC 2.0>0.9[0]
AS PIT-SEA DEC 1.0>0.7[1.0]
AS PSC-SEA DEC 6>4[6]
AS PSP-SEA DEC 4>6[4]
AS PSP-SFO DEC 5>3[4]
AS PUW-SEA DEC 4>1.8[5]
AS PVR-SAN DEC 1.0>0.5[0.5]
AS PVR-SJC DEC 1.0>0.1[0]
AS RDM-SFO DEC 1.0>0.4[0]
AS RDU-SEA DEC 2>1.0[1.0]
AS SAN-SBA DEC 1.0>0[0]
AS SAN-SBP DEC 1.0>0[0]
AS SAN-SEA DEC 10>7[8]
AS SAN-SFO DEC 8>3[5] JAN 8>7[6]
AS SAN-SJC DEC 6>3[4]
AS SAN-SJD DEC 2>1.0[1.7]
AS SAN-SLC DEC 0.9>0.4[1.0]
AS SAN-STS DEC 1.5>1.0[1.0]
AS SAT-SEA DEC 2>1.0[1.9]
AS SEA-SFO DEC 13>5[12] JAN 13>11[12]
AS SEA-SJC DEC 9>5[8]
AS SEA-SJD JAN 1.1>2[1.5] FEB 1.6>2[1.4]
AS SEA-SLC DEC 5>4[4]
AS SEA-SMF DEC 6>5[6]
AS SEA-SNA DEC 8>5[8]
AS SEA-STL DEC 2.0>1.0[1.8]
AS SEA-STS DEC 2>1.5[1.1]
AS SEA-TPA DEC 2>1.5[1.3]
AS SEA-YEG DEC 3>0[3]
AS SEA-YKM DEC 3>2.0[4]
AS SEA-YLW DEC 1.4>0[1.0]
AS SEA-YVR DEC 6>1.9[5]
AS SEA-YYC DEC 3>0[3]
AS SEA-YYJ DEC 4>0[4]
AS SFO-SLC DEC 1.7>0.9[1.0]
AS SFO-SNA DEC 7>3[7]
AS SJC-SJD DEC 1.5>1.0[0.8]
AT CMN-IAD DEC 0>0.3[0.4] JAN 0>0.5[0.6] FEB 0.1>0.4[0.6]
AT CMN-JFK DEC 0.6>0.8[1.0]
AV BOG-FLL NOV 0>0.3[2.0] DEC 1.9>0.4[1.0]
AV BOG-IAD NOV 1.0>0.6[2] DEC 2>1.0[1.0]
AV BOG-JFK DEC 3>2.0[3]
AV BOG-LAX DEC 1.0>0[1.0]
AV BOG-MCO NOV 1.0>0.3[1.9] DEC 1.9>0.6[1.4]
AV BOG-MIA DEC 4>2[4]
B0 EWR-ORY NOV 2>0[2]
JUN is a schedule extension. Don't pay much attention.
B6 ABQ-JFK JUN 0.5>1.0[0.4]
B6 ACK-BOS JUN 0.9>1.7[0]
B6 ACK-DCA JUN 0.2>0.4[0]
B6 ACK-HPN JUN 0.5>1.0[0]
B6 ACK-JFK JUN 1.9>4[0]
B6 ACK-LGA JUN 0.3>0.7[0]
B6 ALB-FLL JUN 0.5>1.0[0.3]
B6 ALB-MCO JUN 0.5>1.0[0.5]
B6 ANU-JFK JUN 0.3>0.6[0]
B6 ATL-BOS JUN 3>5[2]
B6 ATL-FLL JUN 1.1>2[1.0]
B6 ATL-JFK JUN 1.0>1.9[1.0]
B6 ATL-MCO JUN 0.5>1.0[0]
B6 AUA-BOS JUN 0.8>1.6[2.0]
B6 AUA-EWR JUN 0.5>1.0[0]
B6 AUA-FLL JUN 0.3>0.6[0]
B6 AUA-JFK JUN 1.7>3[1.1]
B6 AUS-BOS JUN 1.6>3[1.5]
B6 AUS-EWR JUN 1.1>2[0]
B6 AUS-FLL JUN 0.5>1.0[0.6]
B6 AUS-JFK JUN 1.1>2.0[0.9]
B6 AUS-LAX JUN 0.5>1.0[0]
B6 AUS-MCO JUN 0.5>1.0[0.6]
B6 BDA-BOS JUN 0.5>1.0[0]
B6 BDA-JFK JUN 1.1>2[0.1]
B6 BDL-CUN JUN 0.5>1.0[0]
B6 BDL-FLL JUN 1.1>2[1.1]
B6 BDL-LAS JUN 0.5>1.0[0]
B6 BDL-LAX JUN 0.5>1.0[0]
B6 BDL-MCO JUN 1.1>2[1.1]
B6 BDL-PBI JUN 0.5>1.0[0.6]
B6 BDL-SFO JUN 0.5>1.0[0]
B6 BDL-SJU JUN 1.5>2.9[1.1]
B6 BDL-TPA JUN 0.5>1.0[0.5]
B6 BGI-JFK JUN 1.7>3[0]
B6 BNA-BOS JUN 1.1>2[0.9]
B6 BNA-FLL JUN 0.5>1.0[0.6]
B6 BNA-JFK JUN 1.1>2[1.4]
B6 BOG-FLL JUN 1.0>1.9[0.3]
B6 BOG-MCO JUN 0.5>1.0[0]
B6 BOS-BUF JUN 1.6>3[2.0]
B6 BOS-BUR JUN 0.5>1.0[0]
B6 BOS-BWI JUN 3>5[0]
B6 BOS-CHS JUN 1.1>2[1.4]
B6 BOS-CLE JUN 2>4[2]
B6 BOS-CLT NOV 0.8>0.6[3] JUN 3>5[3]
B6 BOS-DCA JUN 8>15[6]
B6 BOS-DEN JUN 1.5>3[0.9]
B6 BOS-DFW JUN 1.1>2[0.4]
B6 BOS-DTW JUN 2>4[2]
B6 BOS-EWR JUN 4>7[1.9]
B6 BOS-FLL JUN 2>4[4]
B6 BOS-IAH JUN 0.5>1.0[0.3]
B6 BOS-JAX JUN 1.0>1.8[1.0]
B6 BOS-JFK JUN 3>6[4]
B6 BOS-LAS JUN 1.6>3[2]
B6 BOS-LAX JUN 3>5[3]
B6 BOS-LGA JUN 5>8[0]
B6 BOS-MCO JUN 3>6[4]
B6 BOS-MSP JUN 1.5>3[0.4]
B6 BOS-MSY JUN 0.5>1.0[1.5]
B6 BOS-MVY JUN 0.5>1.0[0]
B6 BOS-ORD NOV 1.9>1.5[3] JUN 3>6[3]
B6 BOS-PAP JUN 0.4>0.7[0]
B6 BOS-PBI JUN 2>4[2]
B6 BOS-PDX JUN 1.1>2[0]
B6 BOS-PHL JUN 4>8[3]
B6 BOS-PHX JUN 1.1>2[1.0]
B6 BOS-PIT NOV 1.3>1.0[3] JUN 2>5[3]
B6 BOS-RDU JUN 3>6[4]
B6 BOS-RIC JUN 2>4[2]
B6 BOS-ROC JUN 0.5>1.0[0.4]
B6 BOS-RSW JUN 1.4>3[3]
B6 BOS-SAN JUN 2>4[1.9]
B6 BOS-SAV JUN 0.5>1.0[1.0]
B6 BOS-SDQ JUN 1.1>2[1.0]
B6 BOS-SEA JUN 1.5>3[1.0]
B6 BOS-SFO JUN 3>5[4]
B6 BOS-SJC JUN 1.0>1.8[0]
B6 BOS-SJU JUN 2.1>4.0[1.0]
B6 BOS-SLC JUN 0.5>1.0[0.6]
B6 BOS-SMF JUN 0.5>1.0[0]
B6 BOS-STI JUN 1.1>2[0]
B6 BOS-SYR JUN 0.5>1.0[1.0]
B6 BOS-TPA JUN 1.6>3[3]
B6 BQN-FLL JUN 0.5>1.0[0]
B6 BQN-JFK JUN 0.5>1.0[0]
B6 BQN-MCO JUN 1.6>3.0[0.4]
B6 BTV-JFK JUN 1.6>3[1.0]
B6 BUF-FLL JUN 0.5>1.0[0]
B6 BUF-JFK NOV 1.0>0.8[4] JUN 3>5[3]
B6 BUF-LAX JUN 0.5>1.0[0]
B6 BUF-MCO JUN 0.5>1.0[0.5]
B6 BUR-JFK JUN 1.0>1.9[0]
B6 BZN-JFK JUN 0.5>1.0[0]
B6 BZN-LAX JUN 0.2>0.4[0]
B6 CHS-EWR JUN 0.5>1.0[0]
B6 CHS-FLL JUN 0.5>1.0[0.6]
B6 CHS-JFK JUN 1.1>2.0[1.0]
B6 CHS-LAX JUN 0.5>1.0[0]
B6 CLE-FLL JUN 0.5>1.0[0]
B6 CLE-RSW JUN 0.5>1.0[0]
B6 CTG-FLL JUN 0.5>1.0[0]
B6 CTG-JFK JUN 0.8>1.4[0]
B6 CUN-EWR NOV 0.4>0.2[1.9] JUN 1.1>2[0]
B6 CUN-FLL JUN 1.6>3[0.4]
B6 CUN-JFK JUN 1.6>3[1.0]
B6 CUN-LAX JUN 1.1>2[0]
B6 CUN-MCO JUN 1.1>2[0.6]
B6 CUN-RDU JUN 0.5>1.0[0]
B6 CUN-SFO JUN 1.1>2[0]
B6 CUN-TPA JUN 0.5>1.0[0]
B6 CUR-JFK JUN 0.2>0.4[0]
B6 DCA-FLL JUN 3>6[2]
