enilria
OAG Changes 1/13/2021:DL Adds SEA-CUN/PVR/SJD,MSP-ESC;UA Adds IAD-ECP/PNS,ORD-FOD/MCW,IAH-SRQ Flights FEB-SEP
Wed Jan 13, 2021 12:52 pm
FAQ
SOURCE: OAG
AS OF JULY 2018 THERE ARE CHANGES TO THE FORMAT OF THIS REPORT...SEE BELOW
WHAT IS THIS REPORT?
This compares departures for sale THIS WEEK for the stated period versus what was for sale LAST WEEK...prior year departures are now shown in brackets e.g. [0].
THE SCHEDULES SHOWN HERE CHANGE AFTER YOU POST???
-To improve is to change; to be perfect is to change often---Winston Churchill. This is data the carriers filed at the point in time it was captured. It's changed since then. You are just going to have to live with it.
HOW DO I READ IT?
XXX-YYY DEC 4>5[4] JAN 4>5[4]
XXX Departure IATA code, YYY Arrival IATA code, Month, Average Departures/Day over the month for sale as of last week, Average Departures/Day over the month for sale as of this week, in brackets is the number of Average Departures/Day over the month that were scheduled one year earlier. So, it means that the listed airline changed the frequency between the two airports to add from 4 to 5 roundtrips in December and January. It also means that there were 4 roundtrips the prior year in each month. No other months were changed. I average two directions.
WHAT ABOUT CARRIERS THAT DON'T PUBLISH A SCHEDULE 9 MONTHS IN ADVANCE?
NEW CHANGE-Sometimes airlines do not load their schedules for the entire 330 day standard sales window. Southwest and many LCCs load their schedules for as little as 5 months into the future. When these flight are extended into a new sales month, it becomes a "schedule change". Previously, I have manually deleted these in many cases and replaced them with a Year-Over-Year compare. Effective immediately, this will now change. When a flight is loaded from 0 departures X departures, where X was the same the prior year, the record will not be shown. For example, if Delta loaded ATL-EGE MAR 0>1(1), it would not be shown because this additional flight does not represent a real year-over-year addition. Similarly, if B6 extended their schedule a record like this ATL-BOS JUL 0>4(4) would not be shown. It will be shown if the flight frequency changed from the prior year. So B6 ATL-BOS JUL 0>3(4) would be shown. If a partial month was loaded in a core schedule that became a full schedule month, those changes may be shown under this logic. For example, WN BNA-SEA 0.3>2(2). Because only a fraction of the month was previously loaded for sale, these changes will not be filtered out. I may, however, manually remove them to declutter.
HOW ARE THE DAILY DEPARTURES CALCULATED?
This report uses total operations for the month listed, divided over the days in the month. The following criteria are used to show a change: 1) The change must be at least 6 roundtrips per month with no exceptions, 2) changes of at least 6/week are always shown, 3) routes that are added or dropped are shown subject to the change minimum, and 4) in all other cases routes must change by 20% to be shown. For example, if a route changed from 21/week to 18/week it would not be shown because the change is -14.3%. This is done to filter minor changes that occur in large numbers.
WHAT ARE THE FRACTIONAL FLIGHTS?
Flights that do not operate every day of the month create fractional service. If the route has more than 2 daily flights, departures are rounded, but in cases of less than 2 departures per day a fraction is shown. For example, if a flight operates 4 times in April it will show 4/30=0.133=0.1. Also , a flight that only operates once per week may vary between 0.1 and 0.2 because a weekday may repeat either 4 or 5 times depending on the month.
THOSE FLIGHTS AREN'T DELTA, THEY ARE SKYWEST
This report only shows the marketing code. It is too complicated to show all the operators.
THE FREQUENCIES MAY HAVE CHANGED AS YOU SHOW, BUT THE SEATS DIDNT CHANGE BECAUSE OF EQUIPMENT SWAPS
Seats are not shown. That is a natural weakness of a frequency based report, but it provides something to discuss below.
THIS LOOKS LIKE AN ERROR?
The carriers file the schedules. They do make mistakes. Most of the mistakes I have seen are either related to code shares not being marked as "duplicates" or carriers filing flights with invalid data such as equipment codes that are not standard or overlapping schedule periods that see the same flight number in two places at once. These cause flights to not appear.
CHARTERS?
Lately charters have been showing up in the database. I have no idea if that will continue.
I marked some of the ones I thought were interesting with an "*".
NOTE: The source feed was delayed to me for unknown reasons. So, a day late, but better late than never.
3E ATL-MKL FEB 0.7>0[0.7]
3E BRL-ORD FEB 1.4>0[1.4]
3E BRL-STL FEB 1.4>0[1.4]
3E FOD-MSP FEB 0.7>0[0.7]
3E FOD-STL FEB 2>0[2]
3E JBR-STL FEB 3>1.9[2]
3E MCW-MSP FEB 1.4>0[1.4]
3E MCW-ORD FEB 1.4>0[1.4]
3E MKL-STL FEB 1.5>0.4[1.4]
3M CHS-TPA MAR 0.4>0.2[0]
3M ELH-FLL FEB 1.6>0.2[1.5] MAR 2>0.2[2] APR 2>0.8[3] MAY 2>0.9[1.9] JUN 2>0.8[1.2] JUL 2>0.9[1.3] AUG 2>0.9[2] SEP 2>0.8[0.7]
3M EYW-FLL FEB 1.8>0.7[1.8] MAR 2>0.5[3] APR 2>1.0[3] MAY 2>1.0[2] JUN 2>1.0[1.3] JUL 2>1.0[1.4] AUG 2>1.0[3] SEP 2>1.0[1.1]
3M EYW-MCO FEB 1.3>0.8[1.2] MAR 2>1.0[1.7] APR 2>1.5[2] MAY 2>1.4[2] JUN 2>1.4[0.7] JUL 2>1.5[1.0] AUG 2>1.4[1.9] SEP 2>1.4[1.1]
3M EYW-TPA FEB 1.9>0.8[1.9] MAR 3>0.8[3] APR 3>1.9[3] MAY 3>1.9[2] JUN 3>1.8[1.1] JUL 3>1.9[1.5] AUG 3>1.9[3] SEP 3>1.9[1.6]
3M FLL-FPO MAR 0.5>0.1[0.7] APR 0.6>0.3[0.7] MAY 0.5>0.3[0.8] JUN 0.6>0.3[0.5] JUL 0.6>0.3[0.5] AUG 0.5>0.3[0.9] SEP 0.6>0.3[0.1]
3M FLL-GGT FEB 1.0>0.2[1.0] MAR 0.7>0.3[1.3] APR 1.5>0.7[1.6] MAY 1.5>0.7[1.1] JUN 1.4>0.7[0.8] JUL 1.5>0.7[0.8] AUG 1.4>0.7[1.5] SEP 1.4>0.7[0.4]
3M FLL-JAX FEB 0.3>0[0.2]
*3M FLL-MHH APR 0>0.3[0.9] MAY 0>0.3[0.4] JUN 0>0.3[0.5] JUL 0>0.3[0.4] AUG 0>0.3[0.8] SEP 0>0.3[0.1]
3M FLL-NAS APR 0.3>0.6[0] MAY 0.3>0.6[0] JUN 0.3>0.6[0] JUL 0.3>0.6[0] AUG 0.3>0.6[0] SEP 0.3>0.6[0]
3M FLL-TLH FEB 0.9>0.4[0.9] MAR 1.5>0.3[1.4] APR 1.6>0.6[1.6] MAY 1.5>0.6[0.7] JUN 1.6>0.5[0.5] JUL 1.5>0.6[0.8] AUG 1.6>0.6[1.4] SEP 1.6>0.6[0.4]
3M FLL-TPA FEB 1.6>0.7[1.5] MAR 2.0>0.7[1.8] APR 2>1.0[2] MAY 2>1.0[1.5] JUN 2>1.0[1.0] JUL 2>1.0[1.2] AUG 2>1.0[1.8] SEP 2>1.0[0.8]
3M JAX-TPA FEB 0.3>0[0.2]
3M MCO-PNS FEB 1.2>0.5[1.3] MAR 1.7>0.8[1.6] APR 1.7>1.0[1.8] MAY 1.7>1.0[1.2] JUN 1.7>1.0[0.9] JUL 1.7>1.0[1.1] AUG 1.7>1.0[1.6] SEP 1.7>1.0[0.8]
*3M NAS-TPA FEB 0.4>0[0.4] MAR 0.5>0[0.8] APR 0.6>0.1[1.0] MAY 0.6>0.2[1.0] JUN 0.6>0.1[0.4] JUL 0.6>0.2[0.5] AUG 0.6>0.1[0.9] SEP 0.6>0.1[0.4]
3M PNS-TPA FEB 1.2>0.3[1.1] MAR 1.7>0.3[1.6] APR 1.7>0.9[1.8] MAY 1.7>0.9[1.4] JUN 1.7>0.8[0.6] JUL 1.7>0.9[0.9] AUG 1.7>0.8[1.6] SEP 1.7>0.9[0.7]
*3M TLH-TPA FEB 1.0>0[0.9] MAR 1.6>0[1.4] APR 1.6>0.4[1.6] MAY 1.5>0.5[1.0] JUN 1.6>0.4[0.8] JUL 1.5>0.4[1.0] AUG 1.6>0.5[1.4] SEP 1.6>0.4[0]
4B ABQ-CNM FEB 0>1.7[0] MAR 1.3>1.7[1.9] MAY 1.3>1.7[1.9]
4B AOO-BWI FEB 1.0>1.9[1.0]
4B AOO-PIT FEB 1.0>1.9[1.0]
4B CDR-DEN FEB 0>1.8[0] APR 0>1.9[2] MAY 0>1.8[1.9] JUN 0>1.9[2]
4B CEZ-DEN FEB 0>1.8[0] MAR 0>1.9[3] APR 0>1.9[3] MAY 0>1.8[3]
4B CEZ-PHX FEB 0>0.8[0] APR 0>0.9[1.0] MAY 0>0.8[1.0]
4B CNM-ELP FEB 0>1.9[0] MAR 0>1.9[0] APR 0>1.9[0] MAY 0>1.8[0] JUN 0>1.9[0]
4B DEN-MCK FEB 0>1.0[0] MAR 0>1.0[1.9] APR 0>1.0[2] MAY 0>1.0[1.9] JUN 0>1.0[2]
4B IWD-MSP FEB 0>0.9[0]
4B IWD-ORD JUN 2.0>1.5[0]
4B PHX-SOW FEB 0.5>2[0.5]
7H AKN-ANC MAY 0>0.7[1.0] JUL 0>5[0] AUG 0>4[0] SEP 0>2[0]
