  • 1
  • 5
  • 6
  • 7
  • 8
  • 9
  • 21
MileHFL400
Re: 737-10MAX Update
Sat Apr 24, 2021 8:25 pm
SEU wrote:
Mods please move to the right thread if I have missed it
What is the update with the 737-10MAX? After its lowkey rollout and all of the grounding/covid it seems to have gone off the face of the earth in regards to aviation news about it
Is it delayed indefinitely ? getting cancelled?
No frame with 500 plus frames on its order book is getting cancelled.
A388
Re: Boeing 737MAX Production/Delivery Thread - 2021
Sat Apr 24, 2021 9:40 pm
WoodysAeroimag wrote:
A388 wrote:
Still no sign of the first Caribbean Airlines MAX (9Y-CAL)? :)
A388
No sign of it and it may not even be in final assembly. Boeing is skipping frames like some Chinese carriers. There are also 2 Buzz Air frames that have not seen the light of day and a SWA frame as well. Even though several LN#'s after have rolled out and been delivered or flown.
Thanks Woody. Just to understand how Boeing works, can they give LN's to other customers instead of its originally intended customers or is their final assembly just delayed?
A388
WoodysAeroimag
Sat Apr 24, 2021 11:17 pm
Sooner787 wrote:
Where is the test frame right bow? Renton? storage at MWH?
The 1st MAX10 frame is inside the final assembly hall as seen by the 1st officer that took delivery of a COPA 11 weeks ago
https://www.instagram.com/p/CK5Jx_ZhFiS/?utm_source=ig_web_copy_link
MEA-707
Sat Apr 24, 2021 11:28 pm
A388
A388
There is an extraordinary situation that Wichita has been keeping on building fuselages for (too) long. Most have customer specific things in them already. So in Wichita many fuselages with LNs 7905-8400 are stacked up, most have airlines already allocated to them. But as, say American and Southwest are more eager than China Southern let alone these once due for Norwegian or Jet Airways, they order the fuselages with eager customers to ship to Seattle and complete them and leave the others in Wichita for a while which means they are delayed, LN 7905 has been built in 2019 and might take another 1 or 2 years to complete. That's what's going on now. Later down the line you will see Boeing allocate ntu fuselages to other airlines instead and delivering everything in the end, unlike Airbus which has a habit to skip LN's more often, Boeing so far only didn't complete one 767 ever.
ikolkyo
Sat Apr 24, 2021 11:29 pm
I believe that is the 2nd aircraft, the aircraft pictured here has the reg N27752. The first -10 is N27751
seahawks7757
Sun Apr 25, 2021 3:06 am
A388
Nope, was at Renton yesterday. The 4th Malta has rolled out, VUD. Belavia was in the paint hanger painted next to the P8 but when I left it was still sitting inside of it. Also 8047, another Malta has rolled out.
WoodysAeroimag
Sun Apr 25, 2021 4:58 am
seahawks7757 wrote:
A388
8047 rolled out 10 days ago. The reg on the Belavia is EW-546PA
WoodysAeroimag
Sun Apr 25, 2021 4:59 am
Correct, Point I was making was that they are inside final assembly at RNT.
seahawks7757
Wed Apr 28, 2021 10:31 pm
And appears Boeing is sending Malta to Moses Lake for long term storage along with another Ryanair/Buzz frame. Not sure who 202 was.
seahawks7757
Wed Apr 28, 2021 11:53 pm
Actually may have been Kunming that was 202 as Woody texted me it’s now gone from Renton.
WoodysAeroimag
Thu Apr 29, 2021 1:04 am
BOE202 was indeed Kunming. It was wearing temp reg of N5002K
WoodysAeroimag
Thu Apr 29, 2021 3:41 am
8036 9H-VUD 737-8 200 Malta Air - Painted
Image8036 9H-VUD 737-8 200 Malta Air by 737 MAX Production, on Flickr
8071 737-8 200 Ryanair - Rolled out
Image8071 737-8 200 Ryanair by 737 MAX Production, on Flickr
8077 737-8 200 Ryanair
Image8077 737-8 200 Ryanair by 737 MAX Production, on Flickr
8091 737-8 200 Ryanair
Image8091 737-8 200 Ryanair by 737 MAX Production, on Flickr
8101 737-8 200 Ryanair - Rolled out
Image8101 737-8 200 Ryanair by 737 MAX Production, on Flickr
WoodysAeroimag
Thu Apr 29, 2021 3:46 am
Video of the 1st Malta Air 9H-VUA performing taxi checks before heading to MWH for storage.