B6 DCA-MCO JUN 2>4[2]
B6 DCA-MVY JUN 0.2>0.4[0]
B6 DCA-PBI JUN 1.1>2[0.6]
B6 DCA-RSW JUN 0.5>1.0[0.6]
B6 DCA-SJU JUN 0.5>1.0[0.4]
B6 DCA-TPA JUN 0.5>1.0[0]
B6 DEN-JFK JUN 1.1>2[0.8]
B6 DFW-JFK JUN 1.1>2[0]
B6 DTW-JFK JUN 1.1>2[0]
B6 EWR-FLL JUN 2>4[3]
B6 EWR-JAX JUN 0.5>1.0[0]
B6 EWR-LAS JUN 1.1>2[0]
B6 EWR-LAX JUN 3>5[0]
B6 EWR-MBJ JUN 0.5>1.0[0]
B6 EWR-MCO JUN 3>6[3]
B6 EWR-NAS JUN 0.5>1.0[0]
B6 EWR-PBI JUN 1.1>2[1.0]
B6 EWR-PHX JUN 1.1>2[0]
B6 EWR-PLS JUN 0.5>1.0[0]
B6 EWR-PUJ JUN 0.5>1.0[0]
B6 EWR-RSW JUN 0.5>1.0[0.6]
B6 EWR-SAN JUN 0.5>1.0[0]
B6 EWR-SDQ JUN 1.1>2[0.8]
B6 EWR-SFO JUN 1.1>2[0]
B6 EWR-SJU JUN 2.1>3.9[1.5]
B6 EWR-SRQ JUN 0.5>1.0[0]
B6 EWR-STI JUN 1.5>3[0.6]
B6 EWR-SXM JUN 0.5>1.0[0]
B6 EWR-TPA JUN 1.1>2[1.0]
B6 FLL-GCM JUN 0.2>0.4[0.2]
B6 FLL-GYE JUN 0.5>1.0[0.8]
B6 FLL-HAV JUN 1.5>3[1.0]
B6 FLL-HPN JUN 1.1>2[0]
B6 FLL-JAX JUN 2>4[1.6]
B6 FLL-JFK JUN 4>8[3]
B6 FLL-KIN JUN 2>4[0.4]
B6 FLL-LAS JUN 1.1>2[1.1]
B6 FLL-LAX JUN 3>5[3]
B6 FLL-LGA JUN 1.1>2[0]
B6 FLL-LIM JUN 0.5>1.0[0.6]
B6 FLL-MBJ JUN 1.6>3[0.5]
B6 FLL-MDE JUN 0.5>1.0[0]
B6 FLL-MSY JUN 0.5>1.0[0.6]
B6 FLL-NAS JUN 2>4[1.0]
B6 FLL-ORD JUN 0.5>1.0[0]
B6 FLL-PAP JUN 1.6>3[0.6]
B6 FLL-PHL JUN 0.5>1.0[0.6]
B6 FLL-PHX JUN 0.5>1.0[0]
B6 FLL-PIT JUN 0.5>1.0[0]
B6 FLL-PLS JUN 0.4>0.7[0.4]
B6 FLL-POS JUN 0.5>1.0[0.2]
B6 FLL-PUJ JUN 0.2>0.4[0.2]
B6 FLL-PVD JUN 0.5>1.0[0]
B6 FLL-RDU JUN 1.1>2[0.6]
B6 FLL-RIC JUN 0.8>1.6[0.6]
B6 FLL-SAN JUN 0.5>1.0[0]
B6 FLL-SDQ JUN 0.5>1.0[0.6]
B6 FLL-SEA JUN 0.2>0.4[0]
B6 FLL-SFO JUN 1.6>3[1.0]
B6 FLL-SJO JUN 0.5>1.0[0.3]
B6 FLL-SJU JUN 3.1>6[2.8]
B6 FLL-SLC JUN 0.5>1.0[0]
B6 FLL-SXM JUN 0.2>0.4[0.2]
B6 FLL-UIO JUN 0.5>1.0[0.6]
B6 GCM-JFK JUN 0.3>0.6[0.2]
B6 GND-JFK JUN 1.1>2[0.4]
B6 GUA-JFK JUN 0.5>1.0[0]
B6 GYE-JFK JUN 0.5>1.0[0]
B6 HPN-MCO JUN 1.6>3[0]
B6 HPN-PBI JUN 1.6>3[0]
B6 HPN-RSW JUN 1.1>2[0]
B6 HPN-TPA JUN 0.5>1.0[0]
B6 HYA-JFK JUN 0.5>1.0[0]
B6 IAH-JFK JUN 0.5>1.0[0.3]
B6 JAX-JFK JUN 1.6>3[1.0]
B6 JFK-KIN JUN 2>4[1.0]
B6 JFK-LAS JUN 3>5[2]
B6 JFK-LAX JUN 5>10[6]
B6 JFK-LIR JUN 0.5>1.0[0]
B6 JFK-MBJ JUN 1.1>2[1.0]
B6 JFK-MCO JUN 4>8[4]
B6 JFK-MSP JUN 1.1>2[0]
B6 JFK-MSY JUN 1.1>2.0[1.0]
B6 JFK-MVY JUN 1.1>2[0]
B6 JFK-NAS JUN 1.1>2[0.6]
B6 JFK-ONT JUN 0.5>1.0[0]
B6 JFK-ORD NOV 0.7>0.5[3] JUN 1.0>1.9[0]
B6 JFK-PAP JUN 1.1>2[0.4]
B6 JFK-PBI JUN 1.6>3[2]
B6 JFK-PDX JUN 0.5>1.0[0]
B6 JFK-PHX JUN 0.5>1.0[0]
B6 JFK-PLS JUN 0.6>1.1[0.6]
B6 JFK-POP JUN 1.1>2[0.3]
B6 JFK-POS JUN 1.1>2[0]
B6 JFK-PSE JUN 0.5>1.0[0]
B6 JFK-PUJ JUN 1.0>1.9[1.0]
B6 JFK-PWM JUN 1.6>3[0]
B6 JFK-RDU JUN 1.1>2[1.0]
B6 JFK-RNO JUN 0.5>1.0[0]
B6 JFK-ROC NOV 1.3>1.0[3] JUN 1.6>3[1.0]
B6 JFK-RSW JUN 1.6>3[1.0]
B6 JFK-SAN JUN 1.1>2.0[1.0]
B6 JFK-SAV JUN 1.1>2.0[1.0]
B6 JFK-SDQ JUN 4>7[2]
B6 JFK-SEA JUN 1.0>1.9[1.0]
B6 JFK-SFO JUN 3>6[3]
B6 JFK-SJC JUN 0.5>1.0[0]
B6 JFK-SJO JUN 0.5>1.0[0]
B6 JFK-SJU JUN 3.8>7[3.0]
B6 JFK-SLC JUN 1.1>2[1.0]
B6 JFK-SMF JUN 0.5>1.0[0.4]
B6 JFK-SRQ JUN 0.5>1.0[0.6]
B6 JFK-STI JUN 4>7[2]
B6 JFK-SXM JUN 0.7>1.3[0.6]
B6 JFK-SYR JUN 1.1>2.0[1.0]
B6 JFK-TPA JUN 2>4[2]
B6 JFK-UVF JUN 0.6>1.1[0.6]
B6 LAS-LAX JUN 1.1>2[0]
B6 LAS-RIC JUN 0.5>1.0[0]
B6 LAX-MCO JUN 0.3>0.7[0]
B6 LAX-PBI JUN 0.5>1.0[0]
B6 LAX-RDU JUN 0.5>1.0[0]
B6 LAX-RIC JUN 0.5>1.0[0]
B6 LAX-RNO JUN 0.5>1.0[0]
B6 LAX-SEA JUN 0.5>1.0[0]
B6 LAX-SFO JUN 1.1>2[0]
B6 LAX-SJO JUN 0.5>1.0[0]
B6 LAX-SLC JUN 1.1>2[0]
B6 LGA-MCO JUN 1.1>2[0]
B6 LGA-PBI JUN 1.1>2[0]
B6 LGA-RSW JUN 0.5>1.0[0]
B6 LGA-TPA JUN 1.1>2[0]
B6 MBJ-MCO JUN 1.1>2[0.4]
B6 MBJ-RDU JUN 0.5>1.0[0]
B6 MCO-NAS JUN 0.4>0.8[0]
B6 MCO-PHL JUN 1.1>2.0[0]
B6 MCO-PSE JUN 1.1>2.0[0.4]
B6 MCO-PVD JUN 0.5>1.0[0]
B6 MCO-RIC JUN 1.1>2[0.8]
B6 MCO-SDQ JUN 1.1>2[0]
B6 MCO-SFO JUN 0.5>1.0[0]
B6 MCO-SJO JUN 0.5>1.0[0.4]
B6 MCO-SJU JUN 3.7>7[3.8]
B6 MCO-SLC JUN 0.5>1.0[0.6]
B6 MCO-SYR JUN 0.5>1.0[0.6]
B6 ORD-PBI JUN 0.5>1.0[0]
B6 PBI-PHL JUN 1.1>2[0]
B6 PBI-PIT JUN 0.5>1.0[0]
B6 PBI-PVD JUN 0.5>1.0[0]
B6 PHL-RSW JUN 0.5>1.0[0]
B6 PHL-SJU JUN 0.5>1.0[0]
B6 PHL-TPA JUN 0.5>1.0[0]
B6 PVD-RSW JUN 0.5>1.0[0]
B6 PVD-TPA JUN 0.5>1.0[0]
B6 RDU-RSW JUN 0.5>1.0[0]
B6 RDU-SJU JUN 0.5>1.0[0]
B6 RIC-TPA JUN 0.5>1.0[0]
B6 SJU-TPA JUN 1.1>2.0[0.6]
BA ATL-LHR NOV 1.0>0.4[0.6]
BA BOS-LHR NOV 1.9>0.9[1.9]
BA DEN-LHR NOV 0.4>0[1.0]
BA JFK-LHR NOV 5>1.9[6]
BA LAS-LHR NOV 0.4>0[1.0]
BA LAX-LHR NOV 1.5>1.0[1.5]
BA LGW-MCO NOV 0.7>0[0.4]
