InnsbruckFlyer wrote:RIP to all those onboard, hope they didn't suffer. The speeds shown on FR24 seem pretty weird to me. I compared it with the speeds of the Metrojet crash in Egypt in 2015 (https://www.flightradar24.com/data/pinn ... d3#7d986d3), and both flights reported a massive loss in airspeed during the very rapid descend. Based on that, it sounds like it may have been a bomb...
aemoreira1981 wrote:Just fell from the sky at 11,000 feet, or was it forced that way? The fall appears to be a free fall or straight vertical (plunged into the ocean) as it was less than 2 minutes from climbing to crash. I would imagine there would be eyewitnesses to this crash. Planespotters noted a nose-dive.
F9Animal wrote:aemoreira1981 wrote:Just fell from the sky at 11,000 feet, or was it forced that way? The fall appears to be a free fall or straight vertical (plunged into the ocean) as it was less than 2 minutes from climbing to crash. I would imagine there would be eyewitnesses to this crash. Planespotters noted a nose-dive.
The first concern that comes to mind would be possible spatial disorientation. I don't know if this -500 had any modern equipment in the cockpit, or was it original steam dials? Speculation at this point.
Indonesia just cannot get a break from these horrible disasters. My heart is going out to those lost, the loved ones, and the airline community.
F9Animal wrote:I don't know if this -500 had any modern equipment in the cockpit, or was it original steam dials? Speculation at this point.
polywad6963 wrote:Could an in-flight breakup still cause the plane to keep its velocity up as well? That is an incredibly straight line down, just seeing if its possible at all. Among the wreckage, pieces of jeans were found by fisherman as well as small parts of the aircraft (per Telegraph)
Lighthouse wrote:Can’t see a spatial disorientation, stall or some other instrument failure leading to such an immediate and dramatic event. The data looks like some sort of catastrophic structural failure which made the aircraft immediately uncontrollable but obviously it’s too early to say anything with any certainty.
anatolialevant wrote:Lighthouse wrote:Can’t see a spatial disorientation, stall or some other instrument failure leading to such an immediate and dramatic event. The data looks like some sort of catastrophic structural failure which made the aircraft immediately uncontrollable but obviously it’s too early to say anything with any certainty.
Can I go a limb and say that, if catastrophic structural failure happened, it cannot be explosive decompression at all? The 737 cabin pressure can only be at 8000ft max at FL270 (http://www.b737.org.uk/pressurisation.htm), hence at FL100-FL110, the difference in pressure is definitely too low to create any explosive decompression.
flyingturtle wrote::worried:vrbarreto wrote:has already come to the conclusion that it was pilot error/suicide/poor maintenance
With these three possibilities, chances they are right must be 85%... in other news, I might be male, female, or a friendly, green alien.
Antaras wrote:flyingturtle wrote::worried:vrbarreto wrote:has already come to the conclusion that it was pilot error/suicide/poor maintenance
How about...a bomb?
mxaxai wrote:morrisond wrote:ikolkyo wrote:That graph is crazy, the aircraft is climbing but then loses altitude and loses speed in 10 seconds? Extremely odd. If I had to take guess, high AOA stall. Icing maybe?
Icing was involved in the Saratov Airlines flight, and could be a contributing factor here as well.
MEA-707 wrote:My guts feeling think of these possibilities:
1- Pilot suicide or intruder in cockpit. Many major accidents in the last years like MH370, Germanwings 9545, LAM, earlier Egyptair 990, RAM, Silkair turned out to be something like that.
Icing after 4 mins of flight in tropical Indonesia? Is that even possible?
kennethP3 wrote:MEA-707 wrote:My guts feeling think of these possibilities:
Correct me if I'm wrong, but we still have no idea what happened to MH370, right?
EgyptAir Flight 990 and SilkAir Flight 185 being incidents of pilot suicide are still disputed
kennethP3 wrote:Correct me if I'm wrong, but we still have no idea what happened to MH370, right?
travaz wrote:I know we don't know much about the debris field but if an aircraft broke apart in flight (a Bomb) the debris field would be over a large area. If the Aircraft nosedived into the sea the debris field would be compact. I am waiting to see where the wreckage is.
anatolialevant wrote:Digital dials for EICAS
76er wrote:anatolialevant wrote:Digital dials for EICAS
AFAIK the 737 does not have EICAS. (Any iteration)
MattFewer wrote:I'd assume anyone participating in a specialist aviation forum online like this one might be better informed ? There are copious amounts of discussion, links and information as to the current status of the Max and where it's flying again. Unfortunately all this proves is that 'Max hysteria' is as we expected, still a thing.