Taxi checks
https://twitter.com/i/status/1387506947474157570
RTO
https://twitter.com/i/status/1387509437452099585
WoodysAeroimag
Sun May 02, 2021 2:17 am
The MAX 10 test frame has re-appeared on the flight line.
7644 66122 N27751 737-10 United Airlines
Image7644 66122 N27751 737-10 United Airlines by 737 MAX Production, on Flickr
8054 9H-VUF 737-8 200 Malta Air - rolled out
Image8054 9H-VUF 737-8 200 Malta Air by 737 MAX Production, on Flickr
BWIAirport
Sun May 02, 2021 10:26 pm
Wow, in that picture it seems like the 10 sits off the ground noticeably higher than its older and shorter siblings
Noshow
Mon May 03, 2021 9:27 am
A bit like some SUV-MAX. :D I had expected the gear struts to extend during rotation only. Looks a bit like "tundra tires" mounted on a small single.
How about stairs, airbridges and repair docks and hangar clearance height including tail and wingtips ? Doesn't this add complexity to operations?
Does it need so much more rotation angle to take off with the larger fuselage and weight? Is this what all MAXes will look like some day?
Still surprising to see how much engine pod clearance Boeing could squeeze out of it. It doesn't look unusually tight or too close to the ground.
Momo1435
Mon May 03, 2021 9:38 am
It doesn't sit of the ground higher then the other MAX versions. The "semi-levered" landing gear only extends during rotation, not when it's on ground. If it appears higher then it's just the angle of this picture.
Noshow
Mon May 03, 2021 9:40 am
Thanks. Would make sense.
Polot
Mon May 03, 2021 9:44 am
The plane is also likely lighter than usual (eg may be lacking a full interior, and obviously not loaded down with pax and fuel) so it would be sitting up higher.
It really doesn’t look like its height is any different than the Malta Air Max in the same post though.
FluidFlow
Mon May 03, 2021 10:12 am
The MAX-10 almost has a bit a retro look compared to any other new design. When you think how huge the engines are compared to the fuselages on 777X, A220, EMB-E2s, A320neos, the engines on the MAX-10 look so tiny.
737max8
Mon May 03, 2021 1:44 pm
That Malta Air livery is amazing
WoodysAeroimag
Mon May 03, 2021 2:38 pm
The 1st MAX 8 for UAL LN8035 just arrived outside final assembly for load in.
Beedo46
Mon May 03, 2021 2:49 pm
Air Stairs for Malta Air or is this a NTU bird reallocated?
WoodysAeroimag
Mon May 03, 2021 3:01 pm
Malta Air is a Ryanair subsidiary like Buzz Air. So Malta Air's will have air stairs.
Beedo46
Mon May 03, 2021 3:05 pm
Thank you. Being in Atlanta, I miss out on a lot (and I don't take time for the hobby like I used to). Keep up your awesome work.
WoodysAeroimag
Mon May 03, 2021 3:11 pm
Correction: The 2nd MAX 8 for UAL LN8075 just arrived outside final assembly for load in. The 1st is in final assembly and should make an appearance soon
WoodysAeroimag
Fri May 07, 2021 12:36 am
A fellow local spotter caught the 1st MAX for Caribbean 9Y-CAL painted at RNT
https://twitter.com/KPAE_Spotter/status/1390458716466475008?s=20
seahawks7757
Fri May 07, 2021 1:31 am
Hideous livery. Being back the last one.
EWRamp
Fri May 07, 2021 2:13 am
Bring back the steel pan
RobK
Fri May 07, 2021 3:36 am
What the juddering f..k has happened there ????????! JH Christ that is a mess. :yuck:
MileHFL400
Fri May 07, 2021 7:59 am
Any updates on the super stretch 10?
Zidane
Fri May 07, 2021 7:57 pm
Terrible livery, way to ruin a brand new plane. Really ... Purple??
jbs2886
Fri May 07, 2021 8:07 pm
I actually like the purple, but the tail just looks like part of the sticker ripped off. They could do a colorful bird on a purple tail, but oh well.
seahawks7757
Fri May 07, 2021 8:18 pm
Nope. Still got a little while before first flight.