7H ANC-DLG MAY 0>0.7[1.9] JUL 0>1.8[0] AUG 0>2[0] SEP 0>3[0]
7H ANC-DUT MAR 0.8>2[1.9] MAY 0>1.9[3] JUN 0>2[1.3] JUL 0>2[0] AUG 0>2[0] SEP 0>2[0]
7H ANC-ENA FEB 6>3[6] APR 0>3[8] MAY 0>3[8] JUN 0>3[4] JUL 0>4[0] AUG 0>4[0] SEP 0>3[0]
7H ANC-FAI MAR 0.4>1.0[2.0] APR 0>1.0[2] MAY 0>1.0[2] JUN 0>1.0[0.8] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0]
7H ANC-HOM MAR 0.7>1.6[4] APR 0>1.6[4] MAY 0>1.7[4] JUN 0>1.6[1.7] JUL 0>1.7[0] AUG 0>1.7[0] SEP 0>1.6[0]
7H ANC-SNP APR 0>0.3[0.5] MAY 0>0.3[0.4] JUN 0>0.2[0.4] JUL 0>0.3[0] AUG 0>0.5[0] SEP 0>0.3[0]
7H ANC-UNK APR 0>0.3[1.0] MAY 0>0.2[1.0] JUN 0>0.4[0.5] JUL 0>0.3[0] AUG 0>0.3[0] SEP 0>0.4[0]
7H ANC-VDZ MAR 0.4>0.9[1.6] APR 0>0.9[1.8] MAY 0>0.8[1.7] JUN 0>0.9[0.7] JUL 0>0.8[0] AUG 0>0.9[0] SEP 0>0.9[0]
7H ENA-HOM FEB 0>0.7[0] MAR 0>0.7[0] APR 0>0.7[0] MAY 0>0.7[0] JUN 0>0.7[0] JUL 0>0.7[0] AUG 0>0.8[0] SEP 0>0.7[0]
8E KTS-TLA FEB 0.8>0.4[0.8]
8E KTS-WAA FEB 0.4>0[0.3]
8E OME-TLA FEB 0.8>0.4[0.8]
8E OME-WAA FEB 0.8>0.4[0.8]
8E OTZ-PHO FEB 1.1>0.4[1.1]
8E SMK-UNK FEB 0.4>1.3[0.4] MAR 0.4>1.3[1.3] APR 0.4>1.3[1.4] MAY 0.4>1.3[1.3] JUN 0.4>1.3[0.4] JUL 0.4>1.3[1.3] AUG 0.4>1.3[1.3] SEP 0.4>1.3[1.3]
8E SMK-WBB FEB 0.4>1.3[0.4] MAR 0.4>1.3[1.3] APR 0.4>1.3[1.4] MAY 0.4>1.3[1.3] JUN 0.4>1.3[0.4] JUL 0.4>1.3[1.3] AUG 0.4>1.3[1.3] SEP 0.4>1.3[1.3]
8V AET-BTT MAR 0.2>0[0.5]
8V AET-FAI MAR 0.5>0[0.7]
8V AET-HUS MAR 0.2>0[0.2]
8V AKP-FAI FEB 1.4>0[1.4]
8V ARC-VEE FEB 0.7>0[0.7]
8V BTT-FAI MAR 0.2>0[0.5]
8V CIK-FYU FEB 0.7>0[0.7]
8V FAI-FYU FEB 2>0[2]
8V FAI-GAL FEB 2>0[2]
8V FAI-HSL MAR 0.5>0[0.5]
8V FAI-HUS MAR 0.2>0[0.3]
8V FAI-KBC FEB 0.7>0[0.7]
8V FAI-RBY MAR 0.5>0[0.8]
8V FAI-TAL MAR 0.9>0[1.6]
8V FAI-VEE FEB 0.7>0[0.7]
8V FYU-KBC FEB 0.7>0[0.7]
8V FYU-VEE FEB 0.7>0[0.7]
8V GAL-HSL MAR 0.5>0[0.4]
8V GAL-KAL FEB 0.7>0[0.7]
8V GAL-KYU FEB 0.4>0[0.3]
8V GAL-NUL FEB 1.1>0[1.0]
8V GAL-RBY MAR 0.5>0[0.5]
8V KYU-NUL FEB 0.4>0[0.3]
9K ACK-EWB AUG 0.4>0.8[1.2] SEP 0.4>0.8[1.3]
9K ACK-HYA JUN 8>9[7] JUL 8>9[9] AUG 8>9[10] SEP 8>9[13]
9K BNA-MWA FEB 1.7>0[1.7] MAY 1.7>0[1.7]
9K BNA-OWB FEB 2>0[1.9] MAR 2>1.5[1.9] APR 2>1.5[2] MAY 2>0[1.9] JUN 2>1.5[2] JUL 2>1.4[1.9] AUG 2>1.4[2] SEP 2>1.5[0]
9K BOS-LEB JUN 1.4>2[5] JUL 1.4>2[4] AUG 1.4>3[4]
9K BOS-RUT SEP 3>2[0]
9K HPN-LEB JUN 0.5>0.8[1.2] JUL 0.5>0.9[1.0] AUG 0.5>0.9[2] SEP 0.5>0.9[2]
9K IRK-STL FEB 3>0.9[3] MAR 3>2[3] APR 3>2[3] MAY 3>0[3] JUN 3>2[3] JUL 3>2[3] AUG 3>2[3] SEP 3>2[3]
9K MBL-ORD MAY 3>0[0]
9K MWA-STL FEB 4>0[3] MAY 3>0[3]
9K ORD-UIN FEB 3>0.9[2] MAR 3>1.2[2] APR 3>1.2[3] MAY 3>0[3] JUN 3>1.2[3] JUL 3>1.2[3] AUG 3>1.2[3] SEP 3>1.2[0]
9K OWB-STL FEB 1.0>0[1.0] MAR 1.0>0.7[0.9] APR 1.0>0.7[1.0] MAY 1.0>0[1.0] JUN 1.0>0.7[1.0] JUL 1.0>0.7[1.0] AUG 1.0>0.7[1.0] SEP 1.0>0.7[0]
9K STL-UIN FEB 3>1.3[3] MAR 3>1.3[2] APR 3>1.3[3] MAY 3>0[3] JUN 3>1.3[3] JUL 3>1.3[3] AUG 3>1.3[3] SEP 3>1.3[0]
9X BFD-PIT FEB 2>0[2] MAR 3>2[3]
9X BWI-DUJ FEB 1.4>0[1.4]
9X BWI-LNS FEB 1.4>0[0]
9X BWI-MGW FEB 1.4>0[1.4]
9X DFW-ELD FEB 0.7>0[0.7] MAR 1.3>0.7[1.6]
9X DFW-HOT FEB 1.8>0[1.7]
9X DFW-HRO FEB 1.4>0[1.4]
9X DUJ-PIT FEB 3>0[3]
9X ELD-MEM FEB 0.7>0[0.7]
9X HRO-MEM FEB 0.7>0[0.7]
9X IPL-LAX FEB 3>1.3[3]
9X LNS-PIT FEB 2>0.9[0]
9X MGW-PIT FEB 3>0[3]
9X PBI-TPA MAR 1.8>0[2]
AA ABQ-PHX FEB 1.0>1.2[1.0]
AA BTR-DFW MAR 5>4[5]
AA BTV-PHL FEB 1.1>0.8[1.0]
AA CHS-DFW FEB 1.6>1.0[1.5]
AA CLL-DFW MAR 1.7>0.9[3]
AA CLT-GCM FEB 0.3>0[0.3]
AA CRP-DFW MAR 7>5[6]
AA DFW-GGG MAR 1.7>1.2[2]
AA DFW-GPT MAR 1.1>0.7[2]
AA DFW-LBB MAR 7>6[6]
AA DFW-LRD MAR 3>2[3]
AA DFW-MAF MAR 6>5[6]
AA DFW-SPS MAR 3>2.0[3]
AA DFW-TYR MAR 3>2[4]
AA ISP-PHL MAR 0.6>0.9[2]
AA JFK-RDU JUN 2>1.3[0] SEP 2>1.3[3]
AA JFK-RIC APR 1.0>0.8[2] MAY 1.0>0.8[3]
AA JFK-YUL MAR 0.9>0[0.9]
AA JFK-YYZ MAR 0.9>0[0]
AA LAX-LIH FEB 1.0>0.1[1.0]
AA LAX-ORD MAR 8>7[8]
AA LIH-PHX FEB 1.0>0.6[1.0]
AA MGA-MIA FEB 1.8>1.1[1.7]
AA MIA-ORF FEB 1.6>1.3[1.5]
AA MIA-TLH FEB 1.0>0.5[1.0]
AA MLI-ORD MAR 1.7>1.1[3]
**AA ORD-PNS MAR 0>0.5[0] APR 0>0.3[0.1] MAY 0>0.3[0.1]
**AA ORD-VPS MAR 0>0.8[0] APR 0>0.3[0.1] MAY 0>0.3[0.2]
AA ORD-YYZ FEB 0.6>0.3[0.6] MAR 4>3[5]
AA PHF-PHL MAR 0.6>0.9[1.8]
AA PHL-YUL MAR 5>1.8[1.7]
AA PHL-YYZ MAR 5>1.5[3]
AD MCO-VCP APR 0.6>0[1.1]
AM DEN-MEX MAR 0.8>1.2[1.1]
AM FAT-GDL MAR 0.4>0.7[0.4]
AM GDL-SMF MAR 0.4>0.8[0.4]
AM IAH-MEX MAR 3>2.0[3]
AM JFK-MEX MAR 3>2.0[3]
AM JFK-MTY MAR 1.0>0[0.9]
AM LAS-MEX MAR 1.0>0.4[1.0]
AM LAS-MTY MAR 0.3>0[0.3]
AM LAX-MEX MAR 4>2.0[4]
AM LAX-MTY MAR 1.0>0[0.9]
AM MEX-ORD MAR 1.0>1.5[0.9]
AM MEX-SAT MAR 1.0>2[0.9]
AM MEX-SEA MAR 1.0>0.5[0.9]
AM MEX-SFO FEB 1.0>0.7[1.0] MAR 2.0>1.0[1.9]
AS ABQ-PDX FEB 0.6>0[0.6] MAR 1.0>0.5[0.9]
AS ADQ-ANC FEB 1.6>2[1.5] MAR 1.7>2[1.6]
AS ANC-BRW FEB 0.6>1.0[0.6] MAR 0.5>0.8[0.5]
AS ANC-HNL FEB 0.8>0.4[0.7] MAR 1.0>0.6[0.9]
AS ANC-JNU FEB 3>2.0[3] MAR 4>3[3]
AS ANC-OME FEB 1.3>1.0[1.3]
AS ANC-OTZ FEB 1.3>1.0[1.2]
AS ANC-PDX FEB 1.9>0.6[1.8] MAR 3>1.8[1.9]
AS ANC-SEA MAR 12>10[12]
AS ATL-SEA FEB 1.6>1.0[1.6]
3X is nuts. Unlikely they actually fly it.
**AS AUS-LAX MAR 0>0.5[0] APR 0>1.0[0] MAY 0>1.8[0] JUN 0>3[0] JUL 0>3[0] AUG 0>3[0] SEP 0>3[0]
AS AUS-PDX FEB 0.6>0[0.6] MAR 1.0>0.5[0.9]
AS AUS-SEA FEB 2>1.8[2]
AS AUS-SFO FEB 1.4>0.7[1.4] MAR 1.9>1.1[1.5] JUN 2>3[1.0] JUL 2>3[1.0] AUG 2>3[2] SEP 2>3[1.0]
AS AUS-SJC FEB 1.6>0.7[1.6] MAR 2>1.1[1.6]
AS BIL-PDX FEB 1.6>1.0[1.6] MAR 2.0>1.5[0.8]
AS BOI-GEG FEB 3>2.0[3] MAR 4>3[1.6]
AS BOI-PDX FEB 6>3[6] MAR 8>5[7]
AS BOI-SAN FEB 1.9>1.3[1.9] MAR 2.0>1.4[1.0]
AS BOI-SFO FEB 1.6>1.0[1.6] MAR 2.0>1.3[0]
AS BOI-SJC FEB 1.6>1.0[1.5] MAR 2.0>1.4[0.9]
AS BOS-PDX FEB 0.6>0[0.6] MAR 1.0>0.4[0.9]
AS BOS-SFO FEB 1.2>0.3[1.2] MAR 1.8>1.0[1.5]
AS BRW-FAI FEB 0.3>0[0.3] MAR 0.5>0.2[0.5]
AS BRW-SCC FEB 0.6>0[0.6] MAR 1.0>0.5[0.9]
AS BUR-PDX FEB 2>1.0[2] MAR 3>1.9[1.9]
AS CMH-SEA MAR 0.8>0.6[0.8]
AS DAL-LAX FEB 2>0.9[2] MAR 3>1.8[2]
AS DAL-PDX FEB 1.9>0[1.8] MAR 3>1.3[2]
AS DAL-SEA FEB 1.5>0.9[1.4]
AS DAL-SFO FEB 2>0.9[2] MAR 3>1.5[3]
AS DCA-PDX FEB 0.6>0[0.6] MAR 1.0>0.5[0.9]
AS DEN-PDX FEB 1.6>1.0[1.6] MAR 2>1.5[0]
AS DEN-SEA MAR 5>4[4]
AS EUG-PDX FEB 1.8>0[1.8] MAR 3>1.3[3]
AS EWR-LAX FEB 2>0.7[2] MAR 3>1.6[2]
AS EWR-PDX FEB 0.6>0[0.6] MAR 1.0>0.4[0.9]
AS EWR-SEA FEB 1.6>0.9[1.5]
AS EWR-SFO FEB 2>0.7[2] MAR 3>1.6[2]
AS FAI-SEA FEB 2>1.8[2]
AS FAT-LAX FEB 1.4>0.9[1.4] MAR 1.8>1.3[0]
AS FAT-PDX FEB 1.6>1.0[1.6] MAR 2.0>1.4[1.7]
AS FAT-SAN FEB 3>1.0[3] MAR 4>2[2]
AS FCA-PDX FEB 0.6>0[0.6] MAR 1.0>0.5[0]
AS GDL-LAX FEB 1.9>1.2[1.8] MAR 1.5>1.0[0.9]
AS GEG-PDX FEB 6>3[6] MAR 8>5[8]
AS GEG-SAN FEB 1.5>0.9[1.5] MAR 1.9>1.4[0.9]
AS GEG-SEA FEB 11>10[11] MAR 13>12[13]
AS GEG-SFO FEB 1.6>1.0[1.5] MAR 2.0>1.5[0]
AS GEG-SJC MAR 1.0>0.7[0]
AS GST-JNU AUG 1.0>0.5[0.8] SEP 1.0>0[0]
AS HNL-LAX FEB 0.8>0.4[0.8] MAR 1.0>0.6[0.8]
AS HNL-PDX MAR 1.0>0.8[0.9]
AS HNL-SAN FEB 0.9>0.6[0.8] MAR 1.0>0.7[0.9]
AS HNL-SEA FEB 3>1.8[2]
AS HNL-SJC FEB 0.7>0.4[0.7] MAR 1.0>0.6[0.5]
AS IAD-SEA FEB 1.6>1.0[1.5]
AS JFK-PDX FEB 0.6>0[0.6] MAR 1.0>0.5[0.9]
AS JFK-SFO FEB 3>0.5[3] MAR 4>2[3]
AS JNU-SIT FEB 1.4>1.0[1.4] MAR 1.7>1.3[1.7]
AS KOA-SAN FEB 0.7>0.3[0.7] MAR 1.0>0.6[0.4]
AS KOA-SJC FEB 0.8>0.5[0.8] MAR 1.0>0.7[0.5]
AS KTN-SIT FEB 0.6>0[0.6] MAR 1.0>0.5[0.9]
AS LAS-LAX MAR 1.4>1.7[3]
AS LAS-PAE FEB 1.6>1.0[1.5] MAR 1.8>1.3[1.9]
AS LAS-SEA MAR 9>7[8]
AS LAS-SFO MAR 5>2[7]
AS LAX-LIR MAR 0.9>0.7[0.9]
AS LAX-LTO FEB 0.7>0.4[0.7] MAR 1.0>0.6[0.9]
AS LAX-MZT FEB 0.8>0.4[0.8] MAR 1.0>0.6[0.8]
AS LAX-OGG FEB 0.8>0.5[0.8] MAR 0.9>0.6[0.6]
AS LAX-PDX FEB 8>5[8] MAR 9>6[6]
AS LAX-RDM MAR 1.9>1.4[0.9]
