720B
Azores Airlines flies the longest commercial Airbus A321LR flight
Sat Jan 09, 2021 12:39 am
As per simpleflying, Azores Airlines flew a nonstop flight between Lisbon and Bogota, taking just under 10 hours; beating Air Transat record of a 9 hour flight using this type of aircraft
https://simpleflying.com/azores-longest-a321lr/
A388
Re: Azores Airlines flies the longest commercial Airbus A321LR flight
Sat Jan 09, 2021 2:16 am
Sounds a bit misleading as the aircraft is most likely weight restricted to operate that flight nonstop due to the altitude of Bogota's airport. It probably wouldn't be able to operate it nonstop at a full payload. On most flights they make a stop along the way.
A388
N62NA
Sat Jan 09, 2021 2:36 am
A388
If it was BOG-LIS, yes, but this was LIS-BOG.
TranscendZac
Sat Jan 09, 2021 2:45 am
It’s amazing how much performance Airbus has managed to get out of the A321. Amazing airplane.
Zac
Weatherwatcher1
Sat Jan 09, 2021 3:07 am
Was anyone actually on the flight? Was it just a ferry flight? The airline doesn’t serve bogota.
For reference, the delivery flights for 737s for European airlines usually go nonstop between BFI and Europe since 10 hours without passengers isn’t a big deal for the modern narrowbodies.
A388
Wed Jan 13, 2021 5:05 pm
It is impressive for sure but as I said before, it probably flew with restrictions in order to make it nonstop. There were probably few passengers on board which made a nonstop flight a possibility. Nonetheless, the A321NEO-LR and later the XLR version are impressive birds in their category as narrow body airplane.
A388
Polot
Wed Jan 13, 2021 6:11 pm
Were there even passengers on the flight, or was this just cargo?
LAX772LR
Wed Jan 13, 2021 8:36 pm
That wouldn't be much of a factor on the westbound, which this was.
:checkmark: :checkmark: :checkmark: Particularly seeing as it used to struggle just to do a US transcon, not too long ago.
airbazar
Wed Jan 13, 2021 8:56 pm
This was a cargo only flight. No passengers. It was originally scheduled for December 19th:
https://kiosquedaaviacao.pt/sata-azores ... -e-bogota/