Polot
Fri May 07, 2021 8:24 pm
I actually like the new Caribbean livery, I just wish the titles were larger with a more interesting font. Anything is better than their current one in which it looks like someone just discovered Microsoft Word WordArt circa 2000 though.
res77W
Fri May 07, 2021 8:45 pm
Agreed, the purple isn't bad. I do wish the bird on the tail was larger, and extended onto the fuselage.
-Rowen
Opus99
Fri May 07, 2021 8:51 pm
Same here
ikolkyo
Fri May 07, 2021 8:57 pm
I agree, the titles should be much larger.
WoodysAeroimag
Sun May 09, 2021 2:52 am
9Y-CAL 737-8 Caribbean Airlines
Image9Y-CAL 737-8 Caribbean Airlines by 737 MAX Production, on Flickr
7967 60194 VP-BYI 737-8 Ural Airlines - Painted now
Image7967 60194 VP-BYI 737-8 Ural Airlines by 737 MAX Production, on Flickr
8051 43321 EW-546PA 737-8 Belavia - Belarusian Airlines
Image8051 43321 EW-546PA 737-8 Belavia - Belarusian Airlines by 737 MAX Production, on Flickr
8054 9H-VUF 737-8 200 Malta Air - Painted
8063 EI-HGN 737-8 200 Ryanair - Painted
Image8063 EI-HGN 737-8 200 Ryanair by 737 MAX Production, on Flickr
8102 737-8 200 Ryanair - Rolled out
Image8102 737-8 200 Ryanair by 737 MAX Production, on Flickr
MileHFL400
Sun May 09, 2021 9:57 am
So have deliveries resumed ?
Opus99
Sun May 09, 2021 10:06 am
Not until Service Bulletin is sent out
WoodysAeroimag
Thu May 13, 2021 1:24 pm
8105 EI-HGV 737-8 200 Ryanair
Image8105 EI-HGV 737-8 200 Ryanair by 737 MAX Production, on Flickr
Opus99
Thu May 13, 2021 1:40 pm
Now they can resume
mjoelnir
Thu May 13, 2021 1:46 pm
Opus99 wrote:
Now they can resume
For already produced frames after they finished the electrical changes. And for new frames they will have to change production procedures.
Opus99
Thu May 13, 2021 1:57 pm
mjoelnir wrote:
Opus99 wrote:
Now they can resume
Okay, thanks for the additional info. The point is they can resume.
WSJ article saying resumption expected in the coming days
WoodysAeroimag
Sun May 16, 2021 2:54 am
7944 60928 B-20E3 737-8 Air China - Painted
Image7944 60928 B-20E3 737-8 Air China by 737 MAX Production, on Flickr
7947 43385 9Y-CAL 737-8 Caribbean Air - moved to flight line
Image7947 43385 9Y-CAL 737-8 Caribbean Air by 737 MAX Production, on Flickr
8071 EI-HGO 737-8 200 Ryanair - Painted
Image8071 EI-HGO 737-8 200 Ryanair by 737 MAX Production, on Flickr
RoyalBrunei757
Sun May 16, 2021 4:02 am
Is it only me or others have the same view the engine cowling now are actual full round/circle as opposed to previous generation? Sorry if this has been covered. And the MAX family looks to be higher on ground now comparative to previous generation, no matter which variant MAX7, MAX8, MAX9 and MAX10. Haven't seen much MAX here in South East Asia at the moment since only SQ (MI), MH (2024 delivery), GA (1 airframe), JT (operation largely limited to domestic) and VJ (none delivered yet) bought them and covid19 hits the industry badly.
planecane
Sun May 16, 2021 4:28 am
When I see the fuselages on the trains, is there any way to know the LN from a distance?
gr8slvrflt
Sun May 16, 2021 7:37 am
Does the MAX 7 need separate certification from the 8 and 9? If so, has it been certified?
WoodysAeroimag
Sun May 16, 2021 5:14 pm
On the right side of the fuselage the line number is located in 3 places. On the nose and above each lower cargo hold doors. On the left side its on the Nose only.
Image7571 43303 C-FTXF 737-8 Sunwing by 737 MAX Production, on Flickr
  • 1
  • 5
  • 6
  • 7
  • 8
  • 9
  • 21