AS LAX-SFO FEB 10>6[10] MAR 12>7[9]
AS LAX-SJC FEB 5>3[5] MAR 6>4[6]
AS LAX-STS FEB 2>1.3[2] MAR 2>1.5[3]
AS LAX-ZIH FEB 0.8>0.5[0.8] MAR 1.0>0.7[0.9]
AS LIH-PDX MAR 1.0>0.5[0.9]
AS LIH-SAN MAR 1.0>0.5[0.5]
AS LIH-SEA MAR 1.8>1.2[1.9]
AS LIH-SJC MAR 1.0>0.5[0.5]
AS MCI-PDX FEB 0.6>0[0.6] MAR 1.0>0.5[0]
AS MCO-PDX FEB 1.1>0.8[1.0]
AS MCO-SAN FEB 1.4>0.7[1.4] MAR 1.9>1.2[0.9]
AS MCO-SFO FEB 0.6>0.2[0.6] MAR 1.0>0.5[0.9]
AS MFR-PDX FEB 4>2.0[4] MAR 6>4[4]
AS MRY-SAN FEB 1.6>1.0[1.6] MAR 1.9>1.4[0.9]
AS MSO-PDX FEB 0.6>0[0.6] MAR 1.0>0.5[0.9]
AS MSP-PDX FEB 0.6>0[0.6] MAR 1.0>0.5[0.9]
AS OAK-PDX FEB 2>1.0[2] MAR 3>1.9[1.7]
AS OGG-PDX FEB 1.6>1.0[1.6] MAR 2.0>1.4[1.9]
AS OME-OTZ FEB 0.3>0[0.3] MAR 0.5>0.2[0.5]
AS ONT-PDX FEB 2>1.0[2] MAR 3>1.9[1.7]
AS ORD-PDX FEB 1.6>0.9[1.6] MAR 1.9>1.2[0.9]
AS ORD-SFO FEB 1.6>0.3[1.5] MAR 2.0>0.9[0.9]
AS PAE-PHX FEB 1.6>1.0[1.6] MAR 1.9>1.3[1.9]
AS PAE-SAN FEB 1.3>0[1.2] MAR 2.0>0.9[1.9]
AS PAE-SNA FEB 0.6>0[0.6] MAR 1.0>0.5[0.9]
AS PDX-PHX FEB 3>4[3]
AS PDX-RDM FEB 3>0.9[3] MAR 4>2[4]
AS PDX-RNO FEB 3>2.0[3] MAR 4>3[3]
AS PDX-SAN FEB 5>4[5] MAR 6>4[4]
AS PDX-SFO FEB 5>3[5] MAR 6>4[6]
AS PDX-SJC FEB 4>3[4] MAR 5>4[4]
AS PDX-SJD FEB 0.8>0.6[0.8]
AS PDX-SLC FEB 3>2.0[3] MAR 4>3[3]
AS PDX-STS FEB 1.6>0.3[1.6] MAR 2>0.9[0.9]
AS PDX-YVR FEB 0.6>0[0.6] MAR 1.0>0.5[0.9]
AS PHX-SFO FEB 1.6>1.0[1.6] MAR 1.9>1.5[1.0]
AS PIT-SEA FEB 0.7>0.4[0.6] MAR 0.8>0.6[0.9]
AS PSP-SFO FEB 4>3[4] MAR 4>3[4]
AS PVR-SAN FEB 0.8>0.4[0.8] MAR 1.0>0.7[0.4]
AS PVR-SJC FEB 0.6>0.4[0.6]
AS RDM-SFO MAR 1.9>1.5[0]
AS SAN-SFO FEB 6>5[6] MAR 6>4[5]
AS SAN-SJC FEB 5>3[5] MAR 6>4[4]
AS SAN-SJD FEB 1.6>1.1[1.6] MAR 2>1.5[1.0]
AS SAN-SLC FEB 1.6>1.0[1.6] MAR 1.9>1.3[1.5]
AS SEA-SMF FEB 5>4[5]
AS SEA-SUN MAR 0.9>1.1[1.2]
AS SEA-YEG FEB 0.6>0[0.6] MAR 1.7>1.1[2]
AS SEA-YLW FEB 0.6>0[0.6] MAR 1.3>0.8[1.9]
AS SEA-YVR FEB 3>1.9[3] MAR 5>3[6]
AS SEA-YYC FEB 0.6>0[0.6] MAR 1.8>1.1[2]
AS SEA-YYJ FEB 0.6>0[0.6] MAR 2>1.4[3]
AS SFO-SLC FEB 1.6>1.0[1.6] MAR 1.7>1.0[1.6]
AS SFO-SNA FEB 5>2[5] MAR 6>3[6]
AS SNA-STS FEB 0.6>0[0.6] MAR 1.0>0.5[0.9]
AV BAQ-MIA FEB 1.0>0.4[1.0]
AV BOG-FLL FEB 1.0>0.4[1.0]
AV BOG-IAD FEB 2>1.0[1.9]
AV BOG-JFK FEB 3>2[3]
AV BOG-LAX FEB 1.0>0[1.0]
AV BOG-MCO FEB 1.0>0.6[1.0]
AV BOG-MIA FEB 4>2[4]
AV CLO-MIA FEB 1.0>0.4[1.0]
AV DFW-SAL FEB 0.9>0.4[0.9]
AV EWR-SAL FEB 1.0>0.4[1.0]
AV GUA-LAX FEB 1.0>0.5[1.0]
AV IAD-SAL FEB 3>1.7[3]
AV IAH-SAL FEB 1.0>0.3[1.0]
AV JFK-MDE FEB 1.0>0.4[1.0]
AV JFK-SAL FEB 2>1.4[1.9]
AV LAX-SAL FEB 4>3[4]
AV MDE-MIA FEB 1.0>0.6[1.0]
AV MIA-SAL FEB 1.0>0.6[1.0]
AV SAL-SFO FEB 2>1.0[1.9]
B5 MDR-WIL FEB 0>2[0] MAR 0>2[0] APR 0>2[0] MAY 0>2[0]
B6 ABQ-JFK MAR 0.2>0[0.6]
*B6 BOS-BUR APR 1.0>0[1.0] MAY 1.0>0[1.0] JUN 1.0>0.7[0]
B6 BOS-BWI APR 4>0[5] MAY 5>0[3] JUN 5>3[0]
B6 BOS-MSP MAR 0.2>0[2]
*B6 BOS-SJC APR 1.0>0[0.7] MAY 1.9>0[0.9] JUN 1.8>1.3[0]
*B6 BTV-JFK FEB 0.3>0[0.3] MAR 0.5>0[3]
*B6 BUR-JFK APR 1.9>0[1.8] MAY 1.8>0[1.0] JUN 1.9>1.3[0]
B6 EWR-SDQ FEB 1.6>1.9[1.5]
*B6 FLL-PDX FEB 0.2>0[0.2] MAR 0.3>0[0]
B6 JFK-MSP MAR 0.4>0[0]
*B6 JFK-ONT APR 0.6>0[0.9] MAY 1.0>0[0.5] JUN 1.0>0.7[0]
*B6 JFK-SJC APR 1.0>0[0.7] MAY 0.9>0[0.9] JUN 1.0>0.7[0]
BA JFK-LHR FEB 2>1.6[1.9]
BA LHR-MCO FEB 1.0>0.6[1.0]
BA LHR-PHL FEB 0.7>0.4[0.7]
CM BOS-PTY MAR 1.0>0.4[0.9] APR 1.0>0.4[1.0] MAY 1.0>0.3[0.9]
CM DEN-PTY APR 0.6>0[0.6] MAY 0.6>0[0.5]
CM FLL-PTY MAR 1.0>0.4[0.7] APR 1.0>0.4[0.9] MAY 1.0>0.4[0.7]
CM IAD-PTY MAR 3>1.5[1.9] APR 3>1.5[2] MAY 3>1.5[2]
*CM LAS-PTY MAR 1.0>0[0.7] APR 1.0>0[0.8] MAY 1.0>0[0.7]
CM LAX-PTY MAR 3>1.5[3] APR 3>1.5[3] MAY 3>1.6[3]
CM MCO-PTY MAR 5>2[4] APR 5>2[5] MAY 5>2[5]
CM MIA-PTY MAR 6>4[5] APR 6>4[6] MAY 6>4[6]
*CM MSY-PTY MAR 0.6>0[0.5] APR 0.6>0[0.6] MAY 0.6>0[0.4]
CM ORD-PTY MAR 2>0.5[1.6] APR 2>0.5[2] MAY 2>0.5[1.7]
CM PTY-SFO MAR 2>0.4[1.9] APR 2>0.4[2] MAY 2>0.5[1.8]
CM PTY-TPA MAR 1.0>0.2[0.6] APR 1.0>0.2[0.7] MAY 1.0>0.3[0.7]
CX HKG-JFK FEB 0.7>0.4[0.7]
CX HKG-LAX FEB 1.0>0.6[1.0]
CX HKG-SFO FEB 0.9>0.4[0.7]
D7 HNL-KIX FEB 1.0>0[1.0]
DL ATL-YUL MAR 4>1.0[3]
This probably goes back out with the new intl entry req
**DL CUN-SEA APR 0.1>1.0[0.6] MAY 0>1.0[0.3] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0]
DL DSS-JFK APR 0.7>1.0[0.3] MAY 0.7>1.0[0.3] JUN 0.7>1.0[0] JUL 0.7>1.0[0] AUG 0.7>1.0[0.3] SEP 0.7>1.0[0.3]
DL DTW-ESC MAR 1.7>1.0[1.6] APR 1.7>1.0[1.8] MAY 1.7>1.0[1.7] JUN 1.7>1.0[1.7] JUL 1.7>1.0[1.0] AUG 1.7>1.0[1.7] SEP 1.7>1.0[1.7]
**DL ESC-MSP MAR 0>0.6[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0]
DL JFK-KEF APR 0>0.6[0]
DL JFK-ORD FEB 2.0>1.5[1.9]
DL LAX-SJD APR 3>2[1.9]
**DL PVR-SEA APR 0.1>1.0[0.6] MAY 0>1.0[0.3] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0]
**DL SEA-SJD APR 0.1>1.0[1.0] MAY 0>1.0[0.4] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0]
EK ATH-EWR APR 0.7>0[1.0] MAY 0.7>0[0] JUN 0.7>1.0[0]
EK DFW-DXB MAR 0.0>0.4[0.9]
EK DXB-SFO MAR 0.1>0.5[0.9]
EK JFK-MXP APR 0.6>0[1.0] MAY 0.6>0[0] JUN 0.6>1.0[0]
F2 MBA-MDR JUN 0>0.5[0]
F2 MDR-WIL JUN 2>3[0]
GV AKN-KCG FEB 0.4>0[0.3]
GV AKN-KLL FEB 0.7>0[0.7]
GV AKN-PTH FEB 0.4>0[0.3]
GV AKN-UGB FEB 0.4>0[0.3]
GV AKN-WSN FEB 0.4>0[0.3]
GV ANC-ENA FEB 9>4[9] MAR 9>8[9] APR 9>8[11] MAY 9>8[10] JUN 9>8[10] JUL 9>8[10] AUG 9>8[10] SEP 9>8[10]
GV ATT-BET FEB 0.9>0.5[0.8]
GV ATT-KUK FEB 0.9>0.5[0.8]
GV AUK-BET FEB 0>0.5[0]
GV AUK-EMK FEB 1.3>0.9[1.2]
GV AUK-KOT FEB 0>0.5[0] MAR 0.5>0.9[1.7] APR 0>0.9[1.9] MAY 0.5>0.8[1.8] JUN 0>0.9[1.4] JUL 0.5>0.9[1.8] AUG 0.5>0.9[1.9] SEP 0>0.9[1.9]
GV AUK-SXP FEB 1.3>1.9[1.2] APR 1.8>3[4] JUN 1.8>3[3] SEP 1.8>3[4]
GV BET-CYF FEB 0.9>0.5[0.8]
GV BET-EEK FEB 0.9>0.5[0.8]
GV BET-KKH FEB 0.9>0.5[0.8]
GV BET-KOT FEB 0>0.5[0] MAR 0.5>0.9[1.7] APR 0.5>0.9[1.9] MAY 0.5>0.8[1.8] JUN 0.5>0.9[1.2] JUL 0.5>0.9[1.8] AUG 0.5>0.9[1.9] SEP 0.5>0.9[1.9]
GV BET-KPN FEB 0.9>0.5[0.8]
GV BET-KSM FEB 0.7>0[0.7]
GV BET-KWK FEB 1.2>0.5[1.2]
GV BET-KWN FEB 0.9>0.5[0.8]
GV BET-MOU FEB 0.7>0[0.7]
GV BET-NME FEB 0.4>0[0.3]
GV BET-NUP FEB 0.9>0.5[0.8]
GV BET-SCM FEB 1.3>0.9[1.2] MAR 1.3>1.7[1.8] APR 1.3>1.7[2.0] MAY 1.3>1.6[1.9] JUN 1.3>1.7[1.5] JUL 1.3>1.6[1.9] AUG 1.3>1.6[1.9] SEP 1.3>1.7[1.9]
GV BET-VAK FEB 1.3>0.9[1.2] MAR 1.3>1.7[1.8] APR 1.3>1.7[2.0] MAY 1.3>1.6[1.9] JUN 1.3>1.7[1.5] JUL 1.3>1.6[1.9] AUG 1.3>1.6[1.9] SEP 1.3>1.7[1.9]
GV BET-WTL FEB 2>1.0[2]
GV BET-WWT FEB 0.9>0.5[0.8]
GV CYF-KPN FEB 0.9>0.5[0.8]
GV DLG-KEK FEB 0.3>0[0.3] MAR 0.3>0[1.3] APR 0.3>0[1.5] MAY 0.3>0[1.4] JUN 0.3>0[1.1] JUL 0.3>0[1.4] AUG 0.3>0[1.4] SEP 0.3>0[1.4]
GV DLG-KNW FEB 0.3>0[0.3] MAR 0.3>0[1.5] APR 0.3>0[1.6] MAY 0.3>0[1.4] JUN 0.3>0[1.1] JUL 0.3>0[1.4] AUG 0.3>0[1.4] SEP 0.3>0[1.4]
GV DUT-KQA FEB 0>0.9[0] MAR 0>0.9[1.6] APR 0>0.9[1.7] MAY 0>0.8[1.7] JUN 0>0.9[1.7] JUL 0>0.9[1.7] AUG 0>0.8[1.7] SEP 0>0.9[1.7]
GV EEK-KWN FEB 0.9>0.5[0.8]
GV EMK-KOT FEB 1.7>1.0[1.7]
GV EMK-SXP FEB 1.3>1.9[1.2]
GV HPB-SCM FEB 1.3>0.9[1.2] MAR 1.3>1.7[1.8] APR 1.3>1.7[2.0] MAY 1.3>1.6[1.9] JUN 1.3>1.7[1.5] JUL 1.3>1.6[1.9] AUG 1.3>1.6[1.9] SEP 1.3>1.7[1.9]
GV HPB-VAK FEB 1.3>0.9[1.2] MAR 1.3>1.7[1.8] APR 1.3>1.7[2.0] MAY 1.3>1.6[1.9] JUN 1.3>1.7[1.5] JUL 1.3>1.6[1.9] AUG 1.3>1.6[1.9] SEP 1.3>1.7[1.9]
GV KCG-KCL FEB 0.4>0[0.3]
GV KCL-KCQ FEB 0.4>0[0.3]
GV KCQ-KPV FEB 0.4>0[0.3]
GV KEK-KNW FEB 0.3>0[0.3] MAR 0.3>0[1.3] APR 0.3>0[1.5] MAY 0.3>0[1.4] JUN 0.3>0[1.1] JUL 0.3>0[1.4] AUG 0.3>0[1.4] SEP 0.3>0[1.4]
GV KKH-KWK FEB 1.2>0.5[1.2]
GV KKH-WTL FEB 0.4>0[0.3]
GV KPV-PTH FEB 0.4>0[0.3]
GV KSM-MOU FEB 0.7>0[0.7]
GV KUK-NUP FEB 0.9>0.5[0.8]
GV NME-OOK FEB 0.4>0[0.3]
GV OOK-TNK FEB 0.9>0.5[0.8]
GV PIP-UGB FEB 0.4>0[0.3]