BA LHR-ORD NOV 2>1.0[2]
BA LHR-SEA NOV 1.0>0.6[1.0]
BW GEO-JFK NOV 1.1>0.6[1.2] DEC 1.1>0.5[1.4] JAN 1.2>0.6[1.5] FEB 1.1>0.6[1.5] MAR 1.1>0.9[1.3]
DL ABE-ATL DEC 2>0.8[3]
DL ABE-DTW DEC 1.9>3[3]
DL ABQ-ATL DEC 2>1.5[2]
DL ALB-ATL DEC 2>0.9[3]
DL AMS-MSP DEC 0.8>1.0[1.8]
DL ANC-SEA DEC 3>4[3] JAN 3>4[3]
DL ANC-SLC DEC 0.8>1.0[0]
DL ANU-ATL DEC 0.1>0.4[0.1] JAN 0.1>0.3[0.1]
DL ATL-ATW DEC 1.8>0.8[1.6]
DL ATL-AUS DEC 7>5[7]
DL ATL-AVL DEC 6>5[6] JAN 7>6[7]
DL ATL-BDL DEC 6>4[6]
DL ATL-BHM DEC 8>6[9]
DL ATL-BNA DEC 8>5[10] JAN 9>8[9]
DL ATL-BOS DEC 11>8[11] JAN 12>11[12]
DL ATL-BQK DEC 2>3[3]
DL ATL-BTR DEC 5>4[6]
DL ATL-BTV DEC 0.5>0[0.9] JAN 1.0>0.7[1.0]
DL ATL-BUF DEC 3>1.9[4]
DL ATL-BUR DEC 1.4>0[1.5] JAN 1.8>1.3[1.8]
DL ATL-BWI DEC 8>6[10]
DL ATL-CHA DEC 7>6[9] JAN 8>7[9]
DL ATL-CHO DEC 3>2.0[4] JAN 4>3[4]
DL ATL-CHS DEC 10>8[10]
DL ATL-CID DEC 1.6>0[3] JAN 1.9>1.4[3]
DL ATL-CLT DEC 8>6[9]
DL ATL-CMH DEC 7>6[7]
DL ATL-COS DEC 0.8>0[0.9] JAN 1.0>0.7[0.9]
DL ATL-CSG DEC 2>3[4]
DL ATL-CVG DEC 8>7[7]
DL ATL-DCA DEC 10>7[10] JAN 11>10[11]
DL ATL-DFW DEC 8>6[8]
DL ATL-DHN DEC 2>3[4]
DL ATL-EWR DEC 9>7[9]
DL ATL-EZE DEC 0.5>0.2[0.8]
DL ATL-FLL DEC 13>12[11]
DL ATL-FWA DEC 3>2[4]
DL ATL-GCM DEC 1.2>0.5[1.0] JAN 1.3>1.0[1.3]
DL ATL-GIG DEC 0.4>0[1.0]
DL ATL-GRB DEC 1.1>1.8[1.5] JAN 0.9>1.3[1.0]
DL ATL-GTR DEC 2>3[3] JAN 4>3[3]
DL ATL-GUA JAN 1.1>1.3[1.4]
DL ATL-HHH DEC 3>2[3]
DL ATL-HNL DEC 0.8>0.5[0.9]
DL ATL-HOU DEC 5>4[6]
DL ATL-HPN JAN 6>4[6]
DL ATL-HSV DEC 6>5[7]
DL ATL-IAD DEC 6>4[6]
DL ATL-ICT DEC 3>1.8[3]
DL ATL-IND DEC 8>6[9]
DL ATL-JAN DEC 6>4[6] JAN 7>6[6]
DL ATL-JAX DEC 11>10[10]
DL ATL-JFK DEC 6>5[7]
DL ATL-LGA DEC 13>7[14] JAN 15>13[15]
DL ATL-LIM NOV 0.6>0.2[1.0]
DL ATL-LIR DEC 1.5>1.0[1.0]
DL ATL-MCI DEC 7>6[7]
DL ATL-MCO DEC 17>14[16] JAN 16>15[17]
DL ATL-MDW DEC 4>3[6]
DL ATL-MEM DEC 8>6[10]
DL ATL-MGM JAN 6>5[6]
DL ATL-MKE DEC 6>5[6]
DL ATL-MOB DEC 4>3[6] JAN 7>6[6]
DL ATL-MSN DEC 2>1.8[3]
DL ATL-MSY DEC 9>6[9] JAN 9>8[10]
DL ATL-NAS DEC 2>1.8[4]
DL ATL-OAJ DEC 3>4[3]
DL ATL-OAK JAN 0.9>0.7[0.1]
DL ATL-OKC DEC 5>4[5]
DL ATL-ONT DEC 1.7>2[1.5] JAN 1.7>2[1.6]
DL ATL-ORD DEC 8>6[10]
DL ATL-ORF DEC 8>7[8]
DL ATL-PBI DEC 10>9[10]
DL ATL-PHX DEC 5>6[6]
DL ATL-PIT DEC 6>5[7]
DL ATL-PNS DEC 8>6[7]
DL ATL-PTY DEC 1.0>0.5[1.0]
DL ATL-PVR DEC 0.8>1.2[0.3] JAN 1.0>1.3[0.6]
DL ATL-RDU DEC 10>8[12]
DL ATL-RIC DEC 7>6[8]
DL ATL-ROC DEC 2>1.0[3]
DL ATL-RST DEC 1.1>0[1.6] JAN 1.0>0.7[1.6]
DL ATL-SAN DEC 5>4[5]
DL ATL-SAT DEC 6>5[7]
DL ATL-SBN DEC 4>3[4]
DL ATL-SCL DEC 0.5>0.3[1.0]
DL ATL-SDF DEC 7>5[7]
DL ATL-SFO DEC 7>5[6]
DL ATL-SHV DEC 4>3[6]
DL ATL-SJC DEC 2>0[2] JAN 3>1.9[3]
DL ATL-SJD DEC 1.0>1.5[0.7] JAN 1.0>2[1.1] FEB 1.0>2[1.2] MAR 1.0>2[1.1] APR 1.0>2[1.2]
DL ATL-SJO DEC 2>1.0[1.9]
DL ATL-SNA DEC 3>1.8[3]
DL ATL-STL DEC 6>4[7]
DL ATL-SYR DEC 3>1.0[3]
DL ATL-TLH DEC 6>5[7]
DL ATL-TUL DEC 4>3[4]
DL ATL-VCE JUN 0>0.7[0]
DL ATL-VLD DEC 1.4>2[3]
DL ATL-YUL DEC 3>0[4] JAN 4>3[4]
DL ATL-YVR DEC 0.8>0[0.4] JAN 1.0>0.7[0.5]
DL ATL-YYZ DEC 5>0.4[6] JAN 6>5[6]
DL ATW-DTW DEC 2>3[3]
DL AUS-BOS DEC 0.6>0[0.9] JAN 1.6>1.2[0.6]
DL AUS-DTW DEC 3>1.4[3]
DL AUS-JFK DEC 2.0>1.0[2]
DL AUS-MSP DEC 1.9>1.4[2]
DL AUS-RDU DEC 0.4>0[0.7] JAN 1.0>0.7[0.6]
DL AUS-SEA DEC 1.3>0.8[0.7]
DL BDL-CLE JAN 0.8>0.6[0.6]
DL BDL-CVG JAN 0.8>0.6[0.6]
DL BDL-DTW DEC 4>3[4]
DL BDL-MSP DEC 3>2.0[3]
DL BDL-RDU DEC 0.5>0[0.8] JAN 1.0>0.7[0.8]
DL BGM-DTW DEC 2>1.0[3] JAN 3>2[3]
DL BHM-DTW DEC 1.4>0[2] JAN 3>1.9[2]
DL BHM-LGA DEC 1.4>0[2] JAN 2>1.6[2.0]
DL BNA-BOS DEC 2>1.0[3]
DL BNA-JFK DEC 1.5>0[2] JAN 1.9>1.4[2.0]
DL BNA-LAX DEC 1.2>1.7[1.5] JAN 1.0>1.3[1.3]
DL BNA-LGA DEC 4>3[5]
DL BNA-RDU JAN 1.7>1.3[1.2]
DL BNA-SEA DEC 1.0>0.8[0.8]
DL BNA-SLC DEC 1.3>1.9[1.6] JAN 0.8>1.2[1.0]
A lot of BOS cuts
DL BOS-BUF JAN 2>1.9[1.7]
DL BOS-CHS DEC 0.7>0[0.9] JAN 1.0>0.7[1.0]
DL BOS-CLE DEC 1.8>1.0[2]
DL BOS-CMH DEC 1.3>0[2] JAN 3>1.9[2]
DL BOS-CVG DEC 3>0.6[3] JAN 4>3[3]
DL BOS-DCA DEC 3>0[5] JAN 5>4[5]
DL BOS-DTW DEC 6>4[6]
DL BOS-EWR DEC 1.4>0[4] JAN 4>3[4]
DL BOS-FCO JUN 0>1.0[0]
DL BOS-FLL DEC 0.9>1.4[0.9] JAN 0.9>1.2[1.6]
DL BOS-IND DEC 1.8>0[3] JAN 3>1.9[3]
DL BOS-JAX DEC 1.6>0[2] JAN 1.8>1.2[2]
DL BOS-JFK DEC 5>3[7] JAN 6>5[7]
DL BOS-LAS DEC 0.8>0[0.9] JAN 1.0>0.7[1.0]
DL BOS-LGA DEC 6>2[12] JAN 12>10[11]