Antaras wrote:kennethP3 wrote:Correct me if I'm wrong, but we still have no idea what happened to MH370, right?
The only thing we knew is that the signal was (actively?) turned off when it nearly entered SGN-airspace, and it flew for a few hours on the Indian Ocean.
SurlyBonds wrote:MattFewer wrote:I'd assume anyone participating in a specialist aviation forum online like this one might be better informed ? There are copious amounts of discussion, links and information as to the current status of the Max and where it's flying again. Unfortunately all this proves is that 'Max hysteria' is as we expected, still a thing.
Set aside the fact that much of this "Max hysteria," as you colorfully, is perfectly justified, given Boeing's cutting of corners. The fact that the Sriwijaya crash involved a 737-500 in no way clears the 737-MAX, any more than the Pakistan Airlines A320 crash last year cleared the MAX.
Aesma wrote:
It's one of the risks associated with keeping the 737 going instead of building a new aircraft. Once the 737 brand is in the gutter, that's a problem for all 737 operators. I wonder if those who ordered new 737Max recently have thought about that.
scarebus03 wrote:Pure speculation on my part but a rudder hard over has caused such a dive in the past. In theory all affected B737's should have been modified years ago.
evanbu wrote:The aircraft was a former Continental Airlines 737-500 (N27610).
Ironically, N18611 was the aircraft that crashed in Denver in December of 2008. CO #1404
Not sure if those were delivered back-to-back but I found it interesting.
2- (Part of) stabilizer or wing broke off
3- Spatial disorientation maybe due to instrument failure, can make an aircraft make a 90 degree turn and dive to earth
Bradlee102896 wrote:Could this be a possible bombing? That could explain the sudden fall from the sky very abruptly. Just my two cents.
https://www.reuters.com/article/us-usa-boeing-airplanes/cracks-found-on-38-of-810-boeing-737-ng-jets-inspected-globally-idUSKBN1WP2BD
Indonesia's Sriwijaya Air said on Friday that it had grounded two planes.
Planes with cracks “may need to be taken out of the fleet for up to 60 days for maintenance,” Syth said.
The FAA last week said inspections would look for “cracking of the left and right hand side outboard chords of frame fittings and failsafe straps.”
It added that the cracking “could adversely affect the structural integrity of the airplane and result in loss of control of the airplane.”
Aircraft with more than 30,000 cycles must be inspected within seven days, while planes between 22,600 and 29,999 cycles must be inspected within 1,000 cycles, which typically correspond to the number of flights. In total, 1,911 U.S. 737 NGs are covered by the FAA directive.
https://leehamnews.com/2019/10/08/boeings-737-in-another-pickle-part-2/
The combination of a wing center-wingbox pushing wing and landing gear forces into the fuselage in an area where the fuselage has a large cutout for the folded main landing gear makes this area complex regarding forces and how these work the parts during flights.
The stress spectrum in the area can also have been affected by the later fitting of winglets on the NG, not foreseen in the original design of this area.
Winglets change the pressure distribution of the wing to a distribution spreading further outboard, by it increasing the wing root bending moment.
twinotter wrote:evanbu wrote:The aircraft was a former Continental Airlines 737-500 (N27610).
There is no irony. That is merely coincidence.
zeke wrote:I just hope this is not a max. The last position is near where lion air went down.
Interested wrote:AeroplaneFreak wrote:zeke wrote:I just hope this is not a max. The last position is near where lion air went down.
Light fires much? As if you don't already know Sriwijaya Air don't have the MAX let alone it being allowed to fly in Indonesia at the moment.
Fact is the first thought for vast majority when they read a 737 has crashed shortly after take off would be the same
Please Lord not another Max
Let's be honest
Breathe wrote:Being honest, my first thought would be the safety and well-being of the passengers and crew, rather than what variant of the Boeing 737 has crashed.
Noshow wrote:A very steep fall. Not a descent anymore.
From that altitude he could have glided back to the runway even with engines out?