GV PIP-WSN FEB 0.4>0[0.3]
GV TNK-WWT FEB 0.4>0[0.3]
J5 HNH-JNU FEB 1.4>0[1.3]
J5 HNS-JNU FEB 0.7>0[0.7]
J5 HNS-SGY FEB 0.7>0[0.7]
J5 JNU-PEC MAR 0.6>0[0.8] APR 0.6>0[0.9] MAY 0.5>0[0.8] JUN 0.6>0[1.7] JUL 0.6>0[0.5] AUG 0.6>0[2] SEP 0.6>0[0]
J5 JNU-SGY FEB 0.7>0[0.7]
J5 JNU-SIT MAR 0.9>1.6[1.9] APR 1.7>3[2] MAY 1.7>3[1.9] JUN 1.7>3[3] JUL 1.7>3[0.4] AUG 1.7>3[2] SEP 1.7>3[2]
K2 AKI-KKI FEB 0.9>0[0.8] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 AKI-TLT FEB 0.9>0[0.8] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 ATT-BET FEB 0.9>0[0.8] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 ATT-NUP FEB 0.9>0[0.8] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 BET-CYF FEB 0.9>0[0.8] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 BET-EEK FEB 0.9>0[0.8] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 BET-GNU FEB 0.9>0[0.8] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 BET-KPN FEB 0.9>0[0.8] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 BET-KUK FEB 0.9>0[0.8] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 BET-KWK FEB 0.4>0[0.4] MAR 0.4>0[0] APR 0.4>0[0.4] MAY 0.4>0[0.4] JUN 0.4>0[0.4] JUL 0.4>0[0.4] AUG 0.4>0[0.4] SEP 0.4>0[0.4]
K2 BET-KWN FEB 0.9>0[0.8] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 BET-KWT FEB 0.9>0[0.8] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 BET-NME FEB 0.9>0[0.8] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 BET-OOK FEB 0.4>0[0.4] MAR 0.4>0[0.4] APR 0.4>0[0.4] MAY 0.4>0[0.4] JUN 0.4>0[0.4] JUL 0.4>0[0.4] AUG 0.4>0[0.4] SEP 0.4>0[0.4]
K2 BET-PKA FEB 0.9>0[0.8] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 BET-PQS MAR 0.4>0[0]
K2 BET-PTU FEB 0.9>0[0.8] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 BET-RSH MAR 0.4>0[0]
K2 BET-TLT FEB 0.9>0[0.8] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 BET-WNA FEB 0.9>0[0.8] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 BET-WTL FEB 0.9>0[0.8] MAR 0.9>0[1.6] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 CYF-KPN FEB 0.9>0[0.8] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 EEK-KWN FEB 0.9>0[0.8] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 GNU-PTU FEB 0.9>0[0.8] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 KKH-KWK FEB 0.4>0[0.4] MAR 0.4>0[0] APR 0.4>0[0.4] MAY 0.4>0[0.4] JUN 0.4>0[0.4] JUL 0.4>0[0.4] AUG 0.4>0[0.4] SEP 0.4>0[0.4]
K2 KKH-WTL FEB 0.9>0[0.8] MAR 0.9>0[0] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 KKI-KWT FEB 0.9>0[0.8] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 KUK-NUP FEB 0.9>0[0.8] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 MLL-PQS MAR 0.4>0[0]
K2 MLL-RSH MAR 0.4>0[0]
K2 NME-WWT FEB 0.9>0[0.8] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 OOK-TNK FEB 0.9>0[0.8] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 PKA-WNA FEB 0.9>0[0.8] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K2 TNK-WWT FEB 0.9>0[0.8] MAR 0.9>0[0.8] APR 0.9>0[0.9] MAY 0.8>0[0.8] JUN 0.9>0[0.9] JUL 0.9>0[0.8] AUG 0.8>0[0.8] SEP 0.9>0[0.9]
K3 CGA-KLW MAR 1.7>0[0] APR 1.7>0[1.5] MAY 1.7>0[1.3] JUN 1.7>0[1.3] JUL 1.7>0[1.3] AUG 1.7>0[1.3] SEP 1.7>0[1.3]
K3 CGA-KTB MAR 1.7>0[0] APR 1.7>0[0.6] MAY 1.7>0[0.5] JUN 1.7>0[0.5] JUL 1.7>0[0.5] AUG 1.7>0[0.5] SEP 1.7>0[0.5]
K3 KLW-KTN MAR 0.9>0[0] APR 0.9>0[0.6] MAY 0.8>0[0.5] JUN 0.9>0[0.5] JUL 0.9>0[0.5] AUG 0.8>0[0.5] SEP 0.9>0[0.5]
K3 KTB-KTN MAR 0.9>0[0.8] APR 0.9>0[1.3] MAY 0.8>0[1.3] JUN 0.9>0[1.3] JUL 0.9>0[1.3] AUG 0.8>0[1.3] SEP 0.9>0[1.3]
K3 KTN-MTM MAR 1.7>0[0] APR 1.7>0[1.7] MAY 1.7>0[1.7] JUN 1.7>0[1.7] JUL 1.7>0[1.7] AUG 1.7>0[1.7] SEP 1.7>0[1.7]
KG AIA-DEN FEB 0>1.3[0] MAR 0>1.3[1.6] APR 0>1.3[1.8] MAY 0>1.3[1.7]
LA LIM-MCO MAR 0.4>0[0.9]
LY BOS-TLV FEB 0.4>0.0[0.4]
LY ORD-TLV FEB 0.4>0.0[0.4]
LY SFO-TLV FEB 0.4>0.0[0.4]
M5 BFI-FRD FEB 0>0.9[0] MAR 0>0.9[1.9] APR 0.5>1.0[1.9]
M5 BFI-PAE MAR 0>0.4[0] APR 0>0.5[0]
M5 ESD-FRD FEB 0>1.0[0]
M5 FRD-PAE MAR 0>0.4[0] APR 0>0.5[0]
NK ACY-FLL FEB 2>1.0[2]
NK ACY-MCO FEB 2>1.0[2]
NK ACY-PBI FEB 0.9>0.6[0.8]
NK ACY-RSW FEB 1.7>1.0[1.6]
NK ACY-TPA FEB 0.9>0.6[0.8]
NK ATL-AUS FEB 0.7>0[0.7] MAR 1.0>0.7[0.9]
NK ATL-BOS FEB 0.7>0[0.7] MAR 1.0>0.7[0.4]
NK ATL-BWI FEB 1.7>1.0[1.6]
NK ATL-EWR FEB 1.7>1.0[1.6]
NK ATL-MCO FEB 1.7>1.0[1.6]
NK ATL-PHL FEB 0.8>0.6[0.8]
NK ATL-TPA FEB 1.6>0.7[1.5]
NK AUS-BNA FEB 0.7>0[0.7] MAR 1.0>0.7[0]
NK AUS-BWI FEB 0.7>0[0.7] MAR 1.0>0.7[0.9]
NK AUS-CUN FEB 0.4>0[0.4]
NK AUS-DEN FEB 0.7>0[0.7] MAR 1.0>0.7[0.9]
NK AUS-DTW FEB 0.7>0[0.7] MAR 1.0>0.7[0.9]
NK AUS-EWR FEB 0.7>0[0.7] MAR 1.0>0.7[0]
NK AUS-MCO FEB 1.4>1.0[1.3]
NK AUS-MSY FEB 0.7>0[0.7] MAR 1.0>0.7[0.9]
NK AUS-ORD FEB 0.7>0[0.7] MAR 1.0>0.7[0.9]
NK BDL-FLL FEB 2>0.8[2] MAR 3>2[1.8]
NK BDL-MCO FEB 2>0.9[2]
NK BDL-RSW FEB 0.7>0[0.7] MAR 1.0>0.7[0.8]
NK BDL-TPA FEB 1.4>0[1.3] MAR 2.0>1.4[1.5]
NK BNA-BWI FEB 0.7>0[0.7] MAR 1.0>0.7[0.9]
NK BNA-CUN FEB 0.3>0[0.3]
NK BNA-EWR FEB 0.7>0[0.7] MAR 1.0>0.7[0]
NK BNA-LAS FEB 0.8>0.4[0.7]
NK BNA-MCO FEB 1.2>0.9[1.2]
NK BNA-MSY FEB 0.7>0[0.7] MAR 1.0>0.7[0.9]
NK BNA-TPA FEB 0.7>0[0.7] MAR 1.0>0.7[0.9]
NK BOG-MCO FEB 0.9>0.6[0.8]
NK BOS-BWI FEB 3>0[3] MAR 4>3[0]
NK BOS-EWR FEB 1.4>0[1.3] MAR 2>1.4[0]
NK BOS-LAS FEB 0.7>0[0.7] MAR 1.0>0.7[1.0]
NK BOS-MSY FEB 0.7>0[0.7] MAR 1.0>0.7[0.8]
NK BOS-PBI FEB 0.7>0[0.7] MAR 1.0>0.7[0.9]
NK BOS-RSW FEB 1.6>0.7[1.5]
NK BOS-SJU FEB 0.7>0[0.7]
NK BOS-TPA FEB 0.9>0.6[0.8]
NK BQN-FLL FEB 0.7>0[0.7]
NK BQN-MCO FEB 1.0>0[1.0]
NK BUR-LAS FEB 1.5>0.6[1.5] MAR 2>1.6[1.9]
NK BWI-CLT FEB 0.7>0[0.7] MAR 1.0>0.7[0.9]
NK BWI-DEN FEB 0.7>0[0.7] MAR 1.0>0.7[0.8]
NK BWI-DFW FEB 0.7>0[0.7] MAR 1.0>0.7[1.0]
NK BWI-DTW FEB 0.7>0[0.7] MAR 1.0>0.7[0.9]
NK BWI-FLL FEB 4>3[3]
NK BWI-IAH FEB 0.9>0.6[0.8]
NK BWI-LAS FEB 0.9>0.6[0.8]
NK BWI-LAX FEB 0.9>0.6[0.8]
NK BWI-MBJ FEB 0.7>0[0.7] MAR 1.0>0.7[0.8]
NK BWI-MCO FEB 4>3[3]
NK BWI-MSP FEB 0.7>0[0.7] MAR 1.0>0.7[0.5]
NK BWI-MSY FEB 0.7>0[0.7] MAR 1.0>0.7[0.9]
NK BWI-ORD FEB 0.7>0[0.7] MAR 1.0>0.7[0.5]
NK BWI-RDU FEB 0.7>0[0.7] MAR 1.0>0.7[0.5]
NK BWI-RSW FEB 0.7>0[0.7] MAR 1.0>0.7[0.9]
NK BWI-SAL FEB 0.7>0[0.7] MAR 1.0>0.7[0]
NK BWI-SJU FEB 1.6>0.7[1.5]
NK BWI-TPA FEB 1.5>0.6[1.5] MAR 2>1.6[1.0]
NK CAK-MCO FEB 0.8>0.3[0.7] MAR 1.0>0.8[0.8]
NK CAK-RSW FEB 0.3>0[0.3]
NK CAK-TPA FEB 0.4>0[0.4]
NK CLE-CUN FEB 0.4>0.1[0.4]
NK CLE-EWR FEB 0.7>0[0.7] MAR 1.0>0.7[0]
NK CLE-FLL FEB 3>1.6[2]
NK CLE-LAS FEB 1.7>1.0[1.6]
NK CLE-MCO FEB 2>1.0[2]
NK CLE-MSY FEB 0.3>0[0.3]
NK CLT-EWR FEB 0.7>0[0.7] MAR 1.0>0.7[0.9]
NK CLT-FLL FEB 0.9>0.6[0.8]
NK CMH-FLL FEB 1.7>1.0[1.6]
NK CMH-LAS FEB 0.8>0.3[0.7] MAR 1.0>0.8[0.9]
NK CMH-MCO FEB 1.6>0.7[1.5]
NK CMH-RSW FEB 0.9>0.6[0.8]
NK CMH-TPA FEB 1.4>0[1.3] MAR 2>1.4[0.8]
NK CTG-FLL FEB 0.6>0.9[0.6]
NK CUN-DFW FEB 1.2>1.6[1.1]
NK CUN-FLL FEB 1.2>1.6[1.1]
NK CUN-IAH FEB 0.8>1.7[0.8] MAR 0.5>0.8[0.4]
NK CUN-MSY FEB 0.4>0[0.4]
NK CUN-PHL FEB 0.7>0[0.7] MAR 1.0>0.7[0]
NK CUN-PIT FEB 0.3>0[0.3]
NK DEN-DTW FEB 0.7>0[0.7] MAR 1.0>0.7[0.8]
NK DEN-LAS FEB 1.6>0.7[1.5]
NK DEN-MCO FEB 0.7>0[0.7] MAR 1.0>0.7[0.9]
NK DEN-MSP FEB 0.7>0[0.7] MAR 1.0>0.7[0]
NK DEN-ORD FEB 0.7>0[0.7] MAR 1.0>0.7[0.9]
NK DFW-DTW FEB 0.9>0.6[0.8]
NK DFW-LAS FEB 3>4[3]
NK DFW-LGA FEB 0.7>0[0.7] MAR 1.0>0.7[0.9]
NK DFW-ORD FEB 0.7>0.4[0.7]
NK DFW-PHL FEB 0.7>0[0.7] MAR 1.0>0.7[1.0]
NK DTW-LGA FEB 1.6>0.7[1.5]
NK DTW-MBJ FEB 0.3>0[0.3]
NK DTW-MCI FEB 0.7>0[0.7] MAR 1.0>0.7[0.5]
NK DTW-MSP FEB 0.7>0[0.7] MAR 1.0>0.7[0.5]
NK DTW-MSY FEB 0.9>0.6[0.8]
NK DTW-MYR FEB 0.2>0.4[0.2]
NK DTW-PBI FEB 0.4>0[0.4]
NK DTW-RSW FEB 3>2.0[3]
NK DTW-TPA FEB 3>2[3]