**DL BOS-LHR NOV 0.6>0[0.6] DEC 0.6>0[1.0] JAN 0.6>0[1.0] FEB 0.6>0[1.1] MAR 0.5>0[0.9]
DL BOS-MCI DEC 0.9>0[2] JAN 1.6>1.2[2]
DL BOS-MCO NOV 1.1>1.4[3] DEC 3>2[2]
DL BOS-MIA DEC 1.0>0[0] JAN 1.9>1.4[0.6]
DL BOS-MKE DEC 1.0>0[1.6] JAN 1.7>1.2[1.5]
DL BOS-MSP DEC 5>3[5]
DL BOS-ORD DEC 2>0[4] JAN 4>3[4]
DL BOS-ORF DEC 0.3>0[0.7]
DL BOS-PBI DEC 0.4>0[0] JAN 1.0>0.6[0.6]
DL BOS-PHL DEC 2>0[5] JAN 5>4[5]
DL BOS-PIT NOV 0.3>0.6[2] DEC 2.0>1.0[4]
DL BOS-RDU NOV 1.5>2[5] DEC 4>2[5]
DL BOS-RIC DEC 1.3>0.7[2] MAR 1.2>1.4[2]
DL BOS-RSW DEC 0.4>0[0] JAN 1.0>0.7[0.7]
DL BOS-SEA DEC 3>1.8[1.4]
DL BOS-SFO DEC 0.7>0[0.9] JAN 1.0>0.7[0.8]
DL BOS-TPA DEC 2>1.4[2]
DL BTV-JFK DEC 1.6>0[3] JAN 2>1.3[3]
DL BTV-LGA DEC 0.7>0[1.8] JAN 1.8>1.3[1.8]
DL BUF-DTW DEC 4>3[4]
DL BUF-JFK DEC 3>1.0[4] JAN 4>3[4]
DL BUF-LGA DEC 3>0[3] JAN 3>2[4]
DL BWI-CVG DEC 1.0>0[2] JAN 2>1.6[1.9]
DL BWI-JFK DEC 1.6>0[4] JAN 4>3[3]
DL BWI-MSP DEC 3>1.9[3]
DL BWI-RDU JAN 1.8>1.3[1.2]
DL BWI-SLC DEC 1.5>0.8[1.5]
DL BZN-SEA DEC 0.8>0[0] JAN 2>1.4[0.4]
DL CAE-LGA DEC 1.0>0[1.4] JAN 1.8>1.3[1.4]
DL CHA-DTW DEC 0.6>0[2] JAN 1.7>1.2[1.2]
DL CHA-LGA JAN 0.8>0.6[0.6]
DL CHO-LGA DEC 0.4>0[2] JAN 2>1.6[1.5]
DL CHS-DTW DEC 2>0.8[3]
DL CHS-JFK DEC 1.8>1.3[2]
DL CHS-LGA DEC 2>0[3] JAN 3>1.9[3]
DL CID-DTW DEC 1.9>1.0[3] JAN 3>2[3]
DL CLE-DTW DEC 5>4[4]
DL CLE-JFK DEC 1.9>0[3] JAN 4>3[3]
DL CLE-LGA DEC 4>1.0[5] JAN 4>3[5]
DL CLE-RDU JAN 0.8>0.6[0.6]
DL CLT-CVG DEC 0.9>0[2] JAN 1.5>1.0[1.7]
DL CLT-JFK DEC 2>0[3] JAN 4>3[3]
DL CLT-LGA DEC 5>1.9[6] JAN 7>5[6]
DL CMH-JFK DEC 2>0[2] JAN 3>2[3]
DL CMH-LAX DEC 0.7>0[0.7] JAN 0.8>0.6[0.9]
DL CMH-LGA DEC 4>1.9[5] JAN 5>4[5]
DL CMH-MSP DEC 3>4[3]
DL CMH-RDU JAN 0.9>0.7[1.1]
DL CMH-SLC JAN 0.1>0.3[1.0]
**DL CUN-CVG JAN 0.1>1.0[0.3] FEB 0>1.0[0.2] MAR 0>1.0[0.2] APR 0>1.0[0.1] MAY 0>1.0[0.1] JUN 0>1.0[0]
**DL CUN-RDU JAN 0>1.0[0.3] FEB 0>1.0[0.2] MAR 0>1.0[0.2] APR 0>1.0[0.1] MAY 0>1.0[0.1] JUN 0>1.0[0]
DL CVG-DCA DEC 1.9>0.7[2]
DL CVG-DEN DEC 0.8>0.5[0.8]
DL CVG-DFW DEC 1.6>0[1.9] JAN 2>1.4[1.4]
DL CVG-EWR DEC 1.8>0.8[2.0]
DL CVG-FLL DEC 1.0>1.4[0.8] JAN 1.0>1.3[1.1]
DL CVG-IAH DEC 0.5>0[0.8] JAN 1.0>0.7[0.6]
DL CVG-JFK DEC 0.8>0[1.0] JAN 1.0>0.7[1.0]
DL CVG-LAX DEC 1.5>0.9[1.6]
DL CVG-LGA DEC 4>1.7[5] JAN 5>4[5]
DL CVG-MCI JAN 1.5>1.0[1.1]
DL CVG-MCO DEC 3>1.9[3]
DL CVG-MSP DEC 5>4[4]
DL CVG-ORD DEC 1.5>0[3] JAN 3>1.8[3]
DL CVG-PHL DEC 0.9>0[2] JAN 1.5>1.1[1.7]
DL CVG-PHX DEC 0.8>0[0.8] JAN 1.0>0.7[0.9]
DL CVG-RDU DEC 1.1>0[1.4] JAN 1.9>1.4[1.5]
DL CVG-RSW DEC 1.2>1.9[0.9] JAN 1.0>1.3[1.3]
DL CVG-SEA DEC 0.7>0[0.6] JAN 0.7>0.5[0.6]
DL CVG-SFO DEC 0.8>0[0.8] JAN 0.9>0.6[0.8]
DL CVG-SLC JAN 1.1>1.3[1.4]
DL CVG-STL JAN 1.5>1.1[1.1]
DL CVG-TPA DEC 1.0>1.4[0.9] JAN 1.0>1.3[1.3]
DL CVG-YYZ DEC 0.6>0[1.3]
DL DAY-MSP DEC 2.0>0[2] JAN 1.9>1.3[3]
DL DCA-DTW DEC 5>3[5]
DL DCA-LEX DEC 0.3>0[0.7] JAN 0.8>0.6[0.6]
DL DCA-LGA DEC 5>3[8] JAN 7>6[7]
DL DCA-MSN DEC 0.3>0[0.8] JAN 0.8>0.6[0.6]
DL DCA-MSP DEC 5>3[5]
DL DCA-OMA DEC 0.3>0[0.7] JAN 0.8>0.6[0.6]
DL DCA-RDU DEC 1.9>0[3] JAN 3>2[3]
DL DEN-LGA DEC 1.7>1.0[1.7]
DL DEN-SLC DEC 6>4[5]
DL DFW-DTW DEC 5>4[5]
DL DFW-JFK DEC 1.5>0[2] JAN 2>1.8[3]
DL DFW-LAX DEC 1.9>1.5[3]
DL DFW-LGA DEC 4>3[5]
DL DSM-DTW DEC 3>1.7[3]
DL DSM-LGA DEC 0.3>0[1.2] JAN 0.8>0.6[1.4]
DL DSM-SLC DEC 1.0>0.8[0.9]
DL DTW-ELM DEC 4>1.7[4]
DL DTW-GRR DEC 6>5[6]
DL DTW-GSO DEC 1.9>0[3] JAN 3>1.9[2]
DL DTW-GSP DEC 2>1.7[3]
DL DTW-HNL DEC 0.4>0[0]
DL DTW-HPN JAN 3>2[3]
DL DTW-HSV JAN 0.9>0.7[0.6]
DL DTW-IAH DEC 4>3[4]
DL DTW-IND DEC 6>4[6]
DL DTW-ITH DEC 1.9>1.0[3] JAN 3>2[3]
DL DTW-JAX DEC 1.7>0.8[1.6]
DL DTW-JFK DEC 4>3[4]
DL DTW-LEX DEC 3>2[4]
DL DTW-LGA DEC 7>4[7]
DL DTW-MBS DEC 4>3[4]
DL DTW-MCO DEC 6>5[6]
DL DTW-MDW DEC 2>0[3] JAN 4>3[3]
DL DTW-MEM DEC 3>2.0[2]
DL DTW-MKE DEC 4>3[4]
DL DTW-MLI DEC 1.2>0[1.7] JAN 1.7>1.2[1.9]
DL DTW-MQT JAN 1.8>1.5[1.8]
DL DTW-MSN DEC 4>3[5]
DL DTW-MSP DEC 7>5[7]
DL DTW-MSY DEC 3>0.8[3]
DL DTW-MTY JAN 0.8>0.6[0.5]
DL DTW-OKC DEC 0.8>0[1.5] JAN 1.0>0.7[1.1]
DL DTW-OMA DEC 3>1.7[3]
DL DTW-ORD DEC 4>3[6]
DL DTW-PBI DEC 0.9>0.5[0.9]
DL DTW-PDX DEC 1.2>1.5[1.2] JAN 1.0>1.3[1.3]
DL DTW-PWM DEC 2>3[3]
DL DTW-RIC DEC 2>1.0[3]
DL DTW-SAN DEC 3>2[2]
DL DTW-SAV DEC 0.4>0[0.9] JAN 1.0>0.7[0.9]
DL DTW-SBN DEC 3>4[4]
DL DTW-SCE DEC 2>1.0[3]
DL DTW-SFO DEC 4>3[4]
DL DTW-SJC DEC 0.5>0[0.8] JAN 1.0>0.7[1.1]
