BBDFlyer wrote:Do you mean B80-B94? The gates will remain but the odd gates inside the horseshoe will no longer be there. There is not enough room inside the horseshoe to park planes on both sides. Once the odd gates are removed, there will be half the quantity of passengers but the same amount of room.
PSAatSAN4Ever wrote:What I was trying to put forth was that the original design - for the prop planes - was a bad design even then. As in, "from the moment the plans were approved". The seemingly endless corridors and endless walking coupled with the vast warehouse-like waiting area could have been better designed in the 1990's. It was just so out-of-step with everything else at the airport.
william wrote:So the north gates are gone because the regionals are using the regular main gates?
ScottB wrote:PSAatSAN4Ever wrote:What I was trying to put forth was that the original design - for the prop planes - was a bad design even then. As in, "from the moment the plans were approved". The seemingly endless corridors and endless walking coupled with the vast warehouse-like waiting area could have been better designed in the 1990's. It was just so out-of-step with everything else at the airport.
It was pretty much in-step with other facilities from the era at other airports -- look at Concourse A at IAD, the old Concourse E at SLC, Concourse D at CLE, Concourse E at PIT, etc. Heck, the banjos on the south side of Terminal B at IAH were replaced with that kind of design less than ten years ago (not to mention the A3 gates which WN will use temporarily). And the prop gates at the east end of Concourse A at DEN were probably even worse.
Better experiences like Concourses A & B at MSP, Terminal F at PHL, Concourse E at CLT, and the proper build-out of DTW Concourse C didn't really happen until the 2000-2010 time period.
Kden95 wrote:Any idea of when Cayman Airways is set to return?
303dk wrote:DEN is reporting 19.1” of snow and is under a blizzard warning. All runways are closed.
https://twitter.com/denairport/status/1 ... 68489?s=21
CURRENT BRAKING ACTION REPORTS ARE NIL
CALMSP wrote:the news is reporting that the airport will remain closed until 14:00. Wonder how much of that is due to staffing problems vs. removing snow. Didn't expect DEN to stay closed until mid-afternoon.
wnflyguy wrote:Anyone have an update on when the C gates are to open up?
Thanks in advance.
Flyguy
DEN1895 wrote:wnflyguy wrote:Anyone have an update on when the C gates are to open up?
Thanks in advance.
Flyguy
Construction should be finished at the end of 2020, Operational beginning of 2021.
Frontier14 wrote:DEN1895 wrote:wnflyguy wrote:Anyone have an update on when the C gates are to open up?
Thanks in advance.
Flyguy
Perhaps you meant the end of 2021 and the beginning of 2022 ?
Frontier 14
f18raider wrote:Just ran across this insta story by one of the many local DEN accounts I follow. Any speculation? Exciting regardless!
Wneast wrote:f18raider wrote:Just ran across this insta story by one of the many local DEN accounts I follow. Any speculation? Exciting regardless!
Hawaiian maybe but I think it’s more likely breeze which would be interesting since I don’t think they would go that far west to start but this is very interesting
Nicknuzzii wrote:Wneast wrote:f18raider wrote:Just ran across this insta story by one of the many local DEN accounts I follow. Any speculation? Exciting regardless!
Hawaiian is a really good guess in my opinion. They should really shift more of their long-haul aircraft to the states for this summer.
Wneast wrote:Nicknuzzii wrote:Wneast wrote:Hawaiian maybe but I think it’s more likely breeze which would be interesting since I don’t think they would go that far west to start but this is very interesting
That would be intriguing with southwest going to fly to Hawaii from Denver probably not tell next year because of the max 7 and United flying many flights I feel like they would get killed though chances are it wouldn’t be daily
What is your source that WN will fly Denver to Hawaii? I haven't seen anything on that.
Wneast wrote:ytib wrote:Wneast wrote:That would be intriguing with southwest going to fly to Hawaii from Denver probably not tell next year because of the max 7 and United flying many flights I feel like they would get killed though chances are it wouldn’t be daily
I don’t have a source they have said it many articles that they would use the max seven to do that route
So where are the articles?
Ishrion wrote:f18raider wrote:Just ran across this insta story by one of the many local DEN accounts I follow. Any speculation? Exciting regardless!
Some random guesses:
- Avianca to SAL (pretty sure this has minimal O&D)
- VivaAerobus to MTY/MEX
- JSX to LAS
- Swiss takes over Edelweiss' ZRH flight.
Or, what if it's a new cargo airline? Korean Air, Cathay Pacific, etc.
- JSX to LAS
jhsusman wrote:Wasn't Aer Lingus close to announcing a DEN flight pre-COVID? With Norwegian gone, there is space for another trans-Atlantic carrier once demand recovers. . .