NK EWR-LAS FEB 1.6>0.7[1.5]
NK EWR-MCO FEB 3>2[3]
NK EWR-MSY FEB 0.7>0[0.7] MAR 1.0>0.7[0.9]
NK EWR-MYR FEB 2>0.9[2]
NK EWR-PBI FEB 1.7>0.3[1.6] MAR 2>1.4[0]
NK EWR-RSW FEB 1.4>0[1.3] MAR 2>1.4[0.9]
NK EWR-SJU FEB 1.4>0[1.3] MAR 2.0>1.4[1.9]
NK EWR-TPA FEB 0.7>0[0.7] MAR 1.0>0.7[0.9]
NK FLL-GUA FEB 1.4>1.0[1.3]
NK FLL-KIN FEB 0.8>0.3[0.8]
NK FLL-LAS FEB 1.0>1.4[1.0]
NK FLL-LBE FEB 0.7>0[0.7] MAR 1.0>0.7[0.8]
NK FLL-MBJ FEB 0.8>0.3[0.7] MAR 1.0>0.8[0.7]
NK FLL-MYR FEB 1.6>0.7[1.5]
NK FLL-ORD FEB 3>2[3]
NK FLL-PHL FEB 3>2[3]
NK FLL-PIT FEB 2>1.0[2]
NK FLL-PTY FEB 0.9>0.6[0.8]
NK FLL-PUJ FEB 0.9>0.6[0.8]
NK FLL-RDU FEB 1.6>0.9[1.5]
NK FLL-SJU FEB 3.4>2.6[3.2]
NK FLL-STI FEB 0.7>1.0[0.7]
NK FLL-TPA FEB 1.7>1.0[1.6]
NK GUA-MCO FEB 0.8>0.4[0.7]
NK IAH-LAX FEB 3>1.7[2]
NK IAH-MCO FEB 3>1.9[2]
NK IAH-MSY FEB 0.7>0.4[0.7]
NK IAH-ORD FEB 1.6>0.9[1.5]
NK IAH-SAN FEB 0.7>0[0.7] MAR 1.0>0.7[0.9]
NK IND-RSW FEB 0.8>0.5[0.7]
NK IND-TPA FEB 1.5>0.3[1.4] MAR 2>1.5[0.9]
NK LAS-LAX FEB 2>1.0[2]
NK LAS-MSP FEB 1.4>0.3[1.4] MAR 2>1.5[1.7]
NK LAS-OAK FEB 3>1.7[3]
NK LAS-ORD FEB 3>2.0[3]
NK LAS-PDX FEB 1.7>1.0[1.6]
NK LAS-PHL FEB 0.9>0.5[0.8]
NK LAS-PIT FEB 0.9>0.6[0.8]
NK LAS-SAN FEB 2>1.0[2]
NK LAS-SEA FEB 2>1.0[2]
NK LAS-SMF FEB 3>1.3[3]
NK LAX-MSP FEB 0.7>0[0.7] MAR 1.0>0.7[0.8]
NK LAX-MSY FEB 0.9>1.3[0.9]
NK LAX-OAK FEB 1.6>0.7[1.5]
NK LAX-PHL FEB 0.8>0.3[0.7]
NK LAX-PIT FEB 0.8>0.3[0.7]
NK LBE-RSW FEB 0.4>0[0.4]
NK LBE-TPA FEB 0.3>0[0.3]
NK LGA-MCO FEB 1.6>0.7[1.5] MAR 2>1.6[0.9]
NK MBJ-MCO FEB 0.3>0[0.3]
NK MCI-MCO FEB 1.1>0.9[1.1]
NK MCO-MSY FEB 3>1.9[2]
NK MCO-MYR FEB 0.2>0[0.2]
NK MCO-ORD FEB 1.7>1.0[1.6]
NK MCO-PHL FEB 4>3[4]
NK MCO-PIT FEB 3>1.0[3] MAR 4>3[1.9]
NK MCO-RDU FEB 1.5>0.9[1.5]
NK MCO-SJO FEB 0.8>0.5[0.8]
NK MSP-MSY FEB 0.4>0[0.4]
NK MSP-PHX FEB 0.8>0.4[0.7]
NK MSP-RSW FEB 0.7>0[0.7] MAR 1.0>0.7[0.9]
NK MSP-TPA FEB 0.7>0[0.7] MAR 1.0>0.7[0.9]
NK MSY-ORD FEB 0.8>0.4[0.7]
NK MSY-RDU FEB 0.7>0[0.7] MAR 1.0>0.7[0.9]
NK MSY-SAP FEB 0.3>0[0.3]
NK MYR-PHL FEB 0>0.2[0]
NK MYR-PIT MAR 0.4>0.6[0]
NK OAK-SNA FEB 1.7>1.0[1.6]
NK ORD-PHX FEB 0.7>0.4[0.7]
NK ORD-RSW FEB 1.7>1.0[1.6]
NK ORD-SAN FEB 0.7>0[0.7] MAR 1.0>0.7[0.8]
NK PHL-RSW FEB 0.7>0[0.7] MAR 1.0>0.7[0.5]
NK PHL-SJU FEB 1.7>1.0[1.6]
NK PHL-TPA FEB 1.4>0[1.3] MAR 2>1.4[0.5]
NK PHX-SEA FEB 0.7>0[0.7] MAR 1.0>0.7[0.9]
NK PIT-TPA FEB 0.9>0.6[0.8]
PY GEO-MIA FEB 0.6>0[0.6] MAR 0.5>0.1[0.5]
**SS JFK-ORY APR 0.8>0[0] MAY 1.0>0[0] JUN 1.0>0[0] JUL 1.0>0[0.6] AUG 1.0>0[0] SEP 1.0>0[0]
SY BNA-MSP FEB 0.3>0[0.2]
SY CUN-MSP FEB 2>1.5[1.9]
SY MBJ-MSP FEB 0.9>0.4[0.8]
SY MIA-MSP FEB 1.4>1.1[1.3]
SY MSP-PUJ FEB 0.7>0.5[0.7]
SY MSP-PVR FEB 1.1>0.7[1.1]
SY MSP-SAN FEB 0.6>0.3[0.6]
SY MSP-SJD FEB 0.8>0.5[0.8]
TK EWR-IST APR 1.0>0[0] MAY 1.0>0.3[0]
TP IAD-LIS APR 1.0>1.6[0.7] MAY 1.0>1.6[0.0] JUN 1.0>1.6[0.3] JUL 1.0>1.5[0.8] AUG 1.0>1.6[0.3] SEP 1.0>1.6[0.4]
UA ABE-ORD FEB 3>0[3]
UA ABI-IAH FEB 2>1.0[1.9]
UA ABQ-DEN FEB 5>1.7[5]
UA ABQ-IAH FEB 5>1.9[5]
UA ABQ-ORD FEB 1.0>0[1.0]
UA ABQ-SFO FEB 1.9>0.5[1.8]
UA ACV-DEN FEB 1.0>0[1.0]
UA ACV-LAX FEB 2>0.8[1.9]
UA ACV-SFO FEB 3>1.7[3]
UA AEX-IAH FEB 3>1.5[3]
UA AGU-IAH FEB 2.0>1.0[1.9]
UA ALB-EWR FEB 3>1.0[3]
UA ALB-IAD FEB 3>1.4[3]
UA ALB-ORD FEB 4>1.1[4]
UA AMA-DEN FEB 2>0.7[1.9]
UA AMS-EWR FEB 1.0>0.6[1.0]
UA AMS-IAH FEB 1.0>0[1.0]
UA ASE-DEN FEB 8>5[7]
UA ASE-LAX FEB 3>1.8[3]
UA ASE-ORD FEB 4>2[4]
UA ASE-SFO FEB 1.9>0.9[1.9]
UA ATL-DEN FEB 4>2[4]
UA ATL-EWR FEB 8>2[8]
UA ATL-IAD FEB 4>1.2[4]
UA ATL-IAH FEB 7>3[7]
UA ATL-ORD FEB 8>3[8]
UA ATL-SFO FEB 1.9>0[1.9]
UA ATW-DEN FEB 1.0>0[1.0]
UA ATW-ORD FEB 10>4[10] MAR 10>9[5]
UA ATY-ORD FEB 1.0>0.7[1.0]
UA AUA-IAD FEB 1.0>0.3[1.0]
UA AUA-ORD FEB 0.9>0.1[0.8]
UA AUS-DEN FEB 5>3[5]
UA AUS-EWR FEB 5>1.3[5]
UA AUS-IAD FEB 3>0.7[3]
UA AUS-IAH FEB 9>4[9]
UA AUS-LAX FEB 2>0.6[1.9]
UA AUS-ORD FEB 5>1.3[5]
UA AUS-SFO FEB 4>1.7[4]
UA AVL-EWR FEB 1.0>0[1.0]
UA AVL-IAD FEB 3>1.7[3]
UA AVL-ORD FEB 4>1.0[4]
UA AVP-IAD FEB 3>1.7[3]
UA AVP-ORD FEB 1.8>1.0[1.8]
UA AZO-ORD FEB 3>1.0[3]
UA BDL-DEN FEB 2>1.0[1.9]
UA BDL-IAD FEB 4>1.6[4]
UA BDL-IAH FEB 2>0[1.9]
UA BDL-ORD FEB 4>1.8[4]
UA BFL-DEN FEB 1.9>1.0[1.8]
UA BFL-SFO FEB 1.0>0.7[0.9]
UA BGR-EWR FEB 2>0[1.9]
UA BHM-IAH FEB 5>3[4]
UA BHM-ORD FEB 4>0.9[3]
UA BIL-DEN FEB 5>2[5]
UA BIS-DEN FEB 4>1.7[4]
UA BIS-ORD FEB 2>0[1.9]
UA BJX-IAH FEB 4>3[4]
UA BNA-DEN FEB 5>3[5]
UA BNA-EWR FEB 6>1.2[6]
UA BNA-IAD FEB 3>1.2[3]
UA BNA-IAH FEB 6>4[6]
UA BNA-ORD FEB 7>3[7]
UA BNA-SFO FEB 1.9>0[1.8]
UA BOG-IAH FEB 2>1.0[1.9]
UA BOI-DEN FEB 6>3[6]
UA BOI-IAH FEB 2>1.0[1.9]
UA BOI-LAX FEB 2>1.0[1.9]
UA BOI-ORD FEB 3>1.9[3]
UA BOI-SFO FEB 6>2[6]
UA BOS-DEN FEB 4>3[4]
UA BOS-EWR FEB 12>2[11] MAR 12>11[8]
UA BOS-IAD FEB 5>1.5[4]
UA BOS-IAH FEB 5>1.8[5]
UA BOS-LAX FEB 2>0[1.9]
UA BOS-ORD FEB 8>3[8]
UA BOS-SFO FEB 7>0[6]
UA BRO-IAH FEB 4>2[4]
UA BRU-ORD FEB 0.4>0[0.4]
UA BTR-IAH FEB 7>3[7]
UA BTV-EWR FEB 3>0.7[3]
UA BTV-IAD FEB 4>1.7[4]
UA BTV-ORD FEB 4>1.4[4]
UA BUF-EWR FEB 5>1.1[5]
UA BUF-IAD FEB 4>1.3[4]
UA BUF-ORD FEB 4>1.0[4]
UA BUR-DEN FEB 3>1.0[3]
UA BUR-SFO FEB 5>0[5]
UA BWI-DEN FEB 2>1.0[1.9]
UA BWI-LAX FEB 1.0>0[1.0]
UA BWI-ORD FEB 4>2[4]
UA BWI-SFO FEB 1.9>0[1.8]
UA BZE-IAH FEB 2>1.0[1.9]
UA BZE-ORD FEB 0.4>0.1[0.4]
UA CAE-IAD FEB 3>1.6[3]
UA CAE-IAH FEB 1.0>0[1.0]
UA CAE-ORD FEB 3>0.9[3]
UA CAK-IAD FEB 3>1.0[3]
UA CAK-IAH FEB 1.0>0[1.0]
UA CAK-ORD FEB 4>1.6[4]
UA CDG-EWR FEB 1.0>0.4[1.0]
UA CHA-ORD FEB 4>1.0[4]
UA CHO-IAD FEB 3>1.7[3]
UA CHO-ORD FEB 3>0[3]
UA CHS-EWR FEB 5>1.0[5]
UA CHS-IAD FEB 4>1.4[4]
UA CHS-IAH FEB 3>1.6[3]
UA CHS-ORD FEB 3>1.3[3]
UA CID-DEN FEB 4>2[4]
UA CID-ORD FEB 7>2[7]
UA CLE-DEN FEB 3>2.0[3]
UA CLE-EWR FEB 8>2[7]
UA CLE-IAD FEB 4>1.6[4]
UA CLE-IAH FEB 5>1.9[5]
UA CLE-LAX FEB 2>0[1.9]
UA CLE-ORD FEB 9>3[9] MAR 9>8[7]
UA CLE-SFO FEB 1.4>0[1.3]
UA CLL-IAH FEB 3>1.5[3]
UA CLT-EWR FEB 6>3[6]
UA CLT-IAD FEB 4>1.2[4]
UA CLT-IAH FEB 4>1.8[4]
UA CLT-ORD FEB 5>2.0[4]
UA CMH-EWR FEB 8>1.5[8] MAR 8>7[6]
UA CMH-IAD FEB 4>0.8[4]
UA CMH-IAH FEB 4>1.9[4]
UA CMH-ORD FEB 8>3[8]
UA CMH-SFO FEB 1.0>0[1.0]
UA CNY-DEN FEB 1.7>1.0[1.7]
UA COD-DEN FEB 2>0.9[1.9]
UA COS-DEN FEB 10>5[9]
UA COS-IAH FEB 4>1.6[4]
UA COS-LAX FEB 2>0.5[1.9]
UA COS-ORD FEB 3>1.7[3]
UA COU-DEN FEB 1.0>0[1.0]
UA COU-ORD FEB 3>0.9[3]
UA CPR-DEN FEB 7>3[6]
UA CRP-IAH FEB 7>4[6]
UA CRW-ORD FEB 3>1.3[3]
UA CTU-SFO FEB 0.4>0[0.4]
UA CUN-DEN FEB 3>2.0[3]
UA CUN-EWR FEB 4>3[4]
UA CUN-IAH FEB 5>4[5]
UA CUN-ORD FEB 2>3[2]
UA CVG-EWR FEB 5>1.3[5]
UA CVG-IAD FEB 4>1.4[4]
UA CVG-IAH FEB 4>2[4]
UA CVG-ORD FEB 7>3[7]
UA CWA-ORD FEB 3>1.0[3]
UA DAY-DEN FEB 1.9>0[1.8]
UA DAY-IAD FEB 3>1.6[3]
UA DAY-ORD FEB 7>4[6]
UA DCA-EWR FEB 13>1.4[12] MAR 12>11[7]
UA DCA-IAH FEB 7>3[7]
UA DCA-ORD FEB 13>3[13] MAR 13>12[13]
UA DCA-SFO FEB 1.0>0[1.0]
UA DEN-DFW FEB 6>3[6]
UA DEN-DIK FEB 1.9>0.8[1.8]
UA DEN-DRO FEB 8>4[8]
UA DEN-DSM FEB 6>3[6]
UA DEN-EAR FEB 1.9>1.0[1.8]
UA DEN-ELP FEB 5>1.9[5]
UA DEN-EWR FEB 7>5[7]
UA DEN-FAR FEB 4>2[4]
UA DEN-FAT FEB 5>3[5]
UA DEN-FLG FEB 2>1.0[1.9]
UA DEN-FLL FEB 2>1.9[2]
UA DEN-FRA FEB 1.0>0.4[1.0]
UA DEN-FSD FEB 5>2.0[5]
UA DEN-GCC FEB 2>1.0[1.9]
UA DEN-GEG FEB 3>2[3]
UA DEN-GJT FEB 7>3[7]
UA DEN-GSP FEB 1.0>0[1.0]
UA DEN-HLN FEB 2>1.0[1.9]
UA DEN-HOB FEB 0.6>0[0.6]
UA DEN-HSV FEB 2>1.0[1.9]
UA DEN-IAD FEB 7>4[6]
UA DEN-IAH FEB 11>7[10]
UA DEN-ICT FEB 5>3[5]
UA DEN-IDA FEB 4>3[4]
UA DEN-IND FEB 3>2[3]
UA DEN-KOA FEB 1.0>0.4[1.0]
UA DEN-LAS FEB 6>3[6]
UA DEN-LAX FEB 8>5[8]
UA DEN-LBB FEB 2>1.0[1.9]
UA DEN-LGA FEB 7>3[7]
UA DEN-LHR FEB 1.0>0[1.0]
UA DEN-LIH FEB 1.0>0.1[1.0]
UA DEN-LIT FEB 3>1.9[3]