**DL DTW-SMF DEC 0.3>0[0.6] JAN 0.5>0[0.9] FEB 0.4>0[0.9] MAR 0.4>0[0.7] APR 0.5>0[0.9] MAY 0.4>0[0.6] JUN 0.4>0[0]
DL DTW-SNA DEC 0.5>0[0.6] JAN 1.0>0.7[0.7]
DL DTW-SRQ JAN 0.1>0.3[0.4]
DL DTW-STL DEC 4>3[4]
DL DTW-TYS DEC 3>1.8[4]
DL DTW-YUL DEC 3>1.0[3]
DL DTW-YYZ DEC 4>3[4]
DL EWR-RDU DEC 1.9>0[3] JAN 3>1.7[3]
**DL EYW-LGA DEC 0>0.5[0] JAN 0>1.0[0] FEB 0>1.0[0.1] MAR 0>0.9[0.2]
DL FAI-SEA JAN 1.0>1.3[1.0]
DL FAR-MSP DEC 7>5[6]
DL FCA-LAX DEC 0.3>0[0] JAN 0.3>0[0.4]
DL FLL-LAX DEC 1.0>0.5[0]
DL FLL-SLC DEC 1.0>1.5[0.9] JAN 1.0>1.3[1.3]
DL FSD-MSP DEC 6>5[6]
DL FWA-MSP DEC 0.5>0[1.0] JAN 1.0>0.6[1.0]
DL GCM-JFK DEC 0.5>0[0] JAN 1.0>0.7[0]
This went out a week or two ago
*DL GDL-SLC FEB 0>1.0[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0]
DL GEG-SEA DEC 8>6[7]
DL GFK-MSP DEC 5>3[5]
DL GRR-LGA DEC 1.8>0[2] JAN 3>1.7[2]
DL GRU-JFK DEC 0.5>0.3[1.0]
DL GSO-LGA DEC 3>0[4] JAN 4>3[3]
DL GSP-LGA DEC 1.7>0[2] JAN 2>1.7[2]
DL HLN-MSP DEC 0.8>0[0.8] JAN 0.9>0.6[0.9]
DL HNL-JFK DEC 0.4>0[0]
DL IAD-JFK DEC 1.4>0[3] JAN 3>1.7[4]
DL IAD-SEA DEC 1.0>0[0.7] JAN 1.8>1.3[0.9]
DL IAD-SLC DEC 1.2>0.7[0.8]
DL IAH-JFK DEC 1.6>0[1.9] JAN 2.0>1.4[1.8]
DL IAH-LGA DEC 3>0.9[4] JAN 4>3[4]
DL IAH-MSP DEC 4>3[4]
DL IND-JFK DEC 1.3>0[2] JAN 2.0>1.3[2.0]
DL IND-LAX DEC 0.7>0[0.8] JAN 0.8>0.6[0.9]
DL IND-LGA DEC 4>1.9[4]
DL IND-MCO DEC 0.5>0[0.9] JAN 1.0>0.7[1.0]
DL IND-MEM DEC 0.5>0[0]
DL IND-RDU DEC 0.3>0[1.5] JAN 1.8>1.4[1.4]
DL IND-SEA DEC 0.3>0[0.7]
DL IND-SLC DEC 1.0>0.8[0.8]
DL JAX-JFK DEC 2>1.0[3]
DL JAX-LGA DEC 2>0[2] JAN 3>1.9[3]
DL JAX-MSP DEC 0.3>0[0.7] JAN 0.8>0.6[0.7]
DL JFK-LAS DEC 4>1.9[4]
DL JFK-LAX DEC 7>5[8] JAN 8>7[9]
*DL JFK-MAD NOV 0.4>0[0.4] DEC 0.4>0[0.7] JAN 0.5>0[0.7] FEB 0.4>0[0.6]
DL JFK-MSP DEC 4>3[4]
DL JFK-MSY DEC 2>0.7[3] JAN 3>2[3]
DL JFK-NAS DEC 1.2>0.5[1.2]
DL JFK-ORD DEC 3>1.6[4]
DL JFK-ORF DEC 1.2>0[3] JAN 3>2.0[3]
DL JFK-PBI JAN 0.9>0.7[1.0]
DL JFK-PDX DEC 1.0>0.8[1.5]
DL JFK-PHX DEC 2>1.3[1.8]
DL JFK-PIT DEC 2>0[3] JAN 3>2.0[3]
DL JFK-PWM DEC 1.6>0[3] JAN 2>1.4[1.6]
DL JFK-RDU DEC 4>2[5]
DL JFK-RIC DEC 2>0[2] JAN 3>2[3]
DL JFK-ROC DEC 2>1.0[3]
DL JFK-RSW JAN 0.9>0.7[0.9]
DL JFK-SAN DEC 2>1.0[2]
DL JFK-SAT DEC 0.8>0[1.0] JAN 1.0>0.7[1.0]
DL JFK-SAV DEC 1.7>0.7[1.9]
DL JFK-SFO DEC 4>2[6]
DL JFK-SJC DEC 0.3>0[0.9] JAN 0.8>0.6[0.8]
DL JFK-SYR DEC 2.0>0.8[3]
DL JFK-TLV DEC 1.6>1.0[0.9] JAN 2>1.0[1.4] FEB 2>1.0[1.3] MAR 2>1.0[0.9]
DL JFK-YUL DEC 1.2>0[3] JAN 1.8>1.4[2]
DL JFK-YYZ DEC 2>0[3] JAN 3>2[3]
Back in?
*DL KEF-MSP JUN 0>0.6[0]
DL KOA-SEA DEC 0.9>0.6[0.6]
DL LAN-MSP DEC 0.7>0[1.0] JAN 1.0>0.6[1.0]
DL LAS-SEA DEC 5>3[5]
DL LAX-MCI DEC 1.4>1.0[1.5]
DL LAX-MSP DEC 6>5[6]
DL LAX-MSY DEC 2>1.0[2]
DL LAX-OMA DEC 0.5>0[0.7] JAN 0.9>0.6[0.9]
DL LAX-PDX DEC 4>5[4]
DL LAX-SAN DEC 1.5>0[5] JAN 4>3[5]
DL LAX-SAT DEC 1.3>0.8[1.6]
DL LAX-SEA DEC 7>5[8]
DL LAX-SFO DEC 6>3[7] JAN 8>6[7]
DL LAX-SJC DEC 3>2[6]
DL LAX-SJD JAN 2>3[1.6] FEB 2.0>3[2] MAR 2>3[1.6] APR 2>3[1.9]
DL LAX-SLC DEC 7>6[7]
DL LAX-TPA DEC 1.2>1.5[0.9] JAN 1.0>1.3[1.3]
DL LAX-TUS DEC 1.3>1.6[3]
DL LEX-LGA JAN 0.8>0.6[0.6]
DL LEX-MSP DEC 0.5>0[0.7]
DL LGA-MCI DEC 3>1.0[4]
DL LGA-MEM DEC 1.4>0[2] JAN 2>1.7[2]
DL LGA-MKE DEC 3>0[4] JAN 5>3[4]
DL LGA-MSN DEC 1.8>0[2] JAN 2>1.7[2]
DL LGA-MSP DEC 6>3[6] JAN 6>5[6]
DL LGA-MSY DEC 2>0[3] JAN 3>1.9[3]
DL LGA-OMA DEC 1.2>0[2] JAN 1.7>1.3[1.9]
DL LGA-ORD DEC 7>4[10] JAN 12>10[9]
DL LGA-ORF DEC 3>0[4] JAN 4>3[4]
DL LGA-PIT DEC 4>1.9[6] JAN 7>5[6]
DL LGA-PWM DEC 2>1.0[3]
DL LGA-RDU DEC 6>3[7] JAN 7>6[7]
DL LGA-RIC DEC 3>0.9[4] JAN 4>3[4]
DL LGA-ROC DEC 3>0[3] JAN 3>2[3]
DL LGA-RSW DEC 2>1.4[3]
DL LGA-SAV DEC 1.8>0[2] JAN 1.8>1.3[2]
DL LGA-SDF DEC 1.6>0[3] JAN 3>1.8[2]
DL LGA-STL DEC 4>1.0[5] JAN 5>4[5]
DL LGA-SYR DEC 1.9>0[3] JAN 3>1.7[3]
DL LGA-TYS DEC 1.3>0[2] JAN 2>1.7[2]
DL LGA-XNA DEC 0.3>0[0.6] JAN 0.8>0.6[0.6]
DL LGA-YUL DEC 3>0[3] JAN 3>2[3]
DL LGB-SLC DEC 5>3[5]
DL LIR-MSP DEC 0.1>0.3[0] JAN 0.2>0.6[0.3] FEB 0.1>0.6[0.8] MAR 0.1>0.6[0.7]
DL MBS-MSP DEC 0.3>0[0.8]
DL MCI-SEA DEC 0.5>0[0.8] JAN 1.0>0.7[0.9]
DL MCO-MIA DEC 1.0>0[0] JAN 4>3[0]
DL MCO-RDU DEC 3>1.8[3]
DL MDW-MSP DEC 4>0[6] JAN 5>4[6]
DL MEM-MSP DEC 3>2.0[2]
DL MEX-MSP MAY 0>1.0[0.7]
DL MIA-RDU DEC 0.8>0[0] JAN 1.8>1.3[0.3]
DL MIA-SLC DEC 0.5>0[0] JAN 1.0>0.7[0]
DL MIA-TPA DEC 1.1>0[0] JAN 4>3[0]
DL MKE-SEA DEC 0.8>0[0.8] JAN 0.9>0.6[0.9]
DL MSN-MSP DEC 4>3[5]
DL MSN-SLC DEC 0.2>0[0.7] JAN 0.8>0.6[0.8]
