Akwagon wrote:Paywall. So couldn’t read whole thing
Are these United flights cargo only?? How’d the get around dry ice faa max on a plane?
For instance, there are refrigerated storage sites at the company’s final-assembly centers in Kalamazoo, Michigan, and Puurs, Belgium. Moreover, it is expanding storage capacity at distribution sites in Pleasant Prairie, Wisconsin, and Karlsruhe, Germany. United plans to perform chartered cargo services between Brussels International Airport and Chicago O’Hare International Airport to support distribution.
deltacto wrote:this may be a dumb question: if the vaccine is not yet approved, what is United carrying on these flights?
cesar666cu wrote:deltacto wrote:this may be a dumb question: if the vaccine is not yet approved, what is United carrying on these flights?
Probably vaccines, already dispatching it to have it ready to administer to people for the day it's approved.
eightcone wrote:Akwagon wrote:Paywall. So couldn’t read whole thing
Per a foxnews article:
“United Airlines will be allowed to carry five times the amount of dry ice normally permitted on board to keep the vaccine at the necessary cold temperature.”
https://www.google.com/amp/s/www.foxnew ... accine.amp
Fun question, what is the max amount of dry ice allowed?
eightcone wrote:A couple sources I have seen today say that FAA is allowing 15,000 pounds of dry ice instead of the usual 3,000 pounds on the 777.
Side question that is interesting from a technical point and maybe a United wide body driver could chime in with. With the increased volume of sublimation gases, as part of the FAA waiver for this are the crews being required to stay on oxygen for the whole flight?
LAXintl wrote:I posted this previously in the COVID cargo thread, but here is the same news
Turkish Cargo carried out the transport of 7 cooled containers of vaccine from Beijing China to Sao Paulo Brazil.
https://www.dailysabah.com/business/tra ... -transport
smokeybandit wrote:deltacto wrote:this may be a dumb question: if the vaccine is not yet approved, what is United carrying on these flights?
I'm sure there's a gentleman's agreement already with the FDA that they know it'll be approved.
gon2fly wrote:eightcone wrote:A couple sources I have seen today say that FAA is allowing 15,000 pounds of dry ice instead of the usual 3,000 pounds on the 777.
15,000 pounds is correct. On the first few 'test' flights between BRU and ORD, United has an environmental engineer onboard who is tasked with monitoring CO2 levels throughout the cabin and flight deck. Additionally, there are some new requirements for dispatch that relate to APU and pack operability. There was an internal pilot bulletin that came out explaining these flights, extra precautions being taken, dispatch requirements, etc.....and a reminder of symptoms to CO2 overexposure. Oxygen masks not required at all unless experiencing unusual symptoms (fatigue, headache, etc.). Don't think they are expecting any issues on these flights, but the process and cargo loads are something new.....so a bit of an education campaign for the 777 fleet.
jomur wrote:smokeybandit wrote:deltacto wrote:this may be a dumb question: if the vaccine is not yet approved, what is United carrying on these flights?
That would only allow use in the US then. Other countries would also need to approve the use first as well before it can be used elsewhere. Not every one blindly follows US regulators.
IFlyVeryLittle wrote:OK, chemistry boffins: Dry ice is a solid but "melts" into a weightless gas. Maybe these flights aren't long enough to make a difference but how would an operator deal with an enroute cargo weight change like this?
Folks, they are positioning the vaccine in anticipation of approval. Nothing can be administered, except as part if the testing, until aporoved.
Right now the data shows it can be approved. There is no new information for the FDA; this is on the paperwork process.
You cannot carry/move around unapproved stuff like that...if so, any airline doing so would actually be illegal drugrunners
Spacepope wrote:Probably as noticeable as when sink water gets dumped directly overboard (so likely: not).
AZa346 wrote:Spacepope wrote:Probably as noticeable as when sink water gets dumped directly overboard (so likely: not).
Does water get dumped overboard????![]()
I might not be getting the joke haahha
Other countries... won't have supply so no worries about them.
By the end of December, there might be 40 million doses available of the first two vaccines.
https://www.usatoday.com/in-depth/news/ ... 359544002/
Per the above link, 1st distro Sunday Dec 13th. So please comment within realistic time frames.
The Oxford Vaccine has its testing hickups. (I like how it becomes the Astra-Zeneca vaccine when news is bad...). This vaccine is probably the first for Europe.
At this time, I'm not even expecting anything but the Sputnik V vaccine to be distributed in 2020. Did I miss any others besides: Pfizer, Johnson & Johnson, Oxford-AstraZeneca, and Sputnik V for possible distribution in 2020?
Supply will be far less than demand in 2021, in my opinion.
Lightsaber
Spacepope wrote:AZa346 wrote:Spacepope wrote:Probably as noticeable as when sink water gets dumped directly overboard (so likely: not).
Yes, the sink water (galley and lav) at least on most Boeing aircraft exits through a "drain mast" which is heated. Waste grey water isn't really dangerous for pathogens and the like, and hauling it around after it's used is very heavy, so overboard it goes. viewtopic.php?t=725829
You can see a "fifth contrail" here from water coming out of the heated mast in flight here.
TIL. Thanks for this, Spacepope. Are there regulations that dictate how high airliners must be for the drain masts to be used? I imagine the masts perhaps aren't used at low altitude. The referenced thread from 19 years ago doesn't specify. TIA.
EDIT: clarification.
jomur wrote:That would only allow use in the US then. Other countries would also need to approve the use first as well before it can be used elsewhere. Not every one blindly follows US regulators.
LCDFlight wrote:This is contingency logistics. If the probability is 70% the material will be approved, it justifies setting up a bunch of infrastructure to help distribute this vaccine, potentially saving thousands of lives and helping restart the global economy. EVEN If that probability is not 100%, this is still worth it.
32andBelow wrote:LCDFlight wrote:This is contingency logistics. If the probability is 70% the material will be approved, it justifies setting up a bunch of infrastructure to help distribute this vaccine, potentially saving thousands of lives and helping restart the global economy. EVEN If that probability is not 100%, this is still worth it.
I think the probability is more like 99.99% but yes.
lightsaber wrote:Did I miss any others besides: Pfizer, Johnson & Johnson, Oxford-AstraZeneca, and Sputnik V for possible distribution in 2020? Lightsaber
dtw2hyd wrote:Is it all dry ice or any powered cooling while in transport? Also what would be the vaccine to dry ice volume ratio to keep at -70C for Pfizer vaccine.
andrew1996 wrote:Its been reported that SQ Cargo has already started transporting vaccines too; a freigth forwarder said its cargo is being offloaded at AMS (https://theloadstar.com/forwarders-see- ... -take-off/). I imagine the AMS is the pax service A359. I wonder if KLM has started too? However SQ Cargo has not said in public they have started transporting vaccine but have said they are ready and will pritorize capacity for vaccines. Its also unclear where the vaccine is destined for for SQ since Singapore has not signed a contract with the vaccine makers yet (at least from my knowledge from the news)
Can vaccines be transported on the passenger level for pax planes flying cargo in the passenger cabin too or do they have to be loaded into special air cargo containers?