UA DEN-LNK FEB 4>0.9[4]
UA DEN-MAF FEB 4>1.7[4]
UA DEN-MCI FEB 6>3[6]
UA DEN-MCO FEB 4>3[4]
UA DEN-MEM FEB 3>1.9[3]
UA DEN-MLI FEB 1.9>1.3[1.8]
UA DEN-MOT FEB 3>2[3]
UA DEN-MRY FEB 2>0.6[1.9]
UA DEN-MSN FEB 4>1.8[4]
UA DEN-MSP FEB 4>2[4]
UA DEN-MSY FEB 3>2.0[3]
UA DEN-MTJ FEB 5>4[4]
UA DEN-NRT FEB 1.0>0[1.0]
UA DEN-OKC FEB 6>3[6]
UA DEN-OMA FEB 6>3[6]
UA DEN-ONT FEB 3>1.0[3]
UA DEN-ORD FEB 10>6[10]
UA DEN-PAE FEB 3>0.9[3]
UA DEN-PDX FEB 5>3[5]
UA DEN-PHL FEB 3>2[3]
UA DEN-PHX FEB 5>3[5]
UA DEN-PIT FEB 3>1.7[3]
UA DEN-PSC FEB 3>2[3]
UA DEN-PSP FEB 4>2[4]
UA DEN-RAP FEB 7>3[7]
UA DEN-RDM FEB 3>2.0[3]
UA DEN-RIC FEB 2>1.0[1.9]
UA DEN-RIW FEB 1.6>1.0[1.5]
UA DEN-RKS FEB 2>0.9[1.9]
UA DEN-RNO FEB 4>3[4]
UA DEN-SAF FEB 4>1.0[4]
UA DEN-SAN FEB 5>3[5]
UA DEN-SAT FEB 4>3[4]
UA DEN-SBA FEB 4>2.0[4]
UA DEN-SBP FEB 3>1.9[3]
UA DEN-SDF FEB 1.9>1.0[1.8]
UA DEN-SEA FEB 6>3[6]
UA DEN-SFO FEB 9>5[8]
UA DEN-SGF FEB 4>3[4]
UA DEN-SGU FEB 3>2[3]
UA DEN-SHR FEB 1.9>1.0[1.8]
UA DEN-SHV FEB 1.0>0[1.0]
UA DEN-SJC FEB 5>2.0[5]
UA DEN-SLC FEB 7>4[6]
UA DEN-SMF FEB 5>3[5]
UA DEN-SNA FEB 4>1.9[4]
UA DEN-STL FEB 6>3[6]
UA DEN-SYR FEB 1.0>0[1.0]
UA DEN-TPA FEB 3>1.9[3]
UA DEN-TUL FEB 4>3[4]
UA DEN-TUS FEB 5>3[5]
UA DEN-TYS FEB 2>0.9[1.9]
UA DEN-XNA FEB 4>0.8[4]
UA DEN-XWA FEB 4>2.0[4]
UA DEN-YVR FEB 2>0.6[1.9]
UA DEN-YYC FEB 3>1.9[3]
UA DFW-EWR FEB 7>1.4[7]
UA DFW-IAD FEB 3>0.8[3]
UA DFW-IAH FEB 8>5[7]
UA DFW-ORD FEB 8>2[7]
UA DFW-SFO FEB 4>0.8[4]
UA DLH-ORD FEB 3>1.0[3]
UA DSM-IAH FEB 3>1.5[3]
UA DSM-ORD FEB 6>3[5]
UA DTW-EWR FEB 7>1.9[6]
UA DTW-IAD FEB 4>1.3[4]
UA DTW-IAH FEB 5>2[5]
UA DTW-ORD FEB 8>3[7]
UA DTW-SFO FEB 1.0>0[1.0]
UA DUB-EWR FEB 1.0>0.6[1.0]
**UA ECP-IAD MAR 0>0.8[0] APR 0>1.0[0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0]
UA ELP-IAH FEB 5>3[4]
UA ELP-ORD FEB 1.0>0[1.0]
UA ERI-ORD FEB 3>0[3]
UA EUG-LAX FEB 1.9>0.7[1.9]
UA EUG-ORD FEB 1.0>0[0.9]
UA EUG-SFO FEB 4>1.7[4]
UA EVV-ORD FEB 3>0.9[3]
UA EWR-FLL FEB 8>3[7]
UA EWR-GRR FEB 4>0[4]
UA EWR-GSO FEB 3>0[3]
UA EWR-GSP FEB 3>0[3]
UA EWR-HND FEB 1.0>0[1.0]
UA EWR-HNL FEB 1.0>0[1.0]
UA EWR-IAD FEB 7>2[7]
UA EWR-IAH FEB 9>5[8]
UA EWR-IND FEB 7>1.6[7] MAR 7>6[6]
UA EWR-JAX FEB 4>1.5[4]
UA EWR-LAS FEB 6>1.9[6]
UA EWR-LAX FEB 12>4[12]
UA EWR-LHR FEB 3>1.0[3]
UA EWR-LIR FEB 1.0>0.4[1.0]
UA EWR-MBJ FEB 2>1.1[1.9]
UA EWR-MCI FEB 4>0.9[4]
UA EWR-MCO FEB 10>4[10]
UA EWR-MEM FEB 3>0[3]
UA EWR-MEX FEB 3>1.8[3]
UA EWR-MIA FEB 6>3[5]
UA EWR-MKE FEB 5>0[5]
UA EWR-MSN FEB 2>0[1.9]
UA EWR-MSP FEB 6>0.8[6]
UA EWR-MSY FEB 5>1.0[5]
UA EWR-MUC FEB 0.4>0[0.4]
UA EWR-NAS FEB 2>0.8[1.9]
UA EWR-NRT FEB 1.0>0.6[1.0]
UA EWR-OKC FEB 1.0>0[1.0]
UA EWR-OMA FEB 1.9>0[1.8]
UA EWR-ORD FEB 12>3[11] MAR 11>10[9]
UA EWR-ORF FEB 6>2[6]
UA EWR-PBI FEB 7>3[7]
UA EWR-PDX FEB 2>0[1.9]
UA EWR-PEK FEB 1.0>0[1.0]
UA EWR-PHX FEB 4>1.7[4]
UA EWR-PIT FEB 10>2[9] MAR 10>9[8]
UA EWR-PQI FEB 1.0>0.2[1.0]
UA EWR-PTY FEB 1.4>0.9[1.3]
UA EWR-PUJ FEB 2>1.6[1.9]
UA EWR-PVD FEB 5>1.0[5]
UA EWR-PVG FEB 1.0>0[1.0]
UA EWR-PVR FEB 0.4>0.1[0.4]
UA EWR-PWM FEB 7>1.4[7] MAR 7>6[4]
UA EWR-RDU FEB 8>2[8]
UA EWR-RIC FEB 7>1.2[6]
UA EWR-ROC FEB 4>1.4[4]
UA EWR-RSW FEB 5>2[5]
UA EWR-SAN FEB 4>1.5[4]
UA EWR-SAP FEB 1.0>0.4[1.0]
UA EWR-SAT FEB 1.9>0[1.8]
UA EWR-SAV FEB 5>1.3[5]
UA EWR-SDF FEB 2>0[2]
UA EWR-SEA FEB 3>0.3[3]
UA EWR-SFO FEB 15>4[14] MAR 14>13[10]
UA EWR-SJD FEB 0.6>0.4[0.6]
UA EWR-SJO FEB 2>1.0[1.9]
UA EWR-SJU FEB 4.0>1.7[3.8]
UA EWR-SMF FEB 1.0>0[1.0]
UA EWR-SNA FEB 3>0[2]
UA EWR-SRQ FEB 3>1.4[3]
UA EWR-STL FEB 5>1.2[5]
UA EWR-SXM FEB 1.0>0.8[1.0]
UA EWR-SYR FEB 2>0.7[2]
UA EWR-TLV FEB 2>1.0[1.9]
UA EWR-TPA FEB 5>3[5]
UA EWR-TYS FEB 0.8>0[0.8]
UA EWR-XNA FEB 0.7>0[0.7]
UA EYW-IAD FEB 1.0>0.7[0.9]
UA EYW-IAH APR 0>1.0[0]
UA EZE-IAH FEB 1.0>0.4[1.0]
UA FAR-ORD FEB 4>0.9[4]
UA FAT-LAX FEB 4>1.2[4]
UA FAT-ORD FEB 1.0>0[0.9]
UA FAT-SFO FEB 3>1.3[3]
UA FLL-IAH FEB 5>3[5]
UA FLL-ORD FEB 4>3[4]
UA FLL-SFO FEB 0.6>0[0.6]
UA FNT-ORD FEB 3>1.3[3]
**UA FOD-ORD MAR 0>1.7[0] APR 0>1.7[0] MAY 0>1.7[0] JUN 0>1.7[0] JUL 0>1.7[0] AUG 0>1.7[0] SEP 0>1.7[0]
UA FSD-ORD FEB 5>1.7[5]
UA FWA-ORD FEB 3>1.0[3]
UA GDL-IAH FEB 4>3[4]
UA GEG-ORD FEB 1.0>0[0.9]
UA GEG-SFO FEB 3>0.8[3]
UA GIG-IAH FEB 1.0>0.6[1.0]
UA GPT-IAH FEB 4>1.8[4]
UA GRB-ORD FEB 5>3[5]
UA GRK-IAH FEB 3>1.5[3]
UA GRR-IAD FEB 1.0>0[1.0]
UA GRR-IAH FEB 1.0>0[1.0]
UA GRR-ORD FEB 7>3[7]
UA GSO-IAD FEB 3>1.5[3]
UA GSO-ORD FEB 4>0[4]
UA GSP-IAD FEB 4>1.3[4]
UA GSP-ORD FEB 3>1.5[3]
UA HKG-SFO FEB 1.0>0[1.0]
UA HND-LAX FEB 1.0>0[1.0]
UA HND-ORD FEB 1.0>0[1.0]
UA HND-SFO FEB 1.0>0[1.0]
UA HNL-IAH FEB 1.0>0.7[1.0]
UA HNL-LAX FEB 4>2[3]
UA HNL-MAJ FEB 0.6>0[0.6]
UA HNL-NRT FEB 1.0>0[1.0]
UA HNL-ORD FEB 1.0>0.7[1.0]
UA HNL-SFO FEB 4>3[4]
UA HOB-IAH FEB 1.9>0.6[1.8]
UA HPN-ORD FEB 3>0[2]
UA HRL-IAH FEB 5>3[4]
UA HSV-IAD FEB 3>1.5[3]
UA HSV-IAH FEB 4>1.6[4]
UA HSV-ORD FEB 3>0[3]
UA IAD-IAH FEB 5>4[5]
UA IAD-ILM FEB 3>1.7[3]
UA IAD-IND FEB 4>1.2[4]
UA IAD-JAX FEB 3>1.5[3]
UA IAD-LAS FEB 3>1.3[3]
UA IAD-LAX FEB 7>3[7]
UA IAD-LEX FEB 2>0[1.9]
UA IAD-LGA FEB 4>1.6[4]
UA IAD-LHR FEB 1.0>0.6[1.0]
UA IAD-MBJ FEB 1.0>0.5[1.0]
UA IAD-MCI FEB 3>0.8[3]
UA IAD-MCO FEB 4>1.4[4]
UA IAD-MDT FEB 4>1.4[4]
UA IAD-MIA FEB 2>1.5[1.9]
UA IAD-MSN FEB 2>0[1.9]
UA IAD-MSP FEB 2.0>0.6[1.9]
UA IAD-MSY FEB 3>1.2[3]
UA IAD-MUC FEB 1.0>0.4[1.0]
UA IAD-NAS FEB 1.0>0.3[1.0]
UA IAD-OGS FEB 1.0>0.7[1.0]
UA IAD-OKC FEB 2>0[1.9]
UA IAD-ORD FEB 5>3[5]
UA IAD-ORF FEB 4>1.6[4]
UA IAD-PBI FEB 1.0>1.7[1.0]
UA IAD-PDX FEB 1.0>0[1.0]
UA IAD-PHL FEB 4>1.3[4]
UA IAD-PIT FEB 4>1.3[4]
UA IAD-PLS FEB 1.0>0.5[1.0]
**UA IAD-PNS MAR 0.8>1.8[0] APR 0>2[0] MAY 0>2[0] JUN 0>2[0] JUL 0>2[0] AUG 0>2[0] SEP 0>2.0[0]
UA IAD-PUJ FEB 1.0>0.7[1.0]
UA IAD-PVD FEB 4>1.4[4]
UA IAD-PWM FEB 4>1.6[4]
UA IAD-RDU FEB 4>1.4[4]
UA IAD-RIC FEB 4>1.1[4]
UA IAD-ROA FEB 4>1.3[4]
UA IAD-ROC FEB 4>1.5[4]
UA IAD-SAN FEB 3>1.3[3]
UA IAD-SAT FEB 3>0.8[3]
UA IAD-SAV FEB 3>1.3[3]
UA IAD-SCE FEB 3>1.7[3]
UA IAD-SDF FEB 3>1.6[3]
UA IAD-SDQ FEB 1.0>0.6[1.0]
UA IAD-SEA FEB 3>0.9[3]
UA IAD-SFO FEB 7>3[7]
UA IAD-SHD FEB 2>0.7[1.9]
UA IAD-SJU FEB 1.9>0.6[1.9]
UA IAD-SMF FEB 1.0>0[1.0]
UA IAD-STL FEB 3>0.7[3]
UA IAD-SYR FEB 4>1.1[4]
UA IAD-TPA FEB 3>1.6[3]
UA IAD-TYS FEB 3>1.3[3]
UA IAD-YUL FEB 1.0>0.7[1.0]
UA IAD-ZRH FEB 1.0>0[1.0]
UA IAH-ICT FEB 4>3[3]
UA IAH-IND FEB 5>3[5]
UA IAH-JAN FEB 5>3[5]
UA IAH-LAS FEB 7>4[7]
UA IAH-LAX FEB 9>5[9]
UA IAH-LCH FEB 4>1.9[4]
UA IAH-LEX FEB 1.0>0[1.0]
UA IAH-LFT FEB 6>4[6]
UA IAH-LGA FEB 7>3[7]
UA IAH-LHR FEB 1.0>0[1.0]
UA IAH-LIM FEB 1.0>0.7[1.0]
UA IAH-LIR FEB 2>1.0[2]
UA IAH-LIT FEB 6>3[6]
UA IAH-LRD FEB 3>1.6[3]
UA IAH-MAF FEB 7>4[6]
UA IAH-MCI FEB 5>4[5]
UA IAH-MCO FEB 6>5[6]
UA IAH-MEM FEB 6>3[6]
UA IAH-MEX FEB 6>4[5]
UA IAH-MFE FEB 7>4[6]
UA IAH-MGA FEB 0.6>0[0.6]
UA IAH-MID FEB 1.0>0.6[1.0]
UA IAH-MKE FEB 1.9>1.0[1.8]
UA IAH-MLM FEB 1.0>0.4[1.0]
UA IAH-MLU FEB 1.9>0.9[1.8]
UA IAH-MOB FEB 4>3[4]
UA IAH-MSP FEB 5>2.0[4]
UA IAH-MSY FEB 8>4[8]
UA IAH-MTY FEB 7>2.0[6]
UA IAH-NAS FEB 1.0>0.3[1.0]
UA IAH-NRT FEB 1.0>0[1.0]
UA IAH-OAX FEB 1.0>0[1.0]
UA IAH-OKC FEB 7>4[7]
UA IAH-OMA FEB 4>3[4]
UA IAH-ORD FEB 10>6[9]
UA IAH-ORF FEB 2>0[1.9]
UA IAH-PDX FEB 3>1.0[3]
UA IAH-PHL FEB 5>2.0[5]
UA IAH-PHX FEB 5>3[5]
UA IAH-PIT FEB 6>2.0[6]
UA IAH-PNS FEB 5>3[5]
UA IAH-PTY FEB 3>1.5[3]
UA IAH-PUJ FEB 0.1>0.5[0.1]
UA IAH-PVR FEB 3>2[3]
UA IAH-RDU FEB 4>2[4]
UA IAH-RIC FEB 3>0[3]
UA IAH-RSW FEB 3>1.9[3]
UA IAH-SAN FEB 5>3[5]
UA IAH-SAP FEB 3>2[3]
UA IAH-SAT FEB 7>4[7]
UA IAH-SCL FEB 1.0>0.4[1.0]
UA IAH-SDF FEB 4>1.0[4]
UA IAH-SEA FEB 5>1.0[5]