DL MSO-MSP DEC 1.2>1.8[1.7] JAN 1.0>1.3[1.3]
DL MSP-MSY DEC 1.0>0.8[1.2]
DL MSP-OMA DEC 5>3[5]
DL MSP-PBI JAN 0.1>0.3[0.3]
DL MSP-RIC DEC 1.1>0[1.7] JAN 0.9>0.6[1.6]
DL MSP-ROC DEC 0.5>0[0.8] JAN 0.9>0.6[0.9]
DL MSP-SAT DEC 2>2.0[2]
DL MSP-SBN DEC 0.8>0[1.7] JAN 1.0>0.6[1.0]
DL MSP-SDF DEC 2>1.0[2]
DL MSP-SEA DEC 6>5[5]
DL MSP-SFO DEC 5>4[4]
DL MSP-SJC DEC 1.6>0[1.6] JAN 2>1.4[1.0]
DL MSP-SNA DEC 3>1.4[2]
DL MSP-STL DEC 5>4[5]
DL MSP-STT JAN 0.0>0.4[0] FEB 0>0.4[0] MAR 0>0.4[0]
DL MSP-TPA DEC 3>4[1.8]
DL MSP-TUL DEC 1.4>0[1.6] JAN 1.7>1.3[0.9]
DL MSP-TYS JAN 0.9>0.7[0.7]
DL MSP-XNA DEC 0.9>0[1.4] JAN 1.4>1.1[1.3]
DL MSP-YUL DEC 0.7>0[0.9] JAN 0.8>0.6[0.9]
DL MSP-YVR DEC 1.6>0[1.6] JAN 2>1.4[1.8]
DL MSP-YWG DEC 3>1.0[3] JAN 4>3[4]
DL MSP-YYC DEC 2>1.0[2] JAN 3>2[3]
DL MSP-YYZ DEC 2>0[3] JAN 3>1.9[3]
DL OAK-SLC DEC 4>3[4]
DL OMA-SLC DEC 2>3[1.6] JAN 1.9>2[1.9]
DL ORD-RDU DEC 1.3>0[2] JAN 2>1.8[1.7]
DL ORD-SEA DEC 3>1.9[2]
DL PDX-SEA DEC 7>5[6]
DL PHL-RDU JAN 3>1.9[2]
DL PHL-SLC JAN 1.0>1.3[0.9]
DL PIT-RDU JAN 0.8>0.6[0.6]
DL PIT-SLC DEC 0.8>0[0.8] JAN 0.9>0.6[0.9]
**DL PSP-SEA DEC 0>0.9[0] JAN 0>2[0.6] FEB 0>2[1.2] MAR 0>1.8[0.9]
DL RDM-SEA DEC 2>3[3]
DL RDU-SEA DEC 1.0>0.8[0.8]
DL RDU-TPA DEC 3>1.5[2]
DL RNO-SLC DEC 5>4[4]
DL SAN-SEA DEC 4>3[4]
DL SEA-SFO DEC 6>3[6] JAN 7>6[6]
DL SEA-SJC DEC 5>3[4] JAN 6>5[4]
DL SEA-SLC DEC 8>6[7]
DL SEA-SNA DEC 4>1.9[4] JAN 5>4[4]
DL SEA-YVR DEC 4>0.8[6] JAN 5>4[6]
DL SEA-YYC DEC 1.5>0[2.0] JAN 2>1.4[1.9]
DL SJC-SLC DEC 5>4[4]
DL SLC-TPA DEC 1.2>2[0.8] JAN 1.0>1.3[0.9]
DL SLC-TUS DEC 3>4[3]
DL SLC-YVR DEC 1.6>0[1.6] JAN 2>1.4[1.3]
DL SLC-YYC DEC 1.5>0[1.6] JAN 2>1.4[1.4]
DL SLC-YYZ DEC 0.8>0[0.8] JAN 1.0>0.7[0.9]
EI BDL-DUB NOV 0.7>0.2[0.7]
EI BNA-ORD JAN 0.4>0.2[0] FEB 0.4>0.2[0]
EI BOS-SNN NOV 0.9>0.2[1.0]
EI DUB-EWR NOV 0.9>0.2[1.0]
EI DUB-IAD NOV 0.9>0.2[1.0]
EI DUB-LAX NOV 0.8>0.2[0.8]
EI DUB-MCO NOV 0.6>0.1[0.6]
EI DUB-PHL NOV 0.8>0.2[0.9]
EI DUB-SEA NOV 0.7>0.2[0.6]
EI DUB-SFO NOV 0.9>0.2[1.0]
EI JFK-SNN NOV 0.9>0.2[1.0]
EW FRA-PHX APR 0.6>0[0] MAY 0.7>0[0.0] JUN 0.7>0[0]
FI DEN-KEF JUN 0.6>1.0[1.1]
FI JFK-KEF MAY 1.0>1.3[1.0] JUN 1.0>1.4[1.3]
FI KEF-MSP MAY 0.5>1.0[0.6] JUN 0.6>1.0[1.0]
FI KEF-SEA MAY 1.0>1.4[1.0] JUN 1.0>1.4[1.4]
HA BOS-HNL DEC 0.7>0.1[0.7]
HA HNL-ITO DEC 13>9[13]
HA HNL-JFK DEC 1.0>0.2[1.0]
HA HNL-KOA DEC 18>9[19] JAN 16>14[19]
HA HNL-LAS DEC 3>1.2[3]
HA HNL-LAX DEC 3>1.8[3]
HA HNL-LGB DEC 1.0>0.5[1.0]
HA HNL-LIH DEC 18>10[18] JAN 17>16[18]
HA HNL-OGG DEC 24>12[26] JAN 25>23[27]
HA HNL-PHX DEC 1.0>0.7[1.0]
HA HNL-SEA DEC 1.5>1.0[1.0]
HA HNL-SFO DEC 1.5>1.0[1.9]
HA ITO-OGG DEC 2>1.5[2.0]
HA KOA-LAX DEC 1.0>0[1.0]
HA KOA-OGG DEC 3>1.5[3]
HA LAS-OGG DEC 0.3>0[0]
HA LAX-LIH DEC 1.0>0.3[1.0]
HA LAX-OGG DEC 1.5>0.8[1.0]
HA LIH-OAK DEC 1.0>0.2[1.0]
HA LIH-OGG DEC 4>1.5[3]
HA OAK-OGG DEC 1.0>0.7[1.0]
HA OGG-PDX DEC 1.0>0.4[1.0]
HA OGG-SAN DEC 1.0>0.3[1.0]
HA OGG-SEA DEC 1.0>0.7[1.0]
HA OGG-SFO DEC 1.0>0.2[1.0]
HA OGG-SJC DEC 1.0>0.5[1.0]
HA OGG-SMF DEC 1.0>0.6[1.0]
II CAP-FLL NOV 0.6>0[0] DEC 0.5>0[0] JAN 0.6>0[0] FEB 0.6>0[0] MAR 0.6>0[0] APR 0.6>0[0] MAY 0.6>0[0] JUN 0.6>0[0]
K2 BET-PQS DEC 0>0.4[0] MAR 0>0.4[0] APR 0>0.4[0] JUN 0>0.4[0.2]
K2 BET-PSQ DEC 0.4>0[0] MAR 0.4>0[0] APR 0.4>0[0] JUN 0.4>0[0]
K2 BET-RSH JAN 0.4>0[0]
K2 MLL-PQS DEC 0>0.4[0] MAR 0>0.4[0] APR 0>0.4[0] JUN 0>0.4[0.2]
K2 MLL-PSQ DEC 0.4>0[0] JAN 0.4>0[0] MAR 0.4>0[0] APR 0.4>0[0] JUN 0.4>0[0]
K2 MLL-RSH JAN 0.4>0[0]
LY MIA-TLV DEC 0.6>0.3[0.5] JAN 0.5>0.3[0.6] FEB 0.6>0.3[0.6]
MF FOC-LAX NOV 0.1>0.6[0] DEC 0>0.2[0]
OS EWR-VIE NOV 0.6>0.4[0.7] DEC 0.7>0.5[1.0]
OZ ICN-JFK DEC 2.0>1.0[1.2]
OZ ICN-LAX DEC 2>1.3[1.9]
OZ ICN-SEA DEC 0.8>0.4[0.7]
OZ ICN-SFO DEC 1.0>0.6[1.0]
PY GEO-MIA NOV 0.6>0.2[0.6] DEC 0.6>0.3[0.5]
QG TRT-UPG NOV 0.4>0[0.4] DEC 0.4>0[0] JAN 0.5>0[0] FEB 0.4>0[0] MAR 0.4>0[0] APR 0.4>0[0] MAY 0.4>0[0] JUN 0.4>0[0]
QR BOS-DOH DEC 0.8>0.4[1.0] JAN 1.0>0.5[1.0] FEB 1.0>0.4[1.1] MAR 1.0>0.5[0.9]
RJ DTW-YUL NOV 0.3>0.1[0.3]
SQ JFK-SIN NOV 0>0.3[0] DEC 0>0.4[0] JAN 0>0.4[0] FEB 0>0.4[0] MAR 0>0.4[0]
SV JED-JFK JAN 0.4>0.2[0.5]
TP BOS-PDL DEC 0.2>0[0] JAN 0.4>0[0]
TS FLL-YQB DEC 0.3>0[0.5] JAN 0.7>0[0.6]
TS FLL-YUL DEC 0.8>0[0.5] JAN 1.4>0[0.8]
TS FLL-YYZ DEC 0.5>0[0.5] JAN 0.8>0[0.6]
TS MCO-YUL DEC 0.2>0[0.3] JAN 0.5>0[0.3]
TS MCO-YYZ DEC 0.5>0[0.3] JAN 0.9>0[0.3]
It finally opened???