UA IAH-SFO FEB 9>5[8]
UA IAH-SGF FEB 2>0[1.9]
UA IAH-SHV FEB 4>1.7[4]
UA IAH-SJC FEB 2>1.0[1.9]
UA IAH-SJO FEB 3>1.6[3]
UA IAH-SJU FEB 3.0>1.7[2.9]
UA IAH-SMF FEB 3>2.0[3]
UA IAH-SNA FEB 4>1.9[4]
**UA IAH-SRQ FEB 0>0.6[0] MAR 0>1.0[0] APR 0>1.0[0.0] MAY 0>1.0[0] JUN 0>1.0[0] JUL 0>1.0[0] AUG 0>1.0[0] SEP 0>1.0[0]
UA IAH-STL FEB 5>3[4]
UA IAH-TGU FEB 1.4>2[1.3]
UA IAH-TPA FEB 5>4[5]
UA IAH-TUL FEB 7>3[6]
UA IAH-TUS FEB 3>1.6[3]
UA IAH-TYS FEB 4>3[4]
UA IAH-XNA FEB 5>3[5]
UA IAH-ZIH FEB 0.6>0.9[0.6]
UA ICT-ORD FEB 4>1.9[4]
UA ILM-ORD FEB 2>0[1.9]
UA IND-ORD FEB 10>2[10]
UA IND-SFO FEB 1.9>0[1.8]
UA ITO-LAX FEB 0.7>0[0.7]
UA JAC-SFO FEB 1.6>0.9[1.6]
UA JAN-ORD FEB 1.0>0[1.0]
UA JAX-ORD FEB 3>1.7[3]
UA KOA-LAX FEB 1.6>0.6[1.5]
UA KOA-SFO FEB 3>2[3]
UA LAN-ORD FEB 3>1.0[3]
UA LAS-LAX FEB 5>2[5]
UA LAS-ORD FEB 5>3[5]
UA LAS-SFO FEB 8>3[8]
UA LAX-LIH FEB 0.9>0.6[0.9]
UA LAX-MFR FEB 2.0>0.7[1.9]
UA LAX-MRY FEB 5>0.9[5]
UA LAX-MSN FEB 1.0>0[1.0]
UA LAX-NRT FEB 1.0>0[1.0]
UA LAX-OGG FEB 2>1.0[2]
UA LAX-ORD FEB 10>3[9]
UA LAX-PHX FEB 4>1.5[4]
UA LAX-PVG FEB 1.0>0[1.0]
UA LAX-RDD FEB 1.0>0[1.0]
UA LAX-RNO FEB 3>2[3]
UA LAX-SAN FEB 4>1.4[4]
UA LAX-SAT FEB 1.9>0[1.8]
UA LAX-SBA FEB 3>0[3]
UA LAX-SBP FEB 3>0[3]
UA LAX-SEA FEB 2>0.5[1.9]
UA LAX-SFO FEB 12>4[12] MAR 12>11[11]
UA LAX-SJO FEB 1.0>0.6[1.0]
UA LAX-SLC FEB 1.9>0.9[1.8]
UA LAX-SMF FEB 3>0.7[3]
UA LAX-SYD FEB 0.4>0.7[0.4]
UA LEX-ORD FEB 4>2[4]
UA LGA-ORD FEB 14>3[13] MAR 13>12[12]
UA LHR-ORD FEB 2>1.0[1.9]
UA LHR-SFO FEB 1.0>0[1.0]
UA LIH-SFO FEB 1.6>1.0[1.5]
UA LIT-ORD FEB 4>1.0[4]
UA LNK-ORD FEB 5>1.9[4]
UA MBJ-ORD FEB 1.1>0.4[1.1]
UA MBS-ORD FEB 3>1.0[3]
UA MCI-ORD FEB 6>3[6]
UA MCI-SFO FEB 2>0[1.9]
UA MCO-ORD FEB 8>3[8]
UA MCO-SFO FEB 3>0.8[3]
**UA MCW-ORD MAR 0>1.7[0] APR 0>1.7[0] MAY 0>1.7[0] JUN 0>1.7[0] JUL 0>1.7[0] AUG 0>1.7[0] SEP 0>1.7[0]
UA MDT-ORD FEB 4>2[3]
UA MEM-ORD FEB 4>2[3]
UA MEX-SFO FEB 2>1.0[1.9]
UA MFR-SFO FEB 4>1.5[4]
UA MIA-ORD FEB 4>1.8[4]
UA MIA-SFO FEB 0.6>0[0.6]
UA MKE-ORD FEB 9>4[8] MAR 8>7[8]
UA MKG-ORD FEB 2>1.6[1.9]
UA MLI-ORD FEB 5>1.4[5]
UA MRY-SFO FEB 2>0[1.9]
UA MSN-ORD FEB 8>1.6[7]
UA MSN-SFO FEB 1.0>0[1.0]
UA MSP-ORD FEB 8>3[8]
UA MSP-SFO FEB 2>0[1.9]
UA MSY-ORD FEB 3>1.8[3]
UA MSY-SFO FEB 1.0>0[1.0]
UA MTY-ORD FEB 2>0.9[1.9]
UA MUC-SFO FEB 0.4>0[0.4]
UA NAS-ORD FEB 1.1>0.4[1.1]
UA OGG-ORD FEB 0.6>0.4[0.6]
UA OGG-SFO FEB 4>3[3]
UA OKC-ORD FEB 4>1.4[4]
UA OKC-SFO FEB 1.0>0[1.0]
UA OMA-ORD FEB 5>3[5]
UA OMA-SFO FEB 1.8>0[1.7]
UA ONT-SFO FEB 5>2[5]
UA ORD-ORF FEB 3>1.9[3]
UA ORD-PBI FEB 3>1.5[3]
UA ORD-PDX FEB 4>0.9[4]
UA ORD-PHL FEB 7>3[6]
UA ORD-PHX FEB 5>2[5]
UA ORD-PIA FEB 5>0.9[5]
UA ORD-PIT FEB 6>2[6]
UA ORD-PNS FEB 1.0>0.6[1.0]
UA ORD-PSC FEB 1.0>0[0.9]
UA ORD-PVD FEB 3>0[3]
UA ORD-PVG FEB 1.0>0[1.0]
UA ORD-PWM FEB 3>0[3]
UA ORD-RAP FEB 2>0[1.9]
UA ORD-RDU FEB 6>2[6]
UA ORD-RIC FEB 6>3[6]
UA ORD-RNO FEB 1.0>0[0.9]
UA ORD-ROA FEB 4>0.9[3]
UA ORD-ROC FEB 4>1.4[4]
UA ORD-RSW FEB 5>3[5]
UA ORD-SAN FEB 5>2[5]
UA ORD-SAT FEB 4>1.8[4]
UA ORD-SAV FEB 3>1.3[3]
UA ORD-SBA FEB 1.0>0[0.9]
UA ORD-SBN FEB 10>2[10] MAR 9>8[5]
UA ORD-SCE FEB 3>0.9[3]
UA ORD-SDF FEB 6>2[6]
UA ORD-SEA FEB 5>0.9[4]
UA ORD-SFO FEB 11>4[11]
UA ORD-SGF FEB 4>1.3[4]
UA ORD-SJC FEB 1.0>0[0.9]
UA ORD-SJO FEB 1.0>0.1[1.0]
UA ORD-SJU FEB 2.0>0.6[1.9]
UA ORD-SLC FEB 3>2[3]
UA ORD-SMF FEB 3>0.9[3]
UA ORD-SNA FEB 3>0.9[3]
UA ORD-SPI FEB 1.9>0.9[1.9]
UA ORD-SRQ FEB 2>1.5[1.9]
UA ORD-STL FEB 9>3[9] MAR 8>7[8]
UA ORD-SXM FEB 0.4>0.1[0.4]
UA ORD-SYR FEB 5>1.9[5]
UA ORD-TLV FEB 0.4>0[0.4]
UA ORD-TPA FEB 5>3[5]
UA ORD-TUL FEB 4>1.0[4]
UA ORD-TVC FEB 4>2[4]
UA ORD-TYS FEB 5>1.1[5]
UA ORD-XNA FEB 5>0.9[5]
UA ORD-YYZ FEB 1.9>1.3[1.9]
UA PDX-SFO FEB 6>2[6]
UA PEK-SFO FEB 1.0>0[1.0]
UA PHL-SFO FEB 1.9>0[1.9]
UA PHX-SFO FEB 4>3[4]
UA PIT-SFO FEB 2>0[1.9]
UA PSC-SFO FEB 2.0>0[1.9]
UA PSP-SFO FEB 5>3[5]
UA PVG-SFO FEB 1.0>0[1.0]
UA RDD-SFO FEB 3>0.8[3]
UA RDM-SFO FEB 4>1.8[4]
UA RDU-SFO FEB 2>0[1.9]
UA RNO-SFO FEB 4>2[4]
UA SAN-SFO FEB 9>3[9]
UA SAT-SFO FEB 1.0>0[1.0]
UA SBA-SFO FEB 7>1.6[7]
UA SBP-SFO FEB 5>1.6[5]
UA SEA-SFO FEB 5>2[5]
UA SFO-SIN FEB 1.0>0[1.0]
UA SFO-SLC FEB 5>3[5]
UA SFO-SMF FEB 5>3[5]
UA SFO-SNA FEB 6>1.9[6]
UA SFO-STL FEB 1.0>0[1.0]
UA SFO-TLV FEB 1.0>0.4[1.0]
UA SFO-TPA FEB 0.6>0[0.6]
UA SFO-TPE FEB 1.0>0.7[1.0]
UA SFO-TUS FEB 4>2[4]
UA SFO-XNA FEB 1.0>0[1.0]
UA SFO-YVR FEB 1.9>0.8[1.9]
UP MIA-NAS FEB 0.6>0.1[0.6] MAR 0.5>0.2[2]
VB CUN-MIA FEB 0>1.0[0] MAR 0>1.0[0]
VB MTY-SAT FEB 0.7>1.0[0.7]
WN HAV-TPA FEB 1.1>0.1[1.1] MAR 1.1>0.2[1.1]
WO AZA-YEG FEB 0.5>0.1[0.5] MAR 0.5>0.1[0.3] APR 0.5>0.1[0.3]
WO LAS-YEG FEB 0.4>0[0.4] MAR 0.5>0.2[0.9] APR 0.5>0.2[1.0]
WO MCO-YYZ FEB 0.5>0[0.5] MAR 0.7>0[0] APR 0.6>0[0]
WO TPA-YYZ FEB 0.2>0[0.2] MAR 0.5>0[0] APR 0.5>0[0]
WS LAS-YEG FEB 0.5>0[0.5] MAR 0.5>0[0.5]
WS LAS-YQR FEB 0.2>0[0.2] MAR 0.2>0[0.3] APR 0.2>0[0.3]
WS LAS-YVR FEB 1.5>0[1.5] MAR 1.7>0[1.7]
WS LAS-YWG FEB 0.2>0[0.2] MAR 0.3>0[0.3] APR 0.3>0.1[0.3]
WS LAS-YXE FEB 0.2>0[0.2] APR 0.2>0[0.3]
WS LAS-YYC FEB 2>0[2] MAR 2>0[3]
WS LAS-YYZ FEB 1.4>0[1.3] MAR 1.6>0[1.6]
WS MCO-YYC FEB 0.9>0[0.8] MAR 0.9>0[0.9] APR 0.8>0[1.0]
X4 GST-JNU MAR 0>1.7[1.9]
Y4 GDL-IAH MAR 1.0>1.3[0.5]
Y4 GDL-LAX MAR 4>5[4]
Y4 IAH-MEX FEB 1.3>0.7[1.2]
Y4 MCO-MEX FEB 0.4>0.1[0.4]
Y4 MEX-MIA FEB 1.4>0.6[1.4]
YR BLD-GCW FEB 0>1.0[0]
Z3 AKN-EGX MAR 0>0.4[0] APR 0>0.4[0] MAY 0>0.3[0.4] SEP 0>0.4[0.7]
Z3 AKN-IGG MAR 0>0.4[0.6] APR 0>0.4[0.7] MAY 0>0.3[0.4] SEP 0>0.4[0.6]
Chasensfo
Re: OAG Changes 1/13/2021:DL Adds SEA-CUN/PVR/SJD,MSP-ESC;UA Adds IAD-ECP/PNS,ORD-FOD/MCW,IAH-SRQ Flights FEB-SEP
Wed Jan 13, 2021 1:29 pm
Interesting looking at jetBlue, is the BOS-MSP route only cancelled for March but operating normally otherwise? Sad to see SJC will go a few months with no service.
AC4500
Wed Jan 13, 2021 1:42 pm
PDX loses JetBlue service too... :(
joeblow10
Wed Jan 13, 2021 1:43 pm
All the Mexico and Caribbean capacity that has been added is going to be wrecked by the new intl entry requirement which is really going to hurt the next few months even more for the airlines. I get the idea of the requirement but how on earth are you expected to get a test in some of these places... they don’t have capacity to test every tourist coming in/out I don’t think (exemptions seem like they’re going to be hard to get)
Also confused why A4A was supposedly in support of such a move. Yes it supposedly makes it “safer” to fly but the economic cost to the airlines is going to be huge
SteveXC500
Wed Jan 13, 2021 2:05 pm
I believe they cease flying 2/11/21 until April. Includes both BOS-MSP and JFK-MSP. There are a couple of other routes that are similar.
enilria
Wed Jan 13, 2021 2:08 pm
Is that all PDX service? G4 just added it!
MIflyer12
Wed Jan 13, 2021 2:12 pm
IMHO, A4A was between a rock and a hard place: border closures or testing requirements. Testing may help the perception of safety and allow (in their own minds) people to travel again. Border closures take the decision to travel away from prospective passengers entirely.
As for all the new Caribbean and Mexico service? Yes, I have to wonder. I don't know if avg fare levels will sustain the routes and frequencies -- but they know they don't need LGA-ORD 15x daily so they're desperate to try something.
jetsetter629
Wed Jan 13, 2021 2:27 pm
As for all the new Caribbean and Mexico services? Yes, I have to wonder. I don't know if avg fare levels will sustain the routes and frequencies -- but they know they don't need LGA-ORD 15x daily so they're desperate to try something.
I agree with both of you. A4A didn't want blanket border closures but the WTCC (World Travel & Tourism Council) has been calling for more testing to allow international travel to slowly open up. Those countries that need the tourists (and their dollars) are mainly Mexico and the DR purposefully took the steps on not requiring COVID tests for entry and they've been the biggest recipients of inbound traffic. Just look at CUN and SJD for example...
I'm a travel advisor on the side and without a doubt this is going to hurt these countries. But on the other hand, resorts will likely promote testing to fulfill the requirement to return home. What happens if you do test positive in country? Do you have to wait the 10 days? This put airlines in a position to be the 'border patrol' - I can see sobbing travelers pleading to get back home
Dominion301
Wed Jan 13, 2021 2:35 pm
The USA is following Canada in that regard. Here in Canada, the Canadian government legally cannot stop anyone from travelling internationally, but if you don’t want to risk getting stuck outside the country, don’t travel outside the country. It’s why Canada has the transborder flying “loophole”. Allowing only the most expensive mode of transborder travel is a large barrier, but not an outright travel ban.
On a separate note, the two new UA routes from ORD I’m guessing are new EAS contracts that Skywest won?
Hey enrilia, thanks as always.
Chuska
Wed Jan 13, 2021 2:50 pm
ABQ looses jetBlue too after Feb 7. Wasn't the new Cares package supposed to prevent this?
Chuska
Wed Jan 13, 2021 2:54 pm
Yes, the two new UA routes, ORD-FOD and MCW, are EAS routes. So glad to see these cities elevate from 3E Caravans to UA* RJ's especially since MCW-ORD is 303 miles and FOD-STL is 343 miles, rather far for Caravans. Although both cities are rather small, they both saw Ozark DC-9s in the early 1980's.
Brickell305
Wed Jan 13, 2021 3:27 pm
I agree. I expect to see significant cuts coming shortly. There may possibly be increases to domestic tourist destinations that somewhat offset this. Unless the local tourism authorities/hotels in the Caribbean/Mexico/Bahamas, etc. set up some means for quick, cheap or free testing, this will be a disaster for their tourism industries.
There will also be people who do not want to risk the possibility of getting COVID while abroad and not being able to return to the US. A disaster for the tourism industry all around.
Dieuwer
Wed Jan 13, 2021 3:34 pm
I can imagine DL having to reconsider adding SEA-CUN/PVR/SJD with the new COVID testing requirements on the return.
Planeboy17
Wed Jan 13, 2021 4:16 pm
These cities have been suspended from 2/11 - 3/31
ABQ
MSP
BTV
PDX
These cities have extended their suspension until 06/10
BUR
BWI
ONT
SJC
ScottB
Wed Jan 13, 2021 4:21 pm
You have to wait until you can get documentation from a healthcare provider stating you have recovered. And yeah, CDC is putting the burden of enforcement on the airlines -- they have to deny boarding if you can't produce the required documentation. I don't think I'd want to risk having to rely on the healthcare system in a country where I don't speak the local language fluently and don't have family to advocate for me.
Dominion301
Wed Jan 13, 2021 4:31 pm
Yeah those are long hauls on a Caravan. Even in the current environment, traffic will probably grow on the RJs.
SANFan
Wed Jan 13, 2021 4:54 pm
I just wanted to point out that the Feb/Mar numbers for AS are a bit confusing because the Feb sked is effective on Feb 11 and March begins on Mar 18. Because of the start dates of those 2 schedules, you have some bleed-over from adjoining schedules that throw off the numbers a bit.
Example:
The first half of February is actually part of the January sked which offers 2x daily flights between SAN & BOI, but on Feb 11, the route is reduced to a single daily r/t (being upgraded to mainline.) Therefore, since about half of Feb is 2 flights and half is 1 flight, the result is showing Feb as 1.3.
Hope this makes sense and helps interpret AS's numbers.
Thanks Enilria for hanging in there waiting to eventually receive your report to share with us. As always, your efforts are much appreciated!
bb
AC4500
Wed Jan 13, 2021 5:10 pm
That's what I thought.... We'll have to see what happens when the dates get closer in.
tphuang
Wed Jan 13, 2021 5:19 pm
I believe there are 5 airports they can suspend services to as part of the original CARES package. I would assume the same stipulations here.
MIflyer12
Wed Jan 13, 2021 5:39 pm
Actually, I would think those among the airports that have strong incentive to offer testing and could scale up pretty well. Some place like PAP, maybe not so much...
dolphinflyer
Wed Jan 13, 2021 5:42 pm
Spirit announces daily nonstop service linking SMF and SNA beginning March 1. Flights now available at spirit.com.
enilria
Wed Jan 13, 2021 5:46 pm
I think A4A has given up fighting. I think a negative test for domestic travel is not out of the question as the next knife in the heart of the aviation and tourism industry. From a political perspective it would also hurt Red States most which is another reason it is not out of the question.
I thought so too, but I guess these markets are too large to be protected???
Your healthcare won't cover you. You can't leave. AND it costs $150-200 out of pocket for each test. This is death to most int'l travel. Also, the 72 hour timeframe is VERY risky in most countries. Even in the USA you often can't get a test within 72 hours reliably.
Example:
bb
Good point on the AS calc. Thanks
I don't think AA is operating on that basis with their station resumptions.
The problem is at $150-200 per test in a foreign country, with no insurance coverage, and all the other risks it's a death knell.
It is against international law to block entry to your own citizens. This will all go to court in a 2 years when it is too late to matter. That's what happened with Spanish Flu and the precedents are all now being ignored. It is going to be a "human rights" nightmare. Imagine if you check out of the hotel, get a positive result, and have nowhere to go for 14 days...what if the country demands you leave?
ContinentalEWR
Wed Jan 13, 2021 5:53 pm
If I am reading it correctly, AA zero'd out YUL/YYZ from JFK. Guessing that's part of the slots (or all four) it is relinquishing?
Trk1
Wed Jan 13, 2021 6:48 pm
This is good news. Should have been done months ago. The COVID problem needs to be solved and vacation trips is not the solution. Selfish. Tome to suck it up
HNLSLCPDX
Wed Jan 13, 2021 6:55 pm
Tome? Tell that to the people who’s livelihoods are reliant on the tourism and travel industry. Get real. It’s not good news. Delusional thinking if you think it’s good news in any form.
Cubsrule
Unless there starts to be some evidence of spread on airplanes (which is pretty much absent so far, although there have been a few recent studies that suggest that tide may be turning), a test requirement for domestic travel would be on very shaky legal ground.
lightsaber
Wed Jan 13, 2021 7:22 pm
Discuss Covid19 testing in non av.
Do not discuss moderation in an open forum.
6 months without TV. The best decision of my life.
ScottB
Wed Jan 13, 2021 8:13 pm
I can already see the stories on the news/internet: College students go to Cancun/D.R. for Spring Break and forget to hold on to enough cash to get a test. Or worse yet they get a positive test and don't have the money to get a room for a couple of weeks and don't have money to get a note from a doctor which lets them travel afterwards (keep in mind that not all national health care systems will treat non-residents without payment). And no money for food either. It's an utter nightmare. I don't see who can travel apart from the very wealthy and the handful of folks who must travel for business and whose employers can absorb the potential costs of testing positive outside the U.S.
I bet they have structured this as making the airlines responsible to deny boarding for exactly this reason. They're not blocking entry since the passenger never reaches the border. But yeah, if it ever goes to court it gets dismissed as being moot because the policy had been rescinded.
One could get around it, I suppose, by flying to TIJ/CJS/REX and walking across the border (this only applies to air passengers) and then getting home from SAN/ELP/MFE but that doesn't really help you if you're in PUJ.
enilria
Wed Jan 13, 2021 8:48 pm
Sure, but this new policy denying entrance of U.S. Citizens is also not legal. I believe they are having the airlines enforce it to attempt to dodge the legality. That is the same trick they would try on domestic.
>>>The right of return is a principle in international law which guarantees everyone's right of voluntary return to, or re-entry to, their country of origin or of citizenship. The right of return is part of the broader human rights concept freedom of movement and is also related to the legal concept of nationality.[1] While many states affords its citizens the right of abode, the right of return is not restricted to citizenship or nationality in the formal sense.[2] It allows stateless persons and for those born outside their country to return for the first time, so long as they have maintained a "genuine and effective link."[2][3]
>>>The right is formulated in several modern treaties and conventions, most notably in the 1948 Universal Declaration of Human Rights, the 1966 International Covenant on Civil and Political Rights and the 1948 Fourth Geneva Convention. Legal scholars have argued that one or more of these international human rights instruments have attained the status of customary international law and that the right of return is therefore binding on non-signatories to these conventions.[4][5]
>>>The right of return is often invoked by representatives of refugee groups to assert that they have a right to return to the country from which they were displaced.
100% agree
I've been saying that as well, just above. Nevertheless it is de facto the same, it just means it becomes more difficult and time-consuming to litigate it because of the way they implemented that. BTW, it takes as long as 3 days to travel from some parts of the world. How is that going to work? Answer: It won't.
Many of these same issues came up in the Spanish Flu and the courts ultimately ruled on the side of the Constitution. Now they are simply ignoring legal precedent knowing that the court process is so long that it is moot.
BOTTOM LINE: We are going to see the demise of probably 75% of current intl service in the next couple of weeks if this change is not weakened. Personally, I think they should change it to only foreign citizens which is perfectly legal, but I don't really think that will happen.
Cubsrule
Wed Jan 13, 2021 9:10 pm
Denying entry would be illegal. Denying boarding isn't. It's no different from saying that I can't fly with a firearm in my carryon.
ScottB
Wed Jan 13, 2021 9:51 pm
Well, denying boarding effectively denies entry for air passengers who may not have another option for reaching the border; i.e. if one is coming from a Caribbean island, there are few, if any, other options at present. I mean, I guess you could try your hand at sailing to the U.S.
Cubsrule
Wed Jan 13, 2021 10:06 pm
That's true, but the existence of an alternative hasn't ever really figured in the body of law we're discussing.
Rajahdhani
Wed Jan 13, 2021 10:35 pm
I understand your point - effectively denying boarding has the other effect of denying entry. However, consider what @cubsrule is saying, and another factor/angle - that that airline may be denying you boarding at that time, but not forever. From the perspective of the carrier, and the government - they are preventing a sick passenger from traveling, and perhaps - at that time. It will be, in most cases (sadly not for all) just temporary.
I'm no DL FanBoy - but consider how well they advertise no change fees for customers, and they ways that they are managing the issues (before the implementation of said programs);
https://www.delta.com/us/en/travel-update-center/overview?id=79992&redtmpid=9&t28=%2Bairline%20%2Bchange%20%2Bfees&t29=459199346365_98535554766&t30=SEzzzGGusaBSWpriBD&t32=_k_EAIaIQobChMI9IeBsvqZ7gIVFYdbCh18oAr_EAAYASAAEgLm4_D_BwE_k_&requesttype=sem.click&clickid=_k_EAIaIQobChMI9IeBsvqZ7gIVFYdbCh18oAr_EAAYASAAEgLm4_D_BwE_k_&gclid=EAIaIQobChMI9IeBsvqZ7gIVFYdbCh18oAr_EAAYASAAEgLm4_D_BwE
What effect does, no change fees - have on capacity and yields? Not every passenger will be rejected, and increasingly, fewer will be. The carriers have the capacity, and getting them back home is not really a matter of cost - if there are no fees for changing that return.
Admittedly, it does not address the other costs - of hotels, food, and hospital costs - if a passenger is found to be Positive prior to travel. That said, I think that placing that much 'blame' (and I use that word lightly, because it may not have been your aim - and we have used the word 'responsibility' above - and understand that it connotes another message/meaning - but could be as a simile for our discussion here) with the airlines - as they can and probably would be happy to re-acomodate for a later date of travel. I admit that there are is a need for greater thoughts to what will happen in each case, and further - in macro issues - and see that increasingly, that burden will be put upon embassies and consulates in the nations of travel to better advocate for their respective citizens, and I can admit that those are currently overburdened by the current pandemic and regular issues while in it - with limited abilities to 'return home'.
Rajahdhani
Wed Jan 13, 2021 11:01 pm
As a general question - is the policy, too early?
Whether we believe the efficacy of the vaccines and how they will be adopted, some nations, or areas - may be able to achieve high levels of citizens/populations with high vaccination rates. Just as an example, some Caribbean nations will be able to achieve fully immunized (or, as full as possible to be categorized in the medial/scientific/political term necessary) to mean that travel, and increasingly - some activities can resume. Travel to some of these nations, might prove more 'safe'. In that reality - I can see that the 'Positive' cases would be lesser and lesser over time. I get that, in that reality - where more of us are vaccinated - that the positive results (and effect that we see of them) are lessened - if so - these procedures seem like a decent response to that - where lesser and lesser cases in future. It does not fit the first part of the idea, though, at least not well - and could be damaging, as predicted in how much international traffic will be viable. If so, what sort of policies or procedures should airlines, governments (and increasingly - what are the smart solutions that can help minimize these pains, waits et al) should be adopted, or could be adopted (and perhaps even play within the context or framework of these rules)?
Case in point - as I mentioned above -a lack of change fees will definitely sit well with a passenger, who can be told - in the moment of panic,
"Don't worry, we will get you home,". Based on DL's site, though - those no change fees are only in effect until March 30, 2021. What next? It seems that baring a policy change (in effect, specifically in the event of a positive result, and resultant denied boarding - no change fees for future travel out), many of those international services are going to be - as you described. I thank you for this thread so much, Enilria - but hope that you're not right...
You're expertise and experience has proven invaluable in the past. Looking at it from this perspective - and based on the issues that we are unpacking - it really does present a rather large issue with knock on effect that are not perhaps best considered for this particular issue.
As an aside - how do/did most airlines handle passengers who were not medically fit to fly, in past? I am sure that they are many procedures and policies, as many as they are airlines - but with as much intelligences that we have here - who had the best (or a notably sound policy that could be applied here)?
Miamiairport
Wed Jan 13, 2021 11:23 pm
I believe that if people think they can't get home (whether they can in reality or not) because they take a COVID test before flight and test positive that's going to dampen International travel. No one wants to be stuck in a foreign country unable to get home for 14 days. Particularly when they a. feel perfectly fine b. the unreliability of tests. I know I certainly won't be taking an International trips.
hpff
Wed Jan 13, 2021 11:52 pm
Of course it's legal under the right of return law. The US isn't telling citizens they're barred from ever coming back to the U.S. (the point of the law - you can't exile your own citizens), they're just requiring a COVID test in order to enter the country again. The US isn't the first country to require this sort of restriction, either. (If you're saying it's illegal for another reason, I apologise, but I'm not sure which.)
The UK isn't allowing anyone to travel abroad without a proper reason at the moment so I can't make a direct comparison but I agree this clearly won't be good for short term international travel.
Brickell305
Thu Jan 14, 2021 1:10 am
Exactly. It’s illegal to prevent a US citizen from entering the country once they present themselves at the border. It’s not illegal to prevent someone from boarding a flight before they get to the border.
lightsaber
Thu Jan 14, 2021 2:34 am
Thread has gone off topic.