**UA BER-EWR APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0]
*UA BOS-FLL JAN 0.6>0.9[0] FEB 0>1.0[0] MAR 0>0.9[0]
*UA BOS-MCO JAN 0.6>0.9[0] FEB 0>1.0[0] MAR 0>0.9[0]
*UA BOS-RSW FEB 0>0.9[0] MAR 0>0.9[0]
*UA BOS-TPA JAN 0.6>0.4[0] FEB 0>0.6[0] MAR 0>0.9[0]
UA CHS-IAD NOV 1.3>0.9[4]
*UA CLE-TPA JAN 0.3>0.7[0.1] FEB 0>0.7[0] MAR 0>0.6[0]
UA CMH-IAD NOV 1.2>0.8[4]
*UA CMH-RSW JAN 0.3>0.6[0] FEB 0>0.6[0] MAR 0>0.9[0] APR 0>0.4[0]
UA DEN-HDN JAN 3>4[3]
UA EWR-PUJ DEC 1.0>1.8[1.0]
**UA EWR-TXL APR 1.0>0[1.0] MAY 1.0>0[0] JUN 1.0>0[0]
*UA FLL-LGA JAN 0.6>0.9[0] FEB 0>1.1[0] MAR 0>0.9[0]
UA IAD-ORF NOV 1.4>1.1[4]
UA IAD-PHX JAN 1.0>1.8[1.4] FEB 1.0>1.4[1.2]
UA IAH-MGA NOV 1.0>0[1.0]
UA IAH-TGU NOV 0.6>1.0[1.0]
*UA IND-RSW JAN 0.3>0.6[0] FEB 0>0.6[0] MAR 0>0.9[0]
UA LAX-LIH JAN 0.5>1.0[1.5] FEB 0.7>1.0[0.4]
**UA LAX-LIR JAN 0>0.4[0] FEB 0>0.4[0] MAR 0>0.4[0] APR 0>0.4[0] MAY 0>0.5[0] JUN 0>0.4[0]
**UA LAX-SAP APR 0>0.4[0] MAY 0>0.5[0] JUN 0>0.4[0]
**UA LAX-SJO DEC 0>0.5[0] JAN 0>1.0[0] FEB 0>1.0[0] MAR 0>1.0[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0]
*UA LGA-MCO JAN 0.6>0.9[0] FEB 0>1.0[0] MAR 0>0.9[0]
*UA LGA-PBI JAN 0.0>0.3[0] FEB 0>0.5[0] MAR 0>0.9[0]
*UA LGA-RSW FEB 0>0.9[0] MAR 0>0.9[0]
*UA LGA-TPA FEB 0>0.7[0] MAR 0>0.9[0]
*UA MKE-RSW JAN 0.2>0.6[0] FEB 0>0.6[0] MAR 0>0.5[0] APR 0>0.3[0]
*UA MKE-TPA JAN 0.2>0.6[0] FEB 0>0.6[0] MAR 0>0.4[0]
UA PDX-SFO NOV 3>2[8]
*UA PIT-RSW JAN 0.2>0.6[0] FEB 0>0.6[0] MAR 0>0.9[0]
UA SFO-TPA NOV 0.6>0.2[1.5]
UP FLL-NAS NOV 2>0.4[2]
UP MCO-NAS NOV 0.6>0[0.3]
UP MIA-NAS NOV 2>0[0.7]
UX JFK-MAD DEC 0.5>0[0.7] JAN 0.6>0[0.8] FEB 0.4>0[0.3] MAR 0.5>0.1[0.1]
UX MAD-MIA DEC 0.6>0.2[1.0] JAN 1.0>0.3[1.0] FEB 1.0>0.3[1.1] MAR 1.0>0.4[0.9]
VH MDE-MIA JAN 1.0>1.4[1.3] FEB 1.0>1.4[1.3] MAR 1.0>1.4[1.0]
VS ATL-LHR NOV 0.7>0.4[1.0]
VS ATL-MAN NOV 0.2>0[0.4]
VS BOS-LHR NOV 0.9>0.2[1.9]
VS IAD-LHR NOV 0.5>0[1.0]
VS JFK-LHR NOV 3>2[5]
VS JFK-MAN NOV 0.5>0[1.0]
VS LAS-LHR NOV 0.5>0[1.0]
VS LAX-LHR NOV 1.4>1.0[2]
VS LHR-MIA NOV 1.2>0.4[2]
VS LHR-SEA NOV 0.5>0[1.0] APR 1.6>1.0[1.1] MAY 1.5>1.0[0.8] JUN 1.6>1.0[1.1]
VS LHR-SFO NOV 0.8>0[1.8]
WG MCO-YYZ JAN 0.3>0.5[0.6]
WN ATL-LAS DEC 1.3>1.6[2]
WN ATL-PHL DEC 0.9>1.2[1.2]
WN ATL-PHX DEC 1.0>1.3[2]
WN BNA-CHS DEC 1.2>1.5[1.7]
WN BNA-CMH DEC 0.9>1.3[1.9]
WN BNA-PIT DEC 1.2>1.5[1.8]
WN BOI-LAS DEC 1.8>2[1.9]
WN BWI-SJU DEC 0.9>1.3[1.9]
WN DAL-DCA DEC 0.9>1.2[5]
WN DEN-DSM DEC 0.8>1.2[0]
WN ELP-HOU DEC 1.0>1.4[3]
WN LAS-SEA DEC 1.1>1.4[2]
WN MDW-SLC DEC 0.9>1.3[2]
WN MDW-SMF DEC 0.9>1.2[1.0]
Y4 MCO-MEX JAN 0>0.3[0.4] FEB 0>0.3[0.5] MAR 0>0.3[0.4]
Y4 MEX-MIA DEC 0>0.4[0.5] JAN 0>0.7[0.6] FEB 0>0.7[0.6] MAR 0>0.7[0.5] APR 0>0.7[0.6] MAY 0>0.7[0.3] JUN 0>0.7[0.3]
enilria
Re: OAG Changes 10/27/2020:DL PSP-SEA,CUN-CVG/RDU,EYWLGA Daily;UA Adds BER Breaks Curse,Extends Sun Adds;4B BWIORF,EUGPD
Tue Oct 27, 2020 7:48 pm
BETTER LATE THAN NEVER EDITION
The original dataset was corrupt. Had to wait until it was corrected.
Also, if you aren't aware airlineroute.net shut down, at least for now. This post is not connected to airlineroute, other than likely being one of their sources!
Ishrion
Tue Oct 27, 2020 7:55 pm
Thanks as always
Is this an error? I don’t think Xiamen Air has authority to fly passenger Fuzhou to Los Angeles? I know they’re doing several cargo-only flights on the route, so did it accidentally show up?
AVLAirlineFreq
Tue Oct 27, 2020 8:05 pm
Thanks for doing this as always, but especially this week!
BA744PHX
Tue Oct 27, 2020 8:07 pm
Thanks for your work, my morning is now complete LOL
sargester
Tue Oct 27, 2020 8:13 pm
AA CLT JFK 0.8? I see it at least 3x per day for November
ADent
Tue Oct 27, 2020 8:17 pm
ArcticSEA wrote:
And they have already changed SXF to BER.
BAINY3
Tue Oct 27, 2020 8:18 pm
Yes, officially the BER code became operational Oct 25 (SXF has changed to BER; the new BER terminals don't open until Oct 31 and TXL closes gradually in the week or two after that).
UA's Berlin schedule overall didn't really change. They'd already had it on the books to resume Berlin at the end of March 2021 and this OAG update merely reflected that change.
There is a BER megathread discussing it all in detail.
LASVegan
Tue Oct 27, 2020 8:33 pm
As always, thank you Enilria. I found myself antsy today and realized it was because I didn’t have my OAG fix.
ChrisNH38
Tue Oct 27, 2020 8:37 pm
I thought I saw that BA was originally going to bump up to 2x daily on BOS-LHR soon; now, they're planning on fewer than one daily (0.9)? Wow...no end in sight.
https://my.flightradar24.com/ChrisNH
enilria
Tue Oct 27, 2020 8:39 pm
Ishrion wrote:
Thanks as always
No idea. I don't know why cargo flights would be in OAG, but it is possible that like charters the airline just puts them in out of laziness and just doesn't apply any sellable inventory. OR it's a real flight.
Every week is a different kind of challenge!
We lost some in the move from Sunday. Glad you are onboard.
Chuska
Tue Oct 27, 2020 10:06 pm
Out with the old, in with the new. Now that Boutique is building up PDX (EUG, RDM, and PDT), wonder if they'll be an AS* code share in the future like 4B does with UA.
flyboy7974
Tue Oct 27, 2020 10:18 pm
Confused by this one, anybody have thoughts?
Lots of military traffic in/out of ORF but just the weight of their bags , how will it survive? Can’t see the a/c flying full load with bags and only one flight a day.
toltommy
Tue Oct 27, 2020 10:31 pm
Interesting to see DL finally trying something besides ATL again. Looked like AA had a lot of success at EYW. DFW went from seasonal Saturdays to daily mainline, ORD and PHL also went to daily as well/ They all stayed year round, even if less than daily after COVID. UA seemed to have good luck out of EWR, going to double daily at one point. I'm still surprised that they haven't tried a 175 from DTW. Key West is very popular in the midwest.
A300/A310/A319/A320/A321/A332/A333 / 707/712/727/732/733/734/735/738/739/752/753
/762/763/764/772/788/789/DC8/DC9-10/30/40/50/MD81/83/87/88/90/L1011-/250/500/CRJ200/440 /700/900/EMB135/140/145/170/175/190/328Jet/F70/SF3/BE1/J31
enilria
Wed Oct 28, 2020 12:27 am
I guess it was just too short for AS, but strange to see it unserved by AS.
I'm really surprised the LCCs aren't jumping into EYW even if its via FLL. There's a quasi-scheduled carrier doing FLL-EYW I think. Awful drive.
DaCubbyBearBar
Wed Oct 28, 2020 1:06 am
Thank you as always!!! AS with pretty good sized reduction in December, imho
I am me and no one else...so my opinions are mine
PHLspecial
Wed Oct 28, 2020 1:09 am
ArcticSEA wrote:
I will believe when there is flights and people walking in the airport. But seriously good on them for getting it done.
phxa340
Wed Oct 28, 2020 1:33 am
The problem ... there is not enough hotel rooms for all of those extra proposed flights. Key West isn’t that big ...
MIAFLLPBIFlyer
Wed Oct 28, 2020 1:35 am
Thank you for doing what you do. Was so depressed when I got that email this morning from them!
MIAFLLPBIFlyer
Wed Oct 28, 2020 1:41 am
enilria wrote:
FAQ
A very healthy sign for UA and Florida that these routes are being extended. I wasn't sure p2p from Florida would work especially to LGA & BOS (particularly from FLL & MCO which are busy, over-saturated markets to New York). Pleasantly surprised by this development!
enilria
Wed Oct 28, 2020 2:04 am
And Delta cut further...
I think it "works" relative to other options. Probably still a huge loser.
Yeah, sad to lose them.
The papers down there say crowds are WAY down, so perhaps fewer people are driving?
MIflyer12
Wed Oct 28, 2020 2:25 am
The Miami - Key West drive is interesting - once. Yes, we might see people flying instead of driving.
MIflyer12
Wed Oct 28, 2020 2:28 am
DTW - EYW would need O&D and I'm not sure it's there in numbers - nothing like NYC - EYW. If people are going to connect they can do so in ATL as well as DTW. That's why you have a big, proximate hub.
NYCAAer
Wed Oct 28, 2020 4:03 am
So now AA won’t be restarting JFK-GRU and JFK-EZE as previously planned on December 17th. And DFW-MAD is going away for the winter as well. It’s going to be a rough winter for international flights, or lack thereof.
Grandforks12
Wed Oct 28, 2020 8:52 am
Good to see CUN coming back this winter to CVG. I don't think DL has given up on CVG at least as a focus city goes..
Brickell305
Wed Oct 28, 2020 10:36 am
Also, it’s likely that those flights aren’t going out full to EYW. They may be more full than potential alternatives would be but it could simply be a case of more capacity with less overall traffic.
MIAFLLPBIFlyer
Wed Oct 28, 2020 12:38 pm
It's a beautiful but tiring drive. Much of it is one lane in each direction with a fair amount of local traffic. Driving Miami-Jacksonville or Miami-Tallahassee is actually easier IMO.
That's why the options of American Eagle and Silver from MIA and FLL respectively survive. It's not just connecting traffic but surely some O&D also.
silentbob
Wed Oct 28, 2020 1:36 pm
Silver has reduced frequency on the their EYW flights out of FLL and AA has dramatically cut the flights out of MIA. Given the relatively high price of flights to EYW in the past, I'm a bit surprised that the cuts were so deep there.
Going over seven mile bridge, or seeing the old bridge at Bahia Honda are both worth the drive at least once. It seems that when I connect, I'm either rushing to barely make the connection at MIA, or driving is faster. The biggest reason to fly is that your car is basically useless once you get to EYW, unless you're staying farther up the Keys.
tjwgrr
Wed Oct 28, 2020 1:51 pm
UA code share?
Direct KNOBS, maintain 2700' until established on the localizer, cleared ILS runway 26 left approach.
slcdeltarumd11
Wed Oct 28, 2020 2:00 pm
klm617
Wed Oct 28, 2020 3:14 pm
Delta doesn't even operate DTW-SRQ consistently when GRR and FNT do. Delta is not going to start DTW-EYM but it's a nice thought.
the truth does matter, guys. too bad it's often quite subjective. the truth is beyond the mere facts and figures. it's beyond good and bad, right and wrong...
flymco753
Wed Oct 28, 2020 3:18 pm
Q4 & Q1 are the strongest with mid 60s each way so 30-35 passengers one way per day. DL used to run BZN with weaker numbers on an A319 so it's not probable but not out of the realm of possibilities as a Saturday only flight.
...the carriage of liquids, gels, and aerosols are prohibited through the screening checkpoint except for travel size toiletries of 3 ounces or less...
AVLAirlineFreq
Wed Oct 28, 2020 3:33 pm
Are the runway limitations at EYW too great for the LCCs with the aircraft types and business models they use?
enilria
Wed Oct 28, 2020 4:28 pm
UA code share?
Not sure who is the partner, but they must have forgotten the "Duplicate" identifier in their filing.
COLLAPSE VIEW TOPIC REVIEW: OAG CHANGES 10/27/2020:DL PSP-SEA,CUN-CVG/RDU,EYWLGA DAILY;UA ADDS BER BREAKS CURSE,EXTENDS SUN ADDS;4B BWIORF,EUGPDX
I find it hard to believe EYW-FLL can't work operationally with any narrowbody aircraft. Agree on JFK or ORD.
FATFlyer
Wed Oct 28, 2020 5:20 pm
4B supposedly is looking at adding several routes at BWI and ORF.
According to the Virginian-Pilot newspaper:
Teresa Mesman, marketing director for Boutique Air, said the company sees Norfolk airport as a good place to expand its route map, describing it as a potential “hub” for that growth.
The company, so far, has no estimate for how many routes it foresees in Norfolk, she said.
“No pun intended, but the sky’s the limit," she said of the company’s plans. Raleigh-Durham is another destination the airline is eyeing, she said. The airline is hoping to get feedback from Norfolk travelers about routes they’d be interested in.
https://www.pilotonline.com/business/consumer/vp-bz-boutique-air-orf-20201022-v4xn5gfqkzeaje5u7eyrce5kda-story.html
Then there are reports that 4B is considering adding BWI-MSS to go along with BOS-MSS.
MASSENA — A destination that had originally been on Boutique Air’s flight schedule could be coming back.
Massena Town Council member Samuel D. Carbone Jr. said Boutique Air is weighing the possibility of flying to Baltimore-Washington International Airport in lieu of one of three daily round-trip flights to Boston.
“They’re thinking about taking the afternoon flight, the middle flight, and going somewhere else, like Baltimore. You would still get two flights to Boston,” he said.
https://www.nny360.com/communitynews/business/boutique-air-considering-flying-from-massena-to-baltimore-again/article_694450f0-777d-56f3-8bf4-afc754779880.html
"Travel is fatal to prejudice, bigotry, and narrow-mindedness." - Mark Twain
ScroogeMcDuck
Wed Oct 28, 2020 5:44 pm
Glad to see this route returning! I thought that the new year-round SEA-ONT flights were possibly started to replace the seasonal PSP service, even though PSP carries pretty decent loads. More choices for everyone.
wedgetail737
Thu Oct 29, 2020 3:37 am
I'm a little surprised that DL doesn't make this service year-round...using E-175's during the summer months.
AmericanAir88
Thu Oct 29, 2020 2:53 pm
That caught my eye also. I flew JFK-CLT in July and August. Both were 3-4x a day.
Big connecting route and was always crowded.
An error?
Cointrin330
Thu Oct 29, 2020 3:55 pm
No. And JFK-CDG, which was supposed to come back on line this month, isn't either. The only passenger route (long haul international) right now at JFK for AA is LHR, AA 106. There are cargo flights operating here and there (JFK-CDG has gone out a few times) but other than that, no.
jfklganyc
Thu Oct 29, 2020 6:08 pm
enilria wrote:
FAQ
Nothing is busy or over saturated at this point. Especially LGA Florida. If you have a plane and 100 people willing to pay you something, why not?
Boof02671
Thu Oct 29, 2020 6:43 pm
I just pulled up CLT-JFK for 12/13 and it’s showing five flights.
flymco753
Thu Oct 29, 2020 6:58 pm
enilria wrote:
FAQ
100 flights a day between LGA or BOS to MCO and yet people throw shade at the thought of B6 starting MCO-DTW, CLE, ORD. :duck:
airlinepeanuts
Thu Oct 29, 2020 7:14 pm
I feel like we see some iteration of this every few years a small airline starts up from small Northern Ava airports or Oregon airports and attempts these types of routes. Who was it that flew the Saab’s from Crescent City to PDX a couple years ago? Was it PenAir? I always hope one becomes successful. Horizon used to fly a lot of these routes.
Dominion301
Thu Oct 29, 2020 11:07 pm
enilria wrote:
BETTER LATE THAN NEVER EDITION!
Tomorrow it looks like we will finally be able to apply that expression to BER, lol!
Thanks enilria. I’m still a loyal follower of your weekly OAG thread, but I’m still getting used to the change to Tuesday, so I now often see it later in the week. It’s too bad the weekly load was moved from the weekends as it made for great leisurely Sunday reading material. I remember way back when it also wasn’t on Sundays.
Looks like airline route or routes online is back online today.
klm617
Fri Oct 30, 2020 1:13 am
Exactly it's more than just people from NYC and BOS who want cheap flights to Florida. Yet all the other markets outside of the top 10 have to pay for these follies so people can fly for $10 to Florida.
wedgetail737
Fri Oct 30, 2020 2:23 am
Yes...they actually had a quite an operation out of PDX with the Saab's until they went bankrupt. Contour Airlines took over the CEC flights, but now flies to OAK.
flymco753
Sat Oct 31, 2020 12:05 am
Don't forget every single airline HAS to fly from NYC, BOS, & PHL to Florida. Joking aside MCO is a market that goes up when there's more demand. If you have a Frontier A320 going to a major US metropolitan area, there will be butts to put in seats after you add the flight as opposed to business centric markets that can only take a flight or two before someone has to give if there's competition at all.
NWADTWE16
Sat Oct 31, 2020 1:29 am
DTW getting some healthy adds back, and it looks like at the expense of BOS/JFK. B6 isnt taking long to pounce, increasing BOSDTW to 4x, with the new JFK, thats 6x daily from DTW. Impressive finally for them.
All this Florida stuff is interesting. TPA was hella crowded 2 weeks ago, but RSW had just as many carriers add for October and it was a ghost town yesterday. Perhaps it was my times, but i left late afternoon and arrived back at 9pm the following day. I saw 3 B6 at the gate, no NK. 5 AA. DL had 4. UA had 3. WN had 1 (thats way off), F9/SY no shows and typically they both have multiple planes on the ground at any given time. AS starts the 20nov
I still think (and this is the time to try it) B6 needs to run a couple multi stop intra Florida flights to pick up people and drop them at FLL twice daily. You can say, just drive all you want, but driving sucks, especially in Florida. Its deadly. B6 could run (entertain me here) TLH/SRQ/RSW-FLL and maybe another on the other coast PNS/JAX/MCO-FLL. They are just not an option for any of us down here without a long drive and chaotic situation for parking/driving at FLL. throw some E190s on these routes , run them twice daily to meet banks. It would work. They of course need TPA-FLL in there as well, so adjust the routing accordingly, or honestly do TPA-FLL on its own a few times a day. Silver is hanging by a thread.
I haven't been everywhere, but it's on my list!
MIAFLLPBIFlyer
Sat Oct 31, 2020 2:00 am
I think the TLH/SRQ/RSW/FLL milk run would be interesting. Also would love to see TLH-FLL back as a route with jet service. Haven't had jets on the route since DL pulled out a few years back. TLH-MCO would also be a smart ad when the A220's come online for B6.
